[Mapbender-users] How to increase the search radius of objects data search
Viacheslav Golovastikov
v.golovastikov at gmail.com
Tue Sep 27 06:09:41 PDT 2022
Astrid. Another question. Where are output templates stored FeatureInfo
вт, 27 сент. 2022 г. в 14:54, Viacheslav Golovastikov <
v.golovastikov at gmail.com>:
> Astrid. I figured out how to increase the search radius. You need to add
> the "buffer" parameter in Vendor Specific Parameter , for example 15. By
> default, 5 is used
> вт, 27 сент. 2022 г. в 12:18, Viacheslav Golovastikov <
>> Astrid. I am using Geoserver 2.21.1
>> вт, 27 сент. 2022 г. в 12:14, Astrid Emde (WhereGroup) <
>> astrid.emde at wheregroup.com>:
>>> Hello Viacheslav,
>>> what server to do you use? MapServer, QGIS Server, GeoServer for your
>>> WMS?
>>> As I understand your question is about the tolerance for featureinfos
>>> requests. Is that right?
>>> Am 2022-09-27 11:05, schrieb Viacheslav Golovastikov:
>>> > I would like to increase the radius of the object data search. In the
>>> > properties of the layer I see there is a Vendor Specific Parameter.
>>> > But it is passed in the GetMap request. And the GetFeatureInfo request
>>> > is not passed. What needs to be done and how to solve this
>>> > _______________________________________________
>>> > Mapbender_users mailing list
>>> > Mapbender_users at lists.osgeo.org
>>> > https://lists.osgeo.org/mailman/listinfo/mapbender_users
>>> Mit freundlichen Grüßen
>>> Astrid Emde
>>> GIS-Consultant
>>> Aufwind durch Wissen!
>>> Jetzt neu: Web-Seminare und Online-Schulungen
>>> bei der www.foss-academy.com
>>> Astrid Emde
>>> WhereGroup GmbH
>>> Eifelstraße 7
>>> 53119 Bonn
>>> Germany
>>> Tel: +49(0)228 90 90 38 - 22
>>> Fax: +49(0)228 90 90 38 - 11
>>> www.wheregroup.com
>>> Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
>>> https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
>>> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>>> Folgen Sie der WhereGroup auf twitter:
>>> http://twitter.com/WhereGroup_com
>>> Geschäftsführer:
>>> Olaf Knopp, Peter Stamm
>>> Amtsgericht Bonn, HRB 9885
>>> -------------------------------_______________________________________________
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220927/1817a2cb/attachment.htm>
More information about the Mapbender_users
