[Mapbender-users] How to increase the search radius of objects data search
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Tue Sep 27 06:27:14 PDT 2022
Hello,
your questions are GeoServer connected.
Template Styling is done via Freemarker Templates- see
https://docs.geoserver.org/latest/en/user/tutorials/GetFeatureInfo/html.html
FeatureInfo Tolerance
https://docs.geoserver.org/latest/en/user/services/wms/vendor.html#buffer
https://gis.stackexchange.com/questions/257794/getgetfeatureinfourl-hit-detection-tolerance
The buffer should be part of the getcapabiltilies request-. Like that
Mapbender will use it.
You could define a vendor specific in Mapbender for the WMS instance to
set the tolerance for FeatureInfo.
Astrid
Am 2022-09-27 15:09, schrieb Viacheslav Golovastikov:
> Astrid. Another question. Where are output templates stored
> FeatureInfo
> вт, 27 сент. 2022 г. в 14:54, Viacheslav Golovastikov
> <v.golovastikov at gmail.com>:
>> Astrid. I figured out how to increase the search radius. You need to
>> add the "buffer" parameter in Vendor Specific Parameter , for
>> example 15. By default, 5 is used
>> вт, 27 сент. 2022 г. в 12:18, Viacheslav Golovastikov
>> Astrid. I am using Geoserver 2.21.1
>> вт, 27 сент. 2022 г. в 12:14, Astrid Emde (WhereGroup)
>> <astrid.emde at wheregroup.com>:
>> Hello Viacheslav,
>> what server to do you use? MapServer, QGIS Server, GeoServer for
>> your
>> WMS?
>> As I understand your question is about the tolerance for
>> featureinfos
>> requests. Is that right?
>> Am 2022-09-27 11:05, schrieb Viacheslav Golovastikov:
>>> I would like to increase the radius of the object data search. In
>> the
>>> properties of the layer I see there is a Vendor Specific
>> Parameter.
>>> But it is passed in the GetMap request. And the GetFeatureInfo
>> request
>>> is not passed. What needs to be done and how to solve this
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Mit freundlichen Grüßen
>> Astrid Emde
>> GIS-Consultant
>> Aufwind durch Wissen!
>> Jetzt neu: Web-Seminare und Online-Schulungen
>> bei der www.foss-academy.com [1]
>> Astrid Emde
>> WhereGroup GmbH
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> Tel: +49(0)228 90 90 38 - 22
>> Fax: +49(0)228 90 90 38 - 11
>> www.wheregroup.com [2]
>> Meinen PGP Public-Key können Sie unter pgp.mit.edu [3]
>> herunterladen:
> https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
>> Signierte und/oder verschlüsselte Nachrichten sind sehr
>> willkommen
>> Folgen Sie der WhereGroup auf twitter:
>> http://twitter.com/WhereGroup_com
>> Geschäftsführer:
>> Olaf Knopp, Peter Stamm
>> Amtsgericht Bonn, HRB 9885
> -------------------------------_______________________________________________
> Links:
> [1] http://www.foss-academy.com
> [2] http://www.wheregroup.com
> [3] http://pgp.mit.edu
Astrid Emde
GIS-Consultant
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   www.wheregroup.com
   Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
   Geschäftsführer:
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220927/1270c5b7/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20220927/1270c5b7/attachment.sig>
More information about the Mapbender_users mailing list
