[Mapbender-users] Tips or recommendations on how to enable time support properly
Marcin Niemyjski mniemyjski at cloudferro.com
Wed Jun 21 01:32:20 PDT 2023
Hello,
Do you have any tips or recommendations on how to enable time support properly?
Recently, I created a WMS-T serving time range of Sentinel-1 data. I attempted to apply it to Mapbender following the instructions provided in this link: https://doc.mapbender.org/en/functions/misc/dimensions_handler.html.
You can verify it by visiting https://www.eo4ua.org. The WMS-T layer is the first layer named Sentinel-1 IW_GRDH_1S. However, as you can see, the time slider does not function correctly.
https://pasteboard.co/iJgdTOaubFG6.png
How did I define it?
I activated the time dimension checkbox (the values within it cannot be edited).
https://pasteboard.co/UNuoo2zcX1Ua.png
Then, I moved to Layouts, and in the Layer tree, I also checked Dimension. According to the instructions, it should work.
https://pasteboard.co/xMrCets3vLxN.png
The time slider (kind of) appears, as you can see, but it cannot be moved even after clicking the checkbox.
Next, I tried to add the timeslider to the context menu as a Dimension handler.
https://pasteboard.co/6GrIJM3SBooA.png
As you can see, there is only one group available, and the Extent tab is not editable.
I'm also attaching the GetCapabilities URL to my S1 WMS-T:
http://64.225.135.141.nip.io/?map=/etc/mapserver/S1-PT.map&version=1.3.0&service=wms&request=Getcapabilities
Huge thank you to everyone for help 🙂
Marcin
[cid:a79cc361-f5f6-45dd-9d1c-a5ab458e757d]<https://outlook.office.com/bookwithme/user/6347c7def05a478ba013ae948648789d@cloudferro.com?anonymous&ep=signature>           Book time to meet with me<https://outlook.office.com/bookwithme/user/6347c7def05a478ba013ae948648789d@cloudferro.com?anonymous&ep=signature>
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20230621/bf1c66ef/attachment.htm>
Type: image/png
Desc: Outlook-pwpdhx0x.png
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20230621/bf1c66ef/attachment.png>
More information about the Mapbender_users mailing list
