[Mapbender-users] Tips or recommendations on how to enable time support properly
Thorsten Hack (WhereGroup)
thorsten.hack at wheregroup.com
Mon Jun 26 05:01:17 PDT 2023
Hello Marcin,
thank you for your question.
It looks like your WMS service does not follow the required syntax for
listing dimensional values.
The specification can be found at
https://portal.ogc.org/files/?artifact_id=1081&format=pdf in Table C.1
(page 59/ PDF page 71).
The available values can be listed either by a comma-separated list
(which mapbender does not support yet), or by the syntax
min/max/resolution. Your WMS however responds by
<Dimension name="time" units="ISO8601" default="2023-05-01"
nearestValue="0">2023-05-01/2023-05-05</Dimension>
missing the resolution parameter. If you have daily resolution, change
the value to 2023-05-01/2023-05-05/P1D. If you have only the two
available dates, use 2023-05-01/2023-05-05/P5D instead.
Then, remove your layerset instance, update your data source in the tab
"Data Source" and re-add a layerset instance to your application.
Good luck!
Best regards,
Thorsten Hack
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei derwww.foss-academy.com/
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Tel.: +49 (0)761 / 519 102 - 67
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Am 21.06.23 um 10:32 schrieb Marcin Niemyjski:
> Hello,
> Do you have any tips or recommendations on how to enable time support
> properly?
> Recently, I created a WMS-T serving time range of Sentinel-1 data. I
> attempted to apply it to Mapbender following the instructions provided
> in this link:
> https://doc.mapbender.org/en/functions/misc/dimensions_handler.html
> <https://doc.mapbender.org/en/functions/misc/dimensions_handler.html>.
> You can verify it by visiting https://www.eo4ua.org
> <https://www.eo4ua.org>. The WMS-T layer is the first layer named
> Sentinel-1 IW_GRDH_1S. However, as you can see, the time slider does
> not function correctly.
> https://pasteboard.co/iJgdTOaubFG6.png
> How did I define it?
> I activated the time dimension checkbox (the values within it cannot
> be edited).
> https://pasteboard.co/UNuoo2zcX1Ua.png
> Then, I moved to Layouts, and in the Layer tree, I also checked
> Dimension. According to the instructions, it should work.
> https://pasteboard.co/xMrCets3vLxN.png
> The time slider (kind of) appears, as you can see, but it cannot be
> moved even after clicking the checkbox.
> Next, I tried to add the timeslider to the context menu as a Dimension
> handler.
> https://pasteboard.co/6GrIJM3SBooA.png
> As you can see, there is only one group available, and the Extent tab
> is not editable.
> I'm also attaching the GetCapabilities URL to my S1 WMS-T:
> http://64.225.135.141.nip.io/?map=/etc/mapserver/S1-PT.map&version=1.3.0&service=wms&request=Getcapabilities
> <http://64.225.135.141.nip.io/?map=/etc/mapserver/S1-PT.map&version=1.3.0&service=wms&request=Getcapabilities>
> Huge thank you to everyone for help 🙂
> Marcin
> <https://outlook.office.com/bookwithme/user/6347c7def05a478ba013ae948648789d@cloudferro.com?anonymous&ep=signature>
> Book time to meet with me
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20230626/c3522fff/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20230626/c3522fff/attachment.png>
More information about the Mapbender_users
