[Mapbender-users] Filtering and searching
    Astrid Emde (WhereGroup)
    astrid.emde at wheregroup.com
    Wed Mar 22 04:17:24 PDT 2023
Hello Tjiko,
Am 2023-03-22 11:21, schrieb Tjiko Schutte:
> Hi,
> Hope some can help. I have configured the search module. But I'm not
> sure how to implement the query.
> For example if you have the url
> /items?f=json&limit=10&filter=adres%3D%27HEREISTHEADRES%27&.
> How can i Put HEREISTHEADRES in the query? When I put q there. It
> doesnt do anything
This is not possible yet. maybe Mapbender has to learn more about OGC
API Feature Services in the future to handle complex questions.
> A seperate question.
> Is filtering also possible. For example I have a map with 9000 points.
> 3000 have value A, 3000 value B and 3000 value C.
> Can I filter (not search) the map on only value B.
> So the points on the map will be reduced to 3000 (and not 9000).
When you have a WMS with all this points you could configure Vendor
specific for your instnace. Go to the Application -> Layerset ->
Service-Instance
See
https://doc.mapbender.org/en/functions/backend/layerset.html#vendor-specific-parameter
In the vendor specific section you can define the filter. This is only
possible in the backend yet. Maybe in future version a configuration in
the clinet would be nice. If you like to support the development you are
welcome.
Hope the answer helps
Astrid Emde
> Thanks in advance.
> Kind regards,
> Tjiko Schutte
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
WhereGroup-Blog
https://wheregroup.com/blog/
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Tel: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
   Folgen Sie der WhereGroup auf twitter:
   http://twitter.com/WhereGroup_com
   Geschäftsführer:
   Olaf Knopp, Peter Stamm
   Amtsgericht Bonn, HRB 9885
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20230322/68d02063/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20230322/68d02063/attachment.sig>
More information about the Mapbender_users
