[mapguide-commits] r1130 - in trunk/MgDev:
Common/MapGuideCommon/System Server/src/Core
Server/src/Gws/GwsCommon Server/src/Gws/GwsQueryEngine
Server/src/Gws/GwsQueryEngine/inc Server/src/Gws/GwsResource
Server/src/Gws/Include Server/src/Services/Feature
svn_mapguide at osgeo.org
Thu Feb 22 19:41:59 EST 2007
Author: brucedechant
Date: 2007-02-22 19:41:58 -0500 (Thu, 22 Feb 2007)
New Revision: 1130
Added:
trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsBatchSortedBlockJoinQueryResults.cpp
trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightBatchSortedBlockJoinQueryResults.cpp
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
trunk/MgDev/Server/src/Core/serverconfig.ini
trunk/MgDev/Server/src/Gws/GwsCommon/GwsResourceUtil.cpp
trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureSourceQuery.cpp
trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsPreparedFeatureQuery.cpp
trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsPreparedJoinQuery.cpp
trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsQueryEngine.vcproj
trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightJoinQueryResults.cpp
trunk/MgDev/Server/src/Gws/GwsQueryEngine/Makefile.am
trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsQuery.h
trunk/MgDev/Server/src/Gws/GwsResource/GwsResource.h
trunk/MgDev/Server/src/Gws/GwsResource/GwsResource.rc
trunk/MgDev/Server/src/Gws/Include/GwsCommon.h
trunk/MgDev/Server/src/Services/Feature/Makefile.am
trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.vcproj
trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp
trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h
Add an optimized join query algorithm to the server that is significantly faster then the default brute force algorithm. This optimized algorithm is only used when the primary is unordered and the secondary is ordered.
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2007-02-23 00:41:58 UTC (rev 1130)
@@ -55,6 +55,9 @@
#define MG_CONFIG_MIN_TIMER_INTERVAL 1
#define MG_CONFIG_MAX_TIMER_INTERVAL MG_CONFIG_MAX_INT32
+#define MG_CONFIG_MIN_JOIN_QUERY_BATCH_SIZE 1
+#define MG_CONFIG_MAX_JOIN_QUERY_BATCH_SIZE 1024
/// Length ranges of string properties
@@ -239,6 +242,8 @@
const INT32 MgConfigProperties::DefaultFeatureServicePropertyDataConnectionTimeout = 600;
const STRING MgConfigProperties::FeatureServicePropertyDataConnectionTimerInterval = L"DataConnectionTimerInterval";
const INT32 MgConfigProperties::DefaultFeatureServicePropertyDataConnectionTimerInterval = 60;
+const STRING MgConfigProperties::FeatureServicePropertyJoinQueryBatchSize = L"JoinQueryBatchSize";
+const INT32 MgConfigProperties::DefaultFeatureServicePropertyJoinQueryBatchSize = 100;
// Mapping Service Properties
@@ -507,6 +512,7 @@
{ MgConfigProperties::FeatureServicePropertyDataConnectionPoolSize , MgPropertyType::Int32 , MG_CONFIG_MIN_CONNECTION_POOL_SIZE , MG_CONFIG_MAX_CONNECTION_POOL_SIZE , L"" },
{ MgConfigProperties::FeatureServicePropertyDataConnectionTimeout , MgPropertyType::Int32 , MG_CONFIG_MIN_TIMEOUT , MG_CONFIG_MAX_TIMEOUT , L"" },
{ MgConfigProperties::FeatureServicePropertyDataConnectionTimerInterval , MgPropertyType::Int32 , MG_CONFIG_MIN_TIMER_INTERVAL , MG_CONFIG_MAX_TIMER_INTERVAL , L"" },
+ { MgConfigProperties::FeatureServicePropertyJoinQueryBatchSize , MgPropertyType::Int32 , MG_CONFIG_MIN_JOIN_QUERY_BATCH_SIZE , MG_CONFIG_MAX_JOIN_QUERY_BATCH_SIZE , L"" },
{ L"" , 0 , 0.0 , 0.0 , L"" }
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2007-02-23 00:41:58 UTC (rev 1130)
@@ -291,6 +291,10 @@
static const STRING FeatureServicePropertyDataConnectionTimerInterval; /// value("DataConnectionTimerInterval")
static const INT32 DefaultFeatureServicePropertyDataConnectionTimerInterval;/// value(60)
+ /// Sets the batch size used by the join query algorithm
+ static const STRING FeatureServicePropertyJoinQueryBatchSize; /// value("JoinQueryBatchSize")
+ static const INT32 DefaultFeatureServicePropertyJoinQueryBatchSize; /// value(100)
/// MAPPING SERVICE PROPERTIES SECTION -------------------------------------------------------------------------------
/// Mapping Service properties
Modified: trunk/MgDev/Server/src/Core/serverconfig.ini
--- trunk/MgDev/Server/src/Core/serverconfig.ini 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Server/src/Core/serverconfig.ini 2007-02-23 00:41:58 UTC (rev 1130)
@@ -242,6 +242,8 @@
# DataConnectionTimerInterval Time interval in seconds for when the server
# checks for idle connections
# 0 < Value <= 2147483647
+# JoinQueryBatchSize Join query batch size
+# 1 < Value <= 1024
CacheSize = 100
CacheTimeLimit = 86400
@@ -252,6 +254,7 @@
DataConnectionPoolSize = 20
+JoinQueryBatchSize = 100
[MappingServiceProperties]
Modified: trunk/MgDev/Server/src/Gws/GwsCommon/GwsResourceUtil.cpp
--- trunk/MgDev/Server/src/Gws/GwsCommon/GwsResourceUtil.cpp 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Server/src/Gws/GwsCommon/GwsResourceUtil.cpp 2007-02-23 00:41:58 UTC (rev 1130)
@@ -270,6 +270,7 @@
GET_STR (eGwsNoLayers, str);
GET_STR (eGwsFeatureSourceIsReadOnly, str);
GET_STR (eGwsFeatureClassHasNoIdentity, str);
+ GET_STR (eGwsFdoInvalidDataType, str);
default:
str = L"GWS message resource id is not defined.";
break;
Added: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsBatchSortedBlockJoinQueryResults.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsBatchSortedBlockJoinQueryResults.cpp (rev 0)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsBatchSortedBlockJoinQueryResults.cpp 2007-02-23 00:41:58 UTC (rev 1130)
@@ -0,0 +1,1264 @@
+// Copyright (C) 2004-2007 Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+// Includes
+#include "stdafx.h"
+#include "GwsQueryEngineImp.h"
+#include "GwsBinaryFeatureWriter.h"
+// This setting limits the batch size used by the join algorithm
+#ifdef _DEBUG_BATCHSORT_JOIN
+int CGwsBatchSortedBlockJoinQueryResults::sm_nBatchSize = 5; // Default
+#else
+int CGwsBatchSortedBlockJoinQueryResults::sm_nBatchSize = 100; //Default
+#endif
+// class CGwsBatchSortedBlockJoinQueryResults
+CGwsBatchSortedBlockJoinQueryResults::CGwsBatchSortedBlockJoinQueryResults (
+ m_right = NULL;
+ m_primaryFeatureIterator = NULL;
+ m_pPrimaryCacheIterator = m_pPrimaryCache.begin();
+CGwsBatchSortedBlockJoinQueryResults::~CGwsBatchSortedBlockJoinQueryResults (
+) throw()
+ #ifdef _DEBUG_BATCHSORT_JOIN
+ printf("CGwsBatchSortedBlockJoinQueryResults::~CGwsBatchSortedBlockJoinQueryResults()\n");
+ #endif
+ ClearIteratorCache();
+ for ( size_t i=0;i<m_propertyDescriptionCollection.size();i++ )
+ CGwsPropertyDesc* propDesc = m_propertyDescriptionCollection[i];
+ delete propDesc;
+ m_propertyDescriptionCollection.clear();
+ if (m_primaryFeatureIterator != NULL)
+ m_primaryFeatureIterator->Release ();
+EGwsStatus CGwsBatchSortedBlockJoinQueryResults::InitializeReader (
+ IGWSQuery * query,
+ CGwsPreparedJoinQuery * prepquery,
+ bool bScrollable
+ printf("CGwsBatchSortedBlockJoinQueryResults::InitializeReader() - Start\n");
+ #endif
+ EGwsStatus stat = eGwsOk;
+ CGwsPreparedQuery * leftquery = prepquery->LeftQuery ();
+ CGwsPreparedQuery * rightquery = prepquery->RightQuery ();
+ FdoPtr<FdoStringCollection> leftcols = prepquery->LeftProperties ();
+ FdoPtr<FdoStringCollection> rightcols = prepquery->RightProperties ();
+ FdoPtr<FdoFilter> lqFilter = leftquery->GetFilter();
+ FdoPtr<FdoFilter> rqFilter = rightquery->GetFilter();
+ FdoStringP lqFilterStr = lqFilter ? lqFilter->ToString() : NULL;
+ FdoStringP rqFilterStr = rqFilter ? rqFilter->ToString() : NULL;
+ printf(" Left Query Filter: %S\n", lqFilterStr);
+ printf(" Right Query Filter: %S\n", rqFilterStr);
+ printf(" Left Query Properties: %S\n", leftcols ? leftcols->ToString() : L"<null>");
+ printf(" Right Query Properties: %S\n", rightcols ? rightcols->ToString() : L"<null>");
+ #endif
+ stat = CGwsJoinQueryResults::InitializeReader (leftcols, query, leftquery, bScrollable);
+ if (IGWSException::IsError (stat)) {
+ PushStatus (stat);
+ return stat;
+ IGWSFeatureIterator * primaryFeatureIterator = NULL;
+ stat = leftquery->Execute (& primaryFeatureIterator, bScrollable);
+ delete primaryFeatureIterator;
+ else
+ m_primaryFeatureIterator = primaryFeatureIterator;
+ m_prepquery = prepquery;
+ CGwsRightJoinQueryResults * results =
+ (CGwsRightJoinQueryResults *) rightquery->CreateFeatureIterator (eGwsRightBatchSortedBlockIterator);
+ stat = results->InitializeReader (query, rightquery, rightcols, bScrollable);
+ delete results;
+ } else {
+ m_right = results;
+ m_right->AddRef ();
+ // Get the feature description so that we can get the primary property names
+ FdoPtr<IGWSExtendedFeatureDescription> featDsc;
+ DescribeFeature (&featDsc);
+ m_propertyNames = featDsc->PropertyNames();
+ // Set the size of the property collection cache
+ m_propertyDescriptionCollection.resize(m_propertyNames->GetCount());
+ for(int j=0;j<m_propertyNames->GetCount();j++)
+ FdoString* propertyName = m_propertyNames->GetString(j);
+ const CGwsPropertyDesc propertyDesc = GetPropertyDescriptor(propertyName);
+ CGwsPropertyDesc* pPropertyDesc = new CGwsPropertyDesc(propertyDesc);
+ if(pPropertyDesc)
+ m_propertyDescriptionCollection[j] = pPropertyDesc;
+ printf("CGwsBatchSortedBlockJoinQueryResults::InitializeReader() - End\n");
+ #endif
+ return stat;
+bool CGwsBatchSortedBlockJoinQueryResults::ReadNext ()
+ printf("CGwsBatchSortedBlockJoinQueryResults::ReadNext()\n");
+ #endif
+ if(m_pPrimaryCache.size() > 0)
+ m_pPrimaryCacheIterator++;
+ if(m_pPrimaryCacheIterator == m_pPrimaryCache.end())
+ m_bLeftJoinValuesSet = false;
+ // Read the left side
+ bool bRes = CGwsFeatureIterator::ReadNext ();
+ // Read the right side
+ bRes = SetupBatchRightSide(bRes);
+ return bRes;
+IGWSFeatureIterator * CGwsBatchSortedBlockJoinQueryResults::GetJoinedFeatures (int iJoin)
+ printf(" CGwsBatchSortedBlockJoinQueryResults::GetJoinedFeatures(%d)\n", iJoin);
+ #endif
+ // check join feature index
+ FdoPtr<IGWSExtendedFeatureDescription> fdsc;
+ DescribeFeature (& fdsc);
+ if (iJoin >= fdsc->GetCount ())
+ GWS_THROW (eGwsIndexOutOfBounds);
+ if (iJoin < m_prepquery->GetPathLength () - 1) {
+ if (m_prepquery->QueryType () == eGwsQueryLeftOuterJoin ||
+ m_prepquery->QueryType () == eGwsQueryEqualJoin)
+ CGwsJoinQueryResults * jqr = dynamic_cast<CGwsJoinQueryResults*> (m_reader.p);
+ assert (jqr);
+ return jqr->GetJoinedFeatures (iJoin);
+ return GetJoinedFeatures ();
+IGWSFeatureIterator * CGwsBatchSortedBlockJoinQueryResults::GetJoinedFeatures ()
+ printf(" CGwsBatchSortedBlockJoinQueryResults::GetJoinedFeatures()\n");
+ #endif
+ // Only update the ride side when needed
+ if(!m_bLeftJoinValuesSet)
+ GetJoinValues ();
+ assert (m_bLeftJoinValuesSet);
+ stat = m_right->SetRelatedValues (m_leftJoinVals);
+ CopyStatus (* m_right); // TODO: candidate for exception throwing
+ return NULL;
+ return m_right;
+bool CGwsBatchSortedBlockJoinQueryResults::SetupBatchRightSide(bool bRes) {
+ printf(" CGwsBatchSortedBlockJoinQueryResults::SetupBatchRightSide()\n");
+ #endif
+ if (m_prepquery->QueryType () == eGwsQueryLeftOuterJoin) {
+ return bRes;
+ } else {
+ while (bRes) {
+ FdoPtr<IGWSFeatureIterator> riter = GetJoinedFeatures ();
+ if (riter->ReadNext ()) {
+ break;
+ bRes = CGwsFeatureIterator::ReadNext ();
+ return bRes;
+FdoDataValueCollection * CGwsBatchSortedBlockJoinQueryResults::GetJoinValues ()
+ printf(" CGwsBatchSortedBlockJoinQueryResults::GetJoinValues()\n");
+ #endif
+ if (! m_bLeftJoinValuesSet)
+ // Clear the cache
+ // Populate the primary iterator cache
+ for(int i=0;i<sm_nBatchSize;i++)
+ if(m_primaryFeatureIterator->ReadNext())
+ PrimaryCacheEntry* cacheEntry = new PrimaryCacheEntry();
+ if(cacheEntry)
+ // Need to cache all primary properties as we walk the primary iterator
+ cacheEntry->propertyCollection.resize(m_propertyNames->GetCount());
+ PropertyCacheEntry* propertyCacheEntry = new PropertyCacheEntry();
+ if(propertyCacheEntry)
+ printf("%S - ", propertyName);
+ #endif
+ CGwsPropertyDesc* propertyDesc = m_propertyDescriptionCollection[j];
+ if(FdoPropertyType_GeometricProperty == propertyDesc->m_ptype)
+ // This is a geometry property
+ FdoByteArray* geometry = m_primaryFeatureIterator->GetGeometry(propertyName);
+ printf("<Geometry>\n");
+ #endif
+ propertyCacheEntry->geometry = geometry;
+ else
+ // This is a data property
+ FdoDataValue* dataValue = m_primaryFeatureIterator->GetDataValue(propertyName);
+ FdoStringP value = dataValue->ToString();
+ printf("%S\n", value);
+ #endif
+ // Is this the primary key?
+ if(wcscmp(propertyName, m_leftcols->GetString(0)) == 0)
+ dataValue->AddRef();
+ cacheEntry->primaryKey = dataValue;
+ propertyCacheEntry->dataValue = dataValue;
+ cacheEntry->propertyCollection[j] = propertyCacheEntry;
+ // Add the iterator cache entry
+ m_pPrimaryCache.push_back(cacheEntry);
+ else
+ // No more keys
+ break;
+ // Sort the cache if needed
+ if(m_pPrimaryCache.size() > 1)
+ QuickSort(m_pPrimaryCache, 0, (FdoInt32)(m_pPrimaryCache.size()-1));
+ // Set the 1st cache entry to read
+ FdoPtr<FdoDataValueCollection> dvcol = NULL;
+ for ( size_t i=0;i<m_pPrimaryCache.size();i++ )
+ FdoPtr<FdoDataValue> val = NULL;
+ PrimaryCacheEntry* cacheEntry = m_pPrimaryCache.at(i);
+ if(cacheEntry)
+ FdoPtr<FdoDataValue> primary = cacheEntry->primaryKey;
+ FdoDataType dtPrimary = primary->GetDataType();
+ // We need to match primary data type to secondary join data type
+ FdoDataType dtSecondary = dtPrimary;
+ if (m_right)
+ FdoPtr<FdoStringCollection> joinColumns = m_right->GetJoinColumns();
+ FdoString* propname = joinColumns->GetString (0);
+ CGwsPropertyDesc propDesc = m_right->GetPropertyDescriptor(propname);
+ dtSecondary = propDesc.m_dataprop;
+ switch (dtPrimary)
+ case FdoDataType_Byte:
+ case FdoDataType_Int16:
+ case FdoDataType_Int32:
+ case FdoDataType_Int64:
+ case FdoDataType_Decimal:
+ case FdoDataType_Single:
+ case FdoDataType_Double:
+ switch (dtSecondary)
+ val = primary;
+ break;
+ case FdoDataType_String:
+ // Convert primary to string
+ FdoStringP strPrimVal = primary->ToString();
+ FdoPtr<FdoStringValue> strval = FdoStringValue::Create();
+ strval->SetString(strPrimVal);
+ val = strval;
+ break;
+ break;
+ val = primary;
+ break;
+ // Convert primary string to number
+ // Remove the single quote from the string
+ FdoStringP quote = "'"; // NOXLATE
+ FdoStringP emptyString = ""; // NOXLATE
+ strPrimVal = strPrimVal.Replace(quote, emptyString);
+ if (strPrimVal.IsNumber())
+ FdoPtr<FdoDoubleValue> dval = FdoDoubleValue::Create();
+ dval->SetDouble(strPrimVal.ToDouble());
+ val = dval;
+ break;
+ if(val)
+ if (dvcol == NULL)
+ dvcol = (CGwsDataValueCollection *) CGwsDataValueCollection::Create ();
+ dvcol->Add (val);
+ m_leftJoinVals = dvcol;
+ wchar_t* buffer = new wchar_t[255];
+ m_leftJoinVals.ToString(buffer, 255);
+ printf(" Join Values = %S\n", buffer);
+ delete [] buffer;
+ #endif
+ m_bLeftJoinValuesSet = true;
+ return NULL; // m_leftJoinVals;
+FdoString * CGwsBatchSortedBlockJoinQueryResults::GetString (FdoString* propertyName)
+ FdoString* result = NULL;
+ // Read from the cache
+ PrimaryCacheEntry* cacheEntry = *m_pPrimaryCacheIterator;
+ for(size_t i=0;i<cacheEntry->propertyCollection.size();i++)
+ PropertyCacheEntry* propertyCacheEntry = cacheEntry->propertyCollection.at(i);
+ if(propDesc)
+ if(wcscmp(propDesc->m_name.c_str(), propertyName) == 0)
+ if(propDesc->m_ptype == FdoPropertyType_DataProperty)
+ if(propDesc->m_dataprop == FdoDataType_String)
+ FdoStringValue* value = (FdoStringValue*)(propertyCacheEntry->dataValue.p);
+ if(value)
+ result = value->GetString();
+ else
+ // Wrong data type
+ // Exception!
+ GWS_THROW (eGwsFdoInvalidDataType);
+ else
+ // Invalid property type
+ // Exception!
+ GWS_THROW (eGwsFdoInvalidPropertyType);
+ break;
+ return result;
+bool CGwsBatchSortedBlockJoinQueryResults::GetBoolean(FdoString* propertyName)
+ bool result = false;
+ if(propDesc)
+ if(propDesc->m_dataprop == FdoDataType_Boolean)
+ FdoBooleanValue* value = (FdoBooleanValue*)(propertyCacheEntry->dataValue.p);
+ if(value)
+ result = value->GetBoolean();
+ else
+ // Exception!
+ else
+ // Exception!
+ break;
+ return result;
+FdoByte CGwsBatchSortedBlockJoinQueryResults::GetByte(FdoString* propertyName)
+ FdoByte result = 0;
+ if(propDesc)
+ if(propDesc->m_dataprop == FdoDataType_Byte)
+ FdoByteValue* value = (FdoByteValue*)(propertyCacheEntry->dataValue.p);
+ if(value)
+ result = value->GetByte();
+ else
+ // Exception!
+ else
+ // Exception!
+ break;
+ return result;
+FdoDateTime CGwsBatchSortedBlockJoinQueryResults::GetDateTime(FdoString* propertyName)
+ FdoDateTime result;
+ if(propDesc)
+ if(propDesc->m_dataprop == FdoDataType_DateTime)
+ FdoDateTimeValue* value = (FdoDateTimeValue*)(propertyCacheEntry->dataValue.p);
+ if(value)
+ result = value->GetDateTime();
+ else
+ // Exception!
+ else
+ // Exception!
+ break;
+ return result;
+double CGwsBatchSortedBlockJoinQueryResults::GetDouble(FdoString* propertyName)
+ double result = 0.0;
+ if(propDesc)
+ if(propDesc->m_dataprop == FdoDataType_Double)
+ FdoDoubleValue* value = (FdoDoubleValue*)(propertyCacheEntry->dataValue.p);
+ if(value)
+ result = value->GetDouble();
+ else
+ // Exception!
+ else
+ // Exception!
+ break;
+ return result;
+FdoInt16 CGwsBatchSortedBlockJoinQueryResults::GetInt16(FdoString* propertyName)
+ FdoInt16 result = 0;
+ if(propDesc)
+ if(propDesc->m_dataprop == FdoDataType_Int16)
+ FdoInt16Value* value = (FdoInt16Value*)(propertyCacheEntry->dataValue.p);
+ if(value)
+ result = value->GetInt16();
+ else
+ // Exception!
+ else
+ // Exception!
+ break;
+ return result;
+FdoInt32 CGwsBatchSortedBlockJoinQueryResults::GetInt32(FdoString* propertyName)
+ FdoInt32 result = 0;
+ if(propDesc)
+ if(propDesc->m_dataprop == FdoDataType_Int32)
+ FdoInt32Value* value = (FdoInt32Value*)(propertyCacheEntry->dataValue.p);
+ if(value)
+ result = value->GetInt32();
+ else
+ // Exception!
+ else
+ // Exception!
+ break;
+ return result;
+FdoInt64 CGwsBatchSortedBlockJoinQueryResults::GetInt64(FdoString* propertyName)
+ FdoInt64 result = 0;
+ if(propDesc)
+ if(propDesc->m_dataprop == FdoDataType_Int64)
+ FdoInt64Value* value = (FdoInt64Value*)(propertyCacheEntry->dataValue.p);
+ if(value)
+ result = value->GetInt64();
+ else
+ // Exception!
+ else
+ // Exception!
+ break;
+ return result;
+float CGwsBatchSortedBlockJoinQueryResults::GetSingle(FdoString* propertyName)
+ float result = 0.0;
+ if(propDesc)
+ if(propDesc->m_dataprop == FdoDataType_Single)
+ FdoSingleValue* value = (FdoSingleValue*)(propertyCacheEntry->dataValue.p);
+ if(value)
+ result = value->GetSingle();
+ else
+ // Exception!
+ else
+ // Exception!
+ break;
+ return result;
+FdoLOBValue * CGwsBatchSortedBlockJoinQueryResults::GetLOB(FdoString* propertyName)
+ FdoLOBValue* result = NULL;
+ if(propDesc)
+ if(propDesc->m_dataprop == FdoDataType_CLOB)
+ FdoLOBValue* value = (FdoLOBValue*)(propertyCacheEntry->dataValue.p);
+ if(value)
+ result = value;
+ else
+ // Exception!
+ else
+ // Exception!
+ break;
+ return result;
+FdoIStreamReader* CGwsBatchSortedBlockJoinQueryResults::GetLOBStreamReader(const wchar_t* propertyName )
+ // Not implemented
+ assert (false);
+ return NULL;
+bool CGwsBatchSortedBlockJoinQueryResults::IsNull(FdoString* propertyName)
+ if(propDesc)
+ FdoDataValue* value = (FdoDataValue*)(propertyCacheEntry->dataValue.p);
+ if(value)
+ result = value->IsNull();
+ else
+ // Exception!
+ break;
+ return result;
+FdoIRaster* CGwsBatchSortedBlockJoinQueryResults::GetRaster(FdoString* propertyName)
+ assert (false);
+ return NULL;
+FdoDataValue * CGwsBatchSortedBlockJoinQueryResults::GetPropertyValue (
+ const CGwsPropertyDesc & desc
+ if (desc.m_ptype != FdoPropertyType_DataProperty)
+ return NULL;
+ FdoDataValue* result = NULL;
+ if(propDesc)
+ if(propDesc->m_dataprop == desc.m_dataprop)
+ if(wcscmp(propDesc->m_name.c_str(), desc.m_name.c_str()) == 0)
+ if(value)
+ result = value;
+ break;
+ return result;
+FdoDataValue * CGwsBatchSortedBlockJoinQueryResults::GetDataValue (FdoString* propertyName)
+ const CGwsPropertyDesc & desc = GetPropertyDescriptor (propertyName);
+ if (desc.m_name.empty ())
+ return NULL;
+ return GetPropertyValue (desc);
+FdoDataValueCollection * CGwsBatchSortedBlockJoinQueryResults::GetDataValues (
+ FdoStringCollection* propertyNames
+ CGwsDataValueCollection * vals = NULL;
+ for (int i = 0; i < propertyNames->GetCount (); i ++) {
+ FdoPtr<FdoDataValue> val = GetDataValue (propertyNames->GetString (i));
+ assert (val != NULL);
+ if (vals == NULL)
+ vals = (CGwsDataValueCollection *) CGwsDataValueCollection::Create ();
+ vals->Add (val);
+ return vals;
+const FdoByte * CGwsBatchSortedBlockJoinQueryResults::GetGeometry(
+ FdoString * propertyName,
+ FdoInt32 * count
+ FdoByte * gvalue = NULL;
+ if(propDesc)
+ if(propDesc->m_ptype == FdoPropertyType_GeometricProperty)
+ FdoByteArray* value = (FdoByteArray*)(propertyCacheEntry->geometry.p);
+ if(value)
+ gvalue = value->GetData();
+ if(count)
+ *count = value->GetCount();
+ else
+ // Exception!
+ break;
+ if (m_converter != NULL && ! m_bGeometryConverted && gvalue) {
+ EGwsStatus stat = m_converter->ConvertForward (gvalue, * count);
+ GWS_THROW (stat);
+ m_bGeometryConverted = true;
+ return gvalue;
+FdoByteArray* CGwsBatchSortedBlockJoinQueryResults::GetGeometry(FdoString* propertyName)
+ FdoByteArray * gvalue = NULL;
+ if(propDesc)
+ if(value)
+ gvalue = value;
+ else
+ // Exception!
+ break;
+ EGwsStatus stat = m_converter->ConvertForward (gvalue);
+ GWS_THROW (stat);
+ return gvalue;
+FdoByteArray * CGwsBatchSortedBlockJoinQueryResults::GetOriginalGeometry (FdoString* propertyName)
+ return GetGeometry (propertyName);
+FdoIFeatureReader* CGwsBatchSortedBlockJoinQueryResults::GetFeatureObject(FdoString* propertyName)
+ assert (false);
+ return NULL;
+void CGwsBatchSortedBlockJoinQueryResults::ClearIteratorCache()
+ PrimaryCacheEntry* primaryCacheEntry = m_pPrimaryCache.at(i);
+ if(primaryCacheEntry)
+ for(size_t j=0;j<primaryCacheEntry->propertyCollection.size();j++)
+ PropertyCacheEntry* propertyCacheEntry = primaryCacheEntry->propertyCollection.at(j);
+ delete propertyCacheEntry;
+ primaryCacheEntry->propertyCollection.clear();
+ delete primaryCacheEntry;
+ m_pPrimaryCache.clear();
+void CGwsBatchSortedBlockJoinQueryResults::QuickSort(std::vector<PrimaryCacheEntry*>& cache, FdoInt32 left, FdoInt32 right)
+ assert(left >= 0);
+ assert(right >= 0);
+ int i = left;
+ int j = right;
+ PrimaryCacheEntry* cacheEntry = cache[(left + right) / 2];
+ do {
+ while (QuickSortCompare(cache[i], cacheEntry))
+ i++;
+ while (QuickSortCompare(cacheEntry, cache[j]))
+ j--;
+ if (i <= j) {
+ if (i < j) {
+ PrimaryCacheEntry* tempCacheEntry = cache[i];
+ cache[i] = cache[j];
+ cache[j] = tempCacheEntry;
+ i++; j--;
+ } while (i <= j);
+ if (left < j)
+ QuickSort(cache, left, j);
+ if (i < right)
+ QuickSort(cache, i, right);
+bool CGwsBatchSortedBlockJoinQueryResults::QuickSortCompare(PrimaryCacheEntry* compareA, PrimaryCacheEntry* compareB)
+ bool bResult = false;
+ if((compareA != NULL) && (compareB != NULL))
+ FdoPtr<FdoDataValue> compareADataValue;
+ FdoPtr<FdoDataValue> compareBDataValue;
+ compareADataValue = compareA->primaryKey;
+ compareBDataValue = compareB->primaryKey;
+ FdoDataType dataType = compareADataValue->GetDataType();
+ switch (dataType)
+ FdoInt32 compareAValue = ((FdoInt32Value*)(compareADataValue.p))->GetInt32();
+ FdoInt32 compareBValue = ((FdoInt32Value*)(compareBDataValue.p))->GetInt32();
+ if(compareAValue < compareBValue)
+ bResult = true;
+ break;
+ FdoStringP compareAValue = ((FdoStringValue*)(compareADataValue.p))->GetString();
+ FdoStringP compareBValue = ((FdoStringValue*)(compareBDataValue.p))->GetString();
+ if(wcscmp(compareAValue, compareBValue) < 0)
+ bResult = true;
+ break;
+ return bResult;
Property changes on: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsBatchSortedBlockJoinQueryResults.cpp
___________________________________________________________________
+ native
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureSourceQuery.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureSourceQuery.cpp 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureSourceQuery.cpp 2007-02-23 00:41:58 UTC (rev 1130)
@@ -401,14 +401,18 @@
if (rSupportsOrdering) {
// sort-merge
joinmethod = eGwsSortMerge;
} else {
// nested loop join and sorted block
joinmethod = eGwsNestedLoopSortedBlock;
} else {
- // nested loop join
- joinmethod = eGwsNestedLoops;
+ if (rSupportsOrdering) {
+ joinmethod = eGwsBatchSortedBlock;
+ else {
+ // nested loop join
+ joinmethod = eGwsNestedLoops;
prepQuery = CreatePreparedJoinQuery (pFQuery->Type (),
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsPreparedFeatureQuery.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsPreparedFeatureQuery.cpp 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsPreparedFeatureQuery.cpp 2007-02-23 00:41:58 UTC (rev 1130)
@@ -76,12 +76,16 @@
return new CGwsNestedLoopsJoinQueryResults ();
case eGwsNestedLoopSortedBlockIterator:
return new CGwsNestedLoopSortedBlockJoinQueryResults ();
+ case eGwsBatchSortedBlockIterator:
+ return new CGwsBatchSortedBlockJoinQueryResults ();
case eGwsRightSortMergeJoinIterator:
return new CGwsRightSortedJoinQueryResults ();
case eGwsRightNestedLoopsIterator:
return new CGwsRightNestedLoopJoinQueryResults ();
case eGwsRightNestedLoopSortedBlockIterator:
return new CGwsRightNestedLoopSortedBlockJoinQueryResults ();
+ case eGwsRightBatchSortedBlockIterator:
+ return new CGwsRightBatchSortedBlockJoinQueryResults ();
return NULL;
@@ -357,8 +361,12 @@
try {
FdoPtr<FdoFilter> filter = ((FdoISelect *)m_pCommand.p)->GetFilter ();
PrepareFilter (filter, m_bIsAxisAlignedRectangleFilter);
- // do I need to set filter after converting it?
+ #ifdef _DEBUG
+ if(filter)
+ printf("Filter:%S\n\n", filter->ToString());
+ #endif
//Code for executing an extended query - if it's requested (bScrollable)
//AND if it's supported (m_bSdfExtendedQuerySupported)
bool bGotScrollableIterator = false;
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsPreparedJoinQuery.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsPreparedJoinQuery.cpp 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsPreparedJoinQuery.cpp 2007-02-23 00:41:58 UTC (rev 1130)
@@ -116,6 +116,8 @@
reader = dynamic_cast<CGwsJoinQueryResults *> (CreateFeatureIterator (eGwsNestedLoopsIterator));
} else if (m_joinmethod == eGwsNestedLoopSortedBlock) {
reader = dynamic_cast<CGwsJoinQueryResults *> (CreateFeatureIterator (eGwsNestedLoopSortedBlockIterator));
+ } else if (m_joinmethod == eGwsBatchSortedBlock) {
+ reader = dynamic_cast<CGwsJoinQueryResults *> (CreateFeatureIterator (eGwsBatchSortedBlockIterator));
if (reader != NULL) {
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsQueryEngine.vcproj
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsQueryEngine.vcproj 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsQueryEngine.vcproj 2007-02-23 00:41:58 UTC (rev 1130)
@@ -243,6 +243,10 @@
</File>
</Filter>
<File
+ RelativePath=".\GwsBatchSortedBlockJoinQueryResults.cpp"
+ </File>
+ <File
RelativePath=".\GwsBinaryFeature.cpp"
</File>
@@ -387,6 +391,10 @@
</File>
<File
+ RelativePath=".\GwsRightBatchSortedBlockJoinQueryResults.cpp"
+ </File>
+ <File
RelativePath=".\GwsRightJoinQueryResults.cpp"
</File>
Added: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightBatchSortedBlockJoinQueryResults.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightBatchSortedBlockJoinQueryResults.cpp (rev 0)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightBatchSortedBlockJoinQueryResults.cpp 2007-02-23 00:41:58 UTC (rev 1130)
@@ -0,0 +1,163 @@
+// Includes
+// class CGwsRightBatchSortedBlockJoinQueryResults
+CGwsRightBatchSortedBlockJoinQueryResults::CGwsRightBatchSortedBlockJoinQueryResults ()
+ m_pos = eBeforeFirstRow;
+CGwsRightBatchSortedBlockJoinQueryResults::~CGwsRightBatchSortedBlockJoinQueryResults () throw()
+EGwsStatus CGwsRightBatchSortedBlockJoinQueryResults::InitializeReader (
+ CGwsPreparedQuery * prepquery,
+ FdoStringCollection * joincols,
+ bool bScrollable
+ return CGwsRightNestedLoopJoinQueryResults::InitializeReader (query, prepquery, joincols, bScrollable);
+bool CGwsRightBatchSortedBlockJoinQueryResults::ReadNext()
+ if (m_usepool) {
+ // reading from the pool
+ if (m_poolpos + 1 < m_pool->GetCount ()) {
+ m_poolpos ++;
+ return true;
+ return false;
+ bool bRet = false;
+ if(m_pos == eBeforeFirstRow)
+ bRet = CGwsRightJoinQueryResults::ReadNext ();
+ else
+ // Next read will be for the next primary key so we don't want to advance the secondary
+ printf(" CGwsRightBatchSortedBlockJoinQueryResults::ReadNext() - JoinColumns:%S\n", m_joincols->ToString());
+ #endif
+ if (bRet)
+ printf(" CGwsRightBatchSortedBlockJoinQueryResults::ReadNext()\n");
+ #endif
+ m_pool->AddFeature (this);
+ m_pos = eOnJoinRow;
+ return bRet;
+void CGwsRightBatchSortedBlockJoinQueryResults::Close ()
+ CGwsRightNestedLoopJoinQueryResults::Close ();
+EGwsStatus CGwsRightBatchSortedBlockJoinQueryResults::SetRelatedValues (
+ const GWSFeatureId & vals
+ printf(" CGwsRightBatchSortedBlockJoinQueryResults::SetRelatedValues()\n");
+ #endif
+ if (m_joinkeys == vals) {
+ if (! m_neverusepooling) {
+ // this completes features pool
+ if (! m_bClosed) {
+ while (ReadNext ())
+ Close ();
+ m_usepool = true;
+ m_poolpos = -1;
+ return eGwsOk;
+ m_pool->Reset ();
+ m_usepool = false;
+ m_poolpos = -1;
+ // The code below is similar to the base class, but we want to use an IN clause in order to
+ // do a batch comparison instead of the typical = and LIKE operators.
+ try {
+ Close ();
+ FdoString* propname = m_joincols->GetString (0);
+ WSTR filter = propname;
+ filter += L" IN (";
+ FdoPtr<FdoFilter> pFilter = NULL;
+ for (int idx = 0; idx < vals.GetCount (); idx ++)
+ if(idx > 0)
+ filter += L",";
+ FdoPtr<FdoDataValue> val = vals.GetItem (idx);
+ FdoStringP valStr = val->ToString();
+ filter += valStr;
+ filter += L")";
+ pFilter = FdoFilter::Parse(filter.c_str());
+ m_prepquery->SetFilter (pFilter);
+ IGWSFeatureIterator * fiter = NULL;
+ stat = m_prepquery->Execute (& fiter);
+ return stat;
+ m_reader = dynamic_cast<FdoIFeatureReader*> (fiter);
+ m_bClosed = false;
+ stat = CGwsRightJoinQueryResults::SetRelatedValues (vals);
+ } catch (FdoException *e) {
+ PushFdoException (eGwsFailed, e);
+ e->Release();
+ stat = eGwsFailed;
+ return stat;
Property changes on: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightBatchSortedBlockJoinQueryResults.cpp
+ native
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightJoinQueryResults.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightJoinQueryResults.cpp 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightJoinQueryResults.cpp 2007-02-23 00:41:58 UTC (rev 1130)
@@ -517,4 +517,9 @@
return CGwsFeatureIterator::ToString (propertyName, buff, len);
+FdoStringCollection* CGwsRightJoinQueryResults::GetJoinColumns()
+ m_joincols.p->AddRef();
+ return m_joincols;
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/Makefile.am
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/Makefile.am 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/Makefile.am 2007-02-23 00:41:58 UTC (rev 1130)
@@ -5,6 +5,7 @@
lib_LTLIBRARIES = libMgGwsQueryEngine.la
libMgGwsQueryEngine_la_SOURCES = \
+ GwsBatchSortedBlockJoinQueryResults.cpp \
GwsBinaryFeature.cpp \
GwsBinaryFeatureReader.cpp \
GwsBinaryFeatureWriter.cpp \
@@ -38,6 +39,7 @@
GwsQueryFactories.cpp \
GwsQueryUtils.cpp \
GwsQueryXml.cpp \
+ GwsRightBatchSortedBlockJoinQueryResults.cpp \
GwsRightJoinQueryResults.cpp \
GwsRightNestedLoopJoinQueryResults.cpp \
GwsRightNestedLoopSortedBlockJoinQueryResults.cpp \
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsQuery.h
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsQuery.h 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsQuery.h 2007-02-23 00:41:58 UTC (rev 1130)
@@ -57,6 +57,12 @@
} EGwsCacheFeatureStatus;
+typedef enum _EGwsCursorPosition {
+ eBeforeFirstRow,
+ eOnJoinRow,
+ eAfterJoinRow,
+ eAfterLastRow
+} EGwsCursorPosition;
@@ -71,6 +77,7 @@
kGwsSortMergeResults = 1,
kGwsNestedLoopSortBlockResults,
kGwsNestedLoopResults,
+ kGwsBatchSortBlockResults,
kGwsHashResults
} EJoinResultsType;
@@ -79,6 +86,7 @@
eGwsSortMerge = 1,
eGwsNestedLoops,
eGwsNestedLoopSortedBlock,
+ eGwsBatchSortedBlock,
eGwsHash
} EGwsJoinMethod;
@@ -88,9 +96,11 @@
eGwsSortMergeJoinIterator,
eGwsNestedLoopsIterator,
eGwsNestedLoopSortedBlockIterator,
+ eGwsBatchSortedBlockIterator,
eGwsRightSortMergeJoinIterator,
eGwsRightNestedLoopsIterator,
- eGwsRightNestedLoopSortedBlockIterator
+ eGwsRightNestedLoopSortedBlockIterator,
+ eGwsRightBatchSortedBlockIterator
} EGwsFeatureIteratorType;
@@ -914,7 +924,7 @@
GWS_QUERYENGINE_API
virtual EJoinResultsType Type () const = 0;
- FdoDataValueCollection * GetJoinValues ();
+ virtual FdoDataValueCollection * GetJoinValues ();
GWS_QUERYENGINE_API
bool CacheReadNext ();
@@ -937,8 +947,8 @@
bool m_bLeftJoinValuesSet;
bool m_started;
bool m_forceOneToOne;
+ bool SetupRightSide(bool leftResult);
private:
- bool SetupRightSide(bool leftResult);
@@ -1031,6 +1041,9 @@
GWS_QUERYENGINE_API
virtual void ToString (FdoString* propertyName, wchar_t * buff, int len);
+ GWS_QUERYENGINE_API
+ virtual FdoStringCollection* GetJoinColumns();
protected:
IGWSFeature * GetPooledFeature ();
@@ -1138,9 +1151,126 @@
+typedef struct {
+ FdoPtr<FdoByteArray> geometry;
+ FdoPtr<FdoDataValue> dataValue;
+} PropertyCacheEntry;
+typedef std::vector< CGwsPropertyDesc* > PropertyDescriptionCollection;
+typedef std::vector< PropertyCacheEntry* > PropertyCollection;
+typedef struct {
+ PropertyCollection propertyCollection;
+ FdoPtr<FdoDataValue> primaryKey;
+} PrimaryCacheEntry;
+// Left join results iterator. (Batch sorted block)
+class CGwsBatchSortedBlockJoinQueryResults : public CGwsJoinQueryResults
+friend class CGwsPreparedFeatureQuery;
+friend class CGwsPreparedLeftJoinQuery;
+friend class CGwsPreparedEqualJoinQuery;
+friend class CGwsPreparedJoinQuery;
+public:
+ GWS_QUERYENGINE_API CGwsBatchSortedBlockJoinQueryResults ();
+ virtual ~CGwsBatchSortedBlockJoinQueryResults () throw();
+ virtual EGwsStatus InitializeReader (
+ bool bScrollable = false);
+ virtual EJoinResultsType Type () const
+ return kGwsBatchSortBlockResults;
+ virtual bool ReadNext ();
+ virtual IGWSFeatureIterator * GetJoinedFeatures (int i);
+ // get right hand side joined features
+ IGWSFeatureIterator * GetJoinedFeatures ();
+ // Getters by the prperty name - this will come from the cache
+ virtual bool IsNull (FdoString* propertyName);
+ virtual FdoString * GetString (FdoString* propertyName);
+ virtual bool GetBoolean (FdoString* propertyName);
+ virtual FdoByte GetByte (FdoString* propertyName);
+ virtual FdoDateTime GetDateTime (FdoString* propertyName);
+ virtual double GetDouble (FdoString* propertyName);
+ virtual FdoInt16 GetInt16 (FdoString* propertyName);
+ virtual FdoInt32 GetInt32 (FdoString* propertyName);
+ virtual FdoInt64 GetInt64 (FdoString* propertyName);
+ virtual float GetSingle (FdoString* propertyName);
+ virtual FdoLOBValue* GetLOB (FdoString* propertyName);
+ virtual FdoIStreamReader* GetLOBStreamReader(const wchar_t* propertyName );
+ virtual FdoIRaster* GetRaster (FdoString* propertyName);
+ virtual const FdoByte * GetGeometry (FdoString* propertyName, FdoInt32 * count) ;
+ virtual FdoByteArray* GetGeometry (FdoString* propertyName);
+ virtual FdoIFeatureReader* GetFeatureObject(FdoString* propertyName);
+ virtual FdoDataValue * GetDataValue (FdoString* propertyName);
+ GetDataValues (FdoStringCollection* propertyNames);
+ // returns unconverted geometry. Coordinate system transaformations are not applied
+ virtual FdoByteArray* GetOriginalGeometry (FdoString* propertyName);
+ // get data property value
+ virtual FdoDataValue * GetPropertyValue (const CGwsPropertyDesc &);
+ static int sm_nBatchSize;
+protected:
+ bool SetupBatchRightSide(bool leftResult);
+ void ClearIteratorCache();
+ void QuickSort(std::vector<PrimaryCacheEntry*>& cache, FdoInt32 left, FdoInt32 right);
+ bool QuickSortCompare(PrimaryCacheEntry* compareA, PrimaryCacheEntry* compareB);
+ IGWSFeatureIterator* m_primaryFeatureIterator;
+ FdoPtr<FdoStringCollection> m_propertyNames;
+ PropertyDescriptionCollection m_propertyDescriptionCollection;
+ // Primary iterator cache
+ std::vector<PrimaryCacheEntry*> m_pPrimaryCache;
+ std::vector<PrimaryCacheEntry*>::iterator m_pPrimaryCacheIterator;
// class CGwsRightSortedJoinQueryResults
// ordered right side of the joined query results
@@ -1171,14 +1301,6 @@
virtual EGwsStatus SetRelatedValues (const GWSFeatureId & vals);
protected:
- typedef enum _EGwsCursorPosition {
- eBeforeFirstRow,
- eOnJoinRow,
- eAfterJoinRow,
- eAfterLastRow
- } EGwsCursorPosition;
-protected:
EGwsCursorPosition m_pos;
@@ -1258,6 +1380,43 @@
+// join batch sorted block right side
+class CGwsRightBatchSortedBlockJoinQueryResults
+ : public CGwsRightNestedLoopJoinQueryResults
+public:
+ GWS_QUERYENGINE_API CGwsRightBatchSortedBlockJoinQueryResults ();
+ virtual ~CGwsRightBatchSortedBlockJoinQueryResults () throw();
+ bool bScrollable);
+ virtual bool ReadNext();
+ virtual void Close ();
+ virtual EGwsStatus SetRelatedValues (const GWSFeatureId & vals);
+protected:
+ EGwsCursorPosition m_pos;
// class CGwsMultiSelectIterator
// Wrapper, implemeting multiple selects during iteration
// Must be able to wrap all iterator types
Modified: trunk/MgDev/Server/src/Gws/GwsResource/GwsResource.h
--- trunk/MgDev/Server/src/Gws/GwsResource/GwsResource.h 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Server/src/Gws/GwsResource/GwsResource.h 2007-02-23 00:41:58 UTC (rev 1130)
@@ -211,6 +211,7 @@
#define IDS_STRING_eGwsFeatureClassHasNoIdentity 1192
#define IDS_PROGRESS_LAYEREXTENTS 1193
#define IDS_PROGRESS_LAYER 1194
+#define IDS_STRING_eGwsFdoInvalidDataType 1195
// Next default values for new objects
Modified: trunk/MgDev/Server/src/Gws/GwsResource/GwsResource.rc
--- trunk/MgDev/Server/src/Gws/GwsResource/GwsResource.rc 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Server/src/Gws/GwsResource/GwsResource.rc 2007-02-23 00:41:58 UTC (rev 1130)
@@ -435,6 +435,7 @@
"Instance cannot be updated because the feature class doesn't have identity properties."
IDS_PROGRESS_LAYEREXTENTS "Calculating layer extents..."
+ IDS_STRING_eGwsFdoInvalidDataType "Invalid data type."
END
#endif // English (U.S.) resources
Modified: trunk/MgDev/Server/src/Gws/Include/GwsCommon.h
--- trunk/MgDev/Server/src/Gws/Include/GwsCommon.h 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Server/src/Gws/Include/GwsCommon.h 2007-02-23 00:41:58 UTC (rev 1130)
@@ -223,6 +223,7 @@
,eGwsNoLayers
,eGwsFeatureSourceIsReadOnly
,eGwsFeatureClassHasNoIdentity
+ ,eGwsFdoInvalidDataType
} EGwsStatus;
Modified: trunk/MgDev/Server/src/Services/Feature/Makefile.am
--- trunk/MgDev/Server/src/Services/Feature/Makefile.am 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Server/src/Services/Feature/Makefile.am 2007-02-23 00:41:58 UTC (rev 1130)
@@ -10,6 +10,7 @@
-I../../../../Oem/dbxml-2.2.13/xerces-c-src/src \
-I../../Gws/Include \
-I../../Gws/GwsCommon/inc \
+ -I../../Gws/GwsQueryEngine/inc \
-I../../../../Common/Security \
-I../../../../Common/Foundation \
-I../../../../Common/Geometry \
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.vcproj
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.vcproj 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.vcproj 2007-02-23 00:41:58 UTC (rev 1130)
@@ -41,7 +41,7 @@
<Tool
Name="VCCLCompilerTool"
Optimization="0"
- AdditionalIncludeDirectories="..\..\..\..\Oem\ACE\ACE_wrappers;"..\..\..\..\Oem\dbxml-2.2.13\xerces-c-src\src";..\..\..\..\Oem\FDO\inc;..\..\..\..\Common\CoordinateSystem;..\..\..\..\Common\Security;..\..\..\..\Common\Foundation;..\..\..\..\Common\Geometry;..\..\..\..\Common\PlatformBase;..\..\..\..\Common\MapGuideCommon;..\..\..\..\Common\MdfModel;..\..\..\..\Common\MdfParser;..\..\Common;..\..\Common\Base;..\..\Common\Manager;..\..\Common\ServerUtil;..\..\Gws\Include;..\..\Gws\GwsCommon\inc"
+ AdditionalIncludeDirectories="..\..\..\..\Oem\ACE\ACE_wrappers;"..\..\..\..\Oem\dbxml-2.2.13\xerces-c-src\src";..\..\..\..\Oem\FDO\inc;..\..\..\..\Common\CoordinateSystem;..\..\..\..\Common\Security;..\..\..\..\Common\Foundation;..\..\..\..\Common\Geometry;..\..\..\..\Common\PlatformBase;..\..\..\..\Common\MapGuideCommon;..\..\..\..\Common\MdfModel;..\..\..\..\Common\MdfParser;..\..\Common;..\..\Common\Base;..\..\Common\Manager;..\..\Common\ServerUtil;..\..\Gws\Include;..\..\Gws\GwsCommon\inc;..\..\Gws\GwsQueryEngine\inc"
PreprocessorDefinitions="WIN32;_DEBUG;_WINDOWS;_USRDLL;MG_SERVER_FEATURE_EXPORTS"
MinimalRebuild="true"
ExceptionHandling="2"
@@ -123,7 +123,7 @@
<Tool
PreprocessorDefinitions="WIN32;NDEBUG;_WINDOWS;_USRDLL;MG_SERVER_FEATURE_EXPORTS"
RuntimeLibrary="2"
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp 2007-02-23 00:41:58 UTC (rev 1130)
@@ -16,6 +16,7 @@
#include "ServerFeatureServiceDefs.h"
+#include "MapGuideCommon.h"
#include "Services/FeatureService.h"
#include "ServerSelectFeatures.h"
#include "ServerFeatureConnection.h"
@@ -30,6 +31,10 @@
#include "ServerGwsFeatureReader.h"
#include "GwsConnectionPool.h"
+#include "GwsCommonImp.h"
+#include "GwsMutableFeature.h"
+#include "GwsFdoCommand.h"
+#include "GwsQuery.h"
MgServerSelectFeatures::MgServerSelectFeatures()
@@ -40,6 +45,19 @@
m_customFunction = NULL;
m_customPropertyName = L"";
m_featureSource = NULL;
+ // Set a default join query batch size
+ m_nJoinQueryBatchSize = MgConfigProperties::DefaultFeatureServicePropertyJoinQueryBatchSize;
+ // Get the join batch size
+ MgConfiguration* config = MgConfiguration::GetInstance();
+ if(config)
+ config->GetIntValue(MgConfigProperties::FeatureServicePropertiesSection,
+ MgConfigProperties::FeatureServicePropertyJoinQueryBatchSize,
+ m_nJoinQueryBatchSize,
+ MgConfigProperties::DefaultFeatureServicePropertyJoinQueryBatchSize);
MgServerSelectFeatures::~MgServerSelectFeatures()
@@ -380,7 +398,7 @@
FdoPtr<FdoIGeometry> geometry = geometryFactory->CreateGeometryFromFgf(byteArray);
STRING geomText = geometry->GetText();
- ACE_DEBUG((LM_ERROR, ACE_TEXT("SPATIAL FILTER: %W\n"), geomText.c_str()));
+ ACE_DEBUG((LM_ERROR, ACE_TEXT("SPATIAL FILTER:\n%W\n\n"), geomText.c_str()));
#endif
@@ -997,6 +1015,9 @@
FdoPtr<IGWSFeatureIterator> iter;
FdoPtr<IGWSFeatureIterator> iterCopy;
+ // Set batch size as it may be needed
+ CGwsBatchSortedBlockJoinQueryResults::sm_nBatchSize = m_nJoinQueryBatchSize;
// Prepare and Execute Query
query->Prepare();
query->Execute(&iter, true);
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h
--- trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h 2007-02-22 23:22:12 UTC (rev 1129)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h 2007-02-23 00:41:58 UTC (rev 1130)
@@ -86,6 +86,9 @@
MgResourceIdentifier* GetSecondaryResourceIdentifier(MgResourceIdentifier* primResId, CREFSTRING extensionName, CREFSTRING relationName);
MdfModel::FeatureSource* GetFeatureSource(MgResourceIdentifier* resource);
+ // This setting limits the batch size used by the join query algorithm
+ INT32 m_nJoinQueryBatchSize;
#endif
More information about the mapguide-commits
