[mapguide-commits] r1131 - trunk/MgDev/Server/src/Services/Feature
svn_mapguide at osgeo.org
Thu Feb 22 19:45:29 EST 2007
Author: brucedechant
Date: 2007-02-22 19:45:29 -0500 (Thu, 22 Feb 2007)
New Revision: 1131
trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.cpp
trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.h
Add performance optimization to the server's feature service join feature reader.
Modified: trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.cpp 2007-02-23 00:41:58 UTC (rev 1130)
+++ trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.cpp 2007-02-23 00:45:29 UTC (rev 1131)
@@ -36,6 +36,9 @@
m_attributeNameDelimiters = SAFE_ADDREF(attributeNameDelimiters);
m_gwsGetFeatures = new MgServerGwsGetFeatures(gwsFeatureIterator, this);
+ // Get the Extended Feature Description
+ m_gwsFeatureIterator->DescribeFeature(&m_primaryExtendedFeatureDescription);
MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerGwsFeatureReader.MgServerGwsFeatureReader")
@@ -94,20 +97,15 @@
// retrieve the secondary feature source iterators, advance the iterators and store into a collection
- FdoPtr<IGWSExtendedFeatureDescription> desc;
- m_gwsFeatureIterator->DescribeFeature(&desc);
- int myCount = desc->GetCount();
// Check if a delimiter has been defined for each Attribute Relate,
// i.e. the number of delimiters collected should equal the number of joined secondary features
- if (m_attributeNameDelimiters->GetCount() != (INT32)desc->GetCount())
+ if (m_attributeNameDelimiters->GetCount() != (INT32)m_primaryExtendedFeatureDescription->GetCount())
// Should never get here
throw new MgInvalidArgumentException(L"MgServerGwsFeatureReader.ReadNext", __LINE__, __WFILE__, NULL, L"MgInvalidCollectionSize", NULL);
- for (int i = 0; i < desc->GetCount(); i++)
+ for (int i = 0; i < m_primaryExtendedFeatureDescription->GetCount(); i++)
// Retrieve the AttributeNameDelimiter from the collection for the properties from this secondary feature source
STRING attributeNameDelimiter = m_attributeNameDelimiters->GetItem(i);
@@ -137,11 +135,6 @@
// advance the secondary iterator
IGWSFeatureIterator* secondaryFeatureIter = NULL;
// Advance the last iterator inserted into the collection until no more features.
// Then remove from the collection.
// Repeat until the collection is empty.
@@ -179,20 +172,16 @@
m_secondaryGwsFeatureIteratorMap.clear();
// Check if each a delimiter has been defined for each Attribute Relate,
@@ -898,19 +887,15 @@
// Check if the input propName is prefixed with the relationName
// by comparing with primary feature source property names
- FdoPtr<IGWSExtendedFeatureDescription> primaryDesc;
- m_gwsFeatureIterator->DescribeFeature(&primaryDesc);
- FdoPtr<FdoStringCollection> primaryPropNames = primaryDesc->PropertyNames();
+ FdoPtr<FdoStringCollection> primaryPropNames = m_primaryExtendedFeatureDescription->PropertyNames();
int primaryIndex = primaryPropNames->IndexOf(inputPropName.c_str());
if( -1 != primaryIndex)
// No prefix, but the property name does exist in the primary feature source
relationName.clear();
- GWSQualifiedName primQualifiedClassName = primaryDesc->ClassName();
+ GWSQualifiedName primQualifiedClassName = m_primaryExtendedFeatureDescription->ClassName();
FdoString* fclassName = primQualifiedClassName.Name();
className = (wchar_t*)fclassName;
Modified: trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.h
--- trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.h 2007-02-23 00:41:58 UTC (rev 1130)
+++ trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.h 2007-02-23 00:45:29 UTC (rev 1131)
@@ -312,6 +312,7 @@
Ptr<MgServerGwsGetFeatures> m_gwsGetFeatures;
GwsFeatureIteratorMap m_secondaryGwsFeatureIteratorMap;
FdoPtr<IGWSFeatureIterator> m_gwsFeatureIteratorCopy;
+ FdoPtr<IGWSExtendedFeatureDescription> m_primaryExtendedFeatureDescription;
bool m_bAdvancePrimaryIterator;
bool m_bForceOneToOne;
More information about the mapguide-commits
