[mapguide-commits] r1136 - trunk/MgDev/Common/PlatformBase/Services
svn_mapguide at osgeo.org
Mon Feb 26 19:17:33 EST 2007
Author: philipsharman
Date: 2007-02-26 19:17:33 -0500 (Mon, 26 Feb 2007)
New Revision: 1136
trunk/MgDev/Common/PlatformBase/Services/FeatureService.h
Corrected and clarified the comments.
Modified: trunk/MgDev/Common/PlatformBase/Services/FeatureService.h
--- trunk/MgDev/Common/PlatformBase/Services/FeatureService.h 2007-02-23 22:21:27 UTC (rev 1135)
+++ trunk/MgDev/Common/PlatformBase/Services/FeatureService.h 2007-02-27 00:17:33 UTC (rev 1136)
@@ -68,10 +68,6 @@
/// relational database and do transaction-based operations.
/// \remarks
-/// Construct an MgFeatureService object by calling \link MgSiteConnection::CreateService MgSiteConnection::CreateService Method (INT32) \endlink.
-/// A connection to the site repository must be open. See the
-/// example code.
-/// \n
/// The following use cases are supported:
/// <ul>
/// <li>Connection to a datastore. See
@@ -94,9 +90,9 @@
/// <li>Description of the schema used to store feature data. See
/// MgFeatureService::DescribeSchema,
/// MgFeatureService::DescribeSchemaAsXml,
-/// MgFeatureService::GetSchemas, MgFeatureService::SchemaToXm,
+/// MgFeatureService::GetSchemas, MgFeatureService::SchemaToXml,
/// MgFeatureService::GetClasses and
-/// MgFeatureService::GetClassDefinitionl. See also \link Feature_Schema_Module Feature Schema \endlink.
+/// MgFeatureService::GetClassDefinition. See also \link Feature_Schema_Module Feature Schema \endlink.
/// </li>
/// <li>Creation of an SDF feature source to cache feature data
/// from other datastores. See
More information about the mapguide-commits
