[mapguide-commits] r1137 - in trunk/MgDev/Common/Geometry: .
CoordinateSystem
svn_mapguide at osgeo.org
Mon Feb 26 19:18:26 EST 2007
Author: philipsharman
Date: 2007-02-26 19:18:26 -0500 (Mon, 26 Feb 2007)
New Revision: 1137
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMeasure.h
trunk/MgDev/Common/Geometry/Geometry.h
Removed some cross references from the comments. (The are
references to topics that we removed because of copyright
concerns.)
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.h 2007-02-27 00:17:33 UTC (rev 1136)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.h 2007-02-27 00:18:26 UTC (rev 1137)
@@ -524,7 +524,7 @@
/// second coordinate.
/// \return
- /// Returns the \link azimuth azimuth \endlink (Angle with respect to the
+ /// Returns the azimuth (Angle with respect to the
/// North) of the vector formed by coord1 and coord2.
/// <!-- Example (PHP) -->
@@ -578,7 +578,7 @@
/// coordinate.
/// \return
/// North) of the vector formed by (x1, y1) and (x2, y2).
@@ -602,7 +602,7 @@
/// \brief
/// Computes a coordinate a given distance along a vector that is
- /// defined by a starting coordinate and an \link azimuth azimuth \endlink
+ /// defined by a starting coordinate and an azimuth
/// (Angle with respect to North).
/// \remarks
@@ -664,7 +664,7 @@
/// \brief
- /// defined by a starting (x, y) coordinate and an \link azimuth azimuth \endlink
+ /// defined by a starting (x, y) coordinate and an azimuth
/// \remarks
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMeasure.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMeasure.h 2007-02-27 00:17:33 UTC (rev 1136)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMeasure.h 2007-02-27 00:18:26 UTC (rev 1137)
@@ -33,7 +33,7 @@
/// Provides operations for measuring the distance between 2
/// coordinates and the azimuth of 2 coordinates as well as
/// calculating a coordinate position given an initial
-/// coordinate, an \link azimuth azimuth \endlink, and a distance.
+/// coordinate, an azimuth, and a distance.
/// \remarks
/// If the coordinate system supports it, the ellipsoid
@@ -217,7 +217,7 @@
/// that specifies the second coordinate.
/// \return
@@ -272,7 +272,7 @@
/// \return
/// North) of the vector formed by (lon1, lat1) and (lon2, lat2).
@@ -295,7 +295,7 @@
/// \brief
/// Computes a coordinate given a distance along a vector that is
/// (Angle with respect to the North).
/// <!-- Syntax in .Net, Java, and PHP -->
@@ -358,7 +358,7 @@
/// \brief
Modified: trunk/MgDev/Common/Geometry/Geometry.h
--- trunk/MgDev/Common/Geometry/Geometry.h 2007-02-27 00:17:33 UTC (rev 1136)
+++ trunk/MgDev/Common/Geometry/Geometry.h 2007-02-27 00:18:26 UTC (rev 1137)
@@ -182,7 +182,7 @@
/// \brief
/// Given 2 geometries a and b, a.Equals(b) is true if the 2
- /// geometries are \link spatially_equals spatially equal \endlink.
+ /// geometries are spatially equal
/// \htmlinclude DotNetSyntaxTop.html
More information about the mapguide-commits
