[mapguide-commits] r1066 - trunk/MgDev/Server/src/UnitTesting
svn_mapguide at osgeo.org
Mon Jan 22 19:03:20 EST 2007
Author: brucedechant
Date: 2007-01-22 19:03:19 -0500 (Mon, 22 Jan 2007)
New Revision: 1066
trunk/MgDev/Server/src/UnitTesting/TestResourceService.cpp
Update resource service unit test.
Modified: trunk/MgDev/Server/src/UnitTesting/TestResourceService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestResourceService.cpp 2007-01-23 00:01:30 UTC (rev 1065)
+++ trunk/MgDev/Server/src/UnitTesting/TestResourceService.cpp 2007-01-23 00:03:19 UTC (rev 1066)
@@ -1370,6 +1370,12 @@
throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_DeleteResource", __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgFeatureService> pFeatureService = dynamic_cast<MgFeatureService*>(serviceManager->RequestService(MgServiceType::FeatureService));
+ if (pFeatureService == 0)
+ throw new MgServiceNotAvailableException(L"TestResourceService.TestCase_DeleteResource", __LINE__, __WFILE__, NULL, L"", NULL);
Ptr<MgUserInformation> userInfo;
//Sets the user information for the current thread to be administrator
@@ -1401,6 +1407,54 @@
MgUserInformation::SetCurrentUserInfo(userInfo);
CPPUNIT_ASSERT_THROW_MG(pService->DeleteResource(&resourceIdentifier), MgUnauthorizedAccessException*);
+ // Try to delete resource after FDO exception
+ MgUserInformation::SetCurrentUserInfo(NULL);
+ userInfo = new MgUserInformation(adminName, adminPass);
+ if (userInfo != NULL)
+ Ptr<MgResourceIdentifier> resource;
+ resource = new MgResourceIdentifier(L"Library://UnitTests/Data/TEST.FeatureSource");
+ #ifdef WIN32
+ STRING rcName = L"..\\UnitTestFiles\\TEST.FeatureSource";
+ STRING dfName = L"..\\UnitTestFiles\\TEST.sdf";
+ #else
+ STRING rcName = L"../UnitTestFiles/TEST.FeatureSource";
+ STRING dfName = L"../UnitTestFiles/TEST.sdf";
+ #endif
+ userInfo->SetLocale(userLocale);
+ MgUserInformation::SetCurrentUserInfo(userInfo);
+ Ptr<MgByteSource> contentSource;
+ contentSource = new MgByteSource(rcName);
+ Ptr<MgByteReader> contentReader = contentSource->GetReader();
+ pService->SetResource(resource, contentReader, NULL);
+ Ptr<MgByteSource> dataSource;
+ dataSource = new MgByteSource(dfName);
+ Ptr<MgByteReader> dataReader;
+ dataReader = dataSource->GetReader();
+ pService->SetResourceData(resource, L"TEST.sdf", L"File", dataReader);
+ dataReader = NULL; // Holds on to the file, so must release resources!
+ // Force an FDO exception
+ Ptr<MgFeatureAggregateOptions> options = new MgFeatureAggregateOptions();
+ STRING className = L"TEST";
+ options->AddFeatureProperty(L"Data");
+ Ptr<MgDataReader> reader = pFeatureService->SelectAggregate(resource, className, options);
+ bool bResult = reader->ReadNext();
+ CPPUNIT_ASSERT(bResult);
+ reader->Close();
+ reader = NULL; // Holds on to the file, so must release resources!
+ // Attempt to delete the resource
+ pService->DeleteResource(resource);
catch(MgException* e)
@@ -1408,4 +1462,13 @@
SAFE_RELEASE(e);
CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch(FdoException* e)
+ FDO_SAFE_RELEASE(e);
+ CPPUNIT_FAIL("FdoException occured");
+ catch(...)
+ throw;
More information about the mapguide-commits
