[mapguide-commits] r1067 - in trunk/MgDev: Server/src/Services/Tile
Web/src/HttpHandler
svn_mapguide at osgeo.org
Tue Jan 23 19:02:11 EST 2007
Author: stevedang
Date: 2007-01-23 19:02:10 -0500 (Tue, 23 Jan 2007)
New Revision: 1067
trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp
trunk/MgDev/Web/src/HttpHandler/HttpGetTileImage.cpp
trunk/MgDev/Web/src/HttpHandler/HttpGetTileImage.h
trunk/MgDev/Web/src/HttpHandler/OgcFramework.h
Miscellaneous code cleanups and fixes:
- Updated HTTP GetTile request to replace scale (double) with scale index (INT32).
- Commented out unused OGC framework parameters (due to Insure++ errors on Linux).
- Got rid of some compiling warnings in Server Tile Service.
Modified: trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp
--- trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2007-01-23 00:03:19 UTC (rev 1066)
+++ trunk/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2007-01-24 00:02:10 UTC (rev 1067)
@@ -119,7 +119,7 @@
cachedMap = new MgMemoryStreamHelper();
Ptr<MgStream> stream = new MgStream(cachedMap);
map->Serialize(stream);
- if (sm_mapCache.size() > sm_mapCacheSize)
+ if ((INT32)sm_mapCache.size() > sm_mapCacheSize)
ClearMapCache(L"");
Modified: trunk/MgDev/Web/src/HttpHandler/HttpGetTileImage.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpGetTileImage.cpp 2007-01-23 00:03:19 UTC (rev 1066)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetTileImage.cpp 2007-01-24 00:02:10 UTC (rev 1067)
@@ -78,8 +78,8 @@
// Get the tile row index and convert to integer
m_tileRow = MgUtil::StringToInt32(params->GetParameterValue(MgHttpResourceStrings::reqRenderingTileRow));
- // Get the scale and convert to double
- m_scale = MgUtil::StringToDouble(params->GetParameterValue(MgHttpResourceStrings::reqRenderingScaleIndex));
+ // Get the scale index and convert to integer
+ m_scaleIndex = MgUtil::StringToInt32(params->GetParameterValue(MgHttpResourceStrings::reqRenderingScaleIndex));
else
@@ -140,7 +140,7 @@
Ptr<MgTileService> service = (MgTileService*)(CreateService(MgServiceType::TileService));
// Call the C++ API
- Ptr<MgByteReader> tileImage = service->GetTile(resId, m_baseMapLayerGroupName, m_tileCol, m_tileRow, m_scale);
+ Ptr<MgByteReader> tileImage = service->GetTile(resId, m_baseMapLayerGroupName, m_tileCol, m_tileRow, m_scaleIndex);
// Set the result
hResult->SetResultObject(tileImage, tileImage->GetMimeType());
Modified: trunk/MgDev/Web/src/HttpHandler/HttpGetTileImage.h
--- trunk/MgDev/Web/src/HttpHandler/HttpGetTileImage.h 2007-01-23 00:03:19 UTC (rev 1066)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetTileImage.h 2007-01-24 00:02:10 UTC (rev 1067)
@@ -65,7 +65,7 @@
INT32 m_tileCol;
INT32 m_tileRow;
STRING m_version;
- double m_scale;
+ INT32 m_scaleIndex;
#endif // _FS_GET_TILE_IMAGE_H
Modified: trunk/MgDev/Web/src/HttpHandler/OgcFramework.h
--- trunk/MgDev/Web/src/HttpHandler/OgcFramework.h 2007-01-23 00:03:19 UTC (rev 1066)
+++ trunk/MgDev/Web/src/HttpHandler/OgcFramework.h 2007-01-24 00:02:10 UTC (rev 1067)
@@ -138,10 +138,10 @@
extern CPSZ kpszAttributeRequest ;// = _("request");
extern CPSZ kpszAttributeVersion ;// = _("version");
-extern CPSZ kpszAttrValueWms ;// = _("WMS");
+//extern CPSZ kpszAttrValueWms ;// = _("WMS");
extern CPSZ kpszElementDefinitions ;// = _("Definitions");
-extern CPSZ kpszAttributeFor ;// = _("for");
+//extern CPSZ kpszAttributeFor ;// = _("for");
extern CPSZ kpszElementDefine ;// = _("Define");
extern CPSZ kpszAttributeItem ;// = _("item");
@@ -164,6 +164,6 @@
extern CPSZ kpszEmpty ;// = _("");
extern CPSZ kpszDefaultExceptionTemplate ;// = _("Server Exception:\nType: &Exception.Type;\nMessage: &Exception.Message;\n");
-extern CPSZ kpszFilenameGlobalConfig ;// = _("OgcWmsService.config");
+//extern CPSZ kpszFilenameGlobalConfig ;// = _("OgcWmsService.config");
#endif//_OgcFramework_h
More information about the mapguide-commits
