[mapguide-commits] r1185 - in trunk/MgDev: Common/MdfModel
Common/MdfParser Common/Schema Common/Stylization
Server/src/Services/Kml
svn_mapguide at osgeo.org
Thu Mar 8 17:58:20 EST 2007
Author: chrisclaydon
Date: 2007-03-08 17:58:19 -0500 (Thu, 08 Mar 2007)
New Revision: 1185
trunk/MgDev/Common/MdfModel/Stroke.cpp
trunk/MgDev/Common/MdfModel/Stroke.h
trunk/MgDev/Common/MdfParser/IOStroke.cpp
trunk/MgDev/Common/Schema/LayerDefinition-1.1.0.xsd
trunk/MgDev/Common/Stylization/DWFRenderer.cpp
trunk/MgDev/Common/Stylization/GDRenderer.cpp
trunk/MgDev/Common/Stylization/GeometryAdapter.cpp
trunk/MgDev/Common/Stylization/KmlRenderer.cpp
trunk/MgDev/Common/Stylization/KmlRenderer.h
trunk/MgDev/Common/Stylization/RendererStyles.h
trunk/MgDev/Server/src/Services/Kml/ServerKmlService.cpp
RFC17 - Map Space Line Widths
Modified: trunk/MgDev/Common/MdfModel/Stroke.cpp
--- trunk/MgDev/Common/MdfModel/Stroke.cpp 2007-03-08 21:12:48 UTC (rev 1184)
+++ trunk/MgDev/Common/MdfModel/Stroke.cpp 2007-03-08 22:58:19 UTC (rev 1185)
@@ -34,6 +34,7 @@
this->SetLineStyle(L"Solid"); // NOXLATE
this->SetThickness(L"0.0"); // NOXLATE
this->SetColor(L"ff000000"); // NOXLATE
+ this->SetSizeContext(MdfModel::DeviceUnits);
@@ -146,3 +147,21 @@
this->m_strColor = strColor;
+// PURPOSE:
+// PARAMETERS:
+SizeContext Stroke::GetSizeContext() const
+ return this->m_eSizeContext;
+// PURPOSE:
+// PARAMETERS:
+void Stroke::SetSizeContext(SizeContext sizeContext)
+ this->m_eSizeContext = sizeContext;
\ No newline at end of file
Modified: trunk/MgDev/Common/MdfModel/Stroke.h
--- trunk/MgDev/Common/MdfModel/Stroke.h 2007-03-08 21:12:48 UTC (rev 1184)
+++ trunk/MgDev/Common/MdfModel/Stroke.h 2007-03-08 22:58:19 UTC (rev 1185)
@@ -55,6 +55,10 @@
const MdfString& GetColor()const;
void SetColor(const MdfString& strColor);
+ // Property : SizeContext
+ SizeContext GetSizeContext() const;
+ void SetSizeContext(SizeContext sizeContext);
private:
// Data members
Modified: trunk/MgDev/Common/MdfParser/IOStroke.cpp
--- trunk/MgDev/Common/MdfParser/IOStroke.cpp 2007-03-08 21:12:48 UTC (rev 1184)
+++ trunk/MgDev/Common/MdfParser/IOStroke.cpp 2007-03-08 22:58:19 UTC (rev 1185)
@@ -30,6 +30,7 @@
ELEM_MAP_ENTRY(3, Thickness);
ELEM_MAP_ENTRY(4, Color);
ELEM_MAP_ENTRY(5, Unit);
+ELEM_MAP_ENTRY(6, SizeContext);
IOStroke::IOStroke(std::wstring elementName)
@@ -72,17 +73,28 @@
void IOStroke::ElementChars(const wchar_t *ch)
- if (m_currElemName == L"LineStyle") // NOXLATE
+ if (m_currElemName == swLineStyle)
(this->_stroke)->SetLineStyle(ch);
- else if (m_currElemName == L"Thickness") // NOXLATE
+ else if (m_currElemName == swThickness)
(this->_stroke)->SetThickness(ch);
- else if (m_currElemName == L"Color") // NOXLATE
+ else if (m_currElemName == swColor)
(this->_stroke)->SetColor(ch);
- else if (m_currElemName == L"Unit") // NOXLATE
+ else if (m_currElemName == swUnit)
LengthUnit unit = LengthConverter::EnglishToUnit(ch);
this->_stroke->SetUnit(unit);
+ else if (this->m_currElemName == swSizeContext) // NOXLATE
+ if (::wcscmp(ch, L"MappingUnits") == 0) // NOXLATE
+ this->_stroke->SetSizeContext(MdfModel::MappingUnits);
+ else // "DeviceUnits" & default
+ this->_stroke->SetSizeContext(MdfModel::DeviceUnits);
void IOStroke::EndElement(const wchar_t *name, HandlerStack *handlerStack)
@@ -125,7 +137,19 @@
fd << EncodeString(*str);
fd << "</Unit>" << std::endl; // NOXLATE
- // Write any previously found unknown XML
+ //Property: SizeContext
+ fd << tab() << "<SizeContext>"; // NOXLATE
+ if(stroke->GetSizeContext() == MdfModel::MappingUnits)
+ fd << "MappingUnits"; // NOXLATE
+ else
+ fd << "DeviceUnits"; // NOXLATE
+ fd << "</SizeContext>" << std::endl; // NOXLATE
+ // Write any previously found unknown XML
if (!stroke->GetUnknownXml().empty())
fd << toCString(stroke->GetUnknownXml());
Modified: trunk/MgDev/Common/Schema/LayerDefinition-1.1.0.xsd
--- trunk/MgDev/Common/Schema/LayerDefinition-1.1.0.xsd 2007-03-08 21:12:48 UTC (rev 1184)
+++ trunk/MgDev/Common/Schema/LayerDefinition-1.1.0.xsd 2007-03-08 22:58:19 UTC (rev 1185)
@@ -430,6 +430,11 @@
<xs:documentation>Unit of measurement that the thickness is specified in</xs:documentation>
</xs:annotation>
</xs:element>
+ <xs:element name="SizeContext" type="SizeContextType">
+ <xs:annotation>
+ <xs:documentation>Whether the sizes are with respect to the earth or the user's display device.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
<xs:element name="ExtendedData1" type="ExtendedDataType" minOccurs="0"/>
</xs:sequence>
</xs:complexType>
Modified: trunk/MgDev/Common/Stylization/DWFRenderer.cpp
--- trunk/MgDev/Common/Stylization/DWFRenderer.cpp 2007-03-08 21:12:48 UTC (rev 1184)
+++ trunk/MgDev/Common/Stylization/DWFRenderer.cpp 2007-03-08 22:58:19 UTC (rev 1185)
@@ -1586,13 +1586,10 @@
m_w2dFile->desired_rendition().color() = Util_ConvertColor(stroke.color());
- int line_weight = 0;
double thickness = stroke.width();
- //line width is always device space.
- //so convert to equivalent mapping space width
- line_weight = (int)(fabs(thickness) / m_metersPerUnit * m_mapScale * m_scale);
+ //convert thickness to equivalent mapping space width
+ int line_weight = (int)(_MeterToMapSize(stroke.units(), fabs(thickness)) * m_scale);
m_w2dFile->desired_rendition().line_weight() = WT_Line_Weight(line_weight);
Modified: trunk/MgDev/Common/Stylization/GDRenderer.cpp
--- trunk/MgDev/Common/Stylization/GDRenderer.cpp 2007-03-08 21:12:48 UTC (rev 1184)
+++ trunk/MgDev/Common/Stylization/GDRenderer.cpp 2007-03-08 22:58:19 UTC (rev 1185)
@@ -1148,9 +1148,8 @@
- //line width is always device space and units are meters.
- //so convert to equivalent pixel width
- int line_weight = (int)(fabs(thickness) / m_metersPerUnit * m_mapScale * m_scale);
gdImagePtr brush1 = NULL;
@@ -1500,7 +1499,7 @@
RS_Color selLineColor = RS_Color(0, 0, 255, 200);
RS_Color selFillColor = RS_Color(0, 0, 255, 160);
RS_Color selBgColor(0, 0, 0, 0);
- RS_LineStroke selStroke = RS_LineStroke(selLineColor, 0.001, L"Solid");
+ RS_LineStroke selStroke = RS_LineStroke(selLineColor, 0.001, L"Solid", RS_Units_Device);
m_selFill = RS_FillStyle(selStroke, selFillColor, selBgColor, L"Solid");
Modified: trunk/MgDev/Common/Stylization/GeometryAdapter.cpp
--- trunk/MgDev/Common/Stylization/GeometryAdapter.cpp 2007-03-08 21:12:48 UTC (rev 1184)
+++ trunk/MgDev/Common/Stylization/GeometryAdapter.cpp 2007-03-08 22:58:19 UTC (rev 1185)
@@ -310,6 +310,7 @@
bool const1 = ConvertLineThickness(stroke->GetThickness(), val);
rsstroke.width()= MdfModel::LengthConverter::UnitToMeters(stroke->GetUnit(), val);
rsstroke.style() = stroke->GetLineStyle();
+ rsstroke.units() = (stroke->GetSizeContext() == MdfModel::MappingUnits) ? RS_Units_Model : RS_Units_Device;
bool const2 = EvalColor(stroke->GetColor(), rsstroke.color());
return const1 && const2; //if all members are constant, the stroke is constant
Modified: trunk/MgDev/Common/Stylization/KmlRenderer.cpp
--- trunk/MgDev/Common/Stylization/KmlRenderer.cpp 2007-03-08 21:12:48 UTC (rev 1184)
+++ trunk/MgDev/Common/Stylization/KmlRenderer.cpp 2007-03-08 22:58:19 UTC (rev 1185)
@@ -30,20 +30,21 @@
//default constructor
KmlRenderer::KmlRenderer(KmlContent* kmlContent, RS_Bounds& extents,
- double scale, double dpi, int drawOrder) :
+ double scale, double dpi, double metersPerUnit, int drawOrder) :
m_mainContent(kmlContent),
m_kmlContent(kmlContent),
m_styleContent(NULL),
m_featureCount(0),
m_layerInfo(NULL),
m_featureClassInfo(NULL),
- m_scale(scale),
+ m_mapScale(scale),
m_styleId(0),
m_extents(extents),
m_drawOrder(drawOrder),
m_elevation(0),
m_extrude(false),
- m_elevType(RS_ElevationType_RelativeToGround)
+ m_elevType(RS_ElevationType_RelativeToGround),
+ m_metersPerUnit(metersPerUnit)
m_kmlContent = m_mainContent;
m_pixelSize = METERS_PER_INCH / dpi;
@@ -400,7 +401,7 @@
double KmlRenderer::GetMapScale()
- return m_scale;
+ return m_mapScale;
@@ -418,7 +419,7 @@
double KmlRenderer::GetMetersPerUnit()
- return 0;
+ return m_metersPerUnit;
@@ -479,7 +480,7 @@
char buffer[256];
int thisStyleId;
- KmlPolyStyle key(fill.outline().color().abgr(), fill.outline().width() / m_pixelSize, fill.color().abgr());
+ KmlPolyStyle key(fill.outline().color().abgr(), _MeterToPixels(fill.outline().units(), fill.outline().width()), fill.color().abgr());
KmlPolyStyleIdMap::iterator iter = m_polyStyleMap.find(key);
if(iter != m_polyStyleMap.end())
@@ -540,7 +541,7 @@
char buffer[256];
int thisStyleId = 0;
- KmlLineStyle key(lsym.color().abgr(), lsym.width() / m_pixelSize );
+ KmlLineStyle key(lsym.color().abgr(), _MeterToPixels(lsym.units(), lsym.width()));
KmlLineStyleIdMap::iterator iter = m_lineStyleMap.find(key);
if(iter != m_lineStyleMap.end())
@@ -575,7 +576,23 @@
m_kmlContent->WriteString(buffer);
+double KmlRenderer::_MeterToPixels(RS_Units unit, double number)
+ double scale_factor;
+ if (unit == RS_Units_Device) // in meters, fixed size
+ scale_factor = 1.0 / m_pixelSize;
+ else
+ scale_factor = 1.0 / m_mapScale / m_pixelSize;
+ return number * scale_factor;
Modified: trunk/MgDev/Common/Stylization/KmlRenderer.h
--- trunk/MgDev/Common/Stylization/KmlRenderer.h 2007-03-08 21:12:48 UTC (rev 1184)
+++ trunk/MgDev/Common/Stylization/KmlRenderer.h 2007-03-08 22:58:19 UTC (rev 1185)
@@ -43,7 +43,7 @@
public:
STYLIZATION_API KmlRenderer(KmlContent* kmlContent, RS_Bounds& extents,
- double scale, double dpi, int drawOrder);
+ double scale, double dpi, double metersPerUnit, int drawOrder);
STYLIZATION_API ~KmlRenderer();
@@ -135,6 +135,7 @@
void WriteElevationSettings();
void ClearThemes();
void ClearStyles();
+ double _MeterToPixels(RS_Units unit, double number);
RS_Bounds& m_extents;
KmlContent* m_kmlContent;
@@ -143,7 +144,7 @@
int m_featureCount;
RS_LayerUIInfo* m_layerInfo;
RS_FeatureClassInfo* m_featureClassInfo;
- double m_scale;
+ double m_mapScale;
ThemeMap m_themeMap;
int m_styleId;
KmlLineStyleIdMap m_lineStyleMap;
@@ -152,6 +153,7 @@
int m_drawOrder;
double m_elevation;
bool m_extrude;
+ double m_metersPerUnit;
RS_ElevationType m_elevType;
Modified: trunk/MgDev/Common/Stylization/RendererStyles.h
--- trunk/MgDev/Common/Stylization/RendererStyles.h 2007-03-08 21:12:48 UTC (rev 1184)
+++ trunk/MgDev/Common/Stylization/RendererStyles.h 2007-03-08 22:58:19 UTC (rev 1185)
@@ -184,27 +184,32 @@
RS_LineStroke() :
m_color(),
m_width(0.0),
- m_style(L"Solid")
+ m_style(L"Solid"),
+ m_units(RS_Units_Device)
RS_LineStroke(RS_Color& lineColor,
double lineWidth,
- const RS_String& lineStyle)
+ const RS_String& lineStyle,
+ RS_Units units)
m_color = lineColor;
m_width = lineWidth;
m_style = lineStyle;
+ m_units = units;
inline RS_Color & color() { return m_color; }
inline double & width() { return m_width; }
inline RS_String & style() { return m_style; }
+ inline RS_Units & units() { return m_units; }
private:
RS_Color m_color;
double m_width;
RS_String m_style;
+ RS_Units m_units;
Modified: trunk/MgDev/Server/src/Services/Kml/ServerKmlService.cpp
--- trunk/MgDev/Server/src/Services/Kml/ServerKmlService.cpp 2007-03-08 21:12:48 UTC (rev 1184)
+++ trunk/MgDev/Server/src/Services/Kml/ServerKmlService.cpp 2007-03-08 22:58:19 UTC (rev 1185)
@@ -432,6 +432,7 @@
-layer->GetDisplayOrder(),
uig);
Ptr<MgCoordinateSystem> destCs = m_csFactory->Create(GOOGLE_EARTH_WKT);
+ double metersPerUnit = (destCs.p != NULL) ? destCs->ConvertCoordinateSystemUnitsToMeters(1.0) : 1.0;
RS_Bounds bounds(extents->GetLowerLeftCoordinate()->GetX(),
extents->GetLowerLeftCoordinate()->GetY(),
@@ -442,7 +443,7 @@
MdfModel::VectorLayerDefinition* vl = dynamic_cast<MdfModel::VectorLayerDefinition*>(layerDef);
if(vl != NULL)
- KmlRenderer renderer(&kmlContent, bounds, scale, dpi, drawOrder);
+ KmlRenderer renderer(&kmlContent, bounds, scale, dpi, metersPerUnit, drawOrder);
DefaultStylizer stylizer;
stylizer.Initialize(&renderer);
if(m_svcFeature == NULL)
More information about the mapguide-commits
