[mapguide-commits] r1186 - in trunk/MgDev/Common: Geometry
Geometry/CoordinateSystem Geometry/Parse Geometry/Spatial
PlatformBase/MapLayer
svn_mapguide at osgeo.org
Thu Mar 8 19:12:31 EST 2007
Author: waltweltonlair
Date: 2007-03-08 19:12:31 -0500 (Thu, 08 Mar 2007)
New Revision: 1186
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.cpp
trunk/MgDev/Common/Geometry/GeometryUtil.cpp
trunk/MgDev/Common/Geometry/GeosUtil.cpp
trunk/MgDev/Common/Geometry/Parse/ParseAwkt.cpp
trunk/MgDev/Common/Geometry/Parse/ParseAwktUtil.cpp
trunk/MgDev/Common/Geometry/Spatial/SpatialUtility.cpp
trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp
Some smart pointer cleanup.
Silly code:
Ptr<MyClass*> myClass = (MyClass*)NULL;
Better code:
Ptr<MyClass*> myClass;
Silly code:
Ptr<MyClass*> myClass = ...;
return SAFE_ADDREF((MyClass*)myClass);
Better code:
return myClass.Detach();
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.cpp
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.cpp 2007-03-08 22:58:19 UTC (rev 1185)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.cpp 2007-03-09 00:12:31 UTC (rev 1186)
@@ -1086,7 +1086,7 @@
if(coordSysInfo)
// Add the coodinate system properties to the collection
- Ptr<MgProperty> pProperty = (MgProperty*)NULL;
+ Ptr<MgProperty> pProperty;
Ptr<MgPropertyCollection> coordSysProperties = new MgPropertyCollection();
// Coordinate system properties
Modified: trunk/MgDev/Common/Geometry/GeometryUtil.cpp
--- trunk/MgDev/Common/Geometry/GeometryUtil.cpp 2007-03-08 22:58:19 UTC (rev 1185)
+++ trunk/MgDev/Common/Geometry/GeometryUtil.cpp 2007-03-09 00:12:31 UTC (rev 1186)
@@ -116,7 +116,7 @@
MgCurveSegment* MgGeometryUtil::ReadCurveSegment(MgStream* stream, MgCoordinate* startCoord, INT32 dimension)
- Ptr<MgCurveSegment> curveSeg = (MgCurveSegment*)NULL;
+ Ptr<MgCurveSegment> curveSeg;
INT32 type;
((MgStreamReader*)stream)->GetInt32(type);
Modified: trunk/MgDev/Common/Geometry/GeosUtil.cpp
--- trunk/MgDev/Common/Geometry/GeosUtil.cpp 2007-03-08 22:58:19 UTC (rev 1185)
+++ trunk/MgDev/Common/Geometry/GeosUtil.cpp 2007-03-09 00:12:31 UTC (rev 1186)
@@ -45,12 +45,11 @@
bool MgGeosUtil::Contains(MgGeometry* geom1, MgGeometry* geom2)
bool contains = false;
+ PrecisionModel* pm = NULL;
+ GeometryFactory* gf = NULL;
+ Geometry* g1 = NULL;
+ Geometry* g2 = NULL;
- PrecisionModel* pm = (PrecisionModel*)NULL;
- GeometryFactory* gf =(GeometryFactory*)NULL;
- Geometry* g1 = (Geometry*)NULL;
- Geometry* g2 = (Geometry*)NULL;
MG_GEOMETRY_TRY()
pm = new PrecisionModel();
@@ -83,10 +82,10 @@
bool MgGeosUtil::Intersects(MgGeometry* geom1, MgGeometry* geom2)
bool intersects = false;
MG_GEOMETRY_TRY()
@@ -120,10 +119,10 @@
bool MgGeosUtil::Crosses(MgGeometry* geom1, MgGeometry* geom2)
bool crosses = false;
MG_GEOMETRY_TRY()
@@ -157,10 +156,10 @@
bool MgGeosUtil::Disjoint(MgGeometry* geom1, MgGeometry* geom2)
bool disjoint = false;
MG_GEOMETRY_TRY()
@@ -194,12 +193,11 @@
bool MgGeosUtil::Equals(MgGeometry* geom1, MgGeometry* geom2)
bool equals = false;
MG_GEOMETRY_TRY()
@@ -232,10 +230,10 @@
bool MgGeosUtil::Overlaps(MgGeometry* geom1, MgGeometry* geom2)
bool overlaps = false;
MG_GEOMETRY_TRY()
@@ -269,12 +267,11 @@
bool MgGeosUtil::Touches(MgGeometry* geom1, MgGeometry* geom2)
bool touches = false;
MG_GEOMETRY_TRY()
@@ -307,12 +304,11 @@
bool MgGeosUtil::Within(MgGeometry* geom1, MgGeometry* geom2)
bool within = false;
MG_GEOMETRY_TRY()
@@ -344,13 +340,12 @@
MgGeometry* MgGeosUtil::Boundary(MgGeometry* geom1)
- Ptr<MgGeometry> bndGeom = (MgGeometry*)NULL;
+ Ptr<MgGeometry> bndGeom;
+ Geometry* g3 = NULL;
- Geometry* g3 = (Geometry*)NULL;
MG_GEOMETRY_TRY()
@@ -386,13 +381,12 @@
MgGeometry* MgGeosUtil::ConvexHull(MgGeometry* geom1)
- Ptr<MgGeometry> convexHull = (MgGeometry*)NULL;
+ Ptr<MgGeometry> convexHull;
MG_GEOMETRY_TRY()
@@ -428,12 +422,12 @@
MgGeometry* MgGeosUtil::Difference(MgGeometry* geom1, MgGeometry* geom2)
- Ptr<MgGeometry> difference = (MgGeometry*)NULL;
+ Ptr<MgGeometry> difference;
MG_GEOMETRY_TRY()
@@ -477,10 +471,10 @@
double MgGeosUtil::Distance(MgGeometry* geom1, MgGeometry* geom2)
double distance = 0.0;
MG_GEOMETRY_TRY()
@@ -513,12 +507,12 @@
MgGeometry* MgGeosUtil::Intersection(MgGeometry* geom1, MgGeometry* geom2)
- Ptr<MgGeometry> intersection = (MgGeometry*)NULL;
+ Ptr<MgGeometry> intersection;
MG_GEOMETRY_TRY()
@@ -560,14 +554,13 @@
MgGeometry* MgGeosUtil::SymetricDifference(MgGeometry* geom1, MgGeometry* geom2)
- Ptr<MgGeometry> symetricDifference = (MgGeometry*)NULL;
+ Ptr<MgGeometry> symetricDifference;
MG_GEOMETRY_TRY()
@@ -608,14 +601,13 @@
MgGeometry* MgGeosUtil::Union(MgGeometry* geom1, MgGeometry* geom2)
- Ptr<MgGeometry> unionGeom = (MgGeometry*)NULL;
+ Ptr<MgGeometry> unionGeom;
MG_GEOMETRY_TRY()
@@ -657,11 +649,10 @@
bool MgGeosUtil::IsValid(MgGeometricEntity* geom1)
bool isValid = false;
MG_GEOMETRY_TRY()
@@ -687,11 +678,10 @@
bool MgGeosUtil::IsSimple(MgGeometricEntity* geom1)
bool isSimple = false;
MG_GEOMETRY_TRY()
@@ -717,11 +707,10 @@
bool MgGeosUtil::IsEmpty(MgGeometricEntity* geom1)
bool isEmpty = false;
MG_GEOMETRY_TRY()
@@ -747,11 +736,10 @@
bool MgGeosUtil::IsClosed(MgGeometricEntity* geom1)
bool isClosed = false;
MG_GEOMETRY_TRY()
@@ -777,11 +765,10 @@
double MgGeosUtil::Area(MgGeometricEntity* geom1)
double area = 0.0;
MG_GEOMETRY_TRY()
@@ -807,11 +794,10 @@
double MgGeosUtil::Length(MgGeometricEntity* geom1)
double length = 0.0;
MG_GEOMETRY_TRY()
@@ -836,13 +822,12 @@
MgPoint* MgGeosUtil::Centroid(MgGeometricEntity* geom1)
- Ptr<MgPoint> point = (MgPoint*)NULL;
+ Ptr<MgPoint> point;
+ Point* g2 = NULL;
- Point* g2 = (Point*)NULL;
MG_GEOMETRY_TRY()
@@ -875,13 +860,12 @@
MgPoint* MgGeosUtil::GetPointInRegion(MgGeometry* geom1)
+ Point* g2 = NULL;
MG_GEOMETRY_TRY()
@@ -914,13 +898,12 @@
MgPoint* MgGeosUtil::GetPointInRing(MgGeometryComponent* geom1)
+ Point* g2 = NULL;
MG_GEOMETRY_TRY()
Modified: trunk/MgDev/Common/Geometry/Parse/ParseAwkt.cpp
--- trunk/MgDev/Common/Geometry/Parse/ParseAwkt.cpp 2007-03-08 22:58:19 UTC (rev 1185)
+++ trunk/MgDev/Common/Geometry/Parse/ParseAwkt.cpp 2007-03-09 00:12:31 UTC (rev 1186)
@@ -89,15 +89,15 @@
__LINE__, __WFILE__, &arguments, L"MgInvalidAgfText", NULL);
- return SAFE_ADDREF((MgGeometry*)m_geometry);
+ return SAFE_ADDREF(m_geometry.p);
// count how many of the same type, starting at iContext and counting it
// but don't move iContext forward (call by value)
INT32 MgParseAwkt::CountSame(INT32 iContext, _types type)
- INT32 iResult = 0;
- INT32 countContext = m_types->GetCount();
+ INT32 iResult = 0;
+ INT32 countContext = m_types->GetCount();
while (iContext < countContext && (*m_types)[iContext] == type)
iResult++;
@@ -108,22 +108,19 @@
MgPoint* MgParseAwkt::DoPoint(INT32& iContext, double* doubles)
- Ptr<MgPoint> geom = (MgPoint*)NULL;
_dims dim = (_dims) (*m_dims)[iContext];
INT32 index = 0;
- geom = MgParseAwktUtil::CreatePoint(DimToDimensionality(dim), &doubles[(*m_starts)[iContext]], index);
+ Ptr<MgPoint> geom = MgParseAwktUtil::CreatePoint(DimToDimensionality(dim), &doubles[(*m_starts)[iContext]], index);
iContext++;
- return SAFE_ADDREF((MgPoint*)geom);
+ return geom.Detach();
MgLineString* MgParseAwkt::DoLineString(INT32& iContext, double* doubles, _types type)
// line strings can have multiple context entries and corresponding n-values per point
MgGeometryFactory factory;
- Ptr<MgLineString> geom = (MgLineString*)NULL;
@@ -131,20 +128,17 @@
INT32 countValues = countSame*DimToCount(dim);
INT32 index = 0;
- geom = MgParseAwktUtil::CreateLineString(DimToDimensionality(dim), countSame, &doubles[(*m_starts)[iContext]], index);
+ Ptr<MgLineString> geom = MgParseAwktUtil::CreateLineString(DimToDimensionality(dim),
+ countSame, &doubles[(*m_starts)[iContext]], index);
iContext += countSame;
- return SAFE_ADDREF((MgLineString*)geom);
MgPolygon* MgParseAwkt::DoPolygon(INT32& iContext, double* doubles, _types type)
// polygons have 1 exterior ring and 0 or more interior rings
- Ptr<MgPolygon> geom = (MgPolygon*)NULL;
- Ptr<MgLinearRing> extRing = (MgLinearRing*)NULL;
- Ptr<MgLinearRingCollection> intRings = (MgLinearRingCollection*)NULL;
@@ -153,13 +147,13 @@
INT32 index = 0;
- extRing = MgParseAwktUtil::CreateLinearRing(DimToDimensionality(dim),
+ Ptr<MgLinearRing> extRing = MgParseAwktUtil::CreateLinearRing(DimToDimensionality(dim),
// interior ring
- intRings = new MgLinearRingCollection();
+ Ptr<MgLinearRingCollection> intRings = new MgLinearRingCollection();
while (iContext < m_types->GetCount() && (*m_types)[iContext] == -type)
(*m_types)[iContext] = type;
@@ -171,29 +165,24 @@
if (intRing != NULL)
intRings->Add(intRing);
- geom = factory.CreatePolygon(extRing, intRings);
+ Ptr<MgPolygon> geom = factory.CreatePolygon(extRing, intRings);
- return SAFE_ADDREF((MgPolygon*)geom);
MgMultiPoint* MgParseAwkt::DoMultiPoint(INT32& iContext, double* doubles)
+ Ptr<MgPointCollection> pnts = new MgPointCollection();
- Ptr<MgMultiPoint> geom = (MgMultiPoint*)NULL;
- Ptr<MgPointCollection> pnts = (MgPointCollection*)NULL;
// there can be n-context entries for each point
- pnts = new MgPointCollection();
INT32 countContext = CountSame(iContext, kMultiPoint);
for (int i=0; i < countContext; i++)
@@ -204,32 +193,25 @@
INT32 index = 0;
Ptr<MgPoint> pnt = MgParseAwktUtil::CreatePoint(DimToDimensionality(dim), &doubles[(*m_starts)[iContext]], index);
if (pnt != NULL)
pnts->Add(pnt);
iContext++;
- geom = factory.CreateMultiPoint(pnts);
+ Ptr<MgMultiPoint> geom = factory.CreateMultiPoint(pnts);
- return SAFE_ADDREF((MgMultiPoint*)geom);
MgMultiLineString* MgParseAwkt::DoMultiLineString(INT32& iContext, double* doubles)
- Ptr<MgMultiLineString> geom = (MgMultiLineString*)NULL;
Ptr<MgLineStringCollection> lineStrings = new MgLineStringCollection();
Ptr<MgLineString> lineString = (MgLineString*)DoLineString(iContext, doubles, kMultiLineString);
if (lineString != NULL)
lineStrings->Add(lineString);
while (iContext < m_types->GetCount() && (*m_types)[iContext] == -kMultiLineString)
@@ -241,25 +223,21 @@
- geom = factory.CreateMultiLineString(lineStrings);
+ Ptr<MgMultiLineString> geom = factory.CreateMultiLineString(lineStrings);
- return SAFE_ADDREF((MgMultiLineString*)geom);
MgMultiPolygon* MgParseAwkt::DoMultiPolygon(INT32& iContext, double* doubles)
- Ptr<MgMultiPolygon> geom = (MgMultiPolygon*)NULL;
Ptr<MgPolygonCollection> polygons = new MgPolygonCollection();
Ptr<MgPolygon> polygon = DoPolygon(iContext, doubles, kMultiPolygon);
if (polygon != NULL)
polygons->Add(polygon);
while (iContext < m_types->GetCount() && (*m_types)[iContext] == kRing)
@@ -267,20 +245,17 @@
iContext++;
Ptr<MgPolygon> polygon1 = DoPolygon(iContext, doubles, kMultiPolygon);
if (polygon1 != NULL)
polygons->Add(polygon1);
- geom = factory.CreateMultiPolygon(polygons);
+ Ptr<MgMultiPolygon> geom = factory.CreateMultiPolygon(polygons);
- return SAFE_ADDREF((MgMultiPolygon*)geom);
MgCurveSegmentCollection* MgParseAwkt::DoCurveSegmentCollection(INT32& iContext, double* doubles)
Ptr<MgCurveSegmentCollection> segs = new MgCurveSegmentCollection();
@@ -319,8 +294,8 @@
else if (typeSegment == kLineStringSegment)
- INT32 countSame = CountSame(iContext, kLineStringSegment);
- INT32 countValues = countSame*DimToCount(dim);
+ INT32 countSame = CountSame(iContext, kLineStringSegment);
+ INT32 countValues = countSame*DimToCount(dim);
//Ptr<MgLinearSegment> linearSeg = m_gf->CreateLineStringSegment(DimToDimensionality(dim),
// countValues+DimToCount(dim), &doubles[(*m_starts)[iContext-1]]);
@@ -336,37 +311,29 @@
break;
- return SAFE_ADDREF((MgCurveSegmentCollection*)segs);
+ return segs.Detach();
MgCurveString* MgParseAwkt::DoCurveString(INT32& iContext, double* doubles)
- Ptr<MgCurveSegmentCollection> segs = (MgCurveSegmentCollection*)NULL;
- Ptr<MgCurveString> geom = (MgCurveString*)NULL;
+ Ptr<MgCurveSegmentCollection> segs = DoCurveSegmentCollection(iContext, doubles);
+ Ptr<MgCurveString> geom = factory.CreateCurveString(segs);
- segs = DoCurveSegmentCollection(iContext, doubles);
- geom = factory.CreateCurveString(segs);
- return SAFE_ADDREF((MgCurveString*)geom);
MgCurvePolygon* MgParseAwkt::DoCurvePolygon(INT32& iContext, double* doubles)
- Ptr<MgCurvePolygon> geom = (MgCurvePolygon*)NULL;
- Ptr<MgCurveSegmentCollection> extSegs = (MgCurveSegmentCollection*)NULL;
- Ptr<MgCurveRing> extRing = (MgCurveRing*)NULL;
Ptr<MgCurveRingCollection> intRings = new MgCurveRingCollection();
// exterior ring
- extSegs = DoCurveSegmentCollection(iContext, doubles);
- extRing = factory.CreateCurveRing(extSegs);
+ Ptr<MgCurveSegmentCollection> extSegs = DoCurveSegmentCollection(iContext, doubles);
+ Ptr<MgCurveRing> extRing = factory.CreateCurveRing(extSegs);
// interior rings
_types typeSegment;
@@ -384,30 +351,26 @@
Ptr<MgCurveRing> intRing = factory.CreateCurveRing(intSegs);
- geom = factory.CreateCurvePolygon(extRing, intRings);
+ Ptr<MgCurvePolygon> geom = factory.CreateCurvePolygon(extRing, intRings);
- return SAFE_ADDREF((MgCurvePolygon*)geom);
MgMultiCurveString* MgParseAwkt::DoMultiCurveString(INT32& iContext, double* doubles)
- Ptr<MgMultiCurveString> geom = (MgMultiCurveString*)NULL;
Ptr<MgCurveStringCollection> curveStrings = new MgCurveStringCollection();
Ptr<MgCurveString> curveString = (MgCurveString*)DoCurveString(iContext, doubles);
if (curveString != NULL)
curveStrings->Add(curveString);
_types typeSegment;
while (iContext < m_types->GetCount())
@@ -419,30 +382,25 @@
(*m_types)[iContext] = -typeSegment;
Ptr<MgCurveString> curveString1 = DoCurveString(iContext, doubles);
if (curveString1 != NULL)
curveStrings->Add(curveString1);
- geom = factory.CreateMultiCurveString(curveStrings);
+ Ptr<MgMultiCurveString> geom = factory.CreateMultiCurveString(curveStrings);
- return SAFE_ADDREF((MgMultiCurveString*)geom);
MgMultiCurvePolygon* MgParseAwkt::DoMultiCurvePolygon(INT32& iContext, double* doubles)
- Ptr<MgMultiCurvePolygon> geom = (MgMultiCurvePolygon*)NULL;
Ptr<MgCurvePolygonCollection> polygons = new MgCurvePolygonCollection();
Ptr<MgCurvePolygon> polygon = DoCurvePolygon(iContext, doubles);
_types typeSegment;
@@ -455,30 +413,27 @@
iContext++;
Ptr<MgCurvePolygon> polygon1 = DoCurvePolygon(iContext, doubles);
- geom = factory.CreateMultiCurvePolygon(polygons);
- return SAFE_ADDREF((MgMultiCurvePolygon*)geom);
+ Ptr<MgMultiCurvePolygon> geom = factory.CreateMultiCurvePolygon(polygons);
MgGeometry* MgParseAwkt::DoGeometryCollection(INT32 iContextStart, bool bCollect)
_types type = kNone;
- Ptr<MgGeometry> geom = (MgGeometry*)NULL;
- Ptr<MgGeometryCollection> geomCollection = (MgGeometryCollection*)NULL;
+ Ptr<MgGeometry> geom;
+ Ptr<MgGeometryCollection> geomCollection;
// take the value and try to constuct the geometry
double* doubles = m_values->GetData();
if (bCollect)
geomCollection = new MgGeometryCollection();
INT32 iCurrent = iContextStart;
@@ -537,7 +492,6 @@
return NULL;
if (geom == NULL)
// some error occured constructing geometry so give up
@@ -555,12 +509,10 @@
Ptr<MgMultiGeometry> multiGeom = factory.CreateMultiGeometry(geomCollection);
- return SAFE_ADDREF((MgMultiGeometry*)multiGeom);
+ return multiGeom.Detach();
- else
- return SAFE_ADDREF((MgGeometry*)geom);
void MgParseAwkt::Done()
@@ -586,9 +538,9 @@
throw new MgInvalidArgumentException(L"MgParseAwkt.ParseAwkt", __LINE__, __WFILE__, NULL, L"", NULL);
- _types type = (_types) (*m_types)[0];
- bool bMultiGeometry = type == kMultiGeometry;
- INT32 iContextStart = 0;
+ _types type = (_types) (*m_types)[0];
+ bool bMultiGeometry = type == kMultiGeometry;
+ INT32 iContextStart = 0;
if (bMultiGeometry)
iContextStart++;
Modified: trunk/MgDev/Common/Geometry/Parse/ParseAwktUtil.cpp
--- trunk/MgDev/Common/Geometry/Parse/ParseAwktUtil.cpp 2007-03-08 22:58:19 UTC (rev 1185)
+++ trunk/MgDev/Common/Geometry/Parse/ParseAwktUtil.cpp 2007-03-09 00:12:31 UTC (rev 1186)
@@ -22,7 +22,7 @@
MgCoordinate* MgParseAwktUtil::CreateCoordinate(INT32 dimension, double* doubles, INT32& index)
- Ptr<MgCoordinate> coord = (MgCoordinate*)NULL;
+ Ptr<MgCoordinate> coord;
switch(dimension)
@@ -52,7 +52,7 @@
- return SAFE_ADDREF((MgCoordinate*)coord);
+ return coord.Detach();
MgCoordinateCollection* MgParseAwktUtil::CreateCoordinateCollection(INT32 dimensionType, INT32 numOfCoordinates, double* ordinates, INT32& index)
@@ -73,7 +73,7 @@
coordCol->Add(coord);
- return SAFE_ADDREF((MgCoordinateCollection*)coordCol);
+ return coordCol.Detach();
MgPoint* MgParseAwktUtil::CreatePoint(INT32 dimension, double* doubles, INT32& index)
Modified: trunk/MgDev/Common/Geometry/Spatial/SpatialUtility.cpp
--- trunk/MgDev/Common/Geometry/Spatial/SpatialUtility.cpp 2007-03-08 22:58:19 UTC (rev 1185)
+++ trunk/MgDev/Common/Geometry/Spatial/SpatialUtility.cpp 2007-03-09 00:12:31 UTC (rev 1186)
@@ -324,9 +324,7 @@
bool zIsNan = ( MgMathUtility::IsNan(z1) || MgMathUtility::IsNan(z2) );
double dz = ( zIsNan ? 0.0 : z2 - z1 );
- double distance = sqrt (dx*dx + dy*dy + dz*dz);
- return distance;
+ return sqrt(dx*dx + dy*dy + dz*dz);
@@ -483,7 +481,7 @@
CHECKNULL(curve, L"MgSpatialUtility.TesselateCurve")
- Ptr<MgGeometryComponent> retGeomComp = (MgGeometryComponent*)NULL;
+ Ptr<MgGeometryComponent> retGeomComp;
Ptr<MgEnvelope> env = curve->Envelope();
double maxdim = max(env->GetWidth(), env->GetHeight());
@@ -514,5 +512,5 @@
- return SAFE_ADDREF((MgGeometryComponent*)retGeomComp);
+ return retGeomComp.Detach();
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp
--- trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp 2007-03-08 22:58:19 UTC (rev 1185)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp 2007-03-09 00:12:31 UTC (rev 1186)
@@ -636,7 +636,7 @@
CHECKNULL((MgFeatureService*)featureService, L"MgSelection.GetExtents");
- Ptr<MgEnvelope> env = (MgEnvelope*)NULL;
+ Ptr<MgEnvelope> env;
Ptr<MgReadOnlyLayerCollection> roLayerCol = this->GetLayers();
if (roLayerCol != NULL)
@@ -658,11 +658,11 @@
else
- env = SAFE_ADDREF((MgEnvelope*)clsEnv);
+ env = clsEnv.Detach();
- return SAFE_ADDREF((MgEnvelope*)env);
+ return env.Detach();
@@ -682,8 +682,8 @@
Ptr<MgResourceIdentifier> featureResId = new MgResourceIdentifier(resId);
Ptr<MgDataReader> geomDataReader = featureService->SelectAggregate(featureResId, clsName, geomQryOptions);
- Ptr<MgGeometry> geomFilter = (MgGeometry*)NULL;
+ Ptr<MgGeometry> geomFilter;
while (geomDataReader->ReadNext())
Ptr<MgByteReader> byteReader = geomDataReader->GetGeometry(L"EXTENT_PROP");
@@ -693,7 +693,7 @@
Ptr<MgEnvelope> geomExtn = geom->Envelope();
if (env == NULL)
- env = SAFE_ADDREF((MgEnvelope*)geomExtn);
+ env = geomExtn.Detach();
else
@@ -705,7 +705,7 @@
geomDataReader->Close();
More information about the mapguide-commits
