[mapguide-commits] r1219 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Wed Mar 14 11:35:17 EDT 2007
Author: traianstanev
Date: 2007-03-14 11:35:17 -0400 (Wed, 14 Mar 2007)
New Revision: 1219
trunk/MgDev/Common/Stylization/SE_Renderer.cpp
Added logic to detect simple solid lines defined in SymbolDefinitions. If a style is just a solid line, it will skip the line style layout and draw the entire feature using a direct line draw call.
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
--- trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-14 11:23:33 UTC (rev 1218)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-14 15:35:17 UTC (rev 1219)
@@ -82,6 +82,37 @@
void SE_Renderer::ProcessLine(LineBuffer* geometry, SE_RenderLineStyle* style)
+ //determine if the style is a simple straight solid line
+ SE_RenderSymbol& rs = style->symbol;
+ //check if it is a single symbol that is not a label participant
+ if (rs.size() == 1
+ && rs[0]->type == SE_PolylinePrimitive
+ && !style->drawLast
+ && !style->addToExclusionRegions)
+ SE_RenderPolyline* rp = (SE_RenderPolyline*)rs[0];
+ LineBuffer* lb = rp->geometry->xf_buffer();
+ //check if it is a horizontal line
+ if (lb->point_count() == 2
+ && lb->points()[1] == 0.0
+ && lb->points()[3] == 0.0)
+ //now make sure it is not a dashed line by comparing the
+ //single segment to the symbol repeat
+ double len = lb->points()[2] - lb->points()[0];
+ if (fabs(len - style->repeat) < 0.001) //repeat must be within 1/100 of a pixel for us to assume solid line
+ //ok, it's only a solid line, just draw it and bail out of the
+ //layout function
+ DrawScreenPolyline(geometry, rp->color, rp->weight);
+ return;
SE_Matrix symxf;
int ptindex = 0;
More information about the mapguide-commits
