[mapguide-commits] r1220 - in trunk/MgDev/Oem/ACE/ACE_wrappers: . ACEXML ACEXML/apps ACEXML/apps/svcconf ACEXML/common ACEXML/docs ACEXML/examples ACEXML/examples/SAXPrint ACEXML/parser ACEXML/parser/debug_validator ACEXML/parser/parser ACEXML/tests Kokyu Kokyu/docs Kokyu/tests/DSRT_MIF Kokyu/tests/EDF Kokyu/tests/FIFO ace ace/RMCast apps apps/FaCE apps/Gateway apps/Gateway/Gateway apps/Gateway/Peer apps/JAWS apps/JAWS/clients apps/JAWS/clients/Blobby apps/JAWS/clients/Caching apps/JAWS/clients/WebSTONE apps/JAWS/clients/WebSTONE/bin apps/JAWS/clients/WebSTONE/conf apps/JAWS/clients/WebSTONE/doc apps/JAWS/clients/WebSTONE/src apps/JAWS/clients/WebSTONE/src/client apps/JAWS/clients/WebSTONE/src/gendata apps/JAWS/clients/WebSTONE/src/master apps/JAWS/clients/WebSTONE/src/nsapi-includes apps/JAWS/clients/WebSTONE/src/nsapi-includes/base apps/JAWS/clients/WebSTONE/src/nsapi-includes/frame apps/JAWS/server apps/JAWS/stress_testing apps/JAWS2 apps/JAWS2/HTTPU apps/JAWS2/JAWS apps/JAWS3 apps/JAWS3/bench apps/JAWS3/contrib/jmills_at_tga_dot_com apps/JAWS3/contrib/john_at_lyris_dot_com apps/JAWS3/docs/web apps/JAWS3/docs/web/images apps/JAWS3/http apps/JAWS3/jaws3 apps/JAWS3/jaws3-todo apps/JAWS3/small apps/drwho apps/gperf apps/gperf/src apps/gperf/tests apps/mkcsregdb apps/soreduce netsvcs netsvcs/clients netsvcs/clients/Logger netsvcs/clients/Naming netsvcs/clients/Naming/Client netsvcs/clients/Naming/Dump_Restore netsvcs/clients/Tokens netsvcs/clients/Tokens/collection netsvcs/clients/Tokens/deadlock netsvcs/clients/Tokens/invariant netsvcs/clients/Tokens/manual netsvcs/clients/Tokens/mutex netsvcs/clients/Tokens/rw_lock netsvcs/lib netsvcs/servers websvcs websvcs/lib websvcs/tests
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Mar 14 12:25:30 EDT 2007
Author: trevorwekel
Date: 2007-03-14 12:25:26 -0400 (Wed, 14 Mar 2007)
New Revision: 1220
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/ACEXML.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/ChangeLog
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/XML_Apps.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/ACEXML_XML_Svc_Conf_Parser.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Makefile.ACEXML_XML_Svc_Conf_Parser
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Makefile.ACEXML_XML_Svc_Conf_Parser.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf_Handler.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/svcconf.dtd
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/svcconf.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ACEXML.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ACEXML_Export.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Attributes.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/AttributesImpl.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/AttributesImpl.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/AttributesImpl.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Attributes_Def_Builder.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Attributes_Def_Builder.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/CharStream.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/CharStream.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ContentHandler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DTDHandler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DTD_Manager.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DTD_Manager.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DefaultHandler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DefaultHandler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DefaultHandler.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Element_Def_Builder.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Element_Def_Builder.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Encoding.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Encoding.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/EntityResolver.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Env.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Env.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Env.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ErrorHandler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Exception.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Exception.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Exception.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/FileCharStream.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/FileCharStream.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/HttpCharStream.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/HttpCharStream.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/InputSource.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/InputSource.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Locator.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/LocatorImpl.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/LocatorImpl.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/LocatorImpl.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Makefile.ACEXML
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Makefile.ACEXML.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Mem_Map_Stream.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Mem_Map_Stream.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/NamespaceSupport.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/NamespaceSupport.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/NamespaceSupport.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/SAXExceptions.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/SAXExceptions.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/SAXExceptions.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/StrCharStream.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/StrCharStream.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/StreamFactory.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/StreamFactory.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Transcode.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Transcode.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Transcode.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/URL_Addr.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/URL_Addr.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/URL_Addr.inl
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Validator.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Validator.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLFilter.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLFilterImpl.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLFilterImpl.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLFilterImpl.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLReader.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XML_Codecs.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XML_Codecs.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XML_Macros.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XML_Types.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ZipCharStream.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ZipCharStream.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/common.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/TODO.txt
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/bugs.txt
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/guidelines.txt
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/parser_features.txt
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/readme.txt
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Makefile.SAXPrint
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Makefile.SAXPrint.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Print_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Print_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Print_Handler.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint_Handler.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/broken.xml
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/main.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/namespaces.xml
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/ns.svc.conf.xml
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/simple.svcconf.xml
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/svc.conf.xml
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_Attributes_Builder.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_Attributes_Builder.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_DTD_Manager.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_DTD_Manager.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_DTD_Manager_Export.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_Element_Builder.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_Element_Builder.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Element_Tree.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Element_Tree.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Element_Tree.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ACEXML_Parser.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Entity_Manager.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Entity_Manager.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Entity_Manager.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Makefile.ACEXML_Parser
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Makefile.ACEXML_Parser.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserContext.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserContext.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserContext.inl
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserInternals.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserInternals.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser_export.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/parser.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/ContentHandler_Test.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/ContentHandler_Test.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/HttpCharStream_Test.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/HttpCharStream_Test.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.ContentHandler_Test
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.ContentHandler_Test.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.HttpCharStream_Test
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.HttpCharStream_Test.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.NamespaceSupport_Test
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.NamespaceSupport_Test.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.Transcoder_Test
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.Transcoder_Test.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/NamespaceSupport_Test.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/NamespaceSupport_Test.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Tests.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Transcoder_Test.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Transcoder_Test.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/tests.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_CV_Dispatcher_Impl_T.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_CV_Dispatcher_Impl_T.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Direct_Dispatcher_Impl_T.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Direct_Dispatcher_Impl_T.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatch_Item_T.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatch_Item_T.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatch_Item_T.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatcher_Impl_T.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatcher_Impl_T.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatcher_Impl_T.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Sched_Queue_T.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Sched_Queue_T.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Default_Dispatcher_Impl.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Default_Dispatcher_Impl.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Default_Dispatcher_Impl.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Impl.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Impl.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Impl.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Task.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Task.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Task.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_defs.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_defs.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_defs.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_dsrt.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_dsrt.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_dsrt.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Makefile.Kokyu
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Makefile.Kokyu.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/docs/Kokyu.html
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/kokyu_export.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/DSRT_MIF.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/MIF.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/MIF.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/MIF.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/svc.conf
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/svc.conf.xml
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/EDF.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/EDF.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/EDF.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/test.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/FIFO.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/FIFO.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/FIFO.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/test.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/Global_Macros.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/Makefile.in
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.rc
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.vcp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.vcproj
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Ack_Worker.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Ack_Worker.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Ack_Worker.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Copy_On_Write.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Copy_On_Write.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Copy_On_Write.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Export.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fork.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fork.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fork.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fragment.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fragment.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fragment.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_IO_UDP.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_IO_UDP.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_IO_UDP.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Membership.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Membership.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Membership.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module_Factory.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module_Factory.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module_Factory.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Partial_Message.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Partial_Message.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Partial_Message.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Proxy.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Proxy.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Proxy.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reassembly.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reassembly.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reassembly.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Receiver_Module.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Receiver_Module.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Receiver_Module.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reliable_Factory.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reliable_Factory.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reliable_Factory.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reordering.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reordering.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reordering.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Handler.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Worker.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Worker.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Worker.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Retransmission.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Retransmission.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Retransmission.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Sequencer.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Sequencer.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Sequencer.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Singleton_Factory.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Singleton_Factory.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Singleton_Factory.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Event_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Event_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Event_Handler.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Proxy.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Proxy.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Proxy.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Receiver.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Receiver.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Receiver.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Sender.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Sender.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Sender.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Worker.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Worker.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Worker.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/rmcast.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/CE_ARGV.CPP
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/CE_ARGV.H
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/CE_Screen_Output.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/CE_Screen_Output.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.rc
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.vcp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.vcw
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCENOACE.vcp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCENOACE.vcw
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE_OS.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/License.txt
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/Main.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/ReadMe.txt
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/newres.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/resource.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Concrete_Connection_Handlers.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Concrete_Connection_Handlers.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Config_Files.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Config_Files.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler_Acceptor.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler_Acceptor.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler_Connector.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler_Connector.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Consumer_Dispatch_Set.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event_Channel.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event_Channel.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event_Forwarding_Discriminator.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event_Forwarding_Discriminator.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/File_Parser.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/File_Parser.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Gateway.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Gateway.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Gateway.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Gateway.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Options.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Options.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/connection_config
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/consumer_config
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/gateway.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/gatewayd.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/gatewayd.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/svc.conf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/Options.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/Options.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/Peer.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/Peer.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/Peer.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/Peer.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/peerd.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/peerd.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/svc.conf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/ChangeLog
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Blobby/Blob.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Blobby/Blob.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Blobby/Blob_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Blobby/Blob_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Blobby/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Blobby/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Blobby/Options.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Blobby/Options.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Blobby/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Blobby/blobby.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Blobby/blobby.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/Caching.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/Caching.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/ID_Generator.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/ID_Generator.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/Local_Locator.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/Local_Locator.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/Local_Locator.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/Locator_Request_Reply.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/Locator_Request_Reply.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/Locator_Request_Reply.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/URL_Array_Helper.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/URL_Array_Helper.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/URL_Locator.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/URL_Locator.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/URL_Locator.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/URL_Properties.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/URL_Properties.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/URL_Properties.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/caching.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/http_client.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/http_handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/http_handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Caching/test_URL.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/COPYING
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/README.DynamicWorkload
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/README.FIRST
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/WebStone-common.pl
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/WebStone-manage.pl
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/WebStone-run.pl
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/WebStone-setup.pl
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/checkfilelist
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/genfiles
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/genfiles-from-filelist.sh
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/gui-configure
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/killbench
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/killbench.pl
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/mine-logs.pl
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/move-filelist.pl
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/move-runs.pl
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/rebootall
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/runbench
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/runbench.pl
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/tabs2html
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/view-results.pl
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/webstone-gui.pl
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/write-testbed.pl
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/bin/wscollect.pl
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/conf/filelist
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/conf/filelist.cgi-heavy
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/conf/filelist.dynamic-heavy
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/conf/filelist.dynamic-light
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/conf/filelist.dynamic-medium
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/conf/filelist.homepage
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/conf/filelist.sample
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/conf/filelist.standard
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/conf/fileset
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/conf/paths.pl
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/conf/testbed
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/doc/COPYING
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/doc/FAQ-webstone.html
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/doc/LICENSE.html
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/doc/WebStone.html
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/doc/testbed.help
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/doc/webstone-white-paper.ps
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/doc/webstone2.html
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/acconfig.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/bench.c
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/bench.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/cgi-send.c
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/client/webclient.mak
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/config.cache
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/config.guess
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/config.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/config.h.in
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/config.log
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/config.status
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/config.sub
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/configure
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/configure.in
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/debug.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/errexit.c
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/gendata/genrand.mak
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/genrand.c
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/get.c
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/get.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/getopt.c
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/gettimeofday.c
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/install-sh
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/logfile27859
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/master/webmaster.mak
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/buffer.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/cinfo.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/crit.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/daemon.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/dll.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/ereport.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/eventlog.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/file.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/minissl.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/net.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/nodelock.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/nterrors.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/objndx.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/pblock.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/sem.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/session.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/shexp.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/shmem.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/systems.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/systhr.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/base/util.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/frame/conf.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/frame/dnfilter.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/frame/func.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/frame/http.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/frame/httpact.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/frame/ipfilter.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/frame/log.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/frame/object.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/frame/objset.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/frame/protocol.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/frame/req.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/frame/servact.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-includes/netsite.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/nsapi-send.c
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/parse_file_list.c
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/parse_file_list.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/rexec.c
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/statistics.c
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/statistics.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/sysdep.c
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/sysdep.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/timefunc.c
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/timefunc.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/webclient.c
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/src/webmaster.c
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/clients/WebSTONE/webstone
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/HTTP_Config.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/HTTP_Config.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/HTTP_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/HTTP_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/HTTP_Helpers.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/HTTP_Helpers.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/HTTP_Request.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/HTTP_Request.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/HTTP_Response.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/HTTP_Response.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/HTTP_Server.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/HTTP_Server.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/IO.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/IO.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/JAWS_Concurrency.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/JAWS_Concurrency.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/JAWS_Pipeline.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/JAWS_Pipeline.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/JAWS_Pipeline_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/JAWS_Pipeline_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/Parse_Headers.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/Parse_Headers.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/jaws.auth
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/jaws.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/jaws.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/main.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/server.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/svc.conf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/server/test.cgi
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/stress_testing/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/stress_testing/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/stress_testing/benchd.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/stress_testing/client.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/stress_testing/config
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/stress_testing/connection.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/stress_testing/connection.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/stress_testing/cp.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/stress_testing/cp.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/stress_testing/global.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/stress_testing/http.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/stress_testing/http_tester.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/stress_testing/out
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/stress_testing/stats.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/stress_testing/stats.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/stress_testing/util.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS/stress_testing/util.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/1000K.html
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/100K.html
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/500K.html
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/50K.html
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/5K.html
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/HTTPU.DSP
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/HTTPU.DSW
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/http_base.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/http_base.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/http_base.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/http_export.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/http_headers.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/http_headers.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/http_headers.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/http_request.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/http_request.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/http_request.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/http_response.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/http_response.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/http_response.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/http_status.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/http_status.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/http_status.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/parse_http_request.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/parse_http_request.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/parse_http_request.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/parse_http_response.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/parse_http_response.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/parse_http_response.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/parse_url.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTPU/parse_url.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTP_10.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTP_10.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTP_10_Parse.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTP_10_Read.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTP_10_Request.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTP_10_Request.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTP_10_Write.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTP_Policy.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/HTTP_Policy.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Assoc_Array.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Assoc_Array.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Cache_Hash_T.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Cache_Hash_T.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Cache_Heap_T.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Cache_Heap_T.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Cache_List_T.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Cache_List_T.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Cache_Manager.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Cache_Manager.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Cache_Manager_T.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Cache_Manager_T.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Cache_Object.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Cache_Object.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Concurrency.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Concurrency.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Data_Block.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Data_Block.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Export.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/FILE.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/FILE.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Filecache.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Filecache.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Hash_Bucket_T.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Hash_Bucket_T.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Headers.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Headers.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/IO.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/IO.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/IO_Acceptor.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/IO_Acceptor.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/IO_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/IO_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/JAWS.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Parse_Headers.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Parse_Headers.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Pipeline.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Pipeline.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Pipeline_Handler_T.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Pipeline_Handler_T.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Pipeline_Tasks.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Pipeline_Tasks.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Policy.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Policy.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Reaper.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Reaper.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Server.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Server.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Waiter.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/Waiter.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/jaws.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/JAWS/jaws.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/main.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/server.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS2/server.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/bench/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/bench/average.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/bench/mkfiles.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/bench/rqfiles.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/contrib/jmills_at_tga_dot_com/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/contrib/jmills_at_tga_dot_com/jaws3-msvc.pat
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/contrib/john_at_lyris_dot_com/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/contrib/john_at_lyris_dot_com/jaws3-cntlC.code
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/docs/web/images/jaws3_banner.fig
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/docs/web/images/jaws3_components.fig
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/docs/web/index.html
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/docs/web/overview.html
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/http/HTTP_Data.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/http/HTTP_Service_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/http/HTTP_Service_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/http/HTTP_States.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3-todo/FILE_Cache.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3-todo/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3-todo/Map_Manager.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3-todo/Map_Manager_T.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3-todo/Map_Manager_T.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3-todo/Reactive_Socket.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3-todo/Reactive_Socket.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3-todo/Reactive_Socket_Helpers.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3-todo/Reactive_Socket_Helpers.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3-todo/Socket.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3-todo/Socket.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Asynch_IO.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Asynch_IO.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Asynch_IO_Helpers.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Cached_Allocator_T.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Cached_Allocator_T.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Concurrency.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Concurrency.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Concurrency_T.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Concurrency_T.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Config_File.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Config_File.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Datagram.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Datagram.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Event_Completer.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Event_Completer.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Event_Dispatcher.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Event_Dispatcher.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Event_Result.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Export.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/FILE.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/FILE.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/IO.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/IO.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Options.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Options.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Protocol_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Protocol_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Reactive_IO.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Reactive_IO.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Reactive_IO_Helpers.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Signal_Task.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Signal_Task.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Symbol_Table.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Symbol_Table.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Synch_IO.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Synch_IO.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/THYBRID_Concurrency.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/THYBRID_Concurrency.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/TPOOL_Concurrency.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/TPOOL_Concurrency.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/TPR_Concurrency.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/TPR_Concurrency.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Task_Timer.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Task_Timer.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Templates.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Timer.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Timer.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Timer_Helpers.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/Timer_Helpers.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/jaws.conf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/jaws3.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/jaws3/main.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/SS_Data.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/SS_Data.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/SS_Service_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/SS_Service_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/SS_State_DONE.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/SS_State_DONE.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/SS_State_ERROR.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/SS_State_ERROR.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/SS_State_PARSE.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/SS_State_PARSE.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/SS_State_READ.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/SS_State_READ.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/SS_State_WRITE.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/SS_State_WRITE.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/SS_Templates.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/jaws.conf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/small/svc.conf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/zBUILD
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/zCHANGES
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/zCONTRIB
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/zCOPYING
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/zFAQ
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/zREADME
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/zTHANKS
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/JAWS3/zTODO
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Makefile.in
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/apps.mwc
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/build.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/BS_Client.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/BS_Client.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/BS_Server.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/BS_Server.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Binary_Search.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Binary_Search.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/CM_Client.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/CM_Client.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/CM_Server.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/CM_Server.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/ChangeLog
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Comm_Manager.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Drwho_Node.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Drwho_Node.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/File_Manager.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/File_Manager.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/HT_Client.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/HT_Client.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/HT_Server.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/HT_Server.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Hash_Table.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Hash_Table.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Multicast_Manager.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Multicast_Manager.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Options.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Options.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PMC_All.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PMC_All.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PMC_Flo.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PMC_Flo.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PMC_Ruser.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PMC_Ruser.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PMC_Usr.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PMC_Usr.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PMS_All.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PMS_All.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PMS_Flo.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PMS_Flo.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PMS_Ruser.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PMS_Ruser.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PMS_Usr.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PMS_Usr.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PM_Client.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PM_Client.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PM_Server.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/PM_Server.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Protocol_Manager.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Protocol_Manager.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Protocol_Record.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Protocol_Record.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Rwho_DB_Manager.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Rwho_DB_Manager.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/SL_Client.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/SL_Client.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/SL_Server.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/SL_Server.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/SML_Client.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/SML_Client.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/SML_Server.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/SML_Server.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/SMR_Client.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/SMR_Client.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/SMR_Server.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/SMR_Server.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/SM_Client.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/SM_Client.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/SM_Server.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/SM_Server.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Search_Struct.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Search_Struct.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Select_Manager.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Single_Lookup.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/Single_Lookup.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/client.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/drwho.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/global.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/drwho/server.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/COPYING
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/ChangeLog
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/Makefile.in
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/gperf.1
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/gperf.info
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/gperf.texi
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Bool_Array.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Bool_Array.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Gen_Perf.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Gen_Perf.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Hash_Table.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Hash_Table.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Iterator.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Iterator.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Key_List.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Key_List.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/List_Node.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/List_Node.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Makefile.in
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Options.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Options.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Vectors.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Vectors.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/Version.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/gperf.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/gperf.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/gperf.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/src/gperf.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/ada-pred.exp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/ada-res.exp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/ada.gperf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/adadefs.gperf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/c-parse.gperf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/c.exp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/c.gperf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/corba.exp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/corba.gperf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/cpp-res.exp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/cpp.gperf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/gpc.gperf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/gperf_test.mpb
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/gplus.gperf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/idl.exp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/idl.gperf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/irc.gperf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/makeinfo.gperf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/modula.exp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/modula2.gperf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/modula3.gperf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/pascal.exp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/pascal.gperf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/tao.exp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/tao.gperf
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/test-1.exp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/test-2.exp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/test-3.exp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/test-4.exp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/test-5.exp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/test-6.exp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/test-7.exp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/test.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/tests/tests.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/gperf/version.texi
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/mkcsregdb/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/mkcsregdb/code_set_registry1.2g.txt
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/mkcsregdb/cs_test.txt
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/mkcsregdb/iso_only.txt
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/mkcsregdb/mkcsregdb.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/mkcsregdb/mkcsregdb.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/mkcsregdb/mkcsregdb.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/soreduce/Library.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/soreduce/Library.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/soreduce/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/soreduce/Obj_Module.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/soreduce/Obj_Module.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/soreduce/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/soreduce/SO_Group.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/soreduce/SO_Group.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/soreduce/Sig_List.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/soreduce/Sig_List.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/soreduce/Signature.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/soreduce/Signature.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/soreduce/soreduce.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/apps/soreduce/soreduce.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/ACE-netsvcs.html
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/build.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Logger/Logger.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Logger/Logger.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Logger/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Logger/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Logger/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Logger/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Logger/direct_logging.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Logger/direct_logging.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Logger/indirect_logging.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Logger/indirect_logging.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Client/Client.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Client/Client.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Client/Client_Test.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Client/Client_Test.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Client/Client_Test.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Client/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Client/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Client/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Client/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Client/main.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Client/main.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Client/svc.conf
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Client/svc2.conf
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Dump_Restore/Dump_Restore.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Dump_Restore/Dump_Restore.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Dump_Restore/Dump_Restore.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Dump_Restore/Dump_Restore.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Dump_Restore/Dump_Restore.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Dump_Restore/Dump_Restore_static.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Dump_Restore/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Dump_Restore/Makefile.Dump_Restore
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Dump_Restore/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Dump_Restore/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Dump_Restore/Makefile.main
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Dump_Restore/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Dump_Restore/createfile.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Dump_Restore/main.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Dump_Restore/main.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Naming/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/collection/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/collection/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/collection/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/collection/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/collection/collection.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/collection/collection.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/collection/collection.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/collection/rw_locks.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/deadlock/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/deadlock/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/deadlock/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/deadlock/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/deadlock/deadlock.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/deadlock/deadlock.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/deadlock/deadlock_detection_test.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/invariant/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/invariant/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/invariant/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/invariant/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/invariant/invariant.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/invariant/invariant.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/invariant/invariant.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/manual/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/manual/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/manual/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/manual/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/manual/manual.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/manual/manual.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/manual/manual.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/mutex/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/mutex/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/mutex/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/mutex/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/mutex/mutex.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/mutex/mutex.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/mutex/test_mutex.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/rw_lock/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/rw_lock/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/rw_lock/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/rw_lock/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/rw_lock/rw_lock.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/rw_lock/rw_lock.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/clients/Tokens/rw_lock/rw_locks.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/Base_Optimizer.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/Base_Optimizer.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/Client_Logging_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/Client_Logging_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/Log_Message_Receiver.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/Log_Message_Receiver.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/Name_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/Name_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/Server_Logging_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/Server_Logging_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/Server_Logging_Handler_T.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/Server_Logging_Handler_T.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/TS_Clerk_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/TS_Clerk_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/TS_Server_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/TS_Server_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/Token_Handler.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/Token_Handler.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/lib.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/netsvcs.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/lib/netsvcs.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/netsvcs.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/servers/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/servers/Makefile.am
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/servers/Makefile.bor
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/servers/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/servers/main.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/servers/servers.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/servers/servers.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/servers/servers.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/servers/svc.conf
   trunk/MgDev/Oem/ACE/ACE_wrappers/netsvcs/servers/svc.conf.xml
   trunk/MgDev/Oem/ACE/ACE_wrappers/websvcs/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/websvcs/README
   trunk/MgDev/Oem/ACE/ACE_wrappers/websvcs/lib/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/websvcs/lib/URL_Addr.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/websvcs/lib/URL_Addr.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/websvcs/lib/URL_Addr.i
   trunk/MgDev/Oem/ACE/ACE_wrappers/websvcs/lib/lib.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/websvcs/lib/websvcs.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/websvcs/lib/websvcs.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/websvcs/lib/websvcs_export.h
   trunk/MgDev/Oem/ACE/ACE_wrappers/websvcs/tests/Makefile
   trunk/MgDev/Oem/ACE/ACE_wrappers/websvcs/tests/Test_URL_Addr.cpp
   trunk/MgDev/Oem/ACE/ACE_wrappers/websvcs/tests/Test_URL_Addr.dsp
   trunk/MgDev/Oem/ACE/ACE_wrappers/websvcs/tests/tests.dsw
   trunk/MgDev/Oem/ACE/ACE_wrappers/websvcs/tests/tests.mpc
   trunk/MgDev/Oem/ACE/ACE_wrappers/websvcs/websvcs.dsw
Update ACE to compile on RHEL4 and prune to source tree to only build libACE.so.  The other components are not used by MapGuide.
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/ACEXML.dsw
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/ACEXML.dsw	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/ACEXML.dsw	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,152 +0,0 @@
-Microsoft Developer Studio Workspace File, Format Version 6.00
-# WARNING: DO NOT EDIT OR DELETE THIS WORKSPACE FILE!
-Project: "ACEXML DLL"=common\ACEXML.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Project: "ACEXML_Parser DLL"=parser\parser\ACEXML_Parser.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-    Begin Project Dependency
-    Project_Dep_Name ACEXML DLL
-    End Project Dependency
-Project: "ACEXML_XML_Svc_Conf_Parser DLL"=apps\svcconf\ACEXML_XML_Svc_Conf_Parser.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-    Project_Dep_Name ACEXML_Parser DLL
-Project: "SAXPrint EXE"=examples\SAXPrint\SAXPrint.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Project: "Transcoder_Test EXE"=tests\Transcoder_Test.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Project: "NamespaceSupport_Test EXE"=tests\NamespaceSupport_Test.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Project: "HttpCharStream_Test EXE"=tests\HttpCharStream_Test.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Project: "ContentHandler_Test EXE"=tests\ContentHandler_Test.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Global:
-Package=<5>
-Package=<3>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/ChangeLog
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/ChangeLog	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/ChangeLog	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,745 +0,0 @@
-Thu Jan  8 18:40:34 2004  Krishnakumar B  <kitty at nospam.invalid.domain>
-        * common/CharStream.h: Added a new rewind() method so that we can
-          reuse the same parser instance to parse the same file multiple
-          times.
-        * common/FileCharStream.cpp:
-        * common/HttpCharStream.h:
-        * common/HttpCharStream.cpp:
-        * common/StrCharStream.cpp:
-        * common/ZipCharStream.cpp:
-          Fixed implementation of rewind().
-        * common/Mem_Map_Stream.cpp:
-          Fixed memory leak caused by the Svc_Handler not getting deleted.
-        * apps/svcconf/Makefile.ACEXML_XML_Svc_Conf_Parser:
-        * parser/parser/Makefile.ACEXML_Parser:
-        * examples/SAXPrint/Makefile.SAXPrint:
-        * common/Makefile.ACEXML:
-        * tests/Makefile.ContentHandler_Test:
-        * tests/Makefile.HttpCharStream_Test:
-        * tests/Makefile.NamespaceSupport_Test:
-        * tests/Makefile.Transcoder_Test:
-          Updated dependencies.
-        * examples/SAXPrint/main.cpp:
-          Added code to test the parser to parse the same file multiple
-          times. This still needs some cleaning.
-        * parser/parser/Entity_Manager.h:
-        * parser/parser/Entity_Manager.i:
-        * parser/parser/Entity_Manager.cpp:
-          Use a pointer to ACE_Hash_Map_Manager_Ex and delete it on every
-          reset() of the Entity_Manager. This should fix all the problems
-          with SIGFPE's when we try to recover from a parse error.
-        * parser/parser/Parser.cpp:
-        * parser/parser/ParserContext.h:
-        * parser/parser/ParserContext.inl:
-          Fixed memory leaks reported by Ken Sedgewick <ken at bonsai.com>.
-          This should fix Bugzill bug 1694. While at it, fix bugs in
-          handling of entity references in INCLUDE/IGNORE sections,
-          ATTLIST sections.
-Thu Dec 18 13:13:57 2003  Krishnakumar B  <kitty at nospam.invalid.domain>
-        * common/Transcode.h (ACEXML_Transcoder):
-        * common/Transcode.cpp (ACEXML_Transcoder):
-          Renamed the ACEXML_Transcoder::STATUS enum to use ACEXML
-          prefixes. Thanks to Johnny Willemsen  <jwillemsen at remedy.nl> for
-          reporting the clash with native #defines on Tru64.
-Sat Jul 19 18:38:50 UTC 2003  Don Hinton  <dhinton at dresystems.com>
-        * ACEXML/apps/svcconf/Svcconf.h:
-        * ACEXML/common/*.h:
-        * ACEXML/parser/*.h:
-        * ACEXML/parser/parser/*.h:
-          Added "/**/" between the #include and filename for pre.h and
-          post.h so Doxygen won't include them in the file reference tree
-          graphs.
-Fri Jul 18 10:29:55 2003  Krishnakumar B  <kitty at nospam.invalid.domain>
-        * tests/NamespaceSupport_Test.cpp (ACE_TMAIN): Added
-          initialization of ACEXML_NamespaceSupport so that we don't
-          crash.
-        * tests/ContentHandler_Test.cpp: Removed "</xml>" at the end of
-          the ACEXML_StrCharStream. XML is not HTML. Added a print
-          statement to the catch clause so that we know what is happening
-          when exception occurs.
-Mon Jul 14 18:49:01 UTC 2003  Johnny Willemsen  <jwillemsen at remedy.nl>
-        * apps/svcconf/Makefile:
-        * common/Makefile:
-        * examples/SAXPrint/Makefile:
-        * parser/parser/Makefile:
-        * tests/Makefile:
-          Removed windows specific rules. They are not needed and only
-          cause problems when using a different command shell then cmd
-          like msys. This solves errors in the MinGW build.
-Sat Jul 5 13:33:36 UTC 2003  Johnny Willemsen  <jwillemsen at remedy.nl>
-        * Makefile:
-Fri Jun 27 12:55:33 UTC 2003  Johnny Willemsen  <jwillemsen at remedy.nl>
-          Removed not useful const return qualifier to resolve intel
-          compiler warnings.
-Thu Jun 26 01:47:03 UTC 2003  Don Hinton  <dhinton at dresystems.com>
-        * parser/parser/Parser.i:
-          Added (int) cast to table index to get rid of a warning.
-Tue Jun 24 23:31:44 2003  Nanbor Wang  <nanbor at cs.wustl.edu>
-        * apps/svcconf/Svcconf.cpp: Turned off validation temporarily when
-          handling svc.conf files.  All of the converted svc.conf.xml
-          files do not have associate doctype at the moment.
-Tue Jun 24 15:38:49 UTC 2003  Don Hinton  <dhinton at dresystems.h>
-        * common/NamespaceSupport.i:
-          Added include of ACE.h.
-Sun Jun  1 09:09:22 2003  Balachandran Natarajan  <bala at dre.vanderbilt.edu>
-        * parser/parser/Entity_Manager.cpp: Added explicit template
-          instantiations.
-Fri May 30 14:16:33 2003  Krishnakumar B  <kitty at spam.invalid.domain>
-        * examples/svcconf/.depend.Makefile.Svcconf:
-        * examples/svcconf/Makefile:
-        * examples/svcconf/Makefile.Svcconf:
-        * examples/svcconf/Makefile.Svcconf.bor:
-        * examples/svcconf/Makefile.bor:
-        * examples/svcconf/README:
-        * examples/svcconf/Svcconf.dsp:
-        * examples/svcconf/Svcconf.dsw:
-        * examples/svcconf/Svcconf.mpc:
-        * examples/svcconf/Svcconf_Handler.cpp:
-        * examples/svcconf/Svcconf_Handler.h:
-        * examples/svcconf/Svcconf_Handler.i:
-        * examples/svcconf/main.cpp:
-          Removed directories causing problems with Win XP release.
-        * ACEXML.dsw:
-        * Makefile:
-        * Makefile.bor:
-        * apps/svcconf/Makefile.ACEXML_XML_Svc_Conf_Parser.bor:
-        * apps/svcconf/Makefile.bor:
-        * common/Makefile.ACEXML.bor:
-        * common/Makefile.bor:
-        * examples/SAXPrint/Makefile.SAXPrint.bor:
-        * examples/SAXPrint/Makefile.bor:
-        * parser/parser/Makefile.ACEXML_Parser.bor:
-        * parser/parser/Makefile.bor:
-        * tests/.depend.Makefile.ContentHandler_Test:
-        * tests/.depend.Makefile.HttpCharStream_Test:
-        * tests/.depend.Makefile.NamespaceSupport_Test:
-        * tests/.depend.Makefile.Transcoder_Test::
-        * tests/Makefile:
-        * tests/Makefile.ContentHandler_Test.bor:
-        * tests/Makefile.HttpCharStream_Test.bor:
-        * tests/Makefile.NamespaceSupport_Test.bor:
-        * tests/Makefile.Transcoder_Test.bor:
-        * tests/Makefile.bor:
-          More build related delicacies needed updating because of the
-          previous change.
-Fri May 30 13:56:40 2003  Krishnakumar B  <kitty at spam.invalid.domain>
-        * common/XML_Common.dsp: Removed old dsp left over from previous
-          merge.
-Fri May 30 13:54:57 2003  Krishnakumar B  <kitty at spam.invalid.domain>
-        * parser/parser/Parser.dsp: Removed this erroneous dsp file left
-          over from the merge.
-Fri May 30 13:50:11 2003  Krishnakumar B  <kitty at spam.invalid.domain>
-        * common/ZipCharStream.h: Removed broken logic to undefine macro
-          version of read. We don't want read to be a macro in ACEXML.
-          Present because of brokenness in ZZIPLIB.
-Fri May 30 13:36:39 2003  Krishnakumar B  <kitty at spam.invalid.domain>
-        * parser/parser/Parser.cpp (parse_ignoresect): Fixed a couple of
-          warnings. Break out of infinite loop.
-        * apps/svcconf/.depend.Makefile.ACEXML_XML_Svc_Conf_Parser:
-        * common/.depend.Makefile.ACEXML:
-        * examples/SAXPrint/.depend.Makefile.SAXPrint:
-        * parser/parser/.depend.Makefile.ACEXML_Parser:
-          Added missing dependency files. This should clear out the red.
-          Fixed warnings with BCB. Thanks to Johnny for reporting these.
-Thu May 29 23:13:40 2003  Krishnakumar B  <kitty at spam.invalid.domain>
-        * examples/SAXPrint/SAXPrint_Handler.cpp: Fixed some minor
-          warnings.
-Thu May 29 23:09:27 2003  Krishnakumar B  <kitty at spam.invalid.domain>
-        * parser/parser/Makefile.Parser:
-          Removed extra file left over by mistake.
-Thu May 29 23:00:24 2003  Krishnakumar B  <kitty at spam.invalid.domain>
-        * tests/Makefile:
-          This file got left out by mistake during the big merge.
-Thu May 29 22:03:40 2003  Krishnakumar B  <kitty at spam.invalid.domain>
-        * ACEXML/ACEXML.mwc:
-        * ACEXML/ChangeLog:
-        * ACEXML/apps/svcconf/ACEXML_XML_Svc_Conf_Parser.dsp:
-        * ACEXML/apps/svcconf/Makefile.ACEXML_XML_Svc_Conf_Parser:
-        * ACEXML/apps/svcconf/Makefile.ACEXML_XML_Svc_Conf_Parser.bor:
-        * ACEXML/common/ACEXML.dsp:
-        * ACEXML/common/Makefile.ACEXML:
-        * ACEXML/common/Makefile.ACEXML.bor:
-        * ACEXML/examples/SAXPrint/Makefile.SAXPrint:
-        * ACEXML/examples/SAXPrint/Makefile.SAXPrint.bor:
-        * ACEXML/examples/svcconf/Makefile:
-        * ACEXML/examples/svcconf/Makefile.Svcconf:
-        * ACEXML/examples/svcconf/Makefile.Svcconf.bor:
-        * ACEXML/examples/svcconf/Svcconf.mpc:
-        * ACEXML/parser/parser/ACEXML_Parser.dsp:
-        * ACEXML/parser/parser/Makefile.ACEXML_Parser:
-        * ACEXML/parser/parser/Makefile.ACEXML_Parser.bor:
-        * ACEXML/parser/parser/Makefile.Parser:
-        * ACEXML/tests/Makefile.ContentHandler_Test.bor:
-        * ACEXML/tests/Makefile.HttpCharStream_Test:
-        * ACEXML/tests/Makefile.HttpCharStream_Test.bor:
-        * ACEXML/tests/Makefile.NamespaceSupport_Test:
-        * ACEXML/tests/Makefile.NamespaceSupport_Test.bor:
-        * ACEXML/tests/Makefile.Transcoder_Test:
-        * ACEXML/tests/Makefile.Transcoder_Test.bor:
-          New files to build ACEXML generated using MPC.
-        * ACEXML/apps/svcconf/svcconf.dtd:
-          Moved the DTD from a hidden location to a prominent one.
-        * ACEXML/examples/SAXPrint/namespaces.xml:
-          New file to test namespace support.
-        * ACEXML/common/ZipCharStream.cpp:
-        * ACEXML/common/ZipCharStream.h:
-          New files to support reading files from within a ZIP archive as
-          a stream.
-        * ACEXML/parser/parser/ParserContext.cpp:
-        * ACEXML/parser/parser/ParserContext.h:
-        * ACEXML/parser/parser/ParserContext.inl:
-          New files to support a per stream context encountered when
-          parsing references.
-        * ACEXML/parser/parser/ParserInternals.cpp:
-        * ACEXML/parser/parser/ParserInternals.h:
-          Move some common functions from Parser.cpp to these files.
-        * ACEXML/ACEXML.dsw:
-        * ACEXML/Makefile:
-        * ACEXML/Makefile.bor:
-        * ACEXML/apps/svcconf/Makefile:
-        * ACEXML/apps/svcconf/Makefile.bor:
-        * ACEXML/common/Makefile:
-        * ACEXML/common/Makefile.bor:
-        * ACEXML/examples/SAXPrint/Makefile:
-        * ACEXML/examples/SAXPrint/Makefile.bor:
-        * ACEXML/examples/SAXPrint/SAXPrint.dsp:
-        * ACEXML/examples/SAXPrint/SAXPrint.mpc:
-        * ACEXML/examples/svcconf/Makefile.bor:
-        * ACEXML/examples/svcconf/Svcconf.dsp:
-        * ACEXML/parser/parser/Makefile:
-        * ACEXML/parser/parser/Makefile.bor:
-        * ACEXML/tests/ContentHandler_Test.cpp:
-        * ACEXML/tests/ContentHandler_Test.dsp:
-        * ACEXML/tests/HttpCharStream_Test.cpp:
-        * ACEXML/tests/HttpCharStream_Test.dsp:
-        * ACEXML/tests/Makefile:
-        * ACEXML/tests/Makefile.bor:
-        * ACEXML/tests/NamespaceSupport_Test.dsp:
-        * ACEXML/tests/Transcoder_Test.dsp:
-          Build related files changed with the introduction of MPC to
-          build ACEXML.
-        * ACEXML/examples/SAXPrint/ns.svc.conf.xml:
-        * ACEXML/examples/SAXPrint/svc.conf.xml:
-          New files to test specific features of the parser.
-        * ACEXML/apps/svcconf/Svcconf.cpp:
-        * ACEXML/common/Attributes.h:
-        * ACEXML/common/Attributes_Def_Builder.h:
-        * ACEXML/common/CharStream.h:
-        * ACEXML/common/DefaultHandler.cpp:
-        * ACEXML/common/Encoding.cpp:
-        * ACEXML/common/Encoding.h:
-        * ACEXML/common/Exception.cpp:
-        * ACEXML/common/FileCharStream.cpp:
-        * ACEXML/common/FileCharStream.h:
-        * ACEXML/common/HttpCharStream.cpp:
-        * ACEXML/common/HttpCharStream.h:
-        * ACEXML/common/InputSource.cpp:
-        * ACEXML/common/InputSource.h:
-        * ACEXML/common/LocatorImpl.cpp:
-        * ACEXML/common/LocatorImpl.h:
-        * ACEXML/common/Mem_Map_Stream.cpp:
-        * ACEXML/common/NamespaceSupport.cpp:
-        * ACEXML/common/NamespaceSupport.h:
-        * ACEXML/common/SAXExceptions.cpp:
-        * ACEXML/common/StrCharStream.cpp:
-        * ACEXML/common/StrCharStream.h:
-        * ACEXML/common/StreamFactory.cpp:
-        * ACEXML/common/Transcode.cpp:
-        * ACEXML/common/Transcode.h:
-        * ACEXML/common/Transcode.i:
-        * ACEXML/examples/SAXPrint/Print_Handler.cpp:
-        * ACEXML/examples/SAXPrint/SAXPrint_Handler.cpp:
-        * ACEXML/examples/SAXPrint/main.cpp:
-        * ACEXML/examples/svcconf/main.cpp:
-        * ACEXML/parser/parser/Parser.cpp:
-        * ACEXML/parser/parser/Parser.h:
-        * ACEXML/parser/parser/Parser.i:
-        * ACEXML/parser/parser/Entity_Manager.cpp:
-        * ACEXML/parser/parser/Entity_Manager.h:
-        * ACEXML/parser/parser/Entity_Manager.i:
-          Merge from the Validator branch. It is not close to conformance
-          related to Validation but is quite stable as a parser which
-          recognizes the complete XML grammar.
-Fri Jan 24 20:28:22 2003  Krishnakumar B  <kitty at insanely.long.id.truncated>
-        * parser/parser/Parser.cpp (pop_context): Bail out if there is
-          only one element on the context stack. Bad things [TM] will happen
-          if we pop the only context available.
-Mon Nov 25 04:25:15 2002  Krishnakumar B  <kitty at cs.wustl.edu>
-        * parser/parser/Parser.cpp (reset):
-        * parser/parser/Parser.h:
-          Fixed a bunch of compilation errors. Removed unnecessary
-          creation and destroyal of ACEXML_Strings which seems to speed up
-          the parser quite a bit.
-          Don't report startPrefixMapping() and endPrefixMapping() as they
-          obstruct the pretty-printing of SAXPrint. They are bogus anyway.
-Wed Nov 20 22:58:12 2002  Krishnakumar B  <kitty at cs.wustl.edu>
-        * parser/parser/Parser.cpp (parse_char_reference):
-          Fixed stupid thinko in conditional parsing of a hex character
-          reference.
-          We can use the old way of fetching on-demand and don't need to
-          use a while loop.
-        * common/NamespaceSupport.cpp:
-          Fixed a long-standing bug with core dumping. With these changes,
-          we are able to parse the XML specification itself. Is this
-          called Meta or what ?
-Wed Nov 20 20:44:56 2002  Krishnakumar B  <kitty at cs.wustl.edu>
-        * common/Mem_Map_Stream.cpp (grow_file_and_remap):
-          Fixed bug where we were trying to remap two different files at
-          the same location without closing the first.
-        * common/HttpCharStream.cpp (get_url):
-          Don't try to parse an empty file. Removes a nasty SIGSEGV.
-Wed Nov 20 01:06:26 2002  Krishnakumar B  <kitty at cs.wustl.edu>
-          Minor indenting changes.
-        * tests/HttpCharStream_Test.cpp:
-          Modified test to show bug in ACE_File_Addr.
-Tue Nov 19 20:46:35 2002  Krishnakumar B  <kitty at cs.wustl.edu>
-        * examples/SAXPrint/Print_Handler.cpp (warning):
-          Missed syncing the function prototypes last time.
-Tue Nov 19 20:18:09 2002  Krishnakumar B  <kitty at cs.wustl.edu>
-        * parser/parser/Parser.cpp (normalize_systemid):
-          Fix an off-by-one error in normalization. The document's base
-          URI is never empty. Now we parse relative document URI
-          correctly.
-          Implement the previously unimplemented parsing from a systemId.
-        * common/InputSource.cpp:
-        * common/InputSource.h:
-          Implement creating an InputSource from a systemId.
-          Added a new method getSystemId().
-        * common/FileCharStream.h:
-        * common/StrCharStream.h:
-          Added implementation for getSystemId().
-        * examples/SAXPrint/Print_Handler.cpp:
-          Synched up the printing of exception messages.
-          Fixed broken internal string version of a sample XML file.
-Tue Nov 19 15:02:06 2002  Krishnakumar B  <kitty at cs.wustl.edu>
-        * apps/svcconf/XML_Svc_Conf_Parser.dsp:
-        * examples/SAXPrint/SAXPrint.dsp:
-        * parser/debug_validator/Debug_Validator.dsp:
-          Modified to accomodate zlib and zziplig. Will probably change
-          before the merge.
-          Try to parse external DTD only if validation is required.
-Mon Nov 18 22:29:39 2002  Krishnakumar B  <kitty at cs.wustl.edu>
-          Deleted this file in the previous check-in. Re-add it.
-Mon Nov 18 22:19:47 2002  Krishnakumar B  <kitty at cs.wustl.edu>
-        * ACEXML/common/common.mpc:
-        * ACEXML/parser/parser/parser.mpc:
-        * ACEXML/parser/debug_validator/validator.mpc:
-        * ACEXML/apps/svcconf/svcconf.mpc:
-        * ACEXML/examples/SAXPrint/saxprint.mpc:
-        * ACEXML/tests/tests.mpc:
-          New MPC files and Workspace file.
-        * ACEXML/common/Makefile.XML_Common:
-        * ACEXML/apps/svcconf/Makefile.XML_Svc_Conf_Parser:
-        * ACEXML/parser/debug_validator/Makefile.Validator:
-          New Makefiles generated by MPC.
-        * ACEXML/parser/Makefile:
-        * ACEXML/examples/Makefile:
-        * ACEXML/apps/Makefile:
-          Removed old Makefiles.
-          Fixed compilation errors.
-Mon Nov 18 20:30:30 2002  Krishnakumar B  <kitty at cs.wustl.edu>
-          Fixed a number of minor typos and debugging statements.
-        * ACEXML/common/LocatorImpl.cpp: Check for a valid string before
-          assigning it to the new Locator.
-          Make sure that we don't have a null prefix before trying to
-          dereference the prefix.
-          New stream which reads files from a ZIP archive.
-          Modified to accomodate ZipCharStream.
-          Commented out a lot of unnecessary debug statements.
-          Lots of bugfixes. Finally we parse the XML version of XHTML
-          specification without dumping core.
-Sat Nov 16 21:18:55 2002  Krishnakumar B  <kitty at cs.wustl.edu>
-          More bugs fixed. Add support for parsing PE references within
-          attribute list declarations and clean up the same. Add support
-          for parsing PE references within element declarations.
-Tue Nov 12 19:48:34 2002  Krishnakumar B  <kitty at cs.wustl.edu>
-          New files which hold the ParserContext needed to handle the
-          switching of input streams on the fly.
-          Moved some generic code from Parser.cpp to here.
-          No need to typedef in C++.
-          Minor typos.
-          If auto-detection of encoding fails, assume that it is UTF-8.
-          Change the error message from ACE_DEBUG to ACE_ERROR.
-        * ACEXML/common/FileCharStream.cpp: Handle BOM of UTF-8 in
-          addition to UTF-16. Cleanup unnecessary parens.
-          Add support for auto-detection of encoding.
-          Fixes for use with ACEXML_Parser_Context.
-          Fixed bug in copy constructor which resulted in locator
-          information not getting set properly.
-          Implement reset() method.
-          Handle copying of bytes according to sizeof (ACE_WCHAR).
-        * ACEXML/common/StreamFactory.cpp: Create the appropriate stream
-          given an URI. We don't try to normalize the URI here. It is done
-          in the Parser.
-          Moved some very big functions from .i to .cpp.
-          Updates to reflect the new calling convention in the Parser.
-          Implemented support for resolving SYSTEM and PUBLIC ids  from
-          the Entity_Manager.
-          Implemented support for external parameter and entity
-          references. Rewrote a lot of the basic parsing functionality to
-          adhere to the standard. Implment partial support for validation
-          of XML files.
-Fri Oct 25 15:44:04 2002  Krishnakumar B  <kitty at cs.wustl.edu>
-        * ACEXML/parser/parser/Parser.i: Handle end-of-line as required by
-          the spec. Specifically any sequence of 0x0D or 0x0D 0x0A should
-          be normalized to a 0x0A before passing to the XML processor.
-        * ACEXML/parser/parser/Parser.cpp: Remove checks for 0x0D as it is
-          handled tranparently now.
-Thu Oct 24 21:06:44 2002  Krishnakumar B  <kitty at cs.wustl.edu>
-        * ACEXML/common/NamespaceSupport.cpp: Define strings normally and
-          not as an array.
-        * ACEXML/common/Attributes_Def_Builder.h: No need to typedef in C++.
-Thu Oct 24 01:52:46 2002  Krishnakumar B  <kitty at cs.wustl.edu>
-        * ACEXML\parser\parser\Parser.cpp: Moved out the declaration of
-          variables outside case labels. MSVC doesn't like it.
-Wed Oct 23 22:24:59 2002  Krishnakumar B  <kitty at cs.wustl.edu>
-        * ACEXML/parser/parser/Parser.cpp: Fixed a stupid thinko in array
-          initialization.
-Wed Oct 23 17:27:14 2002  Krishnakumar B  <kitty at cs.wustl.edu>
-          Use UTF-16 instead of UTF-16LE/UTF-16BE as the specification
-          doesn't require mentioning the endianness of the input.
-        * ACEXML/common/Transcode.h: Fixed some minor typos.
-        * ACEXML/examples/SAXPrint/namespaces.xml: New file which tests
-          out the namespaces feature much better.
-        * ACEXML/parser/parser/ParserErrors.h: New file which contains the
-          error codes of all the error spit out by the parser.
-          Make sure that the characters() function describes the arguments
-          as start and length instead of start and end.
-        * ACEXML/parser/parser/Parser.dsp: Added ParserErrors.h to the
-          project file.
-          Use minor codes when reporting error in the parser. This cleans
-          up a lot of repeated error messages and indenting so that we
-          don't need to spill over 80 columns and have a standardized way
-          of reporting errors. Rewrote parse_cdata() so that is is much
-          simpler. Removed try_grow_cdata() as it is no longer needed.
-          Handle the case when the parser was accepting invalid character
-          references().
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/Makefile
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/Makefile	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/Makefile	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,22 +0,0 @@
-# Makefile,v 1.7 2004/01/07 22:40:16 shuston Exp
-#       GNU ACE Workspace
-include $(ACE_ROOT)/include/makeinclude/macros.GNU
-TARGETS_NESTED := $(TARGETS_NESTED:.nested=)
-MFILES = \
-         common/Makefile.ACEXML \
-         parser/parser/Makefile.ACEXML_Parser \
-         apps/svcconf/Makefile.ACEXML_XML_Svc_Conf_Parser \
-         examples/SAXPrint/Makefile.SAXPrint \
-         tests/Makefile.Transcoder_Test \
-         tests/Makefile.NamespaceSupport_Test \
-         tests/Makefile.HttpCharStream_Test \
-         tests/Makefile.ContentHandler_Test
-$(TARGETS_NESTED):
-	@for file in $(MFILES); do \
-	$(RM) -rf `dirname $$file`/tempinc ;\
-	$(MAKE) -f `basename $$file` -C `dirname $$file` $(@); \
-	done
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/Makefile.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/Makefile.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/Makefile.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,115 +0,0 @@
-# Makefile.bor,v 1.5 2003/12/20 14:21:14 jwillemsen Exp
-#       Borland Workspace
-!include <$(ACE_ROOT)\include\makeinclude\make_flags.bor>
-all:
-	@cd common
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML.bor all
-	@cd ../
-	@cd parser/parser
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML_Parser.bor all
-	@cd ../../
-	@cd apps/svcconf
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML_XML_Svc_Conf_Parser.bor all
-	@cd ../../
-	@cd examples/SAXPrint
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.SAXPrint.bor all
-	@cd ../../
-	@cd tests
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.Transcoder_Test.bor all
-	@cd ../
-	@cd tests
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.NamespaceSupport_Test.bor all
-	@cd ../
-	@cd tests
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.HttpCharStream_Test.bor all
-	@cd ../
-	@cd tests
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ContentHandler_Test.bor all
-	@cd ../
-clean:
-	@cd common
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML.bor clean
-	@cd ../
-	@cd parser/parser
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML_Parser.bor clean
-	@cd ../../
-	@cd apps/svcconf
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML_XML_Svc_Conf_Parser.bor clean
-	@cd ../../
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.SAXPrint.bor clean
-	@cd ../../
-	@cd tests
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.Transcoder_Test.bor clean
-	@cd ../
-	@cd tests
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.NamespaceSupport_Test.bor clean
-	@cd ../
-	@cd tests
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.HttpCharStream_Test.bor clean
-	@cd ../
-	@cd tests
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ContentHandler_Test.bor clean
-	@cd ../
-realclean:
-	@cd common
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML.bor realclean
-	@cd ../
-	@cd parser/parser
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML_Parser.bor realclean
-	@cd ../../
-	@cd apps/svcconf
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML_XML_Svc_Conf_Parser.bor realclean
-	@cd ../../
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.SAXPrint.bor realclean
-	@cd ../../
-	@cd tests
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.Transcoder_Test.bor realclean
-	@cd ../
-	@cd tests
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.NamespaceSupport_Test.bor realclean
-	@cd ../
-	@cd tests
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.HttpCharStream_Test.bor realclean
-	@cd ../
-	@cd tests
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ContentHandler_Test.bor realclean
-	@cd ../
-install:
-	@cd common
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML.bor install
-	@cd ../
-	@cd parser/parser
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML_Parser.bor install
-	@cd ../../
-	@cd apps/svcconf
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML_XML_Svc_Conf_Parser.bor install
-	@cd ../../
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.SAXPrint.bor install
-	@cd ../../
-	@cd tests
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.Transcoder_Test.bor install
-	@cd ../
-	@cd tests
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.NamespaceSupport_Test.bor install
-	@cd ../
-	@cd tests
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.HttpCharStream_Test.bor install
-	@cd ../
-	@cd tests
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ContentHandler_Test.bor install
-	@cd ../
-regenerate:
-	/usr/bin/perl /build/kitty/ACE_wrappers/bin/mwc.pl -type borland ACEXML.mwc
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/README
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/README	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/README	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,17 +0,0 @@
-README,v 1.2 2002/01/24 21:00:01 nanbor Exp
-ACE XML PARSER Framework README file
-* Character set
-ACE XML only deal with pure unicode encoding.  I.e., ACE XML
-does not care about language specific encoding information.
-* SAX - The Simple API for XML
-ACE XML Parser interfaces follows the the design of SAX 2.0, which is
-a public domain specification for Java.  The major difference between
-ACE XML Parser interfaces and SAX is that we added an reference of
-ACEXML_Env to every SAX method to accomodate platforms/compilers that
-don't support C++ exceptions.  SAX is defined by David Megginson
-<david at megginson.com>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/Makefile.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/Makefile.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/Makefile.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,10 +0,0 @@
-# Makefile.bor,v 1.3 2003/12/20 14:21:14 jwillemsen Exp
-# Makefile for building the ACE XML Library
-DIRS = \
-        svcconf
-!include <$(ACE_ROOT)\include\makeinclude\recurse.bor>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/XML_Apps.dsw
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/XML_Apps.dsw	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/XML_Apps.dsw	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,29 +0,0 @@
-Project: "XML_Svc_Conf_Parser"=.\svcconf\XML_Svc_Conf_Parser.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Global:
-Package=<5>
-Package=<3>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/ACEXML_XML_Svc_Conf_Parser.dsp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/ACEXML_XML_Svc_Conf_Parser.dsp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/ACEXML_XML_Svc_Conf_Parser.dsp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,111 +0,0 @@
-# Microsoft Developer Studio Project File - Name="ACEXML_XML_Svc_Conf_Parser DLL" - Package Owner=<4>
-# Microsoft Developer Studio Generated Build File, Format Version 6.00
-# ** DO NOT EDIT **
-# TARGTYPE "Win32 (x86) Dynamic-Link Library" 0x0102
-CFG=ACEXML_XML_Svc_Conf_Parser DLL - Win32 Debug
-!MESSAGE This is not a valid makefile. To build this project using NMAKE,
-!MESSAGE run the tool that generated this project file and specify the
-!MESSAGE nmake output type.  You can then use the following command:
-!MESSAGE
-!MESSAGE NMAKE /f "ACEXML_XML_Svc_Conf_Parser.mak".
-!MESSAGE
-!MESSAGE You can specify a configuration when running NMAKE
-!MESSAGE by defining the macro CFG on the command line. For example:
-!MESSAGE
-!MESSAGE NMAKE /f "ACEXML_XML_Svc_Conf_Parser.mak" CFG="ACEXML_XML_Svc_Conf_Parser DLL - Win32 Debug"
-!MESSAGE
-!MESSAGE Possible choices for configuration are:
-!MESSAGE
-!MESSAGE "ACEXML_XML_Svc_Conf_Parser DLL - Win32 Release" (based on "Win32 (x86) Dynamic-Link Library")
-!MESSAGE "ACEXML_XML_Svc_Conf_Parser DLL - Win32 Debug" (based on "Win32 (x86) Dynamic-Link Library")
-!MESSAGE
-# Begin Project
-# PROP AllowPerConfigDependencies 0
-# PROP Scc_ProjName ""
-# PROP Scc_LocalPath ""
-CPP=cl.exe
-RSC=rc.exe
-!IF  "$(CFG)" == "ACEXML_XML_Svc_Conf_Parser DLL - Win32 Release"
-# PROP Use_MFC 0
-# PROP Use_Debug_Libraries 0
-# PROP Output_Dir "."
-# PROP Intermediate_Dir "Release\ACEXML_XML_Svc_Conf_Parser"
-# PROP Ignore_Export_Lib 0
-# PROP Target_Dir ""
-# ADD CPP /nologo /W3 /GX /O2 /MD /Zi /GR /I "..\..\.." /D NDEBUG=1 /D WIN32=1 /D _WINDOWS=1 /FD /c
-# SUBTRACT CPP /YX
-# ADD RSC /l 0x409 /d NDEBUG=1 /i "..\..\.."
-BSC32=bscmake.exe
-# ADD BSC32 /nologo /o".\ACEXML_XML_Svc_Conf_Parser.bsc"
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACEXML_Parser.lib ACEXML.lib ACE.lib /libpath:"..\..\..\ACEXML\common" /libpath:"..\..\..\ACEXML\parser\parser" /libpath:"..\..\..\ace" /nologo /version:5.3.1 /subsystem:windows /pdb:"..\..\..\bin\ACEXML_XML_Svc_Conf_Parser.pdb" /dll  /machine:I386 /out:"..\..\..\bin\ACEXML_XML_Svc_Conf_Parser.dll"
-!ELSEIF  "$(CFG)" == "ACEXML_XML_Svc_Conf_Parser DLL - Win32 Debug"
-# PROP Use_MFC 0
-# PROP Use_Debug_Libraries 1
-# PROP Intermediate_Dir "Debug\ACEXML_XML_Svc_Conf_Parser"
-# ADD CPP /nologo /W3 /Gm /GX /Zi /Od /MDd /GR /Gy /I "..\..\.." /D _DEBUG=1 /D WIN32=1 /D _WINDOWS=1 /FD /c
-# SUBTRACT CPP /Fr /YX
-# ADD RSC /l 0x409 /d _DEBUG=1 /i "..\..\.."
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACEXML_Parserd.lib ACEXMLd.lib ACEd.lib /libpath:"..\..\..\ACEXML\common" /libpath:"..\..\..\ACEXML\parser\parser" /libpath:"..\..\..\ace" /nologo /version:5.3.1 /subsystem:windows /pdb:"..\..\..\bin\ACEXML_XML_Svc_Conf_Parserd.pdb" /dll /debug /machine:I386 /out:"..\..\..\bin\ACEXML_XML_Svc_Conf_Parserd.dll"
-!ENDIF
-# Begin Target
-# Name "ACEXML_XML_Svc_Conf_Parser DLL - Win32 Release"
-# Name "ACEXML_XML_Svc_Conf_Parser DLL - Win32 Debug"
-# Begin Group "Source Files"
-# PROP Default_Filter "cpp;cxx;c"
-# Begin Source File
-SOURCE=.\Svcconf.cpp
-# End Source File
-SOURCE=.\Svcconf_Handler.cpp
-# End Source File
-# End Group
-# Begin Group "Header Files"
-# PROP Default_Filter "h;hpp;hxx;hh"
-SOURCE=.\Svcconf.h
-# End Source File
-SOURCE=.\Svcconf_Handler.h
-# End Source File
-# End Group
-# Begin Group "Inline Files"
-# PROP Default_Filter "i;inl"
-SOURCE=.\Svcconf_Handler.i
-# End Source File
-# End Group
-# Begin Group "Documentation"
-# PROP Default_Filter ""
-SOURCE=.\README
-# End Source File
-# End Group
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Makefile
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Makefile	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Makefile	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,10 +0,0 @@
-# Makefile,v 1.11 2003/07/14 18:47:57 jwillemsen Exp
-$(TARGETS_NESTED):
-	@$(MAKE) -f Makefile.ACEXML_XML_Svc_Conf_Parser -C . $(@);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Makefile.ACEXML_XML_Svc_Conf_Parser
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Makefile.ACEXML_XML_Svc_Conf_Parser	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Makefile.ACEXML_XML_Svc_Conf_Parser	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,433 +0,0 @@
-#       GNU Makefile
-MAKEFILE        = Makefile.ACEXML_XML_Svc_Conf_Parser
-LIB_UNCHECKED   = libACEXML_XML_Svc_Conf_Parser.a
-SHLIB_UNCHECKED = libACEXML_XML_Svc_Conf_Parser.$(SOEXT)
-FILES = \
-  Svcconf \
-  Svcconf_Handler
-#       Include macros and targets
-LIB   = $(LIB_UNCHECKED)
-SHLIB = $(SHLIB_UNCHECKED)
-ACE_SHLIBS = -lACE
-include $(ACE_ROOT)/include/makeinclude/wrapper_macros.GNU
-LSRC   = $(addsuffix .cpp, $(FILES))
-include $(ACE_ROOT)/include/makeinclude/rules.common.GNU
-include $(ACE_ROOT)/include/makeinclude/rules.nonested.GNU
-include $(ACE_ROOT)/include/makeinclude/rules.lib.GNU
-include $(ACE_ROOT)/include/makeinclude/rules.local.GNU
-CPPFLAGS     += -I../../..
-ifeq ($(static_libs),1)
-  ifneq ($(LIB),)
-    CPPFLAGS += -DACE_AS_STATIC_LIBS
-  endif
-endif
-LDFLAGS      += -L../../../ACEXML/common -L../../../ACEXML/parser/parser -L../../../ace
-ACE_SHLIBS  = -lACEXML_Parser -lACEXML $(ACELIB)
-#       Local targets
-realclean: clean
-ifneq ($(GENERATED_DIRTY),)
-	-$(RM) -r $(GENERATED_DIRTY)
-endif
-#       Dependencies
-# DO NOT DELETE THIS LINE -- g++dep uses it.
-# DO NOT PUT ANYTHING AFTER THIS LINE, IT WILL GO AWAY.
-.obj/Svcconf.o .obj/Svcconf.so .shobj/Svcconf.o .shobj/Svcconf.so: Svcconf.cpp Svcconf.h \
-  $(ACE_ROOT)/ace/pre.h \
-  $(ACE_ROOT)/ace/XML_Svc_Conf.h \
-  $(ACE_ROOT)/ace/ACE_export.h \
-  $(ACE_ROOT)/ace/config.h \
-  $(ACE_ROOT)/ace/$(ACE_PLATFORM_CONFIG) \
-  $(ACE_ROOT)/ace/post.h \
-  $(ACE_ROOT)/ace/ace_wchar.h \
-  $(ACE_ROOT)/ace/ace_wchar.inl \
-  $(ACE_ROOT)/ACEXML/parser/parser/Parser.h \
-  $(ACE_ROOT)/ACEXML/parser/parser/Parser_export.h \
-  $(ACE_ROOT)/ace/config-all.h \
-  $(ACE_ROOT)/ace/OS_main.h \
-  $(ACE_ROOT)/ACEXML/common/XMLReader.h \
-  $(ACE_ROOT)/ACEXML/common/ACEXML_Export.h \
-  $(ACE_ROOT)/ACEXML/common/ContentHandler.h \
-  $(ACE_ROOT)/ACEXML/common/Env.h \
-  $(ACE_ROOT)/ACEXML/common/XML_Macros.h \
-  $(ACE_ROOT)/ace/Exception_Macros.h \
-  $(ACE_ROOT)/ACEXML/common/Exception.h \
-  $(ACE_ROOT)/ACEXML/common/XML_Types.h \
-  $(ACE_ROOT)/ace/SString.h \
-  $(ACE_ROOT)/ace/SStringfwd.h \
-  $(ACE_ROOT)/ace/Basic_Types.h \
-  $(ACE_ROOT)/ace/os_include/os_limits.h \
-  $(ACE_ROOT)/ace/os_include/os_unistd.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_types.h \
-  $(ACE_ROOT)/ace/os_include/os_stddef.h \
-  $(ACE_ROOT)/ace/os_include/os_inttypes.h \
-  $(ACE_ROOT)/ace/os_include/os_stdint.h \
-  $(ACE_ROOT)/ace/os_include/os_stdio.h \
-  $(ACE_ROOT)/ace/os_include/os_stdarg.h \
-  $(ACE_ROOT)/ace/os_include/os_float.h \
-  $(ACE_ROOT)/ace/os_include/os_stdlib.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_wait.h \
-  $(ACE_ROOT)/ace/os_include/os_signal.h \
-  $(ACE_ROOT)/ace/os_include/os_time.h \
-  $(ACE_ROOT)/ace/os_include/os_ucontext.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_resource.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_time.h \
-  $(ACE_ROOT)/ace/String_Base.h \
-  $(ACE_ROOT)/ace/String_Base_Const.h \
-  $(ACE_ROOT)/ace/Global_Macros.h \
-  $(ACE_ROOT)/ace/OS_Errno.h \
-  $(ACE_ROOT)/ace/os_include/os_errno.h \
-  $(ACE_ROOT)/ace/String_Base.cpp \
-  $(ACE_ROOT)/ace/ACE.h \
-  $(ACE_ROOT)/ace/Flag_Manip.h \
-  $(ACE_ROOT)/ace/Flag_Manip.i \
-  $(ACE_ROOT)/ace/OS_NS_fcntl.h \
-  $(ACE_ROOT)/ace/os_include/os_fcntl.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_stat.h \
-  $(ACE_ROOT)/ace/Handle_Ops.h \
-  $(ACE_ROOT)/ace/Handle_Ops.i \
-  $(ACE_ROOT)/ace/Lib_Find.h \
-  $(ACE_ROOT)/ace/Lib_Find.i \
-  $(ACE_ROOT)/ace/Init_ACE.h \
-  $(ACE_ROOT)/ace/Init_ACE.i \
-  $(ACE_ROOT)/ace/Sock_Connect.h \
-  $(ACE_ROOT)/ace/os_include/netinet/os_in.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_socket.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_uio.h \
-  $(ACE_ROOT)/ace/Sock_Connect.i \
-  $(ACE_ROOT)/ace/Default_Constants.h \
-  $(ACE_ROOT)/ace/ACE.i \
-  $(ACE_ROOT)/ace/OS_NS_unistd.h \
-  $(ACE_ROOT)/ace/Time_Value.h \
-  $(ACE_ROOT)/ace/OS_NS_Thread.h \
-  $(ACE_ROOT)/ace/os_include/os_pthread.h \
-  $(ACE_ROOT)/ace/Base_Thread_Adapter.h \
-  $(ACE_ROOT)/ace/OS_Log_Msg_Attributes.h \
-  $(ACE_ROOT)/ace/iosfwd.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_sem.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_ipc.h \
-  $(ACE_ROOT)/ace/os_include/os_semaphore.h \
-  $(ACE_ROOT)/ace/OS_Memory.h \
-  $(ACE_ROOT)/ace/OS_NS_stdlib.h \
-  $(ACE_ROOT)/ace/OS_NS_signal.h \
-  $(ACE_ROOT)/ace/Object_Manager_Base.h \
-  $(ACE_ROOT)/ace/Cleanup.h \
-  $(ACE_ROOT)/ace/os_include/os_ctype.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_socket.h \
-  $(ACE_ROOT)/ace/os_include/net/os_if.h \
-  $(ACE_ROOT)/ace/OS_NS_stropts.h \
-  $(ACE_ROOT)/ace/os_include/os_stropts.h \
-  $(ACE_ROOT)/ace/Malloc_Base.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_mman.h \
-  $(ACE_ROOT)/ace/Auto_Ptr.h \
-  $(ACE_ROOT)/ace/Auto_Ptr.cpp \
-  $(ACE_ROOT)/ace/Auto_Ptr.i \
-  $(ACE_ROOT)/ace/OS_NS_string.h \
-  $(ACE_ROOT)/ace/String_Base.i \
-  $(ACE_ROOT)/ace/Min_Max.h \
-  $(ACE_ROOT)/ACEXML/common/SAXExceptions.h \
-  $(ACE_ROOT)/ACEXML/common/Locator.h \
-  $(ACE_ROOT)/ACEXML/common/Attributes.h \
-  $(ACE_ROOT)/ACEXML/common/DTDHandler.h \
-  $(ACE_ROOT)/ACEXML/common/EntityResolver.h \
-  $(ACE_ROOT)/ACEXML/common/InputSource.h \
-  $(ACE_ROOT)/ACEXML/common/CharStream.h \
-  $(ACE_ROOT)/ACEXML/common/ErrorHandler.h \
-  $(ACE_ROOT)/ACEXML/common/LocatorImpl.h \
-  $(ACE_ROOT)/ACEXML/common/NamespaceSupport.h \
-  $(ACE_ROOT)/ace/Functor.h \
-  $(ACE_ROOT)/ace/Functor_T.h \
-  $(ACE_ROOT)/ace/Functor_T.cpp \
-  $(ACE_ROOT)/ace/Functor_T.i \
-  $(ACE_ROOT)/ace/Hash_Map_Manager.h \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.h \
-  $(ACE_ROOT)/ace/Log_Msg.h \
-  $(ACE_ROOT)/ace/Log_Priority.h \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.cpp \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.i \
-  $(ACE_ROOT)/ace/Guard_T.h \
-  $(ACE_ROOT)/ace/Lock.h \
-  $(ACE_ROOT)/ace/Guard_T.cpp \
-  $(ACE_ROOT)/ace/Guard_T.inl \
-  $(ACE_ROOT)/ace/RW_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/RW_Mutex.h \
-  $(ACE_ROOT)/ace/Containers_T.h \
-  $(ACE_ROOT)/ace/Containers.h \
-  $(ACE_ROOT)/ace/Node.h \
-  $(ACE_ROOT)/ace/Node.cpp \
-  $(ACE_ROOT)/ace/Array_Base.h \
-  $(ACE_ROOT)/ace/Array_Base.cpp \
-  $(ACE_ROOT)/ace/Array_Base.inl \
-  $(ACE_ROOT)/ace/Unbounded_Set.h \
-  $(ACE_ROOT)/ace/Unbounded_Set.cpp \
-  $(ACE_ROOT)/ace/Unbounded_Set.inl \
-  $(ACE_ROOT)/ace/Unbounded_Queue.h \
-  $(ACE_ROOT)/ace/Unbounded_Queue.cpp \
-  $(ACE_ROOT)/ace/Unbounded_Queue.inl \
-  $(ACE_ROOT)/ace/Containers_T.cpp \
-  $(ACE_ROOT)/ace/Containers_T.i \
-  $(ACE_ROOT)/ace/Null_Mutex.h \
-  $(ACE_ROOT)/ace/Obstack.h \
-  $(ACE_ROOT)/ace/Obstack_T.h \
-  $(ACE_ROOT)/ace/Obchunk.h \
-  $(ACE_ROOT)/ace/Malloc.h \
-  $(ACE_ROOT)/ace/Malloc_T.h \
-  $(ACE_ROOT)/ace/Malloc_Allocator.h \
-  $(ACE_ROOT)/ace/Free_List.h \
-  $(ACE_ROOT)/ace/Free_List.cpp \
-  $(ACE_ROOT)/ace/Free_List.i \
-  $(ACE_ROOT)/ace/Malloc_T.cpp \
-  $(ACE_ROOT)/ace/Malloc_T.i \
-  $(ACE_ROOT)/ace/Memory_Pool.h \
-  $(ACE_ROOT)/ace/Event_Handler.h \
-  $(ACE_ROOT)/ace/Atomic_Op.h \
-  $(ACE_ROOT)/ace/Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Atomic_Op_T.h \
-  $(ACE_ROOT)/ace/Atomic_Op_T.cpp \
-  $(ACE_ROOT)/ace/Atomic_Op_T.i \
-  $(ACE_ROOT)/ace/Synch_Traits.h \
-  $(ACE_ROOT)/ace/Signal.h \
-  $(ACE_ROOT)/ace/Mem_Map.h \
-  $(ACE_ROOT)/ace/SV_Semaphore_Complex.h \
-  $(ACE_ROOT)/ace/SV_Semaphore_Simple.h \
-  $(ACE_ROOT)/ace/SV_Semaphore_Simple.i \
-  $(ACE_ROOT)/ace/SV_Semaphore_Complex.i \
-  $(ACE_ROOT)/ace/Obstack_T.cpp \
-  $(ACE_ROOT)/ace/Obstack_T.i \
-  $(ACE_ROOT)/ACEXML/parser/parser/Entity_Manager.h \
-  $(ACE_ROOT)/ACEXML/parser/parser/ParserInternals.h \
-  $(ACE_ROOT)/ACEXML/parser/parser/ParserContext.h \
-  $(ACE_ROOT)/ace/Swap.h \
-  $(ACE_ROOT)/ace/Swap.cpp \
-  $(ACE_ROOT)/ace/Swap.inl Svcconf_Handler.h \
-  $(ACE_ROOT)/ACEXML/common/DefaultHandler.h \
-  $(ACE_ROOT)/ace/Service_Types.h \
-  $(ACE_ROOT)/ace/Service_Object.h \
-  $(ACE_ROOT)/ace/Shared_Object.h \
-  $(ACE_ROOT)/ace/Svc_Conf_Tokens.h \
-  $(ACE_ROOT)/ace/DLL.h \
-  $(ACE_ROOT)/ace/os_include/os_dlfcn.h \
-  $(ACE_ROOT)/ACEXML/common/FileCharStream.h \
-  $(ACE_ROOT)/ACEXML/common/Encoding.h \
-  $(ACE_ROOT)/ACEXML/common/StrCharStream.h
-.obj/Svcconf_Handler.o .obj/Svcconf_Handler.so .shobj/Svcconf_Handler.o .shobj/Svcconf_Handler.so: Svcconf_Handler.cpp Svcconf_Handler.h \
-  $(ACE_ROOT)/ace/Service_Config.h \
-  $(ACE_ROOT)/ace/Reactor.h \
-  $(ACE_ROOT)/ace/Timer_Queuefwd.h \
-  $(ACE_ROOT)/ace/Reactor_Timer_Interface.h \
-  $(ACE_ROOT)/ace/Service_Repository.h \
-  $(ACE_ROOT)/ace/ARGV.h \
-  $(ACE_ROOT)/ace/Module.h \
-  $(ACE_ROOT)/ace/Task_T.h \
-  $(ACE_ROOT)/ace/Message_Queue.h \
-  $(ACE_ROOT)/ace/Message_Block.h \
-  $(ACE_ROOT)/ace/Message_Block_T.h \
-  $(ACE_ROOT)/ace/Message_Block_T.cpp \
-  $(ACE_ROOT)/ace/Message_Block_T.i \
-  $(ACE_ROOT)/ace/IO_Cntl_Msg.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.cpp \
-  $(ACE_ROOT)/ace/OS_NS_sys_time.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.i \
-  $(ACE_ROOT)/ace/Notification_Strategy.h \
-  $(ACE_ROOT)/ace/Task.h \
-  $(ACE_ROOT)/ace/Thread_Manager.h \
-  $(ACE_ROOT)/ace/Thread.h \
-  $(ACE_ROOT)/ace/Thread_Adapter.h \
-  $(ACE_ROOT)/ace/Thread_Exit.h \
-  $(ACE_ROOT)/ace/Thread_Control.h \
-  $(ACE_ROOT)/ace/Condition_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Singleton.h \
-  $(ACE_ROOT)/ace/TSS_T.h \
-  $(ACE_ROOT)/ace/TSS_T.cpp \
-  $(ACE_ROOT)/ace/TSS_T.inl \
-  $(ACE_ROOT)/ace/OS_NS_stdio.h \
-  $(ACE_ROOT)/ace/Singleton.cpp \
-  $(ACE_ROOT)/ace/Singleton.i \
-  $(ACE_ROOT)/ace/Object_Manager.h \
-  $(ACE_ROOT)/ace/Recursive_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Static_Object_Lock.h \
-  $(ACE_ROOT)/ace/Managed_Object.h \
-  $(ACE_ROOT)/ace/Managed_Object.cpp \
-  $(ACE_ROOT)/ace/Managed_Object.i \
-  $(ACE_ROOT)/ace/Framework_Component.h \
-  $(ACE_ROOT)/ace/Framework_Component_T.h \
-  $(ACE_ROOT)/ace/Framework_Component_T.cpp \
-  $(ACE_ROOT)/ace/Framework_Component_T.inl \
-  $(ACE_ROOT)/ace/Task_T.cpp \
-  $(ACE_ROOT)/ace/Null_Condition.h \
-  $(ACE_ROOT)/ace/Task_T.i \
-  $(ACE_ROOT)/ace/os_include/os_assert.h \
-  $(ACE_ROOT)/ace/os_include/os_dirent.h \
-  $(ACE_ROOT)/ace/Module.cpp \
-  $(ACE_ROOT)/ace/Stream_Modules.h \
-  $(ACE_ROOT)/ace/Stream_Modules.cpp \
-  $(ACE_ROOT)/ace/Module.i \
-  $(ACE_ROOT)/ace/OS_NS_strings.h \
-  $(ACE_ROOT)/ace/os_include/os_strings.h
-# IF YOU PUT ANYTHING HERE IT WILL GO AWAY
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Makefile.ACEXML_XML_Svc_Conf_Parser.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Makefile.ACEXML_XML_Svc_Conf_Parser.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Makefile.ACEXML_XML_Svc_Conf_Parser.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,58 +0,0 @@
-# Makefile.ACEXML_XML_Svc_Conf_Parser.bor,v 1.3 2003/12/20 14:21:14 jwillemsen Exp
-# Makefile for building the ACEXML_XML_Svc_Conf_Parser library with Borland C++ Builder
-NAME = ACEXML_XML_Svc_Conf_Parser
-OBJFILES = \
-	$(OBJDIR)\Svcconf.obj \
-	$(OBJDIR)\Svcconf_Handler.obj
-EXTERNAL_LIBS = \
-LFLAGS = \
-	-j..\..\..\ACEXML\common\$(CONFIG_SUBDIR) -j..\..\..\ACEXML\common \
-	-L..\..\..\ACEXML\common\$(CONFIG_SUBDIR) -L..\..\..\ACEXML\common \
-	-j..\..\..\ACEXML\parser\parser\$(CONFIG_SUBDIR) -j..\..\..\ACEXML\parser\parser \
-	-L..\..\..\ACEXML\parser\parser\$(CONFIG_SUBDIR) -L..\..\..\ACEXML\parser\parser \
-	-j..\..\..\ace\$(CONFIG_SUBDIR) -j..\..\..\ace \
-	-L..\..\..\ace\$(CONFIG_SUBDIR) -L..\..\..\ace \
-  -j$(CORE_BINDIR) \
-  -L$(CORE_BINDIR)
-LIBFILES = \
-	ACEXML_Parser$(LIB_DECORATOR).lib \
-	ACEXML$(LIB_DECORATOR).lib \
-	ACE$(LIB_DECORATOR).lib \
-	$(EXTERNAL_LIBS)
-!ifdef STATIC
-LIB_FLAGS = -DACE_AS_STATIC_LIBS
-DLL_FLAGS =
-!else
-LIB_FLAGS =
-DLL_FLAGS =
-!endif
-CFLAGS = \
-	-I..\..\.. \
-	$(LIB_FLAGS) \
-	$(DLL_FLAGS)
-CPPDIR = .
-INCLUDES = \
-	Svcconf.h \
-	Svcconf_Handler.h \
-	Svcconf_Handler.i
-BASE_BINDIR = ..\..\..\bin
-!include <$(ACE_ROOT)\include\makeinclude\build_library.bor>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Makefile.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Makefile.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Makefile.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,23 +0,0 @@
-all:
-clean:
-realclean:
-install:
-regenerate:
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/README
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/README	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/README	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,4 +0,0 @@
-README,v 1.2 2002/05/08 21:54:08 nanbor Exp
-This directory implement a DLL that contains the parser for XML based
-service configurator.
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,131 +0,0 @@
-// Svcconf.cpp,v 1.8 2003/06/25 04:33:31 nanbor Exp
-#include "Svcconf.h"
-#include "ACEXML/common/FileCharStream.h"
-#include "ACEXML/common/StrCharStream.h"
-#include "ACEXML/parser/parser/Parser.h"
-#if (ACE_USES_CLASSIC_SVC_CONF == 0)
-extern "C" ACE_Proper_Export_Flag ACE_XML_Svc_Conf *
-_ACEXML_create_XML_Svc_Conf_Object (void)
-  ACE_XML_Svc_Conf *retp = 0;
-  ACE_NEW_RETURN (retp,
-                  ACEXML_Svcconf_Parser (),
-                  0);
-  return retp;
-ACEXML_Svcconf_Parser::ACEXML_Svcconf_Parser ()
-  this->parser_.setContentHandler (&this->svcconf_handler_);
-  this->parser_.setDTDHandler (&this->svcconf_handler_);
-  this->parser_.setErrorHandler (&this->svcconf_handler_);
-  this->parser_.setEntityResolver (&this->svcconf_handler_);
-  ACEXML_TRY_NEW_ENV
-      this->parser_.setFeature (ACE_TEXT ("http://xml.org/sax/features/validation"),
-                                0
-                                ACEXML_ENV_ARG_PARAMETER);
-      ACEXML_TRY_CHECK;
-  ACEXML_CATCH (ACEXML_SAXException, ex)
-      ex.print ();              // Can't do much except printing the error.
-      return;
-  ACEXML_ENDTRY;
-ACEXML_Svcconf_Parser::~ACEXML_Svcconf_Parser ()
-void *
-ACEXML_Svcconf_Parser::operator new (size_t s)
-  return ::new char[s];
-void
-ACEXML_Svcconf_Parser::operator delete (void *p)
-  delete[] (char*)p;
-int
-ACEXML_Svcconf_Parser::parse_file (const ACE_TCHAR file[])
-  if (file == 0)
-    ACE_ERROR_RETURN ((LM_ERROR, "ACEXML_Svcconf_Parser: No filename specified\n"), -1);
-  ACEXML_FileCharStream *fstm = 0;
-  ACE_NEW_RETURN (fstm,
-                  ACEXML_FileCharStream (),
-                  1);
-  if (fstm->open (file) != 0)
-                       ACE_TEXT ("ACEXML_Svcconf_Parser: Fail to open XML file: %s\n"),
-                       file),
-                      -1);
-  this->input_stream_.setCharStream (fstm);
-      this->parser_.parse (&this->input_stream_ ACEXML_ENV_ARG_PARAMETER);
-      ACEXML_TRY_CHECK;
-      ex.print ();
-      return -1;
-  ACEXML_ENDTRY;
-  return 0;
-int
-ACEXML_Svcconf_Parser::parse_string (const ACE_TCHAR str[])
-  if (str == 0)
-    ACE_ERROR_RETURN ((LM_ERROR, "ACEXML_Svcconf_Parser: Can't parse a null string\n"), -1);
-  ACEXML_StrCharStream *stm = 0;
-  ACE_NEW_RETURN (stm, ACEXML_StrCharStream, -1);
-  if (stm->open (str, ACE_TEXT ("Svcconf")) < 0)
-    ACE_ERROR_RETURN ((LM_ERROR, "ACEXML_Svcconf_Parser: Unable to create "
-                       "input stream.\n"), -1);
-  this->input_stream_.setCharStream (stm);
-      ACEXML_TRY_CHECK;
-      ex.print ();
-      return -1;
-  ACEXML_ENDTRY;
-  return 0;
-#else
-#  if defined (_AIX) && \
-     (defined (__IBMCPP__) && (__IBMCPP__ >= 500) && (__IBMCPP__ < 600))
-// This simply shuts up the AIX linker that complains there are no
-// csects or exported symbols when building with Visual Age C++ 5.
-extern "C" void ace_shut_up_aix_ld (void) {};
-#  endif /* AIX && __IBMCPP__ == 500 */
-#endif /* ACE_USES_CLASSIC_SVC_CONF == 0 */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,48 +0,0 @@
-/* -*- C++ -*- */
- *  @file    Svcconf.h
- *  Svcconf.h,v 1.6 2003/07/19 19:04:10 dhinton Exp
- *  @author Nanbor Wang <nanbor at cs.wustl.edu>
-#ifndef ACEXML_SVCCONF_H
-#define ACEXML_SVCCONF_H
-#include /**/ "ace/pre.h"
-#include "ace/XML_Svc_Conf.h"
-#include "Svcconf_Handler.h"
-class ACEXML_Svcconf_Parser : public ACE_XML_Svc_Conf
-public:
-  ACEXML_Svcconf_Parser ();
-  virtual ~ACEXML_Svcconf_Parser ();
-  virtual int parse_file (const ACE_TCHAR file[]);
-  virtual int parse_string (const ACE_TCHAR str[]);
-  void * operator new (size_t bytes);
-  void operator delete (void *ptr);
-protected:
-  ACEXML_Parser parser_;
-  ACEXML_Svcconf_Handler svcconf_handler_;
-  ACEXML_InputSource input_stream_;
-#include /**/ "ace/post.h"
-#endif /* ACEXML_SVCCONF_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf_Handler.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf_Handler.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf_Handler.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,643 +0,0 @@
-// -*- C++ -*-  Svcconf_Handler.cpp,v 1.11 2003/12/09 17:48:13 jwillemsen Exp
-#include "ace/ACE.h"
-#include "ace/Log_Msg.h"
-#include "ace/Service_Config.h"
-#include "ace/Service_Types.h"
-#include "ace/Service_Repository.h"
-#include "ace/DLL.h"
-#include "ace/ARGV.h"
-#include "ace/Module.h"
-#include "ace/OS_NS_strings.h"
-#if !defined (__ACEXML_INLINE__)
-# include "Svcconf_Handler.i"
-#endif /* __ACEXML_INLINE__ */
-ACEXML_Svcconf_Handler::ACEXML_Svcconf_Handler (void)
-  : in_stream_def_ (0),
-    in_module_ (0),
-    stream_svc_type_ (0),
-    stream_ (0)
-  // no-op
-ACEXML_Svcconf_Handler::~ACEXML_Svcconf_Handler (void)
-  // no-op
-void
-ACEXML_Svcconf_Handler::characters (const ACEXML_Char *,
-                                    int,
-                                    int ACEXML_ENV_ARG_DECL_NOT_USED)
-      ACE_THROW_SPEC ((ACEXML_SAXException))
-  // no-op
-void
-ACEXML_Svcconf_Handler::endDocument ( ACEXML_ENV_SINGLE_ARG_DECL_NOT_USED)
-  // no-op
-void
-ACEXML_Svcconf_Handler::endElement (const ACEXML_Char *,
-                                    const ACEXML_Char *,
-                                    const ACEXML_Char *qName ACEXML_ENV_ARG_DECL)
-  if (ACE_OS::strcmp (qName, ACE_TEXT ("dynamic")) == 0)
-      ACE_Parsed_Info *active_info = (this->in_stream_def_ == 0 ?
-                                      &this->parsed_info_ :
-                                      &this->stream_info_);
-      ACE_DLL svc_dll;
-      if (svc_dll.open (active_info->path ()) == -1)
-          ACEXML_THROW (ACEXML_SAXException (ACE_TEXT("Cannot locate DLL\n")));
-      void *(*func) (ACE_Service_Object_Exterminator *) = 0;
-      ACE_Service_Object_Exterminator gobbler = 0;
-      void *symbol = 0;
-      long temp_ptr =
-        ACE_reinterpret_cast(long, svc_dll.symbol (active_info->init_func ()));
-      func = ACE_reinterpret_cast(void *(*)(ACE_Service_Object_Exterminator *),
-                                  temp_ptr);
-      if (func == 0)
-          ACEXML_THROW (ACEXML_SAXException (ACE_TEXT ("Cannot locate init function\n")));
-      symbol = (*func)(&gobbler); // target object created in the loaded DLL.
-      ACE_Service_Type_Impl *stp = ACE_Service_Config::create_service_type_impl
-        (active_info->name (),
-         active_info->service_type (),
-         symbol,
-         ACE_Service_Type::DELETE_THIS |
-         ACE_Service_Type::DELETE_OBJ,
-         gobbler);
-      if (this->in_stream_def_)
-//           ACE_DEBUG ((LM_INFO, ACE_TEXT ("Create dynamic %s for stream\n"),
-//                       this->stream_info_.name ()));
-          if (active_info->service_type () == ACE_Service_Type::STREAM)
-              this->stream_ = (ACE_Stream_Type *) stp;
-          else
-              ACEXML_THROW (ACEXML_SAXException (ACE_TEXT ("Expecting Stream type in stream header\n")));
-          this->stream_svc_type_ =
-            ACE_Service_Config::create_service_type (this->stream_info_.name (),
-                                                     this->stream_,
-                                                     svc_dll,
-                                                     this->stream_info_.active ());
-      else
-          if (this->in_module_)
-              ACE_ARGV args (active_info->init_params ());
-              ACE_Module_Type *mt = (ACE_Module_Type *) stp;
-              ACE_Module<ACE_SYNCH> *mp = (ACE_Module<ACE_SYNCH> *) mt->object ();
-              if (ACE_OS::strcmp (mp->name (), active_info->name ()) != 0)
-                  ACE_DEBUG ((LM_DEBUG,
-                              ACE_TEXT ("warning: assigning Module_Type name %s to Module %s since names differ\n"),
-                              active_info->name (),
-                              mp->name ()));
-                  mp->name (active_info->name ());
-              if (mt->init (args.argc (), args.argv ()) == -1
-                  || this->stream_->push (mt) == -1)
-                  ACEXML_THROW (ACEXML_SAXException (ACE_TEXT ("Error initializing module")));
-//               ACE_DEBUG ((LM_INFO, ACE_TEXT ("Push dynamic %s into stream %s\n"),
-//                           this->parsed_info_.name (),
-          else
-              ACE_Service_Type *stype =
-                ACE_Service_Config::create_service_type (active_info->name (),
-                                                         stp,
-                                                         svc_dll,
-                                                         active_info->active ());
-              // @@ Check error here.
-              //               ACE_DEBUG ((LM_INFO, ACE_TEXT ("Apply dynamic %s\n"),
-//                           this->parsed_info_.name ()));
-              if (ACE_Service_Config::initialize (stype,
-                                                  active_info->init_params ()) == -1)
-                  ACEXML_THROW (ACEXML_SAXException (ACE_TEXT ("Failed to initialize dynamic service\n")));
-          this->parsed_info_.reset ();
-  else if (ACE_OS::strcmp (qName, ACE_TEXT ("static")) == 0)
-          // @@ Couldn't make sense out of the original Svc_Conf.y.
-          ACE_DEBUG ((LM_ERROR, ACE_TEXT ("Create static %s for stream\n"),
-                      this->stream_info_.name ()));
-      else
-              ACE_DEBUG ((LM_ERROR, ACE_TEXT ("Push static %s into stream %s\n"),
-                          this->parsed_info_.name (),
-          else
-//               ACE_DEBUG ((LM_INFO, ACE_TEXT ("Apply static %s\n"),
-              if (ACE_Service_Config::initialize (this->parsed_info_.name (),
-                                                  this->parsed_info_.init_params ()) == -1)
-                  ACEXML_THROW (ACEXML_SAXException (ACE_TEXT ("Failed to initialize static service\n")));
-  else if (ACE_OS::strcmp (qName, ACE_TEXT ("module")) == 0)
-      this->in_module_ = 0;
-  else if (ACE_OS::strcmp (qName, ACE_TEXT ("streamdef")) == 0)
-//       ACE_DEBUG ((LM_INFO, ACE_TEXT ("Apply stream %s of type %s\n"),
-//                   this->stream_info_.name (),
-      ACE_Service_Config::initialize (this->stream_svc_type_,
-                                      this->stream_info_.init_params ());
-      this->stream_info_.reset ();
-      this->stream_svc_type_ = 0;
-      this->stream_ = 0;
-  else if (ACE_OS::strcmp (qName, ACE_TEXT ("stream")) == 0)
-  else
-void
-ACEXML_Svcconf_Handler::endPrefixMapping (const ACEXML_Char * ACEXML_ENV_ARG_DECL_NOT_USED)
-  // no-op
-void
-ACEXML_Svcconf_Handler::ignorableWhitespace (const ACEXML_Char *,
-                                             int,
-  // no-op
-void
-ACEXML_Svcconf_Handler::processingInstruction (const ACEXML_Char *,
-                                               const ACEXML_Char * ACEXML_ENV_ARG_DECL_NOT_USED)
-  // no-op
-void
-ACEXML_Svcconf_Handler::setDocumentLocator (ACEXML_Locator* locator)
-  this->locator_ = locator;
-void
-ACEXML_Svcconf_Handler::skippedEntity (const ACEXML_Char * ACEXML_ENV_ARG_DECL_NOT_USED)
-  // no-op
-void
-ACEXML_Svcconf_Handler::startDocument ( ACEXML_ENV_SINGLE_ARG_DECL_NOT_USED)
-  // no-op
-void
-ACEXML_Svcconf_Handler::startElement (const ACEXML_Char *,
-                                      const ACEXML_Char *qName,
-                                      ACEXML_Attributes *alist ACEXML_ENV_ARG_DECL)
-      this->get_dynamic_attrs (alist ACEXML_ENV_ARG_PARAMETER);
-  else if (ACE_OS::strcmp (qName, ACE_TEXT ("initializer")) == 0)
-      this->get_initializer_attrs (alist ACEXML_ENV_ARG_PARAMETER);
-      this->get_static_attrs (alist ACEXML_ENV_ARG_PARAMETER);
-      this->get_stream_id (alist ACEXML_ENV_ARG_PARAMETER);
-      if (ACE_Service_Repository::instance()->find
-          (this->stream_info_.name (),
-           (const ACE_Service_Type **) &this->stream_svc_type_) == -1)
-          ACEXML_THROW (ACEXML_SAXException (ACE_TEXT ("Cannot find stream\n")));
-      this->stream_ =   this->stream_svc_type_ == 0
-        ? 0
-        : ACE_dynamic_cast (ACE_Stream_Type *,
-                            ACE_const_cast (ACE_Service_Type_Impl *,
-                                            this->stream_svc_type_->type ()));
-//       ACE_DEBUG ((LM_INFO, ACE_TEXT ("Retrieve stream %s from repository\n"),
-      this->in_stream_def_ = 1;
-      // @@ Set up stream service object
-      this->in_stream_def_ = 0;
-      this->in_module_ = 1;
-  else if (ACE_OS::strcmp (qName, ACE_TEXT ("resume")) == 0)
-      this->get_id (alist ACEXML_ENV_ARG_PARAMETER);
-//           ACE_DEBUG ((LM_INFO, ACE_TEXT ("Resume %s in stream %s\n"),
-          ACE_Module_Type *mt = (this->stream_ == 0)
-            ? 0
-            : this->stream_->find (this->parsed_info_.name ());
-          if (mt == 0)
-              ACEXML_THROW (ACEXML_SAXException (ACE_TEXT ("Can't locate module\n")));
-          mt->resume ();
-      else
-//           ACE_DEBUG ((LM_INFO, ACE_TEXT ("Resume %s\n"),
-          if (ACE_Service_Config::resume (this->parsed_info_.name ()) == -1)
-              ACEXML_THROW (ACEXML_SAXException (ACE_TEXT ("Resume fail\n")));
-  else if (ACE_OS::strcmp (qName, ACE_TEXT ("suspend")) == 0)
-//           ACE_DEBUG ((LM_INFO, ACE_TEXT ("Suspend %s in stream %s\n"),
-            ? 0
-          if (mt == 0)
-          mt->suspend ();
-      else
-          //          ACE_DEBUG ((LM_INFO, ACE_TEXT ("Suspend %s\n"),
-          //                      this->parsed_info_.name ()));
-          if (ACE_Service_Config::suspend (this->parsed_info_.name ()) == -1)
-              ACEXML_THROW (ACEXML_SAXException (ACE_TEXT ("Suspend failed\n")));
-  else if (ACE_OS::strcmp (qName, ACE_TEXT ("remove")) == 0)
-//           ACE_DEBUG ((LM_INFO, ACE_TEXT ("Remove %s in stream %s\n"),
-            ? 0
-          if (mt == 0)
-          this->stream_->remove (mt);
-      else
-//           ACE_DEBUG ((LM_INFO, ACE_TEXT ("Remove %s\n"),
-          if (ACE_Service_Config::remove (this->parsed_info_.name ()) == -1)
-              ACEXML_THROW (ACEXML_SAXException (ACE_TEXT ("Remove failed\n")));
-  else if (ACE_OS::strcmp (qName, ACE_TEXT ("ACE_Svc_Conf")) == 0)
-      // Main document tag. no-op.
-//       ACE_DEBUG ((LM_INFO, ACE_TEXT ("ACE_Svc_Conf tag\n")));
-  else
-      // @@ Error.  Perhaps we should relay to user event handler here, if available.
-  return;
-void
-ACEXML_Svcconf_Handler::startPrefixMapping (const ACEXML_Char *,
-  // No-op.
-// *** Methods inherit from ACEXML_DTDHandler.
-void
-ACEXML_Svcconf_Handler::notationDecl (const ACEXML_Char *,
-  // No-op.
-void
-ACEXML_Svcconf_Handler::unparsedEntityDecl (const ACEXML_Char *,
-  // No-op.
-// Methods inherit from ACEXML_EnitityResolver.
-ACEXML_InputSource *
-ACEXML_Svcconf_Handler::resolveEntity (const ACEXML_Char *,
-  // No-op.
-  return 0;
-// Methods inherit from ACEXML_ErrorHandler.
-   * Receive notification of a recoverable error.
-void
-ACEXML_Svcconf_Handler::error (ACEXML_SAXParseException& ex ACEXML_ENV_ARG_DECL_NOT_USED)
-  ACE_DEBUG ((LM_DEBUG, "%s: line :%d col: %d ", this->locator_->getSystemId(),
-              this->locator_->getLineNumber(),
-              this->locator_->getColumnNumber()));
-  ex.print();
-void
-ACEXML_Svcconf_Handler::fatalError (ACEXML_SAXParseException& ex ACEXML_ENV_ARG_DECL_NOT_USED)
-  ex.print();
-void
-ACEXML_Svcconf_Handler::warning (ACEXML_SAXParseException& ex ACEXML_ENV_ARG_DECL_NOT_USED)
-  ex.print();
-int
-ACEXML_Svcconf_Handler::get_stream_id (ACEXML_Attributes *alist ACEXML_ENV_ARG_DECL)
-  if (alist != 0)
-    for (size_t i = 0; i < alist->getLength (); ++i)
-        if (ACE_OS::strcmp (alist->getQName (i), ACE_TEXT ("id")) == 0)
-            this->stream_info_.name (alist->getValue (i));
-        else
-            ACEXML_THROW_RETURN (ACEXML_SAXException (ACE_TEXT ("Invalid stream attribute\n")),
-													  -1);
-  return 0;
-int
-ACEXML_Svcconf_Handler::get_id (ACEXML_Attributes *alist ACEXML_ENV_ARG_DECL)
-  if (alist != 0)
-            this->parsed_info_.name (alist->getValue (i));
-        else
-            ACEXML_THROW_RETURN (ACEXML_SAXException (ACE_TEXT ("Invalid attribute, expecting 'id'\n")), -1);
-  return 0;
-int
-ACEXML_Svcconf_Handler::get_dynamic_attrs (ACEXML_Attributes *alist ACEXML_ENV_ARG_DECL)
-  if (alist != 0)
-      ACE_Parsed_Info *info = (this->in_stream_def_ == 0 ?
-              info->name (alist->getValue (i));
-          else if (ACE_OS::strcmp (alist->getQName (i), ACE_TEXT ("status")) == 0)
-              if (ACE_OS::strcmp (alist->getValue (i), ACE_TEXT ("inactive")) == 0)
-                  info->active (0);
-              else if (ACE_OS::strcmp (alist->getValue (i), ACE_TEXT ("active")) == 0)
-                  info->active (1);
-              else
-                  ACEXML_THROW_RETURN (ACEXML_SAXException (ACE_TEXT ("Invalid attribute value, expecting 'active' or 'inactive'\n")), -1);
-          else if (ACE_OS::strcmp (alist->getQName (i), ACE_TEXT ("type")) == 0)
-              if (ACE_OS::strcasecmp (alist->getValue (i), ACE_TEXT ("service_object")) == 0)
-                  info->service_type (ACE_Service_Type::SERVICE_OBJECT);
-              else if (ACE_OS::strcasecmp (alist->getValue (i), ACE_TEXT ("stream")) == 0)
-                  info->service_type (ACE_Service_Type::STREAM);
-              else if (ACE_OS::strcasecmp (alist->getValue (i), ACE_TEXT ("module")) == 0)
-                  info->service_type (ACE_Service_Type::MODULE);
-              else
-                  ACEXML_THROW_RETURN (ACEXML_SAXException (ACE_TEXT ("Invalid Service_Object attribute value\n")), -1);
-          else
-              ACEXML_THROW_RETURN(ACEXML_SAXException(ACE_TEXT ("Invalid attribute\n")), -1);
-  return 0;
-int
-ACEXML_Svcconf_Handler::get_initializer_attrs (ACEXML_Attributes *alist ACEXML_ENV_ARG_DECL)
-  if (alist != 0)
-          if (ACE_OS::strcmp (alist->getQName (i), ACE_TEXT ("init")) == 0)
-              info->init_func (alist->getValue (i));
-          else if (ACE_OS::strcmp (alist->getQName (i), ACE_TEXT ("path")) == 0)
-              info->path (alist->getValue (i));
-          else if (ACE_OS::strcmp (alist->getQName (i), ACE_TEXT ("params")) == 0)
-              info->init_params (alist->getValue (i));
-          else
-              ACEXML_THROW_RETURN (ACEXML_SAXException (ACE_TEXT ("Invalid initializer attribute.\n")), -1);
-  return 0;
-int
-ACEXML_Svcconf_Handler::get_static_attrs (ACEXML_Attributes *alist ACEXML_ENV_ARG_DECL)
-  if (alist != 0)
-          else
-              ACEXML_THROW_RETURN (ACEXML_SAXException (ACE_TEXT ("Invalid static attribute.\n")), -1);
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf_Handler.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf_Handler.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf_Handler.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,292 +0,0 @@
-// Svcconf_Handler.h,v 1.6 2002/10/13 03:58:57 kitty Exp
- *  @file    Svcconf_Handler.h
- *  Svcconf_Handler.h,v 1.6 2002/10/13 03:58:57 kitty Exp
-#ifndef ACEXML_SVCCONF_HANDLER_H
-#define ACEXML_SVCCONF_HANDLER_H
-#include "ACEXML/common/DefaultHandler.h"
-class ACE_Parsed_Info
-public:
-  ACE_Parsed_Info ();
-  ~ACE_Parsed_Info ();
-   * Set/get name of a parsed entity.
-  int name (const ACEXML_Char *n);
-  const ACEXML_Char *name (void);
-   * Set/get type of a dynamic node.
-  int service_type (int type);
-  int service_type (void);
-   * Set/Get active status.
-  int active (int a);
-  int active (void);
-   * Set/get initializer path.
-  int path (const ACEXML_Char *n);
-  const ACEXML_Char *path (void);
-   * Set/get initializer init function.
-  int init_func (const ACEXML_Char *n);
-  const ACEXML_Char *init_func (void);
-   * Set/get initializer init parameter.
-  int init_params (const ACEXML_Char *n);
-  const ACEXML_Char *init_params (void);
-   * Reset Parsed_Info.
-  void reset (void);
-protected:
-  ACEXML_Char *name_;
-  int service_type_;
-  int active_;
-  ACEXML_Char *path_;
-  ACEXML_Char *init_func_;
-  ACEXML_Char *init_params_;
- * @class ACEXML_Svcconf_Handler
- * @brief ACEXML_Svcconf_Handler is an example SAX event handler.
- * This SAX event handler try to regenerate the XML document it
- * reads with correct indentation.
-class ACEXML_Svcconf_Handler : public ACEXML_DefaultHandler
-public:
-   * Default constructor.
-  ACEXML_Svcconf_Handler (void);
-   * Default destructor.
-  virtual ~ACEXML_Svcconf_Handler (void);
-  // Methods inherit from ACEXML_ContentHandler.
-   * Receive notification of character data.
-  virtual void characters (const ACEXML_Char *ch,
-                           int start,
-                           int length ACEXML_ENV_ARG_DECL)
-   * Receive notification of the end of a document.
-  virtual void endDocument (ACEXML_ENV_SINGLE_ARG_DECL)
-   * Receive notification of the end of an element.
-  virtual void endElement (const ACEXML_Char *namespaceURI,
-                           const ACEXML_Char *localName,
-   * End the scope of a prefix-URI mapping.
-  virtual void endPrefixMapping (const ACEXML_Char *prefix ACEXML_ENV_ARG_DECL)
-   * Receive notification of ignorable whitespace in element content.
-  virtual void ignorableWhitespace (const ACEXML_Char *ch,
-                                    int start,
-   * Receive notification of a processing instruction.
-  virtual void processingInstruction (const ACEXML_Char *target,
-                                      const ACEXML_Char *data ACEXML_ENV_ARG_DECL)
-   * Receive an object for locating the origin of SAX document events.
-  virtual void setDocumentLocator (ACEXML_Locator *locator) ;
-   * Receive notification of a skipped entity.
-  virtual void skippedEntity (const ACEXML_Char *name ACEXML_ENV_ARG_DECL)
-   * Receive notification of the beginning of a document.
-  virtual void startDocument (ACEXML_ENV_SINGLE_ARG_DECL)
-   * Receive notification of the beginning of an element.
-  virtual void startElement (const ACEXML_Char *namespaceURI,
-                             ACEXML_Attributes *atts ACEXML_ENV_ARG_DECL)
-   * Begin the scope of a prefix-URI Namespace mapping.
-  virtual void startPrefixMapping (const ACEXML_Char *prefix,
-                                   const ACEXML_Char *uri ACEXML_ENV_ARG_DECL)
-  // *** Methods inherit from ACEXML_DTDHandler.
-   * Receive notification of a notation declaration event.
-  virtual void notationDecl (const ACEXML_Char *name,
-                             const ACEXML_Char *publicId,
-                             const ACEXML_Char *systemId ACEXML_ENV_ARG_DECL)
-   * Receive notification of an unparsed entity declaration event.
-  virtual void unparsedEntityDecl (const ACEXML_Char *name,
-                                   const ACEXML_Char *systemId,
-                                   const ACEXML_Char *notationName ACEXML_ENV_ARG_DECL)
-  // Methods inherit from ACEXML_EnitityResolver.
-   * Allow the application to resolve external entities.
-  virtual ACEXML_InputSource *resolveEntity (const ACEXML_Char *publicId,
-  // Methods inherit from ACEXML_ErrorHandler.
-  virtual void error (ACEXML_SAXParseException &exception ACEXML_ENV_ARG_DECL)
-   * Receive notification of a non-recoverable error.
-  virtual void fatalError (ACEXML_SAXParseException &exception ACEXML_ENV_ARG_DECL)
-   * Receive notification of a warning.
-  virtual void warning (ACEXML_SAXParseException &exception ACEXML_ENV_ARG_DECL)
-protected:
-   * Get the only attribute in <stream> or <streamdef>.
-  int get_stream_id (ACEXML_Attributes *alist ACEXML_ENV_ARG_DECL);
-   * Get the only attribute in <resume>, <suspend>, <remove>
-  int get_id (ACEXML_Attributes *alist ACEXML_ENV_ARG_DECL);
-   * Get the dynamic tag attributes.
-  int get_dynamic_attrs (ACEXML_Attributes *alist ACEXML_ENV_ARG_DECL);
-   * Get the initializer tag attributes.
-  int get_initializer_attrs (ACEXML_Attributes *alist ACEXML_ENV_ARG_DECL);
-   * Get the static tag attributes.
-  int get_static_attrs (ACEXML_Attributes *alist ACEXML_ENV_ARG_DECL);
-private:
-  /// We are parsing a stream definition
-  int in_stream_def_;
-  /// We are defining a steam module
-  int in_module_;
-  /// @a stream_ holds the actually Stream_Type object managed by @a stream_svc_type_.
-  ACE_Service_Type *stream_svc_type_;
-  ACE_Stream_Type *stream_;
-  //ACE_SHLIB_HANDLE dll_handle_;
-  ACE_Parsed_Info parsed_info_;
-  ACE_Parsed_Info stream_info_;
-  ACEXML_Locator* locator_;
-#if defined (__ACEXML_INLINE__)
-#endif /* ACEXML_SVCCONF_HANDLER_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf_Handler.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf_Handler.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/Svcconf_Handler.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,133 +0,0 @@
-// -*- C++ -*-  Svcconf_Handler.i,v 1.3 2002/07/13 01:33:11 kitty Exp
-ACE_INLINE
-ACE_Parsed_Info::ACE_Parsed_Info ()
-  : name_ (0),
-    service_type_ (ACE_Service_Type::INVALID_TYPE),
-    active_ (1),
-    path_ (0),
-    init_func_ (0),
-    init_params_ (0)
-ACE_INLINE
-ACE_Parsed_Info::~ACE_Parsed_Info ()
-  delete[] this->name_;
-  delete[] this->path_;
-  delete[] this->init_func_;
-  delete[] this->init_params_;
-ACE_INLINE int
-ACE_Parsed_Info::name (const ACEXML_Char *n)
-  if (this->name_ == 0)
-      this->name_ = ACE::strnew (n);
-      return 0;
-  return -1;
-ACE_INLINE const ACEXML_Char *
-ACE_Parsed_Info::name (void)
-  return this->name_;
-ACE_INLINE int
-ACE_Parsed_Info::service_type (int type)
-  if (this->service_type_ == -1)
-      this->service_type_ = type;
-      return 0;
-  return -1;
-ACE_INLINE int
-ACE_Parsed_Info::service_type (void)
-  return this->service_type_;
-ACE_INLINE int
-ACE_Parsed_Info::active (int a)
-  this->active_ = a;
-  return 0;
-ACE_INLINE int
-ACE_Parsed_Info::active (void)
-  return this->active_;
-ACE_INLINE int
-ACE_Parsed_Info::path (const ACEXML_Char *p)
-  if (this->path_ == 0)
-      this->path_ = ACE::strnew (p);
-      return 0;
-  return -1;
-ACE_Parsed_Info::path (void)
-  return this->path_;
-ACE_INLINE int
-ACE_Parsed_Info::init_func (const ACEXML_Char *n)
-  if (this->init_func_ == 0)
-      this->init_func_ = ACE::strnew (n);
-      return 0;
-  return -1;
-ACE_Parsed_Info::init_func (void)
-  return this->init_func_;
-ACE_INLINE int
-ACE_Parsed_Info::init_params (const ACEXML_Char *n)
-  if (this->init_params_ == 0)
-      this->init_params_ = ACE::strnew (n);
-      return 0;
-  return -1;
-ACE_Parsed_Info::init_params (void)
-  return this->init_params_;
-ACE_INLINE void
-ACE_Parsed_Info::reset (void)
-  this->name_ = 0;
-  this->service_type_ = -1;
-  this->path_ = 0;
-  this->init_func_ = 0;
-  this->init_params_ = 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/svcconf.dtd
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/svcconf.dtd	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/svcconf.dtd	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,60 +0,0 @@
-<!-- svcconf.dtd,v 1.1 2003/05/30 03:31:48 kitty Exp   -->
-<!-- Document Type Definition for XML ACE Service Config files -->
-<!-- An ACE_Svc_Conf document contains zero or more entries    -->
-<!--   The entries are processed in the order they appear      -->
-<!--   in the ACE_Svc_Conf file.                               -->
-<!ELEMENT ACE_Svc_Conf (dynamic|static|suspend|resume|remove|stream|streamdef)*>
-<!-- Streams are separate into two elements.  One defines how  -->
-<!-- the stream should be constructed and the other defines    -->
-<!-- what to do with it.  The identity of a stream is defined  -->
-<!-- in the first dynamic/static element.  -->
-<!ELEMENT streamdef ((dynamic|static),module)>
-<!-- @@ Do we ever need to suspend/resume/remove modules when  -->
-<!--    constructing a stream?  Should we leave only dynamic   -->
-<!--    and static here?  -->
-<!ELEMENT module (dynamic|static|suspend|resume|remove)+>
-<!-- A 'stream' element controls the stream object -->
-<!-- @@ Likewise, we are reusing the 'module' element here.    -->
-<!--    Do we ever need to insert new modules into a stream?   -->
-<!--    Nanbor: I guess we can do that.  -->
-<!ELEMENT stream (module)>
-<!ATTLIST stream id IDREF #REQUIRED>
-<!-- A 'dynamic' entry. -->
-<!-- @@ The kind of attributes the corresponding initializer   -->
-<!--    should take seems to be determined by the 'type'       -->
-<!--    attribute.  Should we further partition the dynamic    -->
-<!--    element definition into several elements?  E.g. into   -->
-<!--    dyn_service_object/dyn_module/dyn_stream?              -->
-<!--    Nanbor: Will that be too confusing? -->
-<!ELEMENT dynamic (initializer)>
-<!ATTLIST dynamic id ID #REQUIRED
-                  status (active|inactive) "active"
-                  type (module|service_object|stream) #REQUIRED>
-<!-- Initializing function for dynamic entry.  -->
-<!ELEMENT initializer EMPTY>
-<!ATTLIST initializer init CDATA #REQUIRED
-                      path CDATA #IMPLIED
-                      params CDATA #IMPLIED>
-<!-- A 'static' entry takes an ID attribute and an optional -->
-<!-- parameter lists.  -->
-<!ELEMENT static EMPTY>
-<!ATTLIST static id ID #REQUIRED
-<!-- A 'suspend' entry takes an ID attribute.  -->
-<!ELEMENT suspend EMPTY>
-<!ATTLIST suspend id IDREF #REQUIRED>
-<!-- A 'resume' entry takes an ID attribute.  -->
-<!ELEMENT resume EMPTY>
-<!ATTLIST resume id IDREF #REQUIRED>
-<!-- A 'remove' entry takes an ID attribute.  -->
-<!ELEMENT remove EMPTY>
-<!ATTLIST remove id IDREF #REQUIRED>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/svcconf.mpc
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/svcconf.mpc	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/apps/svcconf/svcconf.mpc	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,6 +0,0 @@
-//  -*- MPC -*-
-// svcconf.mpc,v 1.3 2003/11/10 04:31:58 dhinton Exp
-project(ACEXML_XML_Svc_Conf_Parser): acelib, acexml {
-  sharedname = ACEXML_XML_Svc_Conf_Parser
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ACEXML.dsp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ACEXML.dsp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ACEXML.dsp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,359 +0,0 @@
-# Microsoft Developer Studio Project File - Name="ACEXML DLL" - Package Owner=<4>
-CFG=ACEXML DLL - Win32 Debug
-!MESSAGE
-!MESSAGE NMAKE /f "ACEXML.mak".
-!MESSAGE
-!MESSAGE
-!MESSAGE NMAKE /f "ACEXML.mak" CFG="ACEXML DLL - Win32 Debug"
-!MESSAGE
-!MESSAGE
-!MESSAGE "ACEXML DLL - Win32 Release" (based on "Win32 (x86) Dynamic-Link Library")
-!MESSAGE "ACEXML DLL - Win32 Debug" (based on "Win32 (x86) Dynamic-Link Library")
-!MESSAGE
-# Begin Project
-CPP=cl.exe
-RSC=rc.exe
-!IF  "$(CFG)" == "ACEXML DLL - Win32 Release"
-# PROP Use_MFC 0
-# PROP Intermediate_Dir "Release\ACEXML"
-# ADD CPP /nologo /W3 /GX /O2 /MD /Zi /GR /I "..\.." /D NDEBUG=1 /D WIN32=1 /D _WINDOWS=1 /D ACEXML_BUILD_DLL=1 /FD /c
-# SUBTRACT CPP /YX
-# ADD RSC /l 0x409 /d NDEBUG=1 /i "..\.."
-BSC32=bscmake.exe
-# ADD BSC32 /nologo /o".\ACEXML.bsc"
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACE.lib /libpath:"..\..\ace" /nologo /version:5.3.1 /subsystem:windows /pdb:"..\..\bin\ACEXML.pdb" /dll  /machine:I386 /out:"..\..\bin\ACEXML.dll"
-!ELSEIF  "$(CFG)" == "ACEXML DLL - Win32 Debug"
-# PROP Use_MFC 0
-# PROP Intermediate_Dir "Debug\ACEXML"
-# ADD CPP /nologo /W3 /Gm /GX /Zi /Od /MDd /GR /Gy /I "..\.." /D _DEBUG=1 /D WIN32=1 /D _WINDOWS=1 /D ACEXML_BUILD_DLL=1 /FD /c
-# ADD RSC /l 0x409 /d _DEBUG=1 /i "..\.."
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACEd.lib /libpath:"..\..\ace" /nologo /version:5.3.1 /subsystem:windows /pdb:"..\..\bin\ACEXMLd.pdb" /dll /debug /machine:I386 /out:"..\..\bin\ACEXMLd.dll"
-!ENDIF
-# Begin Target
-# Name "ACEXML DLL - Win32 Release"
-# Name "ACEXML DLL - Win32 Debug"
-SOURCE=.\Attributes_Def_Builder.cpp
-# End Source File
-SOURCE=.\AttributesImpl.cpp
-# End Source File
-SOURCE=.\CharStream.cpp
-# End Source File
-SOURCE=.\DefaultHandler.cpp
-# End Source File
-SOURCE=.\DTD_Manager.cpp
-# End Source File
-SOURCE=.\Element_Def_Builder.cpp
-# End Source File
-SOURCE=.\Encoding.cpp
-# End Source File
-SOURCE=.\Env.cpp
-# End Source File
-SOURCE=.\Exception.cpp
-# End Source File
-SOURCE=.\FileCharStream.cpp
-# End Source File
-SOURCE=.\HttpCharStream.cpp
-# End Source File
-SOURCE=.\InputSource.cpp
-# End Source File
-SOURCE=.\LocatorImpl.cpp
-# End Source File
-SOURCE=.\Mem_Map_Stream.cpp
-# End Source File
-SOURCE=.\NamespaceSupport.cpp
-# End Source File
-SOURCE=.\SAXExceptions.cpp
-# End Source File
-SOURCE=.\StrCharStream.cpp
-# End Source File
-SOURCE=.\StreamFactory.cpp
-# End Source File
-SOURCE=.\Transcode.cpp
-# End Source File
-SOURCE=.\URL_Addr.cpp
-# End Source File
-SOURCE=.\Validator.cpp
-# End Source File
-SOURCE=.\XML_Codecs.cpp
-# End Source File
-SOURCE=.\XMLFilterImpl.cpp
-# End Source File
-SOURCE=.\ZipCharStream.cpp
-# End Source File
-# End Group
-SOURCE=.\ACEXML_Export.h
-# End Source File
-SOURCE=.\Attributes.h
-# End Source File
-SOURCE=.\Attributes_Def_Builder.h
-# End Source File
-SOURCE=.\AttributesImpl.h
-# End Source File
-SOURCE=.\CharStream.h
-# End Source File
-SOURCE=.\ContentHandler.h
-# End Source File
-SOURCE=.\DefaultHandler.h
-# End Source File
-SOURCE=.\DTD_Manager.h
-# End Source File
-SOURCE=.\DTDHandler.h
-# End Source File
-SOURCE=.\Element_Def_Builder.h
-# End Source File
-SOURCE=.\Encoding.h
-# End Source File
-SOURCE=.\EntityResolver.h
-# End Source File
-SOURCE=.\Env.h
-# End Source File
-SOURCE=.\ErrorHandler.h
-# End Source File
-SOURCE=.\Exception.h
-# End Source File
-SOURCE=.\FileCharStream.h
-# End Source File
-SOURCE=.\HttpCharStream.h
-# End Source File
-SOURCE=.\InputSource.h
-# End Source File
-SOURCE=.\Locator.h
-# End Source File
-SOURCE=.\LocatorImpl.h
-# End Source File
-SOURCE=.\Mem_Map_Stream.h
-# End Source File
-SOURCE=.\NamespaceSupport.h
-# End Source File
-SOURCE=.\SAXExceptions.h
-# End Source File
-SOURCE=.\StrCharStream.h
-# End Source File
-SOURCE=.\StreamFactory.h
-# End Source File
-SOURCE=.\Transcode.h
-# End Source File
-SOURCE=.\URL_Addr.h
-# End Source File
-SOURCE=.\Validator.h
-# End Source File
-SOURCE=.\XML_Codecs.h
-# End Source File
-SOURCE=.\XML_Macros.h
-# End Source File
-SOURCE=.\XML_Types.h
-# End Source File
-SOURCE=.\XMLFilter.h
-# End Source File
-SOURCE=.\XMLFilterImpl.h
-# End Source File
-SOURCE=.\XMLReader.h
-# End Source File
-SOURCE=.\ZipCharStream.h
-# End Source File
-# End Group
-SOURCE=.\AttributesImpl.i
-# End Source File
-SOURCE=.\DefaultHandler.i
-# End Source File
-SOURCE=.\Env.i
-# End Source File
-SOURCE=.\Exception.i
-# End Source File
-SOURCE=.\LocatorImpl.i
-# End Source File
-SOURCE=.\NamespaceSupport.i
-# End Source File
-SOURCE=.\SAXExceptions.i
-# End Source File
-SOURCE=.\Transcode.i
-# End Source File
-SOURCE=.\URL_Addr.inl
-# End Source File
-SOURCE=.\XMLFilterImpl.i
-# End Source File
-# End Group
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ACEXML_Export.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ACEXML_Export.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ACEXML_Export.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,49 +0,0 @@
-// -*- C++ -*-
- *  @file    ACEXML_Export.h
- *  ACEXML_Export.h,v 1.3 2003/03/12 15:56:42 elliott_c Exp
-// Definition for Win32 Export directives.
-// This file is generated automatically by generate_export_file.pl
-#ifndef ACEXML_EXPORT_H
-#define ACEXML_EXPORT_H
-#include "ace/config-all.h"
-#if defined (ACE_AS_STATIC_LIBS)
-# if !defined (ACEXML_HAS_DLL)
-#   define ACEXML_HAS_DLL 0
-# endif /* ! ACEXML_HAS_DLL */
-#else
-#   define ACEXML_HAS_DLL 1
-#endif /* ACE_AS_STATIC_LIB */
-#if defined (ACEXML_HAS_DLL) && (ACEXML_HAS_DLL == 1)
-#  if defined (ACEXML_BUILD_DLL)
-#    define ACEXML_Export ACE_Proper_Export_Flag
-#    define ACEXML_SINGLETON_DECLARATION(T) ACE_EXPORT_SINGLETON_DECLARATION (T)
-#    define ACEXML_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK) ACE_EXPORT_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK)
-#  else /* ACEXML_BUILD_DLL */
-#    define ACEXML_Export ACE_Proper_Import_Flag
-#    define ACEXML_SINGLETON_DECLARATION(T) ACE_IMPORT_SINGLETON_DECLARATION (T)
-#    define ACEXML_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK) ACE_IMPORT_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK)
-#  endif /* ACEXML_BUILD_DLL */
-#else /* ACEXML_HAS_DLL == 1 */
-#endif /* ACEXML_HAS_DLL == 1 */
-#endif /* ACEXML_EXPORT_H */
-// End of auto generated file.
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Attributes.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Attributes.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Attributes.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,126 +0,0 @@
-// -*- C++ -*-
- *  @file    Attributes.h
- *  Attributes.h,v 1.8 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_ATTRIBUTES_H_
-#define _ACEXML_ATTRIBUTES_H_
-#include "ACEXML/common/ACEXML_Export.h"
-#if !defined (ACE_LACKS_PRAGMA_ONCE)
-#pragma once
-#endif /* ACE_LACKS_PRAGMA_ONCE */
-#include "ACEXML/common/XML_Types.h"
- * @class ACEXML_Attributes Attributes.h "ACEXML/common/Attributes.h"
- * @brief ACEXML_Attributes defines a collection of attributes of an XML element.
- * This is an abstract class (interface in Java) that defines
- * the API for accessing attributes of an XML entity.
- * This interface allows access to a list of attributes in three different ways:
- * - by attribute index;
- * - by Namespace-qualified name; or
- * - by qualified (prefixed) name.
- * The list will not contain attributes that were declared #IMPLIED
- * but not specified in the start tag. It will also not contain
- * attributes used as Namespace declarations (xmlns*) unless the
- * http://xml.org/sax/features/namespace-prefixes feature is set to
- * true (it is false by default).
- * If the namespace-prefixes feature (see above) is false, access by
- * qualified name may not be available; if the
- * http://xml.org/sax/features/namespaces feature is false, access by
- * Namespace-qualified names may not be available.
- * This interface replaces the now-deprecated SAX1 AttributeList
- * interface, which does not contain Namespace support. In addition to
- * Namespace support, it adds the getIndex methods (below).
- * The order of attributes in the list is unspecified, and will vary
- * from implementation to implementation.
-class ACEXML_Export ACEXML_Attributes
-public:
-   * Look up the index of an attribute by XML 1.0 qualified name.
-  virtual int getIndex (const ACEXML_Char *qName) = 0;
-   * Look up the index of an attribute by Namespace name.
-  virtual int getIndex (const ACEXML_Char *uri,
-                        const ACEXML_Char *localPart) = 0;
-   * Return the number of attributes in the list.
-  virtual size_t getLength (void) = 0;
-   * Look up an attribute's local name by index.
-  virtual const ACEXML_Char *getLocalName (size_t index) = 0;
-   * Look up an attribute's XML 1.0 qualified name by index.
-  virtual const ACEXML_Char *getQName (size_t index) = 0;
-   * Look up an attribute's type by index.
-  virtual const ACEXML_Char *getType (size_t index) = 0;
-   * Look up an attribute's type by XML 1.0 qualified name.
-  virtual const ACEXML_Char *getType (const ACEXML_Char *qName) = 0;
-   * Look up an attribute's type by Namespace name.
-  virtual const ACEXML_Char *getType (const ACEXML_Char *uri,
-   * Look up an attribute's Namespace URI by index.
-  virtual const ACEXML_Char *getURI (size_t index) = 0;
-   * Look up an attribute's value by index.
-  virtual const ACEXML_Char *getValue (size_t index) = 0;
-   * Look up an attribute's value by XML 1.0 qualified name.
-  virtual const ACEXML_Char *getValue (const ACEXML_Char *qName) = 0;
-   * Look up an attribute's value by Namespace name.
-  virtual const ACEXML_Char *getValue (const ACEXML_Char *uri,
-#endif /* _ACEXML_ ATTRIBUTES_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/AttributesImpl.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/AttributesImpl.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/AttributesImpl.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,302 +0,0 @@
-// -*- C++ -*-  AttributesImpl.cpp,v 1.6 2003/04/29 16:24:28 elliott_c Exp
-#include "ACEXML/common/AttributesImpl.h"
-# include "ACEXML/common/AttributesImpl.i"
-ACEXML_AttributesImpl::ACEXML_AttributesImpl (int size)
-  : attrs_ (size)
-  this->attrs_.size (0);        // attrs array contains nothing
-ACEXML_AttributesImpl::ACEXML_AttributesImpl (const
-                                              ACEXML_AttributesImpl &attrs)
-  : ACEXML_Attributes (attrs),
-    attrs_ (attrs.attrs_.size ())
-  for (size_t i = 0; i < attrs.attrs_.size (); i++)
-    this->attrs_[i] = attrs.attrs_[i];
-ACEXML_AttributesImpl::~ACEXML_AttributesImpl (void)
-int
-ACEXML_AttributesImpl::addAttribute (const ACEXML_Char *uri,
-                                     const ACEXML_Char *type,
-                                     const ACEXML_Char *value)
-  if (this->isDuplicate (uri, localName, qName))
-    return -1;
-  size_t length = this->attrs_.size ();
-  this->attrs_.size (length+1);
-  this->setAttribute (length,
-                      uri,
-                      localName,
-                      qName,
-                      type,
-                      value);
-  return ACE_static_cast (int, length);
-int
-ACEXML_AttributesImpl::addAttribute (const ACEXML_Attribute &att)
-  if (this->isDuplicate (att.uri(), att.localName(), att.qName()))
-    return -1;
-  this->attrs_[length] = att;
-int
-ACEXML_AttributesImpl::isDuplicate (const ACEXML_Char *uri,
-                                    const ACEXML_Char *qName)
-  for (size_t i = 0; i < this->attrs_.size(); ++i)
-      if (ACE_OS::strcmp (this->attrs_[i].localName(), localName) == 0)
-          if (qName != 0 && this->attrs_[i].qName() != 0
-              && ACE_OS::strcmp (this->attrs_[i].qName(), qName) == 0)
-              if (uri != 0 && this->attrs_[i].uri() != 0
-                  && ACE_OS::strcmp (this->attrs_[i].uri(), uri) == 0)
-                return 1;
-  return 0;
-int
-ACEXML_AttributesImpl::removeAttribute (size_t index)
-  if (index >= length)
-    return -1;
-  this->attrs_[index] = this->attrs_[length - 1];
-  this->attrs_.size (length - 1);
-  return 0;
-int
-ACEXML_AttributesImpl::getIndex (const ACEXML_Char *qName)
-  for (size_t i = 0; i < this->attrs_.size (); i++)
-    if (ACE_OS::strcmp (qName, this->attrs_[i].qName ()) == 0)
-      return ACE_static_cast (int, i);
-  return -1;
-int
-ACEXML_AttributesImpl::getIndex (const ACEXML_Char *uri,
-    if (ACE_OS::strcmp (uri, this->attrs_[i].uri ()) == 0 &&
-        ACE_OS::strcmp (localPart, this->attrs_[i].localName ()) == 0)
-  return -1;
-size_t
-ACEXML_AttributesImpl::getLength (void)
-  return this->attrs_.size ();
-const ACEXML_Char *
-ACEXML_AttributesImpl::getLocalName (size_t index)
-  if (index < this->attrs_.size ())
-    return this->attrs_[index].localName ();
-  return 0;
-ACEXML_AttributesImpl::getQName (size_t index)
-    return this->attrs_[index].qName ();
-  return 0;
-ACEXML_AttributesImpl::getType (size_t index)
-    return this->attrs_[index].type ();
-  return 0;
-ACEXML_AttributesImpl::getType (const ACEXML_Char *qName)
-      return this->attrs_[i].type ();
-  return 0;
-ACEXML_AttributesImpl::getType (const ACEXML_Char *uri,
-  return 0;
-ACEXML_AttributesImpl::getURI (size_t index)
-    return this->attrs_[index].uri ();
-  return 0;
-ACEXML_AttributesImpl::getValue (size_t index)
-    return this->attrs_[index].value ();
-  return 0;
-ACEXML_AttributesImpl::getValue (const ACEXML_Char *qName)
-      return this->attrs_[i].value ();
-  return 0;
-ACEXML_AttributesImpl::getValue (const ACEXML_Char *uri,
-  return 0;
-int
-ACEXML_AttributesImpl::setAttribute (size_t index,
-                                     const ACEXML_Char *uri,
-      this->attrs_[index].setAttribute (uri,
-                                        localName,
-                                        qName,
-                                        type,
-                                        value);
-      return 0;
-  return -1;
-int
-ACEXML_AttributesImpl::setLocalName (size_t index,
-                                     const ACEXML_Char *localName)
-      this->attrs_[index].localName (localName);
-      return 0;
-  return -1;
-int
-ACEXML_AttributesImpl::setQName (size_t index,
-      this->attrs_[index].qName (qName);
-      return 0;
-  return -1;
-int
-ACEXML_AttributesImpl::setURI (size_t index,
-                               const ACEXML_Char *uri)
-      this->attrs_[index].uri (uri);
-      return 0;
-  return -1;
-int
-ACEXML_AttributesImpl::setType (size_t index,
-                                const ACEXML_Char *type)
-      this->attrs_[index].type (type);
-      return 0;
-  return -1;
-int
-ACEXML_AttributesImpl::setValue (size_t index,
-      this->attrs_[index].value (value);
-      return 0;
-  return -1;
-#if defined (ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION)
-template class ACE_Array_Base<ACEXML_Attribute>;
-template class ACE_Array<ACEXML_Attribute>;
-template class ACE_Array_Iterator<ACEXML_Attribute>;
-#elif defined (ACE_HAS_TEMPLATE_INSTANTIATION_PRAGMA)
-#pragma instantiate ACE_Array_Base<ACEXML_Attribute>
-#pragma instantiate ACE_Array<ACEXML_Attribute>
-#pragma instantiate ACE_Array_Iterator<ACEXML_Attribute>
-#endif /* ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/AttributesImpl.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/AttributesImpl.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/AttributesImpl.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,310 +0,0 @@
-// -*- C++ -*-
- *  @file    AttributesImpl.h
- *  AttributesImpl.h,v 1.6 2003/07/19 19:04:10 dhinton Exp
-#ifndef ACEXML_ATTRIBUTESIMPL_H
-#define ACEXML_ATTRIBUTESIMPL_H
-#pragma once
-#include "ACEXML/common/Attributes.h"
-#include "ace/Containers_T.h"
-#if !defined ACEXML_AttributesImpl_Default_Size
-#define ACEXML_AttributesImpl_Default_Size 20
-#endif /* ACEXML_AttributesImpl_Default_Size */
-class ACEXML_AttributesImpl;
- * @class ACEXML_Attribute AttributesImpl.h "ACEXML/common/AttributesImpl.h"
- * @brief ACEXML_Attribute defines the data structure of an attribute
- * @sa ACEXML_AttributesImpl
-public:
-  friend class ACEXML_AttributesImpl;
-  /// Default constructor.
-  ACEXML_Attribute (void);
-  /// Copy constructor.
-  ACEXML_Attribute (const ACEXML_Attribute &attr);
-  /// Initialize all constructor.
-  ACEXML_Attribute (const ACEXML_Char *uri,
-                    const ACEXML_Char *value);
-  /// Destructor.
-  ~ACEXML_Attribute (void);
-  /// Set all members.
-  void setAttribute (const ACEXML_Char *uri,
-  /// Get \a uri_.
-  const ACEXML_Char *uri (void) const;
-  /// Set \a uri_.
-  void uri (const ACEXML_Char *uri);
-  /// Get \a localName_.
-  const ACEXML_Char *localName (void) const;
-  /// Set \a localName_.
-  void localName (const ACEXML_Char *localName);
-  /// Get \a qName_.
-  const ACEXML_Char *qName (void) const;
-  /// Set \a qName_.
-  void qName (const ACEXML_Char *qName);
-  /// Get \a type_.
-  const ACEXML_Char *type (void) const;
-  /// Set \a type_.
-  void type (const ACEXML_Char *type);
-  /// Get \a value_.
-  const ACEXML_Char *value (void) const;
-  /// Set \a value_.
-  void value (const ACEXML_Char *value);
-  /// Assignment operator.
-  ACEXML_Attribute &operator= (const ACEXML_Attribute &rhs);
-  /// Comparison operator.
-  int operator!= (const ACEXML_Attribute&rhs) const;
-private:
-  /// @var uri_ Namespace URI of an attribute
-  ACEXML_Char *uri_;
-  /// @var localName_
-  ACEXML_Char *localName_;
-  ACEXML_Char *qName_;
-  ACEXML_Char *type_;
-  ACEXML_Char *value_;
- * @typedef ACE_Array<ACEXML_Attribute> ACEXML_Attribute_Array
-typedef ACE_Array<ACEXML_Attribute> ACEXML_Attribute_Array;
- * @class ACEXML_AttributesImpl AttributesImpl.h "ACEXML/common/AttributesImpl.h"
- * @brief ACEXML_AttributesImpl provides the default implementation
- * of interface ACEXML_Attributes.
- * This class provides a default implementation of the SAX2 Attributes
- * interface, with the addition of manipulators so that the list can
- * be modified or reused.
- * There are two typical uses of this class:
- * - to take a persistent snapshot of an Attributes object in a
- *   startElement event; or
- * - to construct or modify an Attributes object in a SAX2 driver or filter.
- * This class replaces the now-deprecated SAX1 AttributeListImpl
- * class; in addition to supporting the updated Attributes interface
- * rather than the deprecated AttributeList interface, it also
- * includes a much more efficient implementation using a single array
- * rather than a set of Vectors.
-class ACEXML_Export ACEXML_AttributesImpl
-  : public ACEXML_Attributes
-public:
-   * Initialize an AttributesImpl that holds <size> attributes.
-  ACEXML_AttributesImpl (int size = ACEXML_AttributesImpl_Default_Size);
-  ACEXML_AttributesImpl (const ACEXML_AttributesImpl &attrs);
-  virtual ~ACEXML_AttributesImpl (void);
-   * Add a new attribute using the argument(s) supplied.
-   * Return -1 if an attribute with the same name already exists.
-  virtual int addAttribute (const ACEXML_Char *uri,
-  virtual int addAttribute (const ACEXML_Attribute &att);
-   *  Check for duplicate attributes.
-  virtual int isDuplicate (const ACEXML_Char *uri,
-                              const ACEXML_Char *qName);
-   * Remove an attribute from the array.  Notice that this
-   * operation can invalidate previously acquired <index>
-   * value.  (It will repack the array.)
-  virtual int removeAttribute (size_t index);
-   * Return -1 if we fail to find a match.
-  virtual int getIndex (const ACEXML_Char *qName);
-                        const ACEXML_Char *localPart);
-  virtual size_t getLength (void);
-   * Return 0 if index is out of range.
-  virtual const ACEXML_Char *getLocalName (size_t index);
-  virtual const ACEXML_Char *getQName (size_t index);
-  virtual const ACEXML_Char *getType (size_t index);
-   * Return 0 if we fail to find a match.
-  virtual const ACEXML_Char *getType (const ACEXML_Char *qName);
-  virtual const ACEXML_Char *getURI (size_t index);
-  virtual const ACEXML_Char *getValue (size_t index);
-  virtual const ACEXML_Char *getValue (const ACEXML_Char *qName);
-   * Set an attribute at index.  Return -1 if index is out of
-   * range.
-  virtual int setAttribute (size_t index,
-   * Set the localName of the attribute at <index>.
-   * return -1 if <index> is out of range.
-  virtual int setLocalName (size_t index,
-                            const ACEXML_Char *localName);
-   * Set the qName of the attribute at <index>.
-  virtual int setQName (size_t index,
-   * Set the URI of the attribute at <index>.
-  virtual int setURI (size_t index,
-                      const ACEXML_Char *uri);
-   * Set the type of the attribute at <index>.
-  virtual int setType (size_t index,
-                       const ACEXML_Char *type);
-   * Set the value of the attribute at <index>.
-  virtual int setValue (size_t index,
-private:
-  /// Container for all attributes.
-  ACEXML_Attribute_Array attrs_;
-#endif /* ACEXML_ATTRIBUTESIMPL_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/AttributesImpl.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/AttributesImpl.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/AttributesImpl.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,152 +0,0 @@
-// -*- C++ -*-  AttributesImpl.i,v 1.6 2003/11/07 20:27:29 shuston Exp
-#include "ace/OS_NS_string.h"
-ACEXML_INLINE
-ACEXML_Attribute::ACEXML_Attribute (void)
-  : uri_ (0),
-    localName_ (0),
-    qName_ (0),
-    type_ (0),
-    value_ (0)
-ACEXML_INLINE
-ACEXML_Attribute::ACEXML_Attribute (const ACEXML_Attribute &attr)
-  : uri_ (ACE::strnew (attr.uri_)),
-    localName_ (ACE::strnew (attr.localName_)),
-    qName_ (ACE::strnew (attr.qName_)),
-    type_ (ACE::strnew (attr.type_)),
-    value_ (ACE::strnew (attr.value_))
-ACEXML_INLINE
-ACEXML_Attribute::ACEXML_Attribute (const ACEXML_Char *uri,
-  : uri_ (ACE::strnew (uri)),
-    localName_ (ACE::strnew (localName)),
-    qName_ (ACE::strnew (qName)),
-    type_ (ACE::strnew (type)),
-    value_ (ACE::strnew (value))
-ACEXML_INLINE
-ACEXML_Attribute::~ACEXML_Attribute (void)
-  delete[] this->uri_;
-  delete[] this->localName_;
-  delete[] this->qName_;
-  delete[] this->type_;
-  delete[] this->value_;
-ACEXML_INLINE const ACEXML_Char *
-ACEXML_Attribute::uri (void) const
-  return this->uri_;
-ACEXML_INLINE void
-ACEXML_Attribute::uri (const ACEXML_Char *uri)
-  this->uri_ = ACE::strnew (uri);
-ACEXML_Attribute::localName (void) const
-  return this->localName_;
-ACEXML_INLINE void
-ACEXML_Attribute::localName (const ACEXML_Char *localName)
-  this->localName_ = ACE::strnew (localName);
-ACEXML_Attribute::qName (void) const
-  return this->qName_;
-ACEXML_INLINE void
-ACEXML_Attribute::qName (const ACEXML_Char *qName)
-  this->qName_ = ACE::strnew (qName);
-ACEXML_Attribute::type (void) const
-  return this->type_;
-ACEXML_INLINE void
-ACEXML_Attribute::type (const ACEXML_Char *type)
-  this->type_ = ACE::strnew (type);
-ACEXML_Attribute::value (void) const
-  return this->value_;
-ACEXML_INLINE void
-ACEXML_Attribute::value (const ACEXML_Char *value)
-  this->value_ = ACE::strnew (value);
-ACEXML_INLINE void
-ACEXML_Attribute::setAttribute (const ACEXML_Char *uri,
-  this->uri (uri);
-  this->qName (qName);
-  this->localName (localName);
-  this->type (type);
-  this->value (value);
-ACEXML_INLINE ACEXML_Attribute &
-ACEXML_Attribute::operator= (const ACEXML_Attribute &rhs)
-  if (this != &rhs)             // Check for self assignment
-      this->uri (rhs.uri ());
-      this->qName (rhs.qName ());
-      this->localName (rhs.localName ());
-      this->type (rhs.type ());
-      this->value (rhs.value ());
-  return *this;
-ACEXML_INLINE int
-ACEXML_Attribute::operator!= (const ACEXML_Attribute &rhs) const
-  return (ACE_OS::strcmp (this->uri_, rhs.uri ()) == 0 &&
-          ACE_OS::strcmp (this->localName_, rhs.localName ()) == 0 &&
-          ACE_OS::strcmp (this->qName_, rhs .qName ()) == 0 &&
-          ACE_OS::strcmp (this->type_, rhs.type ()) == 0 &&
-          ACE_OS::strcmp (this->value_, rhs.value ()) == 0 ? 0 : 1);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Attributes_Def_Builder.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Attributes_Def_Builder.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Attributes_Def_Builder.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,33 +0,0 @@
-// Attributes_Def_Builder.cpp,v 1.4 2003/06/06 06:40:09 jwillemsen Exp
-#include "ACEXML/common/Attributes_Def_Builder.h"
-ACEXML_Attribute_Def_Builder::~ACEXML_Attribute_Def_Builder ()
-ACEXML_Attributes_Def_Builder::~ACEXML_Attributes_Def_Builder ()
-template class auto_ptr<ACEXML_Attribute_Def_Builder>;
-template class auto_ptr<ACEXML_Attributes_Def_Builder>;
-#  if defined (ACE_LACKS_AUTO_PTR) \
-      || !(defined (ACE_HAS_STANDARD_CPP_LIBRARY) \
-           && (ACE_HAS_STANDARD_CPP_LIBRARY != 0))
-template class ACE_Auto_Basic_Ptr<ACEXML_Attribute_Def_Builder>;
-template class ACE_Auto_Basic_Ptr<ACEXML_Attributes_Def_Builder>;
-#  endif  /* ACE_LACKS_AUTO_PTR */
-#pragma instantiate auto_ptr<ACEXML_Attribute_Def_Builder>
-#pragma instantiate auto_ptr<ACEXML_Attributes_Def_Builder>
-#    pragma instantiate ACE_Auto_Basic_Ptr<ACEXML_Attribute_Def_Builder>
-#    pragma instantiate ACE_Auto_Basic_Ptr<ACEXML_Attributes_Def_Builder>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Attributes_Def_Builder.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Attributes_Def_Builder.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Attributes_Def_Builder.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,153 +0,0 @@
-// -*- C++ -*-
- *  @file    Attributes_Def_Builder.h
- *  Attributes_Def_Builder.h,v 1.10 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_ATTRIBUTES_DEF_BUILDER_H_
-#define _ACEXML_ATTRIBUTES_DEF_BUILDER_H_
-#pragma once
-#include "ACEXML/common/Env.h"
-#include "ACEXML/common/SAXExceptions.h"
-#include "ace/Auto_Ptr.h"
- * @class ACEXML_Attribute_Def_Builder Attributes_Def_Builder.h "common/Attributes_Def_Builder.h"
- * @brief An abstract virtual class defining an interface for building an
- *        attribute definition from DTD.
- * This class should be invisible to application programmers and is only
- * used for validator implementors.
-class ACEXML_Export ACEXML_Attribute_Def_Builder
-public:
-  typedef auto_ptr<ACEXML_Attribute_Def_Builder> VAR;
-  enum ATT_TYPE {
-    CDATA,
-    ID,
-    IDREF,
-    IDREFS,
-    ENTITY,
-    ENTITIES,
-    NMTOKEN,
-    NMTOKENS,
-    NOTATION,
-    ENUMERATION,
-    ERROR_TYPE
-  enum DEFAULT_DECL {
-    REQUIRED,
-    IMPLIED,
-    FIXED,
-    INVALID
-  virtual ~ACEXML_Attribute_Def_Builder () = 0;
-   * Specify the name of the attribute.
-  virtual int setName (const ACEXML_Char *n) = 0;
-   * Get the name of the attribute.
-  virtual const ACEXML_Char *getName (void) = 0;
-   * Set the attribute type.
-  virtual int setAttType (const ATT_TYPE type ACEXML_ENV_ARG_DECL)
-     ACE_THROW_SPEC ((ACEXML_SAXException)) = 0;
-   * Insert an element for NOTATION or ENUMERATION type attribute.
-  virtual int insertList (const ACEXML_Char *Name ACEXML_ENV_ARG_DECL)
-   * Set default attribute declaration.
-  virtual int setDefault (const DEFAULT_DECL def,
-                          const ACEXML_Char *value ACEXML_ENV_ARG_DECL)
-   * Check validity of the current attribute definition being built.
-   * @retval 0 if the attribute is not a valid combo.
-  virtual int validAttr (void) = 0;
-   * Dump the content of the attribute definition.
-  virtual void dump (void) = 0;
- * @ class ACEXML_Attributes_Def_Builder Attributes_Def_Builder.h "common/Attributes_Def_Builder.h"
- * @ brief An abstract virtual class defining an interface for building
- *         attribute definitions from DTD.
- * is only used for validator implementors.
-class ACEXML_Export ACEXML_Attributes_Def_Builder
-public:
-  typedef auto_ptr<ACEXML_Attributes_Def_Builder> VAR;
-  virtual ~ACEXML_Attributes_Def_Builder () = 0;
-   * Set the element name that the attribute builder applies.
-   * @retval 0 if valid, -1 otherwise.
-  virtual int setElement (const ACEXML_Char *namespaceURI,
-   * Acquire an Attribute_Builder.
-  virtual ACEXML_Attribute_Def_Builder *getAttribute_Def_Builder () = 0;
-   * Add a definition for one attribute.
-  virtual int insertAttribute (ACEXML_Attribute_Def_Builder *def ACEXML_ENV_ARG_DECL) = 0;
-#endif /* _ACEXML_ATTRIBUTES_DEF_BUILDER_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/CharStream.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/CharStream.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/CharStream.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,7 +0,0 @@
-// -*- C++ -*-  CharStream.cpp,v 1.3 2002/02/14 06:28:57 nanbor Exp
-#include "ACEXML/common/CharStream.h"
-ACEXML_CharStream::~ACEXML_CharStream (void)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/CharStream.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/CharStream.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/CharStream.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,88 +0,0 @@
-// -*- C++ -*-
- *  @file    CharStream.h
- *  CharStream.h,v 1.9 2004/01/09 00:50:35 kitty Exp
-#ifndef _ACEXML_CHARSTREAM_H_
-#define _ACEXML_CHARSTREAM_H_
-#pragma once
- * @class ACEXML_CharStream CharStream.h "ACEXML/common/CharStream.h"
- * ACEXML_CharStream is an abstract class (interface) which defines the
- * basic opertions a parser could use to retrieve XML charater sequence.
- * The sequence can be read from a file or a character buffer.
-class ACEXML_Export ACEXML_CharStream
-public:
-   * Virtual destructor, must have.
-  virtual ~ACEXML_CharStream () = 0;
-   * Returns the available ACEXML_Char in the buffer.  -1
-   * if the object is not initialized properly.
-  virtual int available (void) = 0;
-   * Close this stream and release all resources used by it.
-  virtual int close (void) = 0;
-   * Read the next ACEXML_Char.  Return -1 if we are not able to
-   * return an ACEXML_Char, 0 if EOS is reached, or 1 if succeed.
-  virtual int get (ACEXML_Char& ch) = 0;
-   * Read the next batch of ACEXML_Char strings
-  virtual int read (ACEXML_Char *str, size_t len) = 0;
-   * Peek the next ACEXML_Char in the CharStream.  Return the
-   * character if succeess, -1 if EOS is reached.
-  virtual int peek (void) = 0;
-   *  Resets the pointer to the beginning of the stream.
-  virtual void rewind (void) = 0;
-   * Get the character encoding for a byte stream or URI.
-  virtual const ACEXML_Char *getEncoding (void)  = 0;
-   * Get the systemId for the underlying CharStream
-  virtual const ACEXML_Char* getSystemId (void) = 0;
-#endif /* _ACEXML_CHARSTREAM_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ContentHandler.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ContentHandler.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ContentHandler.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,128 +0,0 @@
-// -*- C++ -*-
- *  @file    ContentHandler.h
- *  ContentHandler.h,v 1.7 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_CONTENTHANDLER_H_
-#define _ACEXML_CONTENTHANDLER_H_
-#pragma once
-#include "ACEXML/common/Locator.h"
- * @class ACEXML_ContentHandler ContentHandler.h "ACEXML/common/ContentHandler.h"
- * @brief ACEXML_ContentHandler
- * This is the main interface that most SAX applications implement: if the
- * application needs to be informed of basic parsing events, it implements
- * this interface and registers an instance with the SAX parser using the
- * setContentHandler method. The parser uses the instance to report basic
- * document-related events like the start and end of elements and character
- * data.
- * The order of events in this interface is very important, and mirrors the
- * order of information in the document itself. For example, all of an
- * element's content (character data, processing instructions, and/or
- * subelements) will appear, in order, between the startElement event and
- * the corresponding endElement event.
-class ACEXML_Export ACEXML_ContentHandler
-public:
-                           int start,
-                                    int start,
-  virtual void setDocumentLocator (ACEXML_Locator *locator) = 0;
-#endif /* _ACEXML_CONTENTHANDLER_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DTDHandler.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DTDHandler.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DTDHandler.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,75 +0,0 @@
-// -*- C++ -*-
- *  @file    DTDHandler.h
- *  DTDHandler.h,v 1.7 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_DTDHANDLER_H_
-#define _ACEXML_DTDHANDLER_H_
-#pragma once
- * @class ACEXML_DTDHandler DTDHandler.h "ACEXML/common/DTDHandler.h"
- * @brief ACEXML_DTDHandler
- * If a SAX application needs information about notations and unparsed
- * entities, then the application implements this interface and registers
- * an instance with the SAX parser using the parser's setDTDHandler method.
- * The parser uses the instance to report notation and unparsed entity
- * declarations to the application.
- * Note that this interface includes only those DTD events that the XML
- * recommendation requires processors to report: notation and unparsed
- * entity declarations.
- * The SAX parser may report these events in any order, regardless of the
- * order in which the notations and unparsed entities were declared;
- * however, all DTD events must be reported after the document handler's
- * startDocument event, and before the first startElement event.
- * It is up to the application to store the information for future use
- * (perhaps in a hash table or object tree). If the application encounters
- * attributes of type "NOTATION", "ENTITY", or "ENTITIES", it can use the
- * information that it obtained through this interface to find the entity
- * and/or notation corresponding with the attribute value.
-class ACEXML_Export ACEXML_DTDHandler
-public:
-#endif /* _ACEXML_DTDHANDLER_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DTD_Manager.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DTD_Manager.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DTD_Manager.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,8 +0,0 @@
-// DTD_Manager.cpp,v 1.3 2002/02/14 06:28:57 nanbor Exp
-#include "ACEXML/common/DTD_Manager.h"
-ACEXML_DTD_Manager::~ACEXML_DTD_Manager ()
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DTD_Manager.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DTD_Manager.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DTD_Manager.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,82 +0,0 @@
-// -*- C++ -*-
- *  @file    DTD_Manager.h
- *  DTD_Manager.h,v 1.7 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_DTD_Manager_H_
-#define _ACEXML_DTD_Manager_H_
-#pragma once
-#include "ACEXML/common/Element_Def_Builder.h"
-#include "ACEXML/common/Validator.h"
- * @class ACEXML_DTD_Manager DTD_Manager.h "common/DTD_Manager.h"
- * @todo Fill in the blank.
-class ACEXML_Export ACEXML_DTD_Manager
-public:
-  virtual ~ACEXML_DTD_Manager () = 0;
-   * Acquire a pointer to an element definition builder.
-   * The XML parser use this interface to acquire the
-   * definition builder and use the builder to create
-   * the DTD element definition.  The resulting builder
-   * is then registered with the DTD Manager or destroyed
-   * if error occured when the builder encountered errors.
-   * @retval 0 if error occurs creating the builder.
-  virtual ACEXML_Element_Def_Builder *getElement_Def_Builder () = 0;
-   * Insert a new element definition into the DTD Manager.
-   * @retval 0 if success, -1 if error.
-  virtual int insertElement_Definition (ACEXML_Element_Def_Builder *def ACEXML_ENV_ARG_DECL) = 0;
-   * Acquire a pointer to an attributes definition builder.
-  virtual ACEXML_Attributes_Def_Builder *getAttribute_Def_Builder () = 0;
-   * Insert a new attributes definition into the DTD Manager.
-   * @retval 0 if success, -1 otherwise.
-  virtual int insertAttributes_Definition (ACEXML_Attributes_Def_Builder *def ACEXML_ENV_ARG_DECL) = 0;
-   * Acquire an element validator to validate an XML element.
-   * @todo I haven't figured out what memory management scheme
-   *       we should use for the acquired validator.
-  virtual ACEXML_Validator *getValidator (const ACEXML_Char *namespaceURI,
-                                          const ACEXML_Char *qName ACEXML_ENV_ARG_DECL) = 0;
-#endif /* _ACEXML_DTD_Manager_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DefaultHandler.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DefaultHandler.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DefaultHandler.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,162 +0,0 @@
-// -*- C++ -*-  DefaultHandler.cpp,v 1.5 2003/05/30 03:31:48 kitty Exp
-# include "ACEXML/common/DefaultHandler.i"
-ACEXML_DefaultHandler::ACEXML_DefaultHandler (void)
-  // no-op
-ACEXML_DefaultHandler::~ACEXML_DefaultHandler (void)
-  // no-op
-void
-ACEXML_DefaultHandler::characters (const ACEXML_Char *,
-                                   int,
-                                   int
-                                   ACEXML_ENV_ARG_DECL_NOT_USED)
-  // No-op.
-void
-ACEXML_DefaultHandler::endDocument (ACEXML_ENV_SINGLE_ARG_DECL_NOT_USED)
-  // No-op.
-void
-ACEXML_DefaultHandler::endElement (const ACEXML_Char *,
-  // No-op.
-void
-ACEXML_DefaultHandler::endPrefixMapping (const ACEXML_Char * ACEXML_ENV_ARG_DECL_NOT_USED)
-  // No-op.
-void
-ACEXML_DefaultHandler::ignorableWhitespace (const ACEXML_Char *,
-                                            int,
-  // No-op.
-void
-ACEXML_DefaultHandler::processingInstruction (const ACEXML_Char *,
-  // No-op.
-void
-ACEXML_DefaultHandler::setDocumentLocator (ACEXML_Locator * )
-  // No-op.
-void
-ACEXML_DefaultHandler::skippedEntity (const ACEXML_Char * ACEXML_ENV_ARG_DECL_NOT_USED)
-  // No-op.
-void
-ACEXML_DefaultHandler::startDocument (ACEXML_ENV_SINGLE_ARG_DECL_NOT_USED)
-  // No-op.
-void
-ACEXML_DefaultHandler::startElement (const ACEXML_Char *,
-                                     ACEXML_Attributes * ACEXML_ENV_ARG_DECL_NOT_USED)
-  // No-op.
-void
-ACEXML_DefaultHandler::startPrefixMapping (const ACEXML_Char *,
-  // No-op.
-  // *** Methods inherited from ACEXML_DTDHandler.
-void
-ACEXML_DefaultHandler::notationDecl (const ACEXML_Char *,
-  // No-op.
-void
-ACEXML_DefaultHandler::unparsedEntityDecl (const ACEXML_Char *,
-  // No-op.
-  // Methods inherited from ACEXML_EntityResolver.
-ACEXML_DefaultHandler::resolveEntity (const ACEXML_Char *,
-  // No-op.
-  return 0;
-  // Methods inherited from ACEXML_ErrorHandler.
-void
-ACEXML_DefaultHandler::error (ACEXML_SAXParseException & ACEXML_ENV_ARG_DECL_NOT_USED)
-  // No-op.
-void
-ACEXML_DefaultHandler::fatalError (ACEXML_SAXParseException & ACEXML_ENV_ARG_DECL_NOT_USED)
-  // No-op.
-void
-ACEXML_DefaultHandler::warning (ACEXML_SAXParseException & ACEXML_ENV_ARG_DECL_NOT_USED)
-  // No-op.
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DefaultHandler.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DefaultHandler.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DefaultHandler.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,195 +0,0 @@
-// -*- C++ -*-
- *  @file    DefaultHandler.h
- *  DefaultHandler.h,v 1.6 2003/07/19 19:04:10 dhinton Exp
- *  @author Nanbor Wang <nanbor at cs.wustl.edu>
-#ifndef ACEXML_DEFAULTHANDLER_H
-#define ACEXML_DEFAULTHANDLER_H
-#include /**/ "ace/pre.h"
-#pragma once
-#include "ACEXML/common/ContentHandler.h"
-#include "ACEXML/common/DTDHandler.h"
-#include "ACEXML/common/EntityResolver.h"
-#include "ACEXML/common/ErrorHandler.h"
- * @class ACEXML_DefaultHandler DefaultHandler.h "ACEXML/common/DefaultHandler.h"
- * @brief ACEXML_DefaultHandler
- * This class is available as a convenience base class for SAX2
- * applications: it provides default implementations for all of the
- * callbacks in the four core SAX2 handler classes:
- * - EntityResolver
- * - DTDHandler
- * - ContentHandler
- * - ErrorHandler
- * Application writers can extend this class when they need to implement
- * only part of an interface; parser writers can instantiate this class to
- * provide default handlers when the application has not supplied its own.
-class ACEXML_Export ACEXML_DefaultHandler
-  : public ACEXML_ContentHandler,
-    public ACEXML_DTDHandler,
-    public ACEXML_EntityResolver,
-    public ACEXML_ErrorHandler
-public:
-  ACEXML_DefaultHandler (void);
-   * destructor.
-  virtual ~ACEXML_DefaultHandler (void);
-                           int start,
-        ACE_THROW_SPEC ((ACEXML_SAXException)) ;
-                                    int start,
-#endif /* __ACEXML_INLINE__ */
-#include /**/ "ace/post.h"
-#endif /* ACEXML_DEFAULTHANDLER_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DefaultHandler.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DefaultHandler.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/DefaultHandler.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1 +0,0 @@
-// -*- C++ -*-  DefaultHandler.i,v 1.2 2002/01/24 21:00:01 nanbor Exp
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Element_Def_Builder.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Element_Def_Builder.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Element_Def_Builder.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,25 +0,0 @@
-// Element_Def_Builder.cpp,v 1.4 2003/06/06 06:40:09 jwillemsen Exp
-ACEXML_Element_Def_Builder::~ACEXML_Element_Def_Builder ()
-template class auto_ptr<ACEXML_Element_Def_Builder>;
-template class ACE_Auto_Basic_Ptr<ACEXML_Element_Def_Builder>;
-#pragma instantiate auto_ptr<ACEXML_Element_Def_Builder>
-#    pragma instantiate ACE_Auto_Basic_Ptr<ACEXML_Element_Def_Builder>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Element_Def_Builder.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Element_Def_Builder.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Element_Def_Builder.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,133 +0,0 @@
-// -*- C++ -*-
- *  @file    Element_Def_Builder.h
- *  Element_Def_Builder.h,v 1.7 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_ELEMENT_DEF_BUILDER_H_
-#define _ACEXML_ELEMENT_DEF_BUILDER_H_
-#pragma once
- * @class ACEXML_Element_Def_Builder Element_Def_Builder.h "common/Element_Def_Builder.h"
- * @brief An abstract virtual class that defines the interface to define an
- * element definition.
- * This class defines how to define an element definition after parsing a
- * DTD.
-class ACEXML_Export ACEXML_Element_Def_Builder
-public:
-  typedef auto_ptr<ACEXML_Element_Def_Builder> VAR;
-  typedef enum {
-    EMPTY,
-    ANY,
-    MIXED,
-    CHILDREN,
-    UNDEFINED
-  } CONTENT_TYPE;
-  typedef enum {
-    ONE,
-    ZERO_OR_MORE,
-    ONE_OR_MORE,
-    ONE_OR_ZERO
-  } CARDINALITY;
-  virtual ~ACEXML_Element_Def_Builder () = 0;
-   * Define the name of the element.
-  virtual int setElementName (const ACEXML_Char *namespaceURI,
-   * Define the content type of the element.
-  virtual int setContentType (CONTENT_TYPE type ACEXML_ENV_ARG_DECL)
-   * Insert one more element into Mixed definition.
-  virtual int insertMixedElement (const ACEXML_Char *namespaceURI,
-   * Start a new group of children.
-  virtual int startChildGroup () = 0;
-   * End a new group of children.
-   * @retval 0 on success.
-  virtual int endChildGroup (CARDINALITY card ACEXML_ENV_ARG_DECL) = 0;
-   * Set the type of current child group to Choice.
-   * @retval 0 on success, -1 if the type of the child group has
-   * already been set and this action conflicts with the previous
-   * setting.
-  virtual int setChoice () = 0;
-   * Set the type of current child group to Sequence.
-   * setting.
-  virtual int setSequence () = 0;
-   * Insert an new element into the current child group.
-   * @retval 0 on success, -1 otherwise.
-  virtual int insertElement  (const ACEXML_Char *namespaceURI,
-#endif /* _ACEXML_ELEMENT_DEF_BUILDER_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Encoding.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Encoding.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Encoding.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,59 +0,0 @@
-// -*- C++ -*-  Encoding.cpp,v 1.3 2003/11/07 20:27:29 shuston Exp
-#include "ACEXML/common/Encoding.h"
-const ACEXML_Char* ACEXML_Encoding::encoding_names_[8] = {
-  ACE_TEXT ("UCS-4BE"),
-  ACE_TEXT ("UCS-4LE"),
-  ACE_TEXT ("UCS-4_2143"),
-  ACE_TEXT ("UCS-4_3412"),
-  ACE_TEXT ("UTF-16"),
-  ACE_TEXT ("UTF-8"),
-  ACE_TEXT ("Unsupported Encoding")
-const ACEXML_UTF8 ACEXML_Encoding::byte_order_mark_[][4] = {
-  { '\x00', '\x00', '\xFE', '\xFF' }, // UCS-4, big-endian  (1234 order)
-  { '\xFF', '\xFE', '\x00', '\x00' }, // UCS-4, little-endian  (4321 order)
-  { '\x00', '\x00', '\xFF', '\xFE' }, // UCS-4, unusual octet order (2143)
-  { '\xFE', '\xFF', '\x00', '\x00' }, // UCS-4, unusual octet order (3412)
-  { '\xFE', '\xFF', '\xFF', '\xFF' }, // UTF-16, big-endian (3 & 4 != 0)
-  { '\xFF', '\xFE', '\xFF', '\xFF' }, // UTF-16, little-endian ( 3 & 4 != 0)
-  { '\xEF', '\xBB', '\xBF', '\xFF' }  // UTF-8
-const ACEXML_UTF8 ACEXML_Encoding::magic_values_[][4] = {
-  { '\x00', '\x00', '\x00', '\x3c' }, //
-  { '\x3c', '\x00', '\x00', '\x00' }, // UCS-4 and variants
-  { '\x00', '\x00', '\x3c', '\x00' }, //
-  { '\x00', '\x3c', '\x00', '\x00' }, //
-  { '\x00', '\x3c', '\x00', '\x3f' }, // UTF-16BE
-  { '\x3c', '\x00', '\x3f', '\x00' }, // UTF-16LE
-  { '\x3c', '\x3f', '\x78', '\x6d' }, // UTF-8
-const ACEXML_Char*
-ACEXML_Encoding::get_encoding (const char* input)
-  if ((ACE_OS::memcmp (&ACEXML_Encoding::byte_order_mark_[ACEXML_Encoding::UTF16BE][0], input, 2) == 0)
-      && (input[2] != 0 || input[3] != 0)) // 3 & 4 should not be both zero
-    return ACEXML_Encoding::encoding_names_[ACEXML_Encoding::UTF16BE];
-  else if ((ACE_OS::memcmp (&ACEXML_Encoding::byte_order_mark_[ACEXML_Encoding::UTF16LE][0], input, 2) == 0)
-    return ACEXML_Encoding::encoding_names_[ACEXML_Encoding::UTF16LE];
-  else if (ACE_OS::memcmp (&ACEXML_Encoding::byte_order_mark_[ACEXML_Encoding::UTF8][0], input, 3) == 0)
-    return ACEXML_Encoding::encoding_names_[ACEXML_Encoding::UTF8];
-  else if (ACE_OS::memcmp (&ACEXML_Encoding::magic_values_[ACEXML_Encoding::UTF16BE][0], input, 4) == 0)
-  else if (ACE_OS::memcmp (&ACEXML_Encoding::magic_values_[ACEXML_Encoding::UTF16LE][0], input, 4) == 0)
-  else if (ACE_OS::memcmp (&ACEXML_Encoding::magic_values_[ACEXML_Encoding::UTF8][0], input, 4) == 0)
-  else
-      // ACE_ERROR ((LM_ERROR, "Unknown encoding. Assuming UTF-8\n"));
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Encoding.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Encoding.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Encoding.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,61 +0,0 @@
-// -*- C++ -*-
- *  @file    Encoding.h
- * This file provides utility functions to determine the encoding of a file
- * or a byte stream automatically.
- *  Encoding.h,v 1.3 2003/07/19 19:04:10 dhinton Exp
- *  @author Krishnakumar B <kitty at cs.wustl.edu>
-#ifndef _ACEXML_ENCODING_H
-#define _ACEXML_ENCODING_H
-#pragma once
- * @class ACEXML_Encoding Encoding.h "ACEXML/common/Encoding.h"
- * @brief ACEXML_Encoding
- * Wrapper class for determining the encoding of a file or a byte stream.
-class ACEXML_Export ACEXML_Encoding
-public:
-  enum {
-    UCS4BE,
-    UCS4LE,
-    UCS4_2143,
-    UCS4_3412,
-    UTF16BE,
-    UTF16LE,
-    UTF8,
-    OTHER
-  } ENCODING;
-  static const ACEXML_Char* encoding_names_[8];
-  static const ACEXML_UTF8 byte_order_mark_[][4];
-  static const ACEXML_UTF8 magic_values_[][4];
-  static const ACEXML_Char* get_encoding (const char* input);
-#endif /* _ACEXML_ENCODING_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/EntityResolver.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/EntityResolver.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/EntityResolver.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,57 +0,0 @@
-// -*- C++ -*-
- *  @file    EntityResolver.h
- *  EntityResolver.h,v 1.6 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_ENTITYHANDLER_H_
-#define _ACEXML_ENTITYHANDLER_H_
-#pragma once
-#include "ACEXML/common/InputSource.h"
- * @class ACEXML_EntityResolver EntityResolver.h "ACEXML/common/EntityResolver.h"
- * @brief ACEXML_EntityResolver
- * If a SAX application needs to implement customized handling for
- * external entities, it must implement this interface and register an
- * instance with the SAX driver using the setEntityResolver method.
- * The XML reader will then allow the application to intercept any
- * external entities (including the external DTD subset and external
- * parameter entities, if any) before including them.
- * Many SAX applications will not need to implement this interface,
- * but it will be especially useful for applications that build XML
- * documents from databases or other specialised input sources, or for
- * applications that use URI types other than URLs.
-class ACEXML_Export ACEXML_EntityResolver
-public:
-#endif /* _ACEXML_ENTITYHANDLER_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Env.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Env.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Env.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,34 +0,0 @@
-// -*- C++ -*-  Env.cpp,v 1.4 2002/10/13 03:58:57 kitty Exp
-#if !defined (__ACEXML_INLINE__)
-# include "ACEXML/common/Env.i"
-ACEXML_Env::ACEXML_Env (void)
-  : exception_ (0)
-ACEXML_Env::ACEXML_Env (const ACEXML_Env &rhs)
-  : exception_ (0)
-  if (rhs.exception())
-    this->exception_ = rhs.exception_->duplicate();
-ACEXML_Env&
-ACEXML_Env::operator= (const ACEXML_Env& rhs)
-  ACEXML_Env tmp (rhs);
-  ACEXML_Exception* tmp_ex = this->exception_;
-  this->exception_ = tmp.exception_;
-  tmp.exception_ = tmp_ex;
-  return *this;
-ACEXML_Env::~ACEXML_Env (void)
-  this->clear();
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Env.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Env.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Env.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,72 +0,0 @@
-// -*- C++ -*-
- *  @file    Env.h
- *  Env.h,v 1.7 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_ENV_H_
-#define _ACEXML_ENV_H_
-#pragma once
-#include "ACEXML/common/XML_Macros.h"
-#include "ACEXML/common/Exception.h"
- * @class ACEXML_Env Env.h "ACEXML/common/Env.h"
- * @brief ACEXML_Env
- * ACEXML_Env is modeled after CORBA_Environment class. It provides a place
- * holder for callees to propagate exceptions back to callers. ACEXML does
- * not support native exceptions at this moment.
- * @sa ACEXML_Exception
-class ACEXML_Export ACEXML_Env
-public:
-  ACEXML_Env (void);
-  ACEXML_Env (const ACEXML_Env& ACEXML_TRY_ENV);
-  /// Assignment
-  ACEXML_Env& operator= (const ACEXML_Env& ACEXML_TRY_ENV);
-  /// Destructor.
-  ~ACEXML_Env (void);
-  /// Return the contained exception.
-  ACEXML_Exception *exception (void) const;
-  /// Set the contained exception to @arg ex
-  void exception (ACEXML_Exception* ex);
-  /// Clear the exception and reset the evnrionment.
-  void clear (void);
-private:
-  /// Place holder for exception (if one occurs.)
-  ACEXML_Exception *exception_;
-#endif /* _ACEXML_ENV_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Env.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Env.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Env.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,25 +0,0 @@
-// -*- C++ -*- Env.i,v 1.5 2002/11/27 20:50:36 shuston Exp
-#include "ace/Log_Msg.h"      /* to get ACE_ASSERT */
-ACEXML_INLINE ACEXML_Exception *
-ACEXML_Env::exception (void) const
-  return this->exception_;
-ACEXML_INLINE void
-ACEXML_Env::exception (ACEXML_Exception *ex)
-  ACE_ASSERT (ex != this->exception_);
-  this->clear();
-  this->exception_ = ex;
-ACEXML_INLINE void
-ACEXML_Env::clear (void)
-  delete this->exception_;
-  this->exception_ = 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ErrorHandler.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ErrorHandler.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ErrorHandler.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,72 +0,0 @@
-// -*- C++ -*-
- *  @file    ErrorHandler.h
- *  ErrorHandler.h,v 1.6 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_ERRORHANDLER_H_
-#define _ACEXML_ERRORHANDLER_H_
-#pragma once
- * @class ACEXML_ErrorHandler ErrorHandler.h "ACEXML/common/ErrorHandler.h"
- * @brief ACEXML_ErrorHandler
- * If a SAX application needs to implement customized error handling,
- * it must implement this interface and then register an instance with
- * the XML reader using the setErrorHandler method. The parser will
- * then report all errors and warnings through this interface.
- * @b WARNING: If an application does not register an ErrorHandler,
- * XML parsing errors will go unreported and bizarre behaviour may
- * result.
- * For XML processing errors, a SAX driver must use this interface
- * instead of throwing an exception: it is up to the application to
- * decide whether to throw an exception for different types of errors
- * and warnings. Note, however, that there is no requirement that the
- * parser continue to provide useful information after a call to
- * fatalError (in other words, a SAX driver class could catch an
- * exception and report a fatalError).
-class ACEXML_Export ACEXML_ErrorHandler
-public:
-   * Receive notification of a recoverable error.
-#endif /* _ACEXML_ERRORHANDLER_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Exception.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Exception.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Exception.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,52 +0,0 @@
-// -*- C++ -*- Exception.cpp,v 1.8 2003/11/07 20:27:29 shuston Exp
-#include "ace/ACE.h"
-static const ACEXML_Char ACEXML_Exception_name[] = {
-  'A', 'C', 'E', 'X', 'M', 'L',
-  '_', 'E', 'x', 'c', 'e', 'p',
-  't', 'i', 'o', 'n', 0};
-const ACEXML_Char *ACEXML_Exception::exception_name_ = ACEXML_Exception_name;
-static const ACEXML_Char ACEXML_Exception_null [] = {0};
-const ACEXML_Char *ACEXML_Exception::null_ = ACEXML_Exception_null;
-# include "ACEXML/common/Exception.i"
-ACEXML_Exception::ACEXML_Exception (void)
-ACEXML_Exception::ACEXML_Exception (const ACEXML_Exception &)
-ACEXML_Exception::~ACEXML_Exception (void)
-int
-ACEXML_Exception::is_a (const ACEXML_Char *name)
-  if (name == ACEXML_Exception::exception_name_
-      || ACE_OS::strcmp (ACEXML_Exception::exception_name_,
-                         name) == 0)
-    return 1;
-  return 0;
-void
-ACEXML_Exception::print (void)
-  ACE_ERROR ((LM_ERROR,
-              ACE_TEXT ("ACEXML: (%P|%t) EXCEPTION : %s\n"),
-                        this->exception_name_));
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Exception.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Exception.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Exception.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,93 +0,0 @@
-// -*- C++ -*-
- *  @file    Exception.h
- *  Exception.h,v 1.7 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_EXCEPTION_H_
-#define _ACEXML_EXCEPTION_H_
-#pragma once
-#if defined (ACE_USES_NATIVE_EXCEPTIONS)
-# define ACEXML_RAISE(EXCEPTION) throw EXCEPTION
-#else
-#endif
- * @class ACEXML_Exception Exception.h "ACEXML/common/Exception.h"
- * @brief ACEXML_Exception
- * ACEXML_Exception is the base class for all ACEXML related exceptions.
- * Since ACEXML currently does not support native exceptions, all
- * exceptions should be thrown thru ACEXML_Env.
- * @sa ACEXML_Env
-class ACEXML_Export ACEXML_Exception
-public:
-  ACEXML_Exception (const ACEXML_Exception &src);
-  ACEXML_Exception& operator= (const ACEXML_Exception& src);
-  /// Destructor.
-  virtual ~ACEXML_Exception (void);
-  /// Throw the exception.
-  virtual void _raise (void) = 0;
-  /// Static narrow operation.
-  static ACEXML_Exception* _downcast (ACEXML_Exception* ex);
-  /// Return the exception type.  (for safe downcast.)
-  virtual const ACEXML_Char *id (void) const ;
-  /// Dynamically create a copy of this exception.
-  virtual ACEXML_Exception *duplicate (void) const = 0;
-  /// Check whether this is an exception of type specified by <name>.
-  virtual int is_a (const ACEXML_Char *name) = 0;
-  /// Print out exception using ACE_DEBUG.
-  virtual void print (void) = 0;
-protected:
-  /// Default contructor.
-  ACEXML_Exception (void);
-  /// All exceptions have names.  This name is used to identify the
-  /// type of an exception.
-  static const ACEXML_Char *exception_name_;
-  /// A null string that we return when there is no exception.
-  static const ACEXML_Char *null_;
-#if defined (__ACEXML_INLINE__)
-#endif /* _ACEXML_EXCEPTION_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Exception.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Exception.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Exception.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,13 +0,0 @@
-// -*- C++ -*- Exception.i,v 1.3 2002/10/13 03:58:57 kitty Exp
-ACEXML_Exception::id (void) const
-  return ACEXML_Exception::exception_name_;
-ACEXML_INLINE ACEXML_Exception*
-ACEXML_Exception::_downcast (ACEXML_Exception* x)
-  return x;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/FileCharStream.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/FileCharStream.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/FileCharStream.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,256 +0,0 @@
-// FileCharStream.cpp,v 1.23 2004/01/09 00:50:35 kitty Exp
-#include "ACEXML/common/FileCharStream.h"
-#include "ace/OS_NS_stdio.h"
-#include "ace/OS_NS_sys_stat.h"
-#if defined (ACE_USES_WCHAR)
-#  include "ace/OS_NS_wchar.h"
-#endif /* ACE_USES_WCHAR */
-ACEXML_FileCharStream::ACEXML_FileCharStream (void)
-  : filename_ (0), encoding_ (0), size_ (0), infile_ (0), peek_ (0)
-ACEXML_FileCharStream::~ACEXML_FileCharStream (void)
-  this->close();
-int
-ACEXML_FileCharStream::open (const ACEXML_Char *name)
-  delete[] this->filename_;
-  this->filename_ = 0;
-  delete[] this->encoding_;
-  this->encoding_ = 0;
-  this->infile_ = ACE_OS::fopen (name, ACE_TEXT ("r"));
-  if (this->infile_ == 0)
-    return -1;
-  ACE_stat statbuf;
-  if (ACE_OS::stat (name, &statbuf) < 0)
-    return -1;
-  this->size_ = statbuf.st_size;
-  this->filename_ = ACE::strnew (name);
-  return this->determine_encoding();
-int
-ACEXML_FileCharStream::determine_encoding (void)
-    return -1;
-  char input[4];
-  int retval = 0;
-  int i = 0;
-  for (; i < 4 && retval != -1; ++i)
-    retval = this->getchar_i(input[i]);
-  if (i < 4)
-    return -1;
-  // Rewind the stream
-  ACE_OS::rewind (this->infile_);
-  const ACEXML_Char* temp = ACEXML_Encoding::get_encoding (input);
-  if (!temp)
-    return -1;
-  else
-      if (this->encoding_)
-        delete [] this->encoding_;
-      this->encoding_ = ACE::strnew (temp);
-//       ACE_DEBUG ((LM_DEBUG, ACE_TEXT ("File's encoding is %s\n"),
-//                   this->encoding_));
-  // Move over the byte-order-mark if present.
-  char ch;
-  for (int j = 0; j < 3; ++j)
-      if (this->getchar_i (ch) < 0)
-        return -1;
-      if (ch == '\xFF' || ch == '\xFE' || ch == '\xEF' || ch == '\xBB' ||
-          ch == '\xBF')
-        continue;
-      else
-          ungetc (ch, this->infile_);
-          break;
-  return 0;
-void
-ACEXML_FileCharStream::rewind()
-    return;
-  this->determine_encoding();
-int
-ACEXML_FileCharStream::available (void)
-    return -1;
-  long curr;
-  if ((curr = ACE_OS::ftell (this->infile_)) < 0)
-    return -1;
-  return (this->size_ - curr);
-int
-ACEXML_FileCharStream::close (void)
-  if (this->infile_ != 0)
-      ACE_OS::fclose (this->infile_);
-      this->infile_ = 0;
-  this->size_ = 0;
-  this->peek_ = 0;
-  return 0;
-int
-ACEXML_FileCharStream::getchar_i (char& ch)
-  ch = ACE_OS::fgetc (this->infile_);
-  return (feof(this->infile_) ? -1 : 0);
-int
-ACEXML_FileCharStream::read (ACEXML_Char *str,
-                             size_t len)
-    return -1;
-          ACE_OS::fread (str, sizeof (ACEXML_Char), len, this->infile_));
-int
-ACEXML_FileCharStream::get (ACEXML_Char& ch)
-    return -1;
-  return this->get_i (ch);
-#else
-  ch = (ACEXML_Char) ACE_OS::fgetc (this->infile_);
-int
-ACEXML_FileCharStream::peek (void)
-    return -1;
-  return this->peek_i();
-#else
-  ACEXML_Char ch = ACE_OS::fgetc (this->infile_);
-  ::ungetc (ch, this->infile_);
-  return ch;
-int
-ACEXML_FileCharStream::get_i (ACEXML_Char& ch)
-  if (ACE_OS::strcmp (this->encoding_, ACE_TEXT ("UTF-8")) == 0)
-  // If we have a value in peek_, return it.
-  if (this->peek_ != 0)
-      ch = this->peek_;
-      this->peek_ = 0;
-      return 0;
-  int BE = (ACE_OS::strcmp (this->encoding_,
-                            ACE_TEXT ("UTF-16BE")) == 0) ? 1 : 0;
-  ACEXML_Char input[2];
-  int i = 0;
-  for (; i < 2 && !feof (this->infile_); ++i)
-      input[i] = ACE_OS::fgetwc (this->infile_);
-  if (i < 2)
-      ch = 0;
-      return -1;
-  ch = BE ? input[0] << 8 | input[1] : input[1] << 8 | input[0];
-  return 0;
-int
-ACEXML_FileCharStream::peek_i (void)
-  // If we are reading a UTF-8 encoded file, just use the plain unget.
-      ACEXML_Char ch = (ACEXML_Char) ACE_OS::fgetc (this->infile_);
-      return ch;
-  // If somebody had already called peek() and not consumed it, return the
-  // value held in this->peek_.
-    return this->peek_;
-  // Peek into the stream. This reads two characters off the stream, keeps
-  // it in peek_.
-  int i = 0;
-  if (i < 2)
-      this->peek_ = 0;
-      return -1;
-  this->peek_ = BE ? input[0] << 8 | input[1] : input[1] << 8 | input[0];
-const ACEXML_Char*
-ACEXML_FileCharStream::getEncoding (void)
-  return this->encoding_;
-const ACEXML_Char*
-ACEXML_FileCharStream::getSystemId (void)
-  return this->filename_;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/FileCharStream.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/FileCharStream.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/FileCharStream.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,130 +0,0 @@
-// -*- C++ -*-
- *  @file    FileCharStream.h
- *  FileCharStream.h,v 1.13 2003/11/06 16:34:32 dhinton Exp
-#ifndef _ACEXML_FILECHARSTREAM_H_
-#define _ACEXML_FILECHARSTREAM_H_
-#pragma once
- * @class ACEXML_FileCharStream FileCharStream.h "ACEXML/common/FileCharStream.h"
- * An implementation of ACEXML_CharStream for reading input from a file.
-class ACEXML_Export ACEXML_FileCharStream : public ACEXML_CharStream
-public:
-  ACEXML_FileCharStream (void);
-  /// Destructor
-  virtual ~ACEXML_FileCharStream (void);
-  /// Open a file.
-  int open (const ACEXML_Char *name);
-  virtual int available (void);
-  virtual int close (void);
-   * return an ACEXML_Char, 0 if succees.
-  virtual int get (ACEXML_Char& ch);
-                    size_t len);
-   *  Determine the encoding of the file.
-  virtual int determine_encoding (void);
-   * character if success, -1 if EOF is reached.
-  virtual int peek (void);
-   *  Resets the file pointer to the beginning of the stream.
-  virtual void rewind (void);
-   * Get the character encoding for the file.
-  virtual const ACEXML_Char *getEncoding (void);
-  virtual const ACEXML_Char* getSystemId (void);
-private:
-  /** Read the next character as a normal character. Return -1 if EOF is
-   *  reached, else return 0.
-  int getchar_i (char& ch);
-   *  Read the next character from the stream taking into account the
-   *  encoding of the file.
-  int get_i (ACEXML_Char& ch);
-   *  encoding of the file. Subsequent call to get() returns this
-   *  character.
-  int peek_i (void);
-  ACEXML_Char*  filename_;
-  ACEXML_Char*  encoding_;
-  off_t         size_;
-  FILE*         infile_;
-  // This is needed to ensure that we can implement a peek operation on a
-  // UTF-16 encoded file. It is a bit hackish, but there is no other way of
-  // implementing a peek() as the standard I/O FILE* guarantees only one
-  // pushback.
-  ACEXML_Char   peek_;
-#endif /* _ACEXML_FILECHARSTREAM_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/HttpCharStream.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/HttpCharStream.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/HttpCharStream.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,466 +0,0 @@
-// HttpCharStream.cpp,v 1.19 2004/01/09 00:50:35 kitty Exp
-#include "ace/ace_wchar.h"
-#include "ACEXML/common/HttpCharStream.h"
-ACE_RCSID (common, HttpCharStream, "HttpCharStream.cpp,v 1.19 2004/01/09 00:50:35 kitty Exp")
-/* Header FSM states. */
-static const int HDST_LINE1_PROTOCOL = 0;
-static const int HDST_LINE1_WHITESPACE = 1;
-static const int HDST_LINE1_STATUS = 2;
-static const int HDST_BOL = 10;
-static const int HDST_TEXT = 11;
-static const int HDST_LF = 12;
-static const int HDST_CR = 13;
-static const int HDST_CRLF = 14;
-static const int HDST_CRLFCR = 15;
-ACEXML_HttpCharStream::ACEXML_HttpCharStream (void)
-  : url_(0),
-    url_addr_(0),
-    stream_(0),
-    connector_(0),
-    size_(0),
-    data_offset_ (0),
-    encoding_ (0)
-ACEXML_HttpCharStream::~ACEXML_HttpCharStream (void)
-  this->close ();
-int
-ACEXML_HttpCharStream::open (const ACEXML_Char *url)
-  this->url_ = ACE::strnew (url);
-  ACE_NEW_RETURN (this->url_addr_, ACEXML_URL_Addr, -1);
-  ACE_NEW_RETURN (this->stream_, ACEXML_Mem_Map_Stream, -1);
-  if (this->url_addr_->string_to_addr (this->url_) == -1) {
-    this->close();
-    ACE_ERROR_RETURN ((LM_ERROR, "%p\n", "cannot convert URL"), -1);
-  ACE_NEW_RETURN (this->connector_,
-                  Connector (0, ACE_NONBLOCK),
-                  -1);
-  if (this->stream_->open (this->connector_, *this->url_addr_) == -1) {
-    this->close();
-    ACE_ERROR_RETURN ((LM_ERROR, "%p\n", "cannot open backing store"), -1);
-  int result = this->send_request();
-  if (result == -1) {
-    this->close();
-    ACE_ERROR_RETURN ((LM_ERROR, "%p\n", "send_request"), -1);
-  size_t len = 0;
-  result = this->get_url(len);
-    this->close();
-    ACE_ERROR_RETURN ((LM_ERROR, "%p\n", "get_url"), -1);
-  if (result != 200) {
-    this->close();
-    ACE_ERROR_RETURN ((LM_ERROR, "Server returned status %d : %s\n",
-                       result,
-                       "Refer HTTP/1.0 error code for details"), -1);
-  this->size_ = ACE_static_cast (off_t, len);
-// The FSM was taken from the implementation of http_get and that falls
-// under the following license:
-// Copyrigh (c) 2000 by Jef Poskanzer <jef at acme.com>.  All rights reserved.
-// Redistribution and use in source and binary forms, with or without
-// modification, are permitted provided that the following conditions
-// are met:
-// 1. Redistributions of source code must retain the above copyright
-//    notice, this list of conditions and the following disclaimer.
-// 2. Redistributions in binary form must reproduce the above copyright
-//    notice, this list of conditions and the following disclaimer in the
-//    documentation and/or other materials provided with the distribution.
-// THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
-// ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-// IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-// ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
-// FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
-// DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
-// OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
-// HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
-// LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
-// OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
-// SUCH DAMAGE.
-int
-ACEXML_HttpCharStream::get_url (size_t& len)
-  if (this->stream_ == 0)
-    return -1;
-  int header_state = HDST_LINE1_PROTOCOL;
-  int status = 0;
-  size_t b = 0;
-  char* buf = 0;
-  size_t buflen = BUFSIZ;
-  for (;;)
-      if ((buf = ACE_const_cast (char*,
-                                 this->stream_->recv (buflen))) == 0)
-        if (buflen <= 0)
-          break;
-      for (b = 0; b < buflen; ++b)
-          switch ( header_state )
-            case HDST_LINE1_PROTOCOL:
-              switch ( buf[b] )
-                case ' ': case '\t':
-                  header_state = HDST_LINE1_WHITESPACE; break;
-                case '\n': header_state = HDST_LF ; break;
-                case '\r': header_state = HDST_CR; break;
-              break;
-            case HDST_LINE1_WHITESPACE:
-              switch ( buf[b] )
-                case '0': case '1': case '2': case '3': case '4':
-                case '5': case '6': case '7': case '8': case '9':
-                  status = buf[b] - '0';
-                  header_state = HDST_LINE1_STATUS;
-                  break;
-                default: header_state = HDST_TEXT; break;
-              break;
-            case HDST_LINE1_STATUS:
-              switch ( buf[b] )
-                  status = status * 10 + buf[b] - '0';
-                  break;
-              break;
-            case HDST_BOL:
-              switch ( buf[b] )
-                case '\n': header_state = HDST_LF; break;
-              break;
-            case HDST_TEXT:
-              switch ( buf[b] )
-              break;
-            case HDST_LF:
-              switch ( buf[b] )
-                case '\n': goto end_of_headers;
-              break;
-            case HDST_CR:
-              switch ( buf[b] )
-                case '\n': header_state = HDST_CRLF; break;
-                case '\r': goto end_of_headers;
-              break;
-            case HDST_CRLF:
-              switch ( buf[b] )
-                case '\r': header_state = HDST_CRLFCR; break;
-              break;
-            case HDST_CRLFCR:
-              switch ( buf[b] )
-                case '\n': case '\r': goto end_of_headers;
-              break;
- end_of_headers:
-  if (b == 0)
-    return -1;
-  ++b;
-  // Store the address of the beginning of data. We will use it to seek to
-  // beginning of the data in the URL.
-  char* data_beg = buf + b;
-  buflen = BUFSIZ;
-  // Get all of the data. Since this is backed by file store, we won't lose
-  // any of the data.
-  while (( buf = ACE_const_cast (char*,
-                                 this->stream_->recv (buflen))) != 0)
-  // Length of data in the URL.
-  len = this->stream_->recv() - data_beg;
-  // Move the pointer to the beginning of the file store.
-  this->stream_->rewind();
-  this->data_offset_ = data_beg - this->stream_->recv();
-  // Forward to the beginning of data.
-  if (this->stream_->seek (this->data_offset_, SEEK_SET) == -1)
-    ACE_ERROR_RETURN ((LM_ERROR, "%s: %m",
-                       "Error in seeking to beginning of data"), -1);
-  return status;
-int
-ACEXML_HttpCharStream::send_request (void)
-  char* path = ACE::strnew (ACE_TEXT_ALWAYS_CHAR (this->url_addr_->get_path_name()));
-  ACE_Auto_Basic_Array_Ptr<char> path_ptr (path);
-  size_t commandsize = ACE_OS::strlen (path)
-                       + ACE_OS::strlen (this->url_addr_->get_host_name ())
-                       + 20     // Extra
-                       + 1      // NUL byte
-                       + 16 ;   // Protocol filler...
-  char* command;
-  ACE_NEW_RETURN (command, char[commandsize], -1);
-  // Ensure that the <command> memory is deallocated.
-  ACE_Auto_Basic_Array_Ptr<char> cmd_ptr (command);
-  int bytes = ACE_OS::sprintf (command, "GET %s HTTP/1.0\r\n", path);
-  bytes += ACE_OS::sprintf (&command[bytes], "Host: %s\r\n",
-                            this->url_addr_->get_host_name ());
-  bytes += ACE_OS::sprintf (&command[bytes], "\r\n");
-  ACE_Time_Value tv (ACE_DEFAULT_TIMEOUT);
-  // Send the command to the connected server.
-  int retval = this->stream_->send_n (command, bytes, &tv);
-  if (retval <= 0)
-    return -1;
-  return retval;
-int
-ACEXML_HttpCharStream::available (void)
-    return -1;
-  return ACE_static_cast (int, this->stream_->available());
-int
-ACEXML_HttpCharStream::close (void)
-  delete[] this->url_;
-  this->url_ = 0;
-  delete this->url_addr_;
-  this->url_addr_ = 0;
-  delete this->stream_;
-  this->stream_ = 0;
-  delete this->connector_;
-  this->connector_ = 0;
-  this->size_ = 0;
-  this->data_offset_ = 0;
-  return 0;
-int
-ACEXML_HttpCharStream::determine_encoding (void)
-    return -1;
-  char input[4] = {0, 0, 0, 0};
-  int i = 0;
-  for (; i < 4 && input[i] != -1; ++i)
-    input[i] = this->stream_->peek_char(i);
-  if (i < 4)
-    return -1;
-  if (!temp)
-    return -1;
-  else
-      //   ACE_DEBUG ((LM_DEBUG, "URI's encoding is %s\n", this->encoding_));
-      if (input[i] == '\xFF' || input[i] == '\xFE' || input[i] == '\xEF' ||
-          input[i] == '\xBB' || input[i] == '\xBF')
-          this->stream_->get_char();
-          continue;
-      break;
-  return 0;
-void
-ACEXML_HttpCharStream::rewind (void)
-    return;
-    ACE_ERROR ((LM_ERROR, "%s: %m", "Error in seeking to beginning of data"));
-const ACEXML_Char*
-ACEXML_HttpCharStream::getEncoding (void)
-const ACEXML_Char*
-ACEXML_HttpCharStream::getSystemId (void)
-  return this->url_;
-int
-ACEXML_HttpCharStream::read (ACEXML_Char *str,
-                             size_t len)
-    return -1;
-  len = len * sizeof (ACEXML_Char);
-  char* temp = ACE_const_cast (char*, this->stream_->recv (len));
-  str = ACE_TEXT_CHAR_TO_TCHAR (temp);
-  if (str == 0)
-    return -1;
-  return ACE_static_cast (int, len);
-int
-ACEXML_HttpCharStream::get (ACEXML_Char& ch)
-    return -1;
-#else
-  ch = (ACEXML_Char) this->stream_->get_char();
-  return (ch == (ACEXML_Char)EOF ? -1 :0);
-int
-ACEXML_HttpCharStream::peek (void)
-    return -1;
-#else
-  return this->stream_->peek_char (0);
-int
-ACEXML_HttpCharStream::get_i (ACEXML_Char& ch)
-      return (ch == (ACEXML_Char)EOF ? -1 : 0);
-  ACEXML_Char input[2] = {0};
-  int i = 0;
-  for (; i < 2 && (input[i] = this->stream_->get_char()) > 0; ++i)
-  if (i < 2)
-      ch = 0;
-      return input[i];
-  return 0;
-int
-ACEXML_HttpCharStream::peek_i (void)
-      ACEXML_Char ch = (ACEXML_Char) this->stream_->peek_char (0);
-      return ch;
-  int i = 0;
-  for (; i < 2 && (input[i] = this->stream_->peek_char (i)) > 0; ++i)
-  if (i < 2)
-    return -1;
-  return (BE ? input[0] << 8 | input[1] : input[1] << 8 | input[0]);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/HttpCharStream.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/HttpCharStream.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/HttpCharStream.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,140 +0,0 @@
-// -*- C++ -*-
- *  @file    HttpCharStream.h
- *  HttpCharStream.h,v 1.9 2004/01/09 00:50:35 kitty Exp
-#ifndef _ACEXML_HTTPCHARSTREAM_H_
-#define _ACEXML_HTTPCHARSTREAM_H_
-#include "ACEXML/common/ACEXML_Export.h"
-#if !defined (ACE_LACKS_PRAGMA_ONCE)
-#pragma once
-#endif /* ACE_LACKS_PRAGMA_ONCE */
-#include "ACEXML/common/URL_Addr.h"
-#include "ACEXML/common/Mem_Map_Stream.h"
- * @class ACEXML_HttpCharStream HttpCharStream.h "ACEXML/common/HttpCharStream.h"
- * An implementation of ACEXML_CharStream for reading input from a URL.
-class ACEXML_Export ACEXML_HttpCharStream : public ACEXML_CharStream
-public:
-  ACEXML_HttpCharStream (void);
-  /// Destructor
-  virtual ~ACEXML_HttpCharStream (void);
-  /// Open an URL.
-  int open (const ACEXML_Char *url);
-  virtual int read (ACEXML_Char *str, size_t len);
-   * Get the encoding of the file
-  virtual const ACEXML_Char* getEncoding (void);
-private:
-   *  character.
-   *  Send a HTTP/1.1 request to fetch the contents of the URL.
-  int send_request (void);
-   *  Fetch the URL and save it in backing store.
-  int get_url (size_t& len);
-  ACEXML_Char *url_;
-  ACEXML_URL_Addr* url_addr_;
-  ACEXML_Mem_Map_Stream* stream_;
-  Connector* connector_;
-  off_t size_;
-  off_t data_offset_;
-#endif /* _ACEXML_HTTPCHARSTREAM_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/InputSource.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/InputSource.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/InputSource.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,106 +0,0 @@
-// -*- C++ -*- InputSource.cpp,v 1.8 2003/05/30 03:31:48 kitty Exp
-#include "ACEXML/common/StreamFactory.h"
-#include "ace/Swap.h"
-ACEXML_InputSource::ACEXML_InputSource (void)
-  : charStream_ (0),
-    encoding_ (0),
-    publicId_ (0),
-    systemId_ (0)
-ACEXML_InputSource::ACEXML_InputSource (ACEXML_CharStream *stm)
-  : charStream_ (stm),
-    encoding_ (ACE::strnew (stm->getEncoding())),
-    publicId_ (0),
-    systemId_ (stm->getSystemId() ? ACE::strnew (stm->getSystemId()): 0)
-   * Create a new input source with a character stream.
-ACEXML_InputSource::ACEXML_InputSource (const ACEXML_Char *systemId)
-    encoding_ (0),
-    publicId_ (0),
-    systemId_ (ACE::strnew (systemId))
-  ACEXML_StreamFactory factory;
-  ACEXML_CharStream* stm = factory.create_stream (this->systemId_);
-  if (stm)
-      this->setCharStream (stm);
-      this->setEncoding (this->charStream_->getEncoding());
-ACEXML_InputSource::~ACEXML_InputSource (void)
-  delete[] this->publicId_;
-  this->publicId_ = 0;
-  delete[] this->systemId_;
-  this->systemId_ = 0;
-  delete this->charStream_;
-  this->charStream_ = 0;
-ACEXML_CharStream *
-ACEXML_InputSource::getCharStream (void) const
-  return this->charStream_;
-ACEXML_InputSource::getEncoding (void) const
-ACEXML_InputSource::getPublicId (void) const
-  return this->publicId_;
-ACEXML_InputSource::getSystemId (void) const
-  return this->systemId_;
-void
-ACEXML_InputSource::setCharStream (ACEXML_CharStream *stm)
-  this->charStream_ = stm;
-void
-ACEXML_InputSource::setEncoding (const ACEXML_Char *encoding)
-  this->encoding_ = ACE::strnew (encoding);
-void
-ACEXML_InputSource::setPublicId (const ACEXML_Char *publicId)
-  this->publicId_ = ACE::strnew (publicId);
-void
-ACEXML_InputSource::setSystemId (const ACEXML_Char *systemId)
-  this->systemId_ = ACE::strnew (systemId);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/InputSource.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/InputSource.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/InputSource.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,131 +0,0 @@
-// -*- C++ -*-
- *  @file    InputSource.h
- *  InputSource.h,v 1.6 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_INPUTSOURCE_H_
-#define _ACEXML_INPUTSOURCE_H_
-#pragma once
- * @class ACEXML_InputSource InputSource.h "ACEXML/common/InputSource.h"
- * @brief ACEXML_InputSource encapsulates the actual input stream with some
- * added information.
- * This class allows a SAX application to encapsulate information
- * about an input source in a single object, which may include a
- * public identifier, a system identifier, a byte stream (possibly
- * with a specified encoding), and/or a character stream.
- * There are two places that the application will deliver this input
- * source to the parser: as the argument to the Parser.parse method,
- * or as the return value of the EntityResolver.resolveEntity method.
- * The SAX parser will use the InputSource object to determine how to
- * read XML input. If there is a character stream available, the
- * parser will read that stream directly; if not, the parser will use
- * a byte stream, if available; if neither a character stream nor a
- * byte stream is available, the parser will attempt to open a URI
- * connection to the resource identified by the system identifier.
- * An InputSource object belongs to the application: the SAX parser
- * shall never modify it in any way (it may modify a copy if
- * necessary).
- * @sa ACEXML_CharStream
-class ACEXML_Export ACEXML_InputSource
-public:
-   * Default constructor.
-  ACEXML_InputSource (void);
-   * Create a new input source with a ACEXML_Char stream.
-   * Notice that ACEXML_InputSource assumes the ownership
-   * of <stream>
-  ACE_EXPLICIT ACEXML_InputSource (ACEXML_CharStream *stream);
-   * Create a new input source with a system identifier.
-  ACEXML_InputSource (const ACEXML_Char *systemId);
-   * Default destructor.
-  virtual ~ACEXML_InputSource (void);
-   * Get the ACEXML_Char stream for this input source.
-  virtual ACEXML_CharStream *getCharStream (void) const;
-  virtual const ACEXML_Char *getEncoding (void) const;
-   * Get the public identifier for this input source.
-  virtual const ACEXML_Char *getPublicId (void) const;
-   * Get the system identifier for this input source.
-  virtual const ACEXML_Char *getSystemId (void) const;
-   * Set the ACEXML_Char stream for this input source.
-   * of <stream>
-  virtual void setCharStream (ACEXML_CharStream *charStream);
-   * Set the character encoding, if known.
-  virtual void setEncoding (const ACEXML_Char *encoding);
-   * Set the public identifier for this input source.
-  virtual void setPublicId (const ACEXML_Char *publicId);
-  virtual void setSystemId (const ACEXML_Char *systemId);
-private:
-  ACEXML_CharStream *charStream_;
-  ACEXML_Char *encoding_;
-  ACEXML_Char *publicId_;
-  ACEXML_Char *systemId_;
-#endif /* _ACEXML_INPUTSOURCE_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Locator.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Locator.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Locator.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,70 +0,0 @@
-// -*- C++ -*-
- *  @file    Locator.h
- *  Locator.h,v 1.6 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_LOCATOR_H_
-#define _ACEXML_LOCATOR_H_
-#include "ACEXML/common/XML_Types.h"
- * @class ACEXML_Locator Locator.h "ACEXML/common/Locator.h"
- * @brief ACEXML_Locator defines operations that an XML locator should support.
- * If a SAX parser provides location information to the SAX
- * application, it does so by implementing this interface and then
- * passing an instance to the application using the content handler's
- * setDocumentLocator method. The application can use the object to
- * obtain the location of any other content handler event in the XML
- * source document.
- * Note that the results returned by the object will be valid only
- * during the scope of each content handler method: the application
- * will receive unpredictable results if it attempts to use the
- * locator at any other time.
- * SAX parsers are not required to supply a locator, but they are very
- * strongly encouraged to do so. If the parser supplies a locator, it
- * must do so before reporting any other document events. If no
- * locator has been set by the time the application receives the
- * startDocument event, the application should assume that a locator
- * is not available.
-class ACEXML_Export ACEXML_Locator
-public:
-   * Return the column number where the current document event ends.
-  virtual int getColumnNumber (void) const = 0;
-   * Return the line number where the current document event ends.
-  virtual int getLineNumber (void) const = 0;
-   * Return the public identifier for the current document event.
-  virtual const ACEXML_Char *getPublicId (void) const = 0;
-   * Return the system identifier for the current document event.
-  virtual const ACEXML_Char *getSystemId (void) const = 0;
-#endif /* _ACEXML_LOCATOR_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/LocatorImpl.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/LocatorImpl.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/LocatorImpl.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,49 +0,0 @@
-// -*- C++ -*-  LocatorImpl.cpp,v 1.6 2003/05/30 03:31:48 kitty Exp
-#include "ACEXML/common/LocatorImpl.h"
-# include "ACEXML/common/LocatorImpl.i"
-ACEXML_LocatorImpl::ACEXML_LocatorImpl (void)
-  : publicId_ (0),
-    systemId_ (0),
-    lineNumber_ (1),
-    columnNumber_ (0)
-ACEXML_LocatorImpl::ACEXML_LocatorImpl (const ACEXML_Char* systemId,
-                                        const ACEXML_Char* publicId)
-  : publicId_ (publicId ? ACE::strnew (publicId) : 0),
-    systemId_ (systemId ? ACE::strnew (systemId) : 0),
-    lineNumber_ (1),
-    columnNumber_ (0)
-ACEXML_LocatorImpl::ACEXML_LocatorImpl (const ACEXML_Locator& locator)
-  : publicId_ (locator.getPublicId() ? ACE::strnew(locator.getPublicId ()): 0),
-    systemId_ (locator.getSystemId() ? ACE::strnew(locator.getSystemId ()): 0),
-    lineNumber_ (locator.getLineNumber ()),
-    columnNumber_ (locator.getColumnNumber ())
-ACEXML_LocatorImpl::~ACEXML_LocatorImpl (void)
-  this->reset();
-void
-ACEXML_LocatorImpl::reset (void)
-  this->columnNumber_ = 0;
-  this->lineNumber_ = 1;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/LocatorImpl.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/LocatorImpl.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/LocatorImpl.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,159 +0,0 @@
-// -*- C++ -*-
- *  @file    LocatorImpl.h
- *  LocatorImpl.h,v 1.8 2003/07/19 19:04:10 dhinton Exp
- *  @author Krishnakumar Balasubramanian <kitty at cs.wustl.edu>
-#ifndef ACEXML_LOCALTORIMPL_H
-#define ACEXML_LOCALTORIMPL_H
-#pragma once
- * @class ACEXML_LocatorImpl LocatorImpl.h "ACEXML/common/LocatorImpl.h"
- * @brief ACEXML_LocatorImpl is an implementation of ACEXML_Locator.
- * This class is available mainly for application writers, who can
- * use it to make a persistent snapshot of a locator at any point
- * during a document parse:
- * @code
- *   ACEXML_Locator locator;
- *   ACEXML_Locator startloc;
- *   public void setLocator (ACEXML_Locator locator)
- *      // note the locator
- *      this.locator = locator;
- *   public void startDocument ()
- *      // save the location of the start of the document
- *      // for future use.
- *      ACEXML_Locator startloc = new ACEXML_LocatorImpl(locator);
- * @endcode
- * Normally, parser writers will not use this class, since it is more
- * efficient to provide location information only when requested,
- * rather than constantly updating a Locator object.
- * @todo ACEXML parser doesn't support the use of Locator yet.
- * @sa ACEXML_Locator
-class ACEXML_Export ACEXML_LocatorImpl : public ACEXML_Locator
-public:
-  ACEXML_LocatorImpl (void);
-   * Construct a locator with systemId and publicId
-  ACEXML_LocatorImpl (const ACEXML_Char* systemId,
-                      const ACEXML_Char* publicId);
-   * Copy constructor.  Create a persistent copy of the current state
-   * of a locator. When the original locator changes, this copy will
-   * still keep the original values (and it can be used outside the
-   * scope of DocumentHandler methods).
-  ACEXML_LocatorImpl (const ACEXML_Locator& locator);
-   * Destructor.
-  virtual ~ACEXML_LocatorImpl (void);
-  virtual int getColumnNumber (void) const;
-  virtual int getLineNumber (void) const;
-   * Set the column number of this locator.
-  void setColumnNumber (int cn);
-   * Set the line number of this locator.
-  void setLineNumber (int ln);
-   * Set the public identifier of this locator.
-  void setPublicId (const ACEXML_Char *id);
-   * Set the system identifier of this locator.
-  void setSystemId (const ACEXML_Char *id);
-   * Increment the line number.
-  void incrLineNumber ();
-   * Increment the column number.
-  void incrColumnNumber ();
-   * Reset the Locator information. This is necessary because one might
-   * want to use the same parser to parse multiple files. In that case,
-   * tying the life of the Locator with the parser is not appropriate. The
-   * parser calls this method as soon as issuing an endDocument() call.
-  void reset (void);
-private:
-  int lineNumber_;
-  int columnNumber_;
-#endif /* ACEXML_LOCALTORIMPL_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/LocatorImpl.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/LocatorImpl.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/LocatorImpl.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,65 +0,0 @@
-// -*- C++ -*-  LocatorImpl.i,v 1.3 2002/05/23 19:14:25 kitty Exp
-ACEXML_INLINE void
-ACEXML_LocatorImpl::setColumnNumber (int cn)
-  this->columnNumber_ = cn;
-ACEXML_INLINE void
-ACEXML_LocatorImpl::setLineNumber (int ln)
-  this->lineNumber_ = ln;
-ACEXML_INLINE int
-ACEXML_LocatorImpl::getColumnNumber (void) const
-  return this->columnNumber_;
-ACEXML_INLINE int
-ACEXML_LocatorImpl::getLineNumber (void) const
-  return this->lineNumber_;
-ACEXML_INLINE void
-ACEXML_LocatorImpl::setPublicId (const ACEXML_Char *id)
-  this->publicId_ = ACE::strnew (id);
-ACEXML_INLINE void
-ACEXML_LocatorImpl::setSystemId (const ACEXML_Char *id)
-  this->systemId_ = ACE::strnew (id);
-ACEXML_INLINE const ACEXML_Char *
-ACEXML_LocatorImpl::getPublicId (void) const
-ACEXML_LocatorImpl::getSystemId (void) const
-ACEXML_INLINE void
-ACEXML_LocatorImpl::incrLineNumber ()
-  ++this->lineNumber_;
-ACEXML_INLINE void
-ACEXML_LocatorImpl::incrColumnNumber ()
-  ++this->columnNumber_;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Makefile
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Makefile	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Makefile	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,10 +0,0 @@
-# Makefile,v 1.17 2003/07/14 18:47:57 jwillemsen Exp
-#       GNU ACE Workspace
-include $(ACE_ROOT)/include/makeinclude/macros.GNU
-TARGETS_NESTED := $(TARGETS_NESTED:.nested=)
-$(TARGETS_NESTED):
-	@$(MAKE) -f Makefile.ACEXML -C . $(@);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Makefile.ACEXML
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Makefile.ACEXML	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Makefile.ACEXML	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,2620 +0,0 @@
-#       GNU Makefile
-MAKEFILE        = Makefile.ACEXML
-LIB_UNCHECKED   = libACEXML.a
-SHLIB_UNCHECKED = libACEXML.$(SOEXT)
-FILES = \
-  AttributesImpl \
-  Attributes_Def_Builder \
-  CharStream \
-  DefaultHandler \
-  DTD_Manager \
-  Element_Def_Builder \
-  Encoding \
-  Env \
-  Exception \
-  FileCharStream \
-  HttpCharStream \
-  InputSource \
-  LocatorImpl \
-  Mem_Map_Stream \
-  NamespaceSupport \
-  SAXExceptions \
-  StrCharStream \
-  StreamFactory \
-  Transcode \
-  URL_Addr \
-  Validator \
-  XMLFilterImpl \
-  XML_Codecs \
-  ZipCharStream
-#       Include macros and targets
-LIB   = $(LIB_UNCHECKED)
-SHLIB = $(SHLIB_UNCHECKED)
-ACE_SHLIBS = -lACE
-include $(ACE_ROOT)/include/makeinclude/wrapper_macros.GNU
-LSRC   = $(addsuffix .cpp, $(FILES))
-include $(ACE_ROOT)/include/makeinclude/rules.common.GNU
-include $(ACE_ROOT)/include/makeinclude/rules.nonested.GNU
-include $(ACE_ROOT)/include/makeinclude/rules.lib.GNU
-include $(ACE_ROOT)/include/makeinclude/rules.local.GNU
-CPPFLAGS     += -I../..
-ifeq ($(shared_libs),1)
-  ifneq ($(SHLIB),)
-    CPPFLAGS += -DACEXML_BUILD_DLL
-  endif
-endif
-ifeq ($(static_libs),1)
-  ifneq ($(LIB),)
-    CPPFLAGS += -DACE_AS_STATIC_LIBS
-  endif
-endif
-LDFLAGS      += -L../../ace
-#       Local targets
-realclean: clean
-ifneq ($(GENERATED_DIRTY),)
-	-$(RM) -r $(GENERATED_DIRTY)
-endif
-#       Dependencies
-# DO NOT DELETE THIS LINE -- g++dep uses it.
-# DO NOT PUT ANYTHING AFTER THIS LINE, IT WILL GO AWAY.
-.obj/AttributesImpl.o .obj/AttributesImpl.so .shobj/AttributesImpl.o .shobj/AttributesImpl.so: AttributesImpl.cpp \
-  AttributesImpl.h \
-  $(ACE_ROOT)/ace/pre.h \
-  ACEXML_Export.h \
-  $(ACE_ROOT)/ace/config-all.h \
-  $(ACE_ROOT)/ace/config.h \
-  $(ACE_ROOT)/ace/$(ACE_PLATFORM_CONFIG) \
-  $(ACE_ROOT)/ace/post.h \
-  $(ACE_ROOT)/ace/ace_wchar.h \
-  $(ACE_ROOT)/ace/ace_wchar.inl \
-  $(ACE_ROOT)/ace/OS_main.h \
-  $(ACE_ROOT)/ace/ACE_export.h \
-  Attributes.h \
-  XML_Types.h \
-  $(ACE_ROOT)/ace/SString.h \
-  $(ACE_ROOT)/ace/SStringfwd.h \
-  $(ACE_ROOT)/ace/Basic_Types.h \
-  $(ACE_ROOT)/ace/os_include/os_limits.h \
-  $(ACE_ROOT)/ace/os_include/os_unistd.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_types.h \
-  $(ACE_ROOT)/ace/os_include/os_stddef.h \
-  $(ACE_ROOT)/ace/os_include/os_inttypes.h \
-  $(ACE_ROOT)/ace/os_include/os_stdint.h \
-  $(ACE_ROOT)/ace/os_include/os_stdio.h \
-  $(ACE_ROOT)/ace/os_include/os_stdarg.h \
-  $(ACE_ROOT)/ace/os_include/os_float.h \
-  $(ACE_ROOT)/ace/os_include/os_stdlib.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_wait.h \
-  $(ACE_ROOT)/ace/os_include/os_signal.h \
-  $(ACE_ROOT)/ace/os_include/os_time.h \
-  $(ACE_ROOT)/ace/os_include/os_ucontext.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_resource.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_time.h \
-  $(ACE_ROOT)/ace/String_Base.h \
-  $(ACE_ROOT)/ace/String_Base_Const.h \
-  $(ACE_ROOT)/ace/Global_Macros.h \
-  $(ACE_ROOT)/ace/OS_Errno.h \
-  $(ACE_ROOT)/ace/os_include/os_errno.h \
-  $(ACE_ROOT)/ace/String_Base.cpp \
-  $(ACE_ROOT)/ace/ACE.h \
-  $(ACE_ROOT)/ace/Flag_Manip.h \
-  $(ACE_ROOT)/ace/Flag_Manip.i \
-  $(ACE_ROOT)/ace/OS_NS_fcntl.h \
-  $(ACE_ROOT)/ace/os_include/os_fcntl.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_stat.h \
-  $(ACE_ROOT)/ace/Handle_Ops.h \
-  $(ACE_ROOT)/ace/Handle_Ops.i \
-  $(ACE_ROOT)/ace/Lib_Find.h \
-  $(ACE_ROOT)/ace/Lib_Find.i \
-  $(ACE_ROOT)/ace/Init_ACE.h \
-  $(ACE_ROOT)/ace/Init_ACE.i \
-  $(ACE_ROOT)/ace/Sock_Connect.h \
-  $(ACE_ROOT)/ace/os_include/netinet/os_in.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_socket.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_uio.h \
-  $(ACE_ROOT)/ace/Sock_Connect.i \
-  $(ACE_ROOT)/ace/Default_Constants.h \
-  $(ACE_ROOT)/ace/ACE.i \
-  $(ACE_ROOT)/ace/OS_NS_unistd.h \
-  $(ACE_ROOT)/ace/Time_Value.h \
-  $(ACE_ROOT)/ace/OS_NS_Thread.h \
-  $(ACE_ROOT)/ace/os_include/os_pthread.h \
-  $(ACE_ROOT)/ace/Base_Thread_Adapter.h \
-  $(ACE_ROOT)/ace/OS_Log_Msg_Attributes.h \
-  $(ACE_ROOT)/ace/iosfwd.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_sem.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_ipc.h \
-  $(ACE_ROOT)/ace/os_include/os_semaphore.h \
-  $(ACE_ROOT)/ace/OS_Memory.h \
-  $(ACE_ROOT)/ace/OS_NS_stdlib.h \
-  $(ACE_ROOT)/ace/OS_NS_signal.h \
-  $(ACE_ROOT)/ace/Object_Manager_Base.h \
-  $(ACE_ROOT)/ace/Cleanup.h \
-  $(ACE_ROOT)/ace/os_include/os_ctype.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_socket.h \
-  $(ACE_ROOT)/ace/os_include/net/os_if.h \
-  $(ACE_ROOT)/ace/OS_NS_stropts.h \
-  $(ACE_ROOT)/ace/os_include/os_stropts.h \
-  $(ACE_ROOT)/ace/Malloc_Base.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_mman.h \
-  $(ACE_ROOT)/ace/Auto_Ptr.h \
-  $(ACE_ROOT)/ace/Auto_Ptr.cpp \
-  $(ACE_ROOT)/ace/Auto_Ptr.i \
-  $(ACE_ROOT)/ace/OS_NS_string.h \
-  $(ACE_ROOT)/ace/String_Base.i \
-  $(ACE_ROOT)/ace/Min_Max.h \
-  $(ACE_ROOT)/ace/Containers_T.h \
-  $(ACE_ROOT)/ace/Containers.h \
-  $(ACE_ROOT)/ace/Node.h \
-  $(ACE_ROOT)/ace/Node.cpp \
-  $(ACE_ROOT)/ace/Array_Base.h \
-  $(ACE_ROOT)/ace/Array_Base.cpp \
-  $(ACE_ROOT)/ace/Array_Base.inl \
-  $(ACE_ROOT)/ace/Unbounded_Set.h \
-  $(ACE_ROOT)/ace/Unbounded_Set.cpp \
-  $(ACE_ROOT)/ace/Log_Msg.h \
-  $(ACE_ROOT)/ace/Log_Priority.h \
-  $(ACE_ROOT)/ace/Unbounded_Set.inl \
-  $(ACE_ROOT)/ace/Unbounded_Queue.h \
-  $(ACE_ROOT)/ace/Unbounded_Queue.cpp \
-  $(ACE_ROOT)/ace/Unbounded_Queue.inl \
-  $(ACE_ROOT)/ace/Containers_T.cpp \
-  $(ACE_ROOT)/ace/Containers_T.i \
-  AttributesImpl.i
-.obj/Attributes_Def_Builder.o .obj/Attributes_Def_Builder.so .shobj/Attributes_Def_Builder.o .shobj/Attributes_Def_Builder.so: Attributes_Def_Builder.cpp \
-  Attributes_Def_Builder.h \
-  ACEXML_Export.h \
-  XML_Types.h \
-  Env.h \
-  XML_Macros.h \
-  $(ACE_ROOT)/ace/Exception_Macros.h \
-  Exception.h \
-  SAXExceptions.h
-.obj/CharStream.o .obj/CharStream.so .shobj/CharStream.o .shobj/CharStream.so: CharStream.cpp \
-  CharStream.h \
-  ACEXML_Export.h \
-  XML_Types.h \
-.obj/DefaultHandler.o .obj/DefaultHandler.so .shobj/DefaultHandler.o .shobj/DefaultHandler.so: DefaultHandler.cpp \
-  DefaultHandler.h \
-  ACEXML_Export.h \
-  ContentHandler.h \
-  Env.h \
-  XML_Macros.h \
-  Exception.h \
-  XML_Types.h \
-  SAXExceptions.h \
-  Locator.h \
-  Attributes.h \
-  DTDHandler.h \
-  EntityResolver.h \
-  InputSource.h \
-  CharStream.h \
-  ErrorHandler.h \
-  DefaultHandler.i
-.obj/DTD_Manager.o .obj/DTD_Manager.so .shobj/DTD_Manager.o .shobj/DTD_Manager.so: DTD_Manager.cpp \
-  DTD_Manager.h \
-  ACEXML_Export.h \
-  XML_Types.h \
-  Env.h \
-  XML_Macros.h \
-  Exception.h \
-  SAXExceptions.h \
-  Element_Def_Builder.h \
-  Validator.h \
-  Attributes.h
-.obj/Element_Def_Builder.o .obj/Element_Def_Builder.so .shobj/Element_Def_Builder.o .shobj/Element_Def_Builder.so: Element_Def_Builder.cpp \
-  ACEXML_Export.h \
-  XML_Types.h \
-  Env.h \
-  XML_Macros.h \
-  Exception.h \
-  SAXExceptions.h
-.obj/Encoding.o .obj/Encoding.so .shobj/Encoding.o .shobj/Encoding.so: Encoding.cpp \
-  Encoding.h \
-  ACEXML_Export.h \
-  XML_Types.h \
-.obj/Env.o .obj/Env.so .shobj/Env.o .shobj/Env.so: Env.cpp Env.h \
-  ACEXML_Export.h \
-  XML_Macros.h \
-  Exception.h \
-  XML_Types.h \
-  Env.i \
-.obj/Exception.o .obj/Exception.so .shobj/Exception.o .shobj/Exception.so: Exception.cpp \
-  Exception.h \
-  ACEXML_Export.h \
-  XML_Types.h \
-  XML_Macros.h \
-  Exception.i
-.obj/FileCharStream.o .obj/FileCharStream.so .shobj/FileCharStream.o .shobj/FileCharStream.so: FileCharStream.cpp \
-  FileCharStream.h \
-  ACEXML_Export.h \
-  CharStream.h \
-  XML_Types.h \
-  Encoding.h \
-  $(ACE_ROOT)/ace/OS_NS_stdio.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_stat.h
-.obj/HttpCharStream.o .obj/HttpCharStream.so .shobj/HttpCharStream.o .shobj/HttpCharStream.so: HttpCharStream.cpp \
-  HttpCharStream.h \
-  ACEXML_Export.h \
-  CharStream.h \
-  XML_Types.h \
-  URL_Addr.h \
-  $(ACE_ROOT)/ace/INET_Addr.h \
-  $(ACE_ROOT)/ace/Addr.h \
-  Mem_Map_Stream.h \
-  $(ACE_ROOT)/ace/SOCK_Stream.h \
-  $(ACE_ROOT)/ace/SOCK_IO.h \
-  $(ACE_ROOT)/ace/SOCK.h \
-  $(ACE_ROOT)/ace/IPC_SAP.h \
-  $(ACE_ROOT)/ace/IPC_SAP.i \
-  $(ACE_ROOT)/ace/SOCK.i \
-  $(ACE_ROOT)/ace/SOCK_IO.i \
-  $(ACE_ROOT)/ace/SOCK_Stream.i \
-  $(ACE_ROOT)/ace/Mem_Map.h \
-  $(ACE_ROOT)/ace/SOCK_Connector.h \
-  $(ACE_ROOT)/ace/SOCK_Connector.i \
-  $(ACE_ROOT)/ace/Connector.h \
-  $(ACE_ROOT)/ace/Service_Object.h \
-  $(ACE_ROOT)/ace/Shared_Object.h \
-  $(ACE_ROOT)/ace/Svc_Conf_Tokens.h \
-  $(ACE_ROOT)/ace/Event_Handler.h \
-  $(ACE_ROOT)/ace/Atomic_Op.h \
-  $(ACE_ROOT)/ace/Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Atomic_Op_T.h \
-  $(ACE_ROOT)/ace/Atomic_Op_T.cpp \
-  $(ACE_ROOT)/ace/Atomic_Op_T.i \
-  $(ACE_ROOT)/ace/Guard_T.h \
-  $(ACE_ROOT)/ace/Lock.h \
-  $(ACE_ROOT)/ace/Guard_T.cpp \
-  $(ACE_ROOT)/ace/Guard_T.inl \
-  $(ACE_ROOT)/ace/RW_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/RW_Mutex.h \
-  $(ACE_ROOT)/ace/Synch_Traits.h \
-  $(ACE_ROOT)/ace/DLL.h \
-  $(ACE_ROOT)/ace/os_include/os_dlfcn.h \
-  $(ACE_ROOT)/ace/Strategies_T.h \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.h \
-  $(ACE_ROOT)/ace/Functor.h \
-  $(ACE_ROOT)/ace/Functor_T.h \
-  $(ACE_ROOT)/ace/Functor_T.cpp \
-  $(ACE_ROOT)/ace/Functor_T.i \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.cpp \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.i \
-  $(ACE_ROOT)/ace/Reactor.h \
-  $(ACE_ROOT)/ace/Timer_Queuefwd.h \
-  $(ACE_ROOT)/ace/Reactor_Timer_Interface.h \
-  $(ACE_ROOT)/ace/Thread_Manager.h \
-  $(ACE_ROOT)/ace/Thread.h \
-  $(ACE_ROOT)/ace/Thread_Adapter.h \
-  $(ACE_ROOT)/ace/Thread_Exit.h \
-  $(ACE_ROOT)/ace/Thread_Control.h \
-  $(ACE_ROOT)/ace/Condition_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Free_List.h \
-  $(ACE_ROOT)/ace/Free_List.cpp \
-  $(ACE_ROOT)/ace/Free_List.i \
-  $(ACE_ROOT)/ace/Singleton.h \
-  $(ACE_ROOT)/ace/TSS_T.h \
-  $(ACE_ROOT)/ace/TSS_T.cpp \
-  $(ACE_ROOT)/ace/TSS_T.inl \
-  $(ACE_ROOT)/ace/Singleton.cpp \
-  $(ACE_ROOT)/ace/Singleton.i \
-  $(ACE_ROOT)/ace/Object_Manager.h \
-  $(ACE_ROOT)/ace/Recursive_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Static_Object_Lock.h \
-  $(ACE_ROOT)/ace/Managed_Object.h \
-  $(ACE_ROOT)/ace/Managed_Object.cpp \
-  $(ACE_ROOT)/ace/Managed_Object.i \
-  $(ACE_ROOT)/ace/Framework_Component.h \
-  $(ACE_ROOT)/ace/Framework_Component_T.h \
-  $(ACE_ROOT)/ace/Framework_Component_T.cpp \
-  $(ACE_ROOT)/ace/Framework_Component_T.inl \
-  $(ACE_ROOT)/ace/Connection_Recycling_Strategy.h \
-  $(ACE_ROOT)/ace/Recyclable.h \
-  $(ACE_ROOT)/ace/Refcountable.h \
-  $(ACE_ROOT)/ace/Hashable.h \
-  $(ACE_ROOT)/ace/Reverse_Lock_T.h \
-  $(ACE_ROOT)/ace/Reverse_Lock_T.cpp \
-  $(ACE_ROOT)/ace/Reverse_Lock_T.inl \
-  $(ACE_ROOT)/ace/OS_NS_errno.h \
-  $(ACE_ROOT)/ace/Strategies_T.i \
-  $(ACE_ROOT)/ace/Strategies_T.cpp \
-  $(ACE_ROOT)/ace/Service_Repository.h \
-  $(ACE_ROOT)/ace/Service_Types.h \
-  $(ACE_ROOT)/ace/WFMO_Reactor.h \
-  $(ACE_ROOT)/ace/Synch_Options.h \
-  $(ACE_ROOT)/ace/Handle_Set.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_select.h \
-  $(ACE_ROOT)/ace/Connector.cpp \
-  $(ACE_ROOT)/ace/Svc_Handler.h \
-  $(ACE_ROOT)/ace/Task.h \
-  $(ACE_ROOT)/ace/Task_T.h \
-  $(ACE_ROOT)/ace/Message_Queue.h \
-  $(ACE_ROOT)/ace/Message_Block.h \
-  $(ACE_ROOT)/ace/Message_Block_T.h \
-  $(ACE_ROOT)/ace/Message_Block_T.cpp \
-  $(ACE_ROOT)/ace/Message_Block_T.i \
-  $(ACE_ROOT)/ace/IO_Cntl_Msg.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.cpp \
-  $(ACE_ROOT)/ace/OS_NS_sys_time.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.i \
-  $(ACE_ROOT)/ace/Notification_Strategy.h \
-  $(ACE_ROOT)/ace/Task_T.cpp \
-  $(ACE_ROOT)/ace/Module.h \
-  $(ACE_ROOT)/ace/os_include/os_dirent.h \
-  $(ACE_ROOT)/ace/Module.cpp \
-  $(ACE_ROOT)/ace/Stream_Modules.h \
-  $(ACE_ROOT)/ace/Stream_Modules.cpp \
-  $(ACE_ROOT)/ace/Module.i \
-  $(ACE_ROOT)/ace/Null_Condition.h \
-  $(ACE_ROOT)/ace/Null_Mutex.h \
-  $(ACE_ROOT)/ace/Task_T.i \
-  $(ACE_ROOT)/ace/os_include/os_assert.h \
-  $(ACE_ROOT)/ace/Service_Config.h \
-  $(ACE_ROOT)/ace/XML_Svc_Conf.h \
-  $(ACE_ROOT)/ace/Svc_Handler.cpp \
-  $(ACE_ROOT)/ace/Dynamic.h \
-  Encoding.h
-.obj/InputSource.o .obj/InputSource.so .shobj/InputSource.o .shobj/InputSource.so: InputSource.cpp \
-  InputSource.h \
-  ACEXML_Export.h \
-  CharStream.h \
-  XML_Types.h \
-  StreamFactory.h \
-  $(ACE_ROOT)/ace/Swap.h \
-  $(ACE_ROOT)/ace/Swap.cpp \
-  $(ACE_ROOT)/ace/Swap.inl
-.obj/LocatorImpl.o .obj/LocatorImpl.so .shobj/LocatorImpl.o .shobj/LocatorImpl.so: LocatorImpl.cpp \
-  LocatorImpl.h \
-  ACEXML_Export.h \
-  Locator.h \
-  XML_Types.h \
-  LocatorImpl.i
-.obj/Mem_Map_Stream.o .obj/Mem_Map_Stream.so .shobj/Mem_Map_Stream.o .shobj/Mem_Map_Stream.so: Mem_Map_Stream.cpp \
-  $(ACE_ROOT)/ace/FILE_Addr.h \
-  ACEXML_Export.h \
-  XML_Types.h
-.obj/NamespaceSupport.o .obj/NamespaceSupport.so .shobj/NamespaceSupport.o .shobj/NamespaceSupport.so: NamespaceSupport.cpp \
-  NamespaceSupport.h \
-  ACEXML_Export.h \
-  XML_Types.h \
-  $(ACE_ROOT)/ace/Hash_Map_Manager.h \
-  NamespaceSupport.i
-.obj/SAXExceptions.o .obj/SAXExceptions.so .shobj/SAXExceptions.o .shobj/SAXExceptions.so: SAXExceptions.cpp \
-  SAXExceptions.h \
-  ACEXML_Export.h \
-  Exception.h \
-  XML_Types.h \
-  XML_Macros.h \
-  SAXExceptions.i
-.obj/StrCharStream.o .obj/StrCharStream.so .shobj/StrCharStream.o .shobj/StrCharStream.so: StrCharStream.cpp \
-  StrCharStream.h \
-  ACEXML_Export.h \
-  CharStream.h \
-  XML_Types.h \
-  Encoding.h \
-.obj/StreamFactory.o .obj/StreamFactory.so .shobj/StreamFactory.o .shobj/StreamFactory.so: StreamFactory.cpp \
-  StreamFactory.h \
-  ACEXML_Export.h \
-  XML_Types.h \
-  CharStream.h \
-  Encoding.h \
-  URL_Addr.h \
-.obj/Transcode.o .obj/Transcode.so .shobj/Transcode.o .shobj/Transcode.so: Transcode.cpp \
-  Transcode.h \
-  ACEXML_Export.h \
-  XML_Types.h \
-  Transcode.i
-.obj/URL_Addr.o .obj/URL_Addr.so .shobj/URL_Addr.o .shobj/URL_Addr.so: URL_Addr.cpp \
-  URL_Addr.h \
-  ACEXML_Export.h \
-  XML_Types.h \
-  URL_Addr.inl \
-.obj/Validator.o .obj/Validator.so .shobj/Validator.o .shobj/Validator.so: Validator.cpp \
-  Validator.h \
-  ACEXML_Export.h \
-  Attributes.h \
-  XML_Types.h \
-  Env.h \
-  XML_Macros.h \
-  Exception.h \
-  SAXExceptions.h
-.obj/XMLFilterImpl.o .obj/XMLFilterImpl.so .shobj/XMLFilterImpl.o .shobj/XMLFilterImpl.so: XMLFilterImpl.cpp \
-  XMLFilterImpl.h \
-  XMLFilter.h \
-  ACEXML_Export.h \
-  XMLReader.h \
-  Env.h \
-  XML_Macros.h \
-  Exception.h \
-  XML_Types.h \
-  SAXExceptions.h \
-  Locator.h \
-  Attributes.h \
-  DTDHandler.h \
-  InputSource.h \
-  CharStream.h \
-  ErrorHandler.h \
-  XMLFilterImpl.i
-.obj/XML_Codecs.o .obj/XML_Codecs.so .shobj/XML_Codecs.o .shobj/XML_Codecs.so: XML_Codecs.cpp \
-  XML_Codecs.h \
-  ACEXML_Export.h \
-  XML_Types.h \
-  $(ACE_ROOT)/ace/Codecs.h
-.obj/ZipCharStream.o .obj/ZipCharStream.so .shobj/ZipCharStream.o .shobj/ZipCharStream.so: ZipCharStream.cpp
-# IF YOU PUT ANYTHING HERE IT WILL GO AWAY
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Makefile.ACEXML.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Makefile.ACEXML.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Makefile.ACEXML.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,116 +0,0 @@
-# Makefile.ACEXML.bor,v 1.3 2003/12/20 14:21:14 jwillemsen Exp
-# Makefile for building the ACEXML library with Borland C++ Builder
-NAME = ACEXML
-NAME = ACEXML
-OBJFILES = \
-	$(OBJDIR)\AttributesImpl.obj \
-	$(OBJDIR)\Attributes_Def_Builder.obj \
-	$(OBJDIR)\CharStream.obj \
-	$(OBJDIR)\DTD_Manager.obj \
-	$(OBJDIR)\DefaultHandler.obj \
-	$(OBJDIR)\Element_Def_Builder.obj \
-	$(OBJDIR)\Encoding.obj \
-	$(OBJDIR)\Env.obj \
-	$(OBJDIR)\Exception.obj \
-	$(OBJDIR)\FileCharStream.obj \
-	$(OBJDIR)\HttpCharStream.obj \
-	$(OBJDIR)\InputSource.obj \
-	$(OBJDIR)\LocatorImpl.obj \
-	$(OBJDIR)\Mem_Map_Stream.obj \
-	$(OBJDIR)\NamespaceSupport.obj \
-	$(OBJDIR)\SAXExceptions.obj \
-	$(OBJDIR)\StrCharStream.obj \
-	$(OBJDIR)\StreamFactory.obj \
-	$(OBJDIR)\Transcode.obj \
-	$(OBJDIR)\URL_Addr.obj \
-	$(OBJDIR)\Validator.obj \
-	$(OBJDIR)\XMLFilterImpl.obj \
-	$(OBJDIR)\XML_Codecs.obj \
-	$(OBJDIR)\ZipCharStream.obj
-EXTERNAL_LIBS = \
-LFLAGS = \
-	-j..\..\ace\$(CONFIG_SUBDIR) -j..\..\ace \
-	-L..\..\ace\$(CONFIG_SUBDIR) -L..\..\ace \
-  -j$(CORE_BINDIR) \
-  -L$(CORE_BINDIR)
-LIBFILES = \
-	ACE$(LIB_DECORATOR).lib \
-	$(EXTERNAL_LIBS)
-!ifdef STATIC
-LIB_FLAGS = -DACE_AS_STATIC_LIBS
-DLL_FLAGS =
-!else
-LIB_FLAGS =
-DLL_FLAGS = -DACEXML_BUILD_DLL
-!endif
-CFLAGS = \
-	-I..\.. \
-	$(LIB_FLAGS) \
-	$(DLL_FLAGS)
-CPPDIR = .
-INCLUDES = \
-	ACEXML_Export.h \
-	Attributes.h \
-	CharStream.h \
-	DTDHandler.h \
-	DTD_Manager.h \
-	Encoding.h \
-	Env.h \
-	ErrorHandler.h \
-	Exception.h \
-	InputSource.h \
-	Locator.h \
-	LocatorImpl.h \
-	SAXExceptions.h \
-	StrCharStream.h \
-	StreamFactory.h \
-	Transcode.h \
-	URL_Addr.h \
-	Validator.h \
-	XMLFilter.h \
-	XMLFilterImpl.h \
-	XMLReader.h \
-	XML_Codecs.h \
-	XML_Macros.h \
-	XML_Types.h \
-	ZipCharStream.h \
-	AttributesImpl.i \
-	DefaultHandler.i \
-	Env.i \
-	Exception.i \
-	LocatorImpl.i \
-	NamespaceSupport.i \
-	SAXExceptions.i \
-	Transcode.i \
-	URL_Addr.inl \
-	XMLFilterImpl.i
-BASE_BINDIR = ..\..\bin
-!include <$(ACE_ROOT)\include\makeinclude\build_library.bor>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Makefile.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Makefile.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Makefile.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,23 +0,0 @@
-# Makefile.bor,v 1.9 2003/12/20 14:21:14 jwillemsen Exp
-#       Borland Workspace
-!include <$(ACE_ROOT)\include\makeinclude\make_flags.bor>
-all:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML.bor all
-clean:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML.bor clean
-realclean:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML.bor realclean
-install:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML.bor install
-regenerate:
-	/usr/bin/perl /build/kitty/ACE_wrappers/bin/mwc.pl -type borland ACEXML.mwc
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Mem_Map_Stream.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Mem_Map_Stream.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Mem_Map_Stream.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,277 +0,0 @@
-// Mem_Map_Stream.cpp,v 1.12 2004/01/09 00:50:35 kitty Exp
-#include "ace/FILE_Addr.h"
-ACE_RCSID(common, Mem_Map_Stream, "Mem_Map_Stream.cpp,v 1.12 2004/01/09 00:50:35 kitty Exp")
-ACEXML_Mem_Map_Stream::ACEXML_Mem_Map_Stream (void)
-  : svc_handler_ (0)
-ACE_SOCK_Stream &
-ACEXML_Mem_Map_Stream::stream (void)
-  return svc_handler_->peer ();
-ssize_t
-ACEXML_Mem_Map_Stream::send_n (const void *buf, size_t size,
-                               ACE_Time_Value *tv)
-  return svc_handler_->peer ().send_n (buf, size, 0, tv);
-int
-ACEXML_Mem_Map_Stream::eof (void) const
-  return this->get_pos_ >= this->end_of_mapping_plus1_;
-int
-ACEXML_Mem_Map_Stream::get_char (void)
-  if (this->eof () && this->grow_file_and_remap () == -1)
-    return EOF;
-  return *this->get_pos_++;
-void
-ACEXML_Mem_Map_Stream::rewind (void)
-  this->recv_pos_ = ACE_reinterpret_cast (char *, this->mem_map_.addr ());
-  this->get_pos_ = this->recv_pos_;
-  this->end_of_mapping_plus1_ = this->recv_pos_ + this->mem_map_.size ();
-int
-ACEXML_Mem_Map_Stream::peek_char (size_t offset)
-  // We may need to iterate if the size of <n> is large.
-  while (this->get_pos_ + offset >= this->end_of_mapping_plus1_)
-    if (this->grow_file_and_remap () == -1)
-      return EOF;
-  return this->get_pos_[offset];
-const char *
-ACEXML_Mem_Map_Stream::recv (void) const
-  return this->recv_pos_;
-const char *
-ACEXML_Mem_Map_Stream::recv (size_t &len)
-      len = 0;
-      return 0;
-  const char *s = this->recv_pos_;
-  this->seek (ACE_static_cast (off_t, len), SEEK_CUR);
-  len = this->get_pos_ - s;
-  return s;
-size_t
-ACEXML_Mem_Map_Stream::recv_len (void) const
-  return this->get_pos_ - this->recv_pos_;
-const char *
-ACEXML_Mem_Map_Stream::peek_str (size_t offset,
-                                 size_t size)
-  // We will iterate if the size of <offset> is large.
-  while (this->get_pos_ + (offset + size) > this->end_of_mapping_plus1_)
-      return 0;
-  return &this->get_pos_[offset];
-off_t
-ACEXML_Mem_Map_Stream::seek (off_t offset, int whence)
-  switch (whence)
-    case SEEK_SET:
-      this->get_pos_ =
-        ACE_reinterpret_cast (char *,
-                              this->mem_map_.addr ())
-        + offset;
-      break;
-    case SEEK_CUR:
-      this->get_pos_ += offset;
-      break;
-    case SEEK_END:
-      this->get_pos_ =
-        this->end_of_mapping_plus1_ + offset;
-      // @@ Not sure how to implement this (yet).
-      ACE_NOTSUP_RETURN (-1);
-      break;
-  // Make sure that the backing store will cover this.
-  while (this->get_pos_ > this->end_of_mapping_plus1_)
-      this->get_pos_ = this->end_of_mapping_plus1_;
-  this->recv_pos_ = this->get_pos_;
-  return this->recv_pos_ - ACE_reinterpret_cast (char *,
-                                                 this->mem_map_.addr ());
-Svc_Handler *
-ACEXML_Mem_Map_Stream::svc_handler (void)
-  return this->svc_handler_;
-size_t
-ACEXML_Mem_Map_Stream::available (void) const
-  return this->end_of_mapping_plus1_ - this->get_pos_;
-int
-ACEXML_Mem_Map_Stream::open (Connector *connector,
-                             const ACE_INET_Addr &addr)
-  svc_handler_ = 0;
-  // Connect to the server at <addr>. If the handler has to be
-  // connected to the server again, the Caching strategy takes care
-  // and uses the same connection.
-  if (connector->connect (svc_handler_,
-                          addr) == -1)
-                         "%p %s %d\n",
-                         "Connect failed",
-                         addr.get_host_name (),
-                         addr.get_port_number ()),
-                        -1);
-  // Create a temporary filename.
-  ACE_FILE_Addr file (ACE_sap_any_cast (ACE_FILE_Addr &));
-  // Create the temporary file via the <ACE_Mem_Map> class API.
-  if (this->mem_map_.open (file.get_path_name (),
-                           O_RDWR | O_CREAT | O_APPEND,
-                           ACE_DEFAULT_FILE_PERMS) == -1)
-                       "%p\n",
-                       "open"),
-                      -1);
-  // Make sure to unlink this right away so that if this process
-  // crashes these files will be removed automatically.
-  else if (ACE_OS::unlink (file.get_path_name ()) == -1)
-                       "%p\n",
-                       "unlink"),
-                      -1);
-  else
-    // Initialize all the position pointers to 0.
-    this->rewind ();
-  return 0;
-int
-ACEXML_Mem_Map_Stream::grow_file_and_remap (void)
-  char buf[8192];
-  // Copy the next chunk of bytes from the socket into the temporary
-  // file.
-  ssize_t bytes = 0;
-  ssize_t n = 0;
-  while (1)
-      n = this->svc_handler_->peer ().recv (buf, sizeof buf, 0, &tv);
-      if (n == -1)
-          if (errno != EWOULDBLOCK)
-              ACE_ERROR ((LM_ERROR, "%p\n", "recv"));
-              return -1;
-      bytes += n;
-      if (n == 0 && !bytes)
-        return -1;
-      else if (n == 0)
-        break;
-      else if (ACE::write_n (this->mem_map_.handle (), buf, n) != n)
-                           "%p\n",
-                           "write_n"),
-                          -1);
-//   ssize_t n = this->svc_handler_->peer ().recv (buf, sizeof buf, 0, &tv);
-//   if (n == -1)
-//       ACE_ERROR ((LM_ERROR, "%p\n", "recv"));
-//       return -1;
-//   else if (n == 0)
-//     return -1;
-//   else if (ACE::write_n (this->mem_map_.handle (), buf, n) != n)
-//         ACE_ERROR_RETURN ((LM_ERROR,
-//                            "%p\n",
-//                            "write_n"),
-//                           -1);
-  // Grow the memory-mapping to encompass the entire temporary file.
-  if (this->mem_map_.map (-1,
-                          PROT_RDWR,
-                          ACE_MAP_PRIVATE,
-                          (void*)0) == -1)
-                       "%p\n",
-                       "map"),
-                      -1);
-  // MAP_FAILED is used as a "first time in" flag.
-  if (this->recv_pos_ == MAP_FAILED)
-    + this->mem_map_.size ();
-  return 0;
-ACEXML_Mem_Map_Stream::~ACEXML_Mem_Map_Stream (void)
-  // Remove the mapping and the file.
-  this->mem_map_.remove ();
-  delete this->svc_handler_;
-#if defined (ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION)
-template class ACE_Svc_Handler<ACE_SOCK_STREAM, ACE_NULL_SYNCH>;
-template class ACE_Connector_Base <Svc_Handler>;
-template class ACE_Connector <Svc_Handler, ACE_SOCK_CONNECTOR>;
-template class ACE_NonBlocking_Connect_Handler<Svc_Handler>;
-#elif defined (ACE_HAS_TEMPLATE_INSTANTIATION_PRAGMA)
-#pragma instantiate ACE_Svc_Handler<ACE_SOCK_STREAM, ACE_NULL_SYNCH>
-#pragma instantiate ACE_Connector_Base <Svc_Handler>
-#pragma instantiate ACE_Connector <Svc_Handler, ACE_SOCK_CONNECTOR>
-#pragma instantiate ACE_NonBlocking_Connect_Handler<Svc_Handler>
-#endif /* ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Mem_Map_Stream.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Mem_Map_Stream.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Mem_Map_Stream.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,191 +0,0 @@
-/* -*- C++ -*- */
-/** @file   Mem_Map_Stream.h
- *  Mem_Map_Stream.h,v 1.8 2003/11/09 04:12:06 dhinton Exp
- *  @author Douglas C. Schmidt <schmidt at cs.wustl.edu>
- *  @author Krishnakumar B <kitty at cs.wustl.edu>
-#ifndef _ACEXML_MEM_MAP_STREAM_H
-#define _ACEXML_MEM_MAP_STREAM_H
-#include /**/ "ace/pre.h"
-#pragma once
-#include "ace/SOCK_Stream.h"
-#include "ace/Mem_Map.h"
-#include "ace/SOCK_Connector.h"
-#include "ace/Connector.h"
-#include "ace/Svc_Handler.h"
-typedef ACE_Svc_Handler<ACE_SOCK_STREAM, ACE_NULL_SYNCH> Svc_Handler;
-typedef ACE_Connector<Svc_Handler, ACE_SOCK_CONNECTOR> Connector;
- * @class ACEXML_Mem_Map_Stream Mem_Map_Stream.h "ACEXML/common/Mem_Map_Stream.h"
- * @brief Provides a memory-mapped stream abstraction to simplify parsing
- * of tokens.
- * This class makes it possible to treat an connection as a stream of
- * bytes, similar to the C library stdio streams. The contents of the
- * connection are buffered incrementally in a memory-mapped file. This
- * class maintains pointers to two positions in the stream:
- *   1. The <recv> position, which keeps track of the beginning of a
- *      token that is in the stream.
- *   2. The <get> position, which moves along character-by-character
- *      until the end of the token is reached.
- * Once a token has been located, it can be extracted from the stream by
- * calling the <recv>. The length of the token, i.e., the <recv_len>, is
- * the length in bytes between the <get> position and the <recv> position.
- * Once the token has been extracted, the <recv> and <get> positions can be
- * updated by the <seek> method.
-class ACEXML_Export ACEXML_Mem_Map_Stream
-public:
-  /// Default constructor
-  ACEXML_Mem_Map_Stream (void);
-  /// Initialize this object.
-  virtual int open (Connector *connector,
-                    const ACE_INET_Addr &);
-  /// Destructor.
-  virtual ~ACEXML_Mem_Map_Stream (void);
-  /// Returns the underlying <ACE_SOCK_Stream>.
-  ACE_SOCK_Stream &stream (void);
-   * Send <size> bytes in <buf> to the connected peer.  This is a
-   * completely unbuffered call.
-  virtual ssize_t send_n (const void *buf,
-                          size_t size,
-                          ACE_Time_Value *tv = 0);
-   * Return the next character in the stream and advance the <get>
-   * position. Returns EOF when the <get> position reaches the end of the
-   * HTTP stream.
-  virtual int get_char (void);
-   *  Returns a pointer to array of at most <len> characters starting at
-   *  the <recv> position. If the <recv> position + <len> extends past the
-   *  EOF then <len> is set to the number of characters between the <recv>
-   *  position and the EOF and both the <get> and <recv> positions are
-   *  advanced by <len>. Returns 0 if the <recv> position is at the EOF.
-  virtual const char *recv (size_t &len);
-   *  Returns a pointer to array of characters starting at the <recv>
-   *  position.
-  virtual const char *recv (void) const;
-   *  Returns the length in bytes between the <get> position and the <recv>
-   *  position.
-  virtual size_t recv_len (void) const;
-   *  Returns the no. of bytes available in the stream.
-  virtual size_t available (void) const;
-   *  Resets the <get> and <recv> positions to the beginning of the stream.
-   *  This works since all the data has been cached in the memory-mapped
-   *  backing store.
-   *  Returns the nth character <offset> from the <get> position in the
-   *  stream without advancing the <get> position. Automatically extends
-   *  the backing store if necessary. Returns EOF if <offset> is past the
-   *  end of the stream.
-  virtual int peek_char (size_t offset);
-   *  Return a pointer to an array of <size> characters starting at
-   *  <offset> characters from the <get> position in the stream without
-   *  advancing the <get> position. Automatically extends the backing store
-   *  if necessary. Returns 0 if <offset> or <offset + size> is past the
-  virtual const char *peek_str (size_t offset, size_t size);
-   *  Sets the <get> and <recv> positions as follows:
-   *    o  If <whence> is <SEEK_SET>, the positions are set to <offset>
-   *       bytes from the start of the stream.
-   *    o  If <whence> is <SEEK_CUR>, the positions are set to the
-   *       current <get> position plus <offset>.
-   *    o  If <whence> is <SEEK_END>, the positions are set to the size
-   *       of the stream plus <offset>.
-   *  If offset is greater than EOF, both <get> and <recv> are set to EOF.
-   *  Note special return value is returned to indicate this condition.
-  virtual off_t seek (off_t offset, int whence = SEEK_CUR);
-  /// Returns 1 if we're at the end of the HTTP stream, else 0.
-  virtual int eof (void) const;
-  /// Returns the underlying service handler.
-  Svc_Handler *svc_handler (void);
-private:
-   *  Grow the file by reading another chunk from the HTTP socket and
-   *  extend the mapping to cover this chunk.  Returns -1 on failure or
-   *  EOF, else 0.
-  int grow_file_and_remap (void);
-   *  Connection to peer. The granularity is at the Svc_Handler level.
-   *  The Svc_Handler has an SOCK_Stream.
-  Svc_Handler *svc_handler_;
-  /// Memory-mapped file that we're iterating over.
-  ACE_Mem_Map mem_map_;
-  /// Pointer to the address where the next <recv> method will start.
-  char *recv_pos_;
-   *  Pointer to the address where the next <get_char> method will
-   *  start.
-  char *get_pos_;
-  /// Address at the end of the file mapping.
-  char *end_of_mapping_plus1_;
-#include /**/ "ace/post.h"
-#endif /* _ACEXML_MEM_MAP_STREAM_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/NamespaceSupport.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/NamespaceSupport.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/NamespaceSupport.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,293 +0,0 @@
-// -*- C++ -*-  NamespaceSupport.cpp,v 1.11 2003/11/07 20:27:29 shuston Exp
-#include "ACEXML/common/NamespaceSupport.h"
-#include "ace/OS_NS_string.h"
-#if !defined (__ACEXML_INLINE__)
-# include "ACEXML/common/NamespaceSupport.i"
-#endif /* __ACEXML_INLINE__ */
-static const ACEXML_Char ACEXML_XMLNS_PREFIX_name[] = ACE_TEXT ("xmlns");
-const ACEXML_Char *ACEXML_NamespaceSupport::XMLNS_PREFIX = ACEXML_XMLNS_PREFIX_name;
-static const ACEXML_Char ACEXML_DEFAULT_NS_PREFIX[] = {0};
-static const ACEXML_Char ACEXML_TABOO_NS_PREFIX[] = ACE_TEXT ("xml");
-static const ACEXML_Char ACEXML_XMLNS_URI_name[] = ACE_TEXT ("http://www.w3.org/XML/1998/namespace");
-const ACEXML_Char *ACEXML_NamespaceSupport::XMLNS = ACEXML_XMLNS_URI_name;
-ACEXML_Namespace_Context_Stack::ACEXML_Namespace_Context_Stack (void)
-  : head_ (0)
-ACEXML_Namespace_Context_Stack::~ACEXML_Namespace_Context_Stack (void)
-  // Clean up stuff.
-int
-ACEXML_Namespace_Context_Stack::push (ACEXML_NS_CONTEXT *nsc)
-  struct NS_Node_T *temp = 0;
-  ACE_NEW_RETURN (temp, struct NS_Node_T, -1);
-  temp->item_ = nsc;
-  temp->next_ = this->head_;
-  this->head_ = temp;
-  return 0;
-ACEXML_NS_CONTEXT *
-ACEXML_Namespace_Context_Stack::pop (void)
-  if (this->head_ != 0)
-      struct NS_Node_T *temp = this->head_;
-      this->head_ = temp->next_;
-      ACEXML_NS_CONTEXT* retv = temp->item_;
-      delete temp;
-      return retv;
-  return 0;
-ACEXML_NamespaceSupport::ACEXML_NamespaceSupport (void)
-  : ns_stack_ (),
-    effective_context_ (0)
-int
-ACEXML_NamespaceSupport::init (void)
-  // @@ No way to tell if the new fails.
-  ACE_NEW_RETURN (effective_context_, ACEXML_NS_CONTEXT(), -1);
-  ACEXML_String prefix (ACEXML_TABOO_NS_PREFIX, 0, 0);
-  ACEXML_String uri (ACEXML_XMLNS_URI_name, 0, 0);
-  return this->effective_context_->bind (prefix, uri);
-ACEXML_NamespaceSupport::~ACEXML_NamespaceSupport (void)
-  while (this->popContext () == 0)
-int
-ACEXML_NamespaceSupport::declarePrefix (const ACEXML_Char *prefix,
-                                        const ACEXML_Char *uri)
-  if (!prefix || !uri)
-    return -1;
-  // Unless predefined by w3.org(?) NS prefix can never start with
-  // "xml".
-  if (ACE_OS::strcmp (ACEXML_TABOO_NS_PREFIX, prefix) == 0)
-    return -1;
-  ACEXML_String ns_prefix (prefix, 0, 0);
-  ACEXML_String ns_uri (uri, 0, 0);
-  return this->effective_context_->bind (ns_prefix,
-                                         ns_uri);
-int
-ACEXML_NamespaceSupport::getDeclaredPrefixes (ACEXML_STR_LIST &prefixes) const
-  ACEXML_NS_CONTEXT_ENTRY *entry;
-  // The prefix for default namespace (empty string) is included in
-  // the return list.
-  for (ACEXML_NS_CONTEXT_ITER iter (*this->effective_context_);
-       iter.next (entry) != 0;
-       iter.advance ())
-    prefixes.enqueue_tail (entry->ext_id_.c_str ());
-  return 0;
-ACEXML_NamespaceSupport::getPrefix (const ACEXML_Char *uri) const
-  if (!uri || *uri == 0)
-    return 0;
-       iter.advance ())
-    if (entry->int_id_ == ACEXML_String (uri, 0, 0) &&
-        entry->ext_id_ != ACEXML_String (ACEXML_DEFAULT_NS_PREFIX, 0, 0))
-      return entry->ext_id_.c_str ();
-  return 0;                     // Nothing found.
-int
-ACEXML_NamespaceSupport::getPrefixes (ACEXML_STR_LIST &prefixes) const
-  // The prefix for default namespace (empty string) is not included
-  // in the return list.
-       iter.advance ())
-    if (entry->ext_id_ != ACEXML_String(ACEXML_DEFAULT_NS_PREFIX, 0, 0))
-    else
-      continue;
-  return 0;
-int
-ACEXML_NamespaceSupport::getPrefixes (const ACEXML_Char *uri,
-                                      ACEXML_STR_LIST &prefixes) const
-  if (!uri)
-    return -1;
-       iter.advance ())
-    else
-      continue;
-ACEXML_NamespaceSupport::getURI (const ACEXML_Char *prefix) const
-  if (!prefix)
-    return 0;
-  if (this->effective_context_->find (ACEXML_String (prefix, 0, 0),
-                                      entry) == 0)
-    return entry->int_id_.c_str ();
-  return 0;
-int
-ACEXML_NamespaceSupport::popContext (void)
-  delete this->effective_context_;
-  if ((this->effective_context_ = this->ns_stack_.pop ()) == 0)
-    return -1;
-  return 0;
-int
-ACEXML_NamespaceSupport::pushContext (void)
-  ACEXML_NS_CONTEXT *temp = this->effective_context_;
-  ACE_NEW_RETURN (this->effective_context_,
-                  ACEXML_NS_CONTEXT (),
-                  -1);
-  // @@ Copy everything from the old context to the new one.
-  for (ACEXML_NS_CONTEXT_ITER iter (*temp);
-       iter.advance ())
-    this->effective_context_->bind (entry->ext_id_,
-                                    entry->int_id_);
-  this->ns_stack_.push (temp);
-  return 0;
-int
-ACEXML_NamespaceSupport::processName (const ACEXML_Char *qName,
-                                      const ACEXML_Char *&uri,
-                                      const ACEXML_Char *&name,
-                                      int is_attribute) const
-  int qlen = ACE_static_cast (int, ACE_OS::strlen (qName));
-  int len = -1;
-  for (int i = 0; i < qlen; ++i)
-    if (qName [i] == ':')
-        len = i;
-        break;
-  ACEXML_String prefix;
-  if (len == -1)
-      name = qName;
-  else
-      prefix.set (qName, len, 1);
-      name = qName + len + 1;
-  if (is_attribute && len == -1) {
-    uri = ACEXML_DEFAULT_NS_PREFIX;
-    return 0;
-  if (prefix != ACEXML_DEFAULT_NS_PREFIX)
-      if (this->effective_context_->find (prefix, entry) == 0)
-        uri = entry->int_id_.c_str ();
-      else
-          return -1;
-  else
-      return -1;
-  return 0;
-int
-ACEXML_NamespaceSupport::reset (void)
-  while (this->popContext() != -1)
-  return 0;
-template class ACE_Hash_Map_Entry<ACEXML_String, ACEXML_String>;
-template class ACE_Hash_Map_Manager_Ex<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>;
-template class ACE_Hash_Map_Iterator_Base_Ex<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>;
-template class ACE_Hash_Map_Iterator_Ex<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>;
-template class ACE_Hash_Map_Reverse_Iterator_Ex<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>;
-template class ACE_Unbounded_Queue<const ACEXML_Char *>;
-template class ACE_Unbounded_Queue_Iterator<const ACEXML_Char *>;
-template class ACE_Node<const ACEXML_Char *>;
-#pragma instantiate ACE_Hash_Map_Entry<ACEXML_String, ACEXML_String>
-#pragma instantiate ACE_Hash_Map_Manager_Ex<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>
-#pragma instantiate ACE_Hash_Map_Iterator_Base_Ex<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>
-#pragma instantiate ACE_Hash_Map_Iterator_Ex<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>
-#pragma instantiate ACE_Hash_Map_Reverse_Iterator_Ex<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>
-#pragma instantiate ACE_Unbounded_Queue<const ACEXML_Char *>
-#pragma instantiate ACE_Unbounded_Queue_Iterator<const ACEXML_Char *>
-#pragma instantiate ACE_Node<const ACEXML_Char *>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/NamespaceSupport.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/NamespaceSupport.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/NamespaceSupport.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,246 +0,0 @@
-// -*- C++ -*-
- *  @file    NamespaceSupport.h
- *  NamespaceSupport.h,v 1.8 2003/11/01 11:15:06 dhinton Exp
- *  @author Nanbor Wang <nanbor at cs.wustl.edu>
-#ifndef ACEXML_NAMESPACESUPPORT_H
-#define ACEXML_NAMESPACESUPPORT_H
-#pragma once
-#include "ace/Functor.h"
-#include "ace/Hash_Map_Manager.h"
-#include "ace/Containers_T.h"
-#include "ace/Null_Mutex.h"
-typedef ACE_Hash_Map_Entry<ACEXML_String,
-                           ACEXML_String> ACEXML_NS_CONTEXT_ENTRY;
-typedef ACE_Hash_Map_Manager_Ex<ACEXML_String,
-                                ACEXML_String,
-                                ACE_Hash<ACEXML_String>,
-                                ACE_Equal_To<ACEXML_String>,
-                                ACE_Null_Mutex> ACEXML_NS_CONTEXT;
-typedef ACE_Hash_Map_Iterator_Ex<ACEXML_String,
-                                 ACEXML_String,
-                                 ACE_Null_Mutex> ACEXML_NS_CONTEXT_ITER;
-typedef ACE_Hash_Map_Reverse_Iterator_Ex<ACEXML_String,
-                                         ACEXML_String,
-                                         ACE_Null_Mutex> ACEXML_NS_CONTEXT_REVERSE_ITER;
-typedef ACE_Unbounded_Queue<const ACEXML_Char *> ACEXML_STR_LIST;
- * @class ACEXML_Namespace_Context_Stack NamespaceSupport.h "ACEXML/common/NamespaceSupport.h"
- * @brief ACEXML_Namespace_Context_Stack implements a simple stack
- * that ACEXML_NamespaceSupport uses to keep track of namespace scopes.
- * @sa ACEXML_NamespaceSupport
-class ACEXML_Export ACEXML_Namespace_Context_Stack
-public:
-  /// Default constructor.
-  ACEXML_Namespace_Context_Stack (void);
-  /// Destructor.
-  ~ACEXML_Namespace_Context_Stack (void);
-  /// Push the old namespace before entering into a new namespace scope.
-  int push (ACEXML_NS_CONTEXT * old);
-  /// Pop the old namespace when exiting a namespace scope.
-  ACEXML_NS_CONTEXT *pop (void);
-private:
-  /// Internal stack structure to hold namespace context.
-  struct NS_Node_T {
-    ACEXML_NS_CONTEXT *item_;
-    struct NS_Node_T *next_;
-  /// Anchor point for head of stack.
-  NS_Node_T *head_;
- * @class ACEXML_NamespaceSupport NamespaceSupport.h "ACEXML/common/NamespaceSupport.h"
- * @brief ACEXML_NamespaceSupport provides namespace management
- * operation for an XML parser.
- * This class encapsulates the logic of Namespace processing: it
- * tracks the declarations currently in force for each context and
- * automatically processes qualified XML 1.0 names into their
- * Namespace parts; it can also be used in reverse for generating XML
- * 1.0 from Namespaces.
- * Namespace support objects are reusable, but the reset method must
- * be invoked between each session.
- * Here is a simple session (in Java :-p):
- * @code
- *  String parts[] = new String[3];
- *  NamespaceSupport support = new NamespaceSupport();
- *  support.pushContext();
- *  support.declarePrefix("", "http://www.w3.org/1999/xhtml");
- *  support.declarePrefix("dc", "http://www.purl.org/dc#");
- *  String parts[] = support.processName("p", parts, false);
- *  System.out.println("Namespace URI: " + parts[0]);
- *  System.out.println("Local name: " + parts[1]);
- *  System.out.println("Raw name: " + parts[2]);
- *  String parts[] = support.processName("dc:title", parts, false);
- *  support.popContext();
- * @endcode
- * Note that this class is optimized for the use case where most
- * elements do not contain Namespace declarations: if the same
- * prefix/URI mapping is repeated for each context (for example), this
- * class will be somewhat less efficient.
- * @sa ACEXML_Exception
-class ACEXML_Export ACEXML_NamespaceSupport
-public:
-  ACEXML_NamespaceSupport (void);
-  ~ACEXML_NamespaceSupport (void);
-   *  Initialize the namespace support object
-  int init(void);
-   * XMLNS default prefix and URI strings.
-  static const ACEXML_Char *XMLNS_PREFIX;
-  static const ACEXML_Char *XMLNS;
-   * Declare a Namespace prefix.  Return -1 if the prefix was illegal
-   * or an internal error occured.  Return 0 if the prefix gets declared
-   * successfully, 1 if the prefix replaces an existing prefix definition.
-  int declarePrefix (const ACEXML_Char *prefix,
-                     const ACEXML_Char *uri);
-   * Return all prefixes declared in current context in
-   * the user-supplied list @a prefixes.  It is user's reponsibility
-   * to ensure the list was empty originally.
-  int getDeclaredPrefixes (ACEXML_STR_LIST &prefixes) const;
-   * Return one of the prefixes mapped to a Namespace URI.
-  const ACEXML_Char *getPrefix (const ACEXML_Char *uri) const;
-   * Return all prefixes currently declared in the user-supplied list.
-   * @@ Known bug: This function should only return user-defined prefixes.
-  int getPrefixes (ACEXML_STR_LIST &prefixes) const;
-   * Return all prefixes currently declared for a URI in the
-   * user-supplied list.
-  int getPrefixes (const ACEXML_Char *uri,
-                   ACEXML_STR_LIST &prefixes) const;
-   * Look up a prefix and get the currently-mapped Namespace URI.
-  const ACEXML_Char *getURI (const ACEXML_Char *prefix) const;
-   * Revert to the previous namespace context.
-  int popContext (void);
-   * Process a raw XML 1.0 name.
-   * @a qName is the raw XML name we want to parse,
-   * @a uri contains the URI string of the raw name.  It points to a null
-   *    string if the namespace is not valid or there's no namespace defined.
-   * @a name contains the original name without the prefix.
-   * @a is_attribute specifies whether the name is an attribute or not.
-   *    Attributes have different scoping rules from elements.
-  int processName (const ACEXML_Char *qName,
-                   int is_attribute) const;
-   * Start a new Namespace context.  Prefixes defined in previous
-   * context are copied over to the new context.
-  int pushContext (void);
-   * Reset this Namespace support object for reuse.
-  int reset (void);
-private:
-   * Namespace Context stack.  When we entering a new namespace
-   * context, the old context is duplicated and pushed into
-   * this stack.
-  ACEXML_Namespace_Context_Stack ns_stack_;
-   * The effective namespace context.
-  ACEXML_NS_CONTEXT *effective_context_;
-#if defined (__ACEXML_INLINE__)
-#endif /* ACEXML_NAMESPACESUPPORT_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/NamespaceSupport.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/NamespaceSupport.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/NamespaceSupport.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,18 +0,0 @@
-// -*- C++ -*-  NamespaceSupport.i,v 1.4 2003/06/24 16:34:54 dhinton Exp
-#include "ace/ACE.h"
-ACE_TEMPLATE_SPECIALIZATION
-ACEXML_INLINE int
-ACE_Equal_To<ACEXML_String>::operator () (const ACEXML_String &lhs,
-                                          const ACEXML_String &rhs) const
-  return lhs == rhs;
-ACE_INLINE u_long
-ACE_Hash<ACEXML_String>::operator () (const ACEXML_String &t) const
-  return ACE::hash_pjw (t.c_str ());
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/SAXExceptions.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/SAXExceptions.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/SAXExceptions.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,256 +0,0 @@
-// -*- C++ -*- SAXExceptions.cpp,v 1.9 2003/11/07 20:27:29 shuston Exp
-#include "ACEXML/common/SAXExceptions.h"
-#include "ace/Log_Msg.h"
-static const ACEXML_Char ACEXML_SAXException_name[] = {
-  'A', 'C', 'E', 'X', 'M', 'L', '_',
-  'S', 'A', 'X',
-  'E', 'x', 'c', 'e', 'p', 't', 'i', 'o', 'n', 0};
-const ACEXML_Char *ACEXML_SAXException::exception_name_ = ACEXML_SAXException_name;
-static const ACEXML_Char ACEXML_SAXNotSupportedException_name[] = {
-  'S', 'A', 'X',
-  'N', 'o', 't',
-  'S', 'u', 'p', 'p', 'o', 'r', 't', 'e', 'd',
-const ACEXML_Char *ACEXML_SAXNotSupportedException::exception_name_ = ACEXML_SAXNotSupportedException_name;
-static const ACEXML_Char ACEXML_SAXNotRecognizedException_name[] = {
-  'S', 'A', 'X',
-  'N', 'o', 't',
-  'R', 'e', 'c', 'o', 'g', 'n', 'i', 'z', 'e', 'd',
-const ACEXML_Char *ACEXML_SAXNotRecognizedException::exception_name_ = ACEXML_SAXNotRecognizedException_name;
-static const ACEXML_Char ACEXML_SAXParseException_name[] = {
-  'S', 'A', 'X',
-  'P', 'a', 'r', 's', 'e',
-const ACEXML_Char *ACEXML_SAXParseException::exception_name_ = ACEXML_SAXParseException_name;
-# include "ACEXML/common/SAXExceptions.i"
-ACEXML_SAXException::ACEXML_SAXException (void)
-  : message_ (0)
-ACEXML_SAXException::ACEXML_SAXException (const ACEXML_Char *msg)
-  : message_ (ACE::strnew (msg))
-ACEXML_SAXException::ACEXML_SAXException (const ACEXML_SAXException &ex)
-  : ACEXML_Exception (ex),
-    message_ (ACE::strnew (ex.message_))
-ACEXML_SAXException&
-ACEXML_SAXException::operator= (const ACEXML_SAXException& src)
-  ACEXML_SAXException temp (src);
-  ACEXML_Char* message = this->message_;
-  this->exception_name_ = temp.exception_name_;
-  this->message_ = temp.message_;
-  temp.message_ = message;
-  return *this;
-ACEXML_SAXException*
-ACEXML_SAXException::_downcast (ACEXML_Exception* ex)
-  if (ex->is_a (ACE_TEXT ("ACEXML_SAXException")))
-    return ACE_dynamic_cast (ACEXML_SAXException*, ex);
-  return 0;
-ACEXML_SAXException::~ACEXML_SAXException (void)
-  delete[] this->message_;
-ACEXML_Exception *
-ACEXML_SAXException::duplicate (void) const
-  ACEXML_Exception *tmp;
-  ACE_NEW_RETURN (tmp, ACEXML_SAXException (*this), 0);
-  return tmp;
-int
-ACEXML_SAXException::is_a (const ACEXML_Char *name)
-  if (name == ACEXML_SAXException::exception_name_
-      || ACE_OS::strcmp (ACEXML_Exception::exception_name_,
-                         name) == 0)
-    return 1;
-  else
-    return this->ACEXML_Exception::is_a (name);
-  ACE_NOTREACHED (return 0;)
-void
-ACEXML_SAXException::print (void)
-              ACE_TEXT ("ACEXML: (%P|%t) %s: %s\n"),
-              this->exception_name_, this->message()));
-ACEXML_SAXNotSupportedException::ACEXML_SAXNotSupportedException (void)
-ACEXML_SAXNotSupportedException::ACEXML_SAXNotSupportedException (const ACEXML_SAXNotSupportedException &ex)
-  : ACEXML_SAXException (ex)
-ACEXML_SAXNotSupportedException::ACEXML_SAXNotSupportedException (const ACEXML_Char* msg)
-  : ACEXML_SAXException (msg)
-ACEXML_SAXNotSupportedException::~ACEXML_SAXNotSupportedException (void)
-ACEXML_Exception *
-ACEXML_SAXNotSupportedException::duplicate (void) const
-  ACE_NEW_RETURN (tmp, ACEXML_SAXNotSupportedException (*this), 0);
-  return tmp;
-int
-ACEXML_SAXNotSupportedException::is_a (const ACEXML_Char *name)
-  if (name == ACEXML_SAXNotSupportedException::exception_name_
-                         name) == 0)
-    return 1;
-  else
-    return this->ACEXML_SAXException::is_a (name);
-void
-ACEXML_SAXNotSupportedException::print (void)
-  ACE_DEBUG ((LM_ERROR,
-ACEXML_SAXNotRecognizedException::ACEXML_SAXNotRecognizedException (void)
-ACEXML_SAXNotRecognizedException::ACEXML_SAXNotRecognizedException (const ACEXML_Char *msg)
-ACEXML_SAXNotRecognizedException::ACEXML_SAXNotRecognizedException (const ACEXML_SAXNotRecognizedException &ex)
-ACEXML_SAXNotRecognizedException::~ACEXML_SAXNotRecognizedException (void)
-ACEXML_Exception *
-ACEXML_SAXNotRecognizedException::duplicate (void) const
-  ACE_NEW_RETURN (tmp, ACEXML_SAXNotRecognizedException (*this), 0);
-  return tmp;
-int
-ACEXML_SAXNotRecognizedException::is_a (const ACEXML_Char *name)
-  if (name == ACEXML_SAXNotRecognizedException::exception_name_
-                         name) == 0)
-    return 1;
-  else
-void
-ACEXML_SAXNotRecognizedException::print (void)
-ACEXML_SAXParseException::ACEXML_SAXParseException (void)
-ACEXML_SAXParseException::ACEXML_SAXParseException (const ACEXML_Char *msg)
-ACEXML_SAXParseException::ACEXML_SAXParseException (const ACEXML_SAXParseException &ex)
-ACEXML_SAXParseException::~ACEXML_SAXParseException (void)
-ACEXML_Exception *
-ACEXML_SAXParseException::duplicate (void) const
-  ACE_NEW_RETURN (tmp, ACEXML_SAXParseException (*this), 0);
-  return tmp;
-int
-ACEXML_SAXParseException::is_a (const ACEXML_Char *name)
-  if (name == ACEXML_SAXParseException::exception_name_
-                         name) == 0)
-    return 1;
-  else
-void
-ACEXML_SAXParseException::print (void)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/SAXExceptions.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/SAXExceptions.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/SAXExceptions.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,198 +0,0 @@
-// -*- C++ -*-
- *  @file    SAXExceptions.h
- *  SAXExceptions.h,v 1.7 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_SAXEXCEPTIONS_H_
-#define _ACEXML_SAXEXCEPTIONS_H_
-#include "ACEXML/common/ACEXML_Export.h"
-#if !defined (ACE_LACKS_PRAGMA_ONCE)
-#pragma once
-#endif /* ACE_LACKS_PRAGMA_ONCE */
-#include "ACEXML/common/Exception.h"
- * @class ACEXML_SAXException SAXExceptions.h "ACEXML/common/SAXExceptions.h"
- * @brief ACEXML_SAXException
- * ACEXML_SAXException is the mother of all SAX related exceptions.
-class ACEXML_Export ACEXML_SAXException : public ACEXML_Exception
-public:
-  ACEXML_SAXException (void);
-  /// Constructor initializing the exception message.
-  ACEXML_SAXException (const ACEXML_Char *msg);
-  /// Assignment operator
-  ACEXML_SAXException& operator= (const ACEXML_SAXException& src);
-  /// Copy constructor.
-  ACEXML_SAXException (const ACEXML_SAXException &ex);
-  /// Destructor.
-  virtual ~ACEXML_SAXException (void);
-  /// Throw the exception.
-  virtual void _raise (void);
-  /// Static narrow operation.
-  static ACEXML_SAXException* _downcast (ACEXML_Exception* ex);
-  /// Return the name of the exception.
-  virtual const ACEXML_Char *id (void) const;
-  /// Return the extra message accompanying the exception.
-  const ACEXML_Char *message (void);
-  virtual ACEXML_Exception *duplicate (void) const;
-  virtual int is_a (const ACEXML_Char *name);
-  virtual void print (void);
-protected:
-  static const ACEXML_Char *exception_name_;
-  /// A message providing more information about the exception being thrown.
-  ACEXML_Char *message_;
- * @class ACEXML_SAXNotSupportedException SAXExceptions.h "ACEXML/common/SAXExceptions.h"
- * @brief ACEXML_SAXNotSupportedException
-class ACEXML_Export ACEXML_SAXNotSupportedException
-  : public ACEXML_SAXException
-public:
-  ACEXML_SAXNotSupportedException (void);
-  ACEXML_SAXNotSupportedException (const ACEXML_SAXNotSupportedException &ex);
-  /// Constructor which accepts an informational message
-  ACEXML_SAXNotSupportedException (const ACEXML_Char* msg);
-  /// Destructor.
-  virtual ~ACEXML_SAXNotSupportedException (void);
-  static ACEXML_SAXNotSupportedException* _downcast (ACEXML_Exception* ex);
-protected:
- * @class ACEXML_SAXNotRecognizedException SAXExceptions.h "ACEXML/common/SAXExceptions.h"
- * @brief ACEXML_SAXNotRecognizedException
-class ACEXML_Export ACEXML_SAXNotRecognizedException
-public:
-  ACEXML_SAXNotRecognizedException (void);
-  /// Constructor with an initializing exception message.
-  ACEXML_SAXNotRecognizedException (const ACEXML_Char *msg);
-  ACEXML_SAXNotRecognizedException (const ACEXML_SAXNotRecognizedException &ex);
-  /// Destructor.
-  virtual ~ACEXML_SAXNotRecognizedException (void);
-  static ACEXML_SAXNotRecognizedException* _downcast (ACEXML_Exception* ex);
-protected:
- * @class ACEXML_SAXParseException SAXExceptions.h "ACEXML/common/SAXExceptions.h"
- * @brief ACEXML_SAXParseException
-class ACEXML_Export ACEXML_SAXParseException
-public:
-  ACEXML_SAXParseException (void);
-  ACEXML_SAXParseException (const ACEXML_Char *msg);
-  ACEXML_SAXParseException (const ACEXML_SAXParseException &ex);
-  /// Destructor.
-  virtual ~ACEXML_SAXParseException (void);
-  static ACEXML_SAXParseException* _downcast (ACEXML_Exception* ex);
-protected:
-#endif /* _ACEXML_SAXEXCEPTIONS_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/SAXExceptions.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/SAXExceptions.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/SAXExceptions.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,57 +0,0 @@
-// -*- C++ -*- SAXExceptions.i,v 1.3 2002/10/13 03:58:57 kitty Exp
-ACEXML_SAXException::message (void)
-  return (this->message_ == 0 ?
-          ACEXML_Exception::null_ :
-          this->message_);
-ACEXML_INLINE void
-ACEXML_SAXException::_raise (void)
-  ACEXML_RAISE (*this);
-ACEXML_INLINE void
-ACEXML_SAXNotSupportedException::_raise (void)
-ACEXML_INLINE void
-ACEXML_SAXNotRecognizedException::_raise (void)
-ACEXML_INLINE void
-ACEXML_SAXParseException::_raise (void)
-ACEXML_SAXException::id (void) const
-  return ACEXML_SAXException::exception_name_;
-ACEXML_SAXNotSupportedException::id (void) const
-  return ACEXML_SAXNotSupportedException::exception_name_;
-ACEXML_SAXNotRecognizedException::id (void) const
-  return ACEXML_SAXNotRecognizedException::exception_name_;
-ACEXML_SAXParseException::id (void) const
-  return ACEXML_SAXParseException::exception_name_;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/StrCharStream.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/StrCharStream.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/StrCharStream.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,129 +0,0 @@
-// StrCharStream.cpp,v 1.11 2004/01/09 00:50:35 kitty Exp
-#include "ACEXML/common/StrCharStream.h"
-#include "ACEXML/common/Encoding.h"
-ACEXML_StrCharStream::ACEXML_StrCharStream (void)
-  : start_ (0), ptr_ (0), end_ (0), encoding_ (0), name_ (0)
-ACEXML_StrCharStream::~ACEXML_StrCharStream (void)
-  this->close();
-int
-ACEXML_StrCharStream::open (const ACEXML_Char *str, const ACEXML_Char* name)
-  if (str != 0 && name != 0
-      && (this->start_ = ACE::strnew (str)) != 0
-      && (this->name_ = ACE::strnew (name)) != 0)
-      this->ptr_ = this->start_;
-      this->end_ = this->start_ + ACE_OS::strlen (this->start_);
-      return this->determine_encoding();
-  return -1;                // Invalid string passed.
-int
-ACEXML_StrCharStream::available (void)
-  if (this->start_ != 0)
-    return (this->end_ - this->start_); // @@ Will this work on all platforms?
-  return -1;
-int
-ACEXML_StrCharStream::close (void)
-  delete[] this->start_;
-  delete[] this->encoding_;
-  this->encoding_ = 0;
-  delete[] this->name_;
-  this->name_ = 0;
-  this->start_ = this->ptr_ = this->end_ = 0;
-  return 0;
-int
-ACEXML_StrCharStream::determine_encoding (void)
-  if (this->start_ == 0)
-    return -1;
-  char input[4] = {0,0,0,0};
-  char* sptr  = (char*)this->start_;
-  int i = 0;
-  for ( ; i < 4 && sptr != (char*)this->end_; ++sptr, ++i)
-    input[i] = *sptr;
-  const ACEXML_Char* temp = ACEXML_Encoding::get_encoding (input);
-  if (!temp)
-    return -1;
-  else
-      if (this->encoding_)
-        delete [] this->encoding_;
-      this->encoding_ = ACE::strnew (temp);
-      // ACE_DEBUG ((LM_DEBUG, "String's encoding is %s\n", this->encoding_));
-  return 0;
-void
-ACEXML_StrCharStream::rewind (void)
-  this->determine_encoding();
-int
-ACEXML_StrCharStream::get (ACEXML_Char& ch)
-  if (this->start_ != 0 && this->ptr_ != this->end_)
-      ch = *this->ptr_++;
-      return 0;
-  return -1;
-int
-ACEXML_StrCharStream::read (ACEXML_Char *str, size_t len)
-      this->ptr_ != this->end_)
-      if (len * sizeof (ACEXML_Char) > (size_t) (this->end_ - this->ptr_))
-        len = this->end_ - this->ptr_;
-      ACE_OS::strncpy (str, this->ptr_, len);
-      this->ptr_ += len;
-      return ACE_static_cast (int, len);
-  return 0;
-int
-ACEXML_StrCharStream::peek (void)
-    return *this->ptr_;
-  return -1;
-const ACEXML_Char*
-ACEXML_StrCharStream::getEncoding (void)
-  return this->encoding_;
-const ACEXML_Char*
-ACEXML_StrCharStream::getSystemId(void)
-  return this->name_;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/StrCharStream.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/StrCharStream.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/StrCharStream.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,102 +0,0 @@
-// -*- C++ -*-
- *  @file    StrCharStream.h
- *  StrCharStream.h,v 1.7 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_STRCHARSTREAM_H_
-#define _ACEXML_STRCHARSTREAM_H_
-#pragma once
-#include "ACEXML/common/CharStream.h"
- * @class ACEXML_StrCharStream StrCharStream.h "common/StrCharStream.h"
- * An implementation of ACEXML_CharStream for reading
- * input from a null-terminated ACEXML_Char string.
-class ACEXML_Export ACEXML_StrCharStream : public ACEXML_CharStream
-public:
-  ACEXML_StrCharStream (void);
-  /// Destructor
-  virtual ~ACEXML_StrCharStream (void);
-  /// Initializing StrCharStream with @a str and @a name
-  int open (const ACEXML_Char *str, const ACEXML_Char* name);
-   * Returns the available ACEXML_Char in the buffer.  -1
-   * if the object is not initialized properly.
-  virtual int available (void);
-   * Close this stream and release all resources used by it.
-  virtual int close (void);
-   *  Determine the encoding of the file.
-  virtual int determine_encoding (void);
-   * Read the next ACEXML_Char.  Return -1 if we are not able to
-   * return an ACEXML_Char, 0 if EOS is reached, or 1 if succeed.
-  virtual int get (ACEXML_Char& ch);
-   * Read the next batch of ACEXML_Char strings
-  virtual int read (ACEXML_Char *str, size_t len);
-   * Peek the next ACEXML_Char in the CharStream.  Return the
-   * character if succeess, -1 if EOS is reached.
-  virtual int peek (void);
-   * Get the character encoding for a byte stream or URI.
-  virtual const ACEXML_Char *getEncoding (void);
-   * Get the systemId for the underlying CharStream
-  virtual const ACEXML_Char* getSystemId (void);
-   *  Resets the pointer to the beginning of the stream.
-  virtual void rewind (void);
-private:
-  ACEXML_Char *start_;
-  ACEXML_Char *ptr_;
-  ACEXML_Char *end_;
-  ACEXML_Char* encoding_;
-  ACEXML_Char* name_;
-#endif /* _ACEXML_STRCHARSTREAM_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/StreamFactory.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/StreamFactory.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/StreamFactory.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,56 +0,0 @@
-// StreamFactory.cpp,v 1.4 2003/11/07 20:27:29 shuston Exp
-#include "ACEXML/common/StreamFactory.h"
-#include "ACEXML/common/FileCharStream.h"
-#include "ACEXML/common/HttpCharStream.h"
-#ifdef ACEXML_HAS_ZZIPLIB
-#include "ACEXML/common/ZipCharStream.h"
-#endif /* ACEXML_HAS_ZZIPLIB */
-ACE_RCSID (common, StreamFactory, "StreamFactory.cpp,v 1.4 2003/11/07 20:27:29 shuston Exp")
-ACEXML_CharStream*
-ACEXML_StreamFactory::create_stream (const ACEXML_Char* uri)
-  if (uri == 0)
-    return 0;
-  ACEXML_FileCharStream* fstream = 0;
-  ACEXML_HttpCharStream* hstream = 0;
-  if (ACE_OS::strstr (uri, ACE_TEXT("ftp://")) != 0)
-      return 0;
-  else if (ACE_OS::strstr (uri, ACE_TEXT ("http://")) != 0)
-      ACE_NEW_RETURN (hstream, ACEXML_HttpCharStream, 0);
-      if (hstream->open (uri) != -1)
-        return hstream;
-  else
-      if (ACE_OS::strstr (uri, ACE_TEXT ("file://")) != 0)
-        uri += 7; // Skip over file://
-      ACE_NEW_RETURN (fstream, ACEXML_FileCharStream, 0);
-      if (fstream->open (uri) != -1)
-        return fstream;
-      else
-          ACEXML_ZipCharStream* zstream = 0;
-          ACE_NEW_RETURN (zstream, ACEXML_ZipCharStream, 0);
-          if (zstream->open (uri) != -1)
-            return zstream;
-  return 0;
-ACEXML_StreamFactory::~ACEXML_StreamFactory ()
-  // No op
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/StreamFactory.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/StreamFactory.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/StreamFactory.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,58 +0,0 @@
- *  @file StreamFactory.h
- *  StreamFactory.h,v 1.2 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_STREAM_FACTORY_H
-#define _ACEXML_STREAM_FACTORY_H
-#pragma once
-#include "ACEXML/common/XML_Types.h"
-// Forward declarations
-class ACEXML_CharStream;
- *  @class ACEXML_StreamFactory StreamFactory.h "ACEXML/common/ACEXML_StreamFactory.h"
- *  @brief A generic factory used to create an appropriate @sa
- *  ACEXML_CharStream from a SYSTEM id. This class creates a @sa
- *  ACEXML_FileCharStream or a @sa ACEXML_HttpCharStream depending on the
- *  URI supplied.
- *  @todo Write a stream abstraction for handling ftp:// type URIs and add
- *  a function to create and return such streams. That is the only chunk
- *  missing in the armour.
-class ACEXML_Export ACEXML_StreamFactory
-public:
-  // Destructor
-  virtual ~ACEXML_StreamFactory (void);
-   *  Create the appropriate stream from the @a uri passed and return the
-   *  stream. The caller is responsible for deallocating the returned
-   *  stream.
-   *  @param uri SYSTEM id or a stream of characters (in the case of a
-   *  StrCharStream).
-  virtual ACEXML_CharStream* create_stream (const ACEXML_Char* uri);
-#endif /* _ACEXML_STREAM_FACTORY_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Transcode.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Transcode.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Transcode.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,317 +0,0 @@
-// -*- C++ -*-  Transcode.cpp,v 1.7 2003/12/18 19:17:13 kitty Exp
-#include "ACEXML/common/Transcode.h"
-# include "ACEXML/common/Transcode.i"
-int
-ACEXML_Transcoder::utf162utf8 (ACEXML_UTF16 src,
-                               ACEXML_UTF8 *dst,
-                               size_t len)
-  // Check for valid argument first...
-  if (dst == 0)
-    return ACEXML_INVALID_ARGS;
-  if (src < 0x80)
-      if (len < 1)
-        return ACEXML_DESTINATION_TOO_SHORT;
-      *dst = ACE_static_cast (ACEXML_UTF8, src);
-      return 1;
-  else if (src < 0x800)
-      if (len < 2)
-      *dst = 0xc0 | (src / 0x40);
-      *(dst+1) = 0x80 | (src % 0x40);
-      return 2;
-  else
-      if (len < 3)
-      // Surrogates (0xD800 - 0xDFFF) are not valid unicode values
-      if (src >= 0xD800 && src < 0xE000)
-        return ACEXML_IS_SURROGATE;
-      *dst = 0xe0 | (src / 0x1000);
-      *(dst+1) = 0x80 | ((src % 0x1000) / 0x40);
-      *(dst+2) = 0x80 | (src % 0x40);
-      return 3;
-  ACE_NOTREACHED (return ACEXML_NON_UNICODE;)
-int
-ACEXML_Transcoder::ucs42utf8 (ACEXML_UCS4 src,
-                              ACEXML_UTF8 *dst,
-                              size_t len)
-  if (src < 0x10000)
-      int retv = ACEXML_Transcoder::utf162utf8
-                 (ACE_static_cast (ACEXML_UTF16, src),
-                  dst, len);
-      return (retv == ACEXML_IS_SURROGATE ? ACEXML_NON_UNICODE : retv);
-  else if (src >= 0x100000 && src < 0x110000)
-      if (len < 4)
-      if (dst == 0)
-      *dst = 0xf0 | (src / 0x40000);
-      *(dst+1) = 0x80 | ((src % 0x40000) / 0x1000);
-      *(dst+2) = 0x80 | ((src % 0x1000) / 0x40);
-      *(dst+3) = 0x80 | (src % 0x40);
-      return 4;
-  return ACEXML_NON_UNICODE;
-int
-ACEXML_Transcoder::ucs42utf16 (ACEXML_UCS4 src,
-                               ACEXML_UTF16 *dst,
-                               size_t len)
-  if (dst == 0)
-      if (len < 1)
-        return ACEXML_NON_UNICODE;     // Surrogates are not valid unicode value
-      *dst = ACE_static_cast (ACEXML_UTF16, src);
-      return 1;
-    // Scalar values are encoded into surrogates
-      if (len < 2)
-      *dst = 0xD800 | (src / 0x400);
-      *(dst+1) = 0xDC00 | (src % 0x400);
-      return 2;
-int
-ACEXML_Transcoder::surrogate2utf8 (ACEXML_UTF16 high,
-                                   ACEXML_UTF16 low,
-                                   ACEXML_UTF8 *dst,
-                                   size_t len)
-  if (len < 3)
-  if (dst == 0 ||
-      (high >= 0xD800 && high < 0xDC00) ||
-      (low >= 0xDC00 && low < 0xE000))
-  ACEXML_UCS4 src = (high - 0xD800) * 0x400 + (low - 0xDC00) + 0x10000;
-  return 2;
-int
-ACEXML_Transcoder::surrogate2ucs4 (ACEXML_UTF16 high,
-                                   ACEXML_UTF16 low,
-                                   ACEXML_UCS4 &dst)
-  if ((high >= 0xD800 && high < 0xDC00) ||
-  dst = (high - 0xD800) * 0x400 + (low - 0xDC00) + 0x10000;
-  return ACEXML_SUCCESS;
-int
-ACEXML_Transcoder::utf82ucs4 (const ACEXML_UTF8 *the_src,
-                              size_t len,
-                              ACEXML_UCS4 &dst)
-  if (the_src == 0)
-  const unsigned char *src = ACE_reinterpret_cast (const unsigned char *,
-                                                   the_src);
-  size_t forward = 1;
-  if (forward > len)
-    return ACEXML_END_OF_SOURCE;
-  if (ACE_static_cast (unsigned char, *src) < 0x80)
-    dst = *src;
-  else if ((*src & 0xE0) == 0xC0)
-      dst = (*(src++) & 0x1f) * 0x40;
-      if (++forward > len)
-      if ((*src & 0xC0) != 0x80)
-        return ACEXML_NON_UNICODE;     // Error transcoding unicode scalar
-      dst += *src & 0x3f;
-  else if ((*src & 0xF0) == 0xE0)
-      dst = (*src++ & 0x0f) * 0x40;
-      dst = (dst + (*src++ & 0x3f)) * 0x40;
-  else if ((*src & 0xF8) == 0xF0)
-  else
-  return forward;
-int
-ACEXML_Transcoder::utf162ucs4 (const ACEXML_UTF16 *src,
-                               size_t len,
-                               ACEXML_UCS4 &dst)
-  if (src == 0)
-  if (*src >= 0xDC00 && *src < 0xE000)
-      if (len < 2)
-      return ACEXML_Transcoder::surrogate2ucs4 (*src,
-                                                *(src+1),
-                                                dst);
-  else
-      if (len < 1)
-      dst = *src;
-  return forward;
-int
-ACEXML_Transcoder::utf8s2utf16s (const ACEXML_UTF8 *src,
-                                size_t len)
-  if (src == 0 || dst == 0)
-  size_t src_len = ACE_OS::strlen (src) + 1;
-  size_t total_len = 0;
-  int forward;
-  ACEXML_UCS4 temp;
-  while (src_len > 0)
-      if ((forward = ACEXML_Transcoder::utf82ucs4 (src,
-                                                   src_len,
-                                                   temp)) <= 0)
-        return forward;
-      src += forward;
-      src_len -= forward;
-      if ((forward = ACEXML_Transcoder::ucs42utf16 (temp,
-                                                    dst,
-                                                    len)) <= 0)
-        return forward;
-      total_len += forward;
-      dst += forward;
-      len -= forward;
-  return ACE_static_cast (int, total_len);
-int
-ACEXML_Transcoder::utf16s2utf8s (const ACEXML_UTF16 *src,
-                                ACEXML_UTF8 *dst,
-                                size_t len)
-  size_t src_len = 1;
-  for (const ACEXML_UTF16 *p = src; *p++ != 0; ++src_len)
-  int forward;
-  ACEXML_UCS4 temp;
-      if ((forward = ACEXML_Transcoder::utf162ucs4 (src,
-                                                    src_len,
-                                                    temp)) <= 0)
-        return forward;
-      src += forward;
-      if ((forward = ACEXML_Transcoder::ucs42utf8 (temp,
-                                                   dst,
-                                                   len)) <= 0)
-        return forward;
-      dst += forward;
-      len -= forward;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Transcode.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Transcode.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Transcode.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,176 +0,0 @@
-// -*- C++ -*-
- *  @file    Transcode.h
- * This file declares functions to convert char string among different
- * unicode encoding (utf8, utf16, utf32)
- *  Transcode.h,v 1.9 2003/12/18 19:17:13 kitty Exp
-#ifndef _ACEXML_TRANSCODE_H_
-#define _ACEXML_TRANSCODE_H_
-#pragma once
- * @class ACEXML_Transcoder Transcode.h "ACEXML/common/Transcode.h"
- * @brief ACEXML_Transcoder
- * Wrapper class for performing transcoding among different UNICODE
- * encoding.
-class ACEXML_Export ACEXML_Transcoder
-public:
-   * Status of the conversion function.
-  enum
-    ACEXML_SUCCESS = 0,
-    ACEXML_DESTINATION_TOO_SHORT = -1,
-    ACEXML_END_OF_SOURCE = -2,
-    ACEXML_INVALID_ARGS = -3,
-    ACEXML_IS_SURROGATE = -4,
-    ACEXML_NON_UNICODE = -5
-  } STATUS;
-  // The following functions translate a unicode characters
-  // into different encoding.  Return number of characters put into
-  // destination or consumed from src if success without
-  // error, otherwise, return corresponding error code.
-   * Convert a UTF-16 character into a string in UTF-8 encoding.
-   * @return number of characters the function uses to store the
-   *         converted string if it succeeds or one of the error STATUS
-   *         otherwise.
-  static int utf162utf8 (ACEXML_UTF16 src,
-                         ACEXML_UTF8 *dst,
-                         size_t len);
-   * Convert a UCS-4 character into a string in UTF-8 encoding.
-   *         otherwise.
-  static int ucs42utf8 (ACEXML_UCS4 src,
-                        ACEXML_UTF8 *dst,
-                        size_t len);
-   * Convert a UCS-4 character into a string in UTF-16 encoding.
-   *         otherwise.
-  static int ucs42utf16 (ACEXML_UCS4 src,
-                         size_t len);
-   * Convert a UTF-16 surrogate character pair into a string in UTF-8 encoding.
-   *         otherwise.
-  static int surrogate2utf8 (ACEXML_UTF16 high,
-                             ACEXML_UTF16 low,
-                             ACEXML_UTF8 *dst,
-                             size_t len);
-   * Convert a UTF-16 surrogate character pair into a UCS-4 character.
-   * @return SUCCESS if it succeeds or one of the error STATUS
-   *         otherwise.
-  static int surrogate2ucs4 (ACEXML_UTF16 high,
-                             ACEXML_UTF16 low,
-                             ACEXML_UCS4 &dst);
-   * Convert the first UNICODE character in a UTF-8 character string
-   * into a UCS-4 character.
-   * @return number of characters the function consumed from the
-   *         UTF-8 string if it succeeds or one of the error STATUS
-   *         otherwise.
-  static int utf82ucs4 (const ACEXML_UTF8 *src,
-                        size_t len,
-   * Convert the first UNICODE character in a UTF-16 character string
-   *         UTF-16 string if it succeeds or one of the error STATUS
-   *         otherwise.
-  static int utf162ucs4 (const ACEXML_UTF16 *src,
-                        size_t len,
-//    static int utf82utf16 (const ACEXML_UTF8 *src,
-//                           size_t len,
-//                           ACEXML_UTF16 &dst);
-  // This function does not handle surrogates.
-  // = The following functions are non-inlined:
-   * Convert a UTF-8 string into a UTF-16 string.
-   * @param len The length of @a dst string.
-   *         otherwise.
-  static int utf8s2utf16s (const ACEXML_UTF8 *src,
-                           size_t len);
-   * Convert a UTF-16 string into a UTF-8 string.
-   * @return number of characters the function uses in
-   *         otherwise.
-  static int utf16s2utf8s (const ACEXML_UTF16 *src,
-                           ACEXML_UTF8 *dst,
-                           size_t len);
-#endif /* _ACEXML_TRANSCODE_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Transcode.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Transcode.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Transcode.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1 +0,0 @@
-// -*- C++ -*-  Transcode.i,v 1.4 2003/05/30 03:31:48 kitty Exp
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/URL_Addr.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/URL_Addr.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/URL_Addr.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,180 +0,0 @@
-// URL_Addr.cpp,v 1.11 2003/11/07 20:27:29 shuston Exp
-#include "ACEXML/common/URL_Addr.h"
-ACE_RCSID(common, ACEXML_URL_Addr, "URL_Addr.cpp,v 1.11 2003/11/07 20:27:29 shuston Exp")
-#include "ACEXML/common/URL_Addr.inl"
-#include "ace/Auto_Ptr.h"
-#include "ace/OS_NS_stdio.h"
-ACEXML_URL_Addr::ACEXML_URL_Addr (void)
-  : path_name_ (0),
-    addr_string_ (0),
-    addr_string_len_ (0)
-int
-ACEXML_URL_Addr::addr_to_string (ACEXML_Char *s,
-                                 size_t size,
-                                 int ipaddr_format) const
-  size_t total_len = this->calculate_length (ipaddr_format);
-  if (size < total_len)
-    return -1;
-  else
-      ACE_OS::sprintf (s, ACE_TEXT ("%s:%d/%s"),
-                       ACE_TEXT_CHAR_TO_TCHAR (ipaddr_format == 0
-                                               ? this->get_host_name ()
-                                               : this->get_host_addr ()),
-                       this->get_port_number (),
-                       this->get_path_name ());
-      return 0;
-ACEXML_URL_Addr::addr_to_string (int ipaddr_format)
-  size_t size = this->calculate_length (ipaddr_format);
-  if (size > this->addr_string_len_)
-      ACE_ALLOCATOR_RETURN (this->addr_string_,
-                            (ACEXML_Char *) ACE_OS::realloc(this->addr_string_,
-                                                            size), 0);
-      this->addr_string_len_ = size;
-  ACE_OS::sprintf (this->addr_string_,
-                   ACE_TEXT ("%s:%d/%s"),
-  return this->addr_string_;
-#if defined (ACE_USES_WCHAR)
-int
-ACEXML_URL_Addr::string_to_addr (const char* s)
-  return this->string_to_addr (ACE_TEXT_CHAR_TO_TCHAR (s));
-#endif /* ACE_USES_WCHAR */
-int
-ACEXML_URL_Addr::string_to_addr (const ACEXML_Char* s)
-  if (s == 0)
-    return -1;
-  const ACEXML_Char* http = ACE_TEXT ("http://");
-  size_t http_len = ACE_OS::strlen (http);
-  // Check validity of URL
-  if (ACE_OS::strncmp (http, s, http_len) != 0)
-    ACE_ERROR_RETURN ((LM_ERROR, ACE_TEXT ("Invalid URL %s\n"), s), -1);
-  const ACEXML_Char* url = 0;
-  // Get the host name
-  for (url = s + http_len; *url != '\0' && *url != ':' && *url != '/'; ++url)
-  size_t host_len = url - s;
-  host_len -= http_len;
-  ACEXML_Char* host_name = 0;
-  ACE_NEW_RETURN (host_name, ACEXML_Char[host_len + 1], -1);
-  ACE_OS::strncpy (host_name, s + http_len, host_len);
-  host_name[host_len] = '\0';
-  ACE_Auto_Basic_Array_Ptr<ACEXML_Char> cleanup_host_name (host_name);
-  // Get the port number (if any)
-  unsigned short port = ACE_DEFAULT_HTTP_PORT;
-  if (*url == ':')
-      port = (unsigned short) ACE_OS::strtol (++url, 0, 10); // Skip over ':'
-      while ( *url != '\0' && *url != '/' )
-        ++url;
-  // Set the addr
-  int result = this->ACE_INET_Addr::set (port, host_name);
-  if (result == -1)
-    return -1;
-  // Get the path name
-  const ACEXML_Char* path_name = 0;
-  if (*url == '\0')
-    path_name = ACE_TEXT ("/");
-  else
-    path_name = url;
-  ACE_ALLOCATOR_RETURN (this->path_name_, ACE_OS::strdup (path_name), -1);
-  return result;
-ACEXML_URL_Addr::ACEXML_URL_Addr (const ACEXML_URL_Addr &addr)
-  : ACE_INET_Addr (),
-    path_name_ (0),
-    addr_string_ (0),
-  if (this->set (addr) == -1)
-                ACE_TEXT ("%p\n"),
-                ACE_TEXT ("ACEXML_URL_Addr::ACEXML_URL_Addr")));
-int
-ACEXML_URL_Addr::set (const ACEXML_URL_Addr &addr)
-  ACE_OS::free (this->path_name_);
-  ACE_OS::free (this->addr_string_);
-  if (this->ACE_INET_Addr::set (addr) == -1)
-    return -1;
-  else
-      if (addr.path_name_)
-                              ACE_OS::strdup (addr.path_name_),
-                              -1);
-      if (addr.addr_string_)
-                              ACE_OS::strdup (addr.addr_string_),
-                              -1);
-      this->addr_string_len_ = addr.addr_string_len_;
-      return 0;
-ACEXML_URL_Addr::ACEXML_URL_Addr (const ACEXML_Char *host_name,
-                            const ACEXML_Char *path_name,
-                            unsigned short port)
-  : ACE_INET_Addr (port, host_name),
-    path_name_ (ACE_OS::strdup (path_name)),
-    addr_string_ (0),
-ACEXML_URL_Addr::~ACEXML_URL_Addr (void)
-  this->path_name_ = 0;
-template class ACE_Auto_Basic_Array_Ptr<ACEXML_Char>;
-#pragma instantiate ACE_Auto_Basic_Array_Ptr<ACEXML_Char>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/URL_Addr.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/URL_Addr.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/URL_Addr.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,135 +0,0 @@
-/* -*- C++ -*- */
-/** @file   URL_Addr.h
- *  URL_Addr.h,v 1.9 2003/11/07 20:27:29 shuston Exp
-#ifndef _ACEXML_URL_ADDR_H
-#define _ACEXML_URL_ADDR_H
-#pragma once
-#include "ace/Default_Constants.h"
-#include "ace/INET_Addr.h"
- *  @class ACEXML_URL_Addr URL_Addr.h "ACEXML/common/URL_Addr.h"
- *  Defines a URL address family address format.
-class ACEXML_Export ACEXML_URL_Addr : public ACE_INET_Addr
-public:
-  /// Initialization and termination methods.
-  ACEXML_URL_Addr (void);
-  /// Constructor.
-  ACEXML_URL_Addr (const ACEXML_Char *host_name,
-                   unsigned short port = ACE_DEFAULT_HTTP_PORT);
-  ACEXML_URL_Addr (const ACEXML_URL_Addr &addr);
-  /// Essentially the copy constructor.
-  int set (const ACEXML_URL_Addr &addr);
-   *  Initializes an <ACEXML_URL_Addr> from the <address>, which can be
-   *  "ip-number:port-number/path-name" (e.g.,
-   *  "www.cs.wustl.edu:1234/~schmidt/" "ip-number:port-number/path-name"
-   *  (e.g., "128.252.166.57:1234/~schmidt"). If there is no ':' in the
-   *  <address> it is assumed to be an ip-number or ip-address number, with
-   *  the port number <ACE_DEFAULT_HTTP_PORT>.
-  virtual int string_to_addr (const ACEXML_Char* address);
-  //  Function to shut up Borland C++
-  virtual int string_to_addr (const char* address);
-#endif
-   *  Transform the current <ACE_INET_Addr> address into string format. If
-   *  <ipaddr_format> is non-0 this produces
-   *  "128.252.166.57:80/~schmidt/"), whereas if <ipaddr_format> is 0 this
-   *  produces "ip-name:port-number" (e.g.,
-   *  "www.cs.wustl.edu:80/~schmidt/"). Returns -1 if the <size> of the
-   *  <buffer> is too small, else 0.
-  virtual int addr_to_string (ACEXML_Char *s,
-                              size_t size,
-                              int ipaddr_format = 1) const;
-   *  "www.cs.wustl.edu:80/~schmidt/"). Uses dynamic memory, which is
-   *  allocated on demand and deallocated when the object is destroyed.
-   *  Returns -1 if dynamic memory fails, else 0.
-  virtual const ACEXML_Char *addr_to_string (int ipaddr_format = 1);
-  /// Assignment operator.
-  void operator= (const ACEXML_URL_Addr &addr);
-  /// Destructor.
-  ~ACEXML_URL_Addr (void);
-   *  Compare two addresses for equality.  The addresses are considered
-   *  equal if they contain the same IP address, port number, and path name.
-  int operator == (const ACEXML_URL_Addr &SAP) const;
-  /// Compare two addresses for inequality.
-  int operator != (const ACEXML_URL_Addr &SAP) const;
-  /// Computes and returns hash value.
-  virtual u_long hash (void) const;
-  /// Return the path name.
-  const ACEXML_Char *get_path_name (void) const;
-  /// Commit suicide.
-  int destroy (void);
-private:
-  /// Calculate the maximum length of the address string
-  size_t calculate_length (int ipaddr_format) const;
-  /// Our path name.
-  ACEXML_Char *path_name_;
-  /// The dynamically created address string that's used for the
-  /// <addr_to_string> method.
-  ACEXML_Char *addr_string_;
-  /// Current length of the <addr_string_>
-  size_t addr_string_len_;
-# include "ACEXML/common/URL_Addr.inl"
-#endif /* _ACEXML_URL_ADDR_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/URL_Addr.inl
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/URL_Addr.inl	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/URL_Addr.inl	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,63 +0,0 @@
-// URL_Addr.inl,v 1.4 2003/11/07 20:27:29 shuston Exp
-ACE_INLINE size_t
-ACEXML_URL_Addr::calculate_length (int ipaddr_format) const
-  return ACE_OS::strlen (ipaddr_format == 0 ?
-                         this->get_host_name () : this->get_host_addr ())
-                     + ACE_OS::strlen ("65536") // Assume the max port number.
-                     + ACE_OS::strlen (this->get_path_name ())
-                     + sizeof (':')
-                     + sizeof ('/')
-                     + sizeof ('\0'); // For trailing '\0'.
-ACE_INLINE void
-ACEXML_URL_Addr::operator= (const ACEXML_URL_Addr &addr)
-ACE_INLINE u_long
-ACEXML_URL_Addr::hash (void) const
-  u_long result = this->ACE_INET_Addr::hash ()
-                  + ACE::hash_pjw (this->get_path_name ());
-  return result;
-ACE_INLINE int
-ACEXML_URL_Addr::operator== (const ACEXML_URL_Addr &addr) const
-  return ACE_OS::strcmp (addr.get_path_name (), this->get_path_name ()) == 0
-    && addr.get_port_number () == this->get_port_number ()
-    && addr.get_ip_address () == this->get_ip_address ();
-ACE_INLINE int
-ACEXML_URL_Addr::operator!= (const ACEXML_URL_Addr &addr) const
-  return !(*this == addr);
-ACE_INLINE const ACEXML_Char *
-ACEXML_URL_Addr::get_path_name (void) const
-  return this->path_name_;
-ACE_INLINE int
-ACEXML_URL_Addr::destroy (void)
-  // Commit suicide.
-  delete this;
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Validator.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Validator.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Validator.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,8 +0,0 @@
-// Validator.cpp,v 1.3 2002/02/14 06:28:57 nanbor Exp
-#include "ACEXML/common/Validator.h"
-ACEXML_Validator::~ACEXML_Validator ()
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Validator.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Validator.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/Validator.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,64 +0,0 @@
-// -*- C++ -*-
- *  @file    Validator.h
- *  Validator.h,v 1.7 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_VALIDATOR_H_
-#define _ACEXML_VALIDATOR_H_
-#pragma once
-#include "ACEXML/common/Attributes.h"
-#include "ACEXML/common/Env.h"
- * @class ACEXML_Validator Validator.h "common/Validator.h"
- * @brief An abstract virtual class defining validator interface.
- * An validator provides validation service for one XML element.
- * ACEXML_Validators are stateful object.  Implementations should
- * remember the current element encountered and determine if
- * it's a valid sequence of child elements.  A parser fishes
- * out a validator of certain
-class ACEXML_Export ACEXML_Validator
-public:
-  virtual ~ACEXML_Validator () = 0;
-   * Validate attributes of an element.
-   * @retval 0 if valid, -1 otherwise.
-  virtual int startElement (ACEXML_Attributes *atts ACEXML_ENV_ARG_DECL)
-        ACE_THROW_SPEC ((ACEXML_SAXException)) = 0;
-   * Validate the next child element.
-  virtual int nextElement (const ACEXML_Char *namespaceURI,
-                            const ACEXML_Char *localName,
-                            const ACEXML_Char *qName ACEXML_ENV_ARG_DECL)
-#endif /* _ACEXML_VALIDATOR_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLFilter.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLFilter.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLFilter.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,56 +0,0 @@
-// -*- C++ -*-
- *  @file    XMLFilter.h
- *  XMLFilter.h,v 1.5 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_XMLFILTER_H_
-#define _ACEXML_XMLFILTER_H_
-#pragma once
-#include "ACEXML/common/XMLReader.h"
- * @class ACEXML_XMLFilter XMLFilter.h "ACEXML/common/XMLFilter.h"
- * @brief ACEXML_XMLFilter
- * An XML filter is like an XML reader, except that it obtains its events
- * from another XML reader rather than a primary source like an XML
- * document or database. Filters can modify a stream of events as they pass
- * on to the final application.
- * The XMLFilterImpl helper class provides a convenient base for creating
- * SAX2 filters, by passing on all ACEXML_EntityResolver,
- * ACEXML_DTDHandler, ACEXML_ContentHandler and ACEXML_ErrorHandler events
- * automatically.
-class ACEXML_Export ACEXML_XMLFilter : public ACEXML_XMLReader
-public:
-   * Get the parent reader.
-  virtual ACEXML_XMLReader *getParent (void) const = 0;
-   * Set the parent reader.
-  virtual void setParent (ACEXML_XMLReader *parent) = 0;
-#endif /* _ACEXML_XMLFILTER_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLFilterImpl.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLFilterImpl.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLFilterImpl.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,339 +0,0 @@
-// -*- C++ -*-  XMLFilterImpl.cpp,v 1.5 2002/10/13 03:58:57 kitty Exp
-#include "ACEXML/common/XMLFilterImpl.h"
-# include "ACEXML/common/XMLFilterImpl.i"
-ACEXML_XMLFilterImpl::ACEXML_XMLFilterImpl (void)
-  :  parent_ (0),
-     locator_ (0),
-     entityResolver_ (0),
-     dtdHandler_ (0),
-     contentHandler_ (0),
-     errorHandler_ (0)
-ACEXML_XMLFilterImpl::ACEXML_XMLFilterImpl (ACEXML_XMLReader *parent)
-  : parent_ (parent),
-    locator_ (0),
-    dtdHandler_ (0),
-    errorHandler_ (0)
-ACEXML_XMLFilterImpl::~ACEXML_XMLFilterImpl (void)
-  // @@ How are all the object lifecycles managed?
-void
-ACEXML_XMLFilterImpl::parse (ACEXML_InputSource *input ACEXML_ENV_ARG_DECL)
-  if (this->setupParser () < 0)
-      ACEXML_THROW (ACEXML_SAXException (ACE_TEXT ("No Parent available")));
-  this->parent_->parse (input ACEXML_ENV_ARG_PARAMETER);
-  return;
-void
-ACEXML_XMLFilterImpl::parse (const ACEXML_Char *systemId ACEXML_ENV_ARG_DECL)
-  this->parent_->parse (new ACEXML_InputSource (systemId) ACEXML_ENV_ARG_PARAMETER);
-  return;
-int
-ACEXML_XMLFilterImpl::getFeature (const ACEXML_Char *name ACEXML_ENV_ARG_DECL)
-        ACE_THROW_SPEC ((ACEXML_SAXNotRecognizedException,
-                         ACEXML_SAXNotSupportedException))
-  if (this->parent_ != 0)
-    return this->parent_->getFeature (name ACEXML_ENV_ARG_PARAMETER);
-  ACEXML_THROW_RETURN (ACEXML_SAXNotRecognizedException (name), 0);
-void *
-ACEXML_XMLFilterImpl::getProperty (const ACEXML_Char *name ACEXML_ENV_ARG_DECL)
-    return this->parent_->getProperty (name ACEXML_ENV_ARG_PARAMETER);
-void
-ACEXML_XMLFilterImpl::setFeature (const ACEXML_Char *name,
-                                  int boolean_value ACEXML_ENV_ARG_DECL)
-      this->parent_->setFeature (name,
-                                 boolean_value ACEXML_ENV_ARG_PARAMETER);
-      return;
-  ACEXML_THROW (ACEXML_SAXNotRecognizedException (name));
-void
-ACEXML_XMLFilterImpl::setProperty (const ACEXML_Char *name,
-                                   void *value ACEXML_ENV_ARG_DECL)
-      this->parent_->setProperty (name,
-                                  value ACEXML_ENV_ARG_PARAMETER);
-      return;
-ACEXML_XMLReader *
-ACEXML_XMLFilterImpl::getParent (void) const
-  return this->parent_;
-void
-ACEXML_XMLFilterImpl::setParent (ACEXML_XMLReader *parent)
-  this->parent_ = parent;
-void
-ACEXML_XMLFilterImpl::characters (const ACEXML_Char *ch,
-                                  int start,
-                                  int length ACEXML_ENV_ARG_DECL)
-  if (this->contentHandler_ != 0)
-    this->contentHandler_->characters (ch, start, length ACEXML_ENV_ARG_PARAMETER);
-void
-ACEXML_XMLFilterImpl::endDocument (ACEXML_ENV_SINGLE_ARG_DECL)
-    this->contentHandler_->endDocument (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-void
-ACEXML_XMLFilterImpl::endElement (const ACEXML_Char *namespaceURI,
-    this->contentHandler_->endElement (namespaceURI,
-                                       localName,
-                                       qName ACEXML_ENV_ARG_PARAMETER);
-void
-ACEXML_XMLFilterImpl::endPrefixMapping (const ACEXML_Char *prefix ACEXML_ENV_ARG_DECL)
-    this->contentHandler_->endPrefixMapping (prefix ACEXML_ENV_ARG_PARAMETER);
-void
-ACEXML_XMLFilterImpl::ignorableWhitespace (const ACEXML_Char *ch,
-                                           int start,
-    this->contentHandler_->ignorableWhitespace (ch,
-                                                start,
-                                                length ACEXML_ENV_ARG_PARAMETER);
-void
-ACEXML_XMLFilterImpl::processingInstruction (const ACEXML_Char *target,
-                                             const ACEXML_Char *data ACEXML_ENV_ARG_DECL)
-    this->contentHandler_->processingInstruction (target,
-                                                  data ACEXML_ENV_ARG_PARAMETER);
-void
-ACEXML_XMLFilterImpl::setDocumentLocator (ACEXML_Locator *locator)
-    this->contentHandler_->setDocumentLocator (locator);
-void
-ACEXML_XMLFilterImpl::skippedEntity (const ACEXML_Char *name ACEXML_ENV_ARG_DECL)
-    this->contentHandler_->skippedEntity (name ACEXML_ENV_ARG_PARAMETER);
-void
-ACEXML_XMLFilterImpl::startDocument (ACEXML_ENV_SINGLE_ARG_DECL)
-    this->contentHandler_->startDocument (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-void
-ACEXML_XMLFilterImpl::startElement (const ACEXML_Char *namespaceURI,
-                                    const ACEXML_Char *qName,
-                                    ACEXML_Attributes *atts ACEXML_ENV_ARG_DECL)
-    this->contentHandler_->startElement (namespaceURI,
-                                         localName,
-                                         qName,
-                                         atts ACEXML_ENV_ARG_PARAMETER);
-void
-ACEXML_XMLFilterImpl::startPrefixMapping (const ACEXML_Char *prefix,
-                                          const ACEXML_Char *uri ACEXML_ENV_ARG_DECL)
-    this->contentHandler_->startPrefixMapping (prefix,
-                                               uri ACEXML_ENV_ARG_PARAMETER);
-void
-ACEXML_XMLFilterImpl::notationDecl (const ACEXML_Char *name,
-                                    const ACEXML_Char *publicId,
-                                    const ACEXML_Char *systemId ACEXML_ENV_ARG_DECL)
-  if (this->dtdHandler_ != 0)
-    this->dtdHandler_->notationDecl (name,
-                                     publicId,
-                                     systemId ACEXML_ENV_ARG_PARAMETER);
-void
-ACEXML_XMLFilterImpl::unparsedEntityDecl (const ACEXML_Char *name,
-                                          const ACEXML_Char *systemId,
-                                          const ACEXML_Char *notationName ACEXML_ENV_ARG_DECL)
-    this->dtdHandler_->unparsedEntityDecl (name,
-                                           publicId,
-                                           systemId,
-                                           notationName ACEXML_ENV_ARG_PARAMETER);
-ACEXML_InputSource *
-ACEXML_XMLFilterImpl::resolveEntity (const ACEXML_Char *publicId,
-  if (this->entityResolver_ != 0)
-    return this->entityResolver_->resolveEntity (publicId,
-  return 0;
-void
-ACEXML_XMLFilterImpl::error (ACEXML_SAXParseException &exception ACEXML_ENV_ARG_DECL)
-  if (this->errorHandler_ != 0)
-    this->errorHandler_->error (exception ACEXML_ENV_ARG_PARAMETER);
-void
-ACEXML_XMLFilterImpl::fatalError (ACEXML_SAXParseException &exception ACEXML_ENV_ARG_DECL)
-    this->errorHandler_->fatalError (exception ACEXML_ENV_ARG_PARAMETER);
-void
-ACEXML_XMLFilterImpl::warning (ACEXML_SAXParseException &exception ACEXML_ENV_ARG_DECL)
-    this->errorHandler_->warning (exception ACEXML_ENV_ARG_PARAMETER);
-ACEXML_DTDHandler *
-ACEXML_XMLFilterImpl::getDTDHandler (void) const
-  return this->dtdHandler_;
-ACEXML_ContentHandler *
-ACEXML_XMLFilterImpl::getContentHandler (void) const
-  return this->contentHandler_;
-ACEXML_EntityResolver *
-ACEXML_XMLFilterImpl::getEntityResolver (void) const
-  return this->entityResolver_;
-ACEXML_ErrorHandler *
-ACEXML_XMLFilterImpl::getErrorHandler (void) const
-  return this->errorHandler_;
-void
-ACEXML_XMLFilterImpl::setDTDHandler (ACEXML_DTDHandler *handler)
-  this->dtdHandler_ = handler;
-void
-ACEXML_XMLFilterImpl::setContentHandler (ACEXML_ContentHandler *handler)
-  this->contentHandler_ = handler;
-void
-ACEXML_XMLFilterImpl::setEntityResolver (ACEXML_EntityResolver *handler)
-  this->entityResolver_ = handler;
-void
-ACEXML_XMLFilterImpl::setErrorHandler (ACEXML_ErrorHandler *handler)
-  this->errorHandler_ = handler;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLFilterImpl.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLFilterImpl.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLFilterImpl.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,294 +0,0 @@
-// -*- C++ -*-
- *  @file    XMLFilterImpl.h
- *  XMLFilterImpl.h,v 1.7 2003/07/19 19:04:10 dhinton Exp
-#ifndef ACEXML_XMLFILTERIMPL_H
-#define ACEXML_XMLFILTERIMPL_H
-#include /**/ "ace/pre.h"
-#include "ACEXML/common/XMLFilter.h"
-#include "ACEXML/common/Locator.h"
-#include "ACEXML/common/ContentHandler.h"
-#include "ACEXML/common/DTDHandler.h"
-#include "ACEXML/common/EntityResolver.h"
-#include "ACEXML/common/ErrorHandler.h"
- * @class ACEXML_XMLFilterImpl XMLFilterImpl.h "ACEXML/common/XMLFilterImpl.h"
- * @brief ACEXML_XMLFilterImpl
- * This class is designed to sit between an XMLReader and the client
- * application's event handlers. By default, it does nothing but pass
- * requests up to the reader and events on to the handlers unmodified, but
- * subclasses can override specific methods to modify the event stream or
- * the configuration requests as they pass through.
-class ACEXML_Export ACEXML_XMLFilterImpl
-  : public ACEXML_XMLFilter,
-    public ACEXML_ContentHandler,
-    public ACEXML_DTDHandler,
-    public ACEXML_EntityResolver,
-    public ACEXML_ErrorHandler
-public:
-   * Default constructor.  Create with no parent.
-  ACEXML_XMLFilterImpl (void);
-   * Construct an XML filter with the specified parent.
-  ACEXML_XMLFilterImpl (ACEXML_XMLReader *parent);
-   * Destructor.
-  virtual ~ACEXML_XMLFilterImpl (void);
-   * Look up the value of a feature.
-  virtual int getFeature (const ACEXML_Char *name ACEXML_ENV_ARG_DECL)
-                           ACEXML_SAXNotSupportedException)) ;
-   * Look up the value of a property.
-  virtual void * getProperty (const ACEXML_Char *name ACEXML_ENV_ARG_DECL)
-   * Parse an XML document.
-  virtual void parse (ACEXML_InputSource *input ACEXML_ENV_ARG_DECL)
-    ACE_THROW_SPEC ((ACEXML_SAXException)) ;
-   * Parse an XML document from a system identifier (URI).
-  virtual void parse (const ACEXML_Char *systemId ACEXML_ENV_ARG_DECL)
-    // @@ throw IOException???
-   * Set the state of a feature.
-  virtual void setFeature (const ACEXML_Char *name,
-   * Set the value of a property.
-  virtual void setProperty (const ACEXML_Char *name,
-  virtual ACEXML_XMLReader *getParent (void) const;
-  virtual void setParent (ACEXML_XMLReader *parent);
-   * Get the current DTD event handler.
-  virtual ACEXML_DTDHandler *getDTDHandler (void) const;
-   * Get the current content event handler.
-  virtual ACEXML_ContentHandler *getContentHandler (void) const;
-   * Get the current entity resolver.
-  virtual ACEXML_EntityResolver *getEntityResolver (void) const;
-   * Get the current error event handler.
-  virtual ACEXML_ErrorHandler *getErrorHandler (void) const;
-   * Set the DTD event handler.
-  virtual void setDTDHandler (ACEXML_DTDHandler *handler);
-   * Set the content event handler.
-  virtual void setContentHandler (ACEXML_ContentHandler *handler);
-   * Set the entity resolver.
-  virtual void setEntityResolver (ACEXML_EntityResolver *handler);
-   * Set the error event handler.
-  virtual void setErrorHandler (ACEXML_ErrorHandler *handler);
-   * Receive notification of character data.
-  virtual void characters (const ACEXML_Char *ch,
-                           int start,
-   * Receive notification of the end of a document.
-  virtual void endDocument (ACEXML_ENV_SINGLE_ARG_DECL)
-   * Receive notification of the end of an element.
-  virtual void endElement (const ACEXML_Char *namespaceURI,
-   * End the scope of a prefix-URI mapping.
-  virtual void endPrefixMapping (const ACEXML_Char *prefix ACEXML_ENV_ARG_DECL)
-   * Receive notification of ignorable whitespace in element content.
-  virtual void ignorableWhitespace (const ACEXML_Char *ch,
-                                    int start,
-   * Receive notification of a processing instruction.
-  virtual void processingInstruction (const ACEXML_Char *target,
-   * Receive an object for locating the origin of SAX document events.
-  virtual void setDocumentLocator (ACEXML_Locator *locator) ;
-   * Receive notification of a skipped entity.
-  virtual void skippedEntity (const ACEXML_Char *name ACEXML_ENV_ARG_DECL)
-   * Receive notification of the beginning of a document.
-  virtual void startDocument (ACEXML_ENV_SINGLE_ARG_DECL)
-   * Receive notification of the beginning of an element.
-  virtual void startElement (const ACEXML_Char *namespaceURI,
-   * Begin the scope of a prefix-URI Namespace mapping.
-  virtual void startPrefixMapping (const ACEXML_Char *prefix,
-  // *** Methods inherit from ACEXML_DTDHandler.
-   * Receive notification of a notation declaration event.
-  virtual void notationDecl (const ACEXML_Char *name,
-   * Receive notification of an unparsed entity declaration event.
-  virtual void unparsedEntityDecl (const ACEXML_Char *name,
-  // Methods inherit from ACEXML_EnitityResolver.
-   * Allow the application to resolve external entities.
-  virtual ACEXML_InputSource *resolveEntity (const ACEXML_Char *publicId,
-  // Methods inherit from ACEXML_ErrorHandler.
-   * Receive notification of a recoverable error.
-  virtual void error (ACEXML_SAXParseException &exception ACEXML_ENV_ARG_DECL)
-        ACE_THROW_SPEC ((ACEXML_SAXException));
-   * Receive notification of a non-recoverable error.
-  virtual void fatalError (ACEXML_SAXParseException &exception ACEXML_ENV_ARG_DECL)
-   * Receive notification of a warning.
-  virtual void warning (ACEXML_SAXParseException &exception ACEXML_ENV_ARG_DECL)
-protected:
-  int setupParser (void);
-  // Set up the event handlers of parent parser to this.
-  // Returns -1 if no valid parent is set.
-private:
-  ACEXML_XMLReader *parent_;
-  ACEXML_Locator *locator_;
-  ACEXML_EntityResolver *entityResolver_;
-  ACEXML_DTDHandler *dtdHandler_;
-  ACEXML_ContentHandler *contentHandler_;
-  ACEXML_ErrorHandler *errorHandler_;
-#endif /* __ACEXML_INLINE__ */
-#include /**/ "ace/post.h"
-#endif /* ACEXML_XMLFILTERIMPL_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLFilterImpl.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLFilterImpl.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLFilterImpl.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,14 +0,0 @@
-// -*- C++ -*-  XMLFilterImpl.i,v 1.2 2002/01/24 21:00:01 nanbor Exp
-ACEXML_INLINE int
-ACEXML_XMLFilterImpl::setupParser (void)
-  if (this->parent_ == 0)
-    return -1;
-  this->parent_->setEntityResolver (this);
-  this->parent_->setDTDHandler (this);
-  this->parent_->setContentHandler (this);
-  this->parent_->setErrorHandler (this);
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLReader.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLReader.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XMLReader.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,133 +0,0 @@
-// -*- C++ -*-
- *  @file    XMLReader.h
- *  XMLReader.h,v 1.6 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_XMLREADER_H_
-#define _ACEXML_XMLREADER_H_
-#pragma once
- * @class ACEXML_XMLReader XMLReader.h "ACEXML/common/XMLReader.h"
- * @brief ACEXML_XMLReader
- * XMLReader is the interface that an XML parser's SAX2 driver must
- * implement. This interface allows an application to set and query
- * features and properties in the parser, to register event handlers
- * for document processing, and to initiate a document parse.
- * All SAX interfaces are assumed to be synchronous: the parse methods
- * must not return until parsing is complete, and readers must wait
- * for an event-handler callback to return before reporting the next
- * event.
-class ACEXML_Export ACEXML_XMLReader
-public:
-   * Return the current content handler.
-  virtual ACEXML_ContentHandler *getContentHandler (void) const = 0;
-   * Return the current DTD handler.
-  virtual ACEXML_DTDHandler *getDTDHandler (void) const = 0;
-   * Return the current entity resolver.
-  virtual ACEXML_EntityResolver *getEntityResolver (void) const = 0;
-   * Return the current error handler.
-  virtual ACEXML_ErrorHandler *getErrorHandler (void) const = 0;
-   * Look up the value of a feature.  This method allows
-   * programmers to check whether a specific feature has been
-   * activated in the parser.
-                           ACEXML_SAXNotSupportedException)) = 0;
-   * Allow an application to register a content event handler.
-  virtual void setContentHandler (ACEXML_ContentHandler *handler) = 0;
-   * Allow an application to register a DTD event handler.
-  virtual void setDTDHandler (ACEXML_DTDHandler *handler) = 0;
-   * Allow an application to register an entity resolver.
-  virtual void setEntityResolver (ACEXML_EntityResolver *resolver) = 0;
-   * Allow an application to register an error event handler.
-  virtual void setErrorHandler (ACEXML_ErrorHandler *handler) = 0;
-   * Activating or deactivating a feature.
-#endif /* _ACEXML_XMLREADER_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XML_Codecs.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XML_Codecs.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XML_Codecs.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,99 +0,0 @@
-// -*- C++ -*-  XML_Codecs.cpp,v 1.5 2003/11/07 20:27:29 shuston Exp
-#include "ace/OS_Memory.h"
-#include "ace/OS_NS_string.h"
-#include "ACEXML/common/XML_Codecs.h"
-ACE_RCSID (common, XML_Codecs, "XML_Codecs.cpp,v 1.5 2003/11/07 20:27:29 shuston Exp")
-ACEXML_Char*
-ACEXML_Base64::encode (const ACEXML_Char* input,
-                       size_t* output_len)
-  if (!input)
-    return 0;
-  size_t len = ACE_OS::strlen (input);
-  ACE_Byte* buf = 0;
-  ACE_NEW_RETURN (buf,
-                  ACE_Byte[len],
-                  0);
-  ACE_Auto_Basic_Array_Ptr<ACE_Byte> cleanup_buf (buf);
-  for (size_t i = 0; i < len; ++i)
-    buf[i] = (ACE_Byte)input[i];
-  buf[len] = 0;
-  size_t encode_len = 0;
-  ACE_Byte* encodedBuf = ACE_Base64::encode (buf, len, &encode_len);
-  if (!encodedBuf)
-    return 0;
-  ACEXML_Char* result = 0;
-  ACE_NEW_RETURN (result,
-                  ACEXML_Char[encode_len+1],
-                  0);
-  for (size_t j = 0; j < encode_len; ++j)
-    result[j] = (ACEXML_Char)encodedBuf[j];
-  result[encode_len] = 0;
-  *output_len = encode_len;
-  delete[] encodedBuf;
-  return result;
-ACEXML_Char*
-ACEXML_Base64::decode (const ACEXML_Char* input,
-  if (!input)
-    return 0;
-                  ACE_Byte[len],
-                  0);
-  ACE_Auto_Basic_Array_Ptr<ACE_Byte> cleanup (buf);
-  buf[len] = 0;
-  size_t decode_len = 0;
-  ACE_Byte* decodedBuf = ACE_Base64::decode (buf, &decode_len);
-  if (!decodedBuf)
-    return 0;
-                  ACEXML_Char[decode_len+1],
-                  0);
-  for (size_t j = 0; j < decode_len; ++j)
-    result[j] = (ACEXML_Char)decodedBuf[j];
-  result[decode_len] = 0;
-  *output_len = decode_len;
-  delete[] decodedBuf;
-  return result;
-#if defined (ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION)
-template class ACE_Auto_Basic_Array_Ptr<ACE_Byte>;
-#elif defined (ACE_HAS_TEMPLATE_INSTANTIATION_PRAGMA)
-#pragma instantiate ACE_Auto_Basic_Array_Ptr<ACE_Byte>
-#endif /* ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XML_Codecs.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XML_Codecs.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XML_Codecs.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,73 +0,0 @@
-// -*- C++ -*-
- *  @file   XML_Codecs.h
- *  XML_Codecs.h,v 1.5 2003/07/19 19:04:10 dhinton Exp
- *  @author Krishnakumar B <kitty at cs.wustl.edu>
- *  XML_Codecs is a generic wrapper for various encoding and decoding
- *  mechanisms used in ACEXML. Currently it includes support for handling
- *  Base64 content transfer-encoding of ACEXML_Chars.
-#ifndef _ACEXML_XML_CODECS_H
-#define _ACEXML_XML_CODECS_H
-#pragma once
-#include "ace/Codecs.h"
- * @class ACEXML_Base64
- * @brief Encode/Decode a stream of ACEXML_Chars according to Base64 encoding.
- * This class provides methods to encode or decode a stream of ACEXML_Chars
- * to/from Base64 encoding. It doesn't convert the input stream to a
- * canonical form before encoding.
-class ACEXML_Export ACEXML_Base64 : public ACE_Base64
-public:
-   * Encodes a stream of octets to Base64 data
-   * @param input Binary data in ACEXML_Char stream.
-   * @param output_len Length of the encoded Base64 ACEXML_Char stream.
-   * @return Encoded Base64 data in ACEXML_Char stream or NULL if input data
-   *         cannot be encoded.
-  static ACEXML_Char* encode (const ACEXML_Char* input,
-                              size_t* output_len);
-   * Decodes a stream of Base64 to octets data
-   * @param input Encoded Base64 data in ACEXML_Char stream.
-   * @param output_len Length of the binary ACEXML_Char stream.
-   * @return Binary data in ACEXML_Char stream or NULL if input data cannot
-   *         be encoded.
-  static ACEXML_Char* decode (const ACEXML_Char* input,
-#endif /* _ACEXML_XML_CODECS_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XML_Macros.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XML_Macros.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XML_Macros.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,443 +0,0 @@
-// -*- C++ -*-
- * @file XML_Macros.h
- * XML_Macros.h,v 1.3 2003/07/19 19:04:10 dhinton Exp
- *   Writing code that is portable between platforms with or without
- *   native C++ exceptions is hard.  The following macros offer some
- *   help on this task.
- *  @author Nanbor Wang <nanbor at cs.wustl.edu>
- *  @author Aniruddha Gokhale  <gokhale at sahyadri.research.bell-labs.com>
- *  @author Carlos O'Ryan  <coryan at uci.edu>
- *  @author Krishnakumar B <kitty at cs.wustl.edu>, et al.
-// Macros for handling exceptions.
-#ifndef _ACEXML_MACROS_H
-#define _ACEXML_MACROS_H
-#include "ace/config-all.h"
-# if !defined (ACE_LACKS_PRAGMA_ONCE)
-#   pragma once
-# endif /* ACE_LACKS_PRAGMA_ONCE */
-#include "ace/Exception_Macros.h"
-// The following macros assume that an environment variable is passed
-// in/out of each function that can throw an exception. The type of the
-// environment variable is defined by ACEXML_ENV_TYPE.
-#if !defined (ACEXML_ENV_TYPE)
-# define ACEXML_ENV_TYPE  ACEXML_Env
-#endif /* ACEXML_ENV_TYPE */
-// The name of the variable defined by ACEXML_TRY_ENV. Below is the name
-// that we use by default. If you wish to change it you can redefine
-// ACEXML_TRY_ENV to change the default name. Also ACEXML_ADOPT_ENV allows the
-// use of non-standard name within a scope.
-#if !defined (ACEXML_TRY_ENV)
-# define ACEXML_TRY_ENV  _ACEXML_Env_variable
-#endif /* ACEXML_TRY_ENV */
-// The base type of Exception from which all the other exception types are
-// derived. By default, it is set to ACEXML_Exception.
-#if !defined (ACEXML_EXCEPTION_TYPE)
-# define ACEXML_EXCEPTION_TYPE  ACEXML_Exception
-#endif /* ACEXML_EXCEPTION_TYPE */
-// This is the exception caught by ACEXML_CATCHANY.
-#if !defined (ACEXML_ANY_EXCEPTION)
-# define ACEXML_ANY_EXCEPTION ex
-#endif /* ACEXML_ANY_EXCEPTION */
-// Declare a new environment variable on the stack. The type of the
-// environment variable is determined by ACEXML_ENV_TYPE.
-#define ACEXML_DECLARE_NEW_ENV \
-     ACEXML_ENV_TYPE ACEXML_TRY_ENV
-#if defined (ACE_USES_NATIVE_EXCEPTIONS)
-#define ACEXML_ADOPT_ENV (ENV)
-// No need to check. Native exceptions handle the control flow
-// automatically when an exception occurs.
-# define ACEXML_CHECK
-// Used when the function requires a return value.
-# define ACEXML_CHECK_RETURN(RETV)
-// ACEXML_THROW_R_INT should not be used by the user.
-# define ACEXML_THROW_R_INT(EXCEPTION) \
-      throw EXCEPTION
-// Throwing an exception is easy. These two macros should _NOT_ be
-// used within try blocks.
-# define ACEXML_THROW(EXCEPTION) \
-      throw EXCEPTION
-// Throwing an exception when the function reqires a return value.
-# if defined (WIN32) || defined (__HP_aCC)
-#   define ACEXML_THROW_RETURN(EXCEPTION, RETV) \
-      do \
-          throw EXCEPTION; \
-          return RETV; \
-        } while (0)
-# else /* WIN32 */
-#   define ACEXML_THROW_RETURN(EXCEPTION,RETV) \
-        throw EXCEPTION
-# endif /* WIN32 */
-// For compilers with native exceptions, we can simply use try to try. ;-)
-// do {} while (0) is required to avoid compilation warnings.
-# define ACEXML_TRY \
-   do \
-       try \
-# define ACEXML_TRY_NEW_ENV \
-   do \
-       ACEXML_ENV_TYPE ACEXML_TRY_ENV; \
-       try \
-# define ACEXML_TRY_EX(LABEL) \
-   do \
-       try \
-// No need to check for exceptions within try block for compilers with
-// native exceptions.
-# define ACEXML_TRY_CHECK
-# define ACEXML_TRY_CHECK_EX(LABEL)
-// Likewise, throwing exceptions within try blocks is easy.
-# define ACEXML_TRY_THROW(EXCEPTION) throw EXCEPTION
-# define ACEXML_TRY_THROW_EX(EXCEPTION,LABEL) throw EXCEPTION
-// Same thing for catch.
-# define ACEXML_CATCH(EXCEPTION,VAR) \
-       catch (EXCEPTION & VAR) \
-           ACE_UNUSED_ARG (VAR);
-# define ACEXML_CATCHANY \
-       ACEXML_CATCH(ACEXML_EXCEPTION_TYPE, ACEXML_ANY_EXCEPTION)
-# define ACEXML_CATCHALL \
-       catch (...) \
-// Rethrowing the exception from catch blocks.
-# define ACEXML_RE_THROW throw
-# define ACEXML_RE_THROW_EX(LABEL) throw
-// Close the catch block.
-# define ACEXML_ENDTRY \
-     } while (0)
-#else /* ! ACEXML_USES_NATIVE_EXCEPTIONS */
-// When handling compilers without native exceptions, things get a bit
-// hairy. Exceptions are simulated using ACEXML_ENV_TYPE. The trick here is to
-// make sure the flow-of-control can simulate the case when native
-// exceptions occur...
-# define ACEXML_ADOPT_ENV(ENV) ACEXML_ENV_TYPE &ACEXML_TRY_ENV = ENV
-// Follow every statement that could throw exceptions with ACEXML_CHECK or
-// ACEXML_CHECK_RETURN. These two macros should _NOT_ be used within try
-// blocks. Use ACEXML_TRY_CHECK or ACEXML_TRY_CHECK_EX instead.
-# define ACEXML_CHECK \
-    if (ACEXML_TRY_ENV . exception () != 0) \
-      return
-// When function requires a return value
-# define ACEXML_CHECK_RETURN(RETV) \
-      return RETV
-# define ACEXML_THROW_R_INT(EXCEPTION) ACEXML_TRY_ENV.exception (new EXCEPTION)
-// Throwing exceptions will inevitably cause a return from the current
-// function. These two macros should _NOT_ be used within try blocks. Use
-// ACEXML_TRY_THROW or ACEXML_TRY_THROW_EX instead.
-    do \
-        ACEXML_TRY_ENV.exception (new EXCEPTION); \
-        return; \
-      } while (0)
-    do \
-        return RETV; \
-      } while (0)
-// ACEXML_TRY sets up flags to control program flow. ACEXML_TRY_FLAG acts
-// like a one-shot flip-flop. When an exception occurs (detected using
-// ACEXML_TRY_CHECK,) ACEXML_TRY_FLAG will be reset and the control goes
-// back into ACEXML_TRY_LABEL. Since ACEXML_TRY_FLAG is reset, the try
-// block won't get executed again and the control proceeds to the following
-// catch blocks. ACEXML_EXCEPTION_NOT_CAUGHT flag is used to prevent
-// catching an exception twice. This macro assumes there's already an
-// ACEXML_ENV_TYPE variable ACEXML_TRY_ENV defined (which should be the
-// case normally)
-   do { \
-     int ACEXML_TRY_FLAG = 1; \
-     int ACEXML_EXCEPTION_NOT_CAUGHT = 1; \
-   ACEXML_TRY_LABEL: \
-     if (ACEXML_TRY_FLAG) \
-       do {
-// ACEXML_TRY_NEW_ENV functions like the macro ACEXML_TRY but defines a new
-// ACEXML_ENV_TYPE variable ACEXML_TRY_ENV. It is most often used in the outer
-// most function where no ACEXML_TRY_ENV is available.
-   do { \
-     ACEXML_ENV_TYPE ACEXML_TRY_ENV;\
-       do {
-// ACEXML_TRY_EX works exactly like ACEXML_TRY macro except the label used
-// in the try block is customizable to avoid name clashing. It should be
-// used when nested try blocks or multiple try blocks are required, in the
-// same function.
-   do { \
-   ACEXML_TRY_LABEL ## LABEL: \
-       do {
-// Check for exceptions within try blocks.
-# define ACEXML_TRY_CHECK \
-      if (ACEXML_TRY_ENV.exception () != 0) \
-          ACEXML_TRY_FLAG = 0; \
-          goto ACEXML_TRY_LABEL; \
-// Checking exception within EX try blocks.
-# define ACEXML_TRY_CHECK_EX(LABEL) \
-          goto ACEXML_TRY_LABEL ## LABEL; \
-// Throwing exception within TRY blocks.
-# define ACEXML_TRY_THROW(EXCEPTION) \
-# define ACEXML_TRY_THROW_EX(EXCEPTION,LABEL) \
-// When exceptions occur or try block finishes execution without exception,
-// control will continue in the catch block. This macro first checks if
-// there's any uncaught exception left. If all the conditions are met, we
-// have caught an exception. It then resets ACEXML_EXCEPTION_NOT_CAUGHT to
-// prevent subsequent catch blocks from catching the same exception again,
-// and extracts out the underlying exception in ACEXML_TRY_ENV. We also make a
-// copy of ACEXML_TRY_ENV in ACEXML_CAUGHT_ENV, in case we want to rethrow the
-// exception. ACEXML_TRY_ENV is cleared out after the exception is caught so
-// you should not use ACEXML_TRY_ENV within the catch block(You should use the
-// exception directly).
-# define ACEXML_CATCH(TYPE,VAR) \
-     } while (0); \
-   do \
-     if (ACEXML_TRY_ENV.exception () != 0 && ACEXML_EXCEPTION_NOT_CAUGHT && \
-       TYPE::_downcast(ACEXML_TRY_ENV.exception ()) != 0) \
-         ACEXML_ENV_TYPE ACEXML_CAUGHT_ENV = ACEXML_TRY_ENV;\
-         ACEXML_EXCEPTION_NOT_CAUGHT = 0; \
-         TYPE &VAR = *TYPE::_downcast (ACEXML_CAUGHT_ENV.exception ()); \
-         ACE_UNUSED_ARG (VAR); \
-         ACEXML_TRY_ENV.clear ();
-// ACEXML_CATCHANY uses ACEXML_CATCH to catch all exceptions derived from
-// ACEXML_EXCEPTION_TYPE
-# define ACEXML_CATCHANY ACEXML_CATCH (ACEXML_EXCEPTION_TYPE, ACEXML_ANY_EXCEPTION)
-// Since there's no other exception for compilers without exception
-// support, we simply catch all ACEXML_EXCEPTION_TYPE exceptions for
-// ACEXML_CATCHALL.
-# define ACEXML_CATCHALL ACEXML_CATCHANY
-// Rethrowing exception within catch blocks. Notice that we depend on the
-// ACEXML_CHECK/ACEXML_CHECK_RETURN following the ACEXML_ENDTRY, or
-// ACEXML_TRY_CHECK/ ACEXML_TRY_CHECK_EX following the ACEXML_ENDTRY when
-// the catch block is within another try block, to do the "Right
-// Thing[TM]."
-# define ACEXML_RE_THROW \
-    do {\
-      ACEXML_TRY_ENV = ACEXML_CAUGHT_ENV; \
-    } while (0)
-# define ACEXML_RE_THROW_EX(LABEL) \
-    do {\
-    } while (0)
-// Close the try block. Since exceptions may not get caught, and exceptions
-// can also be rethrown from the catch block, it's always a good idea to
-// follow ACEXML_ENDTRY with ACEXML_CHECK or ACEXML_TRY_CHECK (depending on
-// the context.)
-      } while (0); \
-    } while (0)
-#endif /* ! ACE_USES_NATIVE_EXCEPTIONS */
-// ACE_HAS_EXCEPTIONS is not the same as ACE_NEW_THROWS_EXCEPTIONS.
-#if defined(ACE_NEW_THROWS_EXCEPTIONS)
-#   define ACEXML_NEW_THROW_EX(POINTER,CONSTRUCTOR,EXCEPTION) \
-     do { try { POINTER = new CONSTRUCTOR; } \
-       catch (ACE_bad_alloc) { errno = ENOMEM; ACEXML_THROW_R_INT (EXCEPTION); } \
-     } while (0)
-#else /* ! ACE_NEW_THROWS_EXCEPTIONS */
-     do { POINTER = new CONSTRUCTOR; \
-       if (POINTER == 0) { errno = ENOMEM; ACEXML_THROW_R_INT (EXCEPTION); } \
-     } while (0)
-#endif /* ACE_NEW_THROWS_EXCEPTIONS */
-# define ACEXML_GUARD_THROW_EX(MUTEX,OBJ,LOCK,EXCEPTION) \
-  ACE_Guard< MUTEX > OBJ (LOCK); \
-    if (OBJ.locked () == 0) ACEXML_THROW_R_INT (EXCEPTION);
-# define ACEXML_READ_GUARD_THROW_EX(MUTEX,OBJ,LOCK,EXCEPTION) \
-  ACE_Read_Guard< MUTEX > OBJ (LOCK); \
-# define ACEXML_WRITE_GUARD_THROW_EX(MUTEX,OBJ,LOCK,EXCEPTION) \
-  ACE_Write_Guard< MUTEX > OBJ (LOCK); \
- * @name Native C++ exceptions portability macros.
- * The following macros are used to write code portable between platforms
- * with and without native C++ exception support. Their main goal is to
- * hide the presence of the ACEXML_ENV_TYPE argument, but they collaborate
- * with the ACEXML_TRY_* macros to emulate the try/catch blocks.
-/// Define a macro to emit code only when ACEXML_ENV_TYPE is used
-#if !defined (ACE_USES_NATIVE_EXCEPTIONS) || defined (ACEXML_ENV_BKWD_COMPAT)
-#  define ACEXML_ENV_EMIT_CODE(X) X
-#else
-#endif /* ACE_USES_NATIVE_EXCEPTIONS && ! ACEXML_ENV_BKWD_COMPAT */
-/// Another macro to emit code only when ACEXML_ENV_TYPE is used
-#  define ACEXML_ENV_EMIT_CODE2(X,Y) X,Y
-#else
-/// Helper macro
-#define ACEXML_ENV_EMIT_DUMMY
-/// Declare a ACEXML_ENV_TYPE argument as the last argument of a
-/// function
- * Normally this macro is used as follows:
- * <CODE>void my_funct (int x, int y ACEXML_ENV_ARG_DECL);</CODE>
- * Its purpose is to provide developers (and users) with a mechanism to
- * write code that is portable to platforms with and without native C++
- * exceptions.
-#define ACEXML_ENV_ARG_DECL \
-    ACEXML_ENV_EMIT_CODE2(ACEXML_ENV_EMIT_DUMMY, \
-                       ACEXML_ENV_TYPE &ACEXML_TRY_ENV)
-/// Declare a ACEXML_ENV_TYPE argument that is not used by the
-/// function definition.
- * Similar to ACEXML_ENV_ARG_DECL, but the formal parameter name is dropped to
- * avoid warnings about unused parameters
-#define ACEXML_ENV_ARG_DECL_NOT_USED \
-                       ACEXML_ENV_TYPE &)
-/// Declare a ACEXML_ENV_TYPE argument for methods that do not take any other
-/// parameters
-#define ACEXML_ENV_SINGLE_ARG_DECL \
-    ACEXML_ENV_EMIT_CODE(ACEXML_ENV_TYPE &ACEXML_TRY_ENV)
-/// Declare a ACEXML_ENV_TYPE argument for methods which don't use it.
-#define ACEXML_ENV_SINGLE_ARG_DECL_NOT_USED \
-    ACEXML_ENV_EMIT_CODE(ACEXML_ENV_TYPE &)
-/// Use the ACEXML_ENV_TYPE argument in a nested call
-#define ACEXML_ENV_ARG_PARAMETER \
-                       ACEXML_TRY_ENV)
-/// Use the ACEXML_ENV_TYPE argument in a nested call, assuming that the
-/// called function takes only the ACEXML_TRY_ENV argument.
-#define ACEXML_ENV_SINGLE_ARG_PARAMETER \
-    ACEXML_ENV_EMIT_CODE(ACEXML_TRY_ENV)
-/// Eliminate unused argument warnings about ACEXML_TRY_ENV
-#define ACEXML_ENV_ARG_NOT_USED \
-    ACEXML_ENV_EMIT_CODE(ACE_UNUSED_ARG(ACEXML_TRY_ENV))
-// This thing can be moved above when we drop ACEXML_ENV_BKWD_COMPAT.
-#  define ACEXML_ENV_RAISE(ex) ACEXML_TRY_ENV.exception (ex)
-#else
-#  define ACEXML_ENV_RAISE(ex) (ex)->_raise ()
-#endif /* ACEXML_CORBA_HAS_EXCEPTIONS */
-#endif /* _ACEXML_MACROS_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XML_Types.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XML_Types.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/XML_Types.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,80 +0,0 @@
-// -*- C++ -*-
- *  @file    XML_Types.h
- * This file collects the type definitions for data types
- * used in ACE XML parser.
- *  XML_Types.h,v 1.7 2003/11/01 11:15:06 dhinton Exp
-#ifndef _ACEXML_XML_TYPES_H_
-#define _ACEXML_XML_TYPES_H_
-#if !defined (ACE_LACKS_PRAGMA_ONCE)
-#pragma once
-#endif /* ACE_LACKS_PRAGMA_ONCE */
-#include "ace/SString.h"
-# if defined (ACE_HAS_WCHAR) && (ACE_SIZEOF_WCHAR == 2)
-typedef wchar_t ACEXML_UTF16;
-# else
-typedef ACE_USHORT16 ACEXML_UTF16;
-# endif /* ACE_HAS_WCHAR && ACE_SIZEOF_WCHAR == 2 */
-# if defined (ACE_HAS_WCHAR) && (ACE_SIZEOF_WCHAR == 4)
-typedef wchar_t ACEXML_UCS4;
-# else
-typedef ACE_UINT32 ACEXML_UCS4;
-# endif /* ACE_HAS_WCHAR && ACE_SIZEOF_WCHAR == 4 */
-typedef char ACEXML_UTF8;
- * @typedef ACEXML_Char
- * ACEXML_Char only maps to ACEXML_UTF16 when ACE_USES_WCHAR is defined.
- * Here we assume sizeof (wchar_t) is always 2 bytes.
- * Default XML strings will use UTF-8 encoding.  We would like to use
- * the string classes in standard C++ Library here.  But they are not
- * very portable yet (as far as I know,) and I'll just use ACE_CString
- * for now, unless UNICODE support is turned on.  Notice that you
- * should never convert strings between ACE_CString and ACE_WString
- * using the built-in conversion functions as they only perform simple
- * copy without any encoding conversion.
-# if defined (ACE_USES_WCHAR)
-typedef ACEXML_UTF16 ACEXML_Char;
-typedef ACE_WString ACEXML_String;
-# else
-typedef ACEXML_UTF8 ACEXML_Char;
-typedef ACE_CString ACEXML_String;
-# endif /* ACE_USES_WCHAR */
-# if (!defined (ACEXML_HAS_INLINE) && defined (__ACE_INLINE__)) ||  (ACEXML_HAS_INLINE == 1)
-#   define __ACEXML_INLINE__ inline
-# else
-#   if defined (__ACEXML_INLINE__)
-#     undef __ACEXML_INLINE__
-#   endif /* __ACEXML_INLINE__ */
-# endif /* (!ACEXML_HAS_INLINE) && (__ACE_INLINE__) || (ACEXML_HAS_INLINE == 1) */
-#   define ACEXML_INLINE inline
-# else
-# endif /* __ACEXML_INLINE */
-#endif /* _ACEXML_XML_TYPE_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ZipCharStream.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ZipCharStream.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ZipCharStream.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,255 +0,0 @@
-// ZipCharStream.cpp,v 1.4 2004/01/09 00:50:35 kitty Exp
-#include "ace/ACE.h"
-ACEXML_ZipCharStream::ACEXML_ZipCharStream (void)
-  : filename_ (0), encoding_ (0), size_ (0), infile_ (0), pos_ (0),
-    limit_ (0)
-ACEXML_ZipCharStream::~ACEXML_ZipCharStream (void)
-  this->close();
-int
-ACEXML_ZipCharStream::open (const ACEXML_Char *name)
-  delete[] this->filename_;
-  this->filename_ = 0;
-  delete[] this->encoding_;
-  this->encoding_ = 0;
-  this->infile_ = zzip_fopen (name, ACE_TEXT ("r"));
-  if (this->infile_ == 0)
-    return -1;
-  this->filename_ = ACE::strnew (ACE::basename (name));
-  return this->determine_encoding();
-int
-ACEXML_ZipCharStream::determine_encoding (void)
-    return -1;
-  char input[4];
-  int i = 0;
-  for (; i < 4 && (input[i] = this->peekchar_i(i)) > 0; ++i)
-  if (i < 4)
-    return -1;
-  const ACEXML_Char* temp = ACEXML_Encoding::get_encoding (input);
-  if (!temp)
-    return -1;
-  else
-      if (this->encoding_)
-        delete [] this->encoding_;
-      this->encoding_ = ACE::strnew (temp);
-  //     ACE_DEBUG ((LM_DEBUG, ACE_TEXT ("File's encoding is %s\n"),
-//                   this->encoding_));
-  // Move over the byte-order-mark if present.
-  char ch;
-  for (int j = 0; j < 3; ++j)
-      if ((ch = this->peekchar_i()) < 0)
-        return -1;
-      if (ch == '\xFF' || ch == '\xFE' || ch == '\xEF' || ch == '\xBB' ||
-          ch == '\xBF')
-        this->get(ch);
-      else
-        break;
-  return 0;
-void
-ACEXML_ZipCharStream::rewind()
-    return;
-  zzip_rewind (this->infile_);
-  this->determine_encoding();
-int
-ACEXML_ZipCharStream::available (void)
-    return -1;
-  long curr;
-  if ((curr = zzip_tell (this->infile_)) < 0)
-    return -1;
-  return (this->size_ - curr);
-int
-ACEXML_ZipCharStream::close (void)
-  if (this->infile_ != 0)
-      zzip_close (this->infile_);
-      this->infile_ = 0;
-  this->size_ = 0;
-  this->pos_ = 0;
-  this->limit_ = 0;
-  return 0;
-int
-ACEXML_ZipCharStream::getchar_i (char& ch)
-    return -1;
-  if (this->pos_ < this->limit_)
-      ch = this->buf_[this->pos_++];
-      return 0;
-  this->limit_ = zzip_read (this->infile_, this->buf_, sizeof (this->buf_));
-  if (this->limit_ == 0)
-    return -1;
-  this->pos_ = 0;
-  return 0;
-int
-ACEXML_ZipCharStream::peekchar_i (off_t offset)
-    return -1;
-  if (offset > (off_t) sizeof (this->buf_))
-    return -1;
-  if (this->pos_ + offset < this->limit_)
-    return this->buf_[this->pos_ + offset];
-  int i = 0;
-  for (; this->pos_ < this->limit_; ++this->pos_, ++i)
-    this->buf_[i] = this->buf_[this->pos_];
-  this->limit_ = zzip_read (this->infile_, this->buf_ + i,
-                            sizeof (this->buf_) - i);
-  this->limit_ += i;
-    return -1;
-  this->pos_ = 0;
-int
-ACEXML_ZipCharStream::read (ACEXML_Char *str, size_t len)
-    return -1;
-  size_t i = 0;
-  for (; i < len && this->pos_ < this->limit_; ++i)
-    str[i] = this->buf_[this->pos_++];
-  if (i == len)
-    return len;
-  len = len - i;
-  this->pos_ = 0;
-  this->limit_ = 0;
-  int bytes = zzip_fread (str + i, sizeof (ACEXML_Char), len, this->infile_);
-  return (bytes + i);
-int
-ACEXML_ZipCharStream::get (ACEXML_Char& ch)
-  return this->get_i (ch);
-#else
-  return this->getchar_i (ch);
-int
-ACEXML_ZipCharStream::peek (void)
-  return this->peek_i();
-#else
-  return this->peekchar_i();
-const ACEXML_Char*
-ACEXML_ZipCharStream::getEncoding (void)
-  return this->encoding_;
-const ACEXML_Char*
-ACEXML_ZipCharStream::getSystemId (void)
-  return this->filename_;
-int
-ACEXML_ZipCharStream::get_i (ACEXML_Char& ch)
-  if (ACE_OS::strcmp (this->encoding_, ACE_TEXT ("UTF-8")) == 0)
-  int BE = (ACE_OS::strcmp (this->encoding_,
-                            ACE_TEXT ("UTF-16BE")) == 0) ? 1 : 0;
-  ACEXML_Char input[2];
-  int i = 0;
-  for (; i < 2 && (this->getchar_i (input[i]) == 0); ++i)
-  if (i < 2)
-      ch = 0;
-      return -1;
-  ch = BE ? input[0] << 8 | input[1] : input[1] << 8 | input[0];
-  return 0;
-int
-ACEXML_ZipCharStream::peek_i (void)
-  // If we are reading a UTF-8 encoded file, just use the plain unget.
-  // Peek into the stream. This reads two characters off the stream, keeps
-  // it in peek_.
-  int i = 0;
-  for (; i < 2 && (input[i] = this->peekchar_i (i)) > 0; ++i)
-  if (i < 2)
-    return -1;
-  return (BE ? input[0] << 8 | input[1] : input[1] << 8 | input[0]);
-#else
-#if defined (__HP_aCC)
-static int shut_up_aCC = 0;
-#endif /* __HP_aCC */
-#endif /* ACEXML_HAS_ZZIPLIB */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ZipCharStream.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ZipCharStream.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/ZipCharStream.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,144 +0,0 @@
-// -*- C++ -*-
- *  @file    ZipCharStream.h
- *  ZipCharStream.h,v 1.4 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_ZIPCHARSTREAM_H_
-#define _ACEXML_ZIPCHARSTREAM_H_
-#ifdef ACEXML_HAS_ZZIPLIB
-#include "ACEXML/common/ACEXML_Export.h"
-#pragma once
-#include "ACEXML/common/CharStream.h"
-#include "ACEXML/common/Encoding.h"
-#include "zziplib.h"
-// Ugly wart to get aroung a macro version of read defined in zziplib.h. Evil...
-#ifdef read
-#undef read
-#endif
- * @class ACEXML_ZipCharStream ZipCharStream.h "ACEXML/common/ZipCharStream.h"
- * An implementation of ACEXML_CharStream for reading input from a ZIP archive.
-class ACEXML_Export ACEXML_ZipCharStream : public ACEXML_CharStream
-public:
-  /// Default constructor.
-  ACEXML_ZipCharStream (void);
-  /// Destructor
-  virtual ~ACEXML_ZipCharStream (void);
-  /// Open a file.
-  int open (const ACEXML_Char *name);
-   * Returns the available ACEXML_Char in the buffer.  -1
-   * if the object is not initialized properly.
-  virtual int available (void);
-   * Close this stream and release all resources used by it.
-  virtual int close (void);
-   * Read the next ACEXML_Char.  Return -1 if we are not able to
-   * return an ACEXML_Char, 0 if EOF is reached, or 1 if succeed.
-  virtual int get (ACEXML_Char& ch);
-   * Read the next batch of ACEXML_Char strings
-  virtual int read (ACEXML_Char *str, size_t len);
-   *  Determine the encoding of the file.
-  virtual int determine_encoding (void);
-   * Peek the next ACEXML_Char in the CharStream.  Return the
-   * character if success, -1 if EOF is reached.
-  virtual int peek (void);
-   *  Resets the file pointer to the beginning of the stream.
-  virtual void rewind (void);
-   * Get the character encoding for a byte stream or URI.
-  virtual const ACEXML_Char *getEncoding (void);
-   * Get the systemId for the underlying CharStream
-  virtual const ACEXML_Char* getSystemId (void);
-protected:
-  /** Read the next character as a normal character. Return -1 if EOF is
-   *  reached, else return 0.
-  virtual int getchar_i (char& ch);
-   * Peek @c offset bytes into the stream and return the character at @c
-   * offset. If EOF is reached, return -1.
-  virtual int peekchar_i (off_t offset = 0);
-private:
-   *  Read the next character from the stream taking into account the
-   *  encoding of the file.
-  int get_i (ACEXML_Char& ch);
-   *  Return the next character from the stream taking into account the
-   *  encoding of the file. Subsequent call to get() returns this
-   *  character.
-  int peek_i (void);
-  ACEXML_Char*  filename_;
-  ACEXML_Char*  encoding_;
-  off_t         size_;
-  ZZIP_FILE*    infile_;
-  char          buf_[80];
-  int           pos_;
-  int           limit_;
-#endif /* _ACEXML_ZIPCHARSTREAM_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/common.mpc
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/common.mpc	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/common/common.mpc	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,7 +0,0 @@
-//  -*- MPC -*-
-// common.mpc,v 1.5 2003/11/10 04:31:58 dhinton Exp
-project(ACEXML): acelib {
-  sharedname    = ACEXML
-  dynamicflags += ACEXML_BUILD_DLL
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/TODO.txt
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/TODO.txt	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/TODO.txt	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,17 +0,0 @@
- at page acexml_todo ACEXML TO-DO List
-<ul>
-  <li>Add Schema parsing ability.
-  <li>Add support for resolving external entities, such as a
-      schema/namespace definition located on the web.
-  <li>Add parameterized entity management class.  See above.
-  <li>Define validator building/calling interfaces.
-</ul>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/bugs.txt
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/bugs.txt	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/bugs.txt	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,17 +0,0 @@
- at page acexml_bugs ACEXML Known Bugs
-<ul>
-  <li>ACEXML currently do not validate an XML files.  The validator
-      hooks have not fully integrated into the parser yet.
-  <li>Need to verify predefined entities are working correctly.  Check
-      out the SAXPrint example.
-  <li>Currently, replacement of parameterized reference (PEReference) is
-      not working.
-</ul>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/guidelines.txt
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/guidelines.txt	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/guidelines.txt	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,39 +0,0 @@
-// -*- HTML-Helper -*- guidelines.txt,v 1.4 2002/08/02 17:44:44 kitty Exp
- at page acexml_guides ACEXML Programming Guidelines
-<ul>
-  <li>A lot of class names under @c $(ACE_ROOT)/ACEXML/common do not
-      follow the naming convention suggested in ACE-guidelines.html.
-      The reason for that is because those classes were derived from
-      the SAX2 API and we would like to keep them as similar as
-      possible.
-  <li>Character encoding:  The default character encoding for ACEXML
-      can be set at compile time.   ACEXML uses UTF-8 encoding in most
-      platforms where <code>ACEXML_Char</code> maps to
-      <code>char</code> in this case.  When ACE is configured to use
-      <CODE>wchar</CODE> and <CODE>UNICODE</CODE>,  ACEXML uses UTF-16
-      encoding and <code>ACEXML_Char</code> maps to
-      <code>wchar_t</code>.  Notice that ACEXML assume
-      <code>sizeof (wchar_t)</code> is of 2-byte long.  For platforms
-      using 4-byte <code>wchar_t</code>, ACEXML will not work
-      correctly, but it should be trivial to fix.<p>
-  <li>Currently, there's only an example showing how to use the parser
-      under @c $(ACE_ROOT)/ACEXML/examples/SAXPrint/.
-  <li><b>(Not supported yet)</b> To develop a new validator, one must
-      create a DLL implementing
-      @c ACEXML_Attributes_Def_Builder, @c
-      ACEXML_Attribute_Def_Builder, @c ACEXML_Element_Def_Builder,
-      @c ACEXML_Validator, and @c ACEXML_DTD_Manager.  The DLL should
-      also export a traditional C function called @c
-      create_dtd_manager.  The XML parser itself should also be
-      modified to support and dynamically link with the new validator.
-      See @c $(ACE_ROOT)/ACEXML/parser/debug_validator/ for an example.
-</ul>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/parser_features.txt
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/parser_features.txt	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/parser_features.txt	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,25 +0,0 @@
-/**  -*- HTML-Helper -*- parser_features.txt,v 1.3 2002/08/02 17:44:44 kitty Exp
- at defgroup acexml_parser_features Configurable Special Features of ACEXML Parser
-There are special features in ACEXML Parser that can be
-activated/deactivated thru @c setFeature.  Likewise, whether a feature
-has been activated or not can be queried using @c getFeature.
- at sa ACEXML_XMLReader::setFeature
- at sa ACEXML_XMLReader::getFeature
-Here is a list of supported features:
-<OL>
-  <li> namespaces - When this feature is enabled, ACEXML parser allows
-  access by namespace qualified names.
-  <li> namespace_prefixes - Normally the list of attributes returned by the
-  parser will not contain attributes used as namespace declarations
-  (xmlns:foo="bar"). When this feature is enabled, the list of attributes
-  contains the namespace declarations also.
-</OL>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/readme.txt
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/readme.txt	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/docs/readme.txt	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,36 +0,0 @@
-/**  -*- HTML-Helper -*- readme.txt,v 1.2 2002/01/24 21:00:01 nanbor Exp
- at mainpage ACEXML - A Small and Portable XML Parser
- at section acexml_synopsis Synopsis
-ACEXML is a small footprint and portable framework for integrating XML
-parsing ability into user applications.  The framework is based on the
- <a href="http://www.saxproject.org/"> Simple API for XML
-(SAX 2.0) </A> by David Megginson.  A simple non-conformant XML parser
-is also included in the framework.  Since our original motivation was
-to use the parser for specifying software composition and
-configuration descriptors, at the current stage, the parser does not
-fully support all the features specified in the XML specification.
-We do, however, plan to add more features to the parser and will
-either release a more versatile parser or allow the current parser to
-dynamically load in the extra features in the future.
- at section acexml_features Features of ACEXML
-<ul>
-  <li> ACEXML only recognize UNICODE documents, although they can be
-  in various different encoding, such as UTF-8, UTF-16, or UCS-4.
-  Therefore, it might be a problem to handle document containing
-  multi-byte charatersets.  They can, however, be translated into
-  UNICODE before being parsed by ACEXML parser.
-</ul>
- at section acexml_others  Other Topics
-<ol>
-  <li>@ref acexml_parser_features
-  <li>@ref acexml_guides
-  <li>@ref acexml_bugs
-  <li>@ref acexml_todo
-</ol>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/Makefile.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/Makefile.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/Makefile.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,11 +0,0 @@
-# Makefile.bor,v 1.3 2003/12/20 14:21:14 jwillemsen Exp
-# Makefile for building the ACE XML examples
-DIRS = \
-        SAXPrint \
-        svcconf
-!include <$(ACE_ROOT)\include\makeinclude\recurse.bor>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Makefile
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Makefile	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Makefile	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,10 +0,0 @@
-# Makefile,v 1.13 2003/07/14 18:47:58 jwillemsen Exp
-#       GNU ACE Workspace
-include $(ACE_ROOT)/include/makeinclude/macros.GNU
-TARGETS_NESTED := $(TARGETS_NESTED:.nested=)
-$(TARGETS_NESTED):
-	@$(MAKE) -f Makefile.SAXPrint -C . $(@);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Makefile.SAXPrint
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Makefile.SAXPrint	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Makefile.SAXPrint	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,533 +0,0 @@
-#       GNU Makefile
-MAKEFILE        = Makefile.SAXPrint
-BIN_UNCHECKED   = SAXPrint
-FILES = \
-  main \
-  Print_Handler \
-  SAXPrint_Handler
-#       Include macros and targets
-ACE_SHLIBS = -lACE
-include $(ACE_ROOT)/include/makeinclude/wrapper_macros.GNU
-BIN    = $(BIN_UNCHECKED)
-OBJS   = $(addsuffix .o, $(notdir $(FILES)))
-SRC    = $(addsuffix .cpp, $(FILES))
-include $(ACE_ROOT)/include/makeinclude/rules.common.GNU
-include $(ACE_ROOT)/include/makeinclude/rules.nonested.GNU
-include $(ACE_ROOT)/include/makeinclude/rules.local.GNU
-CPPFLAGS     += -I../../..
-ifeq ($(static_libs),1)
-  ifneq ($(LIB),)
-    CPPFLAGS += -DACE_AS_STATIC_LIBS
-  endif
-endif
-LDFLAGS      += -L../../../ACEXML/common -L../../../ACEXML/parser/parser -L../../../ace
-LDLIBS  = -lACEXML_Parser -lACEXML
-#       Local targets
-$(BIN): $(addprefix $(VDIR), $(OBJS))
-	$(LINK.cc) $(LDFLAGS) $(CC_OUTPUT_FLAG) $@ $^ $(VLDLIBS) $(POSTLINK)
-realclean: clean
-ifneq ($(GENERATED_DIRTY),)
-	-$(RM) -r $(GENERATED_DIRTY)
-endif
-#       Dependencies
-# DO NOT DELETE THIS LINE -- g++dep uses it.
-# DO NOT PUT ANYTHING AFTER THIS LINE, IT WILL GO AWAY.
-.obj/main.o .obj/main.so .shobj/main.o .shobj/main.so: main.cpp \
-  $(ACE_ROOT)/ACEXML/common/FileCharStream.h \
-  $(ACE_ROOT)/ace/pre.h \
-  $(ACE_ROOT)/ACEXML/common/ACEXML_Export.h \
-  $(ACE_ROOT)/ace/config-all.h \
-  $(ACE_ROOT)/ace/config.h \
-  $(ACE_ROOT)/ace/$(ACE_PLATFORM_CONFIG) \
-  $(ACE_ROOT)/ace/post.h \
-  $(ACE_ROOT)/ace/ace_wchar.h \
-  $(ACE_ROOT)/ace/ace_wchar.inl \
-  $(ACE_ROOT)/ace/OS_main.h \
-  $(ACE_ROOT)/ace/ACE_export.h \
-  $(ACE_ROOT)/ACEXML/common/CharStream.h \
-  $(ACE_ROOT)/ACEXML/common/XML_Types.h \
-  $(ACE_ROOT)/ace/SString.h \
-  $(ACE_ROOT)/ace/SStringfwd.h \
-  $(ACE_ROOT)/ace/Basic_Types.h \
-  $(ACE_ROOT)/ace/os_include/os_limits.h \
-  $(ACE_ROOT)/ace/os_include/os_unistd.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_types.h \
-  $(ACE_ROOT)/ace/os_include/os_stddef.h \
-  $(ACE_ROOT)/ace/os_include/os_inttypes.h \
-  $(ACE_ROOT)/ace/os_include/os_stdint.h \
-  $(ACE_ROOT)/ace/os_include/os_stdio.h \
-  $(ACE_ROOT)/ace/os_include/os_stdarg.h \
-  $(ACE_ROOT)/ace/os_include/os_float.h \
-  $(ACE_ROOT)/ace/os_include/os_stdlib.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_wait.h \
-  $(ACE_ROOT)/ace/os_include/os_signal.h \
-  $(ACE_ROOT)/ace/os_include/os_time.h \
-  $(ACE_ROOT)/ace/os_include/os_ucontext.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_resource.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_time.h \
-  $(ACE_ROOT)/ace/String_Base.h \
-  $(ACE_ROOT)/ace/String_Base_Const.h \
-  $(ACE_ROOT)/ace/Global_Macros.h \
-  $(ACE_ROOT)/ace/OS_Errno.h \
-  $(ACE_ROOT)/ace/os_include/os_errno.h \
-  $(ACE_ROOT)/ace/String_Base.cpp \
-  $(ACE_ROOT)/ace/ACE.h \
-  $(ACE_ROOT)/ace/Flag_Manip.h \
-  $(ACE_ROOT)/ace/Flag_Manip.i \
-  $(ACE_ROOT)/ace/OS_NS_fcntl.h \
-  $(ACE_ROOT)/ace/os_include/os_fcntl.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_stat.h \
-  $(ACE_ROOT)/ace/Handle_Ops.h \
-  $(ACE_ROOT)/ace/Handle_Ops.i \
-  $(ACE_ROOT)/ace/Lib_Find.h \
-  $(ACE_ROOT)/ace/Lib_Find.i \
-  $(ACE_ROOT)/ace/Init_ACE.h \
-  $(ACE_ROOT)/ace/Init_ACE.i \
-  $(ACE_ROOT)/ace/Sock_Connect.h \
-  $(ACE_ROOT)/ace/os_include/netinet/os_in.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_socket.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_uio.h \
-  $(ACE_ROOT)/ace/Sock_Connect.i \
-  $(ACE_ROOT)/ace/Default_Constants.h \
-  $(ACE_ROOT)/ace/ACE.i \
-  $(ACE_ROOT)/ace/OS_NS_unistd.h \
-  $(ACE_ROOT)/ace/Time_Value.h \
-  $(ACE_ROOT)/ace/OS_NS_Thread.h \
-  $(ACE_ROOT)/ace/os_include/os_pthread.h \
-  $(ACE_ROOT)/ace/Base_Thread_Adapter.h \
-  $(ACE_ROOT)/ace/OS_Log_Msg_Attributes.h \
-  $(ACE_ROOT)/ace/iosfwd.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_sem.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_ipc.h \
-  $(ACE_ROOT)/ace/os_include/os_semaphore.h \
-  $(ACE_ROOT)/ace/OS_Memory.h \
-  $(ACE_ROOT)/ace/OS_NS_stdlib.h \
-  $(ACE_ROOT)/ace/OS_NS_signal.h \
-  $(ACE_ROOT)/ace/Object_Manager_Base.h \
-  $(ACE_ROOT)/ace/Cleanup.h \
-  $(ACE_ROOT)/ace/os_include/os_ctype.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_socket.h \
-  $(ACE_ROOT)/ace/os_include/net/os_if.h \
-  $(ACE_ROOT)/ace/OS_NS_stropts.h \
-  $(ACE_ROOT)/ace/os_include/os_stropts.h \
-  $(ACE_ROOT)/ace/Malloc_Base.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_mman.h \
-  $(ACE_ROOT)/ace/Auto_Ptr.h \
-  $(ACE_ROOT)/ace/Auto_Ptr.cpp \
-  $(ACE_ROOT)/ace/Auto_Ptr.i \
-  $(ACE_ROOT)/ace/OS_NS_string.h \
-  $(ACE_ROOT)/ace/String_Base.i \
-  $(ACE_ROOT)/ace/Min_Max.h \
-  $(ACE_ROOT)/ACEXML/common/Encoding.h \
-  $(ACE_ROOT)/ACEXML/common/HttpCharStream.h \
-  $(ACE_ROOT)/ACEXML/common/URL_Addr.h \
-  $(ACE_ROOT)/ace/INET_Addr.h \
-  $(ACE_ROOT)/ace/Addr.h \
-  $(ACE_ROOT)/ACEXML/common/Mem_Map_Stream.h \
-  $(ACE_ROOT)/ace/SOCK_Stream.h \
-  $(ACE_ROOT)/ace/SOCK_IO.h \
-  $(ACE_ROOT)/ace/SOCK.h \
-  $(ACE_ROOT)/ace/IPC_SAP.h \
-  $(ACE_ROOT)/ace/IPC_SAP.i \
-  $(ACE_ROOT)/ace/SOCK.i \
-  $(ACE_ROOT)/ace/SOCK_IO.i \
-  $(ACE_ROOT)/ace/SOCK_Stream.i \
-  $(ACE_ROOT)/ace/Mem_Map.h \
-  $(ACE_ROOT)/ace/SOCK_Connector.h \
-  $(ACE_ROOT)/ace/SOCK_Connector.i \
-  $(ACE_ROOT)/ace/Connector.h \
-  $(ACE_ROOT)/ace/Service_Object.h \
-  $(ACE_ROOT)/ace/Shared_Object.h \
-  $(ACE_ROOT)/ace/Svc_Conf_Tokens.h \
-  $(ACE_ROOT)/ace/Event_Handler.h \
-  $(ACE_ROOT)/ace/Atomic_Op.h \
-  $(ACE_ROOT)/ace/Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Atomic_Op_T.h \
-  $(ACE_ROOT)/ace/Atomic_Op_T.cpp \
-  $(ACE_ROOT)/ace/Log_Msg.h \
-  $(ACE_ROOT)/ace/Log_Priority.h \
-  $(ACE_ROOT)/ace/Atomic_Op_T.i \
-  $(ACE_ROOT)/ace/Guard_T.h \
-  $(ACE_ROOT)/ace/Lock.h \
-  $(ACE_ROOT)/ace/Guard_T.cpp \
-  $(ACE_ROOT)/ace/Guard_T.inl \
-  $(ACE_ROOT)/ace/RW_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/RW_Mutex.h \
-  $(ACE_ROOT)/ace/Synch_Traits.h \
-  $(ACE_ROOT)/ace/DLL.h \
-  $(ACE_ROOT)/ace/os_include/os_dlfcn.h \
-  $(ACE_ROOT)/ace/Strategies_T.h \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.h \
-  $(ACE_ROOT)/ace/Functor.h \
-  $(ACE_ROOT)/ace/Functor_T.h \
-  $(ACE_ROOT)/ace/Functor_T.cpp \
-  $(ACE_ROOT)/ace/Functor_T.i \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.cpp \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.i \
-  $(ACE_ROOT)/ace/Reactor.h \
-  $(ACE_ROOT)/ace/Timer_Queuefwd.h \
-  $(ACE_ROOT)/ace/Reactor_Timer_Interface.h \
-  $(ACE_ROOT)/ace/Thread_Manager.h \
-  $(ACE_ROOT)/ace/Thread.h \
-  $(ACE_ROOT)/ace/Thread_Adapter.h \
-  $(ACE_ROOT)/ace/Thread_Exit.h \
-  $(ACE_ROOT)/ace/Thread_Control.h \
-  $(ACE_ROOT)/ace/Condition_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Unbounded_Queue.h \
-  $(ACE_ROOT)/ace/Node.h \
-  $(ACE_ROOT)/ace/Node.cpp \
-  $(ACE_ROOT)/ace/Unbounded_Queue.cpp \
-  $(ACE_ROOT)/ace/Unbounded_Queue.inl \
-  $(ACE_ROOT)/ace/Containers.h \
-  $(ACE_ROOT)/ace/Containers_T.h \
-  $(ACE_ROOT)/ace/Array_Base.h \
-  $(ACE_ROOT)/ace/Array_Base.cpp \
-  $(ACE_ROOT)/ace/Array_Base.inl \
-  $(ACE_ROOT)/ace/Unbounded_Set.h \
-  $(ACE_ROOT)/ace/Unbounded_Set.cpp \
-  $(ACE_ROOT)/ace/Unbounded_Set.inl \
-  $(ACE_ROOT)/ace/Containers_T.cpp \
-  $(ACE_ROOT)/ace/Containers_T.i \
-  $(ACE_ROOT)/ace/Free_List.h \
-  $(ACE_ROOT)/ace/Free_List.cpp \
-  $(ACE_ROOT)/ace/Free_List.i \
-  $(ACE_ROOT)/ace/Singleton.h \
-  $(ACE_ROOT)/ace/TSS_T.h \
-  $(ACE_ROOT)/ace/TSS_T.cpp \
-  $(ACE_ROOT)/ace/TSS_T.inl \
-  $(ACE_ROOT)/ace/OS_NS_stdio.h \
-  $(ACE_ROOT)/ace/Singleton.cpp \
-  $(ACE_ROOT)/ace/Singleton.i \
-  $(ACE_ROOT)/ace/Object_Manager.h \
-  $(ACE_ROOT)/ace/Recursive_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Static_Object_Lock.h \
-  $(ACE_ROOT)/ace/Managed_Object.h \
-  $(ACE_ROOT)/ace/Managed_Object.cpp \
-  $(ACE_ROOT)/ace/Managed_Object.i \
-  $(ACE_ROOT)/ace/Framework_Component.h \
-  $(ACE_ROOT)/ace/Framework_Component_T.h \
-  $(ACE_ROOT)/ace/Framework_Component_T.cpp \
-  $(ACE_ROOT)/ace/Framework_Component_T.inl \
-  $(ACE_ROOT)/ace/Connection_Recycling_Strategy.h \
-  $(ACE_ROOT)/ace/Recyclable.h \
-  $(ACE_ROOT)/ace/Refcountable.h \
-  $(ACE_ROOT)/ace/Hashable.h \
-  $(ACE_ROOT)/ace/Reverse_Lock_T.h \
-  $(ACE_ROOT)/ace/Reverse_Lock_T.cpp \
-  $(ACE_ROOT)/ace/Reverse_Lock_T.inl \
-  $(ACE_ROOT)/ace/OS_NS_errno.h \
-  $(ACE_ROOT)/ace/Strategies_T.i \
-  $(ACE_ROOT)/ace/Strategies_T.cpp \
-  $(ACE_ROOT)/ace/Service_Repository.h \
-  $(ACE_ROOT)/ace/Service_Types.h \
-  $(ACE_ROOT)/ace/WFMO_Reactor.h \
-  $(ACE_ROOT)/ace/Synch_Options.h \
-  $(ACE_ROOT)/ace/Handle_Set.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_select.h \
-  $(ACE_ROOT)/ace/Connector.cpp \
-  $(ACE_ROOT)/ace/Svc_Handler.h \
-  $(ACE_ROOT)/ace/Task.h \
-  $(ACE_ROOT)/ace/Task_T.h \
-  $(ACE_ROOT)/ace/Message_Queue.h \
-  $(ACE_ROOT)/ace/Message_Block.h \
-  $(ACE_ROOT)/ace/Message_Block_T.h \
-  $(ACE_ROOT)/ace/Message_Block_T.cpp \
-  $(ACE_ROOT)/ace/Message_Block_T.i \
-  $(ACE_ROOT)/ace/IO_Cntl_Msg.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.cpp \
-  $(ACE_ROOT)/ace/OS_NS_sys_time.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.i \
-  $(ACE_ROOT)/ace/Notification_Strategy.h \
-  $(ACE_ROOT)/ace/Task_T.cpp \
-  $(ACE_ROOT)/ace/Module.h \
-  $(ACE_ROOT)/ace/os_include/os_dirent.h \
-  $(ACE_ROOT)/ace/Module.cpp \
-  $(ACE_ROOT)/ace/Stream_Modules.h \
-  $(ACE_ROOT)/ace/Stream_Modules.cpp \
-  $(ACE_ROOT)/ace/Module.i \
-  $(ACE_ROOT)/ace/Null_Condition.h \
-  $(ACE_ROOT)/ace/Null_Mutex.h \
-  $(ACE_ROOT)/ace/Task_T.i \
-  $(ACE_ROOT)/ace/os_include/os_assert.h \
-  $(ACE_ROOT)/ace/Service_Config.h \
-  $(ACE_ROOT)/ace/XML_Svc_Conf.h \
-  $(ACE_ROOT)/ace/Svc_Handler.cpp \
-  $(ACE_ROOT)/ace/Dynamic.h \
-  $(ACE_ROOT)/ACEXML/common/StrCharStream.h \
-  $(ACE_ROOT)/ACEXML/common/ZipCharStream.h \
-  $(ACE_ROOT)/ACEXML/parser/parser/Parser.h \
-  $(ACE_ROOT)/ACEXML/parser/parser/Parser_export.h \
-  $(ACE_ROOT)/ACEXML/common/XMLReader.h \
-  $(ACE_ROOT)/ACEXML/common/ContentHandler.h \
-  $(ACE_ROOT)/ACEXML/common/Env.h \
-  $(ACE_ROOT)/ACEXML/common/XML_Macros.h \
-  $(ACE_ROOT)/ace/Exception_Macros.h \
-  $(ACE_ROOT)/ACEXML/common/Exception.h \
-  $(ACE_ROOT)/ACEXML/common/SAXExceptions.h \
-  $(ACE_ROOT)/ACEXML/common/Locator.h \
-  $(ACE_ROOT)/ACEXML/common/Attributes.h \
-  $(ACE_ROOT)/ACEXML/common/DTDHandler.h \
-  $(ACE_ROOT)/ACEXML/common/EntityResolver.h \
-  $(ACE_ROOT)/ACEXML/common/InputSource.h \
-  $(ACE_ROOT)/ACEXML/common/ErrorHandler.h \
-  $(ACE_ROOT)/ACEXML/common/LocatorImpl.h \
-  $(ACE_ROOT)/ACEXML/common/NamespaceSupport.h \
-  $(ACE_ROOT)/ace/Hash_Map_Manager.h \
-  $(ACE_ROOT)/ace/Obstack.h \
-  $(ACE_ROOT)/ace/Obstack_T.h \
-  $(ACE_ROOT)/ace/Obchunk.h \
-  $(ACE_ROOT)/ace/Malloc.h \
-  $(ACE_ROOT)/ace/Malloc_T.h \
-  $(ACE_ROOT)/ace/Malloc_Allocator.h \
-  $(ACE_ROOT)/ace/Malloc_T.cpp \
-  $(ACE_ROOT)/ace/Malloc_T.i \
-  $(ACE_ROOT)/ace/Memory_Pool.h \
-  $(ACE_ROOT)/ace/Signal.h \
-  $(ACE_ROOT)/ace/SV_Semaphore_Complex.h \
-  $(ACE_ROOT)/ace/SV_Semaphore_Simple.h \
-  $(ACE_ROOT)/ace/SV_Semaphore_Simple.i \
-  $(ACE_ROOT)/ace/SV_Semaphore_Complex.i \
-  $(ACE_ROOT)/ace/Obstack_T.cpp \
-  $(ACE_ROOT)/ace/Obstack_T.i \
-  $(ACE_ROOT)/ACEXML/parser/parser/Entity_Manager.h \
-  $(ACE_ROOT)/ACEXML/parser/parser/ParserInternals.h \
-  $(ACE_ROOT)/ACEXML/parser/parser/ParserContext.h \
-  $(ACE_ROOT)/ace/Swap.h \
-  $(ACE_ROOT)/ace/Swap.cpp \
-  $(ACE_ROOT)/ace/Swap.inl Print_Handler.h \
-  $(ACE_ROOT)/ACEXML/common/DefaultHandler.h \
-  SAXPrint_Handler.h $(ACE_ROOT)/ace/Get_Opt.h
-.obj/Print_Handler.o .obj/Print_Handler.so .shobj/Print_Handler.o .shobj/Print_Handler.so: Print_Handler.cpp Print_Handler.h \
-  $(ACE_ROOT)/ace/Log_Priority.h Print_Handler.i
-.obj/SAXPrint_Handler.o .obj/SAXPrint_Handler.so .shobj/SAXPrint_Handler.o .shobj/SAXPrint_Handler.so: SAXPrint_Handler.cpp SAXPrint_Handler.h \
-  SAXPrint_Handler.i
-# IF YOU PUT ANYTHING HERE IT WILL GO AWAY
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Makefile.SAXPrint.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Makefile.SAXPrint.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Makefile.SAXPrint.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,58 +0,0 @@
-# Makefile.SAXPrint.bor,v 1.3 2003/12/20 14:21:14 jwillemsen Exp
-# Makefile for building the SAXPrint exe with Borland C++ Builder
-NAME = SAXPrint
-NAME = SAXPrint
-OBJFILES = \
-	$(OBJDIR)\Print_Handler.obj \
-	$(OBJDIR)\SAXPrint_Handler.obj \
-	$(OBJDIR)\main.obj
-EXTERNAL_LIBS = \
-LFLAGS = \
-	-j..\..\..\ACEXML\common\$(CONFIG_SUBDIR) -j..\..\..\ACEXML\common \
-	-L..\..\..\ACEXML\common\$(CONFIG_SUBDIR) -L..\..\..\ACEXML\common \
-	-j..\..\..\ACEXML\parser\parser\$(CONFIG_SUBDIR) -j..\..\..\ACEXML\parser\parser \
-	-L..\..\..\ACEXML\parser\parser\$(CONFIG_SUBDIR) -L..\..\..\ACEXML\parser\parser \
-	-j..\..\..\ace\$(CONFIG_SUBDIR) -j..\..\..\ace \
-	-L..\..\..\ace\$(CONFIG_SUBDIR) -L..\..\..\ace \
-  -j$(CORE_BINDIR) \
-  -L$(CORE_BINDIR)
-LIBFILES = \
-	ACEXML_Parser$(LIB_DECORATOR).lib \
-	ACEXML$(LIB_DECORATOR).lib \
-	ACE$(LIB_DECORATOR).lib \
-	$(EXTERNAL_LIBS)
-!ifdef STATIC
-LIB_FLAGS = -DACE_AS_STATIC_LIBS
-DLL_FLAGS =
-!else
-LIB_FLAGS =
-DLL_FLAGS =
-!endif
-CFLAGS = \
-	-I..\..\.. \
-	$(LIB_FLAGS) \
-	$(DLL_FLAGS)
-CPPDIR = .
-INCLUDES = \
-	Print_Handler.h \
-	SAXPrint_Handler.h \
-	Print_Handler.i \
-!include <$(ACE_ROOT)\include\makeinclude\build_exe.bor>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Makefile.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Makefile.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Makefile.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,23 +0,0 @@
-# Makefile.bor,v 1.4 2003/12/20 14:21:14 jwillemsen Exp
-#       Borland Workspace
-!include <$(ACE_ROOT)\include\makeinclude\make_flags.bor>
-all:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.SAXPrint.bor all
-clean:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.SAXPrint.bor clean
-realclean:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.SAXPrint.bor realclean
-install:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.SAXPrint.bor install
-regenerate:
-	/usr/bin/perl /build/kitty/ACE_wrappers/bin/mwc.pl -type borland ACEXML.mwc
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Print_Handler.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Print_Handler.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Print_Handler.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,258 +0,0 @@
-// -*- C++ -*-  Print_Handler.cpp,v 1.9 2003/05/30 03:31:48 kitty Exp
-#include "Print_Handler.h"
-#include "ace/Log_Msg.h"
-#if !defined (__ACEXML_INLINE__)
-# include "Print_Handler.i"
-ACEXML_Print_Handler::ACEXML_Print_Handler (ACEXML_Char* fileName)
-  : fileName_(ACE::strnew (fileName))
-ACEXML_Print_Handler::~ACEXML_Print_Handler (void)
-  delete[] this->fileName_;
-void
-ACEXML_Print_Handler::characters (const ACEXML_Char *cdata,
-                                  int start,
-                                  int length ACEXML_ENV_ARG_DECL_NOT_USED)
-  ACE_DEBUG ((LM_DEBUG,
-              ACE_TEXT ("* Event characters () ** start: %d  end: %d ***************\n%s\n- End event characters () ---------------\n"),
-              start, length, cdata));
-void
-ACEXML_Print_Handler::endDocument (ACEXML_ENV_SINGLE_ARG_DECL_NOT_USED)
-              ACE_TEXT ("* Event endDocument () ***************\n")));
-void
-ACEXML_Print_Handler::endElement (const ACEXML_Char *uri,
-                                  const ACEXML_Char *name,
-                                  const ACEXML_Char *qName
-                                  ACEXML_ENV_ARG_DECL_NOT_USED)
-              ACE_TEXT ("* Event endElement (%s, %s, %s) ***************\n"),
-              uri, name, qName));
-void
-ACEXML_Print_Handler::endPrefixMapping (const ACEXML_Char *prefix
-              ACE_TEXT ("* Event endPrefixMapping (%s) ***************\n"),
-              prefix));
-void
-ACEXML_Print_Handler::ignorableWhitespace (const ACEXML_Char *,
-                                           int,
-                                           int
-  //               ACE_TEXT ("* Event ignorableWhitespace () ***************\n")));
-void
-ACEXML_Print_Handler::processingInstruction (const ACEXML_Char *target,
-                                             const ACEXML_Char *data
-              ACE_TEXT ("* Event processingInstruction (%s, %s) ***************\n"),
-              target, data));
-void
-ACEXML_Print_Handler::setDocumentLocator (ACEXML_Locator * locator)
-  this->locator_ = locator;
-  // ACE_DEBUG ((LM_DEBUG, ACE_TEXT ("* Event setDocumentLocator () ***************\n")));
-void
-ACEXML_Print_Handler::skippedEntity (const ACEXML_Char *name
-              ACE_TEXT ("* Event skippedEntity (%s) ***************\n"),
-              name));
-void
-ACEXML_Print_Handler::startDocument (ACEXML_ENV_SINGLE_ARG_DECL_NOT_USED)
-              ACE_TEXT ("* Event startDocument () ***************\n")));
-void
-ACEXML_Print_Handler::startElement (const ACEXML_Char *uri,
-                                    const ACEXML_Char *qName,
-                                    ACEXML_Attributes *alist
-              ACE_TEXT ("* Event startElement (%s, %s, %s) ***************\n"),
-  if (alist != 0)
-    for (size_t i = 0; i < alist->getLength (); ++i)
-                    ACE_TEXT ("    %s = \"%s\"\n"),
-                    alist->getQName (i), alist->getValue (i)));
-void
-ACEXML_Print_Handler::startPrefixMapping (const ACEXML_Char * prefix,
-                                          const ACEXML_Char * uri ACEXML_ENV_ARG_DECL_NOT_USED)
-              ACE_TEXT ("* Event startPrefixMapping () ***************\n")));
-              ACE_TEXT ("Prefix = %s, URI = %s\n"), prefix, uri));
-// *** Methods inherit from ACEXML_DTDHandler.
-void
-ACEXML_Print_Handler::notationDecl (const ACEXML_Char *name,
-                                    const ACEXML_Char *publicID,
-                                    const ACEXML_Char *systemID ACEXML_ENV_ARG_DECL_NOT_USED)
-              ACE_TEXT ("* Event notationDecl: (%s) "),
-              name));
-  if (publicID == 0)
-                ACE_TEXT ("SYSTEM %s\n"),
-                systemID));
-  else if (systemID == 0)
-                ACE_TEXT ("PUBLIC %s\n"),
-                publicID));
-  else
-                ACE_TEXT ("PUBLIC %s %s\n"),
-                publicID, systemID));
-void
-ACEXML_Print_Handler::unparsedEntityDecl (const ACEXML_Char *name,
-                                          const ACEXML_Char *systemID,
-                                          const ACEXML_Char *notationName ACEXML_ENV_ARG_DECL_NOT_USED)
-              ACE_TEXT ("* Unparsed Entity: %s"),
-              name));
-                ACE_TEXT (" SYSTEM %s"),
-                systemID));
-  else
-                ACE_TEXT (" PUBLIC %s %s"),
-              ACE_TEXT (" NDATA %s\n"),
-              notationName));
-// Methods inherit from ACEXML_EnitityResolver.
-ACEXML_InputSource *
-ACEXML_Print_Handler::resolveEntity (const ACEXML_Char *,
-                                     const ACEXML_Char * ACEXML_ENV_ARG_DECL_NOT_USED)
-  // No-op.
-  return 0;
-// Methods inherit from ACEXML_ErrorHandler.
-void
-ACEXML_Print_Handler::error (ACEXML_SAXParseException & ex ACEXML_ENV_ARG_DECL_NOT_USED)
-  ACE_DEBUG ((LM_DEBUG, "%s: line: %d col: %d ",
-              (this->locator_->getSystemId() == 0 ? this->fileName_ : this->locator_->getSystemId()),
-              this->locator_->getLineNumber(),
-              this->locator_->getColumnNumber()));
-  ex.print();
-void
-ACEXML_Print_Handler::fatalError (ACEXML_SAXParseException& ex ACEXML_ENV_ARG_DECL_NOT_USED)
-  ex.print();
-void
-ACEXML_Print_Handler::warning (ACEXML_SAXParseException & ex ACEXML_ENV_ARG_DECL_NOT_USED)
-  ex.print();
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Print_Handler.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Print_Handler.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Print_Handler.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,187 +0,0 @@
-// Print_Handler.h,v 1.5 2002/10/13 03:58:57 kitty Exp
- *  @file    Print_Handler.h
- *  Print_Handler.h,v 1.5 2002/10/13 03:58:57 kitty Exp
-#ifndef ACEXML_PRINT_HANDLER_H
-#define ACEXML_PRINT_HANDLER_H
-#include "ACEXML/common/DefaultHandler.h"
- * @class ACEXML_Print_Handler
- * @brief ACEXML_Print_Handler is an example SAX event handler.
- * This SAX event handler prints out a detailed event report
- * on every event it receives.
-class ACEXML_Print_Handler : public ACEXML_DefaultHandler
-public:
-   * Default constructor.
-  ACEXML_Print_Handler (ACEXML_Char* fileName);
-   * Default destructor.
-  virtual ~ACEXML_Print_Handler (void);
-  // Methods inherited from ACEXML_ContentHandler.
-                           int start,
-                           int length ACEXML_ENV_ARG_DECL)
-                           const ACEXML_Char *localName,
-                           const ACEXML_Char *qName ACEXML_ENV_ARG_DECL)
-                                    int start,
-                                      const ACEXML_Char *data ACEXML_ENV_ARG_DECL)
-                             ACEXML_Attributes *atts ACEXML_ENV_ARG_DECL)
-                                   const ACEXML_Char *uri ACEXML_ENV_ARG_DECL)
-                             const ACEXML_Char *publicId,
-                             const ACEXML_Char *systemId ACEXML_ENV_ARG_DECL)
-                                   const ACEXML_Char *systemId,
-                                   const ACEXML_Char *notationName ACEXML_ENV_ARG_DECL)
-private:
-  ACEXML_Char* fileName_;
-  ACEXML_Locator* locator_;
-#endif /* ACEXML_PRINT_HANDLER_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Print_Handler.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Print_Handler.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/Print_Handler.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1 +0,0 @@
-// -*- C++ -*-  Print_Handler.i,v 1.2 2002/01/24 21:00:01 nanbor Exp
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint.dsp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint.dsp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint.dsp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,109 +0,0 @@
-# Microsoft Developer Studio Project File - Name="SAXPrint EXE" - Package Owner=<4>
-# Microsoft Developer Studio Generated Build File, Format Version 6.00
-# ** DO NOT EDIT **
-# TARGTYPE "Win32 (x86) Console Application" 0x0103
-CFG=SAXPrint EXE - Win32 Debug
-!MESSAGE This is not a valid makefile. To build this project using NMAKE,
-!MESSAGE run the tool that generated this project file and specify the
-!MESSAGE nmake output type.  You can then use the following command:
-!MESSAGE
-!MESSAGE NMAKE /f "SAXPrint.mak".
-!MESSAGE
-!MESSAGE You can specify a configuration when running NMAKE
-!MESSAGE by defining the macro CFG on the command line. For example:
-!MESSAGE
-!MESSAGE NMAKE /f "SAXPrint.mak" CFG="SAXPrint EXE - Win32 Debug"
-!MESSAGE
-!MESSAGE Possible choices for configuration are:
-!MESSAGE
-!MESSAGE "SAXPrint EXE - Win32 Release" (based on "Win32 (x86) Console Application")
-!MESSAGE "SAXPrint EXE - Win32 Debug" (based on "Win32 (x86) Console Application")
-!MESSAGE
-# Begin Project
-# PROP AllowPerConfigDependencies 0
-# PROP Scc_ProjName ""
-# PROP Scc_LocalPath ""
-CPP=cl.exe
-RSC=rc.exe
-!IF  "$(CFG)" == "SAXPrint EXE - Win32 Release"
-# PROP Use_MFC 0
-# PROP Use_Debug_Libraries 0
-# PROP Output_Dir "Release"
-# PROP Intermediate_Dir "Release\SAXPrint"
-# PROP Target_Dir ""
-# ADD CPP /nologo /W3 /GX /O2 /MD /GR /I "..\..\.." /D NDEBUG=1 /D WIN32=1 /D _CONSOLE=1 /FD /c
-# SUBTRACT CPP /YX
-# ADD RSC /l 0x409 /d NDEBUG=1 /i "..\..\.."
-BSC32=bscmake.exe
-# ADD BSC32 /nologo
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACEXML_Parser.lib ACEXML.lib ACE.lib /libpath:"..\..\..\ACEXML\common" /libpath:"..\..\..\ACEXML\parser\parser" /libpath:"..\..\..\ace" /nologo /version:5.3.1 /subsystem:console /pdb:"Release\SAXPrint.pdb"  /machine:I386 /out:"Release\SAXPrint.exe"
-!ELSEIF  "$(CFG)" == "SAXPrint EXE - Win32 Debug"
-# PROP Use_MFC 0
-# PROP Use_Debug_Libraries 1
-# PROP Output_Dir "."
-# PROP Intermediate_Dir "Debug\SAXPrint"
-# ADD CPP /nologo /W3 /Gm /GX /Zi /Od /MDd /GR /Gy /I "..\..\.." /D _DEBUG=1 /D WIN32=1 /D _CONSOLE=1 /FD /c
-# SUBTRACT CPP /YX
-# ADD RSC /l 0x409 /d _DEBUG=1 /i "..\..\.."
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACEXML_Parserd.lib ACEXMLd.lib ACEd.lib /libpath:"..\..\..\ACEXML\common" /libpath:"..\..\..\ACEXML\parser\parser" /libpath:"..\..\..\ace" /nologo /version:5.3.1 /subsystem:console /pdb:".\SAXPrint.pdb" /debug /machine:I386 /out:".\SAXPrint.exe"
-!ENDIF
-# Begin Target
-# Name "SAXPrint EXE - Win32 Release"
-# Name "SAXPrint EXE - Win32 Debug"
-# Begin Group "Source Files"
-# PROP Default_Filter "cpp;cxx;c"
-# Begin Source File
-SOURCE=.\main.cpp
-# End Source File
-SOURCE=.\Print_Handler.cpp
-# End Source File
-SOURCE=.\SAXPrint_Handler.cpp
-# End Source File
-# End Group
-# Begin Group "Header Files"
-# PROP Default_Filter "h;hpp;hxx;hh"
-SOURCE=.\Print_Handler.h
-# End Source File
-SOURCE=.\SAXPrint_Handler.h
-# End Source File
-# End Group
-# Begin Group "Inline Files"
-# PROP Default_Filter "i;inl"
-SOURCE=.\Print_Handler.i
-# End Source File
-SOURCE=.\SAXPrint_Handler.i
-# End Source File
-# End Group
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint.dsw
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint.dsw	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint.dsw	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,29 +0,0 @@
-Microsoft Developer Studio Workspace File, Format Version 6.00
-# WARNING: DO NOT EDIT OR DELETE THIS WORKSPACE FILE!
-Project: "SAXPrint"=.\SAXPrint.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Global:
-Package=<5>
-Package=<3>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint.mpc
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint.mpc	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint.mpc	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,6 +0,0 @@
-//  -*- MPC -*-
-// SAXPrint.mpc,v 1.3 2003/11/10 04:31:58 dhinton Exp
-project(SAXPrint): aceexe, acexml {
-    exename = SAXPrint
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint_Handler.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint_Handler.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint_Handler.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,244 +0,0 @@
-// -*- C++ -*-  SAXPrint_Handler.cpp,v 1.9 2003/05/30 04:14:01 kitty Exp
-#include "SAXPrint_Handler.h"
-# include "SAXPrint_Handler.i"
-#endif /* __ACEXML_INLINE__ */
-ACEXML_SAXPrint_Handler::ACEXML_SAXPrint_Handler (const ACEXML_Char* filename)
-  : indent_ (0),  fileName_(ACE::strnew (filename)), locator_ (0)
-  // no-op
-ACEXML_SAXPrint_Handler::~ACEXML_SAXPrint_Handler (void)
-  delete [] this->fileName_;
-void
-ACEXML_SAXPrint_Handler::characters (const ACEXML_Char *cdata,
-                                     int start,
-  ACE_THROW_SPEC ((ACEXML_SAXException))
-  ACE_UNUSED_ARG (start);
-  ACE_UNUSED_ARG (length);
-              ACE_TEXT ("%s"),
-              cdata));
-void
-ACEXML_SAXPrint_Handler::endDocument (ACEXML_ENV_SINGLE_ARG_DECL_NOT_USED)
-  ACE_DEBUG ((LM_DEBUG, ACE_TEXT ("\n")));
-void
-ACEXML_SAXPrint_Handler::endElement (const ACEXML_Char *,
-                                     const ACEXML_Char *,
-  this->dec_indent ();
-  this->print_indent ();
-              ACE_TEXT ("</%s>"),
-              qName));
-void
-ACEXML_SAXPrint_Handler::endPrefixMapping (const ACEXML_Char *
-//   ACE_DEBUG ((LM_DEBUG,
-//               ACE_TEXT ("* Event endPrefixMapping (%s) ***************\n"),
-//               prefix));
-void
-ACEXML_SAXPrint_Handler::ignorableWhitespace (const ACEXML_Char * cdata,
-                                              int,
-                                              int ACEXML_ENV_ARG_DECL_NOT_USED)
-              ACE_TEXT ("%s"),
-              cdata));
-void
-ACEXML_SAXPrint_Handler::processingInstruction (const ACEXML_Char *target,
-              ACE_TEXT ("<?%s %s>\n"),
-              target, data));
-void
-ACEXML_SAXPrint_Handler::setDocumentLocator (ACEXML_Locator * locator)
-  //ACE_DEBUG ((LM_DEBUG, ACE_TEXT ("* Event setDocumentLocator () ***************\n")));
-void
-ACEXML_SAXPrint_Handler::skippedEntity (const ACEXML_Char *name
-              name));
-void
-ACEXML_SAXPrint_Handler::startDocument (ACEXML_ENV_SINGLE_ARG_DECL_NOT_USED)
-void
-ACEXML_SAXPrint_Handler::startElement (const ACEXML_Char *,
-  ACE_DEBUG ((LM_DEBUG, ACE_TEXT ("<%s"),
-              qName));
-  if (alist != 0)
-                    ACE_TEXT (" %s = \"%s\""),
-  ACE_DEBUG ((LM_DEBUG, ACE_TEXT (">")));
-  this->inc_indent ();
-void
-ACEXML_SAXPrint_Handler::startPrefixMapping (const ACEXML_Char * ,
-//               ACE_TEXT ("* Event startPrefixMapping () ***************\n")));
-//               ACE_TEXT ("Prefix = %s, URI = %s\n"), prefix, uri));
-// *** Methods inherited from ACEXML_DTDHandler.
-void
-ACEXML_SAXPrint_Handler::notationDecl (const ACEXML_Char *,
-  // No-op.
-void
-ACEXML_SAXPrint_Handler::unparsedEntityDecl (const ACEXML_Char *,
-  // No-op.
-// Methods inherited from ACEXML_EnitityResolver.
-ACEXML_SAXPrint_Handler::resolveEntity (const ACEXML_Char *,
-  // No-op.
-  return 0;
-// Methods inherited from ACEXML_ErrorHandler.
- * Receive notification of a recoverable error.
-void
-ACEXML_SAXPrint_Handler::error (ACEXML_SAXParseException & ex
-  ex.print();
-void
-ACEXML_SAXPrint_Handler::fatalError (ACEXML_SAXParseException & ex
-  ex.print();
-void
-ACEXML_SAXPrint_Handler::warning (ACEXML_SAXParseException & ex
-  ex.print();
-void
-ACEXML_SAXPrint_Handler::print_indent (void)
-  for (size_t i = 0; i < this->indent_; ++i)
-    ACE_DEBUG ((LM_DEBUG, ACE_TEXT ("  ")));
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint_Handler.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint_Handler.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint_Handler.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,195 +0,0 @@
-// SAXPrint_Handler.h,v 1.5 2002/10/13 03:58:57 kitty Exp
- *  @file    SAXPrint_Handler.h
- *  SAXPrint_Handler.h,v 1.5 2002/10/13 03:58:57 kitty Exp
-#ifndef ACEXML_SAXPRINT_HANDLER_H
-#define ACEXML_SAXPRINT_HANDLER_H
- * @class ACEXML_SAXPrint_Handler
- * @brief ACEXML_SAXPrint_Handler is an example SAX event handler.
- * This SAX event handler try to regenerate the XML document it
- * reads with correct indentation.
-class ACEXML_SAXPrint_Handler : public ACEXML_DefaultHandler
-public:
-  ACEXML_SAXPrint_Handler (const ACEXML_Char* name);
-  virtual ~ACEXML_SAXPrint_Handler (void);
-  // Methods inherit from ACEXML_ContentHandler.
-   * Receive notification of character data.
-  virtual void characters (const ACEXML_Char *ch,
-                           int start,
-   * Receive notification of the end of a document.
-  virtual void endDocument (ACEXML_ENV_SINGLE_ARG_DECL)
-   * Receive notification of the end of an element.
-  virtual void endElement (const ACEXML_Char *namespaceURI,
-   * End the scope of a prefix-URI mapping.
-  virtual void endPrefixMapping (const ACEXML_Char *prefix ACEXML_ENV_ARG_DECL)
-   * Receive notification of ignorable whitespace in element content.
-  virtual void ignorableWhitespace (const ACEXML_Char *ch,
-                                    int start,
-   * Receive notification of a processing instruction.
-  virtual void processingInstruction (const ACEXML_Char *target,
-   * Receive an object for locating the origin of SAX document events.
-  virtual void setDocumentLocator (ACEXML_Locator *locator) ;
-   * Receive notification of a skipped entity.
-  virtual void skippedEntity (const ACEXML_Char *name ACEXML_ENV_ARG_DECL)
-   * Receive notification of the beginning of a document.
-  virtual void startDocument (ACEXML_ENV_SINGLE_ARG_DECL)
-   * Receive notification of the beginning of an element.
-  virtual void startElement (const ACEXML_Char *namespaceURI,
-   * Begin the scope of a prefix-URI Namespace mapping.
-  virtual void startPrefixMapping (const ACEXML_Char *prefix,
-  // *** Methods inherit from ACEXML_DTDHandler.
-   * Receive notification of a notation declaration event.
-  virtual void notationDecl (const ACEXML_Char *name,
-   * Receive notification of an unparsed entity declaration event.
-  virtual void unparsedEntityDecl (const ACEXML_Char *name,
-  // Methods inherit from ACEXML_EnitityResolver.
-   * Allow the application to resolve external entities.
-  virtual ACEXML_InputSource *resolveEntity (const ACEXML_Char *publicId,
-  // Methods inherit from ACEXML_ErrorHandler.
-  virtual void error (ACEXML_SAXParseException &exception ACEXML_ENV_ARG_DECL)
-   * Receive notification of a non-recoverable error.
-  virtual void fatalError (ACEXML_SAXParseException &exception ACEXML_ENV_ARG_DECL)
-   * Receive notification of a warning.
-  virtual void warning (ACEXML_SAXParseException &exception ACEXML_ENV_ARG_DECL)
-  void inc_indent ();
-  void dec_indent ();
-  void print_indent ();
-private:
-  size_t indent_;
-#if defined (__ACEXML_INLINE__)
-#endif /* ACEXML_SAXPRINT_HANDLER_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint_Handler.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint_Handler.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/SAXPrint_Handler.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,13 +0,0 @@
-// -*- C++ -*-  SAXPrint_Handler.i,v 1.2 2002/01/24 21:00:01 nanbor Exp
-ACEXML_INLINE void
-ACEXML_SAXPrint_Handler::inc_indent (void)
-  this->indent_ += 1;
-ACEXML_INLINE void
-ACEXML_SAXPrint_Handler::dec_indent (void)
-  this->indent_ -= 1;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/broken.xml
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/broken.xml	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/broken.xml	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,5 +0,0 @@
-<?xml version="1.0"?>
-<!-- This is a broken XML file.  Most of the stuff here don't make any sense at all -->
-<root>
-  <child> kid </child>
\ No newline at end of file
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/main.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/main.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/main.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,204 +0,0 @@
-// main.cpp,v 1.21 2004/01/09 00:50:35 kitty Exp
-#include "ACEXML/common/FileCharStream.h"
-#include "ACEXML/common/HttpCharStream.h"
-#include "ACEXML/common/StrCharStream.h"
-#include "ACEXML/common/ZipCharStream.h"
-#include "ACEXML/parser/parser/Parser.h"
-#include "ace/Get_Opt.h"
-#include "ace/Auto_Ptr.h"
-#include "ace/OS_main.h"
-static const ACEXML_Char *test_string =
-ACE_TEXT ("<?xml version='1.0'?> <ACE_Svc_Conf> <static id=\"ACE_Service_Manager\" params='-d -p 4911'/> <dynamic id=\"Test_Task\" type=\"service_object\"> &#65; &quot; <initializer path=\"CCM_App\" init='_make_Test_Task' params='-p 3000'/> </dynamic> </ACE_Svc_Conf>");
-static void
-usage (const ACE_TCHAR* program)
-  ACE_ERROR ((LM_ERROR,
-              ACE_TEXT ("Usage: %s [-sl] [-f <filename> | -u <url> | -z <ZIP Archive>]\n")
-              ACE_TEXT ("  -s: Use SAXPrint_Handler (Default is Print_Handler)\n")
-              ACE_TEXT ("  -l: Parse the internal strings (test the StrCharStream class)\n")
-              ACE_TEXT ("  -f: Specify the filename when -l is not specified\n")
-              ACE_TEXT ("  -z: Specify that the file is inside a ZIP archive\n")
-              ACE_TEXT ("  -u: URL specifying the path to the file\n"),
-              program));
-int
-ACE_TMAIN (int argc, ACE_TCHAR *argv[])
-  ACEXML_Char* filename = 0;
-  int sax = 0;                  // Use SAXPrint handler or not.
-  int str = 0;
-  int zip = 0;
-  ACEXML_Char* url = 0;
-  ACE_Get_Opt get_opt (argc, argv, ACE_TEXT ("sf:lu:z"));
-  int c;
-  while ((c = get_opt ()) != EOF)
-      switch (c)
-          case 's':
-            sax = 1;
-            break;
-          case 'l':
-            str = 1;
-            break;
-          case 'f':
-            filename = get_opt.opt_arg ();
-            break;
-          case 'u':
-            url = get_opt.opt_arg();
-            break;
-          case 'z':
-            zip = 1;
-#ifndef ACEXML_HAS_ZZIPLIB
-            ACE_ERROR ((LM_ERROR, ACE_TEXT ("ZZIPLIB support has not been")
-                        ACE_TEXT (" compiled in. Refer to ")
-                        ACE_TEXT ("$ACE_ROOT/ACEXML/README for more ")
-                        ACE_TEXT ("information. \n")));
-            return -1;
-            break;
-          default:
-            usage(argv[0]);
-            return -1;
-  if (str == 0 && filename == 0 && url == 0) {
-    usage(argv[0]);
-    return -1;
-  ACEXML_DefaultHandler *handler = 0;
-  ACEXML_CharStream *stm = 0;
-  ACEXML_FileCharStream *fstm = 0;
-  ACEXML_HttpCharStream *ustm = 0;
-  ACEXML_StrCharStream* sstm = 0;
-  ACEXML_ZipCharStream* zstm = 0;
-  if (filename != 0)
-      if (zip)
-          ACE_NEW_RETURN (zstm, ACEXML_ZipCharStream(), -1);
-          if (zstm->open (filename) != 0)
-            ACE_ERROR_RETURN ((LM_ERROR,
-                               ACE_TEXT ("Failed to open XML file: %s\n"),
-                               filename),
-                              -1);
-          stm = zstm;
-      else
-          ACE_NEW_RETURN (fstm, ACEXML_FileCharStream (), -1);
-          if (fstm->open (filename) != 0)
-                               filename),
-                              -1);
-          stm = fstm;
-  else if (url != 0)
-      ACE_NEW_RETURN (ustm, ACEXML_HttpCharStream (), -1);
-      if (ustm->open (url) != 0)
-                           ACE_TEXT ("Failed to open URL : %s\n"),
-                           url),
-                          -1);
-      stm = ustm;
-  else
-      ACE_NEW_RETURN (sstm, ACEXML_StrCharStream, -1);
-      if (sstm->open (test_string, ACE_TEXT ("test_string")) < 0)
-                           ACE_TEXT ("Failed to open string : %s\n"),
-                           test_string),
-                          -1);
-      stm = sstm;
-  ACEXML_Char* name = (filename == 0) ? url : filename;
-  if (sax == 0)
-    ACE_NEW_RETURN (handler,
-                    ACEXML_Print_Handler (name),
-                    -1);
-  else
-                    ACEXML_SAXPrint_Handler (name),
-                    -1);
-  auto_ptr<ACEXML_DefaultHandler> cleanup_handler (handler);
-  ACEXML_Parser parser;
-  ACEXML_InputSource input (stm);
-  parser.setContentHandler (handler);
-  parser.setDTDHandler (handler);
-  parser.setErrorHandler (handler);
-  parser.setEntityResolver (handler);
-  ACEXML_TRY_NEW_ENV
-    parser.parse (&input ACEXML_ENV_ARG_PARAMETER);
-    ACEXML_TRY_CHECK;
-  ACEXML_CATCH (ACEXML_Exception, ex)
-      ex.print();
-      ACE_DEBUG ((LM_ERROR, ACE_TEXT ("Exception occurred. Exiting...\n")));
-      return 1;
-  ACEXML_ENDTRY;
-//   ACEXML_TRY_EX (SECOND)
-//     parser.parse (&input ACEXML_ENV_ARG_PARAMETER);
-//     ACEXML_TRY_CHECK_EX (SECOND);
-//   ACEXML_CATCH (ACEXML_SAXException, ex)
-//       ex.print();
-//       ACE_DEBUG ((LM_ERROR, ACE_TEXT ("Exception occurred. Exiting...\n")));
-//       return 1;
-//   ACEXML_ENDTRY;
-//   ACEXML_TRY_EX (THIRD)
-//     ACEXML_TRY_CHECK_EX (THIRD);
-//       ex.print();
-//       return 1;
-//   ACEXML_ENDTRY;
-//   ACEXML_TRY_EX (FOURTH)
-//     ACEXML_TRY_CHECK_EX (FOURTH);
-//       ex.print();
-//       return 1;
-//   ACEXML_ENDTRY;
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/namespaces.xml
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/namespaces.xml	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/namespaces.xml	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,95 +0,0 @@
-<?xml version="1.0" encoding="iso8859-1"?>
-<rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:sy="http://purl.org/rss/1.0/modules/syndication/" xmlns:admin="http://webns.net/mvcb/" xmlns="http://purl.org/rss/1.0/">
-<channel rdf:about="http://primates.ximian.com/~ravi/BoozeLog/">
-<title>Vignesh Blogs Here</title>
-<link>http://primates.ximian.com/~ravi/BoozeLog/</link>
-<description></description>
-<language>en-us</language>
-<webMaster></webMaster>
-<lastBuildDate>2002-10-11T00:50:42-06:00</lastBuildDate>
-<pubDate>2002-10-12T20:19:57-06:00</pubDate>
-<admin:generatorAgent rdf:resource="http://www.movabletype.org/?v=2.21" />
-<items>
-<rdf:Seq><rdf:li rdf:resource="http://primates.ximian.com/~ravi/BoozeLog/archives/000025.html" />
-<rdf:li rdf:resource="http://primates.ximian.com/~ravi/BoozeLog/archives/000024.html" />
-<rdf:li rdf:resource="http://primates.ximian.com/~ravi/BoozeLog/archives/000023.html" />
-<rdf:li rdf:resource="http://primates.ximian.com/~ravi/BoozeLog/archives/000020.html" />
-<rdf:li rdf:resource="http://primates.ximian.com/~ravi/BoozeLog/archives/000013.html" />
-<rdf:li rdf:resource="http://primates.ximian.com/~ravi/BoozeLog/archives/000012.html" />
-<rdf:li rdf:resource="http://primates.ximian.com/~ravi/BoozeLog/archives/000011.html" />
-<rdf:li rdf:resource="http://primates.ximian.com/~ravi/BoozeLog/archives/000008.html" />
-</rdf:Seq>
-</items>
-</channel>
-<item rdf:about="http://primates.ximian.com/~ravi/BoozeLog/archives/000025.html">
-<title>Happy Birthday Vidya</title>
-<description>Today is Vidya's birthday ! Happy Birthday Vidya! We had a midnight party,as usual, at Swapna's place, though I dont...</description>
-<link>http://primates.ximian.com/~ravi/BoozeLog/archives/000025.html</link>
-<dc:subject>Blog entry</dc:subject>
-<dc:creator>Booze</dc:creator>
-<dc:date>2002-10-11T00:50:42-06:00</dc:date>
-</item>
-<item rdf:about="http://primates.ximian.com/~ravi/BoozeLog/archives/000024.html">
-<title>Way to go, Shaastra!</title>
-<description>On Flash Back mode now: Shaastra is the technical festival at my alma mater, IIT Madras, that replaced the old,...</description>
-<link>http://primates.ximian.com/~ravi/BoozeLog/archives/000024.html</link>
-<dc:date>2002-10-10T11:52:02-06:00</dc:date>
-</item>
-<item rdf:about="http://primates.ximian.com/~ravi/BoozeLog/archives/000023.html">
-<title>Back and Forth in Time</title>
-<description>The blog is going to be a little skewed in time for the next coupla days.. Inspite of my laziness,...</description>
-<link>http://primates.ximian.com/~ravi/BoozeLog/archives/000023.html</link>
-<dc:date>2002-10-09T23:47:19-06:00</dc:date>
-</item>
-<item rdf:about="http://primates.ximian.com/~ravi/BoozeLog/archives/000020.html">
-<title>Frisco Rocks!</title>
-<description>If there be any reason the blog hasnt been updated,it is simply because I am enjoying my trip to San...</description>
-<link>http://primates.ximian.com/~ravi/BoozeLog/archives/000020.html</link>
-<dc:date>2002-10-03T23:53:16-06:00</dc:date>
-</item>
-<item rdf:about="http://primates.ximian.com/~ravi/BoozeLog/archives/000013.html">
-<title>Think but not make thoughts your aim</title>
-<description>A line from Rudyard Kipling's IF : would sum up my feelings for today, a lot of thinking from morning...</description>
-<link>http://primates.ximian.com/~ravi/BoozeLog/archives/000013.html</link>
-<dc:date>2002-09-28T22:48:09-06:00</dc:date>
-</item>
-<item rdf:about="http://primates.ximian.com/~ravi/BoozeLog/archives/000012.html">
-<title>New ARM but...</title>
-<description>ARM stands for Advanced Recording Model, a simulation software that I use for my work, and I have been tinkering...</description>
-<link>http://primates.ximian.com/~ravi/BoozeLog/archives/000012.html</link>
-<dc:date>2002-09-27T22:36:28-06:00</dc:date>
-</item>
-<item rdf:about="http://primates.ximian.com/~ravi/BoozeLog/archives/000011.html">
-<title>A much needed break</title>
-<description>Slowly got over the hangover of Sandhya's departure and moved to more mundane things in life : assignments, submissions and...</description>
-<link>http://primates.ximian.com/~ravi/BoozeLog/archives/000011.html</link>
-<dc:date>2002-09-26T23:05:46-06:00</dc:date>
-</item>
-<item rdf:about="http://primates.ximian.com/~ravi/BoozeLog/archives/000008.html">
-<title>Here we go !</title>
-<description>My first attempts at Blogging, the idea was introduced to me by Ravi Pratap. MoveableType really makes it easy and...</description>
-<link>http://primates.ximian.com/~ravi/BoozeLog/archives/000008.html</link>
-<dc:date>2002-09-25T19:27:22-06:00</dc:date>
-</item>
-</rdf:RDF>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/ns.svc.conf.xml
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/ns.svc.conf.xml	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/ns.svc.conf.xml	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,46 +0,0 @@
-<ace:ACE_Svc_Conf xmlns="http://ace.doc.wustl.edu/svcconf" xmlns:ace="http://ace.doc.wustl.edu/svcconf">
-<static id="ACE_Service_Manager">
-  <params>-d</params>
-  <params>-p 4911</params>
-</static>
-<dynamic id="Test_Task" type="service_object"> &#65; &amp;lt;
-  <initializer path="CCM_App" init="_make_Test_Task">
-    <params>-p 3000</params>
-  </initializer>
-</dynamic>
-<ace:streamdef>
-  <dynamic id="CCM_App" type="stream" status="active">
-    <initializer path="CCM_App" init="make_stream"/>
-  </dynamic>
-  <module>
-    <dynamic id="Device_Adapter" type="module">
-      <initializer path="CCM_App" init="make_da"/>
-    </dynamic>
-    <dynamic id="Event_Analyzer" type="module">
-      <initializer path="CCM_App" init="make_ea"/>
-    </dynamic>
-    <dynamic id="Multicast_Router" type="module">
-      <initializer path="CCM_App" init="make_mr">
-        <params>-p</params>
-        <params>3001</params>
-      </initializer>
-    </dynamic>
-  </module>
-</ace:streamdef>
-<stream id="CCM_App">
-  <module>
-    <remove id="Device_Adapter"/>
-    <!-- <remove id="Event_Analyzer"/> -->
-    <!-- <remove id="Multicast_Router"/> -->
-    <![CDATA[Only a text string.
-Do you &amp;expect something more?]]>
-  </module>
-</stream>
-<!-- remove CCM_App -->
-<remove id="Test_&amp;Task&#x65;bc"/>
-</ace:ACE_Svc_Conf>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/simple.svcconf.xml
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/simple.svcconf.xml	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/simple.svcconf.xml	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,38 +0,0 @@
-<ACE_Svc_Conf>
-<static id="ACE_Service_Manager" params="-d -p 4911"/>
-  <initializer path="CCM_App" init="_make_Test_Task" params="-p 3000" />
-</dynamic>
-<streamdef>
-  </dynamic>
-  <module>
-    </dynamic>
-    </dynamic>
-      <initializer path="CCM_App" init="make_mr" params="-p 3001"/>
-    </dynamic>
-  </module>
-</streamdef>
-<stream id="&ccm;">
-  <module>
-Do you &amp;expect something more? &#65;]]>
-<!-- Noticed that the "&amp;" in the above CDATA section can not be escaped. -->
-  </module>
-</stream>
-<remove id="Test_&amp;Task&#x61;bc"/>
-</ACE_Svc_Conf>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/svc.conf.xml
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/svc.conf.xml	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/examples/SAXPrint/svc.conf.xml	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,58 +0,0 @@
-<!-- This is a test XML file.  Most of the stuff here don't make any sense at all -->
-<!DOCTYPE ACE_Svc_Conf PUBLIC 'GOODSAM' '../../apps/svcconf/svcconf.dtd'
-    <!NOTATION goody PUBLIC 'NBC' 'http://hardcoreace.com/'>
-    <!NOTATION frodo PUBLIC 'ABC'>
-    <!NOTATION bilbo SYSTEM "C:/ACE-GUIDELINE">
-    <!ENTITY ccm 'CCM_App'>
-    <!ENTITY pippin PUBLIC 'GOTO' 'http://taozen.com/' NDATA goody>
-    <!ENTITY sam PUBLIC 'SHIRE' 'http://taozen.com/'>
-    <!ENTITY gandolf SYSTEM 'D:/RINGS.DOT'>
-    <!ELEMENT GOOBEGONE EMPTY>
-    <!ELEMENT POOPOO ANY>
-    <!ELEMENT HOHOHO ((BOOBOO, GOOBEGONE)?, (GOOBEGONE|POOPOO)*)+>
-    <!ELEMENT BOOBOO (#PCDATA | BOOBOO)*>
-    <!ATTLIST GOOBEGONE
-              ohmy CDATA #REQUIRED
-              testing IDREF #IMPLIED>
-<ACE_Svc_Conf>
-</dynamic>
-<streamdef>
-  </dynamic>
-  <module>
-    </dynamic>
-    </dynamic>
-    </dynamic>
-  </module>
-</streamdef>
-  <module>
-  </module>
-</stream>
-</ACE_Svc_Conf>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/Makefile.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/Makefile.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/Makefile.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,11 +0,0 @@
-# Makefile for building the ACE XML parser Library
-DIRS = \
-        debug_validator \
-        parser
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_Attributes_Builder.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_Attributes_Builder.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_Attributes_Builder.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,215 +0,0 @@
-// Debug_Attributes_Builder.cpp,v 1.8 2002/10/13 03:58:57 kitty Exp
-#include "ACEXML/common/SAXExceptions.h"
-#include "ACEXML/parser/debug_validator/Debug_Attributes_Builder.h"
-ACEXML_Debug_Attribute_Builder::ACEXML_Debug_Attribute_Builder ()
-  : type_ (ERROR_TYPE),
-    default_decl_ (INVALID)
-ACEXML_Debug_Attribute_Builder::ACEXML_Debug_Attribute_Builder (const ACEXML_Debug_Attribute_Builder &rhs)
-  : name_ (rhs.name_),
-    type_ (rhs.type_),
-    default_decl_ (rhs.default_decl_),
-    default_value_ (rhs.default_value_),
-    att_value_queue_ (rhs.att_value_queue_)
-ACEXML_Debug_Attribute_Builder::~ACEXML_Debug_Attribute_Builder ()
-int
-ACEXML_Debug_Attribute_Builder::setName (const ACEXML_Char *n)
-  this->name_.set (n, 0);
-  return 0;
-const ACEXML_Char *
-ACEXML_Debug_Attribute_Builder::getName (void)
-  return this->name_.fast_rep ();
-int
-ACEXML_Debug_Attribute_Builder::setAttType (const ATT_TYPE type
-                                            ACEXML_ENV_ARG_DECL)
-  if (this->type_ == ERROR_TYPE)
-      this->type_ = type;
-      return 0;
-  ACEXML_THROW_RETURN (ACEXML_SAXParseException (ACE_TEXT("Attribute type redefinition in Debug Validator")), -1);
-int
-ACEXML_Debug_Attribute_Builder::insertList (const ACEXML_Char *n
-  ACEXML_String str (n, 0, 0);
-  this->att_value_queue_.enqueue_tail (str);
-  return 0;
-int
-ACEXML_Debug_Attribute_Builder::setDefault (const DEFAULT_DECL def,
-                                            const ACEXML_Char *value
-  this->default_decl_ = def;
-  this->default_value_.set (value, 0);
-  return 0;
-int
-ACEXML_Debug_Attribute_Builder::validAttr (void)
-  // @@ Not implemented.  Always return 1 (true) for now.
-  return 1;
-void
-ACEXML_Debug_Attribute_Builder::dump (void)
-  cout << this->name_ << " ";
-  switch (this->type_)
-    case CDATA:
-      cout << "CDATA ";
-      break;
-    case ID:
-      cout << "ID ";
-      break;
-    case IDREF:
-      cout << "IDREF ";
-      break;
-    case IDREFS:
-      cout << "IDREFS ";
-      break;
-    case ENTITY:
-      cout << "ENTITY ";
-      break;
-    case ENTITIES:
-      cout << "ENTITIES ";
-      break;
-    case NMTOKEN:
-      cout << "NMTOKEN ";
-      break;
-    case NMTOKENS:
-      cout << "NMTOKENS ";
-      break;
-    case NOTATION:
-      cout << "NOTATION ";
-      // Fall thru
-    case ENUMERATION:
-        cout << "(";
-        ACEXML_STRING_QUEUE_ITERATOR iter (this->att_value_queue_);
-        ACEXML_String *n = 0;
-        while (iter.advance () != 0)
-            if (n == 0)
-              cout << " | ";
-            iter.next (n);
-            cout << *n;
-        cout << ") ";
-      break;
-    default:
-      cout << "*** UNKNOWN TYPE ***";
-      break;
-  switch (this->default_decl_)
-    case REQUIRED:
-      cout << "#REQUIRED";
-      break;
-    case IMPLIED:
-      cout << "#IMPLIED";
-      break;
-    case FIXED:
-      cout << "#FIXED " << this->default_value_;
-      break;
-    default:
-      cout << "**** UNDEFINED DEFAULT DECL ****";
-      break;
-ACEXML_Debug_Attributes_Builder::ACEXML_Debug_Attributes_Builder ()
-ACEXML_Debug_Attributes_Builder::~ACEXML_Debug_Attributes_Builder ()
-int
-ACEXML_Debug_Attributes_Builder::setElement (const ACEXML_Char *,
-                                             const ACEXML_Char *qName ACEXML_ENV_ARG_DECL_NOT_USED)
-  this->element_name_.set (qName, 0);
-  return 0;
-ACEXML_Attribute_Def_Builder *
-ACEXML_Debug_Attributes_Builder::getAttribute_Def_Builder ()
-  ACEXML_Attribute_Def_Builder *tmp;
-  ACE_NEW_RETURN (tmp,
-                  ACEXML_Debug_Attribute_Builder (),
-                  0);
-  return tmp;
-int
-ACEXML_Debug_Attributes_Builder::insertAttribute (ACEXML_Attribute_Def_Builder *def ACEXML_ENV_ARG_DECL)
-  ACEXML_Attribute_Def_Builder::VAR ptr (def);
-  if (def != 0)
-      ACEXML_String attname (def->getName (), 0, 0);
-      ACEXML_Debug_Attribute_Builder *ptr =
-        ACE_dynamic_cast (ACEXML_Debug_Attribute_Builder *, def);
-      this->attributes_.bind (attname, *ptr);
-      return 0;
-  ACEXML_THROW_RETURN (ACEXML_SAXParseException (ACE_TEXT("ACEXML_Debug_Attributes_Builder internal error")), -1);
-void
-ACEXML_Debug_Attributes_Builder::dump (void)
-  // @@ Print print.
-  cout << "<!ATTLIST " << this->element_name_ << endl;
-  ACEXML_ATT_MAP_ITER iter (this->attributes_);
-  ACEXML_ATT_MAP_ENTRY *item;
-      iter.next (item);
-      cout << "\n\t";
-      item->int_id_.dump ();
-  cout << ">" << endl;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_Attributes_Builder.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_Attributes_Builder.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_Attributes_Builder.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,170 +0,0 @@
-// -*- C++ -*-
- *  @file   Debug_Attributes_Builder.h
- *  Debug_Attributes_Builder.h,v 1.7 2003/07/19 19:04:10 dhinton Exp
- *  @author Nanbor Wang <nanbor at cs.wustl.edu>
-#ifndef _ACEXML_DEBUG_ATTRIBUTES_BUILDER_H_
-#define _ACEXML_DEBUG_ATTRIBUTES_BUILDER_H_
-#include /**/ "ace/pre.h"
-#include "ACEXML/parser/debug_validator/Debug_DTD_Manager_Export.h"
-#if !defined (ACE_LACKS_PRAGMA_ONCE)
-#pragma once
-#endif /* ACE_LACKS_PRAGMA_ONCE */
-#include "ACEXML/common/Attributes_Def_Builder.h"
-#include "ace/Hash_Map_Manager.h"
-#include "ace/Unbounded_Queue.h"
-typedef ACE_Unbounded_Queue<ACEXML_String> ACEXML_STRING_QUEUE;
-typedef ACE_Unbounded_Queue_Iterator<ACEXML_String> ACEXML_STRING_QUEUE_ITERATOR;
- * @class ACEXML_Debug_Attribute_Builder Debug_Attributes_Builder.h "parser/debug_validator/Debug_Attributes_Builder.h"
- * This class prints out the Attribute definition for debugging purpose.
-class ACEXML_DEBUG_DTD_MANAGER_Export ACEXML_Debug_Attribute_Builder
-  : public ACEXML_Attribute_Def_Builder
-public:
-  ACEXML_Debug_Attribute_Builder ();
-  ACEXML_Debug_Attribute_Builder (const ACEXML_Debug_Attribute_Builder &rhs);
-  virtual ~ACEXML_Debug_Attribute_Builder ();
-   * Specify the name of the attribute.
-  virtual int setName (const ACEXML_Char *n);
-  virtual const ACEXML_Char *getName (void);
-   * Set the attribute type.
-  virtual int setAttType (const ATT_TYPE type ACEXML_ENV_ARG_DECL)
-     ACE_THROW_SPEC ((ACEXML_SAXException)) ;
-   * Insert an element for NOTATION or ENUMERATION type attribute.
-  virtual int insertList (const ACEXML_Char *Name ACEXML_ENV_ARG_DECL)
-   * Set default attribute declaration.
-  virtual int setDefault (const DEFAULT_DECL def,
-                          const ACEXML_Char *value ACEXML_ENV_ARG_DECL)
-   * Check validity of the current attribute definition being built.
-   * @retval 0 if the attribute is not a valid combo.
-  virtual int validAttr (void);
-   * Dump the content of the attribute definition.
-  virtual void dump (void);
-private:
-  /// Attribute name.
-  ACEXML_String name_;
-  /// Type of attribute.
-  ATT_TYPE type_;
-  /// Default value type.
-  DEFAULT_DECL default_decl_;
-  /// Default attribute value.
-  ACEXML_String default_value_;
-  /// Holds a queue of enumerated attribute values.
-  ACEXML_STRING_QUEUE att_value_queue_;
-typedef ACE_Hash_Map_Entry<ACEXML_String,
-                           ACEXML_Debug_Attribute_Builder> ACEXML_ATT_MAP_ENTRY;
-typedef ACE_Hash_Map_Manager_Ex <ACEXML_String,
-                                 ACEXML_Debug_Attribute_Builder,
-                                 ACE_Hash<ACEXML_String>,
-                                 ACE_Equal_To<ACEXML_String>,
-                                 ACE_Null_Mutex> ACEXML_ATT_MAP;
-typedef ACE_Hash_Map_Iterator_Ex<ACEXML_String,
-                                 ACE_Null_Mutex> ACEXML_ATT_MAP_ITER;
-typedef ACE_Hash_Map_Reverse_Iterator_Ex<ACEXML_String,
-                                         ACE_Null_Mutex> ACEXML_ATT_MAP_REVERSE_ITER;
- * @class ACEXML_Debug_Attributes_Builder Debug_Attributes_Builder.h "parser/debug_validator/Debug_Attributes_Builder.h"
- * This class prints out Attribute definitions for debugging purpose.
-class ACEXML_DEBUG_DTD_MANAGER_Export ACEXML_Debug_Attributes_Builder
-  : public ACEXML_Attributes_Def_Builder
-public:
-  ACEXML_Debug_Attributes_Builder ();
-  virtual ~ACEXML_Debug_Attributes_Builder ();
-   * Set the element name that the attribute builder applies.
-   * @retval 0 if valid, -1 otherwise.
-  virtual int setElement (const ACEXML_Char *namespaceURI,
-   * Acquire an Attribute_Builder.
-  virtual ACEXML_Attribute_Def_Builder *getAttribute_Def_Builder ();
-   * Add a definition for one attribute.
-  virtual int insertAttribute (ACEXML_Attribute_Def_Builder *def ACEXML_ENV_ARG_DECL);
-protected:
-  /// The name of the element type these attributes applied.
-  ACEXML_String element_name_;
-  /// Collection of attributes.
-  ACEXML_ATT_MAP attributes_;
-#include /**/ "ace/post.h"
-#endif /* _ACEXML_DEBUG_ATTRIBUTES_BUILDER_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_DTD_Manager.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_DTD_Manager.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_DTD_Manager.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,71 +0,0 @@
-// -*- C++ -*-   Debug_DTD_Manager.cpp,v 1.7 2002/10/13 05:58:28 kitty Exp
-#include "ACEXML/parser/debug_validator/Debug_DTD_Manager.h"
-#include "ACEXML/parser/debug_validator/Debug_Element_Builder.h"
-ACEXML_Debug_DTD_Manager::ACEXML_Debug_DTD_Manager ()
-ACEXML_Debug_DTD_Manager::~ACEXML_Debug_DTD_Manager ()
-ACEXML_Element_Def_Builder *
-ACEXML_Debug_DTD_Manager::getElement_Def_Builder ()
-  return new ACEXML_Debug_Element_Builder ();
-int
-ACEXML_Debug_DTD_Manager::insertElement_Definition (ACEXML_Element_Def_Builder *def ACEXML_ENV_ARG_DECL)
-  ACEXML_Element_Def_Builder::VAR ptr (def);
-  if (def != 0)
-      ptr->dump ();
-      return 0;
-ACEXML_Attributes_Def_Builder *
-ACEXML_Debug_DTD_Manager::getAttribute_Def_Builder ()
-  ACEXML_Attributes_Def_Builder *tmp;
-                  ACEXML_Debug_Attributes_Builder (),
-                  0);
-  return tmp;
-int
-ACEXML_Debug_DTD_Manager::insertAttributes_Definition (ACEXML_Attributes_Def_Builder *def ACEXML_ENV_ARG_DECL)
-  ACEXML_Attributes_Def_Builder::VAR ptr (def);
-  if (def != 0)
-      ptr->dump ();
-      return 0;
-ACEXML_Validator *
-ACEXML_Debug_DTD_Manager::getValidator (const ACEXML_Char *namespaceURI,
-  ACE_UNUSED_ARG (namespaceURI);
-  ACE_UNUSED_ARG (localName);
-  ACE_UNUSED_ARG (qName);
-  ACEXML_THROW_RETURN (ACEXML_SAXNotSupportedException (ACE_TEXT ("getValidator()")), 0);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_DTD_Manager.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_DTD_Manager.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_DTD_Manager.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,76 +0,0 @@
-// -*- C++ -*-
- *  @file    Debug_DTD_Manager.h
- *  Debug_DTD_Manager.h,v 1.6 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_DEBUG_DTD_Manager_H_
-#define _ACEXML_DEBUG_DTD_Manager_H_
-#pragma once
-#include "ACEXML/common/DTD_Manager.h"
-class ACEXML_DEBUG_DTD_MANAGER_Export ACEXML_Debug_DTD_Manager : public ACEXML_DTD_Manager
-public:
-  ACEXML_Debug_DTD_Manager ();
-  virtual ~ACEXML_Debug_DTD_Manager ();
-   * Acquire a pointer to an element definition builder. The XML parser use
-   * this interface to acquire the definition builder and use the builder
-   * to create the DTD element definition. The resulting builder is then
-   * registered with the DTD Manager or destroyed if error occured when the
-   * builder encountered errors.
-   * @retval 0 if error occurs creating the builder.
-  virtual ACEXML_Element_Def_Builder *getElement_Def_Builder ();
-   * Insert a new element definition into the DTD Manager.
-   * @retval 0 if success, -1 if error.
-  virtual int insertElement_Definition (ACEXML_Element_Def_Builder *def ACEXML_ENV_ARG_DECL);
-   * Acquire a pointer to an attributes definition builder.
-  virtual ACEXML_Attributes_Def_Builder *getAttribute_Def_Builder ();
-   * Insert a new attributes definition into the DTD Manager.
-   * @retval 0 if success, -1 otherwise.
-  virtual int insertAttributes_Definition (ACEXML_Attributes_Def_Builder *def ACEXML_ENV_ARG_DECL);
-   * Acquire an element validator to validate an XML element.
-   * @todo I haven't figured out what memory management scheme
-   *       we should use for the acquired validator.
-  virtual ACEXML_Validator *getValidator (const ACEXML_Char *namespaceURI,
-                                          const ACEXML_Char *qName ACEXML_ENV_ARG_DECL);
-#endif /* _ACEXML_DTD_Manager_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_DTD_Manager_Export.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_DTD_Manager_Export.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_DTD_Manager_Export.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,38 +0,0 @@
-// -*- C++ -*-
-// Debug_DTD_Manager_Export.h,v 1.2 2002/01/24 21:00:01 nanbor Exp
-// Definition for Win32 Export directives.
-// This file is generated automatically by generate_export_file.pl -s ACEXML_DEBUG_DTD_MANAGER
-#ifndef ACEXML_DEBUG_DTD_MANAGER_EXPORT_H
-#define ACEXML_DEBUG_DTD_MANAGER_EXPORT_H
-#include "ace/config-all.h"
-#if defined (ACE_AS_STATIC_LIBS) && !defined (ACEXML_DEBUG_DTD_MANAGER_HAS_DLL)
-#  define ACEXML_DEBUG_DTD_MANAGER_HAS_DLL 0
-#endif /* ACE_AS_STATIC_LIBS && ACEXML_DEBUG_DTD_MANAGER_HAS_DLL */
-#if !defined (ACEXML_DEBUG_DTD_MANAGER_HAS_DLL)
-#  define ACEXML_DEBUG_DTD_MANAGER_HAS_DLL 1
-#endif /* ! ACEXML_DEBUG_DTD_MANAGER_HAS_DLL */
-#if defined (ACEXML_DEBUG_DTD_MANAGER_HAS_DLL) && (ACEXML_DEBUG_DTD_MANAGER_HAS_DLL == 1)
-#  if defined (ACEXML_DEBUG_DTD_MANAGER_BUILD_DLL)
-#    define ACEXML_DEBUG_DTD_MANAGER_Export ACE_Proper_Export_Flag
-#    define ACEXML_DEBUG_DTD_MANAGER_SINGLETON_DECLARATION(T) ACE_EXPORT_SINGLETON_DECLARATION (T)
-#    define ACEXML_DEBUG_DTD_MANAGER_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK) ACE_EXPORT_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK)
-#  else /* ACEXML_DEBUG_DTD_MANAGER_BUILD_DLL */
-#    define ACEXML_DEBUG_DTD_MANAGER_Export ACE_Proper_Import_Flag
-#    define ACEXML_DEBUG_DTD_MANAGER_SINGLETON_DECLARATION(T) ACE_IMPORT_SINGLETON_DECLARATION (T)
-#    define ACEXML_DEBUG_DTD_MANAGER_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK) ACE_IMPORT_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK)
-#  endif /* ACEXML_DEBUG_DTD_MANAGER_BUILD_DLL */
-#else /* ACEXML_DEBUG_DTD_MANAGER_HAS_DLL == 1 */
-#endif /* ACEXML_DEBUG_DTD_MANAGER_HAS_DLL == 1 */
-#endif /* ACEXML_DEBUG_DTD_MANAGER_EXPORT_H */
-// End of auto generated file.
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_Element_Builder.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_Element_Builder.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_Element_Builder.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,148 +0,0 @@
-// Debug_Element_Builder.cpp,v 1.7 2002/10/13 03:58:57 kitty Exp
-ACEXML_Debug_Element_Builder::ACEXML_Debug_Element_Builder ()
-  : type_ (UNDEFINED),
-    root_ (0)
-ACEXML_Debug_Element_Builder::~ACEXML_Debug_Element_Builder ()
-  delete this->root_;
-int
-ACEXML_Debug_Element_Builder::setElementName (const ACEXML_Char *,
-  this->element_.set (qName, 0);
-  return 0;
-int
-ACEXML_Debug_Element_Builder::setContentType (CONTENT_TYPE type ACEXML_ENV_ARG_DECL)
-  if (this->type_ == UNDEFINED)
-      return 0;
-  ACEXML_THROW_RETURN (ACEXML_SAXParseException (ACE_TEXT("Element type redefinition in Debug_Validator.")), -1);
-int
-ACEXML_Debug_Element_Builder::insertMixedElement (const ACEXML_Char *,
-  ACEXML_Element_Tree_Name_Node *node;
-  // @@ We should "throw" an exception here instead of returning -1.
-  ACE_NEW_RETURN (node,
-                  ACEXML_Element_Tree_Name_Node (qName),
-                  -1);
-  if (this->root_ == 0)
-    // @@ Memory leak if fail?
-    ACE_NEW_RETURN (this->root_,
-                    ACEXML_Element_Tree_List_Node (),
-                    -1);
-  return this->root_->insert (node);
-int
-ACEXML_Debug_Element_Builder::startChildGroup ()
-  ACEXML_Element_Tree_List_Node *lnode;
-  ACE_NEW_RETURN (lnode,
-                  -1);
-      this->root_ = lnode;
-  else
-      // @@ check error?
-      this->root_->insert (lnode);
-  this->active_list_.push (lnode);
-  return 0;
-int
-ACEXML_Debug_Element_Builder::endChildGroup (CARDINALITY  ACEXML_ENV_ARG_DECL_NOT_USED)
-  this->active_list_.pop ();
-  return 0;
-int
-ACEXML_Debug_Element_Builder::setChoice ()
-  this->active_list_.top ()->set (ACEXML_Element_Tree_List_Node::CHOICE);
-  return 0;
-int
-ACEXML_Debug_Element_Builder::setSequence ()
-  this->active_list_.top ()->set (ACEXML_Element_Tree_List_Node::SEQUENCE);
-  return 0;
-int
-ACEXML_Debug_Element_Builder::insertElement  (const ACEXML_Char *,
-                  -1);
-  return this->active_list_.top ()->insert (node);
-void
-ACEXML_Debug_Element_Builder::dump ()
-  cout << "<!ELEMENT " << this->element_;
-  // @@ Also dump element contentspec here.
-    case EMPTY:
-      cout << "EMPTY";
-      break;
-    case ANY:
-      cout << "ANY";
-      break;
-    case MIXED:
-    case CHILDREN:
-      // @@ Dump the content of this->root_
-      cout << "*** not implemented ***";
-      break;
-    default:
-      cout << "*** Unidentified element type ***";
-      break;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_Element_Builder.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_Element_Builder.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Debug_Element_Builder.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,127 +0,0 @@
-// -*- C++ -*-
- *  @file    Debug_Element_Builder.h
- *  Debug_Element_Builder.h,v 1.7 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_DEBUG_ELEMENT_BUILDER_H_
-#define _ACEXML_DEBUG_ELEMENT_BUILDER_H_
-#pragma once
-#include "ACEXML/common/Element_Def_Builder.h"
-#include "ACEXML/parser/debug_validator/Element_Tree.h"
- * @class ACEXML_Debug_Element_Builder Debug_Element_Builder.h "parser/debug_validator/Debug_Element_Builder.h"
- * This class prints out the element definition for debugging purpose.
- * @todo This class is not namespace-aware.
-class ACEXML_DEBUG_DTD_MANAGER_Export ACEXML_Debug_Element_Builder
-  : public ACEXML_Element_Def_Builder
-public:
-  ACEXML_Debug_Element_Builder ();
-  virtual ~ACEXML_Debug_Element_Builder ();
-   * Define the name of the element.
-  virtual int setElementName (const ACEXML_Char *namespaceURI,
-   * Define the content type of the element.
-  virtual int setContentType (CONTENT_TYPE type ACEXML_ENV_ARG_DECL)
-   * Insert one more element into Mixed definition.
-  virtual int insertMixedElement (const ACEXML_Char *namespaceURI,
-   * Start a new group of children.
-  virtual int startChildGroup ();
-   * End a new group of children.
-   * @retval 0 on success.
-  virtual int endChildGroup (CARDINALITY card ACEXML_ENV_ARG_DECL);
-   * Set the type of current child group to Choice.
-   * @retval 0 on success, -1 if the type of the child group has
-   * already been set and this action conflicts with the previous
-   * setting.
-  virtual int setChoice ();
-   * Set the type of current child group to Sequence.
-   * setting.
-  virtual int setSequence ();
-   * Insert an new element into the current child group.
-   * @retval 0 on success, -1 otherwise.
-  virtual int insertElement  (const ACEXML_Char *namespaceURI,
-private:
-  CONTENT_TYPE type_;
-  ACEXML_String element_;
-  ACEXML_Element_Tree_List_Node *root_;
-  ACEXML_Element_Tree_List_Stack active_list_;
-#endif /* _ACEXML_DEBUG_ELEMENT_BUILDER_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Element_Tree.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Element_Tree.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Element_Tree.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,72 +0,0 @@
-// Element_Tree.cpp,v 1.5 2002/08/22 01:51:15 kitty Exp
-# include "ACEXML/parser/debug_validator/Element_Tree.i"
-ACEXML_Element_Tree_Node::~ACEXML_Element_Tree_Node ()
-  delete this->next_;
-ACE_ALLOC_HOOK_DEFINE (ACEXML_Element_Tree_Node)
-void
-ACEXML_Element_Tree_Name_Node::dump ()
-  cout << this->name_;
-ACE_ALLOC_HOOK_DEFINE (ACEXML_Element_Tree_Name_Node)
-ACEXML_Element_Tree_List_Node::~ACEXML_Element_Tree_List_Node (void)
-  delete this->head_;
-int
-ACEXML_Element_Tree_List_Node::insert (ACEXML_Element_Tree_Node *node)
-  if (this->head_ == 0)
-      this->tail_ = this->head_ = node;
-  else
-      this->tail_->next (node);
-      this->tail_ = node;
-  return 0;
-void
-ACEXML_Element_Tree_List_Node::dump (void)
-  ACEXML_Element_Tree_Node *ptr = this->head_;
-  const ACEXML_Char *separator = (this->type_ == SEQUENCE) ? ACE_TEXT(" , ") : ACE_TEXT(" | ");
-  cout << "(";
-  if (ptr != 0)
-      ptr->dump ();
-      ptr = ptr->next ();
-      while (ptr != 0)
-          cout << separator;
-          ptr->dump ();
-          ptr->next ();
-  cout << ")";
-ACE_ALLOC_HOOK_DEFINE (ACEXML_Element_Tree_List_Node)
-ACE_ALLOC_HOOK_DEFINE (ACEXML_Element_Tree_List_Stack)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Element_Tree.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Element_Tree.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Element_Tree.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,160 +0,0 @@
-// -*- C++ -*-
- *  @file    Element_Tree.h
- *  Element_Tree.h,v 1.6 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_ELEMENT_TREE_H_
-#define _ACEXML_ELEMENT_TREE_H_
-#pragma once
-#include "ACEXML/common/XML_Types.h"
- * @class ACEXML_Element_Tree_Node Element_Tree.h "parser/debug_validator/Element_Tree.h"
- * @brief An abstract base class for describing DTD child element definition.
- * @sa ACEXML_Element_Tree_Name_Node, ACEXML_Element_Tree_List_Node
-class ACEXML_DEBUG_DTD_MANAGER_Export ACEXML_Element_Tree_Node
-public:
-  /// Default constructor.
-  ACEXML_Element_Tree_Node ();
-  /// Destructor
-  virtual ~ACEXML_Element_Tree_Node ();
-  /// Accessor for next element in chain
-  ACEXML_Element_Tree_Node *next ();
-  void next (ACEXML_Element_Tree_Node *n);
-  /// Displaying the content.
-  virtual void dump () = 0;
-  ACE_ALLOC_HOOK_DECLARE;
-protected:
-  ACEXML_Element_Tree_Node *next_;
- * @class ACEXML_Element_Tree_Name_Node Element_Tree.h "parser/debug_validator/Element_Tree.h"
- * @brief An abstract base class for describing a name node in a DTD child
- * element definition.
- * @sa ACEXML_Element_Tree_Node, ACEXML_Element_Tree_List_Node
-class ACEXML_DEBUG_DTD_MANAGER_Export ACEXML_Element_Tree_Name_Node
-  : public ACEXML_Element_Tree_Node
-public:
-  /// Constructor.
-  ACEXML_Element_Tree_Name_Node (const ACEXML_Char *name,
-                                 int release = 1);
-  /// Change the name of this node.
-  void set (const ACEXML_Char *name,
-            int release = 1);
-  virtual void dump ();
-protected:
-class ACEXML_Element_Tree_List_Stack;
- * @class ACEXML_Element_Tree_List_Node Element_Tree.h "parser/debug_validator/Element_Tree.h"
- * @brief An abstract base class for describing a node list in a DTD child
- * @sa ACEXML_Element_Tree_Node, ACEXML_Element_Tree_Name_Node
-class ACEXML_DEBUG_DTD_MANAGER_Export ACEXML_Element_Tree_List_Node
-public:
-  friend class ACEXML_Element_Tree_List_Stack;
-  typedef enum {
-    SEQUENCE,
-    CHOICE
-  } LIST_TYPE;
-  ACEXML_Element_Tree_List_Node (void);
-  /// Destructor.
-  virtual ~ACEXML_Element_Tree_List_Node (void);
-  /// Insert a new ACEXML_Element_Tree_Node into the list.
-  int insert (ACEXML_Element_Tree_Node *node);
-  /// Get/set the type of list.
-  LIST_TYPE get (void);
-  int set (LIST_TYPE type);
-protected:
-  LIST_TYPE type_;
-  ACEXML_Element_Tree_Node *head_;
-  ACEXML_Element_Tree_Node *tail_;
-  ACEXML_Element_Tree_List_Node *pop_next_;
- * @class ACEXML_Element_Tree_List_Stack Element_Tree.h "parser/debug_validator/Element_Tree.h"
- * @brief A class for managing a stack of ACEXML_Element_Tree_List_Node's.
- * @sa ACEXML_Element_Tree_List_Node
-class ACEXML_DEBUG_DTD_MANAGER_Export ACEXML_Element_Tree_List_Stack
-public:
-  ACEXML_Element_Tree_List_Stack ();
-  void push (ACEXML_Element_Tree_List_Node *n);
-  ACEXML_Element_Tree_List_Node *pop (void);
-  ACEXML_Element_Tree_List_Node *top (void);
-  int empty (void);
-protected:
-  ACEXML_Element_Tree_List_Node *top_;
-#endif /* _ACEXML_ELEMENT_TREE_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Element_Tree.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Element_Tree.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/debug_validator/Element_Tree.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,92 +0,0 @@
-// Element_Tree.i,v 1.2 2002/01/24 21:00:01 nanbor Exp
-ACEXML_INLINE
-ACEXML_Element_Tree_Node::ACEXML_Element_Tree_Node ()
-  : next_ (0)
-ACEXML_INLINE ACEXML_Element_Tree_Node *
-ACEXML_Element_Tree_Node::next ()
-  return this->next_;
-ACEXML_INLINE void
-ACEXML_Element_Tree_Node::next (ACEXML_Element_Tree_Node * n)
-  this->next_ = n;
-ACEXML_INLINE
-ACEXML_Element_Tree_Name_Node::ACEXML_Element_Tree_Name_Node (const ACEXML_Char *name,
-                                                              int release)
-  : name_ (name, 0, release)
-ACEXML_INLINE void
-ACEXML_Element_Tree_Name_Node::set (const ACEXML_Char *name,
-                                    int release)
-  this->name_.set (name, release);
-ACEXML_INLINE
-ACEXML_Element_Tree_List_Node::ACEXML_Element_Tree_List_Node (void)
-  : type_ (SEQUENCE),
-    head_ (0),
-    tail_ (0),
-    pop_next_ (0)
-ACEXML_INLINE ACEXML_Element_Tree_List_Node::LIST_TYPE
-ACEXML_Element_Tree_List_Node::get (void)
-  return this->type_;
-ACEXML_INLINE int
-ACEXML_Element_Tree_List_Node::set (ACEXML_Element_Tree_List_Node::LIST_TYPE type)
-  return 0;
-ACEXML_INLINE
-ACEXML_Element_Tree_List_Stack::ACEXML_Element_Tree_List_Stack (void)
-  : top_ (0)
-ACEXML_INLINE ACEXML_Element_Tree_List_Node *
-ACEXML_Element_Tree_List_Stack::top ()
-  return this->top_;
-ACEXML_INLINE  void
-ACEXML_Element_Tree_List_Stack::push (ACEXML_Element_Tree_List_Node *n)
-  n->pop_next_ = this->top_;
-  this->top_ = n;
-ACEXML_Element_Tree_List_Stack::pop ()
-  if (this->top_ != 0)
-      ACEXML_Element_Tree_List_Node *ptr = this->top_;
-      this->top_ = this->top_->pop_next_;
-      return ptr;
-  return 0;
-ACEXML_INLINE int
-ACEXML_Element_Tree_List_Stack::empty ()
-  return this->top_ == 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ACEXML_Parser.dsp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ACEXML_Parser.dsp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ACEXML_Parser.dsp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,131 +0,0 @@
-# Microsoft Developer Studio Project File - Name="ACEXML_Parser DLL" - Package Owner=<4>
-# TARGTYPE "Win32 (x86) Dynamic-Link Library" 0x0102
-CFG=ACEXML_Parser DLL - Win32 Debug
-!MESSAGE
-!MESSAGE NMAKE /f "ACEXML_Parser.mak".
-!MESSAGE
-!MESSAGE
-!MESSAGE NMAKE /f "ACEXML_Parser.mak" CFG="ACEXML_Parser DLL - Win32 Debug"
-!MESSAGE
-!MESSAGE
-!MESSAGE "ACEXML_Parser DLL - Win32 Release" (based on "Win32 (x86) Dynamic-Link Library")
-!MESSAGE "ACEXML_Parser DLL - Win32 Debug" (based on "Win32 (x86) Dynamic-Link Library")
-!MESSAGE
-# Begin Project
-CPP=cl.exe
-RSC=rc.exe
-!IF  "$(CFG)" == "ACEXML_Parser DLL - Win32 Release"
-# PROP Use_MFC 0
-# PROP Intermediate_Dir "Release\ACEXML_Parser"
-# PROP Ignore_Export_Lib 0
-# ADD CPP /nologo /W3 /GX /O2 /MD /Zi /GR /I "..\..\.." /D NDEBUG=1 /D WIN32=1 /D _WINDOWS=1 /D ACEXML_PARSER_BUILD_DLL=1 /FD /c
-# SUBTRACT CPP /YX
-BSC32=bscmake.exe
-# ADD BSC32 /nologo /o".\ACEXML_Parser.bsc"
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACEXML.lib ACE.lib /libpath:"..\..\..\ACEXML\common" /libpath:"..\..\..\ace" /nologo /version:5.3.1 /subsystem:windows /pdb:"..\..\..\bin\ACEXML_Parser.pdb" /dll  /machine:I386 /out:"..\..\..\bin\ACEXML_Parser.dll"
-!ELSEIF  "$(CFG)" == "ACEXML_Parser DLL - Win32 Debug"
-# PROP Use_MFC 0
-# PROP Intermediate_Dir "Debug\ACEXML_Parser"
-# ADD CPP /nologo /W3 /Gm /GX /Zi /Od /MDd /GR /Gy /I "..\..\.." /D _DEBUG=1 /D WIN32=1 /D _WINDOWS=1 /D ACEXML_PARSER_BUILD_DLL=1 /FD /c
-# SUBTRACT CPP /Fr /YX
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACEXMLd.lib ACEd.lib /libpath:"..\..\..\ACEXML\common" /libpath:"..\..\..\ace" /nologo /version:5.3.1 /subsystem:windows /pdb:"..\..\..\bin\ACEXML_Parserd.pdb" /dll /debug /machine:I386 /out:"..\..\..\bin\ACEXML_Parserd.dll"
-!ENDIF
-# Begin Target
-# Name "ACEXML_Parser DLL - Win32 Release"
-# Name "ACEXML_Parser DLL - Win32 Debug"
-SOURCE=.\Entity_Manager.cpp
-# End Source File
-SOURCE=.\Parser.cpp
-# End Source File
-SOURCE=.\ParserContext.cpp
-# End Source File
-SOURCE=.\ParserInternals.cpp
-# End Source File
-# End Group
-SOURCE=.\Entity_Manager.h
-# End Source File
-SOURCE=.\Parser.h
-# End Source File
-SOURCE=.\Parser_export.h
-# End Source File
-SOURCE=.\ParserContext.h
-# End Source File
-SOURCE=.\ParserInternals.h
-# End Source File
-# End Group
-SOURCE=.\Entity_Manager.i
-# End Source File
-SOURCE=.\Parser.i
-# End Source File
-SOURCE=.\ParserContext.inl
-# End Source File
-# End Group
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Entity_Manager.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Entity_Manager.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Entity_Manager.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,46 +0,0 @@
-// Entity_Manager.cpp,v 1.7 2004/01/09 00:50:35 kitty Exp
-#include "ACEXML/parser/parser/Entity_Manager.h"
-static const ACEXML_Char empty_string[] = { 0 };
-#if !defined (__ACEXML_INLINE__)
-# include "ACEXML/parser/parser/Entity_Manager.i"
-ACEXML_Entity_Manager::ACEXML_Entity_Manager (void)
-  : entities_ (0)
-ACEXML_Entity_Manager::~ACEXML_Entity_Manager (void)
-  this->reset();
-#if defined (ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION)
-  // Instantiations for the Hash Map
-template class ACE_Equal_To<ACEXML_String>;
-template class ACE_Hash<ACEXML_String>;
-template class ACE_Hash_Map_Entry<ACEXML_String, ACEXML_String>;
-template class ACE_Hash_Map_Manager_Ex<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>;
-template class ACE_Hash_Map_Iterator_Base_Ex<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>;
-template class ACE_Hash_Map_Iterator_Ex<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>;
-template class ACE_Hash_Map_Reverse_Iterator_Ex<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>;
-template class ACE_Hash_Map_Bucket_Iterator<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>;
-#elif defined (ACE_HAS_TEMPLATE_INSTANTIATION_PRAGMA)
-#pragma instantiate ACE_Equal_To<ACEXML_String>
-#pragma instantiate ACE_Hash<ACEXML_String>
-#pragma instantiate ACE_Hash_Map_Entry<ACEXML_String, ACEXML_String>
-#pragma instantiate ACE_Hash_Map_Manager_Ex<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>
-#pragma instantiate ACE_Hash_Map_Iterator_Base_Ex<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>
-#pragma instantiate ACE_Hash_Map_Iterator_Ex<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>
-#pragma instantiate ACE_Hash_Map_Reverse_Iterator_Ex<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>
-#pragma instantiate ACE_Hash_Map_Bucket_Iterator<ACEXML_String, ACEXML_String, ACE_Hash<ACEXML_String>, ACE_Equal_To<ACEXML_String>, ACE_Null_Mutex>
-#endif /* ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Entity_Manager.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Entity_Manager.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Entity_Manager.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,100 +0,0 @@
-// -*- C++ -*-
- *  @file    Entity_Manager.h
- *  Entity_Manager.h,v 1.10 2004/01/09 00:50:35 kitty Exp
- *  @author Krishnakumar B <kitty at cs.wustl.edu>
-#ifndef ACEXML_ENTITY_MANAGER_H
-#define ACEXML_ENTITY_MANAGER_H
-#include "ACEXML/parser/parser/Parser_export.h"
-#pragma once
-#include "ace/Null_Mutex.h"
-                           ACEXML_String> ACEXML_ENTITY_ENTRY;
-typedef ACE_Hash_Map_Manager_Ex<ACEXML_String,
-                                ACEXML_String,
-                                ACE_Null_Mutex> ACEXML_ENTITIES_MANAGER;
-                                 ACEXML_String,
-                                 ACE_Null_Mutex> ACEXML_ENTITIES_MANAGER_ITER;
-                                         ACEXML_String,
-                                         ACE_Null_Mutex> ACEXML_ENTITIES_MANAGER_REVERSE_ITER;
-typedef ACE_Hash_Map_Bucket_Iterator<ACEXML_String,
-                                     ACEXML_String,
-                                     ACE_Null_Mutex> ACEXML_ENTITY_ENTRY_ITERATOR;
- * @class ACEXML_Entity_Manager Entity_Manager.h "ACEXML/parser/parser/Entity_Manager.h"
- * @brief Class to manage and resolve entity references.
- * @todo Fill in details for this class.
-class ACEXML_PARSER_Export ACEXML_Entity_Manager
-public:
-  ACEXML_Entity_Manager (void);
-  /// Destructor.
-  ~ACEXML_Entity_Manager (void);
-  /// Add a new entity declaration.
-  int add_entity (const ACEXML_Char *ref, const ACEXML_Char *value);
-  /// Resolve an entity reference.
-  const ACEXML_Char* resolve_entity (const ACEXML_Char *ref);
-  /// Resolve an entity reference and return the tuple of @c systemId and
-  /// @c publicId
-  int resolve_entity (const ACEXML_Char* ref, ACEXML_Char*& systemId,
-                      ACEXML_Char*& publicId);
-  /// Number of items in the Entity Manager
-  size_t size(void) const;
-  /// Reset the state
-  int reset (void);
-private:
-  ACEXML_ENTITIES_MANAGER* entities_;
-  bool init_;
-#endif /* ACEXML_ENTITY_MANAGER_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Entity_Manager.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Entity_Manager.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Entity_Manager.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,66 +0,0 @@
-// Entity_Manager.i,v 1.5 2004/01/09 00:50:35 kitty Exp
-ACEXML_INLINE int
-ACEXML_Entity_Manager::add_entity (const ACEXML_Char *ref,
-                                   const ACEXML_Char *v)
-  if (!this->entities_ )
-    ACE_NEW_RETURN (this->entities_, ACEXML_ENTITIES_MANAGER, -1);
-  ACEXML_String name (ref, 0, 0);
-  ACEXML_String value  (v, 0, 0);
-  return this->entities_->bind (name, value);
-ACEXML_INLINE const ACEXML_Char*
-ACEXML_Entity_Manager::resolve_entity (const ACEXML_Char *ref)
-  if (!this->entities_)
-    return 0;
-  ACEXML_ENTITY_ENTRY *entry;
-  if (this->entities_->find (ACEXML_String (ref, 0, 0),
-                            entry) == 0)
-    return entry->int_id_.c_str();
-  return 0;
-ACEXML_INLINE int
-ACEXML_Entity_Manager::resolve_entity (const ACEXML_Char* ref,
-                                       ACEXML_Char*& systemId,
-    return 0;
-  publicId = systemId = 0;
-  ACEXML_ENTITY_ENTRY_ITERATOR iter (*this->entities_, ref);
-  ACEXML_ENTITY_ENTRY_ITERATOR end (*this->entities_, ref, 1);
-  if (iter != end)
-      systemId = ACE_const_cast (ACEXML_Char*, (*iter).int_id_.c_str());
-      ++iter;
-      if (iter != end)
-        publicId = ACE_const_cast (ACEXML_Char*, (*iter).int_id_.c_str());
-      return 0;
-  return -1;
-ACEXML_INLINE int
-ACEXML_Entity_Manager::reset (void)
-  delete this->entities_;
-  this->entities_ = 0;
-  return 0;
-ACEXML_INLINE size_t
-ACEXML_Entity_Manager::size (void) const
-    return 0;
-  return this->entities_->current_size();
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Makefile
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Makefile	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Makefile	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,10 +0,0 @@
-# Makefile,v 1.15 2003/07/14 18:47:58 jwillemsen Exp
-#       GNU ACE Workspace
-include $(ACE_ROOT)/include/makeinclude/macros.GNU
-TARGETS_NESTED := $(TARGETS_NESTED:.nested=)
-$(TARGETS_NESTED):
-	@$(MAKE) -f Makefile.ACEXML_Parser -C . $(@);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Makefile.ACEXML_Parser
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Makefile.ACEXML_Parser	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Makefile.ACEXML_Parser	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,548 +0,0 @@
-#       GNU Makefile
-MAKEFILE        = Makefile.ACEXML_Parser
-LIB_UNCHECKED   = libACEXML_Parser.a
-SHLIB_UNCHECKED = libACEXML_Parser.$(SOEXT)
-FILES = \
-  Entity_Manager \
-  Parser \
-  ParserContext \
-  ParserInternals
-#       Include macros and targets
-LIB   = $(LIB_UNCHECKED)
-SHLIB = $(SHLIB_UNCHECKED)
-ACE_SHLIBS = -lACE
-include $(ACE_ROOT)/include/makeinclude/wrapper_macros.GNU
-LSRC   = $(addsuffix .cpp, $(FILES))
-include $(ACE_ROOT)/include/makeinclude/rules.common.GNU
-include $(ACE_ROOT)/include/makeinclude/rules.nonested.GNU
-include $(ACE_ROOT)/include/makeinclude/rules.lib.GNU
-include $(ACE_ROOT)/include/makeinclude/rules.local.GNU
-CPPFLAGS     += -I../../..
-ifeq ($(shared_libs),1)
-  ifneq ($(SHLIB),)
-    CPPFLAGS += -DACEXML_PARSER_BUILD_DLL
-  endif
-endif
-ifeq ($(static_libs),1)
-  ifneq ($(LIB),)
-    CPPFLAGS += -DACE_AS_STATIC_LIBS
-  endif
-endif
-LDFLAGS      += -L../../../ACEXML/common -L../../../ace
-ACE_SHLIBS  = -lACEXML $(ACELIB)
-#       Local targets
-realclean: clean
-ifneq ($(GENERATED_DIRTY),)
-	-$(RM) -r $(GENERATED_DIRTY)
-endif
-#       Dependencies
-# DO NOT DELETE THIS LINE -- g++dep uses it.
-# DO NOT PUT ANYTHING AFTER THIS LINE, IT WILL GO AWAY.
-.obj/Entity_Manager.o .obj/Entity_Manager.so .shobj/Entity_Manager.o .shobj/Entity_Manager.so: Entity_Manager.cpp \
-  Entity_Manager.h \
-  $(ACE_ROOT)/ace/pre.h \
-  Parser_export.h \
-  $(ACE_ROOT)/ace/config-all.h \
-  $(ACE_ROOT)/ace/config.h \
-  $(ACE_ROOT)/ace/$(ACE_PLATFORM_CONFIG) \
-  $(ACE_ROOT)/ace/post.h \
-  $(ACE_ROOT)/ace/ace_wchar.h \
-  $(ACE_ROOT)/ace/ace_wchar.inl \
-  $(ACE_ROOT)/ace/OS_main.h \
-  $(ACE_ROOT)/ace/ACE_export.h \
-  $(ACE_ROOT)/ACEXML/common/XML_Types.h \
-  $(ACE_ROOT)/ace/SString.h \
-  $(ACE_ROOT)/ace/SStringfwd.h \
-  $(ACE_ROOT)/ace/Basic_Types.h \
-  $(ACE_ROOT)/ace/os_include/os_limits.h \
-  $(ACE_ROOT)/ace/os_include/os_unistd.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_types.h \
-  $(ACE_ROOT)/ace/os_include/os_stddef.h \
-  $(ACE_ROOT)/ace/os_include/os_inttypes.h \
-  $(ACE_ROOT)/ace/os_include/os_stdint.h \
-  $(ACE_ROOT)/ace/os_include/os_stdio.h \
-  $(ACE_ROOT)/ace/os_include/os_stdarg.h \
-  $(ACE_ROOT)/ace/os_include/os_float.h \
-  $(ACE_ROOT)/ace/os_include/os_stdlib.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_wait.h \
-  $(ACE_ROOT)/ace/os_include/os_signal.h \
-  $(ACE_ROOT)/ace/os_include/os_time.h \
-  $(ACE_ROOT)/ace/os_include/os_ucontext.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_resource.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_time.h \
-  $(ACE_ROOT)/ace/String_Base.h \
-  $(ACE_ROOT)/ace/String_Base_Const.h \
-  $(ACE_ROOT)/ace/Global_Macros.h \
-  $(ACE_ROOT)/ace/OS_Errno.h \
-  $(ACE_ROOT)/ace/os_include/os_errno.h \
-  $(ACE_ROOT)/ace/String_Base.cpp \
-  $(ACE_ROOT)/ace/ACE.h \
-  $(ACE_ROOT)/ace/Flag_Manip.h \
-  $(ACE_ROOT)/ace/Flag_Manip.i \
-  $(ACE_ROOT)/ace/OS_NS_fcntl.h \
-  $(ACE_ROOT)/ace/os_include/os_fcntl.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_stat.h \
-  $(ACE_ROOT)/ace/Handle_Ops.h \
-  $(ACE_ROOT)/ace/Handle_Ops.i \
-  $(ACE_ROOT)/ace/Lib_Find.h \
-  $(ACE_ROOT)/ace/Lib_Find.i \
-  $(ACE_ROOT)/ace/Init_ACE.h \
-  $(ACE_ROOT)/ace/Init_ACE.i \
-  $(ACE_ROOT)/ace/Sock_Connect.h \
-  $(ACE_ROOT)/ace/os_include/netinet/os_in.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_socket.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_uio.h \
-  $(ACE_ROOT)/ace/Sock_Connect.i \
-  $(ACE_ROOT)/ace/Default_Constants.h \
-  $(ACE_ROOT)/ace/ACE.i \
-  $(ACE_ROOT)/ace/OS_NS_unistd.h \
-  $(ACE_ROOT)/ace/Time_Value.h \
-  $(ACE_ROOT)/ace/OS_NS_Thread.h \
-  $(ACE_ROOT)/ace/os_include/os_pthread.h \
-  $(ACE_ROOT)/ace/Base_Thread_Adapter.h \
-  $(ACE_ROOT)/ace/OS_Log_Msg_Attributes.h \
-  $(ACE_ROOT)/ace/iosfwd.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_sem.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_ipc.h \
-  $(ACE_ROOT)/ace/os_include/os_semaphore.h \
-  $(ACE_ROOT)/ace/OS_Memory.h \
-  $(ACE_ROOT)/ace/OS_NS_stdlib.h \
-  $(ACE_ROOT)/ace/OS_NS_signal.h \
-  $(ACE_ROOT)/ace/Object_Manager_Base.h \
-  $(ACE_ROOT)/ace/Cleanup.h \
-  $(ACE_ROOT)/ace/os_include/os_ctype.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_socket.h \
-  $(ACE_ROOT)/ace/os_include/net/os_if.h \
-  $(ACE_ROOT)/ace/OS_NS_stropts.h \
-  $(ACE_ROOT)/ace/os_include/os_stropts.h \
-  $(ACE_ROOT)/ace/Malloc_Base.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_mman.h \
-  $(ACE_ROOT)/ace/Auto_Ptr.h \
-  $(ACE_ROOT)/ace/Auto_Ptr.cpp \
-  $(ACE_ROOT)/ace/Auto_Ptr.i \
-  $(ACE_ROOT)/ace/OS_NS_string.h \
-  $(ACE_ROOT)/ace/String_Base.i \
-  $(ACE_ROOT)/ace/Min_Max.h \
-  $(ACE_ROOT)/ace/Hash_Map_Manager.h \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.h \
-  $(ACE_ROOT)/ace/Functor.h \
-  $(ACE_ROOT)/ace/Functor_T.h \
-  $(ACE_ROOT)/ace/Functor_T.cpp \
-  $(ACE_ROOT)/ace/Functor_T.i \
-  $(ACE_ROOT)/ace/Log_Msg.h \
-  $(ACE_ROOT)/ace/Log_Priority.h \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.cpp \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.i \
-  $(ACE_ROOT)/ace/Guard_T.h \
-  $(ACE_ROOT)/ace/Lock.h \
-  $(ACE_ROOT)/ace/Guard_T.cpp \
-  $(ACE_ROOT)/ace/Guard_T.inl \
-  $(ACE_ROOT)/ace/RW_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/RW_Mutex.h \
-  $(ACE_ROOT)/ace/Null_Mutex.h \
-  Entity_Manager.i
-.obj/Parser.o .obj/Parser.so .shobj/Parser.o .shobj/Parser.so: Parser.cpp \
-  Parser.h \
-  Parser_export.h \
-  $(ACE_ROOT)/ACEXML/common/XMLReader.h \
-  $(ACE_ROOT)/ACEXML/common/ACEXML_Export.h \
-  $(ACE_ROOT)/ACEXML/common/ContentHandler.h \
-  $(ACE_ROOT)/ACEXML/common/Env.h \
-  $(ACE_ROOT)/ACEXML/common/XML_Macros.h \
-  $(ACE_ROOT)/ace/Exception_Macros.h \
-  $(ACE_ROOT)/ACEXML/common/Exception.h \
-  $(ACE_ROOT)/ACEXML/common/SAXExceptions.h \
-  $(ACE_ROOT)/ACEXML/common/Locator.h \
-  $(ACE_ROOT)/ACEXML/common/Attributes.h \
-  $(ACE_ROOT)/ACEXML/common/DTDHandler.h \
-  $(ACE_ROOT)/ACEXML/common/EntityResolver.h \
-  $(ACE_ROOT)/ACEXML/common/InputSource.h \
-  $(ACE_ROOT)/ACEXML/common/CharStream.h \
-  $(ACE_ROOT)/ACEXML/common/ErrorHandler.h \
-  $(ACE_ROOT)/ACEXML/common/LocatorImpl.h \
-  $(ACE_ROOT)/ACEXML/common/NamespaceSupport.h \
-  $(ACE_ROOT)/ace/Containers_T.h \
-  $(ACE_ROOT)/ace/Containers.h \
-  $(ACE_ROOT)/ace/Node.h \
-  $(ACE_ROOT)/ace/Node.cpp \
-  $(ACE_ROOT)/ace/Array_Base.h \
-  $(ACE_ROOT)/ace/Array_Base.cpp \
-  $(ACE_ROOT)/ace/Array_Base.inl \
-  $(ACE_ROOT)/ace/Unbounded_Set.h \
-  $(ACE_ROOT)/ace/Unbounded_Set.cpp \
-  $(ACE_ROOT)/ace/Unbounded_Set.inl \
-  $(ACE_ROOT)/ace/Unbounded_Queue.h \
-  $(ACE_ROOT)/ace/Unbounded_Queue.cpp \
-  $(ACE_ROOT)/ace/Unbounded_Queue.inl \
-  $(ACE_ROOT)/ace/Containers_T.cpp \
-  $(ACE_ROOT)/ace/Containers_T.i \
-  $(ACE_ROOT)/ace/Obstack.h \
-  $(ACE_ROOT)/ace/Obstack_T.h \
-  $(ACE_ROOT)/ace/Obchunk.h \
-  $(ACE_ROOT)/ace/Malloc.h \
-  $(ACE_ROOT)/ace/Malloc_T.h \
-  $(ACE_ROOT)/ace/Malloc_Allocator.h \
-  $(ACE_ROOT)/ace/Free_List.h \
-  $(ACE_ROOT)/ace/Free_List.cpp \
-  $(ACE_ROOT)/ace/Free_List.i \
-  $(ACE_ROOT)/ace/Malloc_T.cpp \
-  $(ACE_ROOT)/ace/Malloc_T.i \
-  $(ACE_ROOT)/ace/Memory_Pool.h \
-  $(ACE_ROOT)/ace/Event_Handler.h \
-  $(ACE_ROOT)/ace/Atomic_Op.h \
-  $(ACE_ROOT)/ace/Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Atomic_Op_T.h \
-  $(ACE_ROOT)/ace/Atomic_Op_T.cpp \
-  $(ACE_ROOT)/ace/Atomic_Op_T.i \
-  $(ACE_ROOT)/ace/Synch_Traits.h \
-  $(ACE_ROOT)/ace/Signal.h \
-  $(ACE_ROOT)/ace/Mem_Map.h \
-  $(ACE_ROOT)/ace/SV_Semaphore_Complex.h \
-  $(ACE_ROOT)/ace/SV_Semaphore_Simple.h \
-  $(ACE_ROOT)/ace/SV_Semaphore_Simple.i \
-  $(ACE_ROOT)/ace/SV_Semaphore_Complex.i \
-  $(ACE_ROOT)/ace/Obstack_T.cpp \
-  $(ACE_ROOT)/ace/Obstack_T.i \
-  ParserInternals.h \
-  ParserContext.h \
-  $(ACE_ROOT)/ace/Swap.h \
-  $(ACE_ROOT)/ace/Swap.cpp \
-  $(ACE_ROOT)/ace/Swap.inl \
-  Parser.i \
-  $(ACE_ROOT)/ACEXML/common/Transcode.h \
-  $(ACE_ROOT)/ACEXML/common/AttributesImpl.h \
-  $(ACE_ROOT)/ACEXML/common/StrCharStream.h \
-  $(ACE_ROOT)/ACEXML/common/StreamFactory.h \
-  $(ACE_ROOT)/ace/OS_NS_strings.h \
-  $(ACE_ROOT)/ace/os_include/os_strings.h
-.obj/ParserContext.o .obj/ParserContext.so .shobj/ParserContext.o .shobj/ParserContext.so: ParserContext.cpp \
-  ParserContext.h \
-  Parser_export.h \
-  ParserContext.inl
-.obj/ParserInternals.o .obj/ParserInternals.so .shobj/ParserInternals.o .shobj/ParserInternals.so: ParserInternals.cpp \
-  Parser_export.h \
-# IF YOU PUT ANYTHING HERE IT WILL GO AWAY
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Makefile.ACEXML_Parser.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Makefile.ACEXML_Parser.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Makefile.ACEXML_Parser.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,62 +0,0 @@
-# Makefile.ACEXML_Parser.bor,v 1.3 2003/12/20 14:21:14 jwillemsen Exp
-# Makefile for building the ACEXML_Parser library with Borland C++ Builder
-NAME = ACEXML_Parser
-OBJFILES = \
-	$(OBJDIR)\Entity_Manager.obj \
-	$(OBJDIR)\Parser.obj \
-	$(OBJDIR)\ParserContext.obj \
-	$(OBJDIR)\ParserInternals.obj
-EXTERNAL_LIBS = \
-LFLAGS = \
-	-j..\..\..\ACEXML\common\$(CONFIG_SUBDIR) -j..\..\..\ACEXML\common \
-	-L..\..\..\ACEXML\common\$(CONFIG_SUBDIR) -L..\..\..\ACEXML\common \
-	-j..\..\..\ace\$(CONFIG_SUBDIR) -j..\..\..\ace \
-	-L..\..\..\ace\$(CONFIG_SUBDIR) -L..\..\..\ace \
-  -j$(CORE_BINDIR) \
-  -L$(CORE_BINDIR)
-LIBFILES = \
-	ACEXML$(LIB_DECORATOR).lib \
-	ACE$(LIB_DECORATOR).lib \
-	$(EXTERNAL_LIBS)
-!ifdef STATIC
-LIB_FLAGS = -DACE_AS_STATIC_LIBS
-DLL_FLAGS =
-!else
-LIB_FLAGS =
-DLL_FLAGS = -DACEXML_PARSER_BUILD_DLL
-!endif
-CFLAGS = \
-	-I..\..\.. \
-	$(LIB_FLAGS) \
-	$(DLL_FLAGS)
-CPPDIR = .
-INCLUDES = \
-	Parser.h \
-	ParserContext.h \
-	Parser_export.h \
-	Entity_Manager.i \
-	Parser.i \
-	ParserContext.inl
-BASE_BINDIR = ..\..\..\bin
-!include <$(ACE_ROOT)\include\makeinclude\build_library.bor>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Makefile.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Makefile.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Makefile.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,23 +0,0 @@
-# Makefile.bor,v 1.6 2003/12/20 14:21:14 jwillemsen Exp
-#       Borland Workspace
-!include <$(ACE_ROOT)\include\makeinclude\make_flags.bor>
-all:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML_Parser.bor all
-clean:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML_Parser.bor clean
-realclean:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML_Parser.bor realclean
-install:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ACEXML_Parser.bor install
-regenerate:
-	/usr/bin/perl /build/kitty/ACE_wrappers/bin/mwc.pl -type borland ACEXML.mwc
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,3397 +0,0 @@
-// Parser.cpp,v 1.29 2004/01/09 00:50:35 kitty Exp
-# include "ACEXML/parser/parser/Parser.i"
-#endif /* __ACEXML_INLINE__ */
-#include "ace/ACE.h"
-#include "ACEXML/common/Transcode.h"
-#include "ACEXML/common/AttributesImpl.h"
-#include "ACEXML/common/StrCharStream.h"
-#include "ACEXML/common/StreamFactory.h"
-#include "ACEXML/parser/parser/ParserInternals.h"
-#include "ace/OS_NS_string.h"
-#include "ace/OS_NS_strings.h"
-static const ACEXML_Char default_attribute_type[] = ACE_TEXT ("CDATA");
-const ACEXML_Char
-ACEXML_Parser::simple_parsing_feature_[] = ACE_TEXT ("Simple");
-const ACEXML_Char
-ACEXML_Parser::namespaces_feature_[] = ACE_TEXT ("http://xml.org/sax/features/namespaces");
-const ACEXML_Char
-ACEXML_Parser::namespace_prefixes_feature_[] = ACE_TEXT ("http://xml.org/sax/features/namespace-prefixes");
-const ACEXML_Char
-ACEXML_Parser::validation_feature_[] = ACE_TEXT ("http://xml.org/sax/features/validation");
-ACEXML_Parser::ACEXML_Parser (void)
-  :   dtd_handler_ (0),
-      entity_resolver_ (0),
-      content_handler_ (0),
-      error_handler_ (0),
-      doctype_ (0),
-      current_ (0),
-      alt_stack_ (MAXPATHLEN),
-      nested_namespace_ (0),
-      ref_state_ (ACEXML_ParserInt::INVALID),
-      external_subset_ (0),
-      external_entity_ (0),
-      has_pe_refs_ (0),
-      standalone_ (0),
-      external_dtd_ (0),
-      internal_dtd_ (0),
-      simple_parsing_ (0),
-      validate_ (1),
-      namespaces_(1),
-      namespace_prefixes_ (0)
-ACEXML_Parser::~ACEXML_Parser (void)
-int
-ACEXML_Parser::initialize(ACEXML_InputSource* input)
-  // Initialize namespace support
-  if (this->xml_namespace_.init() == -1)
-                  ACE_TEXT ("Error initializing namespace support\n")));
-      return -1;
-  for (int i = 0; i < 5; ++i)
-      if (this->predef_entities_.add_entity (ACEXML_ParserInt::predef_ent_[i],
-                                             ACEXML_ParserInt::predef_val_[i])
-          != 0)
-          ACE_ERROR ((LM_DEBUG,
-                      ACE_TEXT ("Error adding entity %s to Manager\n"),
-                      ACEXML_ParserInt::predef_ent_[i]));
-          return -1;
-  return this->switch_input (input, input->getSystemId());
-void
-ACEXML_Parser::parse (const ACEXML_Char *systemId ACEXML_ENV_ARG_DECL)
-  ACEXML_InputSource* input = 0;
-  ACE_NEW (input, ACEXML_InputSource (systemId));
-  this->parse (input ACEXML_ENV_ARG_PARAMETER);
-void
-ACEXML_Parser::parse (ACEXML_InputSource *input ACEXML_ENV_ARG_DECL)
-  if (input == 0)
-      this->fatal_error(ACE_TEXT ("Invalid input source")
-                        ACEXML_ENV_ARG_PARAMETER);
-      ACEXML_CHECK;
-  if (this->content_handler_ == 0)
-      this->fatal_error (ACE_TEXT ("No content handlers defined. Exiting..")
-      ACEXML_CHECK;
-  if (this->validate_ && this->dtd_handler_ == 0)
-      this->fatal_error (ACE_TEXT ("No DTD handlers defined. Exiting..")
-      ACEXML_CHECK;
-  if (this->initialize(input) == -1)
-      this->fatal_error (ACE_TEXT ("Failed to initialize parser state")
-      ACEXML_CHECK;
-  // Set up Locator.
-  this->content_handler_->setDocumentLocator (this->current_->getLocator());
-  int xmldecl_defined = 0;
-  ACEXML_Char fwd = this->get();  // Consume '<'
-  if (fwd == '<' && this->peek() == '?')
-      this->get();      // Consume '?'
-      fwd = this->peek();
-      if (fwd == 'x' && !xmldecl_defined)
-          this->parse_xml_decl (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-          ACEXML_CHECK;
-          xmldecl_defined = 1;
-  // We need a XMLDecl in a Valid XML document
-  if (this->validate_ && !xmldecl_defined)
-      this->fatal_error (ACE_TEXT ("Expecting an XMLDecl at the beginning of")
-                         ACE_TEXT (" a valid document")
-      ACEXML_CHECK;
-  this->content_handler_->startDocument (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-  ACEXML_CHECK;
-  int doctype_defined = 0;
-  for (int prolog_done = 0; prolog_done == 0; )
-      // Expect a '<' only if we have encountered a XMLDecl, or we are
-      // looping through Misc blocks.
-      if (xmldecl_defined)
-          if (this->skip_whitespace () != '<')
-              this->fatal_error (ACE_TEXT ("Expecting '<' at the beginning of ")
-                                 ACE_TEXT ("Misc section")
-              ACEXML_CHECK;
-      switch (fwd)
-          case '?':
-            this->get();
-            this->parse_processing_instruction (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-            ACEXML_CHECK;
-            break;
-          case '!':
-            this->get();
-            fwd = this->peek ();
-            if (fwd == 'D' && !doctype_defined)       // DOCTYPE
-                // This will also take care of the trailing MISC block if any.
-                this->parse_doctypedecl (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-                ACEXML_CHECK;
-                doctype_defined = 1;
-                // Now that we have a DOCTYPE Decl defined, we shouldn't
-                // accept XML Decl any longer
-            else if (fwd == 'D')
-                this->fatal_error (ACE_TEXT ("Duplicate DOCTYPE declaration")
-                ACEXML_CHECK;
-            else if (fwd == '-')  // COMMENT
-                if (this->parse_comment () < 0)
-                    this->fatal_error(ACE_TEXT ("Invalid comment in document")
-                    ACEXML_CHECK;
-            break;
-          case 0:
-            this->fatal_error (ACE_TEXT ("Unexpected end-of-file")
-            ACEXML_CHECK;
-          default:                // Root element begins
-            prolog_done = 1;
-            break;
-  if (this->validate_ && !doctype_defined)
-      this->warning (ACE_TEXT ("No doctypeDecl in valid document")
-      ACEXML_CHECK;
-  // Now parse root element.
-  this->parse_element (1 ACEXML_ENV_ARG_PARAMETER);
-  ACEXML_CHECK;
-  this->content_handler_->endDocument (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-  ACEXML_CHECK;
-  // Reset the parser state
-  this->reset();
-int
-ACEXML_Parser::parse_doctypedecl (ACEXML_ENV_SINGLE_ARG_DECL)
-  if (this->parse_token (ACE_TEXT ("DOCTYPE")) < 0)
-      this->fatal_error(ACE_TEXT ("Expecting keyword DOCTYPE in a doctypedecl")
-      ACEXML_CHECK_RETURN (-1);
-  ACEXML_Char nextch = 0;
-  if (this->skip_whitespace_count (&nextch) == 0)
-      this->fatal_error(ACE_TEXT ("Expecting a space between DOCTYPE keyword ")
-                        ACE_TEXT ("and name") ACEXML_ENV_ARG_PARAMETER);
-  this->doctype_ = this->parse_name ();
-  if (this->doctype_ == 0)
-      this->fatal_error(ACE_TEXT ("Invalid DOCTYPE name")
-  int count = this->skip_whitespace_count (&nextch);
-  if (nextch == 'S' || nextch == 'P') // ExternalID defined
-      if (count == 0)
-          this->fatal_error(ACE_TEXT ("Expecting a space between DOCTYPE")
-                            ACE_TEXT ("keyword and name")
-      this->external_dtd_ = 1;
-      this->parse_external_dtd (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-  nextch = this->skip_whitespace ();
-  switch (nextch)
-      case '[':
-        this->internal_dtd_ = 1;  // Internal DTD definition
-        this->parse_internal_dtd (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-        break;
-      case '>':                   // End of DTD definition
-        // This is an XML document without a doctypedecl.
-        if (this->validate_ && !this->external_dtd_)
-            this->fatal_error (ACE_TEXT ("No DTD defined")
-        return 0;
-      case '0':
-      default:
-        break;
-  if (this->skip_whitespace() != '>')
-      this->fatal_error(ACE_TEXT ("Expecting '>' at end of doctypedecl")
-  return 0;
-int
-ACEXML_Parser::parse_internal_dtd (ACEXML_ENV_SINGLE_ARG_DECL)
-  this->ref_state_ = ACEXML_ParserInt::IN_INT_DTD;
-  ACEXML_Char nextch = this->skip_whitespace ();
-  do {
-    switch (nextch)
-        case '<':
-          nextch = this->get();
-          switch (nextch)
-              case '!':
-                this->parse_markup_decl (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-                break;
-              case '?':
-                break;
-              default:
-                this->fatal_error (ACE_TEXT ("Invalid internal subset")
-                break;
-          break;
-        case '%':
-          this->has_pe_refs_ = 1;
-          this->parse_PE_reference (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-          break;
-        case ']':                 // End of internal definitions.
-          return 0;
-        case '&':
-          this->fatal_error (ACE_TEXT ("Invalid Reference in internal DTD")
-          break;
-        case 0:
-          this->pop_context (0 ACEXML_ENV_ARG_PARAMETER);
-          break;
-        default:
-          this->fatal_error (ACE_TEXT ("Invalid content in internal subset")
-  } while (1);
-  ACE_NOTREACHED (return -1);
-int
-ACEXML_Parser::parse_external_dtd (ACEXML_ENV_SINGLE_ARG_DECL)
-  this->ref_state_ = ACEXML_ParserInt::IN_EXT_DTD;
-  ACEXML_Char* publicId = 0;
-  ACEXML_Char* systemId = 0;
-  if (this->parse_external_id (publicId, systemId
-                               ACEXML_ENV_ARG_PARAMETER) != 0)
-      this->fatal_error (ACE_TEXT ("Error in parsing ExternalID")
-  if (this->validate_)
-      ACEXML_Char* uri = this->normalize_systemid (systemId);
-      ACE_Auto_Basic_Array_Ptr<ACEXML_Char> cleanup_uri (uri);
-      ACEXML_InputSource* ip = 0;
-      if (this->entity_resolver_)
-          ip = this->entity_resolver_->resolveEntity (publicId,
-                                                      (uri ? uri : systemId)
-      if (ip)
-          if (this->switch_input (ip, (uri ? uri : systemId), publicId) != 0)
-            return -1;
-      else
-          ACEXML_StreamFactory factory;
-          ACEXML_CharStream* cstream = factory.create_stream (uri ?
-                                                              uri: systemId);
-          if (!cstream) {
-            this->fatal_error (ACE_TEXT ("Invalid input source")
-          if (this->switch_input (cstream, systemId, publicId) != 0)
-            return -1;
-      this->parse_external_subset (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-  return 0;
-int
-ACEXML_Parser::parse_external_subset (ACEXML_ENV_SINGLE_ARG_DECL)
-  this->external_subset_ = 1;
-  int nrelems = 0;
-  ACEXML_Char nextch = this->skip_whitespace();
-  do {
-    switch (nextch)
-        case '<':
-          switch (nextch)
-              case '!':
-                nextch = this->peek();
-                if (nextch == '[')
-                  this->parse_conditional_section (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-                else
-                break;
-              case '?':
-                if (nextch == 'x')
-                  this->parse_text_decl (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-                else
-                break;
-              default:
-                this->fatal_error (ACE_TEXT ("Invalid content in external DTD")
-          break;
-        case '%':
-          break;
-        case 0:
-          nrelems = this->pop_context (0 ACEXML_ENV_ARG_PARAMETER);
-          if (nrelems == 1)
-            return 0;
-          break;
-        default:
-    nextch = this->skip_whitespace();
-  } while (1);
-int
-ACEXML_Parser::parse_conditional_section (ACEXML_ENV_SINGLE_ARG_DECL)
-  ACEXML_Char ch = this->get ();
-  int include = 0;
-  if (ch != '[')
-      this->fatal_error(ACE_TEXT ("Internal Parser Error")
-  ch = this->skip_whitespace();
-  if (ch == '%')
-  if (ch == 'I')
-      ch = this->get();
-      switch (ch)
-          case 'N':
-            if (this->parse_token (ACE_TEXT ("CLUDE")) < 0)
-                this->fatal_error (ACE_TEXT ("Expecting keyword INCLUDE in ")
-                                   ACE_TEXT ("conditionalSect")
-            include = 1;
-            break;
-          case 'G':
-            if (this->parse_token (ACE_TEXT ("GNORE")) < 0)
-                this->fatal_error (ACE_TEXT ("Expecting keyword IGNORE in ")
-            include = 0;
-            break;
-          default:
-            this->fatal_error (ACE_TEXT ("Invalid conditionalSect")
-      ACEXML_Char fwd = '\xFF';
-      this->skip_whitespace_count (&fwd);
-      if (fwd == 0)
-          this->get(); // Consume the 0
-  else
-  if (this->skip_whitespace() != '[')
-      this->fatal_error (ACE_TEXT ("Expecting '[' in conditionalSect")
-  if (include)
-    this->parse_includesect (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-  else
-    this->parse_ignoresect (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-  return 0;
-int
-ACEXML_Parser::parse_ignoresect (ACEXML_ENV_SINGLE_ARG_DECL)
-  int count = 0;
-  int done = 0;
-  do {
-    switch (nextch)
-        case '<':
-          if (this->peek() == '!')
-              this->get();
-              if (this->peek() == '[')
-                  this->get();
-                  count++;
-          break;
-        case ']':
-          if (this->peek() == ']')
-              this->get();
-              if (this->peek() == '>')
-                  this->get();
-                  if (count)
-                      --count;
-                      break;
-                  done = 1;
-          break;
-        case 0: // [VC: Proper Conditional Section/PE Nesting]
-          if (count != 0)
-              this->fatal_error (ACE_TEXT ("Invalid Conditional Section/PE ")
-                                 ACE_TEXT ("Nesting ")
-        default:
-          break;
-    if (done)
-      break;
-  } while (1);
-  return 0;
-int
-ACEXML_Parser::parse_includesect (ACEXML_ENV_SINGLE_ARG_DECL)
-  do {
-    switch (nextch)
-        case '<':
-          switch (nextch)
-              case '!':
-                else
-                break;
-              case '?':
-                break;
-              default:
-                this->fatal_error (ACE_TEXT ("Invalid includeSect")
-          break;
-        case '%':
-          break;
-        case ']':
-                  return 0;
-        default:
-  } while (1);
-int
-ACEXML_Parser::parse_markup_decl (ACEXML_ENV_SINGLE_ARG_DECL)
-  ACEXML_Char nextch = this->peek ();
-  switch (nextch)
-      case 'E':         // An ELEMENT or ENTITY decl
-        this->get ();
-        nextch = this->peek ();
-        switch (nextch)
-            case 'L':
-              this->parse_element_decl (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-              break;
-            case 'N':
-              this->parse_entity_decl (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-              break;
-            default:
-              this->fatal_error(ACE_TEXT ("Expecting keyword ELEMENT/ENTITY")
-        break;
-      case 'A':         // An ATTLIST decl
-        this->parse_attlist_decl (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-        break;
-      case 'N':         // A NOTATION decl
-        this->parse_notation_decl (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-        break;
-      case '-':         // a comment.
-            this->fatal_error(ACE_TEXT ("Invalid comment")
-        break;
-      case 0: //  [VC: Proper Declaration/PE Nesting]
-      default:
-        this->fatal_error (ACE_TEXT ("Invalid markupDecl")
-  return 0;
-int
-ACEXML_Parser::parse_external_id (ACEXML_Char *&publicId,
-                                  ACEXML_Char *&systemId
-  ACEXML_Char nextch = this->get ();
-  ACEXML_Char fwd = 0;
-  switch (nextch)
-      case 'S':                   // External SYSTEM id.
-        if (this->parse_token (ACE_TEXT ("YSTEM")) < 0 ||
-            this->skip_whitespace_count () < 1)
-            this->fatal_error(ACE_TEXT ("Expecting keyword SYSTEM")
-        if (this->parse_system_literal (systemId) != 0)
-            this->fatal_error(ACE_TEXT ("Invalid systemLiteral")
-        break;
-      case 'P': // External PUBLIC id or previously defined PUBLIC id.
-        if (this->parse_token (ACE_TEXT ("UBLIC")) < 0 ||
-            this->fatal_error(ACE_TEXT ("Expecing keyword PUBLIC")
-        if (this->parse_pubid_literal (publicId) != 0)
-            this->fatal_error(ACE_TEXT ("Invalid PubidLiteral")
-        this->skip_whitespace_count(&fwd);
-        if (fwd == '\'' || fwd == '"')
-        else if (this->ref_state_ != ACEXML_ParserInt::IN_NOTATION)
-            this->fatal_error(ACE_TEXT ("Expecting systemLiteral after a ")
-                              ACE_TEXT ("PUBLIC keyword")
-        break;
-      default:
-        this->fatal_error(ACE_TEXT ("Invalid system/public Literal")
-  return 0;
-ACEXML_Char*
-ACEXML_Parser::normalize_systemid (const ACEXML_Char* systemId)
-  if (ACE_OS::strstr (systemId, ACE_TEXT("ftp://")) != 0 ||
-      ACE_OS::strstr (systemId, ACE_TEXT ("http://")) != 0 ||
-      ACE_OS::strstr (systemId, ACE_TEXT ("file://")) != 0)
-    return 0;
-  else
-      ACEXML_Char* normalized_uri = 0;
-      const ACEXML_Char* baseURI = this->current_->getLocator()->getSystemId();
-      ACE_ASSERT (baseURI);
-      const ACEXML_Char* temp = 0;
-      if (ACE_OS::strstr (baseURI, ACE_TEXT ("http://")) != 0)
-        // baseURI is a HTTP URL and systemId is relative. Note that this
-        // is not compliant with RFC2396. Caveat Emptor !
-        temp = ACE_OS::strrchr (baseURI, '/');
-      else
-        // baseURI is a local file and systemId is relative
-        // Unlike the HTTP one, this will work always.
-        temp = ACE_OS::strrchr (baseURI,ACE_DIRECTORY_SEPARATOR_CHAR);
-      if (temp)
-          size_t pos = temp - baseURI + 1;
-          size_t len = pos + ACE_OS::strlen (systemId) + 1;
-          ACE_NEW_RETURN (normalized_uri, ACEXML_Char[len], 0);
-          ACE_OS::strncpy (normalized_uri, baseURI, pos);
-          ACE_OS::strcpy (normalized_uri + pos, systemId);
-          return normalized_uri;
-      return 0;
-void
-ACEXML_Parser::parse_element (int is_root ACEXML_ENV_ARG_DECL)
-  // Parse STag.
-  const ACEXML_Char *startname = this->parse_name ();
-  if (startname == 0)
-      return;
-  if (is_root && this->doctype_ != 0
-      && ACE_OS::strcmp (startname, this->doctype_) != 0)
-      this->fatal_error (ACE_TEXT ("Root element different from DOCTYPE")
-      return ;
-  ACEXML_AttributesImpl attributes;
-  ACEXML_Char ch;
-  const ACEXML_Char* ns_uri = 0;
-  const ACEXML_Char* ns_lname = 0; // namespace URI and localName
-  for (int start_element_done = 0; start_element_done == 0;)
-      ch = this->skip_whitespace ();
-      switch (ch)
-          case 0:
-            this->fatal_error(ACE_TEXT ("Internal Parser error")
-            return;
-          case '/':
-            if (this->get () != '>')
-                this->fatal_error(ACE_TEXT ("Expecting '>' at end of element ")
-                                  ACE_TEXT ("definition")
-                return;
-            this->xml_namespace_.processName(startname, ns_uri,
-                                             ns_lname, 0);
-            this->prefix_mapping (this->xml_namespace_.getPrefix(ns_uri),
-                                  ns_uri, ns_lname, 1
-            ACEXML_CHECK;
-            this->content_handler_->startElement(ns_uri, ns_lname,
-                                                 startname, &attributes
-            ACEXML_CHECK;
-            this->content_handler_->endElement (ns_uri, ns_lname, startname
-            ACEXML_CHECK;
-                                  ns_uri, ns_lname, 0
-            ACEXML_CHECK;
-            if (this->nested_namespace_ >= 1)
-                this->xml_namespace_.popContext ();
-                this->nested_namespace_--;
-            return;
-          case '>':
-            this->xml_namespace_.processName (startname, ns_uri,
-                                              ns_lname, 0);
-            ACEXML_CHECK;
-            this->content_handler_->startElement(ns_uri, ns_lname, startname,
-                                                 &attributes
-            ACEXML_CHECK;
-            start_element_done = 1;
-            break;
-          default:
-            ACEXML_Char *attvalue = 0;
-            ACEXML_Char *attname = this->parse_name (ch);
-            if (attname == 0 ||
-                this->skip_equal () != 0 ||
-                this->parse_attvalue (attvalue ACEXML_ENV_ARG_PARAMETER) != 0)
-                this->fatal_error(ACE_TEXT ("Error reading attribute value")
-                return;
-            // Handling new namespace if any. Notice that the order of
-            // namespace declaration does matter.
-            if (ACE_OS::strcmp (attname, ACE_TEXT("xmlns")) == 0)
-                if (this->namespaces_)
-                    this->xml_namespace_.pushContext ();
-                    this->nested_namespace_++;
-                    ACEXML_Char* name = ACE_OS::strchr (attname, ':');
-                    const ACEXML_Char* ns_name = (name == 0)?
-                                                 empty_string:name+1;
-                    if (this->xml_namespace_.declarePrefix (ns_name,
-                                                            attvalue) == -1)
-                        this->fatal_error(ACE_TEXT ("Duplicate definition of ")
-                                          ACE_TEXT ("prefix")
-                        return;
-                if (this->namespace_prefixes_)
-                    // Namespace_prefixes_feature_ is required. So add the
-                    // xmlns:foo to the list of attributes.
-                    if (attributes.addAttribute (0, 0, attname,
-                                                 default_attribute_type,
-                                                 attvalue) == -1)
-                        this->fatal_error(ACE_TEXT ("Duplicate attribute ")
-                                          ACE_TEXT ("definition. Hint: Try ")
-                                          ACE_TEXT ("setting namespace_prefix")
-                                          ACE_TEXT ("es feature to 0")
-                        return;
-                if (!this->namespaces_ && !this->namespace_prefixes_)
-                    this->fatal_error(ACE_TEXT ("One of namespaces or ")
-                                      ACE_TEXT ("namespace_prefixes should be")
-                                      ACE_TEXT (" declared")
-                    return;
-            else
-                const ACEXML_Char *uri, *lName;
-                this->xml_namespace_.processName (attname, uri, lName, 1);
-                if (attributes.addAttribute (uri, lName, attname,
-                                             attvalue) == -1)
-                    return;
-            break;
-  if (this->parse_content (startname, ns_uri, ns_lname
-    return;
-int
-ACEXML_Parser::parse_content (const ACEXML_Char* startname,
-                              const ACEXML_Char* ns_uri,
-                              const ACEXML_Char* ns_lname ACEXML_ENV_ARG_DECL)
-  ACEXML_Char *cdata;
-  size_t cdata_length = 0;
-  // Parse element contents.
-  while (1)
-      switch (ch)
-          case 0:
-            this->pop_context (1 ACEXML_ENV_ARG_PARAMETER);
-            break;
-          case '<':
-            // Push out old 'characters' event.
-            if (cdata_length != 0)
-                cdata = this->obstack_.freeze ();
-                this->content_handler_->characters (cdata, 0, cdata_length
-                this->obstack_.unwind (cdata);
-                cdata_length = 0;
-            ch = this->peek();
-            switch (ch)
-                case '!':             // a comment or a CDATA section.
-                  this->get ();       // consume '!'
-                  ch = this->peek ();
-                  if (ch == '-')      // a comment
-                          this->fatal_error(ACE_TEXT ("Invalid comment in ")
-                                            ACE_TEXT ("document")
-                  else if (ch == '[') // a CDATA section.
-                      this->parse_cdata (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-                  else
-                      this->fatal_error(ACE_TEXT ("Expecting a CDATA section ")
-                                        ACE_TEXT ("or a comment section")
-                  break;
-                case '?':             // a PI.
-                  this->get();        // consume the '?'
-                    (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-                  break;
-                case '/':             // an ETag.
-                    this->get ();       // consume '/'
-                    ACEXML_Char* endname = this->parse_name ();
-                    if (endname == 0 ||
-                        ACE_OS::strcmp (startname, endname) != 0)
-                        this->fatal_error(ACE_TEXT ("Name in ETag doesn't ")
-                                          ACE_TEXT ("match name in STag")
-                    if (this->skip_whitespace () != '>')
-                        this->fatal_error(ACE_TEXT ("Expecting '>' at end ")
-                                          ACE_TEXT ("of element")
-                        return -1;
-                                                        endname
-                    return 0;
-                default:              // a new nested element?
-                  this->parse_element (0 ACEXML_ENV_ARG_PARAMETER);
-                  break;
-            break;
-          case '&':
-            if (this->peek () == '#')
-                ACEXML_Char buf[7];
-                size_t len = 0;
-                do
-                    len = sizeof (buf);
-                    if (this->parse_char_reference (buf, len) != 0)
-                        // [WFC: Legal Character]
-                        this->fatal_error (ACE_TEXT ("Invalid CharRef")
-                  } while (buf[0] == '&' && this->peek() == '#');
-                  for (size_t j = 0; j < len; ++j)
-                    this->obstack_.grow (buf[j]);
-                cdata_length += len;
-            else
-                this->ref_state_ = ACEXML_ParserInt::IN_CONTENT;
-                int length = this->parse_entity_reference(ACEXML_ENV_SINGLE_ARG_PARAMETER);
-                if (length == 1)
-                  cdata_length++;
-            break;
-          case '\x20': case '\x0D': case '\x0A': case '\x09':
-//             if (this->validate_)
-//                 // Flush out any non-whitespace characters
-//                 if (cdata_length != 0)
-//                     cdata = this->obstack_.freeze ();
-//                     this->content_handler_->characters(cdata, 0, cdata_length
-//                                                        ACEXML_ENV_ARG_PARAMETER);
-//                     ACEXML_CHECK_RETURN (-1);
-//                     this->obstack_.unwind (cdata);
-//                     cdata_length = 0;
-//                 ++cdata_length;
-//                 this->obstack_.grow (ch);
-//                 while (1)
-//                     ch = this->peek();
-//                     if (ch == '\x20' || ch == '\x0D' || ch == '\x0A' ||
-//                         ch == '\x09')
-//                         ch = this->get();
-//                         continue;
-//                     break;
-//                 this->content_handler_->ignorableWhitespace (cdata, 0,
-//                                                              cdata_length
-//                 break;
-            // Fall thru...
-          default:
-            ++cdata_length;
-            this->obstack_.grow (ch);
-  return 0;
-int
-ACEXML_Parser::parse_cdata (ACEXML_ENV_SINGLE_ARG_DECL)
-  ACE_THROW_SPEC ((ACEXML_SAXException))
-  if (this->parse_token (ACE_TEXT ("[CDATA[")) < 0)
-      this->fatal_error(ACE_TEXT ("Expecting '[CDATA[' at beginning of CDATA ")
-                        ACE_TEXT ("section")
-  ACEXML_Char ch;
-  int datalen = 0;
-  ACEXML_Char *cdata = 0;
-  while (1)
-      ch = this->get ();
-      // Anything goes except the sequence "]]>".
-      if (ch == ']' && this->peek() == ']')
-          ACEXML_Char temp = ch;
-          ch = this->get();
-          if (ch == ']' && this->peek() == '>')
-              ch = this->get();
-              this->content_handler_->characters (cdata, 0, datalen
-              this->obstack_.unwind(cdata);
-              return 0;
-          this->obstack_.grow (temp);
-          ++datalen;
-      ++datalen;
-int
-ACEXML_Parser::parse_entity_decl (ACEXML_ENV_SINGLE_ARG_DECL)
-  ACEXML_Char nextch;
-  if ((this->parse_token (ACE_TEXT ("NTITY")) < 0) ||
-      this->skip_whitespace_count (&nextch) == 0)
-      this->fatal_error (ACE_TEXT ("Expecting keyword ENTITY followed by a ")
-                         ACE_TEXT ("space") ACEXML_ENV_ARG_PARAMETER);
-  int is_GEDecl = 1;
-  if (nextch == '%')            // This is a PEDecl.
-      is_GEDecl = 0;
-      this->get ();             // consume the '%'
-          this->fatal_error (ACE_TEXT ("Expecting space between % and ")
-                             ACE_TEXT ("entity name")
-  ACEXML_Char *entity_name = this->parse_name ();
-  if (entity_name == 0)
-      this->fatal_error (ACE_TEXT ("Invalid entity name")
-      this->fatal_error (ACE_TEXT ("Expecting space between entity name and ")
-                         ACE_TEXT ("entityDef")
-  int retval = 0;
-  if (nextch == '\'' || nextch == '"')
-      ACEXML_Char *entity_value = 0;
-      if (this->parse_entity_value (entity_value
-          this->fatal_error(ACE_TEXT ("Invalid EntityValue")
-      if (is_GEDecl)
-        retval = this->internal_GE_.add_entity (entity_name,
-                                                entity_value);
-      else
-        retval = this->internal_PE_.add_entity (entity_name,
-                                                entity_value);
-      if (retval < 0)
-          this->fatal_error (ACE_TEXT ("Internal Parser Error in adding")
-                             ACE_TEXT ("Entity to map")
-      else if (retval == 1)
-          this->warning (ACE_TEXT ("Duplicate entity found")
-  else
-      ACEXML_Char *systemid, *publicid;
-      this->parse_external_id (publicid, systemid
-      if (systemid == 0)
-          this->fatal_error(ACE_TEXT ("Invalid SystemLiteral")
-      this->skip_whitespace_count (&nextch);
-      if (nextch == 'N')        // NDATA section followed
-          if (is_GEDecl == 0)
-              this->fatal_error(ACE_TEXT ("Invalid NDataDecl in PEDef")
-          if ((this->parse_token (ACE_TEXT ("NDATA")) < 0) ||
-              this->fatal_error(ACE_TEXT ("Expecting keyword NDATA followed ")
-                                ACE_TEXT ("by a space") ACEXML_ENV_ARG_PARAMETER);
-          ACEXML_Char *ndata = this->parse_name ();
-          if (this->validate_) // [VC: Notation Declared]
-              if (!this->notations_.resolve_entity (ndata))
-                  this->fatal_error (ACE_TEXT ("Undeclared Notation name")
-              this->dtd_handler_->unparsedEntityDecl(entity_name, publicid,
-                                                     systemid, ndata
-      else
-          if (is_GEDecl)
-            retval = this->external_GE_.add_entity (entity_name,
-                                                    systemid);
-          else
-            retval = this->external_PE_.add_entity (entity_name,
-                                                    systemid);
-          if (retval < 0)
-            this->warning(ACE_TEXT ("Duplicate external entity")
-          if (is_GEDecl)
-                                                    publicid);
-          else
-                                                    publicid);
-          if (retval < 0)
-            this->warning (ACE_TEXT ("Duplicate entity definition")
-  // End of ENTITY definition
-      this->fatal_error(ACE_TEXT ("Expecting '>' at end of entityDef")
-  return 0;
-int
-ACEXML_Parser::parse_attlist_decl (ACEXML_ENV_SINGLE_ARG_DECL)
-  if (this->parse_token (ACE_TEXT ("ATTLIST")) < 0)
-      this->fatal_error(ACE_TEXT ("Expecting keyword 'ATTLIST'")
-  int count = check_for_PE_reference (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-  if (!count)
-      this->fatal_error(ACE_TEXT ("Expecting space between ATTLIST and ")
-                        ACE_TEXT ("element name") ACEXML_ENV_ARG_PARAMETER);
-  ACEXML_Char *element_name = this->parse_name ();
-  if (element_name == 0)
-      this->fatal_error(ACE_TEXT ("Invalid element Name in attlistDecl")
-  ACEXML_Char* attname = 0;
-  count = this->skip_whitespace_count (&fwd);
-  // Parse AttDef*
-  while (fwd != '>')
-      if (!this->check_for_PE_reference (ACEXML_ENV_SINGLE_ARG_PARAMETER)
-          && !count)
-        this->fatal_error(ACE_TEXT ("Expecting space between element ")
-                          ACE_TEXT ("name and AttDef")
-      if (fwd == '>')
-        break;
-      count = this->check_for_PE_reference (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-      attname = this->parse_attname (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-      if (!count)
-          this->fatal_error(ACE_TEXT ("Expecting space between AttName and ")
-                            ACE_TEXT ("AttType") ACEXML_ENV_ARG_PARAMETER);
-      this->parse_atttype (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-      if (!count)
-          this->fatal_error(ACE_TEXT ("Expecting space between AttType and")
-                            ACE_TEXT (" DefaultDecl")
-      this->parse_defaultdecl (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-  this->get ();                 // consume closing '>'
-  return 0;
-int
-ACEXML_Parser::check_for_PE_reference (ACEXML_ENV_SINGLE_ARG_DECL)
-  // Skip any leading whitespaces and store the number of such chars skipped
-  int count = this->skip_whitespace_count (&fwd);
-  if (fwd == 0)
-  if (fwd == '%')
-      this->get();  // Consume the %
-      if (this->external_subset_)
-      else
-          this->fatal_error(ACE_TEXT ("Illegal PERef within markupDecl")
-  if (count)
-      // We have atleast one whitespace. So just skip any more whitespaces
-      // and return the count
-      this->skip_whitespace_count();
-      return count;
-  return this->skip_whitespace_count();
-ACEXML_Char*
-ACEXML_Parser::parse_attname (ACEXML_ENV_SINGLE_ARG_DECL)
-  // Parse attribute name
-  ACEXML_Char *att_name = this->parse_name ();
-  if (att_name == 0)
-      this->fatal_error(ACE_TEXT ("Invalid AttName")
-      ACEXML_CHECK_RETURN (0);
-  return att_name;
-int
-ACEXML_Parser::parse_defaultdecl (ACEXML_ENV_SINGLE_ARG_DECL)
-  // DefaultDecl ::=  '#REQUIRED' | '#IMPLIED' | (('#FIXED' S)? AttValue)
-  ACEXML_Char *fixed_attr = 0;
-  switch (nextch)
-      case '#':
-        this->get ();         // consume the '#'
-        switch (this->get ())
-            case 'R':
-              if (this->parse_token (ACE_TEXT ("EQUIRED")) < 0)
-                  this->fatal_error(ACE_TEXT ("Expecting keyword REQUIRED")
-              // We now know this attribute is required
-              // @@ Set up the validator as such.
-              break;
-            case 'I':
-              if (this->parse_token (ACE_TEXT ("MPLIED")) < 0)
-                  this->fatal_error(ACE_TEXT ("Expecting keyword IMPLIED")
-              // We now know this attribute is implied.
-              break;
-            case 'F':
-              if (this->parse_token (ACE_TEXT ("IXED")) < 0 ||
-                  this->skip_whitespace_count () == 0)
-                  this->fatal_error(ACE_TEXT ("Expecting keyword FIXED")
-              // We now know this attribute is fixed.
-              if (this->parse_attvalue (fixed_attr
-                  this->fatal_error(ACE_TEXT ("Invalid Default AttValue")
-              // @@ set up validator
-              break;
-            default:
-              this->fatal_error (ACE_TEXT ("Invalid DefaultDecl")
-        break;
-      case '\'':
-      case '"':
-        if (this->parse_attvalue (fixed_attr ACEXML_ENV_ARG_PARAMETER) != 0)
-            this->fatal_error(ACE_TEXT ("Invalid AttValue")
-        break;
-      default:
-        break;
-  return 0;
-int
-ACEXML_Parser::parse_tokenized_type (ACEXML_ENV_SINGLE_ARG_DECL)
-  ACEXML_Char ch = this->get();
-  switch (ch)
-      case 'I':
-        if (this->get () == 'D')
-            if (this->peek() != 'R' && this->is_whitespace (this->peek()))
-                // We have successfully identified the type of the
-                // attribute as ID
-                // @@ Set up validator as such.
-                break;
-            if (this->parse_token (ACE_TEXT ("REF")) == 0)
-                if (this->peek() != 'S' && this->is_whitespace (this->peek()))
-                    // the attribute as IDREF
-                    break;
-                else if (this->peek() == 'S'
-                         && this->get() // consume the 'S'
-                         && this->is_whitespace (this->peek()))
-                    // the attribute as IDREFS
-                    break;
-        // Admittedly, this error message is not precise enough
-        this->fatal_error(ACE_TEXT ("Expecting keyword `ID', `IDREF', or")
-                          ACE_TEXT ("`IDREFS'") ACEXML_ENV_ARG_PARAMETER);
-      case 'E':               // ENTITY or ENTITIES
-        if (this->parse_token (ACE_TEXT ("NTIT")) == 0)
-            if (nextch == 'Y')
-                // the attribute as ENTITY
-            else if (this->parse_token (ACE_TEXT ("IES")) == 0)
-                // the attribute as ENTITIES
-            if (this->is_whitespace (this->peek()))
-                // success
-                break;
-        this->fatal_error(ACE_TEXT ("Expecting keyword `ENTITY', or")
-                          ACE_TEXT ("`ENTITIES'") ACEXML_ENV_ARG_PARAMETER);
-      case 'M':
-        if (this->parse_token (ACE_TEXT ("TOKEN")) == 0)
-                // the attribute as NMTOKEN
-                break;
-                     && this->get()
-                // the attribute as NMTOKENS
-                break;
-        this->fatal_error(ACE_TEXT ("Expecting keyword `NMTOKEN' or `NMTO")
-                          ACE_TEXT ("KENS'") ACEXML_ENV_ARG_PARAMETER);
-        break;
-      default:
-        this->fatal_error (ACE_TEXT ("Internal Parser Error")
-        break;
-  return 0;
- * AttType    ::=    StringType | TokenizedType | EnumeratedType
- * StringType ::=    'CDATA'
- * TokenizedType    ::=    'ID'       [VC: ID]
- *                                    [VC: One ID per Element Type]
- *                                    [VC: ID Attribute Default]
- *                       | 'IDREF' [VC: IDREF]
- *                       | 'IDREFS' [VC: IDREF]
- *                       | 'ENTITY' [VC: Entity Name]
- *                       | 'ENTITIES' [VC: Entity Name]
- *                       | 'NMTOKEN' [VC: Name Token]
- *                       | 'NMTOKENS'
- * EnumeratedType  ::=    NotationType | Enumeration
- * NotationType    ::=   'NOTATION' S '(' S? Name (S? '|' S? Name)* S? ')'
- *                                  [VC: Notation Attributes]
- *                                  [VC: One Notation Per Element Type]
- *                                  [VC: No Notation on Empty Element]
- * Enumeration ::= '(' S? Nmtoken (S? '|' S? Nmtoken)* S? ')'
- *                                  [VC: Enumeration]
-int
-ACEXML_Parser::parse_atttype (ACEXML_ENV_SINGLE_ARG_DECL)
-  ACEXML_Char nextch = this->peek();
-  switch (nextch)
-      case 'C':               // CDATA
-        if (this->parse_token (ACE_TEXT ("CDATA")) < 0)
-            this->fatal_error(ACE_TEXT ("Expecting keyword 'CDATA'")
-        // Else, we have successfully identified the type of the
-        // attribute as CDATA
-        // @@ Set up validator appropriately here.
-        break;
-      case 'I': case 'E':      // ID, IDREF, IDREFS, ENTITY or ENTITIES
-        this->parse_tokenized_type (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-        break;
-      case 'N':             // NMTOKEN, NMTOKENS, or NOTATION
-        this->get();
-        if (nextch != 'M' && nextch != 'O')
-            this->fatal_error (ACE_TEXT ("Expecting keyword 'NMTOKEN', ")
-                               ACE_TEXT ("'NMTOKENS' or 'NOTATION'")
-        if (nextch == 'M')
-            break;
-        else                   // NOTATION
-            if (this->parse_token (ACE_TEXT ("OTATION")) < 0)
-                this->fatal_error(ACE_TEXT ("Expecting keyword `NOTATION'")
-            int count = this->check_for_PE_reference (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-            if (!count)
-                this->fatal_error (ACE_TEXT ("Expecting space between keyword ")
-                                   ACE_TEXT ("NOTATION and '('")
-            if (this->get () != '(')
-                this->fatal_error(ACE_TEXT ("Expecting '(' in NotationType")
-            this->check_for_PE_reference (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-            do {
-              ACEXML_Char *notation_name = this->parse_name ();
-              if (notation_name == 0)
-                  this->fatal_error(ACE_TEXT ("Invalid notation name")
-              // @@ get another notation name, set up validator as such
-            } while (nextch == '|');
-            if (nextch != ')')
-                this->fatal_error (ACE_TEXT ("Expecting a ')' after a ")
-                                   ACE_TEXT ("NotationType declaration")
-        break;
-      case '(':               // EnumeratedType - Enumeration
-        this->get();
-        do {
-          ACEXML_Char *token_name = this->parse_nmtoken ();
-          if (token_name == 0)
-              this->fatal_error(ACE_TEXT ("Invalid enumeration name")
-          // @@ get another nmtoken, set up validator as such
-                               ACE_TEXT ("Enumeration declaration")
-        break;
-      default:
-          this->fatal_error(ACE_TEXT ("Invalid AttType")
-        ACE_NOTREACHED (break);
-  return 0;
-int
-ACEXML_Parser::parse_notation_decl (ACEXML_ENV_SINGLE_ARG_DECL)
-  if (this->parse_token (ACE_TEXT ("NOTATION")) < 0)
-      this->fatal_error(ACE_TEXT ("Expecting Keyword 'NOTATION'")
-  if (!count)
-      this->fatal_error (ACE_TEXT ("Expecting a space between keyword NOTATION")
-                         ACE_TEXT (" and notation name")
-  ACEXML_Char *notation = this->parse_name ();
-  if (notation == 0)
-      this->fatal_error(ACE_TEXT ("Invalid Notation name")
-  if (!count)
-      this->fatal_error (ACE_TEXT ("Expecting a space between notation name ")
-                         ACE_TEXT ("and ExternalID/PublicID")
-  // Gross hack but otherwise we need to go around a lot of loops to parse,
-  // When the ExternalID starts with 'PUBLIC' we cannot distinguish a
-  // PublicId from a ExternalID by looking using a one character read-ahead
-  ACEXML_ParserInt::ReferenceState temp = this->ref_state_;
-  this->ref_state_ = ACEXML_ParserInt::IN_NOTATION;
-  // Restore the original value.
-  this->ref_state_ = temp;
-  // [VC: Unique Notation Name]
-  if (systemid && this->notations_.add_entity (notation, systemid) != 0
-      && this->validate_)
-  if (publicid)
-      int retval = this->notations_.add_entity (notation, publicid);
-      if (retval != 0 && !systemid && this->validate_)
-      this->fatal_error(ACE_TEXT ("Expecting '>' at end of NotationDecl")
-  if (this->validate_ && this->dtd_handler_)
-      this->dtd_handler_->notationDecl (notation,
-                                        publicid,
-                                        systemid ACEXML_ENV_ARG_PARAMETER);
-  return 0;
-int
-ACEXML_Parser::parse_element_decl (ACEXML_ENV_SINGLE_ARG_DECL)
-  if (this->parse_token (ACE_TEXT ("LEMENT")) < 0)
-      this->fatal_error (ACE_TEXT ("Expecting keyword ELEMENT")
-  if (!count)
-      this->fatal_error (ACE_TEXT ("Expecting a space between keyword ELEMENT")
-                         ACE_TEXT (" and element name")
-      this->fatal_error (ACE_TEXT ("Invalid element name")
-  if (!count)
-      this->fatal_error (ACE_TEXT ("Expecting a space between element name ")
-                         ACE_TEXT ("and element definition")
-  switch (nextch)
-      case 'E':                   // EMPTY
-        if (this->parse_token (ACE_TEXT ("EMPTY")) < 0)
-            this->fatal_error (ACE_TEXT ("Expecting keyword EMPTY")
-        break;
-      case 'A':                   // ANY
-        if (this->parse_token (ACE_TEXT ("ANY")) < 0)
-            this->fatal_error (ACE_TEXT ("Expecting keyword ANY")
-        break;
-      case '(':                   // children
-        this->parse_children_definition (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-        break;
-      default:                    // error
-        this->fatal_error (ACE_TEXT ("Invalid element definition")
-      this->fatal_error (ACE_TEXT ("Expecting '>' after element defintion")
-  return 0;
-int
-ACEXML_Parser::parse_children_definition (ACEXML_ENV_SINGLE_ARG_DECL)
-  this->get ();                 // consume the '('
-  int subelement_number = 0;
-  switch (nextch)
-      case '#':                   // Mixed element,
-        if (this->parse_token (ACE_TEXT ("#PCDATA")) < 0)
-            this->fatal_error(ACE_TEXT ("Expecting keyword '#PCDATA'")
-        while (nextch == '|')
-            ACEXML_Char *name = this->parse_name ();
-            // @@ name will be used in the Validator later.
-            ACE_UNUSED_ARG (name);
-            ++subelement_number;
-            // @@ Install Mixed element name into the validator.
-        if (nextch != ')' ||
-            (subelement_number && this->get () != '*'))
-            this->fatal_error(ACE_TEXT ("Expecing ')' or ')*' at end of Mixed")
-                              ACE_TEXT (" element") ACEXML_ENV_ARG_PARAMETER);
-        // @@ close the element definition in the validator.
-        break;
-      default:
-        int status = this->parse_child (1 ACEXML_ENV_ARG_PARAMETER);
-        if (status != 0)
-          return -1;
-  // Check for trailing '?', '*', '+'
-  switch (nextch)
-      case '?':
-        // @@ Consume the character and inform validator as such,
-        this->get ();
-        break;
-      case '*':
-        this->get ();
-        break;
-      case '+':
-        this->get ();
-        break;
-      default:
-        break;                    // not much to do.
-  return 0;
-int
-ACEXML_Parser::parse_child (int skip_open_paren ACEXML_ENV_ARG_DECL)
-  // Conditionally consume the open paren.
-  if (skip_open_paren == 0 && this->get () != '(')
-      this->fatal_error(ACE_TEXT ("Expecting '(' at beginning of children")
-  ACEXML_Char node_type = 0;
-  do {
-    switch (nextch)
-        case '(':
-          this->parse_child (0 ACEXML_ENV_ARG_PARAMETER);
-          break;
-        default:
-          // must be an element name here.
-          ACEXML_Char *subelement = this->parse_name ();
-          if (subelement == 0)
-              this->fatal_error(ACE_TEXT ("Invalid subelement name")
-          switch (nextch)
-              case '?':
-                this->get ();
-                break;
-              case '*':
-                this->get ();
-                break;
-              case '+':
-                this->get ();
-                break;
-              default:
-          // @@ Inform validator of the new element here.
-          break;
-    switch (nextch)
-        case '|':
-          switch (node_type)
-              case 0:
-                node_type = '|';
-                // @@ inform validator of this new type??
-                break;
-              case '|':
-                break;
-              default:
-                this->fatal_error (ACE_TEXT ("Expecting `,', `|', or `)' ")
-                                   ACE_TEXT ("while defining an element")
-          break;
-        case ',':
-              case 0:
-                node_type = ',';
-                break;
-              case ',':
-                break;
-              default:
-          break;
-        case ')':
-          break;
-        default:
-    nextch = this->get();  // Consume the `,' or `|' or `)'
-    if (nextch == ')')
-      break;
-  } while (nextch != ')');
-  switch (nextch)
-      case '?':
-        this->get ();
-        break;
-      case '*':
-        this->get ();
-        break;
-      case '+':
-        this->get ();
-        break;
-      default:
-  return 0;
-int
-ACEXML_Parser::parse_char_reference (ACEXML_Char *buf, size_t& len)
-  if (len < 7)   // Max size of a CharRef plus terminating '\0'
-    return -1;
-  if (ch != '#')      // Internal error.
-    return -1;
-  int hex = 0;
-  if (ch == 'x')
-      hex = 1;
-      this->get ();
-  size_t i = 0;
-  int more_digit = 0;
-  for ( ; i < len &&
-          (this->isNormalDigit (ch) || (hex ? this->isCharRef(ch): 0)); ++i)
-      buf[i] = ch;
-      ch = this->get();
-      ++more_digit;
-  if (ch != ';' || !more_digit)
-    return -1;
-  buf[i] = 0;
-  ACEXML_UCS4 sum = (ACEXML_UCS4) ACE_OS::strtol (buf, 0, (hex ? 16 : 10));
-  if (!this->isChar (sum))
-    return -1;
-  int clen;
-#if defined (ACE_USES_WCHAR)    // UTF-16
-  if ((clen = ACEXML_Transcoder::ucs42utf16 (sum, buf, len)) < 0)
-    return -1;
-#else                          // or UTF-8
-  if ((clen = ACEXML_Transcoder::ucs42utf8 (sum, buf, len)) < 0)
-    return -1;
-#endif
-  buf [clen] = 0;
-  len = clen;
-  return 0;
-ACEXML_Char*
-ACEXML_Parser::parse_reference_name (void)
-  if (!this->isLetter (ch) && (ch != '_' || ch != ':'))
-    return 0;
-  while (ch) {
-    this->alt_stack_.grow (ch);
-    if (!this->isNameChar (ch))
-      break;
-  if (ch != ';')
-    return 0;
-  ch = this->get();
-  return this->alt_stack_.freeze ();
-int
-ACEXML_Parser::parse_attvalue (ACEXML_Char *&str ACEXML_ENV_ARG_DECL)
-  ACEXML_Char quote = this->get ();
-  if (quote != '\'' && quote != '"')  // Not a quoted string.
-    return -1;
-  while (1)
-      if (ch == quote)
-          ACEXML_Char* temp = this->obstack_.freeze ();
-          // If the attribute type is not CDATA, then the XML processor
-          // must further process the normalized attribute value by
-          // discarding any leading and trailing space (#x20) characters,
-          // and by replacing sequences of space (#x20) characters by a
-          // single space (#x20) character.
-          //           if (atttype != CDATA) {
-          //             ACEXML_Char* start = temp;
-          //             ACEXML_Char* end = temp + ACE_OS::strlen (temp);
-          //             while (*start == '\x20')
-          //               start++;
-          //             if (start == end) // String which is all spaces
-          //               str = start;
-          //             while (*start != 0)
-          //                 this->obstack_.grow (*start);
-          //                 start++;
-          //                   start++;
-          //             str = this->obstack_.freeze();
-          str = temp;
-          return 0;
-      switch (ch)
-          case '&':
-                size_t len = sizeof (buf);
-                    this->fatal_error (ACE_TEXT ("Invalid CharacterRef")
-            else
-                this->ref_state_ = ACEXML_ParserInt::IN_ATT_VALUE;
-                this->parse_entity_reference (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-            break;
-            this->obstack_.grow ('\x20');
-            break;
-          case '<': // [WFC: No < in Attribute Values]
-            this->fatal_error (ACE_TEXT ("Illegal '<' in AttValue")
-            break;
-          case 0:
-            break;
-          default:
-            break;
-      ch = this->get();
-int
-ACEXML_Parser::parse_entity_reference (ACEXML_ENV_SINGLE_ARG_DECL)
-  ACEXML_Char* replace = this->parse_reference_name ();
-  if (replace == 0)
-      this->fatal_error (ACE_TEXT ("Invalid Reference name")
-  //  [WFC: Parsed Entity]
-  if (this->unparsed_entities_.resolve_entity (replace)) {
-    this->fatal_error (ACE_TEXT ("EntityRef refers to unparsed entity")
-  // Look in the internal general entities set first.
-  const ACEXML_Char* entity = this->internal_GE_.resolve_entity(replace);
-  // Look in the predefined entities.
-  if (!entity)
-      entity = this->predef_entities_.resolve_entity (replace);
-      if (entity)
-          // Special case to return the length in case of predefined entities
-          this->obstack_.grow (*entity);
-          return 1;
-  if (!this->validate_)
-      if (this->standalone_)
-          // [WFC: Entity Declared]
-          this->fatal_error (ACE_TEXT ("Undeclared Entity reference")
-      else
-          this->content_handler_->skippedEntity (replace
-          return 0;
-  // No match in internal subset
-  if (!entity
-          // or No DTDs
-      && (!(this->internal_dtd_ || this->external_dtd_)
-          // or Only Internal DTD and no parameter entity references
-          || (this->internal_dtd_ && !this->external_dtd_
-              && !this->has_pe_refs_)
-          // or Standalone = 'yes'
-          || this->standalone_))
-  if (!entity)
-      if (this->external_GE_.resolve_entity (replace, systemId, publicId) < 0)
-      if (this->ref_state_ == ACEXML_ParserInt::IN_ATT_VALUE)
-          this->fatal_error (ACE_TEXT ("External EntityRef in Attribute Value")
-      this->external_entity_++;
-  // [WFC: No Recursion]
-  ACEXML_Char* ref_name = replace;
-  int present = this->GE_reference_.insert (ref_name);
-  if (present == 1 || present == -1)
-      while (this->GE_reference_.pop(ref_name) != -1)
-      this->fatal_error (ACE_TEXT ("Recursion in resolving entity")
-  if (!this->external_entity_)
-      ACEXML_StrCharStream* str = 0;
-      ACE_NEW_RETURN (str, ACEXML_StrCharStream, -1);
-      if (str->open (entity, replace) < 0
-          || this->switch_input (str, replace) != 0)
-          this->fatal_error (ACE_TEXT ("Unable to create internal input ")
-                             ACE_TEXT ("stream")
-      return 0;
-  else
-          if (ip)
-                                      publicId) != 0)
-              return 0;
-      ACEXML_CharStream* cstream = factory.create_stream (uri ? uri: systemId);
-      if (!cstream) {
-  return 0;
-int
-ACEXML_Parser::parse_PE_reference (ACEXML_ENV_SINGLE_ARG_DECL)
-  if (replace == 0)
-      this->fatal_error (ACE_TEXT ("Invalid PEReference name")
-  const ACEXML_Char* entity = this->internal_PE_.resolve_entity(replace);
-  if (!entity &&                     // No match in internal
-      (!this->external_dtd_ ||       // or No External DTDs
-       this->standalone_))           // or Standalone
-      // [VC: Entity Declared]
-      this->fatal_error (ACE_TEXT ("Undefined Internal PEReference")
-  if (!entity && this->validate_)
-      if (this->external_PE_.resolve_entity (replace, systemId, publicId) < 0)
-          this->fatal_error (ACE_TEXT ("Undefined PEReference")
-  int present = this->PE_reference_.insert (ref_name);
-      while (this->PE_reference_.pop(ref_name) != -1)
-  if (entity && !this->external_entity_)
-      ACEXML_StrCharStream* sstream = 0;
-      ACEXML_String str (entity);
-      if (this->ref_state_ != ACEXML_ParserInt::IN_ENTITY_VALUE)
-          const ACEXML_Char ch = '\x20';
-          str = ch + str + ch;
-      //  ACE_DEBUG ((LM_DEBUG,
-      //             ACE_TEXT ("Entity is %s\n Replacement Text is : %s\n"),
-      //             replace, str.c_str()));
-      ACE_NEW_RETURN (sstream, ACEXML_StrCharStream, -1);
-      if (sstream->open (str.c_str(), replace) < 0
-          || this->switch_input (sstream, replace) != 0)
-          this->fatal_error (ACE_TEXT ("Error in switching InputSource")
-      return 0;
-  else if (this->external_entity_ && this->validate_)
-      if (ip)
-          return 0;
-      else
-          if (!cstream) {
-          if (this->ref_state_ == ACEXML_ParserInt::IN_ENTITY_VALUE)
-              ACEXML_Char less, mark;
-              if (this->peek() == '<')
-                  less = this->get();
-                  if (this->peek() == '?')
-                      mark = this->get();
-                      if (this->peek() == 'x')
-                      else
-                          this->obstack_.grow (less);
-                          this->obstack_.grow (mark);
-          return 0;
-  return -1;
-int
-ACEXML_Parser::parse_entity_value (ACEXML_Char *&str
-                                   ACEXML_ENV_ARG_DECL)
-    return -1;
-  while (1)
-      if (ch == quote)
-          str = this->obstack_.freeze ();
-          return 0;
-      switch (ch)
-          case '&':
-                        this->fatal_error (ACE_TEXT ("Invalid character ")
-                                           ACE_TEXT ("reference")
-                        return -1;
-                    break;
-            break;
-          case '%':
-                this->ref_state_ = ACEXML_ParserInt::IN_ENTITY_VALUE;
-                this->parse_PE_reference(ACEXML_ENV_SINGLE_ARG_PARAMETER);
-                break;
-            break;
-          case 0:
-            break;
-          default:
-            break;
-      ch = this->get();
-ACEXML_Char *
-ACEXML_Parser::parse_name (ACEXML_Char ch)
-  if (ch == 0)
-  if (!this->isLetter (ch) && ch != '_' && ch != ':')
-    return 0;
-  while (ch) {
-      break;
-  return this->obstack_.freeze ();
-ACEXML_Char*
-ACEXML_Parser::parse_nmtoken (ACEXML_Char ch)
-  if (ch == 0)
-    return 0;
-  while (ch) {
-      break;
-int
-ACEXML_Parser::parse_version_num (ACEXML_Char*& str)
-    return -1;
-  int numchars = 0;
-  while (1)
-      if (ch == quote && !numchars)
-        return -1;
-      else if (ch == quote)
-          return 0;
-      // [26]    VersionNum ::= ([a-zA-Z0-9_.:] | '-')+
-      if (ch == '-' || ((ch >= 'a' && ch <= 'z') ||
-                        (ch >= 'A' && ch <= 'Z') ||
-                        (ch >= '0' && ch <= '9') ||
-                        (ch == '_' || ch == '.' || ch == ':')))
-          numchars++;
-      else
-        return -1;
-int
-ACEXML_Parser::parse_system_literal (ACEXML_Char*& str)
-  const ACEXML_Char quote = this->get();
-    return -1;
-  while (1)
-      if (ch == quote)
-          return 0;
-      switch (ch)
-          case '\x00': case '\x01': case '\x02': case '\x03': case '\x04':
-          case '\x05': case '\x06': case '\x07': case '\x08': case '\x09':
-          case '\x0A': case '\x0B': case '\x0C': case '\x0D': case '\x0E':
-          case '\x0F': case '\x10': case '\x11': case '\x12': case '\x13':
-          case '\x14': case '\x15': case '\x16': case '\x17': case '\x18':
-          case '\x19': case '\x1A': case '\x1B': case '\x1C': case '\x1D':
-          case '\x1E': case '\x1F': case '\x7F': case '\x20': case '<':
-          case '>': case '#': case '%':
-            ACE_ERROR ((LM_ERROR,
-                        ACE_TEXT ("Invalid char %c in SystemLiteral\n"), ch));
-            return -1;
-          default:
-int
-ACEXML_Parser::parse_pubid_literal (ACEXML_Char*& str)
-    return -1;
-  while (1)
-      if (ch == quote)
-          return 0;
-      else if (this->isPubidChar (ch))
-      else
-        return -1;
-int
-ACEXML_Parser::parse_encname (ACEXML_Char*& str)
-  const ACEXML_Char quote = this->get ();
-    return -1;
-  int numchars = 0;
-  while (1)
-        return -1;
-          return 0;
-      // [81]    EncName ::= [A-Za-z] ([A-Za-z0-9._] | '-')*
-      if (!((ch >= 'a' && ch <= 'z') || (ch >= 'A' && ch <= 'Z'))
-          && !numchars)
-        return -1;
-                        (ch == '_' || ch == '.')))
-          numchars++;
-      else
-        return -1;
-int
-ACEXML_Parser::parse_sddecl (ACEXML_Char*& str)
-    return -1;
-  int numchars = 0;
-  while (1)
-      if (ch == quote && numchars < 2)
-        return -1;
-          return 0;
-      // [32] SDDecl ::= S 'standalone' Eq (("'" ('yes' | 'no') "'")
-      //                                   | ('"' ('yes' | 'no') '"'))
-      switch (ch)
-          case 'y': case 'e': case 's': case 'n': case 'o':
-            numchars++;
-            break;
-          default:
-            return -1;
-void
-ACEXML_Parser::prefix_mapping (const ACEXML_Char* prefix,
-                               const ACEXML_Char* uri,
-                               const ACEXML_Char* name,
-                               int start ACEXML_ENV_ARG_DECL)
-      const ACEXML_Char* temp = (name == 0) ? empty_string : prefix;
-      if (start) {
-        this->content_handler_->startPrefixMapping (temp, uri
-        ACEXML_CHECK;
-      else
-          this->content_handler_->endPrefixMapping(temp
-          ACEXML_CHECK;
-int
-ACEXML_Parser::switch_input (ACEXML_CharStream* cstream,
-                             const ACEXML_Char* systemId,
-                             const ACEXML_Char* publicId)
-  ACE_NEW_RETURN (input, ACEXML_InputSource (cstream), -1);
-  return this->switch_input (input, systemId, publicId);
-int
-ACEXML_Parser::switch_input (ACEXML_InputSource* input,
-  ACEXML_LocatorImpl* locator = 0;
-  if (!systemId)
-    systemId = input->getSystemId();
-  ACE_NEW_RETURN (locator, ACEXML_LocatorImpl (systemId, publicId), -1);
-  ACEXML_Parser_Context* new_context = 0;
-  ACE_NEW_RETURN (new_context, ACEXML_Parser_Context(input, locator), -1);
-  if (this->push_context (new_context) != 0)
-      ACE_ERROR ((LM_ERROR, "Unable to switch input streams"));
-      delete new_context;
-      return -1;
-  this->current_ = new_context;
-  return 0;
-int
-ACEXML_Parser::push_context (ACEXML_Parser_Context* context)
-  if (this->ctx_stack_.push (context) < 0)
-      ACE_ERROR ((LM_ERROR, "Unable to push input source onto the stack"));
-      return -1;
-  return 0;
-int
-ACEXML_Parser::pop_context (int GE_ref ACEXML_ENV_ARG_DECL)
-  int nrelems = this->ctx_stack_.size();
-  if (nrelems <= 1)
-      this->fatal_error(ACE_TEXT ("Unexpected end-of-file")
-  ACEXML_Parser_Context* temp = 0;
-  int retval = this->ctx_stack_.pop (temp);
-  if (retval != 0)
-      this->fatal_error (ACE_TEXT ("Unable to pop element of the input stack")
-  delete temp;
-  if (this->ctx_stack_.top (this->current_) != 0)
-      this->fatal_error (ACE_TEXT ("Unable to read top element of input stack")
-  ACEXML_Char* reference = 0;
-  if (GE_ref == 1 && this->GE_reference_.size() > 0)
-      if (this->GE_reference_.pop (reference) < 0)
-  else if (GE_ref == 0 && this->PE_reference_.size() > 0)
-      if (this->PE_reference_.pop (reference) < 0)
-  nrelems = this->ctx_stack_.size();
-  if (this->external_entity_ && (GE_ref == 0 || GE_ref == 1))
-    this->external_entity_--;
-  return nrelems;
-int
-ACEXML_Parser::getFeature (const ACEXML_Char *name ACEXML_ENV_ARG_DECL)
-  ACE_THROW_SPEC ((ACEXML_SAXNotRecognizedException,
-                   ACEXML_SAXNotSupportedException))
-  if (ACE_OS::strcmp (name, ACEXML_Parser::simple_parsing_feature_) == 0)
-      return this->simple_parsing_;
-  else if (ACE_OS::strcmp (name, ACEXML_Parser::namespaces_feature_) == 0)
-      return this->namespaces_;
-                           ACEXML_Parser::namespace_prefixes_feature_) == 0)
-      return this->namespace_prefixes_;
-  else if (ACE_OS::strcmp (name, ACEXML_Parser::validation_feature_) == 0)
-      return this->validate_;
-  ACEXML_THROW_RETURN (ACEXML_SAXNotRecognizedException (name), -1);
-void
-ACEXML_Parser::setFeature (const ACEXML_Char *name,
-                           int boolean_value ACEXML_ENV_ARG_DECL)
-      this->simple_parsing_ = (boolean_value == 0 ? 0 : 1);
-      return;
-      this->namespaces_ = (boolean_value == 0 ? 0 : 1);
-      return;
-      this->namespace_prefixes_ = (boolean_value == 0 ? 0 : 1);
-      return;
-      this->validate_ = (boolean_value == 0 ? 0 : 1);
-      return;
-  ACEXML_THROW (ACEXML_SAXNotRecognizedException (name));
-void *
-ACEXML_Parser::getProperty (const ACEXML_Char *name ACEXML_ENV_ARG_DECL)
-  ACEXML_THROW_RETURN (ACEXML_SAXNotSupportedException (name), 0);
-void
-ACEXML_Parser::setProperty (const ACEXML_Char *name,
-                            void *value ACEXML_ENV_ARG_DECL)
-  ACE_UNUSED_ARG (value);
-  ACEXML_THROW (ACEXML_SAXNotSupportedException (name));
-void
-ACEXML_Parser::error (const ACEXML_Char* msg ACEXML_ENV_ARG_DECL)
-  ACEXML_SAXParseException* exception = 0;
-  ACE_NEW_NORETURN (exception, ACEXML_SAXParseException (msg));
-  if (this->error_handler_)
-      this->error_handler_->error (*exception ACEXML_ENV_ARG_PARAMETER);
-  else
-    ACEXML_ENV_RAISE (exception);
-  return;
-void
-ACEXML_Parser::warning (const ACEXML_Char* msg ACEXML_ENV_ARG_DECL)
-    this->error_handler_->warning (*exception ACEXML_ENV_ARG_PARAMETER);
-  delete exception;
-  return;
-void
-ACEXML_Parser::fatal_error (const ACEXML_Char* msg ACEXML_ENV_ARG_DECL)
-    this->error_handler_->fatalError (*exception ACEXML_ENV_ARG_PARAMETER);
-  this->reset();
-  return;
-void
-ACEXML_Parser::parse_version_info (ACEXML_ENV_SINGLE_ARG_DECL)
-  ACEXML_Char* astring;
-  if (this->parse_token (ACE_TEXT("ersion")) < 0
-      || this->skip_equal () != 0
-      || this->parse_version_num (astring) != 0)
-      this->fatal_error (ACE_TEXT ("Invalid VersionInfo specification")
-      return;
-  if (ACE_OS::strcmp (astring, ACE_TEXT ("1.0")) != 0)
-      this->fatal_error (ACE_TEXT ("ACEXML Parser supports XML version 1.0 ")
-                         ACE_TEXT ("documents only") ACEXML_ENV_ARG_PARAMETER);
-      return;
-void
-ACEXML_Parser::parse_encoding_decl (ACEXML_ENV_SINGLE_ARG_DECL)
-  if ((this->parse_token (ACE_TEXT("ncoding")) < 0)
-      || this->parse_encname (astring) != 0)
-      this->fatal_error (ACE_TEXT ("Invalid EncodingDecl specification")
-      ACEXML_CHECK;
-  const ACEXML_Char* encoding = this->current_->getInputSource()->getEncoding();
-  if (ACE_OS::strcmp (astring, encoding) != 0)
-      ACE_ERROR ((LM_ERROR, ACE_TEXT ("Detected Encoding is %s ")
-                  ACE_TEXT (": Declared Encoding is %s\n"),
-                  encoding, astring));
-      this->warning (ACE_TEXT ("Declared encoding differs from detected ")
-                     ACE_TEXT ("encoding") ACEXML_ENV_ARG_PARAMETER);
-int
-ACEXML_Parser::parse_text_decl (ACEXML_ENV_SINGLE_ARG_DECL)
-  // Read xml
-  if (this->parse_token (ACE_TEXT("xml")) < 0)
-      this->fatal_error(ACE_TEXT ("Expecting keyword 'xml' in TextDecl")
-  ACEXML_Char fwd = this->skip_whitespace();
-  // Read version
-  if (fwd == 'v')
-      this->parse_version_info (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-      fwd = this->skip_whitespace();
-  if (fwd == 'e')
-      this->parse_encoding_decl (ACEXML_ENV_SINGLE_ARG_PARAMETER);
-  else
-      this->fatal_error (ACE_TEXT ("Missing encodingDecl in TextDecl")
-  if (fwd == '?' && this->get() == '>')
-    return 0;
-  // All the rules fail. So return an error.
-  this->fatal_error (ACE_TEXT ("Invalid TextDecl") ACEXML_ENV_ARG_PARAMETER);
-  return -1;
-void
-ACEXML_Parser::parse_xml_decl (ACEXML_ENV_SINGLE_ARG_DECL)
-  // Read <?xml
-      this->fatal_error(ACE_TEXT ("Expecting keyword xml in XMLDecl")
-      ACEXML_CHECK;
-  // Read version
-  if (fwd != 'v')
-      this->fatal_error (ACE_TEXT ("Expecting VersionInfo declaration")
-      ACEXML_CHECK;
-  ACEXML_CHECK;
-  if (fwd != '?')
-      if (fwd == 'e')
-          ACEXML_CHECK;
-      if (fwd == 's')
-          if ((this->parse_token (ACE_TEXT("tandalone")) == 0) &&
-              this->skip_equal () == 0 &&
-              this->parse_sddecl (astring) == 0)
-              if (ACE_OS::strcmp (astring, ACE_TEXT ("yes")) == 0)
-                this->standalone_ = 1;
-    return;
-  this->fatal_error (ACE_TEXT ("Invalid XMLDecl declaration")
-  ACEXML_CHECK;
-int
-ACEXML_Parser::parse_comment (void)
-  int state = 0;
-  if (this->get () != '-' ||    // Skip the opening "<!--"
-      this->get () != '-' ||    // completely.
-      this->get () == '-')      // and at least something not '-'.
-    return -1;
-  while (state < 3)
-    // Waiting for the trailing three character '-->'. Notice that
-    // according to the spec, '--->' is not a valid closing comment
-    // sequence. But we'll let it pass anyway.
-      ACEXML_Char fwd = this->get ();
-      if ((fwd == '-' && state < 2) ||
-          (fwd == '>' && state == 2))
-        state += 1;
-      else
-        state = 0;              // Reset parse state.
-  return 0;
-int
-ACEXML_Parser::parse_processing_instruction (ACEXML_ENV_SINGLE_ARG_DECL)
-  const ACEXML_Char *pitarget = this->parse_name ();
-  ACEXML_Char *instruction = 0;
-  if (!ACE_OS::strcasecmp (ACE_TEXT ("xml"), pitarget))
-      // Invalid PITarget name.
-      this->fatal_error(ACE_TEXT ("PI can't have 'xml' in PITarget")
-  int state = 0;
-  ACEXML_Char ch = this->skip_whitespace();
-  while (state < 2)
-      switch (ch)
-          case '?':
-            if (state == 0)
-              state = 1;
-            break;
-          case '>':
-            if (state == 1)
-                instruction = this->obstack_.freeze ();
-                this->content_handler_->processingInstruction (pitarget,
-                                                               instruction
-                this->obstack_.unwind (ACE_const_cast (ACEXML_Char*, pitarget));
-                return 0;
-            break;
-          case 0x0A:
-            // Fall thru...
-          default:
-            if (state == 1)
-              this->obstack_.grow ('?');
-            state = 0;
-  return -1;
-void
-ACEXML_Parser::reset (void)
-  this->doctype_ = 0;
-  if (this->ctx_stack_.pop (this->current_) == -1)
-                ACE_TEXT ("Mismatched push/pop of Context stack")));
-  this->current_->getInputSource()->getCharStream()->rewind();
-  this->current_->setInputSource (0);
-  delete this->current_;
-  this->current_ = 0;
-  ACEXML_Char* temp = 0;
-  while (this->GE_reference_.pop (temp) != -1)
-  while (this->PE_reference_.pop (temp) != -1)
-  this->obstack_.release();
-  this->alt_stack_.release();
-  this->xml_namespace_.reset();
-  this->nested_namespace_ = 0;
-  this->internal_GE_.reset();
-  this->external_GE_.reset();
-  this->unparsed_entities_.reset();
-  this->predef_entities_.reset();
-  this->internal_PE_.reset();
-  this->external_PE_.reset();
-  this->notations_.reset();
-  this->ref_state_ = ACEXML_ParserInt::INVALID;
-  this->external_subset_ = 0;
-  this->external_entity_ = 0;
-  this->has_pe_refs_ = 0;
-  this->standalone_ = 0;
-  this->external_dtd_ = 0;
-  this->internal_dtd_ = 0;
-#if defined (ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION)
-template class ACE_Unbounded_Stack<ACEXML_Parser_Context*>;
-template class ACE_Unbounded_Set_Iterator<ACEXML_Parser_Context*>;
-template class ACE_Node<ACEXML_Parser_Context*>;
-template class ACE_Unbounded_Stack<ACEXML_Char *>;
-template class ACE_Node<ACEXML_Char *>;
-template class ACE_Unbounded_Set_Iterator<ACEXML_Char*>;
-#elif defined (ACE_HAS_TEMPLATE_INSTANTIATION_PRAGMA)
-#pragma instantiate ACE_Unbounded_Stack<ACEXML_Parser_Context*>
-#pragma instantiate ACE_Unbounded_Set_Iterator<ACEXML_Parser_Context*>;
-#pragma instantiate ACE_Node<ACEXML_Parser_Context*>
-#pragma instantiate ACE_Unbounded_Stack<ACEXML_Char*>
-#pragma instantiate ACE_Unbounded_Set_Iterator<ACEXML_Char*>;
-#pragma instantiate ACE_Node<ACEXML_Char *>
-#endif /*ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION*/
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser.dsw
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser.dsw	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser.dsw	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,28 +0,0 @@
-Microsoft Developer Studio Workspace File, Format Version 6.00
-# WARNING: DO NOT EDIT OR DELETE THIS WORKSPACE FILE!
-Project: "Parser"=.\Parser.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Global:
-Package=<5>
-Package=<3>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,905 +0,0 @@
-// -*- C++ -*-
- *  @file    Parser.h
- *  Parser.h,v 1.13 2003/07/19 19:04:10 dhinton Exp
- *  @author Nanbor Wang <nanbor at cs.wustl.edu>
- *  @author Krishnakumar B <kitty at cs.wustl.edu>
-#ifndef _ACEXML_BASIC_PARSER_H_
-#define _ACEXML_BASIC_PARSER_H_
-#include /**/ "ace/pre.h"
-#include "ACEXML/parser/parser/Parser_export.h"
-#if !defined (ACE_LACKS_PRAGMA_ONCE)
-#pragma once
-#endif /* ACE_LACKS_PRAGMA_ONCE */
-#include "ACEXML/common/XMLReader.h"
-#include "ACEXML/common/LocatorImpl.h"
-#include "ACEXML/common/NamespaceSupport.h"
-#include "ACEXML/common/CharStream.h"
-#include "ace/Obstack.h"
-#include "ace/Functor.h"
-#include "ace/SString.h"
-#include "ace/Hash_Map_Manager.h"
-#include "ace/Unbounded_Set.h"
-#include "ace/Containers_T.h"
-#include "ace/Auto_Ptr.h"
-#include "ACEXML/parser/parser/Entity_Manager.h"
-#include "ACEXML/parser/parser/ParserContext.h"
- * @class ACEXML_Parser Parser.h "ACEXML/parser/parser/Parser.h"
- * @brief A SAX based parser.
-class ACEXML_PARSER_Export ACEXML_Parser : public ACEXML_XMLReader
-public:
-  /// Default constructor.
-  ACEXML_Parser (void);
-  /// Destructor.
-  virtual ~ACEXML_Parser (void);
-   *  Initialize the parser state.
-   *  @retval 0 if parser was initialized correctly else -1.
-  int initialize (ACEXML_InputSource* input);
-   * Return the current content handler.
-  virtual ACEXML_ContentHandler *getContentHandler (void) const;
-   * Return the current DTD handler.
-  virtual ACEXML_DTDHandler *getDTDHandler (void) const;
-   * Return the current entity resolver.
-  virtual ACEXML_EntityResolver *getEntityResolver (void) const;
-   * Return the current error handler.
-  virtual ACEXML_ErrorHandler *getErrorHandler (void) const;
-   * Look up the value of a feature.  This method allows
-   * programmers to check whether a specific feature has been
-   * activated in the parser.
-  virtual int getFeature (const ACEXML_Char *name ACEXML_ENV_ARG_DECL)
-                           ACEXML_SAXNotSupportedException)) ;
-   * Activating or deactivating a feature.
-  virtual void setFeature (const ACEXML_Char *name,
-   * Look up the value of a property.
-  virtual void * getProperty (const ACEXML_Char *name ACEXML_ENV_ARG_DECL)
-   * Set the value of a property.
-  virtual void setProperty (const ACEXML_Char *name,
-   * Parse an XML document.
-  virtual void parse (ACEXML_InputSource *input ACEXML_ENV_ARG_DECL)
-    ACE_THROW_SPEC ((ACEXML_SAXException)) ;
-   * Parse an XML document from a system identifier (URI).
-  virtual void parse (const ACEXML_Char *systemId ACEXML_ENV_ARG_DECL)
-   * Allow an application to register a content event handler.
-  virtual void setContentHandler (ACEXML_ContentHandler *handler);
-   * Allow an application to register a DTD event handler.
-  virtual void setDTDHandler (ACEXML_DTDHandler *handler);
-   * Allow an application to register an entity resolver.
-  virtual void setEntityResolver (ACEXML_EntityResolver *resolver);
-   * Allow an application to register an error event handler.
-  virtual void setErrorHandler (ACEXML_ErrorHandler *handler);
-protected:
-   * Parse XML Prolog.
-  void parse_xml_prolog (ACEXML_ENV_SINGLE_ARG_DECL)
-    ACE_THROW_SPEC ((ACEXML_SAXException));
-   * Parse VersionInfo declaration.
-  void parse_version_info (ACEXML_ENV_SINGLE_ARG_DECL)
-   *  Parse a EncodingDecl declaration.
-  void parse_encoding_decl (ACEXML_ENV_SINGLE_ARG_DECL)
-   *  Parse a XMLDecl declaration.
-  void parse_xml_decl (ACEXML_ENV_SINGLE_ARG_DECL)
-   *  Parse a TextDecl declaration.
-  int parse_text_decl (ACEXML_ENV_SINGLE_ARG_DECL)
-   * Parse a PI statement.  The first character encountered
-   * should always be '?' in the PI prefix "@<?".
-   * @retval 0 on success, -1 otherwise.
-  int parse_processing_instruction (ACEXML_ENV_SINGLE_ARG_DECL)
-   * Parse the DOCTYPE declaration.  The first character encountered
-   * should always be  'D' in doctype prefix: "@<@!DOCTYPE".
-  int parse_doctypedecl (ACEXML_ENV_SINGLE_ARG_DECL)
-   * Parse an XML element.  The first character encountered should
-   * be the first character of the element "Name".
-   * @param is_root If not 0, then we are expecting to see the "root"
-   * element now, and the next element's name need to match the name
-   * defined in DOCTYPE definition, i.e., @a this->doctype_.
-   * @todo Instead of simply checking for the root element based on the
-   * argument @a is_root, we should instead either pass in some sort
-   * of validator or allow the function to return the element name so it
-   * can be used in a validator.
-  void parse_element (int is_root ACEXML_ENV_ARG_DECL)
-   *  Parse a content declaration.
-  int parse_content (const ACEXML_Char* startname, const ACEXML_Char* ns_uri,
-   * Parse a character reference, i.e., "&#x20;" or "&#30;".   The first
-   * character encountered should be the '#' char.
-   * @param buf points to a character buffer for the result.
-   * @param len In/out argument which initially specifies the size of the
-   * buffer and is later set to the no. of characters in the reference.
-   * @retval 0 on success and -1 otherwise.
-  int parse_char_reference (ACEXML_Char *buf, size_t& len);
-   * Parse a reference name, i.e., foo in "&foo;" or "%foo;". The first
-   * character encountered should be the character following '&' or '%'.
-   * Effectively the same as @sa parse_name but we don't use the parser's
-   * obstack. Caller is responsible for deleting the memory.
-   * @retval  A pointer to name of reference, 0 otherwise.
-  ACEXML_Char* parse_reference_name (void);
-   * Parse a CDATA section.  The first character should always be the first
-   * '[' in CDATA definition.
-   * @retval 0 on success.
-   * @retval -1 if fail.
-  int parse_cdata (ACEXML_ENV_SINGLE_ARG_DECL)
-   * Parse a "markupdecl" section, this includes both "markupdecl" and
-   * "DeclSep" sections in XML specification
-  int parse_internal_dtd (ACEXML_ENV_SINGLE_ARG_DECL)
-   *  Skip over a comment. The first character encountered should always be
-   *  the first '-' in the comment prefix "@<@!--".
-  int parse_comment (void);
-   * Parse an "ELEMENT" decl.  The first character this method
-   * expects is always the 'L' (the second char) in the word
-   * "ELEMENT".
-  int parse_element_decl (ACEXML_ENV_SINGLE_ARG_DECL)
-   * Parse an "ENTITY" decl.  The first character this method expects
-   * is always the 'N' (the second char) in the word "ENTITY".
-  int parse_entity_decl (ACEXML_ENV_SINGLE_ARG_DECL)
-   * Parse an "ATTLIST" decl.  Thse first character this method
-   * expects is always the 'A' (the first char) in the word
-   * "ATTLIST".
-  int parse_attlist_decl (ACEXML_ENV_SINGLE_ARG_DECL)
-   * Parse a AttType declaration.
-  int parse_atttype (ACEXML_ENV_SINGLE_ARG_DECL)
-   *Parse a "NOTATION" decl.  The first character this method
-   * expects is always the 'N' (the first char) in the word
-   * "NOTATION".
-  int parse_notation_decl (ACEXML_ENV_SINGLE_ARG_DECL)
-   * Parse an ExternalID or a reference to PUBLIC ExternalID.
-   * Possible cases are in the forms of: <code>
-   * SYSTEM 'quoted string representing system resource'
-   * PUBLIC 'quoted name of public ID' 'quoted resource'
-   * PUBLIC 'quoted name we are referring to'
-   * </code>
-   * The first character this function sees must be either 'S' or 'P'.
-   * When the function finishes parsing, the input stream points
-   * at the first non-whitespace character.
-   * @param publicId returns the unquoted publicId read.  If none
-   *        is available, it will be reset to 0.
-   * @param systemId returns the unquoted systemId read.  If none
-  int parse_external_id (ACEXML_Char *&publicId, ACEXML_Char *&systemId
-   *  Parse an external DTD.
-  int parse_external_dtd (ACEXML_ENV_SINGLE_ARG_DECL)
-   *  Parse an external subset. This does the actual parsing of an external
-   *  subset and is called by @sa parse_external_dtd.
-  int parse_external_subset (ACEXML_ENV_SINGLE_ARG_DECL)
-   *  Parse a markupDecl section.
-  int parse_markup_decl (ACEXML_ENV_SINGLE_ARG_DECL)
-   *  Parse a conditionalSect declaration.
-  int parse_conditional_section (ACEXML_ENV_SINGLE_ARG_DECL)
-   *  Parse a includeSect declaration.
-  int parse_includesect (ACEXML_ENV_SINGLE_ARG_DECL)
-   *  Parse a ignoreSect declaration.
-  int parse_ignoresect (ACEXML_ENV_SINGLE_ARG_DECL)
-   * Parse a PEReference.
-  int parse_PE_reference (ACEXML_ENV_SINGLE_ARG_DECL)
-   *  Parse a Reference.
-  int parse_entity_reference (ACEXML_ENV_SINGLE_ARG_DECL)
-   *  Parse an entityValue.
-  int parse_entity_value (ACEXML_Char *&str ACEXML_ENV_ARG_DECL)
-   *  Parse a DefaultDecl specification.
-  int parse_defaultdecl (ACEXML_ENV_SINGLE_ARG_DECL)
-   * Parse the "children" and "Mixed" non-terminals in contentspec.
-   * The first character this function sees must be the first
-   * open paren '(' in children.
-  int parse_children_definition (ACEXML_ENV_SINGLE_ARG_DECL)
-   * Parse a @c cp non-terminal.  @c cp can either be a @c seq or a @c choice.
-   * This function calls itself recursively.
-   * @param skip_open_paren when non-zero, it indicates that the open paren of
-   *        the @c seq or @c choice has already been removed from the input
-   *        stream.
-  int parse_child (int skip_open_paren ACEXML_ENV_ARG_DECL)
-   *  Parse a name from the input CharStream. If @a ch @!= 0, then we have
-   *  already consumed the first name character from the input CharStream,
-   *  otherwise, parse_name will use this->get() to acquire the initial
-   *  character.
-   *  @return A pointer to the string in the obstack, 0 if it's not a
-   *  valid name.
-  ACEXML_Char *parse_name (ACEXML_Char ch = 0);
-   *  Parse a NMTOKEN from the input stream.
-   * @return A pointer to the string in the obstack, 0 if it's not a valid
-   * NMTOKEN.
-  ACEXML_Char* parse_nmtoken (ACEXML_Char ch = 0);
-   *  Parse the version string in an XML Prolog section.
-   *  @param str String containing the version number if successful.
-   *  @return 0 if the string was read successfully, 0 otherwise.
-  int parse_version (ACEXML_Char*& str);
-   *  Parse the version number in a VersionInfo declaration.
-  int parse_version_num (ACEXML_Char*& str);
-   *  Parse the encoding name in an XML Prolog section.
-   *  @param str String containing the encoding name if successful.
-  int parse_encname (ACEXML_Char*& str);
-   *  Parse a SDDecl string.
-   *  @return 0 if the string was read successfully, -1 otherwise.
-  int parse_sddecl (ACEXML_Char*& str);
-   *  Parse an attribute name.
-   *  @retval str String containing the value of the attribute name
-   *             if successful.
-   *  @retval 0 otherwise.
-  ACEXML_Char* parse_attname (ACEXML_ENV_SINGLE_ARG_DECL)
-   *  Parse an attribute value.
-   *  @param str String containing the value of the attribute if successful.
-   *  @return 0 if attribute value was read successfully, -1 otherwise.
-  int parse_attvalue (ACEXML_Char*& str ACEXML_ENV_ARG_DECL)
-   *  Parse a tokenized type attribute.
-   *  @return 0 if attribute type was read successfully, -1 otherwise.
-  int parse_tokenized_type (ACEXML_ENV_SINGLE_ARG_DECL)
-   *  Parse a SystemLiteral.
-   *  @param str String containing the SystemLiteral if successful.
-  int parse_system_literal (ACEXML_Char*& str);
-   *  Parse a PubidLiteral.
-   *  @param str String containing the PubidLiteral if successful.
-  int parse_pubid_literal (ACEXML_Char*& str);
-   * Check if a character @a c is a whitespace.
-   * @retval 1 if @a c is a valid white space character. 0 otherwise.
-  int is_whitespace (const ACEXML_Char c) const;
-   * Check if a character @a c is a valid Char.
-   * @retval 1 if @a c is a valid character. 0 otherwise.
-  int isChar (ACEXML_UCS4 c) const;
-   * Check if a character @a c is a valid CharRef character.
-   * @retval 1 if @a c is a valid character reference character, 0 otherwise.
-  int isCharRef (const ACEXML_Char c) const;
-   * Check if a character @a c is a BaseChar.
-   * @retval 1 if @a c is a valid BaseChar character, 0 otherwise.
-  int isBasechar (const ACEXML_Char c) const;
-   * Check if a character @a c is a Ideographic.
-   * @retval 1 if @a c is a valid Ideographic character, 0 otherwise.
-  int isIdeographic (const ACEXML_Char c) const;
-   * Check if a character @a c is a CombiningChar.
-   * @retval 1 if @a c is a valid CombiningChar character, 0 otherwise.
-  int isCombiningchar (const ACEXML_Char c) const;
-   * Check if a character @a c is a Digit.
-   * @retval 1 if @a c is a valid Digit character, 0 otherwise.
-  int isDigit (const ACEXML_Char c) const;
-   * Check if a character @a c is an Extender.
-   * @retval 1 if @a c is a valid Extender character, 0 otherwise.
-  int isExtender (const ACEXML_Char c) const;
-   * Check if a character @a c is a Letter.
-   * @retval 1 if @a c is a valid Letter character, 0 otherwise.
-  int isLetter (const ACEXML_Char c) const;
-   * Check if a character is an acceptable NameChar.
-   * @retval 1 if @a c is a valid NameChar character, 0 otherwise.
-  int isNameChar (const ACEXML_Char c) const;
-   * Check if a character is a PubidChar.
-   * @retval 1 if @a c is a valid PubidChar character, 0 otherwise.
-  int isPubidChar (const ACEXML_Char c) const;
-  /// Get a character.
-  virtual ACEXML_Char get (void);
-  /// Peek a character.
-  virtual ACEXML_Char peek (void);
-private:
-  // *** Helper functions for parsing XML
-   * Skip any whitespaces encountered until the first non-whitespace
-   * character is encountered.
-   * @return The next non-whitespace character from the CharStream.
-   * @sa skip_whitespace_count
-  ACEXML_Char skip_whitespace (void);
-   * character.  The first non-whitespace character is not consumed.
-   * This method does peek into the input CharStream and therefore
-   * is more expensive than @ref skip_whitespace.
-   * @param peek If non-null, @a peek points to a ACEXML_Char where
-   *        skip_whitespace_count stores the first non-whitespace
-   *        character it sees (character is not removed from the stream.)
-   * @return The number of whitespace characters consumed.
-  int skip_whitespace_count (ACEXML_Char *peek = 0);
-   * Skip an equal sign.
-   * @retval 0 when succeeds, -1 if no equal sign is found.
-  int skip_equal (void);
-   * Get a quoted string.  Quoted strings are used to specify
-   * attribute values and this routine will replace character and
-   * entity references on-the-fly.  Parameter entities are not allowed
-   * (or replaced) in this function.  (But regular entities are.)
-   * @param str returns the un-quoted string.
-  int get_quoted_string (ACEXML_Char *&str);
-  int isNormalDigit (const ACEXML_Char c) const;
-   * Dispatch errors to ErrorHandler.
-  void error (const ACEXML_Char* msg ACEXML_ENV_ARG_DECL)
-   * Dispatch warnings to ErrorHandler.
-  void warning (const ACEXML_Char* msg ACEXML_ENV_ARG_DECL)
-   * Dispatch fatal errors to ErrorHandler.
-  void fatal_error (const ACEXML_Char* msg ACEXML_ENV_ARG_DECL)
-   * Dispatch prefix mapping calls to the ContentHandler.
-   * @param prefix Namespace prefix
-   * @param uri Namespace URI
-   * @param name Local name
-   * @param start 1 => startPrefixMapping 0 => endPrefixMapping
-  void prefix_mapping (const ACEXML_Char* prefix,
-   *  Parse a keyword.
-  int parse_token (const ACEXML_Char* keyword);
-   *  Push the current context on to the stack.
-  int push_context (ACEXML_Parser_Context* context);
-   *  Pop the top element in the stack and replace current context with that.
-  int pop_context (int GE_ref ACEXML_ENV_ARG_DECL);
-   *  Create a new ACEXML_CharStream from @a systemId and @a publicId and
-   *  replace the current input stream with the newly created stream.
-  virtual int switch_input (ACEXML_CharStream* cstream,
-                            const ACEXML_Char* publicId = 0);
-   *  Create a new ACEXML_InputSource from @a systemId and @a publicId and
-   *  replace the current input source with the newly created InputSource.
-  virtual int switch_input (ACEXML_InputSource* input,
-   * Check for a parameter entity reference. This is used to check for the
-   * occurence of a PE Reference withing markupDecl. Additionally this
-   * function consumes any leading or trailing whitespace around the PE
-   * Reference.
-   * @retval Number of whitespace characters skipped.
-  int check_for_PE_reference (ACEXML_ENV_SINGLE_ARG_DECL);
-   *  Reset the parser state.
-  void reset (void);
-   * Very trivial, non-conformant normalization of a systemid.
-  ACEXML_Char* normalize_systemid (const ACEXML_Char* systemId);
-  // Feature names:
-   * \addtogroup acexml_parser_features
-   * @var simple_parsing_feature_
-   * This constant string defines the name of "simple XML parsing"
-   * feature.  When this feature is enabled, ACEXML parser is allowed
-   * to parse a simple XML stream without mandated XML prolog
-   * and no DTD defintion.
-  static const ACEXML_Char simple_parsing_feature_[];
-   * @var namespaces_feature_
-   * This constant string defines the SAX XML Namespace feature. When this
-   * feature is enabled, ACEXML parser allows access by namespace qualified
-   * names.
-  static const ACEXML_Char namespaces_feature_[];
-   *  @var namespace_prefixes_feature_
-   *  This constant string defines the SAX XML Namespace prefixes feature.
-   *  Normally the list of attributes returned by the parser will not
-   *  contain attributes used as namespace declarations (xmlns*). When this
-   *  feature is enabled, the list of attributes contains the namespace
-   *  declarations also.
-  static const ACEXML_Char namespace_prefixes_feature_[];
-   *  @var validation_feature_
-   *  This constant string defines the SAX XML Validation feature. When
-   *  this feature is enabled, the parser validates the document in
-   *  addition to checking for well-formedness.
-  static const ACEXML_Char validation_feature_[];
-  /// Keeping track of the handlers. We do not manage the memory for
-  /// handlers.
-  ACEXML_DTDHandler *dtd_handler_;
-  ACEXML_EntityResolver *entity_resolver_;
-  ACEXML_ContentHandler *content_handler_;
-  ACEXML_ErrorHandler *error_handler_;
-  /// Document Type
-  ACEXML_Char *doctype_;
-  /// Current parser context
-  ACEXML_Parser_Context* current_;
-  /// Stack used to hold the Parser_Context
-  ACE_Unbounded_Stack<ACEXML_Parser_Context*> ctx_stack_;
-   * The following two are essentially chains of references and is used by
-   * the parser to determine if there is any recursion. We keep two of
-   * these one for general entities and one for parameter entities, as they
-   * both fall under different namespaces.
-  /// Set used to hold the general entity references that are active.
-  ACE_Unbounded_Stack<ACEXML_Char*> GE_reference_;
-  /// Set used to hold the parameter entity references that are active.
-  ACE_Unbounded_Stack<ACEXML_Char*> PE_reference_;
-  /// Obstack used by the parser to hold all the strings parsed
-  ACE_Obstack_T<ACEXML_Char> obstack_;
-  /// Alternative obstack used to hold any strings when the original is in use
-  ACE_Obstack_T<ACEXML_Char> alt_stack_;
-  /// Namespace stack used by the parser to implement support for Namespaces
-  ACEXML_NamespaceSupport xml_namespace_;
-  /// T => We are processing a nested namespace
-  int nested_namespace_;
-  /// Set of internal parsed general entities in the document
-  ACEXML_Entity_Manager internal_GE_;
-  /// Set of external parsed general entities in the document
-  ACEXML_Entity_Manager external_GE_;
-  /// Set of unparsed entities in the document
-  ACEXML_Entity_Manager unparsed_entities_;
-  /// Set of predefined entities used by the parser
-  ACEXML_Entity_Manager predef_entities_;
-  /// Set of internal parsed parameter entities in the document
-  ACEXML_Entity_Manager internal_PE_;
-  /// Set of external parsed parameter entities in the document
-  ACEXML_Entity_Manager external_PE_;
-  /// Set of notations declared in the document
-  ACEXML_Entity_Manager notations_;
-  /// State of the parser when it encounters a reference.
-  ACEXML_ParserInt::ReferenceState ref_state_;
-  /// T => We are parsing an external subset
-  int external_subset_;
-  /// T => We are parsing an external entity value
-  int external_entity_;
-  /// T => Internal DTD has parameter entity references
-  int has_pe_refs_;
-  /// If set, the document is a standalone XML document
-  int standalone_;
-  /// If set, the document has an external DTD subset
-  int external_dtd_;
-  /// If set, the document has an internal DTD
-  int internal_dtd_;
-  /// Feature flags
-  /// If set, the parser should parse a document without a prolog
-  int simple_parsing_;
-  /// If set, the parser should also validate
-  int validate_;
-  /// If set, the parser should allow access by namespace qualified names.
-  int namespaces_;
-  /// If set, the parser should include namespace declarations in the list
-  /// of attributes of an element.
-  int namespace_prefixes_;
-#if defined (__ACEXML_INLINE__)
-# include "ACEXML/parser/parser/Parser.i"
-#endif /* __ACEXML_INLINE__ */
-#include /**/ "ace/post.h"
-#endif /* _ACEXML_BASIC_PARSER_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,258 +0,0 @@
- *  @file    Parser.i
- *  Parser.i,v 1.9 2003/12/19 13:30:28 jwillemsen Exp
-ACEXML_INLINE ACEXML_ContentHandler *
-ACEXML_Parser::getContentHandler (void) const
-  return this->content_handler_;
-ACEXML_INLINE ACEXML_DTDHandler *
-ACEXML_Parser::getDTDHandler (void) const
-  return this->dtd_handler_;
-ACEXML_INLINE ACEXML_EntityResolver *
-ACEXML_Parser::getEntityResolver (void) const
-  return this->entity_resolver_;
-ACEXML_INLINE ACEXML_ErrorHandler *
-ACEXML_Parser::getErrorHandler (void) const
-  return this->error_handler_;
-ACEXML_INLINE void
-ACEXML_Parser::setContentHandler (ACEXML_ContentHandler *handler)
-  this->content_handler_ = handler;
-ACEXML_INLINE void
-ACEXML_Parser::setDTDHandler (ACEXML_DTDHandler *handler)
-  this->dtd_handler_ = handler;
-ACEXML_INLINE void
-ACEXML_Parser::setEntityResolver (ACEXML_EntityResolver *resolver)
-  this->entity_resolver_ = resolver;
-ACEXML_INLINE void
-ACEXML_Parser::setErrorHandler (ACEXML_ErrorHandler *handler)
-  this->error_handler_ = handler;
-ACEXML_INLINE int
-ACEXML_Parser::isChar (ACEXML_UCS4 c) const
-  return (c == 0x9 || c == 0xA || c == 0xD ||
-          c >= 0x20 && c <= 0xD7FF ||
-          c >= 0xE000 && c <= 0xFFFD ||
-          c >= 0x10000 && c <= 0x10FFFF);
-ACEXML_INLINE int
-ACEXML_Parser::isCharRef (const ACEXML_Char c) const
-  return ((c >= 'a' && c <= 'f') ||
-          (c >= 'A' && c <= 'F'));
-ACEXML_INLINE int
-ACEXML_Parser::isNormalDigit (const ACEXML_Char c) const
-  return (c >= '\x30' && c <= '\x39');
-ACEXML_INLINE int
-ACEXML_Parser::isBasechar (const ACEXML_Char c) const
-  return ACEXML_ParserInt::isBasechar_i (c);
-#else
-  return ACEXML_ParserInt::base_char_table_[(int) c];
-#endif /* ACE_USES_WCHAR */
-ACEXML_INLINE int
-ACEXML_Parser::isIdeographic (const ACEXML_Char c) const
-  return ACEXML_ParserInt::isIdeographic_i (c);
-#else
-  ACE_UNUSED_ARG (c);
-  return 0;
-ACEXML_INLINE int
-ACEXML_Parser::isCombiningchar (const ACEXML_Char c) const
-  return ACEXML_ParserInt::isCombiningchar_i (c);
-#else
-      return 0;
-ACEXML_INLINE int
-ACEXML_Parser::isDigit (const ACEXML_Char c) const
-  return ACEXML_ParserInt::isDigit_i (c);
-#else
-  return (this->isNormalDigit (c));
-ACEXML_INLINE int
-ACEXML_Parser::isExtender (const ACEXML_Char c) const
-  return ACEXML_ParserInt::isExtender_i (c);
-#else
-  return (c == '\xB7');
-ACEXML_INLINE int
-ACEXML_Parser::isLetter (const ACEXML_Char c) const
-  return (this->isBasechar (c) || this->isIdeographic (c));
-ACEXML_INLINE int
-ACEXML_Parser::isNameChar (const ACEXML_Char c) const
-  return (this->isLetter (c) || this->isDigit (c) || c == '.' || c == '-' ||
-          c == '_' || c == ':' || this->isCombiningchar (c) ||
-          this->isExtender (c));
-ACEXML_INLINE int
-ACEXML_Parser::isPubidChar (const ACEXML_Char c) const
-  return (c == '\x20' || c == '\x0D' || c == '\x0A' ||
-          (c >= 'a' && c <= 'z') || (c >= 'A' && c <= 'Z') ||
-          (c >= '0' && c <= '9') || c == '-' || c == '\'' || c == '(' ||
-          c == ')' || c == '+' || c == ',' || c == '.' || c == '/' ||
-          c == ':' || c == '=' || c == '?' || c == ';' || c == '!' ||
-          c == '*' || c == '#' || c == '@' || c == '$' || c == '_' ||
-          c == '%');
-ACEXML_INLINE int
-ACEXML_Parser::is_whitespace (const ACEXML_Char c) const
-  switch (c)
-      case '\x0A': case '\x20':
-      case '\x09': case '\x0D':
-      return 1;
-    default:
-      return 0;
-ACEXML_INLINE ACEXML_Char
-ACEXML_Parser::skip_whitespace (void)
-  while (this->is_whitespace (ch))
-    ch = this->get ();
-  return ch;
-ACEXML_INLINE int
-ACEXML_Parser::skip_whitespace_count (ACEXML_Char *peeky)
-  int wscount = 0;
-  ACEXML_Char dummy;
-  ACEXML_Char &forward = (peeky == 0 ? dummy : *peeky);
-  for (;this->is_whitespace ((forward = this->peek ())); ++wscount)
-    this->get ();
-  return wscount;
-ACEXML_INLINE int
-ACEXML_Parser::skip_equal (void)
-  if (this->skip_whitespace() != '=')
-    return -1;
-  while (this->is_whitespace (this->peek()))
-    this->get();
-  return 0;
-ACEXML_Parser::get (void)
-  ACEXML_Char ch = 0;
-  const ACEXML_InputSource* ip = this->current_->getInputSource();
-  ACEXML_CharStream* instream = ip->getCharStream();
-  if (instream->get (ch) != -1)
-      this->current_->getLocator()->incrColumnNumber();
-      // Normalize white-space
-      if (ch == '\x0D')
-          if (instream->peek() == 0x0A)
-            instream->get (ch);
-          ch = '\x0A';
-      if (ch == '\x0A')
-          // Reset column number and increment Line Number.
-          this->current_->getLocator()->incrLineNumber();
-          this->current_->getLocator()->setColumnNumber (0);
-      return ch;
-  return 0;
-ACEXML_Parser::peek (void)
-  // Using an extra level of indirection so we can
-  // manage document location in the future.
-  ch = instream->peek ();
-  return (ch > 0 ? ch : 0);
-ACEXML_INLINE int
-ACEXML_Parser::parse_token (const ACEXML_Char* keyword)
-  if (keyword == 0)
-    return -1;
-  const ACEXML_Char* ptr = keyword;
-  ACEXML_Char ch;
-  for (; *ptr != 0 && ((ch = this->get()) == *ptr); ++ptr)
-  if (*ptr == 0)
-  return 0;
-  else
-    return -1;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserContext.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserContext.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserContext.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,24 +0,0 @@
-// ParserContext.cpp,v 1.3 2003/11/01 11:15:07 dhinton Exp
-#if !defined (__ACEXML_INLINE__)
-# include "ACEXML/parser/parser/ParserContext.inl"
-ACEXML_Parser_Context::~ACEXML_Parser_Context()
-  delete this->instream_;
-  this->instream_ = 0;
-  delete this->locator_;
-  this->locator_ = 0;
-template class ACE_Swap <ACEXML_InputSource*>;
-template class ACE_Swap <ACEXML_LocatorImpl*>;
-#  pragma instantiate ACE_Swap <ACEXML_InputSource*>
-#  pragma instantiate ACE_Swap <ACEXML_LocatorImpl*>
-#endif /* ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserContext.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserContext.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserContext.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,85 +0,0 @@
-// -*- C++ -*-
- *  @file    ParserContext.h
- *  ParserContext.h,v 1.4 2004/01/09 00:50:35 kitty Exp
-#ifndef ACEXML_PARSER_CONTEXT_H
-#define ACEXML_PARSER_CONTEXT_H
-#pragma once
-#include "ACEXML/common/XML_Types.h"
-#include "ACEXML/common/InputSource.h"
-#include "ACEXML/common/Locator.h"
-#include "ace/Swap.h"
-class ACEXML_PARSER_Export ACEXML_Parser_Context
-public:
-  ACEXML_Parser_Context();
-  /// Constructor which initializes the context
-  ACEXML_Parser_Context (ACEXML_InputSource* instream,
-                         ACEXML_LocatorImpl* locator);
-  /// Comparison operator
-  int operator!= (const ACEXML_Parser_Context& src);
-  /// Destructor
-  virtual ~ACEXML_Parser_Context();
-  /// Reset the parser context. This does not free up the memory. Only sets
-  /// it to zero. Meant to be called after a context is pushed on to a
-  /// stack.
-  /// Get the underlying input source.
-  virtual ACEXML_InputSource* getInputSource(void);
-  /// Get the underlying locator.
-  virtual ACEXML_LocatorImpl* getLocator(void);
-  /// Set the underlying input source.
-  virtual void setInputSource(ACEXML_InputSource* ip);
-  /// Set the underlying locator.
-  virtual void setLocator(ACEXML_LocatorImpl* locator);
-private:
-  /// Copy constructor
-  ACEXML_Parser_Context (const ACEXML_Parser_Context& src);
-  /// Assignment operator
-  ACEXML_Parser_Context& operator= (const ACEXML_Parser_Context& src);
-  /// Current input char stream.
-  ACEXML_InputSource *instream_;
-  /// Current Locator which provides line no., column no. systemId and publicId
-  ACEXML_LocatorImpl* locator_;
-#endif /* ACEXML_PARSER_CONTEXT_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserContext.inl
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserContext.inl	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserContext.inl	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,74 +0,0 @@
-// ParserContext.inl,v 1.4 2004/01/09 00:50:35 kitty Exp
-ACEXML_INLINE
-ACEXML_Parser_Context::ACEXML_Parser_Context()
-  : instream_ (0),
-    locator_ (0)
-ACEXML_INLINE
-ACEXML_Parser_Context::ACEXML_Parser_Context (ACEXML_InputSource* instream,
-  : instream_ (instream),
-    locator_ (locator)
-ACEXML_INLINE
-ACEXML_Parser_Context::ACEXML_Parser_Context (const ACEXML_Parser_Context& src)
-  : instream_ (src.instream_),
-    locator_ (src.locator_)
-ACEXML_INLINE int
-ACEXML_Parser_Context::operator!= (const ACEXML_Parser_Context& src)
-  return (this->instream_ != src.instream_ && this->locator_ != src.locator_);
-ACEXML_INLINE ACEXML_Parser_Context&
-ACEXML_Parser_Context::operator= (const ACEXML_Parser_Context& src)
-  ACEXML_Parser_Context tmp (src);
-  ACE_Swap<ACEXML_InputSource*>::swap (this->instream_, tmp.instream_);
-  ACE_Swap<ACEXML_LocatorImpl*>::swap (this->locator_, tmp.locator_);
-  return *this;
-ACEXML_INLINE ACEXML_InputSource*
-ACEXML_Parser_Context::getInputSource (void)
-  return this->instream_;
-ACEXML_INLINE ACEXML_LocatorImpl*
-ACEXML_Parser_Context::getLocator (void)
-  return this->locator_;
-ACEXML_INLINE void
-ACEXML_Parser_Context::setInputSource (ACEXML_InputSource* ip)
-  this->instream_ = ip;
-ACEXML_INLINE void
-ACEXML_Parser_Context::setLocator (ACEXML_LocatorImpl* locator)
-  this->locator_ = locator;
-ACEXML_INLINE void
-ACEXML_Parser_Context::reset (void)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserInternals.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserInternals.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserInternals.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,394 +0,0 @@
-// ParserInternals.cpp,v 1.2 2003/05/30 03:31:49 kitty Exp
-#include "ACEXML/parser/parser/ParserInternals.h"
-const ACEXML_Char* ACEXML_ParserInt::predef_ent_[] = {
-  ACE_TEXT ("amp"),
-  ACE_TEXT ("lt"),
-  ACE_TEXT ("gt"),
-  ACE_TEXT ("apos"),
-  ACE_TEXT ("quot")
-const ACEXML_Char* ACEXML_ParserInt::predef_val_[] = {
-  ACE_TEXT ("&"),
-  ACE_TEXT ("<"),
-  ACE_TEXT (">"),
-  ACE_TEXT ("'"),
-  ACE_TEXT ("\"")
-// Optimize away the most common cases. Any compiler worth it's salt should
-// give generate a single memory access.
-const ACEXML_Char ACEXML_ParserInt::base_char_table_[] = {
-  0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, /* 0x0000 - 0x000F */
-  0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, /* 0x0010 - 0x001F */
-  0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, /* 0x0020 - 0x002F */
-  0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, /* 0x0030 - 0x003F */
-  0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, /* 0x0040 - 0x004F */
-  1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, /* 0x0050 - 0x005F */
-  0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, /* 0x0060 - 0x006F */
-  1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, /* 0x0070 - 0x007F */
-  0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, /* 0x0080 - 0x008F */
-  0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, /* 0x0090 - 0x009F */
-  0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, /* 0x00A0 - 0x00AF */
-  0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, /* 0x00B0 - 0x00BF */
-  1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, /* 0x00C0 - 0x00CF */
-  1, 1, 1, 1, 1, 1, 1, 0, 1, 1, 1, 1, 1, 1, 1, 1, /* 0x00D0 - 0x00DF */
-  1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, /* 0x00E0 - 0x00EF */
-  1, 1, 1, 1, 1, 1, 1, 0, 1, 1, 1, 1, 1, 1, 1, 1, /* 0x00F0 - 0x00FF */
-int
-ACEXML_ParserInt::isBasechar_i (const ACEXML_Char c)
-  if (c < 0x0100)
-    return ACEXML_ParserInt::base_char_table_[c];
-  else if (c < 0x0905)
-    return ((c >= 0x0100 && c <= 0x0131) ||
-            (c >= 0x0134 && c <= 0x013E) ||
-            (c >= 0x0141 && c <= 0x0148) ||
-            (c >= 0x014A && c <= 0x017E) ||
-            (c >= 0x0180 && c <= 0x01C3) ||
-            (c >= 0x01CD && c <= 0x01F0) ||
-            (c >= 0x01F4 && c <= 0x01F5) ||
-            (c >= 0x01FA && c <= 0x0217) ||
-            (c >= 0x0250 && c <= 0x02A8) ||
-            (c >= 0x02BB && c <= 0x02C1) ||
-            (c == 0x0386) ||
-            (c >= 0x0388 && c <= 0x038A) ||
-            (c == 0x038C) ||
-            (c >= 0x038E && c <= 0x03A1) ||
-            (c >= 0x03A3 && c <= 0x03CE) ||
-            (c >= 0x03D0 && c <= 0x03D6) ||
-            (c == 0x03DA) ||
-            (c == 0x03DC) ||
-            (c == 0x03DE) ||
-            (c == 0x03E0) ||
-            (c >= 0x03E2 && c <= 0x03F3) ||
-            (c >= 0x0401 && c <= 0x040C) ||
-            (c >= 0x040E && c <= 0x044F) ||
-            (c >= 0x0451 && c <= 0x045C) ||
-            (c >= 0x045E && c <= 0x0481) ||
-            (c >= 0x0490 && c <= 0x04C4) ||
-            (c >= 0x04C7 && c <= 0x04C8) ||
-            (c >= 0x04CB && c <= 0x04CC) ||
-            (c >= 0x04D0 && c <= 0x04EB) ||
-            (c >= 0x04EE && c <= 0x04F5) ||
-            (c >= 0x04F8 && c <= 0x04F9) ||
-            (c >= 0x0531 && c <= 0x0556) ||
-            (c == 0x0559) ||
-            (c >= 0x0561 && c <= 0x0586) ||
-            (c >= 0x05D0 && c <= 0x05EA) ||
-            (c >= 0x05F0 && c <= 0x05F2) ||
-            (c >= 0x0621 && c <= 0x063A) ||
-            (c >= 0x0641 && c <= 0x064A) ||
-            (c >= 0x0671 && c <= 0x06B7) ||
-            (c >= 0x06BA && c <= 0x06BE) ||
-            (c >= 0x06C0 && c <= 0x06CE) ||
-            (c >= 0x06D0 && c <= 0x06D3) ||
-            (c == 0x06D5) ||
-            (c >= 0x06E5 && c <= 0x06E6));
-  else if (c < 0x10A0)
-    return ((c >= 0x0905 && c <= 0x0939) ||
-            (c == 0x093D) ||
-            (c >= 0x0958 && c <= 0x0961) ||
-            (c >= 0x0985 && c <= 0x098C) ||
-            (c >= 0x098F && c <= 0x0990) ||
-            (c >= 0x0993 && c <= 0x09A8) ||
-            (c >= 0x09AA && c <= 0x09B0) ||
-            (c == 0x09B2) ||
-            (c >= 0x09B6 && c <= 0x09B9) ||
-            (c >= 0x09DC && c <= 0x09DD) ||
-            (c >= 0x09DF && c <= 0x09E1) ||
-            (c >= 0x09F0 && c <= 0x09F1) ||
-            (c >= 0x0A05 && c <= 0x0A0A) ||
-            (c >= 0x0A0F && c <= 0x0A10) ||
-            (c >= 0x0A13 && c <= 0x0A28) ||
-            (c >= 0x0A2A && c <= 0x0A30) ||
-            (c >= 0x0A32 && c <= 0x0A33) ||
-            (c >= 0x0A35 && c <= 0x0A36) ||
-            (c >= 0x0A38 && c <= 0x0A39) ||
-            (c >= 0x0A59 && c <= 0x0A5C) ||
-            (c == 0x0A5E) ||
-            (c >= 0x0A72 && c <= 0x0A74) ||
-            (c >= 0x0A85 && c <= 0x0A8B) ||
-            (c == 0x0A8D) ||
-            (c >= 0x0A8F && c <= 0x0A91) ||
-            (c >= 0x0A93 && c <= 0x0AA8) ||
-            (c >= 0x0AAA && c <= 0x0AB0) ||
-            (c >= 0x0AB2 && c <= 0x0AB3) ||
-            (c >= 0x0AB5 && c <= 0x0AB9) ||
-            (c == 0x0ABD || c == 0x0AE0) ||
-            (c >= 0x0B05 && c <= 0x0B0C) ||
-            (c >= 0x0B0F && c <= 0x0B10) ||
-            (c >= 0x0B13 && c <= 0x0B28) ||
-            (c >= 0x0B2A && c <= 0x0B30) ||
-            (c >= 0x0B32 && c <= 0x0B33) ||
-            (c >= 0x0B36 && c <= 0x0B39) ||
-            (c == 0x0B3D) ||
-            (c >= 0x0B5C && c <= 0x0B5D) ||
-            (c >= 0x0B5F && c <= 0x0B61) ||
-            (c >= 0x0B85 && c <= 0x0B8A) ||
-            (c >= 0x0B8E && c <= 0x0B90) ||
-            (c >= 0x0B92 && c <= 0x0B95) ||
-            (c >= 0x0B99 && c <= 0x0B9A) ||
-            (c == 0x0B9C) ||
-            (c >= 0x0B9E && c <= 0x0B9F) ||
-            (c >= 0x0BA3 && c <= 0x0BA4) ||
-            (c >= 0x0BA8 && c <= 0x0BAA) ||
-            (c >= 0x0BAE && c <= 0x0BB5) ||
-            (c >= 0x0BB7 && c <= 0x0BB9) ||
-            (c >= 0x0C05 && c <= 0x0C0C) ||
-            (c >= 0x0C0E && c <= 0x0C10) ||
-            (c >= 0x0C12 && c <= 0x0C28) ||
-            (c >= 0x0C2A && c <= 0x0C33) ||
-            (c >= 0x0C35 && c <= 0x0C39) ||
-            (c >= 0x0C60 && c <= 0x0C61) ||
-            (c >= 0x0C85 && c <= 0x0C8C) ||
-            (c >= 0x0C8E && c <= 0x0C90) ||
-            (c >= 0x0C92 && c <= 0x0CA8) ||
-            (c >= 0x0CAA && c <= 0x0CB3) ||
-            (c >= 0x0CB5 && c <= 0x0CB9) ||
-            (c == 0x0CDE) ||
-            (c >= 0x0CE0 && c <= 0x0CE1) ||
-            (c >= 0x0D05 && c <= 0x0D0C) ||
-            (c >= 0x0D0E && c <= 0x0D10) ||
-            (c >= 0x0D12 && c <= 0x0D28) ||
-            (c >= 0x0D2A && c <= 0x0D39) ||
-            (c >= 0x0D60 && c <= 0x0D61) ||
-            (c >= 0x0E01 && c <= 0x0E2E) ||
-            (c == 0x0E30) ||
-            (c >= 0x0E32 && c <= 0x0E33) ||
-            (c >= 0x0E40 && c <= 0x0E45) ||
-            (c >= 0x0E81 && c <= 0x0E82) ||
-            (c == 0x0E84) ||
-            (c >= 0x0E87 && c <= 0x0E88) ||
-            (c == 0x0E8A || c == 0x0E8D) ||
-            (c >= 0x0E94 && c <= 0x0E97) ||
-            (c >= 0x0E99 && c <= 0x0E9F) ||
-            (c >= 0x0EA1 && c <= 0x0EA3) ||
-            (c == 0x0EA5 || c == 0x0EA7) ||
-            (c >= 0x0EAA && c <= 0x0EAB) ||
-            (c >= 0x0EAD && c <= 0x0EAE) ||
-            (c == 0x0EB0) ||
-            (c >= 0x0EB2 && c <= 0x0EB3) ||
-            (c == 0x0EBD) ||
-            (c >= 0x0EC0 && c <= 0x0EC4) ||
-            (c >= 0x0F40 && c <= 0x0F47) ||
-            (c >= 0x0F49 && c <= 0x0F69));
-  else
-    return ((c >= 0x10A0 && c <= 0x10C5) ||
-            (c >= 0x10D0 && c <= 0x10F6) ||
-            (c == 0x1100) ||
-            (c >= 0x1102 && c <= 0x1103) ||
-            (c >= 0x1105 && c <= 0x1107) ||
-            (c == 0x1109) ||
-            (c >= 0x110B && c <= 0x110C) ||
-            (c >= 0x110E && c <= 0x1112) ||
-            (c == 0x113C || c == 0x113E || c == 0x1140) ||
-            (c == 0x114C || c == 0x114E || c == 0x1150) ||
-            (c >= 0x1154 && c <= 0x1155) ||
-            (c == 0x1159) ||
-            (c >= 0x115F && c <= 0x1161) ||
-            (c == 0x1163) ||
-            (c == 0x1165) ||
-            (c == 0x1167) ||
-            (c == 0x1169) ||
-            (c >= 0x116D && c <= 0x116E) ||
-            (c >= 0x1172 && c <= 0x1173) ||
-            (c == 0x1175) ||
-            (c == 0x119E) ||
-            (c == 0x11A8) ||
-            (c == 0x11AB) ||
-            (c >= 0x11AE && c <= 0x11AF) ||
-            (c >= 0x11B7 && c <= 0x11B8) ||
-            (c == 0x11BA) ||
-            (c >= 0x11BC && c <= 0x11C2) ||
-            (c == 0x11EB) ||
-            (c == 0x11F0) ||
-            (c == 0x11F9) ||
-            (c >= 0x1E00 && c <= 0x1E9B) ||
-            (c >= 0x1EA0 && c <= 0x1EF9) ||
-            (c >= 0x1F00 && c <= 0x1F15) ||
-            (c >= 0x1F18 && c <= 0x1F1D) ||
-            (c >= 0x1F20 && c <= 0x1F45) ||
-            (c >= 0x1F48 && c <= 0x1F4D) ||
-            (c >= 0x1F50 && c <= 0x1F57) ||
-            (c == 0x1F59) ||
-            (c == 0x1F5B) ||
-            (c == 0x1F5D) ||
-            (c >= 0x1F5F && c <= 0x1F7D) ||
-            (c >= 0x1F80 && c <= 0x1FB4) ||
-            (c >= 0x1FB6 && c <= 0x1FBC) ||
-            (c == 0x1FBE) ||
-            (c >= 0x1FC2 && c <= 0x1FC4) ||
-            (c >= 0x1FC6 && c <= 0x1FCC) ||
-            (c >= 0x1FD0 && c <= 0x1FD3) ||
-            (c >= 0x1FD6 && c <= 0x1FDB) ||
-            (c >= 0x1FE0 && c <= 0x1FEC) ||
-            (c >= 0x1FF2 && c <= 0x1FF4) ||
-            (c >= 0x1FF6 && c <= 0x1FFC) ||
-            (c == 0x2126) ||
-            (c >= 0x212A && c <= 0x212B) ||
-            (c == 0x212E) ||
-            (c >= 0x2180 && c <= 0x2182) ||
-            (c >= 0x3041 && c <= 0x3094) ||
-            (c >= 0x30A1 && c <= 0x30FA) ||
-            (c >= 0x3105 && c <= 0x312C) ||
-            (c >= 0xAC00 && c <= 0xD7A3));
-int
-ACEXML_ParserInt::isIdeographic_i (const ACEXML_Char c)
-  return ((c >= 0x4E00 && c <= 0x9FA5) ||
-          (c == 3007) ||
-          (c >= 0x3021 && c <= 0x3029));
-int
-ACEXML_ParserInt::isCombiningchar_i (const ACEXML_Char c)
-  if (c < 0x0901)
-    return ((c >= 0x0300 && c <= 0x0345) ||
-            (c >= 0x0360 && c <= 0x0361) ||
-            (c >= 0x0483 && c <= 0x0486) ||
-            (c >= 0x0591 && c <= 0x05A1) ||
-            (c >= 0x05A3 && c <= 0x05B9) ||
-            (c >= 0x05BB && c <= 0x05BD) ||
-            (c == 0x05BF) ||
-            (c >= 0x05C1 && c <= 0x05C2) ||
-            (c == 0x05C4) ||
-            (c >= 0x064B && c <= 0x0652) ||
-            (c == 0x0670) ||
-            (c >= 0x06D6 && c <= 0x06DC) ||
-            (c >= 0x06DD && c <= 0x06DF) ||
-            (c >= 0x06E0 && c <= 0x06E4) ||
-            (c >= 0x06E7 && c <= 0x06E8) ||
-            (c >= 0x06EA && c <= 0x06ED));
-  else
-    return ((c >= 0x0901 && c <= 0x0903) ||
-            (c == 0x093C) ||
-            (c >= 0x093E && c <= 0x094C) ||
-            (c == 0x094D) ||
-            (c >= 0x0951 && c <= 0x0954) ||
-            (c >= 0x0962 && c <= 0x0963) ||
-            (c >= 0x0981 && c <= 0x0983) ||
-            (c == 0x09BC) ||
-            (c == 0x09BE) ||
-            (c == 0x09BF) ||
-            (c >= 0x09C0 && c <= 0x09C4) ||
-            (c >= 0x09C7 && c <= 0x09C8) ||
-            (c >= 0x09CB && c <= 0x09CD) ||
-            (c == 0x09D7) ||
-            (c >= 0x09E2 && c <= 0x09E3) ||
-            (c == 0x0A02) ||
-            (c == 0x0A3C) ||
-            (c == 0x0A3E) ||
-            (c == 0x0A3F) ||
-            (c >= 0x0A40 && c <= 0x0A42) ||
-            (c >= 0x0A47 && c <= 0x0A48) ||
-            (c >= 0x0A4B && c <= 0x0A4D) ||
-            (c >= 0x0A70 && c <= 0x0A71) ||
-            (c >= 0x0A81 && c <= 0x0A83) ||
-            (c == 0x0ABC) ||
-            (c >= 0x0ABE && c <= 0x0AC5) ||
-            (c >= 0x0AC7 && c <= 0x0AC9) ||
-            (c >= 0x0ACB && c <= 0x0ACD) ||
-            (c >= 0x0B01 && c <= 0x0B03) ||
-            (c == 0x0B3C) ||
-            (c >= 0x0B3E && c <= 0x0B43) ||
-            (c >= 0x0B47 && c <= 0x0B48) ||
-            (c >= 0x0B4B && c <= 0x0B4D) ||
-            (c >= 0x0B56 && c <= 0x0B57) ||
-            (c >= 0x0B82 && c <= 0x0B83) ||
-            (c >= 0x0BBE && c <= 0x0BC2) ||
-            (c >= 0x0BC6 && c <= 0x0BC8) ||
-            (c >= 0x0BCA && c <= 0x0BCD) ||
-            (c == 0x0BD7) ||
-            (c >= 0x0C01 && c <= 0x0C03) ||
-            (c >= 0x0C3E && c <= 0x0C44) ||
-            (c >= 0x0C46 && c <= 0x0C48) ||
-            (c >= 0x0C4A && c <= 0x0C4D) ||
-            (c >= 0x0C55 && c <= 0x0C56) ||
-            (c >= 0x0C82 && c <= 0x0C83) ||
-            (c >= 0x0CBE && c <= 0x0CC4) ||
-            (c >= 0x0CC6 && c <= 0x0CC8) ||
-            (c >= 0x0CCA && c <= 0x0CCD) ||
-            (c >= 0x0CD5 && c <= 0x0CD6) ||
-            (c >= 0x0D02 && c <= 0x0D03) ||
-            (c >= 0x0D3E && c <= 0x0D43) ||
-            (c >= 0x0D46 && c <= 0x0D48) ||
-            (c >= 0x0D4A && c <= 0x0D4D) ||
-            (c == 0x0D57) ||
-            (c == 0x0E31) ||
-            (c >= 0x0E34 && c <= 0x0E3A) ||
-            (c >= 0x0E47 && c <= 0x0E4E) ||
-            (c == 0x0EB1) ||
-            (c >= 0x0EB4 && c <= 0x0EB9) ||
-            (c >= 0x0EBB && c <= 0x0EBC) ||
-            (c >= 0x0EC8 && c <= 0x0ECD) ||
-            (c >= 0x0F18 && c <= 0x0F19) ||
-            (c == 0x0F35) ||
-            (c == 0x0F37) ||
-            (c == 0x0F39) ||
-            (c == 0x0F3E) ||
-            (c == 0x0F3F) ||
-            (c >= 0x0F71 && c <= 0x0F84) ||
-            (c >= 0x0F86 && c <= 0x0F8B) ||
-            (c >= 0x0F90 && c <= 0x0F95) ||
-            (c == 0x0F97) ||
-            (c >= 0x0F99 && c <= 0x0FAD) ||
-            (c >= 0x0FB1 && c <= 0x0FB7) ||
-            (c == 0x0FB9) ||
-            (c >= 0x20D0 && c <= 0x20DC) ||
-            (c == 0x20E1) ||
-            (c >= 0x302A && c <= 0x302F) ||
-            (c == 0x3099) ||
-            (c == 0x309A));
-int
-ACEXML_ParserInt::isDigit_i (const ACEXML_Char c)
-  if (c < 0x0040)
-    return (c >= 0x0030 && c <= 0x0039);
-  else
-    return ((c >= 0x0660 && c <= 0x0669) ||
-            (c >= 0x06F0 && c <= 0x06F9) ||
-            (c >= 0x0966 && c <= 0x096F) ||
-            (c >= 0x09E6 && c <= 0x09EF) ||
-            (c >= 0x0A66 && c <= 0x0A6F) ||
-            (c >= 0x0AE6 && c <= 0x0AEF) ||
-            (c >= 0x0B66 && c <= 0x0B6F) ||
-            (c >= 0x0BE7 && c <= 0x0BEF) ||
-            (c >= 0x0C66 && c <= 0x0C6F) ||
-            (c >= 0x0CE6 && c <= 0x0CEF) ||
-            (c >= 0x0D66 && c <= 0x0D6F) ||
-            (c >= 0x0E50 && c <= 0x0E59) ||
-            (c >= 0x0ED0 && c <= 0x0ED9) ||
-            (c >= 0x0F20 && c <= 0x0F29));
-int
-ACEXML_ParserInt::isExtender_i (const ACEXML_Char c)
-  // The compiler should generate a jump table and index into it directly.
-  switch (c)
-      case 0x00B7: case 0x02D0: case 0x02D1: case 0x0387: case 0x0640:
-      case 0x0E46: case 0x0EC6: case 0x3005: case 0x3031: case 0x3032:
-      case 0x3033: case 0x3034: case 0x3035: case 0x309D: case 0x309E:
-      case 0x30FC: case 0x30FD: case 0x30FE:
-        return 1;
-      default:
-        return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserInternals.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserInternals.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/ParserInternals.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,104 +0,0 @@
-// -*- C++ -*-
- *  @file    ParserInternals.h
- *  ParserInternals.h,v 1.3 2003/07/19 19:04:10 dhinton Exp
-#ifndef _ACEXML_PARSER_INTERNALS_H_
-#define _ACEXML_PARSER_INTERNALS_H_
-#pragma once
- * @class ACEXML_ParserInt ParserInternals.h "ACEXML/parser/parser/ParserInternals.h"
- * @brief A class to hide some of the internal implementation details of
- *        the parser.
-class ACEXML_PARSER_Export ACEXML_ParserInt
-public:
-#if defined (ACE_USES_WCHAR)
-   * Check if a character @a c is a BaseChar. This method checks for the
-   * complete set of characters allowed when WCHAR support is enabled.
-   * @retval 1 if @a c is a valid XML Character, 0 otherwise.
-  static int isBasechar_i (const ACEXML_Char c);
-   * Check if a character @a c is a Ideographic. This method checks for the
-  static int isIdeographic_i (const ACEXML_Char c);
-   * Check if a character @a c is a CombiningChar. This method checks for the
-  static int isCombiningchar_i (const ACEXML_Char c);
-   * Check if a character @a c is a Digit. This method checks for the
-  static int isDigit_i (const ACEXML_Char c);
-   * Check if a character @a c is an Extender. This method checks for the
-  static int isExtender_i (const ACEXML_Char c);
-  static const ACEXML_Char base_char_table_[256];
-  static const ACEXML_Char* msg_[];
-  static const ACEXML_Char* predef_ent_[];
-  static const ACEXML_Char* predef_val_[];
-  // Enum describing the position in a document when a reference occurs.
-  enum ReferenceState {
-    IN_CONTENT,
-    IN_ATT_VALUE,
-    AS_ATT_VALUE,
-    IN_ENTITY_VALUE,
-    IN_INT_DTD,
-    IN_EXT_DTD,
-    IN_NOTATION,
-    INVALID = -1
-#endif /* _ACEXML_PARSER_INTERNALS_H_ */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser_export.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser_export.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/Parser_export.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,47 +0,0 @@
-// -*- C++ -*-
- *  @file    Parser_export.h
- *  Parser_export.h,v 1.2 2002/01/24 21:00:01 nanbor Exp
-// Definition for Win32 Export directives.
-// This file is generated automatically by generate_export_file.pl
-#ifndef ACEXML_PARSER_EXPORT_H
-#define ACEXML_PARSER_EXPORT_H
-#include "ace/config-all.h"
-#if defined (ACE_AS_STATIC_LIBS) && !defined (ACEXML_PARSER_HAS_DLL)
-#  define ACEXML_PARSER_HAS_DLL 0
-#endif /* ACE_AS_STATIC_LIBS && ACEXML_PARSER_HAS_DLL */
-#if !defined (ACEXML_PARSER_HAS_DLL)
-#  define ACEXML_PARSER_HAS_DLL 1
-#endif /* ! ACEXML_PARSER_HAS_DLL */
-#if defined (ACEXML_PARSER_HAS_DLL) && (ACEXML_PARSER_HAS_DLL == 1)
-#  if defined (ACEXML_PARSER_BUILD_DLL)
-#    define ACEXML_PARSER_Export ACE_Proper_Export_Flag
-#    define ACEXML_PARSER_SINGLETON_DECLARATION(T) ACE_EXPORT_SINGLETON_DECLARATION (T)
-#    define ACEXML_PARSER_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK) ACE_EXPORT_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK)
-#  else /* ACEXML_PARSER_BUILD_DLL */
-#    define ACEXML_PARSER_Export ACE_Proper_Import_Flag
-#    define ACEXML_PARSER_SINGLETON_DECLARATION(T) ACE_IMPORT_SINGLETON_DECLARATION (T)
-#    define ACEXML_PARSER_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK) ACE_IMPORT_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK)
-#  endif /* ACEXML_PARSER_BUILD_DLL */
-#else /* ACEXML_PARSER_HAS_DLL == 1 */
-#endif /* ACEXML_PARSER_HAS_DLL == 1 */
-#endif /* ACEXML_PARSER_EXPORT_H */
-// End of auto generated file.
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/parser.mpc
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/parser.mpc	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/parser/parser/parser.mpc	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,9 +0,0 @@
-//  -*- MPC -*-
-// parser.mpc,v 1.5 2003/11/10 04:31:58 dhinton Exp
-project(ACEXML_Parser): acelib {
-  sharedname    = ACEXML_Parser
-  after        += ACEXML
-  libs         += ACEXML
-  dynamicflags += ACEXML_PARSER_BUILD_DLL
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/ContentHandler_Test.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/ContentHandler_Test.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/ContentHandler_Test.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,103 +0,0 @@
- *  @file    ContentHandler_Test.cpp
- *  ContentHandler_Test.cpp,v 1.6 2003/11/07 20:27:29 shuston Exp
- *  @author Steve Huston  <shuston at riverace.com>
-#include "ACEXML/common/DefaultHandler.h"
-#include "ACEXML/common/StrCharStream.h"
-#include "ACEXML/parser/parser/Parser.h"
-#include "ace/OS_NS_string.h"
-#include "ace/OS_main.h"
-class Basic_Content_Tester : public ACEXML_DefaultHandler
-public:
-   * Receive notification of character data.
-  virtual void characters (const ACEXML_Char *ch,
-                           int start,
-                           int length ACEXML_ENV_ARG_DECL)
-  const ACEXML_Char *get_test_string (void)
-    { return Basic_Content_Tester::test_string_; }
-private:
-  static const ACEXML_Char *test_string_;
-const ACEXML_Char * Basic_Content_Tester::test_string_ =
-  ACE_TEXT ("<?xml version=\"1.0\"?>")
-  ACE_TEXT ("<translation type=\"unfinished\">Example\n")
-  ACE_TEXT ("d&apos;internationalisation</translation>");
-void
-Basic_Content_Tester::characters (const ACEXML_Char *ch,
-                                  int start,
-  static int already_called = 0;
-  static const ACEXML_Char *expect =
-    ACE_TEXT ("Example\nd'internationalisation");
-  if (already_called)
-      ACEXML_THROW (ACEXML_SAXException
-                    (ACE_TEXT ("characters() called too much\n")));
-  already_called = 1;
-  int expected_len = ACE_static_cast (int, ACE_OS::strlen (expect));
-  if (length != expected_len)
-                  ACE_TEXT ("characters() expected len %d (%*s); ")
-                  ACE_TEXT ("got %d (%*s)\n"),
-                  expected_len, expected_len, ch + start,
-                  length, length, ch + start));
-      ACEXML_THROW (ACEXML_SAXException (ACE_TEXT ("Functionality failure")));
-  return;
-int
-ACE_TMAIN (int, ACE_TCHAR *[])
-  int status = 0;
-  Basic_Content_Tester tester;
-  ACEXML_StrCharStream *test_stream = 0;
-  ACE_NEW_RETURN (test_stream, ACEXML_StrCharStream, -1);
-  if (test_stream->open (tester.get_test_string (),
-                         ACE_TEXT ("test_stream")) < 0)
-      ACE_ERROR ((LM_ERROR, ACE_TEXT ("Unable to create input stream\n")));
-      return -1;
-  ACEXML_InputSource input (test_stream);
-  ACEXML_Parser parser;
-  parser.setContentHandler (&tester);
-  ACEXML_TRY_NEW_ENV
-    parser.setFeature (ACE_TEXT ("http://xml.org/sax/features/validation"),
-                       0
-                       ACEXML_ENV_ARG_PARAMETER);
-    ACEXML_TRY_CHECK;
-    parser.parse (&input ACEXML_ENV_ARG_PARAMETER);
-    ACEXML_TRY_CHECK;
-  ACEXML_CATCH (ACEXML_SAXException, ex)
-    ex.print();
-    status = 1;
-  ACEXML_ENDTRY;
-  return status;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/ContentHandler_Test.dsp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/ContentHandler_Test.dsp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/ContentHandler_Test.dsp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,77 +0,0 @@
-# Microsoft Developer Studio Project File - Name="ContentHandler_Test EXE" - Package Owner=<4>
-# Microsoft Developer Studio Generated Build File, Format Version 6.00
-# ** DO NOT EDIT **
-# TARGTYPE "Win32 (x86) Console Application" 0x0103
-CFG=ContentHandler_Test EXE - Win32 Debug
-!MESSAGE This is not a valid makefile. To build this project using NMAKE,
-!MESSAGE run the tool that generated this project file and specify the
-!MESSAGE nmake output type.  You can then use the following command:
-!MESSAGE
-!MESSAGE NMAKE /f "ContentHandler_Test.mak".
-!MESSAGE
-!MESSAGE You can specify a configuration when running NMAKE
-!MESSAGE by defining the macro CFG on the command line. For example:
-!MESSAGE
-!MESSAGE NMAKE /f "ContentHandler_Test.mak" CFG="ContentHandler_Test EXE - Win32 Debug"
-!MESSAGE
-!MESSAGE Possible choices for configuration are:
-!MESSAGE
-!MESSAGE "ContentHandler_Test EXE - Win32 Release" (based on "Win32 (x86) Console Application")
-!MESSAGE "ContentHandler_Test EXE - Win32 Debug" (based on "Win32 (x86) Console Application")
-!MESSAGE
-# Begin Project
-# PROP AllowPerConfigDependencies 0
-# PROP Scc_ProjName ""
-# PROP Scc_LocalPath ""
-CPP=cl.exe
-RSC=rc.exe
-!IF  "$(CFG)" == "ContentHandler_Test EXE - Win32 Release"
-# PROP Use_MFC 0
-# PROP Use_Debug_Libraries 0
-# PROP Output_Dir "Release"
-# PROP Intermediate_Dir "Release\ContentHandler_Test"
-# PROP Target_Dir ""
-# ADD CPP /nologo /W3 /GX /O2 /MD /GR /I "..\.." /D NDEBUG=1 /D WIN32=1 /D _CONSOLE=1 /FD /c
-# SUBTRACT CPP /YX
-# ADD RSC /l 0x409 /d NDEBUG=1 /i "..\.."
-BSC32=bscmake.exe
-# ADD BSC32 /nologo
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACEXML_Parser.lib ACEXML.lib ACE.lib /libpath:"..\..\ACEXML\common" /libpath:"..\..\ACEXML\parser\parser" /libpath:"..\..\ace" /nologo /version:5.3.1 /subsystem:console /pdb:"Release\ContentHandler_Test.pdb"  /machine:I386 /out:"Release\ContentHandler_Test.exe"
-!ELSEIF  "$(CFG)" == "ContentHandler_Test EXE - Win32 Debug"
-# PROP Use_MFC 0
-# PROP Use_Debug_Libraries 1
-# PROP Output_Dir "."
-# PROP Intermediate_Dir "Debug\ContentHandler_Test"
-# ADD CPP /nologo /W3 /Gm /GX /Zi /Od /MDd /GR /Gy /I "..\.." /D _DEBUG=1 /D WIN32=1 /D _CONSOLE=1 /FD /c
-# SUBTRACT CPP /YX
-# ADD RSC /l 0x409 /d _DEBUG=1 /i "..\.."
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACEXML_Parserd.lib ACEXMLd.lib ACEd.lib /libpath:"..\..\ACEXML\common" /libpath:"..\..\ACEXML\parser\parser" /libpath:"..\..\ace" /nologo /version:5.3.1 /subsystem:console /pdb:".\ContentHandler_Test.pdb" /debug /machine:I386 /out:".\ContentHandler_Test.exe"
-!ENDIF
-# Begin Target
-# Name "ContentHandler_Test EXE - Win32 Release"
-# Name "ContentHandler_Test EXE - Win32 Debug"
-# Begin Group "Source Files"
-# PROP Default_Filter "cpp;cxx;c"
-# Begin Source File
-SOURCE=.\ContentHandler_Test.cpp
-# End Source File
-# End Group
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/HttpCharStream_Test.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/HttpCharStream_Test.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/HttpCharStream_Test.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,40 +0,0 @@
-// HttpCharStream_Test.cpp,v 1.6 2003/11/07 20:27:29 shuston Exp
-#include "ACEXML/common/HttpCharStream.h"
-#include "ace/OS_NS_stdio.h"
-int ACE_TMAIN (int, ACE_TCHAR *[])
-  const ACEXML_Char* test = ACE_TEXT("http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd");
-  const ACEXML_Char* simple = ACE_TEXT("http://www.w3.org/TR/xhtml1/DTD/xhtml-lat1.ent");
-  ACEXML_HttpCharStream first;
-  ACEXML_HttpCharStream second;
-  ACEXML_Char ch;
-  if (first.open (test) != -1)
-      while (first.get (ch) != -1)
-        ACE_OS::printf ("%c", ch);
-  else
-      first.close();
-      ACE_ERROR ((LM_ERROR, "Error in opening stream : %m\n"));
-  if (second.open (simple) != -1)
-      while (second.get (ch) != -1)
-  else
-      second.close();
-  first.close();
-  second.close();
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/HttpCharStream_Test.dsp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/HttpCharStream_Test.dsp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/HttpCharStream_Test.dsp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,77 +0,0 @@
-# Microsoft Developer Studio Project File - Name="HttpCharStream_Test EXE" - Package Owner=<4>
-CFG=HttpCharStream_Test EXE - Win32 Debug
-!MESSAGE
-!MESSAGE NMAKE /f "HttpCharStream_Test.mak".
-!MESSAGE
-!MESSAGE
-!MESSAGE NMAKE /f "HttpCharStream_Test.mak" CFG="HttpCharStream_Test EXE - Win32 Debug"
-!MESSAGE
-!MESSAGE
-!MESSAGE "HttpCharStream_Test EXE - Win32 Release" (based on "Win32 (x86) Console Application")
-!MESSAGE "HttpCharStream_Test EXE - Win32 Debug" (based on "Win32 (x86) Console Application")
-!MESSAGE
-# Begin Project
-CPP=cl.exe
-RSC=rc.exe
-!IF  "$(CFG)" == "HttpCharStream_Test EXE - Win32 Release"
-# PROP Use_MFC 0
-# PROP Intermediate_Dir "Release\HttpCharStream_Test"
-# SUBTRACT CPP /YX
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACEXML_Parser.lib ACEXML.lib ACE.lib /libpath:"..\..\ACEXML\common" /libpath:"..\..\ACEXML\parser\parser" /libpath:"..\..\ace" /nologo /version:5.3.1 /subsystem:console /pdb:"Release\HttpCharStream_Test.pdb"  /machine:I386 /out:"Release\HttpCharStream_Test.exe"
-!ELSEIF  "$(CFG)" == "HttpCharStream_Test EXE - Win32 Debug"
-# PROP Use_MFC 0
-# PROP Intermediate_Dir "Debug\HttpCharStream_Test"
-# SUBTRACT CPP /YX
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACEXML_Parserd.lib ACEXMLd.lib ACEd.lib /libpath:"..\..\ACEXML\common" /libpath:"..\..\ACEXML\parser\parser" /libpath:"..\..\ace" /nologo /version:5.3.1 /subsystem:console /pdb:".\HttpCharStream_Test.pdb" /debug /machine:I386 /out:".\HttpCharStream_Test.exe"
-!ENDIF
-# Begin Target
-# Name "HttpCharStream_Test EXE - Win32 Release"
-# Name "HttpCharStream_Test EXE - Win32 Debug"
-SOURCE=.\HttpCharStream_Test.cpp
-# End Source File
-# End Group
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,17 +0,0 @@
-# Makefile,v 1.14 2003/07/14 18:47:58 jwillemsen Exp
-#       GNU ACE Workspace
-include $(ACE_ROOT)/include/makeinclude/macros.GNU
-TARGETS_NESTED := $(TARGETS_NESTED:.nested=)
-MFILES = \
-         Makefile.Transcoder_Test \
-         Makefile.NamespaceSupport_Test \
-         Makefile.HttpCharStream_Test \
-         Makefile.ContentHandler_Test
-$(TARGETS_NESTED):
-	@for file in $(MFILES); do \
-	$(MAKE) -f `basename $$file` -C `dirname $$file` $(@); \
-	done
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.ContentHandler_Test
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.ContentHandler_Test	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.ContentHandler_Test	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,231 +0,0 @@
-#       GNU Makefile
-MAKEFILE        = Makefile.ContentHandler_Test
-BIN_UNCHECKED   = ContentHandler_Test
-FILES = \
-  ContentHandler_Test
-#       Include macros and targets
-ACE_SHLIBS = -lACE
-include $(ACE_ROOT)/include/makeinclude/wrapper_macros.GNU
-BIN    = $(BIN_UNCHECKED)
-OBJS   = $(addsuffix .o, $(notdir $(FILES)))
-SRC    = $(addsuffix .cpp, $(FILES))
-include $(ACE_ROOT)/include/makeinclude/rules.common.GNU
-include $(ACE_ROOT)/include/makeinclude/rules.nonested.GNU
-include $(ACE_ROOT)/include/makeinclude/rules.local.GNU
-CPPFLAGS     += -I../..
-ifeq ($(static_libs),1)
-  ifneq ($(LIB),)
-    CPPFLAGS += -DACE_AS_STATIC_LIBS
-  endif
-endif
-LDFLAGS      += -L../../ACEXML/common -L../../ACEXML/parser/parser -L../../ace
-LDLIBS  = -lACEXML_Parser -lACEXML
-#       Local targets
-$(BIN): $(addprefix $(VDIR), $(OBJS))
-	$(LINK.cc) $(LDFLAGS) $(CC_OUTPUT_FLAG) $@ $^ $(VLDLIBS) $(POSTLINK)
-realclean: clean
-ifneq ($(GENERATED_DIRTY),)
-	-$(RM) -r $(GENERATED_DIRTY)
-endif
-#       Dependencies
-# DO NOT DELETE THIS LINE -- g++dep uses it.
-# DO NOT PUT ANYTHING AFTER THIS LINE, IT WILL GO AWAY.
-.obj/ContentHandler_Test.o .obj/ContentHandler_Test.so .shobj/ContentHandler_Test.o .shobj/ContentHandler_Test.so: ContentHandler_Test.cpp \
-  $(ACE_ROOT)/ACEXML/common/DefaultHandler.h \
-  $(ACE_ROOT)/ace/pre.h \
-  $(ACE_ROOT)/ACEXML/common/ACEXML_Export.h \
-  $(ACE_ROOT)/ace/config-all.h \
-  $(ACE_ROOT)/ace/config.h \
-  $(ACE_ROOT)/ace/$(ACE_PLATFORM_CONFIG) \
-  $(ACE_ROOT)/ace/post.h \
-  $(ACE_ROOT)/ace/ace_wchar.h \
-  $(ACE_ROOT)/ace/ace_wchar.inl \
-  $(ACE_ROOT)/ace/OS_main.h \
-  $(ACE_ROOT)/ace/ACE_export.h \
-  $(ACE_ROOT)/ACEXML/common/ContentHandler.h \
-  $(ACE_ROOT)/ACEXML/common/Env.h \
-  $(ACE_ROOT)/ACEXML/common/XML_Macros.h \
-  $(ACE_ROOT)/ace/Exception_Macros.h \
-  $(ACE_ROOT)/ACEXML/common/Exception.h \
-  $(ACE_ROOT)/ACEXML/common/XML_Types.h \
-  $(ACE_ROOT)/ace/SString.h \
-  $(ACE_ROOT)/ace/SStringfwd.h \
-  $(ACE_ROOT)/ace/Basic_Types.h \
-  $(ACE_ROOT)/ace/os_include/os_limits.h \
-  $(ACE_ROOT)/ace/os_include/os_unistd.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_types.h \
-  $(ACE_ROOT)/ace/os_include/os_stddef.h \
-  $(ACE_ROOT)/ace/os_include/os_inttypes.h \
-  $(ACE_ROOT)/ace/os_include/os_stdint.h \
-  $(ACE_ROOT)/ace/os_include/os_stdio.h \
-  $(ACE_ROOT)/ace/os_include/os_stdarg.h \
-  $(ACE_ROOT)/ace/os_include/os_float.h \
-  $(ACE_ROOT)/ace/os_include/os_stdlib.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_wait.h \
-  $(ACE_ROOT)/ace/os_include/os_signal.h \
-  $(ACE_ROOT)/ace/os_include/os_time.h \
-  $(ACE_ROOT)/ace/os_include/os_ucontext.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_resource.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_time.h \
-  $(ACE_ROOT)/ace/String_Base.h \
-  $(ACE_ROOT)/ace/String_Base_Const.h \
-  $(ACE_ROOT)/ace/Global_Macros.h \
-  $(ACE_ROOT)/ace/OS_Errno.h \
-  $(ACE_ROOT)/ace/os_include/os_errno.h \
-  $(ACE_ROOT)/ace/String_Base.cpp \
-  $(ACE_ROOT)/ace/ACE.h \
-  $(ACE_ROOT)/ace/Flag_Manip.h \
-  $(ACE_ROOT)/ace/Flag_Manip.i \
-  $(ACE_ROOT)/ace/OS_NS_fcntl.h \
-  $(ACE_ROOT)/ace/os_include/os_fcntl.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_stat.h \
-  $(ACE_ROOT)/ace/Handle_Ops.h \
-  $(ACE_ROOT)/ace/Handle_Ops.i \
-  $(ACE_ROOT)/ace/Lib_Find.h \
-  $(ACE_ROOT)/ace/Lib_Find.i \
-  $(ACE_ROOT)/ace/Init_ACE.h \
-  $(ACE_ROOT)/ace/Init_ACE.i \
-  $(ACE_ROOT)/ace/Sock_Connect.h \
-  $(ACE_ROOT)/ace/os_include/netinet/os_in.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_socket.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_uio.h \
-  $(ACE_ROOT)/ace/Sock_Connect.i \
-  $(ACE_ROOT)/ace/Default_Constants.h \
-  $(ACE_ROOT)/ace/ACE.i \
-  $(ACE_ROOT)/ace/OS_NS_unistd.h \
-  $(ACE_ROOT)/ace/Time_Value.h \
-  $(ACE_ROOT)/ace/OS_NS_Thread.h \
-  $(ACE_ROOT)/ace/os_include/os_pthread.h \
-  $(ACE_ROOT)/ace/Base_Thread_Adapter.h \
-  $(ACE_ROOT)/ace/OS_Log_Msg_Attributes.h \
-  $(ACE_ROOT)/ace/iosfwd.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_sem.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_ipc.h \
-  $(ACE_ROOT)/ace/os_include/os_semaphore.h \
-  $(ACE_ROOT)/ace/OS_Memory.h \
-  $(ACE_ROOT)/ace/OS_NS_stdlib.h \
-  $(ACE_ROOT)/ace/OS_NS_signal.h \
-  $(ACE_ROOT)/ace/Object_Manager_Base.h \
-  $(ACE_ROOT)/ace/Cleanup.h \
-  $(ACE_ROOT)/ace/os_include/os_ctype.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_socket.h \
-  $(ACE_ROOT)/ace/os_include/net/os_if.h \
-  $(ACE_ROOT)/ace/OS_NS_stropts.h \
-  $(ACE_ROOT)/ace/os_include/os_stropts.h \
-  $(ACE_ROOT)/ace/Malloc_Base.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_mman.h \
-  $(ACE_ROOT)/ace/Auto_Ptr.h \
-  $(ACE_ROOT)/ace/Auto_Ptr.cpp \
-  $(ACE_ROOT)/ace/Auto_Ptr.i \
-  $(ACE_ROOT)/ace/OS_NS_string.h \
-  $(ACE_ROOT)/ace/String_Base.i \
-  $(ACE_ROOT)/ace/Min_Max.h \
-  $(ACE_ROOT)/ACEXML/common/SAXExceptions.h \
-  $(ACE_ROOT)/ACEXML/common/Locator.h \
-  $(ACE_ROOT)/ACEXML/common/Attributes.h \
-  $(ACE_ROOT)/ACEXML/common/DTDHandler.h \
-  $(ACE_ROOT)/ACEXML/common/EntityResolver.h \
-  $(ACE_ROOT)/ACEXML/common/InputSource.h \
-  $(ACE_ROOT)/ACEXML/common/CharStream.h \
-  $(ACE_ROOT)/ACEXML/common/ErrorHandler.h \
-  $(ACE_ROOT)/ACEXML/common/StrCharStream.h \
-  $(ACE_ROOT)/ACEXML/parser/parser/Parser.h \
-  $(ACE_ROOT)/ACEXML/parser/parser/Parser_export.h \
-  $(ACE_ROOT)/ACEXML/common/XMLReader.h \
-  $(ACE_ROOT)/ACEXML/common/LocatorImpl.h \
-  $(ACE_ROOT)/ACEXML/common/NamespaceSupport.h \
-  $(ACE_ROOT)/ace/Functor.h \
-  $(ACE_ROOT)/ace/Functor_T.h \
-  $(ACE_ROOT)/ace/Functor_T.cpp \
-  $(ACE_ROOT)/ace/Functor_T.i \
-  $(ACE_ROOT)/ace/Hash_Map_Manager.h \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.h \
-  $(ACE_ROOT)/ace/Log_Msg.h \
-  $(ACE_ROOT)/ace/Log_Priority.h \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.cpp \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.i \
-  $(ACE_ROOT)/ace/Guard_T.h \
-  $(ACE_ROOT)/ace/Lock.h \
-  $(ACE_ROOT)/ace/Guard_T.cpp \
-  $(ACE_ROOT)/ace/Guard_T.inl \
-  $(ACE_ROOT)/ace/RW_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/RW_Mutex.h \
-  $(ACE_ROOT)/ace/Containers_T.h \
-  $(ACE_ROOT)/ace/Containers.h \
-  $(ACE_ROOT)/ace/Node.h \
-  $(ACE_ROOT)/ace/Node.cpp \
-  $(ACE_ROOT)/ace/Array_Base.h \
-  $(ACE_ROOT)/ace/Array_Base.cpp \
-  $(ACE_ROOT)/ace/Array_Base.inl \
-  $(ACE_ROOT)/ace/Unbounded_Set.h \
-  $(ACE_ROOT)/ace/Unbounded_Set.cpp \
-  $(ACE_ROOT)/ace/Unbounded_Set.inl \
-  $(ACE_ROOT)/ace/Unbounded_Queue.h \
-  $(ACE_ROOT)/ace/Unbounded_Queue.cpp \
-  $(ACE_ROOT)/ace/Unbounded_Queue.inl \
-  $(ACE_ROOT)/ace/Containers_T.cpp \
-  $(ACE_ROOT)/ace/Containers_T.i \
-  $(ACE_ROOT)/ace/Null_Mutex.h \
-  $(ACE_ROOT)/ace/Obstack.h \
-  $(ACE_ROOT)/ace/Obstack_T.h \
-  $(ACE_ROOT)/ace/Obchunk.h \
-  $(ACE_ROOT)/ace/Malloc.h \
-  $(ACE_ROOT)/ace/Malloc_T.h \
-  $(ACE_ROOT)/ace/Malloc_Allocator.h \
-  $(ACE_ROOT)/ace/Free_List.h \
-  $(ACE_ROOT)/ace/Free_List.cpp \
-  $(ACE_ROOT)/ace/Free_List.i \
-  $(ACE_ROOT)/ace/Malloc_T.cpp \
-  $(ACE_ROOT)/ace/Malloc_T.i \
-  $(ACE_ROOT)/ace/Memory_Pool.h \
-  $(ACE_ROOT)/ace/Event_Handler.h \
-  $(ACE_ROOT)/ace/Atomic_Op.h \
-  $(ACE_ROOT)/ace/Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Atomic_Op_T.h \
-  $(ACE_ROOT)/ace/Atomic_Op_T.cpp \
-  $(ACE_ROOT)/ace/Atomic_Op_T.i \
-  $(ACE_ROOT)/ace/Synch_Traits.h \
-  $(ACE_ROOT)/ace/Signal.h \
-  $(ACE_ROOT)/ace/Mem_Map.h \
-  $(ACE_ROOT)/ace/SV_Semaphore_Complex.h \
-  $(ACE_ROOT)/ace/SV_Semaphore_Simple.h \
-  $(ACE_ROOT)/ace/SV_Semaphore_Simple.i \
-  $(ACE_ROOT)/ace/SV_Semaphore_Complex.i \
-  $(ACE_ROOT)/ace/Obstack_T.cpp \
-  $(ACE_ROOT)/ace/Obstack_T.i \
-  $(ACE_ROOT)/ACEXML/parser/parser/Entity_Manager.h \
-  $(ACE_ROOT)/ACEXML/parser/parser/ParserInternals.h \
-  $(ACE_ROOT)/ACEXML/parser/parser/ParserContext.h \
-  $(ACE_ROOT)/ace/Swap.h \
-  $(ACE_ROOT)/ace/Swap.cpp \
-  $(ACE_ROOT)/ace/Swap.inl
-# IF YOU PUT ANYTHING HERE IT WILL GO AWAY
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.ContentHandler_Test.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.ContentHandler_Test.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.ContentHandler_Test.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,50 +0,0 @@
-# Makefile.ContentHandler_Test.bor,v 1.3 2003/12/20 14:21:14 jwillemsen Exp
-# Makefile for building the ContentHandler_Test exe with Borland C++ Builder
-NAME = ContentHandler_Test
-OBJFILES = \
-	$(OBJDIR)\ContentHandler_Test.obj
-EXTERNAL_LIBS = \
-LFLAGS = \
-	-j..\..\ACEXML\common\$(CONFIG_SUBDIR) -j..\..\ACEXML\common \
-	-L..\..\ACEXML\common\$(CONFIG_SUBDIR) -L..\..\ACEXML\common \
-	-j..\..\ACEXML\parser\parser\$(CONFIG_SUBDIR) -j..\..\ACEXML\parser\parser \
-	-L..\..\ACEXML\parser\parser\$(CONFIG_SUBDIR) -L..\..\ACEXML\parser\parser \
-	-j..\..\ace\$(CONFIG_SUBDIR) -j..\..\ace \
-	-L..\..\ace\$(CONFIG_SUBDIR) -L..\..\ace \
-  -j$(CORE_BINDIR) \
-  -L$(CORE_BINDIR)
-LIBFILES = \
-	ACEXML_Parser$(LIB_DECORATOR).lib \
-	ACEXML$(LIB_DECORATOR).lib \
-	ACE$(LIB_DECORATOR).lib \
-	$(EXTERNAL_LIBS)
-!ifdef STATIC
-LIB_FLAGS = -DACE_AS_STATIC_LIBS
-DLL_FLAGS =
-!else
-LIB_FLAGS =
-DLL_FLAGS =
-!endif
-CFLAGS = \
-	-I..\.. \
-	$(LIB_FLAGS) \
-	$(DLL_FLAGS)
-CPPDIR = .
-!include <$(ACE_ROOT)\include\makeinclude\build_exe.bor>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.HttpCharStream_Test
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.HttpCharStream_Test	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.HttpCharStream_Test	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,282 +0,0 @@
-#       GNU Makefile
-MAKEFILE        = Makefile.HttpCharStream_Test
-BIN_UNCHECKED   = HttpCharStream_Test
-FILES = \
-  HttpCharStream_Test
-ACE_SHLIBS = -lACE
-  ifneq ($(LIB),)
-  endif
-endif
-#       Local targets
-realclean: clean
-endif
-#       Dependencies
-.obj/HttpCharStream_Test.o .obj/HttpCharStream_Test.so .shobj/HttpCharStream_Test.o .shobj/HttpCharStream_Test.so: HttpCharStream_Test.cpp \
-  $(ACE_ROOT)/ACEXML/common/HttpCharStream.h \
-  $(ACE_ROOT)/ACEXML/common/URL_Addr.h \
-  $(ACE_ROOT)/ace/INET_Addr.h \
-  $(ACE_ROOT)/ace/Addr.h \
-  $(ACE_ROOT)/ACEXML/common/Mem_Map_Stream.h \
-  $(ACE_ROOT)/ace/SOCK_Stream.h \
-  $(ACE_ROOT)/ace/SOCK_IO.h \
-  $(ACE_ROOT)/ace/SOCK.h \
-  $(ACE_ROOT)/ace/IPC_SAP.h \
-  $(ACE_ROOT)/ace/IPC_SAP.i \
-  $(ACE_ROOT)/ace/SOCK.i \
-  $(ACE_ROOT)/ace/SOCK_IO.i \
-  $(ACE_ROOT)/ace/SOCK_Stream.i \
-  $(ACE_ROOT)/ace/SOCK_Connector.h \
-  $(ACE_ROOT)/ace/SOCK_Connector.i \
-  $(ACE_ROOT)/ace/Connector.h \
-  $(ACE_ROOT)/ace/Service_Object.h \
-  $(ACE_ROOT)/ace/Shared_Object.h \
-  $(ACE_ROOT)/ace/Svc_Conf_Tokens.h \
-  $(ACE_ROOT)/ace/DLL.h \
-  $(ACE_ROOT)/ace/os_include/os_dlfcn.h \
-  $(ACE_ROOT)/ace/Strategies_T.h \
-  $(ACE_ROOT)/ace/Reactor.h \
-  $(ACE_ROOT)/ace/Timer_Queuefwd.h \
-  $(ACE_ROOT)/ace/Reactor_Timer_Interface.h \
-  $(ACE_ROOT)/ace/Thread_Manager.h \
-  $(ACE_ROOT)/ace/Thread.h \
-  $(ACE_ROOT)/ace/Thread_Adapter.h \
-  $(ACE_ROOT)/ace/Thread_Exit.h \
-  $(ACE_ROOT)/ace/Thread_Control.h \
-  $(ACE_ROOT)/ace/Condition_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Singleton.h \
-  $(ACE_ROOT)/ace/TSS_T.h \
-  $(ACE_ROOT)/ace/TSS_T.cpp \
-  $(ACE_ROOT)/ace/TSS_T.inl \
-  $(ACE_ROOT)/ace/OS_NS_stdio.h \
-  $(ACE_ROOT)/ace/Singleton.cpp \
-  $(ACE_ROOT)/ace/Singleton.i \
-  $(ACE_ROOT)/ace/Object_Manager.h \
-  $(ACE_ROOT)/ace/Recursive_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Static_Object_Lock.h \
-  $(ACE_ROOT)/ace/Managed_Object.h \
-  $(ACE_ROOT)/ace/Managed_Object.cpp \
-  $(ACE_ROOT)/ace/Managed_Object.i \
-  $(ACE_ROOT)/ace/Framework_Component.h \
-  $(ACE_ROOT)/ace/Framework_Component_T.h \
-  $(ACE_ROOT)/ace/Framework_Component_T.cpp \
-  $(ACE_ROOT)/ace/Framework_Component_T.inl \
-  $(ACE_ROOT)/ace/Connection_Recycling_Strategy.h \
-  $(ACE_ROOT)/ace/Recyclable.h \
-  $(ACE_ROOT)/ace/Refcountable.h \
-  $(ACE_ROOT)/ace/Hashable.h \
-  $(ACE_ROOT)/ace/Reverse_Lock_T.h \
-  $(ACE_ROOT)/ace/Reverse_Lock_T.cpp \
-  $(ACE_ROOT)/ace/Reverse_Lock_T.inl \
-  $(ACE_ROOT)/ace/OS_NS_errno.h \
-  $(ACE_ROOT)/ace/Strategies_T.i \
-  $(ACE_ROOT)/ace/Strategies_T.cpp \
-  $(ACE_ROOT)/ace/Service_Repository.h \
-  $(ACE_ROOT)/ace/Service_Types.h \
-  $(ACE_ROOT)/ace/WFMO_Reactor.h \
-  $(ACE_ROOT)/ace/Synch_Options.h \
-  $(ACE_ROOT)/ace/Handle_Set.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_select.h \
-  $(ACE_ROOT)/ace/Connector.cpp \
-  $(ACE_ROOT)/ace/Svc_Handler.h \
-  $(ACE_ROOT)/ace/Task.h \
-  $(ACE_ROOT)/ace/Task_T.h \
-  $(ACE_ROOT)/ace/Message_Queue.h \
-  $(ACE_ROOT)/ace/Message_Block.h \
-  $(ACE_ROOT)/ace/Message_Block_T.h \
-  $(ACE_ROOT)/ace/Message_Block_T.cpp \
-  $(ACE_ROOT)/ace/Message_Block_T.i \
-  $(ACE_ROOT)/ace/IO_Cntl_Msg.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.cpp \
-  $(ACE_ROOT)/ace/OS_NS_sys_time.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.i \
-  $(ACE_ROOT)/ace/Notification_Strategy.h \
-  $(ACE_ROOT)/ace/Task_T.cpp \
-  $(ACE_ROOT)/ace/Module.h \
-  $(ACE_ROOT)/ace/os_include/os_dirent.h \
-  $(ACE_ROOT)/ace/Module.cpp \
-  $(ACE_ROOT)/ace/Stream_Modules.h \
-  $(ACE_ROOT)/ace/Stream_Modules.cpp \
-  $(ACE_ROOT)/ace/Module.i \
-  $(ACE_ROOT)/ace/Null_Condition.h \
-  $(ACE_ROOT)/ace/Task_T.i \
-  $(ACE_ROOT)/ace/os_include/os_assert.h \
-  $(ACE_ROOT)/ace/Service_Config.h \
-  $(ACE_ROOT)/ace/XML_Svc_Conf.h \
-  $(ACE_ROOT)/ace/Svc_Handler.cpp \
-  $(ACE_ROOT)/ace/Dynamic.h
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.HttpCharStream_Test.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.HttpCharStream_Test.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.HttpCharStream_Test.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,50 +0,0 @@
-# Makefile.HttpCharStream_Test.bor,v 1.3 2003/12/20 14:21:14 jwillemsen Exp
-# Makefile for building the HttpCharStream_Test exe with Borland C++ Builder
-NAME = HttpCharStream_Test
-OBJFILES = \
-	$(OBJDIR)\HttpCharStream_Test.obj
-EXTERNAL_LIBS = \
-LFLAGS = \
-  -L$(CORE_BINDIR)
-LIBFILES = \
-	$(EXTERNAL_LIBS)
-!ifdef STATIC
-DLL_FLAGS =
-!else
-LIB_FLAGS =
-DLL_FLAGS =
-!endif
-CFLAGS = \
-	-I..\.. \
-	$(LIB_FLAGS) \
-	$(DLL_FLAGS)
-CPPDIR = .
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.NamespaceSupport_Test
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.NamespaceSupport_Test	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.NamespaceSupport_Test	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,179 +0,0 @@
-#       GNU Makefile
-MAKEFILE        = Makefile.NamespaceSupport_Test
-BIN_UNCHECKED   = NamespaceSupport_Test
-FILES = \
-  NamespaceSupport_Test
-ACE_SHLIBS = -lACE
-  ifneq ($(LIB),)
-  endif
-endif
-#       Local targets
-realclean: clean
-endif
-#       Dependencies
-.obj/NamespaceSupport_Test.o .obj/NamespaceSupport_Test.so .shobj/NamespaceSupport_Test.o .shobj/NamespaceSupport_Test.so: NamespaceSupport_Test.cpp \
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.NamespaceSupport_Test.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.NamespaceSupport_Test.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.NamespaceSupport_Test.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,50 +0,0 @@
-# Makefile.NamespaceSupport_Test.bor,v 1.3 2003/12/20 14:21:14 jwillemsen Exp
-# Makefile for building the NamespaceSupport_Test exe with Borland C++ Builder
-NAME = NamespaceSupport_Test
-OBJFILES = \
-	$(OBJDIR)\NamespaceSupport_Test.obj
-EXTERNAL_LIBS = \
-LFLAGS = \
-  -L$(CORE_BINDIR)
-LIBFILES = \
-	$(EXTERNAL_LIBS)
-!ifdef STATIC
-DLL_FLAGS =
-!else
-LIB_FLAGS =
-DLL_FLAGS =
-!endif
-CFLAGS = \
-	-I..\.. \
-	$(LIB_FLAGS) \
-	$(DLL_FLAGS)
-CPPDIR = .
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.Transcoder_Test
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.Transcoder_Test	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.Transcoder_Test	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,149 +0,0 @@
-#       GNU Makefile
-MAKEFILE        = Makefile.Transcoder_Test
-BIN_UNCHECKED   = Transcoder_Test
-FILES = \
-  Transcoder_Test
-ACE_SHLIBS = -lACE
-  ifneq ($(LIB),)
-  endif
-endif
-#       Local targets
-realclean: clean
-endif
-#       Dependencies
-.obj/Transcoder_Test.o .obj/Transcoder_Test.so .shobj/Transcoder_Test.o .shobj/Transcoder_Test.so: Transcoder_Test.cpp \
-  $(ACE_ROOT)/ACEXML/common/Transcode.h \
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.Transcoder_Test.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.Transcoder_Test.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.Transcoder_Test.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,50 +0,0 @@
-# Makefile.Transcoder_Test.bor,v 1.3 2003/12/20 14:21:14 jwillemsen Exp
-# Makefile for building the Transcoder_Test exe with Borland C++ Builder
-NAME = Transcoder_Test
-OBJFILES = \
-	$(OBJDIR)\Transcoder_Test.obj
-EXTERNAL_LIBS = \
-LFLAGS = \
-  -L$(CORE_BINDIR)
-LIBFILES = \
-	$(EXTERNAL_LIBS)
-!ifdef STATIC
-DLL_FLAGS =
-!else
-LIB_FLAGS =
-DLL_FLAGS =
-!endif
-CFLAGS = \
-	-I..\.. \
-	$(LIB_FLAGS) \
-	$(DLL_FLAGS)
-CPPDIR = .
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Makefile.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,35 +0,0 @@
-# Makefile.bor,v 1.6 2003/12/20 14:21:14 jwillemsen Exp
-#       Borland Workspace
-!include <$(ACE_ROOT)\include\makeinclude\make_flags.bor>
-all:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.Transcoder_Test.bor all
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.NamespaceSupport_Test.bor all
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.HttpCharStream_Test.bor all
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ContentHandler_Test.bor all
-clean:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.Transcoder_Test.bor clean
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.NamespaceSupport_Test.bor clean
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.HttpCharStream_Test.bor clean
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ContentHandler_Test.bor clean
-realclean:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.Transcoder_Test.bor realclean
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.NamespaceSupport_Test.bor realclean
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.HttpCharStream_Test.bor realclean
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ContentHandler_Test.bor realclean
-install:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.Transcoder_Test.bor install
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.NamespaceSupport_Test.bor install
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.HttpCharStream_Test.bor install
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.ContentHandler_Test.bor install
-regenerate:
-	/usr/bin/perl /build/kitty/ACE_wrappers/bin/mwc.pl -type borland ACEXML.mwc
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/NamespaceSupport_Test.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/NamespaceSupport_Test.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/NamespaceSupport_Test.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,150 +0,0 @@
-// NamespaceSupport_Test.cpp,v 1.7 2003/11/01 11:15:07 dhinton Exp
-#include "ACEXML/common/NamespaceSupport.h"
-  ACEXML_NamespaceSupport xmlns;
-  if (xmlns.init() == -1)
-      ACE_DEBUG ((LM_DEBUG,
-                  ACE_TEXT ("Error in initializing namespace support.")));
-      return 1;
-  xmlns.pushContext();
-  xmlns.declarePrefix(ACE_TEXT (""),
-                      ACE_TEXT ("http://www.w3.org/1999/xhtml"));
-  xmlns.declarePrefix(ACE_TEXT ("dc"),
-                      ACE_TEXT ("http://www.purl.org/dc#"));
-  xmlns.declarePrefix(ACE_TEXT ("xc"),
-  const ACEXML_Char *lName, *uri;
-  const ACEXML_Char *n1 = ACE_TEXT ("p");
-  ACE_DEBUG ((LM_DEBUG, ACE_TEXT ("*** Checking processName:\n")));
-  if (xmlns.processName (n1, uri, lName, 0) != 0)
-    ACE_DEBUG ((LM_ERROR,
-                ACE_TEXT ("Fail to resolve namespace name %s\n"),
-                n1));
-  else
-                ACE_TEXT ("Namespace URI: %s\nLocal name: %s\nRaw name: %s\n"),
-                uri, lName, n1));
-  const ACEXML_Char *n2 = ACE_TEXT ("dc:title");
-  if (xmlns.processName(n2, uri, lName, 0) != 0)
-                ACE_TEXT ("Fail to resolve namespace name %S\n"),
-                n2));
-  else
-                uri, lName, n2));
-  const ACEXML_Char *n3 = ACE_TEXT ("xml:title");
-  if (xmlns.processName(n3, uri, lName, 0) != 0)
-                n3));
-  else
-                uri, lName, n3));
-              ACE_TEXT ("\n*** Checking getDeclaredPrefixes\n")));
-  ACEXML_STR_LIST prefixes;
-  if (xmlns.getDeclaredPrefixes (prefixes) != 0)
-                ACE_TEXT ("Fail to get a list of declared prefixes\n")));
-  else
-      ACEXML_STR_LIST::ITERATOR iter = prefixes.begin ();
-      const ACEXML_Char **prefix = 0;
-      for (; iter.next (prefix);iter.advance ())
-        ACE_DEBUG ((LM_DEBUG, ACE_TEXT ("prefix: \"%s\"\n"), *prefix));
-  ACE_DEBUG ((LM_DEBUG, ACE_TEXT ("\n*** Checking getPrefix\n")));
-  const ACEXML_Char *prefix = 0;
-  if ((prefix = xmlns.getPrefix (ACE_TEXT ("http://www.purl.org/dc#"))) == 0)
-                ACE_TEXT ("Fail to get prefix of http://www.purl.org/dc#\n")));
-  else
-                ACE_TEXT ("Prefix of http://www.purl.org/dc# is %s\n"),
-                prefix));
-  if ((prefix = xmlns.getPrefix (ACE_TEXT ("http://www.w3.org/1999/xhtml"))) == 0)
-                ACE_TEXT ("Fail to get prefix of http://www.w3.org/1999/xhtml which is okay\n")));
-  else
-                ACE_TEXT ("ERROR: Prefix of http://www.w3.org/1999/xhtml is %s\n"),
-                prefix));
-  if ((prefix = xmlns.getPrefix (ACE_TEXT ("http://www.w3.org/XML/1998/namespace"))) == 0)
-                ACE_TEXT ("Fail to get prefix of http://www.w3.org/XML/1998/namespace\n")));
-  else
-                ACE_TEXT ("Prefix of http://www.w3.org/XML/1998/namespace is %s\n"),
-                prefix));
-  ACE_DEBUG ((LM_DEBUG, ACE_TEXT ("\n*** Checking getPrefixes with known URI\n")));
-  prefixes.reset ();
-  if (xmlns.getPrefixes (ACE_TEXT ("http://www.purl.org/dc#"), prefixes) != 0)
-    ACE_DEBUG ((LM_ERROR, ACE_TEXT ("Fail to getPrefixes based on known URI\n")));
-  else
-  ACE_DEBUG ((LM_DEBUG, ACE_TEXT ("\n*** Checking getPrefixes\n")));
-  if (xmlns.getPrefixes (prefixes) != 0)
-    ACE_DEBUG ((LM_ERROR, ACE_TEXT ("Fail to getPrefixes\n")));
-  else
-  ACE_DEBUG ((LM_DEBUG, ACE_TEXT ("\n*** Checking getURI\n")));
-  const ACEXML_Char *URI = 0;
-  if ((URI = xmlns.getURI (ACE_TEXT ("dc"))) == 0)
-    ACE_DEBUG((LM_ERROR, ACE_TEXT ("Fail to get URI for \"dc\"\n")));
-  else
-    ACE_DEBUG ((LM_DEBUG, ACE_TEXT ("URI for \"dc\" is %s\n"), URI));
-  if ((URI = xmlns.getURI (ACE_TEXT ("xc"))) == 0)
-    ACE_DEBUG ((LM_ERROR, ACE_TEXT ("Fail to get URI for \"xc\"\n")));
-  else
-    ACE_DEBUG ((LM_DEBUG, ACE_TEXT ("URI for \"xc\" is %s\n"), URI));
-  if ((URI = xmlns.getURI (ACE_TEXT ("xml"))) == 0)
-    ACE_DEBUG ((LM_ERROR, ACE_TEXT ("Fail to get URI for \"xml\"\n")));
-  else
-    ACE_DEBUG ((LM_DEBUG, ACE_TEXT ("URI for \"xml\" is %s\n"), URI));
-  if ((URI = xmlns.getURI (ACE_TEXT (""))) == 0)
-    ACE_DEBUG ((LM_ERROR, ACE_TEXT ("Fail to get default namespace URI\n")));
-  else
-    ACE_DEBUG ((LM_DEBUG, ACE_TEXT ("URI for default namespace is %s\n"), URI));
-  xmlns.popContext();
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/NamespaceSupport_Test.dsp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/NamespaceSupport_Test.dsp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/NamespaceSupport_Test.dsp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,77 +0,0 @@
-# Microsoft Developer Studio Project File - Name="NamespaceSupport_Test EXE" - Package Owner=<4>
-CFG=NamespaceSupport_Test EXE - Win32 Debug
-!MESSAGE
-!MESSAGE NMAKE /f "NamespaceSupport_Test.mak".
-!MESSAGE
-!MESSAGE
-!MESSAGE NMAKE /f "NamespaceSupport_Test.mak" CFG="NamespaceSupport_Test EXE - Win32 Debug"
-!MESSAGE
-!MESSAGE
-!MESSAGE "NamespaceSupport_Test EXE - Win32 Release" (based on "Win32 (x86) Console Application")
-!MESSAGE "NamespaceSupport_Test EXE - Win32 Debug" (based on "Win32 (x86) Console Application")
-!MESSAGE
-# Begin Project
-CPP=cl.exe
-RSC=rc.exe
-!IF  "$(CFG)" == "NamespaceSupport_Test EXE - Win32 Release"
-# PROP Use_MFC 0
-# PROP Intermediate_Dir "Release\NamespaceSupport_Test"
-# SUBTRACT CPP /YX
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACEXML_Parser.lib ACEXML.lib ACE.lib /libpath:"..\..\ACEXML\common" /libpath:"..\..\ACEXML\parser\parser" /libpath:"..\..\ace" /nologo /version:5.3.1 /subsystem:console /pdb:"Release\NamespaceSupport_Test.pdb"  /machine:I386 /out:"Release\NamespaceSupport_Test.exe"
-!ELSEIF  "$(CFG)" == "NamespaceSupport_Test EXE - Win32 Debug"
-# PROP Use_MFC 0
-# PROP Intermediate_Dir "Debug\NamespaceSupport_Test"
-# SUBTRACT CPP /YX
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACEXML_Parserd.lib ACEXMLd.lib ACEd.lib /libpath:"..\..\ACEXML\common" /libpath:"..\..\ACEXML\parser\parser" /libpath:"..\..\ace" /nologo /version:5.3.1 /subsystem:console /pdb:".\NamespaceSupport_Test.pdb" /debug /machine:I386 /out:".\NamespaceSupport_Test.exe"
-!ENDIF
-# Begin Target
-# Name "NamespaceSupport_Test EXE - Win32 Release"
-# Name "NamespaceSupport_Test EXE - Win32 Debug"
-SOURCE=.\NamespaceSupport_Test.cpp
-# End Source File
-# End Group
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Tests.dsw
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Tests.dsw	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Tests.dsw	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,67 +0,0 @@
-Microsoft Developer Studio Workspace File, Format Version 6.00
-# WARNING: DO NOT EDIT OR DELETE THIS WORKSPACE FILE!
-Project: "ContentHandler_Test"=.\ContentHandler_Test.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Project: "HttpCharStream_Test"=.\HttpCharStream_Test.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Project: "NamespaceSupport_Test"=.\NamespaceSupport_Test.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Project: "Transcoder_Test"=.\Transcoder_Test.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Global:
-Package=<5>
-Package=<3>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Transcoder_Test.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Transcoder_Test.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Transcoder_Test.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,71 +0,0 @@
-// -*- C++ -*- Transcoder_Test.cpp,v 1.7 2003/11/07 20:27:29 shuston Exp
-#include "ACEXML/common/Transcode.h"
-#include "ace/Log_Msg.h"
-void dump_utf16 (const ACEXML_UTF16 *data,
-                 size_t len)
-  size_t ptr = 0;
-  while (1)
-      ACE_DEBUG ((LM_DEBUG, "%04x", data[ptr]));
-      if (++ptr >= len)
-        break;
-      if (ptr % 4 == 0)
-        ACE_DEBUG ((LM_DEBUG, "\n"));
-      else
-        ACE_DEBUG ((LM_DEBUG, "  "));
-  return;
-int
-ACE_TMAIN (int, ACE_TCHAR*[])
-  ACEXML_UTF16 org [18];
-//  =  { 1, 2, 4, 8, 0x10, 0x20, 0x40,
-//      0x80,
-//      0x100, 0x200, 0x400,
-//      0x800, 0x801, 0x802, 0x804, 0x808, 0x810, 0x820,
-//      0x840, 0x880, 0x900, 0xa00, 0xc00,
-//      0x1000, 0x2000, 0x4000, 0x8000, 0 }
-  ACEXML_UCS4 temp = 1;
-  ACE_OS::memset (org, 0, sizeof org);
-  size_t x;
-  for (x = 0; temp < 0x10000; x++, temp <<= 1)
-      org[x] = ACE_static_cast (ACEXML_UTF16, temp);
-  ACE_DEBUG ((LM_DEBUG, "Original UTF16 string:\n"));
-  dump_utf16 (org, x);
-  ACE_DEBUG ((LM_DEBUG, "\n\n"));
-  ACEXML_UTF8 decoded [MAXPATHLEN];
-  ACE_OS::memset (decoded, 0, sizeof decoded);
-  ACEXML_Transcoder::utf16s2utf8s (org, decoded, MAXPATHLEN);
-  ACE_DEBUG ((LM_DEBUG, "Transcoded UTF8 string:\n"));
-  ACE_HEX_DUMP ((LM_DEBUG, decoded, ACE_OS::strlen (decoded) + 1));
-  ACEXML_UTF16 after [18];
-  ACE_OS::memset (after, 0, sizeof after);
-  ACEXML_Transcoder::utf8s2utf16s (decoded, after, 18);
-  ACE_DEBUG ((LM_DEBUG, "Restored UTF16 string:\n"));
-  dump_utf16 (after, x);
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Transcoder_Test.dsp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Transcoder_Test.dsp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/Transcoder_Test.dsp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,77 +0,0 @@
-# Microsoft Developer Studio Project File - Name="Transcoder_Test EXE" - Package Owner=<4>
-CFG=Transcoder_Test EXE - Win32 Debug
-!MESSAGE
-!MESSAGE NMAKE /f "Transcoder_Test.mak".
-!MESSAGE
-!MESSAGE
-!MESSAGE NMAKE /f "Transcoder_Test.mak" CFG="Transcoder_Test EXE - Win32 Debug"
-!MESSAGE
-!MESSAGE
-!MESSAGE "Transcoder_Test EXE - Win32 Release" (based on "Win32 (x86) Console Application")
-!MESSAGE "Transcoder_Test EXE - Win32 Debug" (based on "Win32 (x86) Console Application")
-!MESSAGE
-# Begin Project
-CPP=cl.exe
-RSC=rc.exe
-!IF  "$(CFG)" == "Transcoder_Test EXE - Win32 Release"
-# PROP Use_MFC 0
-# PROP Intermediate_Dir "Release\Transcoder_Test"
-# SUBTRACT CPP /YX
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACEXML_Parser.lib ACEXML.lib ACE.lib /libpath:"..\..\ACEXML\common" /libpath:"..\..\ACEXML\parser\parser" /libpath:"..\..\ace" /nologo /version:5.3.1 /subsystem:console /pdb:"Release\Transcoder_Test.pdb"  /machine:I386 /out:"Release\Transcoder_Test.exe"
-!ELSEIF  "$(CFG)" == "Transcoder_Test EXE - Win32 Debug"
-# PROP Use_MFC 0
-# PROP Intermediate_Dir "Debug\Transcoder_Test"
-# SUBTRACT CPP /YX
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACEXML_Parserd.lib ACEXMLd.lib ACEd.lib /libpath:"..\..\ACEXML\common" /libpath:"..\..\ACEXML\parser\parser" /libpath:"..\..\ace" /nologo /version:5.3.1 /subsystem:console /pdb:".\Transcoder_Test.pdb" /debug /machine:I386 /out:".\Transcoder_Test.exe"
-!ENDIF
-# Begin Target
-# Name "Transcoder_Test EXE - Win32 Release"
-# Name "Transcoder_Test EXE - Win32 Debug"
-SOURCE=.\Transcoder_Test.cpp
-# End Source File
-# End Group
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/tests.mpc
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/tests.mpc	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ACEXML/tests/tests.mpc	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,26 +0,0 @@
-//  -*- MPC -*-
-// tests.mpc,v 1.3 2003/11/10 04:31:58 dhinton Exp
-project(Transcoder_Test): aceexe, acexml {
-  Source_Files {
-project(NamespaceSupport_Test): aceexe, acexml {
-  Source_Files {
-    NamespaceSupport_Test.cpp
-project(HttpCharStream_Test): aceexe, acexml {
-  Source_Files {
-    HttpCharStream_Test.cpp
-project(ContentHandler_Test): aceexe, acexml {
-  Source_Files {
-    ContentHandler_Test.cpp
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_CV_Dispatcher_Impl_T.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_CV_Dispatcher_Impl_T.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_CV_Dispatcher_Impl_T.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,286 +0,0 @@
-// DSRT_CV_Dispatcher_Impl_T.cpp,v 1.3 2003/10/14 08:53:07 venkita Exp
-#ifndef DSRT_CV_DISPATCHER_IMPL_T_CPP
-#define DSRT_CV_DISPATCHER_IMPL_T_CPP
-#include "DSRT_CV_Dispatcher_Impl_T.h"
-#if !defined (__ACE_INLINE__)
-//#include "DSRT_CV_Dispatcher_Impl_T.i"
-#endif /* __ACE_INLINE__ */
-ACE_RCSID(Kokyu, DSRT_CV_Dispatcher_Impl_T, "DSRT_CV_Dispatcher_Impl_T.cpp,v 1.3 2003/10/14 08:53:07 venkita Exp")
-namespace Kokyu
-//@@VS: This is somehow not being recognized by MSVC, which results
-//in a link error. For now, the definition has been moved to the .h
-//file. Needs further investigation.
-template <class DSRT_Scheduler_Traits>
-int Comparator_Adapter_Generator<DSRT_Scheduler_Traits>::MoreEligible::
-operator ()(const DSRT_Dispatch_Item_var<DSRT_Scheduler_Traits>& item1,
-            const DSRT_Dispatch_Item_var<DSRT_Scheduler_Traits>& item2)
-  int rc = qos_comparator_ (item1->qos (), item2->qos ());
-  //more eligible
-  if (rc == 1)
-    return 1;
-  //if equally eligible, then resolve tie with the creation time of
-  //the item
-  if (rc == 0 && item1->insertion_time () < item2->insertion_time ())
-    return 1;
-  return 0;
-DSRT_CV_Dispatcher_Impl<DSRT_Scheduler_Traits>::
-DSRT_CV_Dispatcher_Impl (ACE_Sched_Params::Policy sched_policy,
-                         int sched_scope)
-  :DSRT_Dispatcher_Impl<DSRT_Scheduler_Traits> (sched_policy, sched_scope),
-   run_cond_ (run_cond_lock_)
-template <class DSRT_Scheduler_Traits> int
-init_i (const DSRT_ConfigInfo&)
-  return 0;
-int DSRT_CV_Dispatcher_Impl<DSRT_Scheduler_Traits>::
-schedule_i (Guid_t id, const DSRT_QoSDescriptor& qos)
-#ifdef KOKYU_DSRT_LOGGING
-              "(%t|%T):schedule_i enter\n"));
-#endif
-  DSRT_Dispatch_Item<DSRT_Scheduler_Traits>* item;
-  ACE_hthread_t thr_handle;
-  ACE_Thread::self (thr_handle);
-  if (ACE_OS::thr_setprio (thr_handle,
-                           this->blocked_prio_,
-                           this->sched_policy_) == -1)
-      ACE_ERROR_RETURN ((LM_ERROR,
-                  ACE_TEXT ("%p\n"),
-                  ACE_TEXT ("thr_setprio failed")), -1);
-  ACE_NEW_RETURN (item,
-                  DSRT_Dispatch_Item<DSRT_Scheduler_Traits> (id, qos),
-                  -1);
-  item->thread_handle (thr_handle);
-  ACE_GUARD_RETURN (ACE_SYNCH_RECURSIVE_MUTEX, guard, this->synch_lock_, -1);
-  if (this->ready_queue_.insert (item) == -1)
-    return -1;
-  this->ready_queue_.dump ();
-              "(%t|%T):schedule_i after ready_q.insert\n"));
-#endif
-  DSRT_Dispatch_Item_var<DSRT_Scheduler_Traits> item_var;
-  ACE_GUARD_RETURN (ACE_SYNCH_MUTEX, cond_guard, run_cond_lock_, -1);
-  this->ready_queue_.most_eligible (item_var);
-  guard.release ();
-  ACE_hthread_t most_eligible_thr_handle = item_var->thread_handle ();
-                  "(%t|%T):curr thr handle = %d\n",
-                  thr_handle));
-                  "(%t|%T):curr scheduled thr handle = %d\n",
-                  this->curr_scheduled_thr_handle_));
-                  "(%t|%T):most eligible thr handle = %d \n",
-                  most_eligible_thr_handle));
-#endif
-  if (this->curr_scheduled_thr_handle_ == thr_handle &&
-      most_eligible_thr_handle != thr_handle)
-                  "(%t|%T):curr sched thr handle = thr_handle & "
-                  "most eligible thr handle != curr thr handle. "
-                  "about to do a broadcast on CV to wake up most eligible\n"));
-#endif
-      this->curr_scheduled_thr_handle_ = most_eligible_thr_handle;
-      //wake up the most eligible thread
-      this->run_cond_.broadcast ();
-  //if the current thread is not the most eligible, then wait.
-  //if the current thread is most eligible, but some thread is
-  //scheduled currently, then wait.
-  while (most_eligible_thr_handle != thr_handle ||
-         (most_eligible_thr_handle == thr_handle &&
-          this->curr_scheduled_thr_handle_ != thr_handle &&
-          this->curr_scheduled_thr_handle_ != 0))
-      ACE_Time_Value tv (60,0);
-      tv += ACE_OS::gettimeofday ();
-      //wait a maximum of 1 min. This is an escape latch against lockups.
-                  "(%t|%T): About to block on cv\n"));
-#endif
-      if (this->run_cond_.wait (&tv) == -1)
-                      "(%t|%T): run_cond.wait timed out -- Possible Lockup\n"));
-      most_eligible_thr_handle = item_var->thread_handle ();
-  this->curr_scheduled_guid_ = item_var->guid ();
-                  "(%t|%T): %d is currently running\n",
-                  thr_handle));
-#endif
-                           this->active_prio_,
-                  ACE_TEXT ("thr_setprio failed")));
-              "(%t|%T):schedule_i exit\n"));
-#endif
-  return 0;
-update_schedule_i (Guid_t guid, const DSRT_QoSDescriptor& qos)
-  return this->schedule_i (guid, qos);
-update_schedule_i (Guid_t guid, Block_Flag_t flag)
-  ACE_DEBUG ((LM_DEBUG, "(%t): update schedule for block entered\n"));
-#endif
-  DSRT_Dispatch_Item_var<DSRT_Scheduler_Traits> dispatch_item;
-  int found = this->ready_queue_.find (guid, dispatch_item);
-  if (found == 0)
-      ACE_DEBUG ((LM_DEBUG, "(%t|%T): %d found in ready queue\n", thr_handle));
-  else
-      ACE_DEBUG ((LM_DEBUG, "(%t|%T): %d not found in ready queue\n",
-                  thr_handle));
-#endif
-  if (found == 0 && flag == BLOCK)
-      thr_handle = dispatch_item->thread_handle ();
-      ACE_DEBUG ((LM_DEBUG, "(%t|%T): update schedule: %d found\n", thr_handle));
-#endif
-      int rc = this->cancel_schedule (guid);
-      ACE_DEBUG ((LM_DEBUG, "(%t): update schedule for block done\n"));
-#endif
-      return rc;
-#endif
-  return -1;
-cancel_schedule_i (Guid_t guid)
-  ACE_DEBUG ((LM_DEBUG, "(%t|%T): about to remove guid\n"));
-#endif
-  this->ready_queue_.remove (guid);
-#endif
-  if (this->curr_scheduled_thr_handle_ == thr_handle)
-      this->curr_scheduled_guid_ = 0;
-      this->curr_scheduled_thr_handle_ = 0;
-  ACE_GUARD_RETURN (cond_lock_t,
-                    mon, this->run_cond_lock_, 0);
-  return 0;
-shutdown_i ()
-  this->shutdown_flagged_ = 1;
-  return 0;
-#endif /* DSRT_CV_DISPATCHER_IMPL_T_CPP */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_CV_Dispatcher_Impl_T.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_CV_Dispatcher_Impl_T.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_CV_Dispatcher_Impl_T.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,86 +0,0 @@
-/* -*- C++ -*- */
- *  @file  DSRT_CV_Dispatcher_Impl_T.h
- *  DSRT_CV_Dispatcher_Impl_T.h,v 1.2 2003/10/13 08:36:22 jwillemsen Exp
- *  @author Venkita Subramonian (venkita at cs.wustl.edu)
-#ifndef DSRT_CV_DISPATCHER_IMPL_T_H
-#define DSRT_CV_DISPATCHER_IMPL_T_H
-#include /**/ "ace/pre.h"
-#include "ace/Task.h"
-#include "ace/Copy_Disabled.h"
-#if !defined (ACE_LACKS_PRAGMA_ONCE)
-# pragma once
-#endif /* ACE_LACKS_PRAGMA_ONCE */
-#include "Kokyu_dsrt.h"
-#include "DSRT_Sched_Queue_T.h"
-#include "DSRT_Dispatcher_Impl_T.h"
-namespace Kokyu
-  template<class DSRT_Scheduler_Traits>
-  class DSRT_CV_Dispatcher_Impl :
-    public DSRT_Dispatcher_Impl<DSRT_Scheduler_Traits>,
-    public ACE_Copy_Disabled
-  public:
-    typedef typename
-    DSRT_Scheduler_Traits::Guid_t Guid_t;
-    typedef typename
-    DSRT_Scheduler_Traits::QoSDescriptor_t DSRT_QoSDescriptor;
-    DSRT_CV_Dispatcher_Impl (ACE_Sched_Params::Policy sched_policy,
-                             int sched_scope);
-    int init_i (const DSRT_ConfigInfo&);
-    /// Schedule a thread dynamically based on the qos info supplied.
-    int schedule_i (Guid_t, const DSRT_QoSDescriptor&);
-    /// Update the schedule for a thread. This could alter the current
-    /// schedule.
-    int update_schedule_i (Guid_t, const DSRT_QoSDescriptor&);
-    /// Inform the scheduler that the caller thread is about to
-    /// block. This could alter the current schedule.
-    int update_schedule_i (Guid_t, Block_Flag_t);
-    /// Cancel the schedule for a thread. This could alter the current
-    /// schedule.
-    int cancel_schedule_i (Guid_t);
-    /// Shut down the dispatcher. The dispatcher will stop processing
-    /// requests.
-    int shutdown_i ();
-  private:
-    typedef ACE_SYNCH_MUTEX cond_lock_t;
-    typedef ACE_SYNCH_CONDITION cond_t;
-    cond_lock_t run_cond_lock_;
-    cond_t run_cond_;
-#if defined (ACE_TEMPLATES_REQUIRE_SOURCE)
-#include "DSRT_CV_Dispatcher_Impl_T.cpp"
-#endif /* ACE_TEMPLATES_REQUIRE_SOURCE */
-#if defined (ACE_TEMPLATES_REQUIRE_PRAGMA)
-#pragma implementation ("DSRT_CV_Dispatcher_Impl_T.cpp")
-#endif /* ACE_TEMPLATES_REQUIRE_PRAGMA */
-#include /**/ "ace/post.h"
-#endif /* DSRT_DIRECT_DISPATCHER_IMPL_T_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Direct_Dispatcher_Impl_T.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Direct_Dispatcher_Impl_T.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Direct_Dispatcher_Impl_T.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,362 +0,0 @@
-// DSRT_Direct_Dispatcher_Impl_T.cpp,v 1.5 2003/10/14 08:53:07 venkita Exp
-#ifndef DSRT_DIRECT_DISPATCHER_IMPL_T_CPP
-#define DSRT_DIRECT_DISPATCHER_IMPL_T_CPP
-#include "DSRT_Direct_Dispatcher_Impl_T.h"
-//#include "DSRT_Direct_Dispatcher_Impl_T.i"
-ACE_RCSID(Kokyu, DSRT_Direct_Dispatcher_Impl_T, "DSRT_Direct_Dispatcher_Impl_T.cpp,v 1.5 2003/10/14 08:53:07 venkita Exp")
-namespace Kokyu
-  //more eligible
-  if (rc == 1)
-    return 1;
-  //the item
-    return 1;
-  return 0;
-DSRT_Direct_Dispatcher_Impl<DSRT_Scheduler_Traits>::
-DSRT_Direct_Dispatcher_Impl (ACE_Sched_Params::Policy sched_policy,
-                         int sched_scope)
-  :DSRT_Dispatcher_Impl<DSRT_Scheduler_Traits>(sched_policy, sched_scope),
-   sched_queue_modified_ (0),
-   sched_queue_modified_cond_ (sched_queue_modified_cond_lock_)
-  //Run scheduler thread at highest priority
-  if (this->activate (this->rt_thr_flags_, 1, 0, this->executive_prio_) == -1)
-                  "(%t|%T) cannot activate scheduler thread in RT mode."
-                  "Trying in non RT mode\n"));
-      if (this->activate (this->non_rt_thr_flags_) == -1)
-                    "(%t|%T) cannot activate scheduler thread\n"));
-  return 0;
-DSRT_Direct_Dispatcher_Impl<DSRT_Scheduler_Traits>::svc (void)
-  ACE_hthread_t scheduler_thr_handle;
-  ACE_Thread::self (scheduler_thr_handle);
-  int prio;
-              ACE_TEXT ("max prio=%d\n")
-              ACE_TEXT ("min prio=%d\n")
-              ACE_TEXT ("active prio=%d\n")
-              ACE_TEXT ("inactive prio=%d\n"),
-              max_prio_,
-              min_prio_,
-              active_prio_,
-              inactive_prio_));
-  if (ACE_OS::thr_getprio (scheduler_thr_handle, prio) == -1)
-      if (errno == ENOTSUP)
-          ACE_ERROR((LM_ERROR,
-                     ACE_TEXT ("getprio not supported\n")
-      else
-                      ACE_TEXT ("%p\n")
-                      ACE_TEXT ("thr_getprio failed")));
-  ACE_DEBUG ((LM_DEBUG, "(%t): Scheduler thread prio is %d\n", prio));
-#endif /*DSRT_LOGGING*/
-  while(1)
-                        mon, sched_queue_modified_cond_lock_, 0);
-      if (this->shutdown_flagged_)
-        break;
-      while (!sched_queue_modified_)
-                      "(%t): sched thread about to wait on cv\n"));
-#endif
-          sched_queue_modified_cond_.wait ();
-      ACE_DEBUG ((LM_DEBUG, "(%t): sched thread done waiting on cv\n"));
-#endif
-      sched_queue_modified_ = 0;
-      ACE_Guard<ACE_SYNCH_RECURSIVE_MUTEX> synch_lock_mon(this->synch_lock_);
-      if (this->ready_queue_.current_size () <= 0)
-        continue;
-      ACE_DEBUG ((LM_DEBUG, "(%t|%T):Sched Queue contents===>\n"));
-#endif
-#endif
-      if (this->curr_scheduled_thr_handle_ != most_eligible_thr_handle)
-          if (this->curr_scheduled_thr_handle_ != 0)
-              if (ACE_OS::thr_setprio (this->curr_scheduled_thr_handle_,
-                                       this->inactive_prio_,
-                              ACE_TEXT ("thr_setprio on curr_scheduled_thr_handle_ failed.")));
-                  ACE_DEBUG ((LM_DEBUG, "thr_handle = %d, prio = %d\n",
-                              this->curr_scheduled_thr_handle_,
-                              this->inactive_prio_));
-          if (ACE_OS::thr_setprio (most_eligible_thr_handle,
-                                   this->active_prio_, this->sched_policy_) == -1)
-                          ACE_TEXT ("thr_setprio on most_eligible_thr_handle failed")));
-  ACE_DEBUG ((LM_DEBUG, "(%t): sched thread exiting\n"));
-#endif
-  return 0;
-int DSRT_Direct_Dispatcher_Impl<DSRT_Scheduler_Traits>::
-#endif
-                  -1);
-    return -1;
-#endif
-              "(%t|%T):schedule_i after thr_setprio\n"));
-#endif
-  //ready_queue_.dump ();
-  //@@ Perhaps the lock could be moved further down just before
-  //setting the condition variable?
-                    mon, this->sched_queue_modified_cond_lock_, 0);
-              "(%t|%T):schedule_i after acquiring cond lock\n"));
-#endif
-  this->sched_queue_modified_ = 1;
-  this->sched_queue_modified_cond_.signal ();
-#endif
-  return 0;
-  return this->schedule (guid, qos);
-#endif
-  //@@ Perhaps the lock could be got rid of. It looks like the state
-  //of this object is not getting modified here. It makes calls to
-  //other methods, which already are thread-safe.
-  //ACE_Guard<cond_lock_t> mon(sched_queue_modified_cond_lock_);
-      //monitor released because cancel_schedule would acquire the
-      //lock. Using recursive mutex creates lock up.
-      //@@ Need to investigate this further. Also we can consider
-      //using the Thread-Safe interface pattern.
-      //mon.release ();
-#endif
-      return rc;
-#endif
-  return -1;
-  ACE_DEBUG ((LM_DEBUG, "(%t): about to remove guid\n"));
-#endif
-#endif
-  if (this->curr_scheduled_guid_ == guid)
-  return 0;
-shutdown_i ()
-  ACE_Guard<cond_lock_t> mon(this->sched_queue_modified_cond_lock_);
-  // We have to wait until the scheduler executive thread shuts
-  // down. But we have acquired the lock and if we wait without
-  // releasing it, the scheduler thread will try to acquire it after
-  // it gets woken up by the above signal and it fails to acquire the
-  // lock. This will lead to a deadlock. So release the lock before we
-  // wait.
-  mon.release ();
-  this->wait ();
-  return 0;
-#endif /* DSRT_DIRECT_DISPATCHER_IMPL_T_CPP */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Direct_Dispatcher_Impl_T.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Direct_Dispatcher_Impl_T.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Direct_Dispatcher_Impl_T.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,92 +0,0 @@
-/* -*- C++ -*- */
- *  @file  DSRT_Direct_Dispatcher_Impl_T.h
- *  DSRT_Direct_Dispatcher_Impl_T.h,v 1.5 2003/10/08 02:23:39 venkita Exp
-#ifndef DSRT_DIRECT_DISPATCHER_IMPL_T_H
-#define DSRT_DIRECT_DISPATCHER_IMPL_T_H
-# pragma once
-namespace Kokyu
-  class DSRT_Direct_Dispatcher_Impl :
-    public ACE_Task_Base,
-  public:
-    typedef typename
-    typedef typename
-    DSRT_Direct_Dispatcher_Impl (ACE_Sched_Params::Policy sched_policy,
-                                 int sched_scope);
-    /// schedule.
-    /// schedule.
-    /// requests.
-  private:
-    u_int sched_queue_modified_;
-    cond_lock_t sched_queue_modified_cond_lock_;
-    cond_t sched_queue_modified_cond_;
-  private:
-    int svc (void);
-#include "DSRT_Direct_Dispatcher_Impl_T.cpp"
-#pragma implementation ("DSRT_Direct_Dispatcher_Impl_T.cpp")
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatch_Item_T.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatch_Item_T.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatch_Item_T.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,35 +0,0 @@
-// DSRT_Dispatch_Item_T.cpp,v 1.1 2003/07/25 23:41:55 venkita Exp
-#ifndef DSRT_DISPATCH_ITEM_T_CPP
-#define DSRT_DISPATCH_ITEM_T_CPP
-#include "DSRT_Dispatch_Item_T.h"
-#if ! defined (__ACE_INLINE__)
-#include "DSRT_Dispatch_Item_T.i"
-ACE_RCSID(Kokyu, DSRT_Dispatch_Item, "DSRT_Dispatch_Item_T.cpp,v 1.1 2003/07/25 23:41:55 venkita Exp")
-namespace Kokyu
-DSRT_Dispatch_Item_var<DSRT_Scheduler_Traits>::
-DSRT_Dispatch_Item_var (DSRT_Dispatch_Item<DSRT_Scheduler_Traits> *p)
-  :ACE_Strong_Bound_Ptr<DSRT_Dispatch_Item<DSRT_Scheduler_Traits>,
-                        ACE_SYNCH_MUTEX> (p)
-DSRT_Dispatch_Item_var (const DSRT_Dispatch_Item_var &r)
-                        ACE_SYNCH_MUTEX> (r)
-#endif /* DSRT_DISPATCH_ITEM_T_CPP */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatch_Item_T.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatch_Item_T.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatch_Item_T.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,103 +0,0 @@
-/* -*- C++ -*- */
- *  @file  DSRT_Dispatch_Item_T.h
- *  DSRT_Dispatch_Item_T.h,v 1.4 2003/10/08 02:23:39 venkita Exp
-#ifndef DSRT_DISPATCH_ITEM_H
-#define DSRT_DISPATCH_ITEM_H
-#include "ace/Bound_Ptr.h"
-# pragma once
-namespace Kokyu
-   * @class DSRT_Dispatch_Item
-   * @brief This stores information about a schedulable thread.
-  template <class DSRT_Scheduler_Traits>
-  class DSRT_Dispatch_Item : private ACE_Copy_Disabled
-    typedef typename
-    typedef typename
-  protected:
-    ACE_hthread_t thr_handle_;
-    Guid_t guid_;
-    DSRT_QoSDescriptor qos_;
-    ACE_Time_Value insertion_time_;
-  public:
-    DSRT_Dispatch_Item (Guid_t guid, const DSRT_QoSDescriptor&);
-    /// Get the guid.
-    Guid_t guid ();
-    /// Get the associated qos value.
-    DSRT_QoSDescriptor qos ();
-    /// Get the thread handle.
-    ACE_hthread_t thread_handle ();
-    /// Set the thread handle.
-    void thread_handle (ACE_hthread_t &handle);
-    /// Get the insertion time.
-    ACE_Time_Value insertion_time ();
-    /// Set the insertion time.
-    void insertion_time (const ACE_Time_Value&);
-   * @class DSRT_Dispatch_Item_var
-   * @brief Smart pointer to dynamically allocated <code>
-   * DSRT_Dispatch_Item </code> objects.
-  class DSRT_Dispatch_Item_var :
-    public ACE_Strong_Bound_Ptr<
-                              DSRT_Dispatch_Item<DSRT_Scheduler_Traits>,
-                              ACE_SYNCH_MUTEX>
-  public:
-    ACE_EXPLICIT
-    DSRT_Dispatch_Item_var (DSRT_Dispatch_Item<DSRT_Scheduler_Traits>
-                            *p = 0);
-         const DSRT_Dispatch_Item_var<DSRT_Scheduler_Traits> &r);
-#if defined (__ACE_INLINE__)
-#include "DSRT_Dispatch_Item_T.cpp"
-#pragma implementation ("DSRT_Dispatch_Item_T.cpp")
-#endif /* DSRT_DISPATCH_ITEM_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatch_Item_T.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatch_Item_T.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatch_Item_T.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,70 +0,0 @@
-/* -*- C++ -*- */
- *  @file  DSRT_Dispatch_Item_T.i
- *  DSRT_Dispatch_Item_T.i,v 1.2 2003/09/30 15:41:48 bala Exp
-namespace Kokyu
-ACE_INLINE
-DSRT_Dispatch_Item<DSRT_Scheduler_Traits>::
-DSRT_Dispatch_Item (Guid_t guid, const DSRT_QoSDescriptor& qos)
-  :guid_ (guid), qos_ (qos)
-ACE_INLINE typename DSRT_Dispatch_Item<DSRT_Scheduler_Traits>::Guid_t
-guid ()
-  return guid_;
-ACE_INLINE typename DSRT_Dispatch_Item<DSRT_Scheduler_Traits>::DSRT_QoSDescriptor
-qos ()
-  return qos_;
-ACE_INLINE ACE_hthread_t
-thread_handle ()
-  return thr_handle_;
-ACE_INLINE void
-thread_handle (ACE_hthread_t &handle)
-  thr_handle_ = handle;
-ACE_INLINE void
-insertion_time (const ACE_Time_Value& tv)
-  this->insertion_time_ = tv;
-ACE_INLINE ACE_Time_Value
-insertion_time ()
-  return this->insertion_time_;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatcher_Impl_T.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatcher_Impl_T.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatcher_Impl_T.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,56 +0,0 @@
-// DSRT_Dispatcher_Impl_T.cpp,v 1.2 2003/10/08 02:23:39 venkita Exp
-#ifndef DSRT_DISPATCHER_IMPL_T_CPP
-#define DSRT_DISPATCHER_IMPL_T_CPP
-#include "DSRT_Dispatcher_Impl_T.i"
-ACE_RCSID(Kokyu, DSRT_Dispatcher_Impl, "DSRT_Dispatcher_Impl_T.cpp,v 1.2 2003/10/08 02:23:39 venkita Exp")
-namespace Kokyu
-DSRT_Dispatcher_Impl<DSRT_Scheduler_Traits>::
-DSRT_Dispatcher_Impl (ACE_Sched_Params::Policy sched_policy,
-                          int sched_scope)
-  : sched_policy_ (sched_policy),
-    sched_scope_ (sched_scope),
-    min_prio_ (ACE_Sched_Params::priority_min
-               (sched_policy_,
-                sched_scope)),
-    max_prio_ (ACE_Sched_Params::priority_max
-               (sched_policy_,
-                sched_scope)),
-    executive_prio_ (max_prio_),
-    blocked_prio_ (ACE_Sched_Params::previous_priority
-                   (sched_policy_,
-                    max_prio_,
-                    sched_scope)),
-    inactive_prio_ (min_prio_),
-    active_prio_ (ACE_Sched_Params::next_priority
-                  (sched_policy_,
-                   min_prio_)),
-    shutdown_flagged_ (0),
-    non_rt_thr_flags_ (THR_NEW_LWP | THR_JOINABLE | THR_BOUND),
-    curr_scheduled_thr_handle_ (0)
-  if (sched_policy_ == ACE_SCHED_FIFO)
-    rt_thr_flags_ = non_rt_thr_flags_ | THR_SCHED_FIFO;
-  else if (sched_policy_ == ACE_SCHED_RR)
-    rt_thr_flags_ = non_rt_thr_flags_ | THR_SCHED_RR;
-//virtual - so don't inline
-DSRT_Dispatcher_Impl<DSRT_Scheduler_Traits>::~DSRT_Dispatcher_Impl ()
-#endif /* DSRT_DISPATCHER_IMPL_T_CPP */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatcher_Impl_T.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatcher_Impl_T.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatcher_Impl_T.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,202 +0,0 @@
-/* -*- C++ -*- */
- *  @file   DSRT_Dispatcher_Impl_T.h
- *  DSRT_Dispatcher_Impl_T.h,v 1.3 2003/10/08 02:23:39 venkita Exp
-#ifndef DSRT_DISPATCHER_IMPL_H
-#define DSRT_DISPATCHER_IMPL_H
-# pragma once
-namespace Kokyu
-   * @class Comparator_Adapter_Generator
-   * @brief Generates function object adapter that adapts the
-   * QoSComparator function object to compare between two schedulable
-   * items instead of QoSDescriptors.
-   * The QoSComparator function object that gets passed through the
-   * <code> DSRT_Scheduler_Traits </code> takes two qos values and
-   * determines the more eligible one. Since the INT_ID (key) for
-   * RB_Tree needs to be of type <code> DSRT_Dispatch_Item_var
-   * </code>, the QoSComparator needs to be adapted using an adapter
-   * to compare two schedulable items. This adapter compares the two
-   * using their qos values. Ties are resolved by giving preference to
-   * items which arrived earlier. Note that this class serves the
-   * purpose of a generator class, since it generates the adapter
-   * class for a given qos comparator function object.
-  class Comparator_Adapter_Generator
-  public:
-    typedef typename
-    DSRT_Scheduler_Traits::QoSComparator_t QoSComparator_t;
-     * @class More_Eligible
-     * @brief Actual function object that gets generated.
-    class MoreEligible
-    public:
-       * Function call operator to do comparison between two
-       * schedulable items. Returns 1 if item1 is more eligible than
-       * item2, otherwise 0.
-      int operator ()
-        (const DSRT_Dispatch_Item_var<DSRT_Scheduler_Traits>& item1,
-                    "(%t|%T): MoreEligible:: qos_comparator returned %d\n",
-                    rc));
-#endif
-        //more eligible
-        if (rc == 1)
-          return rc;
-        //the item
-          return 1;
-        return 0;
-    private:
-      QoSComparator_t qos_comparator_;
-     * Facilitates return of the generated function object adapter.
-    typedef MoreEligible RET;
-   * @class DSRT_Dispatcher
-   * @brief Base class for DSRT dispatcher implementations
-   * The responsibility of this class is to act as a common base class
-   * for different DSRT dispatcher implementations. This is an
-   * abstract base class and cannot be instantiated.
-  class DSRT_Dispatcher_Impl
-  public:
-    typedef typename DSRT_Scheduler_Traits::Guid_t Guid_t;
-    typedef typename DSRT_Scheduler_Traits::QoSDescriptor_t DSRT_QoSDescriptor;
-    DSRT_Dispatcher_Impl (ACE_Sched_Params::Policy sched_policy,
-                          int sched_scope);
-    /// Configure the DSRT dispatcher.
-    int init (const DSRT_ConfigInfo&);
-    int schedule (Guid_t guid,
-                  const DSRT_QoSDescriptor&);
-    /// schedule.
-    int update_schedule (Guid_t guid,
-    int update_schedule (Guid_t guid, Block_Flag_t flag);
-    /// schedule.
-    int cancel_schedule (Guid_t guid);
-    /// requests.
-    int shutdown ();
-    virtual ~DSRT_Dispatcher_Impl ();
-  private:
-    //following an idiom to avoid public virtual functions.
-    //instead make them private and use the template method
-    //pattern - "Virtually Yours" article in CUJ Experts Forum
-    virtual int init_i (const DSRT_ConfigInfo&)=0;
-    virtual int schedule_i (Guid_t guid,
-                    const DSRT_QoSDescriptor&)=0;
-    virtual int update_schedule_i (Guid_t guid,
-    virtual int update_schedule_i (Guid_t guid, Block_Flag_t flag)=0;
-    virtual int cancel_schedule_i (Guid_t guid)=0;
-    virtual int shutdown_i ()=0;
-  protected:
-    /// Generate the QoSComparator adapter.
-    typedef typename
-    Comparator_Adapter_Generator<DSRT_Scheduler_Traits>::RET
-    Queue_Item_Comparator_t;
-    typedef Sched_Ready_Queue<DSRT_Scheduler_Traits,
-                              Queue_Item_Comparator_t,
-                              ACE_SYNCH_NULL_MUTEX>
-    DSRT_Sched_Queue_t;
-    ACE_Sched_Params::Policy sched_policy_;
-    int sched_scope_;
-    Priority_t min_prio_;
-    Priority_t max_prio_;
-    Priority_t executive_prio_;
-    Priority_t blocked_prio_;
-    Priority_t inactive_prio_;
-    Priority_t active_prio_;
-    DSRT_Sched_Queue_t ready_queue_;
-    int shutdown_flagged_;
-    long non_rt_thr_flags_;
-    long rt_thr_flags_;
-    ACE_SYNCH_RECURSIVE_MUTEX synch_lock_;
-    ACE_hthread_t curr_scheduled_thr_handle_;
-    Guid_t curr_scheduled_guid_;
-} //end of namespace
-#include "DSRT_Dispatcher_Impl_T.cpp"
-#pragma implementation ("DSRT_Dispatcher_Impl_T.cpp")
-#endif /* DSRT_DISPATCHER_IMPL_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatcher_Impl_T.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatcher_Impl_T.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Dispatcher_Impl_T.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,57 +0,0 @@
-// DSRT_Dispatcher_Impl_T.i,v 1.1 2003/07/25 23:41:55 venkita Exp
-namespace Kokyu
-ACE_INLINE int
-init (const DSRT_ConfigInfo& config_info)
-  return this->init_i (config_info);
-ACE_INLINE int
-schedule (Guid_t guid,
-          const DSRT_QoSDescriptor& qos)
-ACE_INLINE int
-update_schedule (Guid_t guid,
-  return this->update_schedule_i (guid, qos);
-ACE_INLINE int
-                 Block_Flag_t flag)
-  return this->update_schedule_i (guid, flag);
-ACE_INLINE int
-cancel_schedule (Guid_t guid)
-  return this->cancel_schedule_i (guid);
-ACE_INLINE int
-DSRT_Dispatcher_Impl<DSRT_Scheduler_Traits>::shutdown ()
-  return this->shutdown_i ();
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Sched_Queue_T.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Sched_Queue_T.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Sched_Queue_T.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,255 +0,0 @@
-/* -*- C++ -*- */
- *  @file  DSRT_Sched_Queue_T.cpp
- *  DSRT_Sched_Queue_T.cpp,v 1.3 2003/10/08 02:23:39 venkita Exp
-#ifndef DSRT_SCHED_QUEUE_T_CPP
-#define DSRT_SCHED_QUEUE_T_CPP
-# pragma once
-//#include "DSRT_Sched_Queue_T.i"
-ACE_RCSID(Kokyu,
-          DSRT_Sched_Queue_T,
-          "DSRT_Sched_Queue_T.cpp,v 1.3 2003/10/08 02:23:39 venkita Exp")
-namespace Kokyu
-template <class DSRT_Scheduler_Traits,
-          class More_Eligible_Comparator,
-          class ACE_LOCK>
-u_long
-Sched_Ready_Queue<DSRT_Scheduler_Traits,
-                  More_Eligible_Comparator,
-                  ACE_LOCK>::
-Guid_Hash::operator () (const Guid_t& id)
-  typename DSRT_Scheduler_Traits::Guid_Hash guid_hash;
-  return guid_hash(id);
-          class ACE_LOCK>
-int Sched_Ready_Queue<DSRT_Scheduler_Traits,
-                      ACE_LOCK>::
-current_size ()
-  return dispatch_items_prio_queue_.current_size ();
-          class ACE_LOCK>
-                      ACE_LOCK>::
-most_eligible (DSRT_Dispatch_Item_var<DSRT_Scheduler_Traits>& item)
-  if (dispatch_items_prio_queue_.current_size () == 0)
-      return -1;
-  PRIO_QUEUE_ITERATOR start = dispatch_items_prio_queue_.begin ();
-  PRIO_QUEUE_ENTRY &ent = (*start);
-  item = ent.item ();
-  return 0;
-          class ACE_LOCK>
-                      ACE_LOCK>::
-find (Guid_t guid,
-      DSRT_Dispatch_Item_var<DSRT_Scheduler_Traits>& found_item)
-  ACE_GUARD_RETURN (ACE_LOCK, mon, lock_, -1);
-  RB_Tree_Dispatch_Item_Node* rb_tree_node;
-  if (dispatch_items_hash_map_.find(guid, rb_tree_node) == -1)
-      return -1;
-  else
-      found_item = rb_tree_node->item ();
-      return 0;
-  return 0;
-          class ACE_LOCK>
-                      ACE_LOCK>::
-insert (DSRT_Dispatch_Item<DSRT_Scheduler_Traits>* item)
-  item->insertion_time (ACE_OS::gettimeofday ());
-  DSRT_Dispatch_Item_var<DSRT_Scheduler_Traits> item_var(item);
-  Guid_t guid = item->guid ();
-  ACE_hthread_t thr_handle = item->thread_handle ();
-              "(%t|%T) about to insert %d in sched queue\n",
-              thr_handle));
-#endif
-  if (dispatch_items_hash_map_.find (guid, rb_tree_node) == -1)
-                  "(%t|%T) %d not found in hashmap\n", thr_handle));
-#endif
-      if (dispatch_items_prio_queue_.bind (item_var,
-                                           item_var,
-                                           rb_tree_node) == 0)
-          ACE_DEBUG ((LM_DEBUG, "(%t|%T): item bound in rbtree\n"));
-#endif
-          if (dispatch_items_hash_map_.bind (guid, rb_tree_node) == 0)
-              ACE_DEBUG ((LM_DEBUG, "(%t|%T): item bound in hashmap\n"));
-                          "<===Hash Table contents Begin===>\n"));
-              dispatch_items_hash_map_.dump ();
-                          "<===Hash Table contents End=====>\n"));
-#endif
-              return 0;
-  else
-                  "(%t|%T) %d found in hashmap\n", thr_handle));
-#endif
-      dispatch_items_hash_map_.unbind (guid);
-      dispatch_items_prio_queue_.unbind (rb_tree_node);
-                  "(%t|%T) %d removed from hashmap and rbtree\n", thr_handle));
-#endif
-                                           item_var,
-                      "(%t|%T) %d bound to rbtree\n", thr_handle));
-#endif
-                          "(%t|%T) %d bound to hashmap\n", thr_handle));
-                          "<===Hash Table contents End===>\n"));
-#endif
-              return 0;
-  return -1;
-          class More_Eligible_Comparator, class ACE_LOCK>
-                      More_Eligible_Comparator, ACE_LOCK>::
-remove (Guid_t guid)
-  if (dispatch_items_hash_map_.find(guid, rb_tree_node) == 0)
-#endif
-      return 0;
-  return -1;
-          class ACE_LOCK>
-void Sched_Ready_Queue<DSRT_Scheduler_Traits,
-                       ACE_LOCK>::
-dump ()
-  ACE_GUARD (ACE_LOCK, mon, lock_);
-  ACE_DEBUG ((LM_DEBUG, "(%t|%T):##########################\n"));
-  if (dispatch_items_prio_queue_.current_size ())
-      PRIO_QUEUE_ITERATOR end_iter = dispatch_items_prio_queue_.end ();
-      PRIO_QUEUE_ITERATOR iter;
-      iter = dispatch_items_prio_queue_.begin ();
-      while( iter != end_iter )
-          PRIO_QUEUE_ENTRY &ent = (*iter);
-            item_var = ent.item ();
-          int guid;
-          ACE_OS::memcpy (&guid,
-                  item_var->guid ().get_buffer (),
-                  item_var->guid ().length ());
-          ACE_DEBUG ((LM_DEBUG, "(%t|%T):guid %d, thr_handle = %d\n",
-                      guid, item_var->thread_handle ()));
-          ++iter;
-#endif /* DSRT_SCHED_QUEUE_T_CPP */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Sched_Queue_T.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Sched_Queue_T.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/DSRT_Sched_Queue_T.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,224 +0,0 @@
-/* -*- C++ -*- */
- *  @file  DSRT_Sched_Queue_T.h
- *  DSRT_Sched_Queue_T.h,v 1.5 2003/10/08 02:23:39 venkita Exp
-#ifndef DSRT_SCHED_QUEUE_T_H
-#define DSRT_SCHED_QUEUE_T_H
-#include "ace/RB_Tree.h"
-#include "ace/Hash_Map_Manager_T.h"
-# pragma once
-namespace Kokyu
-   * @class Sched_Ready_Queue
-   * @brief RB_Tree based template class for implementation of
-   * reordering queue.
-   * This queue is used as a priority queue to store schedulable
-   * entities. The item at the top of the RB_Tree is the most eligible
-   * item. The comparator used to determine the most eligible item is
-   * passed as a template parameter <code> More_Eligible_Comparator
-   * </code>. This is expected to be a functor which compares two
-   * schedulable items. The mutex type template parameter for RB_Tree
-   * is chosen to be a null mutex since all the methods in the
-   * enclosing <code> Sched_Ready_Queue </code> class are thread
-   * safe. Since QoS is used for comparison between two schedulable
-   * items, QoSDescriptor is the ideal candidate to be used as the key
-   * or the EXT_ID for RB_Tree instantiation. But two qos descriptors
-   * could be the same. The existing implementation of RB_Tree does
-   * not allow duplicate keys. In order to facilitate insertion of
-   * duplicate qos descriptors, the qos descriptors are contained in a
-   * <code> DSRT_Dispatch_Item </code> and this is used as the basis
-   * of comparison. To resolve tie between equal qos values, an
-   * insertion time stamp is maintained in each item and an item with
-   * an earlier time stamp is more eligible than an item with an
-   * identical qos value. Another requirement is that it should be
-   * possible to remove an item from the RB_Tree based on guid. Since
-   * we have already used up the qos descriptor for the key, we need a
-   * separate index into the list of schedulable items. The second
-   * index should be based on guid. This is achieved by using a hash
-   * map to store <guid, RB_Tree_Node*> pairs. This makes the deletion
-   * of nodes from RB_Tree more efficient.
-  template <class DSRT_Scheduler_Traits,
-            class ACE_LOCK>
-  class Sched_Ready_Queue
-    /// Extract the necessary types from the traits class
-    typedef typename
-    DSRT_Scheduler_Traits::QoSDescriptor_t DSRT_QoSDescriptor_t;
-  public:
-     * Given a guid, find an item in the priority queue.
-     * @param guid Guid of item
-     * @param found_item Reference to DSRT_Dispatch_Item_var
-     *                   to hold the found item.
-     * @return  -1 if no item found and 0 otherwise.
-    int find(Guid_t guid,
-             found_item);
-     * Insert an item in the priority queue. If item with same guid is
-     * already in the queue, the existing one is deleted and the new
-     * one inserted. A deletion and insertion has to happen instead of
-     * update since the rebalancing of the RB_Tree should take place.
-     * @param item <code> DSRT_Dispatch_Item </code> object containing guid and qos.
-     * @return -1 if insertion failed and 0 otherwise.
-    int insert(DSRT_Dispatch_Item<DSRT_Scheduler_Traits>* item);
-     * Remove an item from the priority queue.
-     * @param guid Guid of item.
-     * @param qos QoS associated with item.
-     * @return -1 if removal failed and 0 otherwise.
-    int remove(Guid_t guid);
-     * Returns current size of the priority queue.
-    int current_size ();
-     * Get the most eligible item from the priority queue.
-     * @param item Item which is most eligible, i.e. one at the
-     *             "top" of the priority queue.
-     * @return -1 if there are no items in the priority queue.
-    int most_eligible (DSRT_Dispatch_Item_var<DSRT_Scheduler_Traits>&
-                       item);
-    void dump();
-  private:
-     * @class Guid_Hash
-     * @brief Internal class to generate hash for guid.
-     * This acts just as a wrapper functor to the Hash functor passed
-     * as part of the traits class <code> DSRT_Scheduler_Traits
-     * </code>.
-    class Guid_Hash
-    public:
-      /// Returns hash value.
-      u_long operator () (const typename DSRT_Scheduler_Traits::Guid_t &id)
-    // RB_Tree related typedefs
-    typedef ACE_RB_Tree <DSRT_Dispatch_Item_var<DSRT_Scheduler_Traits>,
-                         DSRT_Dispatch_Item_var<DSRT_Scheduler_Traits>,
-                         ACE_SYNCH_NULL_MUTEX> Dispatch_Items_Priority_Queue;
-    typedef
-    ACE_RB_Tree_Node<DSRT_Dispatch_Item_var<DSRT_Scheduler_Traits>,
-                     DSRT_Dispatch_Item_var<DSRT_Scheduler_Traits> >
-    RB_Tree_Dispatch_Item_Node;
-    typedef typename
-    Dispatch_Items_Priority_Queue::ITERATOR PRIO_QUEUE_ITERATOR;
-    typedef typename
-    Dispatch_Items_Priority_Queue::ENTRY PRIO_QUEUE_ENTRY;
-    // Hash map related typedefs
-    typedef ACE_Hash_Map_Manager_Ex<Guid_t,
-                                    RB_Tree_Dispatch_Item_Node*,
-                                    Guid_Hash,
-                                    ACE_Equal_To<Guid_t>,
-    Dispatch_Items_Hash_Map;
-    typedef ACE_Hash_Map_Iterator_Ex<Guid_t,
-                                     Guid_Hash,
-    Dispatch_Items_Hash_Map_Iterator;
-    typedef ACE_Hash_Map_Entry <Guid_t,
-                                RB_Tree_Dispatch_Item_Node*>
-    Dispatch_Items_Hash_Map_Entry;
-     * Lock used to protect the state of the scheduler queue. A
-     * separate lock is not used for the internal RB_Tree and hashmap.
-    ACE_LOCK lock_;
-     * Hash table to maintain a second index into the list of
-     * schedulable items. This is for efficient removal of items from
-     * the RB_Tree based on guid. The guid is used as the key for the
-     * hash map, whereas the qos value is used as the key for the
-     * RB_Tree.
-    Dispatch_Items_Hash_Map dispatch_items_hash_map_;
-     * RB_Tree implementation of priority queue of schedulable items.
-    Dispatch_Items_Priority_Queue dispatch_items_prio_queue_;
-#include "DSRT_Sched_Queue_T.cpp"
-#pragma implementation ("DSRT_Sched_Queue_T.cpp")
-#endif /* DSRT_SCHED_QUEUE_T_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Default_Dispatcher_Impl.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Default_Dispatcher_Impl.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Default_Dispatcher_Impl.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,170 +0,0 @@
-// Default_Dispatcher_Impl.cpp,v 1.10 2003/10/14 08:53:07 venkita Exp
-#include "Default_Dispatcher_Impl.h"
-#include "ace/Sched_Params.h"
-#include "Default_Dispatcher_Impl.i"
-ACE_RCSID(Kokyu, Default_Dispatcher_Impl, "Default_Dispatcher_Impl.cpp,v 1.10 2003/10/14 08:53:07 venkita Exp")
-namespace Kokyu
-Default_Dispatcher_Impl::Default_Dispatcher_Impl ()
-  : activated_ (0)
-int
-Default_Dispatcher_Impl::init_i (const Dispatcher_Attributes& attrs)
-  //create and init the dispatcher tasks here
-  ACE_DEBUG ((LM_DEBUG, "entering init_t\n" ));
-  int size;
-  size = attrs.config_info_set_.size ();
-  if (size == 0)
-    return -1;
-  this->ntasks_ = size;
-  Dispatcher_Task_Auto_Ptr * tasks_array=0;
-  ACE_NEW_RETURN (tasks_array, Dispatcher_Task_Auto_Ptr[ntasks_], -1);
-  //ACE_DEBUG ((LM_DEBUG, "after new on task array\n" ));
-  tasks_.reset(tasks_array);
-  //ACE_DEBUG ((LM_DEBUG, "task array auto_ptr set\n" ));
-  ConfigInfoSet& config_set =
-    const_cast<ConfigInfoSet&> (attrs.config_info_set_);
-  ConfigInfoSet::ITERATOR iter(config_set);
-  int i=0;
-  ConfigInfo* config;
-  for (;i<size && iter.next (config);iter.advance ())
-      //ACE_DEBUG ((LM_DEBUG, "iter = %d\n", i));
-      Dispatcher_Task* task=0;
-      ACE_NEW_RETURN (task,
-                      Dispatcher_Task (*config,
-                                       ACE_Thread_Manager::instance()),
-                      -1);
-      auto_ptr<Dispatcher_Task> tmp_task_auto_ptr (task);
-      tasks_[i++] = tmp_task_auto_ptr;
-      //I couldn't use reset because MSVC6 auto_ptr does not have reset method.
-      //So in configurations where the auto_ptr maps to the std::auto_ptr instead
-      //of ACE auto_ptr, this would be a problem.
-      //tasks_[i++].reset (task);
-  this->thr_creation_flags_ = attrs.thread_creation_flags ();
-  if (attrs.immediate_activation_ && !this->activated_)
-      this->activate_i ();
-  curr_config_info_ = attrs.config_info_set_;
-  return 0;
-int
-Default_Dispatcher_Impl::activate_i ()
-  int i;
-  if (this->activated_)
-    return 0;
-  for(i=0; i<ntasks_; ++i)
-      Priority_t priority =
-        tasks_[i]->get_curr_config_info ().thread_priority_;
-      if (this->tasks_[i]->activate (this->thr_creation_flags_,
-                                     1, 1, priority) == -1)
-             ACE_TEXT ("EC (%P|%t) cannot activate queue.")
-             ACE_TEXT ("Need superuser privilege to run in RT class\n")),
-             -1);
-  this->activated_ = 1;
-  return 0;
-Dispatcher_Task*
-Default_Dispatcher_Impl::find_task_with_preemption_prio (Priority_t prio)
-  int i;
-  if (prio >=0)
-    for( i=0; i<ntasks_; ++i)
-      if ( tasks_[i]->preemption_priority () == prio)
-        return  tasks_[i].get();
-  return 0;
-int
-Default_Dispatcher_Impl::dispatch_i (const Dispatch_Command* cmd,
-                  const QoSDescriptor& qos_info)
-  //delegate to the appropriate task
-  if (qos_info.preemption_priority_ < 0)
-    return -1;
-  Dispatcher_Task* task =
-    find_task_with_preemption_prio (qos_info.preemption_priority_);
-  //@@VS - We should insert this into the lowest prio queue.
-  //How do we know that the last queue is the lowest prio queue.
-  if (task == 0)
-    task = tasks_[ntasks_-1].get ();
-  return task->enqueue (cmd, qos_info);
-int
-Default_Dispatcher_Impl::shutdown_i ()
-  //This needs to be revisited based on mode transition and
-  //consistent cut through the queues
-  //post shutdown command to all tasks
-  int i;
-      QoSDescriptor qos_info;
-      Shutdown_Task_Command* shutdown_cmd = 0;
-      ACE_NEW_RETURN (shutdown_cmd, Shutdown_Task_Command, -1);
-      tasks_[i]->enqueue (shutdown_cmd, qos_info);
-  //wait for all tasks to exit
-  for (i=0; i<ntasks_; ++i)
-      tasks_[i]->wait ();
-  return 0;
-int
-Shutdown_Task_Command::execute ()
-  return -1;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Default_Dispatcher_Impl.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Default_Dispatcher_Impl.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Default_Dispatcher_Impl.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,77 +0,0 @@
-/* -*- C++ -*- */
- *  @file   Default_Dispatcher_Impl.h
- *  Default_Dispatcher_Impl.h,v 1.6 2003/09/30 15:41:48 bala Exp
- * Based on previous work by Tim Harrison (harrison at cs.wustl.edu),
- * Chris Gill, Carlos O'Ryan and other members of the DOC group.
-#ifndef DEFAULT_DISPATCHER_IMPL_H
-#define DEFAULT_DISPATCHER_IMPL_H
-# pragma once
-#include "ace/Auto_Ptr.h"
-#include "kokyu_export.h"
-#include "Kokyu_defs.h"
-#include "Dispatcher_Impl.h"
-#include "Dispatcher_Task.h"
-namespace Kokyu
-   * @class Default_Dispatcher_Impl
-   * @brief Default implementation class for EC dispatcher
-   * implementations
-  class Default_Dispatcher_Impl : public Dispatcher_Impl
-  public:
-    Default_Dispatcher_Impl ();
-  private:
-    int activate_i ();
-    int init_i (const Dispatcher_Attributes&);
-    int dispatch_i (const Dispatch_Command*,
-                  const QoSDescriptor&);
-    Dispatcher_Task* find_task_with_preemption_prio (Priority_t);
-  private:
-    typedef auto_ptr<Dispatcher_Task> Dispatcher_Task_Auto_Ptr;
-    ACE_Auto_Array_Ptr<Dispatcher_Task_Auto_Ptr> tasks_;
-    int ntasks_;
-    ConfigInfoSet curr_config_info_;
-    int activated_;
-  class Shutdown_Task_Command : public Dispatch_Command
-  public:
-    /// Constructor
-    Shutdown_Task_Command (ACE_Allocator *mb_allocator = 0);
-    /// Command callback
-    int execute ();
-#endif /* DEFAULT_DISPATCHER_IMPL_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Default_Dispatcher_Impl.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Default_Dispatcher_Impl.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Default_Dispatcher_Impl.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,11 +0,0 @@
-// Default_Dispatcher_Impl.i,v 1.3 2003/10/02 12:43:10 venkita Exp
-namespace Kokyu
-ACE_INLINE
-Shutdown_Task_Command::Shutdown_Task_Command (ACE_Allocator *mb_allocator)
-   :Dispatch_Command(0,mb_allocator)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Impl.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Impl.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Impl.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,19 +0,0 @@
-// Dispatcher_Impl.cpp,v 1.2 2003/07/25 23:41:55 venkita Exp
-#include "Dispatcher_Impl.i"
-ACE_RCSID(Kokyu, Dispatcher_Impl, "Dispatcher_Impl.cpp,v 1.2 2003/07/25 23:41:55 venkita Exp")
-namespace Kokyu
-Dispatcher_Impl::~Dispatcher_Impl()
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Impl.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Impl.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Impl.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,74 +0,0 @@
-/* -*- C++ -*- */
- *  @file   Dispatcher_Impl.h
- *  Dispatcher_Impl.h,v 1.7 2003/12/23 12:30:41 jwillemsen Exp
-#ifndef DISPATCHER_IMPL_H
-#define DISPATCHER_IMPL_H
-# pragma once
-namespace Kokyu
-   * @class Dispatcher
-   * @brief Base class for EC dispatcher implementations
-   * for different EC dispatcher implementations. This is an
-  class Kokyu_Export Dispatcher_Impl
-  public:
-    /// Configure the dispatcher.
-    int init (const Dispatcher_Attributes&);
-    int activate ();
-    /// dispatch a command (eg. event) based on the QoS supplied.
-    int dispatch (const Dispatch_Command*,
-    /// shutdown the dispatcher.
-    int shutdown ();
-    virtual ~Dispatcher_Impl();
-  private:
-    virtual int init_i (const Dispatcher_Attributes&) =0;
-    virtual int dispatch_i (const Dispatch_Command*,
-                            const QoSDescriptor&) =0;
-    virtual int shutdown_i () =0;
-    virtual int activate_i () =0;
-  protected:
-    int thr_creation_flags_;
-#endif /* DISPATCHER_IMPL_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Impl.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Impl.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Impl.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,31 +0,0 @@
-// Dispatcher_Impl.i,v 1.3 2003/08/14 00:54:44 venkita Exp
-namespace Kokyu
-ACE_INLINE
-int Dispatcher_Impl::init (const Dispatcher_Attributes& attr)
-  return init_i (attr);
-ACE_INLINE
-int Dispatcher_Impl::dispatch (const Dispatch_Command* cmd,
-  return dispatch_i (cmd, qos_info);
-ACE_INLINE
-int Dispatcher_Impl::shutdown ()
-  return shutdown_i ();
-ACE_INLINE
-int Dispatcher_Impl::activate ()
-  return activate_i ();
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Task.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Task.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Task.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,207 +0,0 @@
-// Dispatcher_Task.cpp,v 1.13 2003/11/09 04:12:06 dhinton Exp
-#include "ace/Malloc_T.h"
-#include "ace/OS_NS_errno.h"
-#include "Dispatcher_Task.i"
-ACE_RCSID(Kokyu, Dispatcher_Task, "Dispatcher_Task.cpp,v 1.13 2003/11/09 04:12:06 dhinton Exp")
-namespace
-//anonymous namespace - use this to avoid polluting the global namespace
-  const int ALLOC_POOL_CHUNKS = 200;
-namespace Kokyu
-typedef ACE_Cached_Allocator<Dispatch_Queue_Item, ACE_SYNCH_MUTEX>
-Dispatch_Queue_Item_Allocator;
-int
-Dispatcher_Task::initialize ()
-  switch(curr_config_info_.dispatching_type_)
-    case FIFO_DISPATCHING:
-      ACE_NEW_RETURN (
-          this->the_queue_,
-          ACE_Message_Queue<ACE_SYNCH>,
-          -1);
-      break;
-    case DEADLINE_DISPATCHING:
-      ACE_NEW_RETURN (
-          this->the_queue_,
-          ACE_Dynamic_Message_Queue<ACE_SYNCH> (deadline_msg_strategy_),
-          -1);
-      break;
-    case LAXITY_DISPATCHING:
-      ACE_NEW_RETURN (
-           this->the_queue_,
-           ACE_Dynamic_Message_Queue<ACE_SYNCH> (laxity_msg_strategy_),
-           -1);
-      break;
-    default:
-      return -1;
-      break;
-  if (this->the_queue_ != 0)
-      this->msg_queue(this->the_queue_);
-  if (this->allocator_ == 0)
-      ACE_NEW_RETURN (this->allocator_,
-                      Dispatch_Queue_Item_Allocator(ALLOC_POOL_CHUNKS),
-                      -1);
-      own_allocator_ = 1;
-  return 0;
-int
-Dispatcher_Task::svc (void)
-  int done = 0;
-    int prio;
-    if (ACE_Thread::getprio (thr_handle, prio) == -1)
-            ACE_DEBUG((LM_DEBUG,
-                       ACE_TEXT ("getprio not supported on this platform\n")
-            return 0;
-                           ACE_TEXT ("getprio failed")),
-                          -1);
-    //ACE_DEBUG ((LM_DEBUG, "(%t) Dispatcher Thread started prio=%d\n", prio));
-  while (!done)
-      ACE_Message_Block *mb;
-      if (this->getq (mb) == -1)
-        if (ACE_OS::last_error () == ESHUTDOWN)
-          return 0;
-        else
-          ACE_ERROR ((LM_ERROR,
-                      "EC (%P|%t) getq error in Dispatching Queue\n"));
-      //ACE_DEBUG ((LM_DEBUG, "(%t) : next command got from queue\n"));
-      Dispatch_Queue_Item *qitem =
-        ACE_dynamic_cast(Dispatch_Queue_Item*, mb);
-      if (qitem == 0)
-          ACE_Message_Block::release (mb);
-          continue;
-      Dispatch_Command* command = qitem->command ();
-      ACE_ASSERT(command != 0);
-      int result = command->execute ();
-      if (command->can_be_deleted ())
-        command->destroy ();
-      if (result == -1)
-        done = 1;
-  return 0;
-int
-Dispatcher_Task::enqueue (const Dispatch_Command* cmd,
-  void* buf = this->allocator_->malloc (sizeof (Dispatch_Queue_Item));
-  if (buf == 0)
-    return -1;
-  ACE_Message_Block *mb =
-    new (buf) Dispatch_Queue_Item (cmd,
-                                   qos_info,
-                                   &(this->data_block_),
-                                   ACE_Message_Block::DONT_DELETE,
-                                   this->allocator_);
-  this->putq (mb);
-  return 0;
-int Dispatcher_Task::get_native_prio ()
-  int prio;
-                 ACE_TEXT ("getprior not supported on this platform\n")
-      return 0;
-                      -1);
-  return prio;
-void Dispatch_Queue_Item::init_i (const QoSDescriptor& qos_info)
-  this->msg_priority (qos_info.preemption_priority_);
-  this->msg_execution_time (qos_info.execution_time_);
-  this->msg_deadline_time (qos_info.deadline_);
-#if defined (ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION)
-template class ACE_Locked_Data_Block<ACE_Lock_Adapter<ACE_SYNCH_MUTEX> >;
-template class ACE_Lock_Adapter<ACE_Thread_Mutex>;
-template class ACE_Cached_Allocator<Kokyu::Dispatch_Queue_Item, ACE_SYNCH_MUTEX>;
-template class ACE_Free_List<ACE_Cached_Mem_Pool_Node<Kokyu::Dispatch_Queue_Item> >;
-template class ACE_Locked_Free_List<ACE_Cached_Mem_Pool_Node<Kokyu::Dispatch_Queue_Item>, ACE_SYNCH_MUTEX>;
-template class ACE_Cached_Mem_Pool_Node<Kokyu::Dispatch_Queue_Item>;
-#elif defined(ACE_HAS_TEMPLATE_INSTANTIATION_PRAGMA)
-#pragma instantiate ACE_Locked_Data_Block<ACE_Lock_Adapter<ACE_SYNCH_MUTEX> >
-#pragma instantiate ACE_Lock_Adapter<ACE_Thread_Mutex>
-#pragma instantiate ACE_Free_List<ACE_Cached_Mem_Pool_Node<Kokyu::Dispatch_Queue_Item> >
-#pragma instantiate ACE_Cached_Allocator<Kokyu::Dispatch_Queue_Item, ACE_SYNCH_MUTEX>
-#pragma instantiate ACE_Locked_Free_List<ACE_Cached_Mem_Pool_Node<Kokyu::Dispatch_Queue_Item, ACE_SYNCH_MUTEX>
-#pragma instantiate ACE_Cached_Mem_Pool_Node<Kokyu::Dispatch_Queue_Item>
-#endif /* ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Task.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Task.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Task.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,106 +0,0 @@
-/* -*- C++ -*- */
- *  @file   Dispatcher_Task.h
- *  Dispatcher_Task.h,v 1.12 2003/10/14 08:53:07 venkita Exp
-#ifndef DISPATCHER_TASK_H
-#define DISPATCHER_TASK_H
-#include "ace/Lock_Adapter_T.h"
-# pragma once
-namespace Kokyu
-class Dispatch_Queue_Item : public ACE_Message_Block
-public:
-  Dispatch_Queue_Item (
-        const Dispatch_Command* cmd,
-        const QoSDescriptor& qos_info,
-        ACE_Allocator* mb_allocator =0);
-        ACE_Data_Block* data_block,
-        int flags,
-  Dispatch_Command* command ();
-private:
-  void init_i(const QoSDescriptor&);
-private:
-  const Dispatch_Command* command_;
-  QoSDescriptor qos_info_;
- * @class Dispatcher_Task
- * @brief Implement the dispatching queues for FIFO and Priority
- * dispatching.
-class Dispatcher_Task : public ACE_Task<ACE_SYNCH>
-public:
-  /// Constructor
-  Dispatcher_Task (const ConfigInfo& config_info,
-                   ACE_Thread_Manager* thr_manager = 0);
-  ~Dispatcher_Task ();
-  int initialize();
-  int enqueue (const Dispatch_Command* cmd,
-           const QoSDescriptor& qos_info);
-  /// Process the events in the queue.
-  int svc (void);
-  const ConfigInfo& get_curr_config_info() const;
-  Priority_t preemption_priority() const;
-private:
-  static int get_native_prio();
-private:
-  ConfigInfo curr_config_info_;
-  ACE_Allocator *allocator_;
-  int own_allocator_;
-  /// Helper data structure to minimize memory allocations...
-  ACE_Locked_Data_Block<ACE_Lock_Adapter<ACE_SYNCH_MUTEX> > data_block_;
-  /// The queue
-  ACE_Message_Queue<ACE_SYNCH>* the_queue_;
-  ACE_Deadline_Message_Strategy deadline_msg_strategy_;
-  ACE_Laxity_Message_Strategy laxity_msg_strategy_;
-#endif /* DISPATCHER_TASK_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Task.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Task.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Dispatcher_Task.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,81 +0,0 @@
-// Dispatcher_Task.i,v 1.6 2003/10/11 22:45:21 venkita Exp
-namespace Kokyu
-ACE_INLINE
-Dispatcher_Task::Dispatcher_Task (const ConfigInfo& config_info,
-                                  ACE_Thread_Manager* thr_manager)
-  :  ACE_Task<ACE_SYNCH> (thr_manager),
-     curr_config_info_ (config_info),
-     allocator_ (config_info.allocator_),
-     own_allocator_ (0),
-     deadline_msg_strategy_ (config_info.reordering_flags_.static_bit_field_mask_,
-                             config_info.reordering_flags_.static_bit_field_shift_,
-                             config_info.reordering_flags_.dynamic_priority_max_,
-                             config_info.reordering_flags_.dynamic_priority_offset_),
-     laxity_msg_strategy_ (config_info.reordering_flags_.static_bit_field_mask_,
-   this->initialize();
-ACE_INLINE
-Dispatcher_Task::~Dispatcher_Task ()
-   if (own_allocator_)
-      delete allocator_;
-ACE_INLINE
-Priority_t
-Dispatcher_Task::preemption_priority() const
-    return curr_config_info_.preemption_priority_;
-ACE_INLINE
-const ConfigInfo&
-Dispatcher_Task::get_curr_config_info() const
-    return curr_config_info_;
-ACE_INLINE
-Dispatch_Queue_Item::Dispatch_Queue_Item (
-        ACE_Data_Block *data_block,
-        int flags,
-        ACE_Allocator* mb_allocator)
- : ACE_Message_Block (data_block,
-                      flags,
-                      mb_allocator),
-   command_ (cmd), qos_info_ (qos_info)
-   this->init_i (qos_info);
-ACE_INLINE
- : ACE_Message_Block (mb_allocator),
-ACE_INLINE
-Dispatch_Command*
-Dispatch_Queue_Item::command()
-  return const_cast<Dispatch_Command*> (command_);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,57 +0,0 @@
-// Kokyu.cpp,v 1.11 2003/08/14 00:54:44 venkita Exp
-#include "Kokyu.h"
-#include "Kokyu.i"
-ACE_RCSID(Kokyu, Kokyu, "Kokyu.cpp,v 1.11 2003/08/14 00:54:44 venkita Exp")
-namespace Kokyu
-int Dispatcher::dispatch (const Dispatch_Command* cmd, const QoSDescriptor& qos)
-  return dispatcher_impl_->dispatch (cmd, qos);
-int Dispatcher::shutdown ()
-  return dispatcher_impl_->shutdown ();
-int Dispatcher::activate ()
-  return dispatcher_impl_->activate ();
-void Dispatcher::implementation (Dispatcher_Impl* impl)
-  auto_ptr<Dispatcher_Impl> tmp_impl (impl);
-  dispatcher_impl_ = tmp_impl;
-  //I couldn't use reset because MSVC++ auto_ptr does not have reset method.
-  //dispatcher_impl_.reset (impl);
-Dispatcher_Auto_Ptr
-Dispatcher_Factory::
-create_dispatcher(const Dispatcher_Attributes& attrs)
-  Dispatcher* disp;
-  Dispatcher_Auto_Ptr nil_ptr((Dispatcher*)0);
-  Dispatcher_Impl* tmp;
-  ACE_NEW_RETURN (tmp, Default_Dispatcher_Impl, nil_ptr);
-  ACE_NEW_RETURN (disp, Dispatcher, nil_ptr);
-  Dispatcher_Auto_Ptr disp_auto_ptr(disp);
-  disp->implementation (tmp);
-  tmp->init (attrs);
-  return disp_auto_ptr;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.dsp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.dsp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.dsp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,287 +0,0 @@
-# Microsoft Developer Studio Project File - Name="Kokyu_DLL" - Package Owner=<4>
-# Microsoft Developer Studio Generated Build File, Format Version 6.00
-# ** DO NOT EDIT **
-# TARGTYPE "Win32 (x86) Dynamic-Link Library" 0x0102
-CFG=Kokyu_DLL - Win32 Debug
-!MESSAGE This is not a valid makefile. To build this project using NMAKE,
-!MESSAGE use the Export Makefile command and run
-!MESSAGE
-!MESSAGE NMAKE /f "Kokyu.mak".
-!MESSAGE
-!MESSAGE You can specify a configuration when running NMAKE
-!MESSAGE by defining the macro CFG on the command line. For example:
-!MESSAGE
-!MESSAGE NMAKE /f "Kokyu.mak" CFG="Kokyu_DLL - Win32 Debug"
-!MESSAGE
-!MESSAGE Possible choices for configuration are:
-!MESSAGE
-!MESSAGE "Kokyu_DLL - Win32 Release" (based on "Win32 (x86) Dynamic-Link Library")
-!MESSAGE "Kokyu_DLL - Win32 Debug" (based on "Win32 (x86) Dynamic-Link Library")
-!MESSAGE
-# Begin Project
-# PROP AllowPerConfigDependencies 0
-# PROP Scc_ProjName ""
-# PROP Scc_LocalPath ""
-CPP=cl.exe
-MTL=midl.exe
-RSC=rc.exe
-!IF  "$(CFG)" == "Kokyu_DLL - Win32 Release"
-# PROP BASE Use_MFC 0
-# PROP BASE Use_Debug_Libraries 0
-# PROP BASE Output_Dir "Release"
-# PROP BASE Intermediate_Dir "Release"
-# PROP BASE Target_Dir ""
-# PROP Use_MFC 0
-# PROP Use_Debug_Libraries 0
-# PROP Output_Dir ""
-# PROP Intermediate_Dir "DLL\Release"
-# PROP Ignore_Export_Lib 0
-# PROP Target_Dir ""
-# ADD BASE CPP /nologo /MT /W3 /GX /O2 /D "WIN32" /D "NDEBUG" /D "_WINDOWS" /D "_MBCS" /D "_USRDLL" /D "KOKYU_DLL_EXPORTS" /YX /FD /c
-# ADD CPP /nologo /MD /W3 /GX /O2 /I "..\\" /D "WIN32" /D "NDEBUG" /D "_WINDOWS" /D "_MBCS" /D "_USRDLL" /D "KOKYU_BUILD_DLL" /FD /c
-# SUBTRACT CPP /YX
-# ADD BASE MTL /nologo /D "NDEBUG" /mktyplib203 /win32
-# ADD MTL /nologo /D "NDEBUG" /mktyplib203 /win32
-# ADD BASE RSC /l 0x409 /d "NDEBUG"
-# ADD RSC /l 0x409 /d "NDEBUG"
-BSC32=bscmake.exe
-# ADD BASE BSC32 /nologo
-# ADD BSC32 /nologo
-LINK32=link.exe
-# ADD BASE LINK32 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /nologo /dll /machine:I386
-# ADD LINK32 ace.lib /nologo /dll /machine:I386 /out:"..\bin\Kokyu.dll" /libpath:"../ace"
-# SUBTRACT LINK32 /incremental:yes /debug
-!ELSEIF  "$(CFG)" == "Kokyu_DLL - Win32 Debug"
-# PROP BASE Use_Debug_Libraries 1
-# PROP BASE Output_Dir "Debug"
-# PROP BASE Intermediate_Dir "Debug"
-# PROP Use_MFC 0
-# PROP Use_Debug_Libraries 1
-# PROP Intermediate_Dir "DLL\Debug"
-# ADD BASE CPP /nologo /MTd /W3 /Gm /GX /Zi /Od /D "WIN32" /D "_DEBUG" /D "_WINDOWS" /D "_MBCS" /D "_USRDLL" /D "KOKYU_DLL_EXPORTS" /YX /FD /c
-# ADD CPP /nologo /MDd /W3 /Gm /GX /Zi /Od /I ".." /D "WIN32" /D "_DEBUG" /D "_WINDOWS" /D "_MBCS" /D "_USRDLL" /D "KOKYU_BUILD_DLL" /FD /c
-# SUBTRACT CPP /YX
-# ADD BASE MTL /nologo /D "_DEBUG" /mktyplib203 /win32
-# ADD MTL /nologo /D "_DEBUG" /mktyplib203 /win32
-# ADD BASE RSC /l 0x409 /d "_DEBUG"
-# ADD RSC /l 0x409 /d "_DEBUG"
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD BASE LINK32 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /nologo /dll /debug /machine:I386 /pdbtype:sept
-# ADD LINK32 aced.lib /nologo /dll /debug /machine:I386 /out:"..\bin\Kokyud.dll" /pdbtype:sept /libpath:"../ace"
-!ENDIF
-# Begin Target
-# Name "Kokyu_DLL - Win32 Release"
-# Name "Kokyu_DLL - Win32 Debug"
-# Begin Group "Source Files"
-# PROP Default_Filter "cpp;c;cxx;rc;def;r;odl;idl;hpj;bat"
-# Begin Source File
-SOURCE=.\Default_Dispatcher_Impl.cpp
-# End Source File
-SOURCE=.\Dispatcher_Impl.cpp
-# End Source File
-SOURCE=.\Dispatcher_Task.cpp
-# End Source File
-SOURCE=.\Kokyu.cpp
-# End Source File
-SOURCE=.\Kokyu_defs.cpp
-# End Source File
-# End Group
-# Begin Group "Header Files"
-# PROP Default_Filter "h;hpp;hxx;hm;inl"
-SOURCE=.\Default_Dispatcher_Impl.h
-# End Source File
-SOURCE=.\Dispatcher_Impl.h
-# End Source File
-SOURCE=.\Dispatcher_Task.h
-# End Source File
-SOURCE=.\Kokyu.h
-# End Source File
-SOURCE=.\Kokyu_defs.h
-# End Source File
-SOURCE=.\kokyu_export.h
-# End Source File
-# End Group
-# Begin Group "Resource Files"
-# PROP Default_Filter "ico;cur;bmp;dlg;rc2;rct;bin;rgs;gif;jpg;jpeg;jpe"
-# End Group
-# Begin Group "Inline Files"
-# PROP Default_Filter ""
-SOURCE=.\Default_Dispatcher_Impl.i
-# PROP Exclude_From_Build 1
-!ENDIF
-# End Source File
-SOURCE=.\Dispatcher_Impl.i
-!ENDIF
-# End Source File
-SOURCE=.\Dispatcher_Task.i
-!ENDIF
-# End Source File
-SOURCE=.\DSRT_Dispatch_Item_T.i
-!ENDIF
-# End Source File
-SOURCE=.\DSRT_Dispatcher_Impl_T.i
-!ENDIF
-# End Source File
-SOURCE=.\Kokyu.i
-!ENDIF
-# End Source File
-SOURCE=.\Kokyu_defs.i
-!ENDIF
-# End Source File
-SOURCE=.\Kokyu_dsrt.i
-!ENDIF
-# End Source File
-# End Group
-# Begin Group "Template Files"
-SOURCE=.\DSRT_Direct_Dispatcher_Impl_T.cpp
-# End Source File
-SOURCE=.\DSRT_Dispatch_Item_T.cpp
-# End Source File
-SOURCE=.\DSRT_Dispatcher_Impl_T.cpp
-# End Source File
-SOURCE=.\DSRT_Sched_Queue_T.cpp
-# End Source File
-SOURCE=.\Kokyu_dsrt.cpp
-# End Source File
-# End Group
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.dsw
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.dsw	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.dsw	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,41 +0,0 @@
-Microsoft Developer Studio Workspace File, Format Version 6.00
-# WARNING: DO NOT EDIT OR DELETE THIS WORKSPACE FILE!
-Project: "Kokyu_DLL"=.\Kokyu.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Project: "Kokyu_Static"=.\Kokyu_Static.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Global:
-Package=<5>
-Package=<3>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,115 +0,0 @@
-/* -*- C++ -*- */
- *  @file   Kokyu.h
- *  Kokyu.h,v 1.12 2003/10/14 08:53:07 venkita Exp
- * Based on previous work by Tim Harrison Chris Gill,
- * Carlos O'Ryan and other members of the DOC group.
-#ifndef KOKYU_H
-#define KOKYU_H
-# pragma once
-//Currently I am not seeing a way to avoid including these here. The
-//whole purpose of the pImpl idiom is to avoid this dependency. But
-//using the auto_ptr<> to store the implementation causes a compile
-//error (in the destructor) that the implementation definition is not
-//found. Note that the auto-ptr<T>::~auto_ptr() calls delete on the
-//internal pointer and at this point the class definition needs to be
-//visible. Need to revisit this and see whether there is a work
-//around.
-//Beware that this interface will be subject to change in the future
-//since this is the very initial release. We will be working on
-//trying to merge the DSRT and EC mechanisms in the future. If you
-//are a user of this interface, kindly let us know so that we can
-//coordinate with you when we refactor this interface.
-namespace Kokyu
-  //class Dispatcher_Impl;
-   * @brief Interface class for dynamic scheduling of events
-   * The responsibility of this class is to forward all methods to
-   * its delegation/implementation class, e.g.,
-   * @c Default_Dispatcher_Impl. This class follows the pImpl idiom
-   * or the bridge pattern to separate the implementation from the interface.
-   * Dispatcher is the class that users will be using to achieve
-   * dynamic dispatching of events in an event channel.
-  class Kokyu_Export Dispatcher : private ACE_Copy_Disabled
-  public:
-    /// Dispatch a command object based on the qos info supplied.
-    int dispatch (const Dispatch_Command*, const QoSDescriptor&);
-    /// Shut down the dispatcher. The dispatcher will stop processing requests.
-    int shutdown ();
-    /// Supply this interface with an appripriate implementation.
-    void implementation (Dispatcher_Impl*);
-    int activate ();
-    /// Non virtual destructor. Read as <b><i>this class not available
-    /// for inheritance<i></b>.
-    ~Dispatcher ();
-  private:
-    /// Auto ptr to the implementation. Implementation will be created on the
-    /// heap and deleted automatically when the dispatcher object is destructed.
-    auto_ptr<Dispatcher_Impl> dispatcher_impl_;
-  typedef auto_ptr<Dispatcher> Dispatcher_Auto_Ptr;
-   * @class Dispatcher_Factory
-   * @brief Factory class to create one of the dispatcher interface
-   * objects - for events.
-   * Factory class creates a dispatcher for EC and configures the
-   * interface object with the appropriate implementation.
-  class Kokyu_Export Dispatcher_Factory : private ACE_Copy_Disabled
-    public:
-       * Create a dispatcher for dynamic dispatching of commands
-       * (eg. events). The caller is responsible for freeing the
-       * returned dynamically allocated memory.
-       * @param config Configuration information for the dispatcher.
-       * @return Auto pointer to the dispatcher.
-      static Dispatcher_Auto_Ptr
-      create_dispatcher (const Dispatcher_Attributes& attr);
-#include "Kokyu.i"
-#endif /* __ACE_INLINE__ */
-#endif /* KOKYU_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,10 +0,0 @@
-// Kokyu.i,v 1.3 2003/07/25 23:41:55 venkita Exp
-namespace Kokyu
-ACE_INLINE
-Dispatcher::~Dispatcher()
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.mpc
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.mpc	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu.mpc	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,23 +0,0 @@
-//  -*- MPC -*- now wouldn't this be cool...
-// Kokyu.mpc,v 1.7 2003/11/10 04:31:58 dhinton Exp
-project(Kokyu) : acelib {
-  sharedname  = Kokyu
-  dynamicflags = KOKYU_BUILD_DLL
-  Source_Files {
-    Dispatcher_Impl.cpp
-    Kokyu.cpp
-    Default_Dispatcher_Impl.cpp
-    Dispatcher_Task.cpp
-    Kokyu_defs.cpp
-  Template_Files {
-    Kokyu_dsrt.cpp
-    DSRT_Direct_Dispatcher_Impl_T.cpp
-    DSRT_Dispatcher_Impl_T.cpp
-    DSRT_Dispatch_Item_T.cpp
-    DSRT_Sched_Queue_T.cpp
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_defs.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_defs.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_defs.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,75 +0,0 @@
-// Kokyu_defs.cpp,v 1.7 2003/10/12 02:56:16 venkita Exp
-#include "Kokyu_defs.i"
-ACE_RCSID(Kokyu, Kokyu_defs, "Kokyu_defs.cpp,v 1.7 2003/10/12 02:56:16 venkita Exp")
-namespace Kokyu
-   Dispatch_Command::~Dispatch_Command (void)
-  DSRT_ConfigInfo::DSRT_ConfigInfo ()
-    :sched_policy_ (ACE_SCHED_RR),
-     sched_scope_ (ACE_SCOPE_THREAD)
-Dispatcher_Attributes::Dispatcher_Attributes()
-    :immediate_activation_ (0),
-     sched_policy_ (ACE_SCHED_FIFO),
-     sched_scope_ (ACE_SCOPE_THREAD),
-     base_thread_creation_flags_ (THR_NEW_LWP | THR_BOUND | THR_JOINABLE)
-int Dispatcher_Attributes::thread_creation_flags () const
-   int thread_creation_flags = base_thread_creation_flags_;
-   switch (sched_policy_)
-      case ACE_SCHED_FIFO:
-         thread_creation_flags |= THR_SCHED_FIFO;
-         break;
-      case ACE_SCHED_OTHER:
-         thread_creation_flags |= THR_SCHED_DEFAULT;
-         break;
-      case ACE_SCHED_RR:
-         thread_creation_flags |= THR_SCHED_RR;
-         break;
-   switch (sched_scope_)
-      case ACE_SCOPE_PROCESS:
-      case ACE_SCOPE_LWP:
-         thread_creation_flags |= THR_SCOPE_PROCESS;
-         break;
-      case ACE_SCOPE_THREAD:
-      default:
-         thread_creation_flags |= THR_SCOPE_SYSTEM;
-         break;
-   return thread_creation_flags;
-template class ACE_Array<Kokyu::ConfigInfo>;
-template class ACE_Array_Base<Kokyu::ConfigInfo>;
-template class ACE_Array_Iterator<Kokyu::ConfigInfo>;
-#pragma instantiate ACE_Array<Kokyu::ConfigInfo>
-#pragma instantiate ACE_Array_Base<Kokyu::ConfigInfo>
-#pragma instantiate ACE_Array_Iterator<Kokyu::ConfigInfo>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_defs.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_defs.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_defs.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,193 +0,0 @@
-/* -*- C++ -*- */
- *  @file   Kokyu_defs.h
- *  Kokyu_defs.h,v 1.13 2003/10/29 20:08:20 venkita Exp
-#ifndef KOKYU_DEFS_H
-#define KOKYU_DEFS_H
-#include "ace/Array.h"
-#include "ace/Time_Value.h"
-#include "ace/Message_Block.h"
-#include "ace/Malloc_Allocator.h"
-# pragma once
-class ACE_Allocator;
-namespace Kokyu
-  typedef long Priority_t;
-  typedef ACE_Time_Value Deadline_t; //absolute deadline
-  typedef ACE_Time_Value Execution_Time_t; //execution time
-  //typedef int Guid_t;
-  enum Dispatching_Type_t
-    // Defines the type of prioritization strategy
-    // to be used by a dispatching queue
-      FIFO_DISPATCHING,
-      DEADLINE_DISPATCHING,
-      LAXITY_DISPATCHING
-  enum Criticality_t
-    // Defines the criticality of the operation.
-    // For use with Dynamic Scheduler.
-      VERY_LOW_CRITICALITY,
-      LOW_CRITICALITY,
-      MEDIUM_CRITICALITY,
-      HIGH_CRITICALITY,
-      VERY_HIGH_CRITICALITY
-  enum Importance_t
-    // Defines the importance of the operation,
-    // which can be used by the RtecScheduler as a
-    // "tie-breaker" when other scheduling
-    // parameters are equal.
-      VERY_LOW_IMPORTANCE,
-      LOW_IMPORTANCE,
-      MEDIUM_IMPORTANCE,
-      HIGH_IMPORTANCE,
-      VERY_HIGH_IMPORTANCE
-  struct Kokyu_Export Reordering_Queue_Attributes
-    Reordering_Queue_Attributes ();
-    unsigned long static_bit_field_mask_;
-    unsigned long static_bit_field_shift_;
-    unsigned long dynamic_priority_max_;
-    unsigned long dynamic_priority_offset_;
-  struct Kokyu_Export ConfigInfo
-    Priority_t preemption_priority_;
-    // OS priority of the dispatching thread associated with the queue
-    Priority_t thread_priority_;
-    // type of dispatching queue
-    Dispatching_Type_t dispatching_type_;
-    //allocator to be used for dynamic memory allocation. If each
-    //thread gets its own memory pool, contention will be less
-    Reordering_Queue_Attributes reordering_flags_;
-    ConfigInfo ();
-  typedef ACE_Array<ConfigInfo> ConfigInfoSet;
-  class Kokyu_Export Dispatcher_Attributes
-  public:
-    ConfigInfoSet config_info_set_;
-    int immediate_activation_;
-  public:
-    Dispatcher_Attributes ();
-    void sched_policy (int);
-    void sched_scope (int);
-    int thread_creation_flags () const;
-  private:
-    int sched_policy_;
-    int sched_scope_;
-    int base_thread_creation_flags_;
-  struct Kokyu_Export QoSDescriptor
-    Deadline_t deadline_;
-    Execution_Time_t execution_time_;
-    Importance_t importance_;
-  enum Block_Flag_t {BLOCK, UNBLOCK};
-  class Kokyu_Export Dispatch_Command
-    public:
-      Dispatch_Command(int dont_delete = 0,
-                       ACE_Allocator *allocator = 0);
-      //dont_delete indicates whether this object needs to be deleted once processed.
-      //allocator indicates the ACE_Allocator, if any, from which this object was created.
-      //This same allocator has to be used for the deletion also
-      virtual int execute () = 0;
-      int can_be_deleted () const;
-      void destroy (void);
-    protected:
-      /// Destructor
-      // only inheritance is possible and object should be on heap,
-      // since object could be handed over to a different thread.
-      virtual ~Dispatch_Command (void);
-    private:
-      int dont_delete_;
-      //if this object has to be deleted, then delete it using the allocator
-      //if one is present.
-  enum DSRT_Sched_Type_t
-      DSRT_FP,
-      DSRT_MUF,
-      DSRT_MIF
-  enum DSRT_Dispatcher_Impl_t
-      DSRT_CV_BASED,
-      DSRT_OS_BASED
-  struct Kokyu_Export DSRT_ConfigInfo
-    //not used currently
-    DSRT_Sched_Type_t sched_strategy_;
-    int sched_scope_;
-    //type of implementation
-    DSRT_Dispatcher_Impl_t impl_type_;
-    DSRT_ConfigInfo ();
-//to satisfy ACE_Array<ConfigInfo>
-ACE_INLINE int operator != (const Kokyu::ConfigInfo& lhs, const Kokyu::ConfigInfo& rhs);
-#include /**/ "ace/post.h"
-#endif /* KOKYU_DEFS_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_defs.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_defs.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_defs.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,86 +0,0 @@
-// Kokyu_defs.i,v 1.8 2003/10/29 20:08:20 venkita Exp
-namespace Kokyu
-ACE_INLINE
-void Dispatcher_Attributes::sched_policy(int policy)
-  sched_policy_ = policy;
-ACE_INLINE
-void Dispatcher_Attributes::sched_scope(int scope)
-  sched_scope_ = scope;
-ACE_INLINE
-Reordering_Queue_Attributes::Reordering_Queue_Attributes ()
-  :static_bit_field_mask_ (0), // not used
-   static_bit_field_shift_ (0), // not used
-   dynamic_priority_max_ (0x7FFFFFFFUL), // 2^31-1
-   dynamic_priority_offset_ (0x08000000UL) // 15/16th of dynamic prio range
-  //bits for static priority = 0
-  //max dynamic prio = 2^31 - 1
-  //pending offset = 15/16th of the dynamic prio range
-  //which means that the LATE population will be in the
-  //1/16th part of the range.
-  //For the Laxity and Deadline strategies these are the
-  //defaults defined in Message_Block.h
-  //static_bit_field_mask (0x3FFUL), // 2^(10) - 1
-  //static_bit_field_shift (10), // 10 low order bits
-  //dynamic_priority_max (0x3FFFFFUL), // 2^(22)-1
-  //dynamic_priority_offset (0x200000UL) // 2^(22-1)
-ACE_INLINE
-Dispatch_Command::Dispatch_Command (int dont_delete,
-        ACE_Allocator *allocator)
-        :dont_delete_ (dont_delete),
-        allocator_ (allocator)
-ACE_INLINE
-int Dispatch_Command::can_be_deleted (void) const
-  return !dont_delete_;
-ACE_INLINE
-void Dispatch_Command::destroy (void)
-  if (allocator_)
-    allocator_->free (this);
-  else
-    delete this;
-ACE_INLINE
-ConfigInfo::ConfigInfo ()
-  :preemption_priority_ (0),
-   thread_priority_ (0),
-   dispatching_type_ (FIFO_DISPATCHING),
-   allocator_ (0)
-ACE_INLINE
-int operator != (const Kokyu::ConfigInfo& lhs,
-                 const Kokyu::ConfigInfo& rhs)
-  return (lhs.preemption_priority_ != rhs.preemption_priority_ ||
-          lhs.thread_priority_ != rhs.thread_priority_ ||
-          lhs.dispatching_type_ != rhs.dispatching_type_ );
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_dsrt.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_dsrt.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_dsrt.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,188 +0,0 @@
-// Kokyu_dsrt.cpp,v 1.3 2003/10/08 02:23:39 venkita Exp
-#include "Kokyu_dsrt.h"
-#include "ace/Dynamic_Service.h"
-#include "DSRT_Direct_Dispatcher_Impl_T.h"
-#include "DSRT_CV_Dispatcher_Impl_T.h"
-#include "Kokyu_dsrt.i"
-ACE_RCSID(Kokyu, Kokyu, "Kokyu_dsrt.cpp,v 1.3 2003/10/08 02:23:39 venkita Exp")
-namespace Kokyu
-template <class DSRT_Scheduler_Traits>
-void
-DSRT_Dispatcher<DSRT_Scheduler_Traits>::implementation (DSRT_Dispatcher_Impl<DSRT_Scheduler_Traits>* impl)
-  auto_ptr<DSRT_Dispatcher_Impl<DSRT_Scheduler_Traits> > tmp_impl (impl);
-int
-DSRT_Dispatcher<DSRT_Scheduler_Traits>::schedule (Guid_t guid, const DSRT_QoSDescriptor& qos)
-  return dispatcher_impl_->schedule (guid, qos);
-int
-DSRT_Dispatcher<DSRT_Scheduler_Traits>::update_schedule (Guid_t guid, const DSRT_QoSDescriptor& qos)
-  return dispatcher_impl_->update_schedule (guid, qos);
-int
-DSRT_Dispatcher<DSRT_Scheduler_Traits>::update_schedule (Guid_t guid, Kokyu::Block_Flag_t flag)
-  return dispatcher_impl_->update_schedule (guid, flag);
-int
-DSRT_Dispatcher<DSRT_Scheduler_Traits>::cancel_schedule (Guid_t guid)
-  return dispatcher_impl_->cancel_schedule (guid);
-int DSRT_Dispatcher<DSRT_Scheduler_Traits>::shutdown ()
-typename DSRT_Dispatcher_Factory<DSRT_Scheduler_Traits>::DSRT_Dispatcher_Auto_Ptr
-DSRT_Dispatcher_Factory<DSRT_Scheduler_Traits>::
-create_DSRT_dispatcher (const DSRT_ConfigInfo& config_info)
-  ACE_UNUSED_ARG ((config_info));
-  DSRT_Dispatcher_Impl<DSRT_Scheduler_Traits>* tmp;
-  DSRT_Dispatcher<DSRT_Scheduler_Traits>* disp;
-  DSRT_Dispatcher_Auto_Ptr nil_ptr((DSRT_Dispatcher<DSRT_Scheduler_Traits>*)0);
-  //DSRT_Dispatcher_Impl::init_svcs ();
-  //ACE_Service_Config::open ("Kokyu", ACE_DEFAULT_LOGGER_KEY, 0);
-  //tmp =
-  //  ACE_Dynamic_Service<DSRT_Dispatcher_Impl>::instance ("DSRT_Dispatcher_Impl");
-  switch (config_info.impl_type_)
-    case DSRT_OS_BASED:
-                      DSRT_Direct_Dispatcher_Impl<DSRT_Scheduler_Traits> (
-                      config_info.sched_policy_,
-                      config_info.sched_scope_),
-                      nil_ptr);
-      break;
-    case DSRT_CV_BASED:
-    default:
-                      DSRT_CV_Dispatcher_Impl<DSRT_Scheduler_Traits>(
-                      nil_ptr);
-      break;
-  ACE_ASSERT (tmp != 0);
-  ACE_NEW_RETURN (disp, DSRT_Dispatcher<DSRT_Scheduler_Traits>, nil_ptr);
-  DSRT_Dispatcher_Auto_Ptr disp_auto_ptr(disp);
-  tmp->init (config_info);
-template <class QoSDescriptor_t>
-int MUF_Comparator<QoSDescriptor_t>::
-operator ()(const QoSDescriptor_t& qos1,
-            const QoSDescriptor_t& qos2)
-  if (qos1.criticality_ > qos2.criticality_)
-      return 1;
-  else if (qos2.criticality_ > qos1.criticality_)
-      return -1;
-  typename QoSDescriptor_t::Now now_functor;
-  Time_t now = now_functor ();
-  Time_t exec_time1 = qos1.exec_time_;
-  Time_t deadline1 = qos1.deadline_;
-  Time_t laxity1 = deadline1 - now - exec_time1;
-  Time_t exec_time2 = qos2.exec_time_;
-  Time_t deadline2 = qos2.deadline_;
-  Time_t laxity2 = deadline2 - now - exec_time2;
-  if (laxity1 < laxity2)
-      return 1;
-  else if (laxity1 == laxity2)
-      return 0;
-  else
-      return -1;
-template <class QoSDescriptor>
-int MIF_Comparator<QoSDescriptor>::
-operator ()(const QoSDescriptor& qos1,
-            const QoSDescriptor& qos2)
-#ifdef KOKYU_DSRT_LOGGING
-              "(%t|%T):qos1.importance = %d, qos2.importance = %d\n",
-              qos1.importance_, qos2.importance_));
-#endif
-  if (qos1.importance_ > qos2.importance_)
-      return 1;
-  else if (qos1.importance_ == qos2.importance_)
-      return 0;
-  else
-      return -1;
-int Fixed_Priority_Comparator<QoSDescriptor>::
-  if (qos1.priority_ > qos2.priority_)
-      return 1;
-  else if (qos1.priority_ == qos2.priority_)
-      return 0;
-  else
-      return -1;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_dsrt.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_dsrt.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_dsrt.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,177 +0,0 @@
-/* -*- C++ -*- */
- *  @file   Kokyu_dsrt.h
- *  Kokyu_dsrt.h,v 1.7 2003/10/13 08:36:22 jwillemsen Exp
- *  @author Venkita Subramonian (venkita at cs.wustl.edu)
-#ifndef KOKYU_DSRT_H
-#define KOKYU_DSRT_H
-#include /**/ "ace/pre.h"
-#include "ace/Copy_Disabled.h"
-//#if !defined (ACE_LACKS_PRAGMA_ONCE)
-//# pragma once
-//#endif /* ACE_LACKS_PRAGMA_ONCE */
-namespace Kokyu
-  template <class DSRT_Scheduler_Traits> class DSRT_Dispatcher_Impl;
-   * @brief Interface class for dynamic scheduling of threads
-   * @c Default_DSRT_Dispatcher_Impl. This class follows the pImpl idiom
-   * DSRT_Dispatcher is the class that users will be using to achieve
-   * dynamic scheduling of threads.
-  class DSRT_Dispatcher : private ACE_Copy_Disabled
-  public:
-    // = Scheduling methods.
-    /// Schedule a thread dynamically based on the qos info supplied.
-    int schedule (Guid_t guid, const DSRT_QoSDescriptor&);
-    /// Update the schedule for a thread. This could alter the current schedule.
-    int update_schedule (Guid_t guid, const DSRT_QoSDescriptor&);
-    /// Inform the scheduler that the caller thread is about to
-    /// block. This could alter the current schedule.
-    int update_schedule (Guid_t guid, Kokyu::Block_Flag_t flag);
-    /// Cancel the schedule for a thread. This could alter the current schedule.
-    /// Supply this interface with an appropriate implementation.
-    void implementation (DSRT_Dispatcher_Impl<DSRT_Scheduler_Traits>*);
-    // = Termination methods.
-    int shutdown ();
-    ~DSRT_Dispatcher ();
-  private:
-    auto_ptr<DSRT_Dispatcher_Impl<DSRT_Scheduler_Traits> > dispatcher_impl_;
-   * @class DSRT_Dispatcher_Factory
-   * objects - for events or DSRT threads.
-   * Factory class creates a dispatcher or DSRT dispatcher and configures
-   * the interface object with the appropriate implementation.
-  class DSRT_Dispatcher_Factory : private ACE_Copy_Disabled
-    public:
-      typedef auto_ptr<DSRT_Dispatcher<DSRT_Scheduler_Traits> > DSRT_Dispatcher_Auto_Ptr;
-       * Create a dispatcher for dynamic dispatching of threads.
-       * This will be used to dynamic scheduling of distributable threads for
-       * DSRTCORBA. The caller is responsible for freeing the memory.
-       * @param config Configuration information for the DSRT dispatcher.
-       * @return Auto pointer to the DSRT dispatcher.
-      static DSRT_Dispatcher_Auto_Ptr create_DSRT_dispatcher (const DSRT_ConfigInfo&);
-   * @class MIF_Sched_Strategy
-   * @brief Strategy class implementing Maximum Importance First
-   * reordering strategy.
-  template <class QoSDesc>
-  class MIF_Comparator
-  public:
-    typedef typename QoSDesc::Importance_t Importance_t;
-    int operator ()(const QoSDesc& qos1,
-		    const QoSDesc& qos2);
-   * @class Fixed_Priority_Sched_Strategy
-   * @brief Strategy class implementing Fixed Priority reordering
-   * strategy.
-  class Fixed_Priority_Comparator
-  public:
-    typedef typename QoSDesc::Priority_t Priority_t;
-   * @class MUF_Sched_Strategy
-   * @brief Strategy class implementing Maximum Urgency First
-  class MUF_Comparator
-    public:
-    typedef typename QoSDesc::Criticality_t Criticality_t;
-    typedef typename QoSDesc::Time_t Time_t;
-#if defined (__ACE_INLINE__)
-#if defined (ACE_TEMPLATES_REQUIRE_SOURCE)
-#include "Kokyu_dsrt.cpp"
-#endif /* ACE_TEMPLATES_REQUIRE_SOURCE */
-#if defined (ACE_TEMPLATES_REQUIRE_PRAGMA)
-#pragma implementation ("Kokyu_dsrt.cpp")
-#endif /* ACE_TEMPLATES_REQUIRE_PRAGMA */
-#endif /* KOKYU_DSRT_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_dsrt.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_dsrt.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Kokyu_dsrt.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,11 +0,0 @@
-// Kokyu_dsrt.i,v 1.1 2003/07/25 23:41:55 venkita Exp
-namespace Kokyu
-ACE_INLINE
-DSRT_Dispatcher<DSRT_Scheduler_Traits>::~DSRT_Dispatcher()
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Makefile
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Makefile	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Makefile	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,11 +0,0 @@
-# Makefile,v 1.5 2003/08/11 06:34:35 jwillemsen Exp
-#       GNU Workspace
-include $(ACE_ROOT)/include/makeinclude/macros.GNU
-TARGETS_NESTED := $(TARGETS_NESTED:.nested=)
-$(TARGETS_NESTED):
-	@$(MAKE) -f Makefile.Kokyu -C . $(@);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Makefile.Kokyu
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Makefile.Kokyu	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Makefile.Kokyu	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,1002 +0,0 @@
-#Makefile.Kokyu,v 1.9 2004/01/05 02:42:23 bala Exp
-#       GNU Makefile
-MAKEFILE        = Makefile.Kokyu
-LIB_UNCHECKED   = libKokyu.a
-SHLIB_UNCHECKED = libKokyu.$(SOEXT)
-FILES = \
-  Dispatcher_Impl \
-  Kokyu \
-  Default_Dispatcher_Impl \
-  Dispatcher_Task \
-  Kokyu_defs
-LIB   = $(LIB_UNCHECKED)
-SHLIB = $(SHLIB_UNCHECKED)
-#       Include macros and targets
-ACE_SHLIBS  = $(ACELIB)
-include $(ACE_ROOT)/include/makeinclude/wrapper_macros.GNU
-LSRC   = $(addsuffix .cpp, $(FILES))
-include $(ACE_ROOT)/include/makeinclude/rules.common.GNU
-include $(ACE_ROOT)/include/makeinclude/rules.nonested.GNU
-include $(ACE_ROOT)/include/makeinclude/rules.lib.GNU
-include $(ACE_ROOT)/include/makeinclude/rules.local.GNU
-CPPFLAGS     += -I..
-LDFLAGS      += -L../ace
-#       Local targets
-#       Dependencies
-# DO NOT DELETE THIS LINE -- g++dep uses it.
-# DO NOT PUT ANYTHING AFTER THIS LINE, IT WILL GO AWAY.
-.obj/Dispatcher_Impl.o .obj/Dispatcher_Impl.so .shobj/Dispatcher_Impl.o .shobj/Dispatcher_Impl.so: Dispatcher_Impl.cpp Dispatcher_Impl.h \
-  $(ACE_ROOT)/ace/pre.h \
-  Kokyu_defs.h \
-  $(ACE_ROOT)/ace/Array.h \
-  $(ACE_ROOT)/ace/Containers_T.h \
-  $(ACE_ROOT)/ace/config-all.h \
-  $(ACE_ROOT)/ace/config.h \
-  $(ACE_ROOT)/ace/$(ACE_PLATFORM_CONFIG) \
-  $(ACE_ROOT)/ace/post.h \
-  $(ACE_ROOT)/ace/ace_wchar.h \
-  $(ACE_ROOT)/ace/ace_wchar.inl \
-  $(ACE_ROOT)/ace/OS_main.h \
-  $(ACE_ROOT)/ace/ACE_export.h \
-  $(ACE_ROOT)/ace/Containers.h \
-  $(ACE_ROOT)/ace/Containers.i \
-  $(ACE_ROOT)/ace/Node.h \
-  $(ACE_ROOT)/ace/Node.cpp \
-  $(ACE_ROOT)/ace/Array_Base.h \
-  $(ACE_ROOT)/ace/Global_Macros.h \
-  $(ACE_ROOT)/ace/OS_Errno.h \
-  $(ACE_ROOT)/ace/os_include/os_errno.h \
-  $(ACE_ROOT)/ace/OS_Errno.inl \
-  $(ACE_ROOT)/ace/Malloc_Base.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_types.h \
-  $(ACE_ROOT)/ace/os_include/os_stddef.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_mman.h \
-  $(ACE_ROOT)/ace/Array_Base.inl \
-  $(ACE_ROOT)/ace/Array_Base.cpp \
-  $(ACE_ROOT)/ace/Unbounded_Set.h \
-  $(ACE_ROOT)/ace/Unbounded_Set.inl \
-  $(ACE_ROOT)/ace/Unbounded_Set.cpp \
-  $(ACE_ROOT)/ace/Log_Msg.h \
-  $(ACE_ROOT)/ace/Default_Constants.h \
-  $(ACE_ROOT)/ace/Log_Priority.h \
-  $(ACE_ROOT)/ace/os_include/os_limits.h \
-  $(ACE_ROOT)/ace/os_include/os_unistd.h \
-  $(ACE_ROOT)/ace/os_include/os_inttypes.h \
-  $(ACE_ROOT)/ace/os_include/os_stdint.h \
-  $(ACE_ROOT)/ace/os_include/os_stdio.h \
-  $(ACE_ROOT)/ace/os_include/os_stdarg.h \
-  $(ACE_ROOT)/ace/OS_Log_Msg_Attributes.h \
-  $(ACE_ROOT)/ace/iosfwd.h \
-  $(ACE_ROOT)/ace/OS_Log_Msg_Attributes.inl \
-  $(ACE_ROOT)/ace/Unbounded_Queue.h \
-  $(ACE_ROOT)/ace/Unbounded_Queue.inl \
-  $(ACE_ROOT)/ace/Unbounded_Queue.cpp \
-  $(ACE_ROOT)/ace/Containers_T.i \
-  $(ACE_ROOT)/ace/Containers_T.cpp \
-  $(ACE_ROOT)/ace/OS_Memory.h \
-  $(ACE_ROOT)/ace/OS_NS_stdlib.h \
-  $(ACE_ROOT)/ace/os_include/os_stdlib.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_wait.h \
-  $(ACE_ROOT)/ace/os_include/os_signal.h \
-  $(ACE_ROOT)/ace/os_include/os_time.h \
-  $(ACE_ROOT)/ace/os_include/os_ucontext.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_resource.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_time.h \
-  $(ACE_ROOT)/ace/OS_NS_stdlib.inl \
-  $(ACE_ROOT)/ace/Object_Manager_Base.h \
-  $(ACE_ROOT)/ace/Cleanup.h \
-  $(ACE_ROOT)/ace/Cleanup.inl \
-  $(ACE_ROOT)/ace/Object_Manager_Base.inl \
-  $(ACE_ROOT)/ace/OS_NS_string.h \
-  $(ACE_ROOT)/ace/Basic_Types.h \
-  $(ACE_ROOT)/ace/os_include/os_float.h \
-  $(ACE_ROOT)/ace/Basic_Types.i \
-  $(ACE_ROOT)/ace/OS_NS_string.inl \
-  $(ACE_ROOT)/ace/OS_NS_wchar.h \
-  $(ACE_ROOT)/ace/os_include/os_wchar.h \
-  $(ACE_ROOT)/ace/os_include/os_string.h \
-  $(ACE_ROOT)/ace/os_include/os_ctype.h \
-  $(ACE_ROOT)/ace/OS_NS_wchar.inl \
-  $(ACE_ROOT)/ace/os_include/os_search.h \
-  $(ACE_ROOT)/ace/OS_Memory.inl \
-  $(ACE_ROOT)/ace/Time_Value.h \
-  $(ACE_ROOT)/ace/Time_Value.inl \
-  $(ACE_ROOT)/ace/OS_NS_sys_time.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_time.inl \
-  $(ACE_ROOT)/ace/Auto_Ptr.h \
-  $(ACE_ROOT)/ace/Auto_Ptr.i \
-  $(ACE_ROOT)/ace/Auto_Ptr.cpp \
-  $(ACE_ROOT)/ace/Message_Block.h \
-  $(ACE_ROOT)/ace/Message_Block.i \
-  $(ACE_ROOT)/ace/Message_Block_T.h \
-  $(ACE_ROOT)/ace/Message_Block_T.i \
-  $(ACE_ROOT)/ace/Message_Block_T.cpp \
-  $(ACE_ROOT)/ace/Sched_Params.h \
-  $(ACE_ROOT)/ace/OS_NS_Thread.h \
-  $(ACE_ROOT)/ace/os_include/os_pthread.h \
-  $(ACE_ROOT)/ace/Base_Thread_Adapter.h \
-  $(ACE_ROOT)/ace/Base_Thread_Adapter.inl \
-  $(ACE_ROOT)/ace/os_include/sys/os_sem.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_ipc.h \
-  $(ACE_ROOT)/ace/os_include/os_semaphore.h \
-  $(ACE_ROOT)/ace/OS_NS_signal.h \
-  $(ACE_ROOT)/ace/OS_NS_signal.inl \
-  $(ACE_ROOT)/ace/OS_NS_macros.h \
-  $(ACE_ROOT)/ace/OS_NS_errno.h \
-  $(ACE_ROOT)/ace/OS_NS_errno.inl \
-  $(ACE_ROOT)/ace/OS_NS_Thread.inl \
-  $(ACE_ROOT)/ace/OS_NS_sys_mman.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_mman.inl \
-  $(ACE_ROOT)/ace/OS_NS_fcntl.h \
-  $(ACE_ROOT)/ace/os_include/os_fcntl.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_stat.h \
-  $(ACE_ROOT)/ace/OS_NS_fcntl.inl \
-  $(ACE_ROOT)/ace/OS_NS_unistd.h \
-  $(ACE_ROOT)/ace/OS_NS_unistd.inl \
-  $(ACE_ROOT)/ace/OS_NS_sys_utsname.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_utsname.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_utsname.inl \
-  $(ACE_ROOT)/ace/OS_NS_stdio.h \
-  $(ACE_ROOT)/ace/OS_NS_stdio.inl \
-  $(ACE_ROOT)/ace/OS_NS_pwd.h \
-  $(ACE_ROOT)/ace/os_include/os_pwd.h \
-  $(ACE_ROOT)/ace/OS_NS_pwd.inl \
-  $(ACE_ROOT)/ace/Sched_Params.i \
-  $(ACE_ROOT)/ace/Malloc_Allocator.h \
-  $(ACE_ROOT)/ace/Malloc_Allocator.i \
-  kokyu_export.h Kokyu_defs.i Dispatcher_Impl.i
-.obj/Kokyu.o .obj/Kokyu.so .shobj/Kokyu.o .shobj/Kokyu.so: Kokyu.cpp Kokyu.h \
-  $(ACE_ROOT)/ace/Copy_Disabled.h \
-  kokyu_export.h \
-  Kokyu_defs.h \
-  Kokyu_defs.i Dispatcher_Impl.h Dispatcher_Impl.i Kokyu.i \
-  Default_Dispatcher_Impl.h \
-  $(ACE_ROOT)/ace/Task.h \
-  $(ACE_ROOT)/ace/Service_Object.h \
-  $(ACE_ROOT)/ace/Shared_Object.h \
-  $(ACE_ROOT)/ace/Shared_Object.i \
-  $(ACE_ROOT)/ace/Svc_Conf_Tokens.h \
-  $(ACE_ROOT)/ace/Event_Handler.h \
-  $(ACE_ROOT)/ace/Atomic_Op.h \
-  $(ACE_ROOT)/ace/Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Thread_Mutex.inl \
-  $(ACE_ROOT)/ace/Atomic_Op_T.h \
-  $(ACE_ROOT)/ace/Atomic_Op_T.i \
-  $(ACE_ROOT)/ace/Guard_T.h \
-  $(ACE_ROOT)/ace/Lock.h \
-  $(ACE_ROOT)/ace/Lock.inl \
-  $(ACE_ROOT)/ace/Guard_T.inl \
-  $(ACE_ROOT)/ace/RW_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/RW_Mutex.h \
-  $(ACE_ROOT)/ace/RW_Mutex.inl \
-  $(ACE_ROOT)/ace/RW_Thread_Mutex.inl \
-  $(ACE_ROOT)/ace/Guard_T.cpp \
-  $(ACE_ROOT)/ace/Atomic_Op_T.cpp \
-  $(ACE_ROOT)/ace/Atomic_Op.i \
-  $(ACE_ROOT)/ace/Synch_Traits.h \
-  $(ACE_ROOT)/ace/Event_Handler.i \
-  $(ACE_ROOT)/ace/DLL.h \
-  $(ACE_ROOT)/ace/os_include/os_dlfcn.h \
-  $(ACE_ROOT)/ace/Service_Object.i \
-  $(ACE_ROOT)/ace/Thread_Manager.h \
-  $(ACE_ROOT)/ace/Thread.h \
-  $(ACE_ROOT)/ace/Thread_Adapter.h \
-  $(ACE_ROOT)/ace/Thread_Adapter.inl \
-  $(ACE_ROOT)/ace/Thread.i \
-  $(ACE_ROOT)/ace/Thread_Exit.h \
-  $(ACE_ROOT)/ace/Thread_Control.h \
-  $(ACE_ROOT)/ace/Thread_Control.inl \
-  $(ACE_ROOT)/ace/Condition_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Condition_Thread_Mutex.inl \
-  $(ACE_ROOT)/ace/Free_List.h \
-  $(ACE_ROOT)/ace/Free_List.i \
-  $(ACE_ROOT)/ace/Free_List.cpp \
-  $(ACE_ROOT)/ace/Singleton.h \
-  $(ACE_ROOT)/ace/TSS_T.h \
-  $(ACE_ROOT)/ace/TSS_T.inl \
-  $(ACE_ROOT)/ace/TSS_T.cpp \
-  $(ACE_ROOT)/ace/Singleton.i \
-  $(ACE_ROOT)/ace/Singleton.cpp \
-  $(ACE_ROOT)/ace/Object_Manager.h \
-  $(ACE_ROOT)/ace/Recursive_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Recursive_Thread_Mutex.inl \
-  $(ACE_ROOT)/ace/Static_Object_Lock.h \
-  $(ACE_ROOT)/ace/Object_Manager.i \
-  $(ACE_ROOT)/ace/Managed_Object.h \
-  $(ACE_ROOT)/ace/Managed_Object.i \
-  $(ACE_ROOT)/ace/Managed_Object.cpp \
-  $(ACE_ROOT)/ace/Framework_Component.h \
-  $(ACE_ROOT)/ace/Framework_Component.inl \
-  $(ACE_ROOT)/ace/ACE.h \
-  $(ACE_ROOT)/ace/Flag_Manip.h \
-  $(ACE_ROOT)/ace/Flag_Manip.i \
-  $(ACE_ROOT)/ace/Handle_Ops.h \
-  $(ACE_ROOT)/ace/Handle_Ops.i \
-  $(ACE_ROOT)/ace/Lib_Find.h \
-  $(ACE_ROOT)/ace/Lib_Find.i \
-  $(ACE_ROOT)/ace/Init_ACE.h \
-  $(ACE_ROOT)/ace/Init_ACE.i \
-  $(ACE_ROOT)/ace/Sock_Connect.h \
-  $(ACE_ROOT)/ace/os_include/netinet/os_in.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_socket.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_uio.h \
-  $(ACE_ROOT)/ace/Sock_Connect.i \
-  $(ACE_ROOT)/ace/ACE.i \
-  $(ACE_ROOT)/ace/OS_NS_sys_socket.h \
-  $(ACE_ROOT)/ace/os_include/net/os_if.h \
-  $(ACE_ROOT)/ace/OS_NS_stropts.h \
-  $(ACE_ROOT)/ace/os_include/os_stropts.h \
-  $(ACE_ROOT)/ace/OS_NS_stropts.inl \
-  $(ACE_ROOT)/ace/OS_QoS.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_socket.inl \
-  $(ACE_ROOT)/ace/OS_NS_sys_uio.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_uio.inl \
-  $(ACE_ROOT)/ace/Framework_Component_T.h \
-  $(ACE_ROOT)/ace/Framework_Component_T.inl \
-  $(ACE_ROOT)/ace/Framework_Component_T.cpp \
-  $(ACE_ROOT)/ace/Thread_Manager.i \
-  $(ACE_ROOT)/ace/Task.i \
-  $(ACE_ROOT)/ace/Task_T.h \
-  $(ACE_ROOT)/ace/Message_Queue.h \
-  $(ACE_ROOT)/ace/IO_Cntl_Msg.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.i \
-  $(ACE_ROOT)/ace/Message_Queue_T.cpp \
-  $(ACE_ROOT)/ace/Notification_Strategy.h \
-  $(ACE_ROOT)/ace/Notification_Strategy.inl \
-  $(ACE_ROOT)/ace/Message_Queue.i \
-  $(ACE_ROOT)/ace/Task_T.i \
-  $(ACE_ROOT)/ace/os_include/os_assert.h \
-  $(ACE_ROOT)/ace/Task_T.cpp \
-  $(ACE_ROOT)/ace/Module.h \
-  $(ACE_ROOT)/ace/os_include/os_dirent.h \
-  $(ACE_ROOT)/ace/Module.i \
-  $(ACE_ROOT)/ace/Module.cpp \
-  $(ACE_ROOT)/ace/Stream_Modules.h \
-  $(ACE_ROOT)/ace/Stream_Modules.cpp \
-  $(ACE_ROOT)/ace/Null_Condition.h \
-  $(ACE_ROOT)/ace/Null_Mutex.h \
-  Dispatcher_Task.h \
-  $(ACE_ROOT)/ace/Lock_Adapter_T.h \
-  $(ACE_ROOT)/ace/Lock_Adapter_T.inl \
-  $(ACE_ROOT)/ace/Lock_Adapter_T.cpp \
-  Dispatcher_Task.i Default_Dispatcher_Impl.i
-.obj/Default_Dispatcher_Impl.o .obj/Default_Dispatcher_Impl.so .shobj/Default_Dispatcher_Impl.o .shobj/Default_Dispatcher_Impl.so: Default_Dispatcher_Impl.cpp \
-  kokyu_export.h Kokyu_defs.h \
-  Kokyu_defs.i Dispatcher_Impl.h Dispatcher_Impl.i Dispatcher_Task.h \
-.obj/Dispatcher_Task.o .obj/Dispatcher_Task.so .shobj/Dispatcher_Task.o .shobj/Dispatcher_Task.so: Dispatcher_Task.cpp Dispatcher_Task.h \
-  Kokyu_defs.h \
-  kokyu_export.h Kokyu_defs.i Dispatcher_Task.i \
-  $(ACE_ROOT)/ace/Malloc_T.h \
-  $(ACE_ROOT)/ace/Malloc.h \
-  $(ACE_ROOT)/ace/Malloc.i \
-  $(ACE_ROOT)/ace/Memory_Pool.h \
-  $(ACE_ROOT)/ace/Signal.h \
-  $(ACE_ROOT)/ace/Signal.i \
-  $(ACE_ROOT)/ace/Mem_Map.h \
-  $(ACE_ROOT)/ace/Mem_Map.i \
-  $(ACE_ROOT)/ace/SV_Semaphore_Complex.h \
-  $(ACE_ROOT)/ace/SV_Semaphore_Simple.h \
-  $(ACE_ROOT)/ace/SV_Semaphore_Simple.i \
-  $(ACE_ROOT)/ace/SV_Semaphore_Complex.i \
-  $(ACE_ROOT)/ace/Memory_Pool.i \
-  $(ACE_ROOT)/ace/Malloc_T.i \
-  $(ACE_ROOT)/ace/Malloc_T.cpp
-.obj/Kokyu_defs.o .obj/Kokyu_defs.so .shobj/Kokyu_defs.o .shobj/Kokyu_defs.so: Kokyu_defs.cpp Kokyu_defs.h \
-# IF YOU PUT ANYTHING HERE IT WILL GO AWAY
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Makefile.Kokyu.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Makefile.Kokyu.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Makefile.Kokyu.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,67 +0,0 @@
-# Makefile.Kokyu.bor,v 1.2 2003/12/21 09:45:02 jwillemsen Exp
-# Makefile for building the Kokyu library with Borland C++ Builder
-NAME = Kokyu
-OBJFILES = \
-	$(OBJDIR)\Default_Dispatcher_Impl.obj \
-	$(OBJDIR)\Dispatcher_Impl.obj \
-	$(OBJDIR)\Dispatcher_Task.obj \
-	$(OBJDIR)\Kokyu.obj \
-	$(OBJDIR)\Kokyu_defs.obj
-EXTERNAL_LIBS =
-LFLAGS = \
-	-L..\ace\$(CONFIG_SUBDIR) -L..\ace \
-  -L$(CORE_BINDIR)
-LIBFILES = \
-	ACE$(LIB_DECORATOR).lib \
-	$(EXTERNAL_LIBS)
-!ifdef STATIC
-LIB_FLAGS = -DACE_AS_STATIC_LIBS=1
-DLL_FLAGS =
-!else
-LIB_FLAGS =
-DLL_FLAGS = -DKOKYU_BUILD_DLL=1
-!endif
-CFLAGS = \
-	-I.. \
-	$(LIB_FLAGS) \
-	$(DLL_FLAGS)
-CPPDIR = .
-INCLUDES = \
-	DSRT_Direct_Dispatcher_Impl_T.h \
-	DSRT_Dispatch_Item_T.h \
-	DSRT_Dispatcher_Impl_T.h \
-	DSRT_Sched_Queue_T.h \
-	Dispatcher_Impl.h \
-	Kokyu.h \
-	Kokyu_defs.h \
-	Kokyu_dsrt.h \
-	DSRT_Direct_Dispatcher_Impl_T \
-	DSRT_Dispatch_Item_T \
-	DSRT_Dispatcher_Impl_T \
-	DSRT_Sched_Queue_T \
-	Kokyu_dsrt \
-	DSRT_Dispatch_Item_T.i \
-	DSRT_Dispatcher_Impl_T.i \
-	Default_Dispatcher_Impl.i \
-	Dispatcher_Impl.i \
-	Dispatcher_Task.i \
-	Kokyu.i \
-	Kokyu_defs.i \
-	Kokyu_dsrt.i
-BASE_BINDIR = ..\bin
-!include <$(ACE_ROOT)\include\makeinclude\build_library.bor>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Makefile.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Makefile.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/Makefile.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,23 +0,0 @@
-# Makefile.bor,v 1.2 2003/12/21 09:45:02 jwillemsen Exp
-#       Borland Workspace
-!include <$(ACE_ROOT)\include\makeinclude\make_flags.bor>
-all:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.Kokyu.bor all
-clean:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.Kokyu.bor clean
-realclean:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.Kokyu.bor realclean
-install:
-	$(MAKE) -$(MAKEFLAGS) $(MAKE_FLAGS) -f Makefile.Kokyu.bor install
-regenerate:
-	perl /home/venkita/DSRT_work/ACE_wrappers/bin/mwc.pl -type borland Kokyu.mwc
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/README
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/README	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/README	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,22 +0,0 @@
-# $Id:
-Kokyu is a portable middleware scheduling framework designed to
-provide flexible scheduling and dispatching services within the
-context of higher-level middleware. Kokyu currently provides real-time
-scheduling and dispatching services for TAO's real-time Event Service
-which mediates supplier-consumer relationships between application
-operations. Kokyu also provides a scheduling and dispatching framework
-for threads. This is being used by the TAO RTCORBA 2.0 scheduler
-implementations. For more information, see
-ACE_wrappers/Kokyu/docs/Kokyu.html
-To build Kokyu on Unix systems, from under $ACE_ROOT/Kokyu do
-make
-To build Kokyu on Windows, open the workspace
-$ACE_ROOT/Kokyu/Kokyu.dsw and build it.
-An mpc file has also been provided - $ACE_ROOT/Kokyu/Kokyu.mpc from
-which IDE specific build files can be generated.
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/docs/Kokyu.html
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/docs/Kokyu.html	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/docs/Kokyu.html	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,416 +0,0 @@
-<!-- Kokyu.html,v 1.1 2003/10/20 01:41:09 venkita Exp -->
-<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
-<html>
-<head>
-   <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
-   <meta name="Author" content="Venkita Subramonian">
-   <meta name="GENERATOR" content="Mozilla/4.79 [en] (Windows NT 5.0; U) [Netscape]">
-   <title>Kokyu</title>
-</head>
-<body>
-<center>
-<h2>
-<b><font size=+2>Kokyu - A middleware framework for flexible scheduling
-and dispatching</font></b></h2></center>
-<a href="#Introduction">Introduction</a>
-<br><a href="#SchedFramework">Strategized Scheduling framework</a>
-<br><a href="#FlexDispatch">Flexible Dispatching Framework</a>
-<br><a href="#KokyuEC">Use of Kokyu within the TAO Real-time Event Channel(RTEC)</a>
-<br><a href="#ConfigKokyuEC">Configuration of RTEC to use Kokyu dispatching</a>
-<br><a href="#KokyuDSRTCORBA">Use of Kokyu within the Dynamic Scheduling
-Real-time CORBA (DSRTCORBA) schedulers</a>
-<br><a href="#newDSRTSched">How to write a new DSRT scheduler using Kokyu</a>
-<br><a href="#DSRTCORBAvsRTEC">Kokyu DSRTCORBA vs Kokyu RTEC</a>
-<br><a href="#Status">Current status</a>
-<br><a href="#Future">Future work</a>
-<br><a href="#Papers">Papers on Kokyu</a>
-<br>&nbsp;
-<h3>
-<a NAME="Introduction"></a>Introduction</h3>
-Kokyu is a portable middleware scheduling framework designed to provide
-flexible scheduling and dispatching services within the context of higher-level
-middleware. Kokyu currently provides real-time scheduling and dispatching
-services for TAO’s real-time CORBA Event Service, which mediates supplier-consumer
-relationships between application operations. Kokyu consists primarily
-of two cooperating infrastructure segments, illustrated in Figure 1:
-<center>
-<p><img SRC="kokyu1.jpg" height=285 width=489>
-<br><b>Figure 1: Kokyu Scheduling and Dispatching Infrastructure</b></center>
-<ol>
-<li>
-A pluggable scheduling infrastructure with efficient support for adaptive
-execution of diverse static, dynamic, and hybrid static/dynamic scheduling
-heuristics.</li>
-<li>
-A flexible dispatching infrastructure that allows composition of primitive
-operating system and middleware mechanisms to enforce arbitrary scheduling
-heuristics.</li>
-</ol>
-The scheduler is responsible for specifying how operation dispatch requests
-are ordered, by assigning priority levels and rates to tasks, and producing
-a configuration specification for the dispatching mechanism. The dispatcher
-is responsible for enforcing the ordering of operation dispatches using
-different threads, requests queues, and timers configured according to
-the scheduler’s specification. The combined framework provides an implicit
-projection of scheduling heuristics into appropriate dispatching infrastructure
-configurations, so that the scheduling and dispatching infrastructure segments
-can be optimized both separately and in combination.
-<h3>
-<a NAME="SchedFramework"></a>Strategized Scheduling framework</h3>
-The Kokyu scheduling framework is designed to support a variety of scheduling
-heuristics including RMS, EDF, MLF, and MUF. In addition, this framework
-provides a common environment to compare systematically both existing and
-new scheduling strategies. This flexibility is achieved in the Kokyu framework
-via the Strategy pattern, which allows parts of the sequence of steps in
-an algorithm to be replaced, thus providing interchangeable variations
-within a consistent algorithmic framework. The Kokyu scheduling framework
-uses the Strategy pattern to encapsulate a family of scheduling algorithms
-within a fixed CORBA IDL interface, thereby enabling different strategies
-to be configured independently from applications that use them.
-<h3>
-<a NAME="FlexDispatch"></a>Flexible Dispatching Framework</h3>
-The right side of Figure 1 shows the essential features of Kokyu’s flexible
-task dispatching infrastructure. Key features of the dispatching infrastructure
-that are essential to performing our optimizations are as follows:
-<p><b>Dispatching queues:</b> Each task is assigned by our strategized
-Kokyu scheduling framework&nbsp; to a specific dispatching queue, each
-of which has an associated queue number, a queueing discipline, and a unique
-operating-system-specific priority for its single associated dispatching
-thread.
-<p><b>Dispatching threads:</b> Operating-system thread priorities decrease
-as the queue number increases, so that the 0th queue is served by the highest
-priority thread. Each dispatching thread removes the task from the head
-of its queue and runs its entry point function to completion before retrieving
-the next task to dispatch. Adapters can be applied to operations to intercept
-and possibly short-circuit the entry-point upcall. In general, however,
-the outermost operation entry point must complete on each dispatch.
-<p><b>Queueing disciplines: </b>Dispatching thread priorities determine
-which queue is active at any given time: the highest priority queue with
-a task to dispatch is always active, preempting tasks in lower priority
-queues. In addition, each queue may have a distinct discipline for determining
-which of its enqueued tasks has the highest eligibility, and must ensure
-the highest is at the head of the queue at the point when one is to be
-dequeued. We consider three disciplines:
-<ul>
-<li>
-Static – Tasks are ordered by a static subpriority value – results in FIFO
-ordering if all static subpriorities are made the same; static queues at
-different priority levels can be used to implement an RMS scheduling strategy.</li>
-<li>
-Deadline – Tasks are ordered by time to deadline; a single deadline queue
-can be used to implement the earliest deadline first (EDF) scheduling strategy.</li>
-<li>
-Laxity – Tasks are ordered by slack time, or laxity – the time to deadline
-minus the execution time; a single laxity queue can be used to implement
-the minimum laxity first (MLF) scheduling strategy; laxity queues at different
-priority levels can be used to implement the maximum urgency first (MUF)
-scheduling strategy.</li>
-</ul>
-Any discipline for which a maximal eligibility may be selected can be employed
-to manage a given dispatching queue in this approach. Scheduling strategies
-can be constructed from one or more queues of each discipline alone, or
-combinations of queues with different disciplines can be used. Figure 2&nbsp;
-illustrates the general queueing mechanism used by the dispatching modules
-in the Kokyu dispatching framework.
-<center>
-<p><img SRC="kokyu2.jpg" height=176 width=779>
-<p><b>Figure 2: Example Queueing Mechanism in a Kokyu Dispatching Module</b></center>
-<p>In addition, this figure shows how the output information provided by
-the Kokyu scheduling framework is used to configure and operate a dispatching
-module. During system initialization, each dispatching module obtains the
-thread priority and dispatching type for each of its queues, typically
-from the scheduling service’s output interface. Next, each queue is assigned
-a unique dispatching priority number, a unique thread priority, and an
-enumerated dispatching type. Finally, each dispatching module has an ordered
-queue of pending dispatches per dispatching priority. To preserve QoS guarantees,
-operations are inserted into the appropriate dispatching queue according
-to their assigned dispatching priority. Operations within a dispatching
-queue are ordered by their assigned dispatching subpriority. To minimize
-priority inversions, operations are dispatched from the queue with the
-highest thread priority, preempting any operation executing in a lower
-priority thread. To minimize preemption overhead, there is no preemption
-within a given priority queue. The following three values are defined for
-the dispatching type:
-<ul>
-<li>
-<b>STATIC DISPATCHING</b>: This type specifies a queue that only considers
-the static portion of an operation’s dispatching subpriority.</li>
-<li>
-<b>DEADLINE DISPATCHING</b>: This type specifies a queue that considers
-the dynamic and static portions of an operation’s dispatching subpriority,
-and updates the dynamic portion according to the time remaining until the
-operation’s deadline.</li>
-<li>
-<b>LAXITY DISPATCHING</b>: This type specifies a queue that considers the
-dynamic and static portions of an operation’s dispatching subpriority,
-and updates the dynamic portion according to the operation’s laxity.</li>
-</ul>
-<h3>
-<a NAME="KokyuEC"></a>Use of Kokyu within the TAO Real-time Event Channel(RTEC)</h3>
-Figure 3 shows the sequence of operations that take place in the Kokyu
-based dispatching module in the TAO RTEC. The client application registers
-all relevant operations with the scheduler along with their real-time requirements.
-This is done through the concept of an <font face="Courier New,Courier">RT_Info
-</font>(see
-TAO/orbsvcs/orbsvcs/RtecScheduler.idl) structure which is a structure that
-contains the execution time, criticality, period, etc of an operation.&nbsp;
-The client then calls <font face="Courier New,Courier">compute_schedule</font>
-method on the scheduler. The scheduler creates a dependency graphs of all
-operations and partitions operations into equivalence classes based on
-the scheduling parameters supplied. The scheduler can be configured to
-have any scheduling policy which determines the equivalence class partitioning
-(queues) and possibly a partial ordering of operations within an equivalence
-class (ordering within a queue). Once this is done, the scheduler has the
-configuration information for the Kokyu dispatcher like the number of dispatch
-queues, priorities for the threads processing each queue, etc.
-<p>When the client calls <font face="Courier New,Courier">activate</font>
-on the event channel, the EC inturn activates the Kokyu based EC dispatching
-module. The EC dispatching module queries the dispatch configuration from
-the scheduler and uses that to create the Kokyu dispatcher with the appropriate
-number of lanes and threads. When an event is pushed into the EC, the EC
-pushes the event to the appropriate consumers, who are subscribed to that
-event. For each consumer, the EC queries the scheduler for the RT_Info
-of that consumer. It then hands over the event to the Kokyu based dispatching
-module. The dispatching module then enqueues the event into the appropriate
-queue for processing by the thread watching that queue.
-<center>
-<p><img SRC="KokyuEC.jpg" height=784 width=716>
-<p><b>Figure 3: Kokyu based dispatching module within TAO RTEC</b></center>
-<h3>
-<a NAME="ConfigKokyuEC"></a>Configuration of RTEC to use Kokyu dispatching</h3>
-<b>Static configuration</b>: In the <b>svc.conf</b> file, make sure you
-have the following configuration for Kokyu dispatching. You can combine
-this with other -ECxxx options.
-<p><font face="Courier New,Courier">static EC_Factory "-ECdispatching kokyu
-SCHED_FIFO -ECscheduling kokyu -ECfiltering kokyu"</font>
-<p>To run the threads in the real-time FIFO class, use SCHED_FIFO. You
-could use SCHED_RR and SCHED_OTHER also.
-<br>The default is SCHED_FIFO.
-<p>In your program, call
-<p><font face="Courier New,Courier">TAO_EC_Kokyu_Factory::init_svcs ();</font>
-<p>to statically create the EC Kokyu dispatching and other Kokyu related
-modules.
-<p><b>Dynamic configuration</b>: In the <b>svc.conf</b> file, make sure
-you have the following configuration for Kokyu dispatching. You can combine
-<p><font face="Courier New,Courier">dynamic EC_Factory Service_Object *
-TAO_RTKokyuEvent:_make_TAO_EC_Kokyu_Factory() "-ECdispatching kokyu -ECscheduling
-kokyu -ECfiltering kokyu"</font>
-<h3>
-<a NAME="KokyuDSRTCORBA"></a>Use of Kokyu within the Dynamic Scheduling
-Real-time CORBA (DSRTCORBA) schedulers</h3>
-An initial implementation of mechanisms to support DSRTCORBA schedulers
-have been released. DSRTCORBA uses the concept of distributed threads,
-which traverse multiple end systems giving the application the illusion
-of a single logical thread executing an end-to-end task. The distributed
-thread carries with it the scheduling parameters like importance, deadline,
-etc so that it can get scheduled by a local scheduler on each endsystem.
-The Kokyu DSRT dispatching framework is used as an enforcing mechanism.
-<p>The DSRT schedulers are available in the directory $TAO_ROOT/examples/Kokyu_dsrt_schedulers.
-They use the Kokyu DSRT
-<br>dispatching classes present in $ACE_ROOT/Kokyu. These act as wrappers/adapters
-around the Kokyu DSRT dispatcher. The Kokyu DSRT dispatcher is responsible
-for scheduling threads which ask the dispatcher to schedule themselves.
-Currently there are two implementations for the Kokyu DSRT dispatcher.
-One uses a condition-variable based approach for scheduling threads and
-the other manipulates priorities of threads and relies on the OS scheduler
-for dispatching the threads appropriately.
-<h4>
-CV-based approach:</h4>
-In this approach, it is assumed that the threads "yield" on a regular basis
-to the scheduler by calling <tt>update_scheduling_segment</tt>. Only one
-thread is running at any point in time. All the other threads are blocked
-on a condition variable. When the currently running thread yields, it will
-cause the condition variable to be signalled. All the eligible threads
-are stored in a scheduler queue (rbtree), the most eligible thread determined
-by the scheduling discipline. This approach has the drawback that it requires
-a cooperative threading model, where threads yield voluntarily on a regular
-basis. The application threads are responsible for doing this voluntary
-yielding.
-<h4>
-OS-based approach:</h4>
-This approach relies on the OS scheduler to do the actual thread dispatching.
-The Kokyu DSRT dispatcher manipulates the priorities of the threads. The
-scheduler maintains a queue (rbtree) of threads. The scheduler also has
-an executive thread, which runs at the maximum available priority. This
-thread runs in a continuous loop until the dispatcher is shut down. The
-executive thread is responsible for selecting the most eligible thread
-from the scheduler queue and bump up its priority if necessary while bumping
-down the priority of the currently running thread, if it is not the most
-eligible. There are four priority levels required for this mechanism to
-work, listed in descending order of priorities. For example, a thread running
-at <i>Active</i> priority will preempt a
-<br>thread running at <i>Inactive</i> priority level.
-<ol>
-<li>
-Executive priority - priority at which the scheduler executive thread runs.</li>
-<li>
-Blocked priority - this is the priority to which threads about to block
-on remote calls will be bumped up to.</li>
-<li>
-Active priority - this is the priority to which the most eligible thread
-is set to.</li>
-<li>
-Inactive priority - this is the priority to which all threads except the
-most eligible thread is set to.</li>
-</ol>
-As soon as a thread asks to be scheduled, a wrapper object is created and
-inserted into the queue. This object carries the qos (sched params) associated
-with that thread. A condition variable is signalled to inform the executive
-thread that the queue is "dirty". The scheduler thread picks up the most
-eligble one and sets its priority to <i>active</i> and sets the currently
-running thread priority to
-<br><i>inactive</i>.
-<p>The drawback to this approach is that it relies on the OS scheduler
-to dispatch the threads. Also, with the current implementation, there is
-only one thread running at active priority and others are all at <i>inactive</i>
-level. This will create undesirable effects with multi-processor systems,
-which could select any one of the <i>inactive</i> level threads and this
-could cause priority inversions.
-<h3>
-<a NAME="newDSRTSched"></a>How to write a new DSRT scheduler using Kokyu</h3>
-One can use one of the schedulers as a starting point. The variation points
-are
-<ol>
-<li>
-The scheduler parameters that need to be propagated along with the service
-context.</li>
-<li>
-The QoS comparison function, that determines which thread is more eligible.</li>
-</ol>
-To aid (1), we have created a Svc_Ctxt_DSRT_QoS idl interface (see ./Kokyu_qos.pidl).
-This interface currently has the necessary things to be propagated for
-FP, MIF and MUF schedulers. This can be altered if necessary to accomodate
-new sched params. The idea here is to let the IDL compiler generate the
-marshalling code (including Any operators) so that these parameters can
-be shipped across in the service context in an encapsulated CDR.
-<p>To create customized QoS comparator functions, we used the idea of C++
-traits to let the user define customized comparator functions. For example,
-the MIF scheduler uses the following traits class.
-<p><tt>&nbsp; struct MIF_Scheduler_Traits</tt>
-<br><tt>&nbsp; {</tt>
-<br><tt>&nbsp;&nbsp;&nbsp; typedef RTScheduling::Current::IdType Guid_t;</tt>
-<p><tt>&nbsp;&nbsp;&nbsp; struct _QoSDescriptor_t</tt>
-<br><tt>&nbsp;&nbsp;&nbsp; {</tt>
-<br><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; typedef long Importance_t;</tt>
-<br><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Importance_t importance_;</tt>
-<br><tt>&nbsp;&nbsp;&nbsp; };</tt>
-<p><tt>&nbsp;&nbsp;&nbsp; typedef _QoSDescriptor_t QoSDescriptor_t;</tt>
-<p><tt>&nbsp;&nbsp;&nbsp; typedef Kokyu::MIF_Comparator&lt;QoSDescriptor_t>
-QoSComparator_t;</tt>
-<p><tt>&nbsp;&nbsp;&nbsp; class _Guid_Hash</tt>
-<br><tt>&nbsp;&nbsp;&nbsp; public:</tt>
-<br><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; u_long operator () (const Guid_t&amp;
-id)</tt>
-<br><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {</tt>
-<br><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; return ACE::hash_pjw
-((const char *) id.get_buffer (),</tt>
-<br><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
-id.length ());</tt>
-<br><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }</tt>
-<p><tt>&nbsp;&nbsp;&nbsp; typedef _Guid_Hash Guid_Hash;</tt>
-<br><tt>&nbsp; };</tt>
-<p>The idea of traits makes the Kokyu dispatcher more flexible in terms
-of creating new schedulers. For example, the Kokyu classes do not care
-about what concrete type Guid is. It could be an OctetSequence for some
-applications, whereas it could be an int for some others. The exact type
-is defined by the application (in this case, the MIF scheduler) using the
-traits class. In the above traits class the Guid's type is defined to be
-an octet sequence (indirectly). The Kokyu dispatcher expects the following
-typedef's to
-<br>be present in the traits class:
-<p><tt>Guid_t - </tt>Type of GUID.
-<br><tt>QoSDescriptor_t - </tt>aggregate for scheduler parameters
-<br><tt>QoSComparator_t - </tt>used by the scheduler queue to determine
-most eligible item
-<br><tt>Guid_Hash - </tt>used by the internal hash map in the scheduler
-to hash the guid.
-<p>It is also expected that the following operator be defined for comparing
-QoS parameters. This comparator function will be used by the scheduler
-queue to determine the most eligible item in the queue.
-<p><tt>QoSComparator_t::operator ()(const QoSDescriptor_t&amp; qos1,</tt>
-const QoSDescriptor_t&amp; qos2)</tt>
-<h3>
-<a NAME="DSRTCORBAvsRTEC"></a>Kokyu DSRTCORBA vs Kokyu RTEC</h3>
-Currently we have separate interfaces for DSRTCORBA and RTEC dispatching
-mechanisms. Once we get more use cases and experience, there is a possibility
-of these getting merged in the future. The RTEC related dispatching interface
-is in <tt>Kokyu::Dispatcher (Kokyu.h)</tt> and DSRTCORBA related dispatching
-interface is in <tt>Kokyu::DSRT_Dispatcher (Kokyu_dsrt.h)</tt>
-<h3>
-<a NAME="Status"></a>Current status</h3>
-Kokyu dispatching framework is available as a separate module under <tt><font size=+1>ACE_wrappers/Kokyu</font></tt>
-as part of the <a href="http://deuce.doc.wustl.edu/Download.html">ACE/TAO
-distribution</a>. Note that this module is not dependent on TAO, though
-it is built on top of ACE. The TAO Event Channel uses the Strategy and
-Service Configurator patterns to use configurable dispatching modules.
-A Kokyu based EC dispatching module is available in the <tt><font size=+1>TAO/orbsvcs/orbsvcs/RTKokyuEvent</font></tt>
-module. This module acts as an adapter between the Kokyu dispatcher and
-the RTEC.
-<p>Kokyu scheduling framework is available under the TAO source tree (<tt><font size=+1>TAO/orbsvcs/orbsvcs/Sched</font></tt>).
-<p>An example using the RTEC Kokyu dispatching module is available under
-<tt><font size=+1>TAO/orbsvcs/examples/RtEC/Kokyu</font></tt>.
-<h3>
-<a NAME="Future"></a>Future work</h3>
-<ol>
-<li>
-Currently there is no support for timers in the Kokyu dispatching module.
-We plan to do this in the near future.</li>
-<li>
-It looks like there is a general structure to the different schedulers.
-May be this can be abstracted using templates or some similar mechanism.</li>
-<li>
-Thread sched policy and sched scope are currently being passed explicitly
-from the application to the scheduler. This can be changed later to get
-this information from the ORB. This requires the usage of RTORB and the
-actual values can be set using svc.conf parameters for RT_ORB_Loader.</li>
-<br>&nbsp;
-<li>
-See whether the approaches could be extended to multiprocessor systems.</li>
-</ol>
-<h3>
-<a NAME="Papers"></a>Papers on Kokyu</h3>
-<ol>
-<li>
-Christopher D. Gill, <a href="http://www.cse.wustl.edu/~cdgill/PDF/cdgill_dissertation.pdf">Dissertation:Flexible
-Scheduling in Middleware for Distributed Rate-Based Real-Time Applications</a></li>
-<li>
-Christopher D. Gill, David L. Levine, and Douglas C. Schmidt <a href="http://www.cse.wustl.edu/~cdgill/PDF/dynamic.pdf">The
-Design and Performance of a Real-Time CORBA Scheduling Service</a>, Real-Time
-Systems: the International Journal of Time-Critical Computing Systems,
-special issue on Real-Time Middleware, guest editor Wei Zhao, March 2001,
-Vol. 20 No. 2</li>
-<li>
-Christopher D. Gill, Douglas C. Schmidt, and Ron Cytron, <a href="http://www.cs.wustl.edu/~schmidt/PDF/embedded_sched.pdf">Multi-Paradigm
-Scheduling for Distributed Real-Time Embedded Computing</a>, IEEE Proceedings
-Special Issue on Modeling and Design of Embedded Systems, Volume 91, Number
-1, January 2003.</li>
-</ol>
-</body>
-</html>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/kokyu_export.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/kokyu_export.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/kokyu_export.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,55 +0,0 @@
-// -*- C++ -*-
-// kokyu_export.h,v 1.2 2003/07/25 23:41:55 venkita Exp
-// Definition for Win32 Export directives.
-// This file is generated automatically by generate_export_file.pl Kokyu
-#ifndef KOKYU_EXPORT_H
-#define KOKYU_EXPORT_H
-#include "ace/config-all.h"
-#if defined (ACE_AS_STATIC_LIBS)
-#  if !defined (KOKYU_HAS_DLL)
-#    define KOKYU_HAS_DLL 0
-#  endif /* ! KOKYU_HAS_DLL */
-#else
-#    define KOKYU_HAS_DLL 1
-#endif
-#if defined (KOKYU_HAS_DLL) && (KOKYU_HAS_DLL == 1)
-#  if defined (KOKYU_BUILD_DLL)
-#    define Kokyu_Export ACE_Proper_Export_Flag
-#    define KOKYU_SINGLETON_DECLARATION(T) ACE_EXPORT_SINGLETON_DECLARATION (T)
-#    define KOKYU_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK) ACE_EXPORT_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK)
-#  else /* KOKYU_BUILD_DLL */
-#    define Kokyu_Export ACE_Proper_Import_Flag
-#    define KOKYU_SINGLETON_DECLARATION(T) ACE_IMPORT_SINGLETON_DECLARATION (T)
-#    define KOKYU_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK) ACE_IMPORT_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK)
-#  endif /* KOKYU_BUILD_DLL */
-#else /* KOKYU_HAS_DLL == 1 */
-#endif /* KOKYU_HAS_DLL == 1 */
-// Set KOKYU_NTRACE = 0 to turn on library specific tracing even if
-// tracing is turned off for ACE.
-#if !defined (KOKYU_NTRACE)
-#  if (ACE_NTRACE == 1)
-#    define KOKYU_NTRACE 1
-#  else /* (ACE_NTRACE == 1) */
-#    define KOKYU_NTRACE 0
-#  endif /* (ACE_NTRACE == 1) */
-#endif /* !KOKYU_NTRACE */
-#if (KOKYU_NTRACE == 1)
-#  define KOKYU_TRACE(X)
-#else /* (KOKYU_NTRACE == 1) */
-#  define KOKYU_TRACE(X) ACE_TRACE_IMPL(X)
-#endif /* (KOKYU_NTRACE == 1) */
-#endif /* KOKYU_EXPORT_H */
-// End of auto generated file.
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/DSRT_MIF.mpc
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/DSRT_MIF.mpc	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/DSRT_MIF.mpc	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,6 +0,0 @@
-//  -*- MPC -*-
-// DSRT_MIF.mpc,v 1.2 2003/11/10 04:31:59 dhinton Exp
-project: kokyu {
-  exename = MIF
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/MIF.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/MIF.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/MIF.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,252 +0,0 @@
-// MIF.cpp,v 1.13 2003/11/09 04:12:06 dhinton Exp
-#include "ace/Auto_Ptr.h"
-#include "ace/Task.h"
-#include "ace/Sched_Params.h"
-#include "ace/Atomic_Op.h"
-#include "ace/High_Res_Timer.h"
-#include "ace/Barrier.h"
-ACE_Atomic_Op<ACE_SYNCH_MUTEX, long> guid=0;
-struct mif_scheduler_traits
-  typedef int Guid_t;
-  struct QoSDescriptor_t
-    typedef long Importance_t;
-    long importance_;
-  static Time_t now()
-    ACE_Time_Value now = ACE_OS::gettimeofday ();
-    return now.sec () * 10000000 + now.usec () * 10;
-  typedef Kokyu::MIF_Comparator<QoSDescriptor_t> QoSComparator_t;
-  struct Guid_Hash
-    u_long operator () (const Guid_t& guid)
-      return guid;
-class MyTask : public ACE_Task_Base
-public:
-  MyTask (ACE_Barrier& barrier,
-          Kokyu::DSRT_Dispatcher<mif_scheduler_traits>* dispatcher,
-          mif_scheduler_traits::QoSDescriptor_t& qos,
-          int exec_duration)
-    :barrier_ (barrier),
-     dispatcher_ (dispatcher),
-     qos_ (qos),
-     guid_ (++guid),
-     exec_duration_ (exec_duration)
-  int svc (void);
- private:
-  ACE_Barrier& barrier_;
-  Kokyu::DSRT_Dispatcher<mif_scheduler_traits>* dispatcher_;
-  mif_scheduler_traits::QoSDescriptor_t qos_;
-  mif_scheduler_traits::Guid_t guid_;
-  int exec_duration_;
-int MyTask::svc (void)
-  ACE_hthread_t thr_handle;
-  ACE_Thread::self (thr_handle);
-  int prio;
-  ACE_DEBUG ((LM_DEBUG, "(%t|%T): task activated\n"));
-  ACE_ASSERT (dispatcher_ != 0);
-  prio = dispatcher_->schedule (guid_, qos_);
-  barrier_.wait ();
-  long prime_number = 9619899;
-  ACE_High_Res_Timer timer;
-  ACE_Time_Value elapsed_time;
-  ACE_Time_Value seconds_tracker(0,0);
-  ACE_Time_Value one_second (1,0);
-  ACE_Time_Value compute_count_down_time (exec_duration_, 0);
-  ACE_Countdown_Time compute_count_down (&compute_count_down_time);
-  timer.start ();
-  while (compute_count_down_time > ACE_Time_Value::zero)
-      ACE::is_prime (prime_number,
-                     2,
-                     prime_number / 2);
-      compute_count_down.update ();
-      timer.stop ();
-      timer.elapsed_time (elapsed_time);
-      seconds_tracker += elapsed_time;
-      if (seconds_tracker >= one_second)
-        seconds_tracker.set (0,0);
-                    ACE_TEXT ("(%t) Currently running guid=%d")
-                    ACE_TEXT (", qos_.importance=%d \n"),
-                    guid_, qos_.importance_));
-      timer.reset ();
-      timer.start ();
-  dispatcher_->cancel_schedule (this->guid_);
-  return 0;
-int main (int,char**)
-  Kokyu::DSRT_ConfigInfo config_info;
-  //  config_info.scheduler_type_ = Kokyu::SCHED_MIF;
-  config_info.impl_type_ = Kokyu::DSRT_OS_BASED;
-  ACE_Barrier barrier (3);
-  ACE_DEBUG ((LM_DEBUG, "before create_dispatcher\n" ));
-  config_info.sched_strategy_ = Kokyu::DSRT_MIF;
-  Kokyu::DSRT_Dispatcher_Factory<mif_scheduler_traits>::DSRT_Dispatcher_Auto_Ptr
-    disp (Kokyu::DSRT_Dispatcher_Factory<mif_scheduler_traits>::
-          create_DSRT_dispatcher (config_info));
-  ACE_DEBUG ((LM_DEBUG, "after create_dispatcher\n" ));
-  ACE_ASSERT (disp.get () != 0);
-  mif_scheduler_traits::QoSDescriptor_t qos1, qos2, qos3;
-  qos1.importance_ = 1;
-  qos2.importance_ = 2;
-  qos3.importance_ = 3;
-  MyTask mytask1 (barrier, disp.get (), qos1, 15);
-  MyTask mytask2 (barrier, disp.get (), qos2, 6);
-  MyTask mytask3 (barrier, disp.get (), qos3, 4);
-  long flags = THR_BOUND | THR_SCHED_FIFO;
-  if (mytask1.activate (flags) == -1)
-      flags = THR_BOUND;
-        ACE_ERROR ((LM_ERROR,
-                        "EC (%P|%t) cannot activate task\n"));
-  if (mytask2.activate (flags) == -1)
-  if (mytask3.activate (flags) == -1)
-  disp->shutdown ();
-  ACE_DEBUG ((LM_DEBUG, "main thread exiting\n"));
-  return 0;
-#if defined (ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION)
-template class Kokyu::DSRT_Dispatcher_Factory<mif_scheduler_traits>;
-template class Kokyu::DSRT_Dispatcher<mif_scheduler_traits>;
-template class Kokyu::DSRT_Dispatcher_Impl<mif_scheduler_traits>;
-template class Kokyu::DSRT_Direct_Dispatcher_Impl<mif_scheduler_traits>;
-template class Kokyu::DSRT_CV_Dispatcher_Impl<mif_scheduler_traits>;
-template class ACE_Lock_Adapter<ACE_Thread_Mutex>;
-template class Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>;
-template class Kokyu::Comparator_Adapter_Generator<mif_scheduler_traits>;
-template class Kokyu::Sched_Ready_Queue<mif_scheduler_traits, Kokyu::Comparator_Adapter_Generator<mif_scheduler_traits>::MoreEligible, ACE_Null_Mutex>;
-template class ACE_Hash_Map_Manager_Ex<int, ACE_RB_Tree_Node<Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits> > *, Kokyu::Sched_Ready_Queue<mif_scheduler_traits, Kokyu::Comparator_Adapter_Generator<mif_scheduler_traits>::MoreEligible, ACE_Null_Mutex>::Guid_Hash, ACE_Equal_To<int>, ACE_Null_Mutex>;
-template class ACE_RB_Tree<Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::Comparator_Adapter_Generator<mif_scheduler_traits>::MoreEligible, ACE_Null_Mutex>;
-template class ACE_RB_Tree_Iterator<Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::Comparator_Adapter_Generator<mif_scheduler_traits>::MoreEligible, ACE_Null_Mutex>;
-template class ACE_Hash_Map_Entry<int, ACE_RB_Tree_Node<Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits> > *>;
-template class ACE_RB_Tree_Node<Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits> >;
-template class Kokyu::MIF_Comparator<mif_scheduler_traits::QoSDescriptor_t>;
-template class ACE_Hash_Map_Iterator_Base_Ex<int, ACE_RB_Tree_Node<Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits> > *, Kokyu::Sched_Ready_Queue<mif_scheduler_traits, Kokyu::Comparator_Adapter_Generator<mif_scheduler_traits>::MoreEligible, ACE_Null_Mutex>::Guid_Hash, ACE_Equal_To<int>, ACE_Null_Mutex>;
-template class ACE_RB_Tree_Reverse_Iterator<Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::Comparator_Adapter_Generator<mif_scheduler_traits>::MoreEligible, ACE_Null_Mutex>;
-template class ACE_RB_Tree_Iterator_Base<Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::Comparator_Adapter_Generator<mif_scheduler_traits>::MoreEligible, ACE_Null_Mutex>;
-template class ACE_Array_Iterator<Kokyu::ConfigInfo>;
-#elif defined(ACE_HAS_TEMPLATE_INSTANTIATION_PRAGMA)
-#pragma instantiate Kokyu::DSRT_Dispatcher_Factory<mif_scheduler_traits>
-#pragma instantiate Kokyu::DSRT_Dispatcher<mif_scheduler_traits>
-#pragma instantiate Kokyu::DSRT_Dispatcher_Impl<mif_scheduler_traits>
-#pragma instantiate Kokyu::DSRT_Direct_Dispatcher_Impl<mif_scheduler_traits>
-#pragma instantiate Kokyu::DSRT_CV_Dispatcher_Impl<mif_scheduler_traits>
-#pragma instantiate Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>
-#pragma instantiate Kokyu::Comparator_Adapter_Generator<mif_scheduler_traits>
-#pragma instantiate Kokyu::Sched_Ready_Queue<mif_scheduler_traits, Kokyu::Comparator_Adapter_Generator<mif_scheduler_traits>::MoreEligible, ACE_Null_Mutex>
-#pragma instantiate ACE_Lock_Adapter<ACE_Thread_Mutex>
-#pragma instantiate ACE_Hash_Map_Manager_Ex<int, ACE_RB_Tree_Node<Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits> > *, Kokyu::Sched_Ready_Queue<mif_scheduler_traits, Kokyu::Comparator_Adapter_Generator<mif_scheduler_traits>::MoreEligible, ACE_Null_Mutex>::Guid_Hash, ACE_Equal_To<int>, ACE_Null_Mutex>
-#pragma instantiate ACE_RB_Tree<Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::Comparator_Adapter_Generator<mif_scheduler_traits>::MoreEligible, ACE_Null_Mutex>
-#pragma instantiate ACE_RB_Tree_Iterator<Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::Comparator_Adapter_Generator<mif_scheduler_traits>::MoreEligible, ACE_Null_Mutex>
-ACE_Hash_Map_Entry<int, ACE_RB_Tree_Node<Koky\
-u::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::DSRT_Dispatch_Item_var<\
-mif_scheduler_traits> >
-#pragma instantiate ACE_Hash_Map_Entry<int, ACE_RB_Tree_Node<Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits> > *>
-#pragma instantiate ACE_RB_Tree_Node<Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits> >
-#pragma instantiate Kokyu::MIF_Comparator<mif_scheduler_traits::QoSDescriptor_t>
-#pragma instantiate ACE_Hash_Map_Iterator_Base_Ex<int, ACE_RB_Tree_Node<Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits> > *, Kokyu::Sched_Ready_Queue<mif_scheduler_traits, Kokyu::Comparator_Adapter_Generator<mif_scheduler_traits>::MoreEligible, ACE_Null_Mutex>::Guid_Hash, ACE_Equal_To<int>, ACE_Null_Mutex>
-#pragma instantiate ACE_RB_Tree_Reverse_Iterator<Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::Comparator_Adapter_Generator<mif_scheduler_traits>::MoreEligible, ACE_Null_Mutex>
-#pragma instantiate ACE_RB_Tree_Iterator_Base<Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::DSRT_Dispatch_Item_var<mif_scheduler_traits>, Kokyu::Comparator_Adapter_Generator<mif_scheduler_traits>::MoreEligible, ACE_Null_Mutex>
-#pragma instantiate ACE_Array_Iterator<Kokyu::ConfigInfo>
-#endif /* ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/MIF.dsp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/MIF.dsp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/MIF.dsp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,104 +0,0 @@
-# Microsoft Developer Studio Project File - Name="DSRT_MIF" - Package Owner=<4>
-# Microsoft Developer Studio Generated Build File, Format Version 6.00
-# ** DO NOT EDIT **
-# TARGTYPE "Win32 (x86) Console Application" 0x0103
-CFG=DSRT_MIF - Win32 Debug
-!MESSAGE This is not a valid makefile. To build this project using NMAKE,
-!MESSAGE use the Export Makefile command and run
-!MESSAGE
-!MESSAGE NMAKE /f "DSRT_MIF.mak".
-!MESSAGE
-!MESSAGE You can specify a configuration when running NMAKE
-!MESSAGE by defining the macro CFG on the command line. For example:
-!MESSAGE
-!MESSAGE NMAKE /f "DSRT_MIF.mak" CFG="DSRT_MIF - Win32 Debug"
-!MESSAGE
-!MESSAGE Possible choices for configuration are:
-!MESSAGE
-!MESSAGE "DSRT_MIF - Win32 Release" (based on "Win32 (x86) Console Application")
-!MESSAGE "DSRT_MIF - Win32 Debug" (based on "Win32 (x86) Console Application")
-!MESSAGE
-# Begin Project
-# PROP AllowPerConfigDependencies 0
-# PROP Scc_ProjName ""
-# PROP Scc_LocalPath ""
-CPP=cl.exe
-RSC=rc.exe
-!IF  "$(CFG)" == "DSRT_MIF - Win32 Release"
-# PROP BASE Use_MFC 0
-# PROP BASE Use_Debug_Libraries 0
-# PROP BASE Output_Dir "Release"
-# PROP BASE Intermediate_Dir "Release"
-# PROP BASE Target_Dir ""
-# PROP Use_MFC 0
-# PROP Use_Debug_Libraries 0
-# PROP Output_Dir "Release"
-# PROP Intermediate_Dir "Release"
-# PROP Ignore_Export_Lib 0
-# PROP Target_Dir ""
-# ADD BASE CPP /nologo /W3 /GX /O2 /D "WIN32" /D "NDEBUG" /D "_CONSOLE" /D "_MBCS" /YX /FD /c
-# ADD CPP /nologo /MD /W3 /GX /O2 /I "../../.." /I "../.." /D "WIN32" /D "NDEBUG" /D "_CONSOLE" /D "_MBCS" /FD /c
-# SUBTRACT CPP /YX
-# ADD BASE RSC /l 0x409 /d "NDEBUG"
-# ADD RSC /l 0x409 /d "NDEBUG"
-BSC32=bscmake.exe
-# ADD BASE BSC32 /nologo
-# ADD BSC32 /nologo
-LINK32=link.exe
-# ADD BASE LINK32 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /nologo /subsystem:console /machine:I386
-# ADD LINK32 ..\..\..\ace\aced.lib ..\..\Kokyud.lib /nologo /subsystem:console /machine:I386
-!ELSEIF  "$(CFG)" == "DSRT_MIF - Win32 Debug"
-# PROP BASE Use_Debug_Libraries 1
-# PROP BASE Output_Dir "Debug"
-# PROP BASE Intermediate_Dir "Debug"
-# PROP Use_MFC 0
-# PROP Use_Debug_Libraries 1
-# PROP Output_Dir "Debug"
-# PROP Intermediate_Dir "Debug"
-# ADD BASE CPP /nologo /W3 /Gm /GX /Zi /Od /D "WIN32" /D "_DEBUG" /D "_CONSOLE" /D "_MBCS" /YX /FD  /c
-# ADD CPP /nologo /MDd /W3 /Gm /GX /Zi /Od /I "..\..\.." /I "..\.." /D "WIN32" /D "_DEBUG" /D "_CONSOLE" /D "_MBCS" /FD  /c
-# SUBTRACT CPP /YX
-# ADD BASE RSC /l 0x409 /d "_DEBUG"
-# ADD RSC /l 0x409 /d "_DEBUG"
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD BASE LINK32 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /nologo /subsystem:console /debug /machine:I386 /pdbtype:sept
-# ADD LINK32 ..\..\..\ace\aced.lib ..\..\Kokyud.lib /nologo /subsystem:console /debug /machine:I386 /pdbtype:sept
-!ENDIF
-# Begin Target
-# Name "DSRT_MIF - Win32 Release"
-# Name "DSRT_MIF - Win32 Debug"
-# Begin Group "Source Files"
-# PROP Default_Filter "cpp;c;cxx;rc;def;r;odl;idl;hpj;bat"
-# Begin Source File
-SOURCE=.\MIF.cpp
-# End Source File
-# End Group
-# Begin Group "Header Files"
-# PROP Default_Filter "h;hpp;hxx;hm;inl"
-# End Group
-# Begin Group "Resource Files"
-# PROP Default_Filter "ico;cur;bmp;dlg;rc2;rct;bin;rgs;gif;jpg;jpeg;jpe"
-# End Group
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/MIF.dsw
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/MIF.dsw	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/MIF.dsw	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,29 +0,0 @@
-Microsoft Developer Studio Workspace File, Format Version 6.00
-# WARNING: DO NOT EDIT OR DELETE THIS WORKSPACE FILE!
-Project: "DSRT_MIF"=.\MIF.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Global:
-Package=<5>
-Package=<3>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/Makefile
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/Makefile	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/Makefile	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,277 +0,0 @@
-#	Makefile,v 1.5 2003/10/12 13:48:46 venkita Exp
-#	Local macros
-BIN	= MIF
-LSRC    = $(addsuffix .cpp,$(BIN))
-VLDLIBS	= $(LDLIBS:%=%$(VAR))
-BUILD	= $(VBIN)
-include		$(ACE_ROOT)/include/makeinclude/rules.bin.GNU
-#	Local targets
-#CPPFLAGS += -I$(ACE_ROOT)/Kokyu -DKOKYU_DSRT_LOGGING
-CPPFLAGS += -I$(ACE_ROOT)/Kokyu
-LDFLAGS += -lKokyu
-#	Dependencies
-.obj/MIF.o .obj/MIF.so .shobj/MIF.o .shobj/MIF.so: MIF.cpp \
-  $(ACE_ROOT)/ace/OS_Export.h \
-  $(ACE_ROOT)/Kokyu/Kokyu_dsrt.h \
-  $(ACE_ROOT)/Kokyu/kokyu_export.h \
-  $(ACE_ROOT)/Kokyu/Kokyu_defs.h \
-  $(ACE_ROOT)/ace/OS.h \
-  $(ACE_ROOT)/ace/OS_Dirent.h \
-  $(ACE_ROOT)/ace/OS_Dirent.inl \
-  $(ACE_ROOT)/ace/OS_String.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_select.h \
-  $(ACE_ROOT)/ace/OS_String.inl \
-  $(ACE_ROOT)/ace/os_include/os_strings.h \
-  $(ACE_ROOT)/ace/OS_TLI.h \
-  $(ACE_ROOT)/ace/OS_TLI.inl \
-  $(ACE_ROOT)/ace/os_include/os_netdb.h \
-  $(ACE_ROOT)/ace/Min_Max.h \
-  $(ACE_ROOT)/ace/os_include/arpa/os_inet.h \
-  $(ACE_ROOT)/ace/os_include/netinet/os_tcp.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_shm.h \
-  $(ACE_ROOT)/ace/os_include/os_termios.h \
-  $(ACE_ROOT)/ace/os_include/os_aio.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_un.h \
-  $(ACE_ROOT)/ace/os_include/os_poll.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_msg.h \
-  $(ACE_ROOT)/ace/os_include/os_syslog.h \
-  $(ACE_ROOT)/ace/OS.i \
-  $(ACE_ROOT)/Kokyu/Kokyu_defs.i \
-  $(ACE_ROOT)/Kokyu/Kokyu_dsrt.i \
-  $(ACE_ROOT)/Kokyu/Kokyu_dsrt.cpp \
-  $(ACE_ROOT)/ace/Dynamic_Service.h \
-  $(ACE_ROOT)/ace/Dynamic_Service_Base.h \
-  $(ACE_ROOT)/ace/Dynamic_Service.i \
-  $(ACE_ROOT)/ace/Dynamic_Service.cpp \
-  $(ACE_ROOT)/Kokyu/DSRT_Direct_Dispatcher_Impl_T.h \
-  $(ACE_ROOT)/Kokyu/DSRT_Sched_Queue_T.h \
-  $(ACE_ROOT)/Kokyu/DSRT_Dispatch_Item_T.h \
-  $(ACE_ROOT)/ace/Bound_Ptr.h \
-  $(ACE_ROOT)/ace/Bound_Ptr.i \
-  $(ACE_ROOT)/Kokyu/DSRT_Dispatch_Item_T.i \
-  $(ACE_ROOT)/Kokyu/DSRT_Dispatch_Item_T.cpp \
-  $(ACE_ROOT)/ace/RB_Tree.h \
-  $(ACE_ROOT)/ace/Functor.h \
-  $(ACE_ROOT)/ace/Functor.i \
-  $(ACE_ROOT)/ace/Functor_T.h \
-  $(ACE_ROOT)/ace/Functor_T.i \
-  $(ACE_ROOT)/ace/Functor_T.cpp \
-  $(ACE_ROOT)/ace/RB_Tree.i \
-  $(ACE_ROOT)/ace/RB_Tree.cpp \
-  $(ACE_ROOT)/ace/SString.h \
-  $(ACE_ROOT)/ace/SStringfwd.h \
-  $(ACE_ROOT)/ace/String_Base.h \
-  $(ACE_ROOT)/ace/String_Base_Const.h \
-  $(ACE_ROOT)/ace/String_Base.i \
-  $(ACE_ROOT)/ace/String_Base.cpp \
-  $(ACE_ROOT)/ace/SString.i \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.h \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.i \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.cpp \
-  $(ACE_ROOT)/Kokyu/DSRT_Sched_Queue_T.cpp \
-  $(ACE_ROOT)/Kokyu/DSRT_Dispatcher_Impl_T.h \
-  $(ACE_ROOT)/Kokyu/DSRT_Dispatcher_Impl_T.i \
-  $(ACE_ROOT)/Kokyu/DSRT_Dispatcher_Impl_T.cpp \
-  $(ACE_ROOT)/Kokyu/DSRT_Direct_Dispatcher_Impl_T.cpp
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/svc.conf
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/svc.conf	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/svc.conf	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,4 +0,0 @@
-dynamic DSRT_Scheduler_Impl Service_Object *
-Kokyu:_make_MIF_Scheduler_Impl()
-"-sched_scope thread -sched_policy fifo -min_importance 0 -max_importance 10"
\ No newline at end of file
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/svc.conf.xml
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/svc.conf.xml	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/DSRT_MIF/svc.conf.xml	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,8 +0,0 @@
-<?xml version='1.0'?>
-<!-- Converted from svc.conf by svcconf-convert.pl -->
-<ACE_Svc_Conf>
- <dynamic id="DSRT_Scheduler_Impl" type="Service_Object">
-   <initializer path="Kokyu" init="_make_MIF_Scheduler_Impl" params="-sched_scope thread -sched_policy fifo -min_importance 0 -max_importance 10"/>
- </dynamic>
-</ACE_Svc_Conf>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/EDF.dsp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/EDF.dsp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/EDF.dsp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,104 +0,0 @@
-# Microsoft Developer Studio Project File - Name="EDF" - Package Owner=<4>
-CFG=EDF - Win32 Debug
-!MESSAGE
-!MESSAGE NMAKE /f "EDF.mak".
-!MESSAGE
-!MESSAGE
-!MESSAGE NMAKE /f "EDF.mak" CFG="EDF - Win32 Debug"
-!MESSAGE
-!MESSAGE
-!MESSAGE "EDF - Win32 Release" (based on "Win32 (x86) Console Application")
-!MESSAGE "EDF - Win32 Debug" (based on "Win32 (x86) Console Application")
-!MESSAGE
-# Begin Project
-CPP=cl.exe
-RSC=rc.exe
-!IF  "$(CFG)" == "EDF - Win32 Release"
-# PROP Use_MFC 0
-# SUBTRACT CPP /YX
-BSC32=bscmake.exe
-LINK32=link.exe
-!ELSEIF  "$(CFG)" == "EDF - Win32 Debug"
-# PROP Use_MFC 0
-# SUBTRACT CPP /YX
-BSC32=bscmake.exe
-LINK32=link.exe
-!ENDIF
-# Begin Target
-# Name "EDF - Win32 Release"
-# Name "EDF - Win32 Debug"
-SOURCE=.\test.cpp
-# End Source File
-# End Group
-# End Group
-# End Group
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/EDF.dsw
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/EDF.dsw	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/EDF.dsw	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,29 +0,0 @@
-Project: "test"=.\EDF.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Global:
-Package=<5>
-Package=<3>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/EDF.mpc
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/EDF.mpc	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/EDF.mpc	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,6 +0,0 @@
-//  -*- MPC -*-
-// EDF.mpc,v 1.2 2003/11/10 04:31:59 dhinton Exp
-project: kokyu {
-  exename = EDF
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/Makefile
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/Makefile	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/Makefile	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,243 +0,0 @@
-#	Makefile,v 1.1 2003/08/10 14:58:16 venkita Exp
-#	Local macros
-BIN	= test
-LSRC    = test.cpp
-BUILD	= $(VBIN)
-include		$(ACE_ROOT)/include/makeinclude/macros.GNU
-#	Local targets
-LDFLAGS += -lKokyu
-#	Dependencies
-.obj/test.o .obj/test.so .shobj/test.o .shobj/test.so: test.cpp \
-  $(ACE_ROOT)/Kokyu/Kokyu.h \
-  $(ACE_ROOT)/Kokyu/Dispatcher_Impl.h \
-  $(ACE_ROOT)/Kokyu/Dispatcher_Impl.i \
-  $(ACE_ROOT)/Kokyu/Kokyu.i \
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/README
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/README	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/README	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,24 +0,0 @@
-This example is a very simple example, showing how to use the Kokyu
-dispatcher to dispatch command objects in a EDF manner. The test
-configures the Kokyu dispatcher with a single EDF lane. Typically this
-would be done by an EDF scheduler which assigns priorities to tasks
-based on the deadlines for tasks. To ensure that the command objects
-enqueued in the dispatcher are dispatched in the correct order, we
-enqueue the command objects and *then* activate the dispatcher. Only
-when the dispatcher is activated, the thread watching each dispatch
-queue starts running.
-To run this example,
-./test -p<fifo|rr|other>
-The following is the expected output
-Deadline of command1 is 1065966081
-Deadline of command2 is 1065966131
-Deadline of command3 is 1065966031
-command 3 executed
-command 1 executed
-command 2 executed
-Note that the deadlines are absolute deadlines.
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/test.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/test.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/EDF/test.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,161 +0,0 @@
-// test.cpp,v 1.6 2003/11/01 11:15:07 dhinton Exp
-#include "Kokyu.h"
-#include "ace/SString.h"
-#include "ace/Get_Opt.h"
-#include "ace/OS_NS_strings.h"
-ACE_CString sched_policy_str = "fifo";
-int parse_args (int argc, char *argv[]);
-class MyCommand : public Kokyu::Dispatch_Command
-public:
-  MyCommand(int i)
-    :Kokyu::Dispatch_Command(1),id_(i)
-  int execute();
-private:
-  int id_;
-int MyCommand::execute()
-  int prio;
-  if (ACE_Thread::getprio (thr_handle, prio) == -1)
-    if (errno == ENOTSUP)
-      ACE_DEBUG((LM_DEBUG,
-                 ACE_TEXT ("getprior not supported on this platform\n")
-      return 0;
-    ACE_ERROR_RETURN ((LM_ERROR,
-                       ACE_TEXT ("%p\n"),
-                       ACE_TEXT ("getprio failed")),
-                      -1);
-                ACE_TEXT (("(%t|prio=%d) | command %d executed\n")),
-                prio, id_));
-    return 0;
-int main (int argc, char** argv)
-  Kokyu::ConfigInfoSet config_info(3);
-  int sched_policy=ACE_SCHED_FIFO;
-  Kokyu::Dispatcher_Attributes attrs;
-  if (parse_args (argc, argv) == -1)
-    return 0;
-  if (ACE_OS::strcasecmp(sched_policy_str.c_str(), "fifo") == 0)
-      sched_policy = ACE_SCHED_FIFO;
-  else if (ACE_OS::strcasecmp(sched_policy_str.c_str(), "other") == 0)
-      sched_policy = ACE_SCHED_OTHER;
-  else if (ACE_OS::strcasecmp(sched_policy_str.c_str(), "rr") == 0)
-      sched_policy = ACE_SCHED_RR;
-  attrs.sched_policy (sched_policy);
-  Kokyu::Priority_t min_prio =
-    ACE_Sched_Params::priority_min (sched_policy);
-  config_info[0].preemption_priority_ = 1;
-  config_info[0].thread_priority_ = min_prio;
-  config_info[0].dispatching_type_ = Kokyu::DEADLINE_DISPATCHING;
-  attrs.config_info_set_ = config_info;
-  auto_ptr<Kokyu::Dispatcher>
-    disp (Kokyu::Dispatcher_Factory::create_dispatcher (attrs));
-  ACE_ASSERT (disp.get() != 0);
-  MyCommand cmd1(1), cmd2(2), cmd3(3);
-  Kokyu::QoSDescriptor qos1, qos2, qos3;
-  // Get the current time.
-  ACE_Time_Value current_time = ACE_OS::gettimeofday ();
-  ACE_Time_Value deadline1, deadline2, deadline3;
-  deadline1 = current_time + ACE_Time_Value(150,0);
-  deadline2 = current_time + ACE_Time_Value(200,0);
-  deadline3 = current_time + ACE_Time_Value(100,0);
-  qos1.preemption_priority_ = 1;
-  qos1.deadline_ = deadline1;
-  qos2.preemption_priority_ = 1;
-  qos2.deadline_ = deadline2;
-  qos3.preemption_priority_ = 1;
-  qos3.deadline_ = deadline3;
-  ACE_DEBUG ((LM_DEBUG, "Deadline of command1 is %d\n",
-              qos1.deadline_.sec ()));
-  disp->dispatch (&cmd1, qos1);
-  ACE_DEBUG ((LM_DEBUG, "Deadline of command2 is %d\n",
-              qos2.deadline_.sec ()));
-  disp->dispatch (&cmd2, qos2);
-  ACE_DEBUG ((LM_DEBUG, "Deadline of command3 is %d\n",
-              qos3.deadline_.sec ()));
-  disp->dispatch (&cmd3, qos3);
-  disp->activate ();
-  ACE_DEBUG ((LM_DEBUG, "after shutdown\n"));
-  return 0;
-  ACE_Get_Opt get_opts (argc, argv, "p:");
-  int c;
-  while ((c = get_opts ()) != -1)
-    switch (c)
-      case 'p':
-        sched_policy_str = ACE_TEXT_ALWAYS_CHAR(get_opts.opt_arg ());
-        break;
-      case '?':
-      default:
-                           "usage:  %s %s"
-                           "\n",
-                           argv [0],
-                           "-p <fifo|rr|other>"),
-                          -1);
-  // Indicates sucessful parsing of the command line
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/FIFO.dsp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/FIFO.dsp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/FIFO.dsp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,104 +0,0 @@
-# Microsoft Developer Studio Project File - Name="FIFO" - Package Owner=<4>
-CFG=FIFO - Win32 Debug
-!MESSAGE
-!MESSAGE NMAKE /f "FIFO.mak".
-!MESSAGE
-!MESSAGE
-!MESSAGE NMAKE /f "FIFO.mak" CFG="FIFO - Win32 Debug"
-!MESSAGE
-!MESSAGE
-!MESSAGE "FIFO - Win32 Release" (based on "Win32 (x86) Console Application")
-!MESSAGE "FIFO - Win32 Debug" (based on "Win32 (x86) Console Application")
-!MESSAGE
-# Begin Project
-CPP=cl.exe
-RSC=rc.exe
-!IF  "$(CFG)" == "FIFO - Win32 Release"
-# PROP Use_MFC 0
-# SUBTRACT CPP /YX
-BSC32=bscmake.exe
-LINK32=link.exe
-!ELSEIF  "$(CFG)" == "FIFO - Win32 Debug"
-# PROP Use_MFC 0
-# SUBTRACT CPP /YX
-BSC32=bscmake.exe
-LINK32=link.exe
-!ENDIF
-# Begin Target
-# Name "FIFO - Win32 Release"
-# Name "FIFO - Win32 Debug"
-SOURCE=.\test.cpp
-# End Source File
-# End Group
-# End Group
-# End Group
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/FIFO.dsw
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/FIFO.dsw	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/FIFO.dsw	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,29 +0,0 @@
-Project: "test"=.\FIFO.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Global:
-Package=<5>
-Package=<3>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/FIFO.mpc
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/FIFO.mpc	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/FIFO.mpc	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,6 +0,0 @@
-//  -*- MPC -*-
-// FIFO.mpc,v 1.2 2003/11/10 04:31:59 dhinton Exp
-project: kokyu {
-  exename = FIFO
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/Makefile
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/Makefile	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/Makefile	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,243 +0,0 @@
-#	Local macros
-BIN	= test
-BUILD	= $(VBIN)
-#	Include macros and targets
-include		$(ACE_ROOT)/include/makeinclude/wrapper_macros.GNU
-include		$(ACE_ROOT)/include/makeinclude/rules.common.GNU
-include		$(ACE_ROOT)/include/makeinclude/rules.nonested.GNU
-include		$(ACE_ROOT)/include/makeinclude/rules.local.GNU
-#	Local targets
-LDFLAGS += -lKokyu
-#	Dependencies
-# DO NOT DELETE THIS LINE -- g++dep uses it.
-# DO NOT PUT ANYTHING AFTER THIS LINE, IT WILL GO AWAY.
-  $(ACE_ROOT)/ace/Auto_Ptr.h \
-  $(ACE_ROOT)/ace/pre.h \
-  $(ACE_ROOT)/ace/post.h \
-  $(ACE_ROOT)/ace/ace_wchar.h \
-  $(ACE_ROOT)/ace/ace_wchar.inl \
-  $(ACE_ROOT)/ace/Auto_Ptr.i \
-  $(ACE_ROOT)/ace/Global_Macros.h \
-  $(ACE_ROOT)/ace/Auto_Ptr.cpp \
-  $(ACE_ROOT)/ace/Array.h \
-  $(ACE_ROOT)/ace/Containers_T.h \
-  $(ACE_ROOT)/ace/Containers.h \
-  $(ACE_ROOT)/ace/ACE_export.h \
-  $(ACE_ROOT)/ace/Containers.i \
-  $(ACE_ROOT)/ace/Node.h \
-  $(ACE_ROOT)/ace/Node.cpp \
-  $(ACE_ROOT)/ace/Array_Base.h \
-  $(ACE_ROOT)/ace/Malloc_Base.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_types.h \
-  $(ACE_ROOT)/ace/os_include/os_stddef.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_mman.h \
-  $(ACE_ROOT)/ace/Array_Base.inl \
-  $(ACE_ROOT)/ace/Array_Base.cpp \
-  $(ACE_ROOT)/ace/os_include/os_errno.h \
-  $(ACE_ROOT)/ace/Unbounded_Set.h \
-  $(ACE_ROOT)/ace/Unbounded_Set.inl \
-  $(ACE_ROOT)/ace/Unbounded_Set.cpp \
-  $(ACE_ROOT)/ace/Log_Msg.h \
-  $(ACE_ROOT)/ace/Default_Constants.h \
-  $(ACE_ROOT)/ace/Log_Priority.h \
-  $(ACE_ROOT)/ace/os_include/os_limits.h \
-  $(ACE_ROOT)/ace/os_include/os_unistd.h \
-  $(ACE_ROOT)/ace/os_include/os_inttypes.h \
-  $(ACE_ROOT)/ace/os_include/os_stdint.h \
-  $(ACE_ROOT)/ace/os_include/os_stdio.h \
-  $(ACE_ROOT)/ace/os_include/os_stdarg.h \
-  $(ACE_ROOT)/ace/OS_Log_Msg_Attributes.h \
-  $(ACE_ROOT)/ace/iosfwd.h \
-  $(ACE_ROOT)/ace/OS_Log_Msg_Attributes.inl \
-  $(ACE_ROOT)/ace/Unbounded_Queue.h \
-  $(ACE_ROOT)/ace/Unbounded_Queue.inl \
-  $(ACE_ROOT)/ace/Unbounded_Queue.cpp \
-  $(ACE_ROOT)/ace/Containers_T.i \
-  $(ACE_ROOT)/ace/Containers_T.cpp \
-  $(ACE_ROOT)/ace/OS_Memory.h \
-  $(ACE_ROOT)/ace/OS_Errno.h \
-  $(ACE_ROOT)/ace/OS_Errno.inl \
-  $(ACE_ROOT)/ace/OS_Memory.inl \
-  $(ACE_ROOT)/ace/Time_Value.h \
-  $(ACE_ROOT)/ace/Time_Value.inl \
-  $(ACE_ROOT)/ace/Message_Block.h \
-  $(ACE_ROOT)/ace/Message_Block.i \
-  $(ACE_ROOT)/ace/Message_Block_T.h \
-  $(ACE_ROOT)/ace/Message_Block_T.i \
-  $(ACE_ROOT)/ace/Message_Block_T.cpp \
-  $(ACE_ROOT)/ace/Sched_Params.h \
-  $(ACE_ROOT)/ace/os_include/os_dirent.h \
-  $(ACE_ROOT)/ace/Basic_Types.h \
-  $(ACE_ROOT)/ace/os_include/os_float.h \
-  $(ACE_ROOT)/ace/os_include/os_stdlib.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_wait.h \
-  $(ACE_ROOT)/ace/os_include/os_signal.h \
-  $(ACE_ROOT)/ace/os_include/os_time.h \
-  $(ACE_ROOT)/ace/os_include/os_ucontext.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_resource.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_time.h \
-  $(ACE_ROOT)/ace/Basic_Types.i \
-  $(ACE_ROOT)/ace/os_include/os_string.h \
-  $(ACE_ROOT)/ace/os_include/os_ctype.h \
-  $(ACE_ROOT)/ace/os_include/os_dlfcn.h \
-  $(ACE_ROOT)/ace/os_include/netinet/os_in.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_socket.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_uio.h \
-  $(ACE_ROOT)/ace/os_include/net/os_if.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_sem.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_ipc.h \
-  $(ACE_ROOT)/ace/os_include/os_pthread.h \
-  $(ACE_ROOT)/ace/os_include/os_assert.h \
-  $(ACE_ROOT)/ace/os_include/os_fcntl.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_stat.h \
-  $(ACE_ROOT)/ace/os_include/os_pwd.h \
-  $(ACE_ROOT)/ace/os_include/os_stropts.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_utsname.h \
-  $(ACE_ROOT)/ace/Sched_Params.i \
-  $(ACE_ROOT)/ace/Task.h \
-  $(ACE_ROOT)/ace/Service_Object.h \
-  $(ACE_ROOT)/ace/Shared_Object.h \
-  $(ACE_ROOT)/ace/Shared_Object.i \
-  $(ACE_ROOT)/ace/Svc_Conf_Tokens.h \
-  $(ACE_ROOT)/ace/Event_Handler.h \
-  $(ACE_ROOT)/ace/Atomic_Op.h \
-  $(ACE_ROOT)/ace/Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Thread_Mutex.inl \
-  $(ACE_ROOT)/ace/Atomic_Op_T.h \
-  $(ACE_ROOT)/ace/Atomic_Op_T.i \
-  $(ACE_ROOT)/ace/Guard_T.h \
-  $(ACE_ROOT)/ace/Lock.h \
-  $(ACE_ROOT)/ace/Lock.inl \
-  $(ACE_ROOT)/ace/Guard_T.inl \
-  $(ACE_ROOT)/ace/Guard_T.cpp \
-  $(ACE_ROOT)/ace/Atomic_Op_T.cpp \
-  $(ACE_ROOT)/ace/Atomic_Op.i \
-  $(ACE_ROOT)/ace/Synch_Traits.h \
-  $(ACE_ROOT)/ace/Event_Handler.i \
-  $(ACE_ROOT)/ace/DLL.h \
-  $(ACE_ROOT)/ace/Service_Object.i \
-  $(ACE_ROOT)/ace/Thread_Manager.h \
-  $(ACE_ROOT)/ace/Thread.h \
-  $(ACE_ROOT)/ace/Thread_Adapter.h \
-  $(ACE_ROOT)/ace/Base_Thread_Adapter.h \
-  $(ACE_ROOT)/ace/Base_Thread_Adapter.inl \
-  $(ACE_ROOT)/ace/Thread_Adapter.inl \
-  $(ACE_ROOT)/ace/Thread.i \
-  $(ACE_ROOT)/ace/Thread_Exit.h \
-  $(ACE_ROOT)/ace/Thread_Control.h \
-  $(ACE_ROOT)/ace/Thread_Control.inl \
-  $(ACE_ROOT)/ace/Condition_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Condition_Thread_Mutex.inl \
-  $(ACE_ROOT)/ace/Free_List.h \
-  $(ACE_ROOT)/ace/Free_List.i \
-  $(ACE_ROOT)/ace/Free_List.cpp \
-  $(ACE_ROOT)/ace/Singleton.h \
-  $(ACE_ROOT)/ace/TSS_T.h \
-  $(ACE_ROOT)/ace/TSS_T.inl \
-  $(ACE_ROOT)/ace/TSS_T.cpp \
-  $(ACE_ROOT)/ace/Singleton.i \
-  $(ACE_ROOT)/ace/Singleton.cpp \
-  $(ACE_ROOT)/ace/Object_Manager.h \
-  $(ACE_ROOT)/ace/Recursive_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Recursive_Thread_Mutex.inl \
-  $(ACE_ROOT)/ace/Object_Manager.i \
-  $(ACE_ROOT)/ace/Managed_Object.h \
-  $(ACE_ROOT)/ace/Managed_Object.i \
-  $(ACE_ROOT)/ace/Managed_Object.cpp \
-  $(ACE_ROOT)/ace/Framework_Component.h \
-  $(ACE_ROOT)/ace/Framework_Component.inl \
-  $(ACE_ROOT)/ace/ACE.h \
-  $(ACE_ROOT)/ace/Flag_Manip.h \
-  $(ACE_ROOT)/ace/Flag_Manip.i \
-  $(ACE_ROOT)/ace/Handle_Ops.h \
-  $(ACE_ROOT)/ace/Handle_Ops.i \
-  $(ACE_ROOT)/ace/Lib_Find.h \
-  $(ACE_ROOT)/ace/Lib_Find.i \
-  $(ACE_ROOT)/ace/Init_ACE.h \
-  $(ACE_ROOT)/ace/Init_ACE.i \
-  $(ACE_ROOT)/ace/Sock_Connect.h \
-  $(ACE_ROOT)/ace/Sock_Connect.i \
-  $(ACE_ROOT)/ace/ACE.i \
-  $(ACE_ROOT)/ace/Framework_Component_T.h \
-  $(ACE_ROOT)/ace/Framework_Component_T.inl \
-  $(ACE_ROOT)/ace/Framework_Component_T.cpp \
-  $(ACE_ROOT)/ace/Thread_Manager.i \
-  $(ACE_ROOT)/ace/Task.i \
-  $(ACE_ROOT)/ace/Task_T.h \
-  $(ACE_ROOT)/ace/Message_Queue.h \
-  $(ACE_ROOT)/ace/IO_Cntl_Msg.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.i \
-  $(ACE_ROOT)/ace/Message_Queue_T.cpp \
-  $(ACE_ROOT)/ace/Notification_Strategy.h \
-  $(ACE_ROOT)/ace/Notification_Strategy.inl \
-  $(ACE_ROOT)/ace/Message_Queue.i \
-  $(ACE_ROOT)/ace/Task_T.i \
-  $(ACE_ROOT)/ace/Task_T.cpp \
-  $(ACE_ROOT)/ace/Module.h \
-  $(ACE_ROOT)/ace/Module.i \
-  $(ACE_ROOT)/ace/Module.cpp \
-  $(ACE_ROOT)/ace/Stream_Modules.h \
-  $(ACE_ROOT)/ace/Stream_Modules.cpp \
-  $(ACE_ROOT)/ace/Null_Condition.h \
-  $(ACE_ROOT)/ace/Null_Mutex.h
-# IF YOU PUT ANYTHING HERE IT WILL GO AWAY
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/README
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/README	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/README	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,24 +0,0 @@
-dispatcher to dispatch command objects in a FIFO manner. The test
-configures the Kokyu dispatcher with 3 FIFO lanes, each having a
-different priority. Typically this would be done by an RMS scheduler
-which assigns priorities to tasks based on the rate of tasks. To
-ensure that the command objects enqueued in the dispatcher are
-dispatched in the correct order, we enqueue the command objects and
-*then* activate the dispatcher. Only when the dispatcher is activated,
-the thread watching each dispatch queue starts running.
-Priority of command1 is 2
-Priority of command2 is 3
-Priority of command3 is 1
-command 3 executed
-command 1 executed
-command 2 executed
-Note that a lower number means a higher priority for the task.
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/test.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/test.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Kokyu/tests/FIFO/test.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,166 +0,0 @@
-// test.cpp,v 1.7 2003/11/01 11:15:07 dhinton Exp
-#include "Kokyu.h"
-public:
-  MyCommand(int i)
-  int execute ();
-private:
-  int id_;
-  int prio;
-      return 0;
-                      -1);
-                prio, id_));
-    return 0;
-  int  hi_prio, me_prio, lo_prio;
-    return 0;
-  hi_prio = ACE_Sched_Params::priority_max (sched_policy);
-  me_prio = ACE_Sched_Params::previous_priority (sched_policy,
-                                                 hi_prio);
-  lo_prio = ACE_Sched_Params::previous_priority (sched_policy,
-                                                 me_prio);
-  config_info[0].thread_priority_ = hi_prio ;
-  config_info[0].dispatching_type_ = Kokyu::FIFO_DISPATCHING;
-  config_info[1].preemption_priority_ = 2;
-  config_info[1].thread_priority_ = me_prio;
-  config_info[1].dispatching_type_ = Kokyu::FIFO_DISPATCHING;
-  config_info[2].preemption_priority_ = 3;
-  config_info[2].thread_priority_ = lo_prio;
-  config_info[2].dispatching_type_ = Kokyu::FIFO_DISPATCHING;
-  qos1.preemption_priority_ = 2;
-  ACE_DEBUG ((LM_DEBUG, "Priority of command1 is %d\n",
-              qos1.preemption_priority_));
-  qos2.preemption_priority_ = 3;
-  ACE_DEBUG ((LM_DEBUG, "Priority of command2 is %d\n",
-              qos2.preemption_priority_));
-  ACE_DEBUG ((LM_DEBUG, "Priority of command3 is %d\n",
-              qos3.preemption_priority_));
-  if (disp->dispatch (&cmd1, qos1) == -1 ||
-      disp->dispatch (&cmd2, qos2) == -1 ||
-      disp->dispatch (&cmd3, qos3) == -1)
-    ACE_ERROR_RETURN ((LM_ERROR, "Error in dispatching command object\n"), -1);
-  if (disp->activate () == -1)
-                         ACE_TEXT ("Error activating dispatcher. ")
-                         ACE_TEXT ("You might not have superuser privileges ")
-                         ACE_TEXT ("to run FIFO class. Try \"-p other\"\n")), -1);
-  return 0;
-  int c;
-    switch (c)
-      case 'p':
-        break;
-      case '?':
-      default:
-                           "usage:  %s %s"
-                           "\n",
-                           argv [0],
-                          -1);
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/Makefile
--- trunk/MgDev/Oem/ACE/ACE_wrappers/Makefile	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/Makefile	2007-03-14 16:25:26 UTC (rev 1220)
@@ -15,31 +15,10 @@
           THANKS \
           VERSION
-DIRS    = ace \
-	  ACEXML \
-          netsvcs \
-          tests \
-          apps \
-          examples \
-          performance-tests \
-          websvcs \
-	  Kokyu
+DIRS    = ace
 CLONE   = Makefile \
-          ace \
-          apps \
-          bin \
-          lib \
-          etc \
-          examples \
-          include \
-          netsvcs \
-          TAO \
-          tests \
-          websvcs \
-	  ACEXML \
-	  Kokyu
+          ace
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/Global_Macros.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/Global_Macros.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/Global_Macros.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -250,7 +250,7 @@
      while (0)
-#if (defined(__IBMCPP__) && (__IBMCPP__ >= 400)) || (__GNUC__ >= 4)
+#if (defined(__IBMCPP__) && (__IBMCPP__ >= 400)) || (__GNUC__ >= 3)
 #   define ACE_DES_FREE_TEMPLATE(POINTER,DEALLOCATOR,T_CLASS,T_PARAMETER) \
      do { \
           if (POINTER) \
@@ -285,7 +285,7 @@
      while (0)
 #   define ACE_DES_FREE_TEMPLATE2(POINTER,DEALLOCATOR,T_CLASS,T_PARAM1,T_PARAM2) \
      do { \
           if (POINTER) \
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/Makefile
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/Makefile	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/Makefile	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,2803 +1,3 @@
-# Makefile,v 1.53 2004/01/05 02:42:24 bala Exp
-MAKEFILE = Makefile
-LIB      = libACE_RMCast.a
-SHLIB    = libACE_RMCast.$(SOEXT)
-FILES= \
-	RMCast \
-	RMCast_Ack_Worker \
-	RMCast_Fork \
-	RMCast_Fragment \
-	RMCast_IO_UDP \
-	RMCast_Membership \
-	RMCast_Module \
-	RMCast_Module_Factory \
-	RMCast_Partial_Message \
-	RMCast_Proxy \
-	RMCast_Reassembly \
-	RMCast_Receiver_Module \
-	RMCast_Reliable_Factory \
-	RMCast_Reordering \
-	RMCast_Resend_Handler \
-	RMCast_Resend_Worker \
-	RMCast_Retransmission \
-	RMCast_Sequencer \
-	RMCast_Singleton_Factory \
-	RMCast_UDP_Event_Handler \
-	RMCast_UDP_Proxy \
-	RMCast_UDP_Reliable_Receiver \
-	RMCast_UDP_Reliable_Sender
-LIBS=$(ACELIB)
-LSRC  = $(addsuffix .cpp,$(FILES))
-include $(ACE_ROOT)/include/makeinclude/rules.lib.GNU
-#       Local targets
-ifeq ($(shared_libs),1)
-ifneq ($(SHLIB),)
-CPPFLAGS     += -DACE_RMCAST_BUILD_DLL
-endif
-endif
-#       Dependencies
-.obj/RMCast.o .obj/RMCast.so .shobj/RMCast.o .shobj/RMCast.so: RMCast.cpp RMCast.h \
-  RMCast_Export.h \
-  $(ACE_ROOT)/ace/config-all.h \
-  $(ACE_ROOT)/ace/config.h \
-  $(ACE_ROOT)/ace/$(ACE_PLATFORM_CONFIG) \
-  $(ACE_ROOT)/ace/OS_main.h \
-  RMCast.i
-.obj/RMCast_Ack_Worker.o .obj/RMCast_Ack_Worker.so .shobj/RMCast_Ack_Worker.o .shobj/RMCast_Ack_Worker.so: RMCast_Ack_Worker.cpp RMCast_Ack_Worker.h \
-  RMCast_Retransmission.h RMCast_Module.h RMCast.h RMCast_Export.h \
-  RMCast.i RMCast_Module.i RMCast_Copy_On_Write.h RMCast_Worker.h \
-  RMCast_Worker.i RMCast_Worker.cpp \
-  $(ACE_ROOT)/ace/OS_NS_Thread.h \
-  $(ACE_ROOT)/ace/os_include/os_semaphore.h \
-  $(ACE_ROOT)/ace/OS_NS_stdlib.h \
-  $(ACE_ROOT)/ace/OS_NS_stdlib.inl \
-  $(ACE_ROOT)/ace/Object_Manager_Base.h \
-  $(ACE_ROOT)/ace/Cleanup.h \
-  $(ACE_ROOT)/ace/Cleanup.inl \
-  $(ACE_ROOT)/ace/Object_Manager_Base.inl \
-  $(ACE_ROOT)/ace/OS_NS_string.h \
-  $(ACE_ROOT)/ace/OS_NS_string.inl \
-  $(ACE_ROOT)/ace/OS_NS_wchar.h \
-  $(ACE_ROOT)/ace/os_include/os_wchar.h \
-  $(ACE_ROOT)/ace/OS_NS_wchar.inl \
-  $(ACE_ROOT)/ace/os_include/os_search.h \
-  $(ACE_ROOT)/ace/OS_NS_signal.h \
-  $(ACE_ROOT)/ace/OS_NS_signal.inl \
-  $(ACE_ROOT)/ace/OS_NS_macros.h \
-  $(ACE_ROOT)/ace/OS_NS_errno.h \
-  $(ACE_ROOT)/ace/OS_NS_errno.inl \
-  $(ACE_ROOT)/ace/OS_NS_Thread.inl \
-  $(ACE_ROOT)/ace/OS_NS_sys_time.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_time.inl \
-  $(ACE_ROOT)/ace/OS_NS_sys_mman.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_mman.inl \
-  $(ACE_ROOT)/ace/OS_NS_fcntl.h \
-  $(ACE_ROOT)/ace/OS_NS_fcntl.inl \
-  $(ACE_ROOT)/ace/OS_NS_unistd.h \
-  $(ACE_ROOT)/ace/OS_NS_unistd.inl \
-  $(ACE_ROOT)/ace/OS_NS_sys_utsname.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_utsname.inl \
-  $(ACE_ROOT)/ace/OS_NS_stdio.h \
-  $(ACE_ROOT)/ace/OS_NS_stdio.inl \
-  $(ACE_ROOT)/ace/OS_NS_pwd.h \
-  $(ACE_ROOT)/ace/OS_NS_pwd.inl \
-  RMCast_Copy_On_Write.i \
-  $(ACE_ROOT)/ace/RW_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/RW_Mutex.h \
-  $(ACE_ROOT)/ace/RW_Mutex.inl \
-  $(ACE_ROOT)/ace/RW_Thread_Mutex.inl \
-  $(ACE_ROOT)/ace/Null_Mutex.h \
-  RMCast_Copy_On_Write.cpp \
-  $(ACE_ROOT)/ace/OS_NS_sys_socket.h \
-  $(ACE_ROOT)/ace/OS_NS_stropts.h \
-  $(ACE_ROOT)/ace/OS_NS_stropts.inl \
-  $(ACE_ROOT)/ace/OS_QoS.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_socket.inl \
-  $(ACE_ROOT)/ace/OS_NS_sys_uio.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_uio.inl \
-  RMCast_Retransmission.i RMCast_Ack_Worker.i \
-.obj/RMCast_Fork.o .obj/RMCast_Fork.so .shobj/RMCast_Fork.o .shobj/RMCast_Fork.so: RMCast_Fork.cpp RMCast_Fork.h \
-  RMCast_Module.h RMCast.h RMCast_Export.h \
-  RMCast.i RMCast_Module.i RMCast_Fork.i
-.obj/RMCast_Fragment.o .obj/RMCast_Fragment.so .shobj/RMCast_Fragment.o .shobj/RMCast_Fragment.so: RMCast_Fragment.cpp RMCast_Fragment.h \
-  RMCast.i RMCast_Module.i RMCast_Fragment.i \
-.obj/RMCast_IO_UDP.o .obj/RMCast_IO_UDP.so .shobj/RMCast_IO_UDP.o .shobj/RMCast_IO_UDP.so: RMCast_IO_UDP.cpp RMCast_IO_UDP.h \
-  RMCast.i RMCast_Module.i \
-  $(ACE_ROOT)/ace/SOCK_Dgram_Mcast.h \
-  $(ACE_ROOT)/ace/SOCK_Dgram.h \
-  $(ACE_ROOT)/ace/SOCK.h \
-  $(ACE_ROOT)/ace/Addr.h \
-  $(ACE_ROOT)/ace/Addr.i \
-  $(ACE_ROOT)/ace/IPC_SAP.h \
-  $(ACE_ROOT)/ace/IPC_SAP.i \
-  $(ACE_ROOT)/ace/SOCK.i \
-  $(ACE_ROOT)/ace/INET_Addr.h \
-  $(ACE_ROOT)/ace/INET_Addr.i \
-  $(ACE_ROOT)/ace/OS_NS_arpa_inet.h \
-  $(ACE_ROOT)/ace/OS_NS_arpa_inet.inl \
-  $(ACE_ROOT)/ace/SOCK_Dgram.i \
-  $(ACE_ROOT)/ace/SOCK_Dgram_Mcast.i \
-  $(ACE_ROOT)/ace/Hash_Map_Manager.h \
-  RMCast_IO_UDP.i RMCast_UDP_Proxy.h RMCast_Proxy.h RMCast_Proxy.i \
-  RMCast_UDP_Proxy.i RMCast_Module_Factory.h RMCast_Module_Factory.i \
-  $(ACE_ROOT)/ace/Handle_Set.h \
-  $(ACE_ROOT)/ace/Handle_Set.i \
-  $(ACE_ROOT)/ace/Reactor.h \
-  $(ACE_ROOT)/ace/Timer_Queuefwd.h \
-  $(ACE_ROOT)/ace/Reactor_Timer_Interface.h \
-  $(ACE_ROOT)/ace/Reactor.i \
-  $(ACE_ROOT)/ace/Reactor_Impl.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_select.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_select.inl
-.obj/RMCast_Membership.o .obj/RMCast_Membership.so .shobj/RMCast_Membership.o .shobj/RMCast_Membership.so: RMCast_Membership.cpp RMCast_Membership.h \
-  RMCast_Membership.i RMCast_Proxy.h RMCast_Proxy.i \
-.obj/RMCast_Module.o .obj/RMCast_Module.so .shobj/RMCast_Module.o .shobj/RMCast_Module.so: RMCast_Module.cpp RMCast_Module.h \
-  RMCast.h RMCast_Export.h \
-.obj/RMCast_Module_Factory.o .obj/RMCast_Module_Factory.so .shobj/RMCast_Module_Factory.o .shobj/RMCast_Module_Factory.so: RMCast_Module_Factory.cpp \
-  RMCast_Module_Factory.h \
-  RMCast.i RMCast_Module_Factory.i
-.obj/RMCast_Partial_Message.o .obj/RMCast_Partial_Message.so .shobj/RMCast_Partial_Message.o .shobj/RMCast_Partial_Message.so: RMCast_Partial_Message.cpp \
-  RMCast_Partial_Message.h \
-  RMCast_Export.h \
-  $(ACE_ROOT)/ace/Static_Object_Lock.h \
-  RMCast_Partial_Message.i
-.obj/RMCast_Proxy.o .obj/RMCast_Proxy.so .shobj/RMCast_Proxy.o .shobj/RMCast_Proxy.so: RMCast_Proxy.cpp RMCast_Proxy.h \
-  RMCast.i RMCast_Module.i RMCast_Proxy.i
-.obj/RMCast_Reassembly.o .obj/RMCast_Reassembly.so .shobj/RMCast_Reassembly.o .shobj/RMCast_Reassembly.so: RMCast_Reassembly.cpp RMCast_Reassembly.h \
-  RMCast_Reassembly.i RMCast_Partial_Message.h \
-.obj/RMCast_Receiver_Module.o .obj/RMCast_Receiver_Module.so .shobj/RMCast_Receiver_Module.o .shobj/RMCast_Receiver_Module.so: RMCast_Receiver_Module.cpp \
-  RMCast_Receiver_Module.h \
-  RMCast.i RMCast_Module.i RMCast_Receiver_Module.i RMCast_Proxy.h \
-  RMCast_Proxy.i \
-.obj/RMCast_Reliable_Factory.o .obj/RMCast_Reliable_Factory.so .shobj/RMCast_Reliable_Factory.o .shobj/RMCast_Reliable_Factory.so: RMCast_Reliable_Factory.cpp \
-  RMCast_Reliable_Factory.h \
-  RMCast_Module_Factory.h RMCast.h RMCast_Export.h \
-  RMCast.i RMCast_Module_Factory.i RMCast_Reliable_Factory.i \
-  RMCast_Receiver_Module.h RMCast_Module.h RMCast_Module.i \
-  RMCast_Receiver_Module.i RMCast_Reassembly.h \
-  RMCast_Reassembly.i RMCast_Reordering.h \
-  RMCast_Reordering.i
-.obj/RMCast_Reordering.o .obj/RMCast_Reordering.so .shobj/RMCast_Reordering.o .shobj/RMCast_Reordering.so: RMCast_Reordering.cpp RMCast_Reordering.h \
-  RMCast_Reordering.i RMCast_Proxy.h RMCast_Proxy.i \
-.obj/RMCast_Resend_Handler.o .obj/RMCast_Resend_Handler.so .shobj/RMCast_Resend_Handler.o .shobj/RMCast_Resend_Handler.so: RMCast_Resend_Handler.cpp \
-  RMCast_Resend_Handler.h \
-  RMCast_Export.h \
-  RMCast_Resend_Handler.i RMCast_Retransmission.h RMCast_Module.h \
-  RMCast.h RMCast.i RMCast_Module.i RMCast_Copy_On_Write.h \
-  RMCast_Worker.h RMCast_Worker.i RMCast_Worker.cpp \
-.obj/RMCast_Resend_Worker.o .obj/RMCast_Resend_Worker.so .shobj/RMCast_Resend_Worker.o .shobj/RMCast_Resend_Worker.so: RMCast_Resend_Worker.cpp RMCast_Resend_Worker.h \
-  RMCast.i RMCast_Copy_On_Write.h RMCast_Worker.h RMCast_Worker.i \
-  RMCast_Worker.cpp \
-  RMCast_Copy_On_Write.cpp RMCast_Resend_Worker.i RMCast_Module.h \
-  RMCast_Module.i
-.obj/RMCast_Retransmission.o .obj/RMCast_Retransmission.so .shobj/RMCast_Retransmission.o .shobj/RMCast_Retransmission.so: RMCast_Retransmission.cpp \
-  RMCast_Retransmission.h \
-  RMCast_Retransmission.i RMCast_Proxy.h RMCast_Proxy.i \
-  RMCast_Ack_Worker.h RMCast_Ack_Worker.i RMCast_Resend_Worker.h \
-  RMCast_Resend_Worker.i \
-.obj/RMCast_Sequencer.o .obj/RMCast_Sequencer.so .shobj/RMCast_Sequencer.o .shobj/RMCast_Sequencer.so: RMCast_Sequencer.cpp RMCast_Sequencer.h \
-  RMCast_Sequencer.i \
-.obj/RMCast_Singleton_Factory.o .obj/RMCast_Singleton_Factory.so .shobj/RMCast_Singleton_Factory.o .shobj/RMCast_Singleton_Factory.so: RMCast_Singleton_Factory.cpp \
-  RMCast_Singleton_Factory.h \
-  RMCast.i RMCast_Module_Factory.i RMCast_Singleton_Factory.i
-.obj/RMCast_UDP_Event_Handler.o .obj/RMCast_UDP_Event_Handler.so .shobj/RMCast_UDP_Event_Handler.o .shobj/RMCast_UDP_Event_Handler.so: RMCast_UDP_Event_Handler.cpp \
-  RMCast_UDP_Event_Handler.h \
-  RMCast_Export.h \
-  RMCast_UDP_Event_Handler.i RMCast_IO_UDP.h RMCast_Module.h RMCast.h \
-.obj/RMCast_UDP_Proxy.o .obj/RMCast_UDP_Proxy.so .shobj/RMCast_UDP_Proxy.o .shobj/RMCast_UDP_Proxy.so: RMCast_UDP_Proxy.cpp RMCast_UDP_Proxy.h \
-  RMCast_Proxy.h RMCast_Module.h RMCast.h RMCast_Export.h \
-  RMCast.i RMCast_Module.i RMCast_Proxy.i \
-  RMCast_UDP_Proxy.i RMCast_IO_UDP.h \
-  RMCast_IO_UDP.i RMCast_Module_Factory.h RMCast_Module_Factory.i \
-.obj/RMCast_UDP_Reliable_Receiver.o .obj/RMCast_UDP_Reliable_Receiver.so .shobj/RMCast_UDP_Reliable_Receiver.o .shobj/RMCast_UDP_Reliable_Receiver.so: RMCast_UDP_Reliable_Receiver.cpp \
-  RMCast_UDP_Reliable_Receiver.h \
-  RMCast_Singleton_Factory.h RMCast_Module_Factory.h RMCast.h \
-  RMCast_Export.h \
-  RMCast.i RMCast_Module_Factory.i RMCast_Singleton_Factory.i \
-  RMCast_Reliable_Factory.h RMCast_Reliable_Factory.i RMCast_IO_UDP.h \
-  RMCast_Module.h RMCast_Module.i \
-  RMCast_UDP_Proxy.i RMCast_UDP_Reliable_Receiver.i \
-  RMCast_UDP_Event_Handler.i \
-.obj/RMCast_UDP_Reliable_Sender.o .obj/RMCast_UDP_Reliable_Sender.so .shobj/RMCast_UDP_Reliable_Sender.o .shobj/RMCast_UDP_Reliable_Sender.so: RMCast_UDP_Reliable_Sender.cpp \
-  RMCast_UDP_Reliable_Sender.h \
-  RMCast_Export.h \
-  RMCast_IO_UDP.h RMCast_Module.h RMCast_Module.i \
-  RMCast_UDP_Proxy.i RMCast_Sequencer.h \
-  RMCast_Sequencer.i RMCast_Retransmission.h RMCast_Copy_On_Write.h \
-  RMCast_Copy_On_Write.i RMCast_Copy_On_Write.cpp \
-  RMCast_Retransmission.i RMCast_Membership.h \
-  RMCast_Membership.i RMCast_Fragment.h RMCast_Fragment.i RMCast_Fork.h \
-  RMCast_Fork.i RMCast_UDP_Reliable_Sender.i RMCast_UDP_Event_Handler.h \
-  RMCast_UDP_Event_Handler.i RMCast_Resend_Handler.h \
-  RMCast_Resend_Handler.i \
+all:
+clean:
+distclean:
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/Makefile.am
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/Makefile.am	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/Makefile.am	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,105 +0,0 @@
-##       Makefile.am,v 1.3 2003/11/28 19:24:36 ossama Exp
-##       Makefile.am for ACE_RMCast library
-##  Process this file with automake to create Makefile.in
-AM_CPPFLAGS = -I$(top_builddir) -I$(top_srcdir)
-lib_LTLIBRARIES = libACE_RMCast.la
-libACE_RMCast_la_SOURCES = \
-  RMCast.cpp \
-  RMCast_Ack_Worker.cpp \
-  RMCast_Fork.cpp \
-  RMCast_Fragment.cpp \
-  RMCast_IO_UDP.cpp \
-  RMCast_Membership.cpp \
-  RMCast_Module.cpp \
-  RMCast_Module_Factory.cpp \
-  RMCast_Partial_Message.cpp \
-  RMCast_Proxy.cpp \
-  RMCast_Reassembly.cpp \
-  RMCast_Receiver_Module.cpp \
-  RMCast_Reliable_Factory.cpp \
-  RMCast_Reordering.cpp \
-  RMCast_Resend_Handler.cpp \
-  RMCast_Resend_Worker.cpp \
-  RMCast_Retransmission.cpp \
-  RMCast_Sequencer.cpp \
-  RMCast_Singleton_Factory.cpp \
-  RMCast_UDP_Event_Handler.cpp \
-  RMCast_UDP_Proxy.cpp \
-  RMCast_UDP_Reliable_Receiver.cpp \
-  RMCast_UDP_Reliable_Sender.cpp
-libACE_RMCast_la_LIBADD = $(top_builddir)/ace/libACE.la
-## These are template source files.
-TEMPLATE_FILES = \
-  RMCast_Worker.cpp
-HEADER_FILES = \
-  RMCast.h \
-  RMCast_Ack_Worker.h \
-  RMCast_Copy_On_Write.h \
-  RMCast_Export.h \
-  RMCast_Fork.h \
-  RMCast_Fragment.h \
-  RMCast_IO_UDP.h \
-  RMCast_Membership.h \
-  RMCast_Module.h \
-  RMCast_Proxy.h \
-  RMCast_Reassembly.h \
-  RMCast_Reordering.h \
-  RMCast_Resend_Worker.h \
-  RMCast_Sequencer.h \
-  RMCast_UDP_Proxy.h \
-  RMCast_Worker.h
-INLINE_FILES = \
-  RMCast.i \
-  RMCast_Ack_Worker.i \
-  RMCast_Fork.i \
-  RMCast_Fragment.i \
-  RMCast_IO_UDP.i \
-  RMCast_Membership.i \
-  RMCast_Module.i \
-  RMCast_Module_Factory.i \
-  RMCast_Partial_Message.i \
-  RMCast_Proxy.i \
-  RMCast_Reassembly.i \
-  RMCast_Receiver_Module.i \
-  RMCast_Reliable_Factory.i \
-  RMCast_Reordering.i \
-  RMCast_Retransmission.i \
-  RMCast_Singleton_Factory.i \
-  RMCast_UDP_Proxy.i \
-  RMCast_UDP_Reliable_Receiver.i \
-  RMCast_UDP_Reliable_Sender.i \
-  RMCast_Worker.i
-pkginclude_HEADERS = \
-  $(HEADER_FILES) \
-  $(INLINE_FILES) \
-  $(TEMPLATE_FILES)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/Makefile.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/Makefile.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/Makefile.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,45 +0,0 @@
-# Makefile.bor,v 1.2 2003/12/21 10:14:49 jwillemsen Exp
-# Makefile for building	the ACE	RMCast library with Borland C++Builder
-NAME = ACE_RMCast
-OBJFILES = \
-	$(OBJDIR)\RMCast.obj \
-	$(OBJDIR)\RMCast_Ack_Worker.obj \
-	$(OBJDIR)\RMCast_Fork.obj \
-	$(OBJDIR)\RMCast_Fragment.obj \
-	$(OBJDIR)\RMCast_IO_UDP.obj \
-	$(OBJDIR)\RMCast_Membership.obj \
-	$(OBJDIR)\RMCast_Module.obj \
-	$(OBJDIR)\RMCast_Module_Factory.obj \
-	$(OBJDIR)\RMCast_Reassembly.obj \
-	$(OBJDIR)\RMCast_Partial_Message.obj \
-        $(OBJDIR)\RMCast_Proxy.obj \
-	$(OBJDIR)\RMCast_Receiver_Module.obj \
-	$(OBJDIR)\RMCast_Reliable_Factory.obj \
-	$(OBJDIR)\RMCast_Reordering.obj \
-	$(OBJDIR)\RMCast_Resend_Handler.obj \
-	$(OBJDIR)\RMCast_Resend_Worker.obj \
-	$(OBJDIR)\RMCast_Retransmission.obj \
-	$(OBJDIR)\RMCast_Sequencer.obj \
-	$(OBJDIR)\RMCast_Singleton_Factory.obj \
-	$(OBJDIR)\RMCast_UDP_Event_Handler.obj \
-	$(OBJDIR)\RMCast_UDP_Proxy.obj \
-	$(OBJDIR)\RMCast_UDP_Reliable_Receiver.obj \
-	$(OBJDIR)\RMCast_UDP_Reliable_Sender.obj
-CFLAGS = $(ACE_CFLAGS) $(ACE_RMCAST_CFLAGS) -DACE_RMCAST_BUILD_DLL
-LIBFILES = $(ACE_LIB)
-CPPDIR = .
-INCDIR_NAME = ace\RMCast
-INCLUDES = *.h *.i RMCast_Copy_On_Write.cpp RMCast_Worker.cpp
-!include <$(ACE_ROOT)\include\makeinclude\build_core_library.bor>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/Makefile.in
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/Makefile.in	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/Makefile.in	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,692 +0,0 @@
-# Makefile.in generated by automake 1.8.2 from Makefile.am.
-# @configure_input@
-# Copyright (C) 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002,
-# 2003, 2004  Free Software Foundation, Inc.
-# This Makefile.in is free software; the Free Software Foundation
-# gives unlimited permission to copy and/or distribute it,
-# with or without modifications, as long as this notice is preserved.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY, to the extent permitted by law; without
-# even the implied warranty of MERCHANTABILITY or FITNESS FOR A
-# PARTICULAR PURPOSE.
- at SET_MAKE@
-SOURCES = $(libACE_RMCast_la_SOURCES)
-srcdir = @srcdir@
-top_srcdir = @top_srcdir@
-VPATH = @srcdir@
-pkgdatadir = $(datadir)/@PACKAGE@
-pkglibdir = $(libdir)/@PACKAGE@
-pkgincludedir = $(includedir)/@PACKAGE@
-top_builddir = ../..
-am__cd = CDPATH="$${ZSH_VERSION+.}$(PATH_SEPARATOR)" && cd
-INSTALL = @INSTALL@
-install_sh_DATA = $(install_sh) -c -m 644
-install_sh_PROGRAM = $(install_sh) -c
-install_sh_SCRIPT = $(install_sh) -c
-INSTALL_HEADER = $(INSTALL_DATA)
-transform = $(program_transform_name)
-NORMAL_INSTALL = :
-PRE_INSTALL = :
-POST_INSTALL = :
-NORMAL_UNINSTALL = :
-PRE_UNINSTALL = :
-POST_UNINSTALL = :
-host_triplet = @host@
-subdir = ace/RMCast
-DIST_COMMON = README $(pkginclude_HEADERS) $(srcdir)/Makefile.am \
-	$(srcdir)/Makefile.in
-ACLOCAL_M4 = $(top_srcdir)/aclocal.m4
-am__aclocal_m4_deps = $(top_srcdir)/m4/ace.m4 \
-	$(top_srcdir)/m4/acinclude.m4 $(top_srcdir)/m4/aio.m4 \
-	$(top_srcdir)/m4/compiler.m4 $(top_srcdir)/m4/config_h.m4 \
-	$(top_srcdir)/m4/platform.m4 $(top_srcdir)/m4/subsets.m4 \
-	$(top_srcdir)/m4/threads.m4 $(top_srcdir)/m4/tls.m4 \
-	$(top_srcdir)/configure.ac
-am__configure_deps = $(am__aclocal_m4_deps) $(CONFIGURE_DEPENDENCIES) \
-	$(ACLOCAL_M4)
-mkinstalldirs = $(mkdir_p)
-CONFIG_HEADER = $(top_builddir)/ace/config.h
-CONFIG_CLEAN_FILES =
-am__installdirs = $(DESTDIR)$(libdir) $(DESTDIR)$(pkgincludedir)
-libLTLIBRARIES_INSTALL = $(INSTALL)
-LTLIBRARIES = $(lib_LTLIBRARIES)
-libACE_RMCast_la_DEPENDENCIES = $(top_builddir)/ace/libACE.la
-am_libACE_RMCast_la_OBJECTS = RMCast.lo RMCast_Ack_Worker.lo \
-	RMCast_Fork.lo RMCast_Fragment.lo RMCast_IO_UDP.lo \
-	RMCast_Membership.lo RMCast_Module.lo RMCast_Module_Factory.lo \
-	RMCast_Partial_Message.lo RMCast_Proxy.lo RMCast_Reassembly.lo \
-	RMCast_Receiver_Module.lo RMCast_Reliable_Factory.lo \
-	RMCast_Reordering.lo RMCast_Resend_Handler.lo \
-	RMCast_Resend_Worker.lo RMCast_Retransmission.lo \
-	RMCast_Sequencer.lo RMCast_Singleton_Factory.lo \
-	RMCast_UDP_Event_Handler.lo RMCast_UDP_Proxy.lo \
-	RMCast_UDP_Reliable_Receiver.lo RMCast_UDP_Reliable_Sender.lo
-libACE_RMCast_la_OBJECTS = $(am_libACE_RMCast_la_OBJECTS)
-DEFAULT_INCLUDES = -I. -I$(srcdir) -I$(top_builddir)/ace
-depcomp = $(SHELL) $(top_srcdir)/aux/depcomp
-am__depfiles_maybe = depfiles
- at AMDEP_TRUE@DEP_FILES = ./$(DEPDIR)/RMCast.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_Ack_Worker.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_Fork.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_Fragment.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_IO_UDP.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_Membership.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_Module.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_Module_Factory.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_Partial_Message.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_Proxy.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_Reassembly.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_Receiver_Module.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_Reliable_Factory.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_Reordering.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_Resend_Handler.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_Resend_Worker.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_Retransmission.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_Sequencer.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_Singleton_Factory.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_UDP_Event_Handler.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_UDP_Proxy.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_UDP_Reliable_Receiver.Plo \
- at AMDEP_TRUE@	./$(DEPDIR)/RMCast_UDP_Reliable_Sender.Plo
-CXXCOMPILE = $(CXX) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) \
-	$(AM_CPPFLAGS) $(CPPFLAGS) $(AM_CXXFLAGS) $(CXXFLAGS)
-LTCXXCOMPILE = $(LIBTOOL) --mode=compile $(CXX) $(DEFS) \
-	$(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) \
-	$(AM_CXXFLAGS) $(CXXFLAGS)
-CXXLD = $(CXX)
-CXXLINK = $(LIBTOOL) --mode=link $(CXXLD) $(AM_CXXFLAGS) $(CXXFLAGS) \
-	$(AM_LDFLAGS) $(LDFLAGS) -o $@
-DIST_SOURCES = $(libACE_RMCast_la_SOURCES)
-pkgincludeHEADERS_INSTALL = $(INSTALL_HEADER)
-HEADERS = $(pkginclude_HEADERS)
-ETAGS = etags
-CTAGS = ctags
-DISTFILES = $(DIST_COMMON) $(DIST_SOURCES) $(TEXINFOS) $(EXTRA_DIST)
-ACE_AGE = @ACE_AGE@
-ACE_CROSS_COMPILED_FALSE = @ACE_CROSS_COMPILED_FALSE@
-ACE_CROSS_COMPILED_TRUE = @ACE_CROSS_COMPILED_TRUE@
-ACE_CURRENT = @ACE_CURRENT@
-ACE_INCLUDEDIR = @ACE_INCLUDEDIR@
-ACE_LIBDIR = @ACE_LIBDIR@
-ACE_LIBS = @ACE_LIBS@
-ACE_ON_PENTIUM_FALSE = @ACE_ON_PENTIUM_FALSE@
-ACE_ON_PENTIUM_TRUE = @ACE_ON_PENTIUM_TRUE@
-ACE_REVISION = @ACE_REVISION@
-ACE_TESTS_DIR = @ACE_TESTS_DIR@
-ACE_TLS_CPPFLAGS = @ACE_TLS_CPPFLAGS@
-ACE_TLS_LIBS = @ACE_TLS_LIBS@
-ACE_XLIBS = @ACE_XLIBS@
-ACLOCAL = @ACLOCAL@
-ALLOCA = @ALLOCA@
-AMDEP_FALSE = @AMDEP_FALSE@
-AMDEP_TRUE = @AMDEP_TRUE@
-AMTAR = @AMTAR@
-AR = @AR@
-AS = @AS@
-AUTOCONF = @AUTOCONF@
-AUTOHEADER = @AUTOHEADER@
-AUTOMAKE = @AUTOMAKE@
-AWK = @AWK@
-BUILD_CODECS_FILES_FALSE = @BUILD_CODECS_FILES_FALSE@
-BUILD_CODECS_FILES_TRUE = @BUILD_CODECS_FILES_TRUE@
-BUILD_CONNECTION_FILES_FALSE = @BUILD_CONNECTION_FILES_FALSE@
-BUILD_CONNECTION_FILES_TRUE = @BUILD_CONNECTION_FILES_TRUE@
-BUILD_DEMUX_FILES_FALSE = @BUILD_DEMUX_FILES_FALSE@
-BUILD_DEMUX_FILES_TRUE = @BUILD_DEMUX_FILES_TRUE@
-BUILD_FULL_LIBRARY_FALSE = @BUILD_FULL_LIBRARY_FALSE@
-BUILD_FULL_LIBRARY_TRUE = @BUILD_FULL_LIBRARY_TRUE@
-BUILD_IPC_FILES_FALSE = @BUILD_IPC_FILES_FALSE@
-BUILD_IPC_FILES_TRUE = @BUILD_IPC_FILES_TRUE@
-BUILD_LOGGING_FILES_FALSE = @BUILD_LOGGING_FILES_FALSE@
-BUILD_LOGGING_FILES_TRUE = @BUILD_LOGGING_FILES_TRUE@
-BUILD_MEMORY_FILES_FALSE = @BUILD_MEMORY_FILES_FALSE@
-BUILD_MEMORY_FILES_TRUE = @BUILD_MEMORY_FILES_TRUE@
-BUILD_OS_FILES_FALSE = @BUILD_OS_FILES_FALSE@
-BUILD_OS_FILES_TRUE = @BUILD_OS_FILES_TRUE@
-BUILD_OTHER_FILES_FALSE = @BUILD_OTHER_FILES_FALSE@
-BUILD_OTHER_FILES_TRUE = @BUILD_OTHER_FILES_TRUE@
-BUILD_QOS_FALSE = @BUILD_QOS_FALSE@
-BUILD_QOS_TRUE = @BUILD_QOS_TRUE@
-BUILD_RMCAST_FALSE = @BUILD_RMCAST_FALSE@
-BUILD_RMCAST_TRUE = @BUILD_RMCAST_TRUE@
-BUILD_SOCKETS_FILES_FALSE = @BUILD_SOCKETS_FILES_FALSE@
-BUILD_SOCKETS_FILES_TRUE = @BUILD_SOCKETS_FILES_TRUE@
-BUILD_SSL_FALSE = @BUILD_SSL_FALSE@
-BUILD_SSL_TRUE = @BUILD_SSL_TRUE@
-BUILD_STREAMS_FILES_FALSE = @BUILD_STREAMS_FILES_FALSE@
-BUILD_STREAMS_FILES_TRUE = @BUILD_STREAMS_FILES_TRUE@
-BUILD_SVCCONF_FILES_FALSE = @BUILD_SVCCONF_FILES_FALSE@
-BUILD_SVCCONF_FILES_TRUE = @BUILD_SVCCONF_FILES_TRUE@
-BUILD_THREADS_FILES_FALSE = @BUILD_THREADS_FILES_FALSE@
-BUILD_THREADS_FILES_TRUE = @BUILD_THREADS_FILES_TRUE@
-BUILD_TIMER_FILES_FALSE = @BUILD_TIMER_FILES_FALSE@
-BUILD_TIMER_FILES_TRUE = @BUILD_TIMER_FILES_TRUE@
-BUILD_TOKEN_FILES_FALSE = @BUILD_TOKEN_FILES_FALSE@
-BUILD_TOKEN_FILES_TRUE = @BUILD_TOKEN_FILES_TRUE@
-BUILD_UTILS_FILES_FALSE = @BUILD_UTILS_FILES_FALSE@
-BUILD_UTILS_FILES_TRUE = @BUILD_UTILS_FILES_TRUE@
-CC = @CC@
-CCDEPMODE = @CCDEPMODE@
-CFLAGS = @CFLAGS@
-COMPILE_GPERF_FALSE = @COMPILE_GPERF_FALSE@
-COMPILE_GPERF_TRUE = @COMPILE_GPERF_TRUE@
-COMPILE_XTREACTOR_TEST_FALSE = @COMPILE_XTREACTOR_TEST_FALSE@
-COMPILE_XTREACTOR_TEST_TRUE = @COMPILE_XTREACTOR_TEST_TRUE@
-CPP = @CPP@
-CPPFLAGS = @CPPFLAGS@
-CXX = @CXX@
-CXXCPP = @CXXCPP@
-CXXDEPMODE = @CXXDEPMODE@
-CXXFLAGS = @CXXFLAGS@
-CYGPATH_W = @CYGPATH_W@
-DEFS = @DEFS@
-DEPDIR = @DEPDIR@
-DLLTOOL = @DLLTOOL@
-ECHO = @ECHO@
-ECHO_C = @ECHO_C@
-ECHO_N = @ECHO_N@
-ECHO_T = @ECHO_T@
-EGREP = @EGREP@
-EXEEXT = @EXEEXT@
-F77 = @F77@
-FFLAGS = @FFLAGS@
-GPERF = @GPERF@
-INSTALL_DATA = @INSTALL_DATA@
-INSTALL_PROGRAM = @INSTALL_PROGRAM@
-INSTALL_SCRIPT = @INSTALL_SCRIPT@
-INSTALL_STRIP_PROGRAM = @INSTALL_STRIP_PROGRAM@
-LDFLAGS = @LDFLAGS@
-LEX = @LEX@
-LEXLIB = @LEXLIB@
-LEX_OUTPUT_ROOT = @LEX_OUTPUT_ROOT@
-LIBOBJS = @LIBOBJS@
-LIBS = @LIBS@
-LIBTOOL = @LIBTOOL@
-LN_S = @LN_S@
-LTLIBOBJS = @LTLIBOBJS@
-MAKEINFO = @MAKEINFO@
-OBJDUMP = @OBJDUMP@
-OBJEXT = @OBJEXT@
-PACKAGE = @PACKAGE@
-PACKAGE_BUGREPORT = @PACKAGE_BUGREPORT@
-PACKAGE_NAME = @PACKAGE_NAME@
-PACKAGE_STRING = @PACKAGE_STRING@
-PACKAGE_TARNAME = @PACKAGE_TARNAME@
-PACKAGE_VERSION = @PACKAGE_VERSION@
-PATH_SEPARATOR = @PATH_SEPARATOR@
-PROF = @PROF@
-PURIFY = @PURIFY@
-QUANTIFY = @QUANTIFY@
-RANLIB = @RANLIB@
-SET_MAKE = @SET_MAKE@
-SHELL = @SHELL@
-STRIP = @STRIP@
-VERSION = @VERSION@
-XTREACTOR_TEST_XLIBS = @XTREACTOR_TEST_XLIBS@
-X_CFLAGS = @X_CFLAGS@
-X_EXTRA_LIBS = @X_EXTRA_LIBS@
-X_LIBS = @X_LIBS@
-X_PRE_LIBS = @X_PRE_LIBS@
-YACC = @YACC@
-ac_ct_AR = @ac_ct_AR@
-ac_ct_AS = @ac_ct_AS@
-ac_ct_CC = @ac_ct_CC@
-ac_ct_CXX = @ac_ct_CXX@
-ac_ct_DLLTOOL = @ac_ct_DLLTOOL@
-ac_ct_F77 = @ac_ct_F77@
-ac_ct_OBJDUMP = @ac_ct_OBJDUMP@
-ac_ct_RANLIB = @ac_ct_RANLIB@
-ac_ct_STRIP = @ac_ct_STRIP@
-am__fastdepCC_FALSE = @am__fastdepCC_FALSE@
-am__fastdepCC_TRUE = @am__fastdepCC_TRUE@
-am__fastdepCXX_FALSE = @am__fastdepCXX_FALSE@
-am__fastdepCXX_TRUE = @am__fastdepCXX_TRUE@
-am__include = @am__include@
-am__leading_dot = @am__leading_dot@
-am__quote = @am__quote@
-bindir = @bindir@
-build = @build@
-build_alias = @build_alias@
-build_cpu = @build_cpu@
-build_os = @build_os@
-build_vendor = @build_vendor@
-datadir = @datadir@
-exec_prefix = @exec_prefix@
-host = @host@
-host_alias = @host_alias@
-host_cpu = @host_cpu@
-host_os = @host_os@
-host_vendor = @host_vendor@
-includedir = @includedir@
-infodir = @infodir@
-install_sh = @install_sh@
-libdir = @libdir@
-libexecdir = @libexecdir@
-localstatedir = @localstatedir@
-mandir = @mandir@
-mkdir_p = @mkdir_p@
-oldincludedir = @oldincludedir@
-prefix = @prefix@
-program_transform_name = @program_transform_name@
-sbindir = @sbindir@
-sharedstatedir = @sharedstatedir@
-sysconfdir = @sysconfdir@
-target = @target@
-target_alias = @target_alias@
-target_cpu = @target_cpu@
-target_os = @target_os@
-target_vendor = @target_vendor@
-  RMCast.cpp \
-  RMCast_Fork.cpp \
-TEMPLATE_FILES = \
-  RMCast_Worker.cpp
-HEADER_FILES = \
-  RMCast.h \
-  RMCast_Export.h \
-  RMCast_Fork.h \
-  RMCast_IO_UDP.h \
-  RMCast_Module.h \
-  RMCast_Proxy.h \
-  RMCast_Worker.h
-INLINE_FILES = \
-  RMCast.i \
-  RMCast_Fork.i \
-  RMCast_IO_UDP.i \
-  RMCast_Module.i \
-  RMCast_Proxy.i \
-  RMCast_Worker.i
-  $(HEADER_FILES) \
-  $(INLINE_FILES) \
-  $(TEMPLATE_FILES)
-all: all-am
-.SUFFIXES:
-.SUFFIXES: .cpp .lo .o .obj
-$(srcdir)/Makefile.in:  $(srcdir)/Makefile.am  $(am__configure_deps)
-	@for dep in $?; do \
-	  case '$(am__configure_deps)' in \
-	    *$$dep*) \
-	      cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh \
-		&& exit 0; \
-	      exit 1;; \
-	  esac; \
-	done; \
-	echo ' cd $(top_srcdir) && $(AUTOMAKE) --gnu  ace/RMCast/Makefile'; \
-	cd $(top_srcdir) && \
-	  $(AUTOMAKE) --gnu  ace/RMCast/Makefile
-.PRECIOUS: Makefile
-Makefile: $(srcdir)/Makefile.in $(top_builddir)/config.status
-	@case '$?' in \
-	  *config.status*) \
-	    cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh;; \
-	    echo ' cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe)'; \
-	    cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe);; \
-	esac;
-$(top_builddir)/config.status: $(top_srcdir)/configure $(CONFIG_STATUS_DEPENDENCIES)
-$(top_srcdir)/configure:  $(am__configure_deps)
-$(ACLOCAL_M4):  $(am__aclocal_m4_deps)
-install-libLTLIBRARIES: $(lib_LTLIBRARIES)
-	@$(NORMAL_INSTALL)
-	$(mkdir_p) $(DESTDIR)$(libdir)
-	@list='$(lib_LTLIBRARIES)'; for p in $$list; do \
-	  if test -f $$p; then \
-	    f="`echo $$p | sed -e 's|^.*/||'`"; \
-	    echo " $(LIBTOOL) --mode=install $(libLTLIBRARIES_INSTALL) $(INSTALL_STRIP_FLAG) $$p $(DESTDIR)$(libdir)/$$f"; \
-	    $(LIBTOOL) --mode=install $(libLTLIBRARIES_INSTALL) $(INSTALL_STRIP_FLAG) $$p $(DESTDIR)$(libdir)/$$f; \
-	  else :; fi; \
-	done
-uninstall-libLTLIBRARIES:
-	@$(NORMAL_UNINSTALL)
-	    p="`echo $$p | sed -e 's|^.*/||'`"; \
-	  echo " $(LIBTOOL) --mode=uninstall rm -f $(DESTDIR)$(libdir)/$$p"; \
-	  $(LIBTOOL) --mode=uninstall rm -f $(DESTDIR)$(libdir)/$$p; \
-	done
-clean-libLTLIBRARIES:
-	-test -z "$(lib_LTLIBRARIES)" || rm -f $(lib_LTLIBRARIES)
-	  dir="`echo $$p | sed -e 's|/[^/]*$$||'`"; \
-	  test "$$dir" = "$$p" && dir=.; \
-	  echo "rm -f \"$${dir}/so_locations\""; \
-	  rm -f "$${dir}/so_locations"; \
-	done
-libACE_RMCast.la: $(libACE_RMCast_la_OBJECTS) $(libACE_RMCast_la_DEPENDENCIES)
-	$(CXXLINK) -rpath $(libdir) $(libACE_RMCast_la_LDFLAGS) $(libACE_RMCast_la_OBJECTS) $(libACE_RMCast_la_LIBADD) $(LIBS)
-mostlyclean-compile:
-	-rm -f *.$(OBJEXT)
-distclean-compile:
-	-rm -f *.tab.c
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_Ack_Worker.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_Fork.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_Fragment.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_IO_UDP.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_Membership.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_Module.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_Module_Factory.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_Partial_Message.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_Proxy.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_Reassembly.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_Receiver_Module.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_Reliable_Factory.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_Reordering.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_Resend_Handler.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_Resend_Worker.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_Retransmission.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_Sequencer.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_Singleton_Factory.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_UDP_Event_Handler.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_UDP_Proxy.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_UDP_Reliable_Receiver.Plo at am__quote@
- at AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/RMCast_UDP_Reliable_Sender.Plo at am__quote@
-.cpp.o:
- at am__fastdepCXX_TRUE@	if $(CXXCOMPILE) -MT $@ -MD -MP -MF "$(DEPDIR)/$*.Tpo" -c -o $@ $<; \
- at am__fastdepCXX_TRUE@	then mv -f "$(DEPDIR)/$*.Tpo" "$(DEPDIR)/$*.Po"; else rm -f "$(DEPDIR)/$*.Tpo"; exit 1; fi
- at AMDEP_TRUE@@am__fastdepCXX_FALSE@	source='$<' object='$@' libtool=no @AMDEPBACKSLASH@
- at AMDEP_TRUE@@am__fastdepCXX_FALSE@	depfile='$(DEPDIR)/$*.Po' tmpdepfile='$(DEPDIR)/$*.TPo' @AMDEPBACKSLASH@
- at AMDEP_TRUE@@am__fastdepCXX_FALSE@	$(CXXDEPMODE) $(depcomp) @AMDEPBACKSLASH@
- at am__fastdepCXX_FALSE@	$(CXXCOMPILE) -c -o $@ $<
-.cpp.obj:
- at am__fastdepCXX_TRUE@	if $(CXXCOMPILE) -MT $@ -MD -MP -MF "$(DEPDIR)/$*.Tpo" -c -o $@ `$(CYGPATH_W) '$<'`; \
- at am__fastdepCXX_FALSE@	$(CXXCOMPILE) -c -o $@ `$(CYGPATH_W) '$<'`
-.cpp.lo:
- at am__fastdepCXX_TRUE@	if $(LTCXXCOMPILE) -MT $@ -MD -MP -MF "$(DEPDIR)/$*.Tpo" -c -o $@ $<; \
- at am__fastdepCXX_TRUE@	then mv -f "$(DEPDIR)/$*.Tpo" "$(DEPDIR)/$*.Plo"; else rm -f "$(DEPDIR)/$*.Tpo"; exit 1; fi
- at AMDEP_TRUE@@am__fastdepCXX_FALSE@	source='$<' object='$@' libtool=yes @AMDEPBACKSLASH@
- at AMDEP_TRUE@@am__fastdepCXX_FALSE@	depfile='$(DEPDIR)/$*.Plo' tmpdepfile='$(DEPDIR)/$*.TPlo' @AMDEPBACKSLASH@
- at am__fastdepCXX_FALSE@	$(LTCXXCOMPILE) -c -o $@ $<
-mostlyclean-libtool:
-	-rm -f *.lo
-clean-libtool:
-	-rm -rf .libs _libs
-distclean-libtool:
-	-rm -f libtool
-uninstall-info-am:
-install-pkgincludeHEADERS: $(pkginclude_HEADERS)
-	$(mkdir_p) $(DESTDIR)$(pkgincludedir)
-	@list='$(pkginclude_HEADERS)'; for p in $$list; do \
-	  if test -f "$$p"; then d=; else d="$(srcdir)/"; fi; \
-	  echo " $(pkgincludeHEADERS_INSTALL) $$d$$p $(DESTDIR)$(pkgincludedir)/$$f"; \
-	  $(pkgincludeHEADERS_INSTALL) $$d$$p $(DESTDIR)$(pkgincludedir)/$$f; \
-	done
-uninstall-pkgincludeHEADERS:
-	  echo " rm -f $(DESTDIR)$(pkgincludedir)/$$f"; \
-	  rm -f $(DESTDIR)$(pkgincludedir)/$$f; \
-	done
-ID: $(HEADERS) $(SOURCES) $(LISP) $(TAGS_FILES)
-	list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \
-	unique=`for i in $$list; do \
-	    if test -f "$$i"; then echo $$i; else echo $(srcdir)/$$i; fi; \
-	  done | \
-	  $(AWK) '    { files[$$0] = 1; } \
-	       END { for (i in files) print i; }'`; \
-	mkid -fID $$unique
-tags: TAGS
-TAGS:  $(HEADERS) $(SOURCES)  $(TAGS_DEPENDENCIES) \
-		$(TAGS_FILES) $(LISP)
-	tags=; \
-	here=`pwd`; \
-	  done | \
-	test -z "$(ETAGS_ARGS)$$tags$$unique" \
-	  || $(ETAGS) $(ETAGSFLAGS) $(AM_ETAGSFLAGS) $(ETAGS_ARGS) \
-	     $$tags $$unique
-ctags: CTAGS
-CTAGS:  $(HEADERS) $(SOURCES)  $(TAGS_DEPENDENCIES) \
-	tags=; \
-	here=`pwd`; \
-	  done | \
-	test -z "$(CTAGS_ARGS)$$tags$$unique" \
-	  || $(CTAGS) $(CTAGSFLAGS) $(AM_CTAGSFLAGS) $(CTAGS_ARGS) \
-	     $$tags $$unique
-GTAGS:
-	here=`$(am__cd) $(top_builddir) && pwd` \
-	  && cd $(top_srcdir) \
-	  && gtags -i $(GTAGS_ARGS) $$here
-distclean-tags:
-	-rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags
-distdir: $(DISTFILES)
-	@srcdirstrip=`echo "$(srcdir)" | sed 's|.|.|g'`; \
-	topsrcdirstrip=`echo "$(top_srcdir)" | sed 's|.|.|g'`; \
-	list='$(DISTFILES)'; for file in $$list; do \
-	  case $$file in \
-	    $(srcdir)/*) file=`echo "$$file" | sed "s|^$$srcdirstrip/||"`;; \
-	    $(top_srcdir)/*) file=`echo "$$file" | sed "s|^$$topsrcdirstrip/|$(top_builddir)/|"`;; \
-	  esac; \
-	  if test -f $$file || test -d $$file; then d=.; else d=$(srcdir); fi; \
-	  dir=`echo "$$file" | sed -e 's,/[^/]*$$,,'`; \
-	  if test "$$dir" != "$$file" && test "$$dir" != "."; then \
-	    dir="/$$dir"; \
-	    $(mkdir_p) "$(distdir)$$dir"; \
-	  else \
-	    dir=''; \
-	  fi; \
-	  if test -d $$d/$$file; then \
-	    if test -d $(srcdir)/$$file && test $$d != $(srcdir); then \
-	      cp -pR $(srcdir)/$$file $(distdir)$$dir || exit 1; \
-	    fi; \
-	    cp -pR $$d/$$file $(distdir)$$dir || exit 1; \
-	  else \
-	    test -f $(distdir)/$$file \
-	    || cp -p $$d/$$file $(distdir)/$$file \
-	    || exit 1; \
-	  fi; \
-	done
-check-am: all-am
-check: check-am
-all-am: Makefile $(LTLIBRARIES) $(HEADERS)
-installdirs:
-	$(mkdir_p) $(DESTDIR)$(libdir) $(DESTDIR)$(pkgincludedir)
-install: install-am
-install-exec: install-exec-am
-install-data: install-data-am
-uninstall: uninstall-am
-install-am: all-am
-	@$(MAKE) $(AM_MAKEFLAGS) install-exec-am install-data-am
-installcheck: installcheck-am
-install-strip:
-	$(MAKE) $(AM_MAKEFLAGS) INSTALL_PROGRAM="$(INSTALL_STRIP_PROGRAM)" \
-	  install_sh_PROGRAM="$(INSTALL_STRIP_PROGRAM)" INSTALL_STRIP_FLAG=-s \
-	  `test -z '$(STRIP)' || \
-	    echo "INSTALL_PROGRAM_ENV=STRIPPROG='$(STRIP)'"` install
-mostlyclean-generic:
-clean-generic:
-distclean-generic:
-	-rm -f $(CONFIG_CLEAN_FILES)
-maintainer-clean-generic:
-	@echo "This command is intended for maintainers to use"
-	@echo "it deletes files that may require special tools to rebuild."
-clean: clean-am
-clean-am: clean-generic clean-libLTLIBRARIES clean-libtool \
-	mostlyclean-am
-distclean: distclean-am
-	-rm -rf ./$(DEPDIR)
-	-rm -f Makefile
-distclean-am: clean-am distclean-compile distclean-generic \
-	distclean-libtool distclean-tags
-dvi: dvi-am
-dvi-am:
-html: html-am
-info: info-am
-info-am:
-install-data-am: install-pkgincludeHEADERS
-install-exec-am: install-libLTLIBRARIES
-install-info: install-info-am
-install-man:
-installcheck-am:
-maintainer-clean: maintainer-clean-am
-	-rm -f Makefile
-maintainer-clean-am: distclean-am maintainer-clean-generic
-mostlyclean: mostlyclean-am
-mostlyclean-am: mostlyclean-compile mostlyclean-generic \
-	mostlyclean-libtool
-pdf: pdf-am
-pdf-am:
-ps: ps-am
-ps-am:
-uninstall-am: uninstall-info-am uninstall-libLTLIBRARIES \
-	uninstall-pkgincludeHEADERS
-.PHONY: CTAGS GTAGS all all-am check check-am clean clean-generic \
-	clean-libLTLIBRARIES clean-libtool ctags distclean \
-	distclean-compile distclean-generic distclean-libtool \
-	distclean-tags distdir dvi dvi-am html html-am info info-am \
-	install install-am install-data install-data-am install-exec \
-	install-exec-am install-info install-info-am \
-	install-libLTLIBRARIES install-man install-pkgincludeHEADERS \
-	install-strip installcheck installcheck-am installdirs \
-	maintainer-clean maintainer-clean-generic mostlyclean \
-	mostlyclean-compile mostlyclean-generic mostlyclean-libtool \
-	pdf pdf-am ps ps-am tags uninstall uninstall-am \
-	uninstall-info-am uninstall-libLTLIBRARIES \
-# Tell versions [3.59,3.63) of GNU make to not export all variables.
-# Otherwise a system limit (for SysV at least) may be exceeded.
-.NOEXPORT:
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/README
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/README	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/README	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,57 +0,0 @@
-# README,v 1.1 2000/08/21 16:09:36 coryan Exp
-	This directory will contain a simple, small-scale reliable
-multicast framework for ACE.  The framework is based on the ASX
-components of the ACE library: the protocol is implemented as a stack
-of interchangeable "modules", each one in charge of a very small task.
-For example, one module implements fragmentation and reassembly, other
-modules implement retransmission, send ACK and NAK messages, and
-maintain receiver membership.
-	The modules are replaced to achieve different levels of
-reliability.  For example, the retransmission module can be either the
-"Best_Effort", "Semi_Reliable" or "Reliable" implementation.  In the
-first case no retransmissions are performed, but lost messages are
-detected and reported to the receiver.  The "Semi_Reliable" case
-messages are held for a pre-specified amount of time, and
-re-transmited if requested, but it is possible to loose some messages
-if multiple re-transmissions fail.  As in the "Best_Effort" case the
-lost messages are detected and flagged to the application.  Finally
-in the "Reliable" mode the senders are flowed controlled until enough
-messages are successfully transmitted.
-	In general the stack looks like this:
-SENDER:
-Buffering	:	Save lost messages
-Retransmission	:	Retransmit
-Fragmentation   :	Fragment messages in smaller chunks
-Reassembly	:	and ensure that the IOVMAX limit is not
-		:	reached
-Tranport	:	Encapsulate the specific transport media
-		:	such as TCP/IP, ATM, or shared memory
-		:	Demuxes incoming data to the right chain
-		:	Change control messages and data messages
-		:	to the right dynamic types.
-RECEIVER:
-Lost detection	:	Detect lost messages and send control
-		:	messages back
-Reassembly	:	Reassemble messages, fragment control
-Fragmentation	:	data
-Transport	:	Group membership, ACT reception,
-		:	handle keep-alive messages...
-@@ TODO: Piggybacking...
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,9 +0,0 @@
-// RMCast.cpp,v 1.1 2000/08/10 01:35:37 coryan Exp
-#include "RMCast.h"
-#if !defined (__ACE_INLINE__)
-#include "RMCast.i"
-#endif /* __ACE_INLINE__ */
-ACE_RCSID(ace, RMCast, "RMCast.cpp,v 1.1 2000/08/10 01:35:37 coryan Exp")
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.dsp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.dsp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.dsp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,403 +0,0 @@
-# Microsoft Developer Studio Project File - Name="RMCast" - Package Owner=<4>
-# Microsoft Developer Studio Generated Build File, Format Version 6.00
-# ** DO NOT EDIT **
-# TARGTYPE "Win32 (x86) Dynamic-Link Library" 0x0102
-CFG=RMCast - Win32 Debug
-!MESSAGE This is not a valid makefile. To build this project using NMAKE,
-!MESSAGE run the tool that generated this project file and specify the
-!MESSAGE nmake output type.  You can then use the following command:
-!MESSAGE
-!MESSAGE NMAKE /f "RMCast.mak".
-!MESSAGE
-!MESSAGE You can specify a configuration when running NMAKE
-!MESSAGE by defining the macro CFG on the command line. For example:
-!MESSAGE
-!MESSAGE NMAKE /f "RMCast.mak" CFG="RMCast - Win32 Debug"
-!MESSAGE
-!MESSAGE Possible choices for configuration are:
-!MESSAGE
-!MESSAGE "RMCast - Win32 Release" (based on "Win32 (x86) Dynamic-Link Library")
-!MESSAGE "RMCast - Win32 Debug" (based on "Win32 (x86) Dynamic-Link Library")
-!MESSAGE
-# Begin Project
-# PROP AllowPerConfigDependencies 0
-# PROP Scc_ProjName ""
-# PROP Scc_LocalPath ""
-CPP=cl.exe
-RSC=rc.exe
-!IF  "$(CFG)" == "RMCast - Win32 Release"
-# PROP Use_MFC 0
-# PROP Use_Debug_Libraries 0
-# PROP Output_Dir "..\..\lib"
-# PROP Intermediate_Dir "Release\RMCast"
-# PROP Ignore_Export_Lib 0
-# PROP Target_Dir ""
-# ADD CPP /nologo /O2 /W3 /GX /MD /GR /I "..\.." /D NDEBUG /D WIN32 /D _WINDOWS /D ACE_RMCAST_BUILD_DLL /FD /c
-# SUBTRACT CPP /YX
-# ADD RSC /l 0x409 /d NDEBUG /i "..\.."
-BSC32=bscmake.exe
-# ADD BSC32 /nologo /o"..\..\lib\ACE_RMCast.bsc"
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACE.lib /libpath:"..\..\lib" /nologo /version:5.4 /subsystem:windows /pdb:"..\..\lib\ACE_RMCast.pdb" /dll  /machine:I386 /out:"..\..\lib\ACE_RMCast.dll"
-!ELSEIF  "$(CFG)" == "RMCast - Win32 Debug"
-# PROP Use_MFC 0
-# PROP Use_Debug_Libraries 1
-# PROP Intermediate_Dir "Debug\RMCast"
-# ADD CPP /nologo /Ob0 /W3 /Gm /GX /Zi /MDd /GR /Gy /I "..\.." /D _DEBUG /D WIN32 /D _WINDOWS /D ACE_RMCAST_BUILD_DLL /FD /c
-# SUBTRACT CPP /Fr /YX
-# ADD RSC /l 0x409 /d _DEBUG /i "..\.."
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 advapi32.lib user32.lib /INCREMENTAL:NO ACEd.lib /libpath:"..\..\lib" /nologo /version:5.4 /subsystem:windows /pdb:"..\..\lib\ACE_RMCastd.pdb" /dll /debug /machine:I386 /out:"..\..\lib\ACE_RMCastd.dll"
-!ENDIF
-# Begin Target
-# Name "RMCast - Win32 Release"
-# Name "RMCast - Win32 Debug"
-# Begin Group "Source Files"
-# PROP Default_Filter "cpp;cxx;c"
-# Begin Source File
-SOURCE="RMCast.cpp"
-# End Source File
-SOURCE="RMCast_Ack_Worker.cpp"
-# End Source File
-SOURCE="RMCast_Copy_On_Write.cpp"
-# End Source File
-SOURCE="RMCast_Fork.cpp"
-# End Source File
-SOURCE="RMCast_Fragment.cpp"
-# End Source File
-SOURCE="RMCast_IO_UDP.cpp"
-# End Source File
-SOURCE="RMCast_Membership.cpp"
-# End Source File
-SOURCE="RMCast_Module.cpp"
-# End Source File
-SOURCE="RMCast_Module_Factory.cpp"
-# End Source File
-SOURCE="RMCast_Partial_Message.cpp"
-# End Source File
-SOURCE="RMCast_Proxy.cpp"
-# End Source File
-SOURCE="RMCast_Reassembly.cpp"
-# End Source File
-SOURCE="RMCast_Receiver_Module.cpp"
-# End Source File
-SOURCE="RMCast_Reliable_Factory.cpp"
-# End Source File
-SOURCE="RMCast_Reordering.cpp"
-# End Source File
-SOURCE="RMCast_Resend_Handler.cpp"
-# End Source File
-SOURCE="RMCast_Resend_Worker.cpp"
-# End Source File
-SOURCE="RMCast_Retransmission.cpp"
-# End Source File
-SOURCE="RMCast_Sequencer.cpp"
-# End Source File
-SOURCE="RMCast_Singleton_Factory.cpp"
-# End Source File
-SOURCE="RMCast_UDP_Event_Handler.cpp"
-# End Source File
-SOURCE="RMCast_UDP_Proxy.cpp"
-# End Source File
-SOURCE="RMCast_UDP_Reliable_Receiver.cpp"
-# End Source File
-SOURCE="RMCast_UDP_Reliable_Sender.cpp"
-# End Source File
-SOURCE="RMCast_Worker.cpp"
-# End Source File
-# End Group
-# Begin Group "Header Files"
-# PROP Default_Filter "h;hpp;hxx;hh"
-SOURCE="RMCast.h"
-# End Source File
-SOURCE="RMCast_Ack_Worker.h"
-# End Source File
-SOURCE="RMCast_Copy_On_Write.h"
-# End Source File
-SOURCE="RMCast_Export.h"
-# End Source File
-SOURCE="RMCast_Fork.h"
-# End Source File
-SOURCE="RMCast_Fragment.h"
-# End Source File
-SOURCE="RMCast_IO_UDP.h"
-# End Source File
-SOURCE="RMCast_Membership.h"
-# End Source File
-SOURCE="RMCast_Module.h"
-# End Source File
-SOURCE="RMCast_Module_Factory.h"
-# End Source File
-SOURCE="RMCast_Partial_Message.h"
-# End Source File
-SOURCE="RMCast_Proxy.h"
-# End Source File
-SOURCE="RMCast_Reassembly.h"
-# End Source File
-SOURCE="RMCast_Receiver_Module.h"
-# End Source File
-SOURCE="RMCast_Reliable_Factory.h"
-# End Source File
-SOURCE="RMCast_Reordering.h"
-# End Source File
-SOURCE="RMCast_Resend_Handler.h"
-# End Source File
-SOURCE="RMCast_Resend_Worker.h"
-# End Source File
-SOURCE="RMCast_Retransmission.h"
-# End Source File
-SOURCE="RMCast_Sequencer.h"
-# End Source File
-SOURCE="RMCast_Singleton_Factory.h"
-# End Source File
-SOURCE="RMCast_UDP_Event_Handler.h"
-# End Source File
-SOURCE="RMCast_UDP_Proxy.h"
-# End Source File
-SOURCE="RMCast_UDP_Reliable_Receiver.h"
-# End Source File
-SOURCE="RMCast_UDP_Reliable_Sender.h"
-# End Source File
-SOURCE="RMCast_Worker.h"
-# End Source File
-# End Group
-# Begin Group "Inline Files"
-# PROP Default_Filter "i;inl"
-SOURCE="RMCast.i"
-# End Source File
-SOURCE="RMCast_Ack_Worker.i"
-# End Source File
-SOURCE="RMCast_Copy_On_Write.i"
-# End Source File
-SOURCE="RMCast_Fork.i"
-# End Source File
-SOURCE="RMCast_Fragment.i"
-# End Source File
-SOURCE="RMCast_IO_UDP.i"
-# End Source File
-SOURCE="RMCast_Membership.i"
-# End Source File
-SOURCE="RMCast_Module.i"
-# End Source File
-SOURCE="RMCast_Module_Factory.i"
-# End Source File
-SOURCE="RMCast_Partial_Message.i"
-# End Source File
-SOURCE="RMCast_Proxy.i"
-# End Source File
-SOURCE="RMCast_Reassembly.i"
-# End Source File
-SOURCE="RMCast_Receiver_Module.i"
-# End Source File
-SOURCE="RMCast_Reliable_Factory.i"
-# End Source File
-SOURCE="RMCast_Reordering.i"
-# End Source File
-SOURCE="RMCast_Resend_Handler.i"
-# End Source File
-SOURCE="RMCast_Resend_Worker.i"
-# End Source File
-SOURCE="RMCast_Retransmission.i"
-# End Source File
-SOURCE="RMCast_Sequencer.i"
-# End Source File
-SOURCE="RMCast_Singleton_Factory.i"
-# End Source File
-SOURCE="RMCast_UDP_Event_Handler.i"
-# End Source File
-SOURCE="RMCast_UDP_Proxy.i"
-# End Source File
-SOURCE="RMCast_UDP_Reliable_Receiver.i"
-# End Source File
-SOURCE="RMCast_UDP_Reliable_Sender.i"
-# End Source File
-SOURCE="RMCast_Worker.i"
-# End Source File
-# End Group
-# Begin Group "Documentation"
-# PROP Default_Filter ""
-SOURCE="README"
-# End Source File
-# End Group
-# Begin Group "Resource Files"
-# PROP Default_Filter "rc;ico;cur;bmp;dlg;rc2;rct;bin;cnt;rtf;gif;jpg;jpeg;jpe"
-SOURCE="RMCast.rc"
-# End Source File
-# End Group
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.dsw
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.dsw	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.dsw	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,29 +0,0 @@
-Microsoft Developer Studio Workspace File, Format Version 6.00
-# WARNING: DO NOT EDIT OR DELETE THIS WORKSPACE FILE!
-Project: "RMCast"=.\RMCast.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Global:
-Package=<5>
-Package=<3>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,257 +0,0 @@
-/* -*- C++ -*- */
-// RMCast.h,v 1.12 2003/12/20 04:58:53 bala Exp
-// = LIBRARY
-//    ace
-// = FILENAME
-//    RMCast.h
-// = AUTHOR
-//    Carlos O'Ryan <coryan at uci.edu>
-#ifndef ACE_RMCAST_H
-#define ACE_RMCAST_H
-#include /**/ "ace/pre.h"
-#include "RMCast_Export.h"
-#if !defined (ACE_LACKS_PRAGMA_ONCE)
-# pragma once
-#endif /* ACE_LACKS_PRAGMA_ONCE */
-#include "ace/Basic_Types.h"
-class ACE_Message_Block;
-class ACE_RMCast_Proxy;
-//! The RMCast namespace
-  Several simple data structures and enums are shared by all the
-  RMCast components, this is the place where we put them by default.
-class ACE_RMCast_Export ACE_RMCast
-public:
-  //! The message types
-    Each message includes a type field in the header used by the
-    receiver to correctly parse it.
-    Classes with the same name as the message type describe the actual
-    format of the message.
-  enum Message_Type
-    // Sender initiated
-    RMCAST_MT_POLL,
-    RMCAST_MT_ACK_JOIN,
-    RMCAST_MT_ACK_LEAVE,
-    RMCAST_MT_DATA,
-    // Receiver initiated
-    RMCAST_MT_JOIN,
-    RMCAST_MT_LEAVE,
-    RMCAST_MT_ACK,
-    RMCAST_MT_LAST
-  //! Simle enum used to describe the state transitions for senders
-   State transition (and actions) for the senders.
-   This configuration is pesimistic, any invalid message is cause
-   enough to reclaim all the resources.  This partially addresses
-   situations where either accidentally or intentionally a sender is
-   multicasting packets to the wrong group.
-  <CODE>
-              NON_EXISTENT   JOINED<BR>
-   ------------------------------------------<BR>
-   POLL       NON_EXISTENT   NON_EXISTENT<BR>
-              Destroy        Destroy<BR>
-  <BR>
-   ACK        NON_EXISTENT   JOINED<BR>
-              Noop           Process/Ack<BR>
-  <BR>
-   JOIN       JOINED         NON_EXISTENT<BR>
-              Send/Join_Ack  Send/Join_Ack<BR>
-  <BR>
-   LEAVE      NON_EXISTENT   NON_EXISTENT<BR>
-              Send/Leave_Ack Send/Leave_Ack<BR>
-                             Destroy<BR>
-  <BR>
-   ACK_JOIN   NON_EXISTENT   NON_EXISTENT<BR>
-              Noop           Destroy<BR>
-  <BR>
-   ACK_LEAVE  NON_EXISTENT   NON_EXISTENT<BR>
-              Noop           Destroy<BR>
-  <BR>
-   SEND_DATA  NON_EXISTENT   NON_EXISTENT<BR>
-              Noop           Destroy<BR>
-  </CODE>
-  enum Sender_State
-    SS_NON_EXISTENT,
-    SS_JOINED
-  // These structures define the basic layout of the messages.
-  //! This is the main message sent by senders
-  <CODE>
-   +---------+----------------------+<BR>
-   | 8 bits  | DATA                 |<BR>
-   | 32 bits | sequence_number      |<BR>
-   | 32 bits | message_size         |<BR>
-   | 32 bits | fragment_offset      |<BR>
-   ? ? ? ? ? | 32 bits | payload_size         |<BR>
-   ? ? ? ? ? +---------+----------------------+<BR>
-   |         | payload              |<BR>
-  </CODE>
-  struct Data
-    // Source ID is implicit in recvfrom()...
-    ACE_UINT32 sequence_number;
-    ACE_UINT32 total_size;
-    ACE_UINT32 fragment_offset;
-    // @@ TODO: we may want to add optional fields, such as:
-    //    - Polling clients for their status
-    //    - Sending the range of messages in the queue
-    //    - If we are using authentic group communication we may
-    //    piggyback the ACK / NAK messages
-    ACE_Message_Block *payload;
-    //! Pass the proxy source between layers
-    ACE_RMCast_Proxy *source;
-    <CODE>
-    | 8 bits  | RMCAST_MT_POLL              |<BR>
-    </CODE>
-  struct Poll
-  //! Receivers accept new members using this message
-    <CODE>
-    | 8 bits  | RMCAST_MT_ACK_JOIN          |<BR>
-    | 32 bits | next_sequence_number |<BR>
-    </CODE>
-  struct Ack_Join
-    ACE_UINT32 next_sequence_number;
-  //! Senders acknowledge when receivers try to leave
-  <CODE>
-    | 8 bits  | ACK_LEAVE            |<BR>
-    </CODE>
-  struct Ack_Leave
-  //! Provide feedback to the sender about messages received and sent
-  //! so far.
-   * This message is used to provide feedback information to senders.
-   * It contains two sequence numbers:
-   * - \param next_expected: is the sequence number of the next message
-   *   expected, i.e. (next_expected-1) is the last message received
-   *   without any losses before it.
-   * - \param highest_received: is the highest sequence number among
-   *   all the messages successfully received.
-   * In other words, all messages lost (if any) are in the range:
-   * [next_expected,highest_received)
-   * <CODE>
-   * +---------+----------------------+<BR>
-   * | 8 bits  | RMCAST_MT_ACK               |<BR>
-   * | 32 bits | next_expected        |<BR>
-   * | 32 bits | highest_received     |<BR>
-   * </CODE>
-  struct Ack
-    //! The last message received without any losses before it.
-    ACE_UINT32 next_expected;
-    //! The last message successfully received
-    ACE_UINT32 highest_received;
-  //! Receivers send this message to indicate they want to join
-  <CODE>
-    | 8 bits  | RMCAST_MT_JOIN              |<BR>
-  </CODE>
-  struct Join
-  //! Receivers send this message to disconnect gracefully
-  <CODE>
-    | 8 bits  | RMCAST_MT_LEAVE             |<BR>
-  </CODE>
-  struct Leave
-#if defined (__ACE_INLINE__)
-#include /**/ "ace/post.h"
-#endif /* ACE_RMCAST_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1 +0,0 @@
-// RMCast.i,v 1.1 2000/08/10 01:35:37 coryan Exp
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.rc
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.rc	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.rc	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,30 +0,0 @@
-#include "..\Version.h"
-1 VERSIONINFO
- FILEVERSION ACE_MAJOR_VERSION,ACE_MINOR_VERSION,ACE_BETA_VERSION,0
- PRODUCTVERSION ACE_MAJOR_VERSION,ACE_MINOR_VERSION,ACE_BETA_VERSION,0
- FILEFLAGSMASK 0x3fL
- FILEFLAGS 0x0L
- FILEOS 0x4L
- FILETYPE 0x1L
- FILESUBTYPE 0x0L
-BEGIN
-    BLOCK "StringFileInfo"
-    BEGIN
-        BLOCK "040904B0"
-        BEGIN
-            VALUE "FileDescription", "RMCast\0"
-            VALUE "FileVersion", ACE_VERSION "\0"
-            VALUE "InternalName", "RMCastDLL\0"
-            VALUE "LegalCopyright", "\0"
-            VALUE "LegalTrademarks", "\0"
-            VALUE "OriginalFilename", "RMCast.DLL\0"
-            VALUE "ProductName", "ACE\0"
-            VALUE "ProductVersion", ACE_VERSION "\0"
-        END
-    END
-    BLOCK "VarFileInfo"
-    BEGIN
-        VALUE "Translation", 0x409, 1200
-    END
-END
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.vcp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.vcp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.vcp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,503 +0,0 @@
-# Microsoft eMbedded Visual Tools Project File - Name="RMCast" - Package Owner=<4>
-# Microsoft eMbedded Visual Tools Generated Build File, Format Version 6.02
-# TARGTYPE "Win32 (WCE ARM) Dynamic-Link Library" 0x8502
-# TARGTYPE "Win32 (WCE x86) Dynamic-Link Library" 0x8302
-# TARGTYPE "Win32 (WCE emulator) Dynamic-Link Library" 0xa602
-CFG=RMCast - Win32 (WCE ARM) Debug
-!MESSAGE
-!MESSAGE NMAKE /f "RMCast.vcn".
-!MESSAGE
-!MESSAGE
-!MESSAGE NMAKE /f "RMCast.vcn" CFG="RMCast - Win32 (WCE ARM) Debug"
-!MESSAGE
-!MESSAGE
-!MESSAGE "RMCast - Win32 (WCE ARM) Release" (based on "Win32 (WCE ARM) Dynamic-Link Library")
-!MESSAGE "RMCast - Win32 (WCE ARM) Debug" (based on "Win32 (WCE ARM) Dynamic-Link Library")
-!MESSAGE "RMCast - Win32 (WCE x86) Release" (based on "Win32 (WCE x86) Dynamic-Link Library")
-!MESSAGE "RMCast - Win32 (WCE x86) Debug" (based on "Win32 (WCE x86) Dynamic-Link Library")
-!MESSAGE "RMCast - Win32 (WCE emulator) Release" (based on "Win32 (WCE emulator) Dynamic-Link Library")
-!MESSAGE "RMCast - Win32 (WCE emulator) Debug" (based on "Win32 (WCE emulator) Dynamic-Link Library")
-!MESSAGE
-# Begin Project
-# PROP ATL_Project 2
-!IF  "$(CFG)" == "RMCast - Win32 (WCE ARM) Release"
-# PROP Use_MFC 0
-# PROP Output_Dir "..\..\lib\ARM"
-# PROP Intermediate_Dir "Release\RMCast\ARM"
-# PROP CPU_ID "{D6518FFC-710F-11D3-99F2-00105A0DF099}"
-# PROP Platform_ID "{8A9A2F80-6887-11D3-842E-005004848CBA}"
-RSC=rc.exe
-# ADD RSC /l 0x409 /d UNDER_CE=$(CEVersion) /d _WIN32_WCE=$(CEVersion) /d "$(CePlatform)" /d NDEBUG /d UNICODE /d _UNICODE /d ARM /d _ARM_ /i "..\.." /r
-CPP=clarm.exe
-# ADD CPP /nologo /O2 /W3 /I "..\.." /D _WIN32_WCE=$(CEVersion) /D "$(CePlatform)" /D UNDER_CE=$(CEVersion) /D NDEBUG /D UNICODE /D _UNICODE /D ARM /D _ARM_ /D ACE_RMCAST_BUILD_DLL /FR /FD /c
-# SUBTRACT CPP /YX
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 winsock.lib commctrl.lib coredll.lib iphlpapi.lib /INCREMENTAL:NO ACE.lib /libpath:"..\..\lib\ARM" /nologo /base:"0x00100000"  /entry:"_DllMainCRTStartup" /nodefaultlib:"$(CENoDefaultLib)" /version:5.4 /subsystem:$(CESubsystem) /align:"4096" /pdb:"..\..\lib\ARM\ACE_RMCast.pdb"  /dll /debug /machine:ARM /out:"..\..\lib\ARM\ACE_RMCast.dll"
-!ELSEIF  "$(CFG)" == "RMCast - Win32 (WCE ARM) Debug"
-# PROP Use_MFC 0
-# PROP Intermediate_Dir "Debug\RMCast\ARM"
-RSC=rc.exe
-# ADD RSC /l 0x409 /d UNDER_CE=$(CEVersion) /d _WIN32_WCE=$(CEVersion) /d "$(CePlatform)" /d _DEBUG /d UNICODE /d _UNICODE /d ARM /d _ARM_ /i "..\.." /r
-CPP=clarm.exe
-# ADD CPP /nologo /Ob0 /W3 /Zi /I "..\.." /D _WIN32_WCE=$(CEVersion) /D "$(CePlatform)" /D UNDER_CE=$(CEVersion) /D _DEBUG /D UNICODE /D _UNICODE /D ARM /D _ARM_ /D ACE_RMCAST_BUILD_DLL /FR /FD /c
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 winsock.lib commctrl.lib coredll.lib iphlpapi.lib /INCREMENTAL:NO ACEd.lib /libpath:"..\..\lib\ARM" /nologo /base:"0x00100000"  /entry:"_DllMainCRTStartup" /nodefaultlib:"$(CENoDefaultLib)" /version:5.4 /subsystem:$(CESubsystem) /align:"4096" /pdb:"..\..\lib\ARM\ACE_RMCastd.pdb"  /dll /debug /machine:ARM /out:"..\..\lib\ARM\ACE_RMCastd.dll"
-!ENDIF
-!IF  "$(CFG)" == "RMCast - Win32 (WCE x86) Release"
-# PROP Use_MFC 0
-# PROP Output_Dir "..\..\lib\IX86"
-# PROP Intermediate_Dir "Release\RMCast\IX86"
-# PROP CPU_ID "{D6518FF3-710F-11D3-99F2-00105A0DF099}"
-RSC=rc.exe
-# ADD RSC /l 0x409 /d UNDER_CE=$(CEVersion) /d _WIN32_WCE=$(CEVersion) /d "$(CePlatform)" /d NDEBUG /d UNICODE /d _UNICODE /d _i386_ /d _X86_ /d x86 /i "..\.." /r
-CPP=cl.exe
-# ADD CPP /nologo /O2 /W3 /I "..\.." /D _WIN32_WCE=$(CEVersion) /D "$(CePlatform)" /D UNDER_CE=$(CEVersion) /D NDEBUG /D UNICODE /D _UNICODE /D _i386_ /D _X86_ /D x86 /D ACE_RMCAST_BUILD_DLL /FR /FD /c
-# SUBTRACT CPP /YX
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 winsock.lib commctrl.lib coredll.lib iphlpapi.lib /INCREMENTAL:NO ACE.lib /libpath:"..\..\lib\IX86" /nologo /base:"0x00100000"  /entry:"_DllMainCRTStartup" /nodefaultlib:"$(CENoDefaultLib)" /version:5.4 /subsystem:$(CESubsystem) /align:"4096" /pdb:"..\..\lib\IX86\ACE_RMCast.pdb"  /dll /debug /machine:IX86 /out:"..\..\lib\IX86\ACE_RMCast.dll"
-!ELSEIF  "$(CFG)" == "RMCast - Win32 (WCE x86) Debug"
-# PROP Use_MFC 0
-# PROP Intermediate_Dir "Debug\RMCast\IX86"
-RSC=rc.exe
-# ADD RSC /l 0x409 /d UNDER_CE=$(CEVersion) /d _WIN32_WCE=$(CEVersion) /d "$(CePlatform)" /d _DEBUG /d UNICODE /d _UNICODE /d _i386_ /d _X86_ /d x86 /i "..\.." /r
-CPP=cl.exe
-# ADD CPP /nologo /Ob0 /W3 /Zi /I "..\.." /D _WIN32_WCE=$(CEVersion) /D "$(CePlatform)" /D UNDER_CE=$(CEVersion) /D _DEBUG /D UNICODE /D _UNICODE /D _i386_ /D _X86_ /D x86 /D ACE_RMCAST_BUILD_DLL /FR /FD /c
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 winsock.lib commctrl.lib coredll.lib iphlpapi.lib /INCREMENTAL:NO ACEd.lib /libpath:"..\..\lib\IX86" /nologo /base:"0x00100000"  /entry:"_DllMainCRTStartup" /nodefaultlib:"$(CENoDefaultLib)" /version:5.4 /subsystem:$(CESubsystem) /align:"4096" /pdb:"..\..\lib\IX86\ACE_RMCastd.pdb"  /dll /debug /machine:IX86 /out:"..\..\lib\IX86\ACE_RMCastd.dll"
-!ENDIF
-!IF  "$(CFG)" == "RMCast - Win32 (WCE emulator) Release"
-# PROP Use_MFC 0
-RSC=rc.exe
-CPP=cl.exe
-# SUBTRACT CPP /YX
-BSC32=bscmake.exe
-LINK32=link.exe
-!ELSEIF  "$(CFG)" == "RMCast - Win32 (WCE emulator) Debug"
-# PROP Use_MFC 0
-RSC=rc.exe
-CPP=cl.exe
-BSC32=bscmake.exe
-LINK32=link.exe
-!ENDIF
-# Begin Target
-# Name "RMCast - Win32 (WCE ARM) Release"
-# Name "RMCast - Win32 (WCE ARM) Debug"
-# Name "RMCast - Win32 (WCE x86) Release"
-# Name "RMCast - Win32 (WCE x86) Debug"
-# Name "RMCast - Win32 (WCE emulator) Release"
-# Name "RMCast - Win32 (WCE emulator) Debug"
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Group
-SOURCE="RMCast.h"
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Group
-SOURCE="RMCast.i"
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Source File
-# End Group
-SOURCE="README"
-# End Source File
-# End Group
-SOURCE="RMCast.rc"
-# End Source File
-# End Group
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.vcproj
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.vcproj	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast.vcproj	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,548 +0,0 @@
-<?xml version="1.0" encoding="Windows-1252"?>
-<VisualStudioProject
-	ProjectType="Visual C++"
-	Version="8.00"
-	Name="RMCast"
-	ProjectGUID="{6952E1FE-FECA-1BAD-5646-8D280B15AEE5}"
-	<Platforms>
-		<Platform
-			Name="Win32"
-	</Platforms>
-	<ToolFiles>
-	</ToolFiles>
-	<Configurations>
-		<Configuration
-			Name="Release|Win32"
-			OutputDirectory="..\..\lib"
-			IntermediateDirectory="Release/RMCast"
-			ConfigurationType="2"
-			InheritedPropertySheets="$(VCInstallDir)VCProjectDefaults\UpgradeFromVC71.vsprops"
-			UseOfMFC="0"
-			ATLMinimizesCRunTimeLibraryUsage="false"
-			CharacterSet="1"
-			<Tool
-				Name="VCPreBuildEventTool"
-			<Tool
-				Name="VCCustomBuildTool"
-			<Tool
-				Name="VCXMLDataGeneratorTool"
-			<Tool
-				Name="VCWebServiceProxyGeneratorTool"
-			<Tool
-				Name="VCMIDLTool"
-			<Tool
-				Name="VCCLCompilerTool"
-				Optimization="3"
-				AdditionalIncludeDirectories="..\.."
-				PreprocessorDefinitions="ACE_RMCAST_BUILD_DLL;NDEBUG;WIN32;_WINDOWS"
-				MinimalRebuild="false"
-				ExceptionHandling="1"
-				RuntimeLibrary="2"
-				BufferSecurityCheck="true"
-				EnableFunctionLevelLinking="true"
-				TreatWChar_tAsBuiltInType="true"
-				ForceConformanceInForLoopScope="true"
-				RuntimeTypeInfo="true"
-				WarningLevel="3"
-				SuppressStartupBanner="true"
-				Detect64BitPortabilityProblems="false"
-				DebugInformationFormat="3"
-			<Tool
-				Name="VCManagedResourceCompilerTool"
-			<Tool
-				Name="VCResourceCompilerTool"
-				PreprocessorDefinitions="NDEBUG"
-				Culture="1033"
-			<Tool
-				Name="VCPreLinkEventTool"
-			<Tool
-				Name="VCLinkerTool"
-				AdditionalDependencies="ACE.lib"
-				OutputFile="$(OutDir)/ACE_RMCast.dll"
-				Version="5.4"
-				LinkIncremental="1"
-				AdditionalLibraryDirectories="..\..\lib"
-				GenerateDebugInformation="true"
-				ProgramDatabaseFile="$(OutDir)/ACE_RMCast.pdb"
-				SubSystem="1"
-				OptimizeReferences="2"
-				EnableCOMDATFolding="2"
-				ImportLibrary="$(OutDir)/ACE_RMCast.lib"
-			<Tool
-				Name="VCALinkTool"
-			<Tool
-				Name="VCManifestTool"
-			<Tool
-				Name="VCXDCMakeTool"
-			<Tool
-				Name="VCBscMakeTool"
-			<Tool
-				Name="VCFxCopTool"
-			<Tool
-				Name="VCAppVerifierTool"
-			<Tool
-				Name="VCWebDeploymentTool"
-			<Tool
-				Name="VCPostBuildEventTool"
-		</Configuration>
-		<Configuration
-			Name="Debug|Win32"
-			IntermediateDirectory="Debug/RMCast"
-			UseOfMFC="0"
-			CharacterSet="1"
-			<Tool
-			<Tool
-			<Tool
-			<Tool
-			<Tool
-				Name="VCMIDLTool"
-			<Tool
-				Optimization="0"
-				PreprocessorDefinitions="ACE_RMCAST_BUILD_DLL;_DEBUG;WIN32;_WINDOWS"
-				BasicRuntimeChecks="3"
-				RuntimeLibrary="3"
-				WarningLevel="3"
-			<Tool
-			<Tool
-				PreprocessorDefinitions="_DEBUG"
-				Culture="1033"
-			<Tool
-			<Tool
-				AdditionalDependencies="ACEd.lib"
-				OutputFile="$(OutDir)/ACE_RMCastd.dll"
-				Version="5.4"
-				ProgramDatabaseFile="$(OutDir)/ACE_RMCastd.pdb"
-				SubSystem="1"
-				ImportLibrary="$(OutDir)/ACE_RMCastd.lib"
-			<Tool
-			<Tool
-			<Tool
-			<Tool
-			<Tool
-			<Tool
-			<Tool
-			<Tool
-		</Configuration>
-	</Configurations>
-	<References>
-	</References>
-	<Files>
-		<Filter
-			Name="Source Files"
-			Filter="cpp;cxx;cc;C;c"
-			<File
-				RelativePath="RMCast.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Ack_Worker.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Copy_On_Write.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Fork.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Fragment.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_IO_UDP.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Membership.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Module.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Module_Factory.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Partial_Message.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Proxy.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Reassembly.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Receiver_Module.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Reliable_Factory.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Reordering.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Resend_Handler.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Resend_Worker.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Retransmission.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Sequencer.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Singleton_Factory.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_UDP_Event_Handler.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_UDP_Proxy.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_UDP_Reliable_Receiver.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_UDP_Reliable_Sender.cpp"
-			</File>
-			<File
-				RelativePath="RMCast_Worker.cpp"
-			</File>
-		</Filter>
-		<Filter
-			Name="Header Files"
-			Filter="h;hpp;hxx;hh"
-			<File
-				RelativePath="RMCast.h"
-			</File>
-			<File
-				RelativePath="RMCast_Ack_Worker.h"
-			</File>
-			<File
-				RelativePath="RMCast_Copy_On_Write.h"
-			</File>
-			<File
-				RelativePath="RMCast_Export.h"
-			</File>
-			<File
-				RelativePath="RMCast_Fork.h"
-			</File>
-			<File
-				RelativePath="RMCast_Fragment.h"
-			</File>
-			<File
-				RelativePath="RMCast_IO_UDP.h"
-			</File>
-			<File
-				RelativePath="RMCast_Membership.h"
-			</File>
-			<File
-				RelativePath="RMCast_Module.h"
-			</File>
-			<File
-				RelativePath="RMCast_Module_Factory.h"
-			</File>
-			<File
-				RelativePath="RMCast_Partial_Message.h"
-			</File>
-			<File
-				RelativePath="RMCast_Proxy.h"
-			</File>
-			<File
-				RelativePath="RMCast_Reassembly.h"
-			</File>
-			<File
-				RelativePath="RMCast_Receiver_Module.h"
-			</File>
-			<File
-				RelativePath="RMCast_Reliable_Factory.h"
-			</File>
-			<File
-				RelativePath="RMCast_Reordering.h"
-			</File>
-			<File
-				RelativePath="RMCast_Resend_Handler.h"
-			</File>
-			<File
-				RelativePath="RMCast_Resend_Worker.h"
-			</File>
-			<File
-				RelativePath="RMCast_Retransmission.h"
-			</File>
-			<File
-				RelativePath="RMCast_Sequencer.h"
-			</File>
-			<File
-				RelativePath="RMCast_Singleton_Factory.h"
-			</File>
-			<File
-				RelativePath="RMCast_UDP_Event_Handler.h"
-			</File>
-			<File
-				RelativePath="RMCast_UDP_Proxy.h"
-			</File>
-			<File
-				RelativePath="RMCast_UDP_Reliable_Receiver.h"
-			</File>
-			<File
-				RelativePath="RMCast_UDP_Reliable_Sender.h"
-			</File>
-			<File
-				RelativePath="RMCast_Worker.h"
-			</File>
-		</Filter>
-		<Filter
-			Name="Inline Files"
-			Filter="i;inl"
-			<File
-				RelativePath="RMCast.i"
-			</File>
-			<File
-				RelativePath="RMCast_Ack_Worker.i"
-			</File>
-			<File
-				RelativePath="RMCast_Copy_On_Write.i"
-			</File>
-			<File
-				RelativePath="RMCast_Fork.i"
-			</File>
-			<File
-				RelativePath="RMCast_Fragment.i"
-			</File>
-			<File
-				RelativePath="RMCast_IO_UDP.i"
-			</File>
-			<File
-				RelativePath="RMCast_Membership.i"
-			</File>
-			<File
-				RelativePath="RMCast_Module.i"
-			</File>
-			<File
-				RelativePath="RMCast_Module_Factory.i"
-			</File>
-			<File
-				RelativePath="RMCast_Partial_Message.i"
-			</File>
-			<File
-				RelativePath="RMCast_Proxy.i"
-			</File>
-			<File
-				RelativePath="RMCast_Reassembly.i"
-			</File>
-			<File
-				RelativePath="RMCast_Receiver_Module.i"
-			</File>
-			<File
-				RelativePath="RMCast_Reliable_Factory.i"
-			</File>
-			<File
-				RelativePath="RMCast_Reordering.i"
-			</File>
-			<File
-				RelativePath="RMCast_Resend_Handler.i"
-			</File>
-			<File
-				RelativePath="RMCast_Resend_Worker.i"
-			</File>
-			<File
-				RelativePath="RMCast_Retransmission.i"
-			</File>
-			<File
-				RelativePath="RMCast_Sequencer.i"
-			</File>
-			<File
-				RelativePath="RMCast_Singleton_Factory.i"
-			</File>
-			<File
-				RelativePath="RMCast_UDP_Event_Handler.i"
-			</File>
-			<File
-				RelativePath="RMCast_UDP_Proxy.i"
-			</File>
-			<File
-				RelativePath="RMCast_UDP_Reliable_Receiver.i"
-			</File>
-			<File
-				RelativePath="RMCast_UDP_Reliable_Sender.i"
-			</File>
-			<File
-				RelativePath="RMCast_Worker.i"
-			</File>
-		</Filter>
-		<Filter
-			Name="Documentation"
-			<File
-				RelativePath="README"
-			</File>
-		</Filter>
-		<Filter
-			Name="Resource Files"
-			Filter="rc;ico;cur;bmp;dlg;rc2;rct;bin;cnt;rtf;gif;jpg;jpeg;jpe"
-			<File
-				RelativePath="RMCast.rc"
-			</File>
-		</Filter>
-	</Files>
-	<Globals>
-	</Globals>
-</VisualStudioProject>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Ack_Worker.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Ack_Worker.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Ack_Worker.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,25 +0,0 @@
-// RMCast_Ack_Worker.cpp,v 1.1 2000/10/11 00:57:08 coryan Exp
-#include "RMCast_Ack_Worker.h"
-#include "ace/Message_Block.h"
-# include "RMCast_Ack_Worker.i"
-#endif /* ! __ACE_INLINE__ */
-ACE_RCSID(ace, RMCast_Ack_Worker, "RMCast_Ack_Worker.cpp,v 1.1 2000/10/11 00:57:08 coryan Exp")
-int
-ACE_RMCast_Ack_Worker::work (ACE_UINT32 const & key,
-                             ACE_RMCast::Data const &item)
-  if (key >= this->ack_.next_expected)
-    return 0;
-  // ACE_DEBUG ((LM_DEBUG,
-  //            "  Retransmission::ack - message %d erased\n",
-  //            key));
-  ACE_Message_Block::release (item.payload);
-  return this->messages_->unbind_i (this->ace_mon_, key);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Ack_Worker.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Ack_Worker.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Ack_Worker.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,47 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_Ack_Worker.h,v 1.2 2003/07/19 19:04:15 dhinton Exp
-#ifndef ACE_RMCAST_ACK_WORKER_H
-#define ACE_RMCAST_ACK_WORKER_H
-#include "RMCast_Retransmission.h"
-# pragma once
-/// Process an Ack message in the ACE_RMCast_Retransmission module
- * The retransmission module uses internal iterators, thus it needs to
- * create helper Worker classes to process some messages.
-class ACE_RMCast_Ack_Worker
-  : public ACE_RMCast_Worker<ACE_UINT32,ACE_RMCast::Data>
-public:
-  ACE_RMCast_Ack_Worker (ACE_RMCast::Ack &ack,
-                         ACE_RMCast_Retransmission::Messages::Write_Guard &g,
-                         ACE_RMCast_Retransmission::Messages *messages);
-  virtual int work (ACE_UINT32 const & key,
-                    ACE_RMCast::Data const &item);
-private:
-  ACE_RMCast_Ack_Worker (const ACE_RMCast_Ack_Worker&);
-  ACE_RMCast_Ack_Worker& operator= (const ACE_RMCast_Ack_Worker&);
-private:
-  ACE_RMCast::Ack &ack_;
-  ACE_RMCast_Retransmission::Messages::Write_Guard &ace_mon_;
-  ACE_RMCast_Retransmission::Messages *messages_;
-#include "RMCast_Ack_Worker.i"
-#endif /* ACE_RMCAST_ACK_WORKER_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Ack_Worker.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Ack_Worker.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Ack_Worker.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,12 +0,0 @@
-// RMCast_Ack_Worker.i,v 1.1 2000/10/11 00:57:08 coryan Exp
-ACE_INLINE
-ACE_RMCast_Ack_Worker (ACE_RMCast::Ack &ack,
-  : ack_ (ack)
-  , ace_mon_ (g)
-  , messages_ (messages)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Copy_On_Write.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Copy_On_Write.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Copy_On_Write.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,199 +0,0 @@
-// RMCast_Copy_On_Write.cpp,v 1.4 2000/10/10 00:06:30 coryan Exp
-#ifndef ACE_RMCAST_COPY_ON_WRITE_CPP
-#define ACE_RMCAST_COPY_ON_WRITE_CPP
-#include "RMCast_Copy_On_Write.h"
-#if ! defined (__ACE_INLINE__)
-#include "RMCast_Copy_On_Write.i"
-ACE_RCSID(RMCast, RMCast_Copy_On_Write, "RMCast_Copy_On_Write.cpp,v 1.4 2000/10/10 00:06:30 coryan Exp")
-template<class COLLECTION, class ITERATOR> void
-ACE_RMCast_Copy_On_Write_Collection<COLLECTION,ITERATOR>::_incr_refcnt (void)
-  // LOCKING: no locking is required, the caller grabs the mutex.
-  this->refcount_++;
-ACE_RMCast_Copy_On_Write_Collection<COLLECTION,ITERATOR>::_decr_refcnt (void)
-    this->refcount_--;
-    if (this->refcount_ != 0)
-      return;
-  //@@ TODO: If this wrapper is going to be completely general some
-  // kind of functor has to be provided to remove the elements in the
-  // collection, in case the are no self-managed
-  delete this;
-template<class KEY, class ITEM, class COLLECTION, class ITERATOR>
-ACE_RMCast_Copy_On_Write<KEY,ITEM,COLLECTION,ITERATOR>::
-    ACE_RMCast_Copy_On_Write (void)
-      : ACE_RMCast_Copy_On_Write_Container<COLLECTION,ITERATOR> ()
-    ~ACE_RMCast_Copy_On_Write (void)
-  ACE_GUARD (ACE_SYNCH_MUTEX, ace_mon, this->mutex_);
-  while (this->pending_writes_ != 0)
-    this->cond_.wait ();
-  this->collection_->_decr_refcnt ();
-  this->collection_ = 0;
-template<class KEY, class ITEM, class COLLECTION, class ITERATOR> int
-    for_each (ACE_RMCast_Worker<KEY,ITEM> *worker)
-  Read_Guard ace_mon (*this);
-  ITERATOR end = ace_mon.collection->collection.end ();
-  for (ITERATOR i = ace_mon.collection->collection.begin (); i != end; ++i)
-      int r = worker->work ((*i).key (), (*i).item ());
-      if (r == 1)
-        return 0; // Abort loop, but no error
-      if (r == -1)
-        return -1;
-  return 0;
-template<class KEY, class ITEM, class C, class ITERATOR> KEY
-ACE_RMCast_Copy_On_Write<KEY,ITEM,C,ITERATOR>::first_key (void)
-  ITERATOR begin = ace_mon.collection->collection.begin ();
-  if (begin == end)
-      return KEY ();
-  return (*begin).key ();
-template<class KEY, class ITEM, class C, class ITERATOR> int
-ACE_RMCast_Copy_On_Write<KEY,ITEM,C,ITERATOR>::empty (void)
-  return end == begin;
-template<class KEY, class ITEM, class C, class I> int
-ACE_RMCast_Copy_On_Write<KEY,ITEM,C,I>::bind (KEY const & k,
-                                              ITEM const & i)
-  Write_Guard ace_mon (*this);
-  return this->bind_i (ace_mon, k, i);
-ACE_RMCast_Copy_On_Write<KEY,ITEM,C,I>::unbind (KEY const & k)
-  return this->unbind_i (ace_mon, k);
-ACE_RMCast_Copy_On_Write<KEY,ITEM,C,I>::bind_i (Write_Guard &ace_mon,
-                                                KEY const & k,
-                                                ITEM const & i)
-  return ace_mon.copy->collection.bind (k, i);
-ACE_RMCast_Copy_On_Write<KEY,ITEM,C,I>::unbind_i (Write_Guard &ace_mon,
-                                                  KEY const & k)
-  return ace_mon.copy->collection.unbind (k);
-ACE_RMCast_Copy_On_Write_Container<COLLECTION,ITERATOR>::ACE_RMCast_Copy_On_Write_Container (void)
-  : pending_writes_ (0)
-  , writing_ (0)
-  , cond_ (mutex_)
-  ACE_NEW (this->collection_, Collection);
-ACE_RMCast_Copy_On_Write_Write_Guard<COLLECTION,ITERATOR>::
-  ACE_RMCast_Copy_On_Write_Write_Guard (Container &container)
-  : copy (0)
-  , mutex (container.mutex_)
-  , cond (container.cond_)
-  , pending_writes (container.pending_writes_)
-  , writing_flag (container.writing_)
-  , collection (container.collection_)
-    ACE_GUARD (ACE_SYNCH_MUTEX, ace_mon, this->mutex);
-    this->pending_writes++;
-    while (this->writing_flag != 0)
-      this->cond.wait ();
-    this->writing_flag = 1;
-  // Copy outside the mutex, because it may take a long time.
-  // Nobody can change it, because it is protected by the
-  // writing_flag.
-  // First initialize it (with the correct reference count
-  ACE_NEW (this->copy, Collection);
-  // Copy the contents
-  this->copy->collection = this->collection->collection;
-    ~ACE_RMCast_Copy_On_Write_Write_Guard (void)
-  Collection *tmp = 0;
-    tmp = this->collection;
-    this->collection = this->copy;
-    this->writing_flag = 0;
-    this->pending_writes--;
-    this->cond.signal ();
-  // Delete outside the mutex, because it may take a long time.
-  // @@ Is this right?  What happens if several readers are still
-  // using the old copy?
-  tmp->_decr_refcnt ();
-#endif /* ACE_RMCAST_COPY_ON_WRITE_CPP */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Copy_On_Write.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Copy_On_Write.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Copy_On_Write.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,214 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_Copy_On_Write.h,v 1.8 2003/11/01 11:15:19 dhinton Exp
-#ifndef ACE_RMCAST_COPY_ON_WRITE_H
-#define ACE_RMCAST_COPY_ON_WRITE_H
-#include "RMCast_Worker.h"
-#include "ace/Synch_Traits.h"
-#include "ace/Condition_Thread_Mutex.h"
-//! A wrapper to implement reference counted collections
-class ACE_RMCast_Copy_On_Write_Collection
-public:
-  //! Constructor
-  ACE_RMCast_Copy_On_Write_Collection (void);
-  //! Increment the reference count
-  void _incr_refcnt (void);
-  //! Decrement the reference count
-  void _decr_refcnt (void);
-  //! The actual collection
-  COLLECTION collection;
-private:
-  //! The reference count
-  ACE_UINT32 refcount_;
-class ACE_RMCast_Copy_On_Write_Read_Guard;
-class ACE_RMCast_Copy_On_Write_Write_Guard;
-//! Base class for the Copy_On_Write collection, used to simplify the
-//! declaration of the Write_Guard
-class ACE_RMCast_Copy_On_Write_Container
-public:
-  //! Constructor
-  ACE_RMCast_Copy_On_Write_Container (void);
-  //! Let the Write_Guard access the internal fields.
-  friend class ACE_RMCast_Copy_On_Write_Write_Guard<COLLECTION,ITERATOR>;
-  //! Let the Read_Guard access the internal fields.
-  friend class ACE_RMCast_Copy_On_Write_Read_Guard<COLLECTION,ITERATOR>;
-  //! A shorter name for the actual collection type
-  typedef ACE_RMCast_Copy_On_Write_Collection<COLLECTION,ITERATOR> Collection;
-protected:
-  //! Number of pending writes
-  int pending_writes_;
-  //! If non-zero then a thread is changing the collection.
-   * Many threads can use the collection simulatenously, but only one
-   * change it.
-  int writing_;
-  //! A mutex to serialize access to the collection pointer.
-  ACE_SYNCH_MUTEX mutex_;
-  //! A condition variable to wait to synchronize multiple writers.
-  ACE_SYNCH_CONDITION cond_;
-  //! The collection, with reference counting added
-  Collection *collection_;
-//! Implement a read guard for a reference counted collection
-public:
-  typedef ACE_RMCast_Copy_On_Write_Container<COLLECTION,ITERATOR> Container;
-  //! Constructor
-  ACE_RMCast_Copy_On_Write_Read_Guard (Container &container);
-  //! Destructor
-  ~ACE_RMCast_Copy_On_Write_Read_Guard (void);
-  //! A reference to the collection
-  Collection *collection;
-private:
-  //! Synchronization
-  ACE_SYNCH_MUTEX &mutex_;
-//! Implement the write guard for a reference counted collecion
- * This helper class atomically increments the reference count of a
- * ACE_RMCast_Copy_On_Write_Collection and reads the current
- * collection in the Copy_On_Write class.
-public:
-  //! Constructor
-  ACE_RMCast_Copy_On_Write_Write_Guard (Container &container);
-  //! Destructor
-  ~ACE_RMCast_Copy_On_Write_Write_Guard (void);
-  Collection *copy;
-private:
-  //! Keep a reference to the mutex
-  ACE_SYNCH_MUTEX &mutex;
-  //! Keep a reference to the condition variable
-  ACE_SYNCH_CONDITION &cond;
-  //! Use a reference to update the pending writes count
-  int &pending_writes;
-  //! Use a reference to update the writing flag
-  int &writing_flag;
-  //! Use this reference to update the collection once the
-  //! modifications are finished.
-  Collection *&collection;
-//! Implement a copy on write wrapper for a map-like collection
- * <B>WARNING: </B>  This class may be moved away in the future, I'm
- * investigating how it could be converted into a reusable component
- * in ACE.   I won't make promises on when will that happen, but I
- * won't promise that it will stay here either.
-class ACE_RMCast_Copy_On_Write : public ACE_RMCast_Copy_On_Write_Container<COLLECTION,ITERATOR>
-public:
-  //! The Read_Guard trait
-  typedef ACE_RMCast_Copy_On_Write_Read_Guard<COLLECTION,ITERATOR> Read_Guard;
-  //! The Write_Guard trait
-  typedef ACE_RMCast_Copy_On_Write_Write_Guard<COLLECTION,ITERATOR> Write_Guard;
-  //! The underlying collection type
-  //! Constructor
-  ACE_RMCast_Copy_On_Write (void);
-  //! Destructor
-  ~ACE_RMCast_Copy_On_Write (void);
-  //! Iterate over all the elements invoking \param worker on each one.
-  int for_each (ACE_RMCast_Worker<KEY,ITEM> *worker);
-  //! Get the first key
-  KEY first_key (void);
-  /// Return non-zero if the collection is empty
-  int empty (void);
-  //! Add a new element
-  int bind (KEY const & key, ITEM const & item);
-  //! Remove an element
-  int unbind (KEY const & key);
-  //! Bind assuming the Write_Guard is held
-  int bind_i (Write_Guard &guard, KEY const & key, ITEM const & item);
-  //! Unbind assuming the Write_Guard is held
-  int unbind_i (Write_Guard &guard, KEY const & key);
-#if defined (ACE_TEMPLATES_REQUIRE_SOURCE)
-#include "RMCast_Copy_On_Write.cpp"
-#endif /* ACE_TEMPLATES_REQUIRE_SOURCE */
-#if defined (ACE_TEMPLATES_REQUIRE_PRAGMA)
-#pragma implementation ("RMCast_Copy_On_Write.cpp")
-#endif /* ACE_TEMPLATES_REQUIRE_PRAGMA */
-#endif /* ACE_RMCAST_COPY_ON_WRITE_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Copy_On_Write.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Copy_On_Write.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Copy_On_Write.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,38 +0,0 @@
-// -*- C++ -*-
-// RMCast_Copy_On_Write.i,v 1.4 2003/11/01 11:15:19 dhinton Exp
-#include "ace/Guard_T.h"
-#include "ace/Null_Mutex.h"
-template<class COLLECTION, class ITERATOR> ACE_INLINE
-      :  refcount_ (1)
-ACE_RMCast_Copy_On_Write_Read_Guard<COLLECTION,ITERATOR>::
-  : collection (0)
-  , mutex_ (container.mutex_)
-  this->collection = container.collection_;
-  this->collection->_incr_refcnt ();
-  if (this->collection != 0)
-      this->collection->_decr_refcnt ();
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Export.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Export.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Export.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,44 +0,0 @@
-// -*- C++ -*-
-// RMCast_Export.h,v 1.2 2001/03/04 09:17:36 nanbor Exp
-// Definition for Win32 Export directives.
-// This file is generated automatically by
-// generate_export_file.pl
-#if !defined (ACE_RMCAST_EXPORT_H)
-#define ACE_RMCAST_EXPORT_H
-#include "ace/config-all.h"
-#if defined (ACE_AS_STATIC_LIBS) && !defined (ACE_RMCAST_HAS_DLL)
-#  define ACE_RMCAST_HAS_DLL 0
-#endif /* ACE_AS_STATIC_LIBS && ACE_RMCAST_HAS_DLL */
-#if !defined (ACE_RMCAST_HAS_DLL)
-#define ACE_RMCAST_HAS_DLL 1
-#endif /* ! ACE_RMCAST_HAS_DLL */
-#if defined (ACE_RMCAST_HAS_DLL)
-#  if (ACE_RMCAST_HAS_DLL == 1)
-#    if defined (ACE_RMCAST_BUILD_DLL)
-#      define ACE_RMCast_Export ACE_Proper_Export_Flag
-#      define ACE_RMCAST_SINGLETON_DECLARATION(T) ACE_EXPORT_SINGLETON_DECLARATION (T)
-#      define ACE_RMCAST_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK) ACE_EXPORT_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK)
-#    else
-#      define ACE_RMCast_Export ACE_Proper_Import_Flag
-#      define ACE_RMCAST_SINGLETON_DECLARATION(T) ACE_IMPORT_SINGLETON_DECLARATION (T)
-#      define ACE_RMCAST_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK) ACE_IMPORT_SINGLETON_DECLARE(SINGLETON_TYPE, CLASS, LOCK)
-#    endif /* ACE_RMCAST_BUILD_DLL */
-#  else
-#  endif   /* ! ACE_RMCAST_HAS_DLL == 1 */
-#else
-#endif     /* ACE_RMCAST_HAS_DLL */
-#endif     /* ACE_RMCAST_EXPORT_H */
-// End of auto generated file.
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fork.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fork.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fork.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,112 +0,0 @@
-// RMCast_Fork.cpp,v 1.1 2000/10/11 00:57:08 coryan Exp
-#include "RMCast_Fork.h"
-# include "RMCast_Fork.i"
-ACE_RCSID(ace, RMCast_Fork, "RMCast_Fork.cpp,v 1.1 2000/10/11 00:57:08 coryan Exp")
-ACE_RMCast_Fork::~ACE_RMCast_Fork (void)
-int
-ACE_RMCast_Fork::open (void)
-  int r = this->ACE_RMCast_Module::open ();
-  if (r != 0)
-    return r;
-  if (this->secondary () != 0)
-    return this->secondary ()->open ();
-  return 0;
-int
-ACE_RMCast_Fork::close (void)
-  int r = this->ACE_RMCast_Module::close ();
-  if (r != 0)
-    return r;
-    return this->secondary ()->close ();
-  return 0;
-int
-ACE_RMCast_Fork::data (ACE_RMCast::Data &data)
-  int r = this->ACE_RMCast_Module::data (data);
-  if (r != 0)
-    return r;
-    return this->secondary ()->data (data);
-  return 0;
-int
-ACE_RMCast_Fork::poll (ACE_RMCast::Poll &poll)
-  int r = this->ACE_RMCast_Module::poll (poll);
-  if (r != 0)
-    return r;
-    return this->secondary ()->poll (poll);
-  return 0;
-int
-ACE_RMCast_Fork::ack_join (ACE_RMCast::Ack_Join &ack_join)
-  int r = this->ACE_RMCast_Module::ack_join (ack_join);
-  if (r != 0)
-    return r;
-    return this->secondary ()->ack_join (ack_join);
-  return 0;
-int
-ACE_RMCast_Fork::ack_leave (ACE_RMCast::Ack_Leave &ack_leave)
-  int r = this->ACE_RMCast_Module::ack_leave (ack_leave);
-  if (r != 0)
-    return r;
-    return this->secondary ()->ack_leave (ack_leave);
-  return 0;
-int
-ACE_RMCast_Fork::ack (ACE_RMCast::Ack &ack)
-  int r = this->ACE_RMCast_Module::ack (ack);
-  if (r != 0)
-    return r;
-    return this->secondary ()->ack (ack);
-  return 0;
-int
-ACE_RMCast_Fork::join (ACE_RMCast::Join &join)
-  int r = this->ACE_RMCast_Module::join (join);
-  if (r != 0)
-    return r;
-    return this->secondary ()->join (join);
-  return 0;
-int
-ACE_RMCast_Fork::leave (ACE_RMCast::Leave &leave)
-  int r = this->ACE_RMCast_Module::leave (leave);
-  if (r != 0)
-    return r;
-    return this->secondary ()->leave (leave);
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fork.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fork.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fork.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,55 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_Fork.h,v 1.2 2003/07/19 19:04:15 dhinton Exp
-#ifndef ACE_RMCAST_FORK_H
-#define ACE_RMCAST_FORK_H
-#include "RMCast_Module.h"
-# pragma once
-/// Fork messages to multiple destinations
- * In some instances the messages must be sent to multiple
- * destinations, this module is a generic component to duplicate such
- * messages.
-class ACE_RMCast_Export ACE_RMCast_Fork : public ACE_RMCast_Module
-public:
-  //! Constructor
-  ACE_RMCast_Fork (void);
-  //! Destructor
-  virtual ~ACE_RMCast_Fork (void);
-  /// Set the control module, all incoming control messages go to it
-  void secondary (ACE_RMCast_Module *module);
-  /// Return the current control module
-  ACE_RMCast_Module *secondary (void) const;
-  virtual int open (void);
-  virtual int close (void);
-  virtual int data (ACE_RMCast::Data &);
-  virtual int poll (ACE_RMCast::Poll &);
-  virtual int ack_join (ACE_RMCast::Ack_Join &);
-  virtual int ack_leave (ACE_RMCast::Ack_Leave &);
-  virtual int ack (ACE_RMCast::Ack &);
-  virtual int join (ACE_RMCast::Join &);
-  virtual int leave (ACE_RMCast::Leave &);
-private:
-  /// The control module
-  ACE_RMCast_Module *secondary_;
-#include "RMCast_Fork.i"
-#endif /* ACE_RMCAST_FORK_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fork.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fork.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fork.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,21 +0,0 @@
-// RMCast_Fork.i,v 1.1 2000/10/11 00:57:08 coryan Exp
-ACE_INLINE
-ACE_RMCast_Fork::ACE_RMCast_Fork (void)
-  : ACE_RMCast_Module ()
-  , secondary_ (0)
-ACE_INLINE void
-ACE_RMCast_Fork::secondary (ACE_RMCast_Module *module)
-  this->secondary_ = module;
-ACE_INLINE ACE_RMCast_Module *
-ACE_RMCast_Fork::secondary (void) const
-  return this->secondary_;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fragment.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fragment.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fragment.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,189 +0,0 @@
-// RMCast_Fragment.cpp,v 1.6 2003/05/05 18:35:26 elliott_c Exp
-#include "RMCast_Fragment.h"
-# pragma once
-#include "RMCast_Fragment.i"
-ACE_RCSID(ace, RMCast_Fragment, "RMCast_Fragment.cpp,v 1.6 2003/05/05 18:35:26 elliott_c Exp")
-ACE_RMCast_Fragment::
-ACE_RMCast_Fragment (void)
-  ,  max_fragment_size_ (ACE_RMCAST_DEFAULT_FRAGMENT_SIZE)
-ACE_RMCast_Fragment::~ACE_RMCast_Fragment (void)
-int
-ACE_RMCast_Fragment::data (ACE_RMCast::Data &received_data)
-  if (this->next () == 0)
-    return 0;
-  // The Data object sent downstream
-  ACE_RMCast::Data data = received_data;
-  ACE_Message_Block *mb = data.payload;
-  // @@ We should keep the total size precomputed
-  data.total_size = ACE_static_cast (ACE_UINT32, mb->total_length ());
-  // We must leave room for the header
-#if defined (ACE_HAS_BROKEN_DGRAM_SENDV)
-  const int ACE_RMCAST_WRITEV_MAX = ACE_IOV_MAX - 2;
-#else
-  const int ACE_RMCAST_WRITEV_MAX = ACE_IOV_MAX - 1;
-#endif /* ACE_HAS_BROKEN_DGRAM_SENDV */
-  // Assume the header will be included on each fragment, so readuce
-  // the maximum amount of memory allowed on each fragment....
-  const size_t fragment_header_size = 1 + 3 * sizeof(ACE_UINT32);
-  const size_t max_fragment_payload =
-    this->max_fragment_size_ - fragment_header_size;
-  // Iterate over all the message blocks in the chain.  If there is
-  // enough data to send an MTU then it is sent immediately.
-  // The last fragment is sent with whatever data remains.
-  // A single fragment can expand multiple message blocks, put
-  // together in an <iovec> array, it is also possible that a single
-  // message block requires multiple fragments... so the code below is
-  // as simple as possible, but not any simpler ;-)
-  // The first piece of each fragment is a header that contains:
-  // - A sequence number for reassembly, this is unrelated to
-  //   the sequence number for re-transmission.
-  //   NOTE: yes, this increases the bandwidth requires by 4 bytes on
-  //   each message, I don't think this is a big deal.
-  // - A fragment offset for reassembly.
-  // - The total size of the message, so the reassembly layer knows
-  //   when a complete message has been received.
-  // Complete the initialization of the <data> structure
-  data.fragment_offset = 0;
-  // The underlying transport layer can only tolerate so many elements
-  // in a chain, so we must count them and send a fragment if we are
-  // going over the limit.
-  ACE_Message_Block blocks[ACE_RMCAST_WRITEV_MAX];
-  // How many elements of the <blocks> array are in use...
-  int iovcnt = 0;
-  // The size of the current message, adding the size of all its
-  // message blocks.
-  size_t fragment_size = 0;
-  for (ACE_Message_Block* b = mb;  b != 0; b = b->cont ())
-      ACE_Message_Block *current_block = &blocks[iovcnt];
-      // Add the block to the vector...
-      current_block->data_block (b->data_block ()->duplicate ());
-      current_block->rd_ptr (b->rd_ptr ());
-      current_block->wr_ptr (b->wr_ptr ());
-      current_block->cont (0);
-      // Set the continuation field
-      if (iovcnt != 0)
-        blocks[iovcnt-1].cont (current_block);
-      size_t current_block_length = current_block->length ();
-      // Recompute the state of the fragment
-      fragment_size += current_block_length;
-      iovcnt++;
-      while (fragment_size >= max_fragment_payload)
-          // We have filled a fragment.  It is possible that we need
-          // to split the last message block in multiple fragments,
-          // thus the loop above...
-          // First adjust the last message block to exactly fit in the
-          // fragment:
-          size_t last_sent_mb_len =
-            max_fragment_payload - (fragment_size - current_block_length);
-          // Send only enough data of the last message block to fill
-          // the fragment...
-          current_block->wr_ptr (current_block->rd_ptr ()
-                              + last_sent_mb_len);
-          data.payload = blocks;
-          if (this->next ()->data (data) == -1)
-            return -1;
-          // adjust the offset
-          data.fragment_offset += ACE_static_cast (ACE_UINT32,
-                                                   max_fragment_payload);
-          // Now compute how much data is left in the last message
-          // block, to check if we should continue sending it...
-          current_block_length -= last_sent_mb_len;
-          if (current_block_length == 0)
-              // No more data from this message block, just continue
-              // the outer loop...
-              iovcnt = 0;
-              fragment_size = 0;
-              blocks[0].cont (0);
-              break; // while
-          // There is some data left, we try to send it in a single
-          // fragment, if it is still too big the beginning of this
-          // loop will adjust things.
-          // We must put the data in the right place in the array..
-          char *rd_ptr = current_block->rd_ptr () + last_sent_mb_len;
-          char *wr_ptr = rd_ptr + current_block_length;
-          blocks[0].data_block (current_block->replace_data_block (0));
-          // And determine what segment of the data will be sent..
-          blocks[0].rd_ptr (rd_ptr);
-          blocks[0].wr_ptr (wr_ptr);
-          // Adjust the state of the fragment
-          fragment_size = current_block_length;
-          iovcnt = 1;
-          // Notice that if <fragment_size> is too big the start of
-          // this loop will continue the fragmentation.
-      // It is also possible to fill up the iovec array before the
-      // fragment is completed, in this case we must send whatever we
-      // have:
-      if (iovcnt == ACE_RMCAST_WRITEV_MAX)
-            return -1;
-          iovcnt = 0;
-  if (iovcnt == 0)
-    return 0;
-  return this->next ()->data (data);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fragment.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fragment.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fragment.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,61 +0,0 @@
-// RMCast_Fragment.h,v 1.6 2003/11/10 01:48:03 dhinton Exp
-#ifndef ACE_RMCAST_FRAGMENT_H
-#define ACE_RMCAST_FRAGMENT_H
-# pragma once
-//! Default fragment size
-#ifndef ACE_RMCAST_DEFAULT_FRAGMENT_SIZE
-# define ACE_RMCAST_DEFAULT_FRAGMENT_SIZE 1024
-#endif /* ACE_RMCAST_DEFAULT_FRAGMENT_SIZE */
-//! Fragmentation module
- * Some transports cannot send very big messages, for example UDP
- * imposes a limit of 64K, and in practice the limit is even more
- * strict than that.
- * This class decomposes a message into multiple fragments, using an
- * application defined maximum size.
-class ACE_RMCast_Export ACE_RMCast_Fragment : public ACE_RMCast_Module
-public:
-  //! Constructor
-  ACE_RMCast_Fragment (void);
-  //! Destructor
-  virtual ~ACE_RMCast_Fragment (void);
-  //! Accessor for the max_fragment size.
-  /*! There is no modifier, the maximum fragment size is obtained
-   *  using feedback from the lower layers (transport?)
-   *  @@TODO We have not implemented the feedback mechanisms yet!
-  size_t max_fragment_size (void) const;
-   * Only data messages need fragmentation, the control messages are
-   * all small enough for all the transports that I know about.
-   * Well, actually for CAN-Bus (Controller Area Network), they may be
-   * too big, because the max payload there is 8 bytes, but we don't
-   * play with those in ACE.
-  virtual int data (ACE_RMCast::Data &data);
-private:
-  //! Current fragment size limit
-  size_t max_fragment_size_;
-#endif /* ACE_RMCAST_FRAGMENT_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fragment.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fragment.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Fragment.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,7 +0,0 @@
-// RMCast_Fragment.i,v 1.2 2000/08/10 01:35:37 coryan Exp
-ACE_INLINE size_t
-ACE_RMCast_Fragment::max_fragment_size (void) const
-  return this->max_fragment_size_;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_IO_UDP.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_IO_UDP.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_IO_UDP.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,463 +0,0 @@
-// RMCast_IO_UDP.cpp,v 1.18 2003/12/20 04:58:53 bala Exp
-#include "RMCast_IO_UDP.h"
-# include "RMCast_IO_UDP.i"
-#include "RMCast_UDP_Proxy.h"
-#include "RMCast_Module_Factory.h"
-#include "ace/Handle_Set.h"
-#include "ace/Reactor.h"
-#include "ace/OS_NS_string.h"
-#include "ace/OS_NS_sys_select.h"
-#include "ace/os_include/arpa/os_inet.h"
-#include "ace/OS_NS_unistd.h"
-ACE_RCSID(ace, RMCast_IO_UDP, "RMCast_IO_UDP.cpp,v 1.12 2000/12/20 22:00:33 oci Exp")
-ACE_RMCast_IO_UDP::~ACE_RMCast_IO_UDP (void)
-int
-ACE_RMCast_IO_UDP::init (const ACE_INET_Addr &mcast_group,
-                         const ACE_Addr &local,
-                         int protocol_family,
-                         int protocol,
-                         int reuse_addr)
-  this->mcast_group_ = mcast_group;
-  ACE_SOCK_Dgram &dgram = this->dgram_;
-  return dgram.open (local, protocol_family, protocol, reuse_addr);
-int
-ACE_RMCast_IO_UDP::subscribe (const ACE_INET_Addr &mcast_addr,
-                              int reuse_addr,
-                              const ACE_TCHAR *net_if,
-                              int protocol)
-  this->mcast_group_ = mcast_addr;
-  return this->dgram_.subscribe (mcast_addr,
-                                 reuse_addr,
-                                 net_if,
-                                 protocol_family,
-                                 protocol);
-int
-ACE_RMCast_IO_UDP::handle_events (ACE_Time_Value *tv)
-  ACE_HANDLE h = this->dgram_.get_handle ();
-  if (h == ACE_INVALID_HANDLE)
-    return -1;
-  ACE_Handle_Set handle_set;
-  handle_set.set_bit (h);
-  ACE_Countdown_Time countdown (tv);
-  int r = ACE_OS::select (int(size_t(h)) + 1,
-                          handle_set, 0, 0,
-                          tv);
-  if (r == -1)
-      if (errno == EINTR)
-        return 0;
-      else
-        return -1;
-  else if (r == 0)
-      return 0;
-  return this->handle_input (h);
-int
-ACE_RMCast_IO_UDP::handle_input (ACE_HANDLE)
-  // @@ We should use a system constant instead of this literal
-  const int max_udp_packet_size = 65536;
-  char buffer[max_udp_packet_size];
-  ACE_INET_Addr from_address;
-  ssize_t r =
-    this->dgram_.recv (buffer, sizeof(buffer), from_address);
-  if (r == -1)
-      // @@ LOG??
-      ACE_ERROR ((LM_ERROR,
-                  "RMCast_IO_UDP::handle_input () - error in recv %p\n",
-                  ACE_TEXT ("")));
-      return -1;
-  // ACE_HEX_DUMP ((LM_DEBUG, buffer, 16, "Receiver::handle_input"));
-  // @@ Locking!
-  int type = buffer[0];
-  if (type < 0 || type >= ACE_RMCast::RMCAST_MT_LAST)
-      // @@ Log: invalid message type!!
-      // @@ TODO: should we return -1?  The socket is still valid, it
-      // makes little sense to destroy it just because one remote
-      // sender is sending invalid messages. Maybe we should
-      // strategize this too, and report the problem to the
-      // application, this could indicate a misconfiguration or
-      // something worse...
-      // In any case the proxy should be destroyed, its peer is making
-      // something really wrong.
-      ACE_RMCast_UDP_Proxy *proxy;
-      if (this->map_.unbind (from_address, proxy) == 0)
-          this->factory_->destroy (proxy->next ());
-          delete proxy;
-      return 0;
-  if (this->map_.find (from_address, proxy) != 0)
-      //ACE_DEBUG ((LM_DEBUG,
-      //            "IO_UDP::handle_input - new proxy from <%s:%d>\n",
-      //            from_address.get_host_addr (),
-      //            from_address.get_port_number ()));
-      // @@ We should validate the message *before* creating the
-      // object, all we need is some sort of validation strategy, a
-      // different one for the receiver and another one for the
-      // sender.
-#if 0
-      if (type == ACE_RMCast::RMCAST_MT_ACK
-          || type == ACE_RMCast::RMCAST_MT_JOIN
-          || type == ACE_RMCast::RMCAST_MT_LEAVE
-          || type == ACE_RMCast::RMCAST_MT_ACK_LEAVE)
-          // All these message types indicate a problem, the should be
-          // generated by receivers, not received by them.
-          return 0;
-#endif /* 0 */
-      ACE_RMCast_Module *module = this->factory_->create ();
-      if (module == 0)
-          // @@ LOG??
-          // Try to continue working, maybe the module can be created
-          // later.
-          return 0;
-      // This is necessary to satisfy the xgcc for Lynx on Solaris
-      // by including the code directly causes :
-      // RMCast_IO_UDP.cpp:202: error: internal error--unrecognizable insn:
-      // (insn 1510 1507 524 (set (mem:SI (plus:SI (reg:SI 28 r28)
-      //                 (const_int 65536)))
-      //         (reg:SI 0 r0)) -1 (insn_list 528 (insn_list 1507 (nil)))
-      //     (nil))
-      // /usr/lynx/home2/jose/98r2/src/gcc/toplev.c:1489: Internal compiler error in function fatal_insn
-      // to be thrown at the end of the function.
-      if ((proxy = allocate_and_bind_proxy(module,from_address)) == 0)
-        return 0;
-  // Have the proxy process the message and do the right thing.
-  if (proxy->receive_message (buffer, r) != 0)
-      (void) this->map_.unbind (from_address);
-      delete proxy;
-  return 0;
-ACE_HANDLE
-ACE_RMCast_IO_UDP::get_handle (void) const
-  return this->dgram_.get_handle ();
-int
-ACE_RMCast_IO_UDP::data (ACE_RMCast::Data &data)
-  return this->send_data (data, this->mcast_group_);
-int
-ACE_RMCast_IO_UDP::poll (ACE_RMCast::Poll &poll)
-  return this->send_poll (poll, this->mcast_group_);
-int
-ACE_RMCast_IO_UDP::ack_join (ACE_RMCast::Ack_Join &ack_join)
-  return this->send_ack_join (ack_join, this->mcast_group_);
-int
-ACE_RMCast_IO_UDP::ack_leave (ACE_RMCast::Ack_Leave &ack_leave)
-  return this->send_ack_leave (ack_leave, this->mcast_group_);
-int
-ACE_RMCast_IO_UDP::ack (ACE_RMCast::Ack &ack)
-  return this->send_ack (ack, this->mcast_group_);
-int
-ACE_RMCast_IO_UDP::join (ACE_RMCast::Join &join)
-  return this->send_join (join, this->mcast_group_);
-int
-ACE_RMCast_IO_UDP::leave (ACE_RMCast::Leave &leave)
-  return this->send_leave (leave, this->mcast_group_);
-int
-ACE_RMCast_IO_UDP::send_data (ACE_RMCast::Data &data,
-                              const ACE_INET_Addr &to)
-  //            "IO_UDP::send_data - pushing out to <%s:%d>\n",
-  //            to.get_host_addr (),
-  //            to.get_port_number ()));
-  // The first message block contains the header
-  // @@ TODO: We could keep the header pre-initialized, and only
-  // update the portions that do change...
-  ACE_UINT32 tmp;
-  char header[1 + 3 * sizeof(ACE_UINT32)];
-  header[0] = ACE_RMCast::RMCAST_MT_DATA;
-  tmp = ACE_HTONL (data.sequence_number);
-  ACE_OS::memcpy (header + 1,
-                  &tmp, sizeof(ACE_UINT32));
-  tmp = ACE_HTONL (data.total_size);
-  ACE_OS::memcpy (header + 1 + sizeof(ACE_UINT32),
-  tmp = ACE_HTONL (data.fragment_offset);
-  ACE_OS::memcpy (header + 1 + 2 * sizeof(ACE_UINT32),
-  iovec iov[ACE_IOV_MAX];
-  int iovcnt = 1;
-  iov[0].iov_base = header;
-  iov[0].iov_len = sizeof(header);
-  for (const ACE_Message_Block *i = mb; i != 0; i = i->cont ())
-      iov[iovcnt].iov_base = i->rd_ptr ();
-      iov[iovcnt].iov_len = ACE_static_cast (u_long, i->length ());
-      iovcnt++;
-      if (iovcnt >= IOV_MAX)
-        return -1;
-  // @@ This pacing stuff here reduced the number of packet lost in
-  // loopback tests, but it should be taken out for real applications
-  // (or at least made configurable!)
-  ACE_Time_Value tv (0, 10000);
-  ACE_OS::sleep (tv);
-  // ACE_SOCK_MCast_Dgram disallows sending, but it actually works.
-  if (dgram.send (iov, iovcnt, to) == -1)
-    return -1;
-#if 0
-  ACE_HEX_DUMP ((LM_DEBUG,
-                 (char*)iov[0].iov_base,
-                 iov[0].iov_len,
-                 "Sending"));
-#endif
-  return 0;
-int
-ACE_RMCast_IO_UDP::send_poll (ACE_RMCast::Poll &,
-  //            "IO_UDP::send_poll - pushing out to <%s:%d>\n",
-  char header[16];
-  header[0] = ACE_RMCast::RMCAST_MT_POLL;
-  if (dgram.send (header, 1, to) == -1)
-    return -1;
-  return 0;
-int
-ACE_RMCast_IO_UDP::send_ack_join (ACE_RMCast::Ack_Join &ack_join,
-  //            "IO_UDP::send_ack_join - pushing out to <%s:%d>\n",
-  char header[16];
-  header[0] = ACE_RMCast::RMCAST_MT_ACK_JOIN;
-  ACE_UINT32 tmp = ACE_HTONL (ack_join.next_sequence_number);
-  if (dgram.send (header, 1 + sizeof(ACE_UINT32), to) == -1)
-    return -1;
-  return 0;
-int
-ACE_RMCast_IO_UDP::send_ack_leave (ACE_RMCast::Ack_Leave &,
-  //            "IO_UDP::send_ack_leave - pushing out to <%s:%d>\n",
-  char header[16];
-  header[0] = ACE_RMCast::RMCAST_MT_ACK_LEAVE;
-    return -1;
-  return 0;
-int
-ACE_RMCast_IO_UDP::send_ack (ACE_RMCast::Ack &ack,
-  //            "IO_UDP::send_ack - pushing (%d:%d) out to <%s:%d>\n",
-  //            ack.next_expected,
-  //            ack.highest_received,
-  char header[16];
-  header[0] = ACE_RMCast::RMCAST_MT_ACK;
-  ACE_UINT32 tmp = ACE_HTONL (ack.next_expected);
-  tmp = ACE_HTONL (ack.highest_received);
-  if (dgram.send (header, 1 + 2*sizeof(ACE_UINT32), to) == -1)
-    return -1;
-  return 0;
-int
-ACE_RMCast_IO_UDP::send_join (ACE_RMCast::Join &,
-  //            "IO_UDP::send_join - pushing out to <%s:%d>\n",
-  char header[16];
-  header[0] = ACE_RMCast::RMCAST_MT_JOIN;
-    return -1;
-  return 0;
-int
-ACE_RMCast_IO_UDP::send_leave (ACE_RMCast::Leave &,
-  //            "IO_UDP::send_leave - pushing out to <%s:%d>\n",
-  char header[16];
-  header[0] = ACE_RMCast::RMCAST_MT_LEAVE;
-    return -1;
-  return 0;
-#if defined (ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION)
-template class ACE_Hash_Map_Manager<ACE_INET_Addr,ACE_RMCast_UDP_Proxy*,ACE_Null_Mutex>;
-template class ACE_Hash_Map_Manager_Ex<ACE_INET_Addr,ACE_RMCast_UDP_Proxy*,ACE_Hash<ACE_INET_Addr>,ACE_Equal_To<ACE_INET_Addr>,ACE_Null_Mutex>;
-template class ACE_Hash_Map_Iterator<ACE_INET_Addr,ACE_RMCast_UDP_Proxy*,ACE_Null_Mutex>;
-template class ACE_Hash_Map_Iterator_Ex<ACE_INET_Addr,ACE_RMCast_UDP_Proxy*,ACE_Hash<ACE_INET_Addr>,ACE_Equal_To<ACE_INET_Addr>,ACE_Null_Mutex>;
-template class ACE_Hash_Map_Reverse_Iterator_Ex<ACE_INET_Addr,ACE_RMCast_UDP_Proxy*,ACE_Hash<ACE_INET_Addr>,ACE_Equal_To<ACE_INET_Addr>,ACE_Null_Mutex>;
-template class ACE_Hash_Map_Iterator_Base_Ex<ACE_INET_Addr,ACE_RMCast_UDP_Proxy*,ACE_Hash<ACE_INET_Addr>,ACE_Equal_To<ACE_INET_Addr>,ACE_Null_Mutex>;
-template class ACE_Hash_Map_Entry<ACE_INET_Addr,ACE_RMCast_UDP_Proxy*>;
-template class ACE_Equal_To<ACE_INET_Addr>;
-template class ACE_Hash<ACE_INET_Addr>;
-#endif /* ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_IO_UDP.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_IO_UDP.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_IO_UDP.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,138 +0,0 @@
-// RMCast_IO_UDP.h,v 1.9 2003/11/10 01:48:03 dhinton Exp
-// = DESCRIPTION
-//     Encapsulate the I/O layer for a UDP based receiver
-// = AUTHOR
-#ifndef ACE_RMCAST_IO_UDP_H
-#define ACE_RMCAST_IO_UDP_H
-#include "ace/SOCK_Dgram_Mcast.h"
-#include "ace/Hash_Map_Manager.h"
-#include "ace/INET_Addr.h"
-# pragma once
-class ACE_RMCast_UDP_Proxy;
-class ACE_RMCast_Module_Factory;
-class ACE_Time_Value;
-class ACE_RMCast_Export ACE_RMCast_IO_UDP : public ACE_RMCast_Module
-public:
-  //! Constructor
-   * The <factory> argument is used to create the modules for each
-   * proxy that process incoming messages. The class does *not* assume
-   * ownership of <factory>, the caller owns it.  But it does assume
-   * ownership of the modules returned by the factory, and it may ask
-   * the factory to release them eventually.
-  ACE_RMCast_IO_UDP (ACE_RMCast_Module_Factory *factory);
-  //! Destructor
-  ~ACE_RMCast_IO_UDP (void);
-  /// Open the internal socket, but only to send multicast data.
-   * It is not clear to me if this is a valid configuration.  Maybe it
-   * would be a problem to expose two separate, incompatible
-   * interfaces (check the subscribe() method). However, the
-   * alternative would be to implement almost identical class for
-   * outgoing and incoming UDP I/O
-  int init (const ACE_INET_Addr &mcast_group,
-            int protocol_family = PF_INET,
-            int protocol = 0,
-            int reuse_addr = 0);
-  //! Join a new multicast group
-   * Start receiving data for the <mcast_addr> multicast group.
-   * Please read the documentation of ACE_SOCK_Dgram_Mcast for more
-   * details.
-  int subscribe (const ACE_INET_Addr &mcast_addr,
-                 int reuse_addr = 1,
-                 const ACE_TCHAR *net_if = 0,
-                 int protocol = 0);
-  // The class can be used with a Reactor or using blocking I/O
-  // depending on what method of the following two is called.
-  //! Wait for events for the period <tv>. If <tv> is zero it blocks
-  //! forever.
-  int handle_events (ACE_Time_Value *tv = 0);
-  //! There is data to read, read it and process it.
-  int handle_input (ACE_HANDLE h);
-  //! Obtain the handle for the underlying socket
-  ACE_HANDLE get_handle (void) const;
-  //! Send the message to the ACE_INET_Addr argument.
-   * These methods are used in the implementation of the
-   * ACE_RMCast_UDP_Proxy objects and the implementation of the
-   * inherited ACE_RMCast_Module methods in this class.
-  int send_data (ACE_RMCast::Data &, const ACE_INET_Addr &);
-  int send_poll (ACE_RMCast::Poll &, const ACE_INET_Addr &);
-  int send_ack_join (ACE_RMCast::Ack_Join &, const ACE_INET_Addr &);
-  int send_ack_leave (ACE_RMCast::Ack_Leave &, const ACE_INET_Addr &);
-  int send_ack (ACE_RMCast::Ack &, const ACE_INET_Addr &);
-  int send_join (ACE_RMCast::Join &, const ACE_INET_Addr &);
-  int send_leave (ACE_RMCast::Leave &, const ACE_INET_Addr &);
-  // Please read the documentation in ACE_RMCast_Module for more details
-private:
-  // This is necessary to satisfy the stupid xgcc for Lynx on Solaris
-  // The compiler barfs up lisp code errors
-  ACE_RMCast_UDP_Proxy *allocate_and_bind_proxy (ACE_RMCast_Module *module,
-                                                 const ACE_INET_Addr &);
-  //! The factory used to create the modules attached to each proxy
-  ACE_RMCast_Module_Factory *factory_;
-  //! The multicast group we subscribe and send to
-  ACE_INET_Addr mcast_group_;
-  //! The socket used to receive and send data
-  ACE_SOCK_Dgram_Mcast dgram_;
-  //! Use a Hash_Map to maintain the collection of proxies
-  typedef ACE_Hash_Map_Manager<ACE_INET_Addr,ACE_RMCast_UDP_Proxy*,ACE_Null_Mutex> Map;
-  //! The collection of proxies
-  Map map_;
-#include "RMCast_IO_UDP.i"
-#endif /* __ACE_INLINE__ */
-#endif /* ACE_RMCAST_IO_UDP_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_IO_UDP.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_IO_UDP.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_IO_UDP.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,37 +0,0 @@
-// RMCast_IO_UDP.i,v 1.5 2003/11/10 21:48:26 shuston Exp
-#include "ace/OS_Memory.h"
-ACE_INLINE
-  :  factory_ (factory)
-// Workaround failure in gcc for lynx hosted on solaris
-// see ACE_RMCast_IO_UDP::handle_input() for more details
-ACE_INLINE ACE_RMCast_UDP_Proxy *
-ACE_RMCast_IO_UDP::allocate_and_bind_proxy (ACE_RMCast_Module *module,
-                                            const ACE_INET_Addr& from_address)
-  ACE_NEW_RETURN (proxy,
-                  ACE_RMCast_UDP_Proxy(this,
-                                       from_address),
-                  0);
-  proxy->next (module);
-  if (this->map_.bind (from_address, proxy) != 0)
-      // @@ LOG??
-      return 0;
-  return proxy;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Membership.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Membership.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Membership.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,186 +0,0 @@
-// RMCast_Membership.cpp,v 1.5 2003/11/01 11:15:19 dhinton Exp
-#include "RMCast_Membership.h"
-#if !defined (__ACE_INLINE__)
-# include "RMCast_Membership.i"
-#include "RMCast_Proxy.h"
-ACE_RCSID(ace, RMCast_Membership, "RMCast_Membership.cpp,v 1.5 2003/11/01 11:15:19 dhinton Exp")
-ACE_RMCast_Membership::~ACE_RMCast_Membership (void)
-int
-ACE_RMCast_Membership::has_members (void)
-  ACE_GUARD_RETURN (ACE_SYNCH_MUTEX, ace_mon, this->mutex_, -1);
-  Proxy_Iterator end = this->proxies_.end ();
-  Proxy_Iterator i = this->proxies_.begin ();
-  return (i != end);
-int
-ACE_RMCast_Membership::ack (ACE_RMCast::Ack &ack)
-  //ACE_DEBUG ((LM_DEBUG, "ACE_RMCast_Membership::ack (%d:%d)\n",
-  //            ack.next_expected, ack.highest_received));
-  ACE_RMCast::Ack next_ack;
-    if (ack.next_expected < this->next_expected_)
-        // @@ This violates an invariant of the class, shouldn't
-        // happen...
-        //ACE_DEBUG ((LM_DEBUG, "ACE_RMCast_Membership::ack[2]\n"));
-        return 0;
-    else if (ack.next_expected == this->next_expected_)
-        // Nothing new, just continue....
-        //ACE_DEBUG ((LM_DEBUG, "ACE_RMCast_Membership::ack[3]\n"));
-        return 0;
-    int r = this->compute_ack_i (ack.source, next_ack);
-    if (r < 0)
-      return r;
-    if (r == 1)
-      return 0;
-  //ACE_DEBUG ((LM_DEBUG, "ACE_RMCast_Membership::ack[4] (%d:%d)\n",
-  //            next_ack.next_expected, next_ack.highest_received));
-  return this->ACE_RMCast_Module::ack (next_ack);
-int
-ACE_RMCast_Membership::join (ACE_RMCast::Join &join)
-  if (join.source == 0)
-    return 0;
-    //            "RMCast_Membership::join - %d\n",
-    //            long(join.source)));
-    if (this->proxies_.insert (join.source) == -1)
-      return -1;
-  (void) this->generate_ack (join.source);
-  return this->ACE_RMCast_Module::join (join);
-int
-ACE_RMCast_Membership::leave (ACE_RMCast::Leave &leave)
-  if (leave.source == 0)
-    return 0;
-    (void) this->proxies_.remove (leave.source);
-  (void) this->generate_ack (leave.source);
-  return this->ACE_RMCast_Module::leave (leave);
-int
-ACE_RMCast_Membership::generate_ack (ACE_RMCast_Proxy *proxy)
-    int r = this->compute_ack_i (proxy, next_ack);
-    if (r < 0)
-      return r;
-    if (r == 1)
-      return 0;
-  //ACE_DEBUG ((LM_DEBUG, "ACE_RMCast_Membership::ack[6] (%d:%d)\n",
-int
-ACE_RMCast_Membership::compute_ack_i (ACE_RMCast_Proxy *source,
-                                      ACE_RMCast::Ack &next_ack)
-  if (i == end)
-    return 1;
-  //            "RMCast_Membership::generate_ack[1] - %d -> (%d:%d)\n",
-  //            long(*i),
-  //            (*i)->next_expected (),
-  //            (*i)->highest_received ()));
-  ACE_UINT32 next_expected = (*i)->next_expected ();
-  ACE_UINT32 highest_received = (*i)->highest_received ();
-  ++i;
-  for (; i != end; ++i)
-      //            "RMCast_Membership::generate_ack[2] - %d -> (%d:%d)\n",
-      //            long(*i),
-      ACE_UINT32 s = (*i)->next_expected ();
-      if (s < next_expected)
-        next_expected = s;
-      ACE_UINT32 r = (*i)->highest_received ();
-      if (r > highest_received)
-        highest_received = r;
-#if 0
-  // @@TODO: this is an important feature, disabled until it is
-  // fully debugged
-  if (this->next_expected_ >= next_expected
-      || this->highest_received_ >= highest_received)
-      // No change....
-      ACE_DEBUG ((LM_DEBUG,
-                  "RMCast_Membership::generate_ack[3]\n"));
-      return 1;
-#endif /* 0 */
-  this->next_expected_ = next_expected;
-  this->highest_received_ = highest_received;
-  next_ack.source = source;
-  next_ack.next_expected = this->next_expected_;
-  next_ack.highest_received = this->highest_received_;
-  //            "RMCast_Membership::generate_ack[4] - (%d:%d)\n",
-  //            next_ack.highest_received));
-  return 0;
-template class ACE_Unbounded_Set<ACE_RMCast_Proxy*>;
-template class ACE_Unbounded_Set_Iterator<ACE_RMCast_Proxy*>;
-template class ACE_Node<ACE_RMCast_Proxy*>;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Membership.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Membership.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Membership.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,104 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_Membership.h,v 1.5 2003/11/01 11:15:19 dhinton Exp
-// = LIBRARY
-//    ace
-// = FILENAME
-// = AUTHOR
-//    Carlos O'Ryan <coryan at uci.edu>
-#ifndef ACE_RMCAST_MEMBERSHIP_H
-#define ACE_RMCAST_MEMBERSHIP_H
-#include /**/ "ace/pre.h"
-#include "ace/Containers.h"
-#include "ace/Thread_Mutex.h"
-#if !defined (ACE_LACKS_PRAGMA_ONCE)
-# pragma once
-#endif /* ACE_LACKS_PRAGMA_ONCE */
-class ACE_RMCast_Proxy;
-/// Track peer membership
- * Reliable senders of events need to know exactly how many peers are
- * receiving the events, and how many events has each peer received so
- * far.
- * This class uses the Join, Leave and Ack messages to build that
- * information, it also summarizes the Ack events and propagate only
- * the global info to the upper layer.
-class ACE_RMCast_Export ACE_RMCast_Membership : public ACE_RMCast_Module
-public:
-  /// Constructor
-  ACE_RMCast_Membership (void);
-  /// Destructor
-  virtual ~ACE_RMCast_Membership (void);
-  /// Return 1 if there are still members in the group
-  int has_members (void);
-  /// Receive an process an Ack message
-   * After receiving the Ack message we find out what is the lowest
-   * sequence number received in order among all the acks received by
-   * the proxies in the collection. We also find out what is the
-   * highest sequence number received by any proxy.
-   * We only propagate that information back to the upper layer, and
-   * then only if there are any news since the last Ack.
-  /// Add a new member to the collection, using the <source> field in
-  /// the Join message
-  /// Remove a member from the collection, using the <source> field in
-private:
-  /// Generate an Ack message, normally due to changes in the
-  /// collection, such as new proxys joining or leaving
-  int generate_ack (ACE_RMCast_Proxy *proxy);
-  /// Compute an Ack message to propagate to the upper layers.
-  int compute_ack_i (ACE_RMCast_Proxy *source,
-                     ACE_RMCast::Ack &next_ack);
-protected:
-  /// Use an unbounded set to maintain the collection of proxies.
-  typedef ACE_Unbounded_Set<ACE_RMCast_Proxy*> Proxy_Collection;
-  typedef ACE_Unbounded_Set_Iterator<ACE_RMCast_Proxy*> Proxy_Iterator;
-  /// The collection of proxies
-  Proxy_Collection proxies_;
-  /// The smallest value of \param next_expected for all the proxies
-  ACE_UINT32 next_expected_;
-  /// The highest value of \param highest_received for all the proxies
-  ACE_UINT32 highest_received_;
-  /// Synchronization
-#if defined (__ACE_INLINE__)
-#include "RMCast_Membership.i"
-#include /**/ "ace/post.h"
-#endif /* ACE_RMCAST_MEMBERSHIP_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Membership.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Membership.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Membership.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,8 +0,0 @@
-// RMCast_Membership.i,v 1.2 2000/10/02 18:40:02 coryan Exp
-ACE_INLINE
-ACE_RMCast_Membership::ACE_RMCast_Membership (void)
-  : next_expected_ (0)
-  , highest_received_ (0)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,102 +0,0 @@
-// RMCast_Module.cpp,v 1.4 2000/10/11 00:57:08 coryan Exp
-# include "RMCast_Module.i"
-ACE_RCSID(ace, RMCast_Module, "RMCast_Module.cpp,v 1.4 2000/10/11 00:57:08 coryan Exp")
-ACE_RMCast_Module::~ACE_RMCast_Module (void)
-int
-ACE_RMCast_Module::next (ACE_RMCast_Module *next)
-  if (this->next_ != 0 && next != 0)
-    return 1;
-  this->next_ = next;
-  return 0;
-ACE_RMCast_Module *
-ACE_RMCast_Module::next (void) const
-  return this->next_;
-int
-ACE_RMCast_Module::open (void)
-  if (this->next () != 0)
-    return this->next ()->open ();
-  return 0;
-int
-ACE_RMCast_Module::close (void)
-    return this->next ()->close ();
-  return 0;
-int
-ACE_RMCast_Module::data (ACE_RMCast::Data &data)
-  return 0;
-int
-ACE_RMCast_Module::poll (ACE_RMCast::Poll &poll)
-    return this->next ()->poll (poll);
-  return 0;
-int
-ACE_RMCast_Module::ack_join (ACE_RMCast::Ack_Join &ack_join)
-    return this->next ()->ack_join (ack_join);
-  return 0;
-int
-ACE_RMCast_Module::ack_leave (ACE_RMCast::Ack_Leave &ack_leave)
-    return this->next ()->ack_leave (ack_leave);
-  return 0;
-int
-ACE_RMCast_Module::ack (ACE_RMCast::Ack &ack)
-    return this->next ()->ack (ack);
-  return 0;
-int
-ACE_RMCast_Module::join (ACE_RMCast::Join &join)
-    return this->next ()->join (join);
-  return 0;
-int
-ACE_RMCast_Module::leave (ACE_RMCast::Leave &leave)
-    return this->next ()->leave (leave);
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,88 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_Module.h,v 1.6 2003/07/19 19:04:15 dhinton Exp
-// = LIBRARY
-//    ace
-// = FILENAME
-//    RMCast_Module.h
-// = AUTHOR
-#ifndef ACE_RMCAST_MODULE_H
-#define ACE_RMCAST_MODULE_H
-#include "RMCast.h"
-# pragma once
-class ACE_Message_Block;
-//! Reliable Multicast Module
-  The reliable multicast protocol is implemented as a stack of
-  "Modules" each one performing one specific task.  In short, this is
-  an instance of the pipes-and-filters architectural pattern.
-class ACE_RMCast_Export ACE_RMCast_Module
-public:
-  //! Constructor
-  ACE_RMCast_Module (void);
-  //! Destructor
-  virtual ~ACE_RMCast_Module (void);
-  //! Modifier for the next element in the stack
-  virtual int next (ACE_RMCast_Module *next);
-  //! Accesor for the next element in the stack
-  virtual ACE_RMCast_Module* next (void) const;
-  //! Initialize the module, setting up the next module
-  //! Close the module.
-  //! Push data through the stack
-  //! Push a polling request through the stack
-  //! Push a message to ack a join request through the stack
-  //! Push a message to ack a leave request through the stack
-  //! Push an ack mesage through the stack
-  //! Push a join message through the stack
-  //! Push a leave message through the stack
-private:
-  //! The next element in the stack
-  ACE_RMCast_Module *next_;
-#include "RMCast_Module.i"
-#endif /* ACE_RMCAST_MODULE_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,7 +0,0 @@
-// RMCast_Module.i,v 1.2 2000/10/10 00:06:30 coryan Exp
-ACE_INLINE
-ACE_RMCast_Module::ACE_RMCast_Module (void)
-  :  next_ (0)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module_Factory.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module_Factory.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module_Factory.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,13 +0,0 @@
-// RMCast_Module_Factory.cpp,v 1.1 2000/08/21 16:09:36 coryan Exp
-# include "RMCast_Module_Factory.i"
-ACE_RCSID(ace, RMCast_Module_Factory, "RMCast_Module_Factory.cpp,v 1.1 2000/08/21 16:09:36 coryan Exp")
-ACE_RMCast_Module_Factory::~ACE_RMCast_Module_Factory (void)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module_Factory.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module_Factory.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module_Factory.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,71 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_Module_Factory.h,v 1.4 2003/07/19 19:04:15 dhinton Exp
-// = LIBRARY
-//    ace
-// = FILENAME
-// = AUTHOR
-#ifndef ACE_RMCAST_MODULE_FACTORY_H
-#define ACE_RMCAST_MODULE_FACTORY_H
-# pragma once
-class ACE_RMCast_Module;
-class ACE_RMCast_IO_UDP;
-//! Create Module stacks
- * Different application will probably require different
- * configurations in their Module stack, some will just want best
- * effort semantics.  Others will use Reliable communication with a
- * maximum retransmission time.  Furthermore, applications may want to
- * receive messages in send order, or just as soon as they are
- * received.
- * Obviously most applications will want to change want happens once a
- * message is completely received.
- * To achieve all this flexibility the IO layer uses this factory to
- * create the full stack of Modules corresponding to a single
- * consumer.
- * To keep the complexity under control the intention is to create
- * helper Factories, such as Reliable_Module_Factory where
- * applications only need to customize a few features.
-class ACE_RMCast_Export ACE_RMCast_Module_Factory
-public:
-  //! Destructor
-  virtual ~ACE_RMCast_Module_Factory (void);
-  //! Create a new proxy
-  virtual ACE_RMCast_Module *create (void) = 0;
-  //! Destroy a proxy
-   * Some factories may allocate modules from a pool, or return the
-   * same module for all proxies.  Consequently, only the factory
-   * knows how to destroy them.
-  virtual void destroy (ACE_RMCast_Module *) = 0;
-#include "RMCast_Module_Factory.i"
-#endif /* ACE_RMCAST_MODULE_FACTORY_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module_Factory.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module_Factory.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Module_Factory.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1 +0,0 @@
-// RMCast_Module_Factory.i,v 1.1 2000/08/21 16:09:36 coryan Exp
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Partial_Message.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Partial_Message.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Partial_Message.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,217 +0,0 @@
-// RMCast_Partial_Message.cpp,v 1.5 2003/11/07 20:27:29 shuston Exp
-#include "RMCast_Partial_Message.h"
-#include "RMCast_Partial_Message.i"
-ACE_RCSID(ace, RMCast_Partial_Message, "RMCast_Partial_Message.cpp,v 1.5 2003/11/07 20:27:29 shuston Exp")
-ACE_RMCast_Partial_Message::
-ACE_RMCast_Partial_Message (ACE_UINT32 message_size)
-  :  max_hole_count_ (ACE_RMCAST_DEFAULT_HOLE_COUNT),
-     hole_count_ (1)
-  ACE_NEW (this->hole_list_,
-           ACE_RMCast_Partial_Message::Hole[this->max_hole_count_]);
-  this->hole_list_[0].start = 0;
-  this->hole_list_[0].end = message_size;
-  this->message_body_.size (message_size);
-  this->message_body_.wr_ptr (message_size);
-~ACE_RMCast_Partial_Message (void)
-  delete[] this->hole_list_;
-int
-ACE_RMCast_Partial_Message::fragment_received (ACE_UINT32 message_size,
-                                               ACE_UINT32 offset,
-                                               ACE_Message_Block *mb)
-  if (this->message_body_.length () != message_size)
-      //                  "Partial_Message::fragment_received - "
-      //                  "invalid message length\n"));
-      return -1;
-  // Just copy the data...
-  char *rd_ptr = this->message_body_.rd_ptr () + offset;
-  size_t total_length = 0;
-        if (rd_ptr + i->length () > this->message_body_.wr_ptr ())
-            //                        "invalid payload length\n"));
-            return -1;
-        ACE_OS::memcpy (rd_ptr, i->rd_ptr (), i->length ());
-        rd_ptr       += i->length ();
-        total_length += i->length ();
-  // The algorithm works like this:
-  //   For each hole we determine if there is an intersection between
-  //   the hole and the incoming fragment.  If there is none we do
-  //   nothing (actually since the holes are ordered we can stop the
-  //   iteration if the
-  ACE_UINT32 start = offset;
-  ACE_UINT32 end   = ACE_static_cast (ACE_UINT32,
-                                      offset + total_length);
-  while (start != end && this->hole_count_ != 0)
-      for (size_t i = 0; i < this->hole_count_; ++i)
-          Hole& hole = this->hole_list_[i];
-          // First check if the new data insersects the hole...
-          if (end <= hole.start)
-            return 0;
-          if (start >= hole.end)
-              if (i == this->hole_count_ - 1)
-                return 0;
-              else
-                continue;
-          // The hole and the new fragment intersect, we have to
-          // update the hole list.
-          // There are only three cases for the <start> value:
-          // start < hole.start
-          // start == hole.start
-          // hole.start < start < hole.end
-          // But the code for both start == hole.start and start <
-          // hole.start is identical....
-          if (start <= hole.start)
-              if (end < hole.end)
-                  // NOTE: hole.start < end, because of previous test
-                  // In this case we shrink the hole, but it is not
-                  // removed!
-                  hole.start = end;
-                  return 0;
-              else // end >= hole.end
-                  start = hole.end;
-                  // We remove the hole, and continue the iteration...
-                  if (this->remove_hole (i) == -1)
-                    return -1;
-                  break;
-          else // hole.start < start < hole.end
-              if (end >= hole.end)
-                  // Just adjust the size of the hole...
-                  ACE_UINT32 tmp = hole.end;
-                  hole.end = start;
-                  start = tmp;
-                  break;
-              else // if (end < hole.end)
-                  // Nasty, we need to insert a new hole...
-                  if (this->insert_hole (i, end, hole.end) == -1)
-                    return -1;
-                  // and change the old hole...
-                  // NOTE: we have to refetch it because the array may
-                  // have been reallocated!
-                  this->hole_list_[i].end = start;
-                  return 0;
-  return 0;
-  // @@ OLD COMMENTS, the algorithm has changed since!
-  // There are several cases:
-  // 1) The fragment is completely contained in data already received,
-  //    nothing changes in this case.
-  // 2) Part of the fragment is contained in data already received and
-  //    part is new data:
-  //    2.1) The new data closes a hole, remove it from the list
-  //    2.2) The beginning of the new fragment is the new data, reduce
-  //    the size of the hole
-  //    2.3) The end of the new fragment is the new data, increment
-  //    the size of the received block
-  // 3) The fragment is completely contained in a hole
-  //    3.1) It closes the hole, remove it from the list
-  //    3.2) It starts at the beginning of a hole, grow the received
-  //    block
-  //    3.3) It ends at the end of a hole, reduce the hole size
-  //    3.4) It is in the middle of a hole, insert a new hole
-int
-ACE_RMCast_Partial_Message::insert_hole (size_t i,
-                                         ACE_UINT32 start,
-                                         ACE_UINT32 end)
-  //              "Partial_Message::insert_hole %d = [%d,%d]\n",
-  //              i, start, end));
-  if (this->hole_count_ + 1 > this->max_hole_count_)
-      this->max_hole_count_ *= 2;
-      Hole *tmp;
-      ACE_NEW_RETURN (tmp, Hole[this->max_hole_count_], -1);
-      for (size_t j = 0; j != this->hole_count_; ++j)
-          tmp[j] = this->hole_list_[j];
-      this->hole_list_ = tmp;
-  if (this->hole_count_ != 0)
-      for (size_t j = this->hole_count_ - 1; j >= i + 1; --j)
-          this->hole_list_[j+1] = this->hole_list_[j];
-  this->hole_list_[i + 1].start = start;
-  this->hole_list_[i + 1].end   = end;
-  this->hole_count_++;
-  return 0;
-int
-ACE_RMCast_Partial_Message::remove_hole (size_t i)
-  //              "Partial_Message::remove_hole %d\n",
-  //              i));
-  for (size_t j = i; j != this->hole_count_ - 1; ++j)
-    this->hole_list_[j] = this->hole_list_[j + 1];
-  this->hole_count_--;
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Partial_Message.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Partial_Message.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Partial_Message.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,102 +0,0 @@
-// RMCast_Partial_Message.h,v 1.4 2003/07/19 19:04:15 dhinton Exp
-// = DESCRIPTION
-//   Helper class used in the reassembly layer of the realiable
-//   multicast library.
-// = AUTHOR
-#ifndef ACE_RMCAST_PARTIAL_MESSAGE_H
-#define ACE_RMCAST_PARTIAL_MESSAGE_H
-#include "RMCast_Export.h"
-#include "ace/Task.h"
-# pragma once
-#ifndef ACE_RMCAST_DEFAULT_HOLE_COUNT
-#define ACE_RMCAST_DEFAULT_HOLE_COUNT 16
-#endif /* ACE_RMCAST_DEFAULT_HOLE_COUNT */
-//! Represent a partially received message in the
-//! ACE_RMCast_Reassembly module
- * This class provides temporary storage for the fragments as they are
- * received in the ACE_RMCast_Reassembly module.  It also keeps track
- * of what portions of the message are still missing.
-class ACE_RMCast_Export ACE_RMCast_Partial_Message
-public:
-  //! Constructor, reserve enough memory for the complete message
-  ACE_RMCast_Partial_Message (ACE_UINT32 message_size);
-  //! Destructor
-  ~ACE_RMCast_Partial_Message (void);
-  //! Process a fragment
-   * A fragment starting at <offset> has been received, copy the
-   * fragment contents and update the list of holes.
-  int fragment_received (ACE_UINT32 message_size,
-                         ACE_Message_Block *mb);
-  //! Return 1 if the message is complete
-  int is_complete (void) const;
-  //! Return the body of the message, the memory is *not* owned by the
-  //! caller
-  ACE_Message_Block *message_body (void);
-private:
-  //! Insert a new hole into the list
-   * The class keeps an array to represent the missing portions of the
-   * message.  This method inserts a new hole, i.e. a new element in
-   * the array at index <i>. The <start> and <end> arguments represent
-   * the offsets of the missing portion of the message.
-  int insert_hole (size_t i,
-                   ACE_UINT32 start,
-                   ACE_UINT32 end);
-  //! Remove a hole from the list
-  int remove_hole (size_t i);
-private:
-  //! Maintain the message storage
-  ACE_Message_Block message_body_;
-  //! Represent a missing portion of a message
-  struct Hole
-    //! Offset where the missing portion of the message starts
-    ACE_UINT32 start;
-    //! Offset where the missing portion of the message ends
-    ACE_UINT32 end;
-  //! Implement a growing array of Hole structures
-  Hole *hole_list_;
-  size_t max_hole_count_;
-  size_t hole_count_;
-#endif /* ACE_RMCAST_PARTIAL_MESSAGE_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Partial_Message.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Partial_Message.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Partial_Message.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,15 +0,0 @@
-// RMCast_Partial_Message.i,v 1.1 2000/06/17 00:39:09 coryan Exp
-ACE_INLINE int
-ACE_RMCast_Partial_Message::is_complete (void) const
-  return (this->hole_count_ == 0)
-    || (this->hole_count_ == 1
-        && this->hole_list_[0].start == this->hole_list_[0].end);
-ACE_INLINE ACE_Message_Block *
-ACE_RMCast_Partial_Message::message_body (void)
-  return &this->message_body_;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Proxy.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Proxy.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Proxy.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,46 +0,0 @@
-// RMCast_Proxy.cpp,v 1.4 2000/10/04 19:28:28 coryan Exp
-# include "RMCast_Proxy.i"
-#endif /* ! __ACE_INLINE__ */
-ACE_RCSID(ace, RMCast_Proxy, "RMCast_Proxy.cpp,v 1.4 2000/10/04 19:28:28 coryan Exp")
-ACE_RMCast_Proxy::~ACE_RMCast_Proxy (void)
-ACE_UINT32
-ACE_RMCast_Proxy::next_expected (void) const
-  return this->next_expected_;
-ACE_UINT32
-ACE_RMCast_Proxy::highest_received (void) const
-  return this->highest_received_;
-int
-ACE_RMCast_Proxy::ack (ACE_RMCast::Ack &ack)
-  this->next_expected_ = ack.next_expected;
-  this->highest_received_ = ack.highest_received;
-  return this->ACE_RMCast_Module::ack (ack);
-int
-ACE_RMCast_Proxy::reply_ack_join (ACE_RMCast::Ack_Join &ack_join)
-  if (this->next_expected_ < ack_join.next_sequence_number)
-      this->next_expected_ = ack_join.next_sequence_number;
-      this->highest_received_ = ack_join.next_sequence_number;
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Proxy.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Proxy.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Proxy.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,102 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_Proxy.h,v 1.5 2003/07/19 19:04:15 dhinton Exp
-// = LIBRARY
-//    ace
-// = FILENAME
-//    RMCast_Proxy.h
-// = AUTHOR
-#ifndef ACE_RMCAST_PROXY_H
-#define ACE_RMCAST_PROXY_H
-# pragma once
-//! Local representation for remote peers
-  Both senders and receivers in the multicast group need to maintain
-  explicit representations of their "peers".  For example, a sender
-  needs to know the list of all the receivers and what messages they
-  have reported as successfully received.
-  Likewise, the receiver needs to maintain separate state for each
-  remote sender, and must be able to disconnect from all of them
-  gracefully when needed.
-  The RMCast_Proxy class is an opaque representation of such a peer,
-  and hides all the networking details from the rest of the system.
-class ACE_RMCast_Export ACE_RMCast_Proxy : public ACE_RMCast_Module
-public:
-  //! Constructor
-  ACE_RMCast_Proxy (void);
-  // Constructor
-  //! Destructor
-  virtual ~ACE_RMCast_Proxy (void);
-  //! Return the next sequence number expected by the peer. Only
-  //! applies to remote receiver proxies.
-   * Please read the documentation in ACE_RMCast::Ack
-  virtual ACE_UINT32 next_expected (void) const;
-  //! Return the highest sequence number successfully received.
-  //! Only applies to remote receiver proxies.
-  virtual ACE_UINT32 highest_received (void) const;
-  //! Send messages directly to the peer.
-   * Send a message directly to the peer, i.e. the message is not
-   * sent through the multicast group and it may not be processed by
-   * all the layers in the stack.
-  virtual int reply_data (ACE_RMCast::Data &) = 0;
-  virtual int reply_poll (ACE_RMCast::Poll &) = 0;
-  virtual int reply_ack_join (ACE_RMCast::Ack_Join &);
-  virtual int reply_ack_leave (ACE_RMCast::Ack_Leave &) = 0;
-  virtual int reply_ack (ACE_RMCast::Ack &) = 0;
-  virtual int reply_join (ACE_RMCast::Join &) = 0;
-  virtual int reply_leave (ACE_RMCast::Leave &) = 0;
-   * Proxies process the ACK sequence numbers to cache the ack
-   * information from the peer.
-private:
-  //! Cache the sequence numbers reported from the remote peer using
-  //! Ack messages
-#include "RMCast_Proxy.i"
-#endif /* ACE_RMCAST_PROXY_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Proxy.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Proxy.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Proxy.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,8 +0,0 @@
-// RMCast_Proxy.i,v 1.2 2000/10/02 18:40:02 coryan Exp
-ACE_INLINE
-ACE_RMCast_Proxy::ACE_RMCast_Proxy (void)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reassembly.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reassembly.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reassembly.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,152 +0,0 @@
-// RMCast_Reassembly.cpp,v 1.11 2003/05/05 18:35:26 elliott_c Exp
-#include "RMCast_Reassembly.h"
-#include "ace/Message_Block.h"
-# pragma once
-#include "RMCast_Reassembly.i"
-ACE_RCSID(ace, RMCast_Reassembly, "RMCast_Reassembly.cpp,v 1.11 2003/05/05 18:35:26 elliott_c Exp")
-ACE_RMCast_Reassembly::
-ACE_RMCast_Reassembly (void)
-ACE_RMCast_Reassembly::~ACE_RMCast_Reassembly (void)
-  (void) this->close_i ();
- * We cleanup the resources in the destructor
-int
-ACE_RMCast_Reassembly::close ()
-  this->close_i ();
-  return this->ACE_RMCast_Module::close ();
-int
-ACE_RMCast_Reassembly::data (ACE_RMCast::Data &data)
-    return 0;
-  // ACE_DEBUG ((LM_DEBUG,
-  //             "Reassembly::data - %d,%d,%d\n",
-  //             data.sequence_number,
-  //             data.total_size,
-  //             data.fragment_offset));
-  if (data.payload->length () + data.fragment_offset > data.total_size)
-                  "RMCast_Reassembly::data - invalid size\n"));
-      return -1; // Corrupt message?
-  ACE_RMCast_Partial_Message *message;
-    if (this->messages_.find (data.sequence_number, message) == -1)
-        ACE_NEW_RETURN (message,
-                        ACE_RMCast_Partial_Message (data.total_size),
-                        -1);
-        //             "Reassembly::data - new message\n"));
-        if (this->messages_.bind (data.sequence_number,
-                                  message) == -1)
-          return -1; // Internal error?
-    if (message->fragment_received (data.total_size,
-                                    data.fragment_offset,
-                                    data.payload) == -1)
-        //             "Error in fragment_received\n"));
-        return -1;
-    if (!message->is_complete ())
-        //             "Reassembly::data - message still incomplete\n"));
-        return 0;
-    if (this->messages_.unbind (data.sequence_number) == -1)
-        //            "Reassembly::data - message now complete\n"));
-        return -1;
-  // Push the message...
-  ACE_RMCast::Data downstream_data;
-  downstream_data.source = data.source;
-  downstream_data.sequence_number = data.sequence_number;
-  downstream_data.total_size = ACE_static_cast(
-                                    ACE_UINT32,
-                                    message->message_body ()->length ());
-  downstream_data.fragment_offset = 0;
-  downstream_data.payload = message->message_body ();
-  int r = this->next ()->data (downstream_data);
-  delete message;
-  return r;
-void
-ACE_RMCast_Reassembly::close_i (void)
-  for (Message_Map_Iterator i = this->messages_.begin ();
-       i != this->messages_.end ();
-       ++i)
-      ACE_RMCast_Partial_Message *message = (*i).int_id_;
-      if (message != 0)
-        delete message;
-  this->messages_.unbind_all ();
-template class ACE_Hash_Map_Manager<ACE_UINT32,ACE_RMCast_Partial_Message*,ACE_Null_Mutex>;
-template class ACE_Hash_Map_Manager_Ex<ACE_UINT32,ACE_RMCast_Partial_Message*,ACE_Hash<ACE_UINT32>,ACE_Equal_To<ACE_UINT32>,ACE_Null_Mutex>;
-template class ACE_Hash_Map_Iterator<ACE_UINT32,ACE_RMCast_Partial_Message*,ACE_Null_Mutex>;
-template class ACE_Hash_Map_Iterator_Ex<ACE_UINT32,ACE_RMCast_Partial_Message*,ACE_Hash<ACE_UINT32>,ACE_Equal_To<ACE_UINT32>,ACE_Null_Mutex >;
-template class ACE_Hash_Map_Reverse_Iterator_Ex<ACE_UINT32,ACE_RMCast_Partial_Message*,ACE_Hash<ACE_UINT32>,ACE_Equal_To<ACE_UINT32>,ACE_Null_Mutex >;
-template class ACE_Hash_Map_Iterator_Base_Ex<ACE_UINT32,ACE_RMCast_Partial_Message*,ACE_Hash<ACE_UINT32>,ACE_Equal_To<ACE_UINT32>,ACE_Null_Mutex >;
-template class ACE_Hash_Map_Entry<ACE_UINT32,ACE_RMCast_Partial_Message*>;
-template class ACE_Less_Than<ACE_UINT32>;
-#elif defined (ACE_HAS_TEMPLATE_INSTANTIATION_PRAGMA)
-#pragma instantiate ACE_Hash_Map_Manager<ACE_UINT32,ACE_RMCast_Partial_Message*,ACE_Null_Mutex>
-#pragma instantiate ACE_Hash_Map_Manager_Ex<ACE_UINT32,ACE_RMCast_Partial_Message*,ACE_Hash<ACE_UINT32>,ACE_Equal_To<ACE_UINT32>,ACE_Null_Mutex>
-#pragma instantiate ACE_Hash_Map_Iterator<ACE_UINT32,ACE_RMCast_Partial_Message*,ACE_Null_Mutex>
-#pragma instantiate ACE_Hash_Map_Iterator_Ex<ACE_UINT32,ACE_RMCast_Partial_Message*,ACE_Hash<ACE_UINT32>,ACE_Equal_To<ACE_UINT32>,ACE_Null_Mutex >
-#pragma instantiate ACE_Hash_Map_Reverse_Iterator_Ex<ACE_UINT32,ACE_RMCast_Partial_Message*,ACE_Hash<ACE_UINT32>,ACE_Equal_To<ACE_UINT32>,ACE_Null_Mutex >
-#pragma instantiate ACE_Hash_Map_Iterator_Base_Ex<ACE_UINT32,ACE_RMCast_Partial_Message*,ACE_Hash<ACE_UINT32>,ACE_Equal_To<ACE_UINT32>,ACE_Null_Mutex >
-#pragma instantiate ACE_Hash_Map_Entry<ACE_UINT32,ACE_RMCast_Partial_Message*>
-#pragma instantiate ACE_Less_Than<ACE_UINT32>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reassembly.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reassembly.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reassembly.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,75 +0,0 @@
-// RMCast_Reassembly.h,v 1.7 2003/11/01 11:15:19 dhinton Exp
-// = DESCRIPTION
-//   The reassembly task for the reliable multicast library
-// = AUTHOR
-#ifndef ACE_RMCAST_REASSEMBLY_H
-#define ACE_RMCAST_REASSEMBLY_H
-#include "ace/Synch_Traits.h"
-#include "ace/Null_Mutex.h"
-# pragma once
-class ACE_RMCast_Partial_Message;
-//! Reassemble multiple data fragments into a single data message
-  Data messages may not fit in a single MTU in the transport layer, in
-  that case the application configure a RMCast_Fragment module on the
-  sender side.  On the receiver side this layer reassemble the
-  messages sent from a <EM>single</EM> source, and passes the messages
-  up the stream.
-class ACE_RMCast_Export ACE_RMCast_Reassembly : public ACE_RMCast_Module
-public:
-  //! Constructor
-  ACE_RMCast_Reassembly (void);
-  //! Destructor
-  virtual ~ACE_RMCast_Reassembly (void);
-  // = The ACE_RMCast_Module methods
-private:
-  /// Cleanup resources, but do not close the other modules in the
-  /// stack
-  void close_i (void);
-private:
-  //! A mutex used to synchronize all the internal operations.
-  ACE_SYNCH_MUTEX mutex_;
-  typedef
-      ACE_Hash_Map_Manager<ACE_UINT32,ACE_RMCast_Partial_Message*,ACE_Null_Mutex>
-      Message_Map;
-  typedef
-      ACE_Hash_Map_Iterator<ACE_UINT32,ACE_RMCast_Partial_Message*,ACE_Null_Mutex>
-      Message_Map_Iterator;
-  //! A map, indexed by sequence number, of the partially received
-  //! messages.
-  Message_Map messages_;
-#endif /* ACE_RMCAST_REASSEMBLY_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reassembly.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reassembly.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reassembly.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1 +0,0 @@
-// RMCast_Reassembly.i,v 1.2 2000/08/10 01:35:38 coryan Exp
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Receiver_Module.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Receiver_Module.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Receiver_Module.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,157 +0,0 @@
-// RMCast_Receiver_Module.cpp,v 1.1 2000/10/11 00:57:08 coryan Exp
-#include "RMCast_Receiver_Module.h"
-#include "ace/Log_Msg.h"
-# include "RMCast_Receiver_Module.i"
-ACE_RCSID(ace, RMCast_Receiver_Module, "RMCast_Receiver_Module.cpp,v 1.1 2000/10/11 00:57:08 coryan Exp")
-ACE_RMCast_Receiver_Module::~ACE_RMCast_Receiver_Module (void)
-int
-ACE_RMCast_Receiver_Module::data (ACE_RMCast::Data &data)
-  switch (this->state_)
-    case RS_NON_EXISTENT:
-    case RS_JOINING:
-      if (data.source != 0)
-          //            "Receiver_Module::data - joining\n"));
-          this->state_ = RS_JOINING;
-          ACE_RMCast::Join join;
-          if (data.source->reply_join (join) != 0)
-            this->leaving (data.source);
-      break;
-    case RS_JOINED:
-      //             "Receiver_Module::data - joined\n"));
-      if (this->ACE_RMCast_Module::data (data) != 0)
-      break;
-    default:
-    case RS_LEAVING:
-      break;
-  return 0;
-int
-ACE_RMCast_Receiver_Module::poll (ACE_RMCast::Poll &poll)
-    case RS_JOINING:
-      if (poll.source != 0)
-          if (poll.source->reply_join (join) != 0)
-            this->leaving (poll.source);
-      break;
-    case RS_JOINED:
-      if (this->ACE_RMCast_Module::poll (poll) != 0)
-    default:
-    case RS_LEAVING:
-      break;
-  return 0;
-int
-ACE_RMCast_Receiver_Module::ack_join (ACE_RMCast::Ack_Join &ack_join)
-      if (ack_join.source != 0)
-          //            "Receiver_Module::ack_join - joining\n"));
-          if (ack_join.source->reply_join (join) != 0)
-            this->leaving (ack_join.source);
-      break;
-    case RS_JOINING:
-    case RS_JOINED:
-      //            "Receiver_Module::ack_join - joined\n"));
-      this->state_ = RS_JOINED;
-      if (this->ACE_RMCast_Module::ack_join (ack_join) != 0)
-      break;
-    default:
-    case RS_LEAVING:
-      break;
-  return 0;
-int
-ACE_RMCast_Receiver_Module::ack_leave (ACE_RMCast::Ack_Leave &ack_leave)
-  //            "Receiver_Module::ack_leave\n"));
-  (void) this->ACE_RMCast_Module::ack_leave (ack_leave);
-  // Returning -1 should remove the Proxy from the local set
-  return -1;
-int
-ACE_RMCast_Receiver_Module::ack (ACE_RMCast::Ack &)
-  return -1;
-int
-ACE_RMCast_Receiver_Module::join (ACE_RMCast::Join &)
-  return -1;
-int
-ACE_RMCast_Receiver_Module::leave (ACE_RMCast::Leave &)
-  return -1;
-void
-ACE_RMCast_Receiver_Module::leaving (ACE_RMCast_Proxy *proxy)
-  this->state_ = RS_LEAVING;
-  if (proxy != 0)
-      ACE_RMCast::Leave leave;
-      (void) proxy->reply_leave (leave);
-  (void) this->close ();
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Receiver_Module.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Receiver_Module.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Receiver_Module.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,108 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_Receiver_Module.h,v 1.2 2003/07/19 19:04:15 dhinton Exp
-// = LIBRARY
-//    ace/RMCast
-// = AUTHOR
-#ifndef ACE_RMCAST_RECEIVER_MODULE_H
-#define ACE_RMCAST_RECEIVER_MODULE_H
-#include "RMCast_Module.h"
-# pragma once
-/// Keep track of the receiver module.
- * A receiver proxy must reject invalid messages and communicate with
- * the sender to join and leave the multicast group.
- * This module performs all the task related to
-class ACE_RMCast_Export ACE_RMCast_Receiver_Module : public ACE_RMCast_Module
-public:
-  //! Constructor
-  ACE_RMCast_Receiver_Module (void);
-  //! Destructor
-  virtual ~ACE_RMCast_Receiver_Module (void);
-  virtual int data (ACE_RMCast::Data &);
-  virtual int poll (ACE_RMCast::Poll &);
-  virtual int ack_join (ACE_RMCast::Ack_Join &);
-  virtual int ack_leave (ACE_RMCast::Ack_Leave &);
-  virtual int ack (ACE_RMCast::Ack &);
-  virtual int join (ACE_RMCast::Join &);
-  virtual int leave (ACE_RMCast::Leave &);
-  /// Simple enum used to describe the receiver state transitions
-   * Receivers go through several states before they can fully accept
-   * messages, the following comments describe those states, as well as
-   * the possible transitions
-   * This configuration is pesimistic, any invalid message is cause
-   * enough to reclaim all the resources.  This partially addresses
-   * situations where either accidentally or intentionally a sender is
-   * multicasting packets to the wrong group.
-   <CODE>
-              NON_EXISTENT JOINING      JOINED       LEAVING<BR>
-   ----------------------------------------------------------------<BR>
-  <BR>
-   DATA       JOINING      JOINING      JOINED       LEAVING<BR>
-              Send/Join    Send/Join    Recv/Data    Send/Leave<BR>
-  <BR>
-   POLL       JOINING      JOINING      JOINED       LEAVING<BR>
-              Send/Join    Send/Join    Send/Ack     Send/Leave<BR>
-  <BR>
-   ACK_JOIN   JOINING      JOINED       JOINED       LEAVING<BR>
-              Send/Join    Receive Msg  Receive Msg  Send/Leave<BR>
-  <BR>
-   ACK_LEAVE  NON_EXISTENT NON_EXISTENT NON_EXISTENT NON_EXISTENT<BR>
-              Noop         Destroy      Destroy      Destroy<BR>
-  <BR>
-   ACK        NON_EXISTENT NON_EXISTENT NON_EXISTENT NON_EXISTENT<BR>
-  <BR>
-   JOIN       NON_EXISTENT NON_EXISTENT NON_EXISTENT NON_EXISTENT<BR>
-  <BR>
-   LEAVE      NON_EXISTENT NON_EXISTENT NON_EXISTENT NON_EXISTENT<BR>
-  <BR>
-  </CODE>
-  enum Receiver_State
-    RS_NON_EXISTENT,
-    RS_JOINING,
-    RS_JOINED,
-    RS_LEAVING
-private:
-  /// Enter the leaving state, prepare for termination
-  void leaving (ACE_RMCast_Proxy *proxy);
-private:
-  /// The current state of the receiver
-  int state_;
-#include "RMCast_Receiver_Module.i"
-#endif /* ACE_RMCAST_RECEIVER_MODULE_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Receiver_Module.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Receiver_Module.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Receiver_Module.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,7 +0,0 @@
-// RMCast_Receiver_Module.i,v 1.1 2000/10/11 00:57:08 coryan Exp
-ACE_INLINE
-ACE_RMCast_Receiver_Module::ACE_RMCast_Receiver_Module (void)
-  :  state_ (ACE_RMCast_Receiver_Module::RS_NON_EXISTENT)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reliable_Factory.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reliable_Factory.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reliable_Factory.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,54 +0,0 @@
-// RMCast_Reliable_Factory.cpp,v 1.2 2000/10/11 00:57:08 coryan Exp
-#include "RMCast_Reliable_Factory.h"
-#include "RMCast_Reordering.h"
-# include "RMCast_Reliable_Factory.i"
-ACE_RCSID(ace, RMCast_Reliable_Factory, "RMCast_Reliable_Factory.cpp,v 1.2 2000/10/11 00:57:08 coryan Exp")
-ACE_RMCast_Reliable_Factory::~ACE_RMCast_Reliable_Factory (void)
-ACE_RMCast_Module*
-ACE_RMCast_Reliable_Factory::create (void)
-  ACE_RMCast_Module *receiver;
-  ACE_NEW_RETURN (receiver, ACE_RMCast_Receiver_Module, 0);
-  ACE_RMCast_Module *reassembly;
-  ACE_NEW_RETURN (reassembly, ACE_RMCast_Reassembly, 0);
-  ACE_RMCast_Module *reordering;
-  ACE_NEW_RETURN (reordering, ACE_RMCast_Reordering, 0);
-  ACE_RMCast_Module *user = this->factory_->create ();
-  if (user == 0)
-      delete receiver;
-      delete reordering;
-      delete reassembly;
-      return 0;
-  receiver->next (reassembly);
-  reassembly->next (reordering);
-  reordering->next (user);
-  return receiver;
-void
-ACE_RMCast_Reliable_Factory::destroy (ACE_RMCast_Module *receiver)
-  ACE_RMCast_Module *reassembly = receiver->next ();
-  ACE_RMCast_Module *reordering = reassembly->next ();
-  ACE_RMCast_Module *user = reordering->next ();
-  this->factory_->destroy (user);
-  delete receiver;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reliable_Factory.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reliable_Factory.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reliable_Factory.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,60 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_Reliable_Factory.h,v 1.4 2003/07/19 19:04:15 dhinton Exp
-// = LIBRARY
-//    ace
-// = FILENAME
-// = AUTHOR
-#ifndef ACE_RMCAST_RELIABLE_FACTORY_H
-#define ACE_RMCAST_RELIABLE_FACTORY_H
-# pragma once
-/// Implement an ACE_RMCast_Module_Factory that "creates" a single
-/// object.
- * Many applications (and even some internal components), will use a
- * single ACE_RMCast_Module to process all the events, for example, a
- * receiver may decide to use the same ACE_RMCast_Module to process
- * all incoming events, instead of using one per remote sender.
-class ACE_RMCast_Export ACE_RMCast_Reliable_Factory : public ACE_RMCast_Module_Factory
-public:
-  /// Constructor
-  ACE_RMCast_Reliable_Factory (ACE_RMCast_Module_Factory *factory);
-  //! Destructor
-  virtual ~ACE_RMCast_Reliable_Factory (void);
-   * The create() method will return always @c reliable.
-  virtual ACE_RMCast_Module *create (void);
-  virtual void destroy (ACE_RMCast_Module *);
-private:
-  /// Delegate on another factory to create the user module
-#include "RMCast_Reliable_Factory.i"
-#endif /* ACE_RMCAST_RELIABLE_FACTORY_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reliable_Factory.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reliable_Factory.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reliable_Factory.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,8 +0,0 @@
-// RMCast_Reliable_Factory.i,v 1.1 2000/10/10 00:06:30 coryan Exp
-ACE_INLINE
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reordering.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reordering.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reordering.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,179 +0,0 @@
-// RMCast_Reordering.cpp,v 1.4 2003/11/07 20:27:29 shuston Exp
-#include "ace/Guard_T.h"
-# include "RMCast_Reordering.i"
-ACE_RCSID(ace, RMCast_Reordering, "RMCast_Reordering.cpp,v 1.4 2003/11/07 20:27:29 shuston Exp")
-ACE_RMCast_Reordering::~ACE_RMCast_Reordering (void)
-int
-ACE_RMCast_Reordering::close (void)
-  Messages_Iterator i = this->messages_.begin ();
-  Messages_Iterator end = this->messages_.end ();
-  while (i != end)
-      ACE_Message_Block::release ((*i).item ().payload);
-      this->messages_.unbind ((*i).key ());
-      i = this->messages_.begin ();
-int
-ACE_RMCast_Reordering::data (ACE_RMCast::Data &data)
-  int must_ack = 0;
-  int result = 0;
-  ACE_RMCast::Ack ack;
-  //ACE_DEBUG ((LM_DEBUG, "Received message (%d)\n", data.sequence_number));
-    if (data.sequence_number < this->next_expected_)
-        // Old message.  Ack with the current status (look at the end
-        // of this block).
-        must_ack = 1;
-        //ACE_DEBUG ((LM_DEBUG, ".... old message is ignored\n"));
-    else if (data.sequence_number == this->next_expected_)
-        //ACE_DEBUG ((LM_DEBUG, ".... message is in order, received\n"));
-        // Accept the message, the current thread will dispatch it, so
-        // it is marked as accepted (using the <next_expected> field).
-        // Any other thread will not push that message because now it
-        // is "old".
-        this->next_expected_++;
-        // Right message, process as many messages as possible from
-        // the queue, then ack the right level...
-        // NOTE: we cannot release the mutex while dispatching
-        // events, otherwise: how do we stop other threads from
-        // delivering messages out of order?  I.E. what if the
-        // next thread receives the next message?
-            result = this->next ()->data (data);
-        // After delivering one message there may be more messages
-        // pending
-        if (result == 0)
-          result = this->push_queued_messages ();
-        //@@ This should be strategized, for example, only Ack if
-        //   there is a message out of order or something, otherwise
-        //   continue with happiness.  That works well for "optimistic
-        //   models".
-        must_ack = 1;
-    else
-        //ACE_DEBUG ((LM_DEBUG, ".... message out of sequence, saved\n"));
-        // Out of sequence.
-        if (this->highest_received_ < data.sequence_number)
-            this->highest_received_ = data.sequence_number;
-        ACE_RMCast::Data new_data = data;
-        new_data.payload = ACE_Message_Block::duplicate (data.payload);
-        (void) this->messages_.bind (data.sequence_number, new_data);
-        // re-ack, otherwise save it and ack.
-    ack.next_expected = this->next_expected_;
-    ack.highest_received = this->highest_received_;
-  if (must_ack && data.source != 0)
-    (void) data.source->reply_ack (ack);
-  return result;
-int
-ACE_RMCast_Reordering::ack_join (ACE_RMCast::Ack_Join &ack_join)
-  //ACE_DEBUG ((LM_DEBUG, "RMCast_Reordering::ack_join - <%d,%d>\n",
-  //            this->next_expected_,
-  //            ack_join.next_sequence_number));
-    if (this->next_expected_ >= ack_join.next_sequence_number)
-        // Nothing to do in this case...
-        return 0;
-    while (i != end
-           && (*i).key () < ack_join.next_sequence_number)
-    if (this->highest_received_ < ack_join.next_sequence_number)
-    this->push_queued_messages ();
-  return 0;
-int
-ACE_RMCast_Reordering::push_queued_messages (void)
-  while (i != end
-         && (*i).key () == this->next_expected_)
-      int r = 0;
-          ACE_RMCast::Data data = (*i).item ();
-          r = this->next ()->data (data);
-      if (r != 0)
-        return r;
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reordering.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reordering.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reordering.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,98 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_Reordering.h,v 1.4 2003/11/01 11:15:19 dhinton Exp
-// = LIBRARY
-//    ace/RMCast
-// = AUTHOR
-#ifndef ACE_RMCAST_REORDERING_H
-#define ACE_RMCAST_REORDERING_H
-#include "ace/RB_Tree.h"
-# pragma once
-/// Pass messages up in sent order
- * Some applications require receivers to process messages in the same
- * order that messages are sent.  This module buffers out of order
- * messages and only delivers a message if:
- * - All the previous messages have been delivered.
- * - The sender sends a notification that previous messages will not
- *   be resent.
- * The module also sends the Ack feedback to the sender.
- * NOTE:  This is not the same as causal or total ordering, that could
- * be implemented someday, but requires a lot more than what we have
- * right now.
-class ACE_RMCast_Export ACE_RMCast_Reordering : public ACE_RMCast_Module
-public:
-  /// Constructor
-  ACE_RMCast_Reordering (void);
-  /// Destructor
-  virtual ~ACE_RMCast_Reordering (void);
-  /// Use a Red-Black Tree to keep the queue of messages
-  typedef ACE_RB_Tree<ACE_UINT32,ACE_RMCast::Data,ACE_Less_Than<ACE_UINT32>,ACE_Null_Mutex> Messages;
-  typedef ACE_RB_Tree_Iterator<ACE_UINT32,ACE_RMCast::Data,ACE_Less_Than<ACE_UINT32>,ACE_Null_Mutex> Messages_Iterator;
-  /// Remove messages still pending
-  virtual int close (void);
-  /// Process a Data message.
-   * Process a Data message, sending the right Ack message back.
-   * The message is passed up only if it is in order.
-  /// During the join process the server informs us of the next
-  /// expected message
-private:
-  /// Push any messages that are pending in the queue
-  int push_queued_messages (void);
-protected:
-  /// The reordering buffer
-  Messages messages_;
-#include "RMCast_Reordering.i"
-#endif /* ACE_RMCAST_REORDERING_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reordering.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reordering.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Reordering.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,8 +0,0 @@
-// RMCast_Reordering.i,v 1.1 2000/10/04 00:10:30 coryan Exp
-ACE_INLINE
-ACE_RMCast_Reordering::ACE_RMCast_Reordering (void)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Handler.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Handler.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Handler.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,22 +0,0 @@
-// RMCast_Resend_Handler.cpp,v 1.2 2000/10/11 00:57:08 coryan Exp
-#include "RMCast_Resend_Handler.h"
-#include "RMCast_Retransmission.h"
-# include "RMCast_Resend_Handler.i"
-ACE_RCSID(ace, RMCast_Resend_Handler, "RMCast_Resend_Handler.cpp,v 1.2 2000/10/11 00:57:08 coryan Exp")
-ACE_RMCast_Resend_Handler::~ACE_RMCast_Resend_Handler (void)
-int
-ACE_RMCast_Resend_Handler::handle_timeout (const ACE_Time_Value &,
-                                           const void *)
-  (void) this->retransmission_->resend_all ();
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Handler.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Handler.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Handler.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,44 +0,0 @@
-// RMCast_Resend_Handler.h,v 1.2 2003/07/19 19:04:15 dhinton Exp
-#ifndef ACE_RMCAST_RESEND_HANDLER_H
-#define ACE_RMCAST_RESEND_HANDLER_H
-#include "ace/Event_Handler.h"
-# pragma once
-class ACE_RMCast_Retransmission;
-/// Implement an adapter to resend messages in the
-/// ACE_RMCast_Retransmission layer, but based on Reactor based
-/// timeouts.
-class ACE_RMCast_Export ACE_RMCast_Resend_Handler : public ACE_Event_Handler
-public:
-  /// Constructor, save io_udp as the Adaptee in the Adapter pattern.
-  ACE_RMCast_Resend_Handler (ACE_RMCast_Retransmission *retransmission);
-  /// Destructor
-  ~ACE_RMCast_Resend_Handler (void);
-  //! Documented in ACE_Event_Handler class
-  virtual int handle_timeout (const ACE_Time_Value &current_time,
-                              const void *act = 0);
-private:
-  //! The adaptee
-  ACE_RMCast_Retransmission *retransmission_;
-#include "RMCast_Resend_Handler.i"
-#endif /* ACE_RMCAST_RESEND_HANDLER_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Handler.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Handler.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Handler.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,8 +0,0 @@
-// RMCast_Resend_Handler.i,v 1.1 2000/10/10 00:06:30 coryan Exp
-ACE_INLINE
-ACE_RMCast_Resend_Handler (ACE_RMCast_Retransmission *r)
-  :  retransmission_ (r)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Worker.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Worker.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Worker.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,31 +0,0 @@
-// RMCast_Resend_Worker.cpp,v 1.1 2000/10/11 00:57:08 coryan Exp
-#include "RMCast_Resend_Worker.h"
-# include "RMCast_Resend_Worker.i"
-ACE_RCSID(ace, RMCast_Resend_Worker, "RMCast_Resend_Worker.cpp,v 1.1 2000/10/11 00:57:08 coryan Exp")
-int
-ACE_RMCast_Resend_Worker::work (ACE_UINT32 const & key,
-                                ACE_RMCast::Data const &item)
-  if (key > this->max_sequence_number_)
-    return 0;
-  //            "RMCast_Resend_Worker::work - message %d resent\n",
-  //            key));
-  ACE_RMCast::Data data = item;
-  int r = this->next_->data (data);
-  if (r != 0)
-    return r;
-  this->n++;
-  return 1; // @@ Stop after the first message...
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Worker.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Worker.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Worker.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,49 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_Resend_Worker.h,v 1.2 2003/07/19 19:04:15 dhinton Exp
-#ifndef ACE_RMCAST_RESEND_WORKER_H
-#define ACE_RMCAST_RESEND_WORKER_H
-#include "RMCast_Copy_On_Write.h"
-# pragma once
-/// Process an Ack message in the ACE_RMCast_Retransmission module
- * The retransmission module uses internal iterators, thus it needs to
- * create helper Worker classes to process some messages.
-class ACE_RMCast_Resend_Worker
-  : public ACE_RMCast_Worker<ACE_UINT32,ACE_RMCast::Data>
-public:
-  ACE_RMCast_Resend_Worker (ACE_RMCast_Module *next,
-                            ACE_UINT32 max_sequence_number);
-  virtual int work (ACE_UINT32 const & key,
-                    ACE_RMCast::Data const &item);
-  int n;
-private:
-  ACE_UINT32 max_sequence_number_;
-private:
-  ACE_RMCast_Resend_Worker (const ACE_RMCast_Resend_Worker&);
-  ACE_RMCast_Resend_Worker& operator= (const ACE_RMCast_Resend_Worker&);
-#include "RMCast_Resend_Worker.i"
-#endif /* ACE_RMCAST_RESEND_WORKER_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Worker.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Worker.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Resend_Worker.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,12 +0,0 @@
-// RMCast_Resend_Worker.i,v 1.1 2000/10/11 00:57:08 coryan Exp
-ACE_INLINE
-ACE_RMCast_Resend_Worker (ACE_RMCast_Module *next,
-  : n (0)
-  , next_ (next)
-  , max_sequence_number_ (max_sequence_number)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Retransmission.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Retransmission.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Retransmission.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,149 +0,0 @@
-// RMCast_Retransmission.cpp,v 1.8 2003/04/11 23:33:40 rpollock Exp
-#include "RMCast_Ack_Worker.h"
-# include "RMCast_Retransmission.i"
-ACE_RCSID(ace, RMCast_Retransmission, "RMCast_Retransmission.cpp,v 1.8 2003/04/11 23:33:40 rpollock Exp")
-ACE_RMCast_Retransmission::~ACE_RMCast_Retransmission (void)
-int
-ACE_RMCast_Retransmission::resend (ACE_UINT32 max_sequence_number)
-  if (this->next () == 0)
-    return 0;
-  ACE_RMCast_Resend_Worker worker (this->next (), max_sequence_number);
-  if (this->messages_.for_each (&worker) == -1)
-    return -1;
-  return worker.n;
-int
-ACE_RMCast_Retransmission::resend_all (void)
-    return 0;
-  ACE_RMCast_Resend_Worker worker (this->next (), ACE_UINT32_MAX);
-    return -1;
-  return worker.n;
-int
-ACE_RMCast_Retransmission::has_data (void)
-  return !this->messages_.empty ();
-int
-ACE_RMCast_Retransmission::close (void)
-  return 0;
-int
-ACE_RMCast_Retransmission::data (ACE_RMCast::Data &data)
-    return 0;
-  int r = this->next ()->data (data);
-  if (r == 0)
-      ACE_RMCast::Data copy = data;
-      copy.payload = ACE_Message_Block::duplicate (data.payload);
-      r = this->messages_.bind (data.sequence_number, copy);
-  return r;
-int
-ACE_RMCast_Retransmission::join (ACE_RMCast::Join &join)
-    return 0;
-  ACE_RMCast::Ack_Join ack_join;
-  ack_join.source = 0;
-  ack_join.next_sequence_number = this->messages_.first_key ();
-  (void) join.source->reply_ack_join (ack_join);
-  // @@ We should force a full retransmission of all the messages!
-  return 0;
-int
-ACE_RMCast_Retransmission::leave (ACE_RMCast::Leave &leave)
-    return 0;
-  ACE_RMCast::Ack_Leave ack_leave;
-  ack_leave.source = 0;
-  (void) leave.source->reply_ack_leave (ack_leave);
-  return 0;
-int
-ACE_RMCast_Retransmission::ack (ACE_RMCast::Ack &ack)
-  Messages::Write_Guard ace_mon (this->messages_);
-  ACE_RMCast_Ack_Worker worker (ack, ace_mon, &this->messages_);
-  return this->messages_.for_each (&worker);
-#if defined (ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION)
-template class ACE_RB_Tree<ACE_UINT32,ACE_RMCast::Data,ACE_Less_Than<ACE_UINT32>,ACE_Null_Mutex>;
-template class ACE_RB_Tree_Iterator_Base<ACE_UINT32,ACE_RMCast::Data,ACE_Less_Than<ACE_UINT32>,ACE_Null_Mutex>;
-template class ACE_RB_Tree_Iterator<ACE_UINT32,ACE_RMCast::Data,ACE_Less_Than<ACE_UINT32>,ACE_Null_Mutex>;
-template class ACE_RB_Tree_Reverse_Iterator<ACE_UINT32,ACE_RMCast::Data,ACE_Less_Than<ACE_UINT32>,ACE_Null_Mutex>;
-template class ACE_RB_Tree_Node<ACE_UINT32,ACE_RMCast::Data>;
-template class ACE_RMCast_Copy_On_Write<ACE_UINT32,ACE_RMCast::Data,ACE_RMCast_Retransmission::Collection,ACE_RMCast_Retransmission::Collection_Iterator>;
-template class ACE_RMCast_Copy_On_Write_Container<ACE_RMCast_Retransmission::Collection,ACE_RMCast_Retransmission::Collection_Iterator>;
-template class ACE_RMCast_Copy_On_Write_Write_Guard<ACE_RMCast_Retransmission::Collection,ACE_RMCast_Retransmission::Collection_Iterator>;
-template class ACE_RMCast_Copy_On_Write_Read_Guard<ACE_RMCast_Retransmission::Collection,ACE_RMCast_Retransmission::Collection_Iterator>;
-template class ACE_RMCast_Copy_On_Write_Collection<ACE_RMCast_Retransmission::Collection,ACE_RMCast_Retransmission::Collection_Iterator>;
-template class ACE_RMCast_Worker<ACE_UINT32,ACE_RMCast::Data>;
-#elif defined(ACE_HAS_TEMPLATE_INSTANTIATION_PRAGMA)
-#pragma instantiate ACE_RB_Tree<ACE_UINT32,ACE_RMCast::Data,ACE_Less_Than<ACE_UINT32>,ACE_Null_Mutex>
-#pragma instantiate ACE_RB_Tree_Iterator_Base<ACE_UINT32,ACE_RMCast::Data,ACE_Less_Than<ACE_UINT32>,ACE_Null_Mutex>
-#pragma instantiate ACE_RB_Tree_Iterator<ACE_UINT32,ACE_RMCast::Data,ACE_Less_Than<ACE_UINT32>,ACE_Null_Mutex>
-#pragma instantiate ACE_RB_Tree_Reverse_Iterator<ACE_UINT32,ACE_RMCast::Data,ACE_Less_Than<ACE_UINT32>,ACE_Null_Mutex>
-#pragma instantiate ACE_RB_Tree_Node<ACE_UINT32,ACE_RMCast::Data>
-#pragma instantiate ACE_RMCast_Copy_On_Write<ACE_UINT32,ACE_RMCast::Data,ACE_RMCast_Retransmission::Collection,ACE_RMCast_Retransmission::Collection_Iterator>
-#pragma instantiate ACE_RMCast_Copy_On_Write_Container<ACE_RMCast_Retransmission::Collection,ACE_RMCast_Retransmission::Collection_Iterator>
-#pragma instantiate ACE_RMCast_Copy_On_Write_Write_Guard<ACE_RMCast_Retransmission::Collection,ACE_RMCast_Retransmission::Collection_Iterator>
-#pragma instantiate ACE_RMCast_Copy_On_Write_Read_Guard<ACE_RMCast_Retransmission::Collection,ACE_RMCast_Retransmission::Collection_Iterator>
-#pragma instantiate ACE_RMCast_Copy_On_Write_Collection<ACE_RMCast_Retransmission::Collection,ACE_RMCast_Retransmission::Collection_Iterator>
-#pragma instantiate ACE_RMCast_Worker<ACE_UINT32,ACE_RMCast::Data>
-#endif /* ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Retransmission.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Retransmission.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Retransmission.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,119 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_Retransmission.h,v 1.6 2003/11/10 01:48:03 dhinton Exp
-// = LIBRARY
-//    ace
-// = FILENAME
-// = AUTHOR
-#ifndef ACE_RMCAST_RETRANSMISSION_H
-#define ACE_RMCAST_RETRANSMISSION_H
-# pragma once
-/// Store messages for retransmission in reliable configurations
- * Reliable configurations of the RMCast framework need to store
- * messages on the sender side to resend them if one or more clients
- * do not receive them successfully.
-class ACE_RMCast_Export ACE_RMCast_Retransmission : public ACE_RMCast_Module
-public:
-  // = Initialization and termination methods.
-  /// Constructor
-  ACE_RMCast_Retransmission (void);
-  /// Destructor
-  virtual ~ACE_RMCast_Retransmission (void);
-  typedef ACE_RB_Tree<ACE_UINT32,ACE_RMCast::Data,ACE_Less_Than<ACE_UINT32>,ACE_Null_Mutex> Collection;
-  typedef ACE_RB_Tree_Iterator<ACE_UINT32,ACE_RMCast::Data,ACE_Less_Than<ACE_UINT32>,ACE_Null_Mutex> Collection_Iterator;
-  /// The messages are stored in the Copy_On_Write wrapper to provide
-  /// an efficient, but thread safe interface.
-  typedef ACE_RMCast_Copy_On_Write<ACE_UINT32,ACE_RMCast::Data,Collection,Collection_Iterator> Messages;
-  /// Resend messages
-   * Resends all the messages up to \param max_sequence_number
-   * Returns the number of messages sent, or -1 if there where any
-   * errors.
-  int resend (ACE_UINT32 max_sequence_number);
-  /// Resend all messages
-   * Resends all the messages currently in the queue.
-  int resend_all (void);
-  /// Return 0 if there is no pending data to send
-  int has_data (void);
-  /// Cleanup all the stored messages
-  /// Pass the message downstream, but also save it in the
-  /// retransmission queue
-   * Sequence number are assigned by the ACE_RMCast_Fragmentation
-   * class, consequently this class first passes the message
-   * downstream, to obtain the sequence number and then stores the
-   * message for later retransmission.
-  virtual int data (ACE_RMCast::Data &data);
-  /// Process an Ack message from the remote receivers.
-   * Normally this Ack message will be a summary of all the Ack
-   * messages received by the ACE_RMCast_Membership class
-  /// Detect when new members join the group and Ack_Join them
-   * When a new receiver joins the group this module sends an Ack_Join
-   * message with the next sequence number that the receiver should
-   * expect.
-   * The sequence number is obtained from the current list of cached
-   * messages.
-  /// A receiver is leaving
-   * Normally the ACE_RMCast_Membership module could do this, but,
-   * because this module processes the Join messages, it seems more
-   * natural to process the Leave messages too.
-protected:
-  /// The retransmission buffer
-#include "RMCast_Retransmission.i"
-#endif /* __ACE_INLINE__ */
-#endif /* ACE_RMCAST_RETRANSMISSION_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Retransmission.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Retransmission.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Retransmission.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,6 +0,0 @@
-// RMCast_Retransmission.i,v 1.1 2000/09/24 00:03:24 coryan Exp
-ACE_INLINE
-ACE_RMCast_Retransmission::ACE_RMCast_Retransmission (void)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Sequencer.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Sequencer.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Sequencer.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,27 +0,0 @@
-// RMCast_Sequencer.cpp,v 1.2 2003/11/01 11:15:19 dhinton Exp
-#include "RMCast_Sequencer.h"
-#if !defined (__ACE_INLINE__)
-# include "RMCast_Sequencer.i"
-ACE_RCSID(ace, RMCast_Sequencer, "RMCast_Sequencer.cpp,v 1.2 2003/11/01 11:15:19 dhinton Exp")
-ACE_RMCast_Sequencer::~ACE_RMCast_Sequencer (void)
-int
-ACE_RMCast_Sequencer::data (ACE_RMCast::Data &data)
-    ACE_GUARD_RETURN (ACE_SYNCH_MUTEX, ace_mon, this->mutex_, -1);
-    data.sequence_number = this->sequence_number_generator_++;
-  return this->ACE_RMCast_Module::data (data);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Sequencer.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Sequencer.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Sequencer.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,55 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_Sequencer.h,v 1.3 2003/11/01 11:15:19 dhinton Exp
-// = LIBRARY
-//    ace/RMCast
-// = AUTHOR
-#ifndef ACE_RMCAST_SEQUENCER_H
-#define ACE_RMCAST_SEQUENCER_H
-# pragma once
-/// Assign sequence numbers to outgoing messages
- * On the sender side we must assign sequence numbers to the messages
- * <B>before</B> they are put in the retransmission queue.
-class ACE_RMCast_Export ACE_RMCast_Sequencer : public ACE_RMCast_Module
-public:
-  /// Constructor
-  ACE_RMCast_Sequencer (void);
-  /// Destructor
-  virtual ~ACE_RMCast_Sequencer (void);
-protected:
-  /// Create the sequence numbers
-  ACE_UINT32 sequence_number_generator_;
-#include "RMCast_Sequencer.i"
-#endif /* ACE_RMCAST_SEQUENCER_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Sequencer.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Sequencer.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Sequencer.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,7 +0,0 @@
-// RMCast_Sequencer.i,v 1.1 2000/10/11 00:57:08 coryan Exp
-ACE_INLINE
-ACE_RMCast_Sequencer::ACE_RMCast_Sequencer (void)
-  :  sequence_number_generator_ (0)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Singleton_Factory.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Singleton_Factory.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Singleton_Factory.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,24 +0,0 @@
-// RMCast_Singleton_Factory.cpp,v 1.1 2000/10/10 00:06:30 coryan Exp
-#include "RMCast_Singleton_Factory.h"
-# include "RMCast_Singleton_Factory.i"
-ACE_RCSID(ace, RMCast_Singleton_Factory, "RMCast_Singleton_Factory.cpp,v 1.1 2000/10/10 00:06:30 coryan Exp")
-ACE_RMCast_Singleton_Factory::~ACE_RMCast_Singleton_Factory (void)
-ACE_RMCast_Module*
-ACE_RMCast_Singleton_Factory::create (void)
-  return this->singleton_;
-void
-ACE_RMCast_Singleton_Factory::destroy (ACE_RMCast_Module *)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Singleton_Factory.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Singleton_Factory.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Singleton_Factory.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,61 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_Singleton_Factory.h,v 1.3 2003/07/19 19:04:15 dhinton Exp
-// = LIBRARY
-//    ace
-// = FILENAME
-// = AUTHOR
-//    Carlos O'Ryan <coryan at uci.edu>
-#ifndef ACE_RMCAST_SINGLETON_FACTORY_H
-#define ACE_RMCAST_SINGLETON_FACTORY_H
-#include /**/ "ace/pre.h"
-#include "RMCast_Module_Factory.h"
-#if !defined (ACE_LACKS_PRAGMA_ONCE)
-# pragma once
-#endif /* ACE_LACKS_PRAGMA_ONCE */
-/// object.
-class ACE_RMCast_Export ACE_RMCast_Singleton_Factory : public ACE_RMCast_Module_Factory
-public:
-  /// Constructor
-   * @param singleton This object is returned by any call to
-   * create().
-  ACE_RMCast_Singleton_Factory (ACE_RMCast_Module *singleton);
-  //! Destructor
-  virtual ~ACE_RMCast_Singleton_Factory (void);
-private:
-  /// The singleton object
-  ACE_RMCast_Module *singleton_;
-#include "RMCast_Singleton_Factory.i"
-#endif /* ACE_RMCAST_SINGLETON_FACTORY_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Singleton_Factory.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Singleton_Factory.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Singleton_Factory.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,8 +0,0 @@
-// RMCast_Singleton_Factory.i,v 1.1 2000/10/10 00:06:30 coryan Exp
-ACE_INLINE
-      : singleton_ (singleton)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Event_Handler.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Event_Handler.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Event_Handler.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,36 +0,0 @@
-// RMCast_UDP_Event_Handler.cpp,v 1.3 2000/10/10 00:06:30 coryan Exp
-#include "RMCast_UDP_Event_Handler.h"
-#include "RMCast_IO_UDP.h"
-# include "RMCast_UDP_Event_Handler.i"
-ACE_RCSID(ace, RMCast_UDP_Event_Handler, "RMCast_UDP_Event_Handler.cpp,v 1.3 2000/10/10 00:06:30 coryan Exp")
-ACE_RMCast_UDP_Event_Handler::~ACE_RMCast_UDP_Event_Handler (void)
-ACE_HANDLE
-ACE_RMCast_UDP_Event_Handler::get_handle (void) const
-  return this->io_udp_->get_handle ();
-int
-ACE_RMCast_UDP_Event_Handler::handle_input (ACE_HANDLE h)
-  return this->io_udp_->handle_input (h);
-int
-ACE_RMCast_UDP_Event_Handler::handle_timeout (const ACE_Time_Value &,
-                                              const void *)
-  // @@ return this->io_udp_->handle_timeout ();
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Event_Handler.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Event_Handler.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Event_Handler.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,59 +0,0 @@
-// RMCast_UDP_Event_Handler.h,v 1.4 2003/07/19 19:04:15 dhinton Exp
-#ifndef ACE_RMCAST_UDP_EVENT_HANDLER_H
-#define ACE_RMCAST_UDP_EVENT_HANDLER_H
-# pragma once
-class ACE_INET_Addr;
-//! Implement an Adapter for the ACE_RMCast_IO_UDP class
- * Applications may wish to use the ACE_Reactor to demultiplex I/O
- * events for an ACE_RMCast_IO_UDP object.  However other application
- * may choose to make ACE_RMCast_IO_UDP active, or they may dedicate
- * their own threads for its events.
- * To avoid couplin ACE_RMCast_IO_UDP with the Reactor we don't make
- * it derived from ACE_Event_Handler or any other class in the Reactor
- * framework, instead, this simple Adapter can forward the Reactor
- * messages to an ACE_RMCast_IO_UDP object.
-class ACE_RMCast_Export ACE_RMCast_UDP_Event_Handler : public ACE_Event_Handler
-public:
-  //! Constructor, save io_udp as the Adaptee in the Adapter pattern.
-  ACE_RMCast_UDP_Event_Handler (ACE_RMCast_IO_UDP *io_udp);
-  //! Destructor
-   * Notice that this class does not own the ACE_RMCast_IO_UDP
-   * adaptee, so it does not destroy it.
-  ~ACE_RMCast_UDP_Event_Handler (void);
-  virtual ACE_HANDLE get_handle (void) const;
-  virtual int handle_input (ACE_HANDLE fd = ACE_INVALID_HANDLE);
-private:
-  //! The adaptee
-  ACE_RMCast_IO_UDP *io_udp_;
-#if defined (__ACE_INLINE__)
-#include "RMCast_UDP_Event_Handler.i"
-#include /**/ "ace/post.h"
-#endif /* ACE_RMCAST_UDP_EVENT_HANDLER_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Event_Handler.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Event_Handler.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Event_Handler.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,8 +0,0 @@
-// RMCast_UDP_Event_Handler.i,v 1.2 2000/08/21 16:09:36 coryan Exp
-ACE_INLINE
-ACE_RMCast_UDP_Event_Handler (ACE_RMCast_IO_UDP *io)
-  :  io_udp_ (io)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Proxy.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Proxy.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Proxy.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,190 +0,0 @@
-// RMCast_UDP_Proxy.cpp,v 1.8 2003/12/20 04:58:53 bala Exp
-#include "RMCast_UDP_Proxy.h"
-# include "RMCast_UDP_Proxy.i"
-#include "ace/OS_Memory.h"
-#include "ace/OS_NS_string.h"
-#include "ace/os_include/arpa/os_inet.h"
-ACE_RCSID(ace, RMCast_UDP_Proxy, "RMCast_UDP_Proxy.cpp,v 1.8 2003/12/20 04:58:53 bala Exp")
-ACE_RMCast_UDP_Proxy::ACE_RMCast_UDP_Proxy (ACE_RMCast_IO_UDP *io_udp,
-                                            const ACE_INET_Addr &addr)
-  : io_udp_ (io_udp)
-  , peer_addr_ (addr)
-ACE_RMCast_UDP_Proxy::~ACE_RMCast_UDP_Proxy (void)
-int
-ACE_RMCast_UDP_Proxy::receive_message (char *buffer, size_t size)
-  int type = buffer[0];
-  // @@ What should we do with invalid messages like this?
-  if (type < 0 || type >= ACE_RMCast::RMCAST_MT_LAST)
-    return 0;
-  if (type == ACE_RMCast::RMCAST_MT_POLL)
-      ACE_RMCast::Poll poll;
-      poll.source = this;
-      return this->poll (poll);
-  else if (type == ACE_RMCast::RMCAST_MT_ACK_JOIN)
-      ack_join.source = this;
-      const size_t header_size = 1 + sizeof(ACE_UINT32);
-      if (size < header_size)
-          // The message is too small
-          return 0;
-      ACE_UINT32 tmp;
-      ACE_OS::memcpy (&tmp, buffer + 1,
-                      sizeof(tmp));
-      ack_join.next_sequence_number = ACE_NTOHL (tmp);
-      return this->ack_join (ack_join);
-  else if (type == ACE_RMCast::RMCAST_MT_ACK_LEAVE)
-      ack_leave.source = this;
-      return this->ack_leave (ack_leave);
-  else if (type == ACE_RMCast::RMCAST_MT_DATA)
-      ACE_RMCast::Data data;
-      data.source = this;
-      const size_t header_size = 1 + 3 * sizeof(ACE_UINT32);
-          return 0;
-      ACE_UINT32 tmp;
-                      sizeof(tmp));
-      data.sequence_number = ACE_NTOHL (tmp);
-      ACE_OS::memcpy (&tmp, buffer + 1 + sizeof(tmp),
-                      sizeof(tmp));
-      data.total_size = ACE_NTOHL (tmp);
-      ACE_OS::memcpy (&tmp, buffer + 1 + 2 * sizeof(tmp),
-                      sizeof(tmp));
-      data.fragment_offset = ACE_NTOHL (tmp);
-      // Pass it up the module...
-      ACE_Message_Block *mb;
-      ACE_NEW_RETURN (mb, ACE_Message_Block, -1);
-      mb->size (size - header_size);
-      mb->copy (buffer + header_size, size - header_size);
-      data.payload = mb;
-      return this->data (data);
-  else if (type == ACE_RMCast::RMCAST_MT_JOIN)
-      join.source = this;
-      return this->join (join);
-  else if (type == ACE_RMCast::RMCAST_MT_LEAVE)
-      leave.source = this;
-      return this->leave (leave);
-  else if (type == ACE_RMCast::RMCAST_MT_ACK)
-      ack.source = this;
-          return 0;
-      ACE_UINT32 tmp;
-                      sizeof(tmp));
-      ack.next_expected = ACE_NTOHL (tmp);
-      ACE_OS::memcpy (&tmp, buffer + 1 + sizeof(ACE_UINT32),
-                      sizeof(tmp));
-      ack.highest_received = ACE_NTOHL (tmp);
-      return this->ack (ack);
-  return 0;
-int
-ACE_RMCast_UDP_Proxy::reply_data (ACE_RMCast::Data &data)
-  return this->io_udp_->send_data (data, this->peer_addr_);
-int
-ACE_RMCast_UDP_Proxy::reply_poll (ACE_RMCast::Poll &poll)
-  return this->io_udp_->send_poll (poll, this->peer_addr_);
-int
-ACE_RMCast_UDP_Proxy::reply_ack_join (ACE_RMCast::Ack_Join &ack_join)
-  (void) this->ACE_RMCast_Proxy::reply_ack_join (ack_join);
-  return this->io_udp_->send_ack_join (ack_join, this->peer_addr_);
-int
-ACE_RMCast_UDP_Proxy::reply_ack_leave (ACE_RMCast::Ack_Leave &ack_leave)
-  return this->io_udp_->send_ack_leave (ack_leave, this->peer_addr_);
-int
-ACE_RMCast_UDP_Proxy::reply_ack (ACE_RMCast::Ack &ack)
-  return this->io_udp_->send_ack (ack, this->peer_addr_);
-int
-ACE_RMCast_UDP_Proxy::reply_join (ACE_RMCast::Join &join)
-  return this->io_udp_->send_join (join, this->peer_addr_);
-int
-ACE_RMCast_UDP_Proxy::reply_leave (ACE_RMCast::Leave &leave)
-  return this->io_udp_->send_leave (leave, this->peer_addr_);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Proxy.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Proxy.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Proxy.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,88 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_UDP_Proxy.h,v 1.5 2003/07/19 19:04:15 dhinton Exp
-// = LIBRARY
-//    ace
-// = FILENAME
-// = AUTHOR
-#ifndef ACE_RMCAST_UDP_PROXY_H
-#define ACE_RMCAST_UDP_PROXY_H
-#include "RMCast_Proxy.h"
-# pragma once
-#include "ace/INET_Addr.h"
-class ACE_RMCast_IO_UDP;
-/// Define the proxy implementation for UDP based communication
- * Proxy objects are transport specific, they are responsible for
- * storing the remote peer addressing information.
- * This class implements the UDP version of a proxy.
-class ACE_RMCast_Export ACE_RMCast_UDP_Proxy : public ACE_RMCast_Proxy
-public:
-  /// Constructor
-   * The \param io_udp argument is kept to send the replys through the
-   * right socket.
-   * The \param peer_addr is the address used byu the peer to receive
-   * responses.
-  ACE_RMCast_UDP_Proxy (ACE_RMCast_IO_UDP *io_udp,
-                        const ACE_INET_Addr &peer_addr);
-  /// Destructor
-  virtual ~ACE_RMCast_UDP_Proxy (void);
-  /// Receive a message, parse and send it upstream in the right
-  /// format.
-  int receive_message (char *buffer, size_t size);
-  /// Make the peer address available
-  const ACE_INET_Addr &peer_addr (void) const;
-   * Implement the ACE_RMCast_Proxy methods, in this case we use the
-   * @var io_udp_ object to send the data, using the address of our
-   * remote peer.
-  virtual int reply_data (ACE_RMCast::Data &);
-  virtual int reply_poll (ACE_RMCast::Poll &);
-  virtual int reply_ack_leave (ACE_RMCast::Ack_Leave &);
-  virtual int reply_ack (ACE_RMCast::Ack &);
-  virtual int reply_join (ACE_RMCast::Join &);
-  virtual int reply_leave (ACE_RMCast::Leave &);
-private:
-  /// The IO facade
-  /// The remote peer's address
-  ACE_INET_Addr peer_addr_;
-#include "RMCast_UDP_Proxy.i"
-#endif /* ACE_RMCAST_UDP_PROXY_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Proxy.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Proxy.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Proxy.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,7 +0,0 @@
-// RMCast_UDP_Proxy.i,v 1.2 2000/09/24 00:03:24 coryan Exp
-ACE_INLINE const ACE_INET_Addr&
-ACE_RMCast_UDP_Proxy::peer_addr (void) const
-  return this->peer_addr_;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Receiver.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Receiver.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Receiver.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,32 +0,0 @@
-// RMCast_UDP_Reliable_Receiver.cpp,v 1.2 2000/10/25 16:54:33 coryan Exp
-#include "RMCast_UDP_Reliable_Receiver.h"
-#include "ace/Reactor.h"
-# include "RMCast_UDP_Reliable_Receiver.i"
-ACE_RCSID(ace, RMCast_UDP_Reliable_Receiver, "RMCast_UDP_Reliable_Receiver.cpp,v 1.2 2000/10/25 16:54:33 coryan Exp")
-ACE_RMCast_UDP_Reliable_Receiver::ACE_RMCast_UDP_Reliable_Receiver (ACE_RMCast_Module *user_module)
-  : user_factory_ (user_module)
-  , factory_ (&user_factory_)
-  , io_udp_ (&factory_)
-ACE_RMCast_UDP_Reliable_Receiver::~ACE_RMCast_UDP_Reliable_Receiver (void)
-void
-ACE_RMCast_UDP_Reliable_Receiver::reactive_incoming_messages (ACE_Reactor *reactor)
-  ACE_RMCast_UDP_Event_Handler *eh;
-  ACE_NEW (eh, ACE_RMCast_UDP_Event_Handler (&this->io_udp_));
-  /// @@ TODO Make sure it is removed from the Reactor at some point
-  (void) reactor->register_handler (eh, ACE_Event_Handler::READ_MASK);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Receiver.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Receiver.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Receiver.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,49 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_UDP_Reliable_Receiver.h,v 1.3 2003/07/19 19:04:15 dhinton Exp
-#ifndef ACE_RMCAST_UDP_RELIABLE_RECEIVER_H
-#define ACE_RMCAST_UDP_RELIABLE_RECEIVER_H
-# pragma once
-class ACE_Reactor;
-class ACE_RMCast_Export ACE_RMCast_UDP_Reliable_Receiver : public ACE_RMCast_Module
-public:
-  /// Constructor
-  ACE_RMCast_UDP_Reliable_Receiver (ACE_RMCast_Module *user_control);
-  /// Destructor
-  virtual ~ACE_RMCast_UDP_Reliable_Receiver (void);
-  /// Open the UDP I/O module.
-  int init (const ACE_INET_Addr &mcast_group);
-  /// Use the reactor to handle incoming messages
-  void reactive_incoming_messages (ACE_Reactor *reactor);
-private:
-  /// All the proxys give their messages to user module
-  ACE_RMCast_Singleton_Factory user_factory_;
-  /// This factory creates the per-proxy stack
-  ACE_RMCast_Reliable_Factory factory_;
-  /// Handle all the UDP I/O
-  ACE_RMCast_IO_UDP io_udp_;
-#include "RMCast_UDP_Reliable_Receiver.i"
-#endif /* ACE_RMCAST_UDP_RELIABLE_RECEIVER_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Receiver.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Receiver.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Receiver.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,7 +0,0 @@
-// RMCast_UDP_Reliable_Receiver.i,v 1.2 2000/10/25 16:54:33 coryan Exp
-ACE_INLINE int
-ACE_RMCast_UDP_Reliable_Receiver::init (const ACE_INET_Addr &mcast_group)
-  return this->io_udp_.subscribe (mcast_group);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Sender.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Sender.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Sender.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,70 +0,0 @@
-// RMCast_UDP_Reliable_Sender.cpp,v 1.3 2000/10/25 17:27:08 coryan Exp
-#include "RMCast_UDP_Reliable_Sender.h"
-# include "RMCast_UDP_Reliable_Sender.i"
-ACE_RCSID(ace, RMCast_UDP_Reliable_Sender, "RMCast_UDP_Reliable_Sender.cpp,v 1.3 2000/10/25 17:27:08 coryan Exp")
-ACE_RMCast_UDP_Reliable_Sender::ACE_RMCast_UDP_Reliable_Sender (ACE_RMCast_Module *user_control)
-  : user_control_ (user_control)
-  // We use a singleton factory, all proxys send their messages to the
-  // retransmission module.  There should be only control messages
-  // coming back, so this is OK.
-  , factory_ (&membership_)
-  // Control messages are received by the membership module and passed
-  // up to the both the retransmission and user modules, we use a fork
-  // module to do that
-  this->membership_.next (&this->fork_);
-  this->fork_.next (&this->retransmission_);
-  this->fork_.secondary (user_control);
-  // Messages are passed down to the sequencer module
-  this->next (&this->sequencer_);
-  // then to the retransmission module
-  this->sequencer_.next (&this->retransmission_);
-  // Then fork the messages, at this point control messages are sent
-  // back to the user, other messages continue down to the
-  // fragmentation layer.
-  this->retransmission_.next (&this->fragment_);
-  // The fragmentation layer delegates all messages to the UDP I/O
-  // module, that sends every message back to the application.
-  this->fragment_.next (&this->io_udp_);
-ACE_RMCast_UDP_Reliable_Sender::~ACE_RMCast_UDP_Reliable_Sender (void)
-void
-ACE_RMCast_UDP_Reliable_Sender::reactive_incoming_messages (ACE_Reactor *reactor)
-void
-ACE_RMCast_UDP_Reliable_Sender::reactive_resends (ACE_Reactor *reactor,
-                                         const ACE_Time_Value &period)
-  ACE_RMCast_Resend_Handler *eh;
-  ACE_NEW (eh, ACE_RMCast_Resend_Handler (&this->retransmission_));
-  /// @@ TODO make sure it is removed from the Reactor at some point
-  (void) reactor->schedule_timer (eh, 0, period, period);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Sender.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Sender.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Sender.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,78 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_UDP_Reliable_Sender.h,v 1.4 2003/07/19 19:04:15 dhinton Exp
-#ifndef ACE_RMCAST_UDP_RELIABLE_SENDER_H
-#define ACE_RMCAST_UDP_RELIABLE_SENDER_H
-#include "RMCast_Membership.h"
-#include "RMCast_Fragment.h"
-#include "RMCast_Fork.h"
-# pragma once
-class ACE_Reactor;
-class ACE_RMCast_Export ACE_RMCast_UDP_Reliable_Sender : public ACE_RMCast_Module
-public:
-  /// Constructor
-  ACE_RMCast_UDP_Reliable_Sender (ACE_RMCast_Module *user_control);
-  /// Destructor
-  virtual ~ACE_RMCast_UDP_Reliable_Sender (void);
-  /// Use the reactor to periodically resend messages
-  void reactive_resends (ACE_Reactor *reactor,
-                         const ACE_Time_Value &period);
-  /// Check if there is still some messages to send, return 0 if not.
-  /// Check if there are any members still connected
-  int has_members (void);
-private:
-  /// The application-level control module
-  ACE_RMCast_Module *user_control_;
-  /// Assign sequence numbers
-  ACE_RMCast_Sequencer sequencer_;
-  /// The retransmission module
-  ACE_RMCast_Retransmission retransmission_;
-  /// All the proxys give their messages to the retransmission module
-  ACE_RMCast_Singleton_Factory factory_;
-  /// The membership module
-  ACE_RMCast_Membership membership_;
-  /// The fragmentation module
-  ACE_RMCast_Fragment fragment_;
-  /// Redirect control messages to the user supplied module
-  ACE_RMCast_Fork fork_;
-#include "RMCast_UDP_Reliable_Sender.i"
-#endif /* ACE_RMCAST_UDP_RELIABLE_SENDER_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Sender.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Sender.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_UDP_Reliable_Sender.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,19 +0,0 @@
-// RMCast_UDP_Reliable_Sender.i,v 1.3 2000/10/25 16:54:33 coryan Exp
-ACE_INLINE int
-ACE_RMCast_UDP_Reliable_Sender::init (const ACE_INET_Addr &mcast_group)
-  return this->io_udp_.init (mcast_group, ACE_Addr::sap_any);
-ACE_INLINE int
-ACE_RMCast_UDP_Reliable_Sender::has_data (void)
-  return this->retransmission_.has_data ();
-ACE_INLINE int
-ACE_RMCast_UDP_Reliable_Sender::has_members (void)
-  return this->membership_.has_members ();
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Worker.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Worker.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Worker.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,19 +0,0 @@
-// RMCast_Worker.cpp,v 1.1 2000/10/02 18:40:02 coryan Exp
-#ifndef ACE_RMCAST_WORKER_CPP
-#define ACE_RMCAST_WORKER_CPP
-#include "RMCast_Worker.h"
-#if ! defined (__ACE_INLINE__)
-#include "RMCast_Worker.i"
-ACE_RCSID(RMCast, RMCast_Worker, "RMCast_Worker.cpp,v 1.1 2000/10/02 18:40:02 coryan Exp")
-template<class KEY, class ITEM>
-ACE_RMCast_Worker<KEY,ITEM>::~ACE_RMCast_Worker (void)
-#endif /* ACE_RMCAST_WORKER_CPP */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Worker.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Worker.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Worker.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,36 +0,0 @@
-/* -*- C++ -*- */
-// RMCast_Worker.h,v 1.1 2000/10/02 18:40:03 coryan Exp
-#ifndef ACE_RMCAST_WORKER_H
-#define ACE_RMCAST_WORKER_H
-#include "ace/config-all.h"
-# pragma once
-class ACE_RMCast_Worker
-public:
-  virtual ~ACE_RMCast_Worker (void);
-  virtual int work (KEY const & key,
-                    ITEM const & item) = 0;
-#if defined (ACE_TEMPLATES_REQUIRE_SOURCE)
-#include "RMCast_Worker.cpp"
-#endif /* ACE_TEMPLATES_REQUIRE_SOURCE */
-#if defined (ACE_TEMPLATES_REQUIRE_PRAGMA)
-#pragma implementation ("RMCast_Worker.cpp")
-#endif /* ACE_TEMPLATES_REQUIRE_PRAGMA */
-#endif /* ACE_RMCAST_WORKER_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Worker.i
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Worker.i	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/RMCast_Worker.i	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1 +0,0 @@
-// RMCast_Worker.i,v 1.1 2000/10/02 18:40:03 coryan Exp
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/rmcast.mpc
--- trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/rmcast.mpc	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/ace/RMCast/rmcast.mpc	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,8 +0,0 @@
-//  -*- MPC -*-
-// rmcast.mpc,v 1.6 2004/01/08 13:51:26 elliott_c Exp
-project(RMCast) : acelib, core {
-  requires    += rmcast
-  sharedname   = ACE_RMCast
-  dynamicflags = ACE_RMCAST_BUILD_DLL
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/CE_ARGV.CPP
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/CE_ARGV.CPP	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/CE_ARGV.CPP	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,118 +0,0 @@
-// CE_ARGV.CPP,v 1.2 2002/03/31 07:20:33 spark Exp
-#include "CE_ARGV.H"
-CE_ARGV::CE_ARGV(wchar_t* cmdLine)
-: ce_argv_(0)
-, ce_argc_(0)
-    const wchar_t* dummyArgv = L"root";  // dummy for the first argv
-    const wchar_t* separator = L" ";     // blank space is a separator
-    int formattedCmdLineLength = wcslen(dummyArgv) +
-                                 wcslen(separator) +
-                                 1;  // 1 is for the NULL at the end
-    if (wcslen(cmdLine) > 0) {
-        formattedCmdLineLength += wcslen(cmdLine);
-        formattedCmdLineLength += wcslen(separator);
-    // formattedCmdLine will have dummyArgv and a separator at the beginning of cmdLine
-    // and a separator at the end to generalize format and reduce the amount of code
-    wchar_t* formattedCmdLine = 0;
-    formattedCmdLine = new wchar_t[formattedCmdLineLength];
-    wcscpy(formattedCmdLine, dummyArgv);
-    wcscat(formattedCmdLine, separator);
-    int max_possible_argc = 1;  // start with 1 because of the dummyArgv at the beginning
-        int formattedPos  = wcslen(formattedCmdLine);
-        int cmdLineLength = wcslen(cmdLine);
-        // Inside of this for loop, it does same thing as strcat except it
-        // checks and puts only one single white space between two argv entries.
-        for (int i = 0; i < cmdLineLength; ++i) {
-            if (iswspace(cmdLine[i]) != 0) {
-                ++max_possible_argc;  // counting the number of white spaces
-            formattedCmdLine[formattedPos++] = cmdLine[i];
-                // make sure there is only one white space between two argv entries.
-                while ((i < cmdLineLength) && (iswspace(cmdLine[i + 1]) != 0)) {
-                    ++i;
-        formattedCmdLine[formattedPos] = 0;
-        wcscat(formattedCmdLine, separator);  // make sure formattedCmdLine ends with a blank
-    int formattedCmdLength = wcslen(formattedCmdLine);
-    bool insideQuotation = false;
-    int* argv_strlen = 0;
-    int entry_size = 0;
-    argv_strlen = new int[max_possible_argc];
-    // determine argc
-    for (int i = 0; i < formattedCmdLength; ++i) {
-        if (formattedCmdLine[i] == '\\') {
-            ++i; // ignore the following character
-            ++entry_size;
-        else if (formattedCmdLine[i] == '"') {
-            insideQuotation = !insideQuotation;
-        else if ((!insideQuotation) && (iswspace(formattedCmdLine[i]) != 0)) {
-            // new argv entry end found
-            argv_strlen[ce_argc_++] = entry_size;  // cache the size of this entry
-            entry_size = 0;
-        else {
-            ++entry_size;
-    ce_argv_ = new wchar_t*[ce_argc_ + 1];
-    ce_argv_[ce_argc_] = 0;  // Last command line entry is a NULL.
-    for (int j = 0, cmdLinePos = 0; j < ce_argc_; ++j, ++cmdLinePos) {
-        int length = argv_strlen[j];
-        ce_argv_[j] = new wchar_t[length + 1];
-        ce_argv_[j][length] = 0;  // string termination null
-        if (iswspace(formattedCmdLine[cmdLinePos]) != 0) {
-            // This is where prior argv has trailing '"' at the end.
-            ++cmdLinePos;
-        for (int n = 0; n < length; ++n, ++cmdLinePos) {
-            if ((formattedCmdLine[cmdLinePos] == '\\') || (formattedCmdLine[cmdLinePos] == '"')) {
-                ++cmdLinePos;
-            ce_argv_[j][n] = formattedCmdLine[cmdLinePos];
-    delete argv_strlen;
-    delete formattedCmdLine;
-CE_ARGV::~CE_ARGV(void)
-    for (int i = 0; i < ce_argc_; ++i) {
-        delete [] ce_argv_[i];
-    delete [] ce_argv_;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/CE_ARGV.H
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/CE_ARGV.H	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/CE_ARGV.H	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,90 +0,0 @@
-// -*- C++ -*-
- *  @file    CE_ARGV.H
- *  CE_ARGV.H,v 1.2 2002/03/31 07:20:33 spark Exp
- *  @author Si Mong Park <spark at ociweb.com>
-#ifndef CE_ARGV_H
-#define CE_ARGV_H
-#include <windows.h>
- * @class CE_ARGV
- * @brief This class is to hash input parameters, argc and argv, for WinCE platform.
- * Since WinCE only supports wchar_t as an input from OS, some implementation detail,
- * especially for CORBA spec, will not support wchar_t (wchar_t) type parameter.
- * Moreover, WinCE's input parameter type is totally different than any other OS;
- * all command line parameters will be stored in a single wide-character string with
- * each unit parameter divided by blank space, and it does not provide the name of
- * executable (generally known as argv[0]).
- * This class is to convert CE's command line parameters and simulate as in the same
- * manner as other general platforms, adding 'root' as a first argc, which is for the
- * name of executable in other OS.
-class CE_ARGV
-public:
-     * Ctor accepts CE command line as a paramter.
-    CE_ARGV(wchar_t* cmdLine);
-     * Default Dtor that deletes any memory allocated for the converted string.
-    ~CE_ARGV(void);
-     * Returns the number of command line paramters, same as argc on Unix.
-    int argc(void);
-     * Returns the 'char**' that contains the converted command line parameters.
-    wchar_t** const argv(void);
-private:
-     * Copy Ctor is not allowed.
-    CE_ARGV(void);
-    CE_ARGV(CE_ARGV&);
-     * Pointer of converted command line paramters.
-    wchar_t** ce_argv_;
-     * Integer that is same as argc on other OS's.
-    int ce_argc_;
-inline int CE_ARGV::argc()
-    return ce_argc_;
-inline wchar_t** const CE_ARGV::argv()
-    return ce_argv_;
-#endif  // CE_ARGV_H
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/CE_Screen_Output.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/CE_Screen_Output.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/CE_Screen_Output.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,162 +0,0 @@
-// CE_Screen_Output.cpp,v 1.1 2002/03/29 19:48:00 spark Exp
-#include "CE_Screen_Output.h"
-#include <string.h>
-HWND CE_Screen_Output::handler_ = 0;
-CE_Screen_Output::CE_Screen_Output()
-: pFile_(0)
-CE_Screen_Output::~CE_Screen_Output()
-    if (pFile_ != 0) {
-        fclose(pFile_);
-void CE_Screen_Output::SetOutputWindow(HWND hEdit)
-    handler_ = hEdit;
-void CE_Screen_Output::clear()
-    SetWindowText(handler_, NULL);
-CE_Screen_Output& CE_Screen_Output::operator << (wchar_t* output)
-    int length = GetWindowTextLength(handler_);
-    SendMessage(handler_, EM_SETSEL, length, length);
-    SendMessage(handler_, EM_REPLACESEL, 0, (LPARAM)output);
-    if (pFile_ != NULL)
-        fwprintf(pFile_, L"%s", output);
-    return *this;
-CE_Screen_Output& CE_Screen_Output::operator << (const wchar_t* output)
-    wchar_t* buffer = _wcsdup(output);
-    if (buffer != 0)
-        *this << buffer;
-        delete buffer;
-    return *this;
-CE_Screen_Output& CE_Screen_Output::operator << (char* output)
-    int len = MultiByteToWideChar(CP_OEMCP, MB_PRECOMPOSED, output, -1, NULL, 0);
-    wchar_t* w_output = new wchar_t[len];
-    MultiByteToWideChar(CP_OEMCP, MB_PRECOMPOSED, output, -1, w_output, len);
-    *this << w_output;
-    delete w_output;
-    return *this;
-CE_Screen_Output& CE_Screen_Output::operator << (const char* output)
-    delete w_output;
-    return *this;
-CE_Screen_Output& CE_Screen_Output::operator << (char output)
-    *this << (int)output;
-    return *this;
-CE_Screen_Output& CE_Screen_Output::operator << (unsigned char output)
-    return *this;
-CE_Screen_Output& CE_Screen_Output::operator << (unsigned short output)
-	wchar_t buffer[20];
-	wsprintf(buffer, L"%u", output);
-	*this << buffer;
-	return *this;
-CE_Screen_Output& CE_Screen_Output::operator << (int output)
-    wsprintf(buffer, L"%d", output);
-    *this << buffer;
-    return *this;
-CE_Screen_Output& CE_Screen_Output::operator << (unsigned int output)
-    wsprintf(buffer, L"%du", output);
-    *this << buffer;
-    return *this;
-CE_Screen_Output& CE_Screen_Output::operator << (float output)
-    swprintf(buffer, L"%f", output);
-    *this << buffer;
-    return *this;
-CE_Screen_Output& CE_Screen_Output::operator << (long output)
-    wsprintf(buffer, L"%l", output);
-    *this << buffer;
-    return *this;
-CE_Screen_Output& CE_Screen_Output::operator << (unsigned long output)
-    wsprintf(buffer, L"%lu", output);
-    *this << buffer;
-    return *this;
-CE_Screen_Output& CE_Screen_Output::operator << (FILE* pFile)
-    pFile_ = pFile;
-    return *this;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/CE_Screen_Output.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/CE_Screen_Output.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/CE_Screen_Output.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,97 +0,0 @@
- *  @file    CE_Screen_Output.h
- *  CE_Screen_Output.h,v 1.1 2002/03/29 19:48:00 spark Exp
-#ifndef CE_Screen_Output_h
-#define CE_Screen_Output_h
-const wchar_t endl[] = L"\r\n";
-const wchar_t tab[]  = L"\t";
- * @class CE_Screen_Output
- * @brief Replacement of text output for Windows CE.
- * This class allows standard text output to be displayed on
- * text window for Windows CE.  Generally, all ACE output will
- * go through under CE if and only if user uses WindozeCE
- * implementation by using main_ce instead of main.
- * Also, for the easier debugging purpose, object pointer of
- * this class can be gotten from ACE_Log_Msg::msg_callback()
- * and then can be used directly by user just like cout stream.
-class CE_Screen_Output
-public:
-     * Default Ctor
-    CE_Screen_Output();
-     * Default Dtor
-    virtual ~CE_Screen_Output();
-     * Interface to specify active window handle.
-    void SetOutputWindow(HWND hWnd);
-     * Clears text screen.
-    void clear();
-     * << operator that performs actual print out.
-     * Note: This is the only one operator that performs
-     *       output.  All other perators convert the type and
-     *       use this operator underneath.
-    CE_Screen_Output& operator << (wchar_t*);
-    CE_Screen_Output& operator << (const wchar_t*);
-    CE_Screen_Output& operator << (char* output);
-    CE_Screen_Output& operator << (const char* output);
-    CE_Screen_Output& operator << (char output);
-    CE_Screen_Output& operator << (unsigned char output);
-    CE_Screen_Output& operator << (unsigned short output);
-    CE_Screen_Output& operator << (int output);
-    CE_Screen_Output& operator << (unsigned int output);
-    CE_Screen_Output& operator << (float output);
-    CE_Screen_Output& operator << (long output);
-    CE_Screen_Output& operator << (unsigned long output);
-    CE_Screen_Output& operator << (FILE* pFile);
-private:
-     * Copy Ctor
-    CE_Screen_Output(CE_Screen_Output&);
-    static HWND handler_;
-     * File pointer that used to save output to file.
-     * This class does not own the file handler pointer.
-    FILE* pFile_;
-#endif  // CE_Screen_Output_h
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,652 +0,0 @@
-// FaCE.cpp,v 1.4 2002/04/01 08:11:41 spark Exp
-#include "FaCE.h"
-#ifdef NO_ACE
-#include "CE_ARGV.h"
-#else
-#include <ace/ace.h>
-#include <ace/Log_Msg.h>
-#endif  // NO_ACE
-#include <commctrl.h>
-#include <aygshell.h>
-#include <sipapi.h>
-ACE_TCHAR* g_ParameterFileName = ACE_LIB_TEXT("Parameters.txt");
- * This simple and small class manages user-input command line
- * parameters and parameter history file.
- * @author Si Mong Park (spark at ociweb.com)
- * @version 1.4 2002/04/01 08:11:41
-class ParameterList
-public:
-     * Default Ctor.
-    ParameterList() : next_(0), param_(0) {};
-     * Dtor: deletes all sub-PameterList objects as well as
-     *       memory block allocated for the param_ by _wcsdup().
-    ~ParameterList() { free(param_); delete next_; };
-     * Add a new parameter to the list.
-    void addParameter(char*);
-    void addParameter(ACE_TCHAR*);
-     * Save all parameters stored in the list to the
-     * file.
-     * Note that 'outputFile' is only for the internal use
-     * and user must call this function without any parameter.
-    void saveParameter(FILE* outputFile = 0);
-     * Send out windows message to load/update parameters.
-    void sendParameterMSG(HWND, UINT);
-private:
-     * A pointer to the next ParameterList object.
-     * This attribute is totally hidden from user.
-    ParameterList* next_;
-     * User-specified command line parameter.
-    ACE_TCHAR* param_;
-void ParameterList::addParameter(char* newParameter)
-#ifdef NO_ACE
-    int len = MultiByteToWideChar(CP_OEMCP, MB_PRECOMPOSED, newParameter, -1, NULL, 0);
-    MultiByteToWideChar(CP_OEMCP, MB_PRECOMPOSED, newParameter, -1, w_output, len);
-    this->addParameter(w_output);
-    delete w_output;
-#else
-    this->addParameter(ACE_TEXT_CHAR_TO_TCHAR(newParameter));
-#endif  // NO_ACE
-void ParameterList::addParameter(ACE_TCHAR* newParameter)
-    if (this->param_ == 0) {
-        this->param_ = _wcsdup(newParameter);
-        this->next_ = new ParameterList();  // create and add a new ParameterList object
-    else {
-        if (wcscmp(this->param_, newParameter) != 0) {
-            this->next_->addParameter(newParameter);
-void ParameterList::saveParameter(FILE* outputFile)
-    if ( (outputFile == 0) && (this->param_ != 0) ) {
-        outputFile = _wfopen(g_ParameterFileName, ACE_LIB_TEXT("w+"));
-    if (outputFile != 0) {
-        if (this->param_ != 0) {
-            fwprintf(outputFile, ACE_LIB_TEXT("%s\n"), this->param_);
-            this->next_->saveParameter(outputFile);
-        else {
-            fclose(outputFile);
-void ParameterList::sendParameterMSG(HWND hDlg, UINT message)
-    if (param_ != 0) {
-        SendDlgItemMessage(hDlg, IDC_CMDEDIT, message, 0, (LPARAM)this->param_);
-        this->next_->sendParameterMSG(hDlg, message);
-// Global Variables:
-HINSTANCE g_hInst;          // The current instance
-HWND      g_hwndCB;         // The command bar handle
-HWND      hWndEdit;         // Read only edit box for output display
-FILE*     g_OutputFile;     // File handler for output save
-ParameterList g_Parameter;  // command line parameter list
-ACE_CE_Screen_Output cout;  // Replacement of std::cout
-ACE_TCHAR g_CommandLine[MAX_COMMAND_LINE]; // User-specified command line parameter
-ACE_TCHAR g_SaveFileName[MAX_LOADSTRING];      // Name of the output file
-static SHACTIVATEINFO s_sai;
-// Forward declarations of functions included in this code module:
-ATOM                MyRegisterClass (HINSTANCE, ACE_TCHAR*);
-BOOL                InitInstance    (HINSTANCE, int);
-LRESULT CALLBACK    WndProc         (HWND, UINT, WPARAM, LPARAM);
-LRESULT CALLBACK    About           (HWND, UINT, WPARAM, LPARAM);
-LRESULT CALLBACK    CommandLine     (HWND, UINT, WPARAM, LPARAM);
-LRESULT CALLBACK    SaveFileName    (HWND, UINT, WPARAM, LPARAM);
-LRESULT CALLBACK    FileError       (HWND, UINT, WPARAM, LPARAM);
-LRESULT CALLBACK    FileExist       (HWND, UINT, WPARAM, LPARAM);
-HWND                CreateRpCommandBar(HWND);
-void InitSetup()
-    g_OutputFile    = 0;
-    memset(g_CommandLine,  0, MAX_COMMAND_LINE * sizeof(ACE_TCHAR));
-    memset(g_SaveFileName, 0, MAX_LOADSTRING   * sizeof(ACE_TCHAR));
-void LoadParameterHistory()
-    FILE* parameterFile = _wfopen(g_ParameterFileName, ACE_LIB_TEXT("r"));
-    if (parameterFile != NULL) {
-        while (feof(parameterFile) == 0) {
-            // Note: Remember that fwprintf takes wide-character format specifier but
-            // save string as ASCII.  Thus, history must be read as ASCII then converted
-            // to wide-character (Unicode on WinCE).
-            char singleParameter[MAX_COMMAND_LINE];
-            int size = 0;
-            fread(&singleParameter[size], sizeof(char), 1, parameterFile);
-            // WinCE does not have function that reads upto the end of line.
-            while (singleParameter[size] != '\n') {
-                fread(&singleParameter[++size], sizeof(char), 1, parameterFile);
-            if (size > 0) {
-                singleParameter[size] = 0;  // NULL terminator
-                g_Parameter.addParameter(singleParameter);
-        fclose(parameterFile);
-//  FUNCTION: MyRegisterClass()
-//  PURPOSE: Registers the window class.
-//  COMMENTS:
-//    It is important to call this function so that the application
-//    will get 'well formed' small icons associated with it.
-ATOM MyRegisterClass(HINSTANCE hInstance, ACE_TCHAR* szWindowClass)
-    WNDCLASS    wc;
-    wc.style            = CS_HREDRAW | CS_VREDRAW;
-    wc.lpfnWndProc      = (WNDPROC) WndProc;
-    wc.cbClsExtra       = 0;
-    wc.cbWndExtra       = 0;
-    wc.hInstance        = hInstance;
-    wc.hIcon            = LoadIcon(hInstance, MAKEINTRESOURCE(IDI_FACE));
-    wc.hCursor          = 0;
-    wc.hbrBackground    = (HBRUSH) GetStockObject(WHITE_BRUSH);
-    wc.lpszMenuName     = 0;
-    wc.lpszClassName    = szWindowClass;
-    return RegisterClass(&wc);
-//  FUNCTION: InitInstance(HANDLE, int)
-//  PURPOSE: Saves instance handle and creates main window
-//  COMMENTS:
-//    In this function, we save the instance handle in a global variable and
-//    create and display the main program window.
-BOOL InitInstance(HINSTANCE hInstance, int nCmdShow)
-    HWND hWnd = NULL;
-    ACE_TCHAR szTitle[MAX_LOADSTRING];            // The title bar text
-    ACE_TCHAR szWindowClass[MAX_LOADSTRING];      // The window class name
-    g_hInst = hInstance;        // Store instance handle in our global variable
-    // Initialize global strings
-    LoadString(hInstance, IDC_FACE, szWindowClass, MAX_LOADSTRING);
-    LoadString(hInstance, IDS_APP_TITLE, szTitle, MAX_LOADSTRING);
-    //If it is already running, then focus on the window
-    hWnd = FindWindow(szWindowClass, szTitle);
-    if (hWnd)
-        // set focus to foremost child window
-        // The "| 0x01" is used to bring any owned windows to the foreground and
-        // activate them.
-        SetForegroundWindow((HWND)((ULONG) hWnd | 0x00000001));
-        return 0;
-    MyRegisterClass(hInstance, szWindowClass);
-    RECT    rect;
-    GetClientRect(hWnd, &rect);
-    hWnd = CreateWindow(szWindowClass, szTitle, WS_VISIBLE,
-        CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT, NULL, NULL, hInstance, NULL);
-    if (!hWnd)
-        int error = 0;
-        error = GetLastError();
-        return FALSE;
-    //When the main window is created using CW_USEDEFAULT the height of the menubar (if one
-    // is created is not taken into account). So we resize the window after creating it
-    // if a menubar is present
-        RECT rc;
-        GetWindowRect(hWnd, &rc);
-        rc.bottom -= MENU_HEIGHT;
-        if (g_hwndCB)
-            MoveWindow(hWnd, rc.left, rc.top, rc.right, rc.bottom, FALSE);
-    ShowWindow(hWnd, nCmdShow);
-    UpdateWindow(hWnd);
-    return TRUE;
-//  FUNCTION: WndProc(HWND, unsigned, WORD, LONG)
-//  PURPOSE:  Processes messages for the main window.
-//  WM_COMMAND  - process the application menu
-//  WM_PAINT    - Paint the main window
-//  WM_DESTROY  - post a quit message and return
-LRESULT CALLBACK WndProc(HWND hWnd, UINT message, WPARAM wParam, LPARAM lParam)
-    HDC hdc;
-    int wmId, wmEvent, nCmdHt;
-    PAINTSTRUCT ps;
-    RECT textRect;
-    switch (message)
-        case WM_COMMAND:
-            wmId    = LOWORD(wParam);
-            wmEvent = HIWORD(wParam);
-            // Parse the menu selections:
-            switch (wmId)
-                case IDM_HELP_ABOUT:
-                    DialogBox(g_hInst, (const ACE_TCHAR*)IDD_ABOUTBOX, hWnd, (DLGPROC)About);
-                    break;
-                case IDOK:
-                    SendMessage(hWnd, WM_ACTIVATE, MAKEWPARAM(WA_INACTIVE, 0), (LPARAM)hWnd);
-                    SendMessage(hWnd, WM_CLOSE, 0, 0);
-                    break;
-                case ID_SETTING_RUN:
-#ifdef NO_ACE
-                        cout << ACE_LIB_TEXT("START with command line: ") << g_CommandLine << endl;
-                        CE_ARGV ce_argv(g_CommandLine);
-                        main_i(ce_argv.argc(), ce_argv.argv());
-                        cout << ACE_LIB_TEXT("END") << endl << endl;
-#else
-                        ACE_CE_ARGV ce_argv(g_CommandLine);
-                        ACE::init();
-                        ACE_MAIN_OBJECT_MANAGER
-                        ACE_LOG_MSG->msg_callback(&cout);  // register call back
-                        ACE_LOG_MSG->set_flags(ACE_Log_Msg::MSG_CALLBACK);  // set call back flag
-                        ace_main_i(ce_argv.argc(), ce_argv.argv());
-                        ACE::fini();
-#endif  // NO_ACE
-                    break;
-                case ID_SETTING_EXIT:
-                    SendMessage(hWnd, WM_DESTROY, 0, 0);
-                    break;
-                case ID_TOOLS_SAVETOFILE:
-                    // create a dialog box to get the file name
-                    DialogBox(g_hInst, (const ACE_TCHAR*)IDD_OUTFILE, hWnd, (DLGPROC)SaveFileName);
-                    break;
-                case ID_SETTING_COMMANDLINE:
-                    // create a dialog box to get the command line
-                    DialogBox(g_hInst, (const ACE_TCHAR*)IDD_CMDLINE, hWnd, (DLGPROC)CommandLine);
-                    break;
-                default:
-                   return DefWindowProc(hWnd, message, wParam, lParam);
-            break;
-        case WM_CREATE:
-            SHMENUBARINFO mbi;
-            memset(&mbi, 0, sizeof(SHMENUBARINFO));
-            mbi.cbSize     = sizeof(SHMENUBARINFO);
-            mbi.hwndParent = hWnd;
-            mbi.nToolBarId = IDM_MENU;
-            mbi.hInstRes   = g_hInst;
-            mbi.nBmpId     = 0;
-            mbi.cBmpImages = 0;
-            if (!SHCreateMenuBar(&mbi))
-                return NULL;
-            g_hwndCB = mbi.hwndMB;
-            // Initialize the shell activate info structure
-            memset (&s_sai, 0, sizeof (s_sai));
-            s_sai.cbSize = sizeof (s_sai);
-            GetClientRect(hWnd, &textRect);
-            nCmdHt = CommandBar_Height(mbi.hwndMB);
-            hWndEdit = CreateWindow(ACE_LIB_TEXT("EDIT"),
-                                    NULL,
-                                    WS_CHILD | WS_VISIBLE | ES_READONLY | ES_MULTILINE | WS_VSCROLL | WS_HSCROLL,
-                                    0,
-                                    0,
-                                    textRect.right,
-                                    textRect.bottom - MENU_HEIGHT,
-                                    hWnd,
-                                    NULL,
-                                    g_hInst,
-                                    NULL);
-            cout.SetOutputWindow(hWndEdit);
-            LoadParameterHistory();
-            break;
-        case WM_PAINT:
-            RECT rt;
-            hdc = BeginPaint(hWnd, &ps);
-            GetClientRect(hWnd, &rt);
-            EndPaint(hWnd, &ps);
-            break;
-        case WM_ACTIVATE:
-            // Notify shell of our activate message
-            SHHandleWMActivate(hWnd, wParam, lParam, &s_sai, FALSE);
-            break;
-        case WM_SETTINGCHANGE:
-            SHHandleWMSettingChange(hWnd, wParam, lParam, &s_sai);
-            break;
-        case WM_HIBERNATE:  // low power
-        case WM_CLOSE:
-        case WM_DESTROY:
-            g_Parameter.saveParameter();  // save parameters to history file
-            CommandBar_Destroy(g_hwndCB);
-            PostQuitMessage(0);
-            break;
-        default:
-   return 0;
-HWND CreateRpCommandBar(HWND hwnd)
-    mbi.hwndParent = hwnd;
-    mbi.nBmpId     = 0;
-        return NULL;
-    return mbi.hwndMB;
-// Mesage handler for the About box.
-LRESULT CALLBACK About(HWND hDlg, UINT message, WPARAM wParam, LPARAM lParam)
-    SHINITDLGINFO shidi;
-    ACE_TCHAR* copyrightNote = ACE_LIB_TEXT(
-"ACE® and TAO® are copyrighted by Dr. Douglas C. Schmidt and Center for Distributed Object \
-Computing at Washington University,© 1993-2002, all rights reserved.  \
-FaCE is copyrighted by Object Computing, Inc.,© 2002,\n all rights reserved.\n\
-See License.txt for more information.");
-    switch (message)
-        case WM_INITDIALOG:
-            // Create a Done button and size it.
-            shidi.dwMask = SHIDIM_FLAGS;
-            shidi.dwFlags = SHIDIF_DONEBUTTON | SHIDIF_SIPDOWN | SHIDIF_SIZEDLGFULLSCREEN;
-            shidi.hDlg = hDlg;
-            SHInitDialog(&shidi);
-            SetDlgItemText(hDlg, IDC_COPYRIGHT, copyrightNote);
-            return TRUE;
-        case WM_COMMAND:
-            if (LOWORD(wParam) == IDOK)
-                EndDialog(hDlg, LOWORD(wParam));
-                return TRUE;
-            break;
-    return FALSE;
-LRESULT CALLBACK CommandLine(HWND hDlg, UINT message, WPARAM wParam, LPARAM lParam)
-    int wmId;
-    int wmEvent;
-    switch (message)
-        g_Parameter.sendParameterMSG(hDlg, CB_INSERTSTRING);
-        SetDlgItemText(hDlg, IDC_CMDEDIT, g_CommandLine);  // pass existing command line for display
-        return TRUE;
-    case WM_COMMAND:
-        switch (wmId)
-        case IDOK:
-            // new command line accepted
-            GetDlgItemText(hDlg, IDC_CMDEDIT, g_CommandLine, MAX_COMMAND_LINE - 1);
-            EndDialog(hDlg, wmId);
-            g_Parameter.addParameter(g_CommandLine);
-            return TRUE;
-        case IDCANCEL:
-            return TRUE;
-        default:
-            return FALSE;
-        break;
-        default:
-            return FALSE;
-    return FALSE;
-LRESULT CALLBACK SaveFileName(HWND hDlg, UINT message, WPARAM wParam, LPARAM lParam)
-    int wmId;
-    int wmEvent;
-    ACE_TCHAR tempBuffer[MAX_LOADSTRING];
-    ACE_TCHAR fileMode[3] = { 0, '+', 0 };  // mode will either be "a+" or "w+"
-    FILE* tempFile;
-    switch (message)
-        SetDlgItemText(hDlg, IDC_SAVEFILE, g_SaveFileName);
-        return TRUE;
-    case WM_COMMAND:
-        switch (wmId)
-        case IDOK:
-            GetDlgItemText(hDlg, IDC_SAVEFILE, tempBuffer, MAX_LOADSTRING - 1);
-            tempFile = _wfopen(tempBuffer, ACE_LIB_TEXT("r"));
-            if (tempFile != NULL)  // if file exists
-                fclose(tempFile);  // close temp handler
-                int choice = DialogBox(g_hInst, (const ACE_TCHAR*)IDD_FILEEXIST, hDlg, (DLGPROC)FileExist);
-                switch (choice)
-                case IDOVERWRITE:  // overwrite existing file
-                    fileMode[0] = 'w';
-                    break;
-                case IDC_APPEND:  // append to existing file
-                    fileMode[0] = 'a';
-                    break;
-                case IDCANCEL:  // cancel operation without changing g_OutputFile
-                    return TRUE;
-            else  // if file does not exist
-            tempFile = _wfopen(tempBuffer, fileMode);
-            if (tempFile == NULL)
-                DialogBox(g_hInst, (const ACE_TCHAR*)IDD_ERRFILE, hDlg, (DLGPROC)FileError);
-            else
-                wcscpy(g_SaveFileName, tempBuffer);
-                if (g_OutputFile != NULL)
-                    fclose(g_OutputFile);  // close any open file
-                g_OutputFile = tempFile;
-                cout << g_OutputFile;  // update FILE* for the CE_Screen_Output class object.
-            return TRUE;
-        case IDCANCEL:
-            return TRUE;
-        default:
-            return FALSE;
-        break;
-        default:
-            return FALSE;
-    return FALSE;
-LRESULT CALLBACK FileError(HWND hDlg, UINT message, WPARAM wParam, LPARAM lParam)
-    switch (message)
-            return TRUE;
-        case WM_COMMAND:
-                return TRUE;
-            break;
-    return FALSE;
-LRESULT CALLBACK FileExist(HWND hDlg, UINT message, WPARAM wParam, LPARAM lParam)
-    switch (message)
-        return TRUE;
-    case WM_COMMAND:
-        return TRUE;
-    default:
-        return FALSE;
-    return FALSE;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,57 +0,0 @@
-// -*- C++ -*-
- *  @file    FaCE.h
- *  FaCE.h,v 1.1 2002/03/29 19:48:00 spark Exp
-#if !defined(AFX_FACE_H__1043241E_A6A9_4246_A9E4_7A774E19EE73__INCLUDED_)
-#define AFX_FACE_H__1043241E_A6A9_4246_A9E4_7A774E19EE73__INCLUDED_
-#if _MSC_VER > 1000
-#pragma once
-#endif // _MSC_VER > 1000
-#if (_WIN32_WCE <= 211)
-#error This project can not be built for H/PC Pro 2.11 or earlier platforms.
-#endif
-#define WIN32_LEAN_AND_MEAN     // Exclude rarely-used stuff from Windows headers
-// BEGIN FaCE specific preprocessor
-#ifdef NO_ACE
-#define ACE_TCHAR wchar_t
-#define ACE_LIB_TEXT(STRING) L##STRING
-#define ACE_CE_Screen_Output CE_Screen_Output
-int main_i(int, wchar_t**);
-#else
-#include <ace/OS.h>
-#include <ace/CE_Screen_Output.h>
-int ace_main_i(int, ACE_TCHAR**);
-#endif  // NO_ACE
-// END FaCE specific
-#include "resource.h"
-#define MENU_HEIGHT 26
-#define MAX_LOADSTRING    101
-#define MAX_COMMAND_LINE 1001  // Max number of characters + 1 (null at the end) for user-input argv
-extern ACE_CE_Screen_Output cout;  // Replacement of std::cout
-#endif // !defined(AFX_FACE_H__1043241E_A6A9_4246_A9E4_7A774E19EE73__INCLUDED_)
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.rc
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.rc	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.rc	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,268 +0,0 @@
-//Microsoft Developer Studio generated resource script.
-#define APSTUDIO_READONLY_SYMBOLS
-// Generated from the TEXTINCLUDE 2 resource.
-#include "newres.h"
-#undef APSTUDIO_READONLY_SYMBOLS
-// English (U.S.) resources
-#if !defined(AFX_RESOURCE_DLL) || defined(AFX_TARG_ENU)
-#ifdef _WIN32
-LANGUAGE LANG_ENGLISH, SUBLANG_ENGLISH_US
-#pragma code_page(1252)
-#endif //_WIN32
-// Icon
-// Icon with lowest ID value placed first to ensure application icon
-// remains consistent on all systems.
-IDI_FACE                ICON    DISCARDABLE     "FACE.ico"
-#ifdef APSTUDIO_INVOKED
-// TEXTINCLUDE
-1 TEXTINCLUDE DISCARDABLE
-BEGIN
-    "resource.h\0"
-END
-2 TEXTINCLUDE DISCARDABLE
-BEGIN
-    "#include ""newres.h""\r\n"
-    "\0"
-END
-3 TEXTINCLUDE DISCARDABLE
-BEGIN
-    "\r\n"
-    "\0"
-END
-#endif    // APSTUDIO_INVOKED
-// Data
-IDM_MENU SHMENUBAR MOVEABLE PURE
-BEGIN
-    IDM_MENU, 2,
-    I_IMAGENONE, ID_SETTING, TBSTATE_ENABLED,
-    TBSTYLE_DROPDOWN | TBSTYLE_AUTOSIZE, IDS_CAP_SETTING, 0, 0,
-    I_IMAGENONE, IDM_MAIN_COMMAND1, TBSTATE_ENABLED,
-    TBSTYLE_DROPDOWN | TBSTYLE_AUTOSIZE, IDS_HELP, 0, 1,
-END
-// Menubar
-IDM_MENU MENU DISCARDABLE
-BEGIN
-    POPUP "Setting"
-    BEGIN
-        MENUITEM "Command Line",                ID_SETTING_COMMANDLINE
-        MENUITEM "Run",                         ID_SETTING_RUN
-        MENUITEM SEPARATOR
-        MENUITEM "Exit",                        ID_SETTING_EXIT
-    END
-    POPUP "Tools"
-    BEGIN
-        MENUITEM "About",                       IDM_HELP_ABOUT
-        MENUITEM "Save To File",                ID_TOOLS_SAVETOFILE
-    END
-END
-// Dialog
-IDD_ABOUTBOX DIALOG DISCARDABLE  0, 0, 148, 161
-STYLE WS_POPUP | WS_CAPTION
-EXSTYLE 0x80000000L
-CAPTION "About FACE"
-FONT 8, "System"
-BEGIN
-    CONTROL         113,IDC_STATIC,"Static",SS_BITMAP | SS_CENTERIMAGE,33,6,
-                    69,52
-    CTEXT           "Static",IDC_COPYRIGHT,7,86,128,68
-    CONTROL         114,IDC_TAO,"Static",SS_BITMAP,7,61,134,22
-END
-IDD_CMDLINE DIALOG DISCARDABLE  0, 0, 125, 50
-STYLE DS_MODALFRAME | WS_POPUP | WS_CAPTION | WS_SYSMENU
-CAPTION "Command Line"
-FONT 8, "System"
-BEGIN
-    DEFPUSHBUTTON   "OK",IDOK,7,29,50,14
-    PUSHBUTTON      "Cancel",IDCANCEL,68,29,50,14
-    COMBOBOX        IDC_CMDEDIT,7,7,111,80,CBS_DROPDOWN | CBS_AUTOHSCROLL |
-                    CBS_OEMCONVERT | CBS_SORT | CBS_HASSTRINGS | WS_VSCROLL |
-                    WS_TABSTOP
-END
-IDD_OUTFILE DIALOG DISCARDABLE  0, 0, 127, 49
-CAPTION "Output File Name"
-FONT 8, "System"
-BEGIN
-    DEFPUSHBUTTON   "OK",IDOK,7,28,50,14
-    PUSHBUTTON      "Cancel",IDCANCEL,70,28,50,14
-    EDITTEXT        IDC_SAVEFILE,7,7,113,14,ES_AUTOHSCROLL
-END
-IDD_ERRFILE DIALOG DISCARDABLE  0, 0, 124, 49
-CAPTION "ERROR"
-FONT 8, "System"
-BEGIN
-    DEFPUSHBUTTON   "OK",IDOK,37,28,50,14
-    CTEXT           "File Creation Error!",IDC_ERRFILE,13,7,98,17,
-                    SS_CENTERIMAGE
-END
-IDD_FILEEXIST DIALOG DISCARDABLE  0, 0, 114, 90
-CAPTION "File Exists"
-FONT 8, "System"
-BEGIN
-    DEFPUSHBUTTON   "Overwrite",IDOVERWRITE,32,32,50,14
-    PUSHBUTTON      "Cancel",IDCANCEL,32,68,50,14
-    PUSHBUTTON      "Append",IDC_APPEND,32,50,50,14
-    CTEXT           "File already exists!",IDC_STATIC,7,15,100,11
-END
-// Accelerator
-IDC_FACE ACCELERATORS DISCARDABLE
-BEGIN
-    "A",            IDM_HELP_ABOUT,         VIRTKEY, CONTROL, NOINVERT
-    "Q",            IDOK,                   VIRTKEY, CONTROL, NOINVERT
-END
-// DESIGNINFO
-GUIDELINES DESIGNINFO DISCARDABLE
-BEGIN
-    IDD_ABOUTBOX, DIALOG
-    BEGIN
-        LEFTMARGIN, 7
-        RIGHTMARGIN, 141
-        TOPMARGIN, 6
-        BOTTOMMARGIN, 154
-    END
-    IDD_CMDLINE, DIALOG
-    BEGIN
-        LEFTMARGIN, 7
-        RIGHTMARGIN, 118
-        TOPMARGIN, 7
-        BOTTOMMARGIN, 43
-    END
-    IDD_OUTFILE, DIALOG
-    BEGIN
-        LEFTMARGIN, 7
-        RIGHTMARGIN, 120
-        TOPMARGIN, 7
-        BOTTOMMARGIN, 42
-    END
-    IDD_ERRFILE, DIALOG
-    BEGIN
-        LEFTMARGIN, 7
-        RIGHTMARGIN, 117
-        TOPMARGIN, 7
-        BOTTOMMARGIN, 42
-    END
-    IDD_FILEEXIST, DIALOG
-    BEGIN
-        LEFTMARGIN, 7
-        RIGHTMARGIN, 107
-        TOPMARGIN, 7
-        BOTTOMMARGIN, 82
-    END
-END
-// Bitmap
-IDB_ACERACER            BITMAP  DISCARDABLE     "ACE_Racer.bmp"
-IDB_TAO                 BITMAP  DISCARDABLE     "TAO.bmp"
-// String Table
-STRINGTABLE DISCARDABLE
-BEGIN
-    IDS_APP_TITLE           "FaCE"
-    IDC_FACE                "FaCE"
-END
-BEGIN
-    IDS_HELP                "Tools"
-END
-BEGIN
-    IDS_COMMAND1            "Done "
-END
-BEGIN
-    IDS_CAP_SETTING         "Setting"
-END
-#endif    // English (U.S.) resources
-#ifndef APSTUDIO_INVOKED
-// Generated from the TEXTINCLUDE 3 resource.
-#endif    // not APSTUDIO_INVOKED
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.vcp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.vcp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.vcp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,604 +0,0 @@
-# Microsoft eMbedded Visual Tools Project File - Name="FaCE" - Package Owner=<4>
-# Microsoft eMbedded Visual Tools Generated Build File, Format Version 6.02
-# ** DO NOT EDIT **
-# TARGTYPE "Win32 (WCE x86) Application" 0x8301
-# TARGTYPE "Win32 (WCE ARM) Application" 0x8501
-CFG=FaCE - Win32 (WCE ARM) Debug
-!MESSAGE This is not a valid makefile. To build this project using NMAKE,
-!MESSAGE use the Export Makefile command and run
-!MESSAGE
-!MESSAGE NMAKE /f "FaCE.vcn".
-!MESSAGE
-!MESSAGE You can specify a configuration when running NMAKE
-!MESSAGE by defining the macro CFG on the command line. For example:
-!MESSAGE
-!MESSAGE NMAKE /f "FaCE.vcn" CFG="FaCE - Win32 (WCE ARM) Debug"
-!MESSAGE
-!MESSAGE Possible choices for configuration are:
-!MESSAGE
-!MESSAGE "FaCE - Win32 (WCE ARM) Release" (based on "Win32 (WCE ARM) Application")
-!MESSAGE "FaCE - Win32 (WCE ARM) Debug" (based on "Win32 (WCE ARM) Application")
-!MESSAGE "FaCE - Win32 (WCE x86) Release" (based on "Win32 (WCE x86) Application")
-!MESSAGE "FaCE - Win32 (WCE x86) Debug" (based on "Win32 (WCE x86) Application")
-!MESSAGE
-# Begin Project
-# PROP AllowPerConfigDependencies 0
-# PROP Scc_ProjName ""
-# PROP Scc_LocalPath ""
-# PROP ATL_Project 2
-!IF  "$(CFG)" == "FaCE - Win32 (WCE ARM) Release"
-# PROP BASE Use_MFC 0
-# PROP BASE Use_Debug_Libraries 0
-# PROP BASE Output_Dir "ARMRel"
-# PROP BASE Intermediate_Dir "ARMRel"
-# PROP BASE CPU_ID "{D6518FFC-710F-11D3-99F2-00105A0DF099}"
-# PROP BASE Platform_ID "{8A9A2F80-6887-11D3-842E-005004848CBA}"
-# PROP BASE Target_Dir ""
-# PROP Use_MFC 0
-# PROP Use_Debug_Libraries 0
-# PROP Output_Dir "ARMRel"
-# PROP Intermediate_Dir "ARMRel"
-# PROP CPU_ID "{D6518FFC-710F-11D3-99F2-00105A0DF099}"
-# PROP Platform_ID "{8A9A2F80-6887-11D3-842E-005004848CBA}"
-# PROP Ignore_Export_Lib 0
-# PROP Target_Dir ""
-RSC=rc.exe
-# ADD BASE RSC /l 0x409 /d UNDER_CE=$(CEVersion) /d _WIN32_WCE=$(CEVersion) /d "UNICODE" /d "_UNICODE" /d "NDEBUG" /d "$(CePlatform)" /d "ARM" /d "_ARM_" /r
-# ADD RSC /l 0x409 /d UNDER_CE=$(CEVersion) /d _WIN32_WCE=$(CEVersion) /d "UNICODE" /d "_UNICODE" /d "NDEBUG" /d "$(CePlatform)" /d "ARM" /d "_ARM_" /r
-CPP=clarm.exe
-# ADD BASE CPP /nologo /W3 /D _WIN32_WCE=$(CEVersion) /D "$(CePlatform)" /D "ARM" /D "_ARM_" /D UNDER_CE=$(CEVersion) /D "UNICODE" /D "_UNICODE" /D "NDEBUG" /Yu"stdafx.h" /Oxs /M$(CECrtMT) /c
-# ADD CPP /nologo /W3 /I "$(ACE_ROOT)" /D _WIN32_WCE=$(CEVersion) /D "$(CePlatform)" /D "ARM" /D "_ARM_" /D UNDER_CE=$(CEVersion) /D "UNICODE" /D "_UNICODE" /D "NDEBUG" /Oxs /M$(CECrtMT) /c
-# SUBTRACT CPP /YX /Yc /Yu
-MTL=midl.exe
-# ADD BASE MTL /nologo /D "NDEBUG" /mktyplib203 /o "NUL" /win32
-# ADD MTL /nologo /D "NDEBUG" /mktyplib203 /o "NUL" /win32
-BSC32=bscmake.exe
-# ADD BASE BSC32 /nologo
-# ADD BSC32 /nologo
-LINK32=link.exe
-# ADD BASE LINK32 commctrl.lib coredll.lib aygshell.lib /nologo /base:"0x00010000" /stack:0x10000,0x1000 /entry:"WinMainCRTStartup" /nodefaultlib:"$(CENoDefaultLib)" /subsystem:$(CESubsystem) /align:"4096" /MACHINE:ARM
-# ADD LINK32 commctrl.lib coredll.lib aygshell.lib ace_os.lib ace.lib /nologo /base:"0x00010000" /stack:0x10000,0x1000 /entry:"WinMainCRTStartup" /nodefaultlib:"$(CENoDefaultLib)" /libpath:"$(ACE_ROOT)\LIB\Release\ARM" /subsystem:$(CESubsystem) /align:"4096" /MACHINE:ARM
-!ELSEIF  "$(CFG)" == "FaCE - Win32 (WCE ARM) Debug"
-# PROP BASE Use_Debug_Libraries 1
-# PROP BASE Output_Dir "ARMDbg"
-# PROP BASE Intermediate_Dir "ARMDbg"
-# PROP Use_MFC 0
-# PROP Use_Debug_Libraries 1
-# PROP Output_Dir "ARMDbg"
-# PROP Intermediate_Dir "ARMDbg"
-RSC=rc.exe
-# ADD BASE RSC /l 0x409 /d UNDER_CE=$(CEVersion) /d _WIN32_WCE=$(CEVersion) /d "UNICODE" /d "_UNICODE" /d "DEBUG" /d "$(CePlatform)" /d "ARM" /d "_ARM_" /r
-# ADD RSC /l 0x409 /d UNDER_CE=$(CEVersion) /d _WIN32_WCE=$(CEVersion) /d "UNICODE" /d "_UNICODE" /d "DEBUG" /d "$(CePlatform)" /d "ARM" /d "_ARM_" /r
-CPP=clarm.exe
-# ADD BASE CPP /nologo /W3 /Zi /Od /D "DEBUG" /D "ARM" /D "_ARM_" /D UNDER_CE=$(CEVersion) /D _WIN32_WCE=$(CEVersion) /D "$(CePlatform)" /D "UNICODE" /D "_UNICODE" /Yu"stdafx.h" /M$(CECrtMTDebug) /c
-# ADD CPP /nologo /W3 /Zi /Od /I "$(ACE_ROOT)" /D "DEBUG" /D "ARM" /D "_ARM_" /D UNDER_CE=$(CEVersion) /D _WIN32_WCE=$(CEVersion) /D "$(CePlatform)" /D "UNICODE" /D "_UNICODE" /M$(CECrtMTDebug) /c
-MTL=midl.exe
-# ADD BASE MTL /nologo /D "_DEBUG" /mktyplib203 /o "NUL" /win32
-# ADD MTL /nologo /D "_DEBUG" /mktyplib203 /o "NUL" /win32
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD BASE LINK32 commctrl.lib coredll.lib aygshell.lib /nologo /base:"0x00010000" /stack:0x10000,0x1000 /entry:"WinMainCRTStartup" /debug /nodefaultlib:"$(CENoDefaultLib)" /subsystem:$(CESubsystem) /align:"4096" /MACHINE:ARM
-# ADD LINK32 commctrl.lib coredll.lib aygshell.lib ace_osd.lib aced.lib /nologo /base:"0x00010000" /stack:0x10000,0x1000 /entry:"WinMainCRTStartup" /debug /nodefaultlib:"$(CENoDefaultLib)" /libpath:"$(ACE_ROOT)\LIB\Debug\ARM" /subsystem:$(CESubsystem) /align:"4096" /MACHINE:ARM
-!ELSEIF  "$(CFG)" == "FaCE - Win32 (WCE x86) Release"
-# PROP BASE Output_Dir "X86Rel"
-# PROP BASE Intermediate_Dir "X86Rel"
-# PROP BASE CPU_ID "{D6518FF3-710F-11D3-99F2-00105A0DF099}"
-# PROP Use_MFC 0
-# PROP Output_Dir "X86Rel"
-# PROP Intermediate_Dir "X86Rel"
-# PROP CPU_ID "{D6518FF3-710F-11D3-99F2-00105A0DF099}"
-RSC=rc.exe
-# ADD BASE RSC /l 0x409 /d UNDER_CE=$(CEVersion) /d _WIN32_WCE=$(CEVersion) /d "UNICODE" /d "_UNICODE" /d "NDEBUG" /d "$(CePlatform)" /d "_X86_" /d "x86" /d "_i386_" /r
-# ADD RSC /l 0x409 /d UNDER_CE=$(CEVersion) /d _WIN32_WCE=$(CEVersion) /d "UNICODE" /d "_UNICODE" /d "NDEBUG" /d "$(CePlatform)" /d "_X86_" /d "x86" /d "_i386_" /r
-CPP=cl.exe
-# ADD BASE CPP /nologo /W3 /D _WIN32_WCE=$(CEVersion) /D "$(CePlatform)" /D "_i386_" /D UNDER_CE=$(CEVersion) /D "i_386_" /D "UNICODE" /D "_UNICODE" /D "_X86_" /D "x86" /D "NDEBUG" /Yu"stdafx.h" /Gs8192 /GF /Oxs /c
-# ADD CPP /nologo /W3 /I "$(ACE_ROOT)" /D _WIN32_WCE=$(CEVersion) /D "$(CePlatform)" /D "_i386_" /D UNDER_CE=$(CEVersion) /D "i_386_" /D "UNICODE" /D "_UNICODE" /D "_X86_" /D "x86" /D "NDEBUG" /Gs8192 /GF /Oxs /c
-MTL=midl.exe
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD BASE LINK32 commctrl.lib coredll.lib $(CEx86Corelibc) aygshell.lib /nologo /base:"0x00010000" /stack:0x10000,0x1000 /entry:"WinMainCRTStartup" /nodefaultlib:"OLDNAMES.lib" /nodefaultlib:$(CENoDefaultLib) /subsystem:$(CESubsystem) /MACHINE:IX86
-# ADD LINK32 commctrl.lib coredll.lib $(CEx86Corelibc) aygshell.lib ace_os.lib ace.lib /nologo /base:"0x00010000" /stack:0x10000,0x1000 /entry:"WinMainCRTStartup" /nodefaultlib:"OLDNAMES.lib" /nodefaultlib:$(CENoDefaultLib) /subsystem:$(CESubsystem) /MACHINE:IX86
-!ELSEIF  "$(CFG)" == "FaCE - Win32 (WCE x86) Debug"
-# PROP BASE Output_Dir "X86Dbg"
-# PROP BASE Intermediate_Dir "X86Dbg"
-# PROP Use_MFC 0
-# PROP Output_Dir "X86Dbg"
-# PROP Intermediate_Dir "X86Dbg"
-RSC=rc.exe
-# ADD BASE RSC /l 0x409 /d UNDER_CE=$(CEVersion) /d _WIN32_WCE=$(CEVersion) /d "UNICODE" /d "_UNICODE" /d "DEBUG" /d "$(CePlatform)" /d "_X86_" /d "x86" /d "_i386_" /r
-# ADD RSC /l 0x409 /d UNDER_CE=$(CEVersion) /d _WIN32_WCE=$(CEVersion) /d "UNICODE" /d "_UNICODE" /d "DEBUG" /d "$(CePlatform)" /d "_X86_" /d "x86" /d "_i386_" /r
-CPP=cl.exe
-# ADD BASE CPP /nologo /W3 /Zi /Od /D "DEBUG" /D "_i386_" /D UNDER_CE=$(CEVersion) /D _WIN32_WCE=$(CEVersion) /D "$(CePlatform)" /D "i_386_" /D "UNICODE" /D "_UNICODE" /D "_X86_" /D "x86" /Yu"stdafx.h" /Gs8192 /GF /c
-# ADD CPP /nologo /W3 /Zi /Od /I "$(ACE_ROOT)" /D "DEBUG" /D "_i386_" /D UNDER_CE=$(CEVersion) /D _WIN32_WCE=$(CEVersion) /D "$(CePlatform)" /D "i_386_" /D "UNICODE" /D "_UNICODE" /D "_X86_" /D "x86" /Gs8192 /GF /c
-MTL=midl.exe
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD BASE LINK32 commctrl.lib coredll.lib $(CEx86Corelibc) aygshell.lib /nologo /base:"0x00010000" /stack:0x10000,0x1000 /entry:"WinMainCRTStartup" /debug /nodefaultlib:"OLDNAMES.lib" /nodefaultlib:$(CENoDefaultLib) /subsystem:$(CESubsystem) /MACHINE:IX86
-# ADD LINK32 commctrl.lib coredll.lib $(CEx86Corelibc) aygshell.lib ace_osd.lib aced.lib /nologo /base:"0x00010000" /stack:0x10000,0x1000 /entry:"WinMainCRTStartup" /debug /nodefaultlib:"OLDNAMES.lib" /nodefaultlib:$(CENoDefaultLib) /libpath:"$(ACE_ROOT)\LIB\Debug\X86EM" /subsystem:$(CESubsystem) /MACHINE:IX86
-!ENDIF
-# Begin Target
-# Name "FaCE - Win32 (WCE ARM) Release"
-# Name "FaCE - Win32 (WCE ARM) Debug"
-# Name "FaCE - Win32 (WCE x86) Release"
-# Name "FaCE - Win32 (WCE x86) Debug"
-# Begin Group "Source Files"
-# PROP Default_Filter "cpp;c;cxx;rc;def;r;odl;idl;hpj;bat"
-# Begin Source File
-SOURCE=.\FaCE.cpp
-DEP_CPP_FACE_=\
-	".\FaCE.h"\
-NODEP_CPP_FACE_=\
-	".\ipapi.h"\
-	".\StdAfx.h"\
-	".\ygshell.h"\
-DEP_CPP_FACE_=\
-	".\FaCE.h"\
-NODEP_CPP_FACE_=\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\ace.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\ACE.i"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\ACE_export.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\ace_wchar.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\ace_wchar.inl"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Base_Thread_Adapter.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Base_Thread_Adapter.inl"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Basic_Types.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Basic_Types.i"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\CE_Screen_Output.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\config-all.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\config-cygwin32-common.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\config-cygwin32.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\config-g++-common.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\config-ghs-common.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\config-win32-borland.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\config-win32-common.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\config-win32-ghs.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\config-win32-mingw.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\config-win32-msvc-5.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\config-win32-msvc-6.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\config-win32-msvc-7.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\config-win32-msvc.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\config-win32-visualage.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\config-win32.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\config-WinCE.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\config.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Flag_Manip.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Flag_Manip.i"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Handle_Ops.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Handle_Ops.i"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Init_ACE.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Init_ACE.i"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\iosfwd.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Lib_Find.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Lib_Find.i"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Log_Msg.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Log_Msg_Callback.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Log_Priority.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Log_Record.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Log_Record.i"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Managed_Object.cpp"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Managed_Object.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Managed_Object.i"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Min_Max.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Object_Manager.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Object_Manager.i"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\OS.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\OS.i"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\OS_Dirent.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\OS_Dirent.inl"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\OS_Errno.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\OS_Errno.inl"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\OS_Export.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\OS_Log_Msg_Attributes.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\OS_Log_Msg_Attributes.inl"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\OS_Memory.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\OS_Memory.inl"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\OS_String.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\OS_String.inl"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\OS_TLI.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\OS_TLI.inl"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\post.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\pre.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Sock_Connect.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Sock_Connect.i"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\streams.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\svc_export.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Thread_Adapter.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Thread_Adapter.inl"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Thread_Control.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Thread_Control.inl"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Thread_Exit.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Thread_Hook.h"\
-	"..\..\toshiba\implementation\ACE_wrappers\ace\Trace.h"\
-	".\ipapi.h"\
-	".\StdAfx.h"\
-	".\ygshell.h"\
-DEP_CPP_FACE_=\
-	".\FaCE.h"\
-NODEP_CPP_FACE_=\
-	".\ipapi.h"\
-	".\StdAfx.h"\
-	".\ygshell.h"\
-DEP_CPP_FACE_=\
-	"..\..\ace\ace.h"\
-	"..\..\ace\ACE.i"\
-	"..\..\ace\ACE_export.h"\
-	"..\..\ace\ace_wchar.h"\
-	"..\..\ace\ace_wchar.inl"\
-	"..\..\ace\Argv_Type_Converter.h"\
-	"..\..\ace\Argv_Type_Converter.inl"\
-	"..\..\ace\Base_Thread_Adapter.h"\
-	"..\..\ace\Base_Thread_Adapter.inl"\
-	"..\..\ace\Basic_Types.h"\
-	"..\..\ace\Basic_Types.i"\
-	"..\..\ace\CE_Screen_Output.h"\
-	"..\..\ace\config-all.h"\
-	"..\..\ace\config-cygwin32-common.h"\
-	"..\..\ace\config-cygwin32.h"\
-	"..\..\ace\config-g++-common.h"\
-	"..\..\ace\config-ghs-common.h"\
-	"..\..\ace\config-win32-borland.h"\
-	"..\..\ace\config-win32-common.h"\
-	"..\..\ace\config-win32-ghs.h"\
-	"..\..\ace\config-win32-mingw.h"\
-	"..\..\ace\config-win32-msvc-5.h"\
-	"..\..\ace\config-win32-msvc-6.h"\
-	"..\..\ace\config-win32-msvc-7.h"\
-	"..\..\ace\config-win32-msvc.h"\
-	"..\..\ace\config-win32-visualage.h"\
-	"..\..\ace\config-win32.h"\
-	"..\..\ace\config-WinCE.h"\
-	"..\..\ace\config.h"\
-	"..\..\ace\Default_Constants.h"\
-	"..\..\ace\Flag_Manip.h"\
-	"..\..\ace\Flag_Manip.i"\
-	"..\..\ace\Global_Macros.h"\
-	"..\..\ace\Handle_Ops.h"\
-	"..\..\ace\Handle_Ops.i"\
-	"..\..\ace\Init_ACE.h"\
-	"..\..\ace\Init_ACE.i"\
-	"..\..\ace\iosfwd.h"\
-	"..\..\ace\Lib_Find.h"\
-	"..\..\ace\Lib_Find.i"\
-	"..\..\ace\Log_Msg.h"\
-	"..\..\ace\Log_Msg_Callback.h"\
-	"..\..\ace\Log_Priority.h"\
-	"..\..\ace\Log_Record.h"\
-	"..\..\ace\Log_Record.i"\
-	"..\..\ace\Managed_Object.cpp"\
-	"..\..\ace\Managed_Object.h"\
-	"..\..\ace\Managed_Object.i"\
-	"..\..\ace\Min_Max.h"\
-	"..\..\ace\Object_Manager.h"\
-	"..\..\ace\Object_Manager.i"\
-	"..\..\ace\OS.h"\
-	"..\..\ace\OS.i"\
-	"..\..\ace\OS_Dirent.h"\
-	"..\..\ace\OS_Dirent.inl"\
-	"..\..\ace\OS_Errno.h"\
-	"..\..\ace\OS_Errno.inl"\
-	"..\..\ace\OS_Export.h"\
-	"..\..\ace\OS_Log_Msg_Attributes.h"\
-	"..\..\ace\OS_Log_Msg_Attributes.inl"\
-	"..\..\ace\OS_Memory.h"\
-	"..\..\ace\OS_Memory.inl"\
-	"..\..\ace\OS_String.h"\
-	"..\..\ace\OS_String.inl"\
-	"..\..\ace\OS_TLI.h"\
-	"..\..\ace\OS_TLI.inl"\
-	"..\..\ace\post.h"\
-	"..\..\ace\pre.h"\
-	"..\..\ace\Sock_Connect.h"\
-	"..\..\ace\Sock_Connect.i"\
-	"..\..\ace\streams.h"\
-	"..\..\ace\svc_export.h"\
-	"..\..\ace\Thread_Adapter.h"\
-	"..\..\ace\Thread_Adapter.inl"\
-	"..\..\ace\Thread_Control.h"\
-	"..\..\ace\Thread_Control.inl"\
-	"..\..\ace\Thread_Exit.h"\
-	"..\..\ace\Thread_Hook.h"\
-	"..\..\ace\Trace.h"\
-	".\CE_ARGV.h"\
-	".\CE_Screen_Output.h"\
-	".\FaCE.h"\
-	{$(INCLUDE)}"aygshell.h"\
-	{$(INCLUDE)}"sipapi.h"\
-!ENDIF
-# End Source File
-SOURCE=.\FaCE.rc
-!ENDIF
-# End Source File
-SOURCE=.\Main.cpp
-DEP_CPP_MAIN_=\
-	".\FaCE.h"\
-DEP_CPP_MAIN_=\
-	".\FaCE.h"\
-NODEP_CPP_MAIN_=\
-DEP_CPP_MAIN_=\
-	".\FaCE.h"\
-DEP_CPP_MAIN_=\
-	"..\..\ace\OS.h"\
-	"..\..\ace\OS.i"\
-	".\FaCE.h"\
-!ENDIF
-# End Source File
-# End Group
-# Begin Group "Header Files"
-# PROP Default_Filter "h;hpp;hxx;hm;inl"
-SOURCE=.\FaCE.h
-# End Source File
-SOURCE=.\newres.h
-# End Source File
-SOURCE=.\resource.h
-# End Source File
-# End Group
-# Begin Group "Resource Files"
-# PROP Default_Filter "ico;cur;bmp;dlg;rc2;rct;bin;rgs;gif;jpg;jpeg;jpe"
-# End Source File
-SOURCE=.\FaCE.ico
-# End Source File
-# End Source File
-# End Group
-SOURCE=.\License.txt
-# End Source File
-SOURCE=.\ReadMe.txt
-# End Source File
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.vcw
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.vcw	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE.vcw	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,29 +0,0 @@
-Microsoft eMbedded Visual Tools Workspace File, Format Version 3.00
-# WARNING: DO NOT EDIT OR DELETE THIS WORKSPACE FILE!
-Project: "FaCE"=".\FaCE.vcp" - Package Owner=<4>
-Package=<5>
-Package=<4>
-Global:
-Package=<5>
-Package=<3>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCENOACE.vcp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCENOACE.vcp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCENOACE.vcp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,528 +0,0 @@
-# Microsoft eMbedded Visual Tools Project File - Name="FaCENOACE" - Package Owner=<4>
-CFG=FaCENOACE - Win32 (WCE ARM) Debug
-!MESSAGE
-!MESSAGE NMAKE /f "FaCENOACE.vcn".
-!MESSAGE
-!MESSAGE
-!MESSAGE NMAKE /f "FaCENOACE.vcn" CFG="FaCENOACE - Win32 (WCE ARM) Debug"
-!MESSAGE
-!MESSAGE
-!MESSAGE "FaCENOACE - Win32 (WCE ARM) Release" (based on "Win32 (WCE ARM) Application")
-!MESSAGE "FaCENOACE - Win32 (WCE ARM) Debug" (based on "Win32 (WCE ARM) Application")
-!MESSAGE "FaCENOACE - Win32 (WCE x86) Release" (based on "Win32 (WCE x86) Application")
-!MESSAGE "FaCENOACE - Win32 (WCE x86) Debug" (based on "Win32 (WCE x86) Application")
-!MESSAGE
-# Begin Project
-!IF  "$(CFG)" == "FaCENOACE - Win32 (WCE ARM) Release"
-# PROP Use_MFC 0
-# PROP Output_Dir "ARMRelNOACE"
-# PROP Intermediate_Dir "ARMRelNOACE"
-RSC=rc.exe
-CPP=clarm.exe
-# ADD CPP /nologo /W3 /D "ARM" /D "_ARM_" /D "NDEBUG" /D UNDER_CE=$(CEVersion) /D _WIN32_WCE=$(CEVersion) /D "$(CePlatform)" /D "UNICODE" /D "_UNICODE" /D "NO_ACE" /Oxs /M$(CECrtMT) /c
-MTL=midl.exe
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 commctrl.lib coredll.lib aygshell.lib /nologo /base:"0x00010000" /stack:0x10000,0x1000 /entry:"WinMainCRTStartup" /nodefaultlib:"$(CENoDefaultLib)" /subsystem:$(CESubsystem) /align:"4096" /MACHINE:ARM
-!ELSEIF  "$(CFG)" == "FaCENOACE - Win32 (WCE ARM) Debug"
-# PROP Use_MFC 0
-# PROP Output_Dir "ARMDbgNOACE"
-# PROP Intermediate_Dir "ARMDbgNOACE"
-RSC=rc.exe
-CPP=clarm.exe
-# ADD CPP /nologo /W3 /Zi /Od /D "DEBUG" /D "ARM" /D "_ARM_" /D UNDER_CE=$(CEVersion) /D _WIN32_WCE=$(CEVersion) /D "$(CePlatform)" /D "UNICODE" /D "_UNICODE" /D "NO_ACE" /M$(CECrtMTDebug) /c
-MTL=midl.exe
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 commctrl.lib coredll.lib aygshell.lib /nologo /base:"0x00010000" /stack:0x10000,0x1000 /entry:"WinMainCRTStartup" /debug /nodefaultlib:"$(CENoDefaultLib)" /subsystem:$(CESubsystem) /align:"4096" /MACHINE:ARM
-!ELSEIF  "$(CFG)" == "FaCENOACE - Win32 (WCE x86) Release"
-# PROP Use_MFC 0
-# PROP Output_Dir "X86RelNOACE"
-# PROP Intermediate_Dir "X86RelNOACE"
-RSC=rc.exe
-CPP=cl.exe
-# ADD CPP /nologo /W3 /D "_i386_" /D "i_386_" /D "_X86_" /D "x86" /D "NDEBUG" /D UNDER_CE=$(CEVersion) /D _WIN32_WCE=$(CEVersion) /D "$(CePlatform)" /D "UNICODE" /D "_UNICODE" /D "NO_ACE" /Gs8192 /GF /Oxs /c
-MTL=midl.exe
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 commctrl.lib coredll.lib $(CEx86Corelibc) aygshell.lib /nologo /base:"0x00010000" /stack:0x10000,0x1000 /entry:"WinMainCRTStartup" /nodefaultlib:"OLDNAMES.lib" /nodefaultlib:$(CENoDefaultLib) /subsystem:$(CESubsystem) /MACHINE:IX86
-!ELSEIF  "$(CFG)" == "FaCENOACE - Win32 (WCE x86) Debug"
-# PROP Use_MFC 0
-# PROP Output_Dir "X86DbgNOACE"
-# PROP Intermediate_Dir "X86DbgNOACE"
-RSC=rc.exe
-CPP=cl.exe
-# ADD CPP /nologo /W3 /Zi /Od /D "DEBUG" /D "_i386_" /D "i_386_" /D "_X86_" /D "x86" /D UNDER_CE=$(CEVersion) /D _WIN32_WCE=$(CEVersion) /D "$(CePlatform)" /D "UNICODE" /D "_UNICODE" /D "NO_ACE" /Gs8192 /GF /c
-MTL=midl.exe
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD LINK32 commctrl.lib coredll.lib $(CEx86Corelibc) aygshell.lib /nologo /base:"0x00010000" /stack:0x10000,0x1000 /entry:"WinMainCRTStartup" /debug /nodefaultlib:"OLDNAMES.lib" /nodefaultlib:$(CENoDefaultLib) /subsystem:$(CESubsystem) /MACHINE:IX86
-!ENDIF
-# Begin Target
-# Name "FaCENOACE - Win32 (WCE ARM) Release"
-# Name "FaCENOACE - Win32 (WCE ARM) Debug"
-# Name "FaCENOACE - Win32 (WCE x86) Release"
-# Name "FaCENOACE - Win32 (WCE x86) Debug"
-SOURCE=.\CE_ARGV.CPP
-DEP_CPP_CE_AR=\
-	".\CE_ARGV.H"\
-DEP_CPP_CE_AR=\
-	".\CE_ARGV.H"\
-DEP_CPP_CE_AR=\
-	".\CE_ARGV.H"\
-DEP_CPP_CE_AR=\
-	".\CE_ARGV.H"\
-!ENDIF
-# End Source File
-SOURCE=.\CE_Screen_Output.cpp
-DEP_CPP_CE_SC=\
-DEP_CPP_CE_SC=\
-DEP_CPP_CE_SC=\
-DEP_CPP_CE_SC=\
-!ENDIF
-# End Source File
-SOURCE=.\FaCE.cpp
-DEP_CPP_FACE_=\
-	".\FaCE.h"\
-	".\StdAfx.h"\
-NODEP_CPP_FACE_=\
-	".\ipapi.h"\
-	".\ygshell.h"\
-DEP_CPP_FACE_=\
-	".\FaCE.h"\
-	".\StdAfx.h"\
-NODEP_CPP_FACE_=\
-	".\ipapi.h"\
-	".\ygshell.h"\
-DEP_CPP_FACE_=\
-	".\FaCE.h"\
-	".\StdAfx.h"\
-NODEP_CPP_FACE_=\
-	".\ipapi.h"\
-	".\ygshell.h"\
-DEP_CPP_FACE_=\
-	".\CE_ARGV.H"\
-	".\FaCE.h"\
-!ENDIF
-# End Source File
-SOURCE=.\FaCE.rc
-!ENDIF
-# End Source File
-SOURCE=.\Main.cpp
-DEP_CPP_MAIN_=\
-	".\FaCE.h"\
-DEP_CPP_MAIN_=\
-	".\FaCE.h"\
-NODEP_CPP_MAIN_=\
-DEP_CPP_MAIN_=\
-	".\FaCE.h"\
-DEP_CPP_MAIN_=\
-	".\FaCE.h"\
-!ENDIF
-# End Source File
-# End Group
-SOURCE=.\CE_ARGV.H
-# End Source File
-SOURCE=.\CE_Screen_Output.h
-# End Source File
-SOURCE=.\FaCE.h
-# End Source File
-SOURCE=.\newres.h
-# End Source File
-# End Source File
-# End Group
-# End Source File
-SOURCE=.\FaCE.ico
-# End Source File
-# End Source File
-# End Group
-# End Source File
-# End Source File
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCENOACE.vcw
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCENOACE.vcw	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCENOACE.vcw	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,29 +0,0 @@
-Project: "FaCENOACE"=".\FaCENOACE.vcp" - Package Owner=<4>
-Package=<5>
-Package=<4>
-Global:
-Package=<5>
-Package=<3>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE_OS.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE_OS.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/FaCE_OS.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,38 +0,0 @@
-// -*- C++ -*-
- *  @file    FaCE_OS.h
- *  FaCE_OS.h,v 1.3 2002/04/01 04:48:18 spark Exp
-#ifndef FaCE_OS_h
-#define FaCE_OS_h
-// This definition is for the "int FaCE_MAIN(int, wchar_t**)" using FaCE.
-#     define FaCE_MAIN \
-ace_main_i (int, ACE_TCHAR**); \
-extern BOOL InitInstance (HINSTANCE, int); \
-extern void InitSetup(); \
-int WINAPI WinMain (HINSTANCE hInstance, HINSTANCE hPrevInstance, ACE_TCHAR* lpCmdLine, int nCmdShow) \
-    MSG msg; \
-    HACCEL hAccelTable; \
-    if (!InitInstance (hInstance, nCmdShow)) return FALSE; \
-    hAccelTable = LoadAccelerators(hInstance, (const ACE_TCHAR*)IDC_FACE); \
-    InitSetup(); \
-    while (GetMessage(&msg, NULL, 0, 0)) { \
-        if (!TranslateAccelerator(msg.hwnd, hAccelTable, &msg)) { \
-            TranslateMessage(&msg); \
-            DispatchMessage(&msg); \
-    return msg.wParam; \
-int ace_main_i
-#endif  // FaCE_OS_h
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/License.txt
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/License.txt	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/License.txt	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,27 +0,0 @@
-== Copyright and Licensing Information
-ACE(tm) and TAO(tm) are copyrighted by Dr. Douglas C. Schmidt and the Center for Distributed
-Object Computing ('DOC' group) at Washington University, Copyright (C) 1993 - 2002, all rights
-reserved.  Since ACE and TAO are open source, free software, you are free to use, modify, and
-distribute the ACE and TAO source code and object code produced from the source, as long as
-you include this copyright statement along with code built using ACE and TAO.  Please refer to
-ACE and TAO documentations for detailed copyright and license information on ACE and TAO.
-FaCE is an additional front-end shell package designed for ACE and TAO testing work for Pocket
-PC 2002 platform, created and released by Object Computing, Inc. (OCI) and distributed with ACE
-and TAO under the same licensing terms. You can modify and change the source of FaCE for your
-own use as long as you provide attribution to OCI by including its copyright statement in your
-distributions of source and object code. OCI welcomes submissions of improvements to the FaCE
-code base.
-FaCE is copyrighted by Object Computing, Inc., St. Louis Missouri, Copyright (C) 2002,
-all rights reserved.
-== Warranty Information
-FaCE is provided 'as is' without warranties of any kind.
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/Main.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/Main.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/Main.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,49 +0,0 @@
-// Main.cpp,v 1.3 2002/04/01 04:48:18 spark Exp
-// ** This file is NOT to be used for framework. **
-// This file defines the entry point for Windows CE, which is defined in OS.h for real applications.
-#include "FaCE.h"
-int WINAPI WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance, ACE_TCHAR* lpCmdLine, int nCmdShow)
-    MSG msg;
-    InitSetup();
-#ifdef NO_ACE
-int main_i(int, ACE_TCHAR**)
-    // this function will be replaced by user's main_ce function
-    return 0;
-#else
-    return 0;
-#endif  // NO_ACE
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/ReadMe.txt
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/ReadMe.txt	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/ReadMe.txt	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,287 +0,0 @@
-=== FaCE (Front-end for ACE CE)
-=== Object Computing, Inc.  <http://www.ociweb.com>
-=== St. Louis, Missouri
-=== Copyright (C) 2002.  All rights reserved.
-=== V1.01, March 30th, 2002
-== What's FaCE?
-FaCE is a simple front-end framework for testing and debugging non-Windows
-CE applications on the Pocket PC 2002 platform.  Originally, FaCE was
-developed to test ACE and TAO components internally in Object Computing, Inc.
-However, since it has shown dramatic increase of productivity in a lot
-shorter amount of time, it has been prepared as a package for all programmers
-who want to test and run existing codes (non-WinCE native codes) on Pocket PC
-2002 and WinCE 3.0.
-The features of FaCE are:
-  1. command line parameter support
-  2. command line history support (never type in same command line again)
-  3. output displayed on the windows screen
-  4. output to file (with append and overwrite support)
-  5. does not use MFC
-  6. almost no modification to existing user code
-  7. easy to enable and disable after install
-* Default project files only contain Pocket PC 2002 platform configuration.
-  A new configuration can be added for other WinCE 3.0 platform from eVC.
-== Package Contents
-Files contained in FaCE package are:
- Main Framework Files for both ACE users and non-ACE users
-  - FaCE.h & cpp
-  - FaCE.ico
-  - FaCE.rc
-  - newres.h
-  - resource.h
- ACE entry point definition file
-  - FaCE_OS.h
- Additional Framework files for non-ACE users
-  - CE_ARGV.h & cpp
-  - CE_Screen_Output.h & cpp
- Files for loading skeleton FaCE from eVC
-  - FaCE.vcp & vcw      : FaCE Project files for ACE users
-  - FaCENOACE.vcp & vcw : FaCE Project files for non-ACE users
-  - Main.cpp            : almost empty entry point function
- Misc. Files
-  - ACE.ico         : a bonus icon of ACE logo
-  - License.txt     : license and warranty information
-  - ReadMe.txt      : this document
-== Requirement
- - Microsoft(C) eMbedded Visual Studio/C++ (eVC) 3.0
- - Pocket PC 2002 SDK
- ** For ACE-users only:
- - ACE+TAO installed and configured for WinCE build only for ACE-users
- - ace and ace_os libraries built for WinCE and loaded on machine
-== Important Note
-It has been reported that certain Pocket PC 2002 machines with ARM processor
-can be totally dead and will not even respond to the hard reset.  While the
-real cause of this problem is unknown, HP has released a patch for this
-problem.  We have tested it, and it seems working fine on our machine (HP
-Jornada 568), which is our 5th machine that has been running fine for the
-longest time.
-As this has been identified by hardware manufacturer and can be fixed as HP
-did, Object Computing, Inc. (OCI) or any member of ACE+TAO community cannot
-be responsible for this problem.  If this problem happens during debugging,
-contact your hardware manufacturer for fix or replacement.  It has found
-that almost all Pocket PC 2002 machines regardless of manufacturers have same
-problem.
-Also, Phil Mesnier at OCI has found that virtual function calls under certain
-situation can cause a problem that randomly changes parameter and pointer
-values over function calls.  This is due to the incorrect instructions
-generated by eVC for ARM processor.  So far, no solution or patch has been
-released by compiler vendor, although vendor is aware of this problem.
-Since Pocket PC 2002 is based on WinCE 3.0, ACE+TAO as well as FaCE should
-be able to run on any WinCE 3.0 platform by adding a new configuraion with
-minimal change.
-== Installation & Setup
-1. Create a subdirectory named 'FaCE' (or anything in your taste) under
-   your current project directory.
-2. Copy FaCE_OS.h to the ACE_ROOT/ace directory, and add following line at
-   the end of your ACE_ROOT/ace/config.h file:
-   #include "FaCE_OS.h"
-3. Copy main framework files listed above and add them into "your" project
-   (NOT FaCE.vcw/vcp).  For non-ACE users, copy additional framework files
-   for non-ACE users in addition to the main framework files.
-   It would be a good idea to create a new folder in your project and put
-   all FaCE files into it.  This way, it will be easy to disable FaCE by
-   setting the folder excluded from the build on the folder property option.
-   ** IMPORTANT! **
-   FaCE does NOT use MFC.  Thus, if your project is already set for
-   'Not using MFC', then do not change the setting.
-   * Note: Make sure those files are not shared by multiple executables.
-           Each project must have its own copy of those files.
-           It is a good idea to create a separate folder on your project
-           and put FaCE related files into that folder.  In that case,
-           if you want to disable FaCE and run by using normal 'main',
-           then you can simply set the whole FaCE folder excluded from
-           build in the project setting menu.
-4. Change your 'main()' function part similar to the following example.
-   #ifdef ACE_HAS_WINCE
-   #include "FaCE/FaCE.h"   // use the name of subdirectory you created
-   int FaCE_MAIN (int argc, ACE_TCHAR *argv[])
-   #else
-   int ACE_TMAIN (int argc, ACE_TCHAR *argv[])  // ACE normal entry point
-   #endif
-   Change the directory name for "FaCE/FaCE.h" if necessary.
-   For non-ACE users, use 'UNDER_CE' instead of 'ACE_HAS_WINCE'.
-   == Possible Additional Change
-   Above change will be the only change if your program compiles and links
-   fine under eVC.  It does not mean that your program is WinCE-ready but
-   just means that your program does not include the libraries that are not
-   supported by WinCE, such as iostream.
-   For ACE users, good examples will be the ACE test programs under
-   $ACE_ROOT/test.
-   For non-ACE users, I highly recommend to create a project for WinCE first
-   if it has not already been done and write your code using wmain.
-   Try compile and link your program without FaCE to check your program does
-   not include any libraries not supported by WinCE.  FaCE supports text output
-   by aliasing 'cout' in FaCE.h; however, it is NOT a real iostream but an alias
-   for CE_Screen_Output class.  You may need to use '#ifdef UNDER_CE' for your
-   iostream includes, if you want to share the code among different platforms.
-   Also, it is important to match the parameter types for 'wmain' function.
-   For WinCE, it MUST be in the format of:
-     int FaCE_MAIN (int, wchar_t**)
-   and you can leave your original wmain type as it was for non-CE platform
-   definition.
-5. Go to 'ResourceView' or double-click on the 'FaCE.rc'.  Open 'String Table ->
-   String Table' from the resource browse view, and change the string value (caption)
-   defined for 'IDS_APP_TITLE' from 'FaCE' to your program name.  This will
-   help identifying multiple FaCE-fied applications when you brose them
-   through system memory -> running programs in case of crash.
-6. That's it!
-** Optionally, you can personalize the icons defined for FaCE for your own.
-   To do this easily, load "FaCE.vcw" (requires ACE library) or "FaCENOACE.vcw"
-   from eVC.  Also, FaCENOACE.vcw can be used as 'hello world'-type starting
-   frame-work for non-WinCE programmers.
-** Non-ACE users may see the warning messages saying, "Could not find the file xxx",
-   for ace.h, Log_Msg.h, OS.h, and CE_Screen_Output.h.  This is due to the eVC's
-   not-so-perfect precompilation file checking and totally harmless.
-** Later if you don't want to use FaCE anymore, simply restore your original
-   main function and remove FaCE files from your project (or exclude FaCE files
-   from build).  ACE library does not have to be rebuilt as FaCE_OS.h only
-   contains macro.
-== Running FaCE
-1. Command line option
-User can specify the command line option for the program by using 'Settings ->
-Command Line' from the FaCE menu.  FaCE will automatically save all user-entered
-command line parameters as a ASCII format file named 'Parameters.txt' in the
-root directory of WinCE device/emulator.  User can edit and change by openning
-this file from any text editor and save as a ASCII text file with DOS standard
-CR/LF combo.  This will greatly save time especially when you are working on the
-Pocket PC machine that does not have keyboard.  Remember NOT to convert file
-format to Unicode; it must be standard DOS ASCII text file.
-2. Output Saving
-You can save output to file by selecting 'Tools -> Save To File'.  By default,
-FaCE will not create/save any file.  Also, any output received before setting
-up this feature will not be saved.
-If the file with specified name exists, FaCE will ask whether you want to
-append to the end of file or erase and overwrite.  All output files will be
-saved in the root directory of the system.
-3. Running Your Program
-'Setting -> Run' will execute your program.  Two tags, 'START' and 'END'
-indicate the beginning and end of your code.
-For ACE users, any log message sent to ACE message log (ACE_DEBUG, for example)
-will be displayed on the screen.  Also, if you have setup to save to file,
-the same contents will be saved to the file as well.  Note that the output will
-NOT have ACE internal tags (i.e. Dec 04 14:51:12.000 2001 at LM_DEBUG@) because
-FaCE uses callback message function, and ACE does not pass those tags along
-with the output message.
-For non-ACE users, you can declare your own local copy of CE_Screen_Output
-object.  For example, you can declare CE_Screen_Output object in your cpp file
-like:
-  CE_Screen_Output cout;
-and use it like,
-  int a = 100;
-  wchar_t* strTemp = L"Hello, world!";
-  cout << L"String : " << strTemp << L"a = " << a << endl;
-Remember, CE_Screen_Output is just a simple text output function and does not
-have the full capabilities of iostream, which is not available for WinCE 3.0.
-4. In case of crash
-If you have started your code, but the code crashes, which can be easily
-identified by looking for the 'END' tag, then you can use Windows CE's memory
-program to kill the process (Start -> Settings -> System tag -> Memory ->
-Running Programs tag).  If you have changed IDS_APP_TITLE in the resource
-viewer, then you will see the name you have specified; otherwise, FaCE will be
-listed.  You can select the name and stop the process by clicking 'Stop' button.
-Sometimes, you may need to reset the machine if you cannot access memory program.
-== Note
-- This FaCE framework does not use any MFC; it only uses general Win32
-  API, thus, your project setting does not have to be changed.
-- FaCE is for the 'legacy' Unix/DOS style console applications that
-  do not use any Win32 and MFC for Windows OS.  Programs that are already
-  using native Windows/WinCE API's will not need FaCE framework.
-- If you run your application from FaCE (Settings -> Run), 'START' and
-  'END' will appear at the beginning and end of output messages from your
-  application.  If you see 'END' lable after execution, you can run your
-  program again without exit and start up FaCE again.
-- Make sure to terminate FaCE by selecting 'Settings -> Exit'.  It will
-  completely terminate FaCE session; Clicking on the 'X' button
-  at the top-left corner of the screen will not, just like most WinCE programs.
-- FaCE_MAIN is only for the WinCE port of ACE, ensuring proper windows system
-  message filtering along with proper registraion so that user can see the
-  process from memory setting and task switcher applications.
-- ACE and FaCE do not overrides native WinMain.  If you are developing for
-  Windows OS only, your WinMain should be just safe from any overrides.
-  In this case, of course, you don't need to use FaCE package.
-== Question or Comment
-If you have question and/or comment specific to the FaCE, please contact
-Si Park at spark at ociweb.com or Justin Michel at michel_j at ociweb.com.
-For general ACE+TAO support, please refer to comp.soft-sys.ace or contact
-Object Computing, Inc. at http://www.ociweb.com.
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/newres.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/newres.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/newres.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,43 +0,0 @@
-// newres.h,v 1.1 2002/03/29 19:48:00 spark Exp
-#ifndef __NEWRES_H__
-#define __NEWRES_H__
-#if !defined(UNDER_CE)
-#define UNDER_CE _WIN32_WCE
-#endif
-#if defined(_WIN32_WCE)
-    #if !defined(WCEOLE_ENABLE_DIALOGEX)
-        #define DIALOGEX DIALOG DISCARDABLE
-    #endif
-    #include <commctrl.h>
-    #define  SHMENUBAR RCDATA
-    #if defined(WIN32_PLATFORM_PSPC) && (_WIN32_WCE >= 300)
-        #include <aygshell.h>
-        #define AFXCE_IDR_SCRATCH_SHMENU  28700
-    #else
-        #define I_IMAGENONE     (-2)
-        #define NOMENU          0xFFFF
-        #define IDS_SHNEW       1
-        #define IDM_SHAREDNEW        10
-        #define IDM_SHAREDNEWDEFAULT 11
-    #endif // _WIN32_WCE_PSPC
-    #define AFXCE_IDD_SAVEMODIFIEDDLG 28701
-#endif // _WIN32_WCE
-#ifdef RC_INVOKED
-#ifndef _INC_WINDOWS
-#define _INC_WINDOWS
-    #include "winuser.h"           // extract from windows header
-    #include "winver.h"
-#endif
-#endif
-#ifdef IDC_STATIC
-#undef IDC_STATIC
-#endif
-#define IDC_STATIC      (-1)
-#endif //__NEWRES_H__
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/resource.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/resource.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/FaCE/resource.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,45 +0,0 @@
-// resource.h,v 1.1 2002/03/29 19:48:00 spark Exp
-//{{NO_DEPENDENCIES}}
-// Microsoft Developer Studio generated include file.
-// Used by FaCE.rc
-#define IDS_APP_TITLE                   1
-#define IDC_FACE                        3
-#define IDI_FACE                        101
-#define IDM_MENU                        102
-#define IDD_ABOUTBOX                    103
-#define IDS_HELP                        104
-#define IDD_CMDLINE                     104
-#define IDD_OUTFILE                     105
-#define IDD_ERRFILE                     107
-#define IDD_FILEEXIST                   109
-#define IDB_ACERACER                    113
-#define IDB_TAO                         114
-#define IDS_COMMAND1                    301
-#define IDC_CMDEDIT                     1001
-#define IDC_SAVEFILE                    1002
-#define IDC_ERRFILE                     1003
-#define IDOVERWRITE                     1004
-#define IDC_APPEND                      1005
-#define IDC_COPYRIGHT                   1007
-#define IDC_TAO                         1008
-#define IDM_MAIN_COMMAND1               40001
-#define IDM_HELP_ABOUT                  40003
-#define ID_SETTING                      40004
-#define IDS_CAP_SETTING                 40006
-#define ID_SETTING_COMMANDLINE          40007
-#define ID_SETTING_RUN                  40008
-#define ID_SETTING_EXIT                 40011
-#define ID_TOOLS_SAVETOFILE             40012
-// Next default values for new objects
-#ifndef APSTUDIO_READONLY_SYMBOLS
-#define _APS_NEXT_RESOURCE_VALUE        116
-#define _APS_NEXT_COMMAND_VALUE         40013
-#define _APS_NEXT_CONTROL_VALUE         1009
-#define _APS_NEXT_SYMED_VALUE           101
-#endif
-#endif
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Concrete_Connection_Handlers.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Concrete_Connection_Handlers.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Concrete_Connection_Handlers.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,802 +0,0 @@
-// Concrete_Connection_Handlers.cpp,v 4.17 2002/03/04 20:36:21 schmidt Exp
-#define ACE_BUILD_SVC_DLL
-#include "Event_Channel.h"
-#include "Concrete_Connection_Handlers.h"
-ACE_RCSID(Gateway, Concrete_Connection_Handlers, "Concrete_Connection_Handlers.cpp,v 4.17 2002/03/04 20:36:21 schmidt Exp")
-Consumer_Handler::Consumer_Handler (const Connection_Config_Info &pci)
-  : Connection_Handler (pci)
-  this->connection_role_ = 'C';
-  this->msg_queue ()->high_water_mark (Options::instance ()->max_queue_size ());
-// This method should be called only when the Consumer shuts down
-// unexpectedly.  This method simply marks the Connection_Handler as
-// having failed so that handle_close () can reconnect.
-// Do not close handler when received data successfully.
-// Consumer_Handler should could process received data.
-// For example, Consumer could send reply-event to Supplier.
-int
-Consumer_Handler::handle_input (ACE_HANDLE)
-  // Do not set FAILED state at here, just at real failed place.
-  char buf[BUFSIZ];
-  ssize_t received = this->peer ().recv (buf, sizeof buf);
-  switch (received)
-    case -1:
-      this->state (Connection_Handler::FAILED);
-      ACE_ERROR_RETURN ((LM_ERROR,
-                        "(%t) Peer has failed unexpectedly for Consumer_Handler %d\n",
-                        this->connection_id ()),
-                        -1);
-      /* NOTREACHED */
-    case 0:
-                        "(%t) Peer has shutdown unexpectedly for Consumer_Handler %d\n",
-                        -1);
-      /* NOTREACHED */
-    default:
-                        "(%t) IGNORED: Consumer is erroneously sending input to Consumer_Handler %d\n"
-                        "data size = %d\n",
-                        this->connection_id (),
-                        received),
-                        0); // Return 0 to identify received data successfully.
-      /* NOTREACHED */
-// Perform a non-blocking put() of event.  If we are unable to send
-// the entire event the remainder is re-queued at the *front* of the
-// Event_List.
-int
-Consumer_Handler::nonblk_put (ACE_Message_Block *event)
-  // Try to send the event.  If we don't send it all (e.g., due to
-  // flow control), then re-queue the remainder at the head of the
-  // Event_List and ask the ACE_Reactor to inform us (via
-  // handle_output()) when it is possible to try again.
-  ssize_t n = this->send (event);
-  if (n == -1)
-      // -1 is returned only when things have really gone wrong (i.e.,
-      // not when flow control occurs).  Thus, let's try to close down
-      // and set up a new reconnection by calling handle_close().
-      this->handle_close ();
-      return -1;
-  else if (errno == EWOULDBLOCK)
-      // We didn't manage to send everything, so we need to queue
-      // things up.
-      ACE_DEBUG ((LM_DEBUG,
-                  "(%t) queueing activated on handle %d to routing id %d\n",
-                  this->get_handle (),
-                  this->connection_id ()));
-      // ACE_Queue in *front* of the list to preserve order.
-      if (this->msg_queue ()->enqueue_head
-          (event, (ACE_Time_Value *) &ACE_Time_Value::zero) == -1)
-                           "(%t) %p\n",
-                           "enqueue_head"),
-                          -1);
-      // Tell ACE_Reactor to call us back when we can send again.
-      else if (ACE_Reactor::instance ()->schedule_wakeup
-               (this, ACE_Event_Handler::WRITE_MASK) == -1)
-                           "(%t) %p\n",
-                           "schedule_wakeup"),
-                          -1);
-      return 0;
-  else
-    return n;
-ssize_t
-Consumer_Handler::send (ACE_Message_Block *event)
-              "(%t) sending %d bytes to Consumer %d\n",
-              event->length (),
-  ssize_t len = event->length ();
-  ssize_t n = this->peer ().send (event->rd_ptr (), len);
-  if (n <= 0)
-    return errno == EWOULDBLOCK ? 0 : n;
-  else if (n < len)
-      // Re-adjust pointer to skip over the part we did send.
-      event->rd_ptr (n);
-      errno = EWOULDBLOCK;
-  else // if (n == length)
-      // The whole event is sent, we now decrement the reference count
-      // (which deletes itself with it reaches 0).
-      event->release ();
-      errno = 0;
-  this->total_bytes (n);
-  return n;
-// Finish sending an event when flow control conditions abate.
-// This method is automatically called by the ACE_Reactor.
-int
-Consumer_Handler::handle_output (ACE_HANDLE)
-  ACE_Message_Block *event = 0;
-              ACE_TEXT("(%t) Receiver signalled 'resume transmission' %d\n"),
-              this->get_handle ()));
-  // WIN32 Notes: When the receiver blocked, we started adding to the
-  // consumer handler's message Q. At this time, we registered a
-  // callback with the reactor to tell us when the TCP layer signalled
-  // that we could continue to send messages to the consumer. However,
-  // Winsock only sends this notification ONCE, so we have to assume
-  // at the application level, that we can continue to send until we
-  // get any subsequent blocking signals from the receiver's buffer.
-#if defined (ACE_WIN32)
-  // Win32 Winsock doesn't trigger multiple "You can write now"
-  // signals, so we have to assume that we can continue to write until
-  // we get another EWOULDBLOCK.
-  // We cancel the wakeup callback we set earlier.
-  if (ACE_Reactor::instance ()->cancel_wakeup
-                       ACE_TEXT ("(%t) %p\n"),
-                       ACE_TEXT ("Error in ACE_Reactor::cancel_wakeup()")),
-                      -1);
-  // The list had better not be empty, otherwise there's a bug!
-  while (this->msg_queue ()->dequeue_head
-         (event, (ACE_Time_Value *) &ACE_Time_Value::zero) != -1)
-      switch (this->nonblk_put (event))
-        case -1:                // Error sending message to consumer.
-            // We are responsible for releasing an ACE_Message_Block if
-            // failures occur.
-            ACE_ERROR ((LM_ERROR,
-                        ACE_TEXT ("transmission failure")));
-            break;
-        case 0:                 // Partial Send - we got flow controlled by the receiver
-            ACE_ASSERT (errno == EWOULDBLOCK);
-                        ACE_TEXT ("%D Partial Send due to flow control")
-                        ACE_TEXT ("- scheduling new wakeup with reactor\n")));
-            // Re-schedule a wakeup call from the reactor when the
-            // flow control conditions abate.
-            if (ACE_Reactor::instance ()->schedule_wakeup
-                (this,
-                 ACE_Event_Handler::WRITE_MASK) == -1)
-                                 ACE_TEXT ("Error in ACE_Reactor::schedule_wakeup()")),
-                                -1);
-            // Didn't write everything this time, come back later...
-            return 0;
-        default:                // Sent the whole thing
-                        ACE_TEXT ("Sent message from message Q, Q size = %d\n"),
-                        this->msg_queue()->message_count ()));
-            break;
-  // If we drop out of the while loop, then the message Q should be
-  // empty...or there's a problem in the dequeue_head() call...but
-  // thats another story.
-              ACE_TEXT ("%D Sent all messages from consumers message Q\n")));
-              ACE_TEXT ("(%t) queueing deactivated on handle %d to routing id %d\n"),
-#else /* !defined (ACE_WIN32) */
-  if (this->msg_queue ()->dequeue_head
-        case 0:           // Partial send.
-                      ACE_TEXT ("%D Partial Send\n")));
-          break;
-        case -1:
-          /* FALLTHROUGH */
-        default: // Sent the whole thing.
-          // If we succeed in writing the entire event (or we did not
-          // fail due to EWOULDBLOCK) then check if there are more
-          // events on the Message_Queue.  If there aren't, tell the
-          // ACE_Reactor not to notify us anymore (at least until
-          // there are new events queued up).
-                      ACE_TEXT ("QQQ::Sent Message from consumer's Q\n")));
-          if (this->msg_queue ()->is_empty ())
-                            ACE_TEXT ("cancel_wakeup")));
-  else
-                ACE_TEXT ("dequeue_head - handle_output called by reactor but nothing in Q")));
-#endif /* ACE_WIN32 */
-  return 0;
-// Send an event to a Consumer (may queue if necessary).
-int
-Consumer_Handler::put (ACE_Message_Block *event,
-                       ACE_Time_Value *)
-    // Try to send the event *without* blocking!
-    return this->nonblk_put (event);
-  else
-    // If we have queued up events due to flow control then just
-    // enqueue and return.
-    return this->msg_queue ()->enqueue_tail
-      (event, (ACE_Time_Value *) &ACE_Time_Value::zero);
-Supplier_Handler::Supplier_Handler (const Connection_Config_Info &pci)
-  : Connection_Handler (pci),
-    msg_frag_ (0)
-  this->connection_role_ = 'S';
-  this->msg_queue ()->high_water_mark (0);
-// Receive an Event from a Supplier.  Handles fragmentation.
-// The event returned from recv consists of two parts:
-// 1. The Address part, contains the "virtual" routing id.
-// 2. The Data part, which contains the actual data to be forwarded.
-// The reason for having two parts is to shield the higher layers
-// of software from knowledge of the event structure.
-int
-Supplier_Handler::recv (ACE_Message_Block *&forward_addr)
-  if (this->msg_frag_ == 0)
-    // No existing fragment...
-    ACE_NEW_RETURN (this->msg_frag_,
-                    ACE_Message_Block (sizeof (Event),
-                                       ACE_Message_Block::MB_DATA,
-                                       0,
-                                       0,
-                                       0,
-                                       Options::instance ()->locking_strategy ()),
-                    -1);
-  Event *event = (Event *) this->msg_frag_->rd_ptr ();
-  ssize_t header_received = 0;
-  const size_t HEADER_SIZE = sizeof (Event_Header);
-  ssize_t header_bytes_left_to_read =
-    HEADER_SIZE - this->msg_frag_->length ();
-  if (header_bytes_left_to_read > 0)
-      header_received = this->peer ().recv
-        (this->msg_frag_->wr_ptr (), header_bytes_left_to_read);
-      if (header_received == -1 /* error */
-          || header_received == 0  /* EOF */)
-          ACE_ERROR ((LM_ERROR, "%p\n",
-                      "Recv error during header read "));
-                      "attempted to read %d\n",
-                      header_bytes_left_to_read));
-          this->msg_frag_ = this->msg_frag_->release ();
-          return header_received;
-      // Bump the write pointer by the amount read.
-      this->msg_frag_->wr_ptr (header_received);
-      // At this point we may or may not have the ENTIRE header.
-      if (this->msg_frag_->length () < HEADER_SIZE)
-                      "Partial header received: only %d bytes\n",
-                     this->msg_frag_->length ()));
-          // Notify the caller that we didn't get an entire event.
-          return -1;
-      // Convert the header into host byte order so that we can access
-      // it directly without having to repeatedly muck with it...
-      event->header_.decode ();
-      if (event->header_.len_ > ACE_INT32 (sizeof event->data_))
-          // This data_ payload is too big!
-          errno = EINVAL;
-                      "Data payload is too big (%d bytes)\n",
-                      event->header_.len_));
-          return -1;
-  // At this point there is a complete, valid header in Event.  Now we
-  // need to get the event payload.  Due to incomplete reads this may
-  // not be the first time we've read in a fragment for this message.
-  // We account for this here.  Note that the first time in here
-  // msg_frag_->wr_ptr() will point to event->data_.  Every time we do
-  // a successful fragment read, we advance wr_ptr().  Therefore, by
-  // subtracting how much we've already read from the
-  // event->header_.len_ we complete the data_bytes_left_to_read...
-  ssize_t data_bytes_left_to_read =
-    ssize_t (event->header_.len_ - (msg_frag_->wr_ptr () - event->data_));
-  ssize_t data_received =
-    !data_bytes_left_to_read
-    ? 0 // peer().recv() should not be called when data_bytes_left_to_read is 0.
-    : this->peer ().recv (this->msg_frag_->wr_ptr (), data_bytes_left_to_read);
-  // Try to receive the remainder of the event.
-  switch (data_received)
-    case -1:
-      if (errno == EWOULDBLOCK)
-        // This might happen if only the header came through.
-        return -1;
-      else
-        /* FALLTHROUGH */;
-    case 0: // Premature EOF.
-      if (data_bytes_left_to_read)
-          return 0;
-    default:
-      // Set the write pointer at 1 past the end of the event.
-      this->msg_frag_->wr_ptr (data_received);
-      if (data_received != data_bytes_left_to_read)
-          // Inform caller that we didn't get the whole event.
-          return -1;
-      else
-          // Set the read pointer to the beginning of the event.
-          this->msg_frag_->rd_ptr (this->msg_frag_->base ());
-          // Allocate an event forwarding header and chain the data
-          // portion onto its continuation field.
-          forward_addr = new ACE_Message_Block (sizeof (Event_Key),
-                                                ACE_Message_Block::MB_PROTO,
-                                                this->msg_frag_,
-                                                0,
-                                                0,
-                                                Options::instance ()->locking_strategy ());
-          if (forward_addr == 0)
-              errno = ENOMEM;
-              return -1;
-          Event_Key event_addr (this->connection_id (),
-                                event->header_.type_);
-          // Copy the forwarding address from the Event_Key into
-          // forward_addr.
-          forward_addr->copy ((char *) &event_addr, sizeof (Event_Key));
-          // Reset the pointer to indicate we've got an entire event.
-          this->msg_frag_ = 0;
-      this->total_bytes (data_received + header_received);
-                  "(%t) connection id = %d, cur len = %d, total bytes read = %d\n",
-                  event->header_.connection_id_,
-                  event->header_.len_,
-                  data_received + header_received));
-      if (Options::instance ()->enabled (Options::VERBOSE))
-                    "data_ = %*s\n",
-                    event->header_.len_ - 2,
-                    event->data_));
-      // Encode before returning so that we can set things out in
-      // network byte order.
-      event->header_.encode ();
-      return data_received + header_received;
-// Receive various types of input (e.g., Peer event from the gatewayd,
-// as well as stdio).
-int
-Supplier_Handler::handle_input (ACE_HANDLE)
-  ACE_Message_Block *event_key = 0;
-  switch (this->recv (event_key))
-    case 0:
-      // Note that a peer shouldn't initiate a shutdown by closing the
-      // connection.  Therefore, the peer must have crashed, so we'll
-      // need to bail out here and let the higher layers reconnect.
-                        "(%t) Peer has closed down unexpectedly for Input Connection_Handler %d\n",
-                        -1);
-      /* NOTREACHED */
-    case -1:
-        // A short-read, we'll come back and finish it up later on!
-        return 0;
-      else // A weird problem occurred, shut down and start again.
-          ACE_ERROR_RETURN ((LM_ERROR, "(%t) %p for Input Connection_Handler %d\n",
-                             "Peer has failed unexpectedly",
-                            -1);
-      /* NOTREACHED */
-    default:
-      // Route messages to Consumers.
-      return this->process (event_key);
-// This delegates to the <Event_Channel> to do the actual processing.
-// Typically, this forwards the event to its appropriate Consumer(s).
-int
-Supplier_Handler::process (ACE_Message_Block *event_key)
-  return this->event_channel_->put (event_key);
-Thr_Consumer_Handler::Thr_Consumer_Handler (const Connection_Config_Info &pci)
-  : Consumer_Handler (pci)
-  // It is not in thread svc() now.
-  in_thread_ = 0;
-// Overriding handle_close() method.  If in thread svc(), no need to
-// process handle_close() when call peer().close(), because the
-// connection is blocked now.
-int
-Thr_Consumer_Handler::handle_close (ACE_HANDLE h, ACE_Reactor_Mask m)
-  if (in_thread_)
-    return 0;
-  else
-    return Consumer_Handler::handle_close (h, m);
-// unexpectedly.  This method marks the Connection_Handler as having
-// failed and deactivates the ACE_Message_Queue (to wake up the thread
-// blocked on <dequeue_head> in svc()).
-// Thr_Consumer_Handler::handle_close () will eventually try to
-// reconnect...
-// Let Consumer_Handler receive normal data.
-int
-Thr_Consumer_Handler::handle_input (ACE_HANDLE h)
-  // Call down to the <Consumer_Handler> to handle this first.
-  if (this->Consumer_Handler::handle_input (h) != 0)
-      // Only do such work when failed.
-      ACE_Reactor::instance ()->remove_handler
-        (h, ACE_Event_Handler::ALL_EVENTS_MASK | ACE_Event_Handler::DONT_CALL);
-      // Deactivate the queue while we try to get reconnected.
-      this->msg_queue ()->deactivate ();
-      // Will call handle_close.
-      return -1;
-  return 0;
-// Initialize the threaded Consumer_Handler object and spawn a new
-// thread.
-int
-Thr_Consumer_Handler::open (void *)
-  // Turn off non-blocking I/O.
-  if (this->peer ().disable (ACE_NONBLOCK) == -1)
-                       "(%t) %p\n",
-                       "disable"),
-                      -1); // Incorrect info fixed.
-  // Call back to the <Event_Channel> to complete our initialization.
-  else if (this->event_channel_->complete_connection_connection (this) == -1)
-                       "(%t) %p\n",
-                       "complete_connection_connection"),
-                      -1);
-  // Register ourselves to receive input events (which indicate that
-  // the Consumer has shut down unexpectedly).
-  else if (ACE_Reactor::instance ()->register_handler
-      (this, ACE_Event_Handler::READ_MASK) == -1)
-                       "(%t) %p\n",
-                       "register_handler"),
-                      -1);
-  // Reactivate message queue.  If it was active then this is the
-  // first time in and we need to spawn a thread, otherwise the queue
-  // was inactive due to some problem and we've already got a thread.
-  else if (this->msg_queue ()->activate () == ACE_Message_Queue<ACE_SYNCH>::WAS_ACTIVE)
-                  "(%t) spawning new thread\n"));
-      // Become an active object by spawning a new thread to transmit
-      // events to Consumers.
-      return this->activate (THR_NEW_LWP | THR_DETACHED);
-  else
-                  "(%t) reusing existing thread\n"));
-      return 0;
-// Queue up an event for transmission (must not block since
-// Supplier_Handlers may be single-threaded).
-int
-Thr_Consumer_Handler::put (ACE_Message_Block *mb, ACE_Time_Value *)
-  // Perform non-blocking enqueue, i.e., if <msg_queue> is full
-  // *don't* block!
-    (mb, (ACE_Time_Value *) &ACE_Time_Value::zero);
-// Transmit events to the peer.  Note the simplification resulting
-// from the use of threads, compared with the Reactive solution.
-int
-Thr_Consumer_Handler::svc (void)
-  for (in_thread_ = 1;;)
-                  "(%t) Thr_Consumer_Handler's handle = %d\n",
-                  this->peer ().get_handle ()));
-      // Since this method runs in its own thread it is OK to block on
-      // output.
-      for (ACE_Message_Block *mb = 0;
-           this->msg_queue ()->dequeue_head (mb) != -1;
-        if (this->send (mb) == -1)
-                      "(%t) %p\n",
-                      "send failed"));
-      ACE_ASSERT (errno == ESHUTDOWN);
-                  "(%t) shutting down threaded Consumer_Handler %d on handle %d\n",
-      this->peer ().close ();
-      // Re-establish the connection, using exponential backoff.
-      for (this->timeout (1);
-           // Default is to reconnect synchronously.
-           this->event_channel_->initiate_connection_connection (this, 1) == -1;
-           // Second parameter '1' means using sync mode directly,
-           // don't care Options::blocking_semantics().  If don't do
-           // so, async mode will be used to connect which won't
-           // satisfy original design.
-          ACE_Time_Value tv (this->timeout ());
-                      "(%t) reattempting connection, sec = %d\n",
-                      tv.sec ()));
-          ACE_OS::sleep (tv);
-  ACE_NOTREACHED (return 0;)
-Thr_Supplier_Handler::Thr_Supplier_Handler (const Connection_Config_Info &pci)
-  : Supplier_Handler (pci)
-  in_thread_ = 0;
-int
-Thr_Supplier_Handler::handle_close (ACE_HANDLE h, ACE_Reactor_Mask m)
-  if (in_thread_)
-    return 0;
-  else
-    return Supplier_Handler::handle_close (h, m);
-int
-Thr_Supplier_Handler::open (void *)
-                       "(%t) %p\n",
-                       "disable"),
-                       "(%t) %p\n",
-                      -1);
-      // events to peers.
-  else
-      ACE_DEBUG ((LM_DEBUG, "(%t) reusing existing thread\n"));
-      return 0;
-// Receive events from a Peer in a separate thread (note reuse of
-// existing code!).
-int
-Thr_Supplier_Handler::svc (void)
-                  "(%t) Thr_Supplier_Handler's handle = %d\n",
-      // Since this method runs in its own thread and processes events
-      // for one connection it is OK to call down to the
-      // <Supplier_Handler::handle_input> method, which blocks on
-      // input.
-      while (this->Supplier_Handler::handle_input () != -1)
-        continue;
-                  "(%t) shutting down threaded Supplier_Handler %d on handle %d\n",
-      // Re-establish the connection, using expoential backoff.
-                      tv.sec ()));
-  ACE_NOTREACHED(return 0);
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Concrete_Connection_Handlers.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Concrete_Connection_Handlers.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Concrete_Connection_Handlers.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,151 +0,0 @@
-/* -*- C++ -*- */
-// Concrete_Connection_Handlers.h,v 4.5 2001/03/21 11:59:40 schmidt Exp
-// = LIBRARY
-//    gateway
-// = FILENAME
-// = DESCRIPTION
-//    These are all the subclasses of Connection_Handler that define the
-//    appropriate threaded/reactive Consumer/Supplier behavior.
-// = AUTHOR
-//    Doug Schmidt <schmidt at cs.wustl.edu>
-#ifndef CONCRETE_CONNECTION_HANDLER
-#define CONCRETE_CONNECTION_HANDLER
-#include "Connection_Handler.h"
-class Supplier_Handler : public Connection_Handler
-  // = TITLE
-  //     Handles reception of Events from Suppliers.
-  // = DESCRIPTION
-  //     Performs framing and error checking on Events.  Intended to
-  //     run reactively, i.e., in one thread of control using a
-  //     Reactor for demuxing and dispatching.
-public:
-  // = Initialization method.
-  Supplier_Handler (const Connection_Config_Info &);
-protected:
-  // = All the following methods are upcalls, so they can be protected.
-  virtual int handle_input (ACE_HANDLE = ACE_INVALID_HANDLE);
-  // Receive and process peer events.
-  virtual int recv (ACE_Message_Block *&);
-  // Receive an event from a Supplier.
-  int process (ACE_Message_Block *event);
-  // This delegates to the <Event_Channel> to do the actual
-  // processing.  Typically, it forwards the <event> to its
-  // appropriate Consumer.
-  ACE_Message_Block *msg_frag_;
-  // Keep track of event fragment to handle non-blocking recv's from
-  // Suppliers.
-class Consumer_Handler : public Connection_Handler
-  // = TITLE
-  //     Handles transmission of events to Consumers.
-  // = DESCRIPTION
-  //     Performs queueing and error checking.  Intended to run
-  //     reactively, i.e., in one thread of control using a Reactor
-  //     for demuxing and dispatching.  Also uses a Reactor to handle
-  //     flow controlled output connections.
-public:
-  Consumer_Handler (const Connection_Config_Info &);
-  virtual int put (ACE_Message_Block *event,
-                   ACE_Time_Value * = 0);
-  // Send an event to a Consumer (may be queued if necessary).
-protected:
-  virtual int handle_output (ACE_HANDLE);
-  // Finish sending event when flow control conditions abate.
-  int nonblk_put (ACE_Message_Block *mb);
-  // Perform a non-blocking put().
-  virtual ssize_t send (ACE_Message_Block *);
-  // Send an event to a Consumer.
-  virtual int handle_input (ACE_HANDLE);
-  // Receive and process shutdowns from a Consumer.
-class Thr_Consumer_Handler : public Consumer_Handler
-  // = TITLE
-  //    Runs each <Consumer_Handler> in a separate thread.
-public:
-  Thr_Consumer_Handler (const Connection_Config_Info &);
-  virtual int open (void *);
-  // Initialize the threaded Consumer_Handler object and spawn a new
-  // thread.
-  virtual int put (ACE_Message_Block *, ACE_Time_Value * = 0);
-  // Send a message to a peer.
-protected:
-  // Called when Peer shutdown unexpectedly.
-  virtual int svc (void);
-  // Transmit peer messages.
-  virtual int handle_close (ACE_HANDLE = ACE_INVALID_HANDLE,
-                            ACE_Reactor_Mask = ACE_Event_Handler::ALL_EVENTS_MASK);
-  // When thread started, connection become blocked, so no need to use
-  // handle_close to reinitiate the connection_handler, so should
-  // override this function to justify if controlling is in thread or
-  // not. If yes, handle_close do nothing, otherwise, it call parent
-  // handle_close().
-private:
-  int in_thread_;
-  // If the controlling is in thread's svc() or not.
-class Thr_Supplier_Handler : public Supplier_Handler
-  // = TITLE
-  //    Runs each <Supplier_Handler> in a separate thread.
-public:
-  Thr_Supplier_Handler (const Connection_Config_Info &pci);
-  // Initialize the object and spawn a new thread.
-protected:
-private:
-  int in_thread_;
-#endif /* CONCRETE_CONNECTION_HANDLER */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Config_Files.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Config_Files.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Config_Files.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,222 +0,0 @@
-// Config_Files.cpp,v 4.14 2003/12/24 12:49:28 jwillemsen Exp
-#include "Config_Files.h"
-#include "Options.h"
-ACE_RCSID(Gateway, Config_Files, "Config_Files.cpp,v 4.14 2003/12/24 12:49:28 jwillemsen Exp")
-// This fixes a nasty bug with cfront-based compilers (like
-// Centerline).
-typedef FP::Return_Type FP_RETURN_TYPE;
-FP_RETURN_TYPE
-Consumer_Config_File_Parser::read_entry (Consumer_Config_Info &entry,
-                                         int &line_number)
-  FP_RETURN_TYPE result;
-  // Increment the line count.
-  line_number++;
-  // Ignore comments, check for EOF and EOLINE if this succeeds, we
-  // have our connection id.
-  while ((result = this->getint (entry.connection_id_)) != FP::RT_SUCCESS)
-    if (result == FP::RT_EOFILE)
-      return FP::RT_EOFILE;
-    else if (result == FP::RT_EOLINE
-             || result == FP::RT_COMMENT)
-      line_number++;
-  // Get the payload type.
-  result = this->getint (entry.type_);
-  if (result != FP::RT_SUCCESS)
-    return result;
-  // get all the consumers.
-  entry.total_consumers_ = 0;
-          (entry.consumers_[entry.total_consumers_])) == FP::RT_SUCCESS)
-    ++entry.total_consumers_; // do nothing (should check against max...)
-  if (result == FP::RT_EOLINE || result == FP::RT_EOFILE)
-    return FP::RT_SUCCESS;
-  else
-    return result;
-FP_RETURN_TYPE
-Connection_Config_File_Parser::read_entry (Connection_Config_Info &entry,
-                                           int &line_number)
-  char buf[BUFSIZ];
-  line_number++;
-      line_number++;
-  // Get the hostname.
-  result = this->getword (entry.host_);
-    return result;
-  ACE_INT32 port;
-  // Get the port number.
-  result = this->getint (port);
-  if (result == FP::RT_DEFAULT)
-      // Get the proxy role, i.e., 'C' (Consumer) or 'S' (Supplier).
-      result = this->getword (buf);
-        return result;
-      else
-        entry.connection_role_ = buf[0];
-      if (entry.connection_role_ == 'C')
-        entry.remote_port_ = Options::instance ()->consumer_connector_port ();
-      else if (entry.connection_role_ == 'S')
-        entry.remote_port_ = Options::instance ()->supplier_connector_port ();
-      else
-        // Yikes, this is a *weird* error!
-        entry.remote_port_ = 0;
-  else if (result != FP::RT_SUCCESS)
-    return result;
-  else
-      entry.remote_port_ = (unsigned short) port;
-        return result;
-      else
-  // Get the max retry delay.
-  result = this->getint (entry.max_retry_timeout_);
-    entry.max_retry_timeout_ = Options::instance ()->max_timeout ();
-    return result;
-  // Get the local port number.
-    entry.local_port_ = 0; // @@ Should make this an option.
-    return result;
-  else
-    entry.local_port_ = (unsigned short) port;
-  ACE_INT32 priority;
-  // Get the priority.
-  result = this->getint (priority);
-    return result;
-  else
-    entry.priority_ = priority;
-#if defined (DEBUGGING)
-int
-main (int argc, char *argv[])
-  int line_number = 0;
-    Connection_Config_Info entry;
-    Connection_Config_File_Parser connection_config_file;
-    connection_config_file.open (argc > 1 ? argv[1] : "connection_config");
-                "ConnID\tHost\t\tRPort\tRole\tRetry\tLPort\tPriority\n"));
-    // Read config file line at a time.
-    while ((result = connection_config_file.read_entry (entry, line_number)) != FP::RT_EOFILE)
-      if (result == FP::RT_PARSE_ERROR)
-                    "Error line %d.\n",
-                    line_number));
-      else
-                    "%d\t%s\t%d\t%c\t%d\t%d\t%d\n",
-                    entry.connection_id_,
-                    entry.host_,
-                    entry.remote_port_,
-                    entry.connection_role_,
-                    entry.max_retry_timeout_,
-                    entry.local_port_,
-                    entry.priority_));
-    connection_config_file.close ();
-    Consumer_Config_Info entry;
-    Consumer_Config_File_Parser consumer_config_file;
-    consumer_config_file.open (argc > 2 ? argv[2] : "consumer_config");
-    line_number = 0;
-                "\nConnID\tLogic\tPayload\tDestinations\n"));
-    while ((result = consumer_config_file.read_entry (entry, line_number)) != FP::RT_EOFILE)
-                    line_number));
-      else
-                      "%d\t%d\t",
-                      entry.type_));
-          while (--entry.total_consumers_ >= 0)
-                        "%d,",
-                        entry.consumers_[entry.total_consumers_]));
-                      "\n"));
-    consumer_config_file.close ();
-  return 0;
-#endif /* DEBUGGING */
-#if defined (ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION)
-template class File_Parser<Connection_Config_Info>;
-template class File_Parser<Consumer_Config_Info>;
-#elif defined (ACE_HAS_TEMPLATE_INSTANTIATION_PRAGMA)
-#pragma instantiate File_Parser<Connection_Config_Info>
-#pragma instantiate File_Parser<Consumer_Config_Info>
-#endif /* ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Config_Files.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Config_Files.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Config_Files.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,98 +0,0 @@
-/* -*- C++ -*- */
-// Config_Files.h,v 4.10 1998/10/20 02:34:17 levine Exp
-// = LIBRARY
-//    gateway
-// = FILENAME
-//    Config_Files.h
-// = AUTHOR
-//    Doug Schmidt
-#ifndef _CONFIG_FILES
-#define _CONFIG_FILES
-#include "File_Parser.h"
-#include "Event.h"
-// Forward declaration.
-class Event_Channel;
-class Connection_Config_Info
-  // = TITLE
-  //     Stores connection configuration information.
-public:
-  ACE_INT32 connection_id_;
-  // Connection id for this Connection_Handler.
-  char host_[BUFSIZ];
-  // Host to connect with.
-  u_short remote_port_;
-  // Port to connect with.
-  char connection_role_;
-  // 'S' (supplier) or 'C' (consumer).
-  ACE_INT32 max_retry_timeout_;
-  // Maximum amount of time to wait for reconnecting.
-  u_short local_port_;
-  // Our local port number.
-  ACE_INT32 priority_;
-  // Priority by which different Consumers and Suppliers should be
-  // serviced.
-  Event_Channel *event_channel_;
-  // We just need a place to store this until we can pass it along
-  // when creating a Connection_Handler.
-class Connection_Config_File_Parser : public File_Parser<Connection_Config_Info>
-  // = TITLE
-  //     Parser for the Connection_Handler Connection file.
-public:
-  virtual FP::Return_Type read_entry (Connection_Config_Info &entry,
-                                      int &line_number);
-  // Read in a <Connection_Config_Info> entry.
-class Consumer_Config_Info
-  // = TITLE
-  //     Stores the information in a Consumer Map entry.
-public:
-  // Connection id.
-  ACE_INT32 type_;
-  // Message type.
-  ACE_INT32 consumers_[MAX_CONSUMERS];
-  // Connection ids for consumers that will be routed information
-  // containing this <connection_id_>
-  ACE_INT32 total_consumers_;
-  // Total number of these consumers.
-class Consumer_Config_File_Parser : public File_Parser<Consumer_Config_Info>
-  // = TITLE
-  //     Parser for the Consumer Map file.
-public:
-  virtual FP::Return_Type read_entry (Consumer_Config_Info &entry,
-  // Read in a <Consumer_Config_Info> entry.
-#endif /* _CONFIG_FILES */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,289 +0,0 @@
-// Connection_Handler.cpp,v 4.5 1998/07/31 23:36:42 gonzo Exp
-ACE_RCSID(Gateway, Connection_Handler, "Connection_Handler.cpp,v 4.5 1998/07/31 23:36:42 gonzo Exp")
-Event_Channel *
-Connection_Handler::event_channel (void) const
-  return this->event_channel_;
-void
-Connection_Handler::event_channel (Event_Channel *ec)
-  this->event_channel_ = ec;
-void
-Connection_Handler::connection_id (CONNECTION_ID id)
-  this->connection_id_ = id;
-CONNECTION_ID
-Connection_Handler::connection_id (void) const
-  return this->connection_id_;
-// The total number of bytes sent/received on this Proxy.
-size_t
-Connection_Handler::total_bytes (void) const
-  return this->total_bytes_;
-void
-Connection_Handler::total_bytes (size_t bytes)
-  this->total_bytes_ += bytes;
-Connection_Handler::Connection_Handler (void)
-Connection_Handler::Connection_Handler (const Connection_Config_Info &pci)
-  : remote_addr_ (pci.remote_port_, pci.host_[0] == '\0' ? ACE_DEFAULT_SERVER_HOST : pci.host_),
-    local_addr_ (pci.local_port_),
-    connection_id_ (pci.connection_id_),
-    total_bytes_ (0),
-    state_ (Connection_Handler::IDLE),
-    timeout_ (1),
-    max_timeout_ (pci.max_retry_timeout_),
-    event_channel_ (pci.event_channel_)
-  // Set the priority of the Proxy.
-  this->priority (int (pci.priority_));
-// Set the connection_role.
-void
-Connection_Handler::connection_role (char d)
-  this->connection_role_ = d;
-// Get the connection_role.
-char
-Connection_Handler::connection_role (void) const
-  return this->connection_role_;
-// Sets the timeout delay.
-void
-Connection_Handler::timeout (int to)
-  if (to > this->max_timeout_)
-    to = this->max_timeout_;
-  this->timeout_ = to;
-// Re-calculate the current retry timeout delay using exponential
-// backoff.  Returns the original timeout (i.e., before the
-// re-calculation).
-int
-Connection_Handler::timeout (void)
-  int old_timeout = this->timeout_;
-  this->timeout_ *= 2;
-  if (this->timeout_ > this->max_timeout_)
-    this->timeout_ = this->max_timeout_;
-  return old_timeout;
-// Sets the max timeout delay.
-void
-Connection_Handler::max_timeout (int mto)
-  this->max_timeout_ = mto;
-// Gets the max timeout delay.
-int
-Connection_Handler::max_timeout (void) const
-  return this->max_timeout_;
-// Restart connection asynchronously when timeout occurs.
-int
-Connection_Handler::handle_timeout (const ACE_Time_Value &,
-                                    const void *)
-	     "(%t) attempting to reconnect Connection_Handler %d with timeout = %d\n",
-              this->timeout_));
-  // Delegate the re-connection attempt to the Event Channel.
-  this->event_channel_->initiate_connection_connection (this);
-  return 0;
-// Handle shutdown of the Connection_Handler object.
-int
-Connection_Handler::handle_close (ACE_HANDLE, ACE_Reactor_Mask)
-	      "(%t) shutting down %s Connection_Handler %d on handle %d\n",
-	      this->connection_role () == 'C' ? "Consumer" : "Supplier",
-  // Restart the connection, if possible.
-  return this->event_channel_->reinitiate_connection_connection (this);
-// Set the state of the Proxy.
-void
-Connection_Handler::state (Connection_Handler::State s)
-  this->state_ = s;
-// Return the current state of the Proxy.
-Connection_Handler::State
-Connection_Handler::state (void) const
-  return this->state_;
-// Upcall from the <ACE_Acceptor> or <ACE_Connector> that delegates
-// control to our Connection_Handler.
-int
-Connection_Handler::open (void *)
-  ACE_DEBUG ((LM_DEBUG, "(%t) %s Connection_Handler's handle = %d\n",
-  if (this->event_channel_->complete_connection_connection (this) == -1)
-    ACE_ERROR_RETURN ((LM_ERROR, "(%t) %p\n", "complete_connection_connection"), -1);
-  // Turn on non-blocking I/O.
-  else if (this->peer ().enable (ACE_NONBLOCK) == -1)
-    ACE_ERROR_RETURN ((LM_ERROR, "(%t) %p\n", "enable"), -1);
-  // Register ourselves to receive input events.
-    ACE_ERROR_RETURN ((LM_ERROR, "(%t) %p\n", "register_handler"), -1);
-  else
-    return 0;
-const ACE_INET_Addr &
-Connection_Handler::remote_addr (void) const
-  return this->remote_addr_;
-void
-Connection_Handler::remote_addr (ACE_INET_Addr &ra)
-  this->remote_addr_ = ra;
-Connection_Handler::local_addr (void) const
-  return this->local_addr_;
-void
-Connection_Handler::local_addr (ACE_INET_Addr &la)
-  this->local_addr_ = la;
-// Make the appropriate type of <Connection_Handler> (i.e.,
-// <Consumer_Handler>, <Supplier_Handler>, <Thr_Consumer_Handler>, or
-// <Thr_Supplier_Handler>).
-Connection_Handler *
-Connection_Handler_Factory::make_connection_handler (const Connection_Config_Info &pci)
-  Connection_Handler *connection_handler = 0;
-  // The next few lines of code are dependent on whether we are making
-  // a threaded/reactive Supplier_Handler/Consumer_Handler.
-  if (pci.connection_role_ == 'C') // Configure a Consumer_Handler.
-      // Create a threaded Consumer_Handler.
-      if (ACE_BIT_ENABLED (Options::instance ()->threading_strategy (),
-			   Options::OUTPUT_MT))
-	ACE_NEW_RETURN (connection_handler,
-			Thr_Consumer_Handler (pci),
-			0);
-      // Create a reactive Consumer_Handler.
-      else
-			Consumer_Handler (pci),
-			0);
-  else // connection_role == 'S', so configure a Supplier_Handler.
-      // Create a threaded Supplier_Handler.
-			   Options::INPUT_MT))
-			Thr_Supplier_Handler (pci),
-			0);
-      // Create a reactive Supplier_Handler.
-      else
-			Supplier_Handler (pci),
-			0);
-  return connection_handler;
-template class ACE_Map_Entry<Event_Key, Consumer_Dispatch_Set *>;
-template class ACE_Map_Iterator_Base<Event_Key, Consumer_Dispatch_Set *, MAP_MUTEX>;
-template class ACE_Map_Iterator<Event_Key, Consumer_Dispatch_Set *, MAP_MUTEX>;
-template class ACE_Map_Reverse_Iterator<Event_Key, Consumer_Dispatch_Set *, MAP_MUTEX>;
-template class ACE_Map_Manager<Event_Key, Consumer_Dispatch_Set *, MAP_MUTEX>;
-template class ACE_Svc_Handler<ACE_SOCK_STREAM, ACE_NULL_SYNCH>;
-#if defined (ACE_HAS_THREADS)
-template class ACE_Svc_Handler<ACE_SOCK_STREAM, ACE_MT_SYNCH>;
-#endif /* ACE_HAS_THREADS */
-#pragma instantiate ACE_Map_Entry<Event_Key, Consumer_Dispatch_Set *>
-#pragma instantiate ACE_Map_Iterator<Event_Key, Consumer_Dispatch_Set *, MAP_MUTEX>
-#pragma instantiate ACE_Map_Reverse_Iterator<Event_Key, Consumer_Dispatch_Set *, MAP_MUTEX>
-#pragma instantiate ACE_Map_Iterator_Base<Event_Key, Consumer_Dispatch_Set *, MAP_MUTEX>
-#pragma instantiate ACE_Map_Manager<Event_Key, Consumer_Dispatch_Set *, MAP_MUTEX>
-#pragma instantiate ACE_Svc_Handler<ACE_SOCK_STREAM, ACE_NULL_SYNCH>
-#pragma instantiate ACE_Svc_Handler<ACE_SOCK_STREAM, ACE_MT_SYNCH>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,157 +0,0 @@
-/* -*- C++ -*- */
-// Connection_Handler.h,v 4.4 1998/10/20 02:34:17 levine Exp
-// = LIBRARY
-//    gateway
-// = FILENAME
-// = AUTHOR
-//    Doug Schmidt
-#ifndef _CONNECTION_HANDLER
-#define _CONNECTION_HANDLER
-#include "ace/Service_Config.h"
-#if !defined (ACE_LACKS_PRAGMA_ONCE)
-# pragma once
-#endif /* ACE_LACKS_PRAGMA_ONCE */
-#include "ace/SOCK_Connector.h"
-#include "ace/Svc_Handler.h"
-#include "Event.h"
-class Connection_Handler : public ACE_Svc_Handler<ACE_SOCK_STREAM, ACE_SYNCH>
-  // = TITLE
-  //     <Connection_Handler> contains info about connection state and
-  //     addressing.
-  // = DESCRIPTION
-  //     The <Connection_Handler> classes process events sent to the
-  //     Event Channel from Suppliers and forward them to Consumers.
-public:
-  Connection_Handler (void);
-  // Default constructor (needed to make <ACE_Connector> happy).
-  Connection_Handler (const Connection_Config_Info &);
-  // Real constructor.
-  virtual int open (void * = 0);
-  // Initialize and activate a single-threaded <Connection_Handler>
-  // (called by <ACE_Connector::handle_output>).
-  // = The current state of the Connection_Handler.
-  enum State
-    IDLE = 1,      // Prior to initialization.
-    CONNECTING,    // During connection establishment.
-    ESTABLISHED,   // Connection_Handler is established and active.
-    DISCONNECTING, // Connection_Handler is in the process of connecting.
-    FAILED         // Connection_Handler has failed.
-  // = Set/get the current state.
-  void state (State);
-  State state (void) const;
-  // = Set/get remote INET addr.
-  void remote_addr (ACE_INET_Addr &);
-  const ACE_INET_Addr &remote_addr (void) const;
-  // = Set/get local INET addr.
-  void local_addr (ACE_INET_Addr &);
-  const ACE_INET_Addr &local_addr (void) const;
-  // = Set/get connection id.
-  void connection_id (CONNECTION_ID);
-  CONNECTION_ID connection_id (void) const;
-  // = Set/get the current retry timeout delay.
-  void timeout (int);
-  int timeout (void);
-  // = Set/get the maximum retry timeout delay.
-  void max_timeout (int);
-  int max_timeout (void) const;
-  // = Set/get proxy role (i.e., 'S' for Supplier and 'C' for Consumer
-  // (necessary for error checking).
-  void connection_role (char);
-  char connection_role (void) const;
-  // = Set/get the <Event_Channel> *.
-  void event_channel (Event_Channel *);
-  Event_Channel *event_channel (void) const;
-  // = The total number of bytes sent/received on this proxy.
-  void total_bytes (size_t bytes);
-  // Increment count by <bytes>.
-  size_t total_bytes (void) const;
-  // Return the current byte count.
-  virtual int handle_timeout (const ACE_Time_Value &, const void *arg);
-  // Perform timer-based Connection_Handler reconnection.
-  // Perform Connection_Handler termination.
-protected:
-  ACE_INET_Addr remote_addr_;
-  // Address of peer.
-  ACE_INET_Addr local_addr_;
-  // Address of us.
-  CONNECTION_ID connection_id_;
-  // The assigned connection ID of this entry.
-  size_t total_bytes_;
-  // The total number of bytes sent/received on this proxy.
-  State state_;
-  // The current state of the proxy.
-  int timeout_;
-  // Amount of time to wait between reconnection attempts.
-  int max_timeout_;
-  // Maximum amount of time to wait between reconnection attempts.
-  // Indicates which role the proxy plays ('S' == Supplier and 'C' ==
-  // Consumer).
-  // Reference to the <Event_Channel> that we use to forward all
-  // the events from Consumers and Suppliers.
-class Connection_Handler_Factory
-  // = TITLE
-  //     Creates the appropriate type of <Connection_Handler>.
-  // = DESCRIPTION
-  //     <Connection_Handler>s can include <Consumer_Handler>,
-  //     <Supplier_Handler>, <Thr_Consumer_Handler>, or
-  //     <Thr_Supplier_Handler>).
-public:
-  Connection_Handler *make_connection_handler (const Connection_Config_Info &);
-  // Make the appropriate type of <Connection_Handler>, based on the
-  // <Connection_Config_Info> parameter.
-#endif /* _CONNECTION_HANDLER */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler_Acceptor.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler_Acceptor.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler_Acceptor.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,62 +0,0 @@
-// Connection_Handler_Acceptor.cpp,v 4.4 1998/07/31 23:36:42 gonzo Exp
-#include "Connection_Handler_Acceptor.h"
-ACE_RCSID(Gateway, Connection_Handler_Acceptor, "Connection_Handler_Acceptor.cpp,v 4.4 1998/07/31 23:36:42 gonzo Exp")
-int
-Connection_Handler_Acceptor::make_svc_handler (Connection_Handler *&ch)
-  ACE_ALLOCATOR_RETURN (ch,
-                        this->connection_handler_factory_.make_connection_handler (this->connection_config_info_),
-                        -1);
-  return 0;
-int
-Connection_Handler_Acceptor::accept_svc_handler (Connection_Handler *ch)
-  if (this->inherited::accept_svc_handler (ch) == -1)
-    return -1;
-  else
-      ch->connection_id (Options::instance ()->connection_id ());
-      ACE_INET_Addr remote_addr;
-      if (ch->peer ().get_remote_addr (remote_addr) == -1)
-        return -1;
-      // Set the remote address of our connected Peer.
-      ch->remote_addr (remote_addr);
-      // Set the Event_Channel pointer.
-      ch->event_channel (&this->event_channel_);
-      // Increment the connection ID by one.
-      Options::instance ()->connection_id ()++;
-      return 0;
-Connection_Handler_Acceptor::Connection_Handler_Acceptor (Event_Channel &ec,
-                                                          char connection_role)
-  : event_channel_ (ec)
-  this->connection_config_info_.connection_id_ = 0;
-  this->connection_config_info_.host_[0] = '\0';
-  this->connection_config_info_.remote_port_ = 0;
-  this->connection_config_info_.connection_role_ = connection_role;
-  this->connection_config_info_.max_retry_timeout_ = Options::instance ()->max_timeout ();
-  this->connection_config_info_.local_port_ = 0;
-  this->connection_config_info_.priority_ = 1;
-template class ACE_Acceptor<Connection_Handler, ACE_SOCK_ACCEPTOR>;
-#pragma instantiate ACE_Acceptor<Connection_Handler, ACE_SOCK_ACCEPTOR>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler_Acceptor.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler_Acceptor.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler_Acceptor.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,65 +0,0 @@
-/* -*- C++ -*- */
-// Connection_Handler_Acceptor.h,v 4.4 1998/10/20 02:34:17 levine Exp
-// = LIBRARY
-//    gateway
-// = FILENAME
-//    Connection_Handler_acceptor.h
-// = AUTHOR
-//    Doug Schmidt
-#ifndef _CONNECTION_HANDLER_ACCEPTOR
-#define _CONNECTION_HANDLER_ACCEPTOR
-#include "ace/Acceptor.h"
-# pragma once
-#include "ace/SOCK_Acceptor.h"
-class Connection_Handler_Acceptor : public ACE_Acceptor<Connection_Handler, ACE_SOCK_ACCEPTOR>
-  // = TITLE
-  //     A concrete factory class that setups connections to peerds
-  //     and produces a new Connection_Handler object to do the dirty
-  //     work...
-public:
-  Connection_Handler_Acceptor (Event_Channel &,
-                               char connection_role);
-  // Constructor.
-  virtual int make_svc_handler (Connection_Handler *&ch);
-  // Hook method for creating an appropriate <Connection_Handler>.
-  virtual int accept_svc_handler (Connection_Handler *ch);
-  // Hook method for accepting a connection into the
-  // <Connection_Handler>.
-protected:
-  typedef ACE_Acceptor<Connection_Handler, ACE_SOCK_ACCEPTOR>
-          inherited;
-  // Make life easier later on.
-  Event_Channel &event_channel_;
-  // Reference to the event channel.
-  Connection_Config_Info connection_config_info_;
-  // Keeps track of what type of proxy we need to create.
-  Connection_Handler_Factory connection_handler_factory_;
-  // Make the appropriate type of <Connection_Handler>.
-#endif /* _CONNECTION_HANDLER_ACCEPTOR */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler_Connector.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler_Connector.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler_Connector.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,69 +0,0 @@
-// Connection_Handler_Connector.cpp,v 4.7 2003/11/01 11:15:19 dhinton Exp
-#include "Connection_Handler_Connector.h"
-#include "ace/os_include/os_netdb.h"
-ACE_RCSID(Gateway, Connection_Handler_Connector, "Connection_Handler_Connector.cpp,v 4.7 2003/11/01 11:15:19 dhinton Exp")
-Connection_Handler_Connector::Connection_Handler_Connector (void)
-// Initiate (or reinitiate) a connection to the Connection_Handler.
-int
-Connection_Handler_Connector::initiate_connection (Connection_Handler *connection_handler,
-                                                   ACE_Synch_Options &synch_options)
-  char addr_buf[MAXHOSTNAMELEN];
-  // Mark ourselves as idle so that the various iterators will ignore
-  // us until we are reconnected.
-  connection_handler->state (Connection_Handler::IDLE);
-  // We check the remote addr second so that it remains in the
-  // addr_buf.
-  if (connection_handler->local_addr ().addr_to_string (addr_buf, sizeof addr_buf) == -1
-      || connection_handler->remote_addr ().addr_to_string (addr_buf, sizeof addr_buf) == -1)
-                      "can't obtain peer's address"), -1);
-  // Try to connect to the Peer.
-  if (this->connect (connection_handler,
-                     connection_handler->remote_addr (),
-                     synch_options,
-                     connection_handler->local_addr ()) == -1)
-      if (errno != EWOULDBLOCK)
-          connection_handler->state (Connection_Handler::FAILED);
-          ACE_DEBUG ((LM_DEBUG, "(%t) %p on address %s\n",
-                      "connect", addr_buf));
-          return -1;
-      else
-          connection_handler->state (Connection_Handler::CONNECTING);
-                      "(%t) in the process of connecting to %s\n",
-                      addr_buf));
-  else
-      connection_handler->state (Connection_Handler::ESTABLISHED);
-      ACE_DEBUG ((LM_DEBUG, "(%t) connected to %s on %d\n",
-                  addr_buf, connection_handler->get_handle ()));
-  return 0;
-template class ACE_Connector_Base<Connection_Handler>;
-template class ACE_Connector<Connection_Handler, ACE_SOCK_CONNECTOR>;
-template class ACE_NonBlocking_Connect_Handler<Connection_Handler>;
-#pragma instantiate ACE_Connector_Base<Connection_Handler>
-#pragma instantiate ACE_Connector<Connection_Handler, ACE_SOCK_CONNECTOR>
-#pragma instantiate ACE_NonBlocking_Connect_Handler<Connection_Handler>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler_Connector.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler_Connector.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Connection_Handler_Connector.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,44 +0,0 @@
-/* -*- C++ -*- */
-// Connection_Handler_Connector.h,v 4.2 1998/10/20 02:34:17 levine Exp
-// = LIBRARY
-//    gateway
-// = FILENAME
-// = AUTHOR
-//    Doug Schmidt
-#ifndef _IO_HANDLER_CONNECTOR
-#define _IO_HANDLER_CONNECTOR
-#include "ace/Connector.h"
-# pragma once
-class Connection_Handler_Connector : public ACE_Connector<Connection_Handler, ACE_SOCK_CONNECTOR>
-  // = TITLE
-  //     work...
-public:
-  Connection_Handler_Connector (void);
-  // Initiate (or reinitiate) a connection on the Connection_Handler.
-  int initiate_connection (Connection_Handler *,
-                           ACE_Synch_Options & = ACE_Synch_Options::synch);
-#endif /* _IO_HANDLER_CONNECTOR */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Consumer_Dispatch_Set.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Consumer_Dispatch_Set.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Consumer_Dispatch_Set.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,32 +0,0 @@
-/* -*- C++ -*- */
-// Consumer_Dispatch_Set.h,v 4.4 1998/10/20 02:34:17 levine Exp
-// = LIBRARY
-//    apps
-// = FILENAME
-// = AUTHOR
-//    Doug Schmidt
-#ifndef CONSUMER_DISPATCH_SET
-#define CONSUMER_DISPATCH_SET
-#include "ace/Containers.h"
-# pragma once
-// Forward reference.
-class Connection_Handler;
-typedef ACE_Unbounded_Set<Connection_Handler *> Consumer_Dispatch_Set;
-typedef ACE_Unbounded_Set_Iterator<Connection_Handler *> Consumer_Dispatch_Set_Iterator;
-#endif /* CONSUMER_DISPATCH_SET */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,225 +0,0 @@
-/* -*- C++ -*- */
-// Event.h,v 4.11 2003/11/01 11:15:20 dhinton Exp
-// = LIBRARY
-//    gateway
-// = FILENAME
-//    Event.h
-// = AUTHOR
-//    Doug Schmidt
-#ifndef EVENT_H
-#define EVENT_H
-#include "ace/os_include/arpa/os_inet.h"
-# pragma once
-#include "ace/Basic_Types.h"
-// = The following #defines should really be in a separate include
-// file that is shared with the ../Peer/ directory.  For now, we'll
-// keep them here to simplify the sharing between the two directories.
-// BTW, this is also the reason why all the methods are inlined...
-// Used by Peers to create Consumers in a Gateway.
-#if !defined (DEFAULT_GATEWAY_CONSUMER_PORT)
-#define DEFAULT_GATEWAY_CONSUMER_PORT 10009
-#endif /* DEFAULT_GATEWAY_CONSUMER_PORT */
-// Used by Peers create Suppliers in a Gateway.
-#if !defined (DEFAULT_GATEWAY_SUPPLIER_PORT)
-#define DEFAULT_GATEWAY_SUPPLIER_PORT 10010
-#endif /* DEFAULT_GATEWAY_SUPPLIER_PORT */
-// Used by a Gateway to create Consumers in a Peer.
-#if !defined (DEFAULT_PEER_CONSUMER_PORT)
-#define DEFAULT_PEER_CONSUMER_PORT 10011
-#endif /* DEFAULT_PEER_CONSUMER_PORT */
-// Used by a Gateway to create Suppliers in a Peer.
-#if !defined (DEFAULT_PEER_SUPPLIER_PORT)
-#define DEFAULT_PEER_SUPPLIER_PORT 10012
-#endif /* DEFAULT_PEER_SUPPLIER_PORT */
-#if !defined (MAX_CONSUMERS)
-#define MAX_CONSUMERS 1000
-#endif /* MAX_CONSUMERS */
-// This is the unique supplier identifier that denotes a particular
-// <Connection_Handler> in the Gateway.
-typedef ACE_INT32 CONNECTION_ID;
-enum
-  // = These are the types of events generated by the <Suppliers> and
-  // handled by the <Event_Channel>.
-  ROUTING_EVENT = 0,
-  // A normal event, which is forwarded to the <Consumers>.
-  SUBSCRIPTION_EVENT = 1
-  // A subscription to <Suppliers> managed by the <Event_Channel>.
-class Event_Key
-  // = TITLE
-  //     Address used to identify the source/destination of an event.
-  // = DESCRIPTION
-  //     This is really a "processing descriptor" that is used to
-  //     decouple the processing, filtering, and forwarding logic of
-  //     the Event Channel from the format of the data.  The
-  //     <connection_id_> and <type_> fields are copied from the
-  //     <Event_Header> class below.
-public:
-  Event_Key (CONNECTION_ID cid = -1,
-             ACE_INT32 type = 0,
-             ACE_INT32 priority = 0)
-    : connection_id_ (cid),
-      type_ (type),
-      priority_ (priority)
-  int operator== (const Event_Key &event_addr) const
-    return this->connection_id_ == event_addr.connection_id_
-      && this->type_ == event_addr.type_;
-  // Unique connection identifier that denotes a particular
-  // Connection_Handler.
-  ACE_INT32 type_;
-  // Event type, e.g., <ROUTING_EVENT> or <SUBSCRIPTION_EVENT>.
-  // Event priority.
-class Event_Header
-  // = TITLE
-  //     Fixed sized header.
-  // = DESCRIPTION
-  //     This is designed to have a sizeof (16) to avoid alignment
-  //     problems on most platforms.
-public:
-  enum
-    INVALID_ID = -1 // No peer can validly use this number.
-  Event_Header (ACE_INT32 len,
-                CONNECTION_ID connection_id,
-                ACE_INT32 type,
-                ACE_INT32 priority)
-    : len_ (len),
-      connection_id_ (connection_id),
-      type_ (type),
-  void decode (void)
-    this->len_ = ntohl (this->len_);
-    this->connection_id_ = ntohl (this->connection_id_);
-    this->type_ = ntohl (this->type_);
-    this->priority_ = ntohl (this->priority_);
-  // Decode from network byte order to host byte order.
-  void encode (void)
-    this->len_ = htonl (this->len_);
-    this->connection_id_ = htonl (this->connection_id_);
-    this->type_ = htonl (this->type_);
-    this->priority_ = htonl (this->priority_);
-  // Encode from host byte order to network byte order.
-  ACE_INT32 len_;
-  // Length of the data_ payload, in bytes.
-  ACE_INT32 type_;
-class Event
-  // = TITLE
-  //    Variable-sized event (data_ may be variable-sized between
-  //    0 and MAX_PAYLOAD_SIZE).
-public:
-  enum { MAX_PAYLOAD_SIZE = 1024 };
-  // The maximum size of an Event.
-  Event () : header_ (0, -1, 0, 0) {};
-  Event_Header header_;
-  // Event header.
-  char data_[MAX_PAYLOAD_SIZE];
-  // Event data.
-class Subscription
-  // = TITLE
-  //     Allows Consumers to subscribe to be routed information
-  //     arriving from a particular Supplier connection id.
-public:
-      for (ACE_INT32 i = 0; i < this->total_consumers_; i++)
-        this->consumers_[i] = ntohl (this->consumers_[i]);
-      this->total_consumers_ = ntohl (this->total_consumers_);
-        this->consumers_[i] = htonl (this->consumers_[i]);
-      this->total_consumers_ = htonl (this->total_consumers_);
-  // Connection id.
-#endif /* EVENT_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event_Channel.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event_Channel.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event_Channel.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,601 +0,0 @@
-// Event_Channel.cpp,v 4.36 2003/11/05 02:04:53 dhinton Exp
-#include "ace/OS_NS_sys_select.h"
-#include "ace/Signal.h"
-ACE_RCSID(Gateway, Event_Channel, "Event_Channel.cpp,v 4.36 2003/11/05 02:04:53 dhinton Exp")
-Event_Channel::~Event_Channel (void)
-Event_Channel::Event_Channel (void)
-  : supplier_acceptor_ (*this, 'S'),
-    consumer_acceptor_ (*this, 'C')
-int
-Event_Channel::compute_performance_statistics (void)
-  ACE_DEBUG ((LM_DEBUG, "(%t) doing the performance timeout here...\n"));
-  CONNECTION_MAP_ITERATOR cmi (this->connection_map_);
-  // If we've got a <ACE_Thread_Manager> then use it to suspend all
-  // the threads.  This will enable us to get an accurate count.
-  if (Options::instance ()->threading_strategy ()
-      != Options::REACTIVE)
-      if (ACE_Thread_Manager::instance ()->suspend_all () == -1)
-                           "(%t) %p\n",
-                           "suspend_all"),
-                          -1);
-                  "(%t) suspending all threads..."));
-  size_t total_bytes_in = 0;
-  size_t total_bytes_out = 0;
-  // Iterate through the connection map summing up the number of bytes
-  // sent/received.
-  for (CONNECTION_MAP_ENTRY *me = 0;
-       cmi.next (me) != 0;
-       cmi.advance ())
-      Connection_Handler *connection_handler = me->int_id_;
-      if (connection_handler->connection_role () == 'C')
-        total_bytes_out += connection_handler->total_bytes ();
-      else // connection_handler->connection_role () == 'S'
-        total_bytes_in += connection_handler->total_bytes ();
-              "(%t) after %d seconds, \ntotal_bytes_in = %d\ntotal_bytes_out = %d\n",
-              Options::instance ()->performance_window (),
-              total_bytes_in,
-              total_bytes_out));
-              "(%t) %f Mbits/sec received.\n",
-              (float) (total_bytes_in * 8 /
-                       (float) (1024 * 1024 * Options::instance ()->performance_window ()))));
-              "(%t) %f Mbits/sec sent.\n",
-              (float) (total_bytes_out * 8 /
-  // Resume all the threads again.
-      if (ACE_Thread_Manager::instance ()->resume_all () == -1)
-                           "(%t) %p\n",
-                           "resume_all"),
-                          -1);
-                  "(%t) resuming all threads..."));
-  return 0;
-int
-Event_Channel::handle_timeout (const ACE_Time_Value &,
-                               const void *)
-  // This is called periodically to compute performance statistics.
-  return this->compute_performance_statistics ();
-int
-Event_Channel::put (ACE_Message_Block *event,
-                    ACE_Time_Value *)
-  // We got a valid event, so determine its type, which is stored in
-  // the first of the two <ACE_Message_Block>s, which are chained
-  // together by <ACE::recv>.
-  Event_Key *event_key = (Event_Key *) event->rd_ptr ();
-  // Skip over the address portion and get the data, which is in the
-  // second <ACE_Message_Block>.
-  ACE_Message_Block *data = event->cont ();
-  switch (event_key->type_)
-    case ROUTING_EVENT:
-      this->routing_event (event_key,
-                           data);
-      break;
-    case SUBSCRIPTION_EVENT:
-      this->subscription_event (data);
-      break;
-  // Release the memory in the message block.
-  return 0;
-void
-Event_Channel::subscription_event (ACE_Message_Block *data)
-  Event *event = (Event *) data->rd_ptr ();
-              "(%t) received a subscription with %d bytes from connection id %d\n",
-              event->header_.connection_id_));
-  Subscription *subscription = (Subscription *) event->data_;
-  // Convert the subscription into host byte order so that we can
-  // access it directly without having to repeatedly muck with it...
-  subscription->decode ();
-              "(%t) connection_id_ = %d, total_consumers_ = %d\n",
-              subscription->connection_id_,
-              subscription->total_consumers_));
-       i < subscription->total_consumers_;
-       i++)
-                "(%t) consumers_[%d] = %d\n",
-                i,
-                subscription->consumers_[i]));
-void
-Event_Channel::routing_event (Event_Key *forwarding_address,
-                              ACE_Message_Block *data)
-  Consumer_Dispatch_Set *dispatch_set = 0;
-  // Initialize the <dispatch_set> to points to the set of Consumers
-  // associated with this forwarding address.
-  if (this->efd_.find (*forwarding_address,
-                       dispatch_set) == -1)
-    // Failure.
-    ACE_ERROR ((LM_DEBUG,
-                "(%t) find failed on connection id = %d, type = %d\n",
-                forwarding_address->connection_id_,
-                forwarding_address->type_));
-  else
-      // Check to see if there are any consumers.
-      if (dispatch_set->size () == 0)
-        ACE_DEBUG ((LM_WARNING,
-                    "there are no active consumers for this event currently\n"));
-      else // There are consumers, so forward the event.
-          // Initialize the interator.
-          Consumer_Dispatch_Set_Iterator dsi (*dispatch_set);
-          // At this point, we should assign a thread-safe locking
-          // strategy to the <ACE_Message_Block> is we're running in a
-          // multi-threaded configuration.
-          data->locking_strategy (Options::instance ()->locking_strategy ());
-          for (Connection_Handler **connection_handler = 0;
-               dsi.next (connection_handler) != 0;
-               dsi.advance ())
-              // Only process active connection_handlers.
-              if ((*connection_handler)->state () == Connection_Handler::ESTABLISHED)
-                  // Duplicate the event portion via reference
-                  // counting.
-                  ACE_Message_Block *dup_msg = data->duplicate ();
-                              "(%t) forwarding to Consumer %d\n",
-                              (*connection_handler)->connection_id ()));
-                  if ((*connection_handler)->put (dup_msg) == -1)
-                      if (errno == EWOULDBLOCK) // The queue has filled up!
-                                    "(%t) %p\n",
-                                    "gateway is flow controlled, so we're dropping events"));
-                      else
-                                    "(%t) %p transmission error to peer %d\n",
-                                    "put",
-                      // ACE_Message_Block if failures occur.
-                      dup_msg->release ();
-int
-Event_Channel::initiate_connection_connection (Connection_Handler *connection_handler,
-                                               int sync_directly)
-  ACE_Synch_Options synch_options;
-  if (sync_directly)
-    // In separated connection handler thread, connection can be
-    // initiated by block mode (synch mode) directly.
-    synch_options = ACE_Synch_Options::synch;
-  else if (Options::instance ()->blocking_semantics () == ACE_NONBLOCK)
-    synch_options = ACE_Synch_Options::asynch;
-  else
-  return this->connector_.initiate_connection (connection_handler,
-                                               synch_options);
-int
-Event_Channel::complete_connection_connection (Connection_Handler *connection_handler)
-  int option = connection_handler->connection_role () == 'S'
-    ? SO_RCVBUF
-    : SO_SNDBUF;
-  int socket_queue_size =
-    Options::instance ()->socket_queue_size ();
-  if (socket_queue_size > 0)
-    if (connection_handler->peer ().set_option (SOL_SOCKET,
-                                                option,
-                                                &socket_queue_size,
-                                                sizeof (int)) == -1)
-                  "(%t) %p\n",
-                  "set_option"));
-  connection_handler->thr_mgr (ACE_Thread_Manager::instance ());
-  // Our state is now "established."
-  // Restart the timeout to 1.
-  connection_handler->timeout (1);
-  ACE_INT32 id = htonl (connection_handler->connection_id ());
-  // Send the connection id to the peerd.
-  ssize_t n = connection_handler->peer ().send ((const void *) &id,
-                                                sizeof id);
-  if (n != sizeof id)
-                       "(%t) %p\n",
-                      n == 0 ? "peer has closed down unexpectedly" : "send"),
-                      -1);
-  return 0;
-// Restart connection (blocking_semantics dicates whether we restart
-// synchronously or asynchronously).
-int
-Event_Channel::reinitiate_connection_connection (Connection_Handler *connection_handler)
-  // Cancel asynchronous connecting before re-initializing.  It will
-  // close the peer and cancel the asynchronous connecting.
-  this->cancel_connection_connection(connection_handler);
-  if (connection_handler->state () != Connection_Handler::DISCONNECTING)
-                  "(%t) scheduling reinitiation of Connection_Handler %d\n",
-                  connection_handler->connection_id ()));
-      // Reschedule ourselves to try and connect again.
-      if (ACE_Reactor::instance ()->schedule_timer
-          (connection_handler,
-           0,
-           connection_handler->timeout ()) == -1)
-                           "(%t) %p\n",
-                           "schedule_timer"),
-                          -1);
-  return 0;
-// It is useful to provide a separate method to cancel the
-// asynchronous connecting.
-int
-Event_Channel::cancel_connection_connection (Connection_Handler *connection_handler)
-  // Skip over proxies with deactivated handles.
-  if (connection_handler->get_handle () != ACE_INVALID_HANDLE)
-      // Make sure to close down peer to reclaim descriptor.
-      connection_handler->peer ().close ();
-      return this->connector_.cancel(connection_handler);
-  return 0;
-// Initiate active connections with the Consumer and Supplier Peers.
-void
-Event_Channel::initiate_connector (void)
-      (Options::CONSUMER_CONNECTOR | Options::SUPPLIER_CONNECTOR))
-      // Iterate through the Consumer Map connecting all the
-      // Connection_Handlers.
-           cmi.advance ())
-          if (this->initiate_connection_connection (connection_handler) == -1)
-            continue; // Failures are handled elsewhere...
-// Initiate passive acceptor to wait for Consumer and Supplier Peers
-// to accept.
-int
-Event_Channel::initiate_acceptors (void)
-  if (Options::instance ()->enabled (Options::CONSUMER_ACCEPTOR))
-      if (this->consumer_acceptor_.open
-          (Options::instance ()->consumer_acceptor_port (),
-           ACE_Reactor::instance (),
-           Options::instance ()->blocking_semantics ()) == -1)
-                           "%p\n",
-                           "cannot register acceptor"),
-                          -1);
-      else
-                    "accepting Consumers at %d\n",
-                    Options::instance ()->consumer_acceptor_port ()));
-  if (Options::instance ()->enabled (Options::SUPPLIER_ACCEPTOR))
-    if(this->supplier_acceptor_.open
-          (Options::instance ()->supplier_acceptor_port (),
-                           "%p\n",
-                          -1);
-      else
-                    "accepting Suppliers at %d\n",
-                    Options::instance ()->supplier_acceptor_port ()));
-  return 0;
-// This method gracefully shuts down all the Handlers in the
-// Connection_Handler Connection Map.
-int
-Event_Channel::close (u_long)
-  if (Options::instance ()->threading_strategy () != Options::REACTIVE)
-                           "(%t) %p\n",
-                           "suspend_all"),
-                          -1);
-                  "(%t) suspending all threads\n"));
-  // First tell everyone that the spaceship is here...
-    // Iterate over all the handlers and shut them down.
-    for (CONNECTION_MAP_ENTRY *me = 0; // It's safe to reset me to 0.
-         cmi.advance ())
-                    "(%t) closing down connection %d\n",
-        // If have no this statement, the gatewayd will abort when exiting
-        // with some Consumer/Supplier not connected.
-        if (connection_handler->state()==Connection_Handler::CONNECTING)
-        // Mark Connection_Handler as DISCONNECTING so we don't try to
-        // reconnect...
-        connection_handler->state (Connection_Handler::DISCONNECTING);
-  // Close down the connector
-  this->connector_.close ();
-  // Close down the supplier acceptor.
-  this->supplier_acceptor_.close ();
-  // Close down the consumer acceptor.
-  this->consumer_acceptor_.close ();
-  // Now tell everyone that it is now time to commit suicide.
-         cmi.advance ())
-        // Deallocate Connection_Handler resources.
-        connection_handler->destroy (); // Will trigger a delete.
-  return 0;
-int
-Event_Channel::find_proxy (ACE_INT32 connection_id,
-                               Connection_Handler *&connection_handler)
-  return this->connection_map_.find (connection_id,
-                                     connection_handler);
-int
-Event_Channel::bind_proxy (Connection_Handler *connection_handler)
-  int result = this->connection_map_.bind (connection_handler->connection_id (),
-  switch (result)
-    case -1:
-                         "(%t) bind failed for connection %d\n",
-                         connection_handler->connection_id ()),
-                        -1);
-      /* NOTREACHED */
-    case 1: // Oops, found a duplicate!
-                         "(%t) duplicate connection %d, already bound\n",
-                        -1);
-      /* NOTREACHED */
-    case 0:
-      // Success.
-      return 0;
-      /* NOTREACHED */
-    default:
-      ACE_ERROR_RETURN ((LM_DEBUG,
-                         "(%t) invalid result %d\n",
-                         result),
-                        -1);
-      /* NOTREACHED */
-  ACE_NOTREACHED (return 0);
-int
-Event_Channel::subscribe (const Event_Key &event_addr,
-                          Consumer_Dispatch_Set *cds)
-  int result = this->efd_.bind (event_addr, cds);
-  // Bind with consumer map, keyed by peer address.
-  switch (result)
-    case -1:
-                         event_addr.connection_id_),
-                        -1);
-      /* NOTREACHED */
-                         "(%t) duplicate consumer map entry %d, "
-                         "already bound\n",
-                        -1);
-      /* NOTREACHED */
-    case 0:
-      // Success.
-      return 0;
-    default:
-                         result),
-                        -1);
-      /* NOTREACHED */
-int
-Event_Channel::open (void *)
-  // Ignore <SIGPIPE> so each <Consumer_Handler> can handle it.
-  ACE_Sig_Action sig ((ACE_SignalHandler) SIG_IGN, SIGPIPE);
-  ACE_UNUSED_ARG (sig);
-  // Actively initiate Peer connections.
-  this->initiate_connector ();
-  // Passively initiate Peer acceptor.
-  if (this->initiate_acceptors () == -1)
-    return -1;
-  // If we're not running reactively, then we need to make sure that
-  // <ACE_Message_Block> reference counting operations are
-  // thread-safe.  Therefore, we create an <ACE_Lock_Adapter> that is
-  // parameterized by <ACE_SYNCH_MUTEX> to prevent race conditions.
-      ACE_Lock_Adapter<ACE_SYNCH_MUTEX> *la;
-      ACE_NEW_RETURN (la,
-                      ACE_Lock_Adapter<ACE_SYNCH_MUTEX>,
-                      -1);
-      Options::instance ()->locking_strategy (la);
-  return 0;
-template class ACE_Lock_Adapter<ACE_SYNCH_MUTEX>;
-template class ACE_Map_Entry<ACE_INT32, Connection_Handler *>;
-template class ACE_Map_Iterator<ACE_INT32, Connection_Handler *, MAP_MUTEX>;
-template class ACE_Map_Reverse_Iterator<ACE_INT32, Connection_Handler *, MAP_MUTEX>;
-template class ACE_Map_Iterator_Base<ACE_INT32, Connection_Handler *, MAP_MUTEX>;
-template class ACE_Map_Manager<ACE_INT32, Connection_Handler *, MAP_MUTEX>;
-template class ACE_Unbounded_Set_Iterator<Connection_Handler *>;
-#pragma instantiate ACE_Lock_Adapter<ACE_SYNCH_MUTEX>
-#pragma instantiate ACE_Map_Entry<ACE_INT32, Connection_Handler *>
-#pragma instantiate ACE_Map_Iterator<ACE_INT32, Connection_Handler *, MAP_MUTEX>
-#pragma instantiate ACE_Map_Reverse_Iterator<ACE_INT32, Connection_Handler *, MAP_MUTEX>
-#pragma instantiate ACE_Map_Iterator_Base<ACE_INT32, Connection_Handler *, MAP_MUTEX>
-#pragma instantiate ACE_Map_Manager<ACE_INT32, Connection_Handler *, MAP_MUTEX>
-#pragma instantiate ACE_Unbounded_Set_Iterator<Connection_Handler *>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event_Channel.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event_Channel.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event_Channel.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,135 +0,0 @@
-/* -*- C++ -*- */
-// Event_Channel.h,v 4.18 2002/04/11 02:31:03 ossama Exp
-// = LIBRARY
-//    gateway
-// = FILENAME
-//    Event_Channel.h
-// = AUTHOR
-#ifndef ACE_EVENT_CHANNEL
-#define ACE_EVENT_CHANNEL
-#include "Consumer_Dispatch_Set.h"
-#include "Event_Forwarding_Discriminator.h"
-#include "ace/svc_export.h"
-typedef ACE_Null_Mutex MAP_MUTEX;
-class ACE_Svc_Export Event_Channel : public ACE_Event_Handler
-  // = TITLE
-  //    Define a generic Event_Channel.
-  // = DESCRIPTION
-  //    The inspiration for this class is derived from the CORBA COS
-  //    Event Channel, though the design is simplified.
-  //    We inherit from <ACE_Event_Handler> so that we can be
-  //    registered with an <ACE_Reactor> to handle timeouts.
-public:
-  // = Initialization and termination methods.
-  Event_Channel (void);
-  ~Event_Channel (void);
-  // Open the channel.
-  virtual int close (u_long = 0);
-  // Close down the Channel.
-  // = Proxy management methods.
-  int initiate_connection_connection (Connection_Handler *, int sync_directly = 0);
-  // Initiate the connection of the <Connection_Handler> to its peer.
-  // Second paratemer is used for thread connection-handler which will
-  // block the connecting procedure directly, need not care
-  // Options::blocking_semantics().
-  int complete_connection_connection (Connection_Handler *);
-  // Complete the initialization of the <Connection_Handler> once it's
-  // connected to its Peer.
-  int reinitiate_connection_connection (Connection_Handler *);
-  // Reinitiate a connection asynchronously when the Peer fails.
-  int cancel_connection_connection (Connection_Handler *);
-  // Cancel a asynchronous connection.
-  int bind_proxy (Connection_Handler *);
-  // Bind the <Connection_Handler> to the <connection_map_>.
-  int find_proxy (ACE_INT32 connection_id,
-                  Connection_Handler *&);
-  // Locate the <Connection_Handler> with <connection_id>.
-  int subscribe (const Event_Key &event_addr,
-                 Consumer_Dispatch_Set *cds);
-  // Subscribe the <Consumer_Dispatch_Set> to receive events that
-  // match <Event_Key>.
-  // = Event processing entry point.
-  virtual int put (ACE_Message_Block *mb,
-  // Pass <mb> to the Event Channel so it can forward it to Consumers.
-  void initiate_connector (void);
-  // Actively initiate connections to the Peers.
-  int initiate_acceptors (void);
-  // Passively initiate the <Peer_Acceptor>s for Consumer and
-  // Suppliers.
-private:
-  int parse_args (int argc, char *argv[]);
-  // Parse the command-line arguments.
-  // = Methods for handling events.
-  void routing_event (Event_Key *event_key,
-                    ACE_Message_Block *data);
-  // Forwards the <data> to Consumer that have registered to receive
-  // it, based on addressing information in the <event_key>.
-  void subscription_event (ACE_Message_Block *data);
-  // Add a Consumer subscription.
-  int compute_performance_statistics (void);
-  // Perform timer-based performance profiling.
-                              const void *arg);
-  // Periodically callback to perform timer-based performance
-  // profiling.
-  Connection_Handler_Connector connector_;
-  // Used to establish the connections actively.
-  Connection_Handler_Acceptor supplier_acceptor_;
-  // Used to establish connections passively and create Suppliers.
-  Connection_Handler_Acceptor consumer_acceptor_;
-  // Used to establish connections passively and create Consumers.
-  // = Make life easier by defining typedefs.
-  typedef ACE_Map_Manager<CONNECTION_ID, Connection_Handler *, MAP_MUTEX>
-  CONNECTION_MAP;
-  typedef ACE_Map_Iterator<CONNECTION_ID, Connection_Handler *, MAP_MUTEX>
-  CONNECTION_MAP_ITERATOR;
-  typedef ACE_Map_Entry<CONNECTION_ID, Connection_Handler *>
-  CONNECTION_MAP_ENTRY;
-  CONNECTION_MAP connection_map_;
-  // Table that maps <CONNECTION_ID>s to <Connection_Handler> *'s.
-  Event_Forwarding_Discriminator efd_;
-  // Map that associates an event to a set of <Consumer_Handler> *'s.
-#endif /* ACE_EVENT_CHANNEL */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event_Forwarding_Discriminator.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event_Forwarding_Discriminator.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event_Forwarding_Discriminator.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,64 +0,0 @@
-// Event_Forwarding_Discriminator.cpp,v 4.5 2001/03/26 21:47:25 schmidt Exp
-#if !defined (_CONSUMER_MAP_C)
-#define _CONSUMER_MAP_C
-ACE_RCSID(Gateway, Event_Forwarding_Discriminator, "Event_Forwarding_Discriminator.cpp,v 4.5 2001/03/26 21:47:25 schmidt Exp")
-// Bind the Event_Key to the INT_ID.
-int
-Event_Forwarding_Discriminator::bind (Event_Key event_addr,
-  return this->map_.bind (event_addr, cds);
-// Find the Consumer_Dispatch_Set corresponding to the Event_Key.
-int
-Event_Forwarding_Discriminator::find (Event_Key event_addr,
-				      Consumer_Dispatch_Set *&cds)
-  return this->map_.find (event_addr, cds);
-// Unbind (remove) the Event_Key from the map.
-int
-Event_Forwarding_Discriminator::unbind (Event_Key event_addr)
-  Consumer_Dispatch_Set *cds = 0;
-  int result = this->map_.unbind (event_addr, cds);
-  delete cds;
-  return result;
-Event_Forwarding_Discriminator_Iterator::Event_Forwarding_Discriminator_Iterator
-  (Event_Forwarding_Discriminator &rt)
-    : map_iter_ (rt.map_)
-int
-Event_Forwarding_Discriminator_Iterator::next (Consumer_Dispatch_Set *&cds)
-  ACE_Map_Entry<Event_Key, Consumer_Dispatch_Set *> *temp;
-  if (this->map_iter_.next (temp) == 0)
-    return 0;
-  else
-      cds = temp->int_id_;
-      return 1;
-int
-Event_Forwarding_Discriminator_Iterator::advance (void)
-  return this->map_iter_.advance ();
-#endif /* _CONSUMER_MAP_C */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event_Forwarding_Discriminator.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event_Forwarding_Discriminator.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Event_Forwarding_Discriminator.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,65 +0,0 @@
-/* -*- C++ -*- */
-// Event_Forwarding_Discriminator.h,v 4.7 2003/11/01 11:15:21 dhinton Exp
-// = LIBRARY
-//    gateway
-// = FILENAME
-// = AUTHOR
-//    Doug Schmidt
-#ifndef _CONSUMER_MAP_H
-#define _CONSUMER_MAP_H
-#include "ace/Map_Manager.h"
-# pragma once
-#include "ace/Null_Mutex.h"
-#include "Event.h"
-class Event_Forwarding_Discriminator
-  // = TITLE
-  //    Map events to the set of Consumer_Proxies that have subscribed
-  //    to receive the event.
-public:
-  int bind (Event_Key event, Consumer_Dispatch_Set *cds);
-  // Associate Event with the Consumer_Dispatch_Set.
-  int unbind (Event_Key event);
-  // Locate EXID and pass out parameter via INID.  If found,
-  // return 0, else -1.
-  int find (Event_Key event, Consumer_Dispatch_Set *&cds);
-  // Break any association of EXID.
-public:
-  ACE_Map_Manager<Event_Key, Consumer_Dispatch_Set *, ACE_Null_Mutex> map_;
-  // Map that associates <Event_Key>s (external ids) with
-  // <Consumer_Dispatch_Set> *'s <internal IDs>.
-class Event_Forwarding_Discriminator_Iterator
-  // = TITLE
-  //    Define an iterator for the Consumer Map.
-public:
-  Event_Forwarding_Discriminator_Iterator (Event_Forwarding_Discriminator &mm);
-  int next (Consumer_Dispatch_Set *&);
-  int advance (void);
-private:
-  ACE_Map_Iterator<Event_Key, Consumer_Dispatch_Set *, ACE_Null_Mutex> map_iter_;
-  // Map we are iterating over.
-#endif /* _CONSUMER_MAP_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/File_Parser.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/File_Parser.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/File_Parser.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,165 +0,0 @@
-// File_Parser.cpp,v 4.10 2003/12/24 12:49:28 jwillemsen Exp
-#ifndef FILE_PARSER_C
-#define FILE_PARSER_C
-#include "ace/OS_NS_stdio.h"
-#include "ace/OS_NS_stdlib.h"
-# pragma once
-ACE_RCSID(Gateway, File_Parser, "File_Parser.cpp,v 4.10 2003/12/24 12:49:28 jwillemsen Exp")
-// Centerline).
-// File_Parser stuff.
-template <class ENTRY> int
-File_Parser<ENTRY>::open (const char filename[])
-  this->infile_ = ACE_OS::fopen (filename, "r");
-  if (this->infile_ == 0)
-    return -1;
-  else
-    return 0;
-File_Parser<ENTRY>::close (void)
-  return ACE_OS::fclose (this->infile_);
-template <class ENTRY> FP_RETURN_TYPE
-File_Parser<ENTRY>::getword (char buf[])
-  return this->readword (buf);
-// Get the next string from the file via this->readword()
-// Check make sure the string forms a valid number.
-File_Parser<ENTRY>::getint (ACE_INT32 &value)
-  char buf[BUFSIZ];
-#if defined (__GNUG__)
-  // egcs 1.1b can't handle the typedef.
-  FP::Return_Type
-#else  /* ! __GNUG__ */
-  FP_RETURN_TYPE
-#endif /* ! __GNUG__ */
-    read_result = this->readword (buf);
-  if (read_result == FP::RT_SUCCESS)
-      // Check to see if this is the "use the default value" symbol?
-      if (buf[0] == '*')
-        return FP::RT_DEFAULT;
-      else
-          // ptr is used for error checking with ACE_OS::strtol.
-          char *ptr;
-          // try to convert the buf to a decimal number
-          value = ACE_OS::strtol (buf, &ptr, 10);
-          // check if the buf is a decimal or not
-          if (value == 0 && ptr == buf)
-            return FP::RT_PARSE_ERROR;
-          else
-  else
-    return read_result;
-File_Parser<ENTRY>::readword (char buf[])
-  int wordlength = 0;
-  int c;
-  // Skip over leading delimiters and get word.
-  while ((c = getc (this->infile_)) != EOF && c != '\n')
-    if (this->delimiter (c))
-        // We've reached the end of a "word".
-        if (wordlength > 0)
-          break;
-    else
-      buf[wordlength++] = c;
-  buf[wordlength] = '\0';
-  if (c == EOF) {
-    // If EOF is just a delimiter, don't return EOF so that the word
-    // gets processed.
-        ungetc (c, this->infile_);
-    else
-      // else return EOF so that read loops stop
-  else if (c == '\n')
-      // if the EOLINE is just a delimiter, don't return EOLINE
-      // so that the word gets processed
-      else
-        return FP::RT_EOLINE;
-  // Skip comments.
-  if (this->comments (buf[0]))
-      if (this->skipline () == EOF)
-      else
-        return FP::RT_COMMENT;
-  else
-File_Parser<ENTRY>::delimiter (char ch)
-  return ch == ' ' || ch == ',' || ch == '\t';
-File_Parser<ENTRY>::comments (char ch)
-  return ch == '#';
-File_Parser<ENTRY>::skipline (void)
-  // Skip the remainder of the line.
-  int c;
-  while ((c = getc (this->infile_)) != '\n' && c != EOF)
-    continue;
-  return c;
-#endif /* _FILE_PARSER_C */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/File_Parser.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/File_Parser.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/File_Parser.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,93 +0,0 @@
-/* -*- C++ -*- */
-// File_Parser.h,v 4.14 2003/12/24 12:49:28 jwillemsen Exp
-// = LIBRARY
-//    gateway
-// = FILENAME
-//    File_Parser.h
-// = AUTHOR
-//    Doug Schmidt
-#ifndef _FILE_PARSER
-#define _FILE_PARSER
-# pragma once
-class FP
-  // = TITLE
-  //     This class serves as a namespace for the <Return_Type>.
-public:
-  enum Return_Type
-    RT_EOLINE,
-    RT_EOFILE,
-    RT_SUCCESS,
-    RT_COMMENT,
-    RT_DEFAULT,
-    RT_PARSE_ERROR
-class File_Parser
-  // = TITLE
-  //     Class used to parse the configuration file for the
-  //     <Consumer_Map>.
-public:
-  // = Open and Close the file specified
-  int open (const char filename[]);
-  int close (void);
-  virtual FP::Return_Type read_entry (ENTRY &entry,
-                                      int &line_number) = 0;
-  // Pure virtual hook that subclasses override and use the protected
-  // methods to fill in the <entry>.
-protected:
-  FP::Return_Type getword (char buf[]);
-  // Read the next ASCII word.
-  FP::Return_Type getint (ACE_INT32 &value);
-  // Read the next integer.
-  FP::Return_Type readword (char buf[]);
-  // Read the next "word," which is demarcated by <delimiter>s.
-  // @@ This function is inherently flawed since it doesn't take a
-  // count of the size of <buf>...
-  int delimiter (char ch);
-  // Returns true if <ch> is a delimiter, i.e., ' ', ',', or '\t'.
-  int comments (char ch);
-  // Returns true if <ch> is the comment character, i.e., '#'.
-  int skipline (void);
-  // Skips to the remainder of a line, e.g., when we find a comment
-  // character.
-  FILE *infile_;
-  // Pointer to the file we're reading.
-#if defined (ACE_TEMPLATES_REQUIRE_SOURCE)
-#include "File_Parser.cpp"
-#endif /* ACE_TEMPLATES_REQUIRE_SOURCE */
-#if defined (ACE_TEMPLATES_REQUIRE_PRAGMA)
-#pragma implementation ("File_Parser.cpp")
-#endif /* ACE_TEMPLATES_REQUIRE_PRAGMA */
-#endif /* _FILE_PARSER */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Gateway.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Gateway.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Gateway.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,345 +0,0 @@
-// Gateway.cpp,v 4.36 2003/12/30 23:18:58 shuston Exp
-#define ACE_BUILD_SVC_DLL
-#include "ace/OS_NS_string.h"
-#include "Event_Channel.h"
-#include "Gateway.h"
-ACE_RCSID(Gateway, Gateway, "Gateway.cpp,v 4.36 2003/12/30 23:18:58 shuston Exp")
-class ACE_Svc_Export Gateway : public ACE_Service_Object
-  // = TITLE
-  //     Integrates the whole Gateway application.
-  // = DESCRIPTION
-  //     This implementation uses the <Event_Channel> as the basis
-  //     for the <Gateway> routing.
-protected:
-  // = Service configurator hooks.
-  virtual int init (int argc, char *argv[]);
-  // Perform initialization.
-  virtual int fini (void);
-  // Perform termination when unlinked dynamically.
-  virtual int info (char **, size_t) const;
-  // Return info about this service.
-  // = Configuration methods.
-  int parse_connection_config_file (void);
-  // Parse the proxy configuration file.
-  int parse_consumer_config_file (void);
-  // Parse the consumer configuration file.
-  // = Lifecycle management methods.
-  int handle_input (ACE_HANDLE);
-  // Shut down the Gateway when input comes in from the controlling
-  // console.
-  int handle_signal (int signum, siginfo_t * = 0, ucontext_t * = 0);
-  // Shut down the Gateway when a signal arrives.
-  Event_Channel event_channel_;
-  // The Event Channel routes events from Supplier(s) to Consumer(s)
-  // using <Supplier_Handler> and <Consumer_Handler> objects.
-  // Creates the appropriate type of <Connection_Handlers>.
-int
-Gateway::handle_signal (int signum, siginfo_t *, ucontext_t *)
-  ACE_UNUSED_ARG (signum);
-  // Shut down the main event loop.
-  ACE_Reactor::end_event_loop ();
-  return 0;
-int
-Gateway::handle_input (ACE_HANDLE h)
-  char buf[BUFSIZ];
-  // Consume the input...
-  ACE_OS::read (h, buf, sizeof (buf));
-  // Shut us down.
-  return this->handle_signal ((int) h);
-int
-Gateway::init (int argc, char *argv[])
-  // Parse the "command-line" arguments.
-  Options::instance ()->parse_args (argc, argv);
-  ACE_Sig_Set sig_set;
-  sig_set.sig_add (SIGINT);
-  sig_set.sig_add (SIGQUIT);
-  // Register ourselves to receive signals so we can shut down
-  // gracefully.
-  if (ACE_Reactor::instance ()->register_handler (sig_set,
-                                                  this) == -1)
-                       "(%t) %p\n",
-                       "register_handler"),
-                      -1);
-  // Register this handler to receive events on stdin.  We use this to
-  // shutdown the Gateway gracefully.
-  if (ACE_Event_Handler::register_stdin_handler (this,
-                                                 ACE_Thread_Manager::instance ()) == -1)
-                       "(%t) %p\n",
-                       "register_stdin_handler"),
-                      -1);
-  // If this->performance_window_ > 0 start a timer.
-  if (Options::instance ()->performance_window () > 0)
-          (&this->event_channel_, 0,
-           Options::instance ()->performance_window ()) == -1)
-        ACE_ERROR ((LM_ERROR,
-                    "(%t) %p\n",
-                    "schedule_timer"));
-      else
-                    "starting timer for %d seconds...\n",
-                   Options::instance ()->performance_window ()));
-  // Are we running as a connector?
-      this->parse_connection_config_file ();
-      // Parse the consumer config file and build the event forwarding
-      // discriminator.
-      this->parse_consumer_config_file ();
-  // Initialize the Event_Channel.
-  return this->event_channel_.open ();
-// This method is automatically called when the Gateway is shutdown.
-int
-Gateway::fini (void)
-  // Remove the handler that receive events on stdin.  Otherwise, we
-  // will crash on shutdown.
-  ACE_Event_Handler::remove_stdin_handler (ACE_Reactor::instance (),
-                                           ACE_Thread_Manager::instance ());
-  // Close down the event channel.
-  this->event_channel_.close ();
-  // Need to make sure we cleanup this Singleton.
-  delete Options::instance ();
-  return 0;
-// Returns information on the currently active service.
-int
-Gateway::info (char **strp, size_t length) const
-  char buf[BUFSIZ];
-  ACE_OS::sprintf (buf, "%s\t %s", "Gateway daemon",
-             "# Application-level gateway\n");
-  if (*strp == 0 && (*strp = ACE_OS::strdup (buf)) == 0)
-    return -1;
-  else
-    ACE_OS::strncpy (*strp, buf, length);
-  return ACE_OS::strlen (buf);
-// Parse and build the proxy table.
-int
-Gateway::parse_connection_config_file (void)
-  // File that contains the proxy configuration information.
-  Connection_Config_File_Parser connection_file;
-  int file_empty = 1;
-  if (connection_file.open (Options::instance ()->connection_config_file ()) == -1)
-                       "(%t) %p\n",
-                       Options::instance ()->connection_config_file ()),
-                      -1);
-  // Keep track of the previous connection id to make sure the
-  // connection config file isn't corrupted.
-  int previous_connection_id = 0;
-  // Read config file one line at a time.
-  for (Connection_Config_Info pci;
-       connection_file.read_entry (pci, line_number) != FP::RT_EOFILE;
-      file_empty = 0;
-      // First time in check.
-      if (previous_connection_id == 0)
-          previous_connection_id = 1;
-          if (pci.connection_id_ != 1)
-                        "(%t) warning, the first connection id should be 1 not %d\n",
-                        pci.connection_id_));
-      else if (previous_connection_id + 1 != pci.connection_id_)
-                    "(%t) warning, connection ids should keep increasing by 1 and %d + 1 != %d\n",
-                    previous_connection_id,
-      // Update the last connection id to ensure that we monotonically
-      // increase by 1.
-      previous_connection_id = pci.connection_id_;
-      if (Options::instance ()->enabled (Options::DEBUG))
-                    "(%t) conn id = %d, "
-                    "host = %s, "
-                    "remote port = %d, "
-                    "proxy role = %c, "
-                    "max retry timeout = %d, "
-                    "local port = %d, "
-                    "priority = %d\n",
-                    pci.connection_id_,
-                    pci.host_,
-                    pci.remote_port_,
-                    pci.connection_role_,
-                    pci.max_retry_timeout_,
-                    pci.local_port_,
-                    pci.priority_));
-      pci.event_channel_ = &this->event_channel_;
-      // Create the appropriate type of Proxy.
-      Connection_Handler *connection_handler;
-      ACE_ALLOCATOR_RETURN (connection_handler,
-                            this->connection_handler_factory_.make_connection_handler (pci),
-                            -1);
-      // Bind the new Connection_Handler to the connection ID.
-      this->event_channel_.bind_proxy (connection_handler);
-  // Keep track of the next available connection id, which is
-  // necessary for Peers that connect with us, rather than vice versa.
-  Options::instance ()->connection_id () = previous_connection_id + 1;
-  if (file_empty)
-    ACE_ERROR ((LM_WARNING,
-               "warning: connection connection_handler configuration file was empty\n"));
-  return 0;
-int
-Gateway::parse_consumer_config_file (void)
-  // File that contains the consumer event forwarding information.
-  Consumer_Config_File_Parser consumer_file;
-  int line_number = 0;
-  if (consumer_file.open (Options::instance ()->consumer_config_file ()) == -1)
-                       "(%t) %p\n",
-                       Options::instance ()->consumer_config_file ()),
-                      -1);
-  // Read config file line at a time.
-  for (Consumer_Config_Info cci_entry;
-       consumer_file.read_entry (cci_entry, line_number) != FP::RT_EOFILE;
-      file_empty = 0;
-                      "(%t) connection id = %d, payload = %d, "
-                      "number of consumers = %d\n",
-                      cci_entry.connection_id_,
-                      cci_entry.type_,
-                      cci_entry.total_consumers_));
-          for (int i = 0; i < cci_entry.total_consumers_; i++)
-                        "(%t) destination[%d] = %d\n",
-                        i,
-                        cci_entry.consumers_[i]));
-      Consumer_Dispatch_Set *dispatch_set;
-      ACE_NEW_RETURN (dispatch_set,
-                      Consumer_Dispatch_Set,
-                      -1);
-      Event_Key event_addr (cci_entry.connection_id_,
-                            cci_entry.type_);
-      // Add the Consumers to the Dispatch_Set.
-          // Lookup destination and add to Consumer_Dispatch_Set set
-          // if found.
-          if (this->event_channel_.find_proxy (cci_entry.consumers_[i],
-                                               connection_handler) != -1)
-            dispatch_set->insert (connection_handler);
-          else
-                        "(%t) not found: destination[%d] = %d\n",
-                        i,
-      this->event_channel_.subscribe (event_addr, dispatch_set);
-  if (file_empty)
-               "warning: consumer map configuration file was empty\n"));
-  return 0;
-// The following is a "Factory" used by the ACE_Service_Config and
-// svc.conf file to dynamically initialize the state of the Gateway.
-ACE_SVC_FACTORY_DEFINE (Gateway)
-#if defined (ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION)
-template class ACE_Node<Connection_Handler *>;
-template class ACE_Unbounded_Set<Connection_Handler *>;
-#elif defined (ACE_HAS_TEMPLATE_INSTANTIATION_PRAGMA)
-#pragma instantiate ACE_Node<Connection_Handler *>
-#pragma instantiate ACE_Unbounded_Set<Connection_Handler *>
-#endif /* ACE_HAS_EXPLICIT_TEMPLATE_INSTANTIATION */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Gateway.dsp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Gateway.dsp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Gateway.dsp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,98 +0,0 @@
-# Microsoft Developer Studio Project File - Name="Gateway" - Package Owner=<4>
-# Microsoft Developer Studio Generated Build File, Format Version 6.00
-# ** DO NOT EDIT **
-# TARGTYPE "Win32 (x86) Dynamic-Link Library" 0x0102
-CFG=Gateway - Win32 Debug
-!MESSAGE This is not a valid makefile. To build this project using NMAKE,
-!MESSAGE use the Export Makefile command and run
-!MESSAGE
-!MESSAGE NMAKE /f "Gateway.mak".
-!MESSAGE
-!MESSAGE You can specify a configuration when running NMAKE
-!MESSAGE by defining the macro CFG on the command line. For example:
-!MESSAGE
-!MESSAGE NMAKE /f "Gateway.mak" CFG="Gateway - Win32 Debug"
-!MESSAGE
-!MESSAGE Possible choices for configuration are:
-!MESSAGE
-!MESSAGE "Gateway - Win32 Debug" (based on "Win32 (x86) Dynamic-Link Library")
-!MESSAGE
-# Begin Project
-# PROP AllowPerConfigDependencies 0
-# PROP Scc_ProjName ""
-# PROP Scc_LocalPath ""
-CPP=cl.exe
-MTL=midl.exe
-RSC=rc.exe
-# PROP BASE Use_MFC 0
-# PROP BASE Use_Debug_Libraries 1
-# PROP BASE Output_Dir "Debug"
-# PROP BASE Intermediate_Dir "Debug"
-# PROP BASE Target_Dir ""
-# PROP Use_MFC 0
-# PROP Use_Debug_Libraries 1
-# PROP Output_Dir ""
-# PROP Intermediate_Dir "Debug"
-# PROP Ignore_Export_Lib 0
-# PROP Target_Dir ""
-# ADD BASE CPP /nologo /MTd /W3 /Gm /GX /Zi /Od /D "WIN32" /D "_DEBUG" /D "_WINDOWS" /YX /FD /c
-# ADD CPP /nologo /MDd /W3 /Gm /GX /Zi /Od /I "..\..\..\\" /D "_WINDOWS" /D "WIN32" /D "_DEBUG" /FD /c
-# SUBTRACT CPP /YX
-# ADD BASE MTL /nologo /D "_DEBUG" /mktyplib203 /o "NUL" /win32
-# ADD MTL /nologo /D "_DEBUG" /mktyplib203 /o "NUL" /win32
-# ADD BASE RSC /l 0x409 /d "_DEBUG"
-# ADD RSC /l 0x409 /d "_DEBUG"
-BSC32=bscmake.exe
-# ADD BASE BSC32 /nologo
-# ADD BSC32 /nologo
-LINK32=link.exe
-# ADD BASE LINK32 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /nologo /subsystem:windows /dll /debug /machine:I386 /pdbtype:sept
-# ADD LINK32 aced.lib /nologo /subsystem:windows /dll /debug /machine:I386 /pdbtype:sept /libpath:"..\..\..\ace"
-# Begin Target
-# Name "Gateway - Win32 Debug"
-# Begin Source File
-SOURCE=.\Concrete_Connection_Handlers.cpp
-# End Source File
-SOURCE=.\Config_Files.cpp
-# End Source File
-SOURCE=.\Connection_Handler.cpp
-# End Source File
-SOURCE=.\Connection_Handler_Acceptor.cpp
-# End Source File
-SOURCE=.\Connection_Handler_Connector.cpp
-# End Source File
-SOURCE=.\Event_Channel.cpp
-# End Source File
-SOURCE=.\Event_Forwarding_Discriminator.cpp
-# End Source File
-SOURCE=.\File_Parser.cpp
-# End Source File
-SOURCE=.\Gateway.cpp
-# End Source File
-SOURCE=.\Options.cpp
-# End Source File
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Gateway.dsw
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Gateway.dsw	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Gateway.dsw	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,44 +0,0 @@
-Microsoft Developer Studio Workspace File, Format Version 6.00
-# WARNING: DO NOT EDIT OR DELETE THIS WORKSPACE FILE!
-Project: "Gateway"=.\Gateway.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Project: "gatewayd"=.\gatewayd.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-    Begin Project Dependency
-    Project_Dep_Name Gateway
-    End Project Dependency
-Global:
-Package=<5>
-Package=<3>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Gateway.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Gateway.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Gateway.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,33 +0,0 @@
-// -*- C++ -*-
-// Gateway.h,v 4.7 2003/11/01 11:15:21 dhinton Exp
-// = LIBRARY
-//    gateway
-// = FILENAME
-//    Gateway.h
-// = DESCRIPTION
-//    Since the Gateway is an <ACE_Service_Object>, this file defines
-//    the entry point into the Service Configurator framework.
-// = AUTHOR
-//    Doug Schmidt
-#ifndef ACE_GATEWAY
-#define ACE_GATEWAY
-# pragma once
-ACE_SVC_FACTORY_DECLARE (Gateway)
-#endif /* ACE_GATEWAY */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Makefile
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Makefile	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Makefile	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,2497 +0,0 @@
-#	Makefile,v 4.62 2004/01/05 02:42:24 bala Exp
-#	Makefile for the Gateway.
-#	Local macros
-BIN   	= gatewayd
-LIB   	= libGateway.a
-SHLIB	= libGateway.$(SOEXT)
-ACE_SHLIBS += $(ACELIB)
-FILES	= Concrete_Connection_Handlers \
-	  Config_Files \
-	  File_Parser \
-	  Gateway \
-	  Event_Channel \
-	  Event_Forwarding_Discriminator \
-	  Options \
-	  Connection_Handler \
-	  Connection_Handler_Acceptor \
-LSRC	= $(addsuffix .cpp,$(FILES))
-LDLIBS	= -lGateway
-#	Include macros and targets
-include		$(ACE_ROOT)/include/makeinclude/wrapper_macros.GNU
-include		$(ACE_ROOT)/include/makeinclude/macros.GNU
-include		$(ACE_ROOT)/include/makeinclude/rules.common.GNU
-include		$(ACE_ROOT)/include/makeinclude/rules.nonested.GNU
-include		$(ACE_ROOT)/include/makeinclude/rules.lib.GNU
-include		$(ACE_ROOT)/include/makeinclude/rules.bin.GNU
-include		$(ACE_ROOT)/include/makeinclude/rules.local.GNU
-#	Local targets
-#	Dependencies
-# DO NOT DELETE THIS LINE -- g++dep uses it.
-# DO NOT PUT ANYTHING AFTER THIS LINE, IT WILL GO AWAY.
-.obj/Concrete_Connection_Handlers.o .obj/Concrete_Connection_Handlers.so .shobj/Concrete_Connection_Handlers.o .shobj/Concrete_Connection_Handlers.so: Concrete_Connection_Handlers.cpp \
-  Event_Channel.h Connection_Handler_Connector.h \
-  $(ACE_ROOT)/ace/Connector.h \
-  $(ACE_ROOT)/ace/pre.h \
-  $(ACE_ROOT)/ace/Service_Object.h \
-  $(ACE_ROOT)/ace/Shared_Object.h \
-  $(ACE_ROOT)/ace/ACE_export.h \
-  $(ACE_ROOT)/ace/config.h \
-  $(ACE_ROOT)/ace/$(ACE_PLATFORM_CONFIG) \
-  $(ACE_ROOT)/ace/post.h \
-  $(ACE_ROOT)/ace/ace_wchar.h \
-  $(ACE_ROOT)/ace/ace_wchar.inl \
-  $(ACE_ROOT)/ace/os_include/sys/os_types.h \
-  $(ACE_ROOT)/ace/config-all.h \
-  $(ACE_ROOT)/ace/OS_main.h \
-  $(ACE_ROOT)/ace/os_include/os_stddef.h \
-  $(ACE_ROOT)/ace/Shared_Object.i \
-  $(ACE_ROOT)/ace/Svc_Conf_Tokens.h \
-  $(ACE_ROOT)/ace/Event_Handler.h \
-  $(ACE_ROOT)/ace/os_include/os_signal.h \
-  $(ACE_ROOT)/ace/os_include/os_time.h \
-  $(ACE_ROOT)/ace/os_include/os_ucontext.h \
-  $(ACE_ROOT)/ace/Atomic_Op.h \
-  $(ACE_ROOT)/ace/Thread_Mutex.h \
-  $(ACE_ROOT)/ace/OS_NS_Thread.h \
-  $(ACE_ROOT)/ace/Global_Macros.h \
-  $(ACE_ROOT)/ace/OS_Errno.h \
-  $(ACE_ROOT)/ace/os_include/os_errno.h \
-  $(ACE_ROOT)/ace/OS_Errno.inl \
-  $(ACE_ROOT)/ace/Basic_Types.h \
-  $(ACE_ROOT)/ace/os_include/os_limits.h \
-  $(ACE_ROOT)/ace/os_include/os_unistd.h \
-  $(ACE_ROOT)/ace/os_include/os_inttypes.h \
-  $(ACE_ROOT)/ace/os_include/os_stdint.h \
-  $(ACE_ROOT)/ace/os_include/os_stdio.h \
-  $(ACE_ROOT)/ace/os_include/os_stdarg.h \
-  $(ACE_ROOT)/ace/os_include/os_float.h \
-  $(ACE_ROOT)/ace/os_include/os_stdlib.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_wait.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_resource.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_time.h \
-  $(ACE_ROOT)/ace/Basic_Types.i \
-  $(ACE_ROOT)/ace/Default_Constants.h \
-  $(ACE_ROOT)/ace/os_include/os_pthread.h \
-  $(ACE_ROOT)/ace/Base_Thread_Adapter.h \
-  $(ACE_ROOT)/ace/OS_Log_Msg_Attributes.h \
-  $(ACE_ROOT)/ace/iosfwd.h \
-  $(ACE_ROOT)/ace/OS_Log_Msg_Attributes.inl \
-  $(ACE_ROOT)/ace/Base_Thread_Adapter.inl \
-  $(ACE_ROOT)/ace/os_include/sys/os_sem.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_ipc.h \
-  $(ACE_ROOT)/ace/os_include/os_semaphore.h \
-  $(ACE_ROOT)/ace/OS_Memory.h \
-  $(ACE_ROOT)/ace/OS_NS_stdlib.h \
-  $(ACE_ROOT)/ace/OS_NS_stdlib.inl \
-  $(ACE_ROOT)/ace/Object_Manager_Base.h \
-  $(ACE_ROOT)/ace/Cleanup.h \
-  $(ACE_ROOT)/ace/Cleanup.inl \
-  $(ACE_ROOT)/ace/Object_Manager_Base.inl \
-  $(ACE_ROOT)/ace/OS_NS_string.h \
-  $(ACE_ROOT)/ace/OS_NS_string.inl \
-  $(ACE_ROOT)/ace/OS_NS_wchar.h \
-  $(ACE_ROOT)/ace/os_include/os_wchar.h \
-  $(ACE_ROOT)/ace/os_include/os_string.h \
-  $(ACE_ROOT)/ace/os_include/os_ctype.h \
-  $(ACE_ROOT)/ace/OS_NS_wchar.inl \
-  $(ACE_ROOT)/ace/os_include/os_search.h \
-  $(ACE_ROOT)/ace/OS_Memory.inl \
-  $(ACE_ROOT)/ace/OS_NS_signal.h \
-  $(ACE_ROOT)/ace/OS_NS_signal.inl \
-  $(ACE_ROOT)/ace/OS_NS_macros.h \
-  $(ACE_ROOT)/ace/OS_NS_errno.h \
-  $(ACE_ROOT)/ace/OS_NS_errno.inl \
-  $(ACE_ROOT)/ace/OS_NS_Thread.inl \
-  $(ACE_ROOT)/ace/Time_Value.h \
-  $(ACE_ROOT)/ace/Time_Value.inl \
-  $(ACE_ROOT)/ace/OS_NS_sys_time.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_time.inl \
-  $(ACE_ROOT)/ace/OS_NS_sys_mman.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_mman.inl \
-  $(ACE_ROOT)/ace/OS_NS_fcntl.h \
-  $(ACE_ROOT)/ace/os_include/os_fcntl.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_stat.h \
-  $(ACE_ROOT)/ace/OS_NS_fcntl.inl \
-  $(ACE_ROOT)/ace/OS_NS_unistd.h \
-  $(ACE_ROOT)/ace/OS_NS_unistd.inl \
-  $(ACE_ROOT)/ace/OS_NS_sys_utsname.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_utsname.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_utsname.inl \
-  $(ACE_ROOT)/ace/OS_NS_stdio.h \
-  $(ACE_ROOT)/ace/OS_NS_stdio.inl \
-  $(ACE_ROOT)/ace/OS_NS_pwd.h \
-  $(ACE_ROOT)/ace/os_include/os_pwd.h \
-  $(ACE_ROOT)/ace/OS_NS_pwd.inl \
-  $(ACE_ROOT)/ace/os_include/sys/os_mman.h \
-  $(ACE_ROOT)/ace/Thread_Mutex.inl \
-  $(ACE_ROOT)/ace/Atomic_Op_T.h \
-  $(ACE_ROOT)/ace/Atomic_Op_T.i \
-  $(ACE_ROOT)/ace/Guard_T.h \
-  $(ACE_ROOT)/ace/Lock.h \
-  $(ACE_ROOT)/ace/Lock.inl \
-  $(ACE_ROOT)/ace/Guard_T.inl \
-  $(ACE_ROOT)/ace/RW_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/RW_Mutex.h \
-  $(ACE_ROOT)/ace/RW_Mutex.inl \
-  $(ACE_ROOT)/ace/RW_Thread_Mutex.inl \
-  $(ACE_ROOT)/ace/Guard_T.cpp \
-  $(ACE_ROOT)/ace/Atomic_Op_T.cpp \
-  $(ACE_ROOT)/ace/Log_Msg.h \
-  $(ACE_ROOT)/ace/Log_Priority.h \
-  $(ACE_ROOT)/ace/Atomic_Op.i \
-  $(ACE_ROOT)/ace/Synch_Traits.h \
-  $(ACE_ROOT)/ace/Event_Handler.i \
-  $(ACE_ROOT)/ace/DLL.h \
-  $(ACE_ROOT)/ace/os_include/os_dlfcn.h \
-  $(ACE_ROOT)/ace/Service_Object.i \
-  $(ACE_ROOT)/ace/Strategies_T.h \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.h \
-  $(ACE_ROOT)/ace/Functor.h \
-  $(ACE_ROOT)/ace/Functor.i \
-  $(ACE_ROOT)/ace/ACE.h \
-  $(ACE_ROOT)/ace/Flag_Manip.h \
-  $(ACE_ROOT)/ace/Flag_Manip.i \
-  $(ACE_ROOT)/ace/Handle_Ops.h \
-  $(ACE_ROOT)/ace/Handle_Ops.i \
-  $(ACE_ROOT)/ace/Lib_Find.h \
-  $(ACE_ROOT)/ace/Lib_Find.i \
-  $(ACE_ROOT)/ace/Init_ACE.h \
-  $(ACE_ROOT)/ace/Init_ACE.i \
-  $(ACE_ROOT)/ace/Sock_Connect.h \
-  $(ACE_ROOT)/ace/os_include/netinet/os_in.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_socket.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_uio.h \
-  $(ACE_ROOT)/ace/Sock_Connect.i \
-  $(ACE_ROOT)/ace/ACE.i \
-  $(ACE_ROOT)/ace/OS_NS_sys_socket.h \
-  $(ACE_ROOT)/ace/os_include/net/os_if.h \
-  $(ACE_ROOT)/ace/OS_NS_stropts.h \
-  $(ACE_ROOT)/ace/os_include/os_stropts.h \
-  $(ACE_ROOT)/ace/OS_NS_stropts.inl \
-  $(ACE_ROOT)/ace/OS_QoS.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_socket.inl \
-  $(ACE_ROOT)/ace/OS_NS_sys_uio.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_uio.inl \
-  $(ACE_ROOT)/ace/Functor_T.h \
-  $(ACE_ROOT)/ace/Functor_T.i \
-  $(ACE_ROOT)/ace/Functor_T.cpp \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.i \
-  $(ACE_ROOT)/ace/Hash_Map_Manager_T.cpp \
-  $(ACE_ROOT)/ace/Malloc_Base.h \
-  $(ACE_ROOT)/ace/Reactor.h \
-  $(ACE_ROOT)/ace/Timer_Queuefwd.h \
-  $(ACE_ROOT)/ace/Reactor_Timer_Interface.h \
-  $(ACE_ROOT)/ace/Reactor.i \
-  $(ACE_ROOT)/ace/Reactor_Impl.h \
-  $(ACE_ROOT)/ace/Thread_Manager.h \
-  $(ACE_ROOT)/ace/Thread.h \
-  $(ACE_ROOT)/ace/Thread_Adapter.h \
-  $(ACE_ROOT)/ace/Thread_Adapter.inl \
-  $(ACE_ROOT)/ace/Thread.i \
-  $(ACE_ROOT)/ace/Thread_Exit.h \
-  $(ACE_ROOT)/ace/Thread_Control.h \
-  $(ACE_ROOT)/ace/Thread_Control.inl \
-  $(ACE_ROOT)/ace/Condition_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Condition_Thread_Mutex.inl \
-  $(ACE_ROOT)/ace/Unbounded_Queue.h \
-  $(ACE_ROOT)/ace/Node.h \
-  $(ACE_ROOT)/ace/Node.cpp \
-  $(ACE_ROOT)/ace/Unbounded_Queue.inl \
-  $(ACE_ROOT)/ace/Unbounded_Queue.cpp \
-  $(ACE_ROOT)/ace/Containers.h \
-  $(ACE_ROOT)/ace/Containers.i \
-  $(ACE_ROOT)/ace/Containers_T.h \
-  $(ACE_ROOT)/ace/Array_Base.h \
-  $(ACE_ROOT)/ace/Array_Base.inl \
-  $(ACE_ROOT)/ace/Array_Base.cpp \
-  $(ACE_ROOT)/ace/Unbounded_Set.h \
-  $(ACE_ROOT)/ace/Unbounded_Set.inl \
-  $(ACE_ROOT)/ace/Unbounded_Set.cpp \
-  $(ACE_ROOT)/ace/Containers_T.i \
-  $(ACE_ROOT)/ace/Containers_T.cpp \
-  $(ACE_ROOT)/ace/Free_List.h \
-  $(ACE_ROOT)/ace/Free_List.i \
-  $(ACE_ROOT)/ace/Free_List.cpp \
-  $(ACE_ROOT)/ace/Singleton.h \
-  $(ACE_ROOT)/ace/TSS_T.h \
-  $(ACE_ROOT)/ace/TSS_T.inl \
-  $(ACE_ROOT)/ace/TSS_T.cpp \
-  $(ACE_ROOT)/ace/Singleton.i \
-  $(ACE_ROOT)/ace/Singleton.cpp \
-  $(ACE_ROOT)/ace/Object_Manager.h \
-  $(ACE_ROOT)/ace/Recursive_Thread_Mutex.h \
-  $(ACE_ROOT)/ace/Recursive_Thread_Mutex.inl \
-  $(ACE_ROOT)/ace/Static_Object_Lock.h \
-  $(ACE_ROOT)/ace/Object_Manager.i \
-  $(ACE_ROOT)/ace/Managed_Object.h \
-  $(ACE_ROOT)/ace/Managed_Object.i \
-  $(ACE_ROOT)/ace/Managed_Object.cpp \
-  $(ACE_ROOT)/ace/Framework_Component.h \
-  $(ACE_ROOT)/ace/Framework_Component.inl \
-  $(ACE_ROOT)/ace/Framework_Component_T.h \
-  $(ACE_ROOT)/ace/Framework_Component_T.inl \
-  $(ACE_ROOT)/ace/Framework_Component_T.cpp \
-  $(ACE_ROOT)/ace/Thread_Manager.i \
-  $(ACE_ROOT)/ace/Connection_Recycling_Strategy.h \
-  $(ACE_ROOT)/ace/Recyclable.h \
-  $(ACE_ROOT)/ace/Recyclable.inl \
-  $(ACE_ROOT)/ace/Refcountable.h \
-  $(ACE_ROOT)/ace/Refcountable.inl \
-  $(ACE_ROOT)/ace/Hashable.h \
-  $(ACE_ROOT)/ace/Hashable.inl \
-  $(ACE_ROOT)/ace/Reverse_Lock_T.h \
-  $(ACE_ROOT)/ace/Reverse_Lock_T.inl \
-  $(ACE_ROOT)/ace/Reverse_Lock_T.cpp \
-  $(ACE_ROOT)/ace/Strategies_T.i \
-  $(ACE_ROOT)/ace/Strategies_T.cpp \
-  $(ACE_ROOT)/ace/Service_Repository.h \
-  $(ACE_ROOT)/ace/Service_Repository.i \
-  $(ACE_ROOT)/ace/Service_Types.h \
-  $(ACE_ROOT)/ace/Service_Types.i \
-  $(ACE_ROOT)/ace/WFMO_Reactor.h \
-  $(ACE_ROOT)/ace/Synch_Options.h \
-  $(ACE_ROOT)/ace/Synch_Options.i \
-  $(ACE_ROOT)/ace/Handle_Set.h \
-  $(ACE_ROOT)/ace/os_include/sys/os_select.h \
-  $(ACE_ROOT)/ace/Handle_Set.i \
-  $(ACE_ROOT)/ace/os_include/os_strings.h \
-  $(ACE_ROOT)/ace/Connector.cpp \
-  $(ACE_ROOT)/ace/SOCK_Connector.h \
-  $(ACE_ROOT)/ace/SOCK_Stream.h \
-  $(ACE_ROOT)/ace/SOCK_IO.h \
-  $(ACE_ROOT)/ace/SOCK.h \
-  $(ACE_ROOT)/ace/Addr.h \
-  $(ACE_ROOT)/ace/Addr.i \
-  $(ACE_ROOT)/ace/IPC_SAP.h \
-  $(ACE_ROOT)/ace/IPC_SAP.i \
-  $(ACE_ROOT)/ace/SOCK.i \
-  $(ACE_ROOT)/ace/SOCK_IO.i \
-  $(ACE_ROOT)/ace/INET_Addr.h \
-  $(ACE_ROOT)/ace/INET_Addr.i \
-  $(ACE_ROOT)/ace/OS_NS_arpa_inet.h \
-  $(ACE_ROOT)/ace/os_include/arpa/os_inet.h \
-  $(ACE_ROOT)/ace/OS_NS_arpa_inet.inl \
-  $(ACE_ROOT)/ace/SOCK_Stream.i \
-  $(ACE_ROOT)/ace/SOCK_Connector.i \
-  Connection_Handler.h \
-  $(ACE_ROOT)/ace/Service_Config.h \
-  $(ACE_ROOT)/ace/SString.h \
-  $(ACE_ROOT)/ace/SStringfwd.h \
-  $(ACE_ROOT)/ace/String_Base.h \
-  $(ACE_ROOT)/ace/String_Base_Const.h \
-  $(ACE_ROOT)/ace/String_Base.i \
-  $(ACE_ROOT)/ace/Min_Max.h \
-  $(ACE_ROOT)/ace/String_Base.cpp \
-  $(ACE_ROOT)/ace/Auto_Ptr.h \
-  $(ACE_ROOT)/ace/Auto_Ptr.i \
-  $(ACE_ROOT)/ace/Auto_Ptr.cpp \
-  $(ACE_ROOT)/ace/SString.i \
-  $(ACE_ROOT)/ace/XML_Svc_Conf.h \
-  $(ACE_ROOT)/ace/Service_Config.i \
-  $(ACE_ROOT)/ace/Svc_Handler.h \
-  $(ACE_ROOT)/ace/Task.h \
-  $(ACE_ROOT)/ace/Task.i \
-  $(ACE_ROOT)/ace/Task_T.h \
-  $(ACE_ROOT)/ace/Message_Queue.h \
-  $(ACE_ROOT)/ace/Message_Block.h \
-  $(ACE_ROOT)/ace/Message_Block.i \
-  $(ACE_ROOT)/ace/Message_Block_T.h \
-  $(ACE_ROOT)/ace/Message_Block_T.i \
-  $(ACE_ROOT)/ace/Message_Block_T.cpp \
-  $(ACE_ROOT)/ace/IO_Cntl_Msg.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.h \
-  $(ACE_ROOT)/ace/Message_Queue_T.i \
-  $(ACE_ROOT)/ace/Message_Queue_T.cpp \
-  $(ACE_ROOT)/ace/Notification_Strategy.h \
-  $(ACE_ROOT)/ace/Notification_Strategy.inl \
-  $(ACE_ROOT)/ace/Message_Queue.i \
-  $(ACE_ROOT)/ace/Task_T.i \
-  $(ACE_ROOT)/ace/os_include/os_assert.h \
-  $(ACE_ROOT)/ace/Task_T.cpp \
-  $(ACE_ROOT)/ace/Module.h \
-  $(ACE_ROOT)/ace/os_include/os_dirent.h \
-  $(ACE_ROOT)/ace/Module.i \
-  $(ACE_ROOT)/ace/Module.cpp \
-  $(ACE_ROOT)/ace/Stream_Modules.h \
-  $(ACE_ROOT)/ace/Stream_Modules.cpp \
-  $(ACE_ROOT)/ace/Null_Condition.h \
-  $(ACE_ROOT)/ace/Null_Mutex.h \
-  $(ACE_ROOT)/ace/Svc_Handler.cpp \
-  $(ACE_ROOT)/ace/Dynamic.h \
-  $(ACE_ROOT)/ace/Dynamic.i \
-  Config_Files.h File_Parser.h File_Parser.cpp Event.h Options.h \
-  $(ACE_ROOT)/ace/svc_export.h \
-  $(ACE_ROOT)/ace/Lock_Adapter_T.h \
-  $(ACE_ROOT)/ace/Lock_Adapter_T.inl \
-  $(ACE_ROOT)/ace/Lock_Adapter_T.cpp \
-  Connection_Handler_Acceptor.h \
-  $(ACE_ROOT)/ace/Acceptor.h \
-  $(ACE_ROOT)/ace/Acceptor.cpp \
-  $(ACE_ROOT)/ace/OS_NS_sys_select.h \
-  $(ACE_ROOT)/ace/OS_NS_sys_select.inl \
-  $(ACE_ROOT)/ace/SOCK_Acceptor.h \
-  $(ACE_ROOT)/ace/SOCK_Acceptor.i \
-  Consumer_Dispatch_Set.h Event_Forwarding_Discriminator.h \
-  $(ACE_ROOT)/ace/Map_Manager.h \
-  $(ACE_ROOT)/ace/Map_Manager.i \
-  $(ACE_ROOT)/ace/Map_Manager.cpp \
-  Concrete_Connection_Handlers.h
-.obj/Config_Files.o .obj/Config_Files.so .shobj/Config_Files.o .shobj/Config_Files.so: Config_Files.cpp Config_Files.h File_Parser.h \
-  File_Parser.cpp \
-  Event.h \
-  Options.h \
-.obj/File_Parser.o .obj/File_Parser.so .shobj/File_Parser.o .shobj/File_Parser.so: File_Parser.cpp \
-  File_Parser.h File_Parser.cpp
-.obj/Gateway.o .obj/Gateway.so .shobj/Gateway.o .shobj/Gateway.so: Gateway.cpp \
-  $(ACE_ROOT)/ace/Signal.h \
-  $(ACE_ROOT)/ace/Signal.i \
-  Config_Files.h File_Parser.h File_Parser.cpp Event.h \
-  Options.h \
-  Gateway.h
-.obj/Event_Channel.o .obj/Event_Channel.so .shobj/Event_Channel.o .shobj/Event_Channel.so: Event_Channel.cpp Connection_Handler_Connector.h \
-  Event_Channel.h Connection_Handler_Acceptor.h \
-.obj/Event_Forwarding_Discriminator.o .obj/Event_Forwarding_Discriminator.so .shobj/Event_Forwarding_Discriminator.o .shobj/Event_Forwarding_Discriminator.so: Event_Forwarding_Discriminator.cpp \
-  Event_Forwarding_Discriminator.h \
-  Event.h \
-  Consumer_Dispatch_Set.h \
-.obj/Options.o .obj/Options.so .shobj/Options.o .shobj/Options.so: Options.cpp Event.h \
-  Options.h \
-  $(ACE_ROOT)/ace/Get_Opt.h \
-  $(ACE_ROOT)/ace/Get_Opt.i \
-  $(ACE_ROOT)/ace/OS_NS_strings.h \
-  $(ACE_ROOT)/ace/OS_NS_strings.inl
-.obj/Connection_Handler.o .obj/Connection_Handler.so .shobj/Connection_Handler.o .shobj/Connection_Handler.so: Connection_Handler.cpp Event_Channel.h \
-  Connection_Handler_Connector.h \
-.obj/Connection_Handler_Acceptor.o .obj/Connection_Handler_Acceptor.so .shobj/Connection_Handler_Acceptor.o .shobj/Connection_Handler_Acceptor.so: Connection_Handler_Acceptor.cpp \
-.obj/Connection_Handler_Connector.o .obj/Connection_Handler_Connector.so .shobj/Connection_Handler_Connector.o .shobj/Connection_Handler_Connector.so: Connection_Handler_Connector.cpp \
-  $(ACE_ROOT)/ace/os_include/os_netdb.h
-.obj/gatewayd.o .obj/gatewayd.so .shobj/gatewayd.o .shobj/gatewayd.so: gatewayd.cpp \
-  Gateway.h \
-# IF YOU PUT ANYTHING HERE IT WILL GO AWAY
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Makefile.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Makefile.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Makefile.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,19 +0,0 @@
-# Makefile.bor,v 4.2 2003/12/21 10:14:16 jwillemsen Exp
-NAME = gatewayd
-OBJFILES = \
-	$(OBJDIR)\Concrete_Connection_Handlers.obj \
-	$(OBJDIR)\Config_Files.obj \
-	$(OBJDIR)\File_Parser.obj \
-	$(OBJDIR)\Gateway.obj \
-	$(OBJDIR)\Event_Channel.obj \
-	$(OBJDIR)\Event_Forwarding_Discriminator.obj \
-	$(OBJDIR)\Options.obj \
-	$(OBJDIR)\Connection_Handler.obj \
-	$(OBJDIR)\Connection_Handler_Acceptor.obj \
-	$(OBJDIR)\Connection_Handler_Connector.obj \
-	$(OBJDIR)\gatewayd.obj
-!include <$(ACE_ROOT)\apps\build.bor>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Options.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Options.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Options.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,288 +0,0 @@
-// Options.cpp,v 4.20 2003/11/01 11:15:21 dhinton Exp
-#include "Event.h"
-#include "Options.h"
-#include "ace/Get_Opt.h"
-#include "ace/Log_Msg.h"
-#include "ace/OS_NS_strings.h"
-#include "ace/os_include/os_fcntl.h"
-ACE_RCSID(Gateway, Options, "Options.cpp,v 4.20 2003/11/01 11:15:21 dhinton Exp")
-// Static initialization.
-Options *Options::instance_ = 0;
-// Let's have a usage prompt.
-void
-Options::print_usage (void)
-  ACE_DEBUG ((LM_INFO,
-    "gatewayd [-a {C|S}:acceptor-port] [-c {C|S}:connector-port]"
-    " [-C consumer_config_file] [-P connection_config_filename]"
-    " [-q socket_queue_size] [-t OUTPUT_MT|INPUT_MT] [-w time_out]"
-    " [-b] [-d] [-v] [-T]\n"
-    "\t-a Become an Acceptor\n"
-    "\t-b Use blocking connection establishment\n"
-    "\t-c Become a Connector\n"
-    "\t-d debugging\n"
-    "\t-q Use a different socket queue size\n"
-    "\t-t Use a different threading strategy\n"
-    "\t-v Verbose mode\n"
-    "\t-w Time performance for a designated amount of time\n"
-    "\t-C Use a different proxy config filename\n"
-    "\t-P Use a different consumer config filename\n"
-    "\t-T Tracing\n"
-Options *
-Options::instance (void)
-  if (Options::instance_ == 0)
-    ACE_NEW_RETURN (Options::instance_, Options, 0);
-  return Options::instance_;
-Options::Options (void)
-  : locking_strategy_ (0),
-    performance_window_ (0),
-    blocking_semantics_ (ACE_NONBLOCK),
-    socket_queue_size_ (0),
-    threading_strategy_ (REACTIVE),
-    options_ (0),
-    supplier_acceptor_port_ (DEFAULT_GATEWAY_SUPPLIER_PORT),
-    consumer_acceptor_port_ (DEFAULT_GATEWAY_CONSUMER_PORT),
-    supplier_connector_port_ (DEFAULT_PEER_SUPPLIER_PORT),
-    consumer_connector_port_ (DEFAULT_PEER_CONSUMER_PORT),
-    max_timeout_ (MAX_TIMEOUT),
-    max_queue_size_ (MAX_QUEUE_SIZE),
-    connection_id_ (1)
-  ACE_OS::strcpy (this->connection_config_file_, "connection_config");
-  ACE_OS::strcpy (this->consumer_config_file_, "consumer_config");
-int
-Options::enabled (int option) const
-  return ACE_BIT_ENABLED (this->options_, option);
-Options::~Options (void)
-  delete this->locking_strategy_;
-ACE_Lock_Adapter<ACE_SYNCH_MUTEX> *
-Options::locking_strategy (void) const
-  return this->locking_strategy_;
-void
-Options::locking_strategy (ACE_Lock_Adapter<ACE_SYNCH_MUTEX> *ls)
-  this->locking_strategy_ = ls;
-int
-Options::performance_window (void) const
-  return this->performance_window_;
-CONNECTION_ID &
-Options::connection_id (void)
-  return this->connection_id_;
-long
-Options::max_timeout (void) const
-  return this->max_timeout_;
-int
-Options::blocking_semantics (void) const
-  return this->blocking_semantics_;
-int
-Options::socket_queue_size (void) const
-  return this->socket_queue_size_;
-u_long
-Options::threading_strategy (void) const
-  return this->threading_strategy_;
-const char *
-Options::connection_config_file (void) const
-  return this->connection_config_file_;
-const char *
-Options::consumer_config_file (void) const
-  return this->consumer_config_file_;
-u_short
-Options::consumer_acceptor_port (void) const
-  return this->consumer_acceptor_port_;
-u_short
-Options::supplier_acceptor_port (void) const
-  return this->supplier_acceptor_port_;
-u_short
-Options::consumer_connector_port (void) const
-  return this->consumer_connector_port_;
-long
-Options::max_queue_size (void) const
-  return this->max_queue_size_;
-u_short
-Options::supplier_connector_port (void) const
-  return this->supplier_connector_port_;
-// Parse the "command-line" arguments and set the corresponding flags.
-int
-Options::parse_args (int argc, char *argv[])
-  // Assign defaults.
-  ACE_Get_Opt get_opt (argc,
-                       argv,
-                       "a:bC:c:dm:P:p:q:r:t:vw:",
-                       0);
-  for (int c; (c = get_opt ()) != EOF; )
-      switch (c)
-        case 'a':
-            // Become an Acceptor.
-            for (char *flag = ACE_OS::strtok (get_opt.opt_arg (), "|");
-                 flag != 0;
-                 flag = ACE_OS::strtok (0, "|"))
-              if (ACE_OS::strncasecmp (flag, "C", 1) == 0)
-                  ACE_SET_BITS (this->options_,
-                                Options::CONSUMER_ACCEPTOR);
-                  if (ACE_OS::strlen (flag) > 1)
-                    // Set the Consumer Acceptor port number.
-                    this->consumer_acceptor_port_ = ACE_OS::atoi (flag + 2);
-              else if (ACE_OS::strncasecmp (flag, "S", 1) == 0)
-                                Options::SUPPLIER_ACCEPTOR);
-                    // Set the Supplier Acceptor port number.
-                    this->supplier_acceptor_port_ = ACE_OS::atoi (flag + 2);
-          break;
-          /* NOTREACHED */
-        case 'b': // Use blocking connection establishment.
-          this->blocking_semantics_ = 1;
-          break;
-        case 'C': // Use a different proxy config filename.
-          ACE_OS::strncpy (this->consumer_config_file_,
-                           get_opt.opt_arg (),
-                           sizeof this->consumer_config_file_
-                             / sizeof (ACE_TCHAR));
-          break;
-        case 'c':
-            // Become a Connector.
-                 flag != 0;
-                                Options::CONSUMER_CONNECTOR);
-                    // Set the Consumer Connector port number.
-                    this->consumer_connector_port_ = ACE_OS::atoi (flag + 2);
-                                Options::SUPPLIER_CONNECTOR);
-                    // Set the Supplier Connector port number.
-                    this->supplier_connector_port_ = ACE_OS::atoi (flag + 2);
-          break;
-          /* NOTREACHED */
-        case 'd': // We are debugging.
-                        Options::DEBUG);
-          break;
-        case 'P': // Use a different connection config filename.
-          ACE_OS::strncpy (this->connection_config_file_,
-                           sizeof this->connection_config_file_);
-          break;
-        case 'q': // Use a different socket queue size.
-          this->socket_queue_size_ = ACE_OS::atoi (get_opt.opt_arg ());
-          break;
-        case 't': // Use a different threading strategy.
-                 flag != 0;
-              if (ACE_OS::strcmp (flag, "OUTPUT_MT") == 0)
-                ACE_SET_BITS (this->threading_strategy_,
-                              Options::OUTPUT_MT);
-              else if (ACE_OS::strcmp (flag, "INPUT_MT") == 0)
-                              Options::INPUT_MT);
-            break;
-        case 'v': // Verbose mode.
-                        Options::VERBOSE);
-          break;
-        case 'w': // Time performance for a designated amount of time.
-          this->performance_window_ = ACE_OS::atoi (get_opt.opt_arg ());
-          // Use blocking connection semantics so that we get accurate
-          // timings (since all connections start at once).
-          this->blocking_semantics_ = 0;
-          break;
-        default:
-          this->print_usage(); // It's nice to have a usage prompt.
-          break;
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Options.h
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Options.h	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/Options.h	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,200 +0,0 @@
-/* -*- C++ -*- */
-// Options.h,v 4.14 2003/11/09 04:12:07 dhinton Exp
-// = LIBRARY
-//    gateway
-// = FILENAME
-//    Options.h
-// = AUTHOR
-//    Douglas C. Schmidt <schmidt at cs.wustl.edu>
-#ifndef OPTIONS_H
-#define OPTIONS_H
-#include "ace/config-all.h"
-#if !defined (ACE_LACKS_PRAGMA_ONCE)
-# pragma once
-#endif /* ACE_LACKS_PRAGMA_ONCE */
-#include "ace/Lock_Adapter_T.h"
-#include "ace/Synch_Traits.h"
-#include "ace/Thread_Mutex.h"
-class ACE_Svc_Export Options
-  // = TITLE
-  //     Singleton that consolidates all Options for a gatewayd.
-public:
-  // = Options that can be enabled/disabled.
-  enum
-    // = The types of threading strategies.
-    REACTIVE = 0,
-    OUTPUT_MT = 1,
-    INPUT_MT = 2,
-    VERBOSE = 01,
-    DEBUG = 02,
-    SUPPLIER_ACCEPTOR = 04,
-    CONSUMER_ACCEPTOR = 010,
-    SUPPLIER_CONNECTOR = 020,
-    CONSUMER_CONNECTOR = 040
-  static Options *instance (void);
-  // Return Singleton.
-  ~Options (void);
-  // Termination.
-  // Parse the arguments and set the options.
-  void print_usage(void);
-  // Print the gateway supported parameters.
-  // = Accessor methods.
-  int enabled (int option) const;
-  // Determine if an option is enabled.
-  ACE_Lock_Adapter<ACE_SYNCH_MUTEX> *locking_strategy (void) const;
-  // Gets the locking strategy used for serializing access to the
-  // reference count in <ACE_Message_Block>.  If it's 0, then there's
-  // no locking strategy and we're using a REACTIVE concurrency
-  // strategy.
-  void locking_strategy (ACE_Lock_Adapter<ACE_SYNCH_MUTEX> *);
-  // Set the locking strategy used for serializing access to the
-  int performance_window (void) const;
-  // Number of seconds after connection establishment to report
-  // throughput.
-  int blocking_semantics (void) const;
-  // 0 == blocking connects, ACE_NONBLOCK == non-blocking connects.
-  int socket_queue_size (void) const;
-  // Size of the socket queue (0 means "use default").
-  u_long threading_strategy (void) const;
-  // i.e., REACTIVE, OUTPUT_MT, and/or INPUT_MT.
-  u_short supplier_acceptor_port (void) const;
-  // Our acceptor port number, i.e., the one that we passively listen
-  // on for connections to arrive from a gatewayd and create a
-  // Supplier.
-  u_short consumer_acceptor_port (void) const;
-  // Consumer.
-  u_short supplier_connector_port (void) const;
-  // The connector port number, i.e., the one that we use to actively
-  // establish connections with a gatewayd and create a Supplier.
-  u_short consumer_connector_port (void) const;
-  // establish connections with a gatewayd and create a Consumer.
-  const char *connector_host (void) const;
-  // Our connector port host, i.e., the host running the gatewayd
-  // process.
-  const char *connection_config_file (void) const;
-  // Name of the connection configuration file.
-  const char *consumer_config_file (void) const;
-  // Name of the consumer map configuration file.
-  long max_timeout (void) const;
-  // The maximum retry timeout delay.
-  long max_queue_size (void) const;
-  // The maximum size of the queue.
-  CONNECTION_ID &connection_id (void);
-  // Returns a reference to the next available connection id;
-private:
-  enum
-    MAX_QUEUE_SIZE = 1024 * 1024 * 16,
-    // We'll allow up to 16 megabytes to be queued per-output proxy.
-    MAX_TIMEOUT = 32
-    // The maximum timeout for trying to re-establish connections.
-  Options (void);
-  // Initialization.
-  static Options *instance_;
-  // Options Singleton instance.
-  ACE_Lock_Adapter<ACE_SYNCH_MUTEX> *locking_strategy_;
-  // Points to the locking strategy used for serializing access to the
-  // strategy.
-  int performance_window_;
-  // throughput.
-  int blocking_semantics_;
-  int socket_queue_size_;
-  u_long threading_strategy_;
-  u_long options_;
-  // Flag to indicate if we want verbose diagnostics.
-  u_short supplier_acceptor_port_;
-  // The acceptor port number, i.e., the one that we passively listen
-  // Supplier.
-  u_short consumer_acceptor_port_;
-  // Consumer.
-  u_short supplier_connector_port_;
-  u_short consumer_connector_port_;
-  long max_timeout_;
-  long max_queue_size_;
-  CONNECTION_ID connection_id_;
-  // The next available connection id.
-  char connection_config_file_[MAXPATHLEN + 1];
-  char consumer_config_file_[MAXPATHLEN + 1];
-#endif /* OPTIONS_H */
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/connection_config
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/connection_config	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/connection_config	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,55 +0,0 @@
-# Configuration file that the gatewayd process uses to determine
-# connection information about proxies.
-# The following provides an explanation for the fields in this file,
-# and how they relate to fields in the corresponding "consumer_config"
-# file.
-# 1. Connection ID -- Each Connection Handler is given a unique ID
-#    that is used in the "consumer_config" file to specify to which
-#    Consumers the Event Channel will forward incoming events from
-#    Suppliers using that connection.  The Connection ID field is the
-#    "key" that is used to match up connections in this file with the
-#    Consumer subscription requests in the "consumer_config" file.
-#    The connection ids should start at 1 and monotonically increase
-#    by increments of 1.  This makes it possible for the Gateway to
-#    properly allocate connection ids for Peers that connect to it.
-# 2. Host -- The host name where the Supplier/Consumer peerd
-#    process is running.
-# 3. Remote Port -- The port number where the remote
-#    Supplier/Consumer peerd process is listening on.
-#    If this is a '*' character it is an indication to the
-#    Gateway to use the "default value," e.g., which can be provided
-#    on the command-line, etc.
-# 4. Handler Role -- i.e., Consumer ('C') or Supplier ('S')
-# 5. Max Retry Timeout -- The maximum amount of time that we'll
-#    wait between retry attempts (these start at 1 second and
-#    double until they reach the Max Retry Timeout).
-# 6. Local Port -- The port number that we want to use for
-#    our local Proxy connection.  If this is the value 0 or the '*'
-#    character, then we'll let the socket implementation pick this
-#    value for us.
-# 7. Priority -- Each Consumer/Supplier can be given a priority
-#    that will determine its importance relative to other
-#    Consumers/Suppliers (this feature isn't implemented yet).
-# Connection  Host         Remote  Handler  Max Retry   Local  Priority
-# ID		           Port    Role     Timeout     Port
-   1          localhost    *       S	    *	        *      1
-   2          localhost    *       C	    *	        *      1
-#  3          mambo.cs     *       C	    *	        *      1
-#  4          lambada.cs   *       C	    *	        *      1
-#  5          lambada.cs   *       C	    *	        *      1
-#  6          tango.cs     *       C	    *	        *      1
-#  7          tango.cs     *       S	    *	        *      1
-#  8          tango.cs     *       C	    *	        *      1
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/consumer_config
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/consumer_config	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/consumer_config	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,35 +0,0 @@
-# Configuration file that the gatewayd process uses to determine which
-# Consumers will receive events from which Suppliers.  For now, the
-# Gateway only allows Consumers to "subscribe" to receive events from
-# particular Suppliers.  A more flexible implementation will allow
-# Consumers to subscribe to particular types of events, as well.
-# and how they relate to fields in the corresponding "connection_config"
-# file.
-#    Suppliers.  The Connection ID field is the "key" that is used to
-#    match up Consumer subscription requests in this file with
-#    connections in the "connection_config" file.
-# 2. Event Type -- Indicates the type of the event.  Consumers
-#    can use this to only subscribe to certain types of events.
-#    This feature is currently not implemented.
-# 3. Consumers -- Indicates which Consumers will receive events sent
-#    from this Proxy/Supplier ID, i.e., Consumers can subscribe to
-#    receive events from particular Suppliers.  Note that more than
-#    one Consumer can subscribe to the same Supplier event, i.e.,
-#    we support logical "multicast" (which is currently implemented
-#    using multi-point unicast via TCP/IP).
-# Connection  Event  Consumers
-# ID          Type
-  1           0	     2
-# 2           0	     3,4
-# 3           0	     4
-# 4	      0	     5
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/gateway.mpc
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/gateway.mpc	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/gateway.mpc	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,29 +0,0 @@
-// -*- MPC -*-
-// gateway.mpc,v 1.2 2003/12/23 20:23:20 dhinton Exp
-project(Gateway) : acelib {
-  sharedname = Gateway
-  Source_Files {
-    Concrete_Connection_Handlers.cpp
-    Config_Files.cpp
-    File_Parser.cpp
-    Gateway.cpp
-    Event_Channel.cpp
-    Event_Forwarding_Discriminator.cpp
-    Options.cpp
-    Connection_Handler.cpp
-    Connection_Handler_Acceptor.cpp
-    Connection_Handler_Connector.cpp
-project(gatewayd) : aceexe {
-  after += Gateway
-  libs  += Gateway
-  Source_Files {
-    gatewayd.cpp
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/gatewayd.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/gatewayd.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/gatewayd.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,68 +0,0 @@
-// gatewayd.cpp,v 4.13 2003/12/30 23:18:58 shuston Exp
-// = LIBRARY
-//    gateway
-// = FILENAME
-//    peerd.h
-// = DESCRIPTION
-//    Driver for the gateway daemon (gatewayd).  Note that this is
-//    completely generic code due to the Service Configurator
-//    framework!
-// = AUTHOR
-#include "ace/OS_NS_unistd.h"
-#include "ace/Service_Config.h"
-#include "ace/Service_Object.h"
-ACE_RCSID (Gateway,
-           gatewayd,
-           "gatewayd.cpp,v 4.13 2003/12/30 23:18:58 shuston Exp")
-int
-main (int argc, char *argv[])
-  if (ACE_OS::access (ACE_DEFAULT_SVC_CONF, F_OK) != 0)
-      // Use static linking.
-      ACE_Service_Object_Ptr sp = ACE_SVC_INVOKE (Gateway);
-      if (sp->init (argc - 1, argv + 1) == -1)
-        ACE_ERROR_RETURN ((LM_ERROR,
-                           "%p\n",
-                           "init"),
-                          1);
-      // Run forever, performing the configured services until we
-      // are shut down by a SIGINT/SIGQUIT signal.
-      ACE_Reactor::run_event_loop ();
-      // Destructor of <ACE_Service_Object_Ptr> automagically call
-      // <fini>.
-  else
-      if (ACE_Service_Config::open (argc, argv) == -1)
-                           "%p\n",
-                           "open"),
-                          1);
-      else // Use dynamic linking.
-        // Run forever, performing the configured services until we are
-        // shut down by a signal (e.g., SIGINT or SIGQUIT).
-  return 0;
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/gatewayd.dsp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/gatewayd.dsp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/gatewayd.dsp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,59 +0,0 @@
-# Microsoft Developer Studio Project File - Name="gatewayd" - Package Owner=<4>
-# TARGTYPE "Win32 (x86) Console Application" 0x0103
-CFG=gatewayd - Win32 Debug
-!MESSAGE
-!MESSAGE NMAKE /f "gatewayd.mak".
-!MESSAGE
-!MESSAGE
-!MESSAGE NMAKE /f "gatewayd.mak" CFG="gatewayd - Win32 Debug"
-!MESSAGE
-!MESSAGE
-!MESSAGE "gatewayd - Win32 Debug" (based on "Win32 (x86) Console Application")
-!MESSAGE
-# Begin Project
-CPP=cl.exe
-RSC=rc.exe
-# PROP Use_MFC 0
-# ADD BASE CPP /nologo /W3 /Gm /GX /Zi /Od /D "WIN32" /D "_DEBUG" /D "_CONSOLE" /D "_MBCS" /YX /FD /c
-# ADD CPP /nologo /MDd /W3 /Gm /GX /Zi /Od /I "..\..\..\\" /D "_CONSOLE" /D "_MBCS" /D "WIN32" /D "_DEBUG" /FD /c
-# SUBTRACT CPP /YX
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD BASE LINK32 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /nologo /subsystem:console /debug /machine:I386 /pdbtype:sept
-# ADD LINK32 Gateway.lib aced.lib /nologo /subsystem:console /debug /machine:I386 /pdbtype:sept /libpath:"..\..\..\ace"
-# Begin Target
-# Name "gatewayd - Win32 Debug"
-SOURCE=.\gatewayd.cpp
-# End Source File
-# End Target
-# End Project
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/svc.conf
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/svc.conf	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Gateway/svc.conf	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,3 +0,0 @@
-#static Svc_Manager "-d -p 2913"
-dynamic Gateway Service_Object * ./Gateway:_make_Gateway() active "-b -d -c C|S -a C|S -P connection_config -C consumer_config"
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Makefile
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Makefile	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Makefile	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,26 +0,0 @@
-#	$Id: Makefile	1.1	10/18/96
-#	Makefile for the Gateway application
-#	Local macros
-INFO  = README
-DIRS  =	Gateway \
-        Peer
-include	$(ACE_ROOT)/include/makeinclude/rules.nested.GNU
-include	$(ACE_ROOT)/include/makeinclude/rules.nolocal.GNU
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Makefile.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Makefile.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Makefile.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,7 +0,0 @@
-# Makefile.bor,v 4.4 2003/12/21 10:14:16 jwillemsen Exp
-DIRS = Gateway Peer
-!include <$(ACE_ROOT)\include\makeinclude\recurse.bor>
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/Makefile
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/Makefile	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/Makefile	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,733 +0,0 @@
-#	Makefile,v 4.59 2004/01/05 02:42:24 bala Exp
-#	Makefile for the Peer test driver portion of the Gateway application
-#	Local macros
-BIN   	= peerd
-LIB   	= libPeer.a
-SHLIB	= libPeer.$(SOEXT)
-FILES	= Options \
-	  Peer
-LDLIBS	= -lPeer
-#	Local targets
-INCLDIRS += -I../Gateway
-#	Dependencies
-.obj/Options.o .obj/Options.so .shobj/Options.o .shobj/Options.so: Options.cpp \
-  $(ACE_ROOT)/ace/OS_NS_strings.inl \
-  Options.h ../Gateway/Event.h \
-.obj/Peer.o .obj/Peer.so .shobj/Peer.o .shobj/Peer.so: Peer.cpp \
-  Peer.h \
-.obj/peerd.o .obj/peerd.so .shobj/peerd.o .shobj/peerd.so: peerd.cpp Peer.h \
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/Makefile.bor
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/Makefile.bor	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/Makefile.bor	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,11 +0,0 @@
-# Makefile.bor,v 4.3 2003/12/21 10:14:16 jwillemsen Exp
-NAME = peerd
-OBJFILES = \
-        $(OBJDIR)\Peer.obj \
-        $(OBJDIR)\peerd.obj
Modified: trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/Options.cpp
--- trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/Options.cpp	2007-03-14 15:35:17 UTC (rev 1219)
+++ trunk/MgDev/Oem/ACE/ACE_wrappers/apps/Gateway/Peer/Options.cpp	2007-03-14 16:25:26 UTC (rev 1220)
@@ -1,199 +0,0 @@
-// Options.cpp,v 4.18 2003/12/30 23:18:58 shuston Exp
-#include "ace/OS_Memory.h"
-ACE_RCSID(Peer, Options, "Options.cpp,v 4.18 2003/12/30 23:18:58 shuston Exp")
-void
-Options::print_usage_and_die (void)
-  ACE_DEBUG ((LM_DEBUG,
-              "%n [-a {C|S}:acceptor-port] [-c {C|S}:connector-port] [-C connection-id] [-h gateway-host] [-q max-queue-size] [-t timeout] [-v]\n"));
-  ACE_OS::exit (1);
-  : options_ (0),
-    supplier_acceptor_port_ (DEFAULT_PEER_SUPPLIER_PORT),
-    consumer_acceptor_port_ (DEFAULT_PEER_CONSUMER_PORT),
-    supplier_connector_port_ (DEFAULT_GATEWAY_SUPPLIER_PORT),
-    consumer_connector_port_ (DEFAULT_GATEWAY_CONSUMER_PORT),
-    connector_host_ (ACE_DEFAULT_SERVER_HOST),
-    timeout_ (0),
-    connection_id_ (0)
-  char *timeout = ACE_OS::getenv ("TIMEOUT");
-  if (timeout == 0)
-    this->timeout_ = Options::DEFAULT_TIMEOUT;
-  else
-    this->timeout_ = ACE_OS::atoi (timeout);
-Options *
-long
-Options::timeout (void) const
-  return this->timeout_;
-CONNECTION_ID &
-long
-u_short
-u_short
-u_short
-u_short
-const char *
-Options::connector_host (void) const
-  return this->connector_host_;
-int
-void
-  ACE_Get_Opt get_opt (argc, argv, "a:c:C:h:m:t:v", 0);
-  for (int c; (c = get_opt ()) != -1; )
-      switch (c)
-        case 'a':
-                 flag != 0;
-          break;
-          /* NOTREACHED */
-        case 'c':
-                 flag != 0;
