[mapguide-commits] r1230 - trunk/MgDev
svn_mapguide at osgeo.org
Wed Mar 14 18:15:32 EDT 2007
Author: waltweltonlair
Date: 2007-03-14 18:15:32 -0400 (Wed, 14 Mar 2007)
New Revision: 1230
trunk/MgDev/acinclude.m4
Fix underquoted definition warnings when running aclocal.
Modified: trunk/MgDev/acinclude.m4
--- trunk/MgDev/acinclude.m4 2007-03-14 20:21:17 UTC (rev 1229)
+++ trunk/MgDev/acinclude.m4 2007-03-14 22:15:32 UTC (rev 1230)
@@ -4,25 +4,25 @@
dnl AC_HELP_STRING, so let's try to call it if we can.
dnl Note: this define must be on one line so that it can be properly returned
dnl as the help string.
-AC_DEFUN(MAP_HELP_STRING,[ifelse(regexp(AC_ACVERSION, 2\.1), -1, AC_HELP_STRING($1,$2),[ ]$1 substr([ ],len($1))$2)])dnl
+AC_DEFUN([MAP_HELP_STRING],[ifelse(regexp(AC_ACVERSION, 2\.1), -1, AC_HELP_STRING($1,$2),[ ]$1 substr([ ],len($1))$2)])dnl
dnl MAP_SUBST(VARIABLE)
dnl Makes VARIABLE available in generated files
dnl (do not use @variable@ in Makefiles, but $(variable))
-AC_DEFUN(MAP_SUBST,[
+AC_DEFUN([MAP_SUBST],[
MAP_VAR_SUBST="$MAP_VAR_SUBST $1"
AC_SUBST($1)
dnl MAP_FAST_OUTPUT(FILENAME)
dnl Perform substitutions on FILENAME (Makefiles only)
-AC_DEFUN(MAP_FAST_OUTPUT,[
+AC_DEFUN([MAP_FAST_OUTPUT],[
MAP_FAST_OUTPUT_FILES="$MAP_FAST_OUTPUT_FILES $1"
dnl MAP_GEN_CONFIG_VARS
dnl Creates config_vars.mk
-AC_DEFUN(MAP_GEN_CONFIG_VARS,[
+AC_DEFUN([MAP_GEN_CONFIG_VARS],[
MAP_SUBST(map_srcdir)
MAP_SUBST(bindir)
MAP_SUBST(sbindir)
@@ -64,14 +64,14 @@
dnl #
dnl # MAP_GENERATE_MAKEFILES
dnl # Creates Makefiles
-AC_DEFUN(MAP_GENERATE_MAKEFILES,[
+AC_DEFUN([MAP_GENERATE_MAKEFILES],[
$SHELL $srcdir/fastgen.sh $srcdir $ac_cv_mkdir_p $MAP_FAST_OUTPUT_FILES
dnl ## MAP_OUTPUT(file)
dnl ## adds "file" to the list of files generated by AC_OUTPUT
dnl ## This macro can be used several times.
-AC_DEFUN(MAP_OUTPUT, [
+AC_DEFUN([MAP_OUTPUT], [
MAP_OUTPUT_FILES="$MAP_OUTPUT_FILES $1"
@@ -80,7 +80,7 @@
dnl
dnl If rlim_t is not defined, define it to int
dnl
-AC_DEFUN(MAP_DEFINE_TYPE_RLIM_T, [
+AC_DEFUN([MAP_DEFINE_TYPE_RLIM_T], [
AC_CACHE_CHECK([for rlim_t], ac_cv_type_rlim_t, [
AC_TRY_COMPILE([
#include <sys/types.h>
@@ -105,14 +105,14 @@
dnl Autodesk MapGuide Open Source will use while generating scripts
dnl like autoconf and the default config file.
-AC_DEFUN(MAP_SUBST_EXPANDED_ARG,[
+AC_DEFUN([MAP_SUBST_EXPANDED_ARG],[
APR_EXPAND_VAR(exp_$1, [$]$1)
MAP_SUBST(exp_$1)
APR_PATH_RELATIVE(rel_$1, [$]exp_$1, ${prefix})
MAP_SUBST(rel_$1)
-AC_DEFUN(MAP_EXPORT_ARGUMENTS,[
+AC_DEFUN([MAP_EXPORT_ARGUMENTS],[
MAP_SUBST_EXPANDED_ARG(exec_prefix)
MAP_SUBST_EXPANDED_ARG(bindir)
MAP_SUBST_EXPANDED_ARG(sbindir)
More information about the mapguide-commits
