[mapguide-commits] r1231 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Mar 14 18:40:40 EDT 2007
Author: jasonnogar
Date: 2007-03-14 18:40:40 -0400 (Wed, 14 Mar 2007)
New Revision: 1231
   trunk/MgDev/Common/Stylization/SE_Bounds.cpp
   trunk/MgDev/Common/Stylization/SE_ConvexHull.h
   trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp
   trunk/MgDev/Common/Stylization/SE_LineBuffer.h
* Add Clone method to SE_LineBuffer
* Cleanup SE_Bounds (remove redundant struct)
Modified: trunk/MgDev/Common/Stylization/SE_Bounds.cpp
--- trunk/MgDev/Common/Stylization/SE_Bounds.cpp	2007-03-14 22:15:32 UTC (rev 1230)
+++ trunk/MgDev/Common/Stylization/SE_Bounds.cpp	2007-03-14 22:40:40 UTC (rev 1231)
@@ -89,30 +89,6 @@
-struct SimplePoint
-    double x;
-    double y;
-struct SimplePointUtil
-    SE_INLINE double x(SimplePoint* point)
-        return point->x;
-    SE_INLINE double y(SimplePoint* point)
-        return point->y;
-    SE_INLINE bool equal(SimplePoint* a, SimplePoint* b)
-        return a->x == b->x && a->y == b->y;
 void SE_Bounds::Free()
     pool->FreeBounds(this);
@@ -238,7 +214,7 @@
     double* last = vec + pnts - 2;
     double* first = vec;
-    SE_Bounds* ubounds = AndrewHull<SimplePoint*, SimplePointUtil>((SimplePoint*)first, (SimplePoint*)last, pnts/2, pool);
+    SE_Bounds* ubounds = AndrewHull<SimpleITER, SimplePOINT>((SimpleITER)first, (SimpleITER)last, pnts/2, pool);
     if (usize > 4096)
         delete[] vec;
Modified: trunk/MgDev/Common/Stylization/SE_ConvexHull.h
--- trunk/MgDev/Common/Stylization/SE_ConvexHull.h	2007-03-14 22:15:32 UTC (rev 1230)
+++ trunk/MgDev/Common/Stylization/SE_ConvexHull.h	2007-03-14 22:40:40 UTC (rev 1231)
@@ -29,6 +29,8 @@
+typedef struct { double x, y; }* SimpleITER;
 struct SimplePOINT
     SE_INLINE double x(void* point)
@@ -50,6 +52,8 @@
+// Monotone Chain Convex Hull Algorithm (Andrew, 1979)
+// Input is a lexographically sorted (by x, then y) list of points.
 template<class ITER, class POINT> SE_Bounds* AndrewHull(ITER spoints, ITER epoints, int npoints, SE_LineBufferPool* pool)
     POINT pnt;
Modified: trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp
--- trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp	2007-03-14 22:15:32 UTC (rev 1230)
+++ trunk/MgDev/Common/Stylization/SE_LineBuffer.cpp	2007-03-14 22:40:40 UTC (rev 1231)
@@ -40,7 +40,12 @@
     SE_INLINE void _LineTo(double x, double y);
     SE_INLINE void SetBounds(double minx, double miny, double maxx, double maxy);
     SE_INLINE void SetBounds(SE_Bounds* bounds);
     void SetToTransform(const SE_Matrix& xform, LineBuffer* src);
+    void SetToCopy(SE_LineStorage* src);
+private:
+    SE_INLINE double& _LastX() { return m_last_x; }
+    SE_INLINE double& _LastY() { return m_last_y; }
 SE_LineStorage::SE_LineStorage(int size) :
@@ -166,6 +171,28 @@
     xform.transform(m_last_x, m_last_y);
+void SE_LineStorage::SetToCopy(SE_LineStorage* src)
+    m_cur_pts = m_cur_types = 0;
+    m_cur_cntr = -1;
+    m_last_x = src->_LastX();
+    m_last_y = src->_LastY();
+    m_bounds = src->bounds();
+    m_geom_type = src->geom_type();
+    int grow_types = src->point_count() - m_types_len;
+    if (grow_types > 0)
+        EnsurePoints(m_types_len + grow_types);
+    int grow_cntrs = src->cntr_count() - m_cntrs_len;
+    if (grow_cntrs > 0)
+        EnsureContours(m_cntrs_len + grow_cntrs);
+    memcpy(m_pts, src->points(), sizeof(double)*2*src->point_count());
+    memcpy(m_types, src->types(), src->point_count());
+    memcpy(m_cntrs, src->cntrs(), sizeof(int)*src->cntr_count());
+    m_cur_pts = src->point_count()*2;
+    m_cur_types = src->point_count();
+    m_cur_cntr = src->cntr_count() - 1;
 inline void SineCosineMax(double sAng, double sSine, double sCosine, double eAng, double eSine, double eCosine, double &maxSine, double &maxCosine)
     int quadrants = ((int)(sAng*2.0/M_PI) << 2) | (int)(eAng*2.0/M_PI);
@@ -749,6 +776,37 @@
+SE_LineBuffer* SE_LineBuffer::Clone()
+    SE_LineBuffer* clone = m_pool->NewLineBuffer(m_npts);
+    clone->m_src_lb = m_src_lb;
+    clone->m_start[0] = m_start[0];
+    clone->m_start[1] = m_start[1];
+    clone->m_last[0] = m_last[0];
+    clone->m_last[1] = m_last[1];
+    clone->m_compute_bounds = m_compute_bounds;
+    clone->m_xf = m_xf;
+    clone->m_xf_tol = m_xf_tol;
+    clone->m_xf_weight = m_xf_weight;
+    if (m_xf_bounds)
+        clone->m_xf_bounds = m_xf_bounds->Clone();
+    if (m_inst_bounds)
+        clone->m_inst_bounds = m_inst_bounds->Clone();
+    clone->m_xf_buf->SetToCopy(m_xf_buf);
+    clone->m_inst_buf->SetToCopy(m_inst_buf);
+    int grow_segs = m_nsegs - clone->m_max_segs;
+    if (grow_segs > 0)
+        ResizeBuffer((void**)&clone->m_segs, sizeof(double), grow_segs, clone->m_nsegs, clone->m_max_segs);
+    int grow_pts = m_npts - clone->m_max_pts;
+    if (grow_pts > 0)
+        ResizeBuffer((void**)&clone->m_pts, sizeof(double), grow_pts, clone->m_npts, clone->m_max_pts);
+    memcpy(clone->m_pts, m_pts, sizeof(double)*m_npts);
+    memcpy(clone->m_segs, m_segs, sizeof(SE_LB_SegType)*m_nsegs);
+    clone->m_nsegs = m_nsegs;
+    clone->m_npts = m_npts;
+    return clone;
 SE_LineBufferPool::~SE_LineBufferPool()
     while (!m_lb_pool.empty())
@@ -762,7 +820,6 @@
     if (!m_lb_pool.empty())
         SE_LineBuffer* lb = m_lb_pool.pop();
-        lb->Reset();
         return lb;
     else
@@ -775,6 +832,7 @@
 void SE_LineBufferPool::FreeLineBuffer(SE_LineBuffer* lb)
+    lb->Reset();
     m_lb_pool.push(lb);
Modified: trunk/MgDev/Common/Stylization/SE_LineBuffer.h
--- trunk/MgDev/Common/Stylization/SE_LineBuffer.h	2007-03-14 22:15:32 UTC (rev 1230)
+++ trunk/MgDev/Common/Stylization/SE_LineBuffer.h	2007-03-14 22:40:40 UTC (rev 1231)
@@ -73,6 +73,8 @@
     STYLIZATION_API static void LongestEdge(LineBuffer* lb, double& x0, double& y0, double& x1, double& y1);
+    STYLIZATION_API SE_LineBuffer* Clone();
 private:
     void Reset();
     void ResizeBuffer(void** buffer, int unitsize, int mininc, int cur_pts, int& max_pts);
More information about the mapguide-commits mailing list
