[mapguide-commits] r1274 - trunk/MgDev/Web/src/mapviewerjava
svn_mapguide at osgeo.org
Fri Mar 16 23:51:36 EDT 2007
Author: waltweltonlair
Date: 2007-03-16 23:51:36 -0400 (Fri, 16 Mar 2007)
New Revision: 1274
trunk/MgDev/Web/src/mapviewerjava/ajaxviewer.jsp
trunk/MgDev/Web/src/mapviewerjava/ajaxviewerabout.jsp
trunk/MgDev/Web/src/mapviewerjava/buffer.jsp
trunk/MgDev/Web/src/mapviewerjava/bufferui.jsp
trunk/MgDev/Web/src/mapviewerjava/colorpicker.jsp
trunk/MgDev/Web/src/mapviewerjava/common.jsp
trunk/MgDev/Web/src/mapviewerjava/dwfviewer.jsp
trunk/MgDev/Web/src/mapviewerjava/formframe.jsp
trunk/MgDev/Web/src/mapviewerjava/gettingstarted.jsp
trunk/MgDev/Web/src/mapviewerjava/index.jsp
trunk/MgDev/Web/src/mapviewerjava/init.jsp
trunk/MgDev/Web/src/mapviewerjava/legend.jsp
trunk/MgDev/Web/src/mapviewerjava/legendctrl.jsp
trunk/MgDev/Web/src/mapviewerjava/legendui.jsp
trunk/MgDev/Web/src/mapviewerjava/mainframe.jsp
trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp
trunk/MgDev/Web/src/mapviewerjava/measure.jsp
trunk/MgDev/Web/src/mapviewerjava/measureui.jsp
trunk/MgDev/Web/src/mapviewerjava/printablepage.jsp
trunk/MgDev/Web/src/mapviewerjava/printablepageui.jsp
trunk/MgDev/Web/src/mapviewerjava/product.jsp
trunk/MgDev/Web/src/mapviewerjava/propertyctrl.jsp
trunk/MgDev/Web/src/mapviewerjava/search.jsp
trunk/MgDev/Web/src/mapviewerjava/searchprompt.jsp
trunk/MgDev/Web/src/mapviewerjava/selectwithin.jsp
trunk/MgDev/Web/src/mapviewerjava/selectwithinui.jsp
trunk/MgDev/Web/src/mapviewerjava/setselection.jsp
trunk/MgDev/Web/src/mapviewerjava/statusbar.jsp
trunk/MgDev/Web/src/mapviewerjava/taskbar.jsp
trunk/MgDev/Web/src/mapviewerjava/taskframe.jsp
trunk/MgDev/Web/src/mapviewerjava/tasklist.jsp
trunk/MgDev/Web/src/mapviewerjava/taskpane.jsp
trunk/MgDev/Web/src/mapviewerjava/toolbar.jsp
Update more source code copyright notices to use 2007
Modified: trunk/MgDev/Web/src/mapviewerjava/ajaxviewer.jsp
--- trunk/MgDev/Web/src/mapviewerjava/ajaxviewer.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/ajaxviewer.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
- -Copyright (C) 2004-2007 Autodesk, Inc.
+ -Copyright (C) 2004-2007 by Autodesk, Inc.
-This library is free software; you can redistribute it and/or
-modify it under the terms of version 2.1 of the GNU Lesser
-General Public License as published by the Free Software Foundation.
Modified: trunk/MgDev/Web/src/mapviewerjava/ajaxviewerabout.jsp
--- trunk/MgDev/Web/src/mapviewerjava/ajaxviewerabout.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/ajaxviewerabout.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/buffer.jsp
--- trunk/MgDev/Web/src/mapviewerjava/buffer.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/buffer.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
- -Copyright (C) 2004-2006 Autodesk, Inc.
Modified: trunk/MgDev/Web/src/mapviewerjava/bufferui.jsp
--- trunk/MgDev/Web/src/mapviewerjava/bufferui.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/bufferui.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/colorpicker.jsp
--- trunk/MgDev/Web/src/mapviewerjava/colorpicker.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/colorpicker.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/common.jsp
--- trunk/MgDev/Web/src/mapviewerjava/common.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/common.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
@@ -143,5 +143,4 @@
return str;
Modified: trunk/MgDev/Web/src/mapviewerjava/dwfviewer.jsp
--- trunk/MgDev/Web/src/mapviewerjava/dwfviewer.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/dwfviewer.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/formframe.jsp
--- trunk/MgDev/Web/src/mapviewerjava/formframe.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/formframe.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/gettingstarted.jsp
--- trunk/MgDev/Web/src/mapviewerjava/gettingstarted.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/gettingstarted.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/index.jsp
--- trunk/MgDev/Web/src/mapviewerjava/index.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/index.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/init.jsp
--- trunk/MgDev/Web/src/mapviewerjava/init.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/init.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
@@ -23,7 +23,6 @@
// file should be in the same folder as this script.
String configPath = realpath + "webconfig.ini";
MapGuideJavaApi.MgInitializeWebTier( configPath );
Modified: trunk/MgDev/Web/src/mapviewerjava/legend.jsp
--- trunk/MgDev/Web/src/mapviewerjava/legend.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/legend.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
@@ -259,7 +259,6 @@
void BuildClientSideTree(ArrayList tree, TreeItem parent, String parentName, boolean fulldata, String container, MgResourceService resSrvc, HashMap layerMap) throws MgException
// 2 passes: pass 1 adds layers to the tree, pass 2 adds groups
int treeIndex = 0;
@@ -295,7 +294,6 @@
rtLayerGroup.GetObjectId(),
StrEscape(rtLayerGroup.GetName()),
rtLayerGroup.GetLayerGroupType() == MgLayerGroupType.BaseMap? "true": "false"});
else
Modified: trunk/MgDev/Web/src/mapviewerjava/legendctrl.jsp
--- trunk/MgDev/Web/src/mapviewerjava/legendctrl.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/legendctrl.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/legendui.jsp
--- trunk/MgDev/Web/src/mapviewerjava/legendui.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/legendui.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/mainframe.jsp
--- trunk/MgDev/Web/src/mapviewerjava/mainframe.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/mainframe.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp
--- trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/measure.jsp
--- trunk/MgDev/Web/src/mapviewerjava/measure.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/measure.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/measureui.jsp
--- trunk/MgDev/Web/src/mapviewerjava/measureui.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/measureui.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/printablepage.jsp
--- trunk/MgDev/Web/src/mapviewerjava/printablepage.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/printablepage.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/printablepageui.jsp
--- trunk/MgDev/Web/src/mapviewerjava/printablepageui.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/printablepageui.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/product.jsp
--- trunk/MgDev/Web/src/mapviewerjava/product.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/product.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/propertyctrl.jsp
--- trunk/MgDev/Web/src/mapviewerjava/propertyctrl.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/propertyctrl.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/search.jsp
--- trunk/MgDev/Web/src/mapviewerjava/search.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/search.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/searchprompt.jsp
--- trunk/MgDev/Web/src/mapviewerjava/searchprompt.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/searchprompt.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/selectwithin.jsp
--- trunk/MgDev/Web/src/mapviewerjava/selectwithin.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/selectwithin.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/selectwithinui.jsp
--- trunk/MgDev/Web/src/mapviewerjava/selectwithinui.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/selectwithinui.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/setselection.jsp
--- trunk/MgDev/Web/src/mapviewerjava/setselection.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/setselection.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/statusbar.jsp
--- trunk/MgDev/Web/src/mapviewerjava/statusbar.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/statusbar.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/taskbar.jsp
--- trunk/MgDev/Web/src/mapviewerjava/taskbar.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/taskbar.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/taskframe.jsp
--- trunk/MgDev/Web/src/mapviewerjava/taskframe.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/taskframe.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/tasklist.jsp
--- trunk/MgDev/Web/src/mapviewerjava/tasklist.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/tasklist.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/taskpane.jsp
--- trunk/MgDev/Web/src/mapviewerjava/taskpane.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/taskpane.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/mapviewerjava/toolbar.jsp
--- trunk/MgDev/Web/src/mapviewerjava/toolbar.jsp 2007-03-17 03:36:26 UTC (rev 1273)
+++ trunk/MgDev/Web/src/mapviewerjava/toolbar.jsp 2007-03-17 03:51:36 UTC (rev 1274)
@@ -1,5 +1,5 @@
More information about the mapguide-commits
