[mapguide-commits] r1275 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Sat Mar 17 01:07:51 EDT 2007
Author: jasonnogar
Date: 2007-03-17 01:07:51 -0400 (Sat, 17 Mar 2007)
New Revision: 1275
Added:
trunk/MgDev/Common/Stylization/SE_IdentityJoin.cpp
trunk/MgDev/Common/Stylization/SE_IdentityJoin.h
trunk/MgDev/Common/Stylization/SE_MiterJoin.cpp
trunk/MgDev/Common/Stylization/SE_MiterJoin.h
trunk/MgDev/Common/Stylization/SE_PiecewiseTransform.h
trunk/MgDev/Common/Stylization/Makefile.am
Symbology Joins: Initial Commit of the join transform class;
(SE_LineBuffer and SE_Renderer change commits to follow).
Modified: trunk/MgDev/Common/Stylization/Makefile.am
--- trunk/MgDev/Common/Stylization/Makefile.am 2007-03-17 03:51:36 UTC (rev 1274)
+++ trunk/MgDev/Common/Stylization/Makefile.am 2007-03-17 05:07:51 UTC (rev 1275)
@@ -16,6 +16,8 @@
libMgStylization_la_SOURCES = \
RS_FontEngine.cpp \
SE_Bounds.cpp \
+ SE_IdentityJoin.cpp \
+ SE_MiterJoin.cpp \
SE_ExpressionBase.cpp \
SE_LineBuffer.cpp \
SE_PositioningAlgorithms.cpp \
@@ -69,6 +71,9 @@
RS_FontEngine.h \
SE_Bounds.h \
SE_ConvexHull.h \
+ SE_PiecewiseTransform.h \
+ SE_IdentityJoin.h \
+ SE_MiterJoin.h \
SE_ExpressionBase.h \
SE_SymbolDefProxies.h \
SE_RenderProxies.h \
Added: trunk/MgDev/Common/Stylization/SE_IdentityJoin.cpp
--- trunk/MgDev/Common/Stylization/SE_IdentityJoin.cpp (rev 0)
+++ trunk/MgDev/Common/Stylization/SE_IdentityJoin.cpp 2007-03-17 05:07:51 UTC (rev 1275)
@@ -0,0 +1,93 @@
+// Copyright (C) 2007 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "SE_IdentityJoin.h"
+#include <float.h>
+SE_IdentityJoin::SE_IdentityJoin(RS_Bounds& bounds, double chop, bool end) :
+ m_chop(chop),
+ m_end(end),
+ m_identity_region(),
+ m_xf_bounds()
+ if (end)
+ m_identity_region.minx = -DBL_MAX;
+ m_identity_region.maxx = bounds.maxx - chop;
+ m_xf_bounds.maxx = m_identity_region.maxx;
+ m_xf_bounds.minx = bounds.minx;
+ else
+ m_identity_region.maxx = DBL_MAX;
+ m_identity_region.minx = bounds.minx + chop;
+ m_xf_bounds.minx = m_identity_region.minx;
+ m_xf_bounds.maxx = bounds.maxx;
+ m_identity_region.miny = -DBL_MAX;
+ m_identity_region.maxy = DBL_MAX;
+ m_xf_bounds.miny = bounds.miny;
+ m_xf_bounds.maxy = bounds.maxy;
+RS_Bounds* SE_IdentityJoin::GetIdentityRegions(int &length)
+ length = 1;
+ return &m_identity_region;
+RS_F_Point* SE_IdentityJoin::GetDiscontinuities(int &length)
+ length = 0;
+ return NULL;
+RS_Bounds* SE_IdentityJoin::GetNonlinearRegions(int &length)
+ length = 0;
+ return NULL;
+RS_Bounds& SE_IdentityJoin::GetTransformedBounds()
+ return m_xf_bounds;
+double SE_IdentityJoin::GetXChop(bool &chopEnd)
+ chopEnd = m_end;
+ return m_chop;
+void SE_IdentityJoin::Transform(double& /*x*/, double& /*y*/, SE_TransformInfo* info)
+ if (info)
+ info->dXdx = 1.0;
+ info->dYdy = 1.0;
+ info->dYdx = 0.0;
+ info->dXdy = 0.0;
+ info->d2Xdx2 = 0.0;
+ info->d2Ydx2 = 0.0;
+ info->d2Xdy2 = 0.0;
+ info->d2Ydy2 = 0.0;
+ info->d2Xdxdy = 0.0;
+ info->d2Ydxdy = 0.0;
\ No newline at end of file
Added: trunk/MgDev/Common/Stylization/SE_IdentityJoin.h
--- trunk/MgDev/Common/Stylization/SE_IdentityJoin.h (rev 0)
+++ trunk/MgDev/Common/Stylization/SE_IdentityJoin.h 2007-03-17 05:07:51 UTC (rev 1275)
@@ -0,0 +1,47 @@
+#ifndef SE_IDENTITYJOIN_H
+#define SE_IDENTITYJOIN_H
+#include "SE_PiecewiseTransform.h"
+class SE_IdentityJoin : public SE_PiecewiseTransform
+public:
+ /* bounds: The bounds of the symbol.
+ * chop: The amount to remove in pixel units
+ * end: The symbol is truncated backwards from maxx if true, or forwards from minx if not
+ SE_IdentityJoin(RS_Bounds& bounds, double chop, bool end);
+ virtual RS_F_Point* GetDiscontinuities(int &length);
+ virtual RS_Bounds* GetIdentityRegions(int &length);
+ virtual RS_Bounds* GetNonlinearRegions(int &length);
+ virtual RS_Bounds& GetTransformedBounds();
+ virtual double GetXChop(bool &chopEnd);
+ virtual void Transform(double& x, double &y, SE_TransformInfo* info);
+private:
+ double m_chop;
+ bool m_end;
+ RS_Bounds m_identity_region;
+ RS_Bounds m_xf_bounds;
+#endif // SE_IDENTITYJOIN_H
Added: trunk/MgDev/Common/Stylization/SE_MiterJoin.cpp
--- trunk/MgDev/Common/Stylization/SE_MiterJoin.cpp (rev 0)
+++ trunk/MgDev/Common/Stylization/SE_MiterJoin.cpp 2007-03-17 05:07:51 UTC (rev 1275)
@@ -0,0 +1,315 @@
+#include "SE_MiterJoin.h"
+#include "stdafx.h"
+/* TODO: use vectors instead of sAng, eAng */
+SE_MiterJoin::SE_MiterJoin
+ ( double limit,
+ RS_Bounds& bounds,
+ double vertexOffset,
+ double sAng,
+ double eAng,
+ double dx,
+ double dy,
+ double chopOffset )
+ double V; /* The location of the vertex in symbol coordinates */
+ double wn; /* The height of the symbol below the line (inside the join) */
+ double wp; /* The height of the symbol above the line (outside the join) */
+ double jn; /* The length of the join above the line */
+ double jp; /* The length of the join below the line */
+ double h; /* The half-angle between the segments */
+ double t; /* The tangent of the half-angle */
+ double c; /* The cosine of the half-angle */
+ double s; /* The sine of the half-angle */
+ double mmax; /* The length of the miter before the miter limit is applied */
+ double mlen; /* The miter length (the miter limit times the outside line thickness) */
+ double movr; /* The length of the portion of the miter that exceeds the miter length */
+ m_sAng = sAng;
+ m_eAng = eAng;
+ wn = bounds.miny < 0.0 ? -bounds.miny : 0.0;
+ wp = bounds.maxy > 0.0 ? bounds.maxy : 0.0;
+ /* If t is negative, then jn will become the miter length and jp will become the inside length */
+ h = (eAng - sAng)/2.0;
+ s = sin(h);
+ c = cos(h);
+ t = s/c; /* The calculations will be stable even if the tangent is INF or 0 (assuming a reasonable miter limit) */
+ V = bounds.minx - vertexOffset;
+ /* Rotation should occur about the vertex */
+ m_sRot.translateX(V);
+ m_sRot.rotate(sAng);
+ m_sRot.translate(dx - V, dy);
+ m_eRot.translateX(V);
+ m_eRot.rotate(eAng);
+ m_eRot.translate(dx - V, dy);
+ /* the tangent of the half angle is equal to the upper height over the upper join width */
+ jn = wn/t;
+ /* the tangent of the half angle is equal to the lower height over the lower join width */
+ jp = wp/t;
+ if (t < 0.0)
+ { /* The positive portion of the symbol is inside the join */
+ mmax = sqrt(wn*wn + jn*jn);
+ mlen = wn*limit;
+ if ((movr = mmax - mlen) > 0) /* the miter limit forces a bevel */
+ /* the cosine of the half angle is equal to the chopped length / the truncation of j */
+ jn -= movr/c;
+ jn = (jn < 0) ? 0.0 : jn;
+ m_y_max_len = jn;
+ m_y_max = wn;
+ m_y_min_len = jp;
+ m_y_min = wp;
+ else
+ { /* The negative portion of the symbol is inside the join */
+ mmax = sqrt(wp*wp + jp*jp);
+ mlen = wp*limit;
+ jp -= movr/c;
+ jp = (jp < 0) ? 0.0 : jp;
+ m_y_max_len = jp;
+ m_y_max = wp;
+ m_y_min_len = jn;
+ m_y_min = wn;
+ if (V + chopOffset < bounds.maxx)
+ m_chop = V + chopOffset;
+ else
+ m_chop = DBL_MAX;
+ /* The widest part of the transform is cosine of the half angle times the actual miter length.
+ * If there is no bevel, m_y_mid will be equal to m_y_max.
+ * Despite this mathemtical certainty, using an if ensures that m_y_mid == m_y_max in fp math */
+ if (movr > 0)
+ m_y_mid_len = (mmax < mlen ? mmax : mlen)*c;
+ m_y_mid = m_y_mid_len*t;
+ else
+ m_y_mid_len = m_y_max_len;
+ m_y_mid = m_y_max;
+ m_x_vert = V;
+ m_n_discontinuities = -1;
+ m_n_identity_regions = -1;
+ m_bounds = bounds;
+ /* Factor used in miter calculations (see comments in Transform) */
+ m_miter_scale = m_y_min_len*(m_y_mid_len + m_y_min_len)/(m_y_mid - m_y_min);
+ m_bevel_scale = (m_y_max - m_y_mid)*(m_y_mid_len - m_y_max_len);
+RS_F_Point* SE_MiterJoin::GetDiscontinuities(int &length)
+ if (m_n_discontinuities == -1) /* Lazily initialize */
+ m_first_discontinuity = NULL;
+ double minx = m_x_vert - m_y_min_len;
+ double maxx = m_x_vert + m_y_min_len;
+ if (m_bounds.minx < m_x_vert && m_y_mid != m_y_max)
+ m_first_discontinuity = m_discontinuities;
+ m_n_discontinuities++;
+ m_discontinuities[0].x = (minx > m_bounds.minx) ? minx : m_bounds.minx;
+ m_discontinuities[0].y = m_y_mid;
+ m_discontinuities[1].x = (m_bounds.maxx < m_x_vert) ? m_bounds.maxx : m_x_vert;
+ m_discontinuities[1].y = m_y_mid;
+ if (m_bounds.minx < m_x_vert && m_bounds.maxx > m_x_vert)
+ if (m_first_discontinuity == NULL)
+ m_first_discontinuity = m_discontinuities + 2;
+ m_discontinuities[2].x = m_x_vert;
+ m_discontinuities[2].y = m_y_max;
+ m_discontinuities[3].x = m_x_vert;
+ m_discontinuities[3].y = m_y_min;
+ if (m_bounds.maxx > m_x_vert && m_y_mid != m_y_max)
+ m_first_discontinuity = m_discontinuities + 4;
+ m_discontinuities[4].x = (maxx < m_bounds.maxx) ? maxx : m_bounds.maxx;
+ m_discontinuities[4].y = m_y_mid;
+ m_discontinuities[5].x = (m_bounds.minx > m_x_vert) ? m_bounds.minx : m_x_vert;
+ m_discontinuities[5].y = m_y_mid;
+ length = m_n_discontinuities;
+ return m_first_discontinuity;
+RS_Bounds* SE_MiterJoin::GetIdentityRegions(int &length)
+ if (m_n_identity_regions == -1) /* Lazily initialize */
+ m_first_identity_region = NULL;
+ m_n_identity_regions = 0;
+ if (m_bounds.minx < m_x_vert - m_y_min_len)
+ m_first_identity_region = m_identity_region;
+ m_n_identity_regions++;
+ m_identity_region[0].minx = m_bounds.minx;
+ m_identity_region[0].maxx = m_x_vert - m_y_min_len;
+ m_identity_region[0].miny = m_bounds.miny;
+ m_identity_region[0].maxy = m_bounds.maxy;
+ if (m_bounds.maxx > m_x_vert + m_y_min_len && m_chop > m_x_vert + m_y_min_len)
+ if (m_first_identity_region == NULL)
+ m_first_identity_region = m_identity_region + 1;
+ m_identity_region[1].minx = m_x_vert + m_y_min_len;
+ m_identity_region[1].maxx = m_bounds.maxx > m_chop ? m_chop : m_bounds.maxx;
+ m_identity_region[1].miny = m_bounds.miny;
+ m_identity_region[1].maxy = m_bounds.maxy;
+ length = m_n_identity_regions;
+ return m_first_identity_region;
+RS_Bounds* SE_MiterJoin::GetNonlinearRegions(int &length)
+ length = 0;
+ return NULL;
+RS_Bounds& SE_MiterJoin::GetTransformedBounds()
+ /* TODO: initialize, lazily */
+double SE_MiterJoin::GetXChop(bool &chopEnd)
+ chopEnd = true;
+ return m_chop;
+void SE_MiterJoin::Transform(double& x, double &y, SE_TransformInfo* info)
+ /* By using these, max will always be > min */
+ bool start = x < m_x_vert;
+ double x_min = start ? m_x_vert - m_y_min_len : m_x_vert + m_y_min_len;
+ double dXdx, dXdy, d2Xdxdy;
+ if (x >= m_x_vert - m_y_min_len && x <= m_x_vert + m_y_min_len)
+ if (y > m_y_mid && y <= m_y_max)
+ /* The bevel transform can be described by the following function:
+ * X(x,y) = x_min + (x - x_min) * (y_max_len + (y_max - y) * (y_mid_len - y_max_len) / (y_max - y_mid)
+ * |------------- m_bevel_scale -------------|
+ * where:
+ * dX/dx = y_max_len + (y_max - y) * scale
+ * dX/dy = - (x - x_min) * scale
+ * d2X/dx2 = 0
+ * d2X/dy2 = 0
+ * d2X/dxdy = -scale
+ * The transform is constant over Y, so
+ * Y(x,y) = y
+ double dy = m_y_max - y;
+ double dx = x - x_min;
+ x = x_min + dx * (m_y_max_len + dy * m_bevel_scale);
+ dXdx = m_y_max_len + dy * m_bevel_scale;
+ dXdy = dx * m_bevel_scale;
+ d2Xdxdy = -m_bevel_scale;
+ else if (y <= m_y_mid && y >= m_y_min)
+ /* The miter transform can be described by the following function:
+ * X(x,y) = x_min + (x - x_min) * (y - y_min) * y_min_len * (y_mid_len + y_min_len) / (y_mid - y_min)
+ * |------------------- m_miter_scale -------------------|
+ * where:
+ * dX/dx = (y - y_min) * scale
+ * dX/dy = (x - x_min) * scale
+ * d2X/dx2 = 0
+ * d2X/dy2 = 0
+ * d2X/dxdy = scale
+ * Y(x,y) = y
+ double dy = y - m_y_min;
+ x = x_min + dx * dy * m_miter_scale;
+ dXdx = dy * m_miter_scale;
+ dXdy = dx * m_miter_scale;
+ d2Xdxdy = m_miter_scale;
+ else
+ dXdx = 1.0;
+ dXdy = 0.0;
+ d2Xdxdy = 0.0;
+ else
+ dXdx = 1.0;
+ dXdy = 0.0;
+ d2Xdxdy = 0.0;
+ if (info)
+ info->dXdx = dXdx;
+ info->dXdy = dXdy;
+ info->dYdx = 0.0;
+ info->dYdy = 1.0;
+ info->d2Xdxdy = d2Xdxdy;
+ if (start)
+ m_sRot.transform(x,y);
+ else
+ m_eRot.transform(x, y);
Added: trunk/MgDev/Common/Stylization/SE_MiterJoin.h
--- trunk/MgDev/Common/Stylization/SE_MiterJoin.h (rev 0)
+++ trunk/MgDev/Common/Stylization/SE_MiterJoin.h 2007-03-17 05:07:51 UTC (rev 1275)
@@ -0,0 +1,82 @@
+#ifndef SE_MITERJOIN_H
+#define SE_MITERJOIN_H
+#include "SE_Matrix.h"
+#include <float.h>
+class SE_MiterJoin : public SE_PiecewiseTransform
+public:
+ SE_MiterJoin(double limit, /* The miter limit of the join. */
+ RS_Bounds& bounds, /* The bounds of the unoriented symbol in pixel units. */
+ double vertexOffset, /* The distance along the line (in pixels) from the
+ beginning of the symbol to the vertex of the join
+ (the value will be negative if the symbol starts before
+ the join, and positive if it starts after the join). */
+ double sAng, /* The angle of the first line segment. */
+ double eAng, /* The angle of the second line segment. */
+ double dx, /* The x offset of the origin of the symbol */
+ double dy, /* The y offset of the origin of the symbol */
+ double chopOffset = DBL_MAX); /* The distance after the vertex at which to truncate the symbol */
+ /* Transform will apply the join transform, as well as the appropriate rotation */
+ virtual void Transform(double& x, double& y, SE_TransformInfo* info);
+private:
+ double m_y_max;
+ double m_y_max_len;
+ double m_y_mid;
+ double m_y_mid_len;
+ double m_y_min;
+ double m_y_min_len;
+ double m_x_vert;
+ double m_miter_scale;
+ double m_bevel_scale;
+ double m_sAng;
+ double m_eAng;
+ int m_n_discontinuities;
+ RS_F_Point* m_first_discontinuity;
+ RS_F_Point m_discontinuities[6];
+ int m_n_identity_regions;
+ RS_Bounds* m_first_identity_region;
+ RS_Bounds m_identity_region[2];
+ RS_Bounds m_bounds;
+ SE_Matrix m_sRot;
+ SE_Matrix m_eRot;
+ double m_chop;
+#endif // SE_MITERJOIN_H
Added: trunk/MgDev/Common/Stylization/SE_PiecewiseTransform.h
--- trunk/MgDev/Common/Stylization/SE_PiecewiseTransform.h (rev 0)
+++ trunk/MgDev/Common/Stylization/SE_PiecewiseTransform.h 2007-03-17 05:07:51 UTC (rev 1275)
@@ -0,0 +1,56 @@
+#ifndef SE_PIECEWISETRANSFORM_H
+#define SE_PIECEWISETRANSFORM_H
+#include "Bounds.h"
+struct SE_TransformInfo
+ double dXdx;
+ double dYdx;
+ double dXdy;
+ double dYdy;
+ double d2Xdx2;
+ double d2Ydx2;
+ double d2Xdy2;
+ double d2Ydy2;
+ double d2Xdxdy;
+ double d2Ydxdy;
+class SE_PiecewiseTransform
+public:
+ /* Returned in the format pt00, pt01, pt10, pt11 etc. where each pair of points represents
+ * the endpoints of a line along which the the transform is not smooth */
+ virtual RS_F_Point* GetDiscontinuities(int &length) = 0;
+ /* Regions that are not transformed (other than rotation) */
+ virtual RS_Bounds* GetIdentityRegions(int &length) = 0;
+ /* Regions where simple linear of transformed points is insufficient */
+ virtual RS_Bounds* GetNonlinearRegions(int &length) = 0;
+ virtual RS_Bounds& GetTransformedBounds() = 0;
+ /* Applying the chop is left to the caller */
+ virtual double GetXChop(bool &chopEnd) = 0;
+ /* The transform function is not aware of the chop value */
+ virtual void Transform(double& x, double& y, SE_TransformInfo* info) = 0;
+#endif // SE_PIECEWISETRANSFORM_H
More information about the mapguide-commits
