[mapguide-commits] r1294 - in trunk/MgDev: Common/Stylization Server/src/Services/Mapping
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Mar 19 20:06:47 EDT 2007
Author: waltweltonlair
Date: 2007-03-19 20:06:47 -0400 (Mon, 19 Mar 2007)
New Revision: 1294
   trunk/MgDev/Common/Stylization/DWFRenderer.cpp
   trunk/MgDev/Common/Stylization/DWFRenderer.h
   trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp
Initial set up of DWFRenderer for new symbolization.
DWFRenderer now extends SE_Renderer so it can participate in the new
symbology.  For the purpose of SE_Renderer, we define "screen space"
to be "W2D space".  The virtual SE_Renderer methods which define the
transforms have been implemented, but not yet any of the Draw calls.
This will happen in a subsequent submission.
Modified: trunk/MgDev/Common/Stylization/DWFRenderer.cpp
--- trunk/MgDev/Common/Stylization/DWFRenderer.cpp	2007-03-19 20:25:03 UTC (rev 1293)
+++ trunk/MgDev/Common/Stylization/DWFRenderer.cpp	2007-03-20 00:06:47 UTC (rev 1294)
@@ -67,10 +67,11 @@
 //------------------------------Utilities--------------------------------------
 WT_Color Util_ConvertColor(RS_Color & color)
     WT_Color ret(color.red(), color.green(), color.blue(), color.alpha());
@@ -191,11 +192,13 @@
     return WT_Result::Unknown_File_Read_Error;
 //--------------------------DWFRenderer----------------------------------------
 DWFRenderer::DWFRenderer()
 : m_w2dFile(NULL),
   m_mapInfo(NULL),
@@ -249,6 +252,7 @@
         delete m_attributes;
 // Initializes map generation with required map properties.
@@ -259,8 +263,7 @@
                             double        mapScale,
                             double        dpi,
                             double        metersPerUnit,
-                            CSysTransformer* xformToLL
+                            CSysTransformer* xformToLL)
     if (dpi == 0.0)
         m_dpi = 96.0; // default -- 96 is usually true for Windows
@@ -302,6 +305,7 @@
     m_mapInfo = mapInfo;
 // Tells the Renderer we are done with map generation. It should be overloaded
@@ -349,6 +353,7 @@
     m_mapInfo = NULL;
 // Indicates beginning of a map layer. This function creates a W2D for feature
@@ -357,10 +362,7 @@
 // are labels.
-void DWFRenderer::StartLayer(RS_LayerUIInfo*      legendInfo,
-                             RS_FeatureClassInfo* classInfo
+void DWFRenderer::StartLayer(RS_LayerUIInfo* legendInfo, RS_FeatureClassInfo* classInfo)
     if (classInfo && legendInfo &&
        (legendInfo->selectable() || legendInfo->hastooltips() || legendInfo->hashyperlinks()))
@@ -455,6 +457,7 @@
     m_layerInfo = legendInfo;
 // Cleans up W2D files after processing for a layer is done. Should be
@@ -512,6 +515,7 @@
     m_layerInfo = NULL;
 // All subsequent drawables will be considered as part of a single feature
 // identifier by the given feature reader, until the next call to StartFeature()
@@ -523,7 +527,6 @@
                                double /*zOffset*/,
                                double /*zExtrusion*/,
                                RS_ElevationType /*zOffsetType*/)
     //attributes and selection support
     StoreAttributes(feature, tooltip, url);
@@ -536,8 +539,7 @@
 // holes etc.
-void DWFRenderer::ProcessPolygon (  LineBuffer*         srclb,
-                                    RS_FillStyle&       fill)
+void DWFRenderer::ProcessPolygon(LineBuffer* srclb, RS_FillStyle& fill)
     LineBuffer* workbuffer = srclb->Optimize(m_drawingScale, &m_lbPool);
@@ -620,8 +622,7 @@
 // Polyline features. Transformation to W2D space is done here.
-void DWFRenderer::ProcessPolyline(LineBuffer*           srclb,
-                                  RS_LineStroke&        lsym)
+void DWFRenderer::ProcessPolyline(LineBuffer* srclb, RS_LineStroke& lsym)
     if (srclb->point_count() == 0)
         return;
@@ -663,17 +664,18 @@
     m_lbPool.FreeLineBuffer(workbuffer);
 // Raster serialization.
-void DWFRenderer::ProcessRaster(unsigned char*    data,
-                                int               length,
-                                RS_ImageFormat    format,
-                                int               width,
-                                int               height,
-                                RS_Bounds         extents)
+void DWFRenderer::ProcessRaster(unsigned char* data,
+                                int            length,
+                                RS_ImageFormat format,
+                                int            width,
+                                int            height,
+                                RS_Bounds      extents)
     if (format != RS_ImageFormat_RGBA && format != RS_ImageFormat_PNG)
@@ -733,10 +735,7 @@
 // Marker Symbols
-void DWFRenderer::ProcessMarker(LineBuffer* srclb,
-                                RS_MarkerDef& mdef,
-                                bool allowOverpost,
-                                RS_Bounds* bounds)
+void DWFRenderer::ProcessMarker(LineBuffer* srclb, RS_MarkerDef& mdef, bool allowOverpost, RS_Bounds* bounds)
     for (int i=0; i<srclb->point_count(); i++)
@@ -763,9 +762,7 @@
         // symbol library resource. This is hardcoded right now.
         // If it ever changes, we will need to update it
-        symbol = (RS_InputStream*)m_symbolManager->GetSymbolData(mdef.library().c_str(),
-                                                L"symbols.dwf"); //NOXLATE
+        symbol = (RS_InputStream*)m_symbolManager->GetSymbolData(mdef.library().c_str(), L"symbols.dwf"); //NOXLATE
     //default symbol
@@ -796,7 +793,6 @@
     double aspect = (mdef.width() == 0.0) ? DBL_MAX : mdef.height() / mdef.width();
     RS_Bounds dst;
     if (aspect <= 1.0)
         dst = RS_Bounds(0, 0, SYMBOL_MAX, aspect * SYMBOL_MAX);
     else
@@ -1076,27 +1072,25 @@
         m_obsMesh->ProcessPoint(x, y);
 // Text labels
-void DWFRenderer::ProcessLabel(double           x,
-                               double           y,
-                               const RS_String& text,
-                               RS_TextDef&      tdef)
+void DWFRenderer::ProcessLabel(double x, double y, const RS_String& text, RS_TextDef& tdef)
     RS_LabelInfo info(x, y, 0.0, 0.0, tdef.font().units(), tdef, false);
     ProcessLabelGroup(&info, 1, text, RS_OverpostType_All, false, NULL);
-void DWFRenderer::ProcessLabelGroup( RS_LabelInfo*       labels,
-                                     int                 nlabels,
-                                     RS_OverpostType     type,
-                                     bool                exclude,
-                                     LineBuffer*         /*path*/)
+void DWFRenderer::ProcessLabelGroup(RS_LabelInfo*    labels,
+                                    int              nlabels,
+                                    const RS_String& text,
+                                    RS_OverpostType  type,
+                                    bool             exclude,
+                                    LineBuffer*      /*path*/)
     if (nlabels == 0)
         return;
@@ -1548,6 +1542,7 @@
 // Writes multi-polyline geometry to W2D. Input is a LineBuffer
@@ -1594,6 +1589,7 @@
     m_w2dFile->desired_rendition().line_weight() = WT_Line_Weight(line_weight);
 // Serializes a polygon fill style
@@ -1646,6 +1642,7 @@
 // Serializes font and text alignement and rendering settings
@@ -1719,6 +1716,7 @@
 //scale an input number in meters to a mapping
 //space number given a device or mapping space unit.
@@ -1749,6 +1747,7 @@
     return (double)pixels * (0.0254 / renderer->GetDpi()) * renderer->GetMapScale() / renderer->GetMetersPerUnit();
@@ -1808,14 +1807,14 @@
     file->desired_rendition().drawing_info().units().serialize(*file);
 // Helper function to start a new W2D object node and write out the attributes
 // of the current feature into a DWF object definition instance
-void DWFRenderer::StoreAttributes(RS_FeatureReader* feature, const RS_String* tooltip,
-                                  const RS_String* url)
+void DWFRenderer::StoreAttributes(RS_FeatureReader* feature, const RS_String* tooltip, const RS_String* url)
     if (m_featureClass && m_featureClassInfo)
@@ -1906,6 +1905,12 @@
+void DWFRenderer::SetSymbolManager(RS_SymbolManager* manager)
+    m_symbolManager = manager;
 RS_MapUIInfo* DWFRenderer::GetMapInfo()
     return m_mapInfo;
@@ -1929,6 +1934,11 @@
     return m_mapScale;
+double DWFRenderer::GetMetersPerUnit()
+    return m_metersPerUnit;
 RS_Bounds& DWFRenderer::GetBounds()
     return m_extents;
@@ -1939,9 +1949,9 @@
     return m_dpi;
-double DWFRenderer::GetMetersPerUnit()
+bool DWFRenderer::RequiresClipping()
-    return m_metersPerUnit;
+    return true;
 double DWFRenderer::GetMapToW2DScale()
@@ -1949,10 +1959,6 @@
     return m_scale;
-bool DWFRenderer::RequiresClipping()
-    return true;
 void DWFRenderer::EnsureBufferSize(int len)
@@ -1970,11 +1976,6 @@
-void DWFRenderer::SetSymbolManager(RS_SymbolManager* manager)
-    m_symbolManager = manager;
 void DWFRenderer::StartLayout(RS_Bounds& extents)
     // Reset m_mapScale and m_metersPerUnit
@@ -2010,6 +2011,7 @@
     m_imgID = 0;
 void DWFRenderer::EndLayout()
     m_extents = m_mapExtents;
@@ -2039,6 +2041,7 @@
 void DWFRenderer::Init(RS_Bounds& extents)
     m_mapExtents = m_extents;
@@ -2059,6 +2062,109 @@
     m_offsetY = 0;
+//             SE Renderer
+void DWFRenderer::DrawScreenPolyline(LineBuffer* geom, const SE_Matrix* xform, unsigned int color, double weight)
+    // TODO
+void DWFRenderer::DrawScreenPolygon(LineBuffer* geom, const SE_Matrix* xform, unsigned int fill)
+    // TODO
+void DWFRenderer::DrawScreenRaster(unsigned char* data, int length, RS_ImageFormat format, int native_width, int native_height,
+                                  double x, double y, double w, double h, double angledeg)
+    // TODO
+void DWFRenderer::DrawScreenText(const RS_String& txt, RS_TextDef& tdef, double insx, double insy, double* path, int npts, double param_position)
+    // TODO
+void DWFRenderer::GetWorldToScreenTransform(SE_Matrix& xform)
+    // "screen space" in DWF is W2D space
+    xform.x0 = m_scale;
+    xform.x1 = 0.0;
+    xform.x2 = - m_offsetX * m_scale;
+    xform.y0 = 0.0;
+    xform.y1 = m_scale;
+    xform.y2 = - m_offsetY * m_scale;
+void DWFRenderer::WorldToScreenPoint(double& inx, double& iny, double& ox, double& oy)
+    ox = (inx - m_offsetX) * m_scale;
+    oy = (iny - m_offsetY) * m_scale;
+void DWFRenderer::ScreenToWorldPoint(double& inx, double& iny, double& ox, double& oy)
+    ox = inx / m_scale + m_offsetX;
+    oy = iny / m_scale + m_offsetY;
+// returns number of W2D units per millimeter screen
+double DWFRenderer::GetPixelsPerMillimeterScreen()
+    //  [ W2D ]     [ W2D ]     [ World ]     meter-world     mm-world
+    // mm-screen   [ World ]   meter-world   1000 mm-world   mm-screen
+    return m_scale / m_metersPerUnit / 1000.0 * m_mapScale;
+// returns number of W2D units per millimeter world
+double DWFRenderer::GetPixelsPerMillimeterWorld()
+    // mm-world   [ World ]   meter-world   1000 mm-world
+    return m_scale / m_metersPerUnit / 1000.0;
+RS_FontEngine* DWFRenderer::GetFontEngine()
+    // TODO
+    return NULL;
+void DWFRenderer::ProcessLabelGroup(SE_LabelInfo*    labels,
+                                    int              nlabels,
+                                    bool             exclude,
+                                    LineBuffer*      path)
+    // TODO
+void DWFRenderer::AddExclusionRegion(RS_F_Point* fpts, int npts)
+    // TODO
Modified: trunk/MgDev/Common/Stylization/DWFRenderer.h
--- trunk/MgDev/Common/Stylization/DWFRenderer.h	2007-03-19 20:25:03 UTC (rev 1293)
+++ trunk/MgDev/Common/Stylization/DWFRenderer.h	2007-03-20 00:06:47 UTC (rev 1294)
@@ -28,6 +28,8 @@
 #include "LineBuffer.h"
 #include "KeyEncode.h"
+#include "SE_Renderer.h"
 //forward declare
 class WT_File;
 class WT_Viewport;
@@ -61,61 +63,58 @@
 ///<summary>
 /// Implementation of Renderer for DWF-W2D output
 ///</summary>
-class DWFRenderer : public Renderer
+class DWFRenderer : public Renderer, public SE_Renderer
 public:
     STYLIZATION_API DWFRenderer();
     STYLIZATION_API virtual ~DWFRenderer();
-    STYLIZATION_API virtual void StartMap      (RS_MapUIInfo* mapInfo,
-                                                RS_Bounds&    extents,
-                                                double        mapScale,
-                                                double        dpi,
-                                                double        metersPerUnit,
-                                                CSysTransformer* xformToLL);
+    // Renderer implementation
+    STYLIZATION_API virtual void StartMap(RS_MapUIInfo* mapInfo,
+                                          RS_Bounds&    extents,
+                                          double        mapScale,
+                                          double        dpi,
+                                          double        metersPerUnit,
+                                          CSysTransformer* xformToLL);
-    STYLIZATION_API virtual void EndMap         ();
+    STYLIZATION_API virtual void EndMap();
-    STYLIZATION_API virtual void StartLayer     (RS_LayerUIInfo*      legendInfo,
-                                                 RS_FeatureClassInfo* classInfo);
+    STYLIZATION_API virtual void StartLayer(RS_LayerUIInfo*      legendInfo,
+                                            RS_FeatureClassInfo* classInfo);
-    STYLIZATION_API virtual void EndLayer       ();
+    STYLIZATION_API virtual void EndLayer();
-    STYLIZATION_API virtual void StartFeature (RS_FeatureReader* feature,
-                                               const RS_String*  tooltip = NULL,
-                                               const RS_String*  url = NULL,
-                                               const RS_String* theme = NULL,
-                                               double zOffset = 0,
-                                               double zExtrusion = 0,
-                                               RS_ElevationType zOffsetType = RS_ElevationType_RelativeToGround);
+    STYLIZATION_API virtual void StartFeature(RS_FeatureReader* feature,
+                                              const RS_String*  tooltip = NULL,
+                                              const RS_String*  url = NULL,
+                                              const RS_String* theme = NULL,
+                                              double zOffset = 0,
+                                              double zExtrusion = 0,
+                                              RS_ElevationType zOffsetType = RS_ElevationType_RelativeToGround);
-    STYLIZATION_API virtual void ProcessPolygon (LineBuffer* lb,
-                                                 RS_FillStyle& fill);
+    STYLIZATION_API virtual void ProcessPolygon(LineBuffer* lb, RS_FillStyle& fill);
-    STYLIZATION_API virtual void ProcessPolyline(LineBuffer* lb,
-                                                 RS_LineStroke& lsym);
+    STYLIZATION_API virtual void ProcessPolyline(LineBuffer* lb, RS_LineStroke& lsym);
-    STYLIZATION_API virtual void ProcessRaster  (unsigned char*    data,
-                                                 int               length,
-                                                 int               width,
-                                                 int               height,
-                                                 RS_Bounds         extents);
+    STYLIZATION_API virtual void ProcessRaster(unsigned char* data,
+                                               int            length,
+                                               int            width,
+                                               int            height,
+                                               RS_Bounds      extents);
-    STYLIZATION_API virtual void ProcessMarker(LineBuffer*       lb,
-                                               RS_Bounds*        bounds = NULL);
+    STYLIZATION_API virtual void ProcessMarker(LineBuffer* lb, RS_MarkerDef& mdef, bool allowOverpost, RS_Bounds* bounds = NULL);
-    STYLIZATION_API virtual void ProcessLabel(double x, double y,
-                                              const RS_String& text, RS_TextDef& tdef);
+    STYLIZATION_API virtual void ProcessLabel(double x, double y, const RS_String& text, RS_TextDef& tdef);
-    STYLIZATION_API virtual void ProcessLabelGroup( RS_LabelInfo*       labels,
-                                                    int                 nlabels,
-                                                    bool                exclude,
-                                                    LineBuffer*         path);
+    STYLIZATION_API virtual void ProcessLabelGroup(RS_LabelInfo*    labels,
+                                                   int              nlabels,
+                                                   bool             exclude,
+                                                   LineBuffer*      path);
     STYLIZATION_API virtual void AddDWFContent(RS_InputStream*  in,
                                                CSysTransformer* xformer,
@@ -133,20 +132,49 @@
     STYLIZATION_API virtual double GetMapScale();
+    STYLIZATION_API virtual double GetMetersPerUnit();
     STYLIZATION_API virtual RS_Bounds& GetBounds();
     STYLIZATION_API virtual double GetDpi();
-    STYLIZATION_API virtual double GetMetersPerUnit();
+    STYLIZATION_API virtual bool RequiresClipping();
-    STYLIZATION_API virtual double GetMapToW2DScale();
+    // DWFRenderer specific
+    STYLIZATION_API double GetMapToW2DScale();
-    STYLIZATION_API virtual bool RequiresClipping();
     STYLIZATION_API void StartLayout(RS_Bounds& extents);
     STYLIZATION_API void EndLayout();
+    // SE_Renderer
+    virtual void DrawScreenPolyline(LineBuffer* geom, const SE_Matrix* xform, unsigned int color, double weight); // px
+    virtual void DrawScreenPolygon(LineBuffer* geom, const SE_Matrix* xform, unsigned int fill);
+    virtual void DrawScreenRaster(unsigned char* data, int length, RS_ImageFormat format, int native_width, int native_height,
+                                  double x, double y, double w, double h, double angledeg);
+    virtual void DrawScreenText(const RS_String& txt, RS_TextDef& tdef, double insx, double insy, double* path, int npts, double param_position);
+    virtual void GetWorldToScreenTransform(SE_Matrix& xform);
+    virtual void WorldToScreenPoint(double& inx, double& iny, double& ox, double& oy);
+    virtual void ScreenToWorldPoint(double& inx, double& iny, double& ox, double& oy);
+    virtual double GetPixelsPerMillimeterScreen();
+    virtual double GetPixelsPerMillimeterWorld();
+    virtual RS_FontEngine* GetFontEngine();
+    virtual void ProcessLabelGroup(SE_LabelInfo*    labels,
+                                   int              nlabels,
+                                   bool             exclude,
+                                   LineBuffer*      path = NULL);
+    virtual void AddExclusionRegion(RS_F_Point* fpts, int npts);
 protected:
     //list of layer w2d streams
     WT_File* m_w2dFile;
Modified: trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp
--- trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp	2007-03-19 20:25:03 UTC (rev 1293)
+++ trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp	2007-03-20 00:06:47 UTC (rev 1294)
@@ -16,7 +16,6 @@
 #include "ServerMappingServiceDefs.h"
 #include "ServerMappingService.h"
 #include "Stylization.h"
@@ -34,6 +33,7 @@
 #include "FeatureTypeStyleVisitor.h"
 #include "RSMgSymbolManager.h"
+#include "SEMgSymbolManager.h"
 #include "LegendPlotUtil.h"
@@ -422,7 +422,8 @@
     RSMgSymbolManager mgr(m_svcResource);
     dr.SetSymbolManager(&mgr);
-    DefaultStylizer ds(NULL);
+    SEMgSymbolManager semgr(m_svcResource);
+    DefaultStylizer ds(&semgr);
     RS_MapUIInfo mapInfo(sessionId, map->GetName(), map->GetObjectId(), srs, units, bgcolor);
More information about the mapguide-commits mailing list
