[mapguide-commits] r1295 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Mon Mar 19 20:08:42 EDT 2007
Author: waltweltonlair
Date: 2007-03-19 20:08:42 -0400 (Mon, 19 Mar 2007)
New Revision: 1295
trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
Initial set up of DWFRenderer for new symbolization.
DWFRenderer now extends SE_Renderer so it can participate in the new
symbology. For the purpose of SE_Renderer, we define "screen space"
to be "W2D space". The virtual SE_Renderer methods which define the
transforms have been implemented, but not yet any of the Draw calls.
This will happen in a subsequent submission.
Modified: trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
--- trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp 2007-03-20 00:06:47 UTC (rev 1294)
+++ trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp 2007-03-20 00:08:42 UTC (rev 1295)
@@ -35,8 +35,8 @@
-SE_RenderPrimitive* SE_Polyline::evaluate(SE_EvalContext* cxt)
+SE_RenderPrimitive* SE_Polyline::evaluate(SE_EvalContext* cxt)
SE_RenderPolyline* ret = new SE_RenderPolyline();
ret->resize = (resize == GraphicElement::AdjustToResizeBox);
@@ -56,8 +56,8 @@
return ret;
-SE_RenderPrimitive* SE_Polygon::evaluate(SE_EvalContext* cxt)
+SE_RenderPrimitive* SE_Polygon::evaluate(SE_EvalContext* cxt)
SE_RenderPolygon* ret = new SE_RenderPolygon();
@@ -79,15 +79,18 @@
return ret;
-SE_RenderPrimitive* SE_Text::evaluate(SE_EvalContext* cxt)
+SE_RenderPrimitive* SE_Text::evaluate(SE_EvalContext* cxt)
+ if (cxt->fonte == NULL)
+ return NULL;
SE_RenderText* ret = new SE_RenderText();
ret->text = textExpr.evaluate(cxt->exec);
ret->position[0] = position[0].evaluate(cxt->exec);
ret->position[1] = position[1].evaluate(cxt->exec);
cxt->xform->transform(ret->position[0], ret->position[1]);
ret->tdef.rotation() = angle.evaluate(cxt->exec);
@@ -108,26 +111,26 @@
const wchar_t* hAlign = hAlignment.evaluate(cxt->exec);
if (hAlign)
- if (wcscmp(hAlign, L"Left") == 0)
+ if (wcscmp(hAlign, L"Left") == 0)
ret->tdef.halign() = RS_HAlignment_Left;
- else if (wcscmp(hAlign, L"Center") == 0)
+ else if (wcscmp(hAlign, L"Center") == 0)
ret->tdef.halign() = RS_HAlignment_Center;
- else if (wcscmp(hAlign, L"Right") == 0)
+ else if (wcscmp(hAlign, L"Right") == 0)
ret->tdef.halign() = RS_HAlignment_Right;
const wchar_t* vAlign = vAlignment.evaluate(cxt->exec);
if (vAlign)
- if (wcscmp(vAlign, L"Bottom") == 0)
+ if (wcscmp(vAlign, L"Bottom") == 0)
ret->tdef.valign() = RS_VAlignment_Descent;
- else if (wcscmp(vAlign, L"Baseline") == 0)
+ else if (wcscmp(vAlign, L"Baseline") == 0)
ret->tdef.valign() = RS_VAlignment_Base;
- else if (wcscmp(vAlign, L"Halfline") == 0)
+ else if (wcscmp(vAlign, L"Halfline") == 0)
ret->tdef.valign() = RS_VAlignment_Half;
- else if (wcscmp(vAlign, L"Capline") == 0)
+ else if (wcscmp(vAlign, L"Capline") == 0)
ret->tdef.valign() = RS_VAlignment_Cap;
- else if (wcscmp(vAlign, L"Top") == 0)
+ else if (wcscmp(vAlign, L"Top") == 0)
ret->tdef.valign() = RS_VAlignment_Ascent;
@@ -151,15 +154,15 @@
std::sort((std::pair<double,double>*)buffer, (std::pair<double,double>*)(ptr - 2), PointLess( ));
ret->bounds = AndrewHull<std::pair<double,double>*,SimplePOINT>
- ((std::pair<double,double>*)buffer,
- ((std::pair<double,double>*)ptr) - 1,
+ ((std::pair<double,double>*)buffer,
+ ((std::pair<double,double>*)ptr) - 1,
(int)tm.line_pos.size()*4, cxt->pool);
return ret;
-SE_RenderPrimitive* SE_Raster::evaluate(SE_EvalContext* cxt)
+SE_RenderPrimitive* SE_Raster::evaluate(SE_EvalContext* cxt)
SE_RenderRaster* ret = new SE_RenderRaster();
@@ -192,11 +195,11 @@
rxf.transform( w, -h, pts[1].x, pts[1].y);
rxf.transform(-w, -h, pts[2].x, pts[2].y);
rxf.transform(-w, h, pts[3].x, pts[3].y);
std::sort((std::pair<double,double>*)pts, (std::pair<double,double>*)(pts + 3), PointLess( ));
- ((std::pair<double,double>*)pts,
- ((std::pair<double,double>*)(pts+3)) - 1,
+ ((std::pair<double,double>*)pts,
+ ((std::pair<double,double>*)(pts+3)) - 1,
4, cxt->pool);
return ret;
@@ -204,7 +207,7 @@
void SE_Style::evaluate(SE_EvalContext* cxt)
- //evaluate values that are common to all styles
+ //evaluate values that are common to all styles
rstyle->renderPass = renderPass.evaluate(cxt->exec);
@@ -215,7 +218,7 @@
double minx, maxx, miny, maxy;
double growx, growy;
SE_Matrix growxform;
if (useBox)
dx = resizePosition[0].evaluate(cxt->exec);
@@ -324,7 +327,7 @@
break;
if (rstyle->bounds)
SE_Bounds* bounds = rstyle->bounds;
@@ -339,8 +342,8 @@
-void SE_PointStyle::evaluate(SE_EvalContext* cxt)
+void SE_PointStyle::evaluate(SE_EvalContext* cxt)
SE_RenderPointStyle* render;
if (cacheable && rstyle)
@@ -385,7 +388,7 @@
double slope_rad = 0.0;
cxt->geometry->Centroid(LineBuffer::ctLine, &x0, &y0, &slope_rad);
- angle = slope_rad;
+ angle = slope_rad;
//TODO: do we really need to invert this in case of y-down?
if (cxt->xform->y1 < 0)
@@ -408,8 +411,8 @@
SE_Style::evaluate(cxt);
-void SE_LineStyle::evaluate(SE_EvalContext* cxt)
+void SE_LineStyle::evaluate(SE_EvalContext* cxt)
SE_RenderLineStyle* render;
@@ -439,8 +442,8 @@
-void SE_AreaStyle::evaluate(SE_EvalContext* cxt)
+void SE_AreaStyle::evaluate(SE_EvalContext* cxt)
SE_RenderAreaStyle* render;
More information about the mapguide-commits
