[mapguide-commits] r1366 - in trunk/MgDev: Common/Foundation/System
Common/MapGuideCommon/MapLayer Common/PlatformBase/MapLayer
Server/src/Common/Manager
svn_mapguide at osgeo.org
Fri Mar 23 22:10:49 EDT 2007
Author: stevedang
Date: 2007-03-23 22:10:49 -0400 (Fri, 23 Mar 2007)
New Revision: 1366
trunk/MgDev/Common/Foundation/System/Util.cpp
trunk/MgDev/Common/Foundation/System/Util.h
trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp
trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.h
trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h
trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp
trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.h
trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.cpp
trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.h
trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
Implement MapGuide RFC 9 - Add Convenience Methods to MgLayerBase.
Modified: trunk/MgDev/Common/Foundation/System/Util.cpp
--- trunk/MgDev/Common/Foundation/System/Util.cpp 2007-03-24 00:37:34 UTC (rev 1365)
+++ trunk/MgDev/Common/Foundation/System/Util.cpp 2007-03-24 02:10:49 UTC (rev 1366)
@@ -620,7 +620,7 @@
STRING tmp = Trim(str, L" \t\r\n");
std::transform(tmp.begin(), tmp.end(), tmp.begin(), ::tolower);
- return tmp.compare(L"true") == 0 ? true : false;
+ return (tmp.compare(L"true") == 0 ? true : false);
INT32 MgUtil::StringToInt32(CREFSTRING str)
@@ -645,6 +645,14 @@
return ::wcstod(tmp.c_str(), NULL);
+bool MgUtil::StringToBoolean(const string& str)
+ string tmp = Trim(str, " \t\r\n");
+ std::transform(tmp.begin(), tmp.end(), tmp.begin(), ::tolower);
+ return (tmp.compare("true") == 0 ? true : false);
/// <summary>
/// Generates an Universal Unique IDentifier.
Modified: trunk/MgDev/Common/Foundation/System/Util.h
--- trunk/MgDev/Common/Foundation/System/Util.h 2007-03-24 00:37:34 UTC (rev 1365)
+++ trunk/MgDev/Common/Foundation/System/Util.h 2007-03-24 02:10:49 UTC (rev 1366)
@@ -378,6 +378,15 @@
/// \brief
+ /// Converts a string to a boolean.
+ /// \return
+ /// returns boolean value.
+ static bool StringToBoolean(const string& str);
+ /// \brief
/// \param uuid
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp 2007-03-24 00:37:34 UTC (rev 1365)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp 2007-03-24 02:10:49 UTC (rev 1366)
@@ -16,6 +16,7 @@
#include "MapGuideCommon.h"
+#include "FSDSAX2Parser.h"
IMPLEMENT_CREATE_OBJECT(MgLayer)
@@ -27,8 +28,6 @@
// Creates a MgLayerBase object given a reference to a LayerDefinition
@@ -46,8 +45,28 @@
+/// \brief
+/// Return the map object.
+MgMapBase* MgLayer::GetMap()
+ MgMapBase* baseMap = NULL;
+ if (NULL != m_layers)
+ baseMap = m_layers->GetMap();
+ if (NULL == baseMap)
+ throw new MgNullReferenceException(L"MgLayerBase.GetMap",
+ __LINE__, __WFILE__, NULL, L"", NULL);
+ return baseMap;
// Parse the layer definition XML and extracts scale ranges,
// feature source and feature class from it
@@ -73,13 +92,12 @@
// If the class name is fully qualified (prefixed with a schema name),
// then use it to determine the schema name.
- STRING schemaName;
STRING className;
size_t pfxSep = m_featureName.find_first_of(L':');
if (pfxSep != STRING::npos)
// fully qualified
- schemaName = m_featureName.substr(0, pfxSep);
+ m_schemaName = m_featureName.substr(0, pfxSep);
className = m_featureName.substr(pfxSep + 1, m_featureName.length() - pfxSep - 1);
else
@@ -89,12 +107,12 @@
//TODO: How do we deal with different schemas? Just use first one for now...
Ptr<MgStringCollection> schemaNames = featureService->GetSchemas(resId);
- schemaName = schemaNames->GetItem(0);
+ m_schemaName = schemaNames->GetItem(0);
// Get the identity properties
Ptr<MgPropertyDefinitionCollection> idProps = featureService->GetIdentityProperties(resId,
- schemaName,
+ m_schemaName,
className);
assert(idProps != NULL);
for (int nIds=0; nIds<idProps->GetCount(); nIds++)
@@ -150,6 +168,7 @@
helper->WriteString(m_featureSourceId);
helper->WriteString(m_featureName);
+ helper->WriteString(m_schemaName);
helper->WriteString(m_geometry);
helper->WriteUINT32((UINT32)m_idProps.size());
@@ -197,6 +216,7 @@
helper->GetString(m_featureSourceId);
helper->GetString(m_featureName);
+ helper->GetString(m_schemaName);
helper->GetString(m_geometry);
UINT32 idCount = 0;
@@ -212,3 +232,122 @@
+/// \brief
+/// Gets the class definition for the feature class of the layer. If the
+/// feature class of the layer is extended with properties from other feature
+/// classes, then all those properties are also contained in the returned
+/// class definition.
+MgClassDefinition* MgLayer::GetClassDefinition()
+ Ptr<MgFeatureService> featureService = dynamic_cast<MgFeatureService*>(
+ GetMap()->GetService(MgServiceType::FeatureService));
+ Ptr<MgResourceIdentifier> resourceId = new MgResourceIdentifier(m_featureSourceId);
+ return featureService->GetClassDefinition(resourceId, m_schemaName, m_featureName);
+/// \brief
+/// Selects features from a feature source according to the
+/// criteria set in the MgFeatureQueryOptions argument The
+/// criteria are applied to all of the features in the feature
+/// source. If you want to apply the criteria to a subset of the
+/// features, use the MgFeatureService::SelectAggregate Method.
+MgFeatureReader* MgLayer::SelectFeatures(MgFeatureQueryOptions* options)
+ return featureService->SelectFeatures(resourceId, m_featureName, options);
+/// \brief
+/// Selects groups of features from a feature source and applies
+/// filters to each of the groups according to the criteria set
+/// in the MgFeatureAggregateOptions argument. If you want to
+/// apply the criteria to all features without grouping them, use
+/// the MgFeatureService::SelectFeatures Method.
+MgDataReader* MgLayer::SelectAggregate(MgFeatureAggregateOptions* options)
+ return featureService->SelectAggregate(resourceId, m_featureName, options);
+/// \brief
+/// Executes the MgDeleteFeatures, MgInsertFeatures,
+/// MgUpdateFeatures, MgLockFeatures or MgUnlockFeatures commands
+/// contained in the given MgFeatureCommandCollection object.
+MgPropertyCollection* MgLayer::UpdateFeatures(MgFeatureCommandCollection* commands)
+ Ptr<MgPropertyCollection> propCol;
+ MG_TRY()
+ // Get the content of the feature source.
+ Ptr<MgResourceService> resourceService = dynamic_cast<MgResourceService*>(
+ GetMap()->GetService(MgServiceType::ResourceService));
+ Ptr<MgByteReader> byteReader = resourceService->GetResourceContent(resourceId);
+ string xmlContent;
+ byteReader->ToStringUtf8(xmlContent);
+ // Create the feature source object.
+ MdfParser::FSDSAX2Parser parser;
+ parser.ParseString(xmlContent.c_str(),
+ (unsigned int)(xmlContent.length() * sizeof(char)));
+ ACE_ASSERT(parser.GetSucceeded());
+ auto_ptr<MdfModel::FeatureSource> featureSource;
+ featureSource.reset(parser.DetachFeatureSource());
+ // Get the provider name.
+ STRING providerName = (STRING)featureSource->GetProvider();
+ // Determine if the provider supports transactions.
+ bool useTransaction = false;
+ byteReader = featureService->GetCapabilities(providerName);
+ xmlContent.clear();
+ const string openTag = "<SupportsTransactions>"; //NOXLATE
+ const string closeTag = "</SupportsTransactions>"; //NOXLATE
+ size_t startIndex = xmlContent.find(openTag);
+ if (string::npos != startIndex)
+ size_t endIndex = xmlContent.find(closeTag, startIndex);
+ if (string::npos == endIndex)
+ throw new MgXmlParserException(L"MgLayer.UpdateFeatures",
+ else
+ string tagValue = xmlContent.substr(startIndex + openTag.length(),
+ endIndex - startIndex - openTag.length());
+ useTransaction = MgUtil::StringToBoolean(tagValue);
+ propCol = featureService->UpdateFeatures(resourceId, commands, useTransaction);
+ MG_CATCH_AND_THROW(L"MgLayer.UpdateFeatures")
+ return propCol.Detach();
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.h
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.h 2007-03-24 00:37:34 UTC (rev 1365)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.h 2007-03-24 02:10:49 UTC (rev 1366)
@@ -67,6 +67,158 @@
MgLayer(MgResourceIdentifier* layerDefinition, MgResourceService* resourceService);
+ /// \brief
+ /// Gets the class definition for the feature class of the layer. If the
+ /// feature class of the layer is extended with properties from other feature
+ /// classes, then all those properties are also contained in the returned
+ /// class definition. See \link Feature_Schema_Module Feature Schema \endlink.
+ /// <!-- Syntax in .Net, Java, and PHP -->
+ /// \htmlinclude DotNetSyntaxTop.html
+ /// virtual MgClassDefinition GetClassDefinition(string schemaName);
+ /// \htmlinclude SyntaxBottom.html
+ /// \htmlinclude JavaSyntaxTop.html
+ /// virtual MgClassDefinition GetClassDefinition(String schemaName);
+ /// \htmlinclude PHPSyntaxTop.html
+ /// \return
+ /// Returns an MgClassDefinition instance for the feature class of the layer.
+ /// \exception MgFeatureServiceException
+ /// \exception MgInvalidArgumentException
+ /// \exception MgFdoException
+ virtual MgClassDefinition* GetClassDefinition();
+ /// \brief
+ /// Selects features from a feature source according to the
+ /// criteria set in the MgFeatureQueryOptions argument The
+ /// criteria are applied to all of the features in the feature
+ /// source. If you want to apply the criteria to a subset of the
+ /// features, use the \link MgFeatureService::SelectAggregate MgFeatureService::SelectAggregate Method \endlink.
+ /// See \link FiltersAndExpressions Filters and expressions \endlink.
+ /// virtual MgFeatureReader SelectFeatures(MgFeatureQueryOptions options);
+ /// \param options (MgFeatureQueryOptions)
+ /// MgFeatureQueryOptions instance
+ /// containing all required filters for this
+ /// select operation.
+ /// \return
+ /// Returns an MgFeatureReader containing the set of selected
+ /// features.
+ virtual MgFeatureReader* SelectFeatures(MgFeatureQueryOptions* options);
+ /// \brief
+ /// Selects groups of features from a feature source and applies
+ /// filters to each of the groups according to the criteria set
+ /// in the MgFeatureAggregateOptions argument. If you want to
+ /// apply the criteria to all features without grouping them, use
+ /// the \link MgFeatureService::SelectFeatures MgFeatureService::SelectFeatures Method \endlink.
+ /// virtual MgDataReader SelectAggregate(MgFeatureAggregateOptions options);
+ /// \param options (MgFeatureAggregateOptions)
+ /// An MgFeatureAggregateOptions instance
+ /// containing all the criteria and filters
+ /// required for this select operation.
+ /// \return
+ /// Returns an MgDataReader containing the group values.
+ virtual MgDataReader* SelectAggregate(MgFeatureAggregateOptions* options);
+ /// \brief
+ /// Executes the MgDeleteFeatures, MgInsertFeatures,
+ /// MgUpdateFeatures, MgLockFeatures or MgUnlockFeatures commands
+ /// contained in the given MgFeatureCommandCollection object.
+ /// \remarks
+ /// The XML returned by MgFeatureService::GetCapabilities says
+ /// whether a provider supports SQL commands. See \link ProviderCapabilities Provider Capabilities \endlink.
+ /// virtual MgPropertyCollection UpdateFeatures(MgFeatureCommandCollection commands);
+ /// \param commands (MgFeatureCommandCollection)
+ /// A collection of feature commands to be
+ /// executed.
+ /// \return
+ /// Returns an MgPropertyCollection object. Each property in the
+ /// collection corresponds to a command in the
+ /// MgFeatureCommandCollection argument. The property name is the
+ /// index of the command in the feature command collection.
+ /// <ul>
+ /// <li>If the command is of type MgDeleteFeatures, the property
+ /// type is an MgPropertyType::Int32, and its value is the number
+ /// of features deleted.</li>
+ /// <li>If the command is of type MgInsertFeatures, the property
+ /// type is an MgPropertyType::Feature, and its value is a
+ /// MgFeatureReader object. The feature reader object contains
+ /// the set of properties inserted into the datastore by the
+ /// insert command.</li>
+ /// <li>If the command is of type MgUpdateFeatures, the property
+ /// type is MgPropertyType::Int32, and its value is the number of
+ /// features updated.</li>
+ /// <li>If the command is of type MgLockFeatures, the property
+ /// type is MgPropertyType::Feature, and its value is the number
+ /// of features locked.</li>
+ /// <li>If the command is of type MgUnLockFeatures, the property
+ /// features unlocked.</li>
+ /// </ul>
+ /// \exception MgInvalidOperationException
+ virtual MgPropertyCollection* UpdateFeatures(MgFeatureCommandCollection* commands);
INTERNAL_API:
@@ -131,6 +283,10 @@
delete this;
+private:
+ MgMapBase* GetMap();
CLASS_ID:
static const INT32 m_cls_id = MapGuide_MapLayer_Layer;
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2007-03-24 00:37:34 UTC (rev 1365)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2007-03-24 02:10:49 UTC (rev 1366)
@@ -39,7 +39,71 @@
+/// Constructs an MgMap object that takes an MgSiteConnection instance.
+/// The object cannot be used until either the Create or Open method is called.
+MgMap::MgMap(MgSiteConnection* siteConnection)
+ : MgMapBase(),
+ m_inSave(false),
+ m_unpackedLayersGroups(false)
+ if (NULL == siteConnection)
+ throw new MgNullArgumentException(L"MgMap.MgMap",
+ m_siteConnection = SAFE_ADDREF(siteConnection);
+/// Initialize the resource service on demand only.
+void MgMap::InitializeResourceService(MgResourceService* resourceService)
+ if (NULL != resourceService)
+ m_resourceService = SAFE_ADDREF(resourceService);
+ else if (NULL == m_resourceService.p)
+ if (NULL == m_siteConnection.p)
+ throw new MgNullReferenceException(L"MgMap.InitializeResourceService",
+ m_resourceService = dynamic_cast<MgResourceService*>(
+ m_siteConnection->CreateService(MgServiceType::ResourceService));
+ ACE_ASSERT(NULL != m_resourceService.p);
+/// \brief
+/// Returns an instance of the specified service.
+MgService* MgMap::GetService(INT32 serviceType)
+ throw new MgNullReferenceException(L"MgMap.GetSiteConnection",
+ if (MgServiceType::ResourceService == serviceType)
+ InitializeResourceService(NULL);
+ return SAFE_ADDREF((MgResourceService*)m_resourceService);
+ else
+ return m_siteConnection->CreateService(serviceType);
// Initializes a new Map object.
// This method is used for Mg Viewers or for offline map production.
@@ -48,6 +112,7 @@
MG_TRY()
+ InitializeResourceService(resourceService);
m_trackChangesDisabled = true;
m_mapDefinitionId = mapDefinition;
@@ -58,7 +123,7 @@
MgUtil::GenerateUuid(m_objectId);
//get the map definition from the resource repository
- Ptr<MgByteReader> content = resourceService->GetResourceContent(mapDefinition);
+ Ptr<MgByteReader> content = m_resourceService->GetResourceContent(mapDefinition);
Ptr<MgByteSink> sink = new MgByteSink(content);
Ptr<MgByte> bytes = sink->ToBuffer();
@@ -194,7 +259,7 @@
MapLayer* layer = (MapLayer*)layers->GetAt(i);
//create a runtime layer from this layer and add it to the layer collection
Ptr<MgResourceIdentifier> layerDefId = new MgResourceIdentifier(layer->GetLayerResourceID());
- Ptr<MgLayerBase> rtLayer = new MgLayer(layerDefId, resourceService);
+ Ptr<MgLayerBase> rtLayer = new MgLayer(layerDefId, m_resourceService);
rtLayer->SetName(layer->GetName());
rtLayer->SetVisible(layer->IsVisible());
rtLayer->SetLayerType(MgLayerType::Dynamic);
@@ -263,7 +328,7 @@
//create a runtime layer from this base layer and add it to the layer collection
Ptr<MgResourceIdentifier> layerDefId = new MgResourceIdentifier(baseLayer->GetLayerResourceID());
rtLayer->SetName(baseLayer->GetName());
rtLayer->SetVisible(true);
rtLayer->SetLayerType(MgLayerType::BaseMap);
@@ -322,6 +387,14 @@
MG_CATCH_AND_THROW(L"MgMap.Create")
+/// Initializes a new MgMap object given a map definition and a name for the map.
+/// This method is used for MapGuide Viewers or for offline map production.
+void MgMap::Create(MgResourceIdentifier* mapDefinition, CREFSTRING mapName)
+ Create(NULL, mapDefinition, mapName);
// Call down to base class implementation. Ptr<> seems to be
@@ -339,11 +412,13 @@
void MgMap::Open(MgResourceService* resourceService, CREFSTRING mapName)
- m_resourceService = SAFE_ADDREF(resourceService);
+ MG_TRY()
STRING sessionId;
- Ptr<MgUserInformation> userInfo = resourceService->GetUserInfo();
+ Ptr<MgUserInformation> userInfo = m_resourceService->GetUserInfo();
if (userInfo.p != NULL)
@@ -361,13 +436,22 @@
Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(L"Session:" + sessionId + L"//" + mapName + L"." + MgResourceType::Map);
- MgResource::Open(resourceService, resId);
+ MgResource::Open(m_resourceService, resId);
//Note: Layers and Groups are loaded on demand by UnpackLayersAndGroups
m_trackChangesDisabled = false;
+ MG_CATCH_AND_THROW(L"MgMap.Open")
+/// Loads the map object from a session repository.
+void MgMap::Open(CREFSTRING mapName)
+ Open(NULL, mapName);
// Saves the resource using the specified resource service and resource identifier.
@@ -376,15 +460,17 @@
void MgMap::Save(MgResourceService* resourceService)
+ MG_TRY()
if(m_resId == (MgResourceIdentifier*)NULL)
throw new MgNullReferenceException(L"MgMap.Save", __LINE__, __WFILE__, NULL, L"", NULL);
m_inSave = true;
- MG_TRY()
+ SerializeToRepository(m_resourceService, false);
- SerializeToRepository(resourceService, false);
Ptr<MgMemoryStreamHelper> streamHelper = PackLayersAndGroups();
if (NULL != (MgMemoryStreamHelper*) streamHelper)
@@ -392,7 +478,7 @@
Ptr<MgByteSource> bsource = new MgByteSource((BYTE_ARRAY_IN)streamHelper->GetBuffer(), streamHelper->GetLength());
Ptr<MgByteReader> resourceData = bsource->GetReader();
- resourceService->SetResourceData(m_resId, m_layerGroupTag, L"Stream", resourceData);
+ m_resourceService->SetResourceData(m_resId, m_layerGroupTag, L"Stream", resourceData);
MG_CATCH(L"MgMap.Save")
@@ -411,16 +497,18 @@
void MgMap::Save(MgResourceService* resourceService, MgResourceIdentifier* resourceId)
+ MG_TRY()
m_resId = SAFE_ADDREF(resourceId);
m_inSave = true;
- MG_TRY()
+ SerializeToRepository(m_resourceService, true);
- SerializeToRepository(resourceService, true);
@@ -428,7 +516,7 @@
@@ -441,6 +529,13 @@
m_inSave = false;
+/// Saves the Map.
+void MgMap::Save()
+ Save(NULL);
// Destruct a MgMap object
@@ -492,7 +587,7 @@
if (NULL == (MgMemoryStreamHelper*) m_layerGroupHelper)
// Need to query from Resource Service
- if (NULL != (MgResourceService*) m_resourceService)
+ if (NULL != m_resourceService.p)
Ptr<MgByteReader> breader = m_resourceService->GetResourceData(m_resId, m_layerGroupTag);
@@ -828,7 +923,13 @@
/// \brief
/// Sets internal resource service references. Used for Lazy loading
-void MgMap::SetDelayedLoadResourceService(MgResourceService* service)
+void MgMap::SetDelayedLoadResourceService(MgResourceService* resourceService)
- m_resourceService = SAFE_ADDREF(service);
+ if (NULL == resourceService)
+ throw new MgNullArgumentException(L"MgMap.SetDelayedLoadResourceService",
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2007-03-24 00:37:34 UTC (rev 1365)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2007-03-24 02:10:49 UTC (rev 1366)
@@ -39,6 +39,7 @@
class MgMap;
+class MgSiteConnection;
template class MG_MAPGUIDE_API Ptr<MgMap>;
#ifdef WIN32
@@ -234,6 +235,8 @@
/// Constructs an empty un-initialized MgMap object.
/// \remarks
+ /// This method has been depreciated. Use the following method:
+ /// MgMap(MgSiteConnection siteConnection)
/// The instance of MgMap cannot be used until either the \link MgMapBase::Create Create \endlink
/// or \link MgMapBase::Open Open \endlink
/// method is called.
@@ -258,10 +261,53 @@
/// \brief
+ /// Constructs an MgMap object that takes an MgSiteConnection instance.
+ /// \remarks
+ /// The instance of MgMap cannot be used until either the \link MgMapBase::Create Create \endlink
+ /// or \link MgMapBase::Open Open \endlink
+ /// method is called.
+ /// Session ID is required for this MgMap constructor.
+ /// MgMap cannot exist in the Library repository.
+ /// MgMap(MgSiteConnection siteConnection);
+ /// \param siteConnection (MgSiteConnection)
+ /// An MgSiteConnection instance the MgMap object can use to
+ /// allocate service instances.
+ /// <!-- Example (PHP) -->
+ /// \htmlinclude PHPExampleTop.html
+ /// See \link MgMapBase::Create Create \endlink.
+ /// \htmlinclude ExampleBottom.html
+ /// \code
+ /// $siteConn = new MgSiteConnection();
+ /// $userInfo = new MgUserInformation();
+ /// $userInfo->SetMgSessionId('abc123-xxx-yyy');
+ /// $siteConn->Open($userInfo);
+ /// $map = new MgMap($siteConn);
+ MgMap(MgSiteConnection* siteConnection);
+ /// \brief
/// Initializes a new MgMap object given a resource service, map
/// definition, and a name for the map. This method is used for
/// MapGuide Viewers or for offline map production.
+ /// \remarks
+ /// void Create(MgResourceIdentifier mapDefinition, string mapName)
/// void Create(MgResourceService resourceService, MgResourceIdentifier mapDefinition, string mapName);
@@ -298,6 +344,45 @@
/// \brief
+ /// Initializes a new MgMap object given a map definition
+ /// and a name for the map. This method is used for
+ /// MapGuide Viewers or for offline map production.
+ /// void Create(MgResourceIdentifier mapDefinition, string mapName);
+ /// void Create(MgResourceIdentifier mapDefinition, String mapName);
+ /// \param mapDefinition (MgResourceIdentifier)
+ /// An MgResourceIdentifier that specifies the
+ /// location of the map definition in a resource
+ /// repository.
+ /// \param mapName (String/string)
+ /// A string that specifies the name of the map.
+ /// \return
+ /// Returns nothing.
+ /// \code
+ /// // Assuming the site connection has already been intialized
+ /// $resourceID = new MgResourceIdentifier('Library://Calgary/Maps/Calgary.MapDefinition');
+ /// $map = new MgMap($site);
+ /// $map->Create($resourceID, 'Calgary');
+ /// \endcode
+ virtual void Create(MgResourceIdentifier* mapDefinition, CREFSTRING mapName);
+ /// \brief
/// Initializes a new Map object given a spatial reference system,
/// spatial extent of the map, and a name for the map. This method
/// is used for the WMS service implementation and creates a map
@@ -329,6 +414,8 @@
/// \remarks
+ /// void Open(string mapName)
/// For more information, see \link Mapping_Service_Module Mapping Service \endlink.
@@ -368,11 +455,54 @@
virtual void Open(MgResourceService* resourceService, CREFSTRING mapName);
+ /// \brief
+ /// Loads the map object from a session repository.
+ /// \remarks
+ /// For more information, see \link Mapping_Service_Module Mapping Service \endlink.
+ /// virtual void Open(string mapName);
+ /// virtual void Open(String mapName);
+ /// A string that specifies the name of the map. This
+ /// is the name that was specified when \link MgMapBase::Create Create \endlink
+ /// was called to create the map object.
+ /// \return
+ /// \code
+ /// $map->Open('Calgary');
+ /// \endcode
+ /// \todo
+ /// * [[Job for Philip: If I move that overview to the
+ /// Developer's Guide, update the xref here.]]
+ virtual void Open(CREFSTRING mapName);
/// \brief
/// Saves the Map using the specified resource service.
/// \remarks
/// This method assumes a valid resource identifier has already
/// been established via either Open or Save.
@@ -393,6 +523,15 @@
void Save(MgResourceService* resourceService, MgResourceIdentifier* resourceId);
+ /// \brief
+ /// Saves the Map.
+ /// \return
+ void Save();
INTERNAL_API:
/// \brief
@@ -423,12 +562,18 @@
/// \brief
+ /// Returns an instance of the specified service.
+ virtual MgService* GetService(INT32 serviceType);
+ /// \brief
- /// \param service
- /// Resource Service
+ /// \param resourceService
+ /// Resource service.
- void SetDelayedLoadResourceService(MgResourceService* service);
+ void SetDelayedLoadResourceService(MgResourceService* resourceService);
protected:
@@ -464,15 +609,20 @@
virtual void Dispose();
+private:
+ void InitializeResourceService(MgResourceService* resourceService);
CLASS_ID:
static const INT32 m_cls_id = MapGuide_MapLayer_Map;
private:
// Version for serialization
- static const int m_serializeVersion = (3<<16) + 0;
+ static const int m_serializeVersion = (4<<16) + 0;
+ static STRING m_layerGroupTag;
- static STRING m_layerGroupTag;
+ Ptr<MgSiteConnection> m_siteConnection;
Ptr<MgMemoryStreamHelper> m_layerGroupHelper;
Ptr<MgResourceService> m_resourceService;
bool m_inSave;
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp
--- trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp 2007-03-24 00:37:34 UTC (rev 1365)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp 2007-03-24 02:10:49 UTC (rev 1366)
@@ -489,6 +489,7 @@
m_scaleRanges.clear();
m_featureSourceId = L"";
m_featureName = L"";
+ m_schemaName = L"";
MG_TRY()
@@ -684,3 +685,56 @@
return m_geometry;
+/// \brief
+MgClassDefinition* MgLayerBase::GetClassDefinition()
+ throw new MgNotImplementedException(L"MgLayerBase.GetClassDefinition",
+/// \brief
+MgFeatureReader* MgLayerBase::SelectFeatures(MgFeatureQueryOptions* options)
+ throw new MgNotImplementedException(L"MgLayerBase.SelectFeatures",
+/// \brief
+MgDataReader* MgLayerBase::SelectAggregate(MgFeatureAggregateOptions* options)
+ throw new MgNotImplementedException(L"MgLayerBase.SelectAggregate",
+/// \brief
+MgPropertyCollection* MgLayerBase::UpdateFeatures(MgFeatureCommandCollection* commands)
+ throw new MgNotImplementedException(L"MgLayerBase.UpdateFeatures",
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.h
--- trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.h 2007-03-24 00:37:34 UTC (rev 1365)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.h 2007-03-24 02:10:49 UTC (rev 1366)
@@ -685,6 +685,159 @@
virtual STRING GetFeatureGeometryName(); /// _get
+ /// \brief
+ /// \return
+ /// \brief
+ /// \return
+ /// features.
+ /// \brief
+ /// \return
+ /// \brief
+ /// \remarks
+ /// executed.
+ /// \return
+ /// <ul>
+ /// </ul>
INTERNAL_API:
@@ -847,6 +1000,7 @@
SCALERANGES m_scaleRanges;
STRING m_featureSourceId;
STRING m_featureName;
+ STRING m_schemaName;
STRING m_geometry;
IdPropertyList m_idProps;
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.cpp
--- trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.cpp 2007-03-24 00:37:34 UTC (rev 1365)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.cpp 2007-03-24 02:10:49 UTC (rev 1366)
@@ -770,3 +770,13 @@
return "Map";
+/// \brief
+MgService* MgMapBase::GetService(INT32 serviceType)
+ throw new MgNotImplementedException(L"MgMapBase.GetService",
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.h
--- trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.h 2007-03-24 00:37:34 UTC (rev 1365)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.h 2007-03-24 02:10:49 UTC (rev 1366)
@@ -940,6 +940,12 @@
virtual void ResetLayersRefresh();
+ /// \brief
protected:
void TrackChange(CREFSTRING objectId, bool layer, MgObjectChange::ChangeType type, CREFSTRING param);
Modified: trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp 2007-03-24 00:37:34 UTC (rev 1365)
+++ trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp 2007-03-24 02:10:49 UTC (rev 1366)
@@ -754,8 +754,7 @@
// Get the feature source contents
Ptr<MgByteReader> byteReader = resourceService->GetResourceContent(resource, MgResourcePreProcessingType::Substitution);
- Ptr<MgByteSink> byteSink = new MgByteSink((MgByteReader*)byteReader);
- byteSink->ToStringUtf8(resourceContent);
+ byteReader->ToStringUtf8(resourceContent);
ValidateFeatureSource(resourceContent);
More information about the mapguide-commits
