[mapguide-commits] r1367 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Sat Mar 24 15:00:44 EDT 2007
Author: traianstanev
Date: 2007-03-24 15:00:43 -0400 (Sat, 24 Mar 2007)
New Revision: 1367
trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp
trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.h
Fixes to the highway shield positioning algorithm (fix by Martin).
Modified: trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp
--- trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp 2007-03-24 02:10:49 UTC (rev 1366)
+++ trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp 2007-03-24 19:00:43 UTC (rev 1367)
@@ -349,6 +349,78 @@
if (shieldCount < 1)
return;
+ SE_RenderLineStyle* rlStyle = (SE_RenderLineStyle* ) rstyle;
+ double startOffset = rlStyle->startOffset;
+ double increment = rlStyle->repeat;
+ // the endOffset is used in this context as the increment between multiple shields in one group
+ // double incrementS = 10 * mm2px;
+ double incrementS = rlStyle->endOffset;
+ // calc the overall length of this geometry
+ double totalLen = 0;
+ int pointIndex = 0;
+ for (int i = 0; i < geometry->cntr_count(); i++)
+ int ptcount = geometry->cntrs()[i];
+ double* pts = geometry->points() + 2*pointIndex;
+ for (int cur_seg = 0; cur_seg < ptcount - 1; cur_seg++)
+ double* seg = pts + cur_seg * 2;
+ // transform the point to screen space
+ double cx1, cy1, cx2, cy2;
+ renderer->WorldToScreenPoint(seg[0], seg[1], cx1, cy1);
+ renderer->WorldToScreenPoint(seg[2], seg[3], cx2, cy2);
+ // calc length
+ double dx = cx2 - cx1;
+ double dy = cy2 - cy1;
+ totalLen += sqrt(dx*dx + dy*dy);
+ pointIndex += ptcount;
+ if (startOffset >= 0)
+ // calc optimal start offset (with rlStyle->startOffset taken as a minimum)
+ // to co-locate shield groups placed on two-line highways where the two
+ // parallel lines are processed from opposit ends.
+ // this avoids a problem with perceived irregular placement when overposting
+ // removes just some of the duplicate shields
+ double shieldGroupLen = (shieldCount - 1) * incrementS;
+ // length in excess of the required length to place one group with startOffset on each side
+ double availLen = totalLen - (shieldGroupLen + 2 * startOffset);
+ if (availLen < 0)
+ // there is no room to 'properly' place even one group, nothing to do but cry about it
+ return;
+ int numAdditionalGroups = (int) (availLen / (shieldGroupLen + increment));
+ double additionalOffset = (availLen - numAdditionalGroups * (shieldGroupLen + increment)) / 2;
+ startOffset += additionalOffset;
+ else
+ // negative startOffset value disables the optimization
+ // use absolute value as the offset
+ startOffset = startOffset * -1;
SE_RenderPrimitiveList * symbolVectors = new SE_RenderPrimitiveList[shieldCount];
std::wstring countryCode = highwayInfo.getFirstToken();
@@ -363,10 +435,25 @@
SE_RenderRaster* rr = new SE_RenderRaster();
- std::wstring imgPathName = HIGWAY_SHIELD_SYMBOLS_LOCATION + HIGWAY_SHIELD_SYMBOLS_PREFIX +
- countryCode + L"_" + shieldType + L".png";
- rr->pngPtr = symbolManager->GetImageData(L"", imgPathName.c_str(), rr->pngSize);
+ std::wstring imgName = HIGWAY_SHIELD_SYMBOLS_PREFIX + countryCode + L"_" + shieldType + L".png";
+ rr->pngPtr = symbolManager->GetImageData(HIGWAY_SHIELD_SYMBOLS_RESOURCE.c_str(), imgName.c_str(), rr->pngSize);
+ if (rr->pngSize == 0)
+ // could not find the image or resource
+ // we could fall back and try to pick up the image from a disk file like this:
+ // std::wstring imgPathName = HIGWAY_SHIELD_SYMBOLS_LOCATION + imgName;
+ // rr->pngPtr = symbolManager->GetImageData(L"", imgPathName.c_str(), rr->pngSize);
+ // but let's not do that unles really necessary
+ // cannot just leave this shield empty, that causes exceptions later, so bail out
+ // TODO: find a better way to handle this condition
+ return;
rr->position[0] = 0;
rr->position[1] = 0;
rr->extent[0] = 20;
@@ -427,15 +514,13 @@
- SE_RenderLineStyle* style = (SE_RenderLineStyle* ) rstyle;
+ int ptindex = 0;
SE_Matrix symxf;
- int ptindex = 0;
- double increment = style->repeat;
- // double incrementS = 10 * mm2px; // the 'increment' used between multiple shields
- double incrementS = style->endOffset; // use endOffset as the increment between multiple shields
shieldIndex = 0;
+ // init position along the whole geometry to the start offset
+ double drawpos = startOffset;
for (int j=0; j<geometry->cntr_count(); j++)
// current polyline
@@ -443,7 +528,7 @@
double* pts = geometry->points() + 2*ptindex;
// init position along the current segment to the start offset
- double drawpos = style->startOffset;
+ // double drawpos = startOffset;
int cur_seg = 0;
@@ -484,16 +569,16 @@
// follow the segment and place the shield symbols alternated via shieldIndex
while (drawpos < len)
- if (style->drawLast)
+ if (rlStyle->drawLast)
- style->symbol = symbolVectors[shieldIndex];
- memcpy(style->bounds, symbolVectors[shieldIndex].front()->bounds, sizeof(style->bounds));
- SE_RenderStyle* clonedStyle = renderer->CloneRenderStyle(style);
+ rlStyle->symbol = symbolVectors[shieldIndex];
+ memcpy(rlStyle->bounds, symbolVectors[shieldIndex].front()->bounds, sizeof(rlStyle->bounds));
+ SE_RenderStyle* clonedStyle = renderer->CloneRenderStyle(rlStyle);
SE_LabelInfo info(symxf.x2, symxf.y2, 0.0, 0.0, RS_Units_Device, 0, clonedStyle);
- renderer->ProcessLabelGroup(&info, 1, RS_OverpostType_AllFit, style->addToExclusionRegions, geometry);
+ renderer->ProcessLabelGroup(&info, 1, RS_OverpostType_AllFit, rlStyle->addToExclusionRegions, geometry);
else
@@ -501,7 +586,7 @@
renderer->DrawSymbol(symbolVectors[shieldIndex], symxf, 0);
// TODO: if this is ever needed ...
- // if (style->addToExclusionRegions)
+ // if (rlStyle->addToExclusionRegions)
// renderer->AddExclusionRegion(style, symxf, 0);
@@ -531,6 +616,30 @@
ptindex += ptcount;
+ // cleanup time
+ // the rlStyle->symbol has been assigned various values from the 'symbolVectors',
+ // 'un-assign' it, so that we can clean them up
+ rlStyle->symbol.clear();
+ for (shieldIndex = 0; shieldIndex < shieldCount; shieldIndex++)
+ for (SE_RenderPrimitiveList::iterator iter = symbolVectors[shieldIndex].begin();
+ iter != symbolVectors[shieldIndex].end();
+ iter++)
+ // necessary since destructor of SE_RenderPrimitive is not virtual
+ switch ((*iter)->type)
+ case SE_RenderPolylinePrimitive: delete (SE_RenderPolyline*)(*iter);break;
+ case SE_RenderPolygonPrimitive: delete (SE_RenderPolygon*)(*iter);break;
+ case SE_RenderRasterPrimitive: delete (SE_RenderRaster*)(*iter);break;
+ case SE_RenderTextPrimitive: delete (SE_RenderText*)(*iter);break;
+ default: throw; //means there is a bug
delete [] symbolVectors;
Modified: trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.h
--- trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.h 2007-03-24 02:10:49 UTC (rev 1366)
+++ trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.h 2007-03-24 19:00:43 UTC (rev 1367)
@@ -20,8 +20,8 @@
#include "SE_RenderProxies.h"
-//const std::wstring HIGWAY_SHIELD_SYMBOLS_LOCATION = L"Library://Symbology/HighwaySymbols/";
const std::wstring HIGWAY_SHIELD_SYMBOLS_LOCATION = L"C:/";
+const std::wstring HIGWAY_SHIELD_SYMBOLS_RESOURCE = L"Library://Symbology/HighwaySymbols/MultipleShields.SymbolDefinition";
const std::wstring HIGWAY_SHIELD_SYMBOLS_PREFIX = L"shield_";
class LineBuffer;
More information about the mapguide-commits
