[mapguide-commits] r1369 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Sat Mar 24 22:55:10 EDT 2007
Author: waltweltonlair
Date: 2007-03-24 22:55:09 -0400 (Sat, 24 Mar 2007)
New Revision: 1369
trunk/MgDev/Common/Stylization/LabelRenderer.cpp
trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp
trunk/MgDev/Common/Stylization/SE_ExpressionBase.h
trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp
trunk/MgDev/Common/Stylization/SE_RenderProxies.h
trunk/MgDev/Common/Stylization/SE_Renderer.cpp
trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp
trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h
trunk/MgDev/Common/Stylization/StylizationEngine.cpp
Fixed some symbolization bugs:
- The SE_RenderStyle bounds was being initialized to all zero instead
of -/+DBL_MAX. In the case where all the render style's graphics were
offset from the origin you would therefore end up with an incorrect
overall bounds for the render style. I noticed this problem in the
case where I had set the symbol instance insertion offset to non-zero
values. The bounds are now correctly initialized.
- If a resize box is not defined but the primitive's ResizeControl is
set to AddToResizeBox, we now treat this as ResizeNone.
- GrowControl now defaults to GrowInXYMaintainAspect.
Cleaned up some code:
- No need to call SE_Matrix::setIdentity right after creating an SE_Matrix.
- SE_String::evaluate now always returns a non-NULL pointer to a string.
This lets us remove NULL checks in places that call this method.
- Got rid of the SE_EvalContext::useBox variable. Bounds for primitives
are now simply always computed when they're evaluated.
Modified: trunk/MgDev/Common/Stylization/LabelRenderer.cpp
--- trunk/MgDev/Common/Stylization/LabelRenderer.cpp 2007-03-25 00:15:18 UTC (rev 1368)
+++ trunk/MgDev/Common/Stylization/LabelRenderer.cpp 2007-03-25 02:55:09 UTC (rev 1369)
@@ -452,7 +452,6 @@
//apply position and rotation to the native bounds of the symbol
double angle = m_serenderer->GetFontEngine()->_Yup() ? info.m_tdef.rotation() : -info.m_tdef.rotation();
SE_Matrix m;
- m.setIdentity();
m.rotate(angle); //it is already in radians in there
m.translate(info.m_x, info.m_y);
@@ -494,7 +493,8 @@
lb.LineTo(fpts[2].x, fpts[2].y);
lb.LineTo(fpts[3].x, fpts[3].y);
lb.Close();
- m_serenderer->DrawScreenPolyline(&lb, 0xff000000, 0.0);
+ SE_Matrix xform;
+ m_serenderer->DrawScreenPolyline(&lb, &xform, 0xff000000, 0.0);
#endif
Modified: trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp
--- trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp 2007-03-25 00:15:18 UTC (rev 1368)
+++ trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp 2007-03-25 02:55:09 UTC (rev 1369)
@@ -988,7 +988,6 @@
SE_Matrix m;
- m.setIdentity();
@@ -1145,7 +1144,6 @@
SE_Matrix m;
- m.setIdentity();
Modified: trunk/MgDev/Common/Stylization/SE_ExpressionBase.h
--- trunk/MgDev/Common/Stylization/SE_ExpressionBase.h 2007-03-25 00:15:18 UTC (rev 1368)
+++ trunk/MgDev/Common/Stylization/SE_ExpressionBase.h 2007-03-25 02:55:09 UTC (rev 1369)
@@ -204,6 +204,7 @@
SE_INLINE const wchar_t* evaluate(RS_FilterExecutor* processor)
+ static const wchar_t* sEmpty = L"";
if (expression)
delete[] value;
@@ -227,7 +228,7 @@
- return value;
+ return value? value : sEmpty;
SE_INLINE void operator=(const wchar_t* s)
Modified: trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp
--- trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp 2007-03-25 00:15:18 UTC (rev 1368)
+++ trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp 2007-03-25 02:55:09 UTC (rev 1369)
@@ -153,7 +153,6 @@
double box_angle_rad = atan2(dy, dx);
SE_Matrix ixform;
- ixform.setIdentity();
ixform.translate(-cx, -cy); //factor out point position
ixform.rotate(-box_angle_rad); //factor out rotation
//double pixelToMeter = 0.001 / renderer->GetPixelsPerMillimeterScreen();
Modified: trunk/MgDev/Common/Stylization/SE_RenderProxies.h
--- trunk/MgDev/Common/Stylization/SE_RenderProxies.h 2007-03-25 00:15:18 UTC (rev 1368)
+++ trunk/MgDev/Common/Stylization/SE_RenderProxies.h 2007-03-25 02:55:09 UTC (rev 1369)
@@ -114,7 +114,12 @@
drawLast(false),
checkExclusionRegions(false),
addToExclusionRegions(false)
- { memset (&bounds, 0, sizeof(bounds));}
+ bounds[0].x = bounds[3].x = +DBL_MAX;
+ bounds[1].x = bounds[2].x = -DBL_MAX;
+ bounds[0].y = bounds[1].y = +DBL_MAX;
+ bounds[2].y = bounds[3].y = -DBL_MAX;
~SE_RenderStyle()
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
--- trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-25 00:15:18 UTC (rev 1368)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.cpp 2007-03-25 02:55:09 UTC (rev 1369)
@@ -419,7 +419,6 @@
void SE_Renderer::AddExclusionRegion(SE_RenderStyle* rstyle, SE_Matrix& xform, double angle)
SE_Matrix xform2;
- xform2.setIdentity();
xform2.rotate(angle);
xform2.translate(xform.x2, xform.y2);
Modified: trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp
--- trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp 2007-03-25 00:15:18 UTC (rev 1368)
+++ trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp 2007-03-25 02:55:09 UTC (rev 1369)
@@ -588,7 +588,7 @@
ResizeBox* box = simpleSymbol.GetResizeBox();
- m_style->useBox = box != NULL;
+ m_style->useBox = (box != NULL);
if (m_style->useBox)
ParseDoubleExpression(box->GetSizeX(), m_style->resizeSize[0]);
Modified: trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
--- trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp 2007-03-25 00:15:18 UTC (rev 1368)
+++ trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp 2007-03-25 02:55:09 UTC (rev 1369)
@@ -27,15 +27,6 @@
#include <functional>
-//assumes axis aligned
-static void SetUndefinedBounds(RS_F_Point* pts)
- pts[0].x = pts[3].x = DBL_MAX;
- pts[1].x = pts[2].x = -DBL_MAX;
- pts[0].y = pts[1].y = DBL_MAX;
- pts[2].y = pts[3].y = -DBL_MAX;
//assumes axis aligned bounds stored in src and dst
static void BoundsUnion(RS_F_Point* dst, RS_F_Point* src)
@@ -45,11 +36,12 @@
dst[2].y = dst[3].y = rs_max(dst[2].y, src[2].y);
static void ComputeGrowAmount(RS_F_Point* bounds, double minx, double miny, double maxx, double maxy, double &growx, double &growy)
double sx, sy;
- double cx = (minx + maxx)/2.0;
- double cy = (miny + maxy)/2.0;
+ double cx = 0.5*(minx + maxx);
+ double cy = 0.5*(miny + maxy);
minx -= cx;
maxx -= cx;
miny -= cy;
@@ -96,72 +88,63 @@
SE_RenderPolyline* ret = new SE_RenderPolyline();
const wchar_t* sResizeCtrl = resizeControl.evaluate(cxt->exec);
- ret->resize = (sResizeCtrl && wcscmp(sResizeCtrl, L"AdjustToResizeBox") == 0);
+ ret->resize = (wcscmp(sResizeCtrl, L"AdjustToResizeBox") == 0);
- double wx = weightScalable.evaluate(cxt->exec)? cxt->mm2pxw : cxt->mm2pxs;
- ret->weight = weight.evaluate(cxt->exec) * wx;
+ double wx = weightScalable.evaluate(cxt->exec)? cxt->mm2pxw : cxt->mm2pxs;
+ ret->weight = weight.evaluate(cxt->exec) * wx;
ret->geometry = geometry->Clone();
- ret->color = color.evaluate(cxt->exec);
+ ret->color = color.evaluate(cxt->exec);
- if (!cxt->useBox)
- ret->geometry->Transform(*cxt->xform, ret->weight);
+ ret->geometry->Transform(*cxt->xform, ret->weight);
- SE_Bounds* seb = ret->geometry->xf_bounds();
+ SE_Bounds* seb = ret->geometry->xf_bounds();
- //TODO: here we would implement rotating calipers algorithm to get
- //a tighter oriented box, but for now we just get the axis aligned bounds of the path
- ret->bounds[0].x = seb->min[0];
- ret->bounds[0].y = seb->min[1];
- ret->bounds[1].x = seb->max[0];
- ret->bounds[1].y = seb->min[1];
- ret->bounds[2].x = seb->max[0];
- ret->bounds[2].y = seb->max[1];
- ret->bounds[3].x = seb->min[0];
- ret->bounds[3].y = seb->max[1];
- else
- SetUndefinedBounds(ret->bounds);
+ //TODO: here we would implement a rotating calipers algorithm to get a tighter
+ // oriented box, but for now just get the axis-aligned bounds of the path
+ ret->bounds[0].x = seb->min[0];
+ ret->bounds[0].y = seb->min[1];
+ ret->bounds[1].x = seb->max[0];
+ ret->bounds[1].y = seb->min[1];
+ ret->bounds[2].x = seb->max[0];
+ ret->bounds[2].y = seb->max[1];
+ ret->bounds[3].x = seb->min[0];
+ ret->bounds[3].y = seb->max[1];
return ret;
SE_RenderPrimitive* SE_Polygon::evaluate(SE_EvalContext* cxt)
SE_RenderPolygon* ret = new SE_RenderPolygon();
- ret->fill = fill.evaluate(cxt->exec);
+ ret->fill = fill.evaluate(cxt->exec);
- if (!cxt->useBox)
- else
return ret;
SE_RenderPrimitive* SE_Text::evaluate(SE_EvalContext* cxt)
if (cxt->fonte == NULL)
@@ -169,7 +152,7 @@
SE_RenderText* ret = new SE_RenderText();
ret->text = textExpr.evaluate(cxt->exec);
ret->position[0] = position[0].evaluate(cxt->exec);
@@ -198,30 +181,24 @@
ret->tdef.bgcolor() = RS_Color::FromARGB(ghostColor.evaluate(cxt->exec));
const wchar_t* hAlign = hAlignment.evaluate(cxt->exec);
- if (hAlign)
- if (wcscmp(hAlign, L"Left") == 0)
- ret->tdef.halign() = RS_HAlignment_Left;
- else if (wcscmp(hAlign, L"Center") == 0)
- ret->tdef.halign() = RS_HAlignment_Center;
- else if (wcscmp(hAlign, L"Right") == 0)
- ret->tdef.halign() = RS_HAlignment_Right;
+ if (wcscmp(hAlign, L"Left") == 0)
+ ret->tdef.halign() = RS_HAlignment_Left;
+ else if (wcscmp(hAlign, L"Right") == 0)
+ ret->tdef.halign() = RS_HAlignment_Right;
+ else // default is Center
+ ret->tdef.halign() = RS_HAlignment_Center;
const wchar_t* vAlign = vAlignment.evaluate(cxt->exec);
- if (vAlign)
- if (wcscmp(vAlign, L"Bottom") == 0)
- ret->tdef.valign() = RS_VAlignment_Descent;
- else if (wcscmp(vAlign, L"Baseline") == 0)
- ret->tdef.valign() = RS_VAlignment_Base;
- else if (wcscmp(vAlign, L"Halfline") == 0)
- ret->tdef.valign() = RS_VAlignment_Half;
- else if (wcscmp(vAlign, L"Capline") == 0)
- ret->tdef.valign() = RS_VAlignment_Cap;
- else if (wcscmp(vAlign, L"Top") == 0)
- ret->tdef.valign() = RS_VAlignment_Ascent;
+ if (wcscmp(vAlign, L"Bottom") == 0)
+ ret->tdef.valign() = RS_VAlignment_Descent;
+ else if (wcscmp(vAlign, L"Halfline") == 0)
+ ret->tdef.valign() = RS_VAlignment_Half;
+ else if (wcscmp(vAlign, L"Capline") == 0)
+ ret->tdef.valign() = RS_VAlignment_Cap;
+ else if (wcscmp(vAlign, L"Top") == 0)
+ ret->tdef.valign() = RS_VAlignment_Ascent;
+ else // default is Baseline
+ ret->tdef.valign() = RS_VAlignment_Base;
RS_TextMetrics tm;
SE_Matrix txf;
@@ -229,7 +206,7 @@
txf.rotate(ret->tdef.rotation() * M_PI180);
txf.translate(ret->position[0], ret->position[1]);
- //compute axis aligned boudns of the text primitive
+ //compute axis aligned bounds of the text primitive
RS_F_Point fpts[4];
RS_Bounds xformBounds(+DBL_MAX, +DBL_MAX, -DBL_MAX, -DBL_MAX);
@@ -254,11 +231,12 @@
return ret;
SE_RenderPrimitive* SE_Raster::evaluate(SE_EvalContext* cxt)
SE_RenderRaster* ret = new SE_RenderRaster();
if (!pngPtr)
@@ -291,8 +269,8 @@
rxf.rotate(ret->angle);
rxf.translate(ret->position[0], ret->position[1]);
- double w = 0.5 * ret->extent[0];
- double h = 0.5 * ret->extent[1];
+ double w = 0.5*ret->extent[0];
+ double h = 0.5*ret->extent[1];
RS_F_Point pts[4];
rxf.transform( w, h, pts[0].x, pts[0].y);
@@ -305,6 +283,7 @@
return ret;
void SE_Style::evaluate(SE_EvalContext* cxt)
//evaluate values that are common to all styles
@@ -323,8 +302,8 @@
dx = resizePosition[0].evaluate(cxt->exec);
dy = resizePosition[1].evaluate(cxt->exec);
- sx = resizeSize[0].evaluate(cxt->exec)/2.0;
- sy = resizeSize[1].evaluate(cxt->exec)/2.0;
+ sx = 0.5*fabs(resizeSize[0].evaluate(cxt->exec));
+ sy = 0.5*fabs(resizeSize[1].evaluate(cxt->exec));
cxt->xform->transform(dx - sx, dy - sy, minx, miny);
cxt->xform->transform(dx + sx, dy + sy, maxx, maxy);
@@ -332,12 +311,7 @@
growx = 0.0;
growy = 0.0;
- //TODO: find a way to reorg the size box code to get rid of this flag
- cxt->useBox = true;
- else
- cxt->useBox = false;
for (SE_PrimitiveList::const_iterator src = symbol.begin(); src != symbol.end(); src++)
@@ -345,53 +319,50 @@
//evaluate the render primitive
SE_RenderPrimitive* rsym = sym->evaluate(cxt);
+ if (!rsym)
+ continue;
+ rstyle->symbol.push_back(rsym);
//add the primitive bounds to the overall render style bounds
- if (rsym)
+ if (!rsym->resize || !useBox)
+ BoundsUnion(rstyle->bounds, rsym->bounds);
+ //add the primitive bounds to the resize box, if necessary
+ if (useBox)
- if (!rsym->resize)
+ const wchar_t* sResizeCtrl = sym->resizeControl.evaluate(cxt->exec);
+ if (wcscmp(sResizeCtrl, L"AddToResizeBox") == 0)
- BoundsUnion(rstyle->bounds, rsym->bounds);
+ // TODO - rework how resize box growth is done
+ ComputeGrowAmount(rstyle->bounds, minx, miny, maxx, maxy, growx, growy);
- rstyle->symbol.push_back(rsym);
- if (useBox)
- const wchar_t* sResizeCtrl = sym->resizeControl.evaluate(cxt->exec);
- if (wcscmp(sResizeCtrl, L"AddToResizeBox") == 0)
- ComputeGrowAmount(rstyle->bounds, minx, miny, maxx, maxy, growx, growy);
+ // update all primitive which need to adjust to the resize box
if (useBox)
const wchar_t* sGrowCtrl = growControl.evaluate(cxt->exec);
- // TODO - if the string is empty we need to use the default
- if (sGrowCtrl)
+ if (wcscmp(sGrowCtrl, L"GrowInX") == 0)
- if (wcscmp(sGrowCtrl, L"GrowInX") == 0)
- growy = 0.0;
- else if (wcscmp(sGrowCtrl, L"GrowInY") == 0)
- growx = 0.0;
- else if (wcscmp(sGrowCtrl, L"GrowInXY") == 0)
- // TODO
- else if (wcscmp(sGrowCtrl, L"GrowInXYMaintainAspect") == 0)
- if (growy > growx)
- growx = growy;
- else if (growx > growy)
- growy = growx;
+ growy = 0.0;
+ else if (wcscmp(sGrowCtrl, L"GrowInY") == 0)
+ growx = 0.0;
+// else if (wcscmp(sGrowCtrl, L"GrowInXY") == 0)
+// // nothing to do
+ else // default is GrowInXYMaintainAspect
+ if (growy > growx)
+ growx = growy;
+ else if (growx > growy)
+ growy = growx;
SE_Matrix totalxf(*cxt->xform);
SE_Matrix growxf;
@@ -427,7 +398,7 @@
SE_RenderText* rt = (SE_RenderText*)rsym;
growxf.transform(rt->position[0], rt->position[1]);
- rt->tdef.font().height() *= growxf.y1;
+ rt->tdef.font().height() *= growxf.y1; // TODO: should this only be done if HeightScalable is true?
for (int j=0; j<4; j++)
growxf.transform(rt->bounds[j].x, rt->bounds[j].y);
break;
@@ -436,7 +407,7 @@
SE_RenderRaster* rr = (SE_RenderRaster*)rsym;
growxf.transform(rr->position[0], rr->position[1]);
- rr->extent[0] *= growxf.x0;
+ rr->extent[0] *= growxf.x0; // TODO: should this only be done if SizeScalable is true?
rr->extent[1] *= growxf.y1;
growxf.transform(rr->bounds[j].x, rr->bounds[j].y);
@@ -488,8 +459,8 @@
double angle = 0.0;
- const wchar_t* angleControl = this->angleControl.evaluate(cxt->exec);
- if (wcscmp(L"FromGeometry", angleControl) == 0)
+ const wchar_t* sAngleControl = angleControl.evaluate(cxt->exec);
+ if (wcscmp(L"FromGeometry", sAngleControl) == 0)
if (type == LineBuffer::ctLine || type == LineBuffer::ctArea)
@@ -520,6 +491,7 @@
SE_Style::evaluate(cxt);
void SE_LineStyle::evaluate(SE_EvalContext* cxt)
SE_RenderLineStyle* render;
@@ -551,6 +523,7 @@
void SE_AreaStyle::evaluate(SE_EvalContext* cxt)
SE_RenderAreaStyle* render;
@@ -581,16 +554,19 @@
void SE_PointStyle::apply(LineBuffer* geometry, SE_Renderer* renderer)
renderer->ProcessPoint(geometry, (SE_RenderPointStyle*)rstyle);
void SE_LineStyle::apply(LineBuffer* geometry, SE_Renderer* renderer)
renderer->ProcessLine(geometry, (SE_RenderLineStyle*)rstyle);
void SE_AreaStyle::apply(LineBuffer* geometry, SE_Renderer* renderer)
renderer->ProcessArea(geometry, (SE_RenderAreaStyle*)rstyle);
Modified: trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h
--- trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h 2007-03-25 00:15:18 UTC (rev 1368)
+++ trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h 2007-03-25 02:55:09 UTC (rev 1369)
@@ -46,7 +46,6 @@
double mm2pxs;
double mm2px;
SE_LineBufferPool* pool;
- bool useBox;
LineBuffer* geometry; //only used for SE_PointStyles -- get rid of it if possible
Modified: trunk/MgDev/Common/Stylization/StylizationEngine.cpp
--- trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-25 00:15:18 UTC (rev 1368)
+++ trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2007-03-25 02:55:09 UTC (rev 1369)
@@ -256,10 +256,8 @@
// only call StartFeature for the initial rendering pass
if (renderingPass == 0)
- const wchar_t* strTip = seTip->evaluate(executor);
- const wchar_t* strUrl = seUrl->evaluate(executor);
- RS_String rs_tip = strTip? strTip : L"";
- RS_String rs_url = strUrl? strUrl : L"";
+ RS_String rs_tip = seTip->evaluate(executor);
+ RS_String rs_url = seUrl->evaluate(executor);
RS_String& rs_thm = rule->legendLabel;
m_renderer->StartFeature(reader, rs_tip.empty()? NULL : &rs_tip, rs_url.empty()? NULL : &rs_url, rs_thm.empty()? NULL : &rs_thm);
@@ -340,7 +338,7 @@
style->rstyle->drawLast = sym->drawLast.evaluate(executor);
const wchar_t* positioningAlgo = sym->positioningAlgorithm.evaluate(executor);
- if (positioningAlgo && wcslen(positioningAlgo) > 0 && wcscmp(positioningAlgo, L"Default") != 0)
+ if (wcslen(positioningAlgo) > 0 && wcscmp(positioningAlgo, L"Default") != 0)
LayoutCustomLabel(positioningAlgo, geometry, tmpxform, style, style->rstyle, mm2px);
More information about the mapguide-commits
