[mapguide-commits] r1370 - in trunk/MgDev/Common:
MapGuideCommon/MapLayer PlatformBase/MapLayer
svn_mapguide at osgeo.org
Sun Mar 25 11:54:09 EDT 2007
Author: stevedang
Date: 2007-03-25 11:54:09 -0400 (Sun, 25 Mar 2007)
New Revision: 1370
trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp
trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp
trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.cpp
Some code cleanups in Map Layer projects.
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp 2007-03-25 02:55:09 UTC (rev 1369)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp 2007-03-25 15:54:09 UTC (rev 1370)
@@ -60,7 +60,7 @@
if (NULL == baseMap)
- throw new MgNullReferenceException(L"MgLayerBase.GetMap",
+ throw new MgNullReferenceException(L"MgLayer.GetMap",
__LINE__, __WFILE__, NULL, L"", NULL);
@@ -120,7 +120,8 @@
Ptr<MgDataPropertyDefinition> prop = dynamic_cast<MgDataPropertyDefinition*>(idProps->GetItem(nIds));
if (0 == (MgDataPropertyDefinition*)prop)
- throw new MgInvalidCastException(L"MgLayer::GetLayerInfoFromDefinition", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgInvalidCastException(L"MgLayer.GetLayerInfoFromDefinition",
+ __LINE__, __WFILE__, NULL, L"", NULL);
MgLayer::IdProperty idProp;
idProp.type = prop->GetDataType();
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2007-03-25 02:55:09 UTC (rev 1369)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2007-03-25 15:54:09 UTC (rev 1370)
@@ -89,7 +89,7 @@
if (NULL == m_siteConnection.p)
- throw new MgNullReferenceException(L"MgMap.GetSiteConnection",
+ throw new MgNullReferenceException(L"MgMap.GetService",
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp
--- trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp 2007-03-25 02:55:09 UTC (rev 1369)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.cpp 2007-03-25 15:54:09 UTC (rev 1370)
@@ -171,7 +171,8 @@
if (m_type == MgLayerType::BaseMap)
- throw new MgInvalidOperationException(L"MgLayer.SetVisible", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgInvalidOperationException(L"MgLayerBase.SetVisible",
ForceVisible(visible);
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.cpp
--- trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.cpp 2007-03-25 02:55:09 UTC (rev 1369)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.cpp 2007-03-25 15:54:09 UTC (rev 1370)
@@ -277,8 +277,12 @@
double MgMapBase::GetFiniteDisplayScaleAt(INT32 index)
INT32 scaleCount = (INT32)m_finiteDisplayScales.size();
if (index >= scaleCount || index < 0)
- throw new MgIndexOutOfRangeException(L"GetFiniteDisplayScaleAt", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgIndexOutOfRangeException(L"MgMapBase.GetFiniteDisplayScaleAt",
return m_finiteDisplayScales.at(index);
More information about the mapguide-commits
