[mapguide-commits] r1377 - trunk/MgDev/Web/src/mapadmin
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Mar 26 15:22:32 EDT 2007
Author: tonyfang
Date: 2007-03-26 15:22:31 -0400 (Mon, 26 Mar 2007)
New Revision: 1377
   trunk/MgDev/Web/src/mapadmin/resizablepagecomponents.php
   trunk/MgDev/Web/src/mapadmin/serverdatafunctions.php
- added Locale to Web Admin
- added DataConnectionPoolSizeCustom to Web Admin
- renamed some Connection Pooling Web Admin labels to be more descriptive
Modified: trunk/MgDev/Web/src/mapadmin/resizablepagecomponents.php
--- trunk/MgDev/Web/src/mapadmin/resizablepagecomponents.php	2007-03-26 17:39:32 UTC (rev 1376)
+++ trunk/MgDev/Web/src/mapadmin/resizablepagecomponents.php	2007-03-26 19:22:31 UTC (rev 1377)
@@ -533,7 +533,7 @@
         var $icon;
         var $action;
         var $disabled;
-		var $submitForm;
+        var $submitForm;
         function ToolbarButtonRecord()
@@ -542,7 +542,7 @@
             $this->icon = "";
             $this->action = "";
             $this->disabled = false;
-			$this->submitForm = true;
+            $this->submitForm = true;
     function DisplayStandaloneToolbar( $buttons, $formName, $class )
@@ -1103,7 +1103,8 @@
     define( 'DISPLAY_NAME_ID',                  "serverDisplayName" );
-    define( 'DEFAULT_LOCALE_ID',                "serverDefaultLocale" );
+    define( 'LOCALE_ID',                        "serverLocale" );
+    define( 'DEFAULT_MESSAGE_LOCALE_ID',        "serverDefaultMessageLocale" );
     define( 'LOCALIZATION_RESOURCES_PATH_ID',   "serverLocalizationResourcesPath" );
     define( 'TCP_IP_MTU_ID',                    "serverTcpIpMtu" );
     define( 'TEMP_PATH_ID',                     "serverTempPath" );
@@ -1120,8 +1121,10 @@
             $props->displayName = $post[ DISPLAY_NAME_ID ];
             CleanUpMagicQuotes( $props->displayName );
-        if ( array_key_exists( DEFAULT_LOCALE_ID, $post ) )
-            $props->defaultLocale = $post[ DEFAULT_LOCALE_ID ];
+        if ( array_key_exists( LOCALE_ID, $post ) )
+            $props->locale = $post[ LOCALE_ID ];
+        if ( array_key_exists( DEFAULT_MESSAGE_LOCALE_ID, $post ) )
+            $props->defaultMessageLocale = $post[ DEFAULT_MESSAGE_LOCALE_ID ];
         if ( array_key_exists( LOCALIZATION_RESOURCES_PATH_ID, $post ) )
             $props->localizationResourcesPath = $post[ LOCALIZATION_RESOURCES_PATH_ID ];
@@ -1169,10 +1172,14 @@
         echo '          <td  class="inputFormValue"><input class="inputFormValue" name="',DISPLAY_NAME_ID,'"',$enabledStr,' type="text" value="',$props->displayName,'"></td>',"\n";
         echo '      </tr>',"\n";
         echo '      <tr>',"\n";
-        echo '          <td class="propsInputLabel">Default locale:</td>',"\n";
-        echo '          <td class="inputFormValue"><input class="inputFormValue" name="',DEFAULT_LOCALE_ID,'"',$enabledStr,' type="text" value="',$props->defaultLocale,'"></td>',"\n";
+        echo '          <td class="propsInputLabel">Locale:</td>',"\n";
+        echo '          <td class="inputFormValue"><input class="inputFormValue" name="',LOCALE_ID,'"',$enabledStr,' type="text" value="',$props->locale,'"></td>',"\n";
         echo '      </tr>',"\n";
         echo '      <tr>',"\n";
+        echo '          <td class="propsInputLabel">Default message locale:</td>',"\n";
+        echo '          <td class="inputFormValue"><input class="inputFormValue" name="',DEFAULT_MESSAGE_LOCALE_ID,'"',$enabledStr,' type="text" value="',$props->defaultMessageLocale,'"></td>',"\n";
+        echo '      </tr>',"\n";
+        echo '      <tr>',"\n";
         echo '          <td class="propsInputLabel">Localization resources path:</td>',"\n";
         echo '          <td class="inputFormValue"><input class="inputFormValue" name="',LOCALIZATION_RESOURCES_PATH_ID,'"',$enabledStr,' type="text" value="',$props->localizationResourcesPath,'"></td>',"\n";
         echo '      </tr>',"\n";
@@ -1185,7 +1192,7 @@
         echo '          <td class="inputFormValue"><input class="inputFormValue" name="',TEMP_PATH_ID,'"',$enabledStr,' type="text" value="',$props->tempPath,'"></td>',"\n";
         echo '      </tr>',"\n";
         echo '      <tr>',"\n";
-        echo '          <td class="propsInputLabel">Fdo file path:</td>',"\n";
+        echo '          <td class="propsInputLabel">FDO file path:</td>',"\n";
         echo '          <td class="inputFormValue"><input class="inputFormValue" name="',FDO_PATH_ID,'"',$enabledStr,' type="text" value="',$props->fdoPath,'"></td>',"\n";
         echo '      </tr>',"\n";
         echo '      <tr>',"\n";
@@ -1193,11 +1200,11 @@
         echo '          <td class="inputFormValue"><input class="inputFormValue" name="',EMAIL_ID,'"',$enabledStr,' type="text" value="',$props->email,'"></td>',"\n";
         echo '      </tr>',"\n";
         echo '      <tr>',"\n";
-        echo '          <td class="propsInputLabel">Connection timeout (seconds):</td>',"\n";
+        echo '          <td class="propsInputLabel">Data connection timeout (seconds):</td>',"\n";
         echo '          <td class="inputFormValue"><input class="inputFormValue" name="',CONNECTION_TIMEOUT_ID,'"',$enabledStr,' type="text" value="',$props->connectionTimeOut,'"></td>',"\n";
         echo '      </tr>',"\n";
         echo '      <tr>',"\n";
-        echo '          <td class="propsInputLabel">Connection timer interval (seconds):</td>',"\n";
+        echo '          <td class="propsInputLabel">Data connection timer interval (seconds):</td>',"\n";
         echo '          <td class="inputFormValue"><input class="inputFormValue" name="',CONNECTION_TIMER_INT_ID,'"',$enabledStr,' type="text" value="',$props->connectionTimerInt,'"></td>',"\n";
         echo '      </tr>',"\n";
         echo '      <tr>',"\n";
@@ -1248,11 +1255,11 @@
         echo '          <td class="inputFormValue"><input class="inputFormValue" name="',$connStr.PORT_ID,'"',$enabledStr,' type="text" value="',$props->port,'"></td>',"\n";
         echo '      </tr>',"\n";
         echo '      <tr>',"\n";
-        echo '          <td class="propsInputLabel">Queue size:</td>',"\n";
+        echo '          <td class="propsInputLabel">Maximum queued operations:</td>',"\n";
         echo '          <td class="inputFormValue"><input class="inputFormValue" name="',$connStr.QUEUE_SIZE_ID,'"',$enabledStr,' type="text" value="',$props->queueSize,'"></td>',"\n";
         echo '      </tr>',"\n";
         echo '      <tr>',"\n";
-        echo '          <td class="propsInputLabel">Thread pool size:</td>',"\n";
+        echo '          <td class="propsInputLabel">Maximum threads in pool:</td>',"\n";
         echo '          <td class="inputFormValue"><input class="inputFormValue" name="',$connStr.THREAD_POOL_SIZE_ID,'"',$enabledStr,' type="text" value="',$props->threadPoolSize,'"></td>',"\n";
         echo '      </tr>',"\n";
         echo '  </table>',"\n";
@@ -1284,6 +1291,7 @@
     define( 'FEATURE_SERVICE_ENABLED_ID',           "featureServiceEnabled" );
     define( 'FEATURE_SERVICE_CONN_POOL_SIZE_ID',    "featureDataConnPoolSize" );
+    define( 'FEATURE_SERVICE_CONN_POOL_SIZE_CUSTOM_ID', "featureDataConnPoolSizeCustom" );
     define( 'FEATURE_SERVICE_CONN_TIMEOUT_ID',      "featureDataConnTimeOut" );
     define( 'FEATURE_SERVICE_CONN_TIMER_INT_ID',    "featureConnectionTimerInteval" );
     define( 'FEATURE_SERVICE_DATA_CACHE_SIZE_ID',   "featureDataCacheSize" );
@@ -1296,6 +1304,8 @@
             $props->enabled = '0';
         if ( array_key_exists( FEATURE_SERVICE_CONN_POOL_SIZE_ID, $post ) )
             $props->dataConnPoolSize = $post[ FEATURE_SERVICE_CONN_POOL_SIZE_ID ];
+        if ( array_key_exists( FEATURE_SERVICE_CONN_POOL_SIZE_CUSTOM_ID, $post ) )
+            $props->dataConnPoolSize = $post[ FEATURE_SERVICE_CONN_POOL_SIZE_CUSTOM_ID ];
         if ( array_key_exists( FEATURE_SERVICE_CONN_TIMEOUT_ID, $post ) )
             $props->dataConnTimeOut = $post[ FEATURE_SERVICE_CONN_TIMEOUT_ID ];
         if ( array_key_exists( FEATURE_SERVICE_CONN_TIMER_INT_ID, $post ) )
@@ -1307,7 +1317,7 @@
     function DisplayFeatureServicePropVals( $enabled, $props )
-        $sectionFields = array( FEATURE_SERVICE_CONN_POOL_SIZE_ID, FEATURE_SERVICE_CONN_TIMEOUT_ID, FEATURE_SERVICE_CONN_TIMER_INT_ID, FEATURE_SERVICE_DATA_CACHE_SIZE_ID );
+        $sectionFields = array( FEATURE_SERVICE_CONN_POOL_SIZE_ID, FEATURE_SERVICE_CONN_POOL_SIZE_CUSTOM_ID, FEATURE_SERVICE_CONN_TIMEOUT_ID, FEATURE_SERVICE_CONN_TIMER_INT_ID, FEATURE_SERVICE_DATA_CACHE_SIZE_ID );
         DisplayEnabledBar( "Feature Service", FEATURE_SERVICE_ENABLED_ID, $props->enabled, $enabled, $sectionFields );
         if ( $enabled && $props->enabled )
@@ -1317,19 +1327,23 @@
         echo '  <table  border="0" cellspacing="0" class="inputForm">',"\n";
         echo '      <tr>',"\n";
-        echo '          <td class="propsInputLabel">Data connection pool size:</td>',"\n";
+        echo '          <td class="propsInputLabel">Maximum connections pooled per provider (default):</td>',"\n";
         echo '          <td class="inputFormValue"><input class="inputFormValue" name="',FEATURE_SERVICE_CONN_POOL_SIZE_ID,'"',$enabledStr,' type="text" value="',$props->dataConnPoolSize,'"></td>',"\n";
         echo '      </tr>',"\n";
         echo '      <tr>',"\n";
-        echo '          <td class="propsInputLabel">Data connection timeout:</td>',"\n";
+        echo '          <td class="propsInputLabel">Maximum connections pooled per provider (custom):</td>',"\n";
+        echo '          <td class="inputFormValue"><input class="inputFormValue" name="',FEATURE_SERVICE_CONN_POOL_SIZE_CUSTOM_ID,'"',$enabledStr,' type="text" value="',$props->dataConnPoolSizeCustom,'"></td>',"\n";
         echo '          <td class="inputFormValue"><input class="inputFormValue" name="',FEATURE_SERVICE_CONN_TIMEOUT_ID,'"',$enabledStr,' type="text" value="',$props->dataConnTimeOut,'"></td>',"\n";
         echo '      </tr>',"\n";
         echo '      <tr>',"\n";
-        echo '          <td class="propsInputLabel">Data connection timer interval:</td>',"\n";
         echo '          <td class="inputFormValue"><input class="inputFormValue" name="',FEATURE_SERVICE_CONN_TIMER_INT_ID,'"',$enabledStr,' type="text" value="',$props->dataConnTimerInt,'"></td>',"\n";
         echo '      </tr>',"\n";
         echo '      <tr>',"\n";
-        echo '          <td class="propsInputLabel">Data cache size:</td>',"\n";
+        echo '          <td class="propsInputLabel">Maximum features cached:</td>',"\n";
         echo '          <td class="inputFormValue"><input class="inputFormValue" name="',FEATURE_SERVICE_DATA_CACHE_SIZE_ID,'"',$enabledStr,' type="text" value="',$props->dataCacheSize,'"></td>',"\n";
         echo '      </tr>',"\n";
Modified: trunk/MgDev/Web/src/mapadmin/serverdatafunctions.php
--- trunk/MgDev/Web/src/mapadmin/serverdatafunctions.php	2007-03-26 17:39:32 UTC (rev 1376)
+++ trunk/MgDev/Web/src/mapadmin/serverdatafunctions.php	2007-03-26 19:22:31 UTC (rev 1377)
@@ -922,8 +922,10 @@
         var $displayName;
         var $displayNamePropStr;
-        var $defaultLocale;
-        var $defaultLocalePropStr;
+        var $locale;
+        var $localePropStr;
+        var $defaultMessageLocale;
+        var $defaultMessageLocalePropStr;
         var $localizationResourcesPath;
         var $localizationResourcesPathPropStr;
         var $tcpIpMtu;
@@ -945,8 +947,10 @@
             $this->displayName = "";
             $this->displayNamePropStr = MgConfigProperties::GeneralPropertyDisplayName;
-            $this->defaultLocale = "";
-            $this->defaultLocalePropStr = MgConfigProperties::GeneralPropertyDefaultMessageLocale;
+            $this->locale = "";
+            $this->localePropStr = MgConfigProperties::GeneralPropertyLocale;
+            $this->defaultMessageLocale = "";
+            $this->defaultMessageLocalePropStr = MgConfigProperties::GeneralPropertyDefaultMessageLocale;
             $this->localizationResourcesPath = "";
             $this->localizationResourcesPathPropStr = MgConfigProperties::GeneralPropertyResourcesPath;
             $this->tcpIpMtu = "";
@@ -972,9 +976,12 @@
             $prop = $props->GetItem( $this->displayNamePropStr );
             $this->displayName = $prop->GetValue();
-            $prop = $props->GetItem( $this->defaultLocalePropStr );
-            $this->defaultLocale = $prop->GetValue();
+            $prop = $props->GetItem( $this->localePropStr );
+            $this->locale = $prop->GetValue();
+            $prop = $props->GetItem( $this->defaultMessageLocalePropStr );
+            $this->defaultMessageLocale = $prop->GetValue();
             $prop = $props->GetItem( $this->localizationResourcesPathPropStr );
             $this->localizationResourcesPath = $prop->GetValue();
             CleanUpPath( $this->localizationResourcesPath );
@@ -1015,7 +1022,7 @@
             global $errInvalidConnectionTimerInt;
             global $errInvalidServiceRegistrationTimerInt;
-            if ( empty( $this->defaultLocale ) )
+            if ( empty( $this->defaultMessageLocale ) )
                 throw new Exception( $errInvalidServerDefaultLocale );
             if ( empty( $this->localizationResourcesPath ) )
                 throw new Exception( $errInvalidServerLocalizationResourcesPath );
@@ -1040,9 +1047,12 @@
             $prop = new MgStringProperty( $this->displayNamePropStr , $this->displayName );
             $props->Add( $prop );
-            $prop = new MgStringProperty( $this->defaultLocalePropStr , $this->defaultLocale );
+            $prop = new MgStringProperty( $this->localePropStr , $this->locale );
+            $prop = new MgStringProperty( $this->defaultMessageLocalePropStr , $this->defaultMessageLocale );
+            $props->Add( $prop );
             $prop = new MgStringProperty( $this->localizationResourcesPathPropStr, $this->localizationResourcesPath );
@@ -1160,6 +1170,8 @@
         var $dataConnTimerIntPropStr;
         var $dataConnPoolSize;
         var $dataConnPoolSizePropStr;
+        var $dataConnPoolSizeCustom;
+        var $dataConnPoolSizeCustomPropStr;
         var $dataCacheSize;
         var $dataCacheSizePropStr;
@@ -1170,6 +1182,9 @@
             $this->dataConnPoolSize = 0;
             $this->dataConnPoolSizePropStr = MgConfigProperties::FeatureServicePropertyDataConnectionPoolSize;
             $this->dataConnPoolSizeID = "featureDataConnPoolSize";
+            $this->dataConnPoolSizeCustom = 0;
+            $this->dataConnPoolSizeCustomPropStr = MgConfigProperties::FeatureServicePropertyDataConnectionPoolSizeCustom;
+            $this->dataConnPoolSizeCustomID = "featureDataConnPoolSizeCustom";
             $this->dataConnTimeOut = 0;
             $this->dataConnTimeOutPropStr = MgConfigProperties::FeatureServicePropertyDataConnectionTimeout;
             $this->dataConnTimeOutID = "featureDataConnTimeOut";
@@ -1188,6 +1203,9 @@
             $prop = $props->GetItem( $this->dataConnPoolSizePropStr );
             $this->dataConnPoolSize = $prop->GetValue();
+            $prop = $props->GetItem( $this->dataConnPoolSizeCustomPropStr );
+            $this->dataConnPoolSizeCustom = $prop->GetValue();
             $prop = $props->GetItem( $this->dataConnTimeOutPropStr );
             $this->dataConnTimeOut = $prop->GetValue();
@@ -1201,12 +1219,15 @@
         function ValidateProps()
             global $errInvalidFeatureDataConnPoolSize;
+            global $errInvalidFeatureDataConnPoolSizeCustom;
             global $errInvalidFeatureDataConnTimeOut;
             global $errInvalidFeatureDataConnTimerInt;
             global $errInvalidFeatureDataCacheSize;
             if ( $this->dataConnPoolSize <= 0 )
                 throw new Exception( $errInvalidFeatureDataConnPoolSize );
+            if ( $this->dataConnPoolSizeCustom <= 0 )
+                throw new Exception( $errInvalidFeatureDataConnPoolSizeCustom );
             if ( $this->dataConnTimeOut <= 0 )
                 throw new Exception( $errInvalidFeatureDataConnTimeOut );
             if ( $this->dataConnTimerInt < 0 )
@@ -1222,6 +1243,9 @@
             $prop = new MgStringProperty( $this->dataConnPoolSizePropStr, $this->dataConnPoolSize );
+            $prop = new MgStringProperty( $this->dataConnPoolSizeCustomPropStr, $this->dataConnPoolSizeCustom );
             $prop = new MgStringProperty( $this->dataConnTimeOutPropStr, $this->dataConnTimeOut );
More information about the mapguide-commits mailing list
