[mapguide-commits] r1378 - trunk/MgDev/Web/src/mapadmin
svn_mapguide at osgeo.org
Mon Mar 26 17:12:51 EDT 2007
Author: tonyfang
Date: 2007-03-26 17:12:51 -0400 (Mon, 26 Mar 2007)
New Revision: 1378
trunk/MgDev/Web/src/mapadmin/addunmanageddata.php
trunk/MgDev/Web/src/mapadmin/editunmanageddata.php
trunk/MgDev/Web/src/mapadmin/msgs.php
trunk/MgDev/Web/src/mapadmin/resizablepagecomponents.php
trunk/MgDev/Web/src/mapadmin/unmanageddatamanagement.php
Update labels in Site Administration
- "Configure Unmanaged Data" -> "Configure External Files"
- "Add/Edit/Delete Mapping" -> "Add/Edit/Delete Alias"
- "Mapping Name" -> "Alias Name"
- "Location" -> "Path to External Folder"
- add Save/cancel bar to "Add/Edit Alias" pages
Modified: trunk/MgDev/Web/src/mapadmin/addunmanageddata.php
--- trunk/MgDev/Web/src/mapadmin/addunmanageddata.php 2007-03-26 19:22:31 UTC (rev 1377)
+++ trunk/MgDev/Web/src/mapadmin/addunmanageddata.php 2007-03-26 21:12:51 UTC (rev 1378)
@@ -144,15 +144,18 @@
<!-- Input Area -->
<table border="0" cellspacing="0" class="inputForm">
<tr>
- <td class="addUserInputLabel">Mapping Name :</td>
+ <td class="addUserInputLabel">Alias Name:</td>
<td class="inputFormValue"><input class="inputFormValue" name="<?php echo $mappingNameID?>" type="text" value="<?php echo $mappingName?>"></td>
</tr>
<tr>
- <td class="addUserInputLabel">Location :</td>
+ <td class="addUserInputLabel">Path to External Folder:</td>
<td class="inputFormValue"><input class="inputFormValue" name="<?php echo $locationID?>" type="text" value="<?php echo $location?>"></td>
</tr>
</table>
- <?php EndContentArea( true, $formName, $mappingNameID ); ?>
+ <?php
+ DisplaySaveCancelBar();
+ EndContentArea( true, $formName, $mappingNameID );
<!-- End of Contents Area --------------------------------------------------------------------------------------------->
</tr>
Modified: trunk/MgDev/Web/src/mapadmin/editunmanageddata.php
--- trunk/MgDev/Web/src/mapadmin/editunmanageddata.php 2007-03-26 19:22:31 UTC (rev 1377)
+++ trunk/MgDev/Web/src/mapadmin/editunmanageddata.php 2007-03-26 21:12:51 UTC (rev 1378)
@@ -113,7 +113,7 @@
$confirmationMsg = sprintf( $confSuccessfulAddition, $mappingName );
$selectedMapping = $mappingName;
SaveSessionVars();
- header( 'Location: unmanageddatamanagement.php?'.strip_tags(SID) );
+ header( 'Path to External File: unmanageddatamanagement.php?'.strip_tags(SID) );
exit();
@@ -156,15 +156,18 @@
<!-- Input Area -->
<tr>
- <td class="editUserInputLabel">Mapping Name :</td>
+ <td class="editUserInputLabel">Alias Name:</td>
<td class="inputFormValue"><input class="inputFormValue" name="<?php echo $mappingNameID?>" type="text" value="<?php echo $mappingName?>" size="60"></td>
</tr>
<tr>
- <td class="editUserInputLabel">Location :</td>
+ <td class="editUserInputLabel">Path to External Folder:</td>
<td class="inputFormValue"><input class="inputFormValue" name="<?php echo $locationID?>" type="text" value="<?php echo $location?>" size="60"></td>
</tr>
</table>
- <?php EndContentArea( true, $formName, $mappingNameID );?>
+ <?php
</tr>
Modified: trunk/MgDev/Web/src/mapadmin/msgs.php
--- trunk/MgDev/Web/src/mapadmin/msgs.php 2007-03-26 19:22:31 UTC (rev 1377)
+++ trunk/MgDev/Web/src/mapadmin/msgs.php 2007-03-26 21:12:51 UTC (rev 1378)
@@ -29,9 +29,9 @@
$errUserNameMissing = "User's name is not specified.";
$errNoGroupSelectionForDelete = "Group must be selected in order to delete.";
$errGroupNameMissing = "Group's name is not specified.";
- $errMappingNameMissing = "Mapping name is not specified.";
- $errMappingNameExists = "Mapping name already exists.";
- $errLocationMissing = "Location is not specified.";
+ $errMappingNameMissing = "Alias name is not specified.";
+ $errMappingNameExists = "Alias name already exists.";
+ $errLocationMissing = "Path to external folder is not specified.";
$errInvalidInput = "Input values are invalid.";
$errInvalidServerName = "Server name must be specified.";
$errInvalidServerAddress = "Server IP address must be specified.";
Modified: trunk/MgDev/Web/src/mapadmin/resizablepagecomponents.php
--- trunk/MgDev/Web/src/mapadmin/resizablepagecomponents.php 2007-03-26 19:22:31 UTC (rev 1377)
+++ trunk/MgDev/Web/src/mapadmin/resizablepagecomponents.php 2007-03-26 21:12:51 UTC (rev 1378)
@@ -68,9 +68,9 @@
define( 'CONFIGURE_SERVICES_TITLE', "Configure Services" );
define( 'LOG_MANAGEMENT_TITLE', "Manage Logs" );
define( 'SELECT_SITE_SERVER_TITLE', "Select Site Server" );
- define( 'UNMANAGEDDATA_MANAGEMENT_TITLE', "Configure Unmanaged Data" );
- define( 'ADD_UNMANAGEDDATA_TITLE', "Add Mapping" );
- define( 'EDIT_UNMANAGEDDATA_TITLE', "Edit Mapping" );
+ define( 'UNMANAGEDDATA_MANAGEMENT_TITLE', "Configure External Files" );
+ define( 'ADD_UNMANAGEDDATA_TITLE', "Add Alias" );
+ define( 'EDIT_UNMANAGEDDATA_TITLE', "Edit Alias" );
define( 'ADD_GROUP_TITLE', "Add Group" );
define( 'EDIT_GROUP_TITLE', "Edit Group" );
@@ -88,9 +88,9 @@
define( 'CONFIGURE_WFS_TITLE', "Configure WFS" );
- define( 'UNMANAGEDDATA_MANAGEMENT_MENU_ITEM', "Configure Unmanaged Data" );
- define( 'ADD_UNMANAGEDDATA_MENU_ITEM', "Add Mapping" );
- define( 'EDIT_UNMANAGEDDATA_MENU_ITEM', "Edit Mapping" );
+ define( 'UNMANAGEDDATA_MANAGEMENT_MENU_ITEM', "Configure External Files" );
+ define( 'ADD_UNMANAGEDDATA_MENU_ITEM', "Add Alias" );
+ define( 'EDIT_UNMANAGEDDATA_MENU_ITEM', "Edit Alias" );
$unmanagedDataMenuGroup[ UNMANAGEDDATA_MANAGEMENT_MENU_ITEM ] = 'unmanageddatamanagement.php';
$unmanagedDataMenuGroup[ ADD_UNMANAGEDDATA_MENU_ITEM ] = 'addunmanageddata.php';
$unmanagedDataMenuGroup[ EDIT_UNMANAGEDDATA_MENU_ITEM ] = 'editunmanageddata.php';
Modified: trunk/MgDev/Web/src/mapadmin/unmanageddatamanagement.php
--- trunk/MgDev/Web/src/mapadmin/unmanageddatamanagement.php 2007-03-26 19:22:31 UTC (rev 1377)
+++ trunk/MgDev/Web/src/mapadmin/unmanageddatamanagement.php 2007-03-26 21:12:51 UTC (rev 1378)
@@ -189,6 +189,15 @@
DisplayConfirmationMsg( $confirmationMsg );
DisplayErrorMsg( $errorMsg );
+ <div class="textMsg">
+ <br>
+ Configure aliases to external folders containing spatial files such as Raster, SDF, and SHP.
+ You can then connect directly to these external files, instead of loading them into the MapGuide Library.
+ <br><br>
+ </div>
<input type="hidden" name="<?php echo TABLE_PAGE_ID?>" value="<?php echo $currPage?>">
<input type="hidden" name="<?php echo $sortColumnID?>" value="<?php echo $sortColumn?>">
<input type="hidden" name="<?php echo $sortDirectionID?>" value="<?php echo $sortDirection?>">
@@ -200,22 +209,22 @@
// Toolbar
$buttons = array();
$button = new ToolbarButtonRecord();
- $button->label = "Add Mapping";
+ $button->label = "Add Alias";
$button->icon = "images/new.gif";
$button->action = "SetElementValue('".NEXT_PAGE_ID."', 'addunmanageddata.php');";
$buttons[0] = $button;
- $button->label = "Edit Mapping";
+ $button->label = "Edit Alias";
$button->icon = "images/edit.gif";
$button->disabled = !empty( $selectedMapping ) ? false : true;
$button->action = "SetElementValue('".NEXT_PAGE_ID."', 'editunmanageddata.php');";
$buttons[1] = $button;
- $button->label = "Delete Mapping";
+ $button->label = "Delete Alias";
$button->icon = "images/delete.gif";
$button->submitForm = false;
- $button->action = "ConditionalSubmitForm( '".$formName."', 'Are you sure you want to delete the selected mapping?', '".DELETE_SELECTION_ID."', true );";
+ $button->action = "ConditionalSubmitForm( '".$formName."', 'Are you sure you want to delete the selected alias?', '".DELETE_SELECTION_ID."', true );";
$buttons[2] = $button;
DisplayToolbar( $buttons, $formName );
@@ -231,8 +240,8 @@
$sortByLocationStr = "SetElementValue( '".$sortColumnID."', '".ID_SORT_COLUMN."');";
<td class="dataHeader"> </td>
- <td class="dataHeader"><a href="#" onClick="<?php echo $sortDirectionStr.$sortByMappingNameStr?>SubmitForm('<?php echo $formName?>');">Mapping Name<?php echo $mappingNameSortIconStr ?></a> </td>
- <td class="dataHeader"><a href="#" onClick="<?php echo $sortDirectionStr.$sortByLocationStr?>SubmitForm('<?php echo $formName?>');">Location<?php echo $locationSortIconStr ?></a> </td>
+ <td class="dataHeader"><a href="#" onClick="<?php echo $sortDirectionStr.$sortByMappingNameStr?>SubmitForm('<?php echo $formName?>');">Alias Name<?php echo $mappingNameSortIconStr ?></a> </td>
+ <td class="dataHeader"><a href="#" onClick="<?php echo $sortDirectionStr.$sortByLocationStr?>SubmitForm('<?php echo $formName?>');">Path to External Folder<?php echo $locationSortIconStr ?></a> </td>
</tr>
<?php
More information about the mapguide-commits
