[mapguide-commits] r4330 - trunk/MgDev/Server/src/Common/Manager
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Nov 5 14:59:41 EST 2009
Author: brucedechant
Date: 2009-11-05 14:59:40 -0500 (Thu, 05 Nov 2009)
New Revision: 4330
   trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
   trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.h
Fix for trac ticket 1140 - Add better support for PerCommandThreaded/MultiThreaded FDO providers
http://trac.osgeo.org/mapguide/ticket/1140
Notes:
- Added a check for PerCommandThreaded/MultiThreaded FDO provider capability
- Allow FDO connections to be reused if the underlying FDO provider supports PerCommandThreaded/MultiThreaded
Modified: trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp	2009-11-03 19:03:27 UTC (rev 4329)
+++ trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp	2009-11-05 19:59:40 UTC (rev 4330)
@@ -604,11 +604,14 @@
                             if(pFdoConnectionCacheEntry->ltName == ltName)
                                 // We have a long transaction name match
-                                if(!pFdoConnectionCacheEntry->bInUse)
+                                if((!pFdoConnectionCacheEntry->bInUse) ||
+                                   (providerInfo->GetThreadModel() == FdoThreadCapability_PerCommandThreaded) ||
+                                   (providerInfo->GetThreadModel() == FdoThreadCapability_MultiThreaded))
-                                    // It is not in use so claim it
+                                    // It is not in use or the provider is a PerCommandThreaded/MultiThreaded provider so claim it
                                     pFdoConnectionCacheEntry->lastUsed = ACE_OS::gettimeofday();
                                     pFdoConnectionCacheEntry->bInUse = true;
+                                    pFdoConnectionCacheEntry->nUseCount++;  // Only used by PerCommandThreaded/MultiThreaded
                                     // Check to see if the key is blank which indicates a blank connection string was cached
                                     if(0 < key.size())
@@ -1089,6 +1092,7 @@
             pFdoConnectionCacheEntry->bValid = true;
+            pFdoConnectionCacheEntry->nUseCount = 1;
             #ifdef _DEBUG_FDOCONNECTION_MANAGER
             ACE_DEBUG ((LM_DEBUG, ACE_TEXT("CacheFdoConnection:\nConnection: %@\nProvider = %W\nKey = %W\nVersion(LT) = %W\n\n"), (void*)pFdoConnection, provider.c_str(), key.c_str(), ltName.empty() ? L"(empty)" : ltName.c_str()));
@@ -1571,8 +1575,15 @@
                             // Are we supposed to release this provider from the cache?
                             if ((providerInfo->GetKeepCached()) && (pFdoConnectionCacheEntry->bValid))
-                                // Make the connection available
-                                pFdoConnectionCacheEntry->bInUse = false;
+                                // Try to make the connection available
+                                pFdoConnectionCacheEntry->nUseCount--;
+                                // If the provider was PerCommandThreaded/MultiThreaded the connection may still be in use
+                                if(0 >= pFdoConnectionCacheEntry->nUseCount)
+                                    pFdoConnectionCacheEntry->bInUse = false;
+                                    pFdoConnectionCacheEntry->nUseCount = 0;
                             else
@@ -1901,6 +1912,11 @@
                             info += (pFdoConnectionCacheEntry->bInUse) ? L"True" : L"False";
                             info += L"</InUse>\n";
+                            info += L"<UseCount>";
+                            ACE_OS::itoa(pFdoConnectionCacheEntry->nUseCount, buffer, 10);
+                            info += buffer;
+                            info += L"</UseCount>\n";
                             info += L"<LongTransaction>";
                             info += pFdoConnectionCacheEntry->ltName;
                             info += L"</LongTransaction>\n";
Modified: trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.h
--- trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.h	2009-11-03 19:03:27 UTC (rev 4329)
+++ trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.h	2009-11-05 19:59:40 UTC (rev 4330)
@@ -41,6 +41,7 @@
     ACE_Time_Value lastUsed;
     bool bValid;
     bool bInUse;
+    INT32 nUseCount;    // Used by PerCommandThreaded/MultiThreaded providers
 } FdoConnectionCacheEntry;
 // FDO Connection Cache
More information about the mapguide-commits mailing list
