[mapguide-commits] r4331 - in trunk/MgDev: Common/MapGuideCommon
Common/MapGuideCommon/Services Common/MapGuideCommon/System
Server/src/Services/Feature
svn_mapguide at osgeo.org
Thu Nov 5 22:06:50 EST 2009
Author: leaf
Date: 2009-11-05 22:06:50 -0500 (Thu, 05 Nov 2009)
New Revision: 4331
Added:
trunk/MgDev/Common/MapGuideCommon/Services/SqlResult.cpp
trunk/MgDev/Common/MapGuideCommon/Services/SqlResult.h
trunk/MgDev/Common/MapGuideCommon/Makefile.am
trunk/MgDev/Common/MapGuideCommon/MapGuideCommon.vcproj
trunk/MgDev/Common/MapGuideCommon/MapGuideCommonBuild.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp
trunk/MgDev/Common/MapGuideCommon/System/MapGuideCommonClassId.h
trunk/MgDev/Common/MapGuideCommon/System/MapGuideCommonFactory.cpp
trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlNonQuery.cpp
trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlQuery.cpp
Submit on behalf of Aleck Sun
Ticket 1141
This Defect is because the "params" argument of ExecuteSqlQuery and
ExecuteSqlNonQuery method will be used for return value, if the a parameter is
set as OUTPUT. However, current server structure does not allow out parameters.
Therefore, the solution is to create an intermediate object MgSqlResult which
contains a rowUpdated integer, an MgParameterCollection and an MgSqlDataReader
object. Once the ExecuteSqlQuery or ExecuteSqlNonQuery operation is finished,
the intermediate MgSqlResult object will be serialized. The ProxyFeatureService
will deserialize the MgSqlResult and process the value of out parameters.
Modified: trunk/MgDev/Common/MapGuideCommon/Makefile.am
--- trunk/MgDev/Common/MapGuideCommon/Makefile.am 2009-11-05 19:59:40 UTC (rev 4330)
+++ trunk/MgDev/Common/MapGuideCommon/Makefile.am 2009-11-06 03:06:50 UTC (rev 4331)
@@ -119,6 +119,7 @@
Services/TileDefs.cpp \
Services/TileService.cpp \
Services/UnitType.cpp \
+ Services/SqlResult.cpp \
System/ConfigProperties.cpp \
System/MapGuideCommonFactory.cpp \
System/MapGuideStream.cpp \
@@ -240,6 +241,7 @@
Services/TileDefs.h \
Services/TileService.h \
Services/UnitType.h \
+ Services/SqlResult.h \
System/ConfigProperties.h \
System/MapGuideCommonClassId.h \
System/MapGuideStream.h \
Modified: trunk/MgDev/Common/MapGuideCommon/MapGuideCommon.vcproj
--- trunk/MgDev/Common/MapGuideCommon/MapGuideCommon.vcproj 2009-11-05 19:59:40 UTC (rev 4330)
+++ trunk/MgDev/Common/MapGuideCommon/MapGuideCommon.vcproj 2009-11-06 03:06:50 UTC (rev 4331)
@@ -4677,6 +4677,46 @@
</File>
<File
+ RelativePath=".\Services\SqlResult.cpp"
+ <FileConfiguration
+ Name="Debug|Win32"
+ ExcludedFromBuild="true"
+ <Tool
+ Name="VCCLCompilerTool"
+ </FileConfiguration>
+ Name="Debug|x64"
+ <Tool
+ Name="Release|Win32"
+ <Tool
+ Name="Release|x64"
+ <Tool
+ </File>
+ <File
+ RelativePath=".\Services\SqlResult.h"
+ </File>
+ <File
RelativePath=".\Services\TileDefs.cpp"
<FileConfiguration
Modified: trunk/MgDev/Common/MapGuideCommon/MapGuideCommonBuild.cpp
--- trunk/MgDev/Common/MapGuideCommon/MapGuideCommonBuild.cpp 2009-11-05 19:59:40 UTC (rev 4330)
+++ trunk/MgDev/Common/MapGuideCommon/MapGuideCommonBuild.cpp 2009-11-06 03:06:50 UTC (rev 4331)
@@ -126,9 +126,11 @@
#include "Services/TileDefs.cpp"
#include "Services/TileService.cpp"
#include "Services/UnitType.cpp"
+#include "Services/SqlResult.cpp"
#include "System/ConfigProperties.cpp"
#include "System/MapGuideCommonFactory.cpp"
#include "System/MapGuideStream.cpp"
#include "System/UserInformation.cpp"
#include "System/CryptographyManager.cpp"
#include "Util/IpUtil.cpp"
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp 2009-11-05 19:59:40 UTC (rev 4330)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp 2009-11-06 03:06:50 UTC (rev 4331)
@@ -22,6 +22,7 @@
#include "ProxyDataReader.h"
#include "ProxyFeatureTransaction.h"
#include "Command.h"
+#include "Services/SqlResult.h"
static const int Feature_Service = (int)MgPacketParser::msiFeature;
@@ -1039,7 +1040,20 @@
SetWarning(cmd.GetWarningObject());
- Ptr<MgProxySqlDataReader> sqlReader = (MgProxySqlDataReader*)cmd.GetReturnValue().val.m_obj;
+ MgSqlResult * pResult = (MgSqlResult *)cmd.GetReturnValue().val.m_obj;
+ if(params != NULL)
+ Ptr<MgParameterCollection> retParams = pResult->GetParameters();
+ for(int i = 0; i < retParams->GetCount(); i++)
+ Ptr<MgParameter> para = params->GetItem(i);
+ Ptr<MgParameter> newpara = retParams->GetItem(i);
+ Ptr<MgNullableProperty> prop = newpara->GetProperty();
+ para->SetProperty(prop);
+ Ptr<MgProxySqlDataReader> sqlReader = (MgProxySqlDataReader *)pResult->GetReader();
if (sqlReader != NULL)
sqlReader->SetService(this); // Feature reader on proxy side would store proxy service to call GetFeatures()
@@ -1124,7 +1138,7 @@
MgCommand cmd;
cmd.ExecuteCommand(m_connProp, // Connection
- MgCommand::knInt32, // Return type expected
+ MgCommand::knObject, // Return type expected
MgFeatureServiceOpId::ExecuteSqlNonQueryWithTransaction_Id, // Command Code
4, // No of arguments
Feature_Service, // Service Id
@@ -1137,7 +1151,20 @@
- return cmd.GetReturnValue().val.m_i32;
+ return pResult->GetRowAffected();
Added: trunk/MgDev/Common/MapGuideCommon/Services/SqlResult.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/SqlResult.cpp (rev 0)
+++ trunk/MgDev/Common/MapGuideCommon/Services/SqlResult.cpp 2009-11-06 03:06:50 UTC (rev 4331)
@@ -0,0 +1,72 @@
+// Copyright (C) 2004-2009 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation
+#include "SqlResult.h"
+MG_IMPL_DYNCREATE(MgSqlResult);
+MgSqlResult::MgSqlResult()
+MgSqlResult::MgSqlResult(int rowAffected, MgParameterCollection * parameters, MgSqlDataReader * reader)
+: m_rowAffected(rowAffected), m_parameters(parameters), m_reader(reader)
+ if(parameters)
+ SAFE_ADDREF(parameters);
+ if(reader)
+ SAFE_ADDREF(reader);
+MgSqlResult::~MgSqlResult()
+int MgSqlResult::GetRowAffected()
+ return m_rowAffected;
+MgParameterCollection * MgSqlResult::GetParameters()
+ return SAFE_ADDREF((MgParameterCollection *)m_parameters);
+MgSqlDataReader * MgSqlResult::GetReader()
+ return SAFE_ADDREF((MgSqlDataReader *)m_reader);
+void MgSqlResult::Serialize(MgStream *stream)
+ stream->WriteInt32(m_rowAffected);
+ stream->WriteObject(m_parameters);
+ stream->WriteObject(m_reader);
+void MgSqlResult::Deserialize(MgStream* stream)
+ stream->GetInt32(m_rowAffected);
+ m_parameters = (MgParameterCollection *)stream->GetObject();
+ m_reader = (MgSqlDataReader *)stream->GetObject();
+INT32 MgSqlResult::GetClassId()
+ return m_cls_id;
\ No newline at end of file
Added: trunk/MgDev/Common/MapGuideCommon/Services/SqlResult.h
--- trunk/MgDev/Common/MapGuideCommon/Services/SqlResult.h (rev 0)
+++ trunk/MgDev/Common/MapGuideCommon/Services/SqlResult.h 2009-11-06 03:06:50 UTC (rev 4331)
@@ -0,0 +1,80 @@
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#ifndef _MG_SERVER_SQL_QUERY_RESULT_H_
+#define _MG_SERVER_SQL_QUERY_RESULT_H_
+class MgStream;
+class MgByteReader;
+/// <summary>
+/// The SqlReader interface provides a forward-only, read-only
+/// iterator for reading relational table data.
+/// The initial position of the SqlReader interface is prior to the first item.
+/// Thus, you must call ReadNext to begin accessing any data..
+/// </summary>
+class MG_MAPGUIDE_API MgSqlResult : public MgSerializable
+MG_DECL_DYNCREATE();
+DECLARE_CLASSNAME(MgSqlResult)
+public:
+ MgSqlResult();
+ MgSqlResult(int rowAffected, MgParameterCollection * parameters, MgSqlDataReader * reader);
+ ~MgSqlResult();
+ virtual int GetRowAffected();
+ virtual MgParameterCollection * GetParameters();
+ virtual MgSqlDataReader * GetReader();
+ /// <summary>
+ /// Serializes all features into an XML.
+ /// XML is serialized from the current position of feature reader in the order
+ /// data are retrieved.
+ /// <returns>MgByteReader holding XML.</returns>
+ MgByteReader* ToXml();
+ virtual INT32 GetClassId();
+protected:
+ virtual void Dispose()
+ delete this;
+ void Deserialize(MgStream* stream);
+ void Serialize(MgStream* stream);
+private:
+ int m_rowAffected;
+ Ptr<MgParameterCollection> m_parameters;
+ Ptr<MgSqlDataReader> m_reader;
+CLASS_ID:
+ static const INT32 m_cls_id = MapGuide_Service_SqlResult;
+#endif
Modified: trunk/MgDev/Common/MapGuideCommon/System/MapGuideCommonClassId.h
--- trunk/MgDev/Common/MapGuideCommon/System/MapGuideCommonClassId.h 2009-11-05 19:59:40 UTC (rev 4330)
+++ trunk/MgDev/Common/MapGuideCommon/System/MapGuideCommonClassId.h 2009-11-06 03:06:50 UTC (rev 4331)
@@ -109,6 +109,7 @@
#define MapGuide_Service_UserInformation MAPGUIDE_SERVICE_ID+6
#define MapGuide_Service_ServerAdmin MAPGUIDE_SERVICE_ID+7
#define MapGuide_Service_SiteInfo MAPGUIDE_SERVICE_ID+8
+#define MapGuide_Service_SqlResult MAPGUIDE_SERVICE_ID+9
// Drawing Service
#define MapGuide_DrawingService_DrawingService MAPGUIDE_DRAWINGSERVICE_ID+0
Modified: trunk/MgDev/Common/MapGuideCommon/System/MapGuideCommonFactory.cpp
--- trunk/MgDev/Common/MapGuideCommon/System/MapGuideCommonFactory.cpp 2009-11-05 19:59:40 UTC (rev 4330)
+++ trunk/MgDev/Common/MapGuideCommon/System/MapGuideCommonFactory.cpp 2009-11-06 03:06:50 UTC (rev 4331)
@@ -110,7 +110,9 @@
fact->Register(MapGuide_RenderingService_FeatureInformation, MgFeatureInformation::CreateObject);
fact->Register(MapGuide_RenderingService_RenderingOptions, MgRenderingOptions::CreateObject);
fact->Register(PlatformBase_FeatureService_FeatureTransaction, MgProxyFeatureTransaction::CreateObject);
+ fact->Register(MapGuide_Service_SqlResult, MgSqlResult::CreateObject);
MgServiceRegistry* registry = MgServiceRegistry::GetInstance();
registry->RegisterService(MgServiceType::DrawingService, MgProxyDrawingService::CreateService, sctRemoteServerToServer);
registry->RegisterService(MgServiceType::MappingService, MgProxyMappingService::CreateService, sctRemoteServerToServer);
Modified: trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlNonQuery.cpp
--- trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlNonQuery.cpp 2009-11-05 19:59:40 UTC (rev 4330)
+++ trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlNonQuery.cpp 2009-11-06 03:06:50 UTC (rev 4331)
@@ -20,6 +20,7 @@
#include "ServerFeatureService.h"
#include "LogManager.h"
#include "ServerFeatureTransactionPool.h"
@@ -128,7 +129,8 @@
INT32 rowsUpdated = m_service->ExecuteSqlNonQuery(resource, sqlNonSelectStatement, parameters, (MgTransaction*)transaction.p);
// Write the response
- EndExecution(rowsUpdated);
+ MgSqlResult result(rowsUpdated, parameters, NULL);
+ EndExecution(&result);
else
Modified: trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlQuery.cpp
--- trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlQuery.cpp 2009-11-05 19:59:40 UTC (rev 4330)
+++ trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlQuery.cpp 2009-11-06 03:06:50 UTC (rev 4331)
@@ -19,6 +19,7 @@
#include "OpExecuteSqlQuery.h"
@@ -174,8 +175,10 @@
// Execute the operation
Ptr<MgSqlDataReader> sqlReader = m_service->ExecuteSqlQuery(resource, sqlStatement, parameters, (MgTransaction*)transaction.p, fetchSize);
+ MgSqlResult result(0, parameters, sqlReader);
- EndExecution((MgSqlDataReader*)sqlReader);
else
More information about the mapguide-commits
