[mapguide-commits] r4246 - in branches/2.1/MgDev:
Common/CoordinateSystem Common/MapGuideCommon/MapLayer
Common/MdfModel Server/src/Services/Mapping
Server/src/Services/Rendering Server/src/Services/Tile
svn_mapguide at osgeo.org
Mon Sep 21 18:07:02 EDT 2009
Author: trevorwekel
Date: 2009-09-21 18:07:01 -0400 (Mon, 21 Sep 2009)
New Revision: 4246
branches/2.1/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp
branches/2.1/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
branches/2.1/MgDev/Common/MapGuideCommon/MapLayer/Map.h
branches/2.1/MgDev/Common/MdfModel/VectorScaleRange.cpp
branches/2.1/MgDev/Common/MdfModel/VectorScaleRange.h
branches/2.1/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
branches/2.1/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
branches/2.1/MgDev/Server/src/Services/Rendering/ServerRenderingService.h
branches/2.1/MgDev/Server/src/Services/Tile/ServerTileService.cpp
branches/2.1/MgDev/Server/src/Services/Tile/ServerTileService.h
Ticket #1098 Pull accidental RFC60 submission from 2.1 branch
Modified: branches/2.1/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp
--- branches/2.1/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp 2009-09-21 15:36:47 UTC (rev 4245)
+++ branches/2.1/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp 2009-09-21 22:07:01 UTC (rev 4246)
@@ -185,7 +185,6 @@
bool bResult=false;
#ifdef _WIN32
- //prepares the default path for dictionary failes
STRING sDirDefault;
@@ -204,10 +203,7 @@
sDirDefault = szPath;
sDirDefault += _T("\\Autodesk\\Geospatial Coordinate Systems"); //NOXLATE
szPathVar = sDirDefault.c_str();
- //else {
- // ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%t) CCoordinateSystemCatalog::GetDefaultDictionaryDir() - Could not read SpecialFolderPath from registry\n")));
if(szPathVar)
@@ -246,7 +242,7 @@
if (!bResult)
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemCatalog.GetDefaultDictionaryDir ", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemCatalog.GetDefaultDictionaryDir", __LINE__, __WFILE__, NULL, L"", NULL);
//And return success.
Modified: branches/2.1/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
--- branches/2.1/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2009-09-21 15:36:47 UTC (rev 4245)
+++ branches/2.1/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2009-09-21 22:07:01 UTC (rev 4246)
@@ -35,8 +35,7 @@
MgMap::MgMap()
: MgMapBase(),
m_inSave(false),
- m_unpackedLayersGroups(false),
- m_colorPalette(new STRCOLORLIST())
+ m_unpackedLayersGroups(false)
@@ -47,8 +46,7 @@
MgMap::MgMap(MgSiteConnection* siteConnection)
: MgMapBase(),
m_inSave(false),
if (NULL == siteConnection)
@@ -120,14 +118,6 @@
m_mapDefinitionId = SAFE_ADDREF(mapDefinition);
m_name = mapName;
- // dont forget to reset the colorlist from our layers if there are any left - you never know
- if (m_colorPalette && !m_colorPalette->empty())
- m_colorPalette->clear();
- delete m_colorPalette;
- m_colorPalette = new STRCOLORLIST();
// generate a unique id for this map
MgUtil::GenerateUuid(m_objectId);
@@ -267,7 +257,7 @@
for(int i = 0; i < layers->GetCount(); i++, displayOrder += LAYER_ZORDER_INCR)
MapLayer* layer = (MapLayer*)layers->GetAt(i);
- //create a runtime layer from this layerDefinition and add it to the layer collection
+ //create a runtime layer from this layer and add it to the layer collection
//pull identity properties as a batch process after the layers are created
Ptr<MgResourceIdentifier> layerDefId = new MgResourceIdentifier(layer->GetLayerResourceID());
Ptr<MgLayerBase> rtLayer = new MgLayer(layerDefId, m_resourceService, false);
@@ -371,7 +361,6 @@
// attach the layer to its group
rtLayer->SetGroup(rtGroup);
@@ -411,7 +400,6 @@
// there's nothing to unpack anymore in this case
m_unpackedLayersGroups = true;
MG_CATCH_AND_THROW(L"MgMap.Create")
@@ -433,7 +421,6 @@
m_name = mapName;
MgMapBase::Create(mapSRS, mapExtent, mapName);
- m_colorPalette = NULL;
@@ -610,15 +597,12 @@
MgMap::~MgMap()
- if (m_colorPalette != NULL) m_colorPalette->clear(); // clear the STL container
- delete m_colorPalette; // destroy the container
void MgMap::Dispose()
- if (m_colorPalette != NULL) m_colorPalette->clear(); // is this enough cleanup?
delete this;
@@ -1079,26 +1063,3 @@
-// ColorPalette Accessors
-// used for the map colors collected from the stylization of the visible layers
-PSTRCOLORLIST MgMap::GetColorPalette(CREFSTRING baseMapLayerGroupName)
- if (m_colorPalette == NULL)
- return m_colorPalette;
-/// setter does sort and prune the list also
-void MgMap::SetColorPalette(PSTRCOLORLIST newColorPalette, CREFSTRING baseMapLayerGroupName)
- // sort and delete duplicates if any coming in
- if (newColorPalette != NULL && !newColorPalette->empty())
- newColorPalette->sort();
- newColorPalette->unique();
- assert (m_colorPalette == newColorPalette); //make sure this is the same!
- m_colorPalette = newColorPalette;
Modified: branches/2.1/MgDev/Common/MapGuideCommon/MapLayer/Map.h
--- branches/2.1/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2009-09-21 15:36:47 UTC (rev 4245)
+++ branches/2.1/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2009-09-21 22:07:01 UTC (rev 4246)
@@ -22,19 +22,21 @@
/// \ingroup Maps_and_Layers_Module
+/*TSW remove
#include "Foundation.h"
#include <vector>
#include <list>
#include <map>
-//#include "LayerBase.h"
-//#include "LayerGroup.h"
-//#include "LayerCollection.h"
-//#include "LayerGroupCollection.h"
-//#include "MapCollection.h"
-//#include "ObjectChange.h"
-//#include "ChangeList.h"
-//#include "ReadOnlyLayerCollection.h"
-//#include "SelectionBase.h"
+#include "LayerBase.h"
+#include "LayerGroup.h"
+#include "LayerCollection.h"
+#include "LayerGroupCollection.h"
+#include "MapCollection.h"
+#include "ObjectChange.h"
+#include "ChangeList.h"
+#include "ReadOnlyLayerCollection.h"
+#include "SelectionBase.h"
class MgMap;
class MgSiteConnection;
@@ -44,8 +46,6 @@
#undef CreateService
#endif
-// workaround for preprocessor include problems
-#include "../MdfModel/VectorLayerDefinition.h"
/// \brief
@@ -578,10 +578,6 @@
virtual void OnLayerParentChanged(MgLayerBase* layer, CREFSTRING parentId);
- /// accessor for the colors as defined in the baseMap with given name
- PSTRCOLORLIST GetColorPalette(CREFSTRING baseMapLayerGroupName=L"");
- void SetColorPalette(PSTRCOLORLIST newColorPalette, CREFSTRING baseMapLayerGroupName=L"" );
/// Bulk load identity properties
@@ -640,7 +636,6 @@
Ptr<MgResourceService> m_resourceService;
bool m_inSave;
bool m_unpackedLayersGroups;
- PSTRCOLORLIST m_colorPalette;
Modified: branches/2.1/MgDev/Common/MdfModel/VectorScaleRange.cpp
--- branches/2.1/MgDev/Common/MdfModel/VectorScaleRange.cpp 2009-09-21 15:36:47 UTC (rev 4245)
+++ branches/2.1/MgDev/Common/MdfModel/VectorScaleRange.cpp 2009-09-21 22:07:01 UTC (rev 4246)
@@ -22,18 +22,7 @@
#include "stdafx.h"
#include "VectorScaleRange.h"
-#include "AreaRule.h"
-#include "LineRule.h"
-#include "PointRule.h"
-#include "CompositeRule.h"
-#include "BlockSymbol.h"
-#include "FontSymbol.h"
-#include "ImageSymbol.h"
-#include "MarkSymbol.h"
-#include "TextSymbol.h"
-#include "W2DSymbol.h"
using namespace MDFMODEL_NAMESPACE;
// we must undefine the max macro so the limits max function compiles correctly
@@ -55,7 +44,6 @@
this->m_dMinScale = 0.0;
this->m_dMaxScale = MAX_MAP_SCALE;
this->m_elevationSettings = NULL;
- this->m_usedColorList = NULL;
@@ -63,11 +51,8 @@
VectorScaleRange::~VectorScaleRange()
- // delete members which are pointers explicitely
if (this->m_elevationSettings != NULL)
delete this->m_elevationSettings;
- if (this->m_usedColorList != NULL)
- delete this->m_usedColorList;
@@ -156,112 +141,3 @@
this->m_elevationSettings = elevationSettings;
-/// PURPOSE: Accessor method for the base colors defined in this Layer and scaleRange.
-/// RETURNS: A pointer to the list of colors of the collected colors (maybe empty but not null)
-PSTRCOLORLIST VectorScaleRange::GetUsedColorList()
- // lazy instantiation
- if (this->m_usedColorList) return this->m_usedColorList;
- // this should be sufficiently thread safe as the object is created immediately
- PSTRCOLORLIST usedColorList = this->m_usedColorList = new STRCOLORLIST();
- // compute new color list by iterating through the featuretypecollection
- FeatureTypeStyleCollection* pftsColl = this->GetFeatureTypeStyles();
- int ftsccount = pftsColl->GetCount();
- for (int j=0; j< ftsccount; j++)
- FeatureTypeStyle* pfts = pftsColl->GetAt(j);
- // iterate through the rulecollection
- RuleCollection* ruleColl = pfts->GetRules();
- int rccount = ruleColl->GetCount();
- for (int k=0; k < rccount; k++)
- Rule* rule = ruleColl->GetAt(k);
- // get the label which will be the key in the color map
- const MdfString& label = rule->GetLegendLabel();
- // do the casting to access the relevant members
- // this is bad style (instead of virtual functions GetColors() in each subclass)
- // but we save touching too many different files
- AreaRule* paRule = dynamic_cast<AreaRule*>(rule);
- LineRule* plRule = dynamic_cast<LineRule*>(rule);
- PointRule* ppRule = dynamic_cast<PointRule*>(rule);
- //CompositeRule* pcRule = dynamic_cast<CompositeRule*>(rule); // no colors in there
- // AreaRule Symbolization.....
- if (paRule != NULL)
- { AreaSymbolization2D* pasym = paRule->GetSymbolization();
- if (pasym->GetFill() != NULL)
- { // create copies of all strings!!! so we can safely delete the resulting list later
- usedColorList->push_back(pasym->GetFill()->GetForegroundColor().substr());
- usedColorList->push_back(pasym->GetFill()->GetBackgroundColor().substr());
- if (pasym->GetEdge() != NULL)
- usedColorList->push_back(pasym->GetEdge()->GetColor().substr());
- // LineRule Symbolization.....
- if (plRule != NULL)
- LineSymbolizationCollection* plsymcol = plRule->GetSymbolizations();
- // iterate through the linesymbolizations
- int lsccount = plsymcol->GetCount();
- for (int l=0; l < lsccount; l++)
- LineSymbolization2D* plsym = plsymcol->GetAt(l);
- if (plsym->GetStroke() != NULL)
- usedColorList->push_back(plsym->GetStroke()->GetColor().substr());
- // PointRule Symbolization.....
- if (ppRule != NULL)
- PointSymbolization2D* ppsym = ppRule->GetSymbolization();
- if (ppsym)
- Symbol *sym = ppsym->GetSymbol();
- MdfModel::BlockSymbol* blockSymbol = dynamic_cast<MdfModel::BlockSymbol*>(sym);
- MdfModel::FontSymbol* fontSymbol = dynamic_cast<MdfModel::FontSymbol*>(sym);
- MdfModel::MarkSymbol* markSymbol = dynamic_cast<MdfModel::MarkSymbol*>(sym);
- MdfModel::TextSymbol* textSymbol = dynamic_cast<MdfModel::TextSymbol*>(sym);
- MdfModel::W2DSymbol* w2dSymbol = dynamic_cast<MdfModel::W2DSymbol*>(sym);
- if (blockSymbol != NULL)
- usedColorList->push_back(blockSymbol->GetBlockColor().substr());
- usedColorList->push_back(blockSymbol->GetLayerColor().substr());
- if (fontSymbol != NULL)
- usedColorList->push_back(fontSymbol->GetForegroundColor().substr());
- if (markSymbol != NULL)
- if (markSymbol->GetEdge() != NULL)
- usedColorList->push_back(markSymbol->GetEdge()->GetColor().substr());
- if (markSymbol->GetFill() != NULL) {
- usedColorList->push_back(markSymbol->GetFill()->GetForegroundColor().substr());
- usedColorList->push_back(markSymbol->GetFill()->GetBackgroundColor().substr());
- if (textSymbol != NULL)
- usedColorList->push_back(textSymbol->GetForegroundColor().substr());
- usedColorList->push_back(textSymbol->GetBackgroundColor().substr());
- if (w2dSymbol != NULL)
- usedColorList->push_back(w2dSymbol->GetFillColor().substr());
- usedColorList->push_back(w2dSymbol->GetLineColor().substr());
- usedColorList->push_back(w2dSymbol->GetTextColor().substr());
- } // if pointSymbolization
- } // end pointRule
- } // for GetRules
- } // for GetFeatureTypeStyles
- return this->m_usedColorList;
Modified: branches/2.1/MgDev/Common/MdfModel/VectorScaleRange.h
--- branches/2.1/MgDev/Common/MdfModel/VectorScaleRange.h 2009-09-21 15:36:47 UTC (rev 4245)
+++ branches/2.1/MgDev/Common/MdfModel/VectorScaleRange.h 2009-09-21 22:07:01 UTC (rev 4246)
@@ -23,11 +23,7 @@
#include "FeatureTypeStyle.h"
#include "ElevationSettings.h"
#include "MdfRootObject.h"
-#include <list>
-typedef std::list<const MdfModel::MdfString> STRCOLORLIST;
-typedef STRCOLORLIST* PSTRCOLORLIST;
BEGIN_NAMESPACE_MDFMODEL
@@ -66,9 +62,6 @@
ElevationSettings* GetElevationSettings();
void AdoptElevationSettings(ElevationSettings* elevationSettings);
- // Computed Property : UsedColorList
- PSTRCOLORLIST GetUsedColorList();
private:
// Hidden copy constructor and assignment operator.
VectorScaleRange(const VectorScaleRange&);
@@ -86,9 +79,6 @@
// Extended data
ElevationSettings* m_elevationSettings;
- // cached colorlist
- PSTRCOLORLIST m_usedColorList;
typedef MdfOwnerCollection<VectorScaleRange> VectorScaleRangeCollection;
Modified: branches/2.1/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
--- branches/2.1/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2009-09-21 15:36:47 UTC (rev 4245)
+++ branches/2.1/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2009-09-21 22:07:01 UTC (rev 4246)
@@ -30,18 +30,11 @@
#include "StylizationUtil.h"
#include "Fdo.h"
-#include <algorithm>
//For logging
#include "ServerManager.h"
#include "LogManager.h"
#include "LogDetail.h"
-typedef std::list<const MdfString> STRCOLORLIST;
-#define myassert(COND,L,F) if (!(COND)){ printf ("(%d) failed assertion in %d %s", GetCurrentThreadId(), L,F); throw new exception();}
#ifndef _WIN32
#define _wcsnicmp wcsncasecmp
@@ -55,7 +48,7 @@
#endif
MdfModel::MapDefinition* MgMappingUtil::GetMapDefinition(MgResourceService* svcResource, MgResourceIdentifier* resId)
//get and parse the mapdef
@@ -83,7 +76,7 @@
return mdef;
RSMgFeatureReader* MgMappingUtil::ExecuteFeatureQuery(MgFeatureService* svcFeature,
RS_Bounds& extent,
MdfModel::VectorLayerDefinition* vl,
@@ -242,7 +235,7 @@
return new RSMgFeatureReader(rdr.p, svcFeature, featResId.p, options, vl->GetGeometry());
RSMgFeatureReader* MgMappingUtil::ExecuteRasterQuery(MgFeatureService* svcFeature,
RS_Bounds& extent,
MdfModel::GridLayerDefinition* gl,
@@ -353,8 +346,7 @@
return new RSMgFeatureReader(rdr.p, svcFeature, featResId.p, options, L"clipped_raster");
-/// this is called by the MgServerRenderingService::RenderMapInternal to render the layers
void MgMappingUtil::StylizeLayers(MgResourceService* svcResource,
MgDrawingService* svcDrawing,
@@ -543,39 +535,9 @@
dr->StartLayer(&layerInfo, &fcinfo);
ds->StylizeVectorLayer(vl, dr, rsReader, xformer, scale, NULL, NULL);
dr->EndLayer();
- // COLORPALETTE CODE from UV for Ticket #813
- // add the colors from this scaleRange and vectorlayer to the map colors
- // (overrideFilters == NULL could tells us
- // that we have been called for rendering a map and not for selection)
- try {
- // the map object owns the color list so get a pointer from there
- PSTRCOLORLIST pStringColorPalette = map->GetColorPalette();
- PSTRCOLORLIST vLayerColors = scaleRange->GetUsedColorList();
- if (!vLayerColors->empty())
- assert (pStringColorPalette);
- // add the vectorLayer's Colors to the map's color list
- STRCOLORLIST::iterator it = vLayerColors->begin();
- for(; it != vLayerColors->end(); it++)
- { // uppercase the colorcodes (FFABDEFF) and filter empty strings
- if (*it == L"") continue;
- STRING upc = *it;
- std::transform( upc.begin(), upc.end(), upc.begin(), towupper);
- pStringColorPalette->push_back(upc);
- assert (pStringColorPalette == map->GetColorPalette());
- // the property setter canonicalizes the palette
- map->SetColorPalette(pStringColorPalette);
- } catch (exception e) {
- ACE_DEBUG((LM_DEBUG, L"(%t) %w caught in MappingUtil.ColorPaletteGeneration\n", e.what()));
- throw e;
- else // not scaleRange
+ else
#ifdef _DEBUG
printf(" StylizeLayers() **NOT Stylizing - NO SCALE RANGE** Name:%S\n", (mapLayer->GetName()).c_str());
@@ -817,10 +779,7 @@
STRING stackTrace = exception->GetStackTrace(locale);
MG_LOG_EXCEPTION_ENTRY(message.c_str(), stackTrace.c_str());
- // cleanup
- TransformCache::Clear(transformCache);
-#if defined(_DEBUG) || defined(_DEBUG_PNG8)
+#ifdef _DEBUG
STRING details = mgException->GetDetails(locale);
wstring err = L"\n %t Error during stylization of layer ";
@@ -831,10 +790,8 @@
err += L"\n";
ACE_DEBUG( (LM_DEBUG, err.c_str()) );
#endif
- /// this exception can be thrown or not depending on a serverconfig setting
- // throw exception;
- } // if exception
- } // for all layers
#ifdef _DEBUG
printf("StylizeLayers() **MAPDONE** Layers:%d Total Time:%6.4f (s)\n\n", layers->GetCount(), (GetTickCount()-dwStart)/1000.0);
@@ -843,7 +800,7 @@
// When rendering a tile, we need to compute the extent used to determine
// which features to render into it. Features in adjacent tiles, but not
// in the current tile, will potentially draw in this tile due to their
@@ -1097,7 +1054,7 @@
return maxOffsetMCS;
// draws a given feature type style into an image
MgByteReader* MgMappingUtil::DrawFTS(MgResourceService* svcResource,
MdfModel::FeatureTypeStyle* fts,
@@ -1149,7 +1106,7 @@
return ccPoly->Envelope();
// returns an MgPolygon from a given envelope
MgPolygon* MgMappingUtil::GetPolygonFromEnvelope(MgEnvelope* env)
@@ -1169,7 +1126,7 @@
return new MgPolygon(outer, NULL);
void MgMappingUtilExceptionTrap(FdoException* except, int line, wchar_t* file)
MG_TRY()
@@ -1198,7 +1155,7 @@
MG_LOG_WARNING_ENTRY(MgServiceType::MappingService, message.c_str(), stackTrace.c_str());
void MgMappingUtil::InitializeStylizerCallback()
SetStylizerExceptionCallback(&MgMappingUtilExceptionTrap);
Modified: branches/2.1/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
--- branches/2.1/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2009-09-21 15:36:47 UTC (rev 4245)
+++ branches/2.1/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2009-09-21 22:07:01 UTC (rev 4246)
@@ -37,7 +37,7 @@
static const INT32 FILTER_HASTOOLTIPS = 4;
IMPLEMENT_CREATE_SERVICE(MgServerRenderingService)
// used when we want to process a given number of features
bool StylizeThatMany(void* data)
@@ -48,7 +48,7 @@
return false;
MgServerRenderingService::MgServerRenderingService() : MgRenderingService()
m_pCSFactory = new MgCoordinateSystemFactory();
@@ -110,12 +110,12 @@
GDRenderer::s_bGeneralizeData = bGeneralizeData;
MgServerRenderingService::~MgServerRenderingService()
MgByteReader* MgServerRenderingService::RenderTile(MgMap* map,
CREFSTRING baseMapLayerGroupName,
INT32 tileColumn,
@@ -186,8 +186,8 @@
return ret.Detach();
-/// render a map using all layers from the baseGroup
MgLayerGroup* baseGroup,
INT32 scaleIndex,
@@ -257,8 +257,7 @@
-/// default arg bKeepSelection = true
MgByteReader* MgServerRenderingService::RenderDynamicOverlay(MgMap* map,
MgSelection* selection,
CREFSTRING format)
@@ -267,8 +266,7 @@
return RenderDynamicOverlay(map, selection, format, true);
CREFSTRING format,
@@ -280,8 +278,7 @@
return RenderDynamicOverlay(map, selection, &options);
-/// called from API (first call of AjaxPgPViewerSampleApplication)
MgRenderingOptions* options)
@@ -347,8 +344,7 @@
MgByteReader* MgServerRenderingService::RenderMap(MgMap* map,
CREFSTRING format)
@@ -357,8 +353,7 @@
return RenderMap(map, selection, format, true);
-/// default arg bClip = false
CREFSTRING format,
@@ -367,10 +362,7 @@
return RenderMap(map, selection, format, bKeepSelection, false);
-/// render complete map around center point in given scale
-/// using maps background color and display sizes as default arguments to call the real rendermap method
-/// default arg (bKeepSelection = true, bClip = false)
CREFSTRING format,
@@ -401,8 +393,7 @@
MgEnvelope* extents,
@@ -415,9 +406,7 @@
return RenderMap(map, selection, extents, width, height, backgroundColor, format, true);
-/// render the provided extent of the map and align aspect ratios to the provided window
@@ -512,8 +501,8 @@
-/// default argument bKeepSelection = true
MgCoordinate* center,
@@ -526,8 +515,8 @@
// Call updated RenderMap API
return RenderMap(map, selection, center, scale, width, height, backgroundColor, format, true);
-/// default arguments bClip = false
@@ -540,9 +529,8 @@
return RenderMap(map, selection, center, scale, width, height, backgroundColor, format, bKeepSelection, false);
-/// render map around center point in given scale
-/// (default args bKeepSelection = true, bClip = false, backgroundColor = map->backgroundColor, width = map->getDisplayWidth, height = map->getDisplayHeight)
@@ -601,7 +589,7 @@
MgFeatureInformation* MgServerRenderingService::QueryFeatures(MgMap* map,
MgStringCollection* layerNames,
MgGeometry* geometry,
@@ -612,7 +600,7 @@
return QueryFeatures(map, layerNames, geometry, selectionVariant, L"", maxFeatures, 3 /*visible and selectable*/);
@@ -703,7 +691,7 @@
MgBatchPropertyCollection* MgServerRenderingService::QueryFeatureProperties(MgMap* map,
MgGeometry* filterGeometry,
@@ -714,7 +702,7 @@
return QueryFeatureProperties(map, layerNames, filterGeometry, selectionVariant, L"", maxFeatures, 3 /*visible and selectable*/);
@@ -743,8 +731,8 @@
-/// pack options into object and forward call (select Selection AND Layers) maybe keepSelection
MgByteReader* MgServerRenderingService::RenderMapInternal(MgMap* map,
MgReadOnlyLayerCollection* roLayers,
@@ -762,14 +750,7 @@
return RenderMapInternal(map, selection, roLayers, dr, saveWidth, saveHeight, scale, b, expandExtents, &options);
-/// called from (indirectly):
-//// RenderMap(complete), RenderMap(extent)(roLayers == NULL)
-/// RenderTile (selection == NULL)
-/// render the map using from the provided rolayers
-///(this is the baseGroup layers for rendering tiles)
-/// render map using provided options object from before
-/// this is called for tiles and for dynamic overlays
@@ -823,10 +804,9 @@
// begin map stylization
dr->StartMap(&mapInfo, b, scale, map->GetDisplayDpi(), map->GetMetersPerUnit(), NULL);
- MG_TRY()
// if no layer collection is supplied, then put all layers in a temporary collection
Ptr<MgReadOnlyLayerCollection> tempLayers = SAFE_ADDREF(roLayers);
- if (tempLayers == NULL) // if called from renderMap not RenderTile
+ if (tempLayers == NULL)
tempLayers = new MgReadOnlyLayerCollection();
Ptr<MgLayerCollection> layers = map->GetLayers();
@@ -897,16 +877,8 @@
modLayers, overrideFilters, &ds, dr, dstCs, false, false, scale, (behavior & MgRenderingOptions::KeepSelection) != 0);
- MG_CATCH(L"MgServerRenderingService.RenderMapInternal-StylizeLayers")
- dr->EndMap(); // cleanup??
- if (mgException.p)
- //throw mgException; // to skip tile we need to throw an exception as a NULL return
- // // will cause a null pointer exception.
+ dr->EndMap();
// draw a border around the tile - used for debugging
@@ -937,29 +909,11 @@
// Both AGG and GD expect the format to be an uppercase string
STRING format = MgUtil::ToUpper(imageFormat);
- /// PNG8 code by UV
- /// we examine the expressions collected from xml definitions of all layer.
- /// the color Palette for the renderer is a vector<RSColor> allocated on the stack
- RSCOLORS tileColorPalette(map->GetColorPalette()->size());
- /// the map object has a list from all color entries found in the most recent Layerstylization
- /// TODO currently they are interpreted as ffffffff 32 bit RGBA string values.
- /// adding expresssions and other interpretations could be done here.
- try {
- ParseColorStrings (&tileColorPalette, map);
- #ifdef _DEBUG_PNG8
- printf("<<<<<<<<<<<<<<<<<<<<< MgServerRenderingService::ColorPalette->size(): %d\n", mapColorPalette->size());
- #endif
- // call the image renderer to create the image ----------------------------------------
- if (wcscmp(m_rendererName.c_str(), L"AGG") == 0)
- data.reset(((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight, &tileColorPalette));
- else
- data.reset(((GDRenderer*)dr)->Save(format, saveWidth, saveHeight));
- ACE_DEBUG((LM_DEBUG, L"(%t) %w caught in RenderingService ColorPaletteGeneration\n", e.what()));
- throw e;
+ if (wcscmp(m_rendererName.c_str(), L"AGG") == 0)
+ data.reset(((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight));
+ else
+ data.reset(((GDRenderer*)dr)->Save(format, saveWidth, saveHeight));
if (NULL != data.get())
// put this into a byte source
@@ -976,46 +930,11 @@
ret = bs->GetReader();
- else throw new MgNullArgumentException(L"RenderMapInternal", __LINE__, __WFILE__, NULL, L"No data from Renderer", NULL);
-/// PNG8 code by UV
-/// we examine the expressions collected from xml definitions of all layer.
-/// the color Palette for the renderer is a list<RSColor>
-//// PRSCOLORLIST tileColorPalette = new RSCOLORLIST();
-/// the map object has a list from all color entries found in the most recent Layerstylization
-/// TODO currently they are interpreted as ffffffff 32 bit RGBA string values.
-/// adding expresssions and other interpretations could be done here.
-void MgServerRenderingService::ParseColorStrings (PRSCOLORS tileColorPalette, MgMap* map)
- assert(tileColorPalette);
- assert(map);
- PSTRCOLORLIST mapColorList = map->GetColorPalette();
- if (mapColorList && !mapColorList->empty()) // add them if they are available
- // lets sort & uniquify the list
- mapColorList->sort();
- mapColorList->unique();
- STRCOLORLIST::iterator it = mapColorList->begin();
- for(int i=0; it != mapColorList->end(); it++,i++)
- // string color reader for 0xAARRGGBB "%10X" XML color strings
- // this is parsed and converted using the MgColor(string) ctor which also uses rgba order
- // but it* is in argb order ergo => r=a, g=r, b=g, a=b
- MgColor c(*it);
- // set the RS_Color(r,g,b,a) assign the crossed over colors
- tileColorPalette->at(i).red() = c.GetGreen();
- tileColorPalette->at(i).green() = c.GetBlue();
- tileColorPalette->at(i).blue() = c.GetAlpha();
- tileColorPalette->at(i).alpha() = c.GetRed();
MgByteReader* MgServerRenderingService::RenderMapLegend(MgMap* map,
INT32 width,
INT32 height,
@@ -1101,7 +1020,8 @@
// A helper function that does most of the work for QueryFeatures
// and QueryFeatureProperties. Basically runs a rendering loop with
// a custom renderer supplied by the caller that accumulates selection
@@ -1459,13 +1379,13 @@
MG_THROW()
void MgServerRenderingService::SetConnectionProperties(MgConnectionProperties*)
// Do nothing. No connection properties are required for server-side service objects.
SE_Renderer* MgServerRenderingService::CreateRenderer(int width,
int height,
RS_Color& bgColor,
Modified: branches/2.1/MgDev/Server/src/Services/Rendering/ServerRenderingService.h
--- branches/2.1/MgDev/Server/src/Services/Rendering/ServerRenderingService.h 2009-09-21 15:36:47 UTC (rev 4245)
+++ branches/2.1/MgDev/Server/src/Services/Rendering/ServerRenderingService.h 2009-09-21 22:07:01 UTC (rev 4246)
@@ -18,7 +18,6 @@
#ifndef MGSERVERRENDERINGSERVICE_H
#define MGSERVERRENDERINGSERVICE_H
-#include "AGGRenderer.h"
#include "ServerRenderingDllExport.h"
class SE_Renderer;
@@ -204,11 +203,6 @@
bool requiresClipping,
bool localOverposting = false,
double tileExtentOffset = 0.0);
- /// parse the expressions collected from xml definitions of all layer.
- /// the color Palette passed to the renderer is a std::list<RSColor>
- void ParseColorStrings (PRSCOLORS tileColorPalette, MgMap* map);
// member data
Ptr<MgFeatureService> m_svcFeature;
Modified: branches/2.1/MgDev/Server/src/Services/Tile/ServerTileService.cpp
--- branches/2.1/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2009-09-21 15:36:47 UTC (rev 4245)
+++ branches/2.1/MgDev/Server/src/Services/Tile/ServerTileService.cpp 2009-09-21 22:07:01 UTC (rev 4246)
@@ -116,15 +116,13 @@
return found;
-/// create tilename from mapDefinition, scaleIndex, row&col
-/// remove lockfile, look for the tile in the cache,
-/// if not in cache create lockfile and look for map in mapcache
-MgByteReader* MgServerTileService::GetTile( MgResourceIdentifier* mapDefinition,
- CREFSTRING baseMapLayerGroupName,
- INT32 tileColumn,
- INT32 tileRow,
- INT32 scaleIndex)
+MgByteReader* MgServerTileService::GetTile(
+ MgResourceIdentifier* mapDefinition,
+ CREFSTRING baseMapLayerGroupName,
+ INT32 tileColumn,
+ INT32 tileRow,
+ INT32 scaleIndex)
Ptr<MgByteReader> ret;
FILE* lockFile = NULL;
@@ -150,10 +148,27 @@
throw new MgInvalidArgumentException(L"MgServerTileService.GetTile",
__LINE__, __WFILE__, &arguments, L"MgInvalidScaleIndex", NULL);
- // Get the service from our helper method
- Ptr<MgResourceService> resourceService = GetResourceServiceForMapDef(mapDefinition,
- L"MgServerTileService.GetTile");
+ MgServiceManager* serviceMan = MgServiceManager::GetInstance();
+ assert(NULL != serviceMan);
+ // Get the service from service manager
+ Ptr<MgResourceService> resourceService = dynamic_cast<MgResourceService*>(
+ serviceMan->RequestService(MgServiceType::ResourceService));
+ assert(NULL != resourceService);
+ if (!resourceService->HasPermission(mapDefinition, MgResourcePermission::ReadOnly))
+ MG_LOG_AUTHENTICATION_ENTRY(MgResources::PermissionDenied.c_str());
+ MgStringCollection arguments;
+ arguments.Add(mapDefinition->ToString());
+ throw new MgPermissionDeniedException(
+ L"MgServerTileService.GetTile",
+ __LINE__, __WFILE__, &arguments, L"", NULL);
// Generate tile and lock pathnames.
m_tileCache->GeneratePathnames(mapDefinition, scaleIndex, baseMapLayerGroupName,
tileColumn, tileRow, tilePathname, lockPathname, false);
@@ -177,13 +192,11 @@
STRING mapString = mapDefinition->ToString();
Ptr<MgMap> map;
// Protect the serialized MgMap cache with a mutex. Stream reading is not
// thread safe so we need to deserialize the map within the mutex to ensure
// that a Rewind() is not called in the middle of a Deserialize()
- // lockfile test and creation is in same protected scope
- // Attemp to lock the tile file. ???? SOUNDS WRONG
+ // Attemp to lock the tile file.
ACE_MT(ACE_GUARD_RETURN(ACE_Recursive_Thread_Mutex, ace_mon, sm_mutex, NULL));
// Bail out if the tile file has been locked for so long.
@@ -201,7 +214,7 @@
if (NULL != ret)
- break; // tile was in tileCache .. done.
+ break;
// Create the lock file and close it right away.
@@ -212,9 +225,9 @@
arguments.Add(lockPathname);
- // MgUnableToOpenTileFile???? sounds wrong.... lock file maybe?
throw new MgFileIoException(L"MgServerTileService.GetTile",
- __LINE__, __WFILE__, &arguments, L"MgUnableToOpenLockFile", NULL);
+ __LINE__, __WFILE__, &arguments, L"MgUnableToOpenTileFile", NULL);
else
@@ -250,7 +263,7 @@
map = new MgMap();
map->Deserialize(stream);
- } // end of mutex scope
double scale = map->GetFiniteDisplayScaleAt(scaleIndex);
map->SetViewScale(scale);
@@ -271,8 +284,8 @@
-/// look for the tile in the tilecache first
MgByteReader* MgServerTileService::GetTile(MgMap* map,
INT32 tileColumn,
@@ -375,8 +388,7 @@
-/// render a tile and store it in da cache
MgByteReader* MgServerTileService::GetTile(CREFSTRING tilePathname, MgMap* map, INT32 scaleIndex,
CREFSTRING baseMapLayerGroupName, INT32 tileColumn, INT32 tileRow)
@@ -409,8 +421,7 @@
return img.Detach();
-/// take a tile image and store it in the tilecache using lockfiles
void MgServerTileService::SetTile(MgByteReader* img,
MgMap* map,
INT32 scaleIndex,
@@ -485,33 +496,8 @@
MG_THROW()
-/// accessor method for resource service
-MgResourceService* MgServerTileService::GetResourceServiceForMapDef
- (MgResourceIdentifier* mapDefinition, CREFSTRING funcName)
- // get service Manager
- MgServiceManager* serviceMan = MgServiceManager::GetInstance();
- assert(NULL != serviceMan);
- // Get the service from service manager
- Ptr<MgResourceService> resourceService = dynamic_cast<MgResourceService*>(
- serviceMan->RequestService(MgServiceType::ResourceService));
- assert(NULL != resourceService);
- if (!resourceService->HasPermission(mapDefinition, MgResourcePermission::ReadOnly))
- MG_LOG_AUTHENTICATION_ENTRY(MgResources::PermissionDenied.c_str());
- MgStringCollection arguments;
- arguments.Add(mapDefinition->ToString());
- throw new MgPermissionDeniedException(
- funcName, __LINE__, __WFILE__, &arguments, L"", NULL);
- return resourceService.Detach();
void MgServerTileService::ClearCache(MgMap* map)
MG_TRY()
Modified: branches/2.1/MgDev/Server/src/Services/Tile/ServerTileService.h
--- branches/2.1/MgDev/Server/src/Services/Tile/ServerTileService.h 2009-09-21 15:36:47 UTC (rev 4245)
+++ branches/2.1/MgDev/Server/src/Services/Tile/ServerTileService.h 2009-09-21 22:07:01 UTC (rev 4246)
@@ -68,8 +68,6 @@
CREFSTRING baseMapLayerGroupName, INT32 tileColumn, INT32 tileRow);
void ClearMapCache(CREFSTRING mapName);
- MgResourceService* GetResourceServiceForMapDef (MgResourceIdentifier* mapDefinition,
- CREFSTRING funcName);
// member data
Ptr<MgTileCache> m_tileCache;
More information about the mapguide-commits
