[mapguide-commits] r4247 - in trunk/MgDev:
Common/MapGuideCommon/Services Common/PlatformBase/Services
Server/src/Services/Feature
svn_mapguide at osgeo.org
Tue Sep 22 02:03:37 EDT 2009
Author: leaf
Date: 2009-09-22 02:03:36 -0400 (Tue, 22 Sep 2009)
New Revision: 4247
trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.h
trunk/MgDev/Common/PlatformBase/Services/FeatureQueryOptions.cpp
trunk/MgDev/Common/PlatformBase/Services/FeatureQueryOptions.h
trunk/MgDev/Common/PlatformBase/Services/FeatureService.h
trunk/MgDev/Server/src/Services/Feature/FeatureServiceCommand.h
trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlQuery.cpp
trunk/MgDev/Server/src/Services/Feature/SelectAggregateCommand.cpp
trunk/MgDev/Server/src/Services/Feature/SelectAggregateCommand.h
trunk/MgDev/Server/src/Services/Feature/SelectCommand.cpp
trunk/MgDev/Server/src/Services/Feature/SelectCommand.h
trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.h
trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp
trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h
trunk/MgDev/Server/src/Services/Feature/ServerSqlCommand.cpp
trunk/MgDev/Server/src/Services/Feature/ServerSqlCommand.h
Ticket #1100: Implement MapGuide RFC 84 - Fetch Size. Please get more details from the following link.
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc84
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp 2009-09-21 22:07:01 UTC (rev 4246)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp 2009-09-22 06:03:36 UTC (rev 4247)
@@ -973,6 +973,81 @@
/// <summary>
+/// This method executes the SELECT SQL statement specified within a given transaction
+/// and returns a pointer to SqlDataReader instance. This instance can be used to
+/// retrieve column information and related values.
+/// NOTE:
+/// Serialize() method of SqlDataReader would be able to convert data returned
+/// to AWKFF or XML stream.
+/// </summary>
+/// <param name="resource">Input
+/// A resource identifier referring to connection string
+/// </param>
+/// <param name="sqlStatement">Input
+/// This would allow users to specify free format SQL SELECT statement like
+/// SELECT * FROM CLASSNAME WHERE COLOR = RED. This would return all rows
+/// from "CLASSNAME" where COLOR column has value RED.
+/// </param>
+/// <param name="params">Input&Output
+/// Parameters binded to the SQL statement.
+/// </param>
+/// <param name="transaction">Input
+/// The transaction object on which the sql statement will be executed.
+/// </param>
+/// <param name="fetchSize">Input
+/// The fetch size of query. This method returns all data of query if
+/// setting the fetch size to 0.
+/// </param>
+/// <returns>
+/// SqlDataReader pointer, an instance of reader pointing to the actual reader
+/// from FdoProvider (or NULL).
+/// If any statement other than SELECT is passed to this method, it would return failure.
+/// </returns>
+/// EXCEPTIONS:
+/// MgInvalidResourceIdentifer
+/// MgInvalidSqlStatement
+/// MgSqlNotSupported
+MgSqlDataReader* MgProxyFeatureService::ExecuteSqlQuery(MgResourceIdentifier* resource,
+ CREFSTRING sqlStatement,
+ MgParameterCollection* params,
+ MgTransaction* transaction,
+ INT32 fetchSize)
+ STRING transactionId = L"";
+ MgProxyFeatureTransaction* proxyTransaction = dynamic_cast<MgProxyFeatureTransaction*>(transaction);
+ if (NULL != proxyTransaction)
+ transactionId = proxyTransaction->GetTransactionId();
+ MgCommand cmd;
+ cmd.ExecuteCommand(m_connProp, // Connection
+ MgCommand::knObject, // Return type expected
+ MgFeatureServiceOpId::ExecuteSqlQueryWithTransaction_Id, // Command Code
+ 5, // No of arguments
+ Feature_Service, // Service Id
+ BUILD_VERSION(1,0,0), // Operation version
+ MgCommand::knObject, resource, // Argument#1
+ MgCommand::knString, &sqlStatement, // Argument#2
+ MgCommand::knObject, params, // Argument#3
+ MgCommand::knString, &transactionId, // Argument#4
+ MgCommand::knInt32, fetchSize, // Argument#5
+ MgCommand::knNone); // End of argument
+ SetWarning(cmd.GetWarningObject());
+ Ptr<MgProxySqlDataReader> sqlReader = (MgProxySqlDataReader*)cmd.GetReturnValue().val.m_obj;
+ if (sqlReader != NULL)
+ sqlReader->SetService(this); // Feature reader on proxy side would store proxy service to call GetFeatures()
+ return SAFE_ADDREF((MgProxySqlDataReader*)sqlReader);
+/// <summary>
/// This method executes all SQL statements supported by providers except SELECT.
/// </summary>
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.h 2009-09-21 22:07:01 UTC (rev 4246)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.h 2009-09-22 06:03:36 UTC (rev 4247)
@@ -757,7 +757,51 @@
/// \brief
+ /// This method executes the SELECT SQL statement specified and returns a pointer to
+ /// SqlDataReader instance. This instance can be used to retrieve column information
+ /// and related values.
+ /// \note
+ /// Serialize() method of SqlDataReader would be able to convert data returned
+ /// to AWKFF or XML stream.
+ /// \param resource
+ /// Input
+ /// A resource identifier referring to connection string
+ /// \param sqlStatement
+ /// Input
+ /// This would allow users to specify free format SQL SELECT statement like
+ /// SELECT * FROM CLASSNAME WHERE COLOR = RED. This would return all rows
+ /// from "CLASSNAME" where COLOR column has value RED.
+ /// \param params
+ /// Input&Output
+ /// Parameters binded to the SQL statement.
+ /// \param transaction
+ /// Input
+ /// The MgTransaction instance on which the sql statement will be executed.
+ /// \param fetchSize
+ /// Input
+ /// The fetch size of query. This method returns all data
+ /// of query if setting the fetch size to 0.
+ /// \return
+ /// SqlDataReader pointer, an instance of reader pointing to the actual reader
+ /// from FdoProvider (or NULL).
+ /// If any statement other than SELECT is passed to this method, it would return failure.
+ /// \exception MgInvalidResourceIdentifier
+ /// \exception MgInvalidSqlStatement
+ /// \exception MgSqlNotSupported
+ MgSqlDataReader* ExecuteSqlQuery( MgResourceIdentifier* resource,
+ INT32 fetchSize);
+ /// \brief
/// \param resource
Modified: trunk/MgDev/Common/PlatformBase/Services/FeatureQueryOptions.cpp
--- trunk/MgDev/Common/PlatformBase/Services/FeatureQueryOptions.cpp 2009-09-21 22:07:01 UTC (rev 4246)
+++ trunk/MgDev/Common/PlatformBase/Services/FeatureQueryOptions.cpp 2009-09-22 06:03:36 UTC (rev 4247)
@@ -51,6 +51,8 @@
m_geometry = NULL;
m_binaryOp = true;
+ m_fetchSize = 0;
@@ -204,6 +206,28 @@
m_orderOption = orderOption;
+/// <summary>
+/// For queries that return a large number of objects
+/// some feature sources support improving performance by setting
+/// fetch size in order to reduce the number of database server
+/// round trips required to satisfy the selection criteria.
+/// Providers that do not use a fetch size will ignore the fetch
+/// size parameter. This does not affect the actual results of
+/// queries as it is a performance tuning parameter.
+/// </summary>
+/// The fetch size of query. The query returns all of query
+/// results if setting the fetch size to 0.
+/// </param>
+/// <returns>
+/// Returns nothing.
+/// </returns>
+void MgFeatureQueryOptions::SetFetchSize(INT32 fetchSize)
+ m_fetchSize = fetchSize;
/// <summary>
/// Removes class property.
@@ -295,6 +319,11 @@
return m_operation;
+INT32 MgFeatureQueryOptions::GetFetchSize()
+ return m_fetchSize;
void MgFeatureQueryOptions::Serialize(MgStream* stream)
stream->WriteString(m_filterText);
@@ -310,6 +339,7 @@
stream->WriteObject(m_geometry);
stream->WriteBoolean(m_binaryOp);
+ stream->WriteInt32(m_fetchSize);
void MgFeatureQueryOptions::Deserialize(MgStream* stream)
@@ -333,6 +363,7 @@
m_geometry = (MgGeometry*)stream->GetObject();
stream->GetBoolean(m_binaryOp);
+ stream->GetInt32(m_fetchSize);
@@ -427,6 +458,10 @@
+ tmp += L"{FetchSize=";
+ STRING intval;
+ MgUtil::Int32ToString(m_fetchSize ,intval);
+ tmp += intval;
tmp += L"}";
return tmp;
Modified: trunk/MgDev/Common/PlatformBase/Services/FeatureQueryOptions.h
--- trunk/MgDev/Common/PlatformBase/Services/FeatureQueryOptions.h 2009-09-21 22:07:01 UTC (rev 4246)
+++ trunk/MgDev/Common/PlatformBase/Services/FeatureQueryOptions.h 2009-09-22 06:03:36 UTC (rev 4247)
@@ -471,6 +471,7 @@
INT32 GetOrderOption();
INT32 GetSpatialOperation();
+ INT32 GetFetchSize();
virtual void Serialize(MgStream* stream);
virtual void Deserialize(MgStream* stream);
@@ -481,6 +482,36 @@
void ValidateEmptyArgument(CREFSTRING value);
+ /// \brief
+ /// For queries that return a large number of objects
+ /// some feature sources support improving performance by setting
+ /// fetch size in order to reduce the number of database server
+ /// round trips required to satisfy the selection criteria.
+ /// Providers that do not use a fetch size will ignore the fetch
+ /// size parameter. This does not affect the actual results of
+ /// queries as it is a performance tuning parameter.
+ /// <!-- Syntax in .Net, Java, and PHP -->
+ /// \htmlinclude DotNetSyntaxTop.html
+ /// void SetFetchSize(int fetchSize);
+ /// \htmlinclude SyntaxBottom.html
+ /// \htmlinclude JavaSyntaxTop.html
+ /// \htmlinclude PHPSyntaxTop.html
+ /// \param fetchSize (int)
+ /// The fetch size of query. The query returns all of query
+ /// results if setting the fetch size to 0.
+ /// \return
+ /// Returns nothing.
+ void SetFetchSize(INT32 fetchSize);
private:
STRING m_filterText; // Where Clause
@@ -494,6 +525,7 @@
INT32 m_operation; // Geometric operation to be applied
Ptr<MgGeometry> m_geometry; // Actual geometry like Circle; Rectangle etc
bool m_binaryOp; // Binary operator between spatial and regular filter
+ INT32 m_fetchSize; // The fetch size of query.
CLASS_ID:
static const INT32 m_cls_id = PlatformBase_FeatureService_FeatureQueryOptions;
Modified: trunk/MgDev/Common/PlatformBase/Services/FeatureService.h
--- trunk/MgDev/Common/PlatformBase/Services/FeatureService.h 2009-09-21 22:07:01 UTC (rev 4246)
+++ trunk/MgDev/Common/PlatformBase/Services/FeatureService.h 2009-09-22 06:03:36 UTC (rev 4247)
@@ -1607,6 +1607,77 @@
// Rollback the transaction specified by the transaction id.
virtual bool RollbackTransaction(CREFSTRING transactionId) = 0;
+ /// \brief
+ /// Executes the SQL SELECT statement on the specified feature
+ /// source within the given transaction. For queries that return
+ /// a large number of objects some feature sources support
+ /// improving performance by setting fetch size in order to reduce
+ /// the number of database server round trips required to satisfy
+ /// the selection criteria. Providers that do not use a fetch size
+ /// will ignore the fetch size parameter.
+ /// \remarks
+ /// The XML returned by MgFeatureService::GetCapabilities says
+ /// whether a provider supports SQL commands. See \link ProviderCapabilities Provider Capabilities \endlink.
+ /// virtual MgSqlDataReader ExecuteSqlQuery(MgResourceIdentifier resource, string sqlStatement, MgParameterCollection parameters, MgTransaction transaction, int fetchSize);
+ /// virtual MgSqlDataReader ExecuteSqlQuery(MgResourceIdentifier resource, String sqlStatement, MgParameterCollection parameters, MgTransaction transaction, int fetchSize);
+ /// \param resource (MgResourceIdentifier)
+ /// to a feature source.
+ /// \param sqlStatement (String/string)
+ /// The SQL SELECT statement.
+ /// \param parameters (MgParameterCollection)
+ /// \param transaction (MgTransaction)
+ /// statement will be executed.
+ /// \return
+ /// Returns an MgSqlDataReader instance (or NULL).
+ /// \note
+ /// it will throw an MgFdoException.
+ /// <!-- Example (PHP) -->
+ /// \htmlinclude PHPExampleTop.html
+ /// \code
+ /// $sql = "select featid,abyte from featclass where featid = :id";
+ /// $prop = new MgInt32Property("id", 150);
+ /// $param = new MgParameter($prop);
+ /// $params = new MgParameterCollection();
+ /// $params->Add($param);
+ /// $transaction = $featureService->BeginTransaction($activeFeatSrcResId);
+ /// $sqlDataReader = $featureService->ExecuteSqlQuery($activeFeatSrcResId, $sql, $params, $transaction, 0);
+ /// $transaction->Commit();
+ /// \endcode
+ /// \htmlinclude ExampleBottom.html
+ /// \exception MgFeatureServiceException
+ /// \exception MgInvalidArgumentException
+ /// \exception MgInvalidOperationException
+ /// \exception MgFdoException
+ virtual MgSqlDataReader* ExecuteSqlQuery( MgResourceIdentifier* resource,
+ MgParameterCollection* parameters,
+ INT32 fetchSize ) = 0;
protected:
Modified: trunk/MgDev/Server/src/Services/Feature/FeatureServiceCommand.h
--- trunk/MgDev/Server/src/Services/Feature/FeatureServiceCommand.h 2009-09-21 22:07:01 UTC (rev 4246)
+++ trunk/MgDev/Server/src/Services/Feature/FeatureServiceCommand.h 2009-09-22 06:03:36 UTC (rev 4247)
@@ -28,6 +28,9 @@
virtual void SetDistinct( bool value ) = 0;
virtual bool GetDistinct( ) = 0;
+ virtual void SetFetchSize(FdoInt32 fetchSize) = 0;
+ virtual FdoInt32 GetFetchSize() = 0;
virtual FdoIdentifierCollection* GetOrdering() = 0;
virtual void SetOrderingOption( FdoOrderingOption option ) = 0;
virtual FdoOrderingOption GetOrderingOption( ) = 0;
Modified: trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlQuery.cpp
--- trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlQuery.cpp 2009-09-21 22:07:01 UTC (rev 4246)
+++ trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlQuery.cpp 2009-09-22 06:03:36 UTC (rev 4247)
@@ -129,6 +129,54 @@
// Write the response
EndExecution((MgSqlDataReader*)sqlReader);
+ else if (5 == m_packet.m_NumArguments)
+ // Get the feature source
+ Ptr<MgResourceIdentifier> resource = (MgResourceIdentifier*)m_stream->GetObject();
+ // Get the SQL statement
+ STRING sqlStatement;
+ m_stream->GetString(sqlStatement);
+ // Get parameters binded to the SQL statement
+ Ptr<MgParameterCollection> parameters = (MgParameterCollection*)m_stream->GetObject();
+ // Get the transaction id
+ STRING transactionId;
+ m_stream->GetString(transactionId);
+ // Get query fetch size
+ INT32 fetchSize;
+ m_stream->GetInt32(fetchSize);
+ BeginExecution();
+ MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING((NULL == resource) ? L"MgResourceIdentifier" : resource->ToString().c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(sqlStatement.c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(transactionId.c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(fetchSize);
+ MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
+ Validate();
+ MgServerFeatureTransactionPool* transactionPool = MgServerFeatureTransactionPool::GetInstance();
+ CHECKNULL(transactionPool, L"MgOpExecuteSqlQuery.Execute")
+ transactionPool->ValidateTimeout(transactionId);
+ // Get the MgTransaction instance from the pool if one has been started for this resource.
+ Ptr<MgServerFeatureTransaction> transaction = transactionPool->GetTransaction(transactionId);
+ // Execute the operation
+ Ptr<MgSqlDataReader> sqlReader = m_service->ExecuteSqlQuery(resource, sqlStatement, parameters, (MgTransaction*)transaction.p, fetchSize);
+ // Write the response
+ EndExecution((MgSqlDataReader*)sqlReader);
else
Modified: trunk/MgDev/Server/src/Services/Feature/SelectAggregateCommand.cpp
--- trunk/MgDev/Server/src/Services/Feature/SelectAggregateCommand.cpp 2009-09-21 22:07:01 UTC (rev 4246)
+++ trunk/MgDev/Server/src/Services/Feature/SelectAggregateCommand.cpp 2009-09-22 06:03:36 UTC (rev 4247)
@@ -68,6 +68,18 @@
return m_command->GetDistinct();
+void MgSelectAggregateCommand::SetFetchSize(FdoInt32 fetchSize)
+ CHECKNULL((FdoISelectAggregates*)m_command, L"MgSelectAggregateCommand.SetFetchSize");
+ m_command->SetFetchSize(fetchSize);
+FdoInt32 MgSelectAggregateCommand::GetFetchSize()
+ CHECKNULL((FdoISelectAggregates*)m_command, L"MgSelectAggregateCommand.GetFetchSize");
+ return m_command->GetFetchSize();
FdoIdentifierCollection* MgSelectAggregateCommand::GetOrdering()
CHECKNULL((FdoISelectAggregates*)m_command, L"MgSelectAggregateCommand.GetOrdering");
Modified: trunk/MgDev/Server/src/Services/Feature/SelectAggregateCommand.h
--- trunk/MgDev/Server/src/Services/Feature/SelectAggregateCommand.h 2009-09-21 22:07:01 UTC (rev 4246)
+++ trunk/MgDev/Server/src/Services/Feature/SelectAggregateCommand.h 2009-09-22 06:03:36 UTC (rev 4247)
@@ -31,6 +31,9 @@
virtual void SetDistinct( bool value );
virtual bool GetDistinct( );
+ virtual void SetFetchSize(FdoInt32 fetchSize);
+ virtual FdoInt32 GetFetchSize();
virtual FdoIdentifierCollection* GetOrdering();
virtual void SetOrderingOption( FdoOrderingOption option );
virtual FdoOrderingOption GetOrderingOption( );
Modified: trunk/MgDev/Server/src/Services/Feature/SelectCommand.cpp
--- trunk/MgDev/Server/src/Services/Feature/SelectCommand.cpp 2009-09-21 22:07:01 UTC (rev 4246)
+++ trunk/MgDev/Server/src/Services/Feature/SelectCommand.cpp 2009-09-22 06:03:36 UTC (rev 4247)
@@ -82,6 +82,18 @@
return false;
+void MgSelectCommand::SetFetchSize(FdoInt32 fetchSize)
+ CHECKNULL((FdoISelect*)m_command, L"MgSelectCommand.SetFetchSize");
+FdoInt32 MgSelectCommand::GetFetchSize()
+ CHECKNULL((FdoISelect*)m_command, L"MgSelectCommand.GetFetchSize");
FdoIdentifierCollection* MgSelectCommand::GetOrdering()
CHECKNULL((FdoISelect*)m_command, L"MgSelectCommand.GetOrdering");
Modified: trunk/MgDev/Server/src/Services/Feature/SelectCommand.h
--- trunk/MgDev/Server/src/Services/Feature/SelectCommand.h 2009-09-21 22:07:01 UTC (rev 4246)
+++ trunk/MgDev/Server/src/Services/Feature/SelectCommand.h 2009-09-22 06:03:36 UTC (rev 4247)
@@ -35,6 +35,9 @@
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp 2009-09-21 22:07:01 UTC (rev 4246)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp 2009-09-22 06:03:36 UTC (rev 4247)
@@ -734,6 +734,57 @@
/// <summary>
+/// NOTE:
+/// </summary>
+/// </param>
+/// </param>
+/// <param name="params">InputOutput
+/// </param>
+/// The MgTransaction instance on which the sql statement will be executed.
+/// </param>
+/// </param>
+/// <returns>
+/// </returns>
+/// EXCEPTIONS:
+MgSqlDataReader* MgServerFeatureService::ExecuteSqlQuery( MgResourceIdentifier* resource,
+ INT32 fetchSize )
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::ExecuteSqlQuery()");
+ MgServerSqlCommand sqlCommand;
+ return sqlCommand.ExecuteQuery(resource, sqlStatement, params, transaction, fetchSize );
+/// <summary>
/// </summary>
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.h
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.h 2009-09-21 22:07:01 UTC (rev 4246)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.h 2009-09-22 06:03:36 UTC (rev 4247)
@@ -603,6 +603,54 @@
/// <summary>
+ /// SqlDataReader instance within the given transaction. This instance can be used to
+ /// retrieve column information and related values.
+ /// NOTE:
+ /// </summary>
+ /// <remarks>
+ /// If passing in NULL for transaction, it will work the same
+ /// as before within no explicit transaction.
+ /// </remarks>
+ /// <param name="resource">Input
+ /// </param>
+ /// <param name="sqlStatement">Input
+ /// <param name="params">InputOutput
+ /// </param>
+ /// <param name="transaction">Input
+ /// </param>
+ /// <param name="fetchSize">
+ /// The fetch size of query. This method returns all data of query if
+ /// setting the fetch size to 0.
+ /// </param>
+ /// <returns>
+ /// </returns>
+ /// EXCEPTIONS:
+ /// MgInvalidResourceIdentifer
+ /// MgInvalidSqlStatement
+ /// MgSqlNotSupported
+ INT32 fetchSize );
+ /// <summary>
/// </summary>
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp 2009-09-21 22:07:01 UTC (rev 4246)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp 2009-09-22 06:03:36 UTC (rev 4247)
@@ -264,6 +264,7 @@
// ApplySpatialFilter();
ApplyOrderingOptions();
ApplyAggregateOptions(isSelectAggregate);
+ ApplyFetchSize();
@@ -350,6 +351,15 @@
// m_command->SetFilter(filterText.c_str());
+// Fetch size
+void MgServerSelectFeatures::ApplyFetchSize()
+ CHECKNULL(m_options, L"MgServerSelectFeatures.ApplyFetchSize");
+ CHECKNULL(m_command, L"MgServerSelectFeatures.ApplyFetchSize");
+ m_command->SetFetchSize(m_options->GetFetchSize());
// Spatial Filter
void MgServerSelectFeatures::ApplyFilter()
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h
--- trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h 2009-09-21 22:07:01 UTC (rev 4246)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h 2009-09-22 06:03:36 UTC (rev 4247)
@@ -45,6 +45,7 @@
void ApplyFilter();
// void ApplySpatialFilter();
void ApplyOrderingOptions();
+ void ApplyFetchSize();
//bool HasCustomProperty() { return m_customPropertyFound; }
//FdoFunction* GetCustomFunction() { return FDO_SAFE_ADDREF(m_customFunction); }
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSqlCommand.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerSqlCommand.cpp 2009-09-21 22:07:01 UTC (rev 4246)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSqlCommand.cpp 2009-09-22 06:03:36 UTC (rev 4247)
@@ -44,7 +44,12 @@
// Executes the describe schema command and serializes the schema to XML
-MgSqlDataReader* MgServerSqlCommand::ExecuteQuery(MgResourceIdentifier* resource, CREFSTRING sqlStatement, MgParameterCollection* params, MgTransaction* transaction)
+MgSqlDataReader* MgServerSqlCommand::ExecuteQuery(
+ MgResourceIdentifier* resource,
+ INT32 fetchSize)
Ptr<MgSqlDataReader> mgSqlDataReader;
@@ -60,6 +65,9 @@
// Set SQL statement
fdoCommand->SetSQLStatement((FdoString*)sqlStatement.c_str());
+ // Set fetch size
+ fdoCommand->SetFetchSize(fetchSize);
// Set parameters
FdoPtr<FdoParameterValueCollection> fdoParams = NULL;
if (NULL != params && params->GetCount() > 0)
@@ -85,7 +93,11 @@
-INT32 MgServerSqlCommand::ExecuteNonQuery(MgResourceIdentifier* resource, CREFSTRING sqlStatement, MgParameterCollection* params, MgTransaction* transaction)
+INT32 MgServerSqlCommand::ExecuteNonQuery(
+ MgTransaction* transaction)
INT32 rowsAffected = 0;
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSqlCommand.h
--- trunk/MgDev/Server/src/Services/Feature/ServerSqlCommand.h 2009-09-21 22:07:01 UTC (rev 4246)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSqlCommand.h 2009-09-22 06:03:36 UTC (rev 4247)
@@ -30,8 +30,17 @@
public:
MgServerSqlCommand();
~MgServerSqlCommand();
- MgSqlDataReader* ExecuteQuery(MgResourceIdentifier* resource, CREFSTRING sqlStatement, MgParameterCollection* params, MgTransaction* transaction);
- INT32 ExecuteNonQuery(MgResourceIdentifier* resource, CREFSTRING sqlStatement, MgParameterCollection* params, MgTransaction* transaction);
+ MgSqlDataReader* ExecuteQuery(
+ INT32 fetchSize = 0);
+ INT32 ExecuteNonQuery(
+ MgTransaction* transaction);
private:
void Validate(MgResourceIdentifier* resource, CREFSTRING sqlStatement, INT32 commandType, MgTransaction* transaction);
More information about the mapguide-commits
