[mapguide-commits] r4248 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Tue Sep 22 02:49:02 EDT 2009
Author: waltweltonlair
Date: 2009-09-22 02:48:50 -0400 (Tue, 22 Sep 2009)
New Revision: 4248
trunk/MgDev/Common/Stylization/ExpressionFunctionArgb.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionDecap.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureClass.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureId.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionIf.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionLayerId.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionLookup.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionMapName.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionRange.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionSession.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionUrlEncode.cpp
Fix a build issue. The FdoFunctionDefinition::Create method now requires a sixth
argument to specify if the function supports a variable number of arguments.
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionArgb.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionArgb.cpp 2009-09-22 06:03:36 UTC (rev 4247)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionArgb.cpp 2009-09-22 06:48:50 UTC (rev 4248)
@@ -67,7 +67,8 @@
funcDesc.c_str(),
FdoDataType_Int32,
args,
- FdoFunctionCategoryType_String);
+ FdoFunctionCategoryType_String,
+ false);
return FDO_SAFE_ADDREF(m_functionDefinition);
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionDecap.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionDecap.cpp 2009-09-22 06:03:36 UTC (rev 4247)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionDecap.cpp 2009-09-22 06:48:50 UTC (rev 4248)
@@ -59,7 +59,8 @@
funcDesc.c_str(),
FdoDataType_String,
args,
+ false);
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureClass.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureClass.cpp 2009-09-22 06:03:36 UTC (rev 4247)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureClass.cpp 2009-09-22 06:48:50 UTC (rev 4248)
@@ -52,7 +52,8 @@
funcDesc.c_str(),
FdoDataType_String,
args,
+ false);
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureId.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureId.cpp 2009-09-22 06:03:36 UTC (rev 4247)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureId.cpp 2009-09-22 06:48:50 UTC (rev 4248)
@@ -56,7 +56,8 @@
funcDesc.c_str(),
FdoDataType_String,
args,
+ false);
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionIf.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionIf.cpp 2009-09-22 06:03:36 UTC (rev 4247)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionIf.cpp 2009-09-22 06:48:50 UTC (rev 4248)
@@ -102,7 +102,8 @@
funcDesc.c_str(),
false,
signatures,
- FdoFunctionCategoryType_Conversion);
+ FdoFunctionCategoryType_Conversion,
+ false);
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionLayerId.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionLayerId.cpp 2009-09-22 06:03:36 UTC (rev 4247)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionLayerId.cpp 2009-09-22 06:48:50 UTC (rev 4248)
@@ -52,7 +52,8 @@
funcDesc.c_str(),
FdoDataType_String,
args,
+ false);
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionLookup.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionLookup.cpp 2009-09-22 06:03:36 UTC (rev 4247)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionLookup.cpp 2009-09-22 06:48:50 UTC (rev 4248)
@@ -95,7 +95,8 @@
funcDesc.c_str(),
false,
signatures,
+ false);
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionMapName.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionMapName.cpp 2009-09-22 06:03:36 UTC (rev 4247)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionMapName.cpp 2009-09-22 06:48:50 UTC (rev 4248)
@@ -52,7 +52,8 @@
funcDesc.c_str(),
FdoDataType_String,
args,
+ false);
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionRange.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionRange.cpp 2009-09-22 06:03:36 UTC (rev 4247)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionRange.cpp 2009-09-22 06:48:50 UTC (rev 4248)
@@ -100,7 +100,8 @@
funcDesc.c_str(),
false,
signatures,
+ false);
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionSession.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionSession.cpp 2009-09-22 06:03:36 UTC (rev 4247)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionSession.cpp 2009-09-22 06:48:50 UTC (rev 4248)
@@ -52,7 +52,8 @@
funcDesc.c_str(),
FdoDataType_String,
args,
+ false);
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionUrlEncode.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionUrlEncode.cpp 2009-09-22 06:03:36 UTC (rev 4247)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionUrlEncode.cpp 2009-09-22 06:48:50 UTC (rev 4248)
@@ -59,7 +59,8 @@
funcDesc.c_str(),
FdoDataType_String,
args,
+ false);
More information about the mapguide-commits
