[mapguide-commits] r4270 - trunk/MgDev/Common/PlatformBase/MapLayer
svn_mapguide at osgeo.org
Mon Sep 28 15:57:37 EDT 2009
Author: brucedechant
Date: 2009-09-28 15:57:35 -0400 (Mon, 28 Sep 2009)
New Revision: 4270
trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.h
Small update for RFC73
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc73
Submitted on behalf of Christine Bao
- Make GetLayerResourceContent() and SetLayerResourceContent() APIs INTERNAL
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.h
--- trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.h 2009-09-28 18:50:06 UTC (rev 4269)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/LayerBase.h 2009-09-28 19:57:35 UTC (rev 4270)
@@ -501,59 +501,6 @@
/// \brief
- /// Gets the layer's resource content.
- /// <!-- Syntax in .Net, Java, and PHP -->
- /// \htmlinclude DotNetSyntaxTop.html
- /// string GetLayerResourceContent();
- /// \htmlinclude SyntaxBottom.html
- /// \htmlinclude JavaSyntaxTop.html
- /// String GetLayerResourceContent();
- /// \htmlinclude PHPSyntaxTop.html
- /// \return
- /// Returns the resource content of the layer.
- /// <!-- Example (PHP) -->
- /// \htmlinclude PHPExampleTop.html
- /// See \link MgMapBase MgMapBase class \endlink.
- /// \htmlinclude ExampleBottom.html
- virtual STRING GetLayerResourceContent(); /// __get, __set
- /// \brief
- /// Sets the resource content for this layer.
- /// \note
- /// If you change the layer's resource content, you must also
- /// change the cached scale ranges and force an update of any
- /// layer metadata held in the DWF Viewer's eMap.
- /// void SetLayerResourceContent(string resourceContent);
- /// void SetLayerResourceContent(String resourceContent);
- /// \param resourceContent (STRING)
- /// The xml content of the layer's resource content.
- /// \return
- /// Returns nothing.
- virtual void SetLayerResourceContent(CREFSTRING resourceContent);
- /// \brief
/// Determines whether an entry for the layer should appear in
/// the legend.
@@ -1019,7 +966,17 @@
/// Returns id property list
virtual IdPropertyList& GetIdPropertyList();
+ /// \brief
+ /// Gets the layer's resource content.
+ virtual STRING GetLayerResourceContent();
+ /// \brief
+ /// Sets the resource content for this layer.
+ virtual void SetLayerResourceContent(CREFSTRING resourceContent);
protected:
/// \brief
More information about the mapguide-commits
