[mapguide-commits] r4271 - in trunk/MgDev: Common/MapGuideCommon/Services Common/PlatformBase/Services Server/src/Gws/GwsQueryEngine Server/src/Gws/GwsQueryEngine/inc Server/src/Gws/Include Server/src/Services/Feature
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Sep 29 05:14:23 EDT 2009
Author: leaf
Date: 2009-09-29 05:14:23 -0400 (Tue, 29 Sep 2009)
New Revision: 4271
   trunk/MgDev/Common/MapGuideCommon/Services/ProxyDataReader.cpp
   trunk/MgDev/Common/MapGuideCommon/Services/ProxyDataReader.h
   trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureReader.cpp
   trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureReader.h
   trunk/MgDev/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.cpp
   trunk/MgDev/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.h
   trunk/MgDev/Common/MapGuideCommon/Services/ProxySqlDataReader.cpp
   trunk/MgDev/Common/MapGuideCommon/Services/ProxySqlDataReader.h
   trunk/MgDev/Common/PlatformBase/Services/FeatureReader.cpp
   trunk/MgDev/Common/PlatformBase/Services/FeatureReader.h
   trunk/MgDev/Common/PlatformBase/Services/Reader.h
   trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureQueryResults.cpp
   trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFlatFdoReader.cpp
   trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsMultiSelectIterator.cpp
   trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightBatchSortedBlockJoinQueryResults.cpp
   trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightJoinQueryResults.cpp
   trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsFlatFdoReader.h
   trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsQuery.h
   trunk/MgDev/Server/src/Gws/Include/GwsQueryEngine.h
   trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.cpp
   trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.h
   trunk/MgDev/Server/src/Services/Feature/FdoReaderCollection.h
   trunk/MgDev/Server/src/Services/Feature/JoinFeatureReader.cpp
   trunk/MgDev/Server/src/Services/Feature/JoinFeatureReader.h
   trunk/MgDev/Server/src/Services/Feature/ServerDataReader.cpp
   trunk/MgDev/Server/src/Services/Feature/ServerDataReader.h
   trunk/MgDev/Server/src/Services/Feature/ServerFdoFeatureReader.cpp
   trunk/MgDev/Server/src/Services/Feature/ServerFdoFeatureReader.h
   trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.cpp
   trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.h
   trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.cpp
   trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.h
   trunk/MgDev/Server/src/Services/Feature/ServerSqlDataReader.cpp
   trunk/MgDev/Server/src/Services/Feature/ServerSqlDataReader.h
Submitted this change on behalf of Klain Qin
Ticket #1111 - Implementation for RFC 82 - Extend Reader Access by Index.
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc82
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyDataReader.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyDataReader.cpp	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyDataReader.cpp	2009-09-29 09:14:23 UTC (rev 4271)
@@ -132,6 +132,19 @@
 /// <summary>
+/// Gets the index of the property with the specified name.
+/// </summary>
+/// <param name="propertyName">Input the name of the property.</param>
+/// <returns>Returns the property index</returns>
+INT32 MgProxyDataReader::GetPropertyIndex(CREFSTRING propertyName)
+    CHECKNULL(m_propDefCol, L"MgProxyDataReader.GetPropertyIndex");
+    return m_propDefCol->IndexOf(propertyName);
+/// <summary>
 /// Gets the data type of the property with the specified name.
 /// </summary>
 /// <param name="propertyName">Input the property name.</param>
@@ -166,6 +179,26 @@
 /// <summary>
+///  Returns true if the value of the specified property is null.
+/// </summary>
+/// <param name="index">Property index.</param>
+/// <returns>Returns true if the value is null.</returns>
+bool MgProxyDataReader::IsNull(INT32 index)
+    bool isNull = false;
+    Ptr<MgNullableProperty> ptrProp = (MgNullableProperty*)GetProperty(index);
+    if (ptrProp != NULL)
+        isNull = ptrProp->IsNull();
+    return isNull;
+/// <summary>
 /// Gets the Boolean value of the specified property. No conversion is
 /// performed, thus the property must be a of boolean type the result
 /// is undertermined</summary>
@@ -184,6 +217,24 @@
 /// <summary>
+/// Gets the Boolean value of the specified property. No conversion is
+/// performed, thus the property must be a of boolean type the result
+/// is undertermined</summary>
+/// <returns>Returns the Boolean value.</returns>
+bool MgProxyDataReader::GetBoolean(INT32 index)
+    bool retVal = false;
+    Ptr<MgBooleanProperty> ptrProp = (MgBooleanProperty*)GetProperty(index, MgPropertyType::Boolean);
+    retVal = ptrProp->GetValue();
+    return retVal;
+/// <summary>
 /// Gets the Byte value of the specified property. No conversion is
 /// performed, thus the property must be a of byte type or the result
@@ -202,6 +253,24 @@
 /// <summary>
+/// Gets the Byte value of the specified property. No conversion is
+/// performed, thus the property must be a of byte type or the result
+/// <returns>Returns the Byte value.</returns>
+BYTE MgProxyDataReader::GetByte(INT32 index)
+    BYTE retVal = 0;
+    Ptr<MgByteProperty> ptrProp = (MgByteProperty*)GetProperty(index, MgPropertyType::Byte);
+    return retVal;
+/// <summary>
 /// Gets the DTime value of the specified property. No conversion is
 /// performed, thus the property must be a of date type or the result
 /// is NULL</summary>
@@ -218,6 +287,22 @@
 /// <summary>
+/// Gets the DTime value of the specified property. No conversion is
+/// performed, thus the property must be a of date type or the result
+/// is NULL</summary>
+/// <returns>Returns the DTime value.</returns>
+MgDateTime* MgProxyDataReader::GetDateTime(INT32 index)
+    Ptr<MgDateTimeProperty> ptrProp = (MgDateTimeProperty*)GetProperty(index, MgPropertyType::DateTime);
+    Ptr<MgDateTime> retVal = ptrProp->GetValue();
+    return SAFE_ADDREF((MgDateTime*)retVal);
+/// <summary>
 /// Gets the Single value of the specified property. No conversion is
 /// performed, thus the property must be a of type single or the result
 /// is undetermined</summary>
@@ -236,6 +321,24 @@
 /// <summary>
+/// Gets the Single value of the specified property. No conversion is
+/// performed, thus the property must be a of type single or the result
+/// is undetermined</summary>
+/// <returns>Returns the single value.</returns>
+float MgProxyDataReader::GetSingle(INT32 index)
+    float retVal = 0;
+    Ptr<MgSingleProperty> ptrProp = (MgSingleProperty*)GetProperty(index, MgPropertyType::Single);
+    return retVal;
+/// <summary>
 /// Gets the Double value of the specified property. No conversion is
 /// performed, thus the property must be a of type double or the result
@@ -254,6 +357,24 @@
 /// <summary>
+/// Gets the Double value of the specified property. No conversion is
+/// performed, thus the property must be a of type double or the result
+/// <returns>Returns the double value.</returns>
+double MgProxyDataReader::GetDouble(INT32 index)
+    double retVal = 0;
+    Ptr<MgDoubleProperty> ptrProp = (MgDoubleProperty*)GetProperty(index, MgPropertyType::Double);
+    return retVal;
+/// <summary>
 /// Gets the integer 16 bits value of the specified property. No conversion is
 /// performed, thus the property must be a of type integer 16 bits or the result
@@ -271,6 +392,23 @@
 /// <summary>
+/// Gets the integer 16 bits value of the specified property. No conversion is
+/// performed, thus the property must be a of type integer 16 bits or the result
+/// <returns>Returns the integer 16 bits value.</returns>
+INT16 MgProxyDataReader::GetInt16(INT32 index)
+    INT16 retVal = 0;
+    Ptr<MgInt16Property> ptrProp = (MgInt16Property*)GetProperty(index, MgPropertyType::Int16);
+    return retVal;
+/// <summary>
 /// Gets the integer 32 bits value of the specified property. No conversion is
 /// performed, thus the property must be a of type integer 32 bits or the result
@@ -288,6 +426,23 @@
 /// <summary>
+/// Gets the integer 32 bits value of the specified property. No conversion is
+/// performed, thus the property must be a of type integer 32 bits or the result
+/// <returns>Returns the integer 32 bits value.</returns>
+INT32 MgProxyDataReader::GetInt32(INT32 index)
+    INT32 retVal = 0;
+    Ptr<MgInt32Property> ptrProp = (MgInt32Property*)GetProperty(index, MgPropertyType::Int32);
+    return retVal;
+/// <summary>
 /// Gets the integer 64 bits value of the specified property. No conversion is
 /// performed, thus the property must be a of type integer 64 bits or the result
@@ -307,6 +462,25 @@
 /// <summary>
+/// Gets the integer 64 bits value of the specified property. No conversion is
+/// performed, thus the property must be a of type integer 64 bits or the result
+/// <returns>Returns the integer 64 bits value.
+/// Note: INT64 is actually a pointer to an Integer64 object
+///</returns>
+INT64 MgProxyDataReader::GetInt64(INT32 index)
+    INT64 retVal = 0;
+    Ptr<MgInt64Property> ptrProp = (MgInt64Property*)GetProperty(index, MgPropertyType::Int64);
+    return retVal;
+/// <summary>
 /// Gets the string value of the specified property. No conversion is
 /// performed, thus the property must be a of type string or the result
@@ -324,6 +498,23 @@
 /// <summary>
+/// Gets the string value of the specified property. No conversion is
+/// performed, thus the property must be a of type string or the result
+/// <returns>Returns the string value.</returns>
+STRING MgProxyDataReader::GetString(INT32 index)
+    STRING retVal = L"";
+    Ptr<MgStringProperty> ptrProp = (MgStringProperty*)GetProperty(index, MgPropertyType::String);
+    return retVal;
+/// <summary>
 /// Gets the BLOB value of the specified property. No conversion is
 /// performed, thus the property must be a of type BLOBs or the result
@@ -339,6 +530,21 @@
 /// <summary>
+/// Gets the BLOB value of the specified property. No conversion is
+/// performed, thus the property must be a of type BLOBs or the result
+/// <returns>Returns the BLOB value.</returns>
+MgByteReader* MgProxyDataReader::GetBLOB(INT32 index)
+    Ptr<MgBlobProperty> ptrProp = (MgBlobProperty*)GetProperty(index, MgPropertyType::Blob);
+    Ptr<MgByteReader> retVal = ptrProp->GetValue();
+    return SAFE_ADDREF((MgByteReader*)retVal);
+/// <summary>
 /// Gets the CLOB value of the specified property. No conversion is
 /// performed, thus the property must be a of type CLOB or the result
@@ -354,6 +560,21 @@
 /// <summary>
+/// Gets the CLOB value of the specified property. No conversion is
+/// performed, thus the property must be a of type CLOB or the result
+/// <returns>Returns the CLOB value.</returns>
+MgByteReader* MgProxyDataReader::GetCLOB(INT32 index)
+    Ptr<MgClobProperty> ptrProp = (MgClobProperty*)GetProperty(index, MgPropertyType::Clob);
+/// <summary>
 /// Gets the Geometry for the specified property. No conversion is
 /// performed, thus the property must be a of type Geometry or the result
@@ -368,6 +589,21 @@
+/// <summary>
+/// Gets the Geometry for the specified property. No conversion is
+/// performed, thus the property must be a of type Geometry or the result
+/// <returns>Returns a ByteReader object</returns>
+MgByteReader* MgProxyDataReader::GetGeometry(INT32 index)
+    Ptr<MgGeometryProperty> ptrProp = (MgGeometryProperty*)GetProperty(index, MgPropertyType::Geometry);
 ///<summary>
 /// Serialize data to TCP/IP stream
 ///</summary>
@@ -528,6 +764,45 @@
     return SAFE_ADDREF((MgProperty*)ptrProp);
+// Get the property for the specified name
+MgProperty* MgProxyDataReader::GetProperty(INT32 index, INT16 expectedType)
+    Ptr<MgNullableProperty> ptrProp = (MgNullableProperty*)this->GetProperty(index);
+    CHECKNULL(ptrProp, L"MgProxyDataReader.GetProperty");
+    if (ptrProp->IsNull())
+        STRING buffer;
+        MgUtil::Int32ToString(index, buffer);
+        MgStringCollection arguments;
+        arguments.Add(buffer);
+        throw new MgNullPropertyValueException(L"MgProxyDataReader.GetProperty",
+            __LINE__, __WFILE__, &arguments, L"", NULL);
+    INT16 propType = ptrProp->GetPropertyType();
+    MG_CHECK_PROPERTY_TYPE(propType, expectedType, L"MgProxyDataReader.GetProperty");
+    return SAFE_ADDREF((MgProperty*)ptrProp);
+// Get the property for the specified index
+MgProperty* MgProxyDataReader::GetProperty(INT32 index)
+    CHECKNULL(m_set, L"MgProxyDataReader.GetProperty");
+    MG_CHECK_FEATURE_SET_COUNT(m_set, L"MgProxyDataReader.GetProperty");
+    Ptr<MgPropertyCollection> ptrCol = m_set->GetItem(m_currRecord-1);
+    CHECKNULL(ptrCol, L"MgProxyDataReader.GetProperty");
+    Ptr<MgProperty> ptrProp = ptrCol->GetItem(index);
 void MgProxyDataReader::UpdateCurrentSet(MgBatchPropertyCollection* bpCol)
     CHECKNULL((MgBatchPropertyCollection*)m_set, L"MgProxyDataReader.UpdateCurrentSet");
@@ -559,6 +834,21 @@
     return SAFE_ADDREF((MgRaster*)retVal);
+/// <summary>Gets the raster object of the specified property.
+/// the property must be of Raster type; otherwise, an exception is thrown.
+/// </summary>
+/// <param name="index">Input the property index.</param>
+/// <returns>Returns the raster object.</returns>
+MgRaster* MgProxyDataReader::GetRaster(INT32 index)
+    Ptr<MgRasterProperty> ptrProp = (MgRasterProperty*)GetProperty(index, MgPropertyType::Raster);
+    Ptr<MgRaster> retVal = ptrProp->GetValue();
+    retVal->SetMgService(m_service);
+    retVal->SetHandle(m_serverDataReader);
+    return SAFE_ADDREF((MgRaster*)retVal);
 /// <summary>
@@ -573,3 +863,18 @@
     return str.c_str();
+/// <summary>
+const wchar_t* MgProxyDataReader::GetString(INT32 index, INT32& length)
+    STRING str = this->GetString(index);
+    length = (INT32)str.size();
+    return str.c_str();
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyDataReader.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyDataReader.h	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyDataReader.h	2009-09-29 09:14:23 UTC (rev 4271)
@@ -75,6 +75,18 @@
     /// \brief
+    /// Gets the index of the property with the specified name.
+    /// \param propertyName
+    /// Input the name of the property.
+    /// \return
+    /// Returns the property index
+    INT32 GetPropertyIndex(CREFSTRING propertyName);
+    /// \brief
@@ -278,8 +290,202 @@
     MgRaster* GetRaster(CREFSTRING propertyName);
     /// \brief
+    ///  Returns true if the value of the specified property is null.
+    /// \param index
+    /// Property index.
+    /// \return
+    /// Returns true if the value is null.
+    bool IsNull(INT32 index);
+    /// \brief
+    /// Gets the Boolean value of the specified property. No conversion is
+    /// performed, thus the property must be a of boolean type the result
+    /// is undetermined
+    /// \param index
+    /// \return
+    /// Returns the Boolean value.
+    bool GetBoolean(INT32 index);
+    /// \brief
+    /// Gets the Byte value of the specified property. No conversion is
+    /// performed, thus the property must be a of byte type or the result
+    /// \param index
+    /// \return
+    /// Returns the Byte value.
+    BYTE GetByte(INT32 index);
+    /// \brief
+    /// Gets the DTime value of the specified property. No conversion is
+    /// performed, thus the property must be a of date type or the result
+    /// is NULL
+    /// \param index
+    /// \return
+    /// Returns the DTime value.
+    MgDateTime* GetDateTime(INT32 index);
+    /// \brief
+    /// Gets the Single value of the specified property. No conversion is
+    /// performed, thus the property must be a of type single or the result
+    /// \param index
+    /// \return
+    /// Returns the single value.
+    float GetSingle(INT32 index);
+    /// \brief
+    /// Gets the Double value of the specified property. No conversion is
+    /// performed, thus the property must be a of type double or the result
+    /// \param index
+    /// \return
+    /// Returns the double value.
+    double GetDouble(INT32 index);
+    /// \brief
+    /// Gets the integer 16 bits value of the specified property. No conversion is
+    /// performed, thus the property must be a of type integer 16 bits or the result
+    /// \param index
+    /// \return
+    /// Returns the integer 16 bits value.
+    INT16 GetInt16(INT32 index);
+    /// \brief
+    /// Gets the integer 32 bits value of the specified property. No conversion is
+    /// performed, thus the property must be a of type integer 32 bits or the result
+    /// \param index
+    /// \return
+    /// Returns the integer 32 bits value.
+    INT32 GetInt32(INT32 index);
+    /// \brief
+    /// Gets the integer 64 bits value of the specified property. No conversion is
+    /// performed, thus the property must be a of type integer 64 bits or the result
+    /// is NULL
+    /// \param index
+    /// \return
+    /// Returns the integer 64 bits value.
+    /// Note: INT64 is actually a pointer to an Integer64 object
+    INT64 GetInt64(INT32 index);
+    /// \brief
+    /// Gets the string value of the specified property. No conversion is
+    /// performed, thus the property must be a of type string or the result
+    /// is NULL
+    /// \param index
+    /// \return
+    /// Returns the string value.
+    STRING GetString(INT32 index);
+    /// \brief
+    /// Gets the BLOB value of the specified property. No conversion is
+    /// performed, thus the property must be a of type BLOBs or the result
+    /// is NULL
+    /// \param index
+    /// \return
+    /// Returns the BLOB value.
+    MgByteReader* GetBLOB(INT32 index);
+    /// \brief
+    /// Gets the CLOB value of the specified property. No conversion is
+    /// performed, thus the property must be a of type CLOB or the result
+    /// is NULL
+    /// \param index
+    /// \return
+    /// Returns the CLOB value.
+    MgByteReader* GetCLOB(INT32 index);
+    /// \brief
+    /// Gets the Geometry for the specified property. No conversion is
+    /// performed, thus the property must be a of type Geometry or the result
+    /// is NULL
+    /// \param index
+    /// \return
+    /// Returns a ByteReader object
+    MgByteReader* GetGeometry(INT32 index);
+    /// \brief
+    /// Gets the raster object of the specified property.
+    /// the property must be of Raster type; otherwise, an exception is thrown.
+    /// \param index
+    /// \return
+    /// Returns the raster object.
+    MgRaster* GetRaster(INT32 index);
+    /// \brief
     /// Closes the FeatureReader object, freeing any resources it may be holding.
     void Close();
@@ -313,6 +519,20 @@
     /// \brief
+    /// is NULL
+    /// \param index
+    /// \return
+    const wchar_t* GetString(INT32 index, INT32& length);
+    /// \brief
     /// \param stream
@@ -353,6 +573,11 @@
     MgProperty* GetProperty(CREFSTRING propertyName, INT16 expectedType);
     /// Get the property for the specified name
     MgProperty* GetProperty(CREFSTRING propertyName);
+    MgProperty* GetProperty(INT32 index, INT16 expectedType);
+    /// Get the property for the specified index.
+    MgProperty* GetProperty(INT32 index);
     void UpdateCurrentSet(MgBatchPropertyCollection* bpCol);
     Ptr<MgBatchPropertyCollection> m_set;
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureReader.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureReader.cpp	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureReader.cpp	2009-09-29 09:14:23 UTC (rev 4271)
@@ -196,6 +196,26 @@
 /// <summary>
+/// </summary>
+bool MgProxyFeatureReader::IsNull(INT32 index)
+    return isNull;
+/// <summary>
@@ -215,6 +235,25 @@
 /// <summary>
+/// EXCEPTIONS:
+/// InvalidPropertyType
+bool MgProxyFeatureReader::GetBoolean(INT32 index)
+    return retVal;
+/// <summary>
@@ -234,6 +273,25 @@
 /// <summary>
+/// EXCEPTIONS:
+BYTE MgProxyFeatureReader::GetByte(INT32 index)
+    BYTE retVal = 0;
+    return retVal;
+/// <summary>
@@ -251,6 +309,24 @@
 /// <summary>
+/// EXCEPTIONS:
+MgDateTime* MgProxyFeatureReader::GetDateTime(INT32 index)
+/// <summary>
@@ -270,6 +346,25 @@
 /// <summary>
+/// EXCEPTIONS:
+float MgProxyFeatureReader::GetSingle(INT32 index)
+    float retVal = 0;
+    return retVal;
+/// <summary>
@@ -289,6 +384,25 @@
 /// <summary>
+/// EXCEPTIONS:
+double MgProxyFeatureReader::GetDouble(INT32 index)
+    return retVal;
+/// <summary>
@@ -308,6 +422,25 @@
 /// <summary>
+/// EXCEPTIONS:
+INT16 MgProxyFeatureReader::GetInt16(INT32 index)
+    INT16 retVal = 0;
+    return retVal;
+/// <summary>
@@ -327,6 +460,25 @@
 /// <summary>
+/// EXCEPTIONS:
+INT32 MgProxyFeatureReader::GetInt32(INT32 index)
+    INT32 retVal = 0;
+    return retVal;
+/// <summary>
@@ -348,6 +500,27 @@
 /// <summary>
+///</returns>
+/// EXCEPTIONS:
+INT64 MgProxyFeatureReader::GetInt64(INT32 index)
+    INT64 retVal = 0;
+    return retVal;
+/// <summary>
@@ -367,6 +540,25 @@
 /// <summary>
+/// EXCEPTIONS:
+STRING MgProxyFeatureReader::GetString(INT32 index)
+    return retVal;
+/// <summary>
@@ -384,6 +576,23 @@
 /// <summary>
+/// EXCEPTIONS:
+MgByteReader* MgProxyFeatureReader::GetBLOB(INT32 index)
+/// <summary>
@@ -401,6 +610,24 @@
 /// <summary>
+/// EXCEPTIONS:
+MgByteReader* MgProxyFeatureReader::GetCLOB(INT32 index)
+/// <summary>
 /// Gets the FeatureReader to access this object value.
 /// The property must be of an object type{} otherwise, the result is NULL.
 /// </summary>
@@ -418,6 +645,23 @@
 /// <summary>
+/// Gets the FeatureReader to access this object value.
+/// The property must be of an object type{} otherwise, the result is NULL.
+/// </summary>
+/// <returns>Returns the feature reader to access this object.</returns>
+/// EXCEPTIONS:
+MgFeatureReader* MgProxyFeatureReader::GetFeatureObject(INT32 index)
+    Ptr<MgFeatureProperty> ptrProp = (MgFeatureProperty*)GetProperty(index, MgPropertyType::Feature);
+    Ptr<MgFeatureReader> retVal = ptrProp->GetValue();
+    return SAFE_ADDREF((MgFeatureReader*)retVal);
+/// <summary>
 /// Gets the geometry value of the specified property as a GeometryReader.
 /// Because no conversion is performed, the property must be
 /// of Geometric type{} otherwise, the result is NULL.</summary>
@@ -433,6 +677,23 @@
+/// <summary>
+/// Gets the geometry value of the specified property as a GeometryReader.
+/// Because no conversion is performed, the property must be
+/// of Geometric type{} otherwise, the result is NULL.</summary>
+/// <returns>Returns the Geometry object.</returns>
+/// EXCEPTIONS:
+MgByteReader* MgProxyFeatureReader::GetGeometry(INT32 index)
 MgProperty* MgProxyFeatureReader::GetProperty(CREFSTRING propertyName, INT16 expectedType)
@@ -454,6 +715,29 @@
+MgProperty* MgProxyFeatureReader::GetProperty(INT32 index, INT16 expectedType)
+    CHECKNULL(ptrProp, L"MgProxyFeatureReader.GetProperty");
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgProxyFeatureReader.GetProperty",
+    CHECK_PROPERTY_TYPE(propType, expectedType, L"MgProxyFeatureReader.GetProperty");
 MgProperty* MgProxyFeatureReader::GetProperty(CREFSTRING propertyName)
@@ -469,7 +753,21 @@
+MgProperty* MgProxyFeatureReader::GetProperty(INT32 index)
+    CHECKNULL(m_set, L"MgProxyFeatureReader.GetProperty");
+    CHECK_FEATURESET_COUNT(m_set, L"MgProxyFeatureReader.GetProperty");
+    Ptr<MgPropertyCollection> ptrCol = m_set->GetFeatureAt(m_currRecord-1);
+    CHECKNULL(ptrCol, L"MgProxyFeatureReader.GetProperty");
 ///<summary>
@@ -615,6 +913,21 @@
+/// </summary>
+MgRaster* MgProxyFeatureReader::GetRaster(INT32 index)
+    retVal->SetHandle(m_serverfeatReader);
 /// <summary>
@@ -630,6 +943,19 @@
 /// <summary>
+BYTE_ARRAY_OUT MgProxyFeatureReader::GetGeometry(INT32 index, INT32& length)
+    throw new MgNotImplementedException(L"MgProxyFeatureReader.GetGeometry",
+        __LINE__, __WFILE__, NULL, L"", NULL);
+/// <summary>
@@ -643,6 +969,21 @@
     return str.c_str();
+/// <summary>
+const wchar_t* MgProxyFeatureReader::GetString(INT32 index, INT32& length)
 void MgProxyFeatureReader::SetServiceForFeatureProperties(MgFeatureService* service)
     if (m_set != NULL)
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureReader.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureReader.h	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureReader.h	2009-09-29 09:14:23 UTC (rev 4271)
@@ -302,7 +302,170 @@
+    /// <summary>
+    ///  Returns true if the value of the property at the specified index is null.
+    /// </summary>
+    /// <param name="index">Property index.</param>
+    /// <returns>Returns true if the value is null.</returns>
+    /// <summary>
+    /// Gets the Boolean value of the property at the specified index. No conversion is
+    /// is undertermined</summary>
+    /// <returns>Returns the Boolean value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not boolean
+    /// <summary>
+    /// Gets the Byte value of the property at the specified index. No conversion is
+    /// <returns>Returns the Byte value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not byte
+    /// <summary>
+    /// Gets the DTime value of the property at the specified index. No conversion is
+    /// is NULL</summary>
+    /// <returns>Returns the DTime value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not date/time
+    /// <summary>
+    /// Gets the Single value of the property at the specified index. No conversion is
+    /// is undetermined</summary>
+    /// <returns>Returns the single value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not float
+    /// <summary>
+    /// Gets the Double value of the property at the specified index. No conversion is
+    /// <returns>Returns the double value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not double
+    /// <summary>
+    /// Gets the integer 16 bits value of the property at the specified index. No conversion is
+    /// <returns>Returns the integer 16 bits value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not int16
+    /// <summary>
+    /// Gets the integer 32 bits value of the property at the specified index. No conversion is
+    /// <returns>Returns the integer 32 bits value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not int32
+    /// <summary>
+    /// Gets the integer 64 bits value of the property at the specified index. No conversion is
+    /// <returns>Returns the integer 64 bits value.
+    ///</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not int64
+    /// <summary>
+    /// Gets the string value of the property at the specified index. No conversion is
+    /// <returns>Returns the string value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not a string
+    /// <summary>
+    /// Gets the BLOB value of the property at the specified index. No conversion is
+    /// <returns>Returns the BLOB value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not a BLOB
+    /// <summary>
+    /// Gets the CLOB value of the property at the specified index. No conversion is
+    /// <returns>Returns the CLOB value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not a CLOB
+    /// <summary>
+    /// Gets the FeatureReader to access this object value.
+    /// The property must be of an object type; otherwise, the result is NULL.
+    /// </summary>
+    /// <returns>Returns the feature reader to access this object.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not a feature
+    MgFeatureReader* GetFeatureObject(INT32 index);
+    /// <summary>
+    /// Gets the geometry value of the property at the specified index as a GeometryReader.
+    /// Because no conversion is performed, the property must be
+    /// of Geometric type; otherwise, the result is NULL.</summary>
+    /// <returns>Returns the Geometry object.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not geometry
+    /// <summary>
+    /// </summary>
+    /// <returns>Returns the Raster object.</returns>
+    /// EXCEPTIONS:
     /// \brief
     /// Serializes all features into an XML.
     /// XML is serialized from the current position of feature reader in the order
@@ -360,6 +523,20 @@
     BYTE_ARRAY_OUT GetGeometry(CREFSTRING propertyName, INT32& length);
+    /// \brief
+    /// is NULL
+    /// \param index
+    /// \return
+    BYTE_ARRAY_OUT GetGeometry(INT32 index, INT32& length);
     /// \brief
@@ -374,6 +551,20 @@
     const wchar_t* GetString(CREFSTRING propertyName, INT32& length);
+    /// \brief
+    /// is NULL
+    /// \param index
+    /// \return
     /// \brief
@@ -423,6 +614,11 @@
+    /// Get the property at the specified index
     void SetServiceForFeatureProperties(MgFeatureService* service);
     Ptr<MgFeatureSet> m_set;
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.cpp	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.cpp	2009-09-29 09:14:23 UTC (rev 4271)
@@ -165,6 +165,26 @@
 /// <summary>
+/// </summary>
+bool MgProxyGwsFeatureReader::IsNull(INT32 index)
+    return isNull;
+/// <summary>
@@ -183,6 +203,24 @@
 /// <summary>
+bool MgProxyGwsFeatureReader::GetBoolean(INT32 index)
+    return retVal;
+/// <summary>
@@ -201,6 +239,24 @@
 /// <summary>
+BYTE MgProxyGwsFeatureReader::GetByte(INT32 index)
+    BYTE retVal = 0;
+    return retVal;
+/// <summary>
@@ -217,6 +273,22 @@
 /// <summary>
+MgDateTime* MgProxyGwsFeatureReader::GetDateTime(INT32 index)
+/// <summary>
@@ -235,6 +307,24 @@
 /// <summary>
+float MgProxyGwsFeatureReader::GetSingle(INT32 index)
+    float retVal = 0;
+    return retVal;
+/// <summary>
@@ -253,6 +343,24 @@
 /// <summary>
+double MgProxyGwsFeatureReader::GetDouble(INT32 index)
+    return retVal;
+/// <summary>
@@ -270,6 +378,24 @@
 /// <summary>
+INT16 MgProxyGwsFeatureReader::GetInt16(INT32 index)
+    INT16 retVal = 0;
+    return retVal;
+/// <summary>
@@ -287,6 +413,23 @@
 /// <summary>
+INT32 MgProxyGwsFeatureReader::GetInt32(INT32 index)
+    INT32 retVal = 0;
+    return retVal;
+/// <summary>
@@ -306,6 +449,25 @@
 /// <summary>
+///</returns>
+INT64 MgProxyGwsFeatureReader::GetInt64(INT32 index)
+    INT64 retVal = 0;
+    return retVal;
+/// <summary>
@@ -323,6 +485,24 @@
 /// <summary>
+STRING MgProxyGwsFeatureReader::GetString(INT32 index)
+    return retVal;
+/// <summary>
@@ -338,6 +518,22 @@
 /// <summary>
+MgByteReader* MgProxyGwsFeatureReader::GetBLOB(INT32 index)
+/// <summary>
@@ -353,6 +549,22 @@
 /// <summary>
+MgByteReader* MgProxyGwsFeatureReader::GetCLOB(INT32 index)
+/// <summary>
 /// </summary>
@@ -370,6 +582,24 @@
 /// <summary>
+/// </summary>
+/// EXCEPTIONS:
+MgFeatureReader* MgProxyGwsFeatureReader::GetFeatureObject(INT32 index)
+/// <summary>
@@ -383,6 +613,21 @@
+/// <summary>
+MgByteReader* MgProxyGwsFeatureReader::GetGeometry(INT32 index)
 MgProperty* MgProxyGwsFeatureReader::GetProperty(CREFSTRING propertyName, INT16 expectedType)
@@ -419,6 +664,45 @@
+MgProperty* MgProxyGwsFeatureReader::GetProperty(INT32 index, INT16 expectedType)
+    CHECKNULL(ptrProp, L"MgProxyGwsFeatureReader.GetProperty");
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgProxyGwsFeatureReader.GetProperty",
+    MG_CHECK_PROPERTY_TYPE(propType, expectedType, L"MgProxyGwsFeatureReader.GetProperty");
+MgProperty* MgProxyGwsFeatureReader::GetProperty(INT32 index)
+    CHECKNULL(m_set, L"MgProxyGwsFeatureReader.GetProperty");
+    MG_CHECK_FEATURE_SET_COUNT(m_set, L"MgProxyGwsFeatureReader.GetProperty");
+    CHECKNULL(ptrCol, L"MgProxyGwsFeatureReader.GetProperty");
 ///<summary>
@@ -570,6 +854,25 @@
+/// </summary>
+/// EXCEPTIONS:
+/// MgConnectionNotOpenException
+/// MgNullPropertyValueException
+/// MgFdoException
+MgRaster* MgProxyGwsFeatureReader::GetRaster(INT32 index)
+    retVal->SetHandle(m_serverGwsFeatureReader);
 /// <summary>
@@ -585,6 +888,19 @@
 /// <summary>
+BYTE_ARRAY_OUT MgProxyGwsFeatureReader::GetGeometry(INT32 index, INT32& length)
+    throw new MgNotImplementedException(L"MgProxyGwsFeatureReader.GetGeometry",
+/// <summary>
@@ -598,7 +914,21 @@
     return str.c_str();
+/// <summary>
+const wchar_t* MgProxyGwsFeatureReader::GetString(INT32 index, INT32& length)
 void MgProxyGwsFeatureReader::SetServiceForFeatureProperties(MgFeatureService* service)
     if (m_set != NULL)
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.h	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.h	2009-09-29 09:14:23 UTC (rev 4271)
@@ -279,7 +279,171 @@
     /// \exception MgInvalidPropertyTypeException
+    /// <summary>
+    /// </summary>
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    ///</returns>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// </summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// </summary>
+    /// EXCEPTIONS:
     /// \brief
@@ -335,6 +499,20 @@
     /// \brief
+    /// is NULL
+    /// \param index
+    /// \return
+    /// \brief
     /// is NULL
@@ -349,6 +527,20 @@
     /// \brief
+    /// is NULL
+    /// \param index
+    /// \return
+    /// \brief
     /// \param stream
@@ -400,6 +592,11 @@
     //void UpdateCurrentSet(MgBatchPropertyCollection* bpCol);
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxySqlDataReader.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxySqlDataReader.cpp	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxySqlDataReader.cpp	2009-09-29 09:14:23 UTC (rev 4271)
@@ -137,6 +137,19 @@
 /// <summary>
+/// </summary>
+INT32 MgProxySqlDataReader::GetPropertyIndex(CREFSTRING propertyName)
+    CHECKNULL(m_propDefCol, L"MgProxySqlDataReader.GetPropertyIndex");
+/// <summary>
 /// </summary>
@@ -171,6 +184,27 @@
 /// <summary>
+/// </summary>
+bool MgProxySqlDataReader::IsNull(INT32 index)
+    return isNull;
+/// <summary>
@@ -189,6 +223,24 @@
 /// <summary>
+bool MgProxySqlDataReader::GetBoolean(INT32 index)
+    return retVal;
+/// <summary>
@@ -207,6 +259,24 @@
 /// <summary>
+BYTE MgProxySqlDataReader::GetByte(INT32 index)
+    BYTE retVal = 0;
+    return retVal;
+/// <summary>
@@ -223,6 +293,22 @@
 /// <summary>
+MgDateTime* MgProxySqlDataReader::GetDateTime(INT32 index)
+/// <summary>
@@ -241,6 +327,24 @@
 /// <summary>
+float MgProxySqlDataReader::GetSingle(INT32 index)
+    float retVal = 0;
+    return retVal;
+/// <summary>
@@ -259,6 +363,24 @@
 /// <summary>
+double MgProxySqlDataReader::GetDouble(INT32 index)
+    return retVal;
+/// <summary>
@@ -276,6 +398,23 @@
 /// <summary>
+INT16 MgProxySqlDataReader::GetInt16(INT32 index)
+    INT16 retVal = 0;
+    return retVal;
+/// <summary>
@@ -293,6 +432,23 @@
 /// <summary>
+INT32 MgProxySqlDataReader::GetInt32(INT32 index)
+    INT32 retVal = 0;
+    return retVal;
+/// <summary>
@@ -312,6 +468,25 @@
 /// <summary>
+///</returns>
+INT64 MgProxySqlDataReader::GetInt64(INT32 index)
+    INT64 retVal = 0;
+    return retVal;
+/// <summary>
@@ -329,6 +504,23 @@
 /// <summary>
+STRING MgProxySqlDataReader::GetString(INT32 index)
+    return retVal;
+/// <summary>
@@ -344,6 +536,22 @@
 /// <summary>
+MgByteReader* MgProxySqlDataReader::GetBLOB(INT32 index)
+/// <summary>
@@ -359,6 +567,21 @@
 /// <summary>
+MgByteReader* MgProxySqlDataReader::GetCLOB(INT32 index)
+/// <summary>
@@ -373,6 +596,21 @@
+/// <summary>
+MgByteReader* MgProxySqlDataReader::GetGeometry(INT32 index)
 ///<summary>
 ///</summary>
@@ -522,6 +760,45 @@
+MgProperty* MgProxySqlDataReader::GetProperty(INT32 index, INT16 expectedType)
+    CHECKNULL(ptrProp, L"MgProxySqlDataReader.GetProperty");
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgProxySqlDataReader.GetProperty",
+    CHECK_PROPERTY_TYPE(propType, expectedType, L"MgProxySqlDataReader.GetProperty");
+MgProperty* MgProxySqlDataReader::GetProperty(INT32 index)
+    CHECKNULL(m_set, L"MgProxySqlDataReader.GetProperty");
+    CHECK_FEATURESET_COUNT(m_set, L"MgProxySqlDataReader.GetProperty");
+    CHECKNULL(ptrCol, L"MgProxySqlDataReader.GetProperty");
 void MgProxySqlDataReader::UpdateCurrentSet(MgBatchPropertyCollection* bpCol)
     CHECKNULL((MgBatchPropertyCollection*)m_set, L"MgProxySqlDataReader.UpdateCurrentSet");
@@ -552,6 +829,20 @@
     throw new MgInvalidPropertyTypeException(L"MgProxySqlDataReader.GetRaster", __LINE__, __WFILE__, NULL, L"", NULL);
+/// </summary>
+/// <param name="propertyName">Input the property name.</param>
+/// EXCEPTIONS:
+/// MgFdoException
+MgRaster* MgProxySqlDataReader::GetRaster(INT32 index)
+    throw new MgInvalidPropertyTypeException(L"MgProxySqlDataReader.GetRaster", __LINE__, __WFILE__, NULL, L"", NULL);
 /// <summary>
@@ -566,3 +857,18 @@
     return str.c_str();
+/// <summary>
+const wchar_t* MgProxySqlDataReader::GetString(INT32 index, INT32& length)
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxySqlDataReader.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxySqlDataReader.h	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxySqlDataReader.h	2009-09-29 09:14:23 UTC (rev 4271)
@@ -72,6 +72,18 @@
     /// \brief
+    /// \return
+    /// \brief
@@ -279,7 +291,170 @@
+    /// <summary>
+    /// </summary>
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    ///</returns>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// </summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// </summary>
+    /// EXCEPTIONS:
     /// \brief
@@ -314,6 +489,20 @@
     /// \brief
+    /// is NULL
+    /// \param index
+    /// \return
+    /// \brief
     /// \param stream
@@ -354,6 +543,11 @@
Modified: trunk/MgDev/Common/PlatformBase/Services/FeatureReader.cpp
--- trunk/MgDev/Common/PlatformBase/Services/FeatureReader.cpp	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Common/PlatformBase/Services/FeatureReader.cpp	2009-09-29 09:14:23 UTC (rev 4271)
@@ -56,6 +56,23 @@
 /// <summary>
+/// Gets the index of the property with the specified property name.
+/// </summary>
+INT32 MgFeatureReader::GetPropertyIndex(CREFSTRING propertyName)
+    Ptr<MgClassDefinition> classDef = this->GetClassDefinition();
+    CHECKNULL((MgClassDefinition*)classDef, L"MgFeatureReader.GetPropertyIndex");
+    Ptr<MgPropertyDefinitionCollection> propDefCol = classDef->GetProperties();
+    CHECKNULL((MgPropertyDefinitionCollection*)propDefCol, L"MgFeatureReader.GetPropertyIndex");
+    return propDefCol->IndexOf(propertyName);
+/// <summary>
 /// Please refer to MgPropertyType for list of values
 /// </summary>
Modified: trunk/MgDev/Common/PlatformBase/Services/FeatureReader.h
--- trunk/MgDev/Common/PlatformBase/Services/FeatureReader.h	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Common/PlatformBase/Services/FeatureReader.h	2009-09-29 09:14:23 UTC (rev 4271)
@@ -338,6 +338,44 @@
     virtual MgFeatureReader* GetFeatureObject(CREFSTRING propertyName) = 0;
+    /// \brief
+    /// Use this method to obtain the values of the properties
+    /// belonging to an object contained in the feature class
+    /// instance. Such an object is a property of the feature class
+    /// instance with a type of MgPropertyType::Feature.
+    /// <!-- Syntax in .Net, Java, and PHP -->
+    /// \htmlinclude DotNetSyntaxTop.html
+    /// virtual MgFeatureReader GetFeatureObject(int index);
+    /// \htmlinclude SyntaxBottom.html
+    /// \htmlinclude JavaSyntaxTop.html
+    /// \htmlinclude PHPSyntaxTop.html
+    /// \param index (int)
+    /// The position of the property in the list of
+    /// properties belonging to the feature currently
+    /// being read.
+    /// \return
+    /// Returns an MgFeatureReader object, which can be used to
+    /// access properties of an object contained in the feature
+    /// object.
+    /// \exception MgInvalidArgumentException
+    ///  if the property type is not a
+    ///  feature.
+    /// \exception MgConnectionNotOpenException
+    /// \exception MgNullPropertyValueException
+    /// \exception MgFdoException
+    virtual MgFeatureReader* GetFeatureObject(INT32 index) = 0;
 INTERNAL_API:
@@ -354,6 +392,22 @@
     virtual BYTE_ARRAY_OUT GetGeometry(CREFSTRING propertyName, INT32& length) = 0;
+    /// \brief
+    /// is NULL
+    /// being read.
+    /// \return
+    virtual BYTE_ARRAY_OUT GetGeometry(INT32 index, INT32& length) = 0;
     /// \brief
     /// Gets the number of properties in the result set.
@@ -375,6 +429,20 @@
     virtual STRING GetPropertyName(INT32 index);
+    /// \brief
+    /// Gets the index of the property with the specified property name.
+    /// \param propertyName(string)
+    /// The name of the property in the list of
+    /// being read.
+    /// \return
+    /// Returns the property index.
+    virtual INT32 GetPropertyIndex(CREFSTRING propertyName);
     /// \brief
Modified: trunk/MgDev/Common/PlatformBase/Services/Reader.h
--- trunk/MgDev/Common/PlatformBase/Services/Reader.h	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Common/PlatformBase/Services/Reader.h	2009-09-29 09:14:23 UTC (rev 4271)
@@ -563,6 +563,492 @@
     virtual MgRaster* GetRaster(CREFSTRING propertyName) = 0;
+    /// \brief
+    /// virtual int GetPropertyIndex(string propertyName);
+    /// being read.
+    /// \return
+    virtual INT32 GetPropertyIndex(CREFSTRING propertyName) = 0;
+    /// \brief
+    /// Determines whether the value of the specified property is
+    /// null.
+    /// virtual bool IsNull(int index);
+    /// virtual boolean IsNull(int index);
+    /// being read.
+    /// \return
+    /// Returns true if the value is null; otherwise returns false.
+    virtual bool IsNull(INT32 index) = 0;
+    /// \brief
+    /// \remarks
+    /// No conversion is performed. Therefore, the property must be of
+    /// MgPropertyType::Boolean type or an
+    /// MgInvalidPropertyTypeException is thrown.
+    /// virtual bool GetBoolean(int index);
+    /// virtual boolean GetBoolean(int index);
+    /// being read.
+    /// \return
+    /// \exception MgInvalidPropertyTypeException.
+    virtual bool GetBoolean(INT32 index) = 0;
+    /// \brief
+    /// \remarks
+    /// of type MgPropertyType::Byte or an
+    /// virtual unsigned char GetByte(int index);
+    /// virtual signed char GetByte(int index);
+    /// virtual int GetByte(int index);
+    /// being read.
+    /// \return
+    virtual BYTE GetByte(INT32 index) = 0;
+    /// \brief
+    /// Gets the MgDateTime value of the specified property.
+    /// \remarks
+    /// of type MgPropertyType::DateTime or an
+    /// virtual MgDateTime GetDateTime(int index);
+    /// being read.
+    /// \return
+    /// Returns an MgDateTime object.
+    virtual MgDateTime* GetDateTime(INT32 index) = 0;
+    /// \brief
+    /// \remarks
+    /// No conversion is performed. Therefore, the property must be a
+    /// of type MgPropertyType::Single or an
+    /// virtual float GetSingle(int index);
+    /// being read.
+    /// \return
+    virtual float GetSingle(INT32 index) = 0;
+    /// \brief
+    /// \remarks
+    /// of type MgPropertyType::Double or an
+    /// virtual double GetDouble(int index);
+    /// being read.
+    /// \return
+    virtual double GetDouble(INT32 index) = 0;
+    /// \brief
+    /// Gets the 16 bit integer value of the specified property.
+    /// \remarks
+    /// No conversion is performed. Therefore the property must be a
+    /// of type MgPropertyType::Int16 or an
+    /// virtual short GetInt16(int index);
+    /// virtual int GetInt16(int index);
+    /// being read.
+    /// \return
+    /// Returns the 16 bit integer value.
+    virtual INT16 GetInt16(INT32 index) = 0;
+    /// \brief
+    /// Gets the 32 bit integer value of the specified property.
+    /// \remarks
+    /// of type MgPropertyType::Int32 or an
+    /// virtual int GetInt32(int index);
+    /// being read.
+    /// \return
+    virtual INT32 GetInt32(INT32 index) = 0;
+    /// \brief
+    /// Gets the 64 bit integer value of the specified property.
+    /// \remarks
+    /// of type MgPropertyType::Int64 or an
+    ///  virtual long GetInt64(int index);
+    ///  virtual string GetInt64(int index);
+    /// being read.
+    /// \return
+    /// \note
+    /// INT64 is actually a pointer to an Integer64 object
+    virtual INT64 GetInt64(INT32 index) = 0;
+    /// \brief
+    /// \remarks
+    /// of type MgPropertyType::String or an
+    /// virtual string GetString(int index);
+    /// virtual String GetString(int index);
+    /// being read.
+    /// \return
+    virtual STRING GetString(INT32 index) = 0;
+    /// \brief
+    /// Gets the \link BLOB BLOB \endlink value of the specified property.
+    /// \remarks
+    /// of type MgPropertyType::Blob or an
+    /// virtual MgByteReader GetBLOB(int index);
+    /// being read.
+    /// \return
+    /// Returns the BLOB value in an MgByteReader object.
+    virtual MgByteReader* GetBLOB(INT32 index) = 0;
+    /// \brief
+    /// \remarks
+    /// of type MgPropertyType::Clob or an
+    /// virtual MgByteReader GetCLOB(int index);
+    /// being read.
+    /// \return
+    /// Returns the CLOB value in an MgByteReader object.
+    virtual MgByteReader* GetCLOB(INT32 index) = 0;
+    /// \brief
+    /// \remarks
+    /// of type MgPropertyType::Geometry or an
+    /// virtual MgByteReader GetGeometry(int index);
+    /// being read.
+    /// \return
+    /// Returns a geometry in AGF binary format in an MgByteReader
+    /// object.
+    virtual MgByteReader* GetGeometry(INT32 index) = 0;
+    /// \brief
+    /// \remarks
+    /// The property must be of type MgPropertyType::Raster, or an
+    /// virtual MgRaster GetRaster(int index);
+    /// being read.
+    /// \return
+    /// Returns an MgRaster object.
+    /// \exception MgConnectionNotOpenException MgNullPropertyValueException
+    /// \exception MgFdoException MgInvalidPropertyTypeException
+    virtual MgRaster* GetRaster(INT32 index) = 0;
     /// \brief
     /// Closes the object, freeing any resources it may be holding.
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureQueryResults.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureQueryResults.cpp	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureQueryResults.cpp	2009-09-29 09:14:23 UTC (rev 4271)
@@ -316,13 +316,29 @@
     return ((CGwsQueryResultDescriptors *) featDsc.p)->GetPropertyDescriptor (propname);
+FdoString* CGwsFeatureIterator::GetPropertyName(FdoInt32 index)
+    CheckReader ();
+    return m_reader->GetPropertyName(index);
+FdoInt32 CGwsFeatureIterator::GetPropertyIndex(FdoString* propertyName)
+    CheckReader ();
+    return m_reader->GetPropertyIndex(propertyName);
 FdoString * CGwsFeatureIterator::GetString (FdoString * propname)
     CheckReader ();
     return m_reader->GetString (propname);
+FdoString * CGwsFeatureIterator::GetString (FdoInt32 index)
+    CheckReader ();
+    return m_reader->GetString (index);
 bool CGwsFeatureIterator::GetBoolean(FdoString* propname)
@@ -330,6 +346,11 @@
     return m_reader->GetBoolean (propname);
+bool CGwsFeatureIterator::GetBoolean(FdoInt32 index)
+    CheckReader ();
+    return m_reader->GetBoolean (index);
 FdoByte CGwsFeatureIterator::GetByte(FdoString* propname)
@@ -337,6 +358,11 @@
     return m_reader->GetByte (propname);
+FdoByte CGwsFeatureIterator::GetByte(FdoInt32 index)
+    CheckReader ();
+    return m_reader->GetByte (index);
 FdoDateTime CGwsFeatureIterator::GetDateTime(FdoString* propname)
@@ -344,6 +370,11 @@
     return m_reader->GetDateTime (propname);
+FdoDateTime CGwsFeatureIterator::GetDateTime(FdoInt32 index)
+    CheckReader ();
+    return m_reader->GetDateTime (index);
 double CGwsFeatureIterator::GetDouble(FdoString* propname)
@@ -351,6 +382,11 @@
     return m_reader->GetDouble (propname);
+double CGwsFeatureIterator::GetDouble(FdoInt32 index)
+    CheckReader ();
+    return m_reader->GetDouble (index);
 FdoInt16 CGwsFeatureIterator::GetInt16(FdoString* propname)
@@ -358,6 +394,11 @@
     return m_reader->GetInt16 (propname);
+FdoInt16 CGwsFeatureIterator::GetInt16(FdoInt32 index)
+    CheckReader ();
+    return m_reader->GetInt16 (index);
 FdoInt32 CGwsFeatureIterator::GetInt32(FdoString* propname)
@@ -365,6 +406,11 @@
     return m_reader->GetInt32 (propname);
+FdoInt32 CGwsFeatureIterator::GetInt32(FdoInt32 index)
+    CheckReader ();
+    return m_reader->GetInt32 (index);
 FdoInt64 CGwsFeatureIterator::GetInt64(FdoString* propname)
@@ -372,6 +418,11 @@
     return m_reader->GetInt64 (propname);
+FdoInt64 CGwsFeatureIterator::GetInt64(FdoInt32 index)
+    CheckReader ();
+    return m_reader->GetInt64 (index);
 float CGwsFeatureIterator::GetSingle(FdoString* propname)
@@ -379,6 +430,11 @@
     return m_reader->GetSingle (propname);
+float CGwsFeatureIterator::GetSingle(FdoInt32 index)
+    CheckReader ();
+    return m_reader->GetSingle (index);
 FdoLOBValue * CGwsFeatureIterator::GetLOB(FdoString* propertyName)
@@ -386,6 +442,11 @@
     return m_reader->GetLOB (propertyName);
+FdoLOBValue * CGwsFeatureIterator::GetLOB(FdoInt32 index)
+    CheckReader ();
+    return m_reader->GetLOB (index);
 FdoIStreamReader* CGwsFeatureIterator::GetLOBStreamReader(const wchar_t* propertyName )
@@ -393,6 +454,11 @@
     return m_reader->GetLOBStreamReader (propertyName);
+FdoIStreamReader* CGwsFeatureIterator::GetLOBStreamReader(FdoInt32 index)
+    CheckReader ();
+    return m_reader->GetLOBStreamReader (index);
 bool CGwsFeatureIterator::IsNull(FdoString* propertyName)
@@ -400,6 +466,11 @@
     return m_reader->IsNull (propertyName);
+bool CGwsFeatureIterator::IsNull(FdoInt32 index)
+    CheckReader ();
+    return m_reader->IsNull (index);
 FdoIRaster*  CGwsFeatureIterator::GetRaster(FdoString* propertyName)
@@ -407,6 +478,11 @@
     return m_reader->GetRaster (propertyName);
+FdoIRaster*  CGwsFeatureIterator::GetRaster(FdoInt32 index)
+    CheckReader ();
+    return m_reader->GetRaster (index);
 FdoDataValue * CGwsFeatureIterator::GetDataValue (FdoString* propertyName)
@@ -456,7 +532,23 @@
     return gvalue;
+const FdoByte * CGwsFeatureIterator::GetGeometry(
+    FdoInt32 index,
+    FdoInt32  * count
+    CheckReader ();
+    FdoByte * gvalue = (FdoByte *) m_reader->GetGeometry (index, count);
+    if (m_converter != NULL && ! m_bGeometryConverted && gvalue) {
+        EGwsStatus stat = m_converter->ConvertForward (gvalue, * count);
+        if (IGWSException::IsError (stat))
+            GWS_THROW (stat);
+        m_bGeometryConverted = true;
+    return gvalue;
 FdoByteArray* CGwsFeatureIterator::GetGeometry(FdoString* propertyName)
     CheckReader ();
@@ -470,7 +562,20 @@
     return gvalue;
+FdoByteArray* CGwsFeatureIterator::GetGeometry(FdoInt32 index)
+    CheckReader ();
+    FdoByteArray * gvalue = m_reader->GetGeometry (index);
+        EGwsStatus stat = m_converter->ConvertForward (gvalue);
+            GWS_THROW (stat);
+    return gvalue;
 FdoByteArray * CGwsFeatureIterator::GetOriginalGeometry (FdoString* propertyName)
     CheckReader ();
@@ -493,6 +598,11 @@
     return m_reader->GetFeatureObject (propertyName);
+FdoIFeatureReader* CGwsFeatureIterator::GetFeatureObject(FdoInt32 index)
+    CheckReader ();
+    return m_reader->GetFeatureObject (index);
 bool CGwsFeatureIterator::ReadNext()
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFlatFdoReader.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFlatFdoReader.cpp	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFlatFdoReader.cpp	2009-09-29 09:14:23 UTC (rev 4271)
@@ -172,7 +172,20 @@
     return 0;
+FdoString* CGwsFlatFdoReader::GetPropertyName(FdoInt32 index)
+    assert(index >= 0 && index < m_names->GetCount());
+    if (index < m_names->GetCount() && index >= 0)
+        return m_names->GetString(index);
+    return L""; // throw exception?
+FdoInt32 CGwsFlatFdoReader::GetPropertyIndex(FdoString* propertyName)
+    return m_names->IndexOf(propertyName, false);
 const FdoByte * CGwsFlatFdoReader::GetGeometry(FdoString* propertyName, FdoInt32 * count)
     CHECK_GWS_ITERATOR;
@@ -189,7 +202,6 @@
     return freader->GetGeometry (name.c_str (), count);
 FdoByteArray* CGwsFlatFdoReader::GetGeometry(FdoString* propertyName)
     CHECK_GWS_ITERATOR;
@@ -388,7 +400,112 @@
     return freader->GetRaster (name.c_str ());
+const FdoByte * CGwsFlatFdoReader::GetGeometry(FdoInt32 index, FdoInt32 * count)
+    FdoStringP propertyName = GetPropertyName(index);
+    return GetGeometry((FdoString*)propertyName, count);
+FdoByteArray* CGwsFlatFdoReader::GetGeometry(FdoInt32 index)
+    return GetGeometry((FdoString*)propertyName);
+FdoIFeatureReader*  CGwsFlatFdoReader::GetFeatureObject(FdoInt32 index)
+    return GetFeatureObject((FdoString*)propertyName);
+bool CGwsFlatFdoReader::GetBoolean(FdoInt32 index)
+    return GetBoolean((FdoString*)propertyName);
+FdoByte CGwsFlatFdoReader::GetByte(FdoInt32 index)
+    return GetByte((FdoString*)propertyName);
+FdoDateTime CGwsFlatFdoReader::GetDateTime(FdoInt32 index)
+    return GetDateTime((FdoString*)propertyName);
+double CGwsFlatFdoReader::GetDouble(FdoInt32 index)
+    return GetDouble((FdoString*)propertyName);
+FdoInt16 CGwsFlatFdoReader::GetInt16(FdoInt32 index)
+    return GetInt16((FdoString*)propertyName);
+FdoInt32 CGwsFlatFdoReader::GetInt32(FdoInt32 index)
+    return GetInt32((FdoString*)propertyName);
+FdoInt64 CGwsFlatFdoReader::GetInt64(FdoInt32 index)
+    return GetInt64((FdoString*)propertyName);
+float CGwsFlatFdoReader::GetSingle(FdoInt32 index)
+    return GetSingle((FdoString*)propertyName);
+FdoString* CGwsFlatFdoReader::GetString(FdoInt32 index)
+    return GetString((FdoString*)propertyName);
+FdoLOBValue* CGwsFlatFdoReader::GetLOB(FdoInt32 index)
+    return GetLOB((FdoString*)propertyName);
+FdoIStreamReader* CGwsFlatFdoReader::GetLOBStreamReader(FdoInt32 index)
+    return GetLOBStreamReader((FdoString*)propertyName);
+bool CGwsFlatFdoReader::IsNull(FdoInt32 index)
+    return IsNull((FdoString*)propertyName);
+FdoIRaster* CGwsFlatFdoReader::GetRaster(FdoInt32 index)
+    return GetRaster((FdoString*)propertyName);
 bool CGwsFlatFdoReader::ReadNext()
     CHECK_GWS_ITERATOR;
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsMultiSelectIterator.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsMultiSelectIterator.cpp	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsMultiSelectIterator.cpp	2009-09-29 09:14:23 UTC (rev 4271)
@@ -294,13 +294,29 @@
     return m_iter->GetPropertyDescriptor (propname);
+FdoString * CGwsMultiSelectIterator::GetPropertyName(FdoInt32 index)
+	CheckIterator ();
+	return m_iter->GetPropertyName(index);
+FdoInt32 CGwsMultiSelectIterator::GetPropertyIndex(FdoString* propertyName)
+	CheckIterator ();
+	return m_iter->GetPropertyIndex(propertyName);
 FdoString * CGwsMultiSelectIterator::GetString (FdoString * propname)
     CheckIterator ();
     return m_iter->GetString (propname);
+FdoString * CGwsMultiSelectIterator::GetString (FdoInt32 index)
+    CheckIterator ();
+    return m_iter->GetString (index);
 bool CGwsMultiSelectIterator::GetBoolean(FdoString* propname)
@@ -308,6 +324,11 @@
     return m_iter->GetBoolean(propname);
+bool CGwsMultiSelectIterator::GetBoolean(FdoInt32 index)
+    CheckIterator ();
+    return m_iter->GetBoolean(index);
 FdoByte CGwsMultiSelectIterator::GetByte(FdoString* propname)
@@ -315,6 +336,11 @@
     return m_iter->GetByte(propname);
+FdoByte CGwsMultiSelectIterator::GetByte(FdoInt32 index)
+    CheckIterator ();
+    return m_iter->GetByte(index);
 FdoDateTime CGwsMultiSelectIterator::GetDateTime(FdoString* propname)
@@ -322,6 +348,11 @@
     return m_iter->GetDateTime(propname);
+FdoDateTime CGwsMultiSelectIterator::GetDateTime(FdoInt32 index)
+    CheckIterator ();
+    return m_iter->GetDateTime(index);
 double CGwsMultiSelectIterator::GetDouble(FdoString* propname)
@@ -329,6 +360,11 @@
     return m_iter->GetDouble(propname);
+double CGwsMultiSelectIterator::GetDouble(FdoInt32 index)
+    CheckIterator ();
+    return m_iter->GetDouble(index);
 FdoInt16 CGwsMultiSelectIterator::GetInt16(FdoString* propname)
@@ -336,6 +372,11 @@
     return m_iter->GetInt16(propname);
+FdoInt16 CGwsMultiSelectIterator::GetInt16(FdoInt32 index)
+    CheckIterator ();
+    return m_iter->GetInt16(index);
 FdoInt32 CGwsMultiSelectIterator::GetInt32(FdoString* propname)
@@ -343,6 +384,11 @@
     return m_iter->GetInt32(propname);
+FdoInt32 CGwsMultiSelectIterator::GetInt32(FdoInt32 index)
+    CheckIterator ();
+    return m_iter->GetInt32(index);
 FdoInt64 CGwsMultiSelectIterator::GetInt64(FdoString* propname)
@@ -350,6 +396,11 @@
     return m_iter->GetInt64(propname);
+FdoInt64 CGwsMultiSelectIterator::GetInt64(FdoInt32 index)
+    CheckIterator ();
+    return m_iter->GetInt64(index);
 float CGwsMultiSelectIterator::GetSingle(FdoString* propname)
@@ -357,6 +408,11 @@
     return m_iter->GetSingle(propname);
+float CGwsMultiSelectIterator::GetSingle(FdoInt32 index)
+    CheckIterator ();
+    return m_iter->GetSingle(index);
 FdoLOBValue * CGwsMultiSelectIterator::GetLOB(FdoString* propertyName)
@@ -364,6 +420,11 @@
     return m_iter->GetLOB(propertyName);
+FdoLOBValue * CGwsMultiSelectIterator::GetLOB(FdoInt32 index)
+    CheckIterator ();
+    return m_iter->GetLOB(index);
 FdoIStreamReader* CGwsMultiSelectIterator::GetLOBStreamReader(const wchar_t* propertyName )
@@ -371,6 +432,11 @@
     return m_iter->GetLOBStreamReader(propertyName);
+FdoIStreamReader* CGwsMultiSelectIterator::GetLOBStreamReader(FdoInt32 index)
+    CheckIterator ();
+    return m_iter->GetLOBStreamReader(index);
 bool CGwsMultiSelectIterator::IsNull(FdoString* propertyName)
@@ -378,6 +444,11 @@
     return m_iter->IsNull(propertyName);
+bool CGwsMultiSelectIterator::IsNull(FdoInt32 index)
+    CheckIterator ();
+    return m_iter->IsNull(index);
 FdoIRaster*  CGwsMultiSelectIterator::GetRaster(FdoString* propertyName)
@@ -385,6 +456,11 @@
     return m_iter->GetRaster(propertyName);
+FdoIRaster*  CGwsMultiSelectIterator::GetRaster(FdoInt32 index)
+    CheckIterator ();
+    return m_iter->GetRaster(index);
 FdoDataValue * CGwsMultiSelectIterator::GetDataValue (FdoString* propertyName)
@@ -418,6 +494,14 @@
     return m_iter->GetGeometry(propertyName, count);
+const FdoByte * CGwsMultiSelectIterator::GetGeometry(
+    FdoInt32 index,
+    FdoInt32  * count
+    CheckIterator ();
+    return m_iter->GetGeometry(index, count);
 FdoByteArray* CGwsMultiSelectIterator::GetGeometry(FdoString* propertyName)
@@ -425,6 +509,11 @@
     return m_iter->GetGeometry(propertyName);
+FdoByteArray* CGwsMultiSelectIterator::GetGeometry(FdoInt32 index)
+    CheckIterator ();
+    return m_iter->GetGeometry(index);
 FdoByteArray * CGwsMultiSelectIterator::GetOriginalGeometry (FdoString* propertyName)
@@ -446,6 +535,11 @@
     return m_iter->GetFeatureObject(propertyName);
+FdoIFeatureReader* CGwsMultiSelectIterator::GetFeatureObject(FdoInt32 index)
+    CheckIterator ();
+    return m_iter->GetFeatureObject(index);
 FdoGeometryType CGwsMultiSelectIterator::GetGeometryType(FdoByteArray* pArray)
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightBatchSortedBlockJoinQueryResults.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightBatchSortedBlockJoinQueryResults.cpp	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightBatchSortedBlockJoinQueryResults.cpp	2009-09-29 09:14:23 UTC (rev 4271)
@@ -502,6 +502,17 @@
+bool CGwsRightBatchSortedBlockJoinQueryResults::IsNull (FdoInt32 index)
+    if(m_bNullEntry)
+        return true;
+    else
+        return CGwsFeatureIterator::IsNull (index);
 FdoString * CGwsRightBatchSortedBlockJoinQueryResults::GetString (FdoString * propertyName)
@@ -515,6 +526,17 @@
+FdoString * CGwsRightBatchSortedBlockJoinQueryResults::GetString (FdoInt32 index)
+    if(m_bNullEntry)
+        GWS_THROW(eGwsFailed);
+    else
+        return CGwsFeatureIterator::GetString (index);
 bool CGwsRightBatchSortedBlockJoinQueryResults::GetBoolean  (FdoString* propertyName)
@@ -528,6 +550,17 @@
+bool CGwsRightBatchSortedBlockJoinQueryResults::GetBoolean  (FdoInt32 index)
+    if(m_bNullEntry)
+    else
+        return CGwsFeatureIterator::GetBoolean (index);
 FdoByte  CGwsRightBatchSortedBlockJoinQueryResults::GetByte (FdoString* propertyName)
@@ -541,6 +574,17 @@
+FdoByte  CGwsRightBatchSortedBlockJoinQueryResults::GetByte (FdoInt32 index)
+    if(m_bNullEntry)
+    else
+        return CGwsFeatureIterator::GetByte (index);
 FdoDateTime CGwsRightBatchSortedBlockJoinQueryResults::GetDateTime (FdoString* propertyName)
@@ -554,6 +598,17 @@
+FdoDateTime CGwsRightBatchSortedBlockJoinQueryResults::GetDateTime (FdoInt32 index)
+    if(m_bNullEntry)
+    else
+        return CGwsFeatureIterator::GetDateTime (index);
 double CGwsRightBatchSortedBlockJoinQueryResults::GetDouble   (FdoString* propertyName)
@@ -567,6 +622,17 @@
+double CGwsRightBatchSortedBlockJoinQueryResults::GetDouble   (FdoInt32 index)
+    if(m_bNullEntry)
+    else
+        return CGwsFeatureIterator::GetDouble (index);
 FdoInt16 CGwsRightBatchSortedBlockJoinQueryResults::GetInt16 (FdoString* propertyName)
@@ -580,6 +646,17 @@
+FdoInt16 CGwsRightBatchSortedBlockJoinQueryResults::GetInt16 (FdoInt32 index)
+    if(m_bNullEntry)
+    else
+        return CGwsFeatureIterator::GetInt16 (index);
 FdoInt32 CGwsRightBatchSortedBlockJoinQueryResults::GetInt32 (FdoString* propertyName)
@@ -593,6 +670,17 @@
+FdoInt32 CGwsRightBatchSortedBlockJoinQueryResults::GetInt32 (FdoInt32 index)
+    if(m_bNullEntry)
+    else
+        return CGwsFeatureIterator::GetInt32 (index);
 FdoInt64 CGwsRightBatchSortedBlockJoinQueryResults::GetInt64    (FdoString* propertyName)
@@ -606,6 +694,17 @@
+FdoInt64 CGwsRightBatchSortedBlockJoinQueryResults::GetInt64    (FdoInt32 index)
+    if(m_bNullEntry)
+    else
+        return CGwsFeatureIterator::GetInt64 (index);
 float CGwsRightBatchSortedBlockJoinQueryResults::GetSingle   (FdoString* propertyName)
@@ -619,6 +718,17 @@
+float CGwsRightBatchSortedBlockJoinQueryResults::GetSingle   (FdoInt32 index)
+    if(m_bNullEntry)
+    else
+        return CGwsFeatureIterator::GetSingle (index);
 FdoLOBValue* CGwsRightBatchSortedBlockJoinQueryResults::GetLOB (FdoString* propertyName)
@@ -632,6 +742,17 @@
+FdoLOBValue* CGwsRightBatchSortedBlockJoinQueryResults::GetLOB (FdoInt32 index)
+    if(m_bNullEntry)
+    else
+        return CGwsFeatureIterator::GetLOB (index);
 FdoIStreamReader* CGwsRightBatchSortedBlockJoinQueryResults::GetLOBStreamReader(const wchar_t* propertyName )
@@ -645,6 +766,17 @@
+FdoIStreamReader* CGwsRightBatchSortedBlockJoinQueryResults::GetLOBStreamReader(FdoInt32 index)
+    if(m_bNullEntry)
+    else
+        return CGwsFeatureIterator::GetLOBStreamReader (index);
 FdoIRaster* CGwsRightBatchSortedBlockJoinQueryResults::GetRaster (FdoString* propertyName)
@@ -658,6 +790,17 @@
+FdoIRaster* CGwsRightBatchSortedBlockJoinQueryResults::GetRaster (FdoInt32 index)
+    if(m_bNullEntry)
+    else
+        return CGwsFeatureIterator::GetRaster (index);
 const FdoByte * CGwsRightBatchSortedBlockJoinQueryResults::GetGeometry (FdoString* propertyName, FdoInt32 * count)
@@ -671,6 +814,18 @@
+const FdoByte * CGwsRightBatchSortedBlockJoinQueryResults::GetGeometry (FdoInt32 index, FdoInt32 * count)
+    if(m_bNullEntry)
+    else
+        return CGwsFeatureIterator::GetGeometry (index, count);
 FdoByteArray* CGwsRightBatchSortedBlockJoinQueryResults::GetGeometry (FdoString* propertyName)
     if(m_bNullEntry)
@@ -683,6 +838,17 @@
+FdoByteArray* CGwsRightBatchSortedBlockJoinQueryResults::GetGeometry (FdoInt32 index)
+    if(m_bNullEntry)
+    else
+        return CGwsFeatureIterator::GetGeometry (index);
 FdoIFeatureReader* CGwsRightBatchSortedBlockJoinQueryResults::GetFeatureObject(FdoString* propertyName)
@@ -696,6 +862,17 @@
+FdoIFeatureReader* CGwsRightBatchSortedBlockJoinQueryResults::GetFeatureObject(FdoInt32 index)
+    if(m_bNullEntry)
+    else
+        return CGwsFeatureIterator::GetFeatureObject (index);
 FdoDataValue *  CGwsRightBatchSortedBlockJoinQueryResults::GetDataValue (FdoString* propertyName)
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightJoinQueryResults.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightJoinQueryResults.cpp	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightJoinQueryResults.cpp	2009-09-29 09:14:23 UTC (rev 4271)
@@ -30,6 +30,7 @@
 // class CGwsRightJoinQueryResults
+#pragma message("TODO: to rewrite getters by the property index once m_usepool is enabled!")
 CGwsRightJoinQueryResults::CGwsRightJoinQueryResults   ()
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsFlatFdoReader.h
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsFlatFdoReader.h	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsFlatFdoReader.h	2009-09-29 09:14:23 UTC (rev 4271)
@@ -172,6 +172,28 @@
     virtual FdoIStreamReader*   GetLOBStreamReader(const wchar_t* propertyName );
     virtual bool                IsNull(FdoString* propertyName);
     virtual FdoIRaster*         GetRaster(FdoString* propertyName);
+    virtual const FdoByte *     GetGeometry(FdoInt32 index, FdoInt32 * count);
+    virtual FdoByteArray*       GetGeometry(FdoInt32 index);
+    virtual FdoIFeatureReader*  GetFeatureObject(FdoInt32 index);
+    virtual bool                GetBoolean(FdoInt32 index);
+    virtual FdoByte             GetByte(FdoInt32 index);
+    virtual FdoDateTime         GetDateTime(FdoInt32 index);
+    virtual double              GetDouble(FdoInt32 index);
+    virtual FdoInt16            GetInt16(FdoInt32 index);
+    virtual FdoInt32            GetInt32(FdoInt32 index);
+    virtual FdoInt64            GetInt64(FdoInt32 index);
+    virtual float               GetSingle(FdoInt32 index);
+    virtual FdoString*          GetString(FdoInt32 index);
+    virtual FdoLOBValue*        GetLOB(FdoInt32 index);
+    virtual FdoIStreamReader*   GetLOBStreamReader(FdoInt32 index);
+    virtual bool                IsNull(FdoInt32 index);
+    virtual FdoIRaster*         GetRaster(FdoInt32 index);
+    virtual FdoString*          GetPropertyName(FdoInt32 index);
+    virtual FdoInt32            GetPropertyIndex(FdoString* propertyName);
     virtual bool                ReadNext();
     virtual void                Close();
     virtual FdoInt32            GetCacheId();
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsQuery.h
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsQuery.h	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsQuery.h	2009-09-29 09:14:23 UTC (rev 4271)
@@ -738,7 +738,7 @@
     GWS_QUERYENGINE_API
     virtual bool            IsNull      (FdoString* propertyName);
     GWS_QUERYENGINE_API
-    virtual FdoString   *   GetString   (FdoString * propname);
+    virtual FdoString   *   GetString   (FdoString* propertyName);
     GWS_QUERYENGINE_API
     virtual bool            GetBoolean  (FdoString* propertyName);
     GWS_QUERYENGINE_API
@@ -761,6 +761,7 @@
     GWS_QUERYENGINE_API
     virtual FdoIRaster*     GetRaster   (FdoString* propertyName);
     GWS_QUERYENGINE_API
     virtual FdoInt32        GetDepth    ();
     GWS_QUERYENGINE_API
@@ -775,6 +776,44 @@
     virtual FdoDataValueCollection *
         GetDataValues (FdoStringCollection* propertyNames);
+    // getters by the property index
+    GWS_QUERYENGINE_API
+    virtual bool            IsNull      (FdoInt32 index);
+    virtual FdoString   *   GetString   (FdoInt32 index);
+    virtual bool            GetBoolean  (FdoInt32 index);
+    virtual FdoByte         GetByte     (FdoInt32 index);
+    virtual FdoDateTime     GetDateTime (FdoInt32 index);
+    virtual double          GetDouble   (FdoInt32 index);
+    virtual FdoInt16        GetInt16    (FdoInt32 index);
+    virtual FdoInt32        GetInt32    (FdoInt32 index);
+    virtual FdoInt64        GetInt64    (FdoInt32 index);
+    virtual float           GetSingle   (FdoInt32 index);
+    virtual FdoLOBValue*    GetLOB      (FdoInt32 index);
+    virtual FdoIRaster*     GetRaster   (FdoInt32 index);
+    virtual const FdoByte * GetGeometry (FdoInt32 index, FdoInt32 * count) ;
+    virtual FdoByteArray*   GetGeometry (FdoInt32 index);
+    // newly added methods to FdoIFeatureReader
     // returns unconverted geometry. Coordinate system transaformations are not applied
     GWS_QUERYENGINE_API
     virtual FdoByteArray*   GetOriginalGeometry (FdoString* propertyName);
@@ -1456,7 +1495,41 @@
     virtual FdoByteArray*   GetGeometry (FdoString* propertyName);
     GWS_QUERYENGINE_API
     virtual FdoIFeatureReader* GetFeatureObject(FdoString* propertyName);
     GWS_QUERYENGINE_API
     virtual FdoDataValue *  GetDataValue (FdoString* propertyName);
     GWS_QUERYENGINE_API
@@ -1555,10 +1628,16 @@
     virtual EGwsLockType    GetCacheLockType ();
     GWS_QUERYENGINE_API
     virtual IGWSFeatureIterator* GetJoinedFeatures (int i);
     GWS_QUERYENGINE_API
     GWS_QUERYENGINE_API
     GWS_QUERYENGINE_API
     GWS_QUERYENGINE_API
@@ -1589,7 +1668,41 @@
     GWS_QUERYENGINE_API
     GWS_QUERYENGINE_API
     GWS_QUERYENGINE_API
     virtual FdoDataValueCollection * GetDataValues (FdoStringCollection* propertyNames);
Modified: trunk/MgDev/Server/src/Gws/Include/GwsQueryEngine.h
--- trunk/MgDev/Server/src/Gws/Include/GwsQueryEngine.h	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Gws/Include/GwsQueryEngine.h	2009-09-29 09:14:23 UTC (rev 4271)
@@ -721,6 +721,27 @@
     virtual FdoByteArray*       GetGeometry (FdoString * propertyName) = 0;
     virtual FdoIFeatureReader*  GetFeatureObject (FdoString * propertyName) = 0;
+    virtual bool                IsNull (FdoInt32 index) = 0;
+    virtual FdoString   *       GetString   (FdoInt32 index) = 0;
+    virtual bool                GetBoolean  (FdoInt32 index) = 0;
+    virtual FdoByte             GetByte     (FdoInt32 index) = 0;
+    virtual FdoDateTime         GetDateTime (FdoInt32 index) = 0;
+    virtual double              GetDouble   (FdoInt32 index) = 0;
+    virtual FdoInt16            GetInt16    (FdoInt32 index) = 0;
+    virtual FdoInt32            GetInt32    (FdoInt32 index) = 0;
+    virtual FdoInt64            GetInt64    (FdoInt32 index) = 0;
+    virtual float               GetSingle   (FdoInt32 index) = 0;
+    virtual FdoLOBValue*        GetLOB      (FdoInt32 index) = 0;
+    virtual FdoIStreamReader*   GetLOBStreamReader (FdoInt32 index) = 0;
+    virtual FdoIRaster*         GetRaster   (FdoInt32 index) = 0;
+    virtual const FdoByte *     GetGeometry (FdoInt32 index, FdoInt32 * count) = 0;
+    virtual FdoByteArray*       GetGeometry (FdoInt32 index) = 0;
+    virtual FdoIFeatureReader*  GetFeatureObject (FdoInt32 index) = 0;
+    // FdoIFeatureReader
+    virtual FdoString*          GetPropertyName(FdoInt32 index) = 0;
+    virtual FdoInt32            GetPropertyIndex(FdoString* propertyName) = 0;
     /// <summary>
     /// moves the current position on the next feture and returns it
     /// </summary>
Modified: trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.cpp
--- trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.cpp	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.cpp	2009-09-29 09:14:23 UTC (rev 4271)
@@ -72,8 +72,26 @@
     return m_currentReader->GetDepth();
+FdoString* MgFdoFeatureReader::GetPropertyName(FdoInt32 index)
+    if (m_currentReader == NULL)
+        Initialize();
+    return m_currentReader->GetPropertyName(index);
+FdoInt32 MgFdoFeatureReader::GetPropertyIndex(FdoString* propertyName)
+        Initialize();
+    return m_currentReader->GetPropertyIndex(propertyName);
 FdoIFeatureReader* MgFdoFeatureReader::GetFeatureObject( const wchar_t* propertyName )
@@ -84,6 +102,16 @@
     return m_currentReader->GetFeatureObject(propertyName);
+FdoIFeatureReader* MgFdoFeatureReader::GetFeatureObject( FdoInt32 index )
+        Initialize();
+    return m_currentReader->GetFeatureObject(index);
 bool MgFdoFeatureReader::GetBoolean( const wchar_t *propertyName )
@@ -94,6 +122,16 @@
     return m_currentReader->GetBoolean(propertyName);
+bool MgFdoFeatureReader::GetBoolean( FdoInt32 index )
+        Initialize();
+    return m_currentReader->GetBoolean(index);
 FdoByte MgFdoFeatureReader::GetByte( const wchar_t *propertyName )
@@ -104,7 +142,16 @@
     return m_currentReader->GetByte(propertyName);
+FdoByte MgFdoFeatureReader::GetByte( FdoInt32 index )
+        Initialize();
+    return m_currentReader->GetByte(index);
 FdoDateTime MgFdoFeatureReader::GetDateTime( const wchar_t *propertyName )
@@ -115,7 +162,16 @@
     return m_currentReader->GetDateTime(propertyName);
+FdoDateTime MgFdoFeatureReader::GetDateTime( FdoInt32 index )
+        Initialize();
+    return m_currentReader->GetDateTime(index);
 double MgFdoFeatureReader::GetDouble( const wchar_t *propertyName )
@@ -126,6 +182,16 @@
     return m_currentReader->GetDouble(propertyName);
+double MgFdoFeatureReader::GetDouble( FdoInt32 index )
+        Initialize();
+    return m_currentReader->GetDouble(index);
 const wchar_t* MgFdoFeatureReader::GetString( const wchar_t *propertyName )
@@ -137,6 +203,17 @@
+const wchar_t* MgFdoFeatureReader::GetString( FdoInt32 index )
+        Initialize();
+    return m_currentReader->GetString(index);
 short MgFdoFeatureReader::GetInt16( const wchar_t *propertyName )
@@ -147,6 +224,16 @@
     return m_currentReader->GetInt16(propertyName);
+short MgFdoFeatureReader::GetInt16( FdoInt32 index )
+        Initialize();
+    return m_currentReader->GetInt16(index);
 int MgFdoFeatureReader::GetInt32( const wchar_t *propertyName )
@@ -157,6 +244,16 @@
     return m_currentReader->GetInt32(propertyName);
+int MgFdoFeatureReader::GetInt32( FdoInt32 index )
+        Initialize();
+    return m_currentReader->GetInt32(index);
 FdoInt64 MgFdoFeatureReader::GetInt64( const wchar_t *propertyName )
@@ -167,6 +264,16 @@
     return m_currentReader->GetInt64(propertyName);
+FdoInt64 MgFdoFeatureReader::GetInt64( FdoInt32 index )
+        Initialize();
+    return m_currentReader->GetInt64(index);
 float MgFdoFeatureReader::GetSingle( const wchar_t *propertyName )
@@ -177,6 +284,16 @@
     return m_currentReader->GetSingle(propertyName);
+float MgFdoFeatureReader::GetSingle( FdoInt32 index )
+        Initialize();
+    return m_currentReader->GetSingle(index);
 FdoIStreamReader* MgFdoFeatureReader::GetLOBStreamReader(const wchar_t* propertyName)
@@ -188,6 +305,15 @@
     return m_currentReader->GetLOBStreamReader(propertyName);
+FdoIStreamReader* MgFdoFeatureReader::GetLOBStreamReader(FdoInt32 index)
+        Initialize();
+    return m_currentReader->GetLOBStreamReader(index);
 FdoLOBValue* MgFdoFeatureReader::GetLOB(const wchar_t* propertyName)
@@ -199,6 +325,16 @@
     return m_currentReader->GetLOB(propertyName);
+FdoLOBValue* MgFdoFeatureReader::GetLOB(FdoInt32 index)
+        Initialize();
+    return m_currentReader->GetLOB(index);
 bool MgFdoFeatureReader::IsNull( const wchar_t *propertyName )
@@ -209,6 +345,16 @@
     return m_currentReader->IsNull(propertyName);
+bool MgFdoFeatureReader::IsNull( FdoInt32 index )
+        Initialize();
+    return m_currentReader->IsNull(index);
 FdoByteArray* MgFdoFeatureReader::GetGeometry(const wchar_t* propertyName)
@@ -219,7 +365,16 @@
     return m_currentReader->GetGeometry(propertyName);
+FdoByteArray* MgFdoFeatureReader::GetGeometry(FdoInt32 index)
+        Initialize();
+    return m_currentReader->GetGeometry(index);
 const FdoByte * MgFdoFeatureReader::GetGeometry(const wchar_t* propertyName, FdoInt32 * count)
@@ -230,6 +385,16 @@
     return m_currentReader->GetGeometry(propertyName, count);
+const FdoByte * MgFdoFeatureReader::GetGeometry(FdoInt32 index, FdoInt32 * count)
+        Initialize();
+    return m_currentReader->GetGeometry(index, count);
 /// <summary>Gets the raster object of the specified property.
 /// of Raster type; otherwise, an exception is thrown.</summary>
@@ -245,7 +410,16 @@
     return m_currentReader->GetRaster(propertyName);
+FdoIRaster* MgFdoFeatureReader::GetRaster(FdoInt32 index)
+        Initialize();
+    return m_currentReader->GetRaster(index);
 bool MgFdoFeatureReader::ReadNext( )
    bool retVal = false;
Modified: trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.h
--- trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.h	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.h	2009-09-29 09:14:23 UTC (rev 4271)
@@ -55,6 +55,27 @@
         virtual FdoByteArray* GetGeometry(const wchar_t* propertyName);
         virtual const FdoByte * GetGeometry(const wchar_t* propertyName, FdoInt32 * count);
         virtual FdoIRaster* GetRaster(const wchar_t* propertyName);
+        virtual const wchar_t*      GetString   (FdoInt32 index);
+        virtual short               GetInt16    (FdoInt32 index);
+        virtual int                 GetInt32    (FdoInt32 index);
+        virtual FdoIStreamReader*   GetLOBStreamReader (FdoInt32 index);
+        virtual const FdoByte *     GetGeometry (FdoInt32 index, FdoInt32 * count);
+        virtual FdoIFeatureReader*  GetFeatureObject (FdoInt32 index);
         virtual bool     ReadNext( );
Modified: trunk/MgDev/Server/src/Services/Feature/FdoReaderCollection.h
--- trunk/MgDev/Server/src/Services/Feature/FdoReaderCollection.h	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Services/Feature/FdoReaderCollection.h	2009-09-29 09:14:23 UTC (rev 4271)
@@ -25,15 +25,15 @@
 #include <FdoStd.h>
-class FdoIReader;
+class FdoIFeatureReader;
 /// \brief
-/// The MgFdoReaderCollection class represents a collection of FdoIReader objects.
-class MgFdoReaderCollection : public FdoCollection<FdoIReader, FdoException>
+/// The MgFdoReaderCollection class represents a collection of FdoIFeatureReader objects.
+class MgFdoReaderCollection : public FdoCollection<FdoIFeatureReader, FdoException>
 protected:
 /// \cond DOXYGEN-IGNORE
-    MgFdoReaderCollection() : FdoCollection<FdoIReader, FdoException>()
+    MgFdoReaderCollection() : FdoCollection<FdoIFeatureReader, FdoException>()
Modified: trunk/MgDev/Server/src/Services/Feature/JoinFeatureReader.cpp
--- trunk/MgDev/Server/src/Services/Feature/JoinFeatureReader.cpp	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Services/Feature/JoinFeatureReader.cpp	2009-09-29 09:14:23 UTC (rev 4271)
@@ -20,6 +20,8 @@
 MgJoinFeatureReader::MgJoinFeatureReader(MgServerGwsFeatureReader* reader)
     m_reader = SAFE_ADDREF(reader);
+    m_propertyNamesInitialized = false;
 MgJoinFeatureReader::~MgJoinFeatureReader()
@@ -31,6 +33,27 @@
     delete this;
+FdoString* MgJoinFeatureReader::GetPropertyName(FdoInt32 index)
+    InitializePropertyNames();
+    assert(index < m_propertyNames->GetCount());
+    if (index < m_propertyNames->GetCount())
+        return m_propertyNames->GetString(index);
+    else
+        assert(false);
+        return L"";
+FdoInt32 MgJoinFeatureReader::GetPropertyIndex(FdoString* propertyName)
+    return m_propertyNames->IndexOf(propertyName, false);
 bool MgJoinFeatureReader::GetBoolean(FdoString* propertyName)
@@ -602,6 +625,104 @@
     return fdoClassDef.Detach();
+const FdoByte * MgJoinFeatureReader::GetGeometry(FdoInt32 index, FdoInt32 * count)
+FdoByteArray* MgJoinFeatureReader::GetGeometry(FdoInt32 index)
+FdoIFeatureReader*  MgJoinFeatureReader::GetFeatureObject(FdoInt32 index)
+bool MgJoinFeatureReader::GetBoolean(FdoInt32 index)
+FdoByte MgJoinFeatureReader::GetByte(FdoInt32 index)
+FdoDateTime MgJoinFeatureReader::GetDateTime(FdoInt32 index)
+double MgJoinFeatureReader::GetDouble(FdoInt32 index)
+FdoInt16 MgJoinFeatureReader::GetInt16(FdoInt32 index)
+FdoInt32 MgJoinFeatureReader::GetInt32(FdoInt32 index)
+FdoInt64 MgJoinFeatureReader::GetInt64(FdoInt32 index)
+float MgJoinFeatureReader::GetSingle(FdoInt32 index)
+FdoString* MgJoinFeatureReader::GetString(FdoInt32 index)
+FdoLOBValue* MgJoinFeatureReader::GetLOB(FdoInt32 index)
+FdoIStreamReader* MgJoinFeatureReader::GetLOBStreamReader(FdoInt32 index)
+bool MgJoinFeatureReader::IsNull(FdoInt32 index)
+FdoIRaster* MgJoinFeatureReader::GetRaster(FdoInt32 index)
 void MgJoinFeatureReader::GetClassProperties(FdoPropertyDefinitionCollection* fdoPropDefCol,
                                                 MgPropertyDefinitionCollection* propDefCol)
@@ -1038,3 +1159,35 @@
     return orderType;
+void MgJoinFeatureReader::InitializePropertyNames()
+    if (m_propertyNamesInitialized)
+        return;
+    FdoPtr<FdoClassDefinition> classDef = this->GetClassDefinition();
+    CHECKNULL(classDef, L"MgJoinFeatureReader.InitializePropertyNames")
+    m_propertyNames = FdoStringCollection::Create();
+    FillProperties(classDef);
+    m_propertyNamesInitialized = true;
+void MgJoinFeatureReader::FillProperties(FdoClassDefinition* classDef)
+    if (classDef == NULL)
+        return;
+    FdoPtr<FdoClassDefinition> baseClassDef = classDef->GetBaseClass();
+    FillProperties(baseClassDef);
+    FdoPropertiesP props = classDef->GetProperties();
+    CHECKNULL(props, L"MgJoinFeatureReader.FillProperties")
+    for (int i = 0; i < props->GetCount(); i++)
+        FdoPtr<FdoPropertyDefinition> prop = props->GetItem(i);
+        m_propertyNames->Add(prop->GetName());
Modified: trunk/MgDev/Server/src/Services/Feature/JoinFeatureReader.h
--- trunk/MgDev/Server/src/Services/Feature/JoinFeatureReader.h	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Services/Feature/JoinFeatureReader.h	2009-09-29 09:14:23 UTC (rev 4271)
@@ -63,6 +63,28 @@
     virtual FdoInt32 GetDepth();
     /// \brief
+    /// Gets the name of the property at the given ordinal position.
+    /// \param index
+    /// Input the position of the property.
+    /// \return
+    /// Returns the property name
+    /// \brief
+    /// Gets the index of the property with the specified name.
+    /// Input the property name.
+    /// \return
+    /// \brief
     /// Gets the geometry value of the specified property as a byte array in
     /// FGF format. Because no conversion is performed, the property must be
     /// of Geometric type; otherwise, an exception is thrown.
@@ -277,7 +299,225 @@
+	/// \brief
+    /// Gets the geometry value of the property, at the specified index,
+    /// as a byte array in FGF format. Because no conversion is performed,
+    /// the property must be of Geometric type; otherwise, an exception is thrown.
+    /// This method is a language-specific performance optimization that returns a
+    /// pointer to the array data, rather than to an object that encapsulates
+    /// the array.  The array's memory area is only guaranteed to be valid
+    /// until a call to ReadNext() or Close(), or the disposal of this reader
+    /// object.
+    /// \param index
+    /// Input the index of the property.
+    /// \param count
+    /// Output the number of bytes in the array.
+    /// \return
+    /// Returns a pointer to the byte array in FGF format.
+    virtual const FdoByte * GetGeometry(FdoInt32 index, FdoInt32* count);
     /// \brief
+    /// Gets the geometry value of the specified property, at the specified index,
+    /// as a byte array in FGF format. Because no conversion is performed, the property
+    /// must be of Geometric type; otherwise, an exception is thrown.
+    /// \param index
+    /// \return
+    /// Returns the byte array in FGF format.
+    /// \brief
+    /// Gets a reference to an FdoIFeatureReader to read the data contained in
+    /// the object or object collection property defined at the specified index
+    /// position. If the property is not an object property, an exception is thrown.
+    /// \param index
+    /// \return
+    /// Returns the nested feature reader
+    /// \brief
+    /// Gets the Boolean value of the property specified at the index position.
+    /// No conversion is performed, thus the property must be FdoDataType_Boolean
+    /// or an exception is thrown.
+    /// \param index
+    /// \return
+    /// Returns the Boolean value.
+    virtual FdoBoolean GetBoolean(FdoInt32 index);
+    /// \brief
+    /// Gets the Byte value of the property specified at the index position.
+    /// No conversion is performed, thus the property must be FdoDataType_Byte
+    /// \param index
+    /// \return
+    /// Returns the byte value.
+    /// \brief
+    /// Gets the date and time value of the of the property specified at
+    /// the index position. No conversion is performed, thus the property
+    /// must be FdoDataType_DateTime or an exception is thrown.
+    /// \param index
+    /// \return
+    /// Returns the date and time value.
+    /// \brief
+    /// Gets the double-precision floating point value of the property specified at
+    /// the index position. No conversion is performed, thus the property must be
+    /// FdoDataType_Double or an exception is thrown.
+    /// \param index
+    /// \return
+    /// Returns the double floating point value
+    virtual FdoDouble GetDouble(FdoInt32 index);
+    /// \brief
+    /// Gets the 16-bit integer value of the property specified at
+    /// property must be FdoDataType_Int16 or an exception is thrown.
+    /// \param index
+    /// \return
+    /// Returns the FdoInt16 value.
+    /// \brief
+    /// Gets the 32-bit integer value of the property specified at
+    /// property must be FdoDataType_Int32 or an exception is thrown.
+    /// \param index
+    /// \return
+    /// Returns the FdoInt32 value
+    /// \brief
+    /// Gets the 64-bit integer value of the property specified at
+    /// property must be FdoDataType_Int64 or an exception is thrown.
+    /// \param index
+    /// \return
+    /// Returns the FdoInt64 value.
+    /// \brief
+    /// Gets the Single floating point value of the property specified at
+    /// must be FdoDataType_Single or an exception is thrown.
+    /// \param index
+    /// \return
+    /// Returns the single value
+    virtual FdoFloat GetSingle(FdoInt32 index);
+    /// \brief
+    /// Gets the string value of the property specified at the index
+    /// position. No conversion is performed, thus the property must
+    /// be FdoDataType_String or an exception is thrown.
+    /// \param index
+    /// \return
+    /// Returns the string value
+    /// \brief
+    /// Gets a LOBValue pointer to the property specified at the index
+    /// position. The LOB is fully read in and data available.
+    /// FdoDataType_BLOB or FdoDataType_CLOB etc. (a LOB type)
+    /// \param index
+    /// \return
+    /// Returns the pointer to LOBValue
+    /// \brief
+    /// Gets a pointer to the specified LOB property, specified at the index
+    /// position. The reference is returned as an FdoBLOBStreamReader or an
+    /// FdoCLOBStreamReader, to allow reading in blocks of data. Because
+    /// no conversion is performed, the property must be FdoDataType_BLOB
+    /// or FdoDataType_CLOB etc. (a LOB type) Cast the FdoIStreamReader
+    /// to the appropriate LOB Stream Reader.
+    /// \param index
+    /// \return
+    /// Returns a pointer to a LOB stream reader
+    /// \brief
+    /// Returns true if the value of the property at the specified
+    /// index is null.
+    /// \param index
+    /// \return
+    /// Returns true if the value is null.
+    virtual FdoBoolean IsNull(FdoInt32 index);
+    /// \brief
+    /// Gets the raster object of the property at the specified index.
+    /// of Raster type; otherwise, an exception is thrown.
+    /// \param index
+    /// \return
+    /// Returns the raster object.
+    /// \brief
     /// Advances the reader to the next item and returns true if there is
     /// another object to read or false if reading is complete. The default
     /// position of the reader is prior to the first item. Thus you must
@@ -305,6 +545,10 @@
     virtual void Dispose();
 private:
+    void InitializePropertyNames();
+    void FillProperties(FdoClassDefinition* classDef);
+private:
     FdoClassDefinition* GetFdoClassDefinition(MgClassDefinition* mgClassDef);
     void GetClassProperties(FdoPropertyDefinitionCollection* fdoPropDefCol, MgPropertyDefinitionCollection* propDefCol);
     void GetClassProperties(FdoDataPropertyDefinitionCollection* fdoPropDefCol, MgPropertyDefinitionCollection* mgPropDefCol);
@@ -319,5 +563,9 @@
     FdoOrderType MgOrderingOptionToFdoOrderType(INT32 type);
     Ptr<MgServerGwsFeatureReader> m_reader;
+    // Used for access by index readers
+    FdoStringsP m_propertyNames;
+    bool m_propertyNamesInitialized;
 #endif
Modified: trunk/MgDev/Server/src/Services/Feature/ServerDataReader.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerDataReader.cpp	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Services/Feature/ServerDataReader.cpp	2009-09-29 09:14:23 UTC (rev 4271)
@@ -130,6 +130,27 @@
 /// <summary>
+/// Gets the index of the Property with the specified name.
+/// </summary>
+/// <param name="index">Input the name of the Property.</param>
+/// <returns>Returns the Property index</returns>
+INT32 MgServerDataReader::GetPropertyIndex(CREFSTRING propertyName)
+    CHECKNULL(m_dataReader, L"MgServerDataReader.GetPropertyIndex");
+    FdoInt32 index;
+    MG_FEATURE_SERVICE_TRY()
+    index = m_dataReader->GetPropertyIndex(propertyName.c_str());
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerDataReader.GetPropertyIndex")
+    return (INT32)index;
+/// <summary>
 /// Gets the data type of the Property with the specified name.
 /// </summary>
 /// <param name="propertyName">Input the Property name.</param>
@@ -204,6 +225,27 @@
 /// <summary>
+///  Returns true if the value of the specified property is null.
+/// </summary>
+/// <param name="index">Property index.</param>
+/// <returns>Returns true if the value is null.</returns>
+bool MgServerDataReader::IsNull(INT32 index)
+    CHECKNULL(m_dataReader, L"MgServerDataReader.IsNull");
+    bool retVal = false;
+    retVal = m_dataReader->IsNull(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerDataReader.IsNull");
+    return retVal;
+/// <summary>
 /// Gets the Boolean value of the specified property. No conversion is
 /// performed, thus the property must be a of boolean type the result
 /// is undertermined</summary>
@@ -237,6 +279,42 @@
 /// <summary>
+/// Gets the Boolean value of the specified property. No conversion is
+/// performed, thus the property must be a of boolean type the result
+/// is undertermined</summary>
+/// <returns>Returns the Boolean value.</returns>
+bool MgServerDataReader::GetBoolean(INT32 index)
+    CHECKNULL(m_dataReader, L"MgServerDataReader.GetBoolean");
+    if(m_dataReader->IsNull(index))
+        STRING buffer;
+        MgUtil::Int32ToString(index, buffer);
+        MgStringCollection arguments;
+        arguments.Add(buffer);
+        throw new MgNullPropertyValueException(L"MgServerDataReader.GetBoolean",
+            __LINE__, __WFILE__, &arguments, L"", NULL);
+    else
+        retVal = m_dataReader->GetBoolean(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerDataReader.GetBoolean");
+    return retVal;
+/// <summary>
 /// Gets the Byte value of the specified property. No conversion is
 /// performed, thus the property must be a of byte type or the result
@@ -270,6 +348,43 @@
 /// <summary>
+/// Gets the Byte value of the specified property. No conversion is
+/// performed, thus the property must be a of byte type or the result
+/// <returns>Returns the Byte value.</returns>
+BYTE MgServerDataReader::GetByte(INT32 index)
+    CHECKNULL(m_dataReader, L"MgServerDataReader.GetByte");
+    BYTE retVal = 0;
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerDataReader.GetByte",
+    else
+        retVal = (BYTE)m_dataReader->GetByte(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerDataReader.GetByte");
+    return retVal;
+/// <summary>
 /// Gets the DTime value of the specified property. No conversion is
 /// performed, thus the property must be a of date type or the result
 /// is NULL</summary>
@@ -305,6 +420,44 @@
 /// <summary>
+/// Gets the DTime value of the specified property. No conversion is
+/// performed, thus the property must be a of date type or the result
+/// is NULL</summary>
+/// <returns>Returns the DTime value.</returns>
+MgDateTime* MgServerDataReader::GetDateTime(INT32 index)
+    Ptr<MgDateTime> retVal;
+    CHECKNULL(m_dataReader, L"MgServerDataReader.GetDateTime");
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerDataReader.GetDateTime",
+    else
+        FdoDateTime val = m_dataReader->GetDateTime(index);
+        retVal = new MgDateTime((INT16)val.year, (INT8)val.month, (INT8)val.day,
+                            (INT8)val.hour, (INT8)val.minute, val.seconds);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerDataReader.GetDateTime");
+    return retVal.Detach();
+/// <summary>
 /// Gets the Single value of the specified property. No conversion is
 /// performed, thus the property must be a of type single or the result
 /// is undetermined</summary>
@@ -338,6 +491,42 @@
 /// <summary>
+/// Gets the Single value of the specified property. No conversion is
+/// performed, thus the property must be a of type single or the result
+/// is undetermined</summary>
+/// <returns>Returns the single value.</returns>
+float MgServerDataReader::GetSingle(INT32 index)
+    CHECKNULL(m_dataReader, L"MgServerDataReader.GetSingle");
+    float retVal = 0.0f;
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerDataReader.GetSingle",
+    else
+        retVal = m_dataReader->GetSingle(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerDataReader.GetSingle");
+    return retVal;
+/// <summary>
 /// Gets the Double value of the specified property. No conversion is
 /// performed, thus the property must be a of type double or the result
@@ -371,6 +560,42 @@
 /// <summary>
+/// Gets the Double value of the specified property. No conversion is
+/// performed, thus the property must be a of type double or the result
+/// <returns>Returns the double value.</returns>
+double MgServerDataReader::GetDouble(INT32 index)
+    CHECKNULL(m_dataReader, L"MgServerDataReader.GetDouble");
+    double retVal = 0.0;
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerDataReader.GetDouble",
+    else
+        retVal = m_dataReader->GetDouble(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerDataReader.GetDouble");
+    return retVal;
+/// <summary>
 /// Gets the integer 16 bits value of the specified property. No conversion is
 /// performed, thus the property must be a of type integer 16 bits or the result
@@ -404,6 +629,42 @@
 /// <summary>
+/// Gets the integer 16 bits value of the specified property. No conversion is
+/// performed, thus the property must be a of type integer 16 bits or the result
+/// <returns>Returns the integer 16 bits value.</returns>
+INT16 MgServerDataReader::GetInt16(INT32 index)
+    CHECKNULL(m_dataReader, L"MgServerDataReader.GetInt16");
+    INT16 retVal = 0;
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerDataReader.GetInt16",
+    else
+        retVal = (INT16)m_dataReader->GetInt16(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerDataReader.GetInt16");
+    return retVal;
+/// <summary>
 /// Gets the integer 32 bits value of the specified property. No conversion is
 /// performed, thus the property must be a of type integer 32 bits or the result
@@ -437,6 +698,42 @@
 /// <summary>
+/// Gets the integer 32 bits value of the specified property. No conversion is
+/// performed, thus the property must be a of type integer 32 bits or the result
+/// <returns>Returns the integer 32 bits value.</returns>
+INT32 MgServerDataReader::GetInt32(INT32 index)
+    CHECKNULL(m_dataReader, L"MgServerDataReader.GetInt32");
+    INT32 retVal = 0;
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerDataReader.GetInt32",
+    else
+        retVal = (INT32)m_dataReader->GetInt32(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerDataReader.GetInt32");
+    return retVal;
+/// <summary>
 /// Gets the integer 64 bits value of the specified property. No conversion is
 /// performed, thus the property must be a of type integer 64 bits or the result
@@ -472,6 +769,44 @@
 /// <summary>
+/// Gets the integer 64 bits value of the specified property. No conversion is
+/// performed, thus the property must be a of type integer 64 bits or the result
+/// <returns>Returns the integer 64 bits value.
+/// Note: INT64 is actually a pointer to an Integer64 object
+///</returns>
+INT64 MgServerDataReader::GetInt64(INT32 index)
+    CHECKNULL(m_dataReader, L"MgServerDataReader.GetInt64");
+    INT64 retVal = 0;
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerDataReader.GetInt64",
+    else
+        retVal = (INT64)m_dataReader->GetInt64(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerDataReader.GetInt64");
+    return retVal;
+/// <summary>
 /// Gets the string value of the specified property. No conversion is
 /// performed, thus the property must be a of type string or the result
@@ -510,6 +845,47 @@
 /// <summary>
+/// Gets the string value of the specified property. No conversion is
+/// performed, thus the property must be a of type string or the result
+/// <returns>Returns the string value.</returns>
+STRING MgServerDataReader::GetString(INT32 index)
+    CHECKNULL(m_dataReader, L"MgServerDataReader.GetString");
+    STRING retVal = L"";
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerDataReader.GetString",
+    else
+        INT32 length = 0;
+        const wchar_t* str = this->GetString(index, length);
+        if (str != NULL)
+            retVal = str;
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerDataReader.GetString");
+    return retVal;
+/// <summary>
 /// Gets the BLOB value of the specified property. No conversion is
 /// performed, thus the property must be a of type BLOBs or the result
@@ -543,6 +919,42 @@
 /// <summary>
+/// Gets the BLOB value of the specified property. No conversion is
+/// performed, thus the property must be a of type BLOBs or the result
+/// <returns>Returns the BLOB value.</returns>
+MgByteReader* MgServerDataReader::GetBLOB(INT32 index)
+    CHECKNULL(m_dataReader, L"MgServerDataReader.GetBLOB");
+    Ptr<MgByteReader> byteReader;
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerDataReader.GetBLOB",
+    else
+        byteReader = this->GetLOB(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerDataReader.GetBLOB");
+    return byteReader.Detach();
+/// <summary>
 /// Gets the CLOB value of the specified property. No conversion is
 /// performed, thus the property must be a of type CLOB or the result
@@ -576,6 +988,42 @@
 /// <summary>
+/// Gets the CLOB value of the specified property. No conversion is
+/// performed, thus the property must be a of type CLOB or the result
+/// <returns>Returns the CLOB value.</returns>
+MgByteReader* MgServerDataReader::GetCLOB(INT32 index)
+    CHECKNULL(m_dataReader, L"MgServerDataReader.GetCLOB");
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerDataReader.GetCLOB",
+    else
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerDataReader.GetCLOB");
+/// <summary>
 /// Gets the Geometry for the specified property. No conversion is
 /// performed, thus the property must be a of type Geometry or the result
@@ -617,6 +1065,52 @@
+/// <summary>
+/// Gets the Geometry for the specified property. No conversion is
+/// performed, thus the property must be a of type Geometry or the result
+/// <returns>Returns a ByteReader object</returns>
+MgByteReader* MgServerDataReader::GetGeometry(INT32 index)
+    CHECKNULL(m_dataReader, L"MgServerDataReader.GetGeometry");
+    Ptr<MgByteReader> retVal;
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerDataReader.GetGeometry",
+    else
+        FdoPtr<FdoByteArray> byteArray = m_dataReader->GetGeometry(index);
+        INT32 len = (INT32)byteArray->GetCount();
+        const FdoByte* data = byteArray->GetData();
+        if (data != NULL)
+            Ptr<MgByte> mgBytes = new MgByte((BYTE_ARRAY_IN)data, len);
+            Ptr<MgByteSource> bSource = new MgByteSource(mgBytes);
+            bSource->SetMimeType(MgMimeType::Agf);
+            retVal = bSource->GetReader();
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerDataReader.GetGeometry");
 // Get the Raster data
 MgRaster* MgServerDataReader::GetRaster(CREFSTRING propertyName)
@@ -676,6 +1170,69 @@
+// Get the Raster data
+MgRaster* MgServerDataReader::GetRaster(INT32 index)
+    CHECKNULL(m_dataReader, L"MgServerDataReader.GetRaster");
+    Ptr<MgRaster> retVal;
+    STRING dataReader = L"";
+    // TODO: The IsNull() check is returning true for WFS/WMS FDO providers when there is valid data.
+    //       In this case it should really be returning false so that the data can be retrieved.
+    //       For now the check will be commented out until this can be resolved in FDO.
+    if(false) // TODO: Force the exception throwing code to be skipped until issue is resolved.
+//    if(m_dataReader->IsNull(propertyName.c_str()))
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerDataReader.GetRaster",
+    else
+        FdoPtr<FdoIRaster> raster = m_dataReader->GetRaster(index);
+        CHECKNULL((FdoIRaster*)raster, L"MgServerDataReader.GetRaster");
+        STRING propertyName = GetPropertyName(index);
+        retVal = MgServerFeatureUtil::GetMgRaster(raster, propertyName);
+        CHECKNULL((MgRaster*)retVal, L"MgServerDataReader.GetRaster");
+        // Set the service to MgRaster for GetRaster operation called in GetStream method
+        MgServiceManager* serviceMan = MgServiceManager::GetInstance();
+        assert(NULL != serviceMan);
+        // Get the service from service manager
+        Ptr<MgFeatureService> featureService = dynamic_cast<MgFeatureService*>(
+            serviceMan->RequestService(MgServiceType::FeatureService));
+        assert(featureService != NULL);
+        // Collect the data reader into a pool for ReadNext operation
+        MgServerDataReaderPool* dataReaderPool = MgServerDataReaderPool::GetInstance();
+        CHECKNULL((MgServerDataReaderPool*)dataReaderPool, L"MgServerDataReader.GetRaster");
+        dataReader = dataReaderPool->GetReaderId(this);
+        if(L"" == dataReader)
+            dataReader = dataReaderPool->Add(this); // Add the reference
+            m_removeFromPoolOnDestruction = true;
+        retVal->SetMgService(featureService);
+        retVal->SetHandle(dataReader);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerDataReader.GetRaster");
 MgByteReader* MgServerDataReader::GetLOB(CREFSTRING propertyName)
     CHECKNULL(m_dataReader, L"MgServerDataReader.GetLOB");
@@ -714,6 +1271,47 @@
+MgByteReader* MgServerDataReader::GetLOB(INT32 index)
+    CHECKNULL(m_dataReader, L"MgServerDataReader.GetLOB");
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerDataReader.GetLOB",
+    else
+        // TODO: We need to switch to FdoIStreamReader when we have streaming capability in MgByteReader
+        FdoPtr<FdoLOBValue> fdoVal = m_dataReader->GetLOB(index);
+        if (fdoVal != NULL)
+            FdoPtr<FdoByteArray> byteArray = fdoVal->GetData();
+            if (byteArray != NULL)
+                FdoByte* bytes = byteArray->GetData();
+                FdoInt32 len = byteArray->GetCount();
+                Ptr<MgByteSource> byteSource = new MgByteSource((BYTE_ARRAY_IN)bytes,(INT32)len);
+                // TODO: We need to differentiate between CLOB and BLOB
+                // TODO: How do we fine the MimeType of data for CLOB
+                byteSource->SetMimeType(MgMimeType::Binary);
+                retVal = byteSource->GetReader();
 /// <summary>
 /// Releases all the resources of feature reader.
@@ -926,6 +1524,46 @@
     return ((const wchar_t*)retVal);
+/// <summary>
+const wchar_t* MgServerDataReader::GetString(INT32 index, INT32& length)
+    FdoString* retVal = NULL;
+        STRING buffer;
+    else
+        retVal = m_dataReader->GetString(index);
+        if (retVal != NULL)
+            length = (INT32)wcslen((const wchar_t*)retVal);
+    return ((const wchar_t*)retVal);
 MgBatchPropertyCollection* MgServerDataReader::GetRows(INT32 count)
Modified: trunk/MgDev/Server/src/Services/Feature/ServerDataReader.h
--- trunk/MgDev/Server/src/Services/Feature/ServerDataReader.h	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Services/Feature/ServerDataReader.h	2009-09-29 09:14:23 UTC (rev 4271)
@@ -66,6 +66,18 @@
     STRING GetPropertyName(INT32 index);
+    /// \brief
+    /// \param propertyName
+    /// Input the name of the property.
+    /// \return
+    /// Returns the property index
+    INT32 GetPropertyIndex(CREFSTRING propertyName);
     /// <summary>
     /// </summary>
@@ -200,7 +212,201 @@
     /// MgInvalidArgumentException if the property type is not geometry
     MgRaster* GetRaster(CREFSTRING propertyName);
+    /// \brief
+    ///  Returns true if the value of the specified property is null.
+    /// \param index
+    /// Property index.
+    /// \return
+    bool IsNull(INT32 index);
+    /// \brief
+    /// Gets the Boolean value of the specified property. No conversion is
+    /// performed, thus the property must be a of boolean type the result
+    /// is undetermined
+    /// \param index
+    /// \return
+    bool GetBoolean(INT32 index);
+    /// \brief
+    /// Gets the Byte value of the specified property. No conversion is
+    /// performed, thus the property must be a of byte type or the result
+    /// \param index
+    /// \return
+    /// Returns the Byte value.
+    BYTE GetByte(INT32 index);
+    /// \brief
+    /// Gets the DTime value of the specified property. No conversion is
+    /// performed, thus the property must be a of date type or the result
+    /// is NULL
+    /// \param index
+    /// \return
+    /// Returns the DTime value.
+    MgDateTime* GetDateTime(INT32 index);
+    /// \brief
+    /// Gets the Single value of the specified property. No conversion is
+    /// performed, thus the property must be a of type single or the result
+    /// \param index
+    /// \return
+    /// Returns the single value.
+    float GetSingle(INT32 index);
+    /// \brief
+    /// Gets the Double value of the specified property. No conversion is
+    /// performed, thus the property must be a of type double or the result
+    /// \param index
+    /// \return
+    /// Returns the double value.
+    double GetDouble(INT32 index);
+    /// \brief
+    /// Gets the integer 16 bits value of the specified property. No conversion is
+    /// performed, thus the property must be a of type integer 16 bits or the result
+    /// \param index
+    /// \return
+    /// Returns the integer 16 bits value.
+    INT16 GetInt16(INT32 index);
+    /// \brief
+    /// Gets the integer 32 bits value of the specified property. No conversion is
+    /// performed, thus the property must be a of type integer 32 bits or the result
+    /// \param index
+    /// \return
+    /// Returns the integer 32 bits value.
+    INT32 GetInt32(INT32 index);
+    /// \brief
+    /// Gets the integer 64 bits value of the specified property. No conversion is
+    /// performed, thus the property must be a of type integer 64 bits or the result
+    /// is NULL
+    /// \param index
+    /// \return
+    /// Returns the integer 64 bits value.
+    /// Note: INT64 is actually a pointer to an Integer64 object
+    INT64 GetInt64(INT32 index);
+    /// \brief
+    /// Gets the string value of the specified property. No conversion is
+    /// performed, thus the property must be a of type string or the result
+    /// is NULL
+    /// \param index
+    /// \return
+    /// Returns the string value.
+    STRING GetString(INT32 index);
+    /// \brief
+    /// Gets the BLOB value of the specified property. No conversion is
+    /// performed, thus the property must be a of type BLOBs or the result
+    /// is NULL
+    /// \param index
+    /// \return
+    /// Returns the BLOB value.
+    MgByteReader* GetBLOB(INT32 index);
+    /// \brief
+    /// Gets the CLOB value of the specified property. No conversion is
+    /// performed, thus the property must be a of type CLOB or the result
+    /// is NULL
+    /// \param index
+    /// \return
+    /// Returns the CLOB value.
+    MgByteReader* GetCLOB(INT32 index);
+    /// \brief
+    /// Gets the Geometry for the specified property. No conversion is
+    /// performed, thus the property must be a of type Geometry or the result
+    /// is NULL
+    /// \param index
+    /// \return
+    /// Returns a ByteReader object
+    MgByteReader* GetGeometry(INT32 index);
+    /// \brief
+    /// Gets the raster object of the specified property.
+    /// the property must be of Raster type; otherwise, an exception is thrown.
+    /// \param index
+    /// \return
+    MgRaster* GetRaster(INT32 index);
     /// <summary>
     /// Closes the FeatureReader object, freeing any resources it may be holding.
     /// </summary>
@@ -232,6 +438,15 @@
     const wchar_t* GetString(CREFSTRING propertyName, INT32& length);
+    /// <summary>
+    /// is NULL</summary>
+    /// <param name="index">Property index.</param>
+    /// <returns>Returns the string value.</returns>
+    const wchar_t* GetString(INT32 index, INT32& length);
     virtual INT32 GetClassId()
         return m_cls_id;
@@ -243,6 +458,7 @@
     void Deserialize(MgStream* stream);
     void Serialize(MgStream* stream);
     MgByteReader* GetLOB(CREFSTRING propertyName);
+    MgByteReader* GetLOB(INT32 index);
     STRING GetRasterPropertyName();
     MgByteReader* GetRaster(INT32 xSize, INT32 ySize, STRING rasterPropName);
     MgBatchPropertyCollection* GetRows(INT32 count = 0); // If zero means feature all records
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFdoFeatureReader.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerFdoFeatureReader.cpp	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFdoFeatureReader.cpp	2009-09-29 09:14:23 UTC (rev 4271)
@@ -62,6 +62,34 @@
 /// \brief
+/// Gets the name of the property at the given ordinal position.
+/// \param index
+/// Input the position of the property.
+/// \return
+/// Returns the property name
+FdoString* MgServerFdoFeatureReader::GetPropertyName(FdoInt32 index)
+    return m_internalReader->GetPropertyName(index);
+/// \brief
+/// Gets the index of the property with the specified name.
+/// \param propertyName
+/// Input the property name.
+/// \return
+/// Returns the property index
+FdoInt32 MgServerFdoFeatureReader::GetPropertyIndex(FdoString* propertyName)
+    return m_internalReader->GetPropertyIndex(propertyName);
+/// \brief
@@ -96,6 +124,43 @@
 /// \brief
+/// Gets the geometry value of the property, at the specified index,
+/// as a byte array in FGF format. Because no conversion is performed,
+/// the property must be of Geometric type; otherwise, an exception is thrown.
+/// This method is a language-specific performance optimization that returns a
+/// pointer to the array data, rather than to an object that encapsulates
+/// the array.  The array's memory area is only guaranteed to be valid
+/// until a call to ReadNext() or Close(), or the disposal of this reader
+/// object.
+/// \param index
+/// Input the index of the property.
+/// \param count
+/// Output the number of bytes in the array.
+/// \return
+/// Returns a pointer to the byte array in FGF format.
+const FdoByte * MgServerFdoFeatureReader::GetGeometry(FdoInt32 index, FdoInt32 * count)
+    if(m_internalReader->IsNull(index))
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerFdoFeatureReader.GetGeometry",
+    else
+        return m_internalReader->GetGeometry(index, count);
+/// \brief
@@ -123,6 +188,36 @@
 /// \brief
+/// Gets the geometry value of the specified property, at the specified index,
+/// as a byte array in FGF format. Because no conversion is performed, the property
+/// must be of Geometric type; otherwise, an exception is thrown.
+/// \param index
+/// \return
+/// Returns the byte array in FGF format.
+FdoByteArray* MgServerFdoFeatureReader::GetGeometry(FdoInt32 index)
+        STRING buffer;
+    else
+        return m_internalReader->GetGeometry(index);
+/// \brief
 /// the object or object collection property. If the property is not an
 /// object property, an exception is thrown.
@@ -150,6 +245,36 @@
 /// \brief
+/// Gets a reference to an FdoIFeatureReader to read the data contained in
+/// the object or object collection property defined at the specified index
+/// position. If the property is not an object property, an exception is thrown.
+/// \param index
+/// \return
+/// Returns the nested feature reader
+FdoIFeatureReader* MgServerFdoFeatureReader::GetFeatureObject(FdoInt32 index)
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerFdoFeatureReader.GetFeatureObject",
+    else
+        return m_internalReader->GetFeatureObject(index);
+/// \brief
 /// performed, thus the property must be FdoDataType_Boolean or an
 /// exception is thrown.
@@ -177,6 +302,36 @@
 /// \brief
+/// Gets the Boolean value of the property specified at the index position.
+/// No conversion is performed, thus the property must be FdoDataType_Boolean
+/// or an exception is thrown.
+/// \param index
+/// \return
+/// Returns the Boolean value.
+bool MgServerFdoFeatureReader::GetBoolean(FdoInt32 index)
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerFdoFeatureReader.GetBoolean",
+    else
+        return m_internalReader->GetBoolean(index);
+/// \brief
 /// Gets the byte value of the specified property. No conversion is
 /// performed, thus the property must be FdoDataType_Byte or an
@@ -204,6 +359,36 @@
 /// \brief
+/// Gets the Byte value of the property specified at the index position.
+/// No conversion is performed, thus the property must be FdoDataType_Byte
+/// \param index
+/// \return
+/// Returns the byte value.
+FdoByte MgServerFdoFeatureReader::GetByte(FdoInt32 index)
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerFdoFeatureReader.GetByte",
+    else
+        return m_internalReader->GetByte(index);
+/// \brief
 ///  Gets the date and time value of the specified property. No conversion is
 /// performed, thus the property must be FdoDataType_DateTime or an
@@ -231,6 +416,36 @@
 /// \brief
+/// Gets the date and time value of the of the property specified at
+/// the index position. No conversion is performed, thus the property
+/// must be FdoDataType_DateTime or an exception is thrown.
+/// \param index
+/// \return
+/// Returns the date and time value.
+FdoDateTime MgServerFdoFeatureReader::GetDateTime(FdoInt32 index)
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerFdoFeatureReader.GetDateTime",
+    else
+        return m_internalReader->GetDateTime(index);
+/// \brief
 /// Gets the double-precision floating point value of the specified property. No
 /// conversion is performed, thus the property must be FdoDataType_Double
@@ -258,6 +473,36 @@
 /// \brief
+/// Gets the double-precision floating point value of the property specified at
+/// the index position. No conversion is performed, thus the property must be
+/// FdoDataType_Double or an exception is thrown.
+/// \param index
+/// \return
+/// Returns the double floating point value
+double MgServerFdoFeatureReader::GetDouble(FdoInt32 index)
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerFdoFeatureReader.GetDouble",
+    else
+        return m_internalReader->GetDouble(index);
+/// \brief
 /// Gets the 16-bit integer value of the specified property. No conversion is
 /// performed, thus the property must be FdoDataType_Int16 or an exception
 /// is thrown.
@@ -285,6 +530,36 @@
 /// \brief
+/// Gets the 16-bit integer value of the property specified at
+/// property must be FdoDataType_Int16 or an exception is thrown.
+/// \param index
+/// \return
+/// Returns the FdoInt16 value.
+FdoInt16 MgServerFdoFeatureReader::GetInt16(FdoInt32 index)
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerFdoFeatureReader.GetInt16",
+    else
+        return m_internalReader->GetInt16(index);
+/// \brief
 /// Gets the 32-bit integer value of the specified property. No conversion is
 /// performed, thus the property must be FdoDataType_Int32 or an exception
 /// is thrown.
@@ -312,6 +587,36 @@
 /// \brief
+/// Gets the 32-bit integer value of the property specified at
+/// property must be FdoDataType_Int32 or an exception is thrown.
+/// \param index
+/// \return
+/// Returns the FdoInt32 value
+FdoInt32 MgServerFdoFeatureReader::GetInt32(FdoInt32 index)
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerFdoFeatureReader.GetInt32",
+    else
+        return m_internalReader->GetInt32(index);
+/// \brief
 /// Gets the 64-bit integer value of the specified property. No conversion is
 /// performed, thus the property must be FdoDataType_Int64 or an exception
 /// is thrown.
@@ -339,6 +644,36 @@
 /// \brief
+/// Gets the 64-bit integer value of the property specified at
+/// property must be FdoDataType_Int64 or an exception is thrown.
+/// \param index
+/// \return
+/// Returns the FdoInt64 value.
+FdoInt64 MgServerFdoFeatureReader::GetInt64(FdoInt32 index)
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerFdoFeatureReader.GetInt64",
+    else
+        return m_internalReader->GetInt64(index);
+/// \brief
 /// Gets the Single floating point value of the specified property. No
 /// conversion is performed, thus the property must be FdoDataType_Single
@@ -366,6 +701,36 @@
 /// \brief
+/// Gets the Single floating point value of the property specified at
+/// must be FdoDataType_Single or an exception is thrown.
+/// \param index
+/// \return
+/// Returns the single value
+float MgServerFdoFeatureReader::GetSingle(FdoInt32 index)
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerFdoFeatureReader.GetSingle",
+    else
+        return m_internalReader->GetSingle(index);
+/// \brief
 /// performed, thus the property must be FdoDataType_String or an exception
 /// is thrown.
@@ -393,6 +758,36 @@
 /// \brief
+/// Gets the string value of the property specified at the index
+/// position. No conversion is performed, thus the property must
+/// be FdoDataType_String or an exception is thrown.
+/// \param index
+/// \return
+/// Returns the string value
+FdoString* MgServerFdoFeatureReader::GetString(FdoInt32 index)
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerFdoFeatureReader.GetString",
+    else
+        return m_internalReader->GetString(index);
+/// \brief
 /// Gets a LOBValue reference. The LOB is fully read in and data available.
 /// Because no conversion is performed, the property must be FdoDataType_BLOB or
 /// FdoDataType_CLOB etc. (a LOB type)
@@ -420,6 +815,37 @@
 /// \brief
+/// Gets a LOBValue pointer to the property specified at the index
+/// position. The LOB is fully read in and data available.
+/// Because no conversion is performed, the property must be
+/// FdoDataType_BLOB or FdoDataType_CLOB etc. (a LOB type)
+/// \param index
+/// \return
+/// Returns the pointer to LOBValue
+FdoLOBValue* MgServerFdoFeatureReader::GetLOB(FdoInt32 index)
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerFdoFeatureReader.GetLOB",
+    else
+        return m_internalReader->GetLOB(index);
+/// \brief
 /// Gets a reference of the specified LOB property as a FdoBLOBStreamReader or
 /// FdoCLOBStreamReader etc. to allow reading in blocks of data.
@@ -449,6 +875,39 @@
 /// \brief
+/// Gets a pointer to the specified LOB property, specified at the index
+/// position. The reference is returned as an FdoBLOBStreamReader or an
+/// FdoCLOBStreamReader, to allow reading in blocks of data. Because
+/// no conversion is performed, the property must be FdoDataType_BLOB
+/// or FdoDataType_CLOB etc. (a LOB type) Cast the FdoIStreamReader
+/// to the appropriate LOB Stream Reader.
+/// \param index
+/// \return
+/// Returns a pointer to a LOB stream reader
+FdoIStreamReader* MgServerFdoFeatureReader::GetLOBStreamReader(FdoInt32 index)
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerFdoFeatureReader.GetLOBStreamReader",
+    else
+        return m_internalReader->GetLOBStreamReader(index);
+/// \brief
@@ -463,6 +922,21 @@
 /// \brief
+/// Returns true if the value of the property at the specified
+/// index is null.
+/// \param index
+/// \return
+/// Returns true if the value is null.
+bool MgServerFdoFeatureReader::IsNull(FdoInt32 index)
+    return m_internalReader->IsNull(index);
+/// \brief
@@ -494,6 +968,40 @@
 /// \brief
+/// Gets the raster object of the property at the specified index.
+/// of Raster type; otherwise, an exception is thrown.
+/// \param index
+/// \return
+/// Returns the raster object.
+FdoIRaster* MgServerFdoFeatureReader::GetRaster(FdoInt32 index)
+//    if(m_internalReader->IsNull(propertyName))
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerFdoFeatureReader.GetRaster",
+    else
+        return m_internalReader->GetRaster(index);
+/// \brief
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFdoFeatureReader.h
--- trunk/MgDev/Server/src/Services/Feature/ServerFdoFeatureReader.h	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFdoFeatureReader.h	2009-09-29 09:14:23 UTC (rev 4271)
@@ -58,6 +58,28 @@
     /// \brief
+    /// \param index
+    /// \return
+    /// \brief
+    /// \return
+    /// \brief
@@ -272,7 +294,226 @@
     /// \brief
+    /// object.
+    /// \param index
+    /// \param count
+    /// \return
+    /// \brief
+    /// \param index
+    /// \return
+    /// \brief
+    /// \param index
+    /// \return
+    /// \brief
+    /// \param index
+    /// \return
+    /// \brief
+    /// \param index
+    /// \return
+    /// \brief
+    /// \param index
+    /// \return
+    /// \brief
+    /// \param index
+    /// \return
+    /// \brief
+    /// \param index
+    /// \return
+    /// \brief
+    /// \param index
+    /// \return
+    /// \brief
+    /// \param index
+    /// \return
+    /// \brief
+    /// \param index
+    /// \return
+    /// \brief
+    /// \param index
+    /// \return
+    /// \brief
+    /// Because no conversion is performed, the property must be
+    /// \param index
+    /// \return
+    /// \brief
+    /// \param index
+    /// \return
+    /// \brief
+    /// \param index
+    /// \return
+    /// \brief
+    /// \param index
+    /// \return
+    /// \brief
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.cpp	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.cpp	2009-09-29 09:14:23 UTC (rev 4271)
@@ -1135,3 +1135,101 @@
+// getter by index
+BYTE_ARRAY_OUT MgServerFeatureReader::GetGeometry(INT32 index, INT32& length)
+    return GetGeometry(propertyName, length);
+MgByteReader* MgServerFeatureReader::GetGeometry(INT32 index)
+    return GetGeometry(propertyName);
+MgFeatureReader*  MgServerFeatureReader::GetFeatureObject(INT32 index)
+    return GetFeatureObject(propertyName);
+bool MgServerFeatureReader::GetBoolean(INT32 index)
+    return GetBoolean(propertyName);
+BYTE MgServerFeatureReader::GetByte(INT32 index)
+    return GetByte(propertyName);
+MgDateTime* MgServerFeatureReader::GetDateTime(INT32 index)
+    return GetDateTime(propertyName);
+double MgServerFeatureReader::GetDouble(INT32 index)
+    return GetDouble(propertyName);
+INT16 MgServerFeatureReader::GetInt16(INT32 index)
+    return GetInt16(propertyName);
+INT32 MgServerFeatureReader::GetInt32(INT32 index)
+    return GetInt32(propertyName);
+INT64 MgServerFeatureReader::GetInt64(INT32 index)
+    return GetInt64(propertyName);
+float MgServerFeatureReader::GetSingle(INT32 index)
+    return GetSingle(propertyName);
+STRING MgServerFeatureReader::GetString(INT32 index)
+    return GetString(propertyName);
+MgByteReader* MgServerFeatureReader::GetBLOB(INT32 index)
+    return GetBLOB(propertyName);
+MgByteReader* MgServerFeatureReader::GetCLOB(INT32 index)
+    return GetCLOB(propertyName);
+bool MgServerFeatureReader::IsNull(INT32 index)
+    return IsNull(propertyName);
+ MgRaster* MgServerFeatureReader::GetRaster(INT32 index)
+    return GetRaster(propertyName);
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.h
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.h	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.h	2009-09-29 09:14:23 UTC (rev 4271)
@@ -221,8 +221,171 @@
     /// <summary>
+    ///  Returns true if the value of the property at the specified index is null.
+    /// </summary>
+    /// <returns>Returns true if the value is null.</returns>
+    /// <summary>
+    /// Gets the Boolean value of the property at the specified index. No conversion is
+    /// is undertermined</summary>
+    /// <returns>Returns the Boolean value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not boolean
+    /// <summary>
+    /// Gets the Byte value of the property at the specified index. No conversion is
+    /// <returns>Returns the Byte value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not byte
+    /// <summary>
+    /// Gets the DTime value of the property at the specified index. No conversion is
+    /// <returns>Returns the DTime value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not date/time
+    /// <summary>
+    /// Gets the Single value of the property at the specified index. No conversion is
+    /// is undetermined</summary>
+    /// <returns>Returns the single value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not float
+    /// <summary>
+    /// Gets the Double value of the property at the specified index. No conversion is
+    /// <returns>Returns the double value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not double
+    /// <summary>
+    /// Gets the integer 16 bits value of the property at the specified index. No conversion is
+    /// <returns>Returns the integer 16 bits value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not int16
+    /// <summary>
+    /// Gets the integer 32 bits value of the property at the specified index. No conversion is
+    /// <returns>Returns the integer 32 bits value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not int32
+    /// <summary>
+    /// Gets the integer 64 bits value of the property at the specified index. No conversion is
+    /// <returns>Returns the integer 64 bits value.
+    ///</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not int64
+    /// <summary>
+    /// Gets the string value of the property at the specified index. No conversion is
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not a string
+    /// <summary>
+    /// Gets the BLOB value of the property at the specified index. No conversion is
+    /// <returns>Returns the BLOB value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not a BLOB
+    /// <summary>
+    /// Gets the CLOB value of the property at the specified index. No conversion is
+    /// <returns>Returns the CLOB value.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not a CLOB
+    /// <summary>
+    /// Gets the FeatureReader to access this object value.
+    /// The property must be of an object type; otherwise, the result is NULL.
+    /// </summary>
+    /// <returns>Returns the feature reader to access this object.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not a feature
+    MgFeatureReader* GetFeatureObject(INT32 index);
+    /// <summary>
+    /// Gets the geometry value of the property at the specified index as a GeometryReader.
+    /// of Geometric type; otherwise, the result is NULL.</summary>
+    /// <returns>Returns the Geometry object.</returns>
+    /// EXCEPTIONS:
+    /// MgInvalidArgumentException if the property type is not geometry
+    /// <summary>
+    /// </summary>
+    /// <returns>Returns the Raster object.</returns>
+    /// EXCEPTIONS:
+    /// <summary>
     /// Serializes all features into an XML.
     /// XML is serialized from the current position of feature reader in the order
     /// data are retrieved.
@@ -263,6 +426,15 @@
     /// <summary>
+    /// Gets the Geometry for the property at the specified index. No conversion is
+    /// <returns>Returns a ByteReader object</returns>
+    BYTE_ARRAY_OUT GetGeometry(INT32 index, INT32& length);
+    /// <summary>
@@ -271,6 +443,15 @@
+    /// <summary>
     ///<summary>
     /// Serialize data to TCP/IP stream
     ///</summary>
Modified: trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.cpp	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.cpp	2009-09-29 09:14:23 UTC (rev 4271)
@@ -1031,6 +1031,103 @@
+// getter by index
+BYTE_ARRAY_OUT MgServerGwsFeatureReader::GetGeometry(INT32 index, INT32& length)
+MgByteReader* MgServerGwsFeatureReader::GetGeometry(INT32 index)
+MgFeatureReader*  MgServerGwsFeatureReader::GetFeatureObject(INT32 index)
+bool MgServerGwsFeatureReader::GetBoolean(INT32 index)
+BYTE MgServerGwsFeatureReader::GetByte(INT32 index)
+MgDateTime* MgServerGwsFeatureReader::GetDateTime(INT32 index)
+double MgServerGwsFeatureReader::GetDouble(INT32 index)
+INT16 MgServerGwsFeatureReader::GetInt16(INT32 index)
+INT32 MgServerGwsFeatureReader::GetInt32(INT32 index)
+INT64 MgServerGwsFeatureReader::GetInt64(INT32 index)
+float MgServerGwsFeatureReader::GetSingle(INT32 index)
+STRING MgServerGwsFeatureReader::GetString(INT32 index)
+MgByteReader* MgServerGwsFeatureReader::GetBLOB(INT32 index)
+MgByteReader* MgServerGwsFeatureReader::GetCLOB(INT32 index)
+bool MgServerGwsFeatureReader::IsNull(INT32 index)
+ MgRaster* MgServerGwsFeatureReader::GetRaster(INT32 index)
 void MgServerGwsFeatureReader::Serialize(MgStream* stream)
     INT32 count = 1; // Get value from MgConfiguration
Modified: trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.h
--- trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.h	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Services/Feature/ServerGwsFeatureReader.h	2009-09-29 09:14:23 UTC (rev 4271)
@@ -205,8 +205,171 @@
     /// MgFdoException
     /// <summary>
+    /// </summary>
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    ///</returns>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// </summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// </summary>
+    /// EXCEPTIONS:
+    /// <summary>
     /// </summary>
     void Close();
@@ -253,6 +416,15 @@
     /// <summary>
+    /// <summary>
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSqlDataReader.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerSqlDataReader.cpp	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSqlDataReader.cpp	2009-09-29 09:14:23 UTC (rev 4271)
@@ -127,6 +127,27 @@
 /// <summary>
+/// Gets the index of the property with the specified property name.
+/// </summary>
+/// <param name="propertyName">Input the name of the property.</param>
+/// <returns>Returns the property index</returns>
+INT32 MgServerSqlDataReader::GetPropertyIndex(CREFSTRING propertyName)
+    CHECKNULL(m_sqlReader, L"MgServerSqlDataReader.GetPropertyIndex");
+    FdoInt32 index;
+    index = m_sqlReader->GetColumnIndex(propertyName.c_str());
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerSqlDataReader.GetPropertyIndex")
+/// <summary>
 /// Gets the data type of the property with the specified name.
 /// </summary>
 /// <param name="propertyName">Input the property name.</param>
@@ -195,6 +216,27 @@
 /// <summary>
+/// </summary>
+bool MgServerSqlDataReader::IsNull(INT32 index)
+    CHECKNULL(m_sqlReader, L"MgServerSqlDataReader.IsNull");
+    retVal = m_sqlReader->IsNull(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerSqlDataReader.IsNull");
+    return retVal;
+/// <summary>
@@ -228,6 +270,42 @@
 /// <summary>
+bool MgServerSqlDataReader::GetBoolean(INT32 index)
+    CHECKNULL(m_sqlReader, L"MgServerSqlDataReader.GetBoolean");
+    if(m_sqlReader->IsNull(index))
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerSqlDataReader.GetBoolean",
+    else
+        retVal = m_sqlReader->GetBoolean(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerSqlDataReader.GetBoolean");
+    return retVal;
+/// <summary>
@@ -261,6 +339,42 @@
 /// <summary>
+BYTE MgServerSqlDataReader::GetByte(INT32 index)
+    CHECKNULL(m_sqlReader, L"MgServerSqlDataReader.GetByte");
+    BYTE retVal = 0;
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerSqlDataReader.GetByte",
+    else
+        retVal = (BYTE)m_sqlReader->GetByte(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerSqlDataReader.GetByte");
+    return retVal;
+/// <summary>
@@ -296,6 +410,45 @@
 /// <summary>
+MgDateTime* MgServerSqlDataReader::GetDateTime(INT32 index)
+    CHECKNULL(m_sqlReader, L"MgServerSqlDataReader.GetDateTime");
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerSqlDataReader.GetDateTime",
+    else
+        FdoDateTime val = m_sqlReader->GetDateTime(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerSqlDataReader.GetDateTime");
+/// <summary>
@@ -329,6 +482,42 @@
 /// <summary>
+float MgServerSqlDataReader::GetSingle(INT32 index)
+    CHECKNULL(m_sqlReader, L"MgServerSqlDataReader.GetSingle");
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerSqlDataReader.GetSingle",
+    else
+        retVal = m_sqlReader->GetSingle(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerSqlDataReader.GetSingle");
+    return retVal;
+/// <summary>
@@ -362,6 +551,42 @@
 /// <summary>
+double MgServerSqlDataReader::GetDouble(INT32 index)
+    CHECKNULL(m_sqlReader, L"MgServerSqlDataReader.GetDouble");
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerSqlDataReader.GetDouble",
+    else
+        retVal = m_sqlReader->GetDouble(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerSqlDataReader.GetDouble");
+    return retVal;
+/// <summary>
@@ -395,6 +620,42 @@
 /// <summary>
+INT16 MgServerSqlDataReader::GetInt16(INT32 index)
+    CHECKNULL(m_sqlReader, L"MgServerSqlDataReader.GetInt16");
+    INT16 retVal = 0;
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerSqlDataReader.GetInt16",
+    else
+        retVal = (INT16)m_sqlReader->GetInt16(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerSqlDataReader.GetInt16");
+    return retVal;
+/// <summary>
@@ -428,6 +689,42 @@
 /// <summary>
+INT32 MgServerSqlDataReader::GetInt32(INT32 index)
+    CHECKNULL(m_sqlReader, L"MgServerSqlDataReader.GetInt32");
+    INT32 retVal = 0;
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerSqlDataReader.GetInt32",
+    else
+        retVal = (INT32)m_sqlReader->GetInt32(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerSqlDataReader.GetInt32");
+    return retVal;
+/// <summary>
@@ -463,6 +760,44 @@
 /// <summary>
+///</returns>
+INT64 MgServerSqlDataReader::GetInt64(INT32 index)
+    CHECKNULL(m_sqlReader, L"MgServerSqlDataReader.GetInt64");
+    INT64 retVal = 0;
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerSqlDataReader.GetInt64",
+    else
+        retVal = (INT64)m_sqlReader->GetInt64(index);
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerSqlDataReader.GetInt64");
+    return retVal;
+/// <summary>
@@ -501,6 +836,47 @@
 /// <summary>
+STRING MgServerSqlDataReader::GetString(INT32 index)
+    CHECKNULL(m_sqlReader, L"MgServerSqlDataReader.GetString");
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerSqlDataReader.GetString",
+    else
+        INT32 length = 0;
+        if (str != NULL)
+            retVal = str;
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerSqlDataReader.GetString");
+    return retVal;
+/// <summary>
@@ -534,6 +910,42 @@
 /// <summary>
+MgByteReader* MgServerSqlDataReader::GetBLOB(INT32 index)
+    CHECKNULL(m_sqlReader, L"MgServerSqlDataReader.GetBLOB");
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerSqlDataReader.GetBLOB",
+    else
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerSqlDataReader.GetBLOB");
+/// <summary>
@@ -567,6 +979,42 @@
 /// <summary>
+MgByteReader* MgServerSqlDataReader::GetCLOB(INT32 index)
+    CHECKNULL(m_sqlReader, L"MgServerSqlDataReader.GetCLOB");
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerSqlDataReader.GetCLOB",
+    else
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerSqlDataReader.GetCLOB");
+/// <summary>
@@ -608,7 +1056,52 @@
+/// <summary>
+MgByteReader* MgServerSqlDataReader::GetGeometry(INT32 index)
+    CHECKNULL(m_sqlReader, L"MgServerSqlDataReader.GetGeometry");
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerSqlDataReader.GetGeometry",
+    else
+        FdoPtr<FdoByteArray> byteArray = m_sqlReader->GetGeometry(index);
+        if (data != NULL)
+    MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerSqlDataReader.GetGeometry");
 MgByteReader* MgServerSqlDataReader::GetLOB(CREFSTRING propertyName)
     CHECKNULL(m_sqlReader, L"MgServerSqlDataReader.GetLOB");
@@ -645,6 +1138,45 @@
+MgByteReader* MgServerSqlDataReader::GetLOB(INT32 index)
+    CHECKNULL(m_sqlReader, L"MgServerSqlDataReader.GetLOB");
+        STRING buffer;
+        throw new MgNullPropertyValueException(L"MgServerSqlDataReader.GetLOB",
+    else
+        FdoPtr<FdoLOBValue> fdoVal = m_sqlReader->GetLOB(index);
+                byteReader = byteSource->GetReader();
 /// <summary>
@@ -769,6 +1301,22 @@
         __LINE__, __WFILE__, NULL, L"", NULL);
+/// <summary>Gets the raster object of the specified property.
+/// the property must be of Raster type; otherwise, an exception is thrown.
+/// </summary>
+/// <param name="propertyName">Input the property name.</param>
+/// <returns>Returns the raster object.</returns>
+/// EXCEPTIONS:
+/// MgConnectionNotOpenException
+/// MgNullPropertyValueException
+/// MgFdoException
+MgRaster* MgServerSqlDataReader::GetRaster(INT32 index)
+    throw new MgInvalidPropertyTypeException(L"MgServerSqlDataReader.GetRaster",
+        __LINE__, __WFILE__, NULL, L"", NULL);
 /// <summary>
@@ -806,6 +1354,47 @@
+/// <summary>
+const wchar_t* MgServerSqlDataReader::GetString(INT32 index, INT32& length)
+    FdoString* retVal;
+        STRING buffer;
+    else
+        retVal = m_sqlReader->GetString(index);
 MgBatchPropertyCollection* MgServerSqlDataReader::GetRows(INT32 count)
     CHECKNULL((MgServerSqlDataReader*)m_sqlReader, L"MgServerSqlDataReader.GetRows");
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSqlDataReader.h
--- trunk/MgDev/Server/src/Services/Feature/ServerSqlDataReader.h	2009-09-28 19:57:35 UTC (rev 4270)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSqlDataReader.h	2009-09-29 09:14:23 UTC (rev 4271)
@@ -66,6 +66,20 @@
     /// <returns>Returns the property name</returns>
+    /// \brief
+    /// Gets the index of the property with the specified property name.
+    /// \param propertyName(string)
+    /// The name of the property in the list of
+    /// properties belonging to the feature currently
+    /// being read.
+    /// \return
+    /// Returns the property index.
     /// <summary>
@@ -203,8 +217,171 @@
     /// MgFdoException
     /// <summary>
+    /// </summary>
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    ///</returns>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// </summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// EXCEPTIONS:
+    /// <summary>
+    /// </summary>
+    /// EXCEPTIONS:
+    /// <summary>
     /// </summary>
     void Close();
@@ -235,6 +412,15 @@
+    /// <summary>
         return m_cls_id;
@@ -246,6 +432,7 @@
     void AddRows(INT32 count);
     void AddRow(MgPropertyDefinitionCollection* propDefCol);
More information about the mapguide-commits mailing list
