[mapguide-commits] r5073 - in sandbox/maestro-3.0: Maestro.Base
Maestro.Base/Commands Maestro.Editors/WebLayout
svn_mapguide at osgeo.org
Fri Aug 6 01:29:48 EDT 2010
Author: jng
Date: 2010-08-06 05:29:48 +0000 (Fri, 06 Aug 2010)
New Revision: 5073
sandbox/maestro-3.0/Maestro.Base/Commands/NewItemCommand.cs
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
sandbox/maestro-3.0/Maestro.Editors/WebLayout/CommandIconCache.cs
- Fix NullReferenceException when attempting to fetch command icon for a command that has no image url
- Add the NewItemCommand to the site explorer context menu.
Modified: sandbox/maestro-3.0/Maestro.Base/Commands/NewItemCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/NewItemCommand.cs 2010-08-06 05:11:06 UTC (rev 5072)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/NewItemCommand.cs 2010-08-06 05:29:48 UTC (rev 5073)
@@ -31,12 +31,24 @@
public override void Run()
var wb = Workbench.Instance;
+ var exp = wb.ActiveSiteExplorer;
var mgr = ServiceRegistry.GetService<ServerConnectionManager>();
var orm = ServiceRegistry.GetService<OpenResourceManager>();
- var conn = mgr.GetConnection(wb.ActiveSiteExplorer.ConnectionName);
+ var conn = mgr.GetConnection(exp.ConnectionName);
var nits = ServiceRegistry.GetService<NewItemTemplateService>();
- var dlg = new NewResourceDialog(conn.ResourceService, nits);
+ NewResourceDialog dlg = null;
+ if (exp.SelectedItems.Length == 1)
+ var item = exp.SelectedItems[0];
+ if (item.IsFolder)
+ dlg = new NewResourceDialog(conn.ResourceService, nits, item.ResourceId);
+ if (dlg == null)
+ dlg = new NewResourceDialog(conn.ResourceService, nits);
if (dlg.ShowDialog() == System.Windows.Forms.DialogResult.OK)
var tpl = dlg.SelectedTemplate;
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-08-06 05:11:06 UTC (rev 5072)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-08-06 05:29:48 UTC (rev 5073)
@@ -82,7 +82,7 @@
icon="clipboard_paste"
class="Maestro.Base.Commands.NotImplementedCommand" />
</MenuItem>
- <!-- For testing various APIs, disable for releases -->
+ <!-- For testing various APIs, disabled for releases -->
<Condition action="Exclude" name="DebugMode">
<MenuItem id="Menu_Test"
type="Menu"
@@ -262,14 +262,15 @@
<!-- Site Explorer Context Menu -->
<Path name="/Maestro/Shell/SiteExplorer/SelectedFolder">
<Condition action="Disable" name="SelectedItem" type="Folder">
+ <MenuItem id="NewItem"
+ icon="document__plus"
+ label="${res:Menu_File_NewResource}"
+ tooltip="${res:Menu_File_NewResource}"
+ class="Maestro.Base.Commands.NewItemCommand" />
+ <MenuItem type="Separator" />
<MenuItem id="CreatePackage"
label="${res:SiteExplorer_SelectedFolder_CreatePackage}"
- <Condition action="Disable" name="IsNotRoot">
- <MenuItem id="Delete"
- label="${res:SiteExplorer_SelectedItem_Delete}"
- class="Maestro.Base.Commands.NotImplementedCommand" />
- </Condition>
<MenuItem id="LoadPackage"
label="${res:SiteExplorer_SelectedFolder_LoadPackage}"
@@ -285,6 +286,12 @@
<MenuItem id="Paste"
label="${res:SiteExplorer_SelectedFolder_Paste}"
+ <Condition action="Disable" name="IsNotRoot">
+ <MenuItem id="Delete"
+ label="${res:SiteExplorer_SelectedItem_Delete}"
+ class="Maestro.Base.Commands.NotImplementedCommand" />
+ </Condition>
<MenuItem id="Validate"
label="${res:SiteExplorer_ValidateResources}"
class="Maestro.Base.Commands.SiteExplorer.ValidateCommand" />
Modified: sandbox/maestro-3.0/Maestro.Editors/WebLayout/CommandIconCache.cs
--- sandbox/maestro-3.0/Maestro.Editors/WebLayout/CommandIconCache.cs 2010-08-06 05:11:06 UTC (rev 5072)
+++ sandbox/maestro-3.0/Maestro.Editors/WebLayout/CommandIconCache.cs 2010-08-06 05:29:48 UTC (rev 5073)
@@ -37,7 +37,7 @@
public static Bitmap GetStandardCommandIcon(string relpath)
- if (!relpath.StartsWith("../stdicons/") && !relpath.EndsWith(".gif"))
+ if (relpath == null || !relpath.StartsWith("../stdicons/") && !relpath.EndsWith(".gif"))
return null;
var resMgr = Properties.Resources.ResourceManager;
More information about the mapguide-commits
