[mapguide-commits] r5074 - in sandbox/maestro-3.0:
Maestro.Base/Commands/Test Maestro.Editors Maestro.Editors/Common
svn_mapguide at osgeo.org
Fri Aug 6 01:43:53 EDT 2010
Author: jng
Date: 2010-08-06 05:43:53 +0000 (Fri, 06 Aug 2010)
New Revision: 5074
Added:
sandbox/maestro-3.0/Maestro.Editors/Common/GenericItemSelectionDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Common/GenericItemSelectionDialog.cs
sandbox/maestro-3.0/Maestro.Editors/Common/GenericItemSelectionDialog.resx
Removed:
sandbox/maestro-3.0/Maestro.Editors/Common/FdoProviderPicker.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Common/FdoProviderPicker.cs
sandbox/maestro-3.0/Maestro.Editors/Common/FdoProviderPicker.resx
sandbox/maestro-3.0/Maestro.Base/Commands/Test/SelectFdoProviderCommand.cs
sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
Replace the FDO provider selection dialog with a generic one that can be reused for other situations
Modified: sandbox/maestro-3.0/Maestro.Base/Commands/Test/SelectFdoProviderCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/Test/SelectFdoProviderCommand.cs 2010-08-06 05:29:48 UTC (rev 5073)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/Test/SelectFdoProviderCommand.cs 2010-08-06 05:43:53 UTC (rev 5074)
@@ -35,10 +35,11 @@
var mgr = ServiceRegistry.GetService<ServerConnectionManager>();
var conn = mgr.GetConnection(exp.ConnectionName);
- var picker = new FdoProviderPicker(conn.FeatureService);
- if (picker.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ var providers = conn.FeatureService.FeatureProviders;
+ var provider = GenericItemSelectionDialog.SelectItem("Select FDO provider", "Select an FDO provider", providers, "DisplayName", "Name");
+ if (provider != null)
- MessageService.ShowMessage(picker.ProviderName);
+ MessageService.ShowMessage(provider.DisplayName);
else
Deleted: sandbox/maestro-3.0/Maestro.Editors/Common/FdoProviderPicker.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Common/FdoProviderPicker.Designer.cs 2010-08-06 05:29:48 UTC (rev 5073)
+++ sandbox/maestro-3.0/Maestro.Editors/Common/FdoProviderPicker.Designer.cs 2010-08-06 05:43:53 UTC (rev 5074)
@@ -1,110 +0,0 @@
-namespace Maestro.Editors.Common
- partial class FdoProviderPicker
- /// <summary>
- /// Required designer variable.
- /// </summary>
- private System.ComponentModel.IContainer components = null;
- /// <summary>
- /// Clean up any resources being used.
- /// </summary>
- /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
- protected override void Dispose(bool disposing)
- if (disposing && (components != null))
- components.Dispose();
- base.Dispose(disposing);
- #region Windows Form Designer generated code
- /// <summary>
- /// Required method for Designer support - do not modify
- /// the contents of this method with the code editor.
- /// </summary>
- private void InitializeComponent()
- this.CancelBtn = new System.Windows.Forms.Button();
- this.OKBtn = new System.Windows.Forms.Button();
- this.label1 = new System.Windows.Forms.Label();
- this.ProviderList = new System.Windows.Forms.ListBox();
- this.SuspendLayout();
- // CancelBtn
- this.CancelBtn.Anchor = System.Windows.Forms.AnchorStyles.Bottom;
- this.CancelBtn.DialogResult = System.Windows.Forms.DialogResult.Cancel;
- this.CancelBtn.FlatStyle = System.Windows.Forms.FlatStyle.System;
- this.CancelBtn.ImeMode = System.Windows.Forms.ImeMode.NoControl;
- this.CancelBtn.Location = new System.Drawing.Point(134, 228);
- this.CancelBtn.Name = "CancelBtn";
- this.CancelBtn.Size = new System.Drawing.Size(80, 32);
- this.CancelBtn.TabIndex = 8;
- this.CancelBtn.Text = "Cancel";
- this.CancelBtn.Click += new System.EventHandler(this.CancelBtn_Click);
- // OKBtn
- this.OKBtn.Anchor = System.Windows.Forms.AnchorStyles.Bottom;
- this.OKBtn.DialogResult = System.Windows.Forms.DialogResult.Cancel;
- this.OKBtn.Enabled = false;
- this.OKBtn.FlatStyle = System.Windows.Forms.FlatStyle.System;
- this.OKBtn.ImeMode = System.Windows.Forms.ImeMode.NoControl;
- this.OKBtn.Location = new System.Drawing.Point(30, 228);
- this.OKBtn.Name = "OKBtn";
- this.OKBtn.Size = new System.Drawing.Size(80, 32);
- this.OKBtn.TabIndex = 7;
- this.OKBtn.Text = "OK";
- this.OKBtn.Click += new System.EventHandler(this.OKBtn_Click);
- // label1
- this.label1.FlatStyle = System.Windows.Forms.FlatStyle.System;
- this.label1.ImeMode = System.Windows.Forms.ImeMode.NoControl;
- this.label1.Location = new System.Drawing.Point(12, 10);
- this.label1.Name = "label1";
- this.label1.Size = new System.Drawing.Size(120, 16);
- this.label1.TabIndex = 6;
- this.label1.Text = "Providers on server:";
- // ProviderList
- this.ProviderList.Anchor = ((System.Windows.Forms.AnchorStyles)((((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
- | System.Windows.Forms.AnchorStyles.Left)
- | System.Windows.Forms.AnchorStyles.Right)));
- this.ProviderList.Location = new System.Drawing.Point(12, 26);
- this.ProviderList.Name = "ProviderList";
- this.ProviderList.Size = new System.Drawing.Size(218, 186);
- this.ProviderList.TabIndex = 5;
- this.ProviderList.SelectedIndexChanged += new System.EventHandler(this.ProviderList_SelectedIndexChanged);
- // FdoProviderPicker
- this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
- this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
- this.ClientSize = new System.Drawing.Size(242, 272);
- this.ControlBox = false;
- this.Controls.Add(this.CancelBtn);
- this.Controls.Add(this.OKBtn);
- this.Controls.Add(this.label1);
- this.Controls.Add(this.ProviderList);
- this.Name = "FdoProviderPicker";
- this.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent;
- this.Text = "Select FDO Provider";
- this.ResumeLayout(false);
- #endregion
- private System.Windows.Forms.Button CancelBtn;
- private System.Windows.Forms.Button OKBtn;
- private System.Windows.Forms.Label label1;
- private System.Windows.Forms.ListBox ProviderList;
\ No newline at end of file
Deleted: sandbox/maestro-3.0/Maestro.Editors/Common/FdoProviderPicker.cs
--- sandbox/maestro-3.0/Maestro.Editors/Common/FdoProviderPicker.cs 2010-08-06 05:29:48 UTC (rev 5073)
+++ sandbox/maestro-3.0/Maestro.Editors/Common/FdoProviderPicker.cs 2010-08-06 05:43:53 UTC (rev 5074)
@@ -1,74 +0,0 @@
-#region Disclaimer / License
-// Copyright (C) 2010, Jackie Ng
-// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of the GNU Lesser General Public
-// License as published by the Free Software Foundation; either
-// version 2.1 of the License, or (at your option) any later version.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
-#endregion
-using System;
-using System.Collections.Generic;
-using System.ComponentModel;
-using System.Data;
-using System.Drawing;
-using System.Text;
-using System.Windows.Forms;
-using OSGeo.MapGuide.MaestroAPI.Services;
- public partial class FdoProviderPicker : Form
- private FdoProviderPicker()
- InitializeComponent();
- public FdoProviderPicker(IFeatureService featSvc)
- : this()
- var providers = featSvc.FeatureProviders;
- ProviderList.DisplayMember = "DisplayName";
- ProviderList.ValueMember = "Name";
- ProviderList.DataSource = providers;
- public string ProviderName
- get
- if (ProviderList.SelectedIndex >= 0)
- return ProviderList.SelectedValue.ToString();
- return string.Empty;
- private void ProviderList_SelectedIndexChanged(object sender, EventArgs e)
- OKBtn.Enabled = (ProviderList.SelectedIndex >= 0);
- private void CancelBtn_Click(object sender, EventArgs e)
- this.DialogResult = DialogResult.Cancel;
- private void OKBtn_Click(object sender, EventArgs e)
- this.DialogResult = DialogResult.OK;
Deleted: sandbox/maestro-3.0/Maestro.Editors/Common/FdoProviderPicker.resx
--- sandbox/maestro-3.0/Maestro.Editors/Common/FdoProviderPicker.resx 2010-08-06 05:29:48 UTC (rev 5073)
+++ sandbox/maestro-3.0/Maestro.Editors/Common/FdoProviderPicker.resx 2010-08-06 05:43:53 UTC (rev 5074)
@@ -1,120 +0,0 @@
-<?xml version="1.0" encoding="utf-8"?>
-<root>
- Microsoft ResX Schema
- Version 2.0
- The primary goals of this format is to allow a simple XML format
- that is mostly human readable. The generation and parsing of the
- various data types are done through the TypeConverter classes
- associated with the data types.
- Example:
- ... ado.net/XML headers & schema ...
- <resheader name="resmimetype">text/microsoft-resx</resheader>
- <resheader name="version">2.0</resheader>
- <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
- <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
- <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
- <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
- <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
- <value>[base64 mime encoded serialized .NET Framework object]</value>
- </data>
- <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
- <comment>This is a comment</comment>
- </data>
- There are any number of "resheader" rows that contain simple
- name/value pairs.
- Each data row contains a name, and value. The row also contains a
- type or mimetype. Type corresponds to a .NET class that support
- text/value conversion through the TypeConverter architecture.
- Classes that don't support this are serialized and stored with the
- mimetype set.
- The mimetype is used for serialized objects, and tells the
- ResXResourceReader how to depersist the object. This is currently not
- extensible. For a given mimetype the value must be set accordingly:
- Note - application/x-microsoft.net.object.binary.base64 is the format
- that the ResXResourceWriter will generate, however the reader can
- read any of the formats listed below.
- mimetype: application/x-microsoft.net.object.binary.base64
- value : The object must be serialized with
- : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
- : and then encoded with base64 encoding.
- mimetype: application/x-microsoft.net.object.soap.base64
- : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
- mimetype: application/x-microsoft.net.object.bytearray.base64
- value : The object must be serialized into a byte array
- : using a System.ComponentModel.TypeConverter
- <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
- <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
- <xsd:element name="root" msdata:IsDataSet="true">
- <xsd:complexType>
- <xsd:choice maxOccurs="unbounded">
- <xsd:element name="metadata">
- <xsd:complexType>
- <xsd:sequence>
- <xsd:element name="value" type="xsd:string" minOccurs="0" />
- </xsd:sequence>
- <xsd:attribute name="name" use="required" type="xsd:string" />
- <xsd:attribute name="type" type="xsd:string" />
- <xsd:attribute name="mimetype" type="xsd:string" />
- <xsd:attribute ref="xml:space" />
- </xsd:complexType>
- </xsd:element>
- <xsd:element name="assembly">
- <xsd:complexType>
- <xsd:attribute name="alias" type="xsd:string" />
- <xsd:attribute name="name" type="xsd:string" />
- </xsd:element>
- <xsd:element name="data">
- <xsd:complexType>
- <xsd:sequence>
- <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
- <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
- </xsd:sequence>
- <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
- <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
- <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
- </xsd:element>
- <xsd:element name="resheader">
- <xsd:complexType>
- <xsd:sequence>
- </xsd:sequence>
- <xsd:attribute name="name" type="xsd:string" use="required" />
- </xsd:element>
- </xsd:choice>
- </xsd:element>
- </xsd:schema>
- <value>text/microsoft-resx</value>
- </resheader>
- <value>2.0</value>
- </resheader>
- <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </resheader>
- <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </resheader>
-</root>
Added: sandbox/maestro-3.0/Maestro.Editors/Common/GenericItemSelectionDialog.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Common/GenericItemSelectionDialog.Designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/Common/GenericItemSelectionDialog.Designer.cs 2010-08-06 05:43:53 UTC (rev 5074)
@@ -0,0 +1,108 @@
+namespace Maestro.Editors.Common
+ partial class GenericItemSelectionDialog
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.lstItems = new System.Windows.Forms.ListBox();
+ this.lblPrompt = new System.Windows.Forms.Label();
+ this.btnOK = new System.Windows.Forms.Button();
+ this.btnCancel = new System.Windows.Forms.Button();
+ this.SuspendLayout();
+ // lstItems
+ this.lstItems.Anchor = ((System.Windows.Forms.AnchorStyles)((((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
+ | System.Windows.Forms.AnchorStyles.Left)
+ | System.Windows.Forms.AnchorStyles.Right)));
+ this.lstItems.Location = new System.Drawing.Point(13, 42);
+ this.lstItems.Name = "lstItems";
+ this.lstItems.Size = new System.Drawing.Size(259, 173);
+ this.lstItems.TabIndex = 0;
+ this.lstItems.SelectedIndexChanged += new System.EventHandler(this.lstItems_SelectedIndexChanged);
+ // lblPrompt
+ this.lblPrompt.AutoSize = true;
+ this.lblPrompt.Location = new System.Drawing.Point(12, 21);
+ this.lblPrompt.Name = "lblPrompt";
+ this.lblPrompt.Size = new System.Drawing.Size(74, 13);
+ this.lblPrompt.TabIndex = 1;
+ this.lblPrompt.Text = "Select an item";
+ // btnOK
+ this.btnOK.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnOK.Enabled = false;
+ this.btnOK.Location = new System.Drawing.Point(116, 227);
+ this.btnOK.Name = "btnOK";
+ this.btnOK.Size = new System.Drawing.Size(75, 23);
+ this.btnOK.TabIndex = 2;
+ this.btnOK.Text = "OK";
+ this.btnOK.UseVisualStyleBackColor = true;
+ this.btnOK.Click += new System.EventHandler(this.btnOK_Click);
+ // btnCancel
+ this.btnCancel.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ this.btnCancel.Location = new System.Drawing.Point(197, 227);
+ this.btnCancel.Name = "btnCancel";
+ this.btnCancel.Size = new System.Drawing.Size(75, 23);
+ this.btnCancel.TabIndex = 3;
+ this.btnCancel.Text = "Cancel";
+ this.btnCancel.UseVisualStyleBackColor = true;
+ this.btnCancel.Click += new System.EventHandler(this.btnCancel_Click);
+ // ItemSelectionDialog
+ this.AcceptButton = this.btnOK;
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.CancelButton = this.btnCancel;
+ this.ClientSize = new System.Drawing.Size(284, 262);
+ this.ControlBox = false;
+ this.Controls.Add(this.btnCancel);
+ this.Controls.Add(this.btnOK);
+ this.Controls.Add(this.lblPrompt);
+ this.Controls.Add(this.lstItems);
+ this.Name = "ItemSelectionDialog";
+ this.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent;
+ this.Text = "ItemSelectionDialog";
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.ListBox lstItems;
+ private System.Windows.Forms.Label lblPrompt;
+ private System.Windows.Forms.Button btnOK;
+ private System.Windows.Forms.Button btnCancel;
Added: sandbox/maestro-3.0/Maestro.Editors/Common/GenericItemSelectionDialog.cs
--- sandbox/maestro-3.0/Maestro.Editors/Common/GenericItemSelectionDialog.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/Common/GenericItemSelectionDialog.cs 2010-08-06 05:43:53 UTC (rev 5074)
@@ -0,0 +1,106 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Text;
+using System.Windows.Forms;
+ /// <summary>
+ /// A generic dialog that allows selection of an object from a list of objects
+ /// </summary>
+ public partial class GenericItemSelectionDialog : Form
+ private GenericItemSelectionDialog()
+ InitializeComponent();
+ /// <summary>
+ /// Displays a dialog to select an item from an array of items
+ /// </summary>
+ /// <typeparam name="T"></typeparam>
+ /// <param name="title"></param>
+ /// <param name="prompt"></param>
+ /// <param name="items"></param>
+ /// <param name="displayMember"></param>
+ /// <param name="valueMember"></param>
+ /// <returns></returns>
+ public static T SelectItem<T>(string title, string prompt, T[] items, string displayMember, string valueMember) where T : class
+ var dlg = new GenericItemSelectionDialog();
+ dlg.Text = title;
+ dlg.lblPrompt.Text = prompt;
+ dlg.lstItems.DataSource = items;
+ if (!string.IsNullOrEmpty(displayMember))
+ dlg.lstItems.DisplayMember = displayMember;
+ if (!string.IsNullOrEmpty(valueMember))
+ dlg.lstItems.ValueMember = valueMember;
+ if (dlg.ShowDialog() == DialogResult.OK)
+ return (T)dlg.lstItems.SelectedItem;
+ return null;
+ /// <summary>
+ /// Displays a dialog to select a string from an array of strings
+ /// </summary>
+ public static string SelectItem(string title, string prompt, string[] items)
+ dlg.Text = title;
+ return dlg.lstItems.SelectedItem.ToString();
+ return null;
+ private void lstItems_SelectedIndexChanged(object sender, EventArgs e)
+ btnOK.Enabled = (lstItems.SelectedItem != null);
+ private void btnCancel_Click(object sender, EventArgs e)
+ this.DialogResult = DialogResult.Cancel;
+ private void btnOK_Click(object sender, EventArgs e)
+ this.DialogResult = DialogResult.OK;
Added: sandbox/maestro-3.0/Maestro.Editors/Common/GenericItemSelectionDialog.resx
--- sandbox/maestro-3.0/Maestro.Editors/Common/GenericItemSelectionDialog.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/Common/GenericItemSelectionDialog.resx 2010-08-06 05:43:53 UTC (rev 5074)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+</root>
Modified: sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
--- sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj 2010-08-06 05:29:48 UTC (rev 5073)
+++ sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj 2010-08-06 05:43:53 UTC (rev 5074)
@@ -3,7 +3,7 @@
<PropertyGroup>
<Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
<Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
- <ProductVersion>9.0.21022</ProductVersion>
+ <ProductVersion>9.0.30729</ProductVersion>
<SchemaVersion>2.0</SchemaVersion>
<ProjectGuid>{5AD2CDBA-952E-4148-98A1-31D2E0D540D5}</ProjectGuid>
<OutputType>Library</OutputType>
@@ -70,12 +70,6 @@
<Compile Include="Common\EditorBindableCollapsiblePanel.cs">
<SubType>UserControl</SubType>
</Compile>
- <Compile Include="Common\FdoProviderPicker.cs">
- <SubType>Form</SubType>
- </Compile>
- <Compile Include="Common\FdoProviderPicker.Designer.cs">
- <DependentUpon>FdoProviderPicker.cs</DependentUpon>
- </Compile>
<Compile Include="Common\ExpressionEditor.cs">
</Compile>
@@ -85,6 +79,12 @@
<Compile Include="Common\ImageStylePicker.cs">
<SubType>Component</SubType>
</Compile>
+ <Compile Include="Common\GenericItemSelectionDialog.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="Common\GenericItemSelectionDialog.Designer.cs">
+ <DependentUpon>GenericItemSelectionDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="Common\ResourceDataCtrl.cs">
</Compile>
@@ -527,10 +527,6 @@
<DependentUpon>DataFilesCtrl.cs</DependentUpon>
<SubType>Designer</SubType>
</EmbeddedResource>
- <EmbeddedResource Include="Common\FdoProviderPicker.resx">
- <SubType>Designer</SubType>
- </EmbeddedResource>
<EmbeddedResource Include="Common\ExpressionEditor.resx">
<DependentUpon>ExpressionEditor.cs</DependentUpon>
@@ -538,6 +534,9 @@
<EmbeddedResource Include="Common\ImageStylePicker.resx">
<DependentUpon>ImageStylePicker.cs</DependentUpon>
</EmbeddedResource>
+ <EmbeddedResource Include="Common\GenericItemSelectionDialog.resx">
+ </EmbeddedResource>
<EmbeddedResource Include="Common\ResourceDataCtrl.resx">
<DependentUpon>ResourceDataCtrl.cs</DependentUpon>
More information about the mapguide-commits
