[mapguide-commits] r5075 - in sandbox/maestro-3.0/Maestro.Base:
Commands Properties Templates
svn_mapguide at osgeo.org
Fri Aug 6 01:49:03 EDT 2010
Author: jng
Date: 2010-08-06 05:49:03 +0000 (Fri, 06 Aug 2010)
New Revision: 5075
sandbox/maestro-3.0/Maestro.Base/Commands/NewItemCommand.cs
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
sandbox/maestro-3.0/Maestro.Base/Templates/FeatureSourceItemTemplate.cs
sandbox/maestro-3.0/Maestro.Base/Templates/ItemTemplate.cs
Alter the new feature source template to prompt for FDO provider
Modified: sandbox/maestro-3.0/Maestro.Base/Commands/NewItemCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/NewItemCommand.cs 2010-08-06 05:43:53 UTC (rev 5074)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/NewItemCommand.cs 2010-08-06 05:49:03 UTC (rev 5075)
@@ -54,10 +54,13 @@
var tpl = dlg.SelectedTemplate;
var res = tpl.CreateItem(conn);
- res.ResourceID = "Session:" + conn.SessionID + "//" + Guid.NewGuid().ToString() + "." + res.ResourceType.ToString();
- conn.ResourceService.SaveResource(res);
+ if (res != null)
+ res.ResourceID = "Session:" + conn.SessionID + "//" + Guid.NewGuid().ToString() + "." + res.ResourceType.ToString();
+ conn.ResourceService.SaveResource(res);
- orm.Open(res.ResourceID, conn, false);
+ orm.Open(res.ResourceID, conn, false);
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-08-06 05:43:53 UTC (rev 5074)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-08-06 05:49:03 UTC (rev 5075)
@@ -898,6 +898,15 @@
+ /// <summary>
+ /// Looks up a localized string similar to Select FDO Provider.
+ /// </summary>
+ internal static string SelectFdoProvider {
+ get {
+ return ResourceManager.GetString("SelectFdoProvider", resourceCulture);
internal static System.Drawing.Bitmap server {
get {
object obj = ResourceManager.GetObject("server", resourceCulture);
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-08-06 05:43:53 UTC (rev 5074)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-08-06 05:49:03 UTC (rev 5075)
@@ -619,4 +619,7 @@
<data name="SiteExplorer_SelectedItem_OpenWithXmlEditor" xml:space="preserve">
<value>Open Resource with XML Editor</value>
</data>
+ <data name="SelectFdoProvider" xml:space="preserve">
+ <value>Select FDO Provider</value>
+ </data>
</root>
\ No newline at end of file
Modified: sandbox/maestro-3.0/Maestro.Base/Templates/FeatureSourceItemTemplate.cs
--- sandbox/maestro-3.0/Maestro.Base/Templates/FeatureSourceItemTemplate.cs 2010-08-06 05:43:53 UTC (rev 5074)
+++ sandbox/maestro-3.0/Maestro.Base/Templates/FeatureSourceItemTemplate.cs 2010-08-06 05:49:03 UTC (rev 5075)
@@ -25,6 +25,7 @@
using Res = Maestro.Base.Properties.Resources;
using OSGeo.MapGuide.MaestroAPI.Resource;
using OSGeo.MapGuide.MaestroAPI.ObjectModels;
+using Maestro.Editors.Common;
namespace Maestro.Base.Templates
@@ -41,8 +42,18 @@
public override IResource CreateItem(IServerConnection conn)
- string provider = "";
- return ObjectFactory.CreateFeatureSource(conn, provider);
+ var provider = GenericItemSelectionDialog.SelectItem(
+ Properties.Resources.SelectFdoProvider,
+ conn.FeatureService.FeatureProviders,
+ "DisplayName",
+ "Name");
+ if (provider != null)
+ return ObjectFactory.CreateFeatureSource(conn, provider.Name);
+ return null;
Modified: sandbox/maestro-3.0/Maestro.Base/Templates/ItemTemplate.cs
--- sandbox/maestro-3.0/Maestro.Base/Templates/ItemTemplate.cs 2010-08-06 05:43:53 UTC (rev 5074)
+++ sandbox/maestro-3.0/Maestro.Base/Templates/ItemTemplate.cs 2010-08-06 05:49:03 UTC (rev 5075)
@@ -40,6 +40,11 @@
public Image Icon { get; protected set; }
+ /// <summary>
+ /// Creates a new item from this template
+ /// </summary>
+ /// <param name="conn"></param>
+ /// <returns>a new resource, null if the user cancelled during this process</returns>
public abstract IResource CreateItem(IServerConnection conn);
More information about the mapguide-commits
