[mapguide-commits] r5077 - in trunk/MgDev: Server/src/Wms
Web/src/HttpHandler
svn_mapguide at osgeo.org
Sat Aug 7 07:53:15 EDT 2010
Author: liuar
Date: 2010-08-07 11:53:15 +0000 (Sat, 07 Aug 2010)
New Revision: 5077
trunk/MgDev/Server/src/Wms/1.3.0.xml.awd
trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd
trunk/MgDev/Web/src/HttpHandler/OgcWmsServer.cpp
trunk/MgDev/Web/src/HttpHandler/WmsMapUtil.cpp
Ticket #1392 OGC WMS 1.3.0 Support
In order to pass the OGC certification, the implementation of MapGuide web map service should be updated.
Modified: trunk/MgDev/Server/src/Wms/1.3.0.xml.awd
--- trunk/MgDev/Server/src/Wms/1.3.0.xml.awd 2010-08-07 10:04:47 UTC (rev 5076)
+++ trunk/MgDev/Server/src/Wms/1.3.0.xml.awd 2010-08-07 11:53:15 UTC (rev 5077)
@@ -396,8 +396,11 @@
Exception format - XML
-<Response request="Exception" content-type="XML">
-<ServiceExceptionReport version="&TemplateVersion;">
+<Response request="Exception" content-type="text/xml">
+<ServiceExceptionReport version="&TemplateVersion;"
+ xmlns="http://www.opengis.net/ogc"
+ xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
+ xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd">
<ServiceException code="&Exception.Type;">
&Exception.message;
</ServiceException>
Modified: trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd
--- trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd 2010-08-07 10:04:47 UTC (rev 5076)
+++ trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd 2010-08-07 11:53:15 UTC (rev 5077)
@@ -242,7 +242,7 @@
finding the WKT for EPSG:21781 in the CS library.
<translate from="EPSG:21781">PROJCS["CH1903.LV03/01",GEOGCS["LLCH1903",DATUM["CH-1903",SPHEROID["BESSEL",6377397.155,299.15281535],TOWGS84[660.0770,13.5510,369.3440,0.804816,0.577692,0.952236,5.66000000]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Swiss_Oblique_Cylindrical"],PARAMETER["false_easting",600000.000],PARAMETER["false_northing",200000.000],PARAMETER["latitude_of_origin",46.95240555555556],PARAMETER["central_meridian",7.43958333333333],UNIT["Meter",1.00000000000000]]</translate>
+ <translate from="CRS:84">GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.01745329251994]]</translate>
</Define>
</Definitions>
Modified: trunk/MgDev/Web/src/HttpHandler/OgcWmsServer.cpp
--- trunk/MgDev/Web/src/HttpHandler/OgcWmsServer.cpp 2010-08-07 10:04:47 UTC (rev 5076)
+++ trunk/MgDev/Web/src/HttpHandler/OgcWmsServer.cpp 2010-08-07 11:53:15 UTC (rev 5077)
@@ -86,6 +86,7 @@
CPSZ kpszExceptionMessageInvalidImageFormat = _("The request uses an unsupported image format. (Found FORMAT=&Request.format;)"); // Localize
CPSZ kpszExceptionMessageMissingImageFormat = _("The request must contain a FORMAT parameter to specify the required image format."); // Localize
CPSZ kpszExceptionMessageMissingInfoFormat = _("The request must contain an INFO_FORMAT parameter to specify the format of feature information (MIME type)."); // Localize
+CPSZ kpszExceptionMessageInvalidInfoFormat = _("The request uses an unsupported info format. (Found INFO_FORMAT=&Request.info_format;)"); // Localize
CPSZ kpszExceptionMessageMissingVersion = _("The request must contain a VERSION parameter to specify the WMS version."); // Localize
// END LOCALIZATION
@@ -654,6 +655,31 @@
kpszExceptionMessageMissingInfoFormat));
bValid = false;
+ CPSZ pszSupportedFormats = this->Definition(_("Formats.GetFeatureInfo")); //NOXLATE
+ bool bSupport = false;
+ if(pszSupportedFormats != NULL)
+ MgXmlParser SupportedFormats(pszSupportedFormats);
+ while(SupportedFormats.Next())
+ MgXmlNode& node = SupportedFormats.Current();
+ if(node.Contents() == pszFormat)
+ bSupport = true;
+ break;
+ if(!bSupport)
+ ServiceExceptionReportResponse(MgOgcWmsException(MgOgcWmsException::kpszInvalidFormat,
+ kpszExceptionMessageInvalidInfoFormat));
+ bValid = false;
if(bValid)
Modified: trunk/MgDev/Web/src/HttpHandler/WmsMapUtil.cpp
--- trunk/MgDev/Web/src/HttpHandler/WmsMapUtil.cpp 2010-08-07 10:04:47 UTC (rev 5076)
+++ trunk/MgDev/Web/src/HttpHandler/WmsMapUtil.cpp 2010-08-07 11:53:15 UTC (rev 5077)
@@ -222,7 +222,7 @@
void MgWmsMapUtil::ProcessBoundingBoxAxes(STRING sSrs,REFSTRING bbox)
- if(sSrs.empty() || bbox.empty())
+ if(sSrs.empty() || bbox.empty() ||sSrs == _("CRS:84")) //Workaround
return;
Ptr<MgCoordinateSystemFactory> factory = new MgCoordinateSystemFactory();
More information about the mapguide-commits
