[mapguide-commits] r5078 - in trunk/Tools/Maestro: . Installer
Localization/ConvertResX/ConvertResX/Properties
Localization/da-DK/Maestro/ResourceValidators/Strings
Localization/es-ES/Maestro/ResourceValidators/Strings
Localization/fr-FR/Maestro/ResourceValidators/Strings
Localization/hr-HR/Maestro/ResourceValidators/Strings Maestro
Maestro/FusionEditor Maestro/LoginForm/Properties
Maestro/MaestroEditorInterface
Maestro/ResourceBrowser/Properties Maestro/ResourceEditors
Maestro/ResourceValidators MaestroAPI
MaestroAPI/PackageBuilder/Properties MaestroAPI/XsdGenerator
new w generics/Properties
MgCooker/MgCookerCommandline/Properties MgCooker/Properties
svn_mapguide at osgeo.org
Mon Aug 9 06:58:12 EDT 2010
Author: jng
Date: 2010-08-09 10:58:12 +0000 (Mon, 09 Aug 2010)
New Revision: 5078
trunk/Tools/Maestro/
trunk/Tools/Maestro/Installer/UpgradeData.wxi
trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceValidators/Strings/FeatureSourceValidator.da-DK.resx
trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceValidators/Strings/FeatureSourceValidator.es-ES.resx
trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceValidators/Strings/FeatureSourceValidator.fr-FR.resx
trunk/Tools/Maestro/Localization/hr-HR/Maestro/ResourceValidators/Strings/FeatureSourceValidator.hr-HR.resources
trunk/Tools/Maestro/Localization/hr-HR/Maestro/ResourceValidators/Strings/FeatureSourceValidator.hr-HR.resx
trunk/Tools/Maestro/Maestro/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs
trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs
trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs
Prep for 2.1.1 release
Property changes on: trunk/Tools/Maestro
___________________________________________________________________
Modified: svn:ignore
- *.suo
+ *.suo
InstallerTempRelease
Modified: trunk/Tools/Maestro/Installer/UpgradeData.wxi
--- trunk/Tools/Maestro/Installer/UpgradeData.wxi 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/Installer/UpgradeData.wxi 2010-08-09 10:58:12 UTC (rev 5078)
@@ -3,7 +3,7 @@
<?define UpgradeCode="A7C2ECB3-1991-47B9-A22E-8844BB95CAE2" ?>
<!-- Remember to change product version on each install -->
- <?define ProductVersion="2.1.0.4996" ?>
+ <?define ProductVersion="2.1.1.5078" ?>
<?define Manufacturer="Open Source Geospatial Foundation" ?>
Modified: trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs 2010-08-09 10:58:12 UTC (rev 5078)
@@ -32,5 +32,5 @@
// You can specify all the values or you can default the Build and Revision Numbers
// by using the '*' as shown below:
// [assembly: AssemblyVersion("1.0.*")]
-[assembly: AssemblyVersion("2.1.0.4996")]
-[assembly: AssemblyFileVersion("2.1.0.4996")]
+[assembly: AssemblyVersion("2.1.1.5078")]
+[assembly: AssemblyFileVersion("2.1.1.5078")]
Modified: trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceValidators/Strings/FeatureSourceValidator.da-DK.resx
--- trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceValidators/Strings/FeatureSourceValidator.da-DK.resx 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/Localization/da-DK/Maestro/ResourceValidators/Strings/FeatureSourceValidator.da-DK.resx 2010-08-09 10:58:12 UTC (rev 5078)
@@ -149,4 +149,8 @@
<value>En fejl opstod under læsning af spatial information: {0}</value>
<comment>An error message that is displayed if the spatial context could not be read</comment>
</data>
+ <data name="NoPrimaryKeyOrView" xml:space="preserve">
+ <value>Could not obtain identity properties for {0}. This class either has no identity properties and/or is derived from a view with no uniquely identifiable columns. Attempting to create feature joins from this class may produce unexpected results.</value>
+ <comment>A warning message that is displayed when we can't obtain identity properties from a class because it is a view</comment>
+ </data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceValidators/Strings/FeatureSourceValidator.es-ES.resx
--- trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceValidators/Strings/FeatureSourceValidator.es-ES.resx 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/Localization/es-ES/Maestro/ResourceValidators/Strings/FeatureSourceValidator.es-ES.resx 2010-08-09 10:58:12 UTC (rev 5078)
@@ -149,4 +149,8 @@
<value>Failed to read spatial context: {0}</value>
</data>
+ </data>
</root>
Modified: trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceValidators/Strings/FeatureSourceValidator.fr-FR.resx
--- trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceValidators/Strings/FeatureSourceValidator.fr-FR.resx 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/Localization/fr-FR/Maestro/ResourceValidators/Strings/FeatureSourceValidator.fr-FR.resx 2010-08-09 10:58:12 UTC (rev 5078)
@@ -149,4 +149,8 @@
<value>Impossible de lire le contexte spatial : {0}</value>
</data>
+ </data>
</root>
Modified: trunk/Tools/Maestro/Localization/hr-HR/Maestro/ResourceValidators/Strings/FeatureSourceValidator.hr-HR.resources
(Binary files differ)
Modified: trunk/Tools/Maestro/Localization/hr-HR/Maestro/ResourceValidators/Strings/FeatureSourceValidator.hr-HR.resx
--- trunk/Tools/Maestro/Localization/hr-HR/Maestro/ResourceValidators/Strings/FeatureSourceValidator.hr-HR.resx 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/Localization/hr-HR/Maestro/ResourceValidators/Strings/FeatureSourceValidator.hr-HR.resx 2010-08-09 10:58:12 UTC (rev 5078)
@@ -149,4 +149,8 @@
</data>
+ </data>
</root>
Modified: trunk/Tools/Maestro/Maestro/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/AssemblyInfo.cs 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/Maestro/AssemblyInfo.cs 2010-08-09 10:58:12 UTC (rev 5078)
@@ -45,7 +45,7 @@
// You can specify all the values or you can default the Revision and Build Numbers
// In order to sign your assembly you must specify a key to use. Refer to the
@@ -75,4 +75,4 @@
[assembly: AssemblyDelaySign(false)]
[assembly: AssemblyKeyFile("")]
[assembly: AssemblyKeyName("")]
-[assembly: AssemblyFileVersionAttribute("2.1.0.4996")]
+[assembly: AssemblyFileVersionAttribute("2.1.1.5078")]
Modified: trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs 2010-08-09 10:58:12 UTC (rev 5078)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs 2010-08-09 10:58:12 UTC (rev 5078)
@@ -32,5 +32,5 @@
Modified: trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs 2010-08-09 10:58:12 UTC (rev 5078)
@@ -45,7 +45,7 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs 2010-08-09 10:58:12 UTC (rev 5078)
@@ -50,5 +50,5 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs 2010-08-09 10:58:12 UTC (rev 5078)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs 2010-08-09 10:58:12 UTC (rev 5078)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs 2010-08-09 10:58:12 UTC (rev 5078)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
[assembly: AssemblyKeyFile("..\\..\\maestroapi.key")]
Modified: trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs 2010-08-09 10:58:12 UTC (rev 5078)
@@ -48,5 +48,5 @@
// Build Number
// Revision
Modified: trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs 2010-08-09 10:58:12 UTC (rev 5078)
@@ -48,5 +48,5 @@
// Build Number
// Revision
Modified: trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs 2010-08-09 10:58:12 UTC (rev 5078)
@@ -48,5 +48,5 @@
// Build Number
// Revision
Modified: trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs 2010-08-07 11:53:15 UTC (rev 5077)
+++ trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs 2010-08-09 10:58:12 UTC (rev 5078)
@@ -48,5 +48,5 @@
// Build Number
// Revision
More information about the mapguide-commits
