[mapguide-commits] r4612 - in trunk/MgDev/Common/Geometry: . Spatial
svn_mapguide at osgeo.org
Tue Mar 2 18:27:27 EST 2010
Author: NormOlsen
Date: 2010-03-02 18:27:26 -0500 (Tue, 02 Mar 2010)
New Revision: 4612
trunk/MgDev/Common/Geometry/Geometry.vcproj
trunk/MgDev/Common/Geometry/Makefile.am
trunk/MgDev/Common/Geometry/Spatial/MathUtility.cpp
trunk/MgDev/Common/Geometry/Spatial/MathUtility.h
trunk/MgDev/Common/Geometry/Spatial/SpatialUtility.cpp
trunk/MgDev/Common/Geometry/Spatial/SpatialUtility.h
MapGuide Trac Ticket 1253
This submission replaces the previous line string to arbitrary polygon clipper in its entirety. The clipper is now a four phase process and where each phase is implemented as an internally referenced methods. The new clipping algorithms correct problems related to coordinates with hard core 0.0 values, line string points which coincide with the clipping boundary, and the effect of line string segments which are collinear with (and overlap) clipping boundary segments. To accomplish this, the intelligence of the SegmentIntersection method has been improve significantly.
The submission includes a new header file (SpatialUtilityStatus.h) in which the status return values of various methods has been defined and documented.
Modified: trunk/MgDev/Common/Geometry/Geometry.vcproj
--- trunk/MgDev/Common/Geometry/Geometry.vcproj 2010-02-28 15:08:17 UTC (rev 4611)
+++ trunk/MgDev/Common/Geometry/Geometry.vcproj 2010-03-02 23:27:26 UTC (rev 4612)
@@ -66,7 +66,7 @@
AdditionalDependencies="ACEd.lib GEOSd.lib csmapd.lib"
OutputFile="$(OutDir)\MgGeometryd.dll"
LinkIncremental="2"
- AdditionalLibraryDirectories="..\..\Oem\ACE\ACE_wrappers\lib;"..\..\Oem\geos-2.2.0\VisualStudio\Debug";..\..\Oem\CsMap\lib80\Debug"
+ AdditionalLibraryDirectories="..\..\Oem\ACE\ACE_wrappers\lib;"..\..\Oem\geos-2.2.0\VisualStudio\Debug";..\..\..\MetaCrs\CsMap\lib80\Debug"
GenerateDebugInformation="true"
SubSystem="2"
RandomizedBaseAddress="1"
@@ -146,7 +146,7 @@
LinkIncremental="2"
- AdditionalLibraryDirectories="..\..\Oem\ACE\ACE_Wrappers\lib64;"..\..\Oem\geos-2.2.0\VisualStudio\Debug64";..\..\Oem\CsMap\lib80\Debug64"
+ AdditionalLibraryDirectories="..\..\Oem\ACE\ACE_Wrappers\lib64;"..\..\Oem\geos-2.2.0\VisualStudio\Debug64";..\..\..\MetaCrs\CsMap\lib80\Debug64"
SubSystem="2"
ImportLibrary="..\lib\debug64\MgGeometryd.lib"
@@ -219,7 +219,7 @@
AdditionalDependencies="ACE.lib GEOS.lib csmap.lib"
OutputFile="$(OutDir)\MgGeometry.dll"
LinkIncremental="1"
- AdditionalLibraryDirectories="..\..\Oem\ACE\ACE_wrappers\lib;"..\..\Oem\geos-2.2.0\VisualStudio\Release";..\..\Oem\CsMap\lib80\Release"
+ AdditionalLibraryDirectories="..\..\Oem\ACE\ACE_wrappers\lib;"..\..\Oem\geos-2.2.0\VisualStudio\Release";..\..\..\MetaCrs\CsMap\lib80\Release"
SubSystem="2"
OptimizeReferences="2"
@@ -299,7 +299,7 @@
LinkIncremental="1"
- AdditionalLibraryDirectories="..\..\Oem\ACE\ACE_Wrappers\lib64;"..\..\Oem\geos-2.2.0\VisualStudio\Release64";..\..\Oem\CsMap\lib80\Release64"
+ AdditionalLibraryDirectories="..\..\Oem\ACE\ACE_Wrappers\lib64;"..\..\Oem\geos-2.2.0\VisualStudio\Release64";..\..\..\MetaCrs\CsMap\lib80\Release64"
SubSystem="2"
@@ -2477,6 +2477,10 @@
</File>
<File
+ RelativePath=".\Spatial\SpatialUtilityStatus.h"
+ </File>
+ <File
RelativePath=".\Spatial\SpatialUtilityVectorAngle.h"
</File>
Modified: trunk/MgDev/Common/Geometry/Makefile.am
--- trunk/MgDev/Common/Geometry/Makefile.am 2010-02-28 15:08:17 UTC (rev 4611)
+++ trunk/MgDev/Common/Geometry/Makefile.am 2010-03-02 23:27:26 UTC (rev 4612)
@@ -349,6 +349,7 @@
Parse/yyAwkt.h \
Spatial/MathUtility.h \
Spatial/SpatialUtility.h \
+ Spatial/SpatialUtilityStatus.h \
Spatial/SpatialUtilityCircularArc.h \
Spatial/SpatialUtilityVectorAngle.h \
../CoordinateSystem/ArbitraryCoordsys.h \
Modified: trunk/MgDev/Common/Geometry/Spatial/MathUtility.cpp
--- trunk/MgDev/Common/Geometry/Spatial/MathUtility.cpp 2010-02-28 15:08:17 UTC (rev 4611)
+++ trunk/MgDev/Common/Geometry/Spatial/MathUtility.cpp 2010-03-02 23:27:26 UTC (rev 4612)
@@ -212,6 +212,9 @@
return interpolated;
+// This overload of DblCmp __MUST NOT__ be used if either argument can
+// be a hard zero.
bool MgMathUtility::DblCmp (double first,double second)
int exp1, exp2;
@@ -250,3 +253,14 @@
// We ignore any difference in the last few bits.
return (fabs (mant1 - mant2) < 5.0E-13);
+// Use this overload of DblCmp if either argument can be expected to be a
+// hard zero.
+bool MgMathUtility::DblCmp (double first,double second,double tolerance)
+ bool equal;
+ equal = (fabs (first - second) < tolerance);
+ return equal;
Modified: trunk/MgDev/Common/Geometry/Spatial/MathUtility.h
--- trunk/MgDev/Common/Geometry/Spatial/MathUtility.h 2010-02-28 15:08:17 UTC (rev 4611)
+++ trunk/MgDev/Common/Geometry/Spatial/MathUtility.h 2010-03-02 23:27:26 UTC (rev 4612)
@@ -109,6 +109,28 @@
/// Returns <c>true</c> for "essentially equal".
/// </returns>
static bool DblCmp (double first,double second);
+ /// <summary>
+ /// Reliably compares two doubles ignoring differences in the least
+ /// significant bits of the mantissa which are unreliable if either of
+ /// the values being compared are the result of some serious calculations.
+ /// </summary>
+ /// <param name="first">
+ /// The first of two doubles to be compared.
+ /// </param>
+ /// <param name="second">
+ /// The second of two doubles to be compared.
+ /// </param>
+ /// <param name="tolerance">
+ /// If the difference between the two values is euqal to or less than
+ /// this value, the function returns true.
+ /// </param>
+ /// <returns>
+ /// Returns <c>true</c> for "essentially equal".
+ /// </returns>
+ static bool DblCmp (double first,double second,double tolerance);
/// \endcond
Modified: trunk/MgDev/Common/Geometry/Spatial/SpatialUtility.cpp
--- trunk/MgDev/Common/Geometry/Spatial/SpatialUtility.cpp 2010-02-28 15:08:17 UTC (rev 4611)
+++ trunk/MgDev/Common/Geometry/Spatial/SpatialUtility.cpp 2010-03-02 23:27:26 UTC (rev 4612)
@@ -1,3 +1,4 @@
// Copyright (C) 2004-2010 by Autodesk, Inc.
@@ -19,6 +20,7 @@
#include "MathUtility.h"
#include "SpatialUtilityCircularArc.h"
#include "SpatialUtility.h"
+#include "SpatialUtilityStatus.h"
#define EPSILON 1e-10
#define NEGEPSILON -EPSILON
@@ -515,51 +517,189 @@
return retGeomComp.Detach();
-///<summary>
-/// Calculates the two dimensional intersection of two line segments.
-///</summary>
+// Determines the largest coordinate (2D) magnitude in a coordinate collection.
+double MgSpatialUtility::GreatestMagnitude (MgCoordinateIterator* coordinateIterator)
+ double magnitude (0.0);
+ Ptr<MgCoordinate> tmpCoord;
+ // We determine the largest magnitude of any coordinate of the polygon boundary.
+ coordinateIterator->Reset ();
+ while (coordinateIterator->MoveNext ())
+ tmpCoord = coordinateIterator->GetCurrent ();
+ if (fabs (tmpCoord->GetX()) > magnitude) magnitude = fabs (tmpCoord->GetX ());
+ if (fabs (tmpCoord->GetY()) > magnitude) magnitude = fabs (tmpCoord->GetY ());
+ return magnitude;
+// Calculates the two dimensional intersection of two line segments.
INT32 MgSpatialUtility::SegmentIntersection (MgCoordinate* result,MgCoordinate* seg1From,
MgCoordinate* seg1To,
MgCoordinate* seg2From,
- MgCoordinate* seg2To)
+ MgCoordinate* seg2To,
+ double magnitude)
bool preciseFrom;
bool preciseTo;
- INT32 status (-1); // until we know different.
+ int exponent; // exponent (base two) of the magnitude
+ INT32 status;
double delX1, delY1;
double delX2, delY2;
double denom1, denom2;
double num, denom; // numerator and denominator
+ double tolerance;
CHECKNULL(result, L"MgSpatialUtility.SegmentIntersection")
CHECKNULL(seg1From, L"MgSpatialUtility.SegmentIntersection")
CHECKNULL(seg1To, L"MgSpatialUtility.SegmentIntersection")
CHECKNULL(seg2From, L"MgSpatialUtility.SegmentIntersection")
CHECKNULL(seg2To, L"MgSpatialUtility.SegmentIntersection")
+ if (magnitude < 1.0E-04)
+ throw new MgInvalidArgumentException(L"MgSpatialUtility.SegmentIntersection", __LINE__, __WFILE__, NULL, L"", NULL);
+ // Compute a tolerance which is appropriate for the data we are working
+ // with. The intent is to derive a value which will ignore differences
+ // in the last 6 bits of the mantissa of a real number. In standard
+ // IEEE form, the mantissa of a "double" is 52 bits. If magnitude is
+ /// 1.0, this should produce a tolerance value of about ~1.5E-14.
+ frexp (magnitude,&exponent); // ignore the mantissa
+ tolerance = ldexp (0.5,(exponent - 46));
+ // Until we know different.
+ status = 0;
// Compute the denominator which also tells us if the lines are collinear.
delX1 = seg1To->GetX () - seg1From->GetX ();
delY1 = seg1To->GetY () - seg1From->GetY ();
delX2 = seg2To->GetX () - seg2From->GetX ();
delY2 = seg2To->GetY () - seg2From->GetY ();
+ if (fabs (delX1) < tolerance && fabs (delY1) < tolerance)
+ status |= MgSpatialUtilityStatus::DegenerateSeg1;
+ if (fabs (delX2) < tolerance && fabs (delY2) < tolerance)
+ status |= MgSpatialUtilityStatus::DegenerateSeg2;
+ if (status != 0)
+ return status;
denom1 = delX2 * delY1;
denom2 = delX1 * delY2;
if (MgMathUtility::DblCmp (denom1,denom2))
- // Collinear or parallel, there is no intersection.
- status = -1;
+ double intercept1, intercept2;
+ // Here if the segments are parallel, possibly colinear. In either
+ // case, there is no intersection.
+ // Determine collinear status. We determine collinearity by calculating
+ // the axis intercept value of both segments. We choose the axis to use
+ // based on the relative values of deltaX and deltaY. Since the two
+ // lines are parallel, the delta values of the two lines are proportionate.
+ // Necessary to preclude a divide by zero, but also increases the precision
+ // of the determination.
+ if (fabs (delX1) > fabs (delY1))
+ // We'll use the Y axis intercept for this determination.
+ intercept1 = (delX1 * (seg1From->GetX () + seg1To->GetX ())) /
+ (delY1 * (seg1From->GetY () + seg1To->GetY ())) * 0.5;
+ intercept2 = (delX2 * (seg2From->GetX () + seg2To->GetX ())) /
+ (delY2 * (seg2From->GetY () + seg2To->GetY ())) * 0.5;
+ else
+ // We'll use the X axis intercept for this determination.
+ intercept1 = (delY1 * (seg1From->GetY () + seg1To->GetY ())) /
+ (delX1 * (seg1From->GetX () + seg1To->GetX ())) * 0.5;
+ intercept2 = (delY2 * (seg2From->GetY () + seg2To->GetY ())) /
+ (delX2 * (seg2From->GetX () + seg2To->GetX ())) * 0.5;
+ bool collinear = MgMathUtility::DblCmp (intercept1,intercept2,tolerance);
+ if (collinear)
+ status |= MgSpatialUtilityStatus::SegmentsCollinear;
+ // Now we determine if the nature of the collinearity. Could
+ // be tuned for performance, but this case is very rare. Better
+ // top have something that is simple, understandable, and works.
+ double x1From = seg1From->GetX ();
+ double y1From = seg1From->GetY ();
+ double x1To = seg1To->GetX ();
+ double y1To = seg1To->GetX ();
+ double x2From = seg2From->GetX ();
+ double y2From = seg2From->GetY ();
+ double x2To = seg2To->GetX ();
+ double y2To = seg2To->GetX ();
+ // Determine if there is any overlap. A three bit combination should
+ // not be possible. So there are are 12 various combinations which
+ // represent valid situations. For example, when all four bits are
+ // set, the two segments are identical.
+ // We'll use the X coordinates to determine overlap.
+ if (x1From >= (x2From - tolerance) && x1From <= (x2From + tolerance))
+ // The overlap starts at the first point of the first segment.
+ status |= MgSpatialUtilityStatus::CollinearSeg1Start;
+ if (x1To >= (x2From - tolerance) && x1To <= (x2From + tolerance))
+ // The overlap ends at the first point of the first segment.
+ status |= MgSpatialUtilityStatus::CollinearSeg1End;
+ if (x2From >= (x1From - tolerance) && x2From <= (x1From + tolerance))
+ // The overlap starts at the first point of the second segment.
+ status |= MgSpatialUtilityStatus::CollinearSeg2Start;
+ if (x2To >= (x1From - tolerance) && x2To <= (x1From + tolerance))
+ // The overlap endss at the first point of the second segment.
+ status |= MgSpatialUtilityStatus::CollinearSeg2End;
+ else
+ // We'll use the Y coordinates to determine overlap.
+ if (y1From >= (y2From - tolerance) && y1From <= (y2From + tolerance))
+ if (y1To >= (y2From - tolerance) && y1To <= (y2From + tolerance))
+ if (y2From >= (y1From - tolerance) && y2From <= (y1From + tolerance))
+ if (y2To >= (y1From - tolerance) && y2To <= (y1From + tolerance))
+ else
+ status |= MgSpatialUtilityStatus::SegmentsParallel;
else
- // OK, we have a stable geometry and an intersection of some sort should exist.
- // Compute the intersection point.
- status = 0;
+ // OK, we have a stable geometry and an intersection of some sort should exist,
+ // somewhere. Compute the intersection point.
denom = denom1 - denom2;
num = delX1 * delX2 * (seg2From->GetY() - seg1From->GetY()) +
delX2 * delY1 * seg1From->GetX() -
@@ -571,21 +711,22 @@
delY1 * delX2 * seg2From->GetY();
result->SetY (num / -denom);
- // Now to compute the location of the intersection point relative to the
- // line segments involved. This is often very important.
+ // Determine the location of the intersection point relative to the
+ // line segments involved.
// Segment one is more horizontal than vertical. We will use the X
// value to test if the resulting point is on the segment.
- preciseFrom = MgMathUtility::DblCmp (result->GetX(),seg1From->GetX());
- preciseTo = MgMathUtility::DblCmp (result->GetX(),seg1To->GetX());
+ preciseFrom = MgMathUtility::DblCmp (result->GetX(),seg1From->GetX(),tolerance);
+ preciseTo = MgMathUtility::DblCmp (result->GetX(),seg1To->GetX(),tolerance);
if (delX1 >= 0.0)
// X increases from the 'from' point to the 'to' point.
if ((result->GetX() >= seg1From->GetX() || preciseFrom) &&
- (result->GetX() <= seg1To->GetX() || preciseTo))
+ (result->GetX() <= seg1To->GetX() || preciseTo))
- status |= 1;
+ // Intersection is on segment one.
+ status |= MgSpatialUtilityStatus::IntersectOnSeg1;
else
@@ -594,31 +735,35 @@
if ((result->GetX() <= seg1From->GetX() || preciseFrom) &&
(result->GetX() >= seg1To->GetX() || preciseTo))
- status |= 1;
if (preciseFrom)
- status |= 4;
+ // Intersection point is the start point of the segment.
+ status |= MgSpatialUtilityStatus::IntersectIsSeg1Start;
if (preciseTo)
- status |= 8;
+ // Intersection point is the end point of the segment.
+ status |= MgSpatialUtilityStatus::IntersectIsSeg1End;
else
// First segment is more vertical than horizontal. We will use the Y
- preciseFrom = MgMathUtility::DblCmp (result->GetY(),seg1From->GetY());
- preciseTo = MgMathUtility::DblCmp (result->GetY(),seg1To->GetY());
+ preciseFrom = MgMathUtility::DblCmp (result->GetY(),seg1From->GetY(),tolerance);
+ preciseTo = MgMathUtility::DblCmp (result->GetY(),seg1To->GetY(),tolerance);
if (delY1 >= 0.0)
// Y increases from the 'from' point to the 'to' point.
if ((result->GetY() >= seg1From->GetY() || preciseFrom) &&
(result->GetY() <= seg1To->GetY() || preciseTo))
- status |= 1;
else
@@ -627,30 +772,33 @@
if ((result->GetY() <= seg1From->GetY() || preciseFrom) &&
(result->GetY() >= seg1To->GetY() || preciseTo))
- status |= 1;
if (preciseFrom)
- status |= 4;
if (preciseTo)
- status |= 8;
// Same stuff with the second segment, sans comments.
if (fabs (delX2) > fabs (delY2))
- preciseFrom = MgMathUtility::DblCmp (result->GetX(),seg2From->GetX());
- preciseTo = MgMathUtility::DblCmp (result->GetX(),seg2To->GetX());
+ preciseFrom = MgMathUtility::DblCmp (result->GetX(),seg2From->GetX(),tolerance);
+ preciseTo = MgMathUtility::DblCmp (result->GetX(),seg2To->GetX(),tolerance);
if (delX2 >= 0.0)
if ((result->GetX() >= seg2From->GetX() || preciseFrom) &&
(result->GetX() <= seg2To->GetX() || preciseTo))
- status |= 2;
+ status |= MgSpatialUtilityStatus::IntersectOnSeg2;
else
@@ -658,28 +806,28 @@
if ((result->GetX() <= seg2From->GetX() || preciseFrom) &&
(result->GetX() >= seg2To->GetX() || preciseTo))
- status |= 2;
if (preciseFrom)
- status |= 16;
+ status |= MgSpatialUtilityStatus::IntersectIsSeg2Start;
if (preciseTo)
- status |= 32;
+ status |= MgSpatialUtilityStatus::IntersectIsSeg2End;
else
- preciseFrom = MgMathUtility::DblCmp (result->GetY(),seg2From->GetY());
- preciseTo = MgMathUtility::DblCmp (result->GetY(),seg2To->GetY());
+ preciseFrom = MgMathUtility::DblCmp (result->GetY(),seg2From->GetY(),tolerance);
+ preciseTo = MgMathUtility::DblCmp (result->GetY(),seg2To->GetY(),tolerance);
if (delY2 >= 0.0)
if ((result->GetY() >= seg2From->GetY() || preciseFrom) &&
(result->GetY() <= seg2To->GetY() || preciseTo))
- status |= 2;
else
@@ -687,36 +835,60 @@
if ((result->GetY() <= seg2From->GetY() || preciseFrom) &&
(result->GetY() >= seg2To->GetY() || preciseTo))
- status |= 2;
if (preciseFrom)
- status |= 16;
if (preciseTo)
- status |= 32;
return status;
-/// <summary>
-/// Returns a list of coordinates with all of the intersection points of the
-/// provided segment with the polygon provided by the first argument. Note
-/// that the first argument is a CoordinateIterator; so it doesn't have to be
-/// an MgPolygon. However, this function ASSUMES that the iterator does indeed
-/// point to a closed ring.
-/// </summary>
-MgCoordinateCollection* MgSpatialUtility::PolySegIntersection (MgCoordinateIterator* polyItr,MgCoordinate* segFrom,
- MgCoordinate* segTo)
+// Returns a list of coordinates with all of the intersection points of the
+// provided segment with the polygon provided by the first argument. Note
+// that the first argument is an MgCoordinateIterator; so it doesn't have to
+// be an MgPolygon.
+// Note that the returned collection is "new", and that it is a collection
+// of MgCoordinateXYM objects. For each intersection discovered and returned,
+// the M value of the coordinates in the collection will contain (as a double)
+// the status bit map returned by the SegmentIntersection method. (Note,
+// that the integer status value will have 0.01 added to it before being stored
+// as a double to eliminate the possibility of a round off error upon
+// conversion back to an INT32.)
+// In order to preclude duplicate intersection points in the returned
+// result, we always skip an intersection point which is precisely (see
+// MgMathUtility::DblCmp) equal to the 'To' point on a polgon segment,
+// confident that we will pick this intersection up on the next iteration
+// when such point becomes the "From" point.
+// TODO: Currently, this method will loop through the provided polygon
+// to determine an appropriate value for "magnitude" which is used in
+// performing "fuzzy" comparison of 'double's. An overloaded function
+// which accepts a "magnitude" value which can be computed only once
+// for a specific polygon would improve performace in many cases.
+MgCoordinateCollection* MgSpatialUtility::PolySegIntersection (MgCoordinateIterator* polyItr,
+ MgCoordinate* segFrom,
+ MgCoordinate* segTo)
int status;
+ INT32 statusMask;
INT32 insertIndex; // for test and debug;
- Ptr<MgCoordinateCollection> coordinateCollection;
+ double rStatus;
+ double magnitude;
+ Ptr<MgCoordinateCollection> intersectionCollection;
Ptr<MgCoordinate> intersection;
Ptr<MgCoordinate> polyFrom;
Ptr<MgCoordinate> polyTo;
@@ -725,60 +897,84 @@
CHECKNULL(segFrom, L"MgSpatialUtility.PolySegIntersection")
CHECKNULL(segTo, L"MgSpatialUtility.PolySegIntersection")
+ // We need this so we can determine a valid value to use for
+ // "fuzzy" double comparisons.
+ magnitude = GreatestMagnitude (polyItr);
// Create the return object. Quite often it gets returned empty, but we
- // will always return a "new" object (i.e. refCount == 1). Create a work
- // point we can use.
- coordinateCollection = new MgCoordinateCollection ();
+ // will always return a "new" object (i.e. refCount == 1).
+ intersectionCollection = new MgCoordinateCollection ();
+ // Create a work point we can use fo the result of an intersection.
intersection = new MgCoordinateXY ();
// Reset the iterator so we know for sure what its state is.
polyItr->Reset ();
polyItr->MoveNext ();
- // Loop through each segment in the polygon. If its an exterior ring,
- // as is usually the case, it should be in counterclockwise order.
+ // Loop through each segment in the polygon.
polyTo = polyItr->GetCurrent ();
while (polyItr->MoveNext ())
polyFrom = polyTo;
- status = SegmentIntersection (intersection,polyFrom,polyTo,segFrom,segTo);
+ status = SegmentIntersection (intersection,polyFrom,polyTo,segFrom,segTo,magnitude);
- // If the intersection is precisely on the 'From' point of the polygon segment,
- // we're not interested. It will show up again when that point becomes a
- // 'To' point on the polygon.
- if ((status & 4) == 4)
+ // Filter out that which we do nothing with.
+ if ((status & MgSpatialUtilityStatus::SegmentStatusMask) != 0)
+ // There is no intersection to deal with.
continue;
- if ((status & 3) == 3)
+ // An intersection point exists. If the intersection point is precisely
+ // that of the end point of the boundary segment, we skip it. We'll catch
+ // it when this point become the start point of the next boundary segment.
+ // Thus, we don't end up with duplicate points in the intersection
+ // collection. This selection of skipping the end point means that if
+ // the collection we've been given is not closed, this should all still
+ // work (famous last words).
+ statusMask = MgSpatialUtilityStatus::IntersectOnSeg1 | MgSpatialUtilityStatus::IntersectIsSeg1End;
+ if ((status & statusMask) == statusMask)
+ continue;
+ // OK, if we have an intersection point on both segments, we have something of
+ // interest to us.
+ MgSpatialUtilityStatus::IntersectOnSeg2;
// We have an intersection of interest to us. That is, an intersection
- // point which resides on both lines, but not presisely on the 'From"
- // point of the polygon segment. We need to add a point which will still
- // be on the heap when we are done, so we definitely do not want to add
- // the intersection point.
- Ptr<MgCoordinate> newPoint = new MgCoordinateXY (intersection->GetX(),intersection->GetY());
- insertIndex = AddToCoordinateCollection (coordinateCollection,newPoint,segFrom);
+ // point which resides on both lines, but not precisely on the 'To'
+ // point of the polygon segment. We use a MgCoordinateM here so we
+ // can pass back to the calling module the intersection status.
+ rStatus = static_cast<double>(status) + 0.01;
+ Ptr<MgCoordinate> newPoint = new MgCoordinateXYM (intersection->GetX(),intersection->GetY(),rStatus);
+ insertIndex = AddToCoordinateCollection (intersectionCollection,newPoint,segFrom);
if (insertIndex != 0)
insertIndex = 0;
// The line segment can have more than one intersection point with
// the polygon. So we keep trucking.
// We return the generated collection, which will often be empty.
- return coordinateCollection.Detach ();
+ // We never return a null pointer.
+ return intersectionCollection.Detach ();
// In the event that the PolySegIntersection function discovers two or more
// intersection points for a single line segment, it is important that they
// get added to the coordinate collection in the proper order. This is a
// brute force technique, but this situation is rather rare.
-INT32 MgSpatialUtility::AddToCoordinateCollection (MgCoordinateCollection* collection,MgCoordinate* newPoint,MgCoordinate* basePoint)
+INT32 MgSpatialUtility::AddToCoordinateCollection (MgCoordinateCollection* collection,
+ MgCoordinate* newPoint,
+ MgCoordinate* basePoint)
INT32 index = 0;
double deltaX, deltaY;
@@ -793,7 +989,7 @@
else
- // This happens rather in frequently, but it can happen. Need to
+ // This happens rather infrequently, but it can happen. Need to
// insert the value into the collection such that when we are
// done, the points represent the same disrection as the original
// line segment.
@@ -825,185 +1021,636 @@
-/// <summary>
-/// Returns true if the provided query point is inside of, or on, the closed
-/// ring provided by the polyItr argument.
-/// </summary>
-bool MgSpatialUtility::PointIsInPolygon (MgCoordinateIterator* polyItr,MgCoordinate* queryPoint)
+// This function returns a point which is guaranteed to be outside the polygon
+// provided by the argument. Having a separate function here enables users
+// of PointIsInPolygon to determine a point outside the polygon once per
+// polygon, rather than each time PointIsInPolygon is called.
+MgCoordinate* MgSpatialUtility::PointOutsidePolygon (MgCoordinateIterator* polyItr)
- bool isInside;
+ Ptr<MgCoordinate> outPoint;
- INT32 count;
- double minX, maxX;
- double minY, maxY;
double outX, outY;
+ double magnitude;
- Ptr<MgCoordinate> tmpCoord;
- Ptr<MgCoordinate> outPoint;
+ // Obtain the largest magnitude of any coordinate in the polygon boundary.
- // Accunulate min/max;
- polyItr->Reset ();
- minX = minY = +9.9E+100;
- maxX = maxY = -9.9E+100;
- while (polyItr->MoveNext ())
+ // Create a from point known to be outside of the polygon from the
+ // magnitude. The choice here is rather arbitrary.
+ outX = -magnitude * 2.0;
+ outY = -magnitude * 2.0;
+ outPoint = new MgCoordinateXY (outX,outY);
+ return outPoint.Detach ();
+// Use this overload of the PointIsInPolygon function (in conjuction with the
+// PointOutsidePolygon function) when several points are to be tested for the
+// same polygon. That is, arrange your code so the outsidePoint argument is
+// only calculated once. Return value indicates if the the queryPoint is
+// inside, outside, or precisely the polygon boundary.
+INT32 MgSpatialUtility::PointIsInPolygon (MgCoordinateIterator* polyItr,MgCoordinate* outsidePoint,
+ MgCoordinate* queryPoint)
+ INT32 pointStatus (MgSpatialUtilityStatus::PointIsOutside);
+ Ptr<MgCoordinateXYM> lastIntersection;
+ // Get all the intersections between the "outPoint" amd the query Point.
+ intersectionCollection = PolySegIntersection (polyItr,outsidePoint,queryPoint);
+ INT32 count = intersectionCollection->GetCount ();
+ // If the intersection count is zero, the point is definitely not on the
+ // polygon, nor is it inside the polygon.
+ if (count > 0)
- tmpCoord = polyItr->GetCurrent ();
- if (tmpCoord->GetX() < minX) minX = tmpCoord->GetX ();
- if (tmpCoord->GetY() < minY) minY = tmpCoord->GetY ();
- if (tmpCoord->GetX() > maxX) maxX = tmpCoord->GetX ();
- if (tmpCoord->GetY() > maxY) maxY = tmpCoord->GetY ();
+ // Need to extract the intersection type of the last intersection.
+ // It will tell us if we are on the polygon or not.
+ lastIntersection = dynamic_cast<MgCoordinateXYM*>(intersectionCollection->GetItem (count-1));
+ INT32 status = static_cast<INT32>(lastIntersection->GetM ());
+ // If the point is on the polygon, the status of the last intersection will
+ // have the IntersectIsSeg2End bit set.
+ if ((status & MgSpatialUtilityStatus::IntersectIsSeg2End) != 0)
+ pointStatus = MgSpatialUtilityStatus::PointIsOnBoundary;
+ else
+ // The query point is not on the polygon, so its inside/outside
+ // status can be determined by the number of intersections. An
+ // odd number of intersections says the point is inside.
+ pointStatus = ((count % 2) == 1) ? MgSpatialUtilityStatus::PointIsInside : MgSpatialUtilityStatus::PointIsOutside;
+ return pointStatus;
- // Create a from point known to be outside of the polygon.
- outX = (minX >= 0.0) ? -minX : minX * 2.0;
- outY = (minY >= 0.0) ? -minY : minY * 2.0;
- outPoint = new MgCoordinateXY (outX,outY);
+// Use this overload of the PointIsInPolygon function when only a very few
+// points are to be tested against a given polygon or performance is not an
+// issue. The outsidePoint argument of the other overload is calculated upon
+// each call to this function. Return value indicates if the the queryPoint is
+INT32 MgSpatialUtility::PointIsInPolygon (MgCoordinateIterator* polyItr,MgCoordinate* queryPoint)
+ INT32 pointStatus;
+ MgCoordinate* outsidePoint;
- // Get all the intersections between the "outPoint" amd the query Point.
- coordinateCollection = PolySegIntersection (polyItr,outPoint,queryPoint);
- count = coordinateCollection->GetCount ();
+ outsidePoint = PointOutsidePolygon (polyItr);
+ pointStatus = PointIsInPolygon (polyItr,outsidePoint,queryPoint);
- // If the number of intersections is odd, the query point is inside.
- // Otherwise it is outside. (Zero is an even number, isn't it?)
- isInside = ((count & 1) != 0);
+// Returns a collection of line strings which represents those portions of the
+// provided line string which are inside of the provided closed ring. The null
+// pointer is returned rather than an empty line string.
+// To preserve developer sanity, enhance maintainability, and avoid a ton of
+// spaghetti code, the process is broken down into four phases. Data is
+// communicated through the four phases via a collection of MgCoordinateXYZM
+// objects. In these objects, the status of each point is communicated in the
+// M member of the collection (as a double) and the status of each line segment
+// is communicated in the Z member of the collection (as a double). The
+// specific status values used are defined by the following static
+// constants.
+// Values which are stored in the M member of the internally used point
+// collection; i.e. the status of each point relative to the clip ploygon.
+static const INT32 StringPointNotDetermined = 0;
+static const INT32 StringPointOutside = 1;
+static const INT32 StringPointOnBoundary = 2;
+static const INT32 StringPointInside = 3;
+// Values which are stored in the Z member of the internally used point
+// collection; i.e. the status of each segment relative to the clip
+// ploygon. The value stored refers to the segment which starts at
+// the point in which the segment status is stored.
+static const INT32 StringSegNotDetermined = 0;
+static const INT32 StringSegOutside = 1;
+static const INT32 StringSegCollinear = 2;
+static const INT32 StringSegInside = 3;
- return isInside;
+static const double rStringPointNotDetermined = (StringPointNotDetermined + 0.01);
+static const double rStringSegNotDetermined = (StringSegNotDetermined + 0.01);
+MgLineStringCollection* MgSpatialUtility::ClipStringToPolygon (MgCoordinateIterator* polyItr,
+ MgCoordinateIterator* lineItr,
+ bool includeCollinear)
+ Ptr<MgCoordinateCollection> pointCollection;
+ Ptr<MgCoordinateIterator> pointIterator;
+ Ptr<MgLineStringCollection> lineCollection;
+ // Phase One: Expand the line string with all implied transition points,
+ // i.e. intersection with the polygon.
+ pointCollection = StringClipPhaseOne (lineItr,polyItr);
+ pointIterator = pointCollection->GetIterator ();
+ // Phase Two: Classify each point in the newly constructed point collection
+ // as being outside, on, or inside the clipping boundary. This status
+ // is stored as a double in the M element of the coordinate collection.
+ MgSpatialUtility::StringClipPhaseTwo (pointIterator,polyItr);
+ // Phase Three: Clssify each segment in the expanded line as to its
+ // clipping status relative to the polygon (i.e. inside, outside, or
+ // colinear with the boundary). Changes are made in place. This status
+ // is stored as a double in the Z element of the coordinate collection.
+ StringClipPhaseThree (pointIterator,polyItr);
+ // Phase Four: Construct a LineStringCollection in which each LineString
+ // represents a segment of the original line string which is inside of
+ // the provided polygon.
+ lineCollection = StringClipPhaseFour (pointIterator,includeCollinear,false);
+ // Looks pretty simple, maybe that means it will work good; often does.
+ return lineCollection.Detach ();
-/// <summary>
-/// Returns a collection of line strings which represents those portions of the
-/// provided line string which are inside of the provided closed ring. The null
-/// pointer is returned rather than an empty line string.
-/// </summary>
-MgLineStringCollection* MgSpatialUtility::ClipStringToPolygon (MgCoordinateIterator* polyItr,
- MgCoordinateIterator* lineItr)
+// Phase One: during a process of copying the points of the provided line
+// string coordinate collection (in the form of a MgCoordinateIterator)
+// insert points as necessary such that a point on the line string exists at
+// each and every possible transition point. A transition point is a location
+// on the line string where the state of the line string relative to the
+// provided polygon may change from one of three states to another. The three
+// states of interest are: OUSTSIDE the polygon, INSIDE the polygon, or
+// ON THE BOUNDARY defined by the polygon.
+// In this module we do not concern ourselves with the specific state which
+// exists at any specific point, but only making sure that a distinct point
+// exists at any point where a transition may occur. Care is taken to make
+// sure that degenerate line segments within the returned point collection are
+// not created.
+// To facilitate processing which is to be accomplished in phases two, three,
+// and four of the StingClip facility, the collection returned is a collection
+// of MgCoordinateXYZM objects. The Z and M coordinates of the coordinatess in
+// the returned collection will be used to convey status information about each
+// coordinate in the collection from one phase to another and in this manner
+// eliminate duplicate processing. When returned from this module, the Z and
+// M ordinates are set to zero (i.e. NotDetermined).
+MgCoordinateCollection* MgSpatialUtility::StringClipPhaseOne (MgCoordinateIterator* lineString,
+ MgCoordinateIterator* itrPolygon)
- bool inside;
+ bool collinear;
+ INT32 mask;
INT32 index;
+ INT32 count;
+ INT32 status;
+ INT32 insertIndex; // debuggin & testing only
+ INT32 segmentStatus;
+ INT32 collinearStatus;
- Ptr<MgCoordinate> lineFrom;
- Ptr<MgCoordinate> lineTo;
- Ptr<MgCoordinateCollection> curCollection;
- Ptr<MgLineStringCollection> lineCollection;
+ double magnitude;
- // Need to create an empty collections, the factory doesn't do this.
- curCollection = new MgCoordinateCollection ();
- lineCollection = new MgLineStringCollection ();
+ Ptr<MgCoordinate> segFromPoint;
+ Ptr<MgCoordinate> segToPoint;
+ Ptr<MgCoordinate> plyFromPoint;
+ Ptr<MgCoordinate> plyToPoint;
+ Ptr<MgCoordinate> xyzmPoint;
+ Ptr<MgCoordinateCollection> xyzmCollection; // The return value
- // Set up the line string iterator. It is the primary control loop
- // for this operation.
- lineItr->Reset ();
- lineItr->MoveNext ();
- lineTo = lineItr->GetCurrent ();
+ MgGeometryFactory mgFactory;
- // We need to know in what state we are starting in. lineTo currently
- // has the coordinates of the first point, which will become the
- // lineFrom point once the main loop gets started.
- inside = PointIsInPolygon (polyItr,lineTo);
+// TODO: Should throw an invalid argument exception if the provided
+// line sting collection is empty.
- // If we are starting inside the polgon, we push the first point
- // onto the current point collection.
- if (inside)
- curCollection->Add (lineTo);
+ // A value indicating the magnitude of the numbers we will be
+ // dealing with, SegmentIntersection needs to know this.
+ magnitude = GreatestMagnitude (itrPolygon);
- while (lineItr->MoveNext ())
+ // Construct the collection which we will return.
+ xyzmCollection = new MgCoordinateCollection ();
+ // Initialize the line string segment loop by getting the first point.
+ // This will be the "toPoint" in preparation for the segment loop
+ // established below.
+ lineString->Reset ();
+ lineString->MoveNext ();
+ segToPoint = lineString->GetCurrent ();
+ // Add the initial point to the collection which we will eventually return.
+ xyzmPoint = mgFactory.CreateCoordinateXYZM (segToPoint->GetX(),segToPoint->GetY(),
+ rStringPointNotDetermined,
+ rStringSegNotDetermined);
+ xyzmCollection->Add (xyzmPoint);
+ // Loop once for each segment in the line string.
+ while (lineString->MoveNext ())
- lineFrom = lineTo;
+ // We need a temporary collection so that we can assure that the
+ // intersection points are added to the collection we will be
+ // returning in the ciorrect order. Thus, we stash the intersections
+ // in the temporary in the proper order, and then add the ordered
+ // temporary to the collection we will return.
+ Ptr<MgCoordinateCollection> xyzmTemporary;
+ xyzmTemporary = new MgCoordinateCollection ();
- // Intersect this segment with the polygon.
- Ptr<MgCoordinateCollection> segCollection;
- segCollection = PolySegIntersection (polyItr,lineFrom,lineTo);
- INT32 segCount = segCollection->GetCount ();
+ // Get the current segment of the line string.
+ segFromPoint = segToPoint;
- // If the segment count is zero, there were no intersections. If we were
- // inside, we're still inside.
- if (segCount == 0)
+ // Initialize a loop of each segment in the polygon.
+ itrPolygon->Reset ();
+ itrPolygon->MoveNext ();
+ plyToPoint = itrPolygon->GetCurrent ();
+ while (itrPolygon->MoveNext ())
- if (inside)
+ // We need a place for SegementIntersection to place the
+ // calculated intersection. We can't add the transition
+ // points directly to the xyzmCollection object as in the
+ // case of more than one transition point for a segment,
+ // there is no guarantee that this algorithm will find them
+ // in the correct order. Therefore, we use the
+ // AddToCoordinateCollection method to add all transition
+ // points to the xyzmTemporary collection; and add the
+ // points in the temporary collection to the main collection
+ // after all transition points for this segment have been
+ // determined. AddToCoordinateCollection assures that
+ // transition points are properly ordered. To reduce the
+ // possibilty of memory leaks creeping tino the code, we
+ // create a new temporary collection on each iteration of
+ // this loop.
+ Ptr<MgCoordinate> intersection = new MgCoordinateXY ();
+ // We will add the termination point of this segment of the line
+ // string below. Thus, in this loop we are only interested in
+ // transition points which are not already points in the original
+ // line segment.
+ // Determine the end points of the polygon segment.
+ plyFromPoint = plyToPoint;
+ // Determine the relationship of the current line string segment
+ // with the current polygon segment.
+ status = SegmentIntersection (intersection,plyFromPoint,plyToPoint,segFromPoint,segToPoint,magnitude);
+ // Disect the large amount of information embedded in the
+ // status return.
+ segmentStatus = status & MgSpatialUtilityStatus::SegmentStatusMask;
+ collinearStatus = status & MgSpatialUtilityStatus::CollinearStatusMask;
+ collinear = (segmentStatus == MgSpatialUtilityStatus::SegmentsCollinear) && (collinearStatus != 0);
+ if (!collinear && (segmentStatus != 0))
+ // There is no intersection to deal with, collinearity excepted.
+ continue;
- else
- // There is at least one intersection, so there will some state changing going on here.
- for (index = 0;index < segCount;index += 1)
+ // If we are still here, we have an intersection point or a collinear
+ // segment overlap. In the normal case (i.e. not collinear) we are only
+ // interested in intersections where the intersection point resides on
+ // both segments.
+ mask = MgSpatialUtilityStatus::IntersectOnSeg1 | MgSpatialUtilityStatus::IntersectOnSeg2;
+ if ((status & mask) == mask && !collinear)
- Ptr<MgCoordinate> newPoint = segCollection->GetItem (index);
- // Terminate the current state, and initate the new state.
- // At this point, the state switches for each point in the
- // intersection list.
- if (inside)
+ // If the intersection point is precisely equal (ala DblCmp) to
+ // either of the end points of the line string segment, we skip
+ // this intersection as the point already exists in the line
+ // string, we do not need to add another.
+ // If the Intersection point is precisely equal to (ala DblCMp)
+ // the "To" point of the polygon segment, we also skip it.
+ // We'll catch it when it becomes the "From" point on the next
+ // iteration (to prevent adding points which produce degenerate
+ // segments).
+ mask = MgSpatialUtilityStatus::IntersectIsSeg2Start |
+ MgSpatialUtilityStatus::IntersectIsSeg2End |
+ MgSpatialUtilityStatus::IntersectIsSeg1End;
+ if ((status & mask) == 0)
- // We're inside. Switch to outside state. sewPoint is the
- // location where we left the inside of the polygon.
- curCollection->Add (newPoint);
+//TODO: A performance improvement is possibile here. Since this transition
+// point is an intersection point, we know it to reside on the boundary. We
+// could set the M value to indicate that and eliminate the need to determine
+// this point's status in Phase Two. We'll do this after we know all this
+// stuff to work reliably.
- // Make a line string out of the current point collection,
- // and add it to the line string collection which contains
- // the clipped segments.
- Ptr<MgLineString> newLineString = new MgLineString (curCollection);
- lineCollection->Add (newLineString);
+ // OK, we have a transition point to add to the line string.
+ xyzmPoint = mgFactory.CreateCoordinateXYZM (intersection->GetX(),intersection->GetY(),
- // Clear curCollection inpreparation for the nex segment if
- // there is one.
- curCollection->Clear ();
+ // The resulting point collection must contain the "transition points"
+ // in sequential order otherwise we can get zig-zags or changed directions
+ // in the clipped lines. This is what AddToCoordinateCollection
+ // does for us. The returned value is saved only for debugging
+ // convenience, it is the index at which the point was inserted.
+ insertIndex = AddToCoordinateCollection (xyzmTemporary,xyzmPoint,segFromPoint);
+ else if (collinear)
+ // We need to do something with collinear lines, sometimes. The rather
+ // verbose comments were necessary for the author to keep track of what
+ // can/might/could happen and what to do about each possible situation.
+ // The sixteen cases are:
+ // 0000 -> DO NOTHING!! There is no overlap, the segments are disjoint.
+ // 0001 -> DO NOTHING!! Not possible.
+ // 0010 -> DO NOTHING!! Not possible.
+ // 0011 -> DO NOTHING!! End to end continuous, but no overlap.
+ // 0100 -> DO NOTHING!! Not possible.
+ // 0101 -> Insert both segment 1 points, segment 1 _IS_ the ovelapping segment.
+ // 0110 -> Insert segment 1 end point, overlap ends at segment 1 end point.
+ // 0111 -> Insert segment 1 end point, overlap ends at segment 1 end point.
+ // 1000 -> DO NOTHING!! Not possible.
+ // 1001 -> Insert segment 1 start point, overlap beginns in the middle of segment 2.
+ // 1010 -> DO NOTHING!! Segment 2 is the overlap segment.
+ // 1011 -> DO NOTHING!! Segment 2 is the overlap segment.
+ // 1100 -> DO NOTHING!! End to end continuous, but no overlap.
+ // 1101 -> Insert segment 1 start point, overlap begins in the middle of segment 2.
+ // 1110 -> DO NOTHING!! Segment 2 is the overlap segment.
+ // 1111 -> DO NOTHING!! Segments are identical
+ static const INT32 seg1StartA = (MgSpatialUtilityStatus::CollinearSeg2End | MgSpatialUtilityStatus::CollinearSeg1Start); // 1001
+ static const INT32 seg1StartB = (MgSpatialUtilityStatus::CollinearSeg2End | MgSpatialUtilityStatus::CollinearSeg1End | MgSpatialUtilityStatus::CollinearSeg1Start); // 1101
+ static const INT32 seg1EndA = (MgSpatialUtilityStatus::CollinearSeg1End | MgSpatialUtilityStatus::CollinearSeg2Start); // 0110
+ static const INT32 seg1EndB = (MgSpatialUtilityStatus::CollinearSeg1End | MgSpatialUtilityStatus::CollinearSeg2Start | MgSpatialUtilityStatus::CollinearSeg1Start); // 0111
+ static const INT32 seg1Both = (MgSpatialUtilityStatus::CollinearSeg1End | MgSpatialUtilityStatus::CollinearSeg1Start); // 0101
- // We're outside of the polygon now.
- inside = false;
+ if (collinearStatus == seg1StartA || collinearStatus == seg1StartB || collinearStatus == seg1Both)
+ // Insert the polygon "From" point.
+ xyzmPoint = mgFactory.CreateCoordinateXYZM (plyFromPoint->GetX(),plyFromPoint->GetY(),
- else
+ if (collinearStatus == seg1EndA || collinearStatus == seg1EndB || collinearStatus == seg1Both)
- // We were outside the polgon. The intersection point
- // is the point at which we reenterd the polygon.
- // We're back inside now.
- inside = true;
+ // Insert the polygon "To" point.
+ xyzmPoint = mgFactory.CreateCoordinateXYZM (plyToPoint->GetX(),plyToPoint->GetY(),
+ // intersection variable should go out of scope and be deleted here.
- // At this point, if we end up inside, there will be a point in
- // curCollection which will be the point at which we re-entered
- // the last time. Since we are inside, we need to add the
- // lineTo point to the collection.
- if (inside)
+ // If we have some transitions, we copy them from the temporary
+ // collection to the collection we will return. They should be
+ // in the proper order.
+ count = xyzmTemporary->GetCount();
+ for (index = 0;index < count;index += 1)
+ Ptr<MgCoordinate> xyzmPointTmp = xyzmTemporary->GetItem (index);
+ xyzmCollection->Add (xyzmPointTmp);
+ // Add the line string segment end point.
+ // The xyzmTemporary collection should go out of scope and be deleted
+ // here.
+ // We're done. Return the collection. It should never be empty unless
+ // the provided line string collection is empty (or only one point).
+ return xyzmCollection.Detach ();
+// Phase Two: In this method, we classify each point in the provided
+// point collections as being outside, inside, or on the clip boundary.
+// The determination is stored in the M element of the internally
+// used MgCoordinateXYZM collection.
+void MgSpatialUtility::StringClipPhaseTwo (MgCoordinateIterator* lineString,
+ double rPointStatus;
+ Ptr<MgCoordinateXY> xyPoint = new MgCoordinateXY ();
+ // Compute an outpoint.
+ outPoint = MgSpatialUtility::PointOutsidePolygon (itrPolygon);
+ xyzmPoint = lineString->GetCurrent ();
+ rPointStatus = xyzmPoint->GetM ();
+ pointStatus = static_cast<INT32>(rPointStatus);
+ if (pointStatus == StringPointNotDetermined)
+ // The status has not been determined yet, so we do that now.
+ xyPoint->SetX(xyzmPoint->GetX());
+ xyPoint->SetY(xyzmPoint->GetY());
+ pointStatus = MgSpatialUtility::PointIsInPolygon (itrPolygon,outPoint,xyPoint);
+ switch (pointStatus) {
+ case MgSpatialUtilityStatus::PointIsOutside:
+ rPointStatus = static_cast<double>(StringPointOutside) + 0.01;
+ break;
+ case MgSpatialUtilityStatus::PointIsOnBoundary:
+ rPointStatus = static_cast<double>(StringPointOnBoundary) + 0.01;
+ break;
+ case MgSpatialUtilityStatus::PointIsInside:
+ rPointStatus = static_cast<double>(StringPointInside) + 0.01;
+ break;
+ default: // Shouldn't ever happen, for defensive purposes only.
+ rPointStatus = 0.0;
+ break;
+ xyzmPoint->SetM (rPointStatus);
+ return;
+// Phase Three: Based on the fact that all possible state transitions have
+// been eliminated from each line segemnt, and knowledge of the status of
+// each end point of each segment, we can now classify each segment of the
+// internally used MgCoordinateXYZM coordinate collection as being inside,
+// outside, or colinear with the clip boundary. The determined status is
+// stuffed in the Z member of the provided coordinate collection. The
+// status value so stored refers to the segment which starts at the point
+// in which the status is stored.
+void MgSpatialUtility::StringClipPhaseThree (MgCoordinateIterator* lineString,
+ INT32 segStatus;
+ INT32 currentStatus;
+ INT32 nextStatus;
+ INT32 midStatus;
+ double rSegStatus;
+ Ptr<MgCoordinate> xyPoint;
+ Ptr<MgCoordinate> currentPoint;
+ Ptr<MgCoordinate> nextPoint;
+ xyPoint = new MgCoordinateXY ();
+ nextPoint = lineString->GetCurrent ();
+ currentPoint = nextPoint;
+ currentStatus = static_cast<INT32>(currentPoint->GetM());
+ nextStatus = static_cast<INT32>(nextPoint->GetM());
+ segStatus = StringSegNotDetermined;
+ if (currentStatus == StringPointInside || nextStatus == StringPointInside)
+ // Since state transitions have been removed, the entire segment inside
+ // the clipping boundary if either end point is inside.
+ segStatus = StringSegInside;
+ else if (currentStatus == StringPointOutside || nextStatus == StringPointOutside)
+ // Since state transitions have been removed, the entire segment outside
+ // the clipping boundary if either end point is outside.
+ segStatus = StringSegOutside;
+ else
+ // Oops!!! both end points are on the boundary. Could be any one
+ // of the three states. Compute the midpoint of the segment and
+ // determine if it is outside, inside, or on the boundary.
+ double xx = 0.5 * (nextPoint->GetX () + currentPoint->GetX ());
+ double yy = 0.5 * (nextPoint->GetY () + currentPoint->GetY ());
+ xyPoint->SetX (xx);
+ xyPoint->SetY (yy);
+ // If we haven't done so already, compute the location of a point
+ // guaranteed to be outside the polygon.
+ if (!outPoint)
- // Now we do something which might appear strange: we leave the
- // curCollection object alone. In this manner, we should eliminate
- // a lot of contiguous line strings in the line string collection.
- // Hope it works out that way. It should, as if we are inside now,
- // the first point of the segment from the line string should also
- // be inside.
+ // Now we can determine the status of the midpoint relative to
+ // the polygon.
+ midStatus = MgSpatialUtility::PointIsInPolygon (itrPolygon,outPoint,xyPoint);
+ if (midStatus == MgSpatialUtilityStatus::PointIsInside)
+ // The mid point is inside, so the whole segment is inside.
+ else if (midStatus == MgSpatialUtilityStatus::PointIsOutside)
+ // The mid point is outside, so the whole segment is outside.
+ else // if (midStatus == MgSpatialUtilityStatus::PointIsOnBoundary)
+ // The mid point is on the boundary, so the whole segment is
+ // outside.collinear with the boundary.
+ segStatus = StringSegCollinear;
+ rSegStatus = static_cast<double>(segStatus) + 0.01;
+ currentPoint->SetZ (rSegStatus);
- // If we ended this mess in the inside state, curCollection should _NOT_ be
- // empty. In this case, we need to add this final point collection as the
- // final line string in the line string collection.
- if (inside)
+// Phase Four: We construct a collection of line strings from the internally
+// used MgCoordinateXYZM collection. We collect as a member line string all
+// contiguous segments classified as being inside the clipping boundary.
+// Normally, a segment which is collinear with the boundary is considered to
+// be outside the clipping boundary and is not included in any linestring.
+// This behavior can be changed by providing a 'true' value for the collinear
+// argument.
+// This function normally returns a collection of lines generated from those
+// line segments which are inside of the clipping boundary. Set the outside
+// argument to 'true' to reverse this normal behavior.
+MgLineStringCollection* MgSpatialUtility::StringClipPhaseFour (MgCoordinateIterator* lineString,
+ bool collinear,
+ bool outside)
+ bool copy; // true if current segment is to be included in result
+ INT32 status;
+ Ptr<MgCoordinateCollection> curCollection;
+ curCollection = new MgCoordinateCollection ();
+ lineCollection = new MgLineStringCollection ();
+ lineString->MoveNext();
+ status = static_cast<INT32>(currentPoint->GetZ());
+ copy = outside ? (status == StringSegOutside) : (status == StringSegInside);
+ copy |= (collinear && (status == StringSegCollinear));
+ if (copy)
+ if (curCollection->GetCount () == 0)
+ // We haven't started a current line string yet, so we do so
+ // now.
+ xyPoint = mgFactory.CreateCoordinateXY (currentPoint->GetX (),currentPoint->GetY ());
+ curCollection->Add (xyPoint);
+ // Add the end point of the current segment to the cuirrent line
+ // string.
+ xyPoint = mgFactory.CreateCoordinateXY (nextPoint->GetX (),nextPoint->GetY ());
+ else if (curCollection->GetCount () != 0)
+ // We are not to copy this segment. If we have collected a line
+ // string with segments to be copied, we finish this line string
+ /// and add it to the collection which we will return.
+ Ptr<MgLineString> newLineString = new MgLineString (curCollection);
+ lineCollection->Add (newLineString);
+ // Prepare for the possible creation of yet another line string.
+ curCollection->Clear ();
- // Release the LineStringCollection object if it is empty.
- if (lineCollection->GetCount () == 0)
+ // If curCollection has some points in it, need to add that
+ // partial line to the line string collection.
+ if (curCollection->GetCount () != 0)
- lineCollection = 0;
- // Looks pretty simple, maybe that means it will work good; often does.
Modified: trunk/MgDev/Common/Geometry/Spatial/SpatialUtility.h
--- trunk/MgDev/Common/Geometry/Spatial/SpatialUtility.h 2010-02-28 15:08:17 UTC (rev 4611)
+++ trunk/MgDev/Common/Geometry/Spatial/SpatialUtility.h 2010-03-02 23:27:26 UTC (rev 4612)
@@ -111,39 +111,55 @@
/// <summary>
+ /// Extracts the greatest magnitude of the all the coordinates in a
+ /// coordinate collection. Return value is always positive.
+ /// </summary>
+ /// <param name="coordinteIterator">
+ /// An iterator dervied from the target coordinate collection.
+ /// </param>
+ /// <returns>
+ /// Returns a positive value which is the largest magnitude of all
+ /// ordinates in the collection.
+ /// </returns>
+ /// <remarks>
+ /// Intended to be used to determine a suitable tolerance value for such
+ /// things as coordinate comparisons.
+ /// </remarks>
+ static double GreatestMagnitude (MgCoordinateIterator* coordinateIterator);
+ /// <summary>
/// Computes the intersection of two 2D line segments. Intersection point,
/// if any, is returned in the provided result coordinate which (of course)
- /// must already exist.
+ /// must already exist. All point arguments are expected (not required)
+ /// to be MgCoordinateXY objects.
/// </summary>
/// <param name="result">
/// The calculated intersection point is returned in this variable which,
- /// of course, must exist.
+ /// of course, must exist. Coordinates of <c>result</c> remain unaltered
+ /// if an intersection does not exist. Only X and Y are returned.
+ /// </param>
/// <param name="seg1From">
/// The initial point of the first line segment.
+ /// </param>
/// <param name="seg1To">
/// The end point of the first line segment.
+ /// </param>
/// <param name="seg2From">
/// The initial point of the second line segment.
+ /// </param>
/// <param name="seg2To">
/// The end point of the second line segment.
+ /// </param>
+ /// <param name="magnitude">
+ /// A value which represents the greatest coordinate value in the dataset
+ /// being processed. Used to calculate an appropriate "fuzzy" value for
+ /// coordinate comparisions, etc.
+ /// </param>
/// <returns>
- /// Return status:
- /// <list type="table">
- /// <listheader>
- /// <term>Status</term>
- /// <description>Meaning</description>
- /// </listheader>
- /// <item>
- /// <term>-1</term>
- /// <description>no intersection, segments are parallel or collinear or
- /// a segemnt is of zero length; result remains unchanged
- /// </description>
- /// </item>
- /// <item><term> 0</term><desription>intersection exists, intersection point is not on either line</description></item>
- /// <item><term> 1</term><desription>intersection exists, intersection point is on segment 1 only</description></item>
- /// <item><term> 2</term><desription>intersection exists, intersection point is on segment 2 only</description></item>
- /// <item><term> 3</term><desription>intersection exists, intersection point is on both segments</description></item>
- /// </list>
+ /// Return status of the intersection of the two segments as a bit map of
+ /// values as defined in <c>SpatialUtilityStatus.h</c>
+ /// </returns>
/// <remarks>
/// In determining if the intersection point resides on a line, an intersection
/// point identical to the 'to' point is considered on the line, but an
@@ -158,7 +174,8 @@
static INT32 SegmentIntersection (MgCoordinate* result,MgCoordinate* seg1From,
- MgCoordinate* seg2To);
+ double magnitude = 1.0E+10);
/// <summary>
@@ -178,26 +195,23 @@
/// closed ring.
/// </param>
/// <returns>
- /// A 2D coordinate collection of all intersection points; can and often is
- /// an empty collection.
+ /// A new collection of <c>MgCoordinateXYM</c> points, one such point for each
+ /// intersection is returned. This collection can be, and often is, an empty
+ /// collection. A null pointer is never returned.<para>
+ /// The X and Y ordinates of each point in the returned collection represent
+ /// the actual location of the intersection. The M ordinate will carry, as
+ /// a double, the status of the intersection as returned by the
+ /// <c>SegmentIntersection</c> function.
/// </returns>
- /// <remarks>
- /// This is a 2D function only, Z and M coordinates are ignored; the returned
- /// point collection is a collection of <c>MgCoordinateXY</c> objects.<para>
- /// Note that the first argument is a CoordinateIterator; so it doesn't have to be
- /// an <c>MgPolygon</c>. However, this function assumes that the iterator does indeed
- /// point to a closed ring.
- /// </remarks>
static MgCoordinateCollection* PolySegIntersection (MgCoordinateIterator* polyItr,
MgCoordinate* segTo);
/// <summary>
/// Adds a coordinate to a coordinate collection such that the resulting
/// collection represents a collection of points in sequence from the
- /// [rpvoded base point.
+ /// provided base point.
/// </summary>
/// <param name="collection">
/// The coordinate collection to which the <c>newPoint</c> is to be added.
@@ -212,23 +226,25 @@
/// the index at which the insertion occurred.
/// </returns>
/// <remarks>
- /// This is a 2D function only, Z and M coordinates are ignored; the provided
- /// point collection is expected to be a collection of <c>MgCoordinateXY</c> objects.<para>
/// The purpose of this function is serve as a helper for the PolySegIntersection
/// function. It enables PolySegIntersection to return a point collection such
/// that the points in the collection present an orderly sequence of points from
/// the provided base point. Thus, if the original line segment provided to
/// PolySegIntersection proceeded in the south to north direction, the point
/// collection returned would also be returned in that order; regardless of the
- /// shape of the polygon or the direction in which it proceeds.
+ /// shape of the polygon or the direction in which it proceeds.<para>
+ /// The determination as to the insertion point of <c>newPoint</c> is based solely
+ /// on the X and Y ordinates of <c>newPoint</c> and the points which already
+ /// exist in the provided collection. The type of <c>newPoint</c> and the points
+ /// in the collection is immaterial.
/// </remarks>
static INT32 AddToCoordinateCollection (MgCoordinateCollection* collection,MgCoordinate* newPoint,
- MgCoordinate* basePoint);
+ MgCoordinate* basePoint);
/// <summary>
/// Determines if the provided point is inside (or actually on) the closed
- /// ring provided bythe polyItr argument.
+ /// ring provided by the <c>polyItr</c> argument.
/// </summary>
/// <param name="polyItr">
/// An iterator of the closed ring which is the subject polygon.
@@ -237,22 +253,63 @@
/// The 2D point whose status is to be determined.
/// </param>
/// <returns>
- /// Returns true if the query point is inside or on the provided closed
- /// ring.
+ /// Returns zero if the query point is outside the closed ring, +1 if the
+ /// query point is precisely on the closed ring (per MgMathUtility::DblCmp),
+ /// or +2 if the query point is inside the closed ring.
/// </returns>
/// <remarks>
/// Currently, this function calculates the envelope of the provided closed
/// ring in order to determine a point which is known to be outside of the
/// closed ring. An overloaded function which accepts a point known to be
- /// outside the closed ring would be a lot faster.
+ /// outside the closed ring which is a lot faster is also available.
/// </remarks>
- static bool PointIsInPolygon (MgCoordinateIterator* polyItr,MgCoordinate* queryPoint);
+ static INT32 PointIsInPolygon (MgCoordinateIterator* polyItr,MgCoordinate* queryPoint);
/// <summary>
+ /// Determines a point guaranteed to be ouside the provided polygon.
+ /// </summary>
+ /// <param name="polyItr">
+ /// An iterator of the closed ring which is the subject polygon.
+ /// </param>
+ /// <returns>
+ /// Returns an <c>MgCoordinateXY</c> point which is guaranteed to be ooutside
+ /// the provided polygon.
+ /// </returns>
+ static MgCoordinate* MgSpatialUtility::PointOutsidePolygon (MgCoordinateIterator* polyItr);
+ /// <summary>
+ /// Determines if the provided point is inside (or actually on) the closed
+ /// </summary>
+ /// </param>
+ /// <param name="outsidePoint">
+ /// A 2D point which is known to be outside of the provided polygon. Can
+ /// be obtained from <c>PointOutsidePolygon</c>.
+ /// <param name="queryPoint">
+ /// The 2D point whose status is to be determined.
+ /// </param>
+ /// <returns>
+ /// </returns>
+ /// <remarks>
+ /// This function requires that the calling module supply a point known to
+ /// be outside the polygon. Thus, higher performance can be obtained when
+ /// multiple queries against the same polygon are required.
+ /// </remarks>
+ static INT32 PointIsInPolygon (MgCoordinateIterator* polyItr,MgCoordinate* outsidePoint,
+ MgCoordinate* queryPoint);
+ /// <summary>
/// Clips a line string to an arbitrary polygon returning a collection of line
- /// strings which represent the portions of the the provided line string which
- /// are inside the provided closed ring.
+ /// strings which represent the portions of the provided line string which are
+ /// inside the provided closed ring.
/// </summary>
/// An iterator to the closed ring to which the provided line string is to be
@@ -261,18 +318,22 @@
/// <param name="lineItr">
/// An iterator for the line string which is to be clipped.
/// </param>
+ /// <param name="includeCollinear">
+ /// A true value indicates that segments, and/or portions of segments,
+ /// of the line string to be clipped which are collinear with the clipping
+ /// boundary are to be considered to be inside the clipping boundary. A
+ /// false value causes collinear segments (or portions thereof) to be
+ /// outside the clipping boundary and thus excluded from the returned
+ /// line string collection.
+ /// </param>
/// <returns>
/// A collection of line string objects which represents the portions of the
/// provided line string which are inside of the provided closed ring. This
- /// collection may be empty.
+ /// collection may be empty; a null pointer is never returned.
/// </returns>
- /// <remarks>
- /// This is a pure 2D function. The line strings generated will contain
- /// collections of <c>MgCoordinateXY</c> objects.
- /// </remarks>
static MgLineStringCollection* ClipStringToPolygon (MgCoordinateIterator* polyItr,
- MgCoordinateIterator* lineItr);
+ bool includeCollinear = false);
protected:
MgSpatialUtility() {};
@@ -287,6 +348,29 @@
static void AppendPositionsToDistinctCollection(
MgCoordinateCollection * distinctPositions,
MgCoordinateCollection * positionsToAppend);
+ // Values which are stored in the M member of the internally used point
+ // collection; i.e. the status of each point relative to the clip ploygon.
+ static const INT32 StringPointNotDetermined = 0;
+ static const INT32 StringPointIsOutside = 1;
+ static const INT32 StringPointIsOnBoundary = 2;
+ static const INT32 StringPointIsInside = 3;
+ // Values which are stored in the Z member of the internally used point
+ // collection; i.e. the status of each segment relative to the clip
+ // ploygon. The value stored refers to the segment which starts at
+ // the point in which the segment status is stored.
+ static const INT32 StringSegNotDetermined = 0;
+ static const INT32 StringSegIsOutside = 1;
+ static const INT32 StringSegIsCollinear = 2;
+ static const INT32 StringSegIsInside = 3;
+ static MgCoordinateCollection* StringClipPhaseOne (MgCoordinateIterator* lineString,
+ MgCoordinateIterator* itrPolygon);
+ static void StringClipPhaseTwo (MgCoordinateIterator* lineString,MgCoordinateIterator* itrPolygon);
+ static void StringClipPhaseThree (MgCoordinateIterator* lineString,MgCoordinateIterator* itrPolygon);
+ static MgLineStringCollection* StringClipPhaseFour (MgCoordinateIterator* lineString,bool collinear = false,
+ bool outside = false);
/// \endcond
More information about the mapguide-commits
