[mapguide-commits] r4613 - trunk/MgDev/Common/Geometry/Spatial
svn_mapguide at osgeo.org
Tue Mar 2 18:29:33 EST 2010
Author: NormOlsen
Date: 2010-03-02 18:29:33 -0500 (Tue, 02 Mar 2010)
New Revision: 4613
Added:
trunk/MgDev/Common/Geometry/Spatial/SpatialUtilityStatus.h
MapGuide Trac Ticket 1253 -- Oops!!! For got to add the new header file.
This submission replaces the previous line string to arbitrary polygon clipper in its entirety. The clipper is now a four phase process and where each phase is implemented as an internally referenced methods. The new clipping algorithms correct problems related to coordinates with hard core 0.0 values, line string points which coincide with the clipping boundary, and the effect of line string segments which are collinear with (and overlap) clipping boundary segments. To accomplish this, the intelligence of the SegmentIntersection method has been improve significantly.
The submission includes a new header file (SpatialUtilityStatus.h) in which the status return values of various methods has been defined and documented.
Added: trunk/MgDev/Common/Geometry/Spatial/SpatialUtilityStatus.h
--- trunk/MgDev/Common/Geometry/Spatial/SpatialUtilityStatus.h (rev 0)
+++ trunk/MgDev/Common/Geometry/Spatial/SpatialUtilityStatus.h 2010-03-02 23:29:33 UTC (rev 4613)
@@ -0,0 +1,183 @@
+// Copyright (C) 2004-2010 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#ifndef MgSpatialUtilityStatusValues_H
+#define MgSpatialUtilityStatusValues_H
+/// \cond INTERNAL
+/// \brief
+/// Spatial Utility Status Values.
+/// \brief
+/// Defines the status values returned by various methods belonging to the
+/// MgSpatialUtility class.
+class MG_GEOMETRY_API MgSpatialUtilityStatus
+public:
+ // Intersection status is returned as a bit map. The bit map
+ // consists of four sub bit maps, we'll call them groups.
+ // Group 1 -> Segment Status
+ // If any bits in this group are set, an intersection point
+ // does not exist. If all bits in this group are zero, an
+ // intersection does exists and the point is returned.
+ // Group 2 -> Intersection Status
+ // The bits in this group indicate if the intersection point
+ // resides on weither (or both) segments.
+ // Group 3 -> Intersection Point Status
+ // The bits in this group indicate the intersection points
+ // relationship to the end points of the two segments.
+ // Group 4 -> Collinear Segment Status
+ // In the case of collinear segments, the bits in this
+ // section indicate to what extent the collinear lines
+ // actually overlap.
+ /// \brief
+ /// This constant defines the significance of a specific a
+ /// bit in the bit map returned by the SegmentIntersection.
+ /// Set if the segments are parallel but _NOT_ collinear.
+ static const INT32 SegmentsParallel = 0x0010;
+ /// \brief
+ /// Set only if the segments are collinear.
+ static const INT32 SegmentsCollinear = 0x0020;
+ /// \brief
+ /// Set if segment one is a null segement.
+ static const INT32 DegenerateSeg1 = 0x0040;
+ /// \brief
+ /// Set if segment two is a null segement.
+ static const INT32 DegenerateSeg2 = 0x0080;
+ /// \brief
+ /// Set if the intersection point resides on segment one, end
+ /// points included.
+ static const INT32 IntersectOnSeg1 = 0x0001;
+ /// \brief
+ /// The intersection point resides on segment two, end
+ static const INT32 IntersectOnSeg2 = 0x0002;
+ // Group Three -> Intersection Point Status
+ /// \brief
+ /// Intersection at segment 1 start point
+ static const INT32 IntersectIsSeg1Start = 0x0100;
+ /// \brief
+ /// Intersection at segment 1 end point
+ static const INT32 IntersectIsSeg1End = 0x0200;
+ /// \brief
+ /// Intersection at segment 2 start point
+ static const INT32 IntersectIsSeg2Start = 0x0400;
+ /// \brief
+ /// Intersection at segment 2 end point
+ static const INT32 IntersectIsSeg2End = 0x0800;
+ // Group 4 -> Collinear Status
+ // Note that in the case where there is no overlap of the
+ // collinear lines, all four of these bits will be zero.
+ // In the case of overlap, at least two of these bits must be
+ // set; one indicating the start position of the overlap and
+ // one indicating the end position of the overlap. It is
+ // (actually) possible for just one bit to be set, indicating that
+ // the end of one segment is the beginning of the other.
+ /// \brief
+ /// This bit is set if the segments are collinear, there is
+ /// segment overlap, and the overlapping portion starts at the
+ /// initial point of segment 1.
+ static const INT32 CollinearSeg1Start = 0x1000;
+ /// \brief
+ /// initial point of segment 2.
+ static const INT32 CollinearSeg2Start = 0x2000;
+ /// \brief
+ /// segment overlap, and the overlapping portion ends at the
+ /// end point of segment 1.
+ static const INT32 CollinearSeg1End = 0x4000;
+ /// \brief
+ /// end point of segment 2.
+ static const INT32 CollinearSeg2End = 0x8000;
+ /// \brief
+ /// A mask for testing for extracting Segment Status from the
+ /// bit map returned by the SegmentIntersection method.
+ static const INT32 SegmentStatusMask = SegmentsParallel |
+ SegmentsCollinear |
+ DegenerateSeg1 |
+ DegenerateSeg2;
+ /// \brief
+ /// A mask for testing for extracting Collinear Status from
+ /// the bit map returned by the SegmentIntersection method.
+ static const INT32 CollinearStatusMask = CollinearSeg1Start |
+ CollinearSeg1End |
+ CollinearSeg2Start |
+ CollinearSeg2End;
+ /// \brief
+ /// Value returned by the PointIsInPolygon method when the quesry point is
+ /// outside of the provided polygon (outer ring only).
+ static const INT32 PointIsOutside = 0;
+ /// \brief
+ static const INT32 PointIsOnBoundary = 1;
+ /// \brief
+ static const INT32 PointIsInside = 2;
+#endif //_MGCOORDINATESYSTEMTYPE_H_
More information about the mapguide-commits
