[mapguide-commits] r4630 - in trunk/Tools/Maestro:
Maestro/ResourceEditors MaestroAPI
svn_mapguide at osgeo.org
Thu Mar 4 12:03:42 EST 2010
Author: ksgeograf
Date: 2010-03-04 12:03:41 -0500 (Thu, 04 Mar 2010)
New Revision: 4630
trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditor.cs
trunk/Tools/Maestro/MaestroAPI/Selection.cs
Maestro:
Removed redundant code in the LayerEditor for reading extents.
Fixed a bug in the constructor for the runtime map selection.
Added an override to the ToString() method the runtime map selection so it behaves like ToXml().
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditor.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditor.cs 2010-03-04 02:36:52 UTC (rev 4629)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditor.cs 2010-03-04 17:03:41 UTC (rev 4630)
@@ -491,26 +491,16 @@
try
- Topology.Geometries.IEnvelope env = m_layer.GetSpatialExtent();
+ Topology.Geometries.IEnvelope env = m_layer.GetSpatialExtent(true);
map.Extents = new OSGeo.MapGuide.MaestroAPI.Box2DType();
map.Extents.MinX = env.MinX;
map.Extents.MinY = env.MinY;
map.Extents.MaxX = env.MaxX;
map.Extents.MaxY = env.MaxY;
- catch
+ catch (Exception ex)
- OSGeo.MapGuide.MaestroAPI.FdoSpatialContextList lst = m_editor.CurrentConnection.GetSpatialContextInfo(m_layer.Item.ResourceId, false);
- if (lst.SpatialContext != null && lst.SpatialContext.Count >= 1)
- map.Extents = new OSGeo.MapGuide.MaestroAPI.Box2DType();
- map.Extents.MinX = double.Parse(lst.SpatialContext[0].Extent.LowerLeftCoordinate.X, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture);
- map.Extents.MinY = double.Parse(lst.SpatialContext[0].Extent.LowerLeftCoordinate.Y, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture); ;
- map.Extents.MaxX = double.Parse(lst.SpatialContext[0].Extent.UpperRightCoordinate.X, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture); ;
- map.Extents.MaxY = double.Parse(lst.SpatialContext[0].Extent.UpperRightCoordinate.Y, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture); ;
+ m_editor.SetLastException(ex);
MaestroAPI.MapLayerType l = new OSGeo.MapGuide.MaestroAPI.MapLayerType();
Modified: trunk/Tools/Maestro/MaestroAPI/Selection.cs
--- trunk/Tools/Maestro/MaestroAPI/Selection.cs 2010-03-04 02:36:52 UTC (rev 4629)
+++ trunk/Tools/Maestro/MaestroAPI/Selection.cs 2010-03-04 17:03:41 UTC (rev 4630)
@@ -30,6 +30,7 @@
public Selection(RuntimeClasses.RuntimeMap map, string xml)
: this(map)
+ FromXml(xml);
/// <summary>
@@ -93,6 +94,15 @@
/// <summary>
+ /// Returns the selection Xml, the same as ToXml()
+ /// </summary>
+ /// <returns>The selection xml</returns>
+ public override string ToString()
+ return ToXml();
+ /// <summary>
/// Helper class to represent a layer with selected objects
/// </summary>
public class LayerSelection : IList<object[]>
More information about the mapguide-commits
