[mapguide-commits] r4631 - in trunk/MgDev/Web/src: localized mapviewerjava mapviewernet mapviewerphp stdicons viewerfiles
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Mar 5 00:55:14 EST 2010
Author: liuar
Date: 2010-03-05 00:55:13 -0500 (Fri, 05 Mar 2010)
New Revision: 4631
Added:
   trunk/MgDev/Web/src/stdicons/openButton.gif
   trunk/MgDev/Web/src/localized/en
   trunk/MgDev/Web/src/mapviewerjava/toolbar.jsp
   trunk/MgDev/Web/src/mapviewernet/toolbar.aspx
   trunk/MgDev/Web/src/mapviewerphp/toolbar.php
   trunk/MgDev/Web/src/viewerfiles/mainframe.templ
   trunk/MgDev/Web/src/viewerfiles/taskbar.templ
   trunk/MgDev/Web/src/viewerfiles/toolbar.templ
   trunk/MgDev/Web/src/viewerfiles/viewer.css
Ticket #1288 MapGuide Enhancement "Add an ?\226?\128?\156Open Task pane?\226?\128?\157 Button for MGE Basic Web Layout"
Modified: trunk/MgDev/Web/src/localized/en
--- trunk/MgDev/Web/src/localized/en	2010-03-04 17:03:41 UTC (rev 4630)
+++ trunk/MgDev/Web/src/localized/en	2010-03-05 05:55:13 UTC (rev 4631)
@@ -193,9 +193,11 @@
 # Task Bar
 TASKS                   = Tasks
-TASKBARCLOSEBUTTONTEXT  = Close the task bar
-TASKBARCLOSEBUTTONDESC  = Close the task bar
+TASKBARCLOSEBUTTONTEXT  = Close the task pane
+TASKBARCLOSEBUTTONDESC  = Close the task pane
 TASKBARCLOSEBUTTONICON  = ../stdicons/closeButton.gif
+TASKBAROPENBUTTONTEXT   = Open the task pane
+TASKBAROPENBUTTONDESC   = Open the task pane
 # Viewer Options
 OPTIONSTITLE            = Viewer Options
Modified: trunk/MgDev/Web/src/mapviewerjava/toolbar.jsp
--- trunk/MgDev/Web/src/mapviewerjava/toolbar.jsp	2010-03-04 17:03:41 UTC (rev 4630)
+++ trunk/MgDev/Web/src/mapviewerjava/toolbar.jsp	2010-03-05 05:55:13 UTC (rev 4631)
@@ -23,8 +23,24 @@
 <%@ page import="javax.servlet.http.*" %>
 <%@ include file="common.jsp" %>
+String locale;
+    locale = "";
     response.setContentType("text/html; charset=UTF-8");
     request.setCharacterEncoding("UTF-8");
-    response.getWriter().write(LoadTemplate("/viewerfiles/toolbar.templ"));
+    MgLocalizer.SetLocalizedFilesPath(getServletContext().getRealPath("/") + "localized/");
+    GetRequestParameters(request);
+    response.getWriter().write(MgLocalizer.Localize(LoadTemplate("/viewerfiles/toolbar.templ"), locale, GetClientOS(request)));
+void GetRequestParameters(HttpServletRequest request)
+    locale = GetParameter(request, "LOCALE");
Modified: trunk/MgDev/Web/src/mapviewernet/toolbar.aspx
--- trunk/MgDev/Web/src/mapviewernet/toolbar.aspx	2010-03-04 17:03:41 UTC (rev 4630)
+++ trunk/MgDev/Web/src/mapviewernet/toolbar.aspx	2010-03-05 05:55:13 UTC (rev 4631)
@@ -17,10 +17,36 @@
 <%@ Page language="c#" %>
 <%@ Import Namespace="System" %>
 <%@ Import Namespace="System.IO" %>
+<%@ Import Namespace="OSGeo.MapGuide" %>
 <!-- #Include File="common.aspx -->
+<script runat="server">
+String locale;
+</script>
+    locale = "";
     Response.Charset = "utf-8";
-    Response.Write(LoadTemplate(Request, "../viewerfiles/toolbar.templ"));
+    GetRequestParameters();
+    MgLocalizer.SetLocalizedFilesPath(Request.ServerVariables["APPL_PHYSICAL_PATH"] + "..\\localized\\");
+    Response.Write(MgLocalizer.Localize(LoadTemplate(Request, "../viewerfiles/toolbar.templ"), locale, GetClientOS(Request)));
+void GetRequestParameters()
+    if (Request.HttpMethod == "POST")
+        GetParameters(Request.Form);
+    else
+        GetParameters(Request.QueryString);
+void GetParameters(NameValueCollection parameters)
+    locale = GetParameter(parameters, "LOCALE");
+</script>
Modified: trunk/MgDev/Web/src/mapviewerphp/toolbar.php
--- trunk/MgDev/Web/src/mapviewerphp/toolbar.php	2010-03-04 17:03:41 UTC (rev 4630)
+++ trunk/MgDev/Web/src/mapviewerphp/toolbar.php	2010-03-05 05:55:13 UTC (rev 4631)
@@ -17,6 +17,13 @@
 //  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+    include 'common.php';
+    $locale = "";
+    SetLocalizedFilesPath(GetLocalizationPath());
     // pass diferent button height depending on the browser
     // to achieve a similar rendering, as there is no cross-browser conditional CSS
@@ -28,7 +35,23 @@
     // return the HTML template
-    $templ = file_get_contents("../viewerfiles/toolbar.templ");
+    $templ = Localize(file_get_contents("../viewerfiles/toolbar.templ"), $locale, GetClientOS());
     printf($templ, $btnHeight);
+function GetParameters($params)
+    global $locale;
+    if(isset($params['LOCALE']))
+        $locale = $params['LOCALE'];
+function GetRequestParameters()
+    if($_SERVER['REQUEST_METHOD'] == "POST")
+        GetParameters($_POST);
+    else
+        GetParameters($_GET);
Added: trunk/MgDev/Web/src/stdicons/openButton.gif
(Binary files differ)
Property changes on: trunk/MgDev/Web/src/stdicons/openButton.gif
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: trunk/MgDev/Web/src/viewerfiles/mainframe.templ
--- trunk/MgDev/Web/src/viewerfiles/mainframe.templ	2010-03-04 17:03:41 UTC (rev 4630)
+++ trunk/MgDev/Web/src/viewerfiles/mainframe.templ	2010-03-05 05:55:13 UTC (rev 4631)
@@ -180,11 +180,12 @@
         if(orgTaskBarWidth == -1)
-            orgTaskBarWidth = mainappFrame.cols;
+            orgTaskBarWidth = mainappFrame.cols.substring(2);;
         if(width != -1)
-            mainappFrame.cols = width;
+            mainappFrame.cols = "*," + width;
Modified: trunk/MgDev/Web/src/viewerfiles/taskbar.templ
--- trunk/MgDev/Web/src/viewerfiles/taskbar.templ	2010-03-04 17:03:41 UTC (rev 4630)
+++ trunk/MgDev/Web/src/viewerfiles/taskbar.templ	2010-03-05 05:55:13 UTC (rev 4631)
@@ -149,6 +149,21 @@
     active = eltId;
+function CloseTaskPane()
+    var tbframe = parent.frames["tbFrame"];
+    var openTaskbarBtn = tbframe.document.getElementById("divOpenTaskbarBtn");
+    if(openTaskbarBtn != null)
+        openTaskbarBtn.style.display='block';
+    var divRefresh = tbframe.document.getElementById("divRefresh");
+    divRefresh.className = "cssRefreshWithOpenBtn";
+    parent.CloseTaskBar();
 function OpenTaskMenu()
     try
@@ -182,7 +197,7 @@
     <table height=30 border=0 cellpadding=0 cellspacing=0>
         <tr height=30>
           <td align=center valign=center>
-            <span class="btn" id="btnClose" style="position: absolute; left: 5px;" onmouseover="HoverButton('btnClose', '')" onmouseout="LeaveButton('btnClose', '')" onclick="parent.CloseTaskBar()">
+            <span class="btn" id="btnClose" style="position: absolute; left: 5px;" onmouseover="HoverButton('btnClose', '')" onmouseout="LeaveButton('btnClose', '')" onclick="CloseTaskPane()">
               <img class="btnImg" id="imgClose" title="" src="../stdicons/transparentpixel.gif" width=16 height=16>
             </span>
           </td>
Modified: trunk/MgDev/Web/src/viewerfiles/toolbar.templ
--- trunk/MgDev/Web/src/viewerfiles/toolbar.templ	2010-03-04 17:03:41 UTC (rev 4630)
+++ trunk/MgDev/Web/src/viewerfiles/toolbar.templ	2010-03-05 05:55:13 UTC (rev 4631)
@@ -30,11 +30,17 @@
         /* font-family: __#@font#__; */
         /* font-size: __#@fontsize#__; */
-    div.cssRefresh
+    div.cssOpenTaskbarBtn
         position: absolute;
-        right:10px;
-        top:4px;
+        right:5px;
+        top:3px;
+        width: 26;
+        height:25;
+        border-width: 1px;
+        border-style: solid;
+        border-color: #f0f0f0;
+        cursor: pointer;
 </style>
@@ -108,7 +114,11 @@
     document.getElementById(eltId).style.border = "solid #a0a0a0 1px";
     hovered = eltId;
-    parent.SetStatusMsg(cmdId!=null? parent.commands[cmdId].description: '');
+    if(eltId == 'divOpenTaskbarBtn')
+        parent.SetStatusMsg("__#TASKBAROPENBUTTONDESC#__");
+    else
+        parent.SetStatusMsg(cmdId!=null? parent.commands[cmdId].description: '');
 function LeaveButton(eltId)
@@ -147,6 +157,20 @@
     active = eltId;
+function OpenTaskPane()
+    var openTaskbarBtn = document.getElementById("divOpenTaskbarBtn");
+        openTaskbarBtn.style.display='none';
+    var divRefresh = document.getElementById("divRefresh");
+    divRefresh.className = "cssRefresh";
+    parent.OpenTaskBar();
 function ExecuteCommand(index, toggle, eltId)
     parent.ExecuteCommand(index);
@@ -245,6 +269,9 @@
     <div id="divRefresh" name="divRefresh" class="cssRefresh" style="display:none;">
         <img alt="loading" src="../stdicons/icon_loading.gif">
     </div>
+    <div id="divOpenTaskbarBtn" name="divOpenTaskbarBtn" class="cssOpenTaskbarBtn" style="display:none;" onmouseover="HoverButton('divOpenTaskbarBtn', null)" onmouseout="LeaveButton('divOpenTaskbarBtn')" onclick="OpenTaskPane()">
+        <img id="imgOpen" title="__#TASKBAROPENBUTTONTEXT#__" src="../stdicons/openButton.gif" style="margin: 4px 0px 0px 5px;" width=16 height=16>
+    </div>
     <span id="ToolbarContent">
     </span>
     <div class="TextMetricsDiv" id="TextMetricsDiv">
Modified: trunk/MgDev/Web/src/viewerfiles/viewer.css
--- trunk/MgDev/Web/src/viewerfiles/viewer.css	2010-03-04 17:03:41 UTC (rev 4630)
+++ trunk/MgDev/Web/src/viewerfiles/viewer.css	2010-03-05 05:55:13 UTC (rev 4631)
@@ -97,7 +97,18 @@
     position: absolute;
     top: 50px;
+div.cssRefresh
+    position: absolute;
+    right:10px;
+    top:8px;
+div.cssRefreshWithOpenBtn
+    right:35px;
+    top:8px;
    Statusbar styles
More information about the mapguide-commits mailing list
