[mapguide-commits] r4658 - in sandbox/rfc71: localized mapviewerphp
viewerfiles
svn_mapguide at osgeo.org
Thu Mar 11 08:33:23 EST 2010
Author: jng
Date: 2010-03-11 08:33:23 -0500 (Thu, 11 Mar 2010)
New Revision: 4658
Added:
sandbox/rfc71/mapviewerphp/getselectedfeatures.php
sandbox/rfc71/localized/en
sandbox/rfc71/mapviewerphp/mapframe.php
sandbox/rfc71/viewerfiles/ajaxmappane.templ
sandbox/rfc71/viewerfiles/propertyctrl.templ
We're now finally back to where we started, a functional PHP implementation. This is r4125, r4137, r4138 and r4139 reapplied with a little code cleanup as well
Modified: sandbox/rfc71/localized/en
--- sandbox/rfc71/localized/en 2010-03-11 10:30:42 UTC (rev 4657)
+++ sandbox/rfc71/localized/en 2010-03-11 13:33:23 UTC (rev 4658)
@@ -247,3 +247,7 @@
# Localized Icon Files
+# Property Pane Toolbar
+ZOOMSELECTEDFEATUREDESC = Zoom to this feature
+NOFEATSELECTRESPONSE = No response from feature selection request
Added: sandbox/rfc71/mapviewerphp/getselectedfeatures.php
--- sandbox/rfc71/mapviewerphp/getselectedfeatures.php (rev 0)
+++ sandbox/rfc71/mapviewerphp/getselectedfeatures.php 2010-03-11 13:33:23 UTC (rev 4658)
@@ -0,0 +1,456 @@
+<?php
+TODO:
+- Use the property mapping. This will have to be old-fashioned parsing the <PropertyMapping> elements
+of the layer definition. I really wanted to use MgSelection::GetSelectedFeatures(layer, class, true) but realised
+that unless the geometry is mapped, you're not going to see it in the Feature Reader (ie. No zoom point). Right now
+it is returning all properties.
+- I know of a few features in the Sheboygan Dataset that trip up the JSON response. Need to find out of addslashes() fixes this.
+- General cleanup of the code
+//require_once('FirePHPCore/fb.php');
+// Used to model the JSON response.
+class SelectionSet
+ private $layers;
+ public function __construct()
+ $this->layers = array();
+ public function AddFeature($feat)
+ $layerName = $feat->layerName;
+ if(!array_key_exists($layerName, $this->layers))
+ $this->layers[$layerName] = array();
+ array_push($this->layers[$layerName], $feat);
+ public function GetLayers()
+ return array_keys($this->layers);
+ public function GetFeatures($layerName)
+ if(array_key_exists($layerName, $this->layers))
+ return $this->layers[$layerName];
+ return null;
+class ZoomPoint
+ public $x;
+ public $y;
+// Represents a selected feature property
+class FeatureProperty
+ public $name;
+ public $value;
+class Feature
+ public $layerName;
+ public $zoom;
+ private $properties;
+ public function __construct($layerName)
+ $this->layerName = $layerName;
+ $this->properties = array();
+ public function AddProperty($prop)
+ $this->properties[$prop->name] = $prop;
+ public function GetProperties()
+ return $this->properties;
+ include 'common.php';
+ include 'constants.php';
+ $mapName = "";
+ $sessionId = "";
+ //$selText = "";
+ $queryInfo = false;
+ GetRequestParameters();
+ try
+ InitializeWebTier();
+ $cred = new MgUserInformation($sessionId);
+ $cred->SetClientIp(GetClientIp());
+ $cred->SetClientAgent(GetClientAgent());
+ //connect to the site and get an instance of the resource and feature service
+ $site = new MgSiteConnection();
+ $site->Open($cred);
+ $resourceSrvc = $site->CreateService(MgServiceType::ResourceService);
+ $featureSrvc = $site->CreateService(MgServiceType::FeatureService);
+ //load the map runtime state
+ $map = new MgMap();
+ $map->Open($resourceSrvc, $mapName);
+ // Create the selection set
+ $selection = new MgSelection($map);
+ $selection->Open($resourceSrvc, $mapName);
+ //if($selText != "") {
+ // $selection->FromXml($selText);
+ $layers = $selection->GetLayers();
+ if($layers != null)
+ $nLayers = $layers->GetCount();
+ $agfRW = new MgAgfReaderWriter();
+ $selectionSet = new SelectionSet();
+ for ($i = 0; $i < $nLayers; $i++) {
+ $lyr = $layers->GetItem($i);
+ $layerName = $lyr->GetName();
+ //FB::log("Layer Name: " . $lyr->GetName());
+ $featResId = new MgResourceIdentifier($lyr->GetFeatureSourceId());
+ $class = $lyr->GetFeatureClassName();
+ $queryOptions = new MgFeatureQueryOptions();
+ $mappings = GetLayerPropertyMappings($resourceSrvc, $lyr);
+ //FB::log("Property Mappings for Layer: $layerName");
+ foreach($mappings as $name => $value) {
+ $queryOptions->AddFeatureProperty($name);
+ //FB::log("$name => $value");
+ $geomName = $lyr->GetFeatureGeometryName();
+ $queryOptions->AddFeatureProperty($geomName);
+ $filter = $selection->GenerateFilter($lyr, $class);
+ $queryOptions->SetFilter($filter);
+ $fr = $featureSrvc->SelectFeatures($featResId, $class, $queryOptions);
+ $clsDef = $fr->GetClassDefinition();
+ $props = $clsDef->GetProperties();
+ //FB::log("Geometry: $geomName");
+ while($fr->ReadNext())
+ $feat = new Feature($layerName);
+ $zoom = null;
+ for ($k = 0; $k < $props->GetCount(); $k++)
+ $prop = $props->GetItem($k);
+ $propName = $prop->GetName();
+ $propType = $fr->GetPropertyType($propName);
+ //We only care about mapped properties or geometry properties
+ if (array_key_exists($propName, $mappings) || $propType == MgPropertyType::Geometry)
+ $value = "";
+ if (!$fr->IsNull($propName))
+ if(strcmp($propName,$geomName) == 0)
+ //We want the centroid so we have a zoom-to point
+ $agf = $fr->GetGeometry($propName);
+ $geom = $agfRW->Read($agf);
+ $pt = $geom->GetCentroid()->GetCoordinate();
+ $zoom = new ZoomPoint();
+ $zoom->x = $pt->GetX();
+ $zoom->y = $pt->GetY();
+ $feat->zoom = $zoom;
+ //FB::log("zoom: (".$zoom->x.",".$zoom->y.")");
+ else
+ $value = GetPropertyValueFromFeatureReader($fr, $agfRW, $propType, $propName);
+ if (array_key_exists($propName, $mappings))
+ $fp = new FeatureProperty();
+ $fp->name = $mappings[$propName];
+ $fp->value = $value;
+ $feat->AddProperty($fp);
+ $c = count($feat->GetProperties());
+ //FB::log("Selected feature processed ($c)");
+ $selectionSet->AddFeature($feat);
+ $fr->Close();
+ //Now output the selection set
+ header("Content-Type: application/json");
+ header("X-JSON: true");
+ echo GetJson($selectionSet);
+ catch(MgException $e)
+ echo $e->GetDetails();
+function GetJson($selectionSet)
+ if($selectionSet == null)
+ return "";
+ //FB::log("Processing JSON response");
+ A sample of the JSON output this method will produce:
+ "Layer1" : [
+ 'values' { "prop1" : "value1" , "prop2" : "value2" },
+ 'zoom' : { x: num1, y: num2 }
+ "Layer2" : [
+ $layers = $selectionSet->GetLayers();
+ $totalLayers = array(); //The data portion of the JSON response
+ //FB::log("Layers in selection set: ".count($layers));
+ for ($i = 0; $i < count($layers); $i++)
+ $layerName = $layers[$i];
+ $features = $selectionSet->GetFeatures($layerName);
+ //FB::log("Features: ".$features);
+ if($features != null)
+ //FB::log("Processing layer: $layerName");
+ $totalFeaturesOnLayer = array();
+ if (count($features) > 0)
+ for ($j = 0; $j < count($features); $j++)
+ $feat = $features[$j];
+ $featureProperties = array();
+ $fps = $feat->GetProperties();
+ foreach($fps as $fp)
+ $name = $fp->name;
+ $value = $fp->value;
+ //Add JSONified feature property
+ array_push($featureProperties, "{\"name\" : \"$name\", \"value\" : \"$value\" }");
+ if($feat->zoom != null)
+ array_push($totalFeaturesOnLayer, "{\"values\" : [".join(",", $featureProperties)."], \"zoom\" : { \"x\": ".$feat->zoom->x.", \"y\": ".$feat->zoom->y." } }");
+ else
+ array_push($totalFeaturesOnLayer, "{\"values\" : [".join(",", $featureProperties)."], \"zoom\" : null }");
+ //FB::log("Feature processed on layer: $layerName");
+ array_push($totalLayers, "\"$layerName\" : [" . join(", ", $totalFeaturesOnLayer) . "]");
+ //FB::log("Selected features on layer added to final JSON response");
+ //FB::log("Selection layer count: ".count($totalLayers));
+ $result = "{" . join(",",$totalLayers) . "}";
+ //return json_encode($result);
+ return $result;
+function GetPropertyValueFromFeatureReader($fr, $agfRW, $propType, $propName)
+ $val = "";
+ $tStr = "";
+ switch($propType)
+ case MgPropertyType::Null:
+ $tStr = "Null";
+ $val = "";
+ break;
+ case MgPropertyType::Boolean:
+ $tStr = "Boolean";
+ $val = $fr->GetBoolean($propName);
+ break;
+ case MgPropertyType::Byte:
+ $tStr = "Byte";
+ $val = $fr->GetByte($propName);
+ break;
+ case MgPropertyType::DateTime:
+ $tStr = "DateTime";
+ $val = printDateTime($fr->GetDateTime($propName));
+ break;
+ case MgPropertyType::Single:
+ $tStr = "Single";
+ $val = $fr->GetSingle($propName);
+ break;
+ case MgPropertyType::Double:
+ $tStr = "Double";
+ $val = $fr->GetDouble($propName);
+ break;
+ case MgPropertyType::Int16:
+ $tStr = "Int16";
+ $val = $fr->GetInt16($propName);
+ break;
+ case MgPropertyType::Int32:
+ $tStr = "Int32";
+ $val = $fr->GetInt32($propName);
+ break;
+ case MgPropertyType::Int64:
+ $tStr = "Int64";
+ $val = $fr->GetInt64($propName);
+ break;
+ case MgPropertyType::String:
+ $tStr = "String";
+ $val = addslashes($fr->GetString($propName));
+ break;
+ case MgPropertyType::Blob: //NOT PRESENTABLE IN PROPERTY GRID
+ $tStr = "BLOB";
+ break;
+ case MgPropertyType::Clob: //NOT PRESENTABLE IN PROPERTY GRID
+ $tStr = "CLOB";
+ break;
+ case MgPropertyType::Feature: //NOT PRESENTABLE IN PROPERTY GRID
+ $tStr = "Feature";
+ break;
+ case MgPropertyType::Geometry: //NOT PRESENTABLE IN PROPERTY GRID
+ $tStr = "Geometry";
+ break;
+ case MgPropertyType::Raster: //NOT PRESENTABLE IN PROPERTY GRID
+ $tStr = "Raster";
+ break;
+ //FB::log("$propName ($tStr) = $val");
+ return $val;
+/* retrieve the property mappings for a layer */
+function GetLayerPropertyMappings($resourceService, $layer) {
+ $mappings = array();
+ $byteReader = $resourceService->GetResourceContent($layer->GetLayerDefinition());
+ $xmldoc = DOMDocument::loadXML(ByteReaderToString($byteReader));
+ $mappingNodeList = $xmldoc->getElementsByTagName('PropertyMapping');
+ for ($i=0; $i<$mappingNodeList->length; $i++) {
+ $mapping = $mappingNodeList->item($i);
+ $nameElt = $mapping->getElementsByTagName('Name');
+ $name = $nameElt->item(0)->nodeValue;
+ $valueElt = $mapping->getElementsByTagName('Value');
+ $value = $valueElt->item(0)->nodeValue;
+ $mappings[$name] = $value;
+ return $mappings;
+function ByteReaderToString($byteReader)
+ return $byteReader->ToString();
+function printDateTime($mgDateTime)
+ $dayToday = $mgDateTime->GetDay();
+ $month = $mgDateTime->GetMonth();
+ $year = $mgDateTime->GetYear();
+ return $dayToday.".".$month.".".$year;
+function GetParameters($params)
+ global $mapName, $sessionId, $selText, $queryInfo;
+ $mapName = $params['MAPNAME'];
+ $sessionId = $params['SESSION'];
+ //$selText = UnescapeMagicQuotes($params['selection']);
+function UnescapeMagicQuotes($str)
+ if(ini_get("magic_quotes_sybase") == "1")
+ return str_replace("''", "'", $str);
+ else if(get_magic_quotes_gpc() == "1")
+ //Unescape double quotes
+ $str = str_replace('\\"', '"', $str);
+ //remove additional backslash
+ return str_replace("\\", "", $str);
+ return $str;
+function GetRequestParameters()
+ if($_SERVER['REQUEST_METHOD'] == "POST")
+ GetParameters($_POST);
+ else
+ GetParameters($_GET);
\ No newline at end of file
Modified: sandbox/rfc71/mapviewerphp/mapframe.php
--- sandbox/rfc71/mapviewerphp/mapframe.php 2010-03-11 10:30:42 UTC (rev 4657)
+++ sandbox/rfc71/mapviewerphp/mapframe.php 2010-03-11 13:33:23 UTC (rev 4658)
@@ -145,6 +145,7 @@
$vpath . "setselection.php",
$showSlider? "true": "false",
$locale,
+ $vpath . "getselectedfeatures.php",
$scaleCreationCode,
$vpath . "ajaxviewerabout.php",
$vpath . "legendctrl.php",
Modified: sandbox/rfc71/viewerfiles/ajaxmappane.templ
--- sandbox/rfc71/viewerfiles/ajaxmappane.templ 2010-03-11 10:30:42 UTC (rev 4657)
+++ sandbox/rfc71/viewerfiles/ajaxmappane.templ 2010-03-11 13:33:23 UTC (rev 4658)
@@ -334,6 +334,7 @@
var openHlinkText = macOS ? "__#OPENHYPERLINKMAC#__" : "__#OPENHYPERLINK#__";
var selectionColor = '0x0000FFFF'; // Blue
var lastLegendScaleUpdate = curScale;
+var featureRequestUrl = '%s';
%s
@@ -551,6 +552,9 @@
cancelTgt = document.getElementById("KeyTarget");
initTimer = setInterval(delayedInit, 200);
+ var btn = document.getElementById("imgZoomFeature");
+ btn.title = "__#ZOOMSELECTEDFEATUREDESC#__";
function delayedInit()
@@ -2877,26 +2881,17 @@
if(which & 2)
- properties = new Array();
- if(selection.count == 1)
+ if (IsPropertyCtrlVisible())
- try
+ if (selection.count > 0)
- var props = xmlIn.getElementsByTagName("Property");
- if(props != null)
- for(var i=0; i < props.length; i++)
- var name = props[i].getAttribute("name");
- var value = props[i].getAttribute("value");
- properties.push(new Property(name, value));
+ RequestSelectedFeatureProperties();
- catch(e) {}
+ else
+ ResetPropertyPane();
- properties.sort(CompareProperties);
- GetPropertyCtrl().SetProperties(selection.count, properties);
if(which & 4)
@@ -3824,6 +3819,189 @@
+//--- Property Pane Toolbar ---//
+var selFeatureZoom = 200;
+var hovered = "";
+var active = "";
+var selFeatures = {};
+function RequestSelectedFeatureProperties()
+ var mapname = GetMapName();
+ var session = GetSessionId();
+ var selRequest = CreateRequestHandler();
+ var reqParams = "MAPNAME="+mapname+"&SESSION="+session+"&SEQ="+Math.random();
+ selRequest.open("POST", featureRequestUrl, false);
+ selRequest.setRequestHeader("Content-Type", "application/x-www-form-urlencoded");
+ selRequest.send(reqParams);
+ var respText = selRequest.responseText;
+ if (respText && respText.length > 0)
+ var resp = eval('(' + respText + ')');
+ ProcessSelectedFeatureSet(resp);
+ else
+ RequestFailed("__#NOFEATSELECTRESPONSE#__");
+function ProcessSelectedFeatureSet(resp)
+ selFeatures = {};
+ if (!resp)
+ return;
+ var selLayers = document.getElementById("selLayers");
+ selLayers.length = 0;
+ GetPropertyCtrl().Clear();
+ //Construct layer list
+ for(var layerName in resp)
+ var opt = new Option();
+ opt.text = layerName;
+ opt.value = layerName;
+ if(msie)
+ selLayers.add(opt);
+ else
+ selLayers.add(opt, null);
+ //Associates the selected features on layer
+ selFeatures[layerName] = resp[layerName];
+ if (selLayers.length > 0)
+ SetPropertyPaneToolbarVisibility(true);
+ //Set to first result on the layer list
+ selLayers.selectedIndex = 0;
+ OnSelectedFeatureLayerChanged();
+function IsPropertyCtrlVisible()
+ return GetPropertyCtrl().width > 0;
+function ResetPropertyPane()
+ var selFeature = document.getElementById("selFeature");
+ selFeature.length = 0;
+ SetPropertyPaneToolbarVisibility(false);
+ GetPropertyCtrl().SetProperties(0);
+function OnSelectedFeatureLayerChanged()
+ var sLayer = document.getElementById("selLayers");
+ var layerIdx = sLayer.selectedIndex;
+ var layerName = sLayer.options[layerIdx].value;
+ var count = selFeatures[layerName].length;
+ //Clear feature dropdown and repopulate by numerical index (offset by 1)
+ var sFeature = document.getElementById("selFeature");
+ sFeature.length = 0;
+ for (var i = 1; i <= count; i++)
+ //This is just for display purposes. The selected index
+ //gives use the matching feature
+ opt.text = i;
+ opt.value = 1;
+ if (msie)
+ sFeature.add(opt);
+ else
+ sFeature.add(opt, null);
+ if (count > 0)
+ sFeature.selectedIndex = 0;
+ OnSelectedFeatureChanged();
+function OnSelectedFeatureChanged()
+ var featureIdx = sFeature.selectedIndex;
+ //Get matching selected feature from array
+ var feat = selFeatures[layerName][featureIdx];
+ //Show feature
+ GetPropertyCtrl().SetProperties(1, feat.values);
+function GetFeatureZoomLevel()
+ return selFeatureZoom;
+function ZoomSelectedFeature()
+ //Get the zoom component of the selected feature, and zoom to that view
+ if (feat.zoom)
+ ZoomToView(feat.zoom.x, feat.zoom.y, GetFeatureZoomLevel(), true);
+function HoverButton(eltId, description)
+ if (hovered != "")
+ document.getElementById(hovered).style.border = "solid #f0f0f0 1px";
+ document.getElementById(eltId).style.border = "solid #99B5CA 1px";
+ hovered = eltId;
+ parent.SetStatusMsg(description);
+function LeaveButton(eltId)
+ if (eltId == active)
+ else
+ document.getElementById(eltId).style.border = "solid #f0f0f0 1px";
+ hovered = "";
+ parent.SetStatusMsg('');
+function SetPropertyPaneToolbarVisibility(visible)
+ var tb = document.getElementById("PropertyPaneToolbar");
+ tb.style.display = visible ? "block" : "none";
+function OnResizeToolbar(e)
+ if (tb)
+ width = msie ? document.body.clientWidth : window.innerWidth - 2;
+ height = 32;
+ tb.style.width = width + "px";
+ tb.style.height = height + "px";
+ return true;
</script>
</head>
@@ -3854,6 +4032,23 @@
</table>
</div>
<div class="propertyCtrl" id="PropertyCtrlDiv" style="visibility: hidden;">
+ <div id="PropertyPaneToolbar" class="Toolbar" style="display:none">
+ <table width=100 height=30 border=0 cellpadding=0 cellspacing=0>
+ <tr height=30>
+ <td align=center valign=center>
+ <select id="selLayers" onchange="OnSelectedFeatureLayerChanged()"></select>
+ </td>
+ <select id="selFeature" onchange="OnSelectedFeatureChanged()"></select>
+ </td>
+ <td align=right>
+ <span class="btn" id="btnZoomSelectedFeature" style="position: absolute; right: 2px;" onmouseover="HoverButton('btnZoomSelectedFeature', '')" onmouseout="LeaveButton('btnZoomSelectedFeature', '')" onclick="ZoomSelectedFeature()">
+ <img class="btnImg" id="imgZoomFeature" title="" src="../stdicons/icon_zoomselect.gif" width=16 height=16>
+ </span>
+ </td>
+ </tr>
+ </table>
+ </div>
<iframe id="PropertyCtrl" name="PropertyCtrl" src="%s?LOCALE=%s" frameborder="0" width="0">
</iframe>
</div>
Modified: sandbox/rfc71/viewerfiles/propertyctrl.templ
--- sandbox/rfc71/viewerfiles/propertyctrl.templ 2010-03-11 10:30:42 UTC (rev 4657)
+++ sandbox/rfc71/viewerfiles/propertyctrl.templ 2010-03-11 13:33:23 UTC (rev 4658)
@@ -60,9 +60,15 @@
var text;
if(count == 0)
text = "__#PROPERTIESNONE#__";
+ GetMapFrame().SetPropertyPaneToolbarVisibility(false);
else
text = GetMainFrame().FormatMessage("__#PROPERTIESITEMSEL#__", new Array(count, "unused"));
+ GetMapFrame().SetPropertyPaneToolbarVisibility(true);
code = '<table id="Grid" cellspacing=0 cellpadding=0 border=0><tr><td class="Info" align="center">' + text + '</td></tr></table>';
else
@@ -71,15 +77,26 @@
for(var i=0; i < properties.length; i++)
code += '<tr class="GridCell"><td><span style="font-family: __#@font#__; font-size: __#@fontsize#__;"> ' + properties[i].name + '</span></td><td></td><td><span style="font-family: __#@font#__; font-size: __#@fontsize#__;">' + properties[i].value + '</span></td></tr>';
code += '</table>';
+ SetContent(code);
+function Clear()
+ SetContent("");
+// private functions -----------------------------------------------
+function SetContent(html)
var content = document.getElementById("Content");
- content.innerHTML = code; //SAFARI
+ content.innerHTML = html; //SAFARI
OnResizeGrid();
-// private functions -----------------------------------------------
function InitDocument()
document.onmousedown = OnMouseDown;
More information about the mapguide-commits
