[mapguide-commits] r4659 - sandbox/rfc71/mapviewernet
svn_mapguide at osgeo.org
Thu Mar 11 10:14:13 EST 2010
Author: jng
Date: 2010-03-11 10:14:13 -0500 (Thu, 11 Mar 2010)
New Revision: 4659
Added:
sandbox/rfc71/mapviewernet/getselectedfeatures.aspx
sandbox/rfc71/mapviewernet/mapframe.aspx
#1053: Here's the .net implementation
Added: sandbox/rfc71/mapviewernet/getselectedfeatures.aspx
--- sandbox/rfc71/mapviewernet/getselectedfeatures.aspx (rev 0)
+++ sandbox/rfc71/mapviewernet/getselectedfeatures.aspx 2010-03-11 15:14:13 UTC (rev 4659)
@@ -0,0 +1,356 @@
+<%@ Page Language="C#" %>
+<%@ Import Namespace="System" %>
+<%@ Import Namespace="System.IO" %>
+<%@ Import Namespace="System.Collections.Generic" %>
+<%@ Import Namespace="System.Web" %>
+<%@ Import Namespace="System.Xml" %>
+<%@ Import Namespace="System.Globalization" %>
+<%@ Import Namespace="OSGeo.MapGuide" %>
+<!-- #include File="common.aspx" -->
+<script runat="server">
+ class SelectionSet
+ private Dictionary<string, List<Feature>> _layers;
+ public SelectionSet()
+ _layers = new Dictionary<String, List<Feature>>();
+ public void AddFeature(Feature feat)
+ if (!_layers.ContainsKey(feat.LayerName))
+ _layers[feat.LayerName] = new List<Feature>();
+ _layers[feat.LayerName].Add(feat);
+ public String[] GetLayers()
+ return new List<String>(_layers.Keys).ToArray();
+ public Feature[] GetFeatures(String layerName)
+ if (_layers.ContainsKey(layerName))
+ return _layers[layerName].ToArray();
+ return null;
+ class ZoomPoint
+ public double X;
+ public double Y;
+ class FeatureProperty
+ public String Name;
+ public String Value;
+ class Feature
+ public String LayerName;
+ public ZoomPoint Zoom;
+ private Dictionary<string, FeatureProperty> _properties;
+ public Feature(string layerName)
+ this.LayerName = layerName;
+ _properties = new Dictionary<string, FeatureProperty>();
+ public void AddProperty(FeatureProperty prop)
+ _properties[prop.Name] = prop;
+ public FeatureProperty[] GetProperties()
+ return new List<FeatureProperty>(_properties.Values).ToArray();
+ String mapName;
+ String sessionId;
+ static NameValueCollection GetLayerPropertyMappings(MgResourceService resSvc, MgLayerBase layer)
+ NameValueCollection mappings = new NameValueCollection();
+ MgByteReader content = resSvc.GetResourceContent(layer.GetLayerDefinition());
+ XmlDocument doc = new XmlDocument();
+ doc.LoadXml(content.ToString());
+ XmlNodeList propNodes = doc.SelectNodes("//LayerDefinition/VectorLayerDefinition/PropertyMapping");
+ foreach (XmlNode propNode in propNodes)
+ String name = propNode["Name"].InnerText;
+ String value = propNode["Value"].InnerText;
+ mappings[name] = value;
+ return mappings;
+ static String GetPropertyValueFromFeatureReader(MgFeatureReader reader, MgAgfReaderWriter agfRw, int propType, String propName)
+ String value = "";
+ switch(propType)
+ case MgPropertyType.Boolean:
+ value = reader.GetBoolean(propName).ToString();
+ break;
+ case MgPropertyType.Byte:
+ value = reader.GetByte(propName).ToString();
+ break;
+ case MgPropertyType.DateTime:
+ value = GetDateTimeString(reader.GetDateTime(propName));
+ break;
+ case MgPropertyType.Single:
+ value = reader.GetSingle(propName).ToString();
+ break;
+ case MgPropertyType.Double:
+ value = reader.GetDouble(propName).ToString();
+ break;
+ case MgPropertyType.Int16:
+ value = reader.GetInt16(propName).ToString();
+ break;
+ case MgPropertyType.Int32:
+ value = reader.GetInt32(propName).ToString();
+ break;
+ case MgPropertyType.Int64:
+ value = reader.GetInt64(propName).ToString();
+ break;
+ case MgPropertyType.String:
+ value = reader.GetString(propName);
+ break;
+ default: //NOT PRESENTABLE IN PROPERTY GRID
+ value = "";
+ break;
+ return value;
+ static String GetDateTimeString(MgDateTime value)
+ //TODO: Use current culture to determine date format?
+ return String.Format("{0}-{1}-{2}", value.Year, value.Month, value.Day);
+ void GetParameters(NameValueCollection param)
+ mapName = param["MAPNAME"];
+ sessionId = param["SESSION"];
+ void GetRequestParameters()
+ if (Request.RequestType == "POST")
+ GetParameters(Request.Form);
+ else
+ GetParameters(Request.QueryString);
+ static String GetJson(SelectionSet set)
+ A sample of the JSON output this method will produce:
+ "Layer1" : [
+ 'values' { "name" : "name1" , "value" : "value1" },
+ 'zoom' : { x: num1, y: num2 }
+ "Layer2" : [
+ 'values' { "name" : "name2" , "value" : "value2" },
+ if (set == null)
+ return "";
+ StringBuilder sb = new StringBuilder();
+ //Begin selection set
+ sb.Append("{");
+ String[] layers = set.GetLayers();
+ for (int i = 0; i < layers.Length; i++)
+ //Begin layer
+ sb.Append("\"" + layers[i] + "\" : [");
+ Feature[] features = set.GetFeatures(layers[i]);
+ for (int j = 0; j < features.Length; j++)
+ Feature feat = features[j];
+ //begin feature
+ //begin feature properties
+ sb.Append("{\"values\" : [");
+ FeatureProperty[] properties = feat.GetProperties();
+ for(int k = 0; k < properties.Length; k++)
+ FeatureProperty fp = properties[k];
+ sb.Append("{\"name\" : \"" + fp.Name + "\", \"value\" : \"" + fp.Value + "\" }");
+ if (k != properties.Length - 1)
+ sb.Append(",");
+ //end feature properties
+ //begin zoom
+ sb.Append("], \"zoom\" : ");
+ if (feat.Zoom == null)
+ sb.Append("null}");
+ else
+ sb.Append("{\"x\" : " + feat.Zoom.X + ", \"y\" : " + feat.Zoom.Y + "}");
+ //end zoom
+ //end feature
+ sb.Append("}");
+ if (j != features.Length - 1)
+ sb.Append(",");
+ //End Layer
+ sb.Append("]");
+ if (i != layers.Length - 1)
+ sb.Append(",");
+ //End selection set
+ sb.Append("}");
+ return sb.ToString();
+</script>
+ mapName = "";
+ sessionId = "";
+ GetRequestParameters();
+ try
+ MgUserInformation cred = new MgUserInformation(sessionId);
+ cred.SetClientIp(GetClientIp(Request));
+ cred.SetClientAgent(GetClientAgent());
+ MgSiteConnection site = new MgSiteConnection();
+ site.Open(cred);
+ MgResourceService resSvc = (MgResourceService)site.CreateService(MgServiceType.ResourceService);
+ MgFeatureService featSvc = (MgFeatureService)site.CreateService(MgServiceType.FeatureService);
+ MgMap map = new MgMap(site);
+ map.Open(mapName);
+ MgSelection selection = new MgSelection(map);
+ selection.Open(resSvc, mapName);
+ MgReadOnlyLayerCollection layers = selection.GetLayers();
+ if (layers != null && layers.Count > 0)
+ int layerCount = layers.Count;
+ MgAgfReaderWriter agfRW = new MgAgfReaderWriter();
+ SelectionSet selectionSet = new SelectionSet();
+ for (int i = 0; i < layerCount; i++)
+ MgLayerBase layer = layers[i];
+ String layerName = layer.Name;
+ MgResourceIdentifier fsId = new MgResourceIdentifier(layer.GetFeatureSourceId());
+ String className = layer.GetFeatureClassName();
+ String geomName = layer.GetFeatureGeometryName();
+ MgFeatureQueryOptions query = new MgFeatureQueryOptions();
+ NameValueCollection mappings = GetLayerPropertyMappings(resSvc, layer);
+ foreach (String key in mappings.Keys)
+ query.AddFeatureProperty(key);
+ query.AddFeatureProperty(geomName);
+ String filter = selection.GenerateFilter(layer, className);
+ query.SetFilter(filter);
+ MgFeatureReader reader = featSvc.SelectFeatures(fsId, className, query);
+ MgClassDefinition clsDef = reader.GetClassDefinition();
+ MgPropertyDefinitionCollection props = clsDef.GetProperties();
+ while (reader.ReadNext())
+ Feature feat = new Feature(layerName);
+ ZoomPoint zoom = null;
+ for (int k = 0; k < props.Count; k++)
+ MgPropertyDefinition propDef = props[k];
+ String propName = propDef.Name;
+ int propType = reader.GetPropertyType(propName);
+ if (mappings[propName] != null || propType == MgPropertyType.Geometry)
+ if (!reader.IsNull(propName))
+ if (propName == geomName)
+ MgByteReader agf = reader.GetGeometry(propName);
+ MgGeometry geom = agfRW.Read(agf);
+ MgCoordinate pt = geom.Centroid.Coordinate;
+ zoom = new ZoomPoint();
+ zoom.X = pt.X;
+ zoom.Y = pt.Y;
+ feat.Zoom = zoom;
+ else
+ value = GetPropertyValueFromFeatureReader(reader, agfRW, propType, propName);
+ if (mappings[propName] != null)
+ FeatureProperty fp = new FeatureProperty();
+ fp.Name = propName;
+ fp.Value = value;
+ feat.AddProperty(fp);
+ selectionSet.AddFeature(feat);
+ reader.Close();
+ //Now output the selection set
+ Response.AddHeader("Content-Type", "application/json");
+ Response.AddHeader("X-JSON", "true");
+ Response.Write(GetJson(selectionSet));
+ catch (MgException ex)
+ Response.Write(ex.GetDetails());
\ No newline at end of file
Modified: sandbox/rfc71/mapviewernet/mapframe.aspx
--- sandbox/rfc71/mapviewernet/mapframe.aspx 2010-03-11 13:33:23 UTC (rev 4658)
+++ sandbox/rfc71/mapviewernet/mapframe.aspx 2010-03-11 15:14:13 UTC (rev 4659)
@@ -178,6 +178,7 @@
vpath + "setselection.aspx",
showSlider != 0? "true": "false",
locale,
+ vpath + "getselectedfeatures.aspx",
scaleCreationCode,
vpath + "ajaxviewerabout.aspx",
vpath + "legendctrl.aspx",
More information about the mapguide-commits
