[mapguide-commits] r5413 - trunk/MgDev/Common/CoordinateSystem
svn_mapguide at osgeo.org
Mon Nov 29 14:46:07 EST 2010
Author: NormOlsen
Date: 2010-11-29 11:46:07 -0800 (Mon, 29 Nov 2010)
New Revision: 5413
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.cpp
Trac #1542. Add call to CS_gpchk() to determine validity of a Geodetic Path definition.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.cpp 2010-11-29 05:49:48 UTC (rev 5412)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.cpp 2010-11-29 19:46:07 UTC (rev 5413)
@@ -120,41 +120,9 @@
if (NULL == this->pathDefinition)
return false;
- //make sure, the names for this path and the datums are set
- size_t pathNameLength = strlen(this->pathDefinition->pathName);
- if (0 == pathNameLength || pathNameLength >= sizeof(this->pathDefinition->pathName))
- return false;
- size_t srcDatumNameLength = strlen(this->pathDefinition->srcDatum);
- if (0 == srcDatumNameLength || srcDatumNameLength >= sizeof(this->pathDefinition->srcDatum))
- return false;
- size_t trgDatumNameLength = strlen(this->pathDefinition->trgDatum);
- if (0 == trgDatumNameLength || trgDatumNameLength >= sizeof(this->pathDefinition->trgDatum))
- return false;
- //check, whether there are only valid path elements according to MgCoordinateSystemGeodeticPathElement::IsValid()
- Ptr<MgDisposableCollection> pathElements = this->GetPathElements();
- INT32 pathElementCount = pathElements->GetCount();
- if (0 == pathElementCount || pathElementCount > csPATH_MAXXFRM)
- return false;
- if (pathElementCount != this->pathDefinition->elementCount)
- return false;
- for(INT32 i = 0; i < pathElementCount; i++)
- Ptr<MgDisposable> mgDisposable = pathElements->GetItem(i);
- MgCoordinateSystemGeodeticPathElement* pathElement = dynamic_cast<MgCoordinateSystemGeodeticPathElement*>(mgDisposable.p);
- if (NULL == pathElement)
- throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticPath.IsValid", __LINE__, __WFILE__, NULL, L"", NULL);
- if (!pathElement->IsValid())
- return false;
- //TODO: add gp_gpchk in cs_map.h
- return true; //for any other stuff, like [accuracy] etc. rely on cs_gpcheck
+ int errorCount = CS_gpchk (this->pathDefinition,(cs_GPCHK_DATUM | cs_GPCHK_XFORM),NULL,0);
+ return (errorCount == 0);
//all getters and setters
More information about the mapguide-commits
