[mapguide-commits] r5414 - trunk/MgDev/Common/CoordinateSystem
svn_mapguide at osgeo.org
Mon Nov 29 15:45:16 EST 2010
Author: NormOlsen
Date: 2010-11-29 12:45:16 -0800 (Mon, 29 Nov 2010)
New Revision: 5414
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp
Trac #1543 -- Activate use of CS-MAP function CS_gxchk() for checking the validity of Geodetic Transformation definitions.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp 2010-11-29 19:46:07 UTC (rev 5413)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp 2010-11-29 20:45:16 UTC (rev 5414)
@@ -340,17 +340,11 @@
if (!params->IsValid())
return false;
- //TODO: would we also need to check, whether the datum(s) exists?
CriticalClass.Enter();
- //TODO: pass correct parameters; make sure, CS_gxchk checks all stuff
- int nNumErrs = CS_gxchk(this->transformDefinition, 0, NULL, 0);
+ int nNumErrs = CS_gxchk(this->transformDefinition,cs_GXCHK_DATUM, NULL, 0);
CriticalClass.Leave();
return (0 == nNumErrs);
- return true;
//helper - don't delete
More information about the mapguide-commits
