[mapguide-commits] r5169 - trunk/MgDev/Common/Schema
svn_mapguide at osgeo.org
Tue Sep 21 04:36:03 EDT 2010
Author: hubu
Date: 2010-09-21 08:36:03 +0000 (Tue, 21 Sep 2010)
New Revision: 5169
Added:
trunk/MgDev/Common/Schema/WatermarkDefinition-2.3.0.xsd
Removed:
trunk/MgDev/Common/Schema/WatermarkDefinition.xml
Submit on behalf on Spark liu:
Fix incorrect file in previous submission.
Added: trunk/MgDev/Common/Schema/WatermarkDefinition-2.3.0.xsd
--- trunk/MgDev/Common/Schema/WatermarkDefinition-2.3.0.xsd (rev 0)
+++ trunk/MgDev/Common/Schema/WatermarkDefinition-2.3.0.xsd 2010-09-21 08:36:03 UTC (rev 5169)
@@ -0,0 +1,284 @@
+<?xml version="1.0" encoding="utf-8"?>
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified" version="2.3.0">
+ <xs:include schemaLocation="SymbolDefinition-1.1.0.xsd"/>
+ <xs:element name="WatermarkDefinition">
+ <xs:annotation>
+ <xs:documentation>The specification of a watermark.</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:complexContent>
+ <xs:extension base="WatermarkDefinitionType">
+ <xs:attribute name="version" type="xs:string" use="required" fixed="2.3.0"/>
+ </xs:extension>
+ </xs:complexContent>
+ </xs:complexType>
+ </xs:element>
+ <xs:simpleType name="UnitType">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed length units for a watermark position.</xs:documentation>
+ </xs:annotation>
+ <xs:restriction base="xs:string">
+ <xs:enumeration value="Inches"/>
+ <xs:enumeration value="Centimeters"/>
+ <xs:enumeration value="Millimeters"/>
+ <xs:enumeration value="Pixels"/>
+ <xs:enumeration value="Points"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="HorizontalAlignmentType">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed horizontal alignment values for a watermark position.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="Left"/>
+ <xs:enumeration value="Center"/>
+ <xs:enumeration value="Right"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="HorizontalPositionType">
+ <xs:annotation>
+ <xs:documentation>Defines the horizontal position of a watermark.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Offset" type="xs:double" default="0.0">
+ <xs:annotation>
+ <xs:documentation>The horizontal offset for the position.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Unit" type="UnitType" default="Points">
+ <xs:annotation>
+ <xs:documentation>The unit for the offset.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Alignment" type="HorizontalAlignmentType" default="Center">
+ <xs:annotation>
+ <xs:documentation>The horizontal alignment for the position.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:simpleType name="VerticalAlignmentType">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed vertical alignments for a watermark position.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="Top"/>
+ <xs:enumeration value="Bottom"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="VerticalPositionType">
+ <xs:annotation>
+ <xs:documentation>Defines the vertical position of a watermark.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The vertical offset for the position.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Alignment" type="VerticalAlignmentType" default="Center">
+ <xs:annotation>
+ <xs:documentation>The vertical alignment for the position.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="PositionType" abstract="true">
+ <xs:annotation>
+ <xs:documentation>Abstract base type used with all watermark positions.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="XYPositionType">
+ <xs:annotation>
+ <xs:documentation>Positions a watermark at a single X/Y location.</xs:documentation>
+ </xs:annotation>
+ <xs:extension base="PositionType">
+ <xs:sequence>
+ <xs:element name="XPosition" type="HorizontalPositionType">
+ <xs:annotation>
+ <xs:documentation>The position along the X-axis.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="YPosition" type="VerticalPositionType">
+ <xs:annotation>
+ <xs:documentation>The position along the Y-axis.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="TilePositionType">
+ <xs:annotation>
+ <xs:documentation>Positions a watermark according to a regular grid.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="TileWidth" type="xs:double" default="150.0">
+ <xs:annotation>
+ <xs:documentation>The width of each tile in the grid.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="TileHeight" type="xs:double" default="150.0">
+ <xs:annotation>
+ <xs:documentation>The height of each tile in the grid.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="HorizontalPosition" type="HorizontalPositionType">
+ <xs:annotation>
+ <xs:documentation>The horizontal position of the watermark within a tile.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="VerticalPosition" type="VerticalPositionType">
+ <xs:annotation>
+ <xs:documentation>The vertical position of the watermark within a tile.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="WatermarkAppearanceType">
+ <xs:annotation>
+ <xs:documentation>Defines the appearance of a watermark.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Transparency" minOccurs="0" default="0.0">
+ <xs:annotation>
+ <xs:documentation>The transparency of the watermark in the range 0-100. The default value is 0 (opaque).</xs:documentation>
+ </xs:annotation>
+ <xs:simpleType>
+ <xs:restriction base="xs:double">
+ <xs:minInclusive value="0.0"/>
+ <xs:maxInclusive value="100.0"/>
+ </xs:restriction>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="Rotation" minOccurs="0" default="0.0">
+ <xs:annotation>
+ <xs:documentation>The rotation of the watermark, in degrees, in the range 0-360. The default value is 0.</xs:documentation>
+ </xs:annotation>
+ <xs:simpleType>
+ <xs:maxInclusive value="360.0"/>
+ </xs:restriction>
+ </xs:simpleType>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="WatermarkDefinitionType">
+ <xs:annotation>
+ <xs:documentation>A watermark definition containing content, appearance, and position information.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Content">
+ <xs:annotation>
+ <xs:documentation>A symbol definition defining the content of the watermark.</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:choice>
+ <xs:element name="SimpleSymbolDefinition" type="SimpleSymbolDefinition" />
+ <xs:element name="CompoundSymbolDefinition" type="CompoundSymbolDefinition" />
+ </xs:choice>
+ </xs:complexType>
+ </xs:element>
+ <xs:element name="Appearance" type="WatermarkAppearanceType">
+ <xs:annotation>
+ <xs:documentation>The appearance of the watermark.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Position">
+ <xs:annotation>
+ <xs:documentation>The position of the watermark.</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:choice>
+ <xs:element name="XYPosition" type="XYPositionType" />
+ <xs:element name="TilePosition" type="TilePositionType" />
+ </xs:choice>
+ </xs:complexType>
+ </xs:element>
+ <xs:element name="ExtendedData1" type="ExtendedDataType" minOccurs="0"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:simpleType name="UsageType">
+ <xs:annotation>
+ <xs:documentation>Specifies the context in which the watermark is displayed.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="WMS">
+ <xs:annotation>
+ <xs:documentation>Watermark is displayed in WMS.</xs:documentation>
+ </xs:annotation>
+ </xs:enumeration>
+ <xs:enumeration value="Viewer">
+ <xs:annotation>
+ <xs:documentation>Watermark is displayed in AJAX or Fusion viewers.</xs:documentation>
+ </xs:annotation>
+ </xs:enumeration>
+ <xs:enumeration value="All">
+ <xs:annotation>
+ <xs:documentation>Watermark is displayed in all contexts.</xs:documentation>
+ </xs:annotation>
+ </xs:enumeration>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="WatermarkType">
+ <xs:annotation>
+ <xs:documentation>A watermark instance used in a map definition or layer definition.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Name" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The name of the watermark.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ResourceId" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>A library reference to an existing WatermarkDefinition.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Usage" type="UsageType" minOccurs="0" default="All">
+ <xs:annotation>
+ <xs:documentation>The context in which the watermark is displayed. Defaults to All.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="AppearanceOverride" type="WatermarkAppearanceType" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>If specified, overrides the appearance of the watermark definition.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="PositionOverride" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>If specified, overrides the position of the watermark definition.</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:choice>
+ </xs:choice>
+ </xs:complexType>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="WatermarkInstanceCollectionType">
+ <xs:annotation>
+ <xs:documentation>A collection of watermarks used by a map definition or layer definition.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Watermark" type="WatermarkType" minOccurs="0" maxOccurs="unbounded" />
+ </xs:sequence>
+ </xs:complexType>
+</xs:schema>
Property changes on: trunk/MgDev/Common/Schema/WatermarkDefinition-2.3.0.xsd
___________________________________________________________________
Added: svn:eol-style
+ native
Deleted: trunk/MgDev/Common/Schema/WatermarkDefinition.xml
--- trunk/MgDev/Common/Schema/WatermarkDefinition.xml 2010-09-21 08:21:54 UTC (rev 5168)
+++ trunk/MgDev/Common/Schema/WatermarkDefinition.xml 2010-09-21 08:36:03 UTC (rev 5169)
@@ -1,264 +0,0 @@
-<?xml version="1.0" encoding="utf-8"?>
-<WatermarkDefinition version="2.3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="WatermarkDefinition-2.3.0.xsd">
- <Content>
- <CompoundSymbolDefinition>
- <Name>Symbol</Name>
- <Description></Description>
- <SimpleSymbol>
- <SimpleSymbolDefinition>
- <Name>Circle</Name>
- <Description>Default Point Symbol</Description>
- <Graphics>
- <Path>
- <Geometry>M -1,0 A 1,1 0 1 1 1,0 A 1,1 0 1 1 -1,0</Geometry>
- <FillColor>%FILLCOLOR%</FillColor>
- <LineColor>%LINECOLOR%</LineColor>
- <LineWeight>%LINEWEIGHT%</LineWeight>
- </Path>
- </Graphics>
- <PointUsage>
- <Angle>%ROTATION%</Angle>
- </PointUsage>
- <ParameterDefinition>
- <Parameter>
- <Identifier>FILLCOLOR</Identifier>
- <DefaultValue>FFACD372</DefaultValue>
- <DisplayName>&Fill Color</DisplayName>
- <Description>Fill Color</Description>
- <DataType>FillColor</DataType>
- </Parameter>
- <Parameter>
- <Identifier>LINECOLOR</Identifier>
- <DefaultValue>ff000000</DefaultValue>
- <DisplayName>Line &Color</DisplayName>
- <Description>Line Color</Description>
- <DataType>LineColor</DataType>
- </Parameter>
- <Parameter>
- <Identifier>LINEWEIGHT</Identifier>
- <DefaultValue>0.0</DefaultValue>
- <DisplayName>Line &Thickness</DisplayName>
- <Description>Line Thickness</Description>
- <DataType>LineWeight</DataType>
- </Parameter>
- <Parameter>
- <Identifier>ROTATION</Identifier>
- <DisplayName>&Rotation</DisplayName>
- <Description>Rotation</Description>
- <DataType>Angle</DataType>
- </Parameter>
- </ParameterDefinition>
- </SimpleSymbolDefinition>
- </SimpleSymbol>
- <SimpleSymbol>
- <Name>Square</Name>
- <Graphics>
- <Path>
- <Geometry>M -1.0,-1.0 L 1.0,-1.0 L 1.0,1.0 L -1.0,1.0 L -1.0,-1.0</Geometry>
- </Path>
- </Graphics>
- <PointUsage>
- </PointUsage>
- <Parameter>
- <DefaultValue>0xffffffff</DefaultValue>
- </Parameter>
- <Parameter>
- <DefaultValue>0xff000000</DefaultValue>
- </Parameter>
- <Parameter>
- </Parameter>
- <Parameter>
- <DefaultValue>45</DefaultValue>
- </Parameter>
- </SimpleSymbol>
- <SimpleSymbol>
- <Name>Plain Text</Name>
- <Description>Default Plain Text Symbol</Description>
- <Graphics>
- <Text>
- <Content>%CONTENT%</Content>
- <FontName>%FONTNAME%</FontName>
- <Bold>%BOLD%</Bold>
- <Italic>%ITALIC%</Italic>
- <Underlined>%UNDERLINED%</Underlined>
- <Height>%FONTHEIGHT%</Height>
- <HorizontalAlignment>%HORIZONTALALIGNMENT%</HorizontalAlignment>
- <VerticalAlignment>%VERTICALALIGNMENT%</VerticalAlignment>
- <Justification>%JUSTIFICATION%</Justification>
- <LineSpacing>%LINESPACING%</LineSpacing>
- <TextColor>%TEXTCOLOR%</TextColor>
- <GhostColor>%GHOSTCOLOR%</GhostColor>
- <Frame>
- <LineColor>%FRAMELINECOLOR%</LineColor>
- <FillColor>%FRAMEFILLCOLOR%</FillColor>
- </Frame>
- </Text>
- </Graphics>
- <PointUsage>
- </PointUsage>
- <Parameter>
- <Identifier>CONTENT</Identifier>
- <DefaultValue>'Haha'</DefaultValue>
- <DataType>Content</DataType>
- </Parameter>
- <Parameter>
- <Identifier>FONTNAME</Identifier>
- <DefaultValue>'Arial'</DefaultValue>
- <DataType>FontName</DataType>
- </Parameter>
- <Parameter>
- <Identifier>FONTHEIGHT</Identifier>
- <DefaultValue>4.0</DefaultValue>
- <DataType>FontHeight</DataType>
- </Parameter>
- <Parameter>
- <Identifier>BOLD</Identifier>
- <DefaultValue>false</DefaultValue>
- <DataType>Bold</DataType>
- </Parameter>
- <Parameter>
- <Identifier>ITALIC</Identifier>
- <DataType>Italic</DataType>
- </Parameter>
- <Parameter>
- <Identifier>UNDERLINED</Identifier>
- <DataType>Underlined</DataType>
- </Parameter>
- <Parameter>
- <Identifier>OVERLINED</Identifier>
- <DataType>Overlined</DataType>
- </Parameter>
- <Parameter>
- <Identifier>JUSTIFICATION</Identifier>
- <DefaultValue>'FromAlignment'</DefaultValue>
- <DataType>Justification</DataType>
- </Parameter>
- <Parameter>
- <Identifier>LINESPACING</Identifier>
- <DefaultValue>1.05</DefaultValue>
- <DataType>LineSpacing</DataType>
- </Parameter>
- <Parameter>
- <Identifier>GHOSTCOLOR</Identifier>
- <DefaultValue/>
- <DataType>GhostColor</DataType>
- </Parameter>
- <Parameter>
- <Identifier>FRAMELINECOLOR</Identifier>
- <DefaultValue/>
- <DataType>FrameLineColor</DataType>
- </Parameter>
- <Parameter>
- <Identifier>FRAMEFILLCOLOR</Identifier>
- <DefaultValue/>
- <DataType>FrameFillColor</DataType>
- </Parameter>
- <Parameter>
- <Identifier>TEXTCOLOR</Identifier>
- <DataType>TextColor</DataType>
- </Parameter>
- <Parameter>
- <Identifier>HORIZONTALALIGNMENT</Identifier>
- <DefaultValue>'Left'</DefaultValue>
- <DataType>HorizontalAlignment</DataType>
- </Parameter>
- <Parameter>
- <Identifier>VERTICALALIGNMENT</Identifier>
- <DefaultValue>'Bottom'</DefaultValue>
- <DataType>VerticalAlignment</DataType>
- </Parameter>
- <Parameter>
- <DefaultValue>30</DefaultValue>
- </Parameter>
- </SimpleSymbol>
- <SimpleSymbol>
- <Name>Watermark image</Name>
- <Description>Default watermark image Symbol</Description>
- <Graphics>
- <Image>
- <Reference>
- <ResourceId>Library://A.WatermarkDefinition</ResourceId>
- <LibraryItemName>ImageSymbol</LibraryItemName>
- </Reference>
- <SizeX>20</SizeX>
- <SizeY>20</SizeY>
- </Image>
- </Graphics>
- <PointUsage>
- </PointUsage>
- <Parameter>
- </Parameter>
- </SimpleSymbol>
- </CompoundSymbolDefinition>
- </Content>
- <Appearance>
- <Transparency>50</Transparency>
- <Rotation>90</Rotation>
- </Appearance>
- <Position>
- <TilePosition>
- <TileWidth>150</TileWidth>
- <TileHeight>150</TileHeight>
- <HorizontalPosition>
- <Offset>0</Offset>
- <Unit>Points</Unit>
- <Alignment>Left</Alignment>
- </HorizontalPosition>
- <VerticalPosition>
- <Alignment>Top</Alignment>
- </VerticalPosition>
- </TilePosition>
- </Position>
-</WatermarkDefinition>
\ No newline at end of file
More information about the mapguide-commits
