[mapguide-commits] r5170 - in trunk/MgDev/Common: CoordinateSystem
Geometry/CoordinateSystem
svn_mapguide at osgeo.org
Tue Sep 21 10:52:39 EDT 2010
Author: waltweltonlair
Date: 2010-09-21 14:52:39 +0000 (Tue, 21 Sep 2010)
New Revision: 5170
trunk/MgDev/Common/CoordinateSystem/CoordSysDictionaryBase.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysDictionaryBase.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformGridFile.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformGridFile.h
trunk/MgDev/Common/CoordinateSystem/CoordSysMacro.h
trunk/MgDev/Common/CoordinateSystem/namestruct.cpp
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformDefParams.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformationMethod.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticInterpolationTransformDefParams.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformDefParams.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformationMethod.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPath.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathDictionary.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathElement.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefDictionary.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefParams.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefType.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFile.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFileFormat.h
Add svn:eol-style attribute to newly added file Geometry / CoordinateSystem files.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysDictionaryBase.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysDictionaryBase.cpp 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysDictionaryBase.cpp 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,375 +1,375 @@
-// Copyright (C) 2004-2010 by Autodesk, Inc.
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of version 2.1 of the GNU Lesser
-// General Public License as published by the Free Software Foundation.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-#ifdef BUILD_DICTIONARY_BASE //set this define before including CoordSysDictionaryBase.cpp; otherwise nothing will be built
-DICTIONARY_BASE_TEMPLATE
-DICTIONARY_BASE_TEMPLATE_METHOD::CCoordinateSystemDictionaryBase(MgCoordinateSystemCatalog *pCatalog)
- : dictMagicNumber(0) /* no yet initialized - will be read in [SetFileName] */, dictionaryItems(NULL)
- if (NULL == pCatalog)
- throw new MgNullArgumentException(L"CCoordinateSystemDictionaryBase.ctor()", __LINE__, __WFILE__, NULL, L"", NULL);
- this->catalog = SAFE_ADDREF(pCatalog); // 'Ptr = ' does not increment the ref counter
- this->fileName = defaultFileName; //template default parameter
-DICTIONARY_BASE_TEMPLATE_METHOD::~CCoordinateSystemDictionaryBase()
- this->catalog = NULL;
- delete this->dictionaryItems;
- this->dictionaryItems = NULL;
-void DICTIONARY_BASE_TEMPLATE_METHOD::Dispose()
- delete this;
-MgCoordinateSystemCatalog* DICTIONARY_BASE_TEMPLATE_METHOD::GetCatalog()
- return SAFE_ADDREF(this->catalog.p);
-STRING DICTIONARY_BASE_TEMPLATE_METHOD::GetDefaultFileName()
- return defaultFileName; /* from template definition; *NOT* this->fileName ! */
-STRING DICTIONARY_BASE_TEMPLATE_METHOD::GetFileName()
- return this->fileName; /* changeable via SetFileName*/
-void DICTIONARY_BASE_TEMPLATE_METHOD::SetFileName(CREFSTRING sFileName)
- ::SetDictionaryFileName(
- sFileName,
- this->catalog->GetDictionaryDir(),
- this->dictMagicNumber, //will be set
- definitionAccess->magicNumberCallback, //open mode
- definitionAccess->csMapTargetFileName, //CS Map file target
- L"CoordSysDictionaryBase.SetFileName"); //context
- //the filename has been set for CS library; now set it for this object...
- this->fileName = sFileName;
- //...and clean up the list of entries we might have already read from the old dictionary file
-STRING DICTIONARY_BASE_TEMPLATE_METHOD::GetPath() /* the full path to the file we're currently using */
- MG_TRY()
- return (this->catalog->GetDictionaryDir() + this->fileName);
- MG_CATCH_AND_THROW(L"CCoordinateSystemDictionaryBase.GetPath")
- _ASSERT(false); //OOM - unable to create the exception object?
- return NULL;
-UINT32 DICTIONARY_BASE_TEMPLATE_METHOD::GetSize()
- //If we have a summary available, we can just return its size.
- if (NULL != this->dictionaryItems)
- return static_cast<UINT32>(this->dictionaryItems->size());
- SmartCriticalClass critical(true);
- STRING strPath = this->GetPath();
- csFILE *pFile = MentorDictionary::Open(this->dictMagicNumber, definitionAccess->magicNumberCallback, strPath.c_str(), Read);
- _ASSERT(NULL != pFile);
- UINT32 nSize;
- MG_TRY()
- //We're open, but no summary is available. We need to examine
- //the file itself to find out how big it is.
- INT32 pos = CS_ftell(pFile);
- CS_fseek(pFile, 0, SEEK_END);
- UINT32 ulFileBytes = 1 + CS_ftell(pFile);
- CS_fseek(pFile, pos, SEEK_SET);
- UINT32 nRecSize = sizeof(U);
- //take the complete file size; subtract the "header" and divide by the size of the structs contained
- nSize = (ulFileBytes - sizeof(this->dictMagicNumber)) / nRecSize;
- MG_CATCH(L"CCoordinateSystemDictionaryBase.GetSize")
- if(NULL != pFile && (0 != CS_fclose(pFile)))
- throw new MgFileIoException(L"CCoordinateSystemDictionaryBase.GetSize", __LINE__, __WFILE__, NULL, NULL, NULL);
- MG_THROW()
- return nSize;
-void DICTIONARY_BASE_TEMPLATE_METHOD::Add(MgGuardDisposable* pDefinition)
- //we won't take ownership of [pDefinition]; i.e. it can be deleted by the caller after we're done here
- if (NULL == pDefinition)
- throw new MgNullArgumentException(L"CCoordinateSystemDictionaryBase.Add", __LINE__, __WFILE__, NULL, L"", NULL);
- T* pDictionaryDef = dynamic_cast<T*>(pDefinition);
- if (!pDictionaryDef)
- throw new MgInvalidArgumentException(L"CCoordinateSystemDictionaryBase.Add", __LINE__, __WFILE__, NULL, L"CCoordinateSystemDictionaryBase", NULL);
- MG_TRY()
- //::UpdateDef will lock the (file) resource via [SmartCriticalClass critical(true);]
- MentorDictionary::UpdateDef<U, T>(
- this->dictionaryItems, /* can be null in case no enumerator has been created yet or this dictionary isn't set up for caching */
- definitionAccess->readDefinitionName,
- definitionAccess->readDefinitionDescription,
- definitionAccess->validateDefinition,
- definitionAccess->readDefinition,
- definitionAccess->updateDefinition,
- definitionAccess->setupCsStructFromMgInstance,
- pDictionaryDef,
- false); /* bAlreadyExists - we want to create a new one, i.e. the definition must not exist yet */
- MG_CATCH_AND_THROW(L"CCoordinateSystemDictionaryBase.Add")
-void DICTIONARY_BASE_TEMPLATE_METHOD::Remove(CREFSTRING sName)
- MG_TRY()
- MentorDictionary::RemoveDef<U>(
- definitionAccess->deleteDefinition,
- sName.c_str());
- MG_CATCH_AND_THROW(L"CCoordinateSystemDictionaryBase.Remove")
-void DICTIONARY_BASE_TEMPLATE_METHOD::Modify(MgGuardDisposable *pDefinition)
- throw new MgNullArgumentException(L"CCoordinateSystemDictionaryBase.Modify", __LINE__, __WFILE__, NULL, L"", NULL);
- throw new MgInvalidArgumentException(L"CCoordinateSystemDictionaryBase.Modify", __LINE__, __WFILE__, NULL, L"CCoordinateSystemDictionaryBase", NULL);
- MG_TRY()
- //we don't pass our [this->items] here, as the dictionary is accessed anyway;
- //if the caller passes us an unknown definition, we'll fail anyway
- //with an exception what is per se slower than having success here
- pDictionaryDef,
- true); //the definition has to exist
- MG_CATCH_AND_THROW(L"CCoordinateSystemDictionaryBase.Modify")
-MgGuardDisposable* DICTIONARY_BASE_TEMPLATE_METHOD::Get(CREFSTRING sName)
- U *pDef = NULL;
- char *pName = NULL;
- //Get the name to search for
- pName = Convert_Wide_To_Ascii(sName.c_str()); //need to delete [] pName
- Ptr<T> pDefinition;
- MG_TRY()
- //make sure, we've exclusive access here
- //Look in the dictionary
- pDef = definitionAccess->readDefinition(pName);
- if (NULL == pDef)
- MgStringCollection whatArguments;
- whatArguments.Add(sName);
- throw new MgCoordinateSystemLoadFailedException(L"CCoordinateSystemDictionaryBase.Get", __LINE__, __WFILE__, &whatArguments, L"", NULL);
- pDefinition = this->NewItem(); //no AddRef; release if needed
- if (NULL == pDefinition.p) //ABA ???
- throw new MgOutOfMemoryException(L"CCoordinateSystemDictionaryBase.Get", __LINE__, __WFILE__, NULL, L"", NULL);
- //we've created the Mg instance, we got the CS_Map definition; now let the Mg instance initialize itself from the
- //struct;
- //NOTE: [fullInitialize] doesn't take ownership of [pDef] - we've to release it when done
- definitionAccess->fullInitialize(pDefinition, pDef, this->catalog);
- MG_CATCH(L"CCoordinateSystemDictionaryBase.Get")
- /* cleanup - MG_CATCH() catches every exception; i.e. we'll go through here regardless of whether an exception occurred or not */
- CS_free(pDef);
- delete [] pName;
- MG_THROW()
- return pDefinition.Detach(); //done - detach the pointer so the caller can take ownership
-bool DICTIONARY_BASE_TEMPLATE_METHOD::Has(CREFSTRING sName)
- MG_TRY()
- try
- Ptr<MgGuardDisposable> definition = this->Get(sName);
- _ASSERT(NULL != definition);
- return NULL != definition;
- catch(MgCoordinateSystemLoadFailedException* loadFailedException)
- loadFailedException->Release();
- return false;
- MG_CATCH_AND_THROW(L"CCoordinateSystemDictionaryBase.Has")
- _ASSERT(false);
- return false;
-MgCoordinateSystemEnum* DICTIONARY_BASE_TEMPLATE_METHOD::GetEnum()
- //we don't take ownership; the caller has to free it
- return this->GetEnumImp();
-CCoordinateSystemEnum* DICTIONARY_BASE_TEMPLATE_METHOD::GetEnumImp()
- Ptr<CCoordinateSystemEnum> pNew;
- csFILE *dictionaryFile = NULL;
- CSystemNameDescriptionMap* allDictionaryEntries = NULL;
- MG_TRY()
- //do we have to cache the entries read from the dictionary file and have we already read them before?
- if (!cacheDictionaryEntries || NULL == this->dictionaryItems)
- //Not read yet - try to build the map from the entries found in the dictionary file
- //[Open] throws an exception, if the dictionary file couldn't be opened
- dictionaryFile = MentorDictionary::Open(this->dictMagicNumber, definitionAccess->magicNumberCallback, strPath.c_str(), Read);
- allDictionaryEntries = MentorDictionary::GenerateSystemNameDescriptionMap<U>(
- dictionaryFile,
- definitionAccess->readAllDefinitions);
- if (NULL == allDictionaryEntries) //whatever happend here - the dictionay file seems to be invalid
- throw new MgCoordinateSystemLoadFailedException(L"CCoordinateSystemDictionaryBase.GetEnumImp", __LINE__, __WFILE__, NULL, L"", NULL);
- else
- allDictionaryEntries = this->dictionaryItems;
- //create our enumerator we're returning to the caller
- pNew = new CCoordinateSystemEnum;
- pNew->Initialize(this, allDictionaryEntries /* might point to [this->dictionaryItems] */);
- MG_CATCH(L"CCoordinateSystemDictionaryBase.GetEnumImp")
- //in either case, try to close the dictionary file
- if (NULL != dictionaryFile && 0 != CS_fclose(dictionaryFile) //closing went through?
- && NULL == mgException.p)
- //if there hasn't yet an exception occurred we now have one
- //if there was one already we (unfortunately) do now swallow the MgFileIoException
- mgException = new MgFileIoException(L"CCoordinateSystemDictionaryBase.GetEnumImp", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemDictionaryCloseFailedException", NULL);
- MG_THROW()
- //cache the map of entries if we did succeed
- if (cacheDictionaryEntries)
- //this will be false, if this dictionary object is shared between multiple threads; however, the dictionary must not be shared between threads
- //without proper precautions being taken
- _ASSERT(NULL != allDictionaryEntries);
- _ASSERT(NULL == this->dictionaryItems || (void*)this->dictionaryItems == (void*)allDictionaryEntries);
- this->dictionaryItems = allDictionaryEntries; //cache the map now
- return pNew.Detach();
-T* DICTIONARY_BASE_TEMPLATE_METHOD::NewItem()
- //new() throws an exception in case allocation fails; we don't take ownership
- return new T(this->catalog); //the callee has to incr. the ref counter, if it needs the catalog object
+// Copyright (C) 2004-2010 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#ifdef BUILD_DICTIONARY_BASE //set this define before including CoordSysDictionaryBase.cpp; otherwise nothing will be built
+DICTIONARY_BASE_TEMPLATE
+DICTIONARY_BASE_TEMPLATE_METHOD::CCoordinateSystemDictionaryBase(MgCoordinateSystemCatalog *pCatalog)
+ : dictMagicNumber(0) /* no yet initialized - will be read in [SetFileName] */, dictionaryItems(NULL)
+ if (NULL == pCatalog)
+ throw new MgNullArgumentException(L"CCoordinateSystemDictionaryBase.ctor()", __LINE__, __WFILE__, NULL, L"", NULL);
+ this->catalog = SAFE_ADDREF(pCatalog); // 'Ptr = ' does not increment the ref counter
+ this->fileName = defaultFileName; //template default parameter
+DICTIONARY_BASE_TEMPLATE_METHOD::~CCoordinateSystemDictionaryBase()
+ this->catalog = NULL;
+ delete this->dictionaryItems;
+ this->dictionaryItems = NULL;
+void DICTIONARY_BASE_TEMPLATE_METHOD::Dispose()
+ delete this;
+MgCoordinateSystemCatalog* DICTIONARY_BASE_TEMPLATE_METHOD::GetCatalog()
+ return SAFE_ADDREF(this->catalog.p);
+STRING DICTIONARY_BASE_TEMPLATE_METHOD::GetDefaultFileName()
+ return defaultFileName; /* from template definition; *NOT* this->fileName ! */
+STRING DICTIONARY_BASE_TEMPLATE_METHOD::GetFileName()
+ return this->fileName; /* changeable via SetFileName*/
+void DICTIONARY_BASE_TEMPLATE_METHOD::SetFileName(CREFSTRING sFileName)
+ ::SetDictionaryFileName(
+ sFileName,
+ this->catalog->GetDictionaryDir(),
+ this->dictMagicNumber, //will be set
+ definitionAccess->magicNumberCallback, //open mode
+ definitionAccess->csMapTargetFileName, //CS Map file target
+ L"CoordSysDictionaryBase.SetFileName"); //context
+ //the filename has been set for CS library; now set it for this object...
+ this->fileName = sFileName;
+ //...and clean up the list of entries we might have already read from the old dictionary file
+STRING DICTIONARY_BASE_TEMPLATE_METHOD::GetPath() /* the full path to the file we're currently using */
+ MG_TRY()
+ return (this->catalog->GetDictionaryDir() + this->fileName);
+ MG_CATCH_AND_THROW(L"CCoordinateSystemDictionaryBase.GetPath")
+ _ASSERT(false); //OOM - unable to create the exception object?
+ return NULL;
+UINT32 DICTIONARY_BASE_TEMPLATE_METHOD::GetSize()
+ //If we have a summary available, we can just return its size.
+ if (NULL != this->dictionaryItems)
+ return static_cast<UINT32>(this->dictionaryItems->size());
+ SmartCriticalClass critical(true);
+ STRING strPath = this->GetPath();
+ csFILE *pFile = MentorDictionary::Open(this->dictMagicNumber, definitionAccess->magicNumberCallback, strPath.c_str(), Read);
+ _ASSERT(NULL != pFile);
+ UINT32 nSize;
+ MG_TRY()
+ //We're open, but no summary is available. We need to examine
+ //the file itself to find out how big it is.
+ INT32 pos = CS_ftell(pFile);
+ CS_fseek(pFile, 0, SEEK_END);
+ UINT32 ulFileBytes = 1 + CS_ftell(pFile);
+ CS_fseek(pFile, pos, SEEK_SET);
+ UINT32 nRecSize = sizeof(U);
+ //take the complete file size; subtract the "header" and divide by the size of the structs contained
+ nSize = (ulFileBytes - sizeof(this->dictMagicNumber)) / nRecSize;
+ MG_CATCH(L"CCoordinateSystemDictionaryBase.GetSize")
+ if(NULL != pFile && (0 != CS_fclose(pFile)))
+ throw new MgFileIoException(L"CCoordinateSystemDictionaryBase.GetSize", __LINE__, __WFILE__, NULL, NULL, NULL);
+ MG_THROW()
+ return nSize;
+void DICTIONARY_BASE_TEMPLATE_METHOD::Add(MgGuardDisposable* pDefinition)
+ //we won't take ownership of [pDefinition]; i.e. it can be deleted by the caller after we're done here
+ if (NULL == pDefinition)
+ throw new MgNullArgumentException(L"CCoordinateSystemDictionaryBase.Add", __LINE__, __WFILE__, NULL, L"", NULL);
+ T* pDictionaryDef = dynamic_cast<T*>(pDefinition);
+ if (!pDictionaryDef)
+ throw new MgInvalidArgumentException(L"CCoordinateSystemDictionaryBase.Add", __LINE__, __WFILE__, NULL, L"CCoordinateSystemDictionaryBase", NULL);
+ MG_TRY()
+ //::UpdateDef will lock the (file) resource via [SmartCriticalClass critical(true);]
+ MentorDictionary::UpdateDef<U, T>(
+ this->dictionaryItems, /* can be null in case no enumerator has been created yet or this dictionary isn't set up for caching */
+ definitionAccess->readDefinitionName,
+ definitionAccess->readDefinitionDescription,
+ definitionAccess->validateDefinition,
+ definitionAccess->readDefinition,
+ definitionAccess->updateDefinition,
+ definitionAccess->setupCsStructFromMgInstance,
+ pDictionaryDef,
+ false); /* bAlreadyExists - we want to create a new one, i.e. the definition must not exist yet */
+ MG_CATCH_AND_THROW(L"CCoordinateSystemDictionaryBase.Add")
+void DICTIONARY_BASE_TEMPLATE_METHOD::Remove(CREFSTRING sName)
+ MG_TRY()
+ MentorDictionary::RemoveDef<U>(
+ definitionAccess->deleteDefinition,
+ sName.c_str());
+ MG_CATCH_AND_THROW(L"CCoordinateSystemDictionaryBase.Remove")
+void DICTIONARY_BASE_TEMPLATE_METHOD::Modify(MgGuardDisposable *pDefinition)
+ throw new MgNullArgumentException(L"CCoordinateSystemDictionaryBase.Modify", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgInvalidArgumentException(L"CCoordinateSystemDictionaryBase.Modify", __LINE__, __WFILE__, NULL, L"CCoordinateSystemDictionaryBase", NULL);
+ MG_TRY()
+ //we don't pass our [this->items] here, as the dictionary is accessed anyway;
+ //if the caller passes us an unknown definition, we'll fail anyway
+ //with an exception what is per se slower than having success here
+ pDictionaryDef,
+ true); //the definition has to exist
+ MG_CATCH_AND_THROW(L"CCoordinateSystemDictionaryBase.Modify")
+MgGuardDisposable* DICTIONARY_BASE_TEMPLATE_METHOD::Get(CREFSTRING sName)
+ U *pDef = NULL;
+ char *pName = NULL;
+ //Get the name to search for
+ pName = Convert_Wide_To_Ascii(sName.c_str()); //need to delete [] pName
+ Ptr<T> pDefinition;
+ MG_TRY()
+ //make sure, we've exclusive access here
+ //Look in the dictionary
+ pDef = definitionAccess->readDefinition(pName);
+ if (NULL == pDef)
+ MgStringCollection whatArguments;
+ whatArguments.Add(sName);
+ throw new MgCoordinateSystemLoadFailedException(L"CCoordinateSystemDictionaryBase.Get", __LINE__, __WFILE__, &whatArguments, L"", NULL);
+ pDefinition = this->NewItem(); //no AddRef; release if needed
+ if (NULL == pDefinition.p) //ABA ???
+ throw new MgOutOfMemoryException(L"CCoordinateSystemDictionaryBase.Get", __LINE__, __WFILE__, NULL, L"", NULL);
+ //we've created the Mg instance, we got the CS_Map definition; now let the Mg instance initialize itself from the
+ //struct;
+ //NOTE: [fullInitialize] doesn't take ownership of [pDef] - we've to release it when done
+ definitionAccess->fullInitialize(pDefinition, pDef, this->catalog);
+ MG_CATCH(L"CCoordinateSystemDictionaryBase.Get")
+ /* cleanup - MG_CATCH() catches every exception; i.e. we'll go through here regardless of whether an exception occurred or not */
+ CS_free(pDef);
+ delete [] pName;
+ MG_THROW()
+ return pDefinition.Detach(); //done - detach the pointer so the caller can take ownership
+bool DICTIONARY_BASE_TEMPLATE_METHOD::Has(CREFSTRING sName)
+ MG_TRY()
+ try
+ Ptr<MgGuardDisposable> definition = this->Get(sName);
+ _ASSERT(NULL != definition);
+ return NULL != definition;
+ catch(MgCoordinateSystemLoadFailedException* loadFailedException)
+ loadFailedException->Release();
+ return false;
+ MG_CATCH_AND_THROW(L"CCoordinateSystemDictionaryBase.Has")
+ _ASSERT(false);
+ return false;
+MgCoordinateSystemEnum* DICTIONARY_BASE_TEMPLATE_METHOD::GetEnum()
+ //we don't take ownership; the caller has to free it
+ return this->GetEnumImp();
+CCoordinateSystemEnum* DICTIONARY_BASE_TEMPLATE_METHOD::GetEnumImp()
+ Ptr<CCoordinateSystemEnum> pNew;
+ csFILE *dictionaryFile = NULL;
+ CSystemNameDescriptionMap* allDictionaryEntries = NULL;
+ MG_TRY()
+ //do we have to cache the entries read from the dictionary file and have we already read them before?
+ if (!cacheDictionaryEntries || NULL == this->dictionaryItems)
+ //Not read yet - try to build the map from the entries found in the dictionary file
+ //[Open] throws an exception, if the dictionary file couldn't be opened
+ dictionaryFile = MentorDictionary::Open(this->dictMagicNumber, definitionAccess->magicNumberCallback, strPath.c_str(), Read);
+ allDictionaryEntries = MentorDictionary::GenerateSystemNameDescriptionMap<U>(
+ dictionaryFile,
+ definitionAccess->readAllDefinitions);
+ if (NULL == allDictionaryEntries) //whatever happend here - the dictionay file seems to be invalid
+ throw new MgCoordinateSystemLoadFailedException(L"CCoordinateSystemDictionaryBase.GetEnumImp", __LINE__, __WFILE__, NULL, L"", NULL);
+ else
+ allDictionaryEntries = this->dictionaryItems;
+ //create our enumerator we're returning to the caller
+ pNew = new CCoordinateSystemEnum;
+ pNew->Initialize(this, allDictionaryEntries /* might point to [this->dictionaryItems] */);
+ MG_CATCH(L"CCoordinateSystemDictionaryBase.GetEnumImp")
+ //in either case, try to close the dictionary file
+ if (NULL != dictionaryFile && 0 != CS_fclose(dictionaryFile) //closing went through?
+ && NULL == mgException.p)
+ //if there hasn't yet an exception occurred we now have one
+ //if there was one already we (unfortunately) do now swallow the MgFileIoException
+ mgException = new MgFileIoException(L"CCoordinateSystemDictionaryBase.GetEnumImp", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemDictionaryCloseFailedException", NULL);
+ MG_THROW()
+ //cache the map of entries if we did succeed
+ if (cacheDictionaryEntries)
+ //this will be false, if this dictionary object is shared between multiple threads; however, the dictionary must not be shared between threads
+ //without proper precautions being taken
+ _ASSERT(NULL != allDictionaryEntries);
+ _ASSERT(NULL == this->dictionaryItems || (void*)this->dictionaryItems == (void*)allDictionaryEntries);
+ this->dictionaryItems = allDictionaryEntries; //cache the map now
+ return pNew.Detach();
+T* DICTIONARY_BASE_TEMPLATE_METHOD::NewItem()
+ //new() throws an exception in case allocation fails; we don't take ownership
+ return new T(this->catalog); //the callee has to incr. the ref counter, if it needs the catalog object
#endif //BUILD_DICTIONARY_BASE
\ No newline at end of file
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysDictionaryBase.cpp
___________________________________________________________________
Added: svn:eol-style
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysDictionaryBase.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysDictionaryBase.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysDictionaryBase.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,133 +1,133 @@
-#ifndef _COORDSYSDICTIONARYBASE_H_
-#define _COORDSYSDICTIONARYBASE_H_
-#define BUILD_DICTIONARY_BASE //this is needed to build the content in CoordSysDictionaryBase.cpp
-#define MAP_CS_DEFAULT_FILE_NAME(x) L## x //builds the wchar_t default filename from the #define found in cs_map.h, e.g. from [cs_GP_NAME]
-#define DICTIONARY_FILE_NAME(x) DefaultDictName##x //defines the name of the extern variable we need to initialize each template class with
-#define DECLARE_DICTIONARY_FILE_NAME(x) extern const ACE_TCHAR DefaultDictName##x[] //declares(!) the extern variable we need for the template class
-#define DEFINE_DICTIONARY_FILE_NAME(x,y) extern const ACE_TCHAR DefaultDictName##x[] = MAP_CS_DEFAULT_FILE_NAME(y) //defines(!) the extern variable we need for the template class
-//typedef of the callback that's being invoked, when a dictionary file is being opened; the invoked method
-//has to specify the open mode the target dictionary file has to be opened with; the [long] parameter is the magic header number
-typedef CsDictionaryOpenMode (*MagicNumberCallback)(long);
-template<class T/* Mg API class */, class U /* CS map struct */>
-struct DefinitionAccess //carries all method pointers needed by this dictionary base implementation so it can interact with the Mg API and the CS Map API
-public:
- DefinitionAccess(
- U* (*ReadDefinition)(const char* definitionKey), //reads a definition from a dictionary file; the caller is responsible for freeing the returned object
- int (*UpdateDefinition)(U* definition, int), //updates the definition in the dictionary file
- int (*DeleteDefinition)(U* definition), //deletes the definition in the dictionary file
- bool (T::*ValidateDefinition)(), //validates a definition; this method is called on the Mg interface
- bool (*SetupCsStructFromMgInstance)(T*, U&), //initializes the CS Map API struct (type U) from the Mg API objects (type T)
- void (*FullInitialize)(T*, U*, MgCoordinateSystemCatalog* catalog), //fully initializes the Mg API objects from the CS Map API struct
- const char* (*ReadDefinitionName)(const U& definition), //reads the definition's name; the caller has to copy the string's content
- const char* (*ReadDefinitionDescription)(const U& definition), //reads the definition's description; the caller must copy the string's content (if not NULL)
- int (*ReadAllDefinitions) (csFILE *strm, U* definition, int*), // reads the entire content of a dictionary file; depends on the current file pointer position
- void (*CsMapTargetFileName)(const char *newFileName), //set the target dictionary file name in the CS Map library
- CsDictionaryOpenMode (*MagicNumberCallback)(long)) //returns the correct open mode for a dictionary file taking into account the magic number read from the file; passed in as long
- readDefinition(ReadDefinition),
- updateDefinition(UpdateDefinition),
- deleteDefinition(DeleteDefinition),
- validateDefinition(ValidateDefinition),
- setupCsStructFromMgInstance(SetupCsStructFromMgInstance),
- fullInitialize(FullInitialize),
- readDefinitionName(ReadDefinitionName),
- readDefinitionDescription(ReadDefinitionDescription),
- readAllDefinitions(ReadAllDefinitions),
- csMapTargetFileName(CsMapTargetFileName),
- magicNumberCallback(MagicNumberCallback)
- U* (*readDefinition)(const char* definitionKey);
- int (*updateDefinition)(U* definition, int);
- int (*deleteDefinition)(U* definition);
- bool (T::*validateDefinition)();
- bool (*setupCsStructFromMgInstance)(T*, U&);
- void (*fullInitialize)(T*, U*, MgCoordinateSystemCatalog* catalog);
- const char* (*readDefinitionName)(const U& definition);
- const char* (*readDefinitionDescription)(const U& definition);
- int (*readAllDefinitions) (csFILE *strm, U* definition, int*);
- void (*csMapTargetFileName) (const char *newFileName);
- CsDictionaryOpenMode (*magicNumberCallback)(long);
-#define DICTIONARY_BASE_TEMPLATE template <class T /* dictionary entries */, class U /* CS_MAP C type*/, \
- DefinitionAccess<T, U>* definitionAccess, \
- bool cacheDictionaryEntries, INT32 defaultMagicNumber, const wchar_t* defaultFileName>
-#define DICTIONARY_BASE_TEMPLATE_METHOD CCoordinateSystemDictionaryBase<T, U, definitionAccess, cacheDictionaryEntries, defaultMagicNumber, defaultFileName>
-#define DICTIONARY_BASE_TEMPLATE_OBJECT CCoordinateSystemDictionaryBase<T, U, definitionAccess, cacheDictionaryEntries, defaultMagicNumber, defaultFileName>
-#define DICTIONARY_BASE_ENUM_TEMPLATE_METHOD DictionaryBaseEnum<T, U, definitionAccess, cacheDictionaryEntries, defaultMagicNumber, defaultFileName>
-namespace CSLibrary
- DICTIONARY_BASE_TEMPLATE
- class CCoordinateSystemDictionaryBase : public MgCoordinateSystemDictionaryBase
- public:
- /* construction / destruction */
- CCoordinateSystemDictionaryBase(MgCoordinateSystemCatalog *pCatalog);
- virtual ~CCoordinateSystemDictionaryBase();
- /* overrides */
- virtual MgCoordinateSystemCatalog* GetCatalog();
- virtual STRING GetDefaultFileName();
- virtual STRING GetFileName();
- virtual void SetFileName(CREFSTRING sFileName);
- virtual STRING GetPath();
- virtual UINT32 GetSize();
- virtual void Add(MgGuardDisposable *pDefinition);
- virtual void Remove(CREFSTRING sName);
- virtual void Modify(MgGuardDisposable *pDefinition);
- virtual MgGuardDisposable* Get(CREFSTRING sName); // TODO - this needs to be removed!
- virtual bool Has(CREFSTRING sName);
- virtual MgCoordinateSystemEnum* GetEnum();
- virtual void Dispose();
- /* implementation */
- T* NewItem();
- protected:
- virtual CCoordinateSystemEnum* GetEnumImp();
- protected:
- Ptr<MgCoordinateSystemCatalog> catalog;
- STRING fileName;
- CSystemNameDescriptionMap* dictionaryItems;
- INT32 dictMagicNumber;
-} // End of namespace
-#endif //_COORDSYSDICTIONARYBASE_H_
+#ifndef _COORDSYSDICTIONARYBASE_H_
+#define _COORDSYSDICTIONARYBASE_H_
+#define BUILD_DICTIONARY_BASE //this is needed to build the content in CoordSysDictionaryBase.cpp
+#define MAP_CS_DEFAULT_FILE_NAME(x) L## x //builds the wchar_t default filename from the #define found in cs_map.h, e.g. from [cs_GP_NAME]
+#define DICTIONARY_FILE_NAME(x) DefaultDictName##x //defines the name of the extern variable we need to initialize each template class with
+#define DECLARE_DICTIONARY_FILE_NAME(x) extern const ACE_TCHAR DefaultDictName##x[] //declares(!) the extern variable we need for the template class
+#define DEFINE_DICTIONARY_FILE_NAME(x,y) extern const ACE_TCHAR DefaultDictName##x[] = MAP_CS_DEFAULT_FILE_NAME(y) //defines(!) the extern variable we need for the template class
+//typedef of the callback that's being invoked, when a dictionary file is being opened; the invoked method
+//has to specify the open mode the target dictionary file has to be opened with; the [long] parameter is the magic header number
+typedef CsDictionaryOpenMode (*MagicNumberCallback)(long);
+template<class T/* Mg API class */, class U /* CS map struct */>
+struct DefinitionAccess //carries all method pointers needed by this dictionary base implementation so it can interact with the Mg API and the CS Map API
+public:
+ DefinitionAccess(
+ U* (*ReadDefinition)(const char* definitionKey), //reads a definition from a dictionary file; the caller is responsible for freeing the returned object
+ int (*UpdateDefinition)(U* definition, int), //updates the definition in the dictionary file
+ int (*DeleteDefinition)(U* definition), //deletes the definition in the dictionary file
+ bool (T::*ValidateDefinition)(), //validates a definition; this method is called on the Mg interface
+ bool (*SetupCsStructFromMgInstance)(T*, U&), //initializes the CS Map API struct (type U) from the Mg API objects (type T)
+ void (*FullInitialize)(T*, U*, MgCoordinateSystemCatalog* catalog), //fully initializes the Mg API objects from the CS Map API struct
+ const char* (*ReadDefinitionName)(const U& definition), //reads the definition's name; the caller has to copy the string's content
+ const char* (*ReadDefinitionDescription)(const U& definition), //reads the definition's description; the caller must copy the string's content (if not NULL)
+ int (*ReadAllDefinitions) (csFILE *strm, U* definition, int*), // reads the entire content of a dictionary file; depends on the current file pointer position
+ void (*CsMapTargetFileName)(const char *newFileName), //set the target dictionary file name in the CS Map library
+ CsDictionaryOpenMode (*MagicNumberCallback)(long)) //returns the correct open mode for a dictionary file taking into account the magic number read from the file; passed in as long
+ readDefinition(ReadDefinition),
+ updateDefinition(UpdateDefinition),
+ deleteDefinition(DeleteDefinition),
+ validateDefinition(ValidateDefinition),
+ setupCsStructFromMgInstance(SetupCsStructFromMgInstance),
+ fullInitialize(FullInitialize),
+ readDefinitionName(ReadDefinitionName),
+ readDefinitionDescription(ReadDefinitionDescription),
+ readAllDefinitions(ReadAllDefinitions),
+ csMapTargetFileName(CsMapTargetFileName),
+ magicNumberCallback(MagicNumberCallback)
+ U* (*readDefinition)(const char* definitionKey);
+ int (*updateDefinition)(U* definition, int);
+ int (*deleteDefinition)(U* definition);
+ bool (T::*validateDefinition)();
+ bool (*setupCsStructFromMgInstance)(T*, U&);
+ void (*fullInitialize)(T*, U*, MgCoordinateSystemCatalog* catalog);
+ const char* (*readDefinitionName)(const U& definition);
+ const char* (*readDefinitionDescription)(const U& definition);
+ int (*readAllDefinitions) (csFILE *strm, U* definition, int*);
+ void (*csMapTargetFileName) (const char *newFileName);
+ CsDictionaryOpenMode (*magicNumberCallback)(long);
+#define DICTIONARY_BASE_TEMPLATE template <class T /* dictionary entries */, class U /* CS_MAP C type*/, \
+ DefinitionAccess<T, U>* definitionAccess, \
+ bool cacheDictionaryEntries, INT32 defaultMagicNumber, const wchar_t* defaultFileName>
+#define DICTIONARY_BASE_TEMPLATE_METHOD CCoordinateSystemDictionaryBase<T, U, definitionAccess, cacheDictionaryEntries, defaultMagicNumber, defaultFileName>
+#define DICTIONARY_BASE_TEMPLATE_OBJECT CCoordinateSystemDictionaryBase<T, U, definitionAccess, cacheDictionaryEntries, defaultMagicNumber, defaultFileName>
+#define DICTIONARY_BASE_ENUM_TEMPLATE_METHOD DictionaryBaseEnum<T, U, definitionAccess, cacheDictionaryEntries, defaultMagicNumber, defaultFileName>
+namespace CSLibrary
+ DICTIONARY_BASE_TEMPLATE
+ class CCoordinateSystemDictionaryBase : public MgCoordinateSystemDictionaryBase
+ public:
+ /* construction / destruction */
+ CCoordinateSystemDictionaryBase(MgCoordinateSystemCatalog *pCatalog);
+ virtual ~CCoordinateSystemDictionaryBase();
+ /* overrides */
+ virtual MgCoordinateSystemCatalog* GetCatalog();
+ virtual STRING GetDefaultFileName();
+ virtual STRING GetFileName();
+ virtual void SetFileName(CREFSTRING sFileName);
+ virtual STRING GetPath();
+ virtual UINT32 GetSize();
+ virtual void Add(MgGuardDisposable *pDefinition);
+ virtual void Remove(CREFSTRING sName);
+ virtual void Modify(MgGuardDisposable *pDefinition);
+ virtual MgGuardDisposable* Get(CREFSTRING sName); // TODO - this needs to be removed!
+ virtual bool Has(CREFSTRING sName);
+ virtual MgCoordinateSystemEnum* GetEnum();
+ virtual void Dispose();
+ /* implementation */
+ T* NewItem();
+ protected:
+ virtual CCoordinateSystemEnum* GetEnumImp();
+ protected:
+ Ptr<MgCoordinateSystemCatalog> catalog;
+ STRING fileName;
+ CSystemNameDescriptionMap* dictionaryItems;
+ INT32 dictMagicNumber;
+} // End of namespace
+#endif //_COORDSYSDICTIONARYBASE_H_
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysDictionaryBase.h
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.cpp 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.cpp 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,125 +1,125 @@
-#define CS_MAP_DEF_VARIABLE this->geocentricTransformParams
-#include "CoordSysMacro.h"
-#include "GeometryCommon.h"
-#include "CoordSysCommon.h"
-#include "CoordSysGeodeticTransformDefParams.h"
-#include "CoordSysGeodeticAnalyticalTransformDefParams.h"
-#include <cs_map.h>
-using namespace CSLibrary;
-CCoordinateSystemGeodeticAnalyticalTransformDefParams::CCoordinateSystemGeodeticAnalyticalTransformDefParams(
- const csGeocentricXformParams& params, INT32 analyticalTransformMethod, bool isProtected)
- : CCoordinateSystemGeodeticTransformDefParams(isProtected)
- , geocentricTransformParams(NULL), transformationMethod(analyticalTransformMethod)
- this->geocentricTransformParams = (csGeocentricXformParams*) CS_malc(sizeof(csGeocentricXformParams));
- if (NULL == this->geocentricTransformParams)
- throw new MgOutOfMemoryException(L"CCoordinateSystemGeodeticAnalyticalTransformDefParams.Ctor", __LINE__, __WFILE__, NULL, L"", NULL);
- *this->geocentricTransformParams = params;
-CCoordinateSystemGeodeticAnalyticalTransformDefParams::~CCoordinateSystemGeodeticAnalyticalTransformDefParams()
- this->ReleaseInstance();
-void CCoordinateSystemGeodeticAnalyticalTransformDefParams::Dispose()
- delete this;
-void CCoordinateSystemGeodeticAnalyticalTransformDefParams::ReleaseInstance()
- if (NULL != this->geocentricTransformParams)
- CS_free(this->geocentricTransformParams);
- this->geocentricTransformParams = NULL;
-void CCoordinateSystemGeodeticAnalyticalTransformDefParams::CopyTo(void* target) const
- ENSURE_NOT_NULL(target, CCoordinateSystemGeodeticAnalyticalTransformDefParams::CopyTo);
- memcpy(target, this->geocentricTransformParams, sizeof(cs_GeodeticTransform_::csGeodeticXformParameters::csGeodeticXformParmsGeocentric));
-bool CCoordinateSystemGeodeticAnalyticalTransformDefParams::IsValid()
- //we're relying on the CS_gxchk() method that will be invoked, before the parent transformation
- //definition is finally passed to CS_Map
- return true;
-bool CCoordinateSystemGeodeticAnalyticalTransformDefParams::IsProtected()
- return CCoordinateSystemGeodeticTransformDefParams::IsProtected();
-INT32 CCoordinateSystemGeodeticAnalyticalTransformDefParams::GetTransformationMethod()
- return this->transformationMethod;
-void CCoordinateSystemGeodeticAnalyticalTransformDefParams::SetTransformationMethod(INT32 analyticalMethodCode)
- VERIFY_NOT_PROTECTED(L"CCoordinateSystemGeodeticAnalyticalTransformDefParams::SetTransformationMethod");
- switch(analyticalMethodCode)
- case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::None:
- case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::ThreeParameter:
- case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::Molodensky:
- case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::AbridgedMolodensky:
- case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::Geocentric:
- case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::FourParameter:
- case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::SixParameter:
- case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::Bursa:
- case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::Frame:
- case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::SevenParameter:
- case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::MolodenskyBadekas:
- break;
- default:
- throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticAnalyticalTransformDefParams.SetTransformationMethod", __LINE__, __WFILE__, NULL, L"", NULL);
- this->transformationMethod = analyticalMethodCode;
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,DeltaX,double,this->geocentricTransformParams->deltaX)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,DeltaY,double,this->geocentricTransformParams->deltaY)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,DeltaZ,double,this->geocentricTransformParams->deltaZ)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,RotateX,double,this->geocentricTransformParams->rotateX)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,RotateY,double,this->geocentricTransformParams->rotateY)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,RotateZ,double,this->geocentricTransformParams->rotateZ)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,Scale,double,this->geocentricTransformParams->scale)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,TranslateX,double,this->geocentricTransformParams->translateX)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,TranslateY,double,this->geocentricTransformParams->translateY)
+#define CS_MAP_DEF_VARIABLE this->geocentricTransformParams
+#include "CoordSysMacro.h"
+#include "GeometryCommon.h"
+#include "CoordSysCommon.h"
+#include "CoordSysGeodeticTransformDefParams.h"
+#include "CoordSysGeodeticAnalyticalTransformDefParams.h"
+#include <cs_map.h>
+using namespace CSLibrary;
+CCoordinateSystemGeodeticAnalyticalTransformDefParams::CCoordinateSystemGeodeticAnalyticalTransformDefParams(
+ const csGeocentricXformParams& params, INT32 analyticalTransformMethod, bool isProtected)
+ : CCoordinateSystemGeodeticTransformDefParams(isProtected)
+ , geocentricTransformParams(NULL), transformationMethod(analyticalTransformMethod)
+ this->geocentricTransformParams = (csGeocentricXformParams*) CS_malc(sizeof(csGeocentricXformParams));
+ if (NULL == this->geocentricTransformParams)
+ throw new MgOutOfMemoryException(L"CCoordinateSystemGeodeticAnalyticalTransformDefParams.Ctor", __LINE__, __WFILE__, NULL, L"", NULL);
+ *this->geocentricTransformParams = params;
+CCoordinateSystemGeodeticAnalyticalTransformDefParams::~CCoordinateSystemGeodeticAnalyticalTransformDefParams()
+ this->ReleaseInstance();
+void CCoordinateSystemGeodeticAnalyticalTransformDefParams::Dispose()
+ delete this;
+void CCoordinateSystemGeodeticAnalyticalTransformDefParams::ReleaseInstance()
+ if (NULL != this->geocentricTransformParams)
+ CS_free(this->geocentricTransformParams);
+ this->geocentricTransformParams = NULL;
+void CCoordinateSystemGeodeticAnalyticalTransformDefParams::CopyTo(void* target) const
+ ENSURE_NOT_NULL(target, CCoordinateSystemGeodeticAnalyticalTransformDefParams::CopyTo);
+ memcpy(target, this->geocentricTransformParams, sizeof(cs_GeodeticTransform_::csGeodeticXformParameters::csGeodeticXformParmsGeocentric));
+bool CCoordinateSystemGeodeticAnalyticalTransformDefParams::IsValid()
+ //we're relying on the CS_gxchk() method that will be invoked, before the parent transformation
+ //definition is finally passed to CS_Map
+ return true;
+bool CCoordinateSystemGeodeticAnalyticalTransformDefParams::IsProtected()
+ return CCoordinateSystemGeodeticTransformDefParams::IsProtected();
+INT32 CCoordinateSystemGeodeticAnalyticalTransformDefParams::GetTransformationMethod()
+ return this->transformationMethod;
+void CCoordinateSystemGeodeticAnalyticalTransformDefParams::SetTransformationMethod(INT32 analyticalMethodCode)
+ VERIFY_NOT_PROTECTED(L"CCoordinateSystemGeodeticAnalyticalTransformDefParams::SetTransformationMethod");
+ switch(analyticalMethodCode)
+ case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::None:
+ case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::ThreeParameter:
+ case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::Molodensky:
+ case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::AbridgedMolodensky:
+ case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::Geocentric:
+ case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::FourParameter:
+ case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::SixParameter:
+ case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::Bursa:
+ case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::Frame:
+ case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::SevenParameter:
+ case MgCoordinateSystemGeodeticAnalyticalTransformationMethod::MolodenskyBadekas:
+ break;
+ default:
+ throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticAnalyticalTransformDefParams.SetTransformationMethod", __LINE__, __WFILE__, NULL, L"", NULL);
+ this->transformationMethod = analyticalMethodCode;
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,DeltaX,double,this->geocentricTransformParams->deltaX)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,DeltaY,double,this->geocentricTransformParams->deltaY)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,DeltaZ,double,this->geocentricTransformParams->deltaZ)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,RotateX,double,this->geocentricTransformParams->rotateX)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,RotateY,double,this->geocentricTransformParams->rotateY)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,RotateZ,double,this->geocentricTransformParams->rotateZ)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,Scale,double,this->geocentricTransformParams->scale)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,TranslateX,double,this->geocentricTransformParams->translateX)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,TranslateY,double,this->geocentricTransformParams->translateY)
DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,TranslateZ,double,this->geocentricTransformParams->translateZ)
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.cpp
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,84 +1,84 @@
-#ifndef _CCOORDSYSGEODETICANALYTICALTRANSFORMDEFPARAMS_H_
-#define _CCOORDSYSGEODETICANALYTICALTRANSFORMDEFPARAMS_H_
- typedef cs_GeodeticTransform_::csGeodeticXformParameters::csGeodeticXformParmsGeocentric csGeocentricXformParams;
- class CCoordinateSystemGeodeticAnalyticalTransformDefParams :
- public MgCoordinateSystemGeodeticAnalyticalTransformDefParams,
- public CCoordinateSystemGeodeticTransformDefParams
- public:
- CCoordinateSystemGeodeticAnalyticalTransformDefParams(const csGeocentricXformParams& params, INT32 analyticalTransformMethod, bool isProtected);
- ~CCoordinateSystemGeodeticAnalyticalTransformDefParams();
- virtual bool IsValid();
- virtual bool IsProtected();
- virtual void CopyTo(void* target) const;
- //MgCoordinateSystemGeodeticAnalyticalTransformDefParams implementation
- virtual double GetDeltaX();
- virtual void SetDeltaX(double deltaX);
- virtual double GetDeltaY();
- virtual void SetDeltaY(double deltaY);
- virtual double GetDeltaZ();
- virtual void SetDeltaZ(double deltaZ);
- virtual double GetRotateX();
- virtual void SetRotateX(double rotateX);
- virtual double GetRotateY();
- virtual void SetRotateY(double rotateY);
- virtual double GetRotateZ();
- virtual void SetRotateZ(double rotateZ);
- virtual double GetScale();
- virtual void SetScale(double scale);
- virtual double GetTranslateX();
- virtual void SetTranslateX(double translateX);
- virtual double GetTranslateY();
- virtual void SetTranslateY(double translateY);
- virtual double GetTranslateZ();
- virtual void SetTranslateZ(double translateZ);
- virtual INT32 GetTransformationMethod();
- virtual void SetTransformationMethod(INT32 analyticalMethodCode);
- private:
- void ReleaseInstance();
- private:
- csGeocentricXformParams* geocentricTransformParams;
- INT32 transformationMethod;
-} //namespace CSLibrary
+#ifndef _CCOORDSYSGEODETICANALYTICALTRANSFORMDEFPARAMS_H_
+#define _CCOORDSYSGEODETICANALYTICALTRANSFORMDEFPARAMS_H_
+ typedef cs_GeodeticTransform_::csGeodeticXformParameters::csGeodeticXformParmsGeocentric csGeocentricXformParams;
+ class CCoordinateSystemGeodeticAnalyticalTransformDefParams :
+ public MgCoordinateSystemGeodeticAnalyticalTransformDefParams,
+ public CCoordinateSystemGeodeticTransformDefParams
+ public:
+ CCoordinateSystemGeodeticAnalyticalTransformDefParams(const csGeocentricXformParams& params, INT32 analyticalTransformMethod, bool isProtected);
+ ~CCoordinateSystemGeodeticAnalyticalTransformDefParams();
+ virtual bool IsValid();
+ virtual bool IsProtected();
+ virtual void CopyTo(void* target) const;
+ //MgCoordinateSystemGeodeticAnalyticalTransformDefParams implementation
+ virtual double GetDeltaX();
+ virtual void SetDeltaX(double deltaX);
+ virtual double GetDeltaY();
+ virtual void SetDeltaY(double deltaY);
+ virtual double GetDeltaZ();
+ virtual void SetDeltaZ(double deltaZ);
+ virtual double GetRotateX();
+ virtual void SetRotateX(double rotateX);
+ virtual double GetRotateY();
+ virtual void SetRotateY(double rotateY);
+ virtual double GetRotateZ();
+ virtual void SetRotateZ(double rotateZ);
+ virtual double GetScale();
+ virtual void SetScale(double scale);
+ virtual double GetTranslateX();
+ virtual void SetTranslateX(double translateX);
+ virtual double GetTranslateY();
+ virtual void SetTranslateY(double translateY);
+ virtual double GetTranslateZ();
+ virtual void SetTranslateZ(double translateZ);
+ virtual INT32 GetTransformationMethod();
+ virtual void SetTransformationMethod(INT32 analyticalMethodCode);
+ private:
+ void ReleaseInstance();
+ private:
+ csGeocentricXformParams* geocentricTransformParams;
+ INT32 transformationMethod;
+} //namespace CSLibrary
#endif //_CCOORDSYSGEODETICANALYTICALTRANSFORMDEFPARAMS_H_
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.h
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.cpp 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.cpp 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,188 +1,188 @@
-#define CS_MAP_DEF_VARIABLE this->gridFileParams
-#include "CoordSysUtil.h"
-#include "MentorUtil.h"
-#include "CoordSysGeodeticTransformGridFile.h"
-#include "CoordSysGeodeticInterpolationTransformDefParams.h"
-CCoordinateSystemGeodeticInterpolationTransformDefParams::CCoordinateSystemGeodeticInterpolationTransformDefParams(
- const csGridFileXformParams& params, bool isProtected)
- : CCoordinateSystemGeodeticTransformDefParams(isProtected), gridFileParams(NULL)
- this->Reset();
- *this->gridFileParams = params;
-CCoordinateSystemGeodeticInterpolationTransformDefParams::~CCoordinateSystemGeodeticInterpolationTransformDefParams()
-void CCoordinateSystemGeodeticInterpolationTransformDefParams::Dispose()
- delete this;
-void CCoordinateSystemGeodeticInterpolationTransformDefParams::Reset()
- this->gridFileParams = (csGridFileXformParams*) CS_malc(sizeof(csGridFileXformParams));
- if (NULL == this->gridFileParams)
- throw new MgOutOfMemoryException(L"CCoordinateSystemGeodeticInterpolationTransformDefParams.Reset", __LINE__, __WFILE__, NULL, L"", NULL);
- memset(this->gridFileParams, 0, sizeof(csGridFileXformParams));
-void CCoordinateSystemGeodeticInterpolationTransformDefParams::ReleaseInstance()
- if (NULL != this->gridFileParams)
- CS_free(this->gridFileParams);
- this->gridFileParams = NULL;
-void CCoordinateSystemGeodeticInterpolationTransformDefParams::SetGridFiles(MgDisposableCollection* gridFiles)
- VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticInterpolationTransformDefParams.SetGridFiles");
- VERIFY_NOT_PROTECTED(L"CCoordinateSystemGeodeticInterpolationTransformDefParams.SetGridFiles");
- //we don't take ownership over fileNames
- ENSURE_NOT_NULL(gridFiles, CCoordinateSystemGeodeticInterpolationTransformDefParams::SetGridFileNames);
- const INT32 fileNamesCount = gridFiles->GetCount();
- if (fileNamesCount > csGRIDI1_FILEMAX)
- throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticInterpolationTransformDefParams.SetGridFiles", __LINE__, __WFILE__, NULL, L"", NULL);
- bool emptyFileCollection = (0 == fileNamesCount);
- csGeodeticXfromParmsFile_* allFiles = emptyFileCollection ? NULL : new csGeodeticXfromParmsFile_[fileNamesCount];
- MG_TRY()
- if (!emptyFileCollection)
- memset(allFiles, 0, fileNamesCount * sizeof(csGeodeticXfromParmsFile_));
- for(INT32 i = 0; i < fileNamesCount; i++)
- Ptr<MgDisposable> gridFile = gridFiles->GetItem(i); //calls [AddRef] on the item being returned
- CCoordinateSystemGeodeticTransformGridFile* gridFileSetting = dynamic_cast<CCoordinateSystemGeodeticTransformGridFile*>(gridFile.p);
- if (NULL == gridFileSetting)
- //we only allow for setting valid grid files
- if (!gridFileSetting->IsValid())
- //take the values from the settings we have been passed here and set our internal
- //[csGridFileXFormat] instance at index [i] to those values
- gridFileSetting->CopyTo(&allFiles[i]);
- this->gridFileParams->fileReferenceCount = fileNamesCount;
- //wipe out all memory where the filenames are stored...
- memset(this->gridFileParams->fileNames, 0, csGRIDI1_FILEMAX * sizeof(csGeodeticXfromParmsFile_));
- //...and copy our values in case we've been given a non-empty list
- memcpy(this->gridFileParams->fileNames, allFiles, fileNamesCount * sizeof(csGeodeticXfromParmsFile_));
- MG_CATCH(L"CCoordinateSystemGeodeticInterpolationTransformDefParams.SetGridFileNames");
- delete[] allFiles; //safe to call on [null]
- MG_THROW();
-MgDisposableCollection* CCoordinateSystemGeodeticInterpolationTransformDefParams::GetGridFiles()
- Ptr<MgDisposableCollection> gridFileNames = new MgDisposableCollection();
- INT32 fileCount = this->gridFileParams->fileReferenceCount;
- if (0 == fileCount)
- return gridFileNames.Detach();
- for(INT32 i = 0; i < fileCount && i < csGRIDI1_FILEMAX; i++)
- csGeodeticXfromParmsFile_& singleGridFile = this->gridFileParams->fileNames[i];
- Ptr<CCoordinateSystemGeodeticTransformGridFile> gridFileSetting =
- new CCoordinateSystemGeodeticTransformGridFile(&singleGridFile, this->IsProtected());
- //the collection will take ownership over [gridFileSetting]
- gridFileNames->Add(gridFileSetting);
-MgCoordinateSystemGeodeticTransformGridFile* CCoordinateSystemGeodeticInterpolationTransformDefParams::NewGridFile()
- return new CCoordinateSystemGeodeticTransformGridFile(NULL, false);
-bool CCoordinateSystemGeodeticInterpolationTransformDefParams::IsValid()
- return false;
- Ptr<MgDisposableCollection> gridFiles = this->GetGridFiles();
- INT32 gridFileCount = gridFiles->GetCount();
- if (gridFileCount > csGRIDI1_FILEMAX)
- return false;
- for (INT32 i = 0; i < gridFileCount; i++)
- Ptr<MgDisposable> gridFilePtr = gridFiles->GetItem(i);
- MgCoordinateSystemGeodeticTransformGridFile* gridFile = dynamic_cast<MgCoordinateSystemGeodeticTransformGridFile*>(gridFilePtr.p);
- if (NULL == gridFile || !gridFile->IsValid())
- _ASSERT(false); //how comes? This can only have happened when we initialized this item here
- return false;
- return true; //0 items count is ok
-bool CCoordinateSystemGeodeticInterpolationTransformDefParams::IsProtected()
-DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticInterpolationTransformDefParams,Fallback,this->gridFileParams->fallback)
-void CCoordinateSystemGeodeticInterpolationTransformDefParams::CopyTo(void* target) const
- ENSURE_NOT_NULL(target, CCoordinateSystemGeodeticInterpolationTransformDefParams::CopyTo);
- memcpy(target, this->gridFileParams, sizeof(csGridFileXformParams));
+#define CS_MAP_DEF_VARIABLE this->gridFileParams
+#include "CoordSysUtil.h"
+#include "MentorUtil.h"
+#include "CoordSysGeodeticTransformGridFile.h"
+#include "CoordSysGeodeticInterpolationTransformDefParams.h"
+CCoordinateSystemGeodeticInterpolationTransformDefParams::CCoordinateSystemGeodeticInterpolationTransformDefParams(
+ const csGridFileXformParams& params, bool isProtected)
+ : CCoordinateSystemGeodeticTransformDefParams(isProtected), gridFileParams(NULL)
+ this->Reset();
+ *this->gridFileParams = params;
+CCoordinateSystemGeodeticInterpolationTransformDefParams::~CCoordinateSystemGeodeticInterpolationTransformDefParams()
+void CCoordinateSystemGeodeticInterpolationTransformDefParams::Dispose()
+ delete this;
+void CCoordinateSystemGeodeticInterpolationTransformDefParams::Reset()
+ this->gridFileParams = (csGridFileXformParams*) CS_malc(sizeof(csGridFileXformParams));
+ if (NULL == this->gridFileParams)
+ throw new MgOutOfMemoryException(L"CCoordinateSystemGeodeticInterpolationTransformDefParams.Reset", __LINE__, __WFILE__, NULL, L"", NULL);
+ memset(this->gridFileParams, 0, sizeof(csGridFileXformParams));
+void CCoordinateSystemGeodeticInterpolationTransformDefParams::ReleaseInstance()
+ if (NULL != this->gridFileParams)
+ CS_free(this->gridFileParams);
+ this->gridFileParams = NULL;
+void CCoordinateSystemGeodeticInterpolationTransformDefParams::SetGridFiles(MgDisposableCollection* gridFiles)
+ VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticInterpolationTransformDefParams.SetGridFiles");
+ VERIFY_NOT_PROTECTED(L"CCoordinateSystemGeodeticInterpolationTransformDefParams.SetGridFiles");
+ //we don't take ownership over fileNames
+ ENSURE_NOT_NULL(gridFiles, CCoordinateSystemGeodeticInterpolationTransformDefParams::SetGridFileNames);
+ const INT32 fileNamesCount = gridFiles->GetCount();
+ if (fileNamesCount > csGRIDI1_FILEMAX)
+ throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticInterpolationTransformDefParams.SetGridFiles", __LINE__, __WFILE__, NULL, L"", NULL);
+ bool emptyFileCollection = (0 == fileNamesCount);
+ csGeodeticXfromParmsFile_* allFiles = emptyFileCollection ? NULL : new csGeodeticXfromParmsFile_[fileNamesCount];
+ MG_TRY()
+ if (!emptyFileCollection)
+ memset(allFiles, 0, fileNamesCount * sizeof(csGeodeticXfromParmsFile_));
+ for(INT32 i = 0; i < fileNamesCount; i++)
+ Ptr<MgDisposable> gridFile = gridFiles->GetItem(i); //calls [AddRef] on the item being returned
+ CCoordinateSystemGeodeticTransformGridFile* gridFileSetting = dynamic_cast<CCoordinateSystemGeodeticTransformGridFile*>(gridFile.p);
+ if (NULL == gridFileSetting)
+ //we only allow for setting valid grid files
+ if (!gridFileSetting->IsValid())
+ //take the values from the settings we have been passed here and set our internal
+ //[csGridFileXFormat] instance at index [i] to those values
+ gridFileSetting->CopyTo(&allFiles[i]);
+ this->gridFileParams->fileReferenceCount = fileNamesCount;
+ //wipe out all memory where the filenames are stored...
+ memset(this->gridFileParams->fileNames, 0, csGRIDI1_FILEMAX * sizeof(csGeodeticXfromParmsFile_));
+ //...and copy our values in case we've been given a non-empty list
+ memcpy(this->gridFileParams->fileNames, allFiles, fileNamesCount * sizeof(csGeodeticXfromParmsFile_));
+ MG_CATCH(L"CCoordinateSystemGeodeticInterpolationTransformDefParams.SetGridFileNames");
+ delete[] allFiles; //safe to call on [null]
+ MG_THROW();
+MgDisposableCollection* CCoordinateSystemGeodeticInterpolationTransformDefParams::GetGridFiles()
+ Ptr<MgDisposableCollection> gridFileNames = new MgDisposableCollection();
+ INT32 fileCount = this->gridFileParams->fileReferenceCount;
+ if (0 == fileCount)
+ return gridFileNames.Detach();
+ for(INT32 i = 0; i < fileCount && i < csGRIDI1_FILEMAX; i++)
+ csGeodeticXfromParmsFile_& singleGridFile = this->gridFileParams->fileNames[i];
+ Ptr<CCoordinateSystemGeodeticTransformGridFile> gridFileSetting =
+ new CCoordinateSystemGeodeticTransformGridFile(&singleGridFile, this->IsProtected());
+ //the collection will take ownership over [gridFileSetting]
+ gridFileNames->Add(gridFileSetting);
+MgCoordinateSystemGeodeticTransformGridFile* CCoordinateSystemGeodeticInterpolationTransformDefParams::NewGridFile()
+ return new CCoordinateSystemGeodeticTransformGridFile(NULL, false);
+bool CCoordinateSystemGeodeticInterpolationTransformDefParams::IsValid()
+ return false;
+ Ptr<MgDisposableCollection> gridFiles = this->GetGridFiles();
+ INT32 gridFileCount = gridFiles->GetCount();
+ if (gridFileCount > csGRIDI1_FILEMAX)
+ return false;
+ for (INT32 i = 0; i < gridFileCount; i++)
+ Ptr<MgDisposable> gridFilePtr = gridFiles->GetItem(i);
+ MgCoordinateSystemGeodeticTransformGridFile* gridFile = dynamic_cast<MgCoordinateSystemGeodeticTransformGridFile*>(gridFilePtr.p);
+ if (NULL == gridFile || !gridFile->IsValid())
+ _ASSERT(false); //how comes? This can only have happened when we initialized this item here
+ return false;
+ return true; //0 items count is ok
+bool CCoordinateSystemGeodeticInterpolationTransformDefParams::IsProtected()
+DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticInterpolationTransformDefParams,Fallback,this->gridFileParams->fallback)
+void CCoordinateSystemGeodeticInterpolationTransformDefParams::CopyTo(void* target) const
+ ENSURE_NOT_NULL(target, CCoordinateSystemGeodeticInterpolationTransformDefParams::CopyTo);
+ memcpy(target, this->gridFileParams, sizeof(csGridFileXformParams));
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.cpp
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,62 +1,62 @@
-#ifndef _CCOORDINATESYSTEMGEODETICINTERPOLATIONTRANSFORMDEFPARAMS_H_
-#define _CCOORDINATESYSTEMGEODETICINTERPOLATIONTRANSFORMDEFPARAMS_H_
- typedef cs_GeodeticTransform_::csGeodeticXformParameters::csGeodeticXformParmsGridFiles_ csGridFileXformParams;
- class CCoordinateSystemGeodeticInterpolationTransformDefParams :
- public MgCoordinateSystemGeodeticInterpolationTransformDefParams,
- public:
- CCoordinateSystemGeodeticInterpolationTransformDefParams(const csGridFileXformParams& params, bool isProtected);
- ~CCoordinateSystemGeodeticInterpolationTransformDefParams();
- // >>> MgCoordinateSystemGeodeticInterpolationTransformDefParams
- virtual void SetGridFiles(MgDisposableCollection* gridFiles);
- virtual MgDisposableCollection* GetGridFiles();
- virtual STRING GetFallback();
- virtual void SetFallback(CREFSTRING);
- virtual MgCoordinateSystemGeodeticTransformGridFile* NewGridFile();
- // <<< MgCoordinateSystemGeodeticInterpolationTransformDefParams
- virtual bool IsValid(); //from MgCoordinateSystemGeodeticTransformDefParams
- private:
- void CopyTo(void* target) const;
- void Reset();
- private:
- csGridFileXformParams* gridFileParams;
+#ifndef _CCOORDINATESYSTEMGEODETICINTERPOLATIONTRANSFORMDEFPARAMS_H_
+#define _CCOORDINATESYSTEMGEODETICINTERPOLATIONTRANSFORMDEFPARAMS_H_
+ typedef cs_GeodeticTransform_::csGeodeticXformParameters::csGeodeticXformParmsGridFiles_ csGridFileXformParams;
+ class CCoordinateSystemGeodeticInterpolationTransformDefParams :
+ public MgCoordinateSystemGeodeticInterpolationTransformDefParams,
+ public:
+ CCoordinateSystemGeodeticInterpolationTransformDefParams(const csGridFileXformParams& params, bool isProtected);
+ ~CCoordinateSystemGeodeticInterpolationTransformDefParams();
+ // >>> MgCoordinateSystemGeodeticInterpolationTransformDefParams
+ virtual void SetGridFiles(MgDisposableCollection* gridFiles);
+ virtual MgDisposableCollection* GetGridFiles();
+ virtual STRING GetFallback();
+ virtual void SetFallback(CREFSTRING);
+ virtual MgCoordinateSystemGeodeticTransformGridFile* NewGridFile();
+ // <<< MgCoordinateSystemGeodeticInterpolationTransformDefParams
+ virtual bool IsValid(); //from MgCoordinateSystemGeodeticTransformDefParams
+ private:
+ void CopyTo(void* target) const;
+ void Reset();
+ private:
+ csGridFileXformParams* gridFileParams;
#endif //_CCOORDINATESYSTEMGEODETICINTERPOLATIONTRANSFORMDEFPARAMS_H_
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.h
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.cpp 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.cpp 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,133 +1,133 @@
-// Copyright (C) 2004-2010 by Autodesk, Inc.
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of version 2.1 of the GNU Lesser
-// General Public License as published by the Free Software Foundation.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-#define CS_MAP_DEF_VARIABLE this->mulRegParams
-#include "CoordSysGeodeticMultipleRegressionTransformDefParams.h"
-CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::CCoordinateSystemGeodeticMultipleRegressionTransformDefParams(
- const csMultipleRegressionXformParams& params, INT32 mulRegTransformMethod, bool isProtected)
- , mulRegParams(NULL), transformationMethod(mulRegTransformMethod)
- this->Reset();
- *this->mulRegParams = params;
-CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::~CCoordinateSystemGeodeticMultipleRegressionTransformDefParams()
-void CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::Dispose()
- delete this;
-void CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::Reset()
- this->mulRegParams = (csMultipleRegressionXformParams*) CS_malc(sizeof(csMultipleRegressionXformParams));
- if (NULL == this->mulRegParams)
- throw new MgOutOfMemoryException(L"CCoordinateSystemGeodeticMultipleRegressionTransformDefParams.Reset", __LINE__, __WFILE__, NULL, L"", NULL);
- memset(this->mulRegParams, 0, sizeof(csMultipleRegressionXformParams));
-void CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::ReleaseInstance()
- if (NULL != this->mulRegParams)
- CS_free(this->mulRegParams);
- this->mulRegParams = NULL;
-void CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::CopyTo(void* target) const
- ENSURE_NOT_NULL(target, CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::CopyTo);
- memcpy(target, this->mulRegParams, sizeof(csMultipleRegressionXformParams));
-bool CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::IsValid()
- return true;
-bool CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::IsProtected()
-INT32 CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::GetTransformationMethod()
-void CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::SetTransformationMethod(INT32 mulRegTransformationMethod)
- VERIFY_NOT_PROTECTED(L"CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::SetTransformationMethod");
- switch(mulRegTransformationMethod)
- case MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod::None:
- case MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod::GeneralPolynomialEpsg:
- case MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod::MultipleRegression:
- break;
- default:
- throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticMultipleRegressionTransformDefParams.SetTransformationMethod", __LINE__, __WFILE__, NULL, L"", NULL);
- this->transformationMethod = mulRegTransformationMethod;
-//DEFINE_GET_SET_NUMERIC_IDX(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,PhiBitmap,UINT32,this->mulRegParams->phiBitMap,3)
-//DEFINE_GET_SET_NUMERIC_IDX(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,LambdaBitmap,UINT32,this->mulRegParams->lambdaBitMap,3)
-//DEFINE_GET_SET_NUMERIC_IDX(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,HeightBitmap,UINT32,this->mulRegParams->heightBitMap,3)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,Validation,double,this->mulRegParams->validation)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,TestPhi,double,this->mulRegParams->testPhi)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,TestLambda,double,this->mulRegParams->testLambda)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,DeltaPhi,double,this->mulRegParams->deltaPhi)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,DeltaLambda,double,this->mulRegParams->deltaLambda)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,DeltaHeight,double,this->mulRegParams->deltaHeight)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,PhiOffset,double,this->mulRegParams->phiOffset)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,LambdaOffset,double,this->mulRegParams->lambdaOffset)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,NormalizationScale,double,this->mulRegParams->normalizationScale)
-DEFINE_GET_SET_NUMERIC_IDX(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,CoefficientPhi,double,this->mulRegParams->coeffPhi,104)
-DEFINE_GET_SET_NUMERIC_IDX(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,CoefficientLambda,double,this->mulRegParams->coeffLambda,104)
+#define CS_MAP_DEF_VARIABLE this->mulRegParams
+#include "CoordSysGeodeticMultipleRegressionTransformDefParams.h"
+CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::CCoordinateSystemGeodeticMultipleRegressionTransformDefParams(
+ const csMultipleRegressionXformParams& params, INT32 mulRegTransformMethod, bool isProtected)
+ , mulRegParams(NULL), transformationMethod(mulRegTransformMethod)
+ this->Reset();
+ *this->mulRegParams = params;
+CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::~CCoordinateSystemGeodeticMultipleRegressionTransformDefParams()
+void CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::Dispose()
+ delete this;
+void CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::Reset()
+ this->mulRegParams = (csMultipleRegressionXformParams*) CS_malc(sizeof(csMultipleRegressionXformParams));
+ if (NULL == this->mulRegParams)
+ throw new MgOutOfMemoryException(L"CCoordinateSystemGeodeticMultipleRegressionTransformDefParams.Reset", __LINE__, __WFILE__, NULL, L"", NULL);
+ memset(this->mulRegParams, 0, sizeof(csMultipleRegressionXformParams));
+void CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::ReleaseInstance()
+ if (NULL != this->mulRegParams)
+ CS_free(this->mulRegParams);
+ this->mulRegParams = NULL;
+void CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::CopyTo(void* target) const
+ ENSURE_NOT_NULL(target, CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::CopyTo);
+ memcpy(target, this->mulRegParams, sizeof(csMultipleRegressionXformParams));
+bool CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::IsValid()
+ return true;
+bool CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::IsProtected()
+INT32 CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::GetTransformationMethod()
+void CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::SetTransformationMethod(INT32 mulRegTransformationMethod)
+ VERIFY_NOT_PROTECTED(L"CCoordinateSystemGeodeticMultipleRegressionTransformDefParams::SetTransformationMethod");
+ switch(mulRegTransformationMethod)
+ case MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod::None:
+ case MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod::GeneralPolynomialEpsg:
+ case MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod::MultipleRegression:
+ break;
+ default:
+ throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticMultipleRegressionTransformDefParams.SetTransformationMethod", __LINE__, __WFILE__, NULL, L"", NULL);
+ this->transformationMethod = mulRegTransformationMethod;
+//DEFINE_GET_SET_NUMERIC_IDX(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,PhiBitmap,UINT32,this->mulRegParams->phiBitMap,3)
+//DEFINE_GET_SET_NUMERIC_IDX(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,LambdaBitmap,UINT32,this->mulRegParams->lambdaBitMap,3)
+//DEFINE_GET_SET_NUMERIC_IDX(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,HeightBitmap,UINT32,this->mulRegParams->heightBitMap,3)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,Validation,double,this->mulRegParams->validation)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,TestPhi,double,this->mulRegParams->testPhi)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,TestLambda,double,this->mulRegParams->testLambda)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,DeltaPhi,double,this->mulRegParams->deltaPhi)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,DeltaLambda,double,this->mulRegParams->deltaLambda)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,DeltaHeight,double,this->mulRegParams->deltaHeight)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,PhiOffset,double,this->mulRegParams->phiOffset)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,LambdaOffset,double,this->mulRegParams->lambdaOffset)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,NormalizationScale,double,this->mulRegParams->normalizationScale)
+DEFINE_GET_SET_NUMERIC_IDX(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,CoefficientPhi,double,this->mulRegParams->coeffPhi,104)
+DEFINE_GET_SET_NUMERIC_IDX(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,CoefficientLambda,double,this->mulRegParams->coeffLambda,104)
DEFINE_GET_SET_NUMERIC_IDX(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,CoefficientHeight,double,this->mulRegParams->coeffHeight,104)
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.cpp
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,101 +1,101 @@
-#ifndef _CCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMDEFPARAMS_H_
-#define _CCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMDEFPARAMS_H_
- typedef cs_GeodeticTransform_::csGeodeticXformParameters::csGeodeticXformParmsDmaMulReg_ csMultipleRegressionXformParams;
- class CCoordinateSystemGeodeticMultipleRegressionTransformDefParams :
- public MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams,
- public:
- CCoordinateSystemGeodeticMultipleRegressionTransformDefParams(const csMultipleRegressionXformParams& mulRegParams,
- INT32 mulRegTransformMethod, bool isProtected);
- ~CCoordinateSystemGeodeticMultipleRegressionTransformDefParams();
- //virtual UINT32 GetPhiBitmap(INT32 index /* range [0..3]*/); //long compiles as 32 bit in MS VC;
- //virtual void SetPhiBitmap(INT32 index, UINT32 value); //long compiles as 32 bit in MS VC;
- //virtual UINT32 GetLambdaBitmap(INT32 index /* range [0..3]*/); //long compiles as 32 bit in MS VC;
- //virtual void SetLambdaBitmap(INT32 index, UINT32 value); //long compiles as 32 bit in MS VC;
- //virtual UINT32 GetHeightBitmap(INT32 index /* range [0..3]*/); //long compiles as 32 bit in MS VC;
- //virtual void SetHeightBitmap(INT32 index, UINT32 value); //long compiles as 32 bit in MS VC;
- virtual double GetValidation();
- virtual void SetValidation(double validation);
- virtual double GetTestPhi();
- virtual void SetTestPhi(double testPhi);
- virtual double GetTestLambda();
- virtual void SetTestLambda(double testLambda);
- virtual double GetDeltaPhi();
- virtual void SetDeltaPhi(double deltaPhi);
- virtual double GetDeltaLambda();
- virtual void SetDeltaLambda(double deltaLambda);
- virtual double GetDeltaHeight();
- virtual void SetDeltaHeight(double deltaHeight);
- virtual double GetPhiOffset();
- virtual void SetPhiOffset(double phiOffset);
- virtual double GetLambdaOffset();
- virtual void SetLambdaOffset(double lambdaOffset);
- virtual double GetNormalizationScale();
- virtual void SetNormalizationScale(double NormalizationScale);
- virtual double GetCoefficientPhi(INT32 index /* range [0..104]*/);
- virtual void SetCoefficientPhi(INT32 index, double value);
- virtual double GetCoefficientLambda(INT32 index /* range [0..104]*/);
- virtual void SetCoefficientLambda(INT32 index, double value);
- virtual double GetCoefficientHeight(INT32 index /* range [0..104]*/);
- virtual void SetCoefficientHeight(INT32 index, double value);
- virtual void SetTransformationMethod(INT32 mulRegTransformationMethod);
- private:
- void Reset();
- private:
- csMultipleRegressionXformParams* mulRegParams;
+// Copyright (C) 2004-2010 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#ifndef _CCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMDEFPARAMS_H_
+#define _CCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMDEFPARAMS_H_
+ typedef cs_GeodeticTransform_::csGeodeticXformParameters::csGeodeticXformParmsDmaMulReg_ csMultipleRegressionXformParams;
+ class CCoordinateSystemGeodeticMultipleRegressionTransformDefParams :
+ public MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams,
+ public:
+ CCoordinateSystemGeodeticMultipleRegressionTransformDefParams(const csMultipleRegressionXformParams& mulRegParams,
+ INT32 mulRegTransformMethod, bool isProtected);
+ ~CCoordinateSystemGeodeticMultipleRegressionTransformDefParams();
+ //virtual UINT32 GetPhiBitmap(INT32 index /* range [0..3]*/); //long compiles as 32 bit in MS VC;
+ //virtual void SetPhiBitmap(INT32 index, UINT32 value); //long compiles as 32 bit in MS VC;
+ //virtual UINT32 GetLambdaBitmap(INT32 index /* range [0..3]*/); //long compiles as 32 bit in MS VC;
+ //virtual void SetLambdaBitmap(INT32 index, UINT32 value); //long compiles as 32 bit in MS VC;
+ //virtual UINT32 GetHeightBitmap(INT32 index /* range [0..3]*/); //long compiles as 32 bit in MS VC;
+ //virtual void SetHeightBitmap(INT32 index, UINT32 value); //long compiles as 32 bit in MS VC;
+ virtual double GetValidation();
+ virtual void SetValidation(double validation);
+ virtual double GetTestPhi();
+ virtual void SetTestPhi(double testPhi);
+ virtual double GetTestLambda();
+ virtual void SetTestLambda(double testLambda);
+ virtual double GetDeltaPhi();
+ virtual void SetDeltaPhi(double deltaPhi);
+ virtual double GetDeltaLambda();
+ virtual void SetDeltaLambda(double deltaLambda);
+ virtual double GetDeltaHeight();
+ virtual void SetDeltaHeight(double deltaHeight);
+ virtual double GetPhiOffset();
+ virtual void SetPhiOffset(double phiOffset);
+ virtual double GetLambdaOffset();
+ virtual void SetLambdaOffset(double lambdaOffset);
+ virtual double GetNormalizationScale();
+ virtual void SetNormalizationScale(double NormalizationScale);
+ virtual double GetCoefficientPhi(INT32 index /* range [0..104]*/);
+ virtual void SetCoefficientPhi(INT32 index, double value);
+ virtual double GetCoefficientLambda(INT32 index /* range [0..104]*/);
+ virtual void SetCoefficientLambda(INT32 index, double value);
+ virtual double GetCoefficientHeight(INT32 index /* range [0..104]*/);
+ virtual void SetCoefficientHeight(INT32 index, double value);
+ virtual void SetTransformationMethod(INT32 mulRegTransformationMethod);
+ private:
+ void Reset();
+ private:
+ csMultipleRegressionXformParams* mulRegParams;
#endif //_CCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMDEFPARAMS_H_
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.h
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.cpp 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.cpp 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,237 +1,237 @@
-#include "CriticalSection.h"
-#include "CoordSysGeodeticPathElement.h"
-#include "CoordSysGeodeticPath.h"
-#include "CoordSysTransform.h" //for CCoordinateSystemTransform
-#include "CoordSysUtil.h" //for CsDictionaryOpenMode
-#include "MentorDictionary.h"
-#define CS_MAP_DEF_VARIABLE this->pathDefinition //needed by CoordSysMacro
-#include "CoordSysMacro.h" //for DEFINE_GET_SET_STRING and DEFINE_GET_SET_NUMERIC
-CCoordinateSystemGeodeticPath::CCoordinateSystemGeodeticPath(MgCoordinateSystemCatalog* pCatalog)
- : pathDefinition(NULL), catalog(SAFE_ADDREF(pCatalog))
- if (NULL == pCatalog)
- throw new MgNullArgumentException(L"CCoordinateSystemGeodeticPath.ctor", __LINE__, __WFILE__, NULL, L"", NULL);
-CCoordinateSystemGeodeticPath::~CCoordinateSystemGeodeticPath()
- this->CleanupInstanceVariables();
-void CCoordinateSystemGeodeticPath::Dispose()
- delete this;
-void CCoordinateSystemGeodeticPath::CleanupInstanceVariables()
- if (NULL != this->pathDefinition)
- CS_free(this->pathDefinition);
- this->pathDefinition = NULL;
-void CCoordinateSystemGeodeticPath::Reset()
- this->pathDefinition = (cs_GeodeticPath_*)CS_malc(sizeof(cs_GeodeticPath_));
- if (NULL == this->pathDefinition)
- throw new MgOutOfMemoryException(L"CCoordinateSystemGeodeticPath.Initialize", __LINE__, __WFILE__, NULL, L"", NULL);
- memset ((void*)this->pathDefinition, 0, sizeof(cs_GeodeticPath_));
-void CCoordinateSystemGeodeticPath::Initialize(const cs_GeodeticPath_& pathDef)
- this->Reset();
- *this->pathDefinition = pathDef;
-MgCoordinateSystemGeodeticPath* CCoordinateSystemGeodeticPath::CreateClone()
- VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticPath.CreateClone");
- Ptr<CCoordinateSystemGeodeticPath> clonedPath = new CCoordinateSystemGeodeticPath(this->catalog);
- clonedPath->Initialize(*this->pathDefinition);
- clonedPath->pathDefinition->protect = 0; //unset the protection flag; otherwise the caller wouldn't be able to change any values
- return clonedPath.Detach();
-MgCoordinateSystemGeodeticPathElement* CCoordinateSystemGeodeticPath::NewPathElement()
- return new CCoordinateSystemGeodeticPathElement(NULL, false);
-void CCoordinateSystemGeodeticPath::CopyTo(cs_GeodeticPath_& pathDef) const
- VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticPath.CopyTo");
- pathDef = *this->pathDefinition;
-//helper - don't delete; will be called by MentorUtil / DictionaryUtil
-bool CCoordinateSystemGeodeticPath::IsEncrypted()
- return false;
-bool CCoordinateSystemGeodeticPath::IsProtected()
- VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticPath.IsProtected");
- return DICTIONARY_SYS_DEF == this->pathDefinition->protect;
-bool CCoordinateSystemGeodeticPath::IsValid()
- return false;
- //make sure, the names for this path and the datums are set
- size_t pathNameLength = strlen(this->pathDefinition->pathName);
- if (0 == pathNameLength || pathNameLength >= sizeof(this->pathDefinition->pathName))
- return false;
- size_t srcDatumNameLength = strlen(this->pathDefinition->srcDatum);
- if (0 == srcDatumNameLength || srcDatumNameLength >= sizeof(this->pathDefinition->srcDatum))
- return false;
- size_t trgDatumNameLength = strlen(this->pathDefinition->trgDatum);
- if (0 == trgDatumNameLength || trgDatumNameLength >= sizeof(this->pathDefinition->trgDatum))
- return false;
- //check, whether there are only valid path elements according to MgCoordinateSystemGeodeticPathElement::IsValid()
- Ptr<MgDisposableCollection> pathElements = this->GetPathElements();
- INT32 pathElementCount = pathElements->GetCount();
- if (0 == pathElementCount || pathElementCount > csPATH_MAXXFRM)
- return false;
- if (pathElementCount != this->pathDefinition->elementCount)
- return false;
- for(INT32 i = 0; i < pathElementCount; i++)
- Ptr<MgDisposable> mgDisposable = pathElements->GetItem(i);
- MgCoordinateSystemGeodeticPathElement* pathElement = dynamic_cast<MgCoordinateSystemGeodeticPathElement*>(mgDisposable.p);
- if (NULL == pathElement)
- throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticPath.IsValid", __LINE__, __WFILE__, NULL, L"", NULL);
- if (!pathElement->IsValid())
- return false;
- //TODO: add gp_gpchk in cs_map.h
- return true; //for any other stuff, like [accuracy] etc. rely on cs_gpcheck
-//all getters and setters
-MgDisposableCollection* CCoordinateSystemGeodeticPath::GetPathElements()
- VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticPath.GetPathElements");
- Ptr<MgDisposableCollection> pathElements = new MgDisposableCollection();
- const INT32 pathElementCount = this->pathDefinition->elementCount;
- for(int i = 0; (i < pathElementCount && i <= csPATH_MAXXFRM); i++)
- const cs_GeodeticPathElement_ pathElement = this->pathDefinition->geodeticPathElements[i];
- Ptr<CCoordinateSystemGeodeticPathElement> mgPathElement =
- new CCoordinateSystemGeodeticPathElement(&pathElement, this->IsProtected());
- //the elements will be released when the collection is released
- pathElements->Add(mgPathElement);
- return pathElements.Detach();
-void CCoordinateSystemGeodeticPath::SetPathElements(MgDisposableCollection* pathElements)
- VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticPath.SetPathElements");
- VERIFY_NOT_PROTECTED(L"CCoordinateSystemGeodeticPath.SetPathElements");
- ENSURE_NOT_NULL(pathElements, CCoordinateSystemGeodeticPath::SetPathElements);
- const INT32 pathElementCount = pathElements->GetCount();
- throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticPath.SetPathElements", __LINE__, __WFILE__, NULL, L"", NULL);
- cs_GeodeticPathElement_* validElements = new cs_GeodeticPathElement_[pathElementCount];
- MG_TRY()
- memset(validElements, 0, pathElementCount * sizeof(cs_GeodeticPathElement_));
- //we don't take ownership over the elements
- for(int i = 0; i < pathElementCount; i++)
- Ptr<MgDisposable> collectionItem = pathElements->GetItem(i);
- MgCoordinateSystemGeodeticPathElement* pathElement = dynamic_cast<MgCoordinateSystemGeodeticPathElement*>(collectionItem.p);
- cs_GeodeticPathElement_& pathElementDef = validElements[i];
- //set the name of the transformation on the temporary [pathElementDef] we'll later copy into our own [this->pathDefinition]
- MentorSetString(pathElement->GetTransformName(),
- pathElementDef.geodeticXformName /* target buffer */, sizeof(pathElementDef.geodeticXformName));
- pathElementDef.direction = pathElement->GetIsInversed() ? cs_PATHDIR_INV : cs_PATHDIR_FWD;
- //wipe out the current path definition settings...
- memset(this->pathDefinition->geodeticPathElements, 0, csPATH_MAXXFRM * sizeof(cs_GeodeticPathElement_));
- //...copy the new values over...
- memcpy(this->pathDefinition->geodeticPathElements, validElements, pathElementCount * sizeof(cs_GeodeticPathElement_));
- //...and set the number of elements contained in the struct
- this->pathDefinition->elementCount = pathElementCount;
- MG_CATCH(L"CCoordinateSystemGeodeticPath.SetPathElements")
- delete[] validElements;
- MG_THROW();
-DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticPath,PathName,this->pathDefinition->pathName)
-DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticPath,Description,this->pathDefinition->description)
-DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticPath,Group,this->pathDefinition->group)
-DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticPath,Source,this->pathDefinition->source)
-DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticPath,SourceDatum,this->pathDefinition->srcDatum)
-DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticPath,TargetDatum,this->pathDefinition->trgDatum)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticPath,Accuracy,double,this->pathDefinition->accuracy)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticPath,IsReversible,bool,this->pathDefinition->reversible)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticPath,EpsgCode,INT32,this->pathDefinition->epsgCode)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticPath,EpsgVariant,INT32,this->pathDefinition->variant)
+#include "CriticalSection.h"
+#include "CoordSysGeodeticPathElement.h"
+#include "CoordSysGeodeticPath.h"
+#include "CoordSysTransform.h" //for CCoordinateSystemTransform
+#include "CoordSysUtil.h" //for CsDictionaryOpenMode
+#include "MentorDictionary.h"
+#define CS_MAP_DEF_VARIABLE this->pathDefinition //needed by CoordSysMacro
+#include "CoordSysMacro.h" //for DEFINE_GET_SET_STRING and DEFINE_GET_SET_NUMERIC
+CCoordinateSystemGeodeticPath::CCoordinateSystemGeodeticPath(MgCoordinateSystemCatalog* pCatalog)
+ : pathDefinition(NULL), catalog(SAFE_ADDREF(pCatalog))
+ if (NULL == pCatalog)
+ throw new MgNullArgumentException(L"CCoordinateSystemGeodeticPath.ctor", __LINE__, __WFILE__, NULL, L"", NULL);
+CCoordinateSystemGeodeticPath::~CCoordinateSystemGeodeticPath()
+ this->CleanupInstanceVariables();
+void CCoordinateSystemGeodeticPath::Dispose()
+ delete this;
+void CCoordinateSystemGeodeticPath::CleanupInstanceVariables()
+ if (NULL != this->pathDefinition)
+ CS_free(this->pathDefinition);
+ this->pathDefinition = NULL;
+void CCoordinateSystemGeodeticPath::Reset()
+ this->pathDefinition = (cs_GeodeticPath_*)CS_malc(sizeof(cs_GeodeticPath_));
+ if (NULL == this->pathDefinition)
+ throw new MgOutOfMemoryException(L"CCoordinateSystemGeodeticPath.Initialize", __LINE__, __WFILE__, NULL, L"", NULL);
+ memset ((void*)this->pathDefinition, 0, sizeof(cs_GeodeticPath_));
+void CCoordinateSystemGeodeticPath::Initialize(const cs_GeodeticPath_& pathDef)
+ this->Reset();
+ *this->pathDefinition = pathDef;
+MgCoordinateSystemGeodeticPath* CCoordinateSystemGeodeticPath::CreateClone()
+ VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticPath.CreateClone");
+ Ptr<CCoordinateSystemGeodeticPath> clonedPath = new CCoordinateSystemGeodeticPath(this->catalog);
+ clonedPath->Initialize(*this->pathDefinition);
+ clonedPath->pathDefinition->protect = 0; //unset the protection flag; otherwise the caller wouldn't be able to change any values
+ return clonedPath.Detach();
+MgCoordinateSystemGeodeticPathElement* CCoordinateSystemGeodeticPath::NewPathElement()
+ return new CCoordinateSystemGeodeticPathElement(NULL, false);
+void CCoordinateSystemGeodeticPath::CopyTo(cs_GeodeticPath_& pathDef) const
+ VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticPath.CopyTo");
+ pathDef = *this->pathDefinition;
+//helper - don't delete; will be called by MentorUtil / DictionaryUtil
+bool CCoordinateSystemGeodeticPath::IsEncrypted()
+ return false;
+bool CCoordinateSystemGeodeticPath::IsProtected()
+ VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticPath.IsProtected");
+ return DICTIONARY_SYS_DEF == this->pathDefinition->protect;
+bool CCoordinateSystemGeodeticPath::IsValid()
+ return false;
+ //make sure, the names for this path and the datums are set
+ size_t pathNameLength = strlen(this->pathDefinition->pathName);
+ if (0 == pathNameLength || pathNameLength >= sizeof(this->pathDefinition->pathName))
+ return false;
+ size_t srcDatumNameLength = strlen(this->pathDefinition->srcDatum);
+ if (0 == srcDatumNameLength || srcDatumNameLength >= sizeof(this->pathDefinition->srcDatum))
+ return false;
+ size_t trgDatumNameLength = strlen(this->pathDefinition->trgDatum);
+ if (0 == trgDatumNameLength || trgDatumNameLength >= sizeof(this->pathDefinition->trgDatum))
+ return false;
+ //check, whether there are only valid path elements according to MgCoordinateSystemGeodeticPathElement::IsValid()
+ Ptr<MgDisposableCollection> pathElements = this->GetPathElements();
+ INT32 pathElementCount = pathElements->GetCount();
+ if (0 == pathElementCount || pathElementCount > csPATH_MAXXFRM)
+ return false;
+ if (pathElementCount != this->pathDefinition->elementCount)
+ return false;
+ for(INT32 i = 0; i < pathElementCount; i++)
+ Ptr<MgDisposable> mgDisposable = pathElements->GetItem(i);
+ MgCoordinateSystemGeodeticPathElement* pathElement = dynamic_cast<MgCoordinateSystemGeodeticPathElement*>(mgDisposable.p);
+ if (NULL == pathElement)
+ throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticPath.IsValid", __LINE__, __WFILE__, NULL, L"", NULL);
+ if (!pathElement->IsValid())
+ return false;
+ //TODO: add gp_gpchk in cs_map.h
+ return true; //for any other stuff, like [accuracy] etc. rely on cs_gpcheck
+//all getters and setters
+MgDisposableCollection* CCoordinateSystemGeodeticPath::GetPathElements()
+ VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticPath.GetPathElements");
+ Ptr<MgDisposableCollection> pathElements = new MgDisposableCollection();
+ const INT32 pathElementCount = this->pathDefinition->elementCount;
+ for(int i = 0; (i < pathElementCount && i <= csPATH_MAXXFRM); i++)
+ const cs_GeodeticPathElement_ pathElement = this->pathDefinition->geodeticPathElements[i];
+ Ptr<CCoordinateSystemGeodeticPathElement> mgPathElement =
+ new CCoordinateSystemGeodeticPathElement(&pathElement, this->IsProtected());
+ //the elements will be released when the collection is released
+ pathElements->Add(mgPathElement);
+ return pathElements.Detach();
+void CCoordinateSystemGeodeticPath::SetPathElements(MgDisposableCollection* pathElements)
+ VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticPath.SetPathElements");
+ VERIFY_NOT_PROTECTED(L"CCoordinateSystemGeodeticPath.SetPathElements");
+ ENSURE_NOT_NULL(pathElements, CCoordinateSystemGeodeticPath::SetPathElements);
+ const INT32 pathElementCount = pathElements->GetCount();
+ throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticPath.SetPathElements", __LINE__, __WFILE__, NULL, L"", NULL);
+ cs_GeodeticPathElement_* validElements = new cs_GeodeticPathElement_[pathElementCount];
+ MG_TRY()
+ memset(validElements, 0, pathElementCount * sizeof(cs_GeodeticPathElement_));
+ //we don't take ownership over the elements
+ for(int i = 0; i < pathElementCount; i++)
+ Ptr<MgDisposable> collectionItem = pathElements->GetItem(i);
+ MgCoordinateSystemGeodeticPathElement* pathElement = dynamic_cast<MgCoordinateSystemGeodeticPathElement*>(collectionItem.p);
+ cs_GeodeticPathElement_& pathElementDef = validElements[i];
+ //set the name of the transformation on the temporary [pathElementDef] we'll later copy into our own [this->pathDefinition]
+ MentorSetString(pathElement->GetTransformName(),
+ pathElementDef.geodeticXformName /* target buffer */, sizeof(pathElementDef.geodeticXformName));
+ pathElementDef.direction = pathElement->GetIsInversed() ? cs_PATHDIR_INV : cs_PATHDIR_FWD;
+ //wipe out the current path definition settings...
+ memset(this->pathDefinition->geodeticPathElements, 0, csPATH_MAXXFRM * sizeof(cs_GeodeticPathElement_));
+ //...copy the new values over...
+ memcpy(this->pathDefinition->geodeticPathElements, validElements, pathElementCount * sizeof(cs_GeodeticPathElement_));
+ //...and set the number of elements contained in the struct
+ this->pathDefinition->elementCount = pathElementCount;
+ MG_CATCH(L"CCoordinateSystemGeodeticPath.SetPathElements")
+ delete[] validElements;
+ MG_THROW();
+DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticPath,PathName,this->pathDefinition->pathName)
+DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticPath,Description,this->pathDefinition->description)
+DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticPath,Group,this->pathDefinition->group)
+DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticPath,Source,this->pathDefinition->source)
+DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticPath,SourceDatum,this->pathDefinition->srcDatum)
+DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticPath,TargetDatum,this->pathDefinition->trgDatum)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticPath,Accuracy,double,this->pathDefinition->accuracy)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticPath,IsReversible,bool,this->pathDefinition->reversible)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticPath,EpsgCode,INT32,this->pathDefinition->epsgCode)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticPath,EpsgVariant,INT32,this->pathDefinition->variant)
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.cpp
___________________________________________________________________
Added: svn:eol-style
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,91 +1,91 @@
-#ifndef _CCOORDINATESYSTEMGEODETICPATH_H_
-#define _CCOORDINATESYSTEMGEODETICPATH_H_
-namespace CSLibrary
- class CCoordinateSystemGeodeticPath : public MgCoordinateSystemGeodeticPath
- public:
- CCoordinateSystemGeodeticPath(MgCoordinateSystemCatalog* pCatalog);
- ~CCoordinateSystemGeodeticPath();
- virtual void Dispose();
- void Initialize(const cs_GeodeticPath_& pathDef);
- void Reset();
- virtual MgCoordinateSystemGeodeticPath* CreateClone();
- virtual MgCoordinateSystemGeodeticPathElement* NewPathElement();
- //properties
- virtual STRING GetPathName();
- virtual void SetPathName(CREFSTRING);
- virtual STRING GetDescription();
- virtual void SetDescription(CREFSTRING);
- virtual STRING GetGroup();
- virtual void SetGroup(CREFSTRING);
- virtual STRING GetSource();
- virtual void SetSource(CREFSTRING);
- virtual STRING GetTargetDatum();
- virtual void SetTargetDatum(CREFSTRING);
- virtual STRING GetSourceDatum();
- virtual void SetSourceDatum(CREFSTRING);
- virtual double GetAccuracy();
- virtual void SetAccuracy(double accuracy);
- virtual bool GetIsReversible();
- virtual void SetIsReversible(bool isReversible);
- virtual INT32 GetEpsgCode();
- virtual void SetEpsgCode(INT32 epsgCode);
- virtual INT32 GetEpsgVariant();
- virtual void SetEpsgVariant(INT32 epsgVariant);
- virtual MgDisposableCollection* GetPathElements();
- virtual void SetPathElements(MgDisposableCollection* pathElements);
- //helper - don't delete
- virtual bool IsEncrypted();
- void CopyTo(cs_GeodeticPath_& pathDef) const;
- private:
- void CleanupInstanceVariables();
- private:
- cs_GeodeticPath_* pathDefinition;
- Ptr<MgCoordinateSystemCatalog> catalog;
+#ifndef _CCOORDINATESYSTEMGEODETICPATH_H_
+#define _CCOORDINATESYSTEMGEODETICPATH_H_
+namespace CSLibrary
+ class CCoordinateSystemGeodeticPath : public MgCoordinateSystemGeodeticPath
+ public:
+ CCoordinateSystemGeodeticPath(MgCoordinateSystemCatalog* pCatalog);
+ ~CCoordinateSystemGeodeticPath();
+ virtual void Dispose();
+ void Initialize(const cs_GeodeticPath_& pathDef);
+ void Reset();
+ virtual MgCoordinateSystemGeodeticPath* CreateClone();
+ virtual MgCoordinateSystemGeodeticPathElement* NewPathElement();
+ //properties
+ virtual STRING GetPathName();
+ virtual void SetPathName(CREFSTRING);
+ virtual STRING GetDescription();
+ virtual void SetDescription(CREFSTRING);
+ virtual STRING GetGroup();
+ virtual void SetGroup(CREFSTRING);
+ virtual STRING GetSource();
+ virtual void SetSource(CREFSTRING);
+ virtual STRING GetTargetDatum();
+ virtual void SetTargetDatum(CREFSTRING);
+ virtual STRING GetSourceDatum();
+ virtual void SetSourceDatum(CREFSTRING);
+ virtual double GetAccuracy();
+ virtual void SetAccuracy(double accuracy);
+ virtual bool GetIsReversible();
+ virtual void SetIsReversible(bool isReversible);
+ virtual INT32 GetEpsgCode();
+ virtual void SetEpsgCode(INT32 epsgCode);
+ virtual INT32 GetEpsgVariant();
+ virtual void SetEpsgVariant(INT32 epsgVariant);
+ virtual MgDisposableCollection* GetPathElements();
+ virtual void SetPathElements(MgDisposableCollection* pathElements);
+ //helper - don't delete
+ virtual bool IsEncrypted();
+ void CopyTo(cs_GeodeticPath_& pathDef) const;
+ private:
+ void CleanupInstanceVariables();
+ private:
+ cs_GeodeticPath_* pathDefinition;
+ Ptr<MgCoordinateSystemCatalog> catalog;
#endif //_CCOORDINATESYSTEMGEODETICPATH_H_
\ No newline at end of file
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.h
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.cpp 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.cpp 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,220 +1,220 @@
-#include "GeometryCommon.h"
-#include "CoordSysCommon.h"
-#include "CoordSysUtil.h" //for Convert_Wide_To_Ascii
-#include "MentorUtil.h" //for OpenDictionaryFile()
-#include <cs_map.h>
-#include "CoordSysEnum.h"
-#include "CoordSysDictionaryBase.h"
-#include "CoordSysGeodeticPathDictionary.h"
-using namespace CSLibrary;
-DEFINE_DICTIONARY_FILE_NAME(GeodeticPath, cs_GP_NAME);
-extern DefinitionAccess<CCoordinateSystemGeodeticPath, cs_GeodeticPath_> definitionAccess(
- CS_gpdef,
- CCoordinateSystemGeodeticPathDictionary::UpdateGeodeticPath, /* CS_gpupd has a different signature than the other CS 'update' methods */
- CS_gpdel,
- &CCoordinateSystemGeodeticPath::IsValid,
- CCoordinateSystemGeodeticPathDictionary::SetupCsGeodeticPathStruct,
- CCoordinateSystemGeodeticPathDictionary::FullInitialize,
- CCoordinateSystemGeodeticPathDictionary::ReadName,
- CCoordinateSystemGeodeticPathDictionary::ReadDescription,
- CCoordinateSystemGeodeticPathDictionary::ReadAllGeodeticPaths,
- CS_gpfnm,
- CCoordinateSystemGeodeticPathDictionary::GetFileOpenMode);
-CCoordinateSystemGeodeticPathDictionary::CCoordinateSystemGeodeticPathDictionary(MgCoordinateSystemCatalog *pCatalog)
- : m_pDictionary(new CCoordinateSystemDictionaryBase<CCoordinateSystemGeodeticPath, cs_GeodeticPath_, &definitionAccess, true, cs_GPDEF_MAGIC, DICTIONARY_FILE_NAME(GeodeticPath)>(pCatalog))
-CCoordinateSystemGeodeticPathDictionary::~CCoordinateSystemGeodeticPathDictionary()
- this->m_pDictionary = NULL;
-const char* CCoordinateSystemGeodeticPathDictionary::ReadName(const cs_GeodeticPath_& definition)
- return definition.pathName;
-const char* CCoordinateSystemGeodeticPathDictionary::ReadDescription(const cs_GeodeticPath_& definition)
- return definition.description;
-CsDictionaryOpenMode CCoordinateSystemGeodeticPathDictionary::GetFileOpenMode(long magicNumberFromFile)
- if (cs_GPDEF_MAGIC == magicNumberFromFile)
- return Write;
- _ASSERT(false);
- return Closed;
-int CCoordinateSystemGeodeticPathDictionary::UpdateGeodeticPath(cs_GeodeticPath_* csPath, int /*unused*/)
- return CS_gpupd(csPath);
-int CCoordinateSystemGeodeticPathDictionary::ReadAllGeodeticPaths(csFILE *file, cs_GeodeticPath_ *gp_def, int* /*unused*/)
- return CS_gprd(file, gp_def);
-bool CCoordinateSystemGeodeticPathDictionary::SetupCsGeodeticPathStruct(CCoordinateSystemGeodeticPath* mgGeodeticPath, cs_GeodeticPath_& csPath)
- _ASSERT(NULL != mgGeodeticPath);
- //copy the values from [mgGeodeticPath] to [csPath]; this will throw an exception in case [mgGeodeticPath] hasn't been initialized yet
- mgGeodeticPath->CopyTo(csPath);
- return true;
-void CCoordinateSystemGeodeticPathDictionary::FullInitialize(CCoordinateSystemGeodeticPath* mgGeodeticPath, cs_GeodeticPath_* csPath, MgCoordinateSystemCatalog* catalog)
- ENSURE_NOT_NULL(mgGeodeticPath, CCoordinateSystemGeodeticPathDictionary::FullInitialize);
- ENSURE_NOT_NULL(csPath, CCoordinateSystemGeodeticPathDictionary::FullInitialize);
- _ASSERT(NULL != catalog);
- mgGeodeticPath->Initialize(*csPath);
-MgCoordinateSystemGeodeticPath* CCoordinateSystemGeodeticPathDictionary::NewGeodeticPath()
- Ptr<CCoordinateSystemGeodeticPath> newPathItem = this->m_pDictionary->NewItem();
- newPathItem->Reset(); //sets up the [cs_geodeticpath_] struct; it can thus be used by
- return newPathItem.Detach();
-STRING CCoordinateSystemGeodeticPathDictionary::GetDefaultFileName()
- return this->m_pDictionary->GetDefaultFileName();
-//Gets the file name of the dictionary file.
-STRING CCoordinateSystemGeodeticPathDictionary::GetFileName()
- return this->m_pDictionary->GetFileName();
-void CCoordinateSystemGeodeticPathDictionary::SetFileName(CREFSTRING sFileName)
- this->m_pDictionary->SetFileName(sFileName);
-//Gets the path to the dictionary file, if currently open.
-STRING CCoordinateSystemGeodeticPathDictionary::GetPath()
- return this->m_pDictionary->GetPath();
-//Gets the size of the set (number of defs it currently contains).
-UINT32 CCoordinateSystemGeodeticPathDictionary::GetSize()
- return this->m_pDictionary->GetSize();
-void CCoordinateSystemGeodeticPathDictionary::Add(MgGuardDisposable *pDefinition)
- this->m_pDictionary->Add(pDefinition);
-void CCoordinateSystemGeodeticPathDictionary::Remove(CREFSTRING sName)
- this->m_pDictionary->Remove(sName);
-void CCoordinateSystemGeodeticPathDictionary::Modify(MgGuardDisposable *pDefinition)
- this->m_pDictionary->Modify(pDefinition);
-MgGuardDisposable* CCoordinateSystemGeodeticPathDictionary::Get(CREFSTRING sName)
- return this->m_pDictionary->Get(sName);
-MgCoordinateSystemGeodeticPath* CCoordinateSystemGeodeticPathDictionary::GetGeodeticPath(CREFSTRING sName)
- try
- return static_cast<MgCoordinateSystemGeodeticPath*>(this->m_pDictionary->Get(sName));
- catch(MgCoordinateSystemLoadFailedException* loadFailedException)
- //catch only the [MgCoordinateSystemLoadFailedException] and release it right away
- loadFailedException->Release();
- return NULL;
-//Returns whether the set contains a def with the specified name.
-bool CCoordinateSystemGeodeticPathDictionary::Has(CREFSTRING sName)
- return this->m_pDictionary->Has(sName);
-//Gets an enumerator for all the defs in the set.
-MgCoordinateSystemEnum* CCoordinateSystemGeodeticPathDictionary::GetEnum()
- return this->m_pDictionary->GetEnum();
-//MgDisposable
-void CCoordinateSystemGeodeticPathDictionary::Dispose()
- delete this;
-MgCoordinateSystemCatalog* CCoordinateSystemGeodeticPathDictionary::GetCatalog()
- return this->m_pDictionary->GetCatalog();
+#include "GeometryCommon.h"
+#include "CoordSysCommon.h"
+#include "CoordSysUtil.h" //for Convert_Wide_To_Ascii
+#include "MentorUtil.h" //for OpenDictionaryFile()
+#include <cs_map.h>
+#include "CoordSysEnum.h"
+#include "CoordSysDictionaryBase.h"
+#include "CoordSysGeodeticPathDictionary.h"
+using namespace CSLibrary;
+DEFINE_DICTIONARY_FILE_NAME(GeodeticPath, cs_GP_NAME);
+extern DefinitionAccess<CCoordinateSystemGeodeticPath, cs_GeodeticPath_> definitionAccess(
+ CS_gpdef,
+ CCoordinateSystemGeodeticPathDictionary::UpdateGeodeticPath, /* CS_gpupd has a different signature than the other CS 'update' methods */
+ CS_gpdel,
+ &CCoordinateSystemGeodeticPath::IsValid,
+ CCoordinateSystemGeodeticPathDictionary::SetupCsGeodeticPathStruct,
+ CCoordinateSystemGeodeticPathDictionary::FullInitialize,
+ CCoordinateSystemGeodeticPathDictionary::ReadName,
+ CCoordinateSystemGeodeticPathDictionary::ReadDescription,
+ CCoordinateSystemGeodeticPathDictionary::ReadAllGeodeticPaths,
+ CS_gpfnm,
+ CCoordinateSystemGeodeticPathDictionary::GetFileOpenMode);
+CCoordinateSystemGeodeticPathDictionary::CCoordinateSystemGeodeticPathDictionary(MgCoordinateSystemCatalog *pCatalog)
+ : m_pDictionary(new CCoordinateSystemDictionaryBase<CCoordinateSystemGeodeticPath, cs_GeodeticPath_, &definitionAccess, true, cs_GPDEF_MAGIC, DICTIONARY_FILE_NAME(GeodeticPath)>(pCatalog))
+CCoordinateSystemGeodeticPathDictionary::~CCoordinateSystemGeodeticPathDictionary()
+ this->m_pDictionary = NULL;
+const char* CCoordinateSystemGeodeticPathDictionary::ReadName(const cs_GeodeticPath_& definition)
+ return definition.pathName;
+const char* CCoordinateSystemGeodeticPathDictionary::ReadDescription(const cs_GeodeticPath_& definition)
+ return definition.description;
+CsDictionaryOpenMode CCoordinateSystemGeodeticPathDictionary::GetFileOpenMode(long magicNumberFromFile)
+ if (cs_GPDEF_MAGIC == magicNumberFromFile)
+ return Write;
+ _ASSERT(false);
+ return Closed;
+int CCoordinateSystemGeodeticPathDictionary::UpdateGeodeticPath(cs_GeodeticPath_* csPath, int /*unused*/)
+ return CS_gpupd(csPath);
+int CCoordinateSystemGeodeticPathDictionary::ReadAllGeodeticPaths(csFILE *file, cs_GeodeticPath_ *gp_def, int* /*unused*/)
+ return CS_gprd(file, gp_def);
+bool CCoordinateSystemGeodeticPathDictionary::SetupCsGeodeticPathStruct(CCoordinateSystemGeodeticPath* mgGeodeticPath, cs_GeodeticPath_& csPath)
+ _ASSERT(NULL != mgGeodeticPath);
+ //copy the values from [mgGeodeticPath] to [csPath]; this will throw an exception in case [mgGeodeticPath] hasn't been initialized yet
+ mgGeodeticPath->CopyTo(csPath);
+ return true;
+void CCoordinateSystemGeodeticPathDictionary::FullInitialize(CCoordinateSystemGeodeticPath* mgGeodeticPath, cs_GeodeticPath_* csPath, MgCoordinateSystemCatalog* catalog)
+ ENSURE_NOT_NULL(mgGeodeticPath, CCoordinateSystemGeodeticPathDictionary::FullInitialize);
+ ENSURE_NOT_NULL(csPath, CCoordinateSystemGeodeticPathDictionary::FullInitialize);
+ _ASSERT(NULL != catalog);
+ mgGeodeticPath->Initialize(*csPath);
+MgCoordinateSystemGeodeticPath* CCoordinateSystemGeodeticPathDictionary::NewGeodeticPath()
+ Ptr<CCoordinateSystemGeodeticPath> newPathItem = this->m_pDictionary->NewItem();
+ newPathItem->Reset(); //sets up the [cs_geodeticpath_] struct; it can thus be used by
+ return newPathItem.Detach();
+STRING CCoordinateSystemGeodeticPathDictionary::GetDefaultFileName()
+ return this->m_pDictionary->GetDefaultFileName();
+//Gets the file name of the dictionary file.
+STRING CCoordinateSystemGeodeticPathDictionary::GetFileName()
+ return this->m_pDictionary->GetFileName();
+void CCoordinateSystemGeodeticPathDictionary::SetFileName(CREFSTRING sFileName)
+ this->m_pDictionary->SetFileName(sFileName);
+//Gets the path to the dictionary file, if currently open.
+STRING CCoordinateSystemGeodeticPathDictionary::GetPath()
+ return this->m_pDictionary->GetPath();
+//Gets the size of the set (number of defs it currently contains).
+UINT32 CCoordinateSystemGeodeticPathDictionary::GetSize()
+ return this->m_pDictionary->GetSize();
+void CCoordinateSystemGeodeticPathDictionary::Add(MgGuardDisposable *pDefinition)
+ this->m_pDictionary->Add(pDefinition);
+void CCoordinateSystemGeodeticPathDictionary::Remove(CREFSTRING sName)
+ this->m_pDictionary->Remove(sName);
+void CCoordinateSystemGeodeticPathDictionary::Modify(MgGuardDisposable *pDefinition)
+ this->m_pDictionary->Modify(pDefinition);
+MgGuardDisposable* CCoordinateSystemGeodeticPathDictionary::Get(CREFSTRING sName)
+ return this->m_pDictionary->Get(sName);
+MgCoordinateSystemGeodeticPath* CCoordinateSystemGeodeticPathDictionary::GetGeodeticPath(CREFSTRING sName)
+ try
+ return static_cast<MgCoordinateSystemGeodeticPath*>(this->m_pDictionary->Get(sName));
+ catch(MgCoordinateSystemLoadFailedException* loadFailedException)
+ //catch only the [MgCoordinateSystemLoadFailedException] and release it right away
+ loadFailedException->Release();
+ return NULL;
+//Returns whether the set contains a def with the specified name.
+bool CCoordinateSystemGeodeticPathDictionary::Has(CREFSTRING sName)
+ return this->m_pDictionary->Has(sName);
+//Gets an enumerator for all the defs in the set.
+MgCoordinateSystemEnum* CCoordinateSystemGeodeticPathDictionary::GetEnum()
+ return this->m_pDictionary->GetEnum();
+//MgDisposable
+void CCoordinateSystemGeodeticPathDictionary::Dispose()
+ delete this;
+MgCoordinateSystemCatalog* CCoordinateSystemGeodeticPathDictionary::GetCatalog()
+ return this->m_pDictionary->GetCatalog();
#include "CoordSysDictionaryBase.cpp"
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.cpp
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,86 +1,86 @@
-#ifndef _CCOORDINATESYSTEMGEODETICPATHDICTIONARY_H_
-#define _CCOORDINATESYSTEMGEODETICPATHDICTIONARY_H_
-DECLARE_DICTIONARY_FILE_NAME(GeodeticPath);
-//typedef cs_GeodeticPath_* (*ReadPathDefinition)(const char* definitionKey, INT32 dictionaryMagicNumber);
-//typedef const char* (*ReadPathName)(const cs_GeodeticPath_* definition);
-//typedef const char* (*ReadPathDescription)(const cs_GeodeticPath_* definition);
-extern DefinitionAccess<CSLibrary::CCoordinateSystemGeodeticPath, cs_GeodeticPath_> definitionAccess;
- class CCoordinateSystemGeodeticPathDictionary : public MgCoordinateSystemGeodeticPathDictionary
- public:
- CCoordinateSystemGeodeticPathDictionary(MgCoordinateSystemCatalog *pCatalog);
- virtual ~CCoordinateSystemGeodeticPathDictionary();
- //create new path
- virtual MgCoordinateSystemGeodeticPath* NewGeodeticPath();
- virtual MgCoordinateSystemGeodeticPath* GetGeodeticPath(CREFSTRING pathName);
- //querying the dictionary
- virtual MgGuardDisposable* Get(CREFSTRING sName);
- virtual MgCoordinateSystemEnum* GetEnum();
- virtual bool Has(CREFSTRING sName);
- virtual STRING GetPath();
- virtual UINT32 GetSize();
- //CS_Map library support stuff
- virtual MgCoordinateSystemCatalog* GetCatalog();
- virtual STRING GetDefaultFileName();
- virtual STRING GetFileName();
- virtual void SetFileName(CREFSTRING sFileName);
- //modify the dictionary
- virtual void Add(MgGuardDisposable *pDefinition);
- virtual void Remove(CREFSTRING sName);
- virtual void Modify(MgGuardDisposable *pDefinition);
- //virtual void Rename(CREFSTRING sOldName, CREFSTRING sNewName);
- protected:
- //MgDisposable
- protected:
- Ptr<CCoordinateSystemDictionaryBase<CCoordinateSystemGeodeticPath, cs_GeodeticPath_, \
- &definitionAccess, true, cs_GPDEF_MAGIC, DICTIONARY_FILE_NAME(GeodeticPath)>> m_pDictionary;
- public:
- static const char* ReadName(const cs_GeodeticPath_& definition);
- static const char* ReadDescription(const cs_GeodeticPath_& definition);
- static int UpdateGeodeticPath(cs_GeodeticPath_* csPath, int /*unused*/);
- static int ReadAllGeodeticPaths(csFILE *file, cs_GeodeticPath_ *gp_def, int* /*unused*/);
- static bool SetupCsGeodeticPathStruct(CCoordinateSystemGeodeticPath* mgGeodeticPath, cs_GeodeticPath_& csPath);
- static void FullInitialize(CCoordinateSystemGeodeticPath* mgGeodeticPath, cs_GeodeticPath_* csPath, MgCoordinateSystemCatalog* catalog);
- static CsDictionaryOpenMode GetFileOpenMode(long magicNumberFromFile);
-} // End of namespace
-#endif //_CCOORDINATESYSTEMGEODETICPATHDICTIONARY_H_
+#ifndef _CCOORDINATESYSTEMGEODETICPATHDICTIONARY_H_
+#define _CCOORDINATESYSTEMGEODETICPATHDICTIONARY_H_
+DECLARE_DICTIONARY_FILE_NAME(GeodeticPath);
+//typedef cs_GeodeticPath_* (*ReadPathDefinition)(const char* definitionKey, INT32 dictionaryMagicNumber);
+//typedef const char* (*ReadPathName)(const cs_GeodeticPath_* definition);
+//typedef const char* (*ReadPathDescription)(const cs_GeodeticPath_* definition);
+extern DefinitionAccess<CSLibrary::CCoordinateSystemGeodeticPath, cs_GeodeticPath_> definitionAccess;
+ class CCoordinateSystemGeodeticPathDictionary : public MgCoordinateSystemGeodeticPathDictionary
+ public:
+ CCoordinateSystemGeodeticPathDictionary(MgCoordinateSystemCatalog *pCatalog);
+ virtual ~CCoordinateSystemGeodeticPathDictionary();
+ //create new path
+ virtual MgCoordinateSystemGeodeticPath* NewGeodeticPath();
+ virtual MgCoordinateSystemGeodeticPath* GetGeodeticPath(CREFSTRING pathName);
+ //querying the dictionary
+ virtual MgGuardDisposable* Get(CREFSTRING sName);
+ virtual MgCoordinateSystemEnum* GetEnum();
+ virtual bool Has(CREFSTRING sName);
+ virtual STRING GetPath();
+ virtual UINT32 GetSize();
+ //CS_Map library support stuff
+ virtual MgCoordinateSystemCatalog* GetCatalog();
+ virtual STRING GetDefaultFileName();
+ virtual STRING GetFileName();
+ virtual void SetFileName(CREFSTRING sFileName);
+ //modify the dictionary
+ virtual void Add(MgGuardDisposable *pDefinition);
+ virtual void Remove(CREFSTRING sName);
+ virtual void Modify(MgGuardDisposable *pDefinition);
+ //virtual void Rename(CREFSTRING sOldName, CREFSTRING sNewName);
+ protected:
+ //MgDisposable
+ protected:
+ Ptr<CCoordinateSystemDictionaryBase<CCoordinateSystemGeodeticPath, cs_GeodeticPath_, \
+ &definitionAccess, true, cs_GPDEF_MAGIC, DICTIONARY_FILE_NAME(GeodeticPath)>> m_pDictionary;
+ public:
+ static const char* ReadName(const cs_GeodeticPath_& definition);
+ static const char* ReadDescription(const cs_GeodeticPath_& definition);
+ static int UpdateGeodeticPath(cs_GeodeticPath_* csPath, int /*unused*/);
+ static int ReadAllGeodeticPaths(csFILE *file, cs_GeodeticPath_ *gp_def, int* /*unused*/);
+ static bool SetupCsGeodeticPathStruct(CCoordinateSystemGeodeticPath* mgGeodeticPath, cs_GeodeticPath_& csPath);
+ static void FullInitialize(CCoordinateSystemGeodeticPath* mgGeodeticPath, cs_GeodeticPath_* csPath, MgCoordinateSystemCatalog* catalog);
+ static CsDictionaryOpenMode GetFileOpenMode(long magicNumberFromFile);
+} // End of namespace
+#endif //_CCOORDINATESYSTEMGEODETICPATHDICTIONARY_H_
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.h
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.cpp 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.cpp 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,106 +1,106 @@
-#define CS_MAP_DEF_VARIABLE this->pathElement //needed by CoordSysMacro
-CCoordinateSystemGeodeticPathElement::CCoordinateSystemGeodeticPathElement(const cs_GeodeticPathElement_* const pathElementArg, bool isProtected)
- : pathElement(NULL), isProtected(isProtected)
- this->Reset(pathElementArg);
-CCoordinateSystemGeodeticPathElement::~CCoordinateSystemGeodeticPathElement()
-void CCoordinateSystemGeodeticPathElement::Dispose()
- delete this;
-void CCoordinateSystemGeodeticPathElement::CleanupInstanceVariables()
- if (NULL != this->pathElement)
- CS_free(this->pathElement);
- this->pathElement = NULL;
-void CCoordinateSystemGeodeticPathElement::Reset(const cs_GeodeticPathElement_* const pathElementArg)
- cs_GeodeticPathElement_* tempPathElement = (cs_GeodeticPathElement_*) CS_malc(sizeof(cs_GeodeticPathElement_));
- if (NULL == tempPathElement)
- throw new MgOutOfMemoryException(L"CCoordinateSystemGeodeticPathElement.Reset", __LINE__, __WFILE__, NULL, L"", NULL);
- MG_TRY()
- if (NULL == pathElementArg) //initialize to 0 memory
- memset(tempPathElement, 0, sizeof(cs_GeodeticPathElement_));
- else
- *tempPathElement = *pathElementArg; //otherwise, copy the values from the arg over
- this->pathElement = tempPathElement; //make us hold the allocated memory...
- tempPathElement = NULL; //...and make sure, we don't free it below
- MG_CATCH(L"CCoordinateSystemGeodeticPathElement.Reset")
- if (NULL != tempPathElement)
- CS_free(tempPathElement);
- MG_THROW()
-bool CCoordinateSystemGeodeticPathElement::IsValid()
- if (NULL == this->pathElement)
- return false;
- size_t transformNameLength = strlen(this->pathElement->geodeticXformName);
- _ASSERT(transformNameLength < sizeof(this->pathElement->geodeticXformName)); //how comes?
- //TODO: put transformNameLength 64 in cs_map.h
- if (0 == transformNameLength || transformNameLength >= sizeof(this->pathElement->geodeticXformName))
- return false;
- return (cs_PATHDIR_FWD == this->pathElement->direction) || (cs_PATHDIR_INV == this->pathElement->direction);
-bool CCoordinateSystemGeodeticPathElement::IsProtected()
- return this->isProtected;
-DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticPathElement,TransformName,this->pathElement->geodeticXformName)
+#define CS_MAP_DEF_VARIABLE this->pathElement //needed by CoordSysMacro
+CCoordinateSystemGeodeticPathElement::CCoordinateSystemGeodeticPathElement(const cs_GeodeticPathElement_* const pathElementArg, bool isProtected)
+ : pathElement(NULL), isProtected(isProtected)
+ this->Reset(pathElementArg);
+CCoordinateSystemGeodeticPathElement::~CCoordinateSystemGeodeticPathElement()
+void CCoordinateSystemGeodeticPathElement::Dispose()
+ delete this;
+void CCoordinateSystemGeodeticPathElement::CleanupInstanceVariables()
+ if (NULL != this->pathElement)
+ CS_free(this->pathElement);
+ this->pathElement = NULL;
+void CCoordinateSystemGeodeticPathElement::Reset(const cs_GeodeticPathElement_* const pathElementArg)
+ cs_GeodeticPathElement_* tempPathElement = (cs_GeodeticPathElement_*) CS_malc(sizeof(cs_GeodeticPathElement_));
+ if (NULL == tempPathElement)
+ throw new MgOutOfMemoryException(L"CCoordinateSystemGeodeticPathElement.Reset", __LINE__, __WFILE__, NULL, L"", NULL);
+ MG_TRY()
+ if (NULL == pathElementArg) //initialize to 0 memory
+ memset(tempPathElement, 0, sizeof(cs_GeodeticPathElement_));
+ else
+ *tempPathElement = *pathElementArg; //otherwise, copy the values from the arg over
+ this->pathElement = tempPathElement; //make us hold the allocated memory...
+ tempPathElement = NULL; //...and make sure, we don't free it below
+ MG_CATCH(L"CCoordinateSystemGeodeticPathElement.Reset")
+ if (NULL != tempPathElement)
+ CS_free(tempPathElement);
+ MG_THROW()
+bool CCoordinateSystemGeodeticPathElement::IsValid()
+ if (NULL == this->pathElement)
+ return false;
+ size_t transformNameLength = strlen(this->pathElement->geodeticXformName);
+ _ASSERT(transformNameLength < sizeof(this->pathElement->geodeticXformName)); //how comes?
+ //TODO: put transformNameLength 64 in cs_map.h
+ if (0 == transformNameLength || transformNameLength >= sizeof(this->pathElement->geodeticXformName))
+ return false;
+ return (cs_PATHDIR_FWD == this->pathElement->direction) || (cs_PATHDIR_INV == this->pathElement->direction);
+bool CCoordinateSystemGeodeticPathElement::IsProtected()
+ return this->isProtected;
+DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticPathElement,TransformName,this->pathElement->geodeticXformName)
DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticPathElement,IsInversed,bool,this->pathElement->direction)
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.cpp
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,51 +1,51 @@
-#ifndef _COORDSYSGEODETICPATHELEMENT_H_
-#define _COORDSYSGEODETICPATHELEMENT_H_
- class CCoordinateSystemGeodeticPathElement : public MgCoordinateSystemGeodeticPathElement
- public:
- CCoordinateSystemGeodeticPathElement(const cs_GeodeticPathElement_* const pathElement, bool isProtected);
- ~CCoordinateSystemGeodeticPathElement();
- virtual bool IsValid();
- virtual bool IsProtected();
- virtual STRING GetTransformName();
- virtual void SetTransformName(CREFSTRING);
- virtual bool GetIsInversed();
- virtual void SetIsInversed(bool);
- private:
- void Reset(const cs_GeodeticPathElement_* const pathElement);
- private:
- bool isProtected;
- cs_GeodeticPathElement_* pathElement;
-} //namespace CSLibrary
+#ifndef _COORDSYSGEODETICPATHELEMENT_H_
+#define _COORDSYSGEODETICPATHELEMENT_H_
+ class CCoordinateSystemGeodeticPathElement : public MgCoordinateSystemGeodeticPathElement
+ public:
+ CCoordinateSystemGeodeticPathElement(const cs_GeodeticPathElement_* const pathElement, bool isProtected);
+ ~CCoordinateSystemGeodeticPathElement();
+ virtual bool IsValid();
+ virtual bool IsProtected();
+ virtual STRING GetTransformName();
+ virtual void SetTransformName(CREFSTRING);
+ virtual bool GetIsInversed();
+ virtual void SetIsInversed(bool);
+ private:
+ void Reset(const cs_GeodeticPathElement_* const pathElement);
+ private:
+ bool isProtected;
+ cs_GeodeticPathElement_* pathElement;
+} //namespace CSLibrary
#endif //_COORDSYSGEODETICPATHELEMENT_H_
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.h
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,354 +1,354 @@
-// Copyright (C) 2004-2010 by Autodesk, Inc.
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of version 2.1 of the GNU Lesser
-// General Public License as published by the Free Software Foundation.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-#include "CoordSysGeodeticTransformation.h"
-#include "CoordSysGeodeticTransformDefParams.h"
-#include "CoordSysGeodeticAnalyticalTransformDefParams.h"
-#include "CoordSysGeodeticInterpolationTransformDefParams.h"
-#include "CoordSysGeodeticMultipleRegressionTransformDefParams.h"
-#include "CoordSysGeodeticTransformDef.h"
-#define CS_MAP_DEF_VARIABLE this->transformDefinition //needed by CoordSysMacro
-CCoordinateSystemGeodeticTransformDef::CCoordinateSystemGeodeticTransformDef(MgCoordinateSystemCatalog* pCatalog)
- : transformationDefType(0), transformDefinition(NULL), catalog(SAFE_ADDREF(pCatalog) /* make sure, we take a count on it */)
- //have we been passed a non-null argument?
- if (NULL == this->catalog)
- throw new MgNullArgumentException(L"CCoordinateSystemGeodeticTransformDef.ctor", __LINE__, __WFILE__, NULL, L"", NULL);
-CCoordinateSystemGeodeticTransformDef::~CCoordinateSystemGeodeticTransformDef()
- this->ReleaseInstance();
-void CCoordinateSystemGeodeticTransformDef::ReleaseInstance()
- if (NULL != this->transformDefinition)
- CS_free(this->transformDefinition);
- this->transformDefinition = NULL;
- this->transformationDefType = 0;
-void CCoordinateSystemGeodeticTransformDef::Dispose()
- delete this;
-void CCoordinateSystemGeodeticTransformDef::Reset(INT32 transformationDefType)
- INT32 transformationType;
- switch(transformationDefType)
- case MgCoordinateSystemGeodeticTransformDefType::None:
- case MgCoordinateSystemGeodeticTransformDefType::Analytical:
- case MgCoordinateSystemGeodeticTransformDefType::Interpolation:
- case MgCoordinateSystemGeodeticTransformDefType::MultipleRegression:
- transformationType = transformationDefType;
- break;
- default:
- throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticTransformDef.Reset", __LINE__, __WFILE__, NULL, L"", NULL);
- //try creating a new [cs_GeodeticTransform_] instance before we wipe out our own stuff
- cs_GeodeticTransform_* newEmptyDef = (cs_GeodeticTransform_*)CS_malc(sizeof(cs_GeodeticTransform_));
- if (NULL == newEmptyDef) //uses CS_malc which returns NULL in case allocation fails
- throw new MgOutOfMemoryException(L"CCoordinateSystemGeodeticTransformDef.Initialize", __LINE__, __WFILE__, NULL, L"", NULL);
- MG_TRY()
- //now, 0 our temp memory we've allocated
- memset ((void*)newEmptyDef, 0, sizeof(cs_GeodeticTransform_));
- //ok - everything worked out so far; release this instance's information
- _ASSERT(NULL == this->transformDefinition);
- this->transformDefinition = newEmptyDef;
- newEmptyDef = NULL; //make sure, we don't free that one after we get a hold on the (no longer temp) memory
- this->transformationDefType = transformationType;
- MG_CATCH(L"CCoordinateSystemGeodeticTransformDef.Reset")
- if (NULL != newEmptyDef) //will have been set to NULL before
- CS_free(newEmptyDef);
- MG_THROW()
-INT32 CCoordinateSystemGeodeticTransformDef::GetTransformationDefType(INT32 methodCode /* method code as read from the dictionary entry */)
- switch(methodCode)
- //standalone methods; see information in cs_geodetic.h
- case cs_DTCMTH_NULLX:
- case cs_DTCMTH_WGS72:
- transformationType = MgCoordinateSystemGeodeticTransformDefType::None;
- break;
- //multiple Regression methods
- case cs_DTCMTH_MULRG:
- case cs_DTCMTH_PLYNM:
- transformationType = MgCoordinateSystemGeodeticTransformDefType::MultipleRegression;
- break;
- //geocentric methods
- case cs_DTCMTH_3PARM:
- case cs_DTCMTH_MOLOD:
- case cs_DTCMTH_AMOLO:
- case cs_DTCMTH_GEOCT:
- case cs_DTCMTH_4PARM:
- case cs_DTCMTH_6PARM:
- case cs_DTCMTH_BURSA:
- case cs_DTCMTH_FRAME:
- case cs_DTCMTH_7PARM:
- case cs_DTCMTH_BDKAS:
- transformationType = MgCoordinateSystemGeodeticTransformDefType::Analytical;
- break;
- //grid file interpolation methods; if a transformation uses grid file(s), this is the actual
- //type - the ones below are the format of the grid file(s) being used. For example,
- //the dictionary does then contains something like
- //GRID_FILE: NTv2,FWD,.\Australia\Agd66\A66National(13.09.01).gsb
- case cs_DTCMTH_GFILE:
- transformationType = MgCoordinateSystemGeodeticTransformDefType::Interpolation;
- break;
- //the next entries are not expected; we're mapping them to the interpolation transformation type
- case cs_DTCMTH_CNTv1:
- case cs_DTCMTH_CNTv2:
- case cs_DTCMTH_FRNCH:
- case cs_DTCMTH_JAPAN:
- case cs_DTCMTH_ATS77:
- case cs_DTCMTH_OST97:
- case cs_DTCMTH_OST02:
- _ASSERT(false);
- break;
- default: //invalid / unknown [methodCode] given; don't know how to proceed here
- throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticTransformDef.Initialize", __LINE__, __WFILE__, NULL, L"", NULL);
- return transformationType;
-void CCoordinateSystemGeodeticTransformDef::Initialize(const cs_GeodeticTransform_& transformDef)
- //take the transformation type from the param we've been passed; we'll use that information to build the correct
- //parameter object later on
- INT32 transformationType = this->GetTransformationDefType(transformDef.methodCode);
- this->Reset(transformationType);
- *this->transformDefinition = transformDef;
-MgCoordinateSystemGeodeticTransformation* CCoordinateSystemGeodeticTransformDef::CreateTransformation(bool createInverse)
- VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticTransformDef.CreateTransformation");
- if (MgCoordinateSystemGeodeticTransformDefType::None == this->GetTransformDefType() || !this->IsValid())
- throw new MgInvalidOperationException(L"CCoordinateSystemGeodeticTransformDef.CreateTransformation", __LINE__,__WFILE__, NULL, L"", NULL);
- //we don't take ownership of the transformation being returned but
- //will release [sourceDatum] and [targetDatum];
- //new [CCoordinateSystemGeodeticTransformation] will have to ADDREF if needed
- return new CCoordinateSystemGeodeticTransformation(this->catalog, this, createInverse);
-MgCoordinateSystemGeodeticTransformDef* CCoordinateSystemGeodeticTransformDef::CreateClone()
- VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticTransformDef.CreateClone");
- Ptr<CCoordinateSystemGeodeticTransformDef> clonedTransformDef = new CCoordinateSystemGeodeticTransformDef(this->catalog.p);
- clonedTransformDef->Initialize(*this->transformDefinition);
- clonedTransformDef->transformDefinition->protect = 0; //unset the protection flag; otherwise the caller wouldn't be able to change any values
- return clonedTransformDef.Detach();
-void CCoordinateSystemGeodeticTransformDef::CopyTo(cs_GeodeticTransform_& transformDef) const
- VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticTransformDef.CopyTo");
- //copy our values into the [cs_GeodeticTransform_] we've been passed here
- transformDef = *this->transformDefinition;
-INT32 CCoordinateSystemGeodeticTransformDef::GetTransformDefType()
- return this->transformationDefType; //can be None
-MgCoordinateSystemGeodeticTransformDefParams* CCoordinateSystemGeodeticTransformDef::GetParameters()
- VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticTransformDef.GetParameters");
- switch(this->transformationDefType)
- return NULL;
- return static_cast<MgCoordinateSystemGeodeticAnalyticalTransformDefParams*>(new CCoordinateSystemGeodeticAnalyticalTransformDefParams(
- this->transformDefinition->parameters.geocentricParameters, this->transformDefinition->methodCode, this->IsProtected()));
- return static_cast<MgCoordinateSystemGeodeticInterpolationTransformDefParams*>(
- new CCoordinateSystemGeodeticInterpolationTransformDefParams(this->transformDefinition->parameters.fileParameters, this->IsProtected()));
- return static_cast<MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams*>(new CCoordinateSystemGeodeticMultipleRegressionTransformDefParams(
- this->transformDefinition->parameters.dmaMulRegParameters, this->transformDefinition->methodCode, this->IsProtected()));
- default: //invalid state; why's that?
- _ASSERT(false);
- throw new MgInvalidOperationException(L"CCoordinateSystemGeodeticTransformDef.GetParameters", __LINE__, __WFILE__, NULL, L"", NULL);
-void CCoordinateSystemGeodeticTransformDef::SetParameters(MgCoordinateSystemGeodeticTransformDefParams* parameters)
- VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticTransformDef.SetParameters");
- VERIFY_NOT_PROTECTED(L"CCoordinateSystemGeodeticTransformDef.SetParameters");
- //first check, whether this is a NONE transformation definition; if so, ignore the parameter altogether and wipe out
- //this instance's parameter information to NULL
- if (MgCoordinateSystemGeodeticTransformDefType::None == this->transformationDefType)
- memset(&this->transformDefinition->parameters, 0, sizeof(this->transformDefinition->parameters.sizeDetermination.unionSize));
- return;
- //otherwise: make sure, we've been passed non null paramaters...
- ENSURE_NOT_NULL(parameters, CCoordinateSystemGeodeticTransformDef::SetParameters);
- INT32 paramsMethodCode = 0x0;
- //...and the parameters are actually of the correct type, i.e. match whatever we've stored in [this->transformationDefType]
- CCoordinateSystemGeodeticTransformDefParams* transformDefParams = NULL;
- CCoordinateSystemGeodeticMultipleRegressionTransformDefParams* mulRegParams = NULL;
- CCoordinateSystemGeodeticAnalyticalTransformDefParams* analyticalParams = NULL;
- analyticalParams = dynamic_cast<CCoordinateSystemGeodeticAnalyticalTransformDefParams*>(parameters);
- if (NULL != analyticalParams)
- paramsMethodCode = analyticalParams->GetTransformationMethod();
- transformDefParams = analyticalParams;
- break;
- transformDefParams = dynamic_cast<CCoordinateSystemGeodeticInterpolationTransformDefParams*>(parameters);
- //the transformation method is "grid file"; the actual type doesn't matter as this
- //is specified through the [MgCoordinateSystemGeodeticInterpolationTransformDefParams] object;
- //such a transformation can use multiple grid files where each can have a different format
- paramsMethodCode = cs_DTCMTH_GFILE;
- break;
- mulRegParams = dynamic_cast<CCoordinateSystemGeodeticMultipleRegressionTransformDefParams*>(parameters);
- if (NULL != mulRegParams)
- paramsMethodCode = mulRegParams->GetTransformationMethod();
- transformDefParams = mulRegParams;
- break;
- default:
- _ASSERT(false); //why's that?
- break;
- if (NULL == transformDefParams)
- throw new MgInvalidOperationException(L"CCoordinateSystemGeodeticTransformDef.SetParameters", __LINE__, __WFILE__, NULL, L"", NULL);
- //copy the values from the parameter we've been passed into our own [parameters] section
- transformDefParams->CopyTo(&this->transformDefinition->parameters);
- this->transformDefinition->methodCode = paramsMethodCode;
-bool CCoordinateSystemGeodeticTransformDef::IsProtected()
- VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticTransformDef.IsProtected");
- return (DICTIONARY_SYS_DEF == this->transformDefinition->protect);
-bool CCoordinateSystemGeodeticTransformDef::IsValid()
- if (NULL == this->transformDefinition) //an unitialized definition is always invalid
- return false;
- Ptr<MgCoordinateSystemGeodeticTransformDefParams> params = this->GetParameters();
- if (!params->IsValid())
- return false;
- //TODO: would we also need to check, whether the datum(s) exists?
- CriticalClass.Enter();
- //TODO: pass correct parameters; make sure, CS_gxchk checks all stuff
- int nNumErrs = CS_gxchk(this->transformDefinition, 0, NULL, 0);
- CriticalClass.Leave();
- return (0 == nNumErrs);
- return true;
-bool CCoordinateSystemGeodeticTransformDef::IsEncrypted()
- return false;
-DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticTransformDef,TransformName,this->transformDefinition->xfrmName)
-DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticTransformDef,SourceDatum,this->transformDefinition->srcDatum)
-DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticTransformDef,TargetDatum,this->transformDefinition->trgDatum)
-DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticTransformDef,Group,this->transformDefinition->group)
-DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticTransformDef,Description,this->transformDefinition->description)
-DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticTransformDef,Source,this->transformDefinition->source)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,EpsgCode,INT32,this->transformDefinition->epsgCode)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,EpsgVariation,INT32,this->transformDefinition->epsgVariation)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,InverseSupported,bool,this->transformDefinition->inverseSupported)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,MaxIterations,INT32,this->transformDefinition->maxIterations)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,ConvergenceValue,double,this->transformDefinition->cnvrgValue)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,ErrorValue,double,this->transformDefinition->errorValue)
+// Copyright (C) 2004-2010 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "CoordSysGeodeticTransformation.h"
+#include "CoordSysGeodeticTransformDefParams.h"
+#include "CoordSysGeodeticAnalyticalTransformDefParams.h"
+#include "CoordSysGeodeticInterpolationTransformDefParams.h"
+#include "CoordSysGeodeticMultipleRegressionTransformDefParams.h"
+#include "CoordSysGeodeticTransformDef.h"
+#define CS_MAP_DEF_VARIABLE this->transformDefinition //needed by CoordSysMacro
+CCoordinateSystemGeodeticTransformDef::CCoordinateSystemGeodeticTransformDef(MgCoordinateSystemCatalog* pCatalog)
+ : transformationDefType(0), transformDefinition(NULL), catalog(SAFE_ADDREF(pCatalog) /* make sure, we take a count on it */)
+ //have we been passed a non-null argument?
+ if (NULL == this->catalog)
+ throw new MgNullArgumentException(L"CCoordinateSystemGeodeticTransformDef.ctor", __LINE__, __WFILE__, NULL, L"", NULL);
+CCoordinateSystemGeodeticTransformDef::~CCoordinateSystemGeodeticTransformDef()
+ this->ReleaseInstance();
+void CCoordinateSystemGeodeticTransformDef::ReleaseInstance()
+ if (NULL != this->transformDefinition)
+ CS_free(this->transformDefinition);
+ this->transformDefinition = NULL;
+ this->transformationDefType = 0;
+void CCoordinateSystemGeodeticTransformDef::Dispose()
+ delete this;
+void CCoordinateSystemGeodeticTransformDef::Reset(INT32 transformationDefType)
+ INT32 transformationType;
+ switch(transformationDefType)
+ case MgCoordinateSystemGeodeticTransformDefType::None:
+ case MgCoordinateSystemGeodeticTransformDefType::Analytical:
+ case MgCoordinateSystemGeodeticTransformDefType::Interpolation:
+ case MgCoordinateSystemGeodeticTransformDefType::MultipleRegression:
+ transformationType = transformationDefType;
+ break;
+ default:
+ throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticTransformDef.Reset", __LINE__, __WFILE__, NULL, L"", NULL);
+ //try creating a new [cs_GeodeticTransform_] instance before we wipe out our own stuff
+ cs_GeodeticTransform_* newEmptyDef = (cs_GeodeticTransform_*)CS_malc(sizeof(cs_GeodeticTransform_));
+ if (NULL == newEmptyDef) //uses CS_malc which returns NULL in case allocation fails
+ throw new MgOutOfMemoryException(L"CCoordinateSystemGeodeticTransformDef.Initialize", __LINE__, __WFILE__, NULL, L"", NULL);
+ MG_TRY()
+ //now, 0 our temp memory we've allocated
+ memset ((void*)newEmptyDef, 0, sizeof(cs_GeodeticTransform_));
+ //ok - everything worked out so far; release this instance's information
+ _ASSERT(NULL == this->transformDefinition);
+ this->transformDefinition = newEmptyDef;
+ newEmptyDef = NULL; //make sure, we don't free that one after we get a hold on the (no longer temp) memory
+ this->transformationDefType = transformationType;
+ MG_CATCH(L"CCoordinateSystemGeodeticTransformDef.Reset")
+ if (NULL != newEmptyDef) //will have been set to NULL before
+ CS_free(newEmptyDef);
+ MG_THROW()
+INT32 CCoordinateSystemGeodeticTransformDef::GetTransformationDefType(INT32 methodCode /* method code as read from the dictionary entry */)
+ switch(methodCode)
+ //standalone methods; see information in cs_geodetic.h
+ case cs_DTCMTH_NULLX:
+ case cs_DTCMTH_WGS72:
+ transformationType = MgCoordinateSystemGeodeticTransformDefType::None;
+ break;
+ //multiple Regression methods
+ case cs_DTCMTH_MULRG:
+ case cs_DTCMTH_PLYNM:
+ transformationType = MgCoordinateSystemGeodeticTransformDefType::MultipleRegression;
+ break;
+ //geocentric methods
+ case cs_DTCMTH_3PARM:
+ case cs_DTCMTH_MOLOD:
+ case cs_DTCMTH_AMOLO:
+ case cs_DTCMTH_GEOCT:
+ case cs_DTCMTH_4PARM:
+ case cs_DTCMTH_6PARM:
+ case cs_DTCMTH_BURSA:
+ case cs_DTCMTH_FRAME:
+ case cs_DTCMTH_7PARM:
+ case cs_DTCMTH_BDKAS:
+ transformationType = MgCoordinateSystemGeodeticTransformDefType::Analytical;
+ break;
+ //grid file interpolation methods; if a transformation uses grid file(s), this is the actual
+ //type - the ones below are the format of the grid file(s) being used. For example,
+ //the dictionary does then contains something like
+ //GRID_FILE: NTv2,FWD,.\Australia\Agd66\A66National(13.09.01).gsb
+ case cs_DTCMTH_GFILE:
+ transformationType = MgCoordinateSystemGeodeticTransformDefType::Interpolation;
+ break;
+ //the next entries are not expected; we're mapping them to the interpolation transformation type
+ case cs_DTCMTH_CNTv1:
+ case cs_DTCMTH_CNTv2:
+ case cs_DTCMTH_FRNCH:
+ case cs_DTCMTH_JAPAN:
+ case cs_DTCMTH_ATS77:
+ case cs_DTCMTH_OST97:
+ case cs_DTCMTH_OST02:
+ _ASSERT(false);
+ break;
+ default: //invalid / unknown [methodCode] given; don't know how to proceed here
+ throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticTransformDef.Initialize", __LINE__, __WFILE__, NULL, L"", NULL);
+ return transformationType;
+void CCoordinateSystemGeodeticTransformDef::Initialize(const cs_GeodeticTransform_& transformDef)
+ //take the transformation type from the param we've been passed; we'll use that information to build the correct
+ //parameter object later on
+ INT32 transformationType = this->GetTransformationDefType(transformDef.methodCode);
+ this->Reset(transformationType);
+ *this->transformDefinition = transformDef;
+MgCoordinateSystemGeodeticTransformation* CCoordinateSystemGeodeticTransformDef::CreateTransformation(bool createInverse)
+ VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticTransformDef.CreateTransformation");
+ if (MgCoordinateSystemGeodeticTransformDefType::None == this->GetTransformDefType() || !this->IsValid())
+ throw new MgInvalidOperationException(L"CCoordinateSystemGeodeticTransformDef.CreateTransformation", __LINE__,__WFILE__, NULL, L"", NULL);
+ //we don't take ownership of the transformation being returned but
+ //will release [sourceDatum] and [targetDatum];
+ //new [CCoordinateSystemGeodeticTransformation] will have to ADDREF if needed
+ return new CCoordinateSystemGeodeticTransformation(this->catalog, this, createInverse);
+MgCoordinateSystemGeodeticTransformDef* CCoordinateSystemGeodeticTransformDef::CreateClone()
+ VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticTransformDef.CreateClone");
+ Ptr<CCoordinateSystemGeodeticTransformDef> clonedTransformDef = new CCoordinateSystemGeodeticTransformDef(this->catalog.p);
+ clonedTransformDef->Initialize(*this->transformDefinition);
+ clonedTransformDef->transformDefinition->protect = 0; //unset the protection flag; otherwise the caller wouldn't be able to change any values
+ return clonedTransformDef.Detach();
+void CCoordinateSystemGeodeticTransformDef::CopyTo(cs_GeodeticTransform_& transformDef) const
+ VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticTransformDef.CopyTo");
+ //copy our values into the [cs_GeodeticTransform_] we've been passed here
+ transformDef = *this->transformDefinition;
+INT32 CCoordinateSystemGeodeticTransformDef::GetTransformDefType()
+ return this->transformationDefType; //can be None
+MgCoordinateSystemGeodeticTransformDefParams* CCoordinateSystemGeodeticTransformDef::GetParameters()
+ VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticTransformDef.GetParameters");
+ switch(this->transformationDefType)
+ return NULL;
+ return static_cast<MgCoordinateSystemGeodeticAnalyticalTransformDefParams*>(new CCoordinateSystemGeodeticAnalyticalTransformDefParams(
+ this->transformDefinition->parameters.geocentricParameters, this->transformDefinition->methodCode, this->IsProtected()));
+ return static_cast<MgCoordinateSystemGeodeticInterpolationTransformDefParams*>(
+ new CCoordinateSystemGeodeticInterpolationTransformDefParams(this->transformDefinition->parameters.fileParameters, this->IsProtected()));
+ return static_cast<MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams*>(new CCoordinateSystemGeodeticMultipleRegressionTransformDefParams(
+ this->transformDefinition->parameters.dmaMulRegParameters, this->transformDefinition->methodCode, this->IsProtected()));
+ default: //invalid state; why's that?
+ _ASSERT(false);
+ throw new MgInvalidOperationException(L"CCoordinateSystemGeodeticTransformDef.GetParameters", __LINE__, __WFILE__, NULL, L"", NULL);
+void CCoordinateSystemGeodeticTransformDef::SetParameters(MgCoordinateSystemGeodeticTransformDefParams* parameters)
+ VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticTransformDef.SetParameters");
+ VERIFY_NOT_PROTECTED(L"CCoordinateSystemGeodeticTransformDef.SetParameters");
+ //first check, whether this is a NONE transformation definition; if so, ignore the parameter altogether and wipe out
+ //this instance's parameter information to NULL
+ if (MgCoordinateSystemGeodeticTransformDefType::None == this->transformationDefType)
+ memset(&this->transformDefinition->parameters, 0, sizeof(this->transformDefinition->parameters.sizeDetermination.unionSize));
+ return;
+ //otherwise: make sure, we've been passed non null paramaters...
+ ENSURE_NOT_NULL(parameters, CCoordinateSystemGeodeticTransformDef::SetParameters);
+ INT32 paramsMethodCode = 0x0;
+ //...and the parameters are actually of the correct type, i.e. match whatever we've stored in [this->transformationDefType]
+ CCoordinateSystemGeodeticTransformDefParams* transformDefParams = NULL;
+ CCoordinateSystemGeodeticMultipleRegressionTransformDefParams* mulRegParams = NULL;
+ CCoordinateSystemGeodeticAnalyticalTransformDefParams* analyticalParams = NULL;
+ analyticalParams = dynamic_cast<CCoordinateSystemGeodeticAnalyticalTransformDefParams*>(parameters);
+ if (NULL != analyticalParams)
+ paramsMethodCode = analyticalParams->GetTransformationMethod();
+ transformDefParams = analyticalParams;
+ break;
+ transformDefParams = dynamic_cast<CCoordinateSystemGeodeticInterpolationTransformDefParams*>(parameters);
+ //the transformation method is "grid file"; the actual type doesn't matter as this
+ //is specified through the [MgCoordinateSystemGeodeticInterpolationTransformDefParams] object;
+ //such a transformation can use multiple grid files where each can have a different format
+ paramsMethodCode = cs_DTCMTH_GFILE;
+ break;
+ mulRegParams = dynamic_cast<CCoordinateSystemGeodeticMultipleRegressionTransformDefParams*>(parameters);
+ if (NULL != mulRegParams)
+ paramsMethodCode = mulRegParams->GetTransformationMethod();
+ transformDefParams = mulRegParams;
+ break;
+ default:
+ _ASSERT(false); //why's that?
+ break;
+ if (NULL == transformDefParams)
+ throw new MgInvalidOperationException(L"CCoordinateSystemGeodeticTransformDef.SetParameters", __LINE__, __WFILE__, NULL, L"", NULL);
+ //copy the values from the parameter we've been passed into our own [parameters] section
+ transformDefParams->CopyTo(&this->transformDefinition->parameters);
+ this->transformDefinition->methodCode = paramsMethodCode;
+bool CCoordinateSystemGeodeticTransformDef::IsProtected()
+ VERIFY_INITIALIZED(L"CCoordinateSystemGeodeticTransformDef.IsProtected");
+ return (DICTIONARY_SYS_DEF == this->transformDefinition->protect);
+bool CCoordinateSystemGeodeticTransformDef::IsValid()
+ if (NULL == this->transformDefinition) //an unitialized definition is always invalid
+ return false;
+ Ptr<MgCoordinateSystemGeodeticTransformDefParams> params = this->GetParameters();
+ if (!params->IsValid())
+ return false;
+ //TODO: would we also need to check, whether the datum(s) exists?
+ CriticalClass.Enter();
+ //TODO: pass correct parameters; make sure, CS_gxchk checks all stuff
+ int nNumErrs = CS_gxchk(this->transformDefinition, 0, NULL, 0);
+ CriticalClass.Leave();
+ return (0 == nNumErrs);
+ return true;
+bool CCoordinateSystemGeodeticTransformDef::IsEncrypted()
+ return false;
+DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticTransformDef,TransformName,this->transformDefinition->xfrmName)
+DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticTransformDef,SourceDatum,this->transformDefinition->srcDatum)
+DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticTransformDef,TargetDatum,this->transformDefinition->trgDatum)
+DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticTransformDef,Group,this->transformDefinition->group)
+DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticTransformDef,Description,this->transformDefinition->description)
+DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticTransformDef,Source,this->transformDefinition->source)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,EpsgCode,INT32,this->transformDefinition->epsgCode)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,EpsgVariation,INT32,this->transformDefinition->epsgVariation)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,InverseSupported,bool,this->transformDefinition->inverseSupported)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,MaxIterations,INT32,this->transformDefinition->maxIterations)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,ConvergenceValue,double,this->transformDefinition->cnvrgValue)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,ErrorValue,double,this->transformDefinition->errorValue)
DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,Accuracy,double,this->transformDefinition->accuracy)
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,107 +1,107 @@
-#ifndef _CCOORDINATESYSTEMGEODETICTRANSFORMDEF_H_
-#define _CCOORDINATESYSTEMGEODETICTRANSFORMDEF_H_
-class CCoordinateSystemGeodeticTransformDef : public MgCoordinateSystemGeodeticTransformDef
-public:
- CCoordinateSystemGeodeticTransformDef(MgCoordinateSystemCatalog* pCatalog);
- virtual ~CCoordinateSystemGeodeticTransformDef();
- void Reset(INT32 transformationDefType);
- void Initialize(const cs_GeodeticTransform_& transformDef);
- virtual MgCoordinateSystemGeodeticTransformDef* CreateClone();
- //begin properties
- virtual void SetTransformName(CREFSTRING name);
- virtual void SetSourceDatum(CREFSTRING datumKey);
- virtual void SetTargetDatum(CREFSTRING datumKey);
- virtual void SetGroup(CREFSTRING group);
- virtual void SetDescription(CREFSTRING description);
- virtual void SetSource(CREFSTRING source);
- virtual INT32 GetEpsgVariation();
- virtual void SetEpsgVariation(INT32 epsgVariation);
- virtual bool GetInverseSupported();
- virtual void SetInverseSupported(bool inverseSupported);
- virtual INT32 GetMaxIterations();
- virtual void SetMaxIterations(INT32 maxIterations);
- virtual double GetConvergenceValue();
- virtual void SetConvergenceValue(double convergenceValue);
- virtual double GetErrorValue();
- virtual void SetErrorValue(double errorValue);
- virtual MgCoordinateSystemGeodeticTransformDefParams* GetParameters();
- virtual void SetParameters(MgCoordinateSystemGeodeticTransformDefParams* parameters);
- //end properties
- virtual INT32 GetTransformDefType();
- MgCoordinateSystemGeodeticTransformation* CreateTransformation(bool createInverse);
- void CopyTo(cs_GeodeticTransform_& transformDef) const;
-private:
- void ReleaseInstance();
- INT32 GetTransformationDefType(INT32 methodCode);
-private:
- INT32 transformationDefType;
- cs_GeodeticTransform_* transformDefinition;
+#ifndef _CCOORDINATESYSTEMGEODETICTRANSFORMDEF_H_
+#define _CCOORDINATESYSTEMGEODETICTRANSFORMDEF_H_
+class CCoordinateSystemGeodeticTransformDef : public MgCoordinateSystemGeodeticTransformDef
+public:
+ CCoordinateSystemGeodeticTransformDef(MgCoordinateSystemCatalog* pCatalog);
+ virtual ~CCoordinateSystemGeodeticTransformDef();
+ void Reset(INT32 transformationDefType);
+ void Initialize(const cs_GeodeticTransform_& transformDef);
+ virtual MgCoordinateSystemGeodeticTransformDef* CreateClone();
+ //begin properties
+ virtual void SetTransformName(CREFSTRING name);
+ virtual void SetSourceDatum(CREFSTRING datumKey);
+ virtual void SetTargetDatum(CREFSTRING datumKey);
+ virtual void SetGroup(CREFSTRING group);
+ virtual void SetDescription(CREFSTRING description);
+ virtual void SetSource(CREFSTRING source);
+ virtual INT32 GetEpsgVariation();
+ virtual void SetEpsgVariation(INT32 epsgVariation);
+ virtual bool GetInverseSupported();
+ virtual void SetInverseSupported(bool inverseSupported);
+ virtual INT32 GetMaxIterations();
+ virtual void SetMaxIterations(INT32 maxIterations);
+ virtual double GetConvergenceValue();
+ virtual void SetConvergenceValue(double convergenceValue);
+ virtual double GetErrorValue();
+ virtual void SetErrorValue(double errorValue);
+ virtual MgCoordinateSystemGeodeticTransformDefParams* GetParameters();
+ virtual void SetParameters(MgCoordinateSystemGeodeticTransformDefParams* parameters);
+ //end properties
+ virtual INT32 GetTransformDefType();
+ MgCoordinateSystemGeodeticTransformation* CreateTransformation(bool createInverse);
+ void CopyTo(cs_GeodeticTransform_& transformDef) const;
+private:
+ void ReleaseInstance();
+ INT32 GetTransformationDefType(INT32 methodCode);
+private:
+ INT32 transformationDefType;
+ cs_GeodeticTransform_* transformDefinition;
#endif //_CCOORDINATESYSTEMGEODETICTRANSFORMDEF_H_
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.h
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.cpp 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.cpp 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,219 +1,219 @@
-#include "CoordSysMacro.h"
-#include "CriticalSection.h"
-#include "MentorDictionary.h"
-#include "CoordSysGeodeticTransformDefDictionary.h"
-DEFINE_DICTIONARY_FILE_NAME(GeodeticTransformation, cs_GX_NAME);
-extern DefinitionAccess<CCoordinateSystemGeodeticTransformDef, cs_GeodeticTransform_> transformDefinitionAccess(
- CS_gxdef,
- CCoordinateSystemGeodeticTransformDefDictionary::UpdateGeodeticTransformDef, /* CS_gpupd has a different signature than the other CS 'update' methods */
- CS_gxdel,
- &CCoordinateSystemGeodeticTransformDef::IsValid,
- CCoordinateSystemGeodeticTransformDefDictionary::SetupCsStructFromMgTransformDef,
- CCoordinateSystemGeodeticTransformDefDictionary::FullInitialize,
- CCoordinateSystemGeodeticTransformDefDictionary::ReadName,
- CCoordinateSystemGeodeticTransformDefDictionary::ReadDescription,
- CCoordinateSystemGeodeticTransformDefDictionary::ReadAllGeodeticTransformDefs,
- CS_gxfnm,
- CCoordinateSystemGeodeticTransformDefDictionary::GetFileOpenMode);
-CCoordinateSystemGeodeticTransformDefDictionary::CCoordinateSystemGeodeticTransformDefDictionary(MgCoordinateSystemCatalog *pCatalog)
- : m_pDictionary(new CCoordinateSystemDictionaryBase<CCoordinateSystemGeodeticTransformDef, cs_GeodeticTransform_,
- &transformDefinitionAccess, true, cs_GXDEF_MAGIC, DICTIONARY_FILE_NAME(GeodeticTransformation)>(pCatalog))
-CCoordinateSystemGeodeticTransformDefDictionary::~CCoordinateSystemGeodeticTransformDefDictionary()
-void CCoordinateSystemGeodeticTransformDefDictionary::Dispose()
- delete this;
-MgCoordinateSystemGeodeticTransformDef* CCoordinateSystemGeodeticTransformDefDictionary::NewGeodeticTransformationDef(INT32 transformationDefType)
- Ptr<CCoordinateSystemGeodeticTransformDef> newTransformDef = this->m_pDictionary->NewItem();
- newTransformDef->Reset(transformationDefType); //sets up the [cs_geodeticTransfrom_] struct and initializes it to [transformationDefType]
- return newTransformDef.Detach(); //this instance is not yet initialized
-MgCoordinateSystemGeodeticTransformDef* CCoordinateSystemGeodeticTransformDefDictionary::GetGeodeticTransformationDef(CREFSTRING transformationName)
- try
- return static_cast<MgCoordinateSystemGeodeticTransformDef*>(this->m_pDictionary->Get(transformationName));
- return NULL;
-/* BEGIN -------------------- MgCoordinateSystemDicationary implementation -------------------- BEGIN */
-MgGuardDisposable* CCoordinateSystemGeodeticTransformDefDictionary::Get(CREFSTRING sName)
-MgCoordinateSystemEnum* CCoordinateSystemGeodeticTransformDefDictionary::GetEnum()
-bool CCoordinateSystemGeodeticTransformDefDictionary::Has(CREFSTRING sName)
-STRING CCoordinateSystemGeodeticTransformDefDictionary::GetPath()
-UINT32 CCoordinateSystemGeodeticTransformDefDictionary::GetSize()
-MgCoordinateSystemCatalog* CCoordinateSystemGeodeticTransformDefDictionary::GetCatalog()
-STRING CCoordinateSystemGeodeticTransformDefDictionary::GetDefaultFileName()
-STRING CCoordinateSystemGeodeticTransformDefDictionary::GetFileName()
-void CCoordinateSystemGeodeticTransformDefDictionary::SetFileName(CREFSTRING sFileName)
-void CCoordinateSystemGeodeticTransformDefDictionary::Add(MgGuardDisposable *pDefinition)
-void CCoordinateSystemGeodeticTransformDefDictionary::Remove(CREFSTRING sName)
-void CCoordinateSystemGeodeticTransformDefDictionary::Modify(MgGuardDisposable *pDefinition)
-/* END -------------------- MgCoordinateSystemDicationary implementation -------------------- END */
-/* BEGIN -------------------- CCoordinateSystemDictionaryBase support methods -------------------- BEGIN */
-int CCoordinateSystemGeodeticTransformDefDictionary::UpdateGeodeticTransformDef(cs_GeodeticTransform_* csTransformDef, int /*unused*/)
- return CS_gxupd(csTransformDef);
-bool CCoordinateSystemGeodeticTransformDefDictionary::SetupCsStructFromMgTransformDef(CCoordinateSystemGeodeticTransformDef* mgGeodeticTransformDef, cs_GeodeticTransform_& csTransformDef)
- ENSURE_NOT_NULL(mgGeodeticTransformDef, CCoordinateSystemGeodeticTransformDefDictionary::SetupCsStructFromMgTransformDef);
- //copy the struct values from [mgGeodeticTransformDef] to [csTransformDef]; will throw an exception, if [mgGeodeticTransformDef] hasn't been yet initialized
- mgGeodeticTransformDef->CopyTo(csTransformDef);
- return true;
-void CCoordinateSystemGeodeticTransformDefDictionary::FullInitialize(CCoordinateSystemGeodeticTransformDef* mgGeodeticTransformDef,
- cs_GeodeticTransform_* csTransformDef,
- MgCoordinateSystemCatalog* catalog)
- ENSURE_NOT_NULL(mgGeodeticTransformDef, CCoordinateSystemGeodeticTransformDefDictionary::FullInitialize);
- ENSURE_NOT_NULL(csTransformDef, CCoordinateSystemGeodeticTransformDefDictionary::FullInitialize);
- mgGeodeticTransformDef->Initialize(*csTransformDef);
- return;
-const char* CCoordinateSystemGeodeticTransformDefDictionary::ReadName(const cs_GeodeticTransform_& definition)
- return definition.xfrmName;
-const char* CCoordinateSystemGeodeticTransformDefDictionary::ReadDescription(const cs_GeodeticTransform_& definition)
-int CCoordinateSystemGeodeticTransformDefDictionary::ReadAllGeodeticTransformDefs(csFILE *file, cs_GeodeticTransform_* csTransformDef, int* /*unused*/)
- return CS_gxrd(file, csTransformDef);
-CsDictionaryOpenMode CCoordinateSystemGeodeticTransformDefDictionary::GetFileOpenMode(long magicNumberFromFile)
- if (cs_GXDEF_MAGIC == magicNumberFromFile)
- return Write;
- _ASSERT(false);
- return Closed;
-/* END -------------------- CCoordinateSystemDictionaryBase support methods -------------------- END */
+#include "CoordSysMacro.h"
+#include "CriticalSection.h"
+#include "MentorDictionary.h"
+#include "CoordSysGeodeticTransformDefDictionary.h"
+DEFINE_DICTIONARY_FILE_NAME(GeodeticTransformation, cs_GX_NAME);
+extern DefinitionAccess<CCoordinateSystemGeodeticTransformDef, cs_GeodeticTransform_> transformDefinitionAccess(
+ CS_gxdef,
+ CCoordinateSystemGeodeticTransformDefDictionary::UpdateGeodeticTransformDef, /* CS_gpupd has a different signature than the other CS 'update' methods */
+ CS_gxdel,
+ &CCoordinateSystemGeodeticTransformDef::IsValid,
+ CCoordinateSystemGeodeticTransformDefDictionary::SetupCsStructFromMgTransformDef,
+ CCoordinateSystemGeodeticTransformDefDictionary::FullInitialize,
+ CCoordinateSystemGeodeticTransformDefDictionary::ReadName,
+ CCoordinateSystemGeodeticTransformDefDictionary::ReadDescription,
+ CCoordinateSystemGeodeticTransformDefDictionary::ReadAllGeodeticTransformDefs,
+ CS_gxfnm,
+ CCoordinateSystemGeodeticTransformDefDictionary::GetFileOpenMode);
+CCoordinateSystemGeodeticTransformDefDictionary::CCoordinateSystemGeodeticTransformDefDictionary(MgCoordinateSystemCatalog *pCatalog)
+ : m_pDictionary(new CCoordinateSystemDictionaryBase<CCoordinateSystemGeodeticTransformDef, cs_GeodeticTransform_,
+ &transformDefinitionAccess, true, cs_GXDEF_MAGIC, DICTIONARY_FILE_NAME(GeodeticTransformation)>(pCatalog))
+CCoordinateSystemGeodeticTransformDefDictionary::~CCoordinateSystemGeodeticTransformDefDictionary()
+void CCoordinateSystemGeodeticTransformDefDictionary::Dispose()
+ delete this;
+MgCoordinateSystemGeodeticTransformDef* CCoordinateSystemGeodeticTransformDefDictionary::NewGeodeticTransformationDef(INT32 transformationDefType)
+ Ptr<CCoordinateSystemGeodeticTransformDef> newTransformDef = this->m_pDictionary->NewItem();
+ newTransformDef->Reset(transformationDefType); //sets up the [cs_geodeticTransfrom_] struct and initializes it to [transformationDefType]
+ return newTransformDef.Detach(); //this instance is not yet initialized
+MgCoordinateSystemGeodeticTransformDef* CCoordinateSystemGeodeticTransformDefDictionary::GetGeodeticTransformationDef(CREFSTRING transformationName)
+ try
+ return static_cast<MgCoordinateSystemGeodeticTransformDef*>(this->m_pDictionary->Get(transformationName));
+ return NULL;
+/* BEGIN -------------------- MgCoordinateSystemDicationary implementation -------------------- BEGIN */
+MgGuardDisposable* CCoordinateSystemGeodeticTransformDefDictionary::Get(CREFSTRING sName)
+MgCoordinateSystemEnum* CCoordinateSystemGeodeticTransformDefDictionary::GetEnum()
+bool CCoordinateSystemGeodeticTransformDefDictionary::Has(CREFSTRING sName)
+STRING CCoordinateSystemGeodeticTransformDefDictionary::GetPath()
+UINT32 CCoordinateSystemGeodeticTransformDefDictionary::GetSize()
+MgCoordinateSystemCatalog* CCoordinateSystemGeodeticTransformDefDictionary::GetCatalog()
+STRING CCoordinateSystemGeodeticTransformDefDictionary::GetDefaultFileName()
+STRING CCoordinateSystemGeodeticTransformDefDictionary::GetFileName()
+void CCoordinateSystemGeodeticTransformDefDictionary::SetFileName(CREFSTRING sFileName)
+void CCoordinateSystemGeodeticTransformDefDictionary::Add(MgGuardDisposable *pDefinition)
+void CCoordinateSystemGeodeticTransformDefDictionary::Remove(CREFSTRING sName)
+void CCoordinateSystemGeodeticTransformDefDictionary::Modify(MgGuardDisposable *pDefinition)
+/* END -------------------- MgCoordinateSystemDicationary implementation -------------------- END */
+/* BEGIN -------------------- CCoordinateSystemDictionaryBase support methods -------------------- BEGIN */
+int CCoordinateSystemGeodeticTransformDefDictionary::UpdateGeodeticTransformDef(cs_GeodeticTransform_* csTransformDef, int /*unused*/)
+ return CS_gxupd(csTransformDef);
+bool CCoordinateSystemGeodeticTransformDefDictionary::SetupCsStructFromMgTransformDef(CCoordinateSystemGeodeticTransformDef* mgGeodeticTransformDef, cs_GeodeticTransform_& csTransformDef)
+ ENSURE_NOT_NULL(mgGeodeticTransformDef, CCoordinateSystemGeodeticTransformDefDictionary::SetupCsStructFromMgTransformDef);
+ //copy the struct values from [mgGeodeticTransformDef] to [csTransformDef]; will throw an exception, if [mgGeodeticTransformDef] hasn't been yet initialized
+ mgGeodeticTransformDef->CopyTo(csTransformDef);
+ return true;
+void CCoordinateSystemGeodeticTransformDefDictionary::FullInitialize(CCoordinateSystemGeodeticTransformDef* mgGeodeticTransformDef,
+ cs_GeodeticTransform_* csTransformDef,
+ MgCoordinateSystemCatalog* catalog)
+ ENSURE_NOT_NULL(mgGeodeticTransformDef, CCoordinateSystemGeodeticTransformDefDictionary::FullInitialize);
+ ENSURE_NOT_NULL(csTransformDef, CCoordinateSystemGeodeticTransformDefDictionary::FullInitialize);
+ mgGeodeticTransformDef->Initialize(*csTransformDef);
+ return;
+const char* CCoordinateSystemGeodeticTransformDefDictionary::ReadName(const cs_GeodeticTransform_& definition)
+ return definition.xfrmName;
+const char* CCoordinateSystemGeodeticTransformDefDictionary::ReadDescription(const cs_GeodeticTransform_& definition)
+int CCoordinateSystemGeodeticTransformDefDictionary::ReadAllGeodeticTransformDefs(csFILE *file, cs_GeodeticTransform_* csTransformDef, int* /*unused*/)
+ return CS_gxrd(file, csTransformDef);
+CsDictionaryOpenMode CCoordinateSystemGeodeticTransformDefDictionary::GetFileOpenMode(long magicNumberFromFile)
+ if (cs_GXDEF_MAGIC == magicNumberFromFile)
+ return Write;
+ _ASSERT(false);
+ return Closed;
+/* END -------------------- CCoordinateSystemDictionaryBase support methods -------------------- END */
\ No newline at end of file
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.cpp
___________________________________________________________________
Added: svn:eol-style
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,82 +1,82 @@
-#ifndef _CCOORDINATESYSTEMGEODETICTRANSFORMDEFDICTIONARY_H_
-#define _CCOORDINATESYSTEMGEODETICTRANSFORMDEFDICTIONARY_H_
-DECLARE_DICTIONARY_FILE_NAME(GeodeticTransformation);
-extern DefinitionAccess<CSLibrary::CCoordinateSystemGeodeticTransformDef, cs_GeodeticTransform_> transformDefinitionAccess;
-namespace CSLibrary
- class CCoordinateSystemGeodeticTransformDefDictionary : public MgCoordinateSystemGeodeticTransformDefDictionary
- public:
- CCoordinateSystemGeodeticTransformDefDictionary(MgCoordinateSystemCatalog *pCatalog);
- virtual ~CCoordinateSystemGeodeticTransformDefDictionary();
- virtual MgCoordinateSystemGeodeticTransformDef* NewGeodeticTransformationDef(INT32 transformationDefType);
- virtual MgCoordinateSystemGeodeticTransformDef* GetGeodeticTransformationDef(CREFSTRING pathName);
- protected:
- //MgDisposable
- virtual void Dispose();
- protected:
- Ptr<CCoordinateSystemDictionaryBase<CCoordinateSystemGeodeticTransformDef, cs_GeodeticTransform_, \
- &transformDefinitionAccess, true, cs_GXDEF_MAGIC, DICTIONARY_FILE_NAME(GeodeticTransformation)>> m_pDictionary;
- public:
- static int UpdateGeodeticTransformDef(cs_GeodeticTransform_* csTransformDef, int /*unused*/);
- static bool SetupCsStructFromMgTransformDef(CCoordinateSystemGeodeticTransformDef* mgGeodeticTransformDef, cs_GeodeticTransform_& csTransformDef);
- static void FullInitialize(CCoordinateSystemGeodeticTransformDef* mgGeodeticTransformDef, cs_GeodeticTransform_* csTransformDef, MgCoordinateSystemCatalog* catalog);
- static const char* ReadName(const cs_GeodeticTransform_& definition);
- static const char* ReadDescription(const cs_GeodeticTransform_& definition);
- static int ReadAllGeodeticTransformDefs(csFILE *file, cs_GeodeticTransform_* csTransformDef, int* /*unused*/);
-} // namespace CSLibrary
+#ifndef _CCOORDINATESYSTEMGEODETICTRANSFORMDEFDICTIONARY_H_
+#define _CCOORDINATESYSTEMGEODETICTRANSFORMDEFDICTIONARY_H_
+DECLARE_DICTIONARY_FILE_NAME(GeodeticTransformation);
+extern DefinitionAccess<CSLibrary::CCoordinateSystemGeodeticTransformDef, cs_GeodeticTransform_> transformDefinitionAccess;
+namespace CSLibrary
+ class CCoordinateSystemGeodeticTransformDefDictionary : public MgCoordinateSystemGeodeticTransformDefDictionary
+ public:
+ CCoordinateSystemGeodeticTransformDefDictionary(MgCoordinateSystemCatalog *pCatalog);
+ virtual ~CCoordinateSystemGeodeticTransformDefDictionary();
+ virtual MgCoordinateSystemGeodeticTransformDef* NewGeodeticTransformationDef(INT32 transformationDefType);
+ virtual MgCoordinateSystemGeodeticTransformDef* GetGeodeticTransformationDef(CREFSTRING pathName);
+ protected:
+ //MgDisposable
+ virtual void Dispose();
+ protected:
+ Ptr<CCoordinateSystemDictionaryBase<CCoordinateSystemGeodeticTransformDef, cs_GeodeticTransform_, \
+ &transformDefinitionAccess, true, cs_GXDEF_MAGIC, DICTIONARY_FILE_NAME(GeodeticTransformation)>> m_pDictionary;
+ public:
+ static int UpdateGeodeticTransformDef(cs_GeodeticTransform_* csTransformDef, int /*unused*/);
+ static bool SetupCsStructFromMgTransformDef(CCoordinateSystemGeodeticTransformDef* mgGeodeticTransformDef, cs_GeodeticTransform_& csTransformDef);
+ static void FullInitialize(CCoordinateSystemGeodeticTransformDef* mgGeodeticTransformDef, cs_GeodeticTransform_* csTransformDef, MgCoordinateSystemCatalog* catalog);
+ static const char* ReadName(const cs_GeodeticTransform_& definition);
+ static const char* ReadDescription(const cs_GeodeticTransform_& definition);
+ static int ReadAllGeodeticTransformDefs(csFILE *file, cs_GeodeticTransform_* csTransformDef, int* /*unused*/);
+} // namespace CSLibrary
#endif //_CCOORDINATESYSTEMGEODETICTRANSFORMDEFDICTIONARY_H_
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.h
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.cpp 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.cpp 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,38 +1,38 @@
-#include "GeometryCommon.h"
-#include <cs_map.h>
-using namespace CSLibrary;
-CCoordinateSystemGeodeticTransformDefParams::CCoordinateSystemGeodeticTransformDefParams(bool isProtected)
-: isProtected(isProtected)
-CCoordinateSystemGeodeticTransformDefParams::~CCoordinateSystemGeodeticTransformDefParams()
-bool CCoordinateSystemGeodeticTransformDefParams::IsProtected()
+#include "GeometryCommon.h"
+#include <cs_map.h>
+using namespace CSLibrary;
+CCoordinateSystemGeodeticTransformDefParams::CCoordinateSystemGeodeticTransformDefParams(bool isProtected)
+: isProtected(isProtected)
+CCoordinateSystemGeodeticTransformDefParams::~CCoordinateSystemGeodeticTransformDefParams()
+bool CCoordinateSystemGeodeticTransformDefParams::IsProtected()
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.cpp
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,40 +1,40 @@
-#ifndef _CCOORDINATESYSTEMGEODETICTRANSFORMDEFPARAMS_H_
-#define _CCOORDINATESYSTEMGEODETICTRANSFORMDEFPARAMS_H_
- class CCoordinateSystemGeodeticTransformDefParams : public MgCoordinateSystemGeodeticTransformDefParams
- public:
- virtual void CopyTo(void* target) const = 0;
- protected:
- CCoordinateSystemGeodeticTransformDefParams(bool isProtected);
- virtual ~CCoordinateSystemGeodeticTransformDefParams();
- private:
- bool isProtected;
+#ifndef _CCOORDINATESYSTEMGEODETICTRANSFORMDEFPARAMS_H_
+#define _CCOORDINATESYSTEMGEODETICTRANSFORMDEFPARAMS_H_
+ class CCoordinateSystemGeodeticTransformDefParams : public MgCoordinateSystemGeodeticTransformDefParams
+ public:
+ virtual void CopyTo(void* target) const = 0;
+ protected:
+ CCoordinateSystemGeodeticTransformDefParams(bool isProtected);
+ virtual ~CCoordinateSystemGeodeticTransformDefParams();
+ private:
+ bool isProtected;
#endif //_CCOORDINATESYSTEMGEODETICTRANSFORMDEFPARAMS_H_
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.h
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformGridFile.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformGridFile.cpp 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformGridFile.cpp 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,138 +1,138 @@
-#define CS_MAP_DEF_VARIABLE this->gridFileDesc
-#include "CoordSysCommon.h"
-#include "CoordSysUtil.h" //for Convert_Wide_To_Ascii
-#include "MentorUtil.h" //for OpenDictionaryFile()
-#include "CoordSysGeodeticTransformGridFile.h"
-CCoordinateSystemGeodeticTransformGridFile::CCoordinateSystemGeodeticTransformGridFile(const csGeodeticXfromParmsFile_* const fileFormatParam, bool isProtected)
- : gridFileDesc(NULL), isProtected(isProtected)
- this->gridFileDesc = (csGeodeticXfromParmsFile_*)CS_malc(sizeof(csGeodeticXfromParmsFile_));
- if (NULL == this->gridFileDesc)
- throw new MgOutOfMemoryException(L"CCoordinateSystemGeodeticAnalyticalTransformDefParams.ctor", __LINE__, __WFILE__, NULL, L"", NULL);
- ::memset(this->gridFileDesc, 0, sizeof(csGeodeticXfromParmsFile_));
- if (NULL != fileFormatParam)
- *this->gridFileDesc = *fileFormatParam;
- //else: keep the 0'ed memory
-CCoordinateSystemGeodeticTransformGridFile::~CCoordinateSystemGeodeticTransformGridFile()
-void CCoordinateSystemGeodeticTransformGridFile::Dispose()
- delete this;
-void CCoordinateSystemGeodeticTransformGridFile::ReleaseInstance()
- if (NULL != this->gridFileDesc)
- delete this->gridFileDesc;
- this->gridFileDesc = NULL;
-void CCoordinateSystemGeodeticTransformGridFile::CopyTo(csGeodeticXfromParmsFile_* destGridFile) const
- ENSURE_NOT_NULL(destGridFile, CCoordinateSystemGeodeticTransformGridFile::CopyTo);
- *destGridFile = *this->gridFileDesc;
-bool CCoordinateSystemGeodeticTransformGridFile::IsProtected()
-bool CCoordinateSystemGeodeticTransformGridFile::IsValid()
- _ASSERT(NULL != this->gridFileDesc);
- size_t fileNameLength = strlen(this->gridFileDesc->fileName);
- _ASSERT(fileNameLength < csGRIDI1_FLNMSZ);
- if (0 == fileNameLength || fileNameLength >= csGRIDI1_FLNMSZ)
- return false;
- switch(this->gridFileDesc->fileFormat)
- case cs_DTCFRMT_CNTv1:
- case cs_DTCFRMT_CNTv2:
- case cs_DTCFRMT_NADCN:
- case cs_DTCFRMT_FRNCH:
- case cs_DTCFRMT_JAPAN:
- case cs_DTCFRMT_ATS77:
- case cs_DTCFRMT_OST97:
- case cs_DTCFRMT_OST02:
- break;
- case cs_DTCFRMT_NONE:
- _ASSERT(false);
- break;
- //unsupported file formats
- default:
- return false;
- switch(this->gridFileDesc->direction)
- case 'i':
- case 'I':
- case 'f':
- case 'F':
- break;
- default:
- return false;
- return true;
-//************************************ Getters / Setters ***************************** /
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformGridFile,FileFormat,INT32,this->gridFileDesc->fileFormat);
-bool CCoordinateSystemGeodeticTransformGridFile::GetIsInverseDirection()
- return 'I' == this->gridFileDesc->direction || 'i' == this->gridFileDesc->direction;
-void CCoordinateSystemGeodeticTransformGridFile::SetIsInverseDirection(bool isInverseDirection)
- this->gridFileDesc->direction = isInverseDirection ? 'I' : 'F';
-DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticTransformGridFile, FileName, this->gridFileDesc->fileName);
+#define CS_MAP_DEF_VARIABLE this->gridFileDesc
+#include "CoordSysCommon.h"
+#include "CoordSysUtil.h" //for Convert_Wide_To_Ascii
+#include "MentorUtil.h" //for OpenDictionaryFile()
+#include "CoordSysGeodeticTransformGridFile.h"
+CCoordinateSystemGeodeticTransformGridFile::CCoordinateSystemGeodeticTransformGridFile(const csGeodeticXfromParmsFile_* const fileFormatParam, bool isProtected)
+ : gridFileDesc(NULL), isProtected(isProtected)
+ this->gridFileDesc = (csGeodeticXfromParmsFile_*)CS_malc(sizeof(csGeodeticXfromParmsFile_));
+ if (NULL == this->gridFileDesc)
+ throw new MgOutOfMemoryException(L"CCoordinateSystemGeodeticAnalyticalTransformDefParams.ctor", __LINE__, __WFILE__, NULL, L"", NULL);
+ ::memset(this->gridFileDesc, 0, sizeof(csGeodeticXfromParmsFile_));
+ if (NULL != fileFormatParam)
+ *this->gridFileDesc = *fileFormatParam;
+ //else: keep the 0'ed memory
+CCoordinateSystemGeodeticTransformGridFile::~CCoordinateSystemGeodeticTransformGridFile()
+void CCoordinateSystemGeodeticTransformGridFile::Dispose()
+ delete this;
+void CCoordinateSystemGeodeticTransformGridFile::ReleaseInstance()
+ if (NULL != this->gridFileDesc)
+ delete this->gridFileDesc;
+ this->gridFileDesc = NULL;
+void CCoordinateSystemGeodeticTransformGridFile::CopyTo(csGeodeticXfromParmsFile_* destGridFile) const
+ ENSURE_NOT_NULL(destGridFile, CCoordinateSystemGeodeticTransformGridFile::CopyTo);
+ *destGridFile = *this->gridFileDesc;
+bool CCoordinateSystemGeodeticTransformGridFile::IsProtected()
+bool CCoordinateSystemGeodeticTransformGridFile::IsValid()
+ _ASSERT(NULL != this->gridFileDesc);
+ size_t fileNameLength = strlen(this->gridFileDesc->fileName);
+ _ASSERT(fileNameLength < csGRIDI1_FLNMSZ);
+ if (0 == fileNameLength || fileNameLength >= csGRIDI1_FLNMSZ)
+ return false;
+ switch(this->gridFileDesc->fileFormat)
+ case cs_DTCFRMT_CNTv1:
+ case cs_DTCFRMT_CNTv2:
+ case cs_DTCFRMT_NADCN:
+ case cs_DTCFRMT_FRNCH:
+ case cs_DTCFRMT_JAPAN:
+ case cs_DTCFRMT_ATS77:
+ case cs_DTCFRMT_OST97:
+ case cs_DTCFRMT_OST02:
+ break;
+ case cs_DTCFRMT_NONE:
+ _ASSERT(false);
+ break;
+ //unsupported file formats
+ default:
+ return false;
+ switch(this->gridFileDesc->direction)
+ case 'i':
+ case 'I':
+ case 'f':
+ case 'F':
+ break;
+ default:
+ return false;
+ return true;
+//************************************ Getters / Setters ***************************** /
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformGridFile,FileFormat,INT32,this->gridFileDesc->fileFormat);
+bool CCoordinateSystemGeodeticTransformGridFile::GetIsInverseDirection()
+ return 'I' == this->gridFileDesc->direction || 'i' == this->gridFileDesc->direction;
+void CCoordinateSystemGeodeticTransformGridFile::SetIsInverseDirection(bool isInverseDirection)
+ this->gridFileDesc->direction = isInverseDirection ? 'I' : 'F';
+DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticTransformGridFile, FileName, this->gridFileDesc->fileName);
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformGridFile.cpp
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformGridFile.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformGridFile.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformGridFile.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,58 +1,58 @@
-#ifndef _CCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILE_H
-#define _CCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILE_H
- class CCoordinateSystemGeodeticTransformGridFile :
- public MgCoordinateSystemGeodeticTransformGridFile
- public:
- CCoordinateSystemGeodeticTransformGridFile(const csGeodeticXfromParmsFile_* const fileFormatParam, bool isProtected);
- ~CCoordinateSystemGeodeticTransformGridFile();
- // >>> MgCoordinateSystemGeodeticTransformGridFile
- virtual INT32 GetFileFormat();
- virtual void SetFileFormat(INT32 gridFileFormat);
- virtual bool GetIsInverseDirection();
- virtual void SetIsInverseDirection(bool isInverseDirection);
- virtual STRING GetFileName();
- virtual void SetFileName(CREFSTRING fileName);
- // <<< MgCoordinateSystemGeodeticTransformGridFile
- virtual void CopyTo(csGeodeticXfromParmsFile_* destGridFile) const;
- private:
- private:
- csGeodeticXfromParmsFile_* gridFileDesc;
- bool isProtected;
+#ifndef _CCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILE_H
+#define _CCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILE_H
+ class CCoordinateSystemGeodeticTransformGridFile :
+ public MgCoordinateSystemGeodeticTransformGridFile
+ public:
+ CCoordinateSystemGeodeticTransformGridFile(const csGeodeticXfromParmsFile_* const fileFormatParam, bool isProtected);
+ ~CCoordinateSystemGeodeticTransformGridFile();
+ // >>> MgCoordinateSystemGeodeticTransformGridFile
+ virtual INT32 GetFileFormat();
+ virtual void SetFileFormat(INT32 gridFileFormat);
+ virtual bool GetIsInverseDirection();
+ virtual void SetIsInverseDirection(bool isInverseDirection);
+ virtual STRING GetFileName();
+ virtual void SetFileName(CREFSTRING fileName);
+ // <<< MgCoordinateSystemGeodeticTransformGridFile
+ virtual void CopyTo(csGeodeticXfromParmsFile_* destGridFile) const;
+ private:
+ private:
+ csGeodeticXfromParmsFile_* gridFileDesc;
+ bool isProtected;
#endif //_CCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILE_H
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformGridFile.h
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysMacro.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysMacro.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysMacro.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,99 +1,99 @@
-#ifndef _MG_COORDSYSMACRO_H_
-#define _MG_COORDSYSMACRO_H_
-//make sure to have CS_MAP_DEF_VARIABLE defined before including this header; this is used by VERIFY_INITIALIZED(x)
- #define MAKE_L_STRING(x) L## #x
-#ifdef CS_MAP_DEF_VARIABLE
- #define VERIFY_INITIALIZED(x) if (NULL == CS_MAP_DEF_VARIABLE) \
- throw new MgInvalidOperationException(x, __LINE__, __WFILE__, NULL, L"", NULL)
-#else
-#endif
-#define VERIFY_NOT_PROTECTED(x) if (this->IsProtected()) \
- throw new MgCoordinateSystemInitializationFailedException(x, __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
-#define DEFINE_GET_STRING(x,y) STRING x::Get##y()
-#define DEFINE_SET_STRING(x,y) void x::Set##y(CREFSTRING propertyValue)
-#define DEFINE_GET_SET_STRING(className,propertyName,charBuffer) \
- DEFINE_GET_STRING(className,propertyName) \
- VERIFY_INITIALIZED(MAKE_L_STRING(className##.Get##propertyName)); \
- return MentorReadString(charBuffer); \
- DEFINE_SET_STRING(className,propertyName) \
- VERIFY_INITIALIZED(MAKE_L_STRING(className##.Set##propertyName)); \
- if (this->IsProtected()) \
- throw new MgCoordinateSystemInitializationFailedException(L"SetString", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL); \
- MentorSetString(propertyValue, charBuffer /* target buffer */, sizeof(charBuffer)); \
-#define DEFINE_GET_NUMERIC(x,y,targetType) targetType x::Get##y()
-#define DEFINE_SET_NUMERIC(x,y,targetType) void x::Set##y(targetType propertyValue)
-#define DEFINE_GET_NUMERIC_IDX(x,y,targetType) targetType x::Get##y(INT32 index)
-#define DEFINE_SET_NUMERIC_IDX(x,y,targetType) void x::Set##y(INT32 index, targetType propertyValue)
-#define DEFINE_GET_SET_NUMERIC(className, propertyName,targetType,target) \
- DEFINE_GET_NUMERIC(className,propertyName,targetType) \
- return target; \
- DEFINE_SET_NUMERIC(className,propertyName,targetType) \
- throw new MgCoordinateSystemInitializationFailedException(L"SetValue", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL); \
- target = propertyValue;\
-#define DEFINE_GET_SET_NUMERIC_IDX(className, propertyName,targetType,target,maxIdx) \
- DEFINE_GET_NUMERIC_IDX(className,propertyName,targetType) \
- if (index < 0 || index > maxIdx) \
- throw new MgArgumentOutOfRangeException(L"GetValue", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL); \
- return target[index]; \
- DEFINE_SET_NUMERIC_IDX(className,propertyName,targetType) \
- target[index] = propertyValue;\
-#define ENSURE_NOT_NULL(param,method) \
- if (NULL == param) \
- throw new MgNullArgumentException(L# method, __LINE__, __WFILE__, NULL, L"", NULL)
+#ifndef _MG_COORDSYSMACRO_H_
+#define _MG_COORDSYSMACRO_H_
+//make sure to have CS_MAP_DEF_VARIABLE defined before including this header; this is used by VERIFY_INITIALIZED(x)
+ #define MAKE_L_STRING(x) L## #x
+#ifdef CS_MAP_DEF_VARIABLE
+ #define VERIFY_INITIALIZED(x) if (NULL == CS_MAP_DEF_VARIABLE) \
+ throw new MgInvalidOperationException(x, __LINE__, __WFILE__, NULL, L"", NULL)
+#else
+#endif
+#define VERIFY_NOT_PROTECTED(x) if (this->IsProtected()) \
+ throw new MgCoordinateSystemInitializationFailedException(x, __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
+#define DEFINE_GET_STRING(x,y) STRING x::Get##y()
+#define DEFINE_SET_STRING(x,y) void x::Set##y(CREFSTRING propertyValue)
+#define DEFINE_GET_SET_STRING(className,propertyName,charBuffer) \
+ DEFINE_GET_STRING(className,propertyName) \
+ VERIFY_INITIALIZED(MAKE_L_STRING(className##.Get##propertyName)); \
+ return MentorReadString(charBuffer); \
+ DEFINE_SET_STRING(className,propertyName) \
+ VERIFY_INITIALIZED(MAKE_L_STRING(className##.Set##propertyName)); \
+ if (this->IsProtected()) \
+ throw new MgCoordinateSystemInitializationFailedException(L"SetString", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL); \
+ MentorSetString(propertyValue, charBuffer /* target buffer */, sizeof(charBuffer)); \
+#define DEFINE_GET_NUMERIC(x,y,targetType) targetType x::Get##y()
+#define DEFINE_SET_NUMERIC(x,y,targetType) void x::Set##y(targetType propertyValue)
+#define DEFINE_GET_NUMERIC_IDX(x,y,targetType) targetType x::Get##y(INT32 index)
+#define DEFINE_SET_NUMERIC_IDX(x,y,targetType) void x::Set##y(INT32 index, targetType propertyValue)
+#define DEFINE_GET_SET_NUMERIC(className, propertyName,targetType,target) \
+ DEFINE_GET_NUMERIC(className,propertyName,targetType) \
+ return target; \
+ DEFINE_SET_NUMERIC(className,propertyName,targetType) \
+ throw new MgCoordinateSystemInitializationFailedException(L"SetValue", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL); \
+ target = propertyValue;\
+#define DEFINE_GET_SET_NUMERIC_IDX(className, propertyName,targetType,target,maxIdx) \
+ DEFINE_GET_NUMERIC_IDX(className,propertyName,targetType) \
+ if (index < 0 || index > maxIdx) \
+ throw new MgArgumentOutOfRangeException(L"GetValue", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL); \
+ return target[index]; \
+ DEFINE_SET_NUMERIC_IDX(className,propertyName,targetType) \
+ target[index] = propertyValue;\
+#define ENSURE_NOT_NULL(param,method) \
+ if (NULL == param) \
+ throw new MgNullArgumentException(L# method, __LINE__, __WFILE__, NULL, L"", NULL)
#endif //_MG_COORDSYSMACRO_H_
Property changes on: trunk/MgDev/Common/CoordinateSystem/CoordSysMacro.h
+ native
Modified: trunk/MgDev/Common/CoordinateSystem/namestruct.cpp
--- trunk/MgDev/Common/CoordinateSystem/namestruct.cpp 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/CoordinateSystem/namestruct.cpp 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,123 +1,123 @@
-// Copyright (C) 2004-2010 by Autodesk, Inc.
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of version 2.1 of the GNU Lesser
-// General Public License as published by the Free Software Foundation.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-#include "namestruct.h"
-//Constructor. Initializes to a specified string
-//(if one is provided) or to all zeroes (if not).
-TNameStruct::TNameStruct(const char *kpName)
- : name(NULL)
- this->Init(kpName);
-//Copy constructor - needed as we allocate the [name] field dynamically
-TNameStruct::TNameStruct(const TNameStruct& other)
- : name(NULL)
- this->Init(other.name);
-//Destructor - releases the allocated memory
-TNameStruct::~TNameStruct()
- this->Release();
-void TNameStruct::Release()
- delete[] name;
- name = NULL;
-void TNameStruct::Init(const char *kpName)
- this->Release();
- size_t stringLength = (NULL == kpName) ? 0 : strnlen(kpName, MAX_STRING_LENGTH);
- //cannot be null; throws std::bad_alloc in case of failure; (what about replacing the new operator?)
- //don't catch it here - if we're not even able to allocate about [MAX_STRING_LENGTH] something very serious is going on here
- name = new char[stringLength + 1];
- if (stringLength > 0) //copy the string into the buffer if we've been given a valid, non-empty string
- strncpy(name, kpName, stringLength);
- name[stringLength] = '\0'; // finally, set the terminating NULL char in any case; the buffer is at least 1 char long
-//Assignment operator; assign based on other TNameStruct
-TNameStruct&
-TNameStruct::operator=(const TNameStruct& other)
- return *this;
-//Assignment operator; assign based on string
-TNameStruct&
-TNameStruct::operator=(const char* newName)
- this->Init(newName);
- return *this;
-//Comparison operator (alphabetic, case-insensitive).
-bool
-TNameStruct::operator<(const TNameStruct& other) const
- return (_stricmp(name, other.name) < 0);
-bool
-TNameStruct::operator>(const TNameStruct& other) const
- return (_stricmp(name, other.name) > 0);
-//Equality operator (alphabetic, case-insensitive).
-bool
-TNameStruct::operator==(const TNameStruct& other) const
- return (_stricmp(name, other.name) == 0);
-//Inequality operator (alphabetic, case-insensitive).
-bool
-TNameStruct::operator!=(const TNameStruct& other) const
- return (_stricmp(name, other.name) != 0);
-//Returns this [TNameStruct] current char* pointer
-const char*
-TNameStruct::Name() const
- return this->name;
+#include "namestruct.h"
+//Constructor. Initializes to a specified string
+//(if one is provided) or to all zeroes (if not).
+TNameStruct::TNameStruct(const char *kpName)
+ : name(NULL)
+ this->Init(kpName);
+//Copy constructor - needed as we allocate the [name] field dynamically
+TNameStruct::TNameStruct(const TNameStruct& other)
+ : name(NULL)
+ this->Init(other.name);
+//Destructor - releases the allocated memory
+TNameStruct::~TNameStruct()
+ this->Release();
+void TNameStruct::Release()
+ delete[] name;
+ name = NULL;
+void TNameStruct::Init(const char *kpName)
+ this->Release();
+ size_t stringLength = (NULL == kpName) ? 0 : strnlen(kpName, MAX_STRING_LENGTH);
+ //cannot be null; throws std::bad_alloc in case of failure; (what about replacing the new operator?)
+ //don't catch it here - if we're not even able to allocate about [MAX_STRING_LENGTH] something very serious is going on here
+ name = new char[stringLength + 1];
+ if (stringLength > 0) //copy the string into the buffer if we've been given a valid, non-empty string
+ strncpy(name, kpName, stringLength);
+ name[stringLength] = '\0'; // finally, set the terminating NULL char in any case; the buffer is at least 1 char long
+//Assignment operator; assign based on other TNameStruct
+TNameStruct&
+TNameStruct::operator=(const TNameStruct& other)
+ return *this;
+//Assignment operator; assign based on string
+TNameStruct&
+TNameStruct::operator=(const char* newName)
+ this->Init(newName);
+ return *this;
+//Comparison operator (alphabetic, case-insensitive).
+bool
+TNameStruct::operator<(const TNameStruct& other) const
+ return (_stricmp(name, other.name) < 0);
+bool
+TNameStruct::operator>(const TNameStruct& other) const
+ return (_stricmp(name, other.name) > 0);
+//Equality operator (alphabetic, case-insensitive).
+bool
+TNameStruct::operator==(const TNameStruct& other) const
+ return (_stricmp(name, other.name) == 0);
+//Inequality operator (alphabetic, case-insensitive).
+bool
+TNameStruct::operator!=(const TNameStruct& other) const
+ return (_stricmp(name, other.name) != 0);
+//Returns this [TNameStruct] current char* pointer
+const char*
+TNameStruct::Name() const
+ return this->name;
Property changes on: trunk/MgDev/Common/CoordinateSystem/namestruct.cpp
+ native
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformDefParams.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformDefParams.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformDefParams.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,88 +1,88 @@
-#ifndef _MGCOORDINATESYSTEMGEODETICANALYTICALTRANSFORMDEFPARAMS_H_
-#define _MGCOORDINATESYSTEMGEODETICANALYTICALTRANSFORMDEFPARAMS_H_
-/// \defgroup MgCoordinateSystemGeodeticAnalyticalTransformDefParams MgCoordinateSystemGeodeticAnalyticalTransformDefParams
-/// \ingroup Coordinate_System_classes
-/// \brief
-/// This class holds all parameters that are specific to analytical geodetic transformation methods, e.g.
-/// geocentric transformation, molodensky etc.
-class MG_GEOMETRY_API MgCoordinateSystemGeodeticAnalyticalTransformDefParams : public MgCoordinateSystemGeodeticTransformDefParams
- DECLARE_CLASSNAME(MgCoordinateSystemGeodeticAnalyticalTransformDefParams)
-PUBLISHED_API:
- //BEGIN: struct csGeodeticXformParmsGeocentric
- virtual double GetDeltaX() = 0;
- virtual void SetDeltaX(double deltaX) = 0;
- virtual double GetDeltaY() = 0;
- virtual void SetDeltaY(double deltaY) = 0;
- virtual double GetDeltaZ() = 0;
- virtual void SetDeltaZ(double deltaZ) = 0;
- virtual double GetRotateX() = 0;
- virtual void SetRotateX(double rotateX) = 0;
- virtual double GetRotateY() = 0;
- virtual void SetRotateY(double rotateY) = 0;
- virtual double GetRotateZ() = 0;
- virtual void SetRotateZ(double rotateZ) = 0;
- virtual double GetScale() = 0;
- virtual void SetScale(double scale) = 0;
- virtual double GetTranslateX() = 0;
- virtual void SetTranslateX(double translateX) = 0;
- virtual double GetTranslateY() = 0;
- virtual void SetTranslateY(double translateY) = 0;
- virtual double GetTranslateZ() = 0;
- virtual void SetTranslateZ(double translateZ) = 0;
- //END: struct csGeodeticXformParmsGeocentric
- virtual INT32 GetTransformationMethod() = 0;
- virtual void SetTransformationMethod(INT32 analyticalMethodCode) = 0;
-protected:
- /// \brief
- /// Get the class Id
- /// \return
- /// The integer value
- INT32 GetClassId(){return m_cls_id;};
-CLASS_ID:
- static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticAnalyticalTransformDefParams;
+#ifndef _MGCOORDINATESYSTEMGEODETICANALYTICALTRANSFORMDEFPARAMS_H_
+#define _MGCOORDINATESYSTEMGEODETICANALYTICALTRANSFORMDEFPARAMS_H_
+/// \defgroup MgCoordinateSystemGeodeticAnalyticalTransformDefParams MgCoordinateSystemGeodeticAnalyticalTransformDefParams
+/// \ingroup Coordinate_System_classes
+/// \brief
+/// This class holds all parameters that are specific to analytical geodetic transformation methods, e.g.
+/// geocentric transformation, molodensky etc.
+class MG_GEOMETRY_API MgCoordinateSystemGeodeticAnalyticalTransformDefParams : public MgCoordinateSystemGeodeticTransformDefParams
+ DECLARE_CLASSNAME(MgCoordinateSystemGeodeticAnalyticalTransformDefParams)
+PUBLISHED_API:
+ //BEGIN: struct csGeodeticXformParmsGeocentric
+ virtual double GetDeltaX() = 0;
+ virtual void SetDeltaX(double deltaX) = 0;
+ virtual double GetDeltaY() = 0;
+ virtual void SetDeltaY(double deltaY) = 0;
+ virtual double GetDeltaZ() = 0;
+ virtual void SetDeltaZ(double deltaZ) = 0;
+ virtual double GetRotateX() = 0;
+ virtual void SetRotateX(double rotateX) = 0;
+ virtual double GetRotateY() = 0;
+ virtual void SetRotateY(double rotateY) = 0;
+ virtual double GetRotateZ() = 0;
+ virtual void SetRotateZ(double rotateZ) = 0;
+ virtual double GetScale() = 0;
+ virtual void SetScale(double scale) = 0;
+ virtual double GetTranslateX() = 0;
+ virtual void SetTranslateX(double translateX) = 0;
+ virtual double GetTranslateY() = 0;
+ virtual void SetTranslateY(double translateY) = 0;
+ virtual double GetTranslateZ() = 0;
+ virtual void SetTranslateZ(double translateZ) = 0;
+ //END: struct csGeodeticXformParmsGeocentric
+ virtual INT32 GetTransformationMethod() = 0;
+ virtual void SetTransformationMethod(INT32 analyticalMethodCode) = 0;
+protected:
+ /// \brief
+ /// Get the class Id
+ /// \return
+ /// The integer value
+ INT32 GetClassId(){return m_cls_id;};
+CLASS_ID:
+ static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticAnalyticalTransformDefParams;
#endif //_MGCOORDINATESYSTEMGEODETICANALYTICALTRANSFORMDEFPARAMS_H_
Property changes on: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformDefParams.h
+ native
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformationMethod.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformationMethod.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformationMethod.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,53 +1,53 @@
-#ifndef _MGCOORDINATESYSTEMGEODETICANALYTICALTRANSFORMATIONMETHOD_H_
-#define _MGCOORDINATESYSTEMGEODETICANALYTICALTRANSFORMATIONMETHOD_H_
-/// \defgroup MgCoordinateSystemGeodeticAnalyticalTransformationMethod MgCoordinateSystemGeodeticAnalyticalTransformationMethod
-/// \brief
-/// This class defines the currently supported transformation methods for
-/// analytical geodetic transformations as they can be read via the
-/// MgCoordinateSystemGeodeticTransformDefDictionary. That is, the constants
-/// defined below are only valid for MgCoordinateSystemGeodeticTransformDef instances
-/// of type MgCoordinateSystemGeodeticTransformDefType.Analytical.
-class MG_GEOMETRY_API MgCoordinateSystemGeodeticAnalyticalTransformationMethod
-PUBLISHED_API:
- static const INT32 None = 0;
- static const INT32 ThreeParameter = (8192 + 1); //cs_DTCMTH_3PARM
- static const INT32 Molodensky = (8192 + 2); //cs_DTCMTH_MOLOD
- static const INT32 AbridgedMolodensky = (8192 + 3); //cs_DTCMTH_AMOLO
- static const INT32 Geocentric = (8192 + 4); //cs_DTCMTH_GEOCT
- static const INT32 FourParameter = (8192 + 5); //cs_DTCMTH_4PARM
- static const INT32 SixParameter = (8192 + 6); //cs_DTCMTH_6PARM
- static const INT32 Bursa = (8192 + 7); //cs_DTCMTH_BURSA
- static const INT32 Frame = (8192 + 8); //cs_DTCMTH_FRAME
- static const INT32 SevenParameter = (8192 + 9); //cs_DTCMTH_7PARM
- static const INT32 MolodenskyBadekas = (8192 + 10); //cs_DTCMTH_BDKAS
-#endif //_MGCOORDINATESYSTEMGEODETICANALYTICALTRANSFORMATIONMETHOD_H_
+// Copyright (C) 2004-2010 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#ifndef _MGCOORDINATESYSTEMGEODETICANALYTICALTRANSFORMATIONMETHOD_H_
+#define _MGCOORDINATESYSTEMGEODETICANALYTICALTRANSFORMATIONMETHOD_H_
+/// \defgroup MgCoordinateSystemGeodeticAnalyticalTransformationMethod MgCoordinateSystemGeodeticAnalyticalTransformationMethod
+/// \brief
+/// This class defines the currently supported transformation methods for
+/// analytical geodetic transformations as they can be read via the
+/// MgCoordinateSystemGeodeticTransformDefDictionary. That is, the constants
+/// defined below are only valid for MgCoordinateSystemGeodeticTransformDef instances
+/// of type MgCoordinateSystemGeodeticTransformDefType.Analytical.
+class MG_GEOMETRY_API MgCoordinateSystemGeodeticAnalyticalTransformationMethod
+PUBLISHED_API:
+ static const INT32 None = 0;
+ static const INT32 ThreeParameter = (8192 + 1); //cs_DTCMTH_3PARM
+ static const INT32 Molodensky = (8192 + 2); //cs_DTCMTH_MOLOD
+ static const INT32 AbridgedMolodensky = (8192 + 3); //cs_DTCMTH_AMOLO
+ static const INT32 Geocentric = (8192 + 4); //cs_DTCMTH_GEOCT
+ static const INT32 FourParameter = (8192 + 5); //cs_DTCMTH_4PARM
+ static const INT32 SixParameter = (8192 + 6); //cs_DTCMTH_6PARM
+ static const INT32 Bursa = (8192 + 7); //cs_DTCMTH_BURSA
+ static const INT32 Frame = (8192 + 8); //cs_DTCMTH_FRAME
+ static const INT32 SevenParameter = (8192 + 9); //cs_DTCMTH_7PARM
+ static const INT32 MolodenskyBadekas = (8192 + 10); //cs_DTCMTH_BDKAS
+#endif //_MGCOORDINATESYSTEMGEODETICANALYTICALTRANSFORMATIONMETHOD_H_
Property changes on: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformationMethod.h
+ native
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticInterpolationTransformDefParams.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticInterpolationTransformDefParams.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticInterpolationTransformDefParams.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,115 +1,115 @@
-#ifndef _MGCOORDINATESYSTEMGEODETICINTERPOLATIONTRANSFORMDEFPARAMS_H_
-#define _MGCOORDINATESYSTEMGEODETICINTERPOLATIONTRANSFORMDEFPARAMS_H_
-/// \defgroup MgCoordinateSystemGeodeticInterpolationTransformDefParams MgCoordinateSystemGeodeticInterpolationTransformDefParams
-/// \brief
-/// This class holds all parameters that are specific to grid-file based transformation. That is,
-/// where the actual datum shift value for a coordinate is determined by interpolating between grid point values
-/// as defined in the respective grid file(s).
-class MG_GEOMETRY_API MgCoordinateSystemGeodeticInterpolationTransformDefParams : public MgCoordinateSystemGeodeticTransformDefParams
- DECLARE_CLASSNAME(MgCoordinateSystemGeodeticInterpolationTransformDefParams)
-PUBLISHED_API:
- //BEGIN: struct csGeodeticXfromParmsFile
- /// \brief
- /// Sets the grid files to be used by this transformation. See the description for
- /// gridFiles parameter.
- /// \param gridFiles
- /// A (possibly empty) ordered(!) collection of MgCoordinateSystemGeodeticTransformGridFile objects.
- /// The order of the elements contained in the collection is important, because this
- /// instructs the underlying API in which order to use the grid files, e.g. in case of an overlap.
- /// \remarks
- /// The caller is responsible for disposing the collection of grid files. That is,
- /// this parameter object will not take ownership of the collection passed in.
- virtual void SetGridFiles(MgDisposableCollection* gridFiles) = 0;
- /// \brief
- /// Returns an ordered, non-live collection MgCoordinateSystemGeodeticTransformGridFile elements
- /// currently used by this parameter object. Changing the collection does NOT
- /// have an affect on this parent parameter instance. Instead, any API client
- /// has to modify the collection and then set it back via SetGridFiles.
- /// The list returned can be an empty but will never be NULL.
- /// \remarks
- /// The caller is responsible for disposing the collection of grid files being returned
- /// here.
- virtual MgDisposableCollection* GetGridFiles() = 0;
- /// \brief
- /// Returns the name of the transformation to fallback to in case the transformation using the
- /// defined grid files doesn't succeed.
- /// \return
- /// Returns the name of the fallback transformation. Can be empty if no such fallback transformation
- /// is defined.
- virtual STRING GetFallback() = 0;
- /// \brief
- /// Sets the name of the transformation to fallback to, if the transformation could not
- /// be performed using the grid files defined.
- /// \param fallbackTransformation
- /// Name of the transformation to fallback to.
- virtual void SetFallback(CREFSTRING fallbackTransformation) = 0;
- /// \brief
- /// Creates a new, empty MgCoordinateSystemGeodeticTransformGridFile object
- /// that can be added to the collection set via SetGridFiles.
- /// \return
- /// Returns a new, unitialized MgCoordinateSystemGeodeticTransformGridFile instance
- /// The caller is resonsible for disposing the object if no longer needed.
- virtual MgCoordinateSystemGeodeticTransformGridFile* NewGridFile() = 0;
- //END: struct csGeodeticXfromParmsFile
-protected:
- /// \brief
- /// \return
-CLASS_ID:
- static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticInterpolationTransformDefParams;
+#ifndef _MGCOORDINATESYSTEMGEODETICINTERPOLATIONTRANSFORMDEFPARAMS_H_
+#define _MGCOORDINATESYSTEMGEODETICINTERPOLATIONTRANSFORMDEFPARAMS_H_
+/// \defgroup MgCoordinateSystemGeodeticInterpolationTransformDefParams MgCoordinateSystemGeodeticInterpolationTransformDefParams
+/// \brief
+/// This class holds all parameters that are specific to grid-file based transformation. That is,
+/// where the actual datum shift value for a coordinate is determined by interpolating between grid point values
+/// as defined in the respective grid file(s).
+class MG_GEOMETRY_API MgCoordinateSystemGeodeticInterpolationTransformDefParams : public MgCoordinateSystemGeodeticTransformDefParams
+ DECLARE_CLASSNAME(MgCoordinateSystemGeodeticInterpolationTransformDefParams)
+PUBLISHED_API:
+ //BEGIN: struct csGeodeticXfromParmsFile
+ /// \brief
+ /// Sets the grid files to be used by this transformation. See the description for
+ /// gridFiles parameter.
+ /// \param gridFiles
+ /// A (possibly empty) ordered(!) collection of MgCoordinateSystemGeodeticTransformGridFile objects.
+ /// The order of the elements contained in the collection is important, because this
+ /// instructs the underlying API in which order to use the grid files, e.g. in case of an overlap.
+ /// \remarks
+ /// The caller is responsible for disposing the collection of grid files. That is,
+ /// this parameter object will not take ownership of the collection passed in.
+ virtual void SetGridFiles(MgDisposableCollection* gridFiles) = 0;
+ /// \brief
+ /// Returns an ordered, non-live collection MgCoordinateSystemGeodeticTransformGridFile elements
+ /// currently used by this parameter object. Changing the collection does NOT
+ /// have an affect on this parent parameter instance. Instead, any API client
+ /// has to modify the collection and then set it back via SetGridFiles.
+ /// The list returned can be an empty but will never be NULL.
+ /// \remarks
+ /// The caller is responsible for disposing the collection of grid files being returned
+ /// here.
+ virtual MgDisposableCollection* GetGridFiles() = 0;
+ /// \brief
+ /// Returns the name of the transformation to fallback to in case the transformation using the
+ /// defined grid files doesn't succeed.
+ /// \return
+ /// Returns the name of the fallback transformation. Can be empty if no such fallback transformation
+ /// is defined.
+ virtual STRING GetFallback() = 0;
+ /// \brief
+ /// Sets the name of the transformation to fallback to, if the transformation could not
+ /// be performed using the grid files defined.
+ /// \param fallbackTransformation
+ /// Name of the transformation to fallback to.
+ virtual void SetFallback(CREFSTRING fallbackTransformation) = 0;
+ /// \brief
+ /// Creates a new, empty MgCoordinateSystemGeodeticTransformGridFile object
+ /// that can be added to the collection set via SetGridFiles.
+ /// \return
+ /// Returns a new, unitialized MgCoordinateSystemGeodeticTransformGridFile instance
+ /// The caller is resonsible for disposing the object if no longer needed.
+ virtual MgCoordinateSystemGeodeticTransformGridFile* NewGridFile() = 0;
+ //END: struct csGeodeticXfromParmsFile
+protected:
+ /// \brief
+ /// \return
+CLASS_ID:
+ static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticInterpolationTransformDefParams;
#endif //_MGCOORDINATESYSTEMGEODETICINTERPOLATIONTRANSFORMDEFPARAMS_H_
Property changes on: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticInterpolationTransformDefParams.h
+ native
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformDefParams.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformDefParams.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformDefParams.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,103 +1,103 @@
-#ifndef _MGCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMDEFPARAMS_H_
-#define _MGCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMDEFPARAMS_H_
-/// \defgroup MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams
-/// \brief
-/// This class holds all parameters that are specific to the multiple regression transformation method.
-class MG_GEOMETRY_API MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams : public MgCoordinateSystemGeodeticTransformDefParams
- DECLARE_CLASSNAME(MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams)
-PUBLISHED_API:
- //BEGIN: struct csGeodeticXformParmsDmaMulReg
- //virtual UINT32 GetPhiBitmap(INT32 index) = 0; // range [0..3]; long compiles as 32 bit in MS VC;
- //virtual void SetPhiBitmap(INT32 index, UINT32 value) = 0; //long compiles as 32 bit in MS VC;
- //virtual UINT32 GetLambdaBitmap(INT32 index) = 0; // range [0..3]; long compiles as 32 bit in MS VC;
- //virtual void SetLambdaBitmap(INT32 index, UINT32 value) = 0; //long compiles as 32 bit in MS VC;
- //virtual UINT32 GetHeightBitmap(INT32 index) = 0; // range [0..3]; long compiles as 32 bit in MS VC;
- //virtual void SetHeightBitmap(INT32 index, UINT32 value) = 0; //long compiles as 32 bit in MS VC;
- virtual double GetValidation() = 0;
- virtual void SetValidation(double validation) = 0;
- virtual double GetTestPhi() = 0;
- virtual void SetTestPhi(double testPhi) = 0;
- virtual double GetTestLambda() = 0;
- virtual void SetTestLambda(double testLambda) = 0;
- virtual double GetDeltaPhi() = 0;
- virtual void SetDeltaPhi(double deltaPhi) = 0;
- virtual double GetDeltaLambda() = 0;
- virtual void SetDeltaLambda(double deltaLambda) = 0;
- virtual double GetDeltaHeight() = 0;
- virtual void SetDeltaHeight(double deltaHeight) = 0;
- virtual double GetPhiOffset() = 0;
- virtual void SetPhiOffset(double phiOffset) = 0;
- virtual double GetLambdaOffset() = 0;
- virtual void SetLambdaOffset(double lambdaOffset) = 0;
- virtual double GetNormalizationScale() = 0;
- virtual void SetNormalizationScale(double NormalizationScale) = 0;
- virtual double GetCoefficientPhi(INT32 index) = 0; // range [0..104]
- virtual void SetCoefficientPhi(INT32 index, double value) = 0;
- virtual double GetCoefficientLambda(INT32 index) = 0; // range [0..104]
- virtual void SetCoefficientLambda(INT32 index, double value) = 0;
- virtual double GetCoefficientHeight(INT32 index) = 0; // range [0..104]
- virtual void SetCoefficientHeight(INT32 index, double value) = 0;
- //END: struct csGeodeticXformParmsDmaMulReg
- virtual void SetTransformationMethod(INT32 mulRegTransformationMethod) = 0;
-protected:
- /// \brief
- /// \return
-CLASS_ID:
- static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticMultipleRegressionTransformDefParams;
+#ifndef _MGCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMDEFPARAMS_H_
+#define _MGCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMDEFPARAMS_H_
+/// \defgroup MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams
+/// \brief
+/// This class holds all parameters that are specific to the multiple regression transformation method.
+class MG_GEOMETRY_API MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams : public MgCoordinateSystemGeodeticTransformDefParams
+ DECLARE_CLASSNAME(MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams)
+PUBLISHED_API:
+ //BEGIN: struct csGeodeticXformParmsDmaMulReg
+ //virtual UINT32 GetPhiBitmap(INT32 index) = 0; // range [0..3]; long compiles as 32 bit in MS VC;
+ //virtual void SetPhiBitmap(INT32 index, UINT32 value) = 0; //long compiles as 32 bit in MS VC;
+ //virtual UINT32 GetLambdaBitmap(INT32 index) = 0; // range [0..3]; long compiles as 32 bit in MS VC;
+ //virtual void SetLambdaBitmap(INT32 index, UINT32 value) = 0; //long compiles as 32 bit in MS VC;
+ //virtual UINT32 GetHeightBitmap(INT32 index) = 0; // range [0..3]; long compiles as 32 bit in MS VC;
+ //virtual void SetHeightBitmap(INT32 index, UINT32 value) = 0; //long compiles as 32 bit in MS VC;
+ virtual double GetValidation() = 0;
+ virtual void SetValidation(double validation) = 0;
+ virtual double GetTestPhi() = 0;
+ virtual void SetTestPhi(double testPhi) = 0;
+ virtual double GetTestLambda() = 0;
+ virtual void SetTestLambda(double testLambda) = 0;
+ virtual double GetDeltaPhi() = 0;
+ virtual void SetDeltaPhi(double deltaPhi) = 0;
+ virtual double GetDeltaLambda() = 0;
+ virtual void SetDeltaLambda(double deltaLambda) = 0;
+ virtual double GetDeltaHeight() = 0;
+ virtual void SetDeltaHeight(double deltaHeight) = 0;
+ virtual double GetPhiOffset() = 0;
+ virtual void SetPhiOffset(double phiOffset) = 0;
+ virtual double GetLambdaOffset() = 0;
+ virtual void SetLambdaOffset(double lambdaOffset) = 0;
+ virtual double GetNormalizationScale() = 0;
+ virtual void SetNormalizationScale(double NormalizationScale) = 0;
+ virtual double GetCoefficientPhi(INT32 index) = 0; // range [0..104]
+ virtual void SetCoefficientPhi(INT32 index, double value) = 0;
+ virtual double GetCoefficientLambda(INT32 index) = 0; // range [0..104]
+ virtual void SetCoefficientLambda(INT32 index, double value) = 0;
+ virtual double GetCoefficientHeight(INT32 index) = 0; // range [0..104]
+ virtual void SetCoefficientHeight(INT32 index, double value) = 0;
+ //END: struct csGeodeticXformParmsDmaMulReg
+ virtual void SetTransformationMethod(INT32 mulRegTransformationMethod) = 0;
+protected:
+ /// \brief
+ /// \return
+CLASS_ID:
+ static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticMultipleRegressionTransformDefParams;
#endif //_MGCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMDEFPARAMS_H_
Property changes on: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformDefParams.h
+ native
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformationMethod.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformationMethod.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformationMethod.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,45 +1,45 @@
-#ifndef _MGCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMATIONMETHOD_H_
-#define _MGCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMATIONMETHOD_H_
-/// \defgroup MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod
-/// \brief
-/// multiple regression geodetic transformations as they can be read via the
-/// of type MgCoordinateSystemGeodeticTransformDefType.MultipleRegression.
-class MG_GEOMETRY_API MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod
-PUBLISHED_API:
- static const INT32 MultipleRegression = (20480 + 1); //cs_DTCMTH_MULRG
- static const INT32 GeneralPolynomialEpsg = (20480 + 2); //cs_DTCMTH_PLYNM
-#endif //_MGCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMATIONMETHOD_H_
+#ifndef _MGCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMATIONMETHOD_H_
+#define _MGCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMATIONMETHOD_H_
+/// \defgroup MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod
+/// \brief
+/// multiple regression geodetic transformations as they can be read via the
+/// of type MgCoordinateSystemGeodeticTransformDefType.MultipleRegression.
+class MG_GEOMETRY_API MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod
+PUBLISHED_API:
+ static const INT32 MultipleRegression = (20480 + 1); //cs_DTCMTH_MULRG
+ static const INT32 GeneralPolynomialEpsg = (20480 + 2); //cs_DTCMTH_PLYNM
+#endif //_MGCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMATIONMETHOD_H_
Property changes on: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformationMethod.h
+ native
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPath.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPath.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPath.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,143 +1,143 @@
-#ifndef _MGCOORDINATESYSTEMGEODETICPATH_H_
-#define _MGCOORDINATESYSTEMGEODETICPATH_H_
-/// \defgroup MgCoordinateSystemGeodeticPath MgCoordinateSystemGeodeticPath
-/// \brief
-/// A geodetic (transformation) path allows to concatenate multiple
-/// geodetic transformations. For example, converting between 2 datums
-/// cannot be achieved by doing 1 datum shift only but requires to
-/// do 1 or more datums shifts in between.
-class MG_GEOMETRY_API MgCoordinateSystemGeodeticPath : public MgGuardDisposable
- DECLARE_CLASSNAME(MgCoordinateSystemGeodeticPath)
-PUBLISHED_API:
- //properties
- virtual STRING GetPathName()=0;
- virtual void SetPathName(CREFSTRING)=0;
- virtual STRING GetDescription()=0; /// __get
- virtual void SetDescription(CREFSTRING)=0;
- virtual STRING GetGroup()=0; /// __get
- virtual void SetGroup(CREFSTRING)=0;
- virtual STRING GetSource()=0; /// __get
- virtual void SetSource(CREFSTRING)=0;
- virtual STRING GetTargetDatum()=0; /// __get
- virtual void SetTargetDatum(CREFSTRING)=0;
- virtual STRING GetSourceDatum()=0; /// __get
- virtual void SetSourceDatum(CREFSTRING)=0;
- virtual double GetAccuracy()=0; /// __get
- virtual void SetAccuracy(double accuracy)=0;
- virtual bool GetIsReversible()=0;
- virtual void SetIsReversible(bool isReversible)=0;
- virtual INT32 GetEpsgCode()=0;
- virtual void SetEpsgCode(INT32 epsgCode)=0;
- virtual INT32 GetEpsgVariant()=0;
- virtual void SetEpsgVariant(INT32 epsgVariant)=0;
- /// \brief
- /// Returns an ordered collection of MgCoordinateSystemGeodeticPathElement objects
- /// that form this geodetic transformation path. See remarks.
- /// \return
- /// Returns a (possibly empty) collection of MgCoordinateSystemGeodeticPathElement instances.
- /// The caller is responsible for disposing the collection being returned.
- /// \remarks
- /// Changing the collection being returned has no affect on this parent geodetic
- /// path instance. Instead, the collection can be modified and then re-set via
- /// SetPathElements.
- virtual MgDisposableCollection* GetPathElements() = 0;
- /// \brief
- /// Sets the individual transformation steps that form this geodetic transformation
- /// path.
- /// \remarks
- /// The caller is responsible for disposing the collection passed in, i.e.
- /// this geodetic path instance will not take ownership of the elements.
- virtual void SetPathElements(MgDisposableCollection* pathElements) = 0;
- virtual bool IsProtected() = 0;
- virtual bool IsValid() = 0;
- /// \brief
- /// Creates a new, unitialized MgCoordinateSystemGeodeticPathElement instance.
- /// Calling this method does not affect the underlying dictionary file.
- /// Typically, an API client will retrieve new objects through this method
- /// so they can be added to the collection of path elements that can be set
- /// via SetPathElements.
- /// \return
- /// Returns a new MgCoordinateSystemGeodeticPathElement instance. The caller is responsible
- /// for disposing the object being returned.
- virtual MgCoordinateSystemGeodeticPathElement* NewPathElement() = 0;
- /// \brief
- /// Creates a deep clone of this geodetic path. That is, the cloned object
- /// will also have its geodetic path element information cloned.
- /// \return
- /// Returns a new MgCoordinateSystemGeodeticPath object that is an exact clone
- /// of this MgCoordinateSystemGeodeticPath instance. The caller is responsible for
- /// disposing the object being returned.
- /// \remarks:
- /// The returned MgCoordinateSystemGeodeticPath instance will have its protected flag
- /// unset. However, all other properties like name etc will be the same. Any caller will
- /// have to change such values before trying to write the cloned instance into
- /// the dictionary file.
- virtual MgCoordinateSystemGeodeticPath* CreateClone() = 0;
-protected:
- /// \brief
- /// \return
-CLASS_ID:
- static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticPath;
-#endif //_MGCOORDINATESYSTEMGEODETICPATH_H_
+#ifndef _MGCOORDINATESYSTEMGEODETICPATH_H_
+#define _MGCOORDINATESYSTEMGEODETICPATH_H_
+/// \defgroup MgCoordinateSystemGeodeticPath MgCoordinateSystemGeodeticPath
+/// \brief
+/// A geodetic (transformation) path allows to concatenate multiple
+/// geodetic transformations. For example, converting between 2 datums
+/// cannot be achieved by doing 1 datum shift only but requires to
+/// do 1 or more datums shifts in between.
+class MG_GEOMETRY_API MgCoordinateSystemGeodeticPath : public MgGuardDisposable
+ DECLARE_CLASSNAME(MgCoordinateSystemGeodeticPath)
+PUBLISHED_API:
+ //properties
+ virtual STRING GetPathName()=0;
+ virtual void SetPathName(CREFSTRING)=0;
+ virtual STRING GetDescription()=0; /// __get
+ virtual void SetDescription(CREFSTRING)=0;
+ virtual STRING GetGroup()=0; /// __get
+ virtual void SetGroup(CREFSTRING)=0;
+ virtual STRING GetSource()=0; /// __get
+ virtual void SetSource(CREFSTRING)=0;
+ virtual STRING GetTargetDatum()=0; /// __get
+ virtual void SetTargetDatum(CREFSTRING)=0;
+ virtual STRING GetSourceDatum()=0; /// __get
+ virtual void SetSourceDatum(CREFSTRING)=0;
+ virtual double GetAccuracy()=0; /// __get
+ virtual void SetAccuracy(double accuracy)=0;
+ virtual bool GetIsReversible()=0;
+ virtual void SetIsReversible(bool isReversible)=0;
+ virtual INT32 GetEpsgCode()=0;
+ virtual void SetEpsgCode(INT32 epsgCode)=0;
+ virtual INT32 GetEpsgVariant()=0;
+ virtual void SetEpsgVariant(INT32 epsgVariant)=0;
+ /// \brief
+ /// Returns an ordered collection of MgCoordinateSystemGeodeticPathElement objects
+ /// that form this geodetic transformation path. See remarks.
+ /// \return
+ /// Returns a (possibly empty) collection of MgCoordinateSystemGeodeticPathElement instances.
+ /// The caller is responsible for disposing the collection being returned.
+ /// \remarks
+ /// Changing the collection being returned has no affect on this parent geodetic
+ /// path instance. Instead, the collection can be modified and then re-set via
+ /// SetPathElements.
+ virtual MgDisposableCollection* GetPathElements() = 0;
+ /// \brief
+ /// Sets the individual transformation steps that form this geodetic transformation
+ /// path.
+ /// \remarks
+ /// The caller is responsible for disposing the collection passed in, i.e.
+ /// this geodetic path instance will not take ownership of the elements.
+ virtual void SetPathElements(MgDisposableCollection* pathElements) = 0;
+ virtual bool IsProtected() = 0;
+ virtual bool IsValid() = 0;
+ /// \brief
+ /// Creates a new, unitialized MgCoordinateSystemGeodeticPathElement instance.
+ /// Calling this method does not affect the underlying dictionary file.
+ /// Typically, an API client will retrieve new objects through this method
+ /// so they can be added to the collection of path elements that can be set
+ /// via SetPathElements.
+ /// \return
+ /// Returns a new MgCoordinateSystemGeodeticPathElement instance. The caller is responsible
+ /// for disposing the object being returned.
+ virtual MgCoordinateSystemGeodeticPathElement* NewPathElement() = 0;
+ /// \brief
+ /// Creates a deep clone of this geodetic path. That is, the cloned object
+ /// will also have its geodetic path element information cloned.
+ /// \return
+ /// Returns a new MgCoordinateSystemGeodeticPath object that is an exact clone
+ /// of this MgCoordinateSystemGeodeticPath instance. The caller is responsible for
+ /// disposing the object being returned.
+ /// \remarks:
+ /// The returned MgCoordinateSystemGeodeticPath instance will have its protected flag
+ /// unset. However, all other properties like name etc will be the same. Any caller will
+ /// have to change such values before trying to write the cloned instance into
+ /// the dictionary file.
+ virtual MgCoordinateSystemGeodeticPath* CreateClone() = 0;
+protected:
+ /// \brief
+ /// \return
+CLASS_ID:
+ static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticPath;
+#endif //_MGCOORDINATESYSTEMGEODETICPATH_H_
Property changes on: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPath.h
+ native
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathDictionary.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathDictionary.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathDictionary.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,76 +1,76 @@
-#ifndef _MGCOORDINATESYSTEMGEODETICPATHDICTIONARY_H_
-#define _MGCOORDINATESYSTEMGEODETICPATHDICTIONARY_H_
-/// \defgroup MgCoordinateSystemGeodeticPathDictionary MgCoordinateSystemGeodeticPathDictionary
-/// \brief
-/// The MgCoordinateSystemGeodeticPathDictionary provides access to all geodetic transformation path
-/// definitions as defined in the dictionary file this instance reads from / writes to.
-class MG_GEOMETRY_API MgCoordinateSystemGeodeticPathDictionary : public MgCoordinateSystemDictionaryBase
- DECLARE_CLASSNAME(MgCoordinateSystemGeodeticPathDictionary)
-PUBLISHED_API:
- /// \brief
- /// Creates a new, empty geodetic path object that has to be filled by an API client. This
- /// method does not create a new entry in the dictionary. The caller is responsible
- /// \return
- /// Return a new, in-memory geodetic path object. No content is written to disk
- /// when this method executes.
- virtual MgCoordinateSystemGeodeticPath* NewGeodeticPath()=0;
- /// \brief
- /// Returns the geodetic path object where the name is equal to the parameter
- /// pathName. The caller is responsible for disposing the object.
- /// \param pathName
- /// The name of the geodetic path to look up in the dictionary. Must not be an empty string.
- /// \return
- /// Return the geodetic path if found. Otherwise NULL.
- virtual MgCoordinateSystemGeodeticPath* GetGeodeticPath(CREFSTRING pathName)=0;
-protected:
- /// \brief
- /// \return
-CLASS_ID:
- static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticPathDictionary;
-#endif //_MGCOORDINATESYSTEMGEODETICPATHDICTIONARY_H_
+#ifndef _MGCOORDINATESYSTEMGEODETICPATHDICTIONARY_H_
+#define _MGCOORDINATESYSTEMGEODETICPATHDICTIONARY_H_
+/// \defgroup MgCoordinateSystemGeodeticPathDictionary MgCoordinateSystemGeodeticPathDictionary
+/// \brief
+/// The MgCoordinateSystemGeodeticPathDictionary provides access to all geodetic transformation path
+/// definitions as defined in the dictionary file this instance reads from / writes to.
+class MG_GEOMETRY_API MgCoordinateSystemGeodeticPathDictionary : public MgCoordinateSystemDictionaryBase
+ DECLARE_CLASSNAME(MgCoordinateSystemGeodeticPathDictionary)
+PUBLISHED_API:
+ /// \brief
+ /// Creates a new, empty geodetic path object that has to be filled by an API client. This
+ /// method does not create a new entry in the dictionary. The caller is responsible
+ /// \return
+ /// Return a new, in-memory geodetic path object. No content is written to disk
+ /// when this method executes.
+ virtual MgCoordinateSystemGeodeticPath* NewGeodeticPath()=0;
+ /// \brief
+ /// Returns the geodetic path object where the name is equal to the parameter
+ /// pathName. The caller is responsible for disposing the object.
+ /// \param pathName
+ /// The name of the geodetic path to look up in the dictionary. Must not be an empty string.
+ /// \return
+ /// Return the geodetic path if found. Otherwise NULL.
+ virtual MgCoordinateSystemGeodeticPath* GetGeodeticPath(CREFSTRING pathName)=0;
+protected:
+ /// \brief
+ /// \return
+CLASS_ID:
+ static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticPathDictionary;
+#endif //_MGCOORDINATESYSTEMGEODETICPATHDICTIONARY_H_
Property changes on: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathDictionary.h
___________________________________________________________________
Added: svn:eol-style
+ native
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathElement.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathElement.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathElement.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,55 +1,55 @@
-#ifndef _MGCOORDINATESYSTEMGEODETICPATHELEMENT_H_
-#define _MGCOORDINATESYSTEMGEODETICPATHELEMENT_H_
-/// \defgroup MgCoordinateSystemGeodeticPathElement MgCoordinateSystemGeodeticPathElement
-/// \brief
-/// A geodetic transformation path element describes a single transformation step within a series
-/// of concatenated steps that eventually form a geodetic (transformation) path.
-class MG_GEOMETRY_API MgCoordinateSystemGeodeticPathElement : public MgGuardDisposable
- DECLARE_CLASSNAME(MgCoordinateSystemGeodeticPathElement)
-PUBLISHED_API:
- virtual STRING GetTransformName() = 0;
- virtual void SetTransformName(CREFSTRING) = 0;
- virtual bool GetIsInversed() = 0;
- virtual void SetIsInversed(bool) = 0;
-protected:
- /// \brief
- /// \return
-CLASS_ID:
- static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticPathElement;
+#ifndef _MGCOORDINATESYSTEMGEODETICPATHELEMENT_H_
+#define _MGCOORDINATESYSTEMGEODETICPATHELEMENT_H_
+/// \defgroup MgCoordinateSystemGeodeticPathElement MgCoordinateSystemGeodeticPathElement
+/// \brief
+/// A geodetic transformation path element describes a single transformation step within a series
+/// of concatenated steps that eventually form a geodetic (transformation) path.
+class MG_GEOMETRY_API MgCoordinateSystemGeodeticPathElement : public MgGuardDisposable
+ DECLARE_CLASSNAME(MgCoordinateSystemGeodeticPathElement)
+PUBLISHED_API:
+ virtual STRING GetTransformName() = 0;
+ virtual void SetTransformName(CREFSTRING) = 0;
+ virtual bool GetIsInversed() = 0;
+ virtual void SetIsInversed(bool) = 0;
+protected:
+ /// \brief
+ /// \return
+CLASS_ID:
+ static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticPathElement;
#endif
\ No newline at end of file
Property changes on: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathElement.h
+ native
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,178 +1,178 @@
-#ifndef _MGCOORDINATESYSTEMGEODETICTRANSFORMDEF_H_
-#define _MGCOORDINATESYSTEMGEODETICTRANSFORMDEF_H_
-/// \defgroup MgCoordinateSystemGeodeticTransformDef MgCoordinateSystemGeodeticTransformDef
-/// \brief
-/// An instance of this class describes a geodetic transformation with all its parameters
-/// as it is defined in the dictionary file. The actual transformation operation
-/// is performed by the MgCoordinateSystemGeodeticTransformation objects
-/// that's being returned by the CreateTransformation method.
-class MG_GEOMETRY_API MgCoordinateSystemGeodeticTransformDef : public MgGuardDisposable
- DECLARE_CLASSNAME(MgCoordinateSystemGeodeticTransformDef)
-PUBLISHED_API:
- //BEGIN: struct cs_GeodeticTransform_
- virtual void SetTransformName(CREFSTRING name) = 0;
- virtual STRING GetSourceDatum() = 0;
- virtual void SetSourceDatum(CREFSTRING datumKey) = 0;
- virtual STRING GetTargetDatum() = 0;
- virtual void SetTargetDatum(CREFSTRING datumKey) = 0;
- virtual STRING GetGroup() = 0;
- virtual void SetGroup(CREFSTRING group) = 0;
- virtual STRING GetDescription() = 0;
- virtual void SetDescription(CREFSTRING description) = 0;
- virtual STRING GetSource() = 0;
- virtual void SetSource(CREFSTRING source) = 0;
- virtual INT32 GetEpsgCode() = 0;
- virtual void SetEpsgCode(INT32 epsgCode) = 0;
- virtual INT32 GetEpsgVariation() = 0;
- virtual void SetEpsgVariation(INT32 epsgVariation) = 0;
- virtual bool GetInverseSupported() = 0;
- virtual void SetInverseSupported(bool inverseSupported) = 0;
- virtual INT32 GetMaxIterations() = 0;
- virtual void SetMaxIterations(INT32 maxIterations) = 0;
- virtual double GetConvergenceValue() = 0;
- virtual void SetConvergenceValue(double convergenceValue) = 0;
- virtual double GetErrorValue() = 0;
- virtual void SetErrorValue(double errorValue) = 0;
- virtual double GetAccuracy() = 0;
- virtual void SetAccuracy(double accuracy) = 0;
- //END: struct cs_GeodeticTransform_
- /// \brief
- /// Returns the type of this geodetic transformation (as defined by MgCoordinateSystemGeodeticTransformDefType).
- /// The type defines the parameters that are being returned by the GetParameters method.
- virtual INT32 GetTransformDefType() = 0;
- /// \brief
- /// Returns the extended parameters object valid for this transformation definition. See remarks.
- /// Depending on the type returned by GetTransformDefType(), this method returns one of the following:
- /// \li NULL if this is a NULL transformation
- /// \li MgCoordinateSystemGeodeticAnalyticalTransformDefParams if this transformation uses an anylitical transformation method
- /// \li MgCoordinateSystemGeodeticInterpolationTransformDefParams if this transformation uses grid files
- /// \li MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams if this transformation is a multiple regression transformation type
- /// \return
- /// Returns the extended parameters (or NULL) object for this transformation object. The
- /// caller is responsible for disposing the object being returned. See remarks.
- /// \remarks
- /// If a caller needs to change the parameters of a transformation, the values
- /// have to be changed on the object being returned here and then written
- /// back via SetParameters. Setting the values on the parameters object
- /// has no affect on this transformation definition.
- virtual MgCoordinateSystemGeodeticTransformDefParams* GetParameters() = 0;
- /// \brief
- /// Sets the extended parameters for this transformation.
- /// \param parameters
- /// The parameters to set for this transformation. The object passed in,
- /// has to be of the same type as it has been returned by GetParameters. Otherwise,
- /// an exception will be thrown. This parameter can only be NULL, if this is a NONE transformation.
- /// \remarks
- /// The instance passed in has to be disposed by the caller, i.e. this transformation
- /// object will not take ownership of it.
- virtual void SetParameters(MgCoordinateSystemGeodeticTransformDefParams* parameters) = 0;
- /// \brief
- /// Creates a deep clone of this geodetic transformation. That is, the cloned object
- /// will also have its extended parameters cloned.
- /// \return
- /// Returns a new MgCoordinateSystemGeodeticTransformDef object that is an exact clone
- /// of this MgCoordinateSystemGeodeticTransformDef instance. The caller is responsible for
- /// \remarks
- /// The returned MgCoordinateSystemGeodeticTransformDef instance will have its protected flag
- virtual MgCoordinateSystemGeodeticTransformDef* CreateClone() = 0;
- /// \brief
- /// Creates a new MgCoordinateSystemGeodeticTransformation object that
- /// can be used to perform the actual transformation this transformation
- /// definition describes. This method will fail with an exception,
- /// if this is the NONE transformation.
- /// \param createInverse
- /// If true, the MgCoordinateSystemGeodeticTransformation being returned will
- /// perform the inverse of the transformation as defined in the dictionary file. That is,
- /// it will convert from the actual target datum to the source datum. Note, that not all
- /// transformations are invertible. This method will fail with an exception then.
- /// If false, this method will return a MgCoordinateSystemGeodeticTransformation
- /// instance that performs the default forward datum transformation.
- /// \return
- /// Returns the MgCoordinateSystemGeodeticTransformation that performs the actual
- /// datum transformation as described by this definition instance. The caller
- /// is reponsible for disposing the object being returned.
- virtual MgCoordinateSystemGeodeticTransformation* CreateTransformation(bool createInverse) = 0;
-protected:
- /// \brief
- /// \return
-CLASS_ID:
- static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticTransformDef;
+#ifndef _MGCOORDINATESYSTEMGEODETICTRANSFORMDEF_H_
+#define _MGCOORDINATESYSTEMGEODETICTRANSFORMDEF_H_
+/// \defgroup MgCoordinateSystemGeodeticTransformDef MgCoordinateSystemGeodeticTransformDef
+/// \brief
+/// An instance of this class describes a geodetic transformation with all its parameters
+/// as it is defined in the dictionary file. The actual transformation operation
+/// is performed by the MgCoordinateSystemGeodeticTransformation objects
+/// that's being returned by the CreateTransformation method.
+class MG_GEOMETRY_API MgCoordinateSystemGeodeticTransformDef : public MgGuardDisposable
+ DECLARE_CLASSNAME(MgCoordinateSystemGeodeticTransformDef)
+PUBLISHED_API:
+ //BEGIN: struct cs_GeodeticTransform_
+ virtual void SetTransformName(CREFSTRING name) = 0;
+ virtual STRING GetSourceDatum() = 0;
+ virtual void SetSourceDatum(CREFSTRING datumKey) = 0;
+ virtual STRING GetTargetDatum() = 0;
+ virtual void SetTargetDatum(CREFSTRING datumKey) = 0;
+ virtual STRING GetGroup() = 0;
+ virtual void SetGroup(CREFSTRING group) = 0;
+ virtual STRING GetDescription() = 0;
+ virtual void SetDescription(CREFSTRING description) = 0;
+ virtual STRING GetSource() = 0;
+ virtual void SetSource(CREFSTRING source) = 0;
+ virtual INT32 GetEpsgCode() = 0;
+ virtual void SetEpsgCode(INT32 epsgCode) = 0;
+ virtual INT32 GetEpsgVariation() = 0;
+ virtual void SetEpsgVariation(INT32 epsgVariation) = 0;
+ virtual bool GetInverseSupported() = 0;
+ virtual void SetInverseSupported(bool inverseSupported) = 0;
+ virtual INT32 GetMaxIterations() = 0;
+ virtual void SetMaxIterations(INT32 maxIterations) = 0;
+ virtual double GetConvergenceValue() = 0;
+ virtual void SetConvergenceValue(double convergenceValue) = 0;
+ virtual double GetErrorValue() = 0;
+ virtual void SetErrorValue(double errorValue) = 0;
+ virtual double GetAccuracy() = 0;
+ virtual void SetAccuracy(double accuracy) = 0;
+ //END: struct cs_GeodeticTransform_
+ /// \brief
+ /// Returns the type of this geodetic transformation (as defined by MgCoordinateSystemGeodeticTransformDefType).
+ /// The type defines the parameters that are being returned by the GetParameters method.
+ virtual INT32 GetTransformDefType() = 0;
+ /// \brief
+ /// Returns the extended parameters object valid for this transformation definition. See remarks.
+ /// Depending on the type returned by GetTransformDefType(), this method returns one of the following:
+ /// \li NULL if this is a NULL transformation
+ /// \li MgCoordinateSystemGeodeticAnalyticalTransformDefParams if this transformation uses an anylitical transformation method
+ /// \li MgCoordinateSystemGeodeticInterpolationTransformDefParams if this transformation uses grid files
+ /// \li MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams if this transformation is a multiple regression transformation type
+ /// \return
+ /// Returns the extended parameters (or NULL) object for this transformation object. The
+ /// caller is responsible for disposing the object being returned. See remarks.
+ /// \remarks
+ /// If a caller needs to change the parameters of a transformation, the values
+ /// have to be changed on the object being returned here and then written
+ /// back via SetParameters. Setting the values on the parameters object
+ /// has no affect on this transformation definition.
+ virtual MgCoordinateSystemGeodeticTransformDefParams* GetParameters() = 0;
+ /// \brief
+ /// Sets the extended parameters for this transformation.
+ /// \param parameters
+ /// The parameters to set for this transformation. The object passed in,
+ /// has to be of the same type as it has been returned by GetParameters. Otherwise,
+ /// an exception will be thrown. This parameter can only be NULL, if this is a NONE transformation.
+ /// \remarks
+ /// The instance passed in has to be disposed by the caller, i.e. this transformation
+ /// object will not take ownership of it.
+ virtual void SetParameters(MgCoordinateSystemGeodeticTransformDefParams* parameters) = 0;
+ /// \brief
+ /// Creates a deep clone of this geodetic transformation. That is, the cloned object
+ /// will also have its extended parameters cloned.
+ /// \return
+ /// Returns a new MgCoordinateSystemGeodeticTransformDef object that is an exact clone
+ /// of this MgCoordinateSystemGeodeticTransformDef instance. The caller is responsible for
+ /// \remarks
+ /// The returned MgCoordinateSystemGeodeticTransformDef instance will have its protected flag
+ virtual MgCoordinateSystemGeodeticTransformDef* CreateClone() = 0;
+ /// \brief
+ /// Creates a new MgCoordinateSystemGeodeticTransformation object that
+ /// can be used to perform the actual transformation this transformation
+ /// definition describes. This method will fail with an exception,
+ /// if this is the NONE transformation.
+ /// \param createInverse
+ /// If true, the MgCoordinateSystemGeodeticTransformation being returned will
+ /// perform the inverse of the transformation as defined in the dictionary file. That is,
+ /// it will convert from the actual target datum to the source datum. Note, that not all
+ /// transformations are invertible. This method will fail with an exception then.
+ /// If false, this method will return a MgCoordinateSystemGeodeticTransformation
+ /// instance that performs the default forward datum transformation.
+ /// \return
+ /// Returns the MgCoordinateSystemGeodeticTransformation that performs the actual
+ /// datum transformation as described by this definition instance. The caller
+ /// is reponsible for disposing the object being returned.
+ virtual MgCoordinateSystemGeodeticTransformation* CreateTransformation(bool createInverse) = 0;
+protected:
+ /// \brief
+ /// \return
+CLASS_ID:
+ static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticTransformDef;
#endif //_MGCOORDINATESYSTEMGEODETICTRANSFORMDEF_H_
Property changes on: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h
+ native
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefDictionary.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefDictionary.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefDictionary.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,77 +1,77 @@
-#ifndef _MGCOORDINATESYSTEMGEODETICTRANSFORMDEFDICTIONARY_H_
-#define _MGCOORDINATESYSTEMGEODETICTRANSFORMDEFDICTIONARY_H_
-/// \defgroup MgCoordinateSystemGeodeticTransformDefDictionary MgCoordinateSystemGeodeticTransformDefDictionary
-/// \brief
-/// The MgCoordinateSystemGeodeticTransformDefDictionary provides access to all geodetic transformation
-class MG_GEOMETRY_API MgCoordinateSystemGeodeticTransformDefDictionary : public MgCoordinateSystemDictionaryBase
- DECLARE_CLASSNAME(MgCoordinateSystemGeodeticTransformDefDictionary)
-PUBLISHED_API:
- /// \brief
- /// Creates a new, empty geodetic transformation definition object that has to be filled by an API client. This
- /// \return
- /// Return a new, in-memory geodetic transformation definition object. No content is written to disk
- virtual MgCoordinateSystemGeodeticTransformDef* NewGeodeticTransformationDef(INT32 transformationDefType) = 0;
- /// \brief
- /// Returns the geodetic transformation definition object where the name is equal to the parameter
- /// \param transformationName
- /// The name of the geodetic transformation to look up in the dictionary. Must not be an empty string.
- /// \return
- /// Return the geodetic transformation if found. Otherwise NULL.
- virtual MgCoordinateSystemGeodeticTransformDef* GetGeodeticTransformationDef(CREFSTRING transformationName)=0;
-protected:
- /// \brief
- /// \return
-CLASS_ID:
- static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticTransformDefDictionary;
+#ifndef _MGCOORDINATESYSTEMGEODETICTRANSFORMDEFDICTIONARY_H_
+#define _MGCOORDINATESYSTEMGEODETICTRANSFORMDEFDICTIONARY_H_
+/// \defgroup MgCoordinateSystemGeodeticTransformDefDictionary MgCoordinateSystemGeodeticTransformDefDictionary
+/// \brief
+/// The MgCoordinateSystemGeodeticTransformDefDictionary provides access to all geodetic transformation
+class MG_GEOMETRY_API MgCoordinateSystemGeodeticTransformDefDictionary : public MgCoordinateSystemDictionaryBase
+ DECLARE_CLASSNAME(MgCoordinateSystemGeodeticTransformDefDictionary)
+PUBLISHED_API:
+ /// \brief
+ /// Creates a new, empty geodetic transformation definition object that has to be filled by an API client. This
+ /// \return
+ /// Return a new, in-memory geodetic transformation definition object. No content is written to disk
+ virtual MgCoordinateSystemGeodeticTransformDef* NewGeodeticTransformationDef(INT32 transformationDefType) = 0;
+ /// \brief
+ /// Returns the geodetic transformation definition object where the name is equal to the parameter
+ /// \param transformationName
+ /// The name of the geodetic transformation to look up in the dictionary. Must not be an empty string.
+ /// \return
+ /// Return the geodetic transformation if found. Otherwise NULL.
+ virtual MgCoordinateSystemGeodeticTransformDef* GetGeodeticTransformationDef(CREFSTRING transformationName)=0;
+protected:
+ /// \brief
+ /// \return
+CLASS_ID:
+ static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticTransformDefDictionary;
#endif //_MGCOORDINATESYSTEMGEODETICTRANSFORMDEFDICTIONARY_H_
Property changes on: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefDictionary.h
+ native
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefParams.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefParams.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefParams.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,58 +1,58 @@
-// Copyright (C) 2004-2010 by Autodesk, Inc.
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of version 2.1 of the GNU Lesser
-// General Public License as published by the Free Software Foundation.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-#ifndef _MGCOORDINATESYSTEMGEODETICTRANSFORMDEFPARAMS_H_
-#define _MGCOORDINATESYSTEMGEODETICTRANSFORMDEFPARAMS_H_
-/// \defgroup MgCoordinateSystemGeodeticTransformDefParams MgCoordinateSystemGeodeticTransformDefParams
-/// \brief
-/// Common base class for all geodetic transformation parameters.
-class MG_GEOMETRY_API MgCoordinateSystemGeodeticTransformDefParams : public MgGuardDisposable
- DECLARE_CLASSNAME(MgCoordinateSystemGeodeticTransformDefParams)
-PUBLISHED_API:
- /// \brief
- /// Checks, whether this transformation parameter object's content is considered (technically) valid.
- /// That is, even if this method returns true, the transformation might still fail due to
- /// other reasons, e.g. a grid file does not exist.
- /// \return
- /// Returns true, if this parameter object is considered valid. Otherwise false.
- /// \brief
- /// Checks, whether this transformation object is protected, i.e. any attempts to change its
- /// content will fail. All definitions contained in the dictionaries at compile time
- /// are protected by default.
- /// \return
- /// Returns true, if this parameter object is read-only. Otherwise false.
+#ifndef _MGCOORDINATESYSTEMGEODETICTRANSFORMDEFPARAMS_H_
+#define _MGCOORDINATESYSTEMGEODETICTRANSFORMDEFPARAMS_H_
+/// \defgroup MgCoordinateSystemGeodeticTransformDefParams MgCoordinateSystemGeodeticTransformDefParams
+/// \brief
+/// Common base class for all geodetic transformation parameters.
+class MG_GEOMETRY_API MgCoordinateSystemGeodeticTransformDefParams : public MgGuardDisposable
+ DECLARE_CLASSNAME(MgCoordinateSystemGeodeticTransformDefParams)
+PUBLISHED_API:
+ /// \brief
+ /// Checks, whether this transformation parameter object's content is considered (technically) valid.
+ /// That is, even if this method returns true, the transformation might still fail due to
+ /// other reasons, e.g. a grid file does not exist.
+ /// \return
+ /// Returns true, if this parameter object is considered valid. Otherwise false.
+ /// \brief
+ /// Checks, whether this transformation object is protected, i.e. any attempts to change its
+ /// content will fail. All definitions contained in the dictionaries at compile time
+ /// are protected by default.
+ /// \return
+ /// Returns true, if this parameter object is read-only. Otherwise false.
#endif _MGCOORDINATESYSTEMGEODETICTRANSFORMDEFPARAMS_H_
Property changes on: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefParams.h
+ native
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefType.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefType.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefType.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,63 +1,63 @@
-#ifndef _MGCOORDINATESYSTEMGEODETICTRANSFORMDEFTYPE_H_
-#define _MGCOORDINATESYSTEMGEODETICTRANSFORMDEFTYPE_H_
-/// \defgroup MgCoordinateSystemGeodeticTransformDefType MgCoordinateSystemGeodeticTransformDefType
-/// \brief
-/// This class contains the constants for all current transformation definition types.
-class MG_GEOMETRY_API MgCoordinateSystemGeodeticTransformDefType
-PUBLISHED_API:
- /// \brief
- /// The transformation definition describes the NONE transformation. That is, that
- /// transformation doesn't actually perform a datum shift but is basically a NOOP.
- /// \brief
- /// The transformation definition describes an analytical transformation where
- /// the transformation between the source and the target datum is defined
- /// through a formular that's fed with up to 10 parameters.
- static const INT32 Analytical = 1;
- /// \brief
- /// The transformation definition describes a transformation that
- /// uses grid files to calculate the actual datum shift for a given
- /// coordinate by interpolating between given grid points.
- static const INT32 Interpolation = 2;
- /// \brief
- /// uses a multiple regression calculation to perform the actual datum shift.
- static const INT32 MultipleRegression = 4;
+#ifndef _MGCOORDINATESYSTEMGEODETICTRANSFORMDEFTYPE_H_
+#define _MGCOORDINATESYSTEMGEODETICTRANSFORMDEFTYPE_H_
+/// \defgroup MgCoordinateSystemGeodeticTransformDefType MgCoordinateSystemGeodeticTransformDefType
+/// \brief
+/// This class contains the constants for all current transformation definition types.
+class MG_GEOMETRY_API MgCoordinateSystemGeodeticTransformDefType
+PUBLISHED_API:
+ /// \brief
+ /// The transformation definition describes the NONE transformation. That is, that
+ /// transformation doesn't actually perform a datum shift but is basically a NOOP.
+ /// \brief
+ /// The transformation definition describes an analytical transformation where
+ /// the transformation between the source and the target datum is defined
+ /// through a formular that's fed with up to 10 parameters.
+ static const INT32 Analytical = 1;
+ /// \brief
+ /// The transformation definition describes a transformation that
+ /// uses grid files to calculate the actual datum shift for a given
+ /// coordinate by interpolating between given grid points.
+ static const INT32 Interpolation = 2;
+ /// \brief
+ /// uses a multiple regression calculation to perform the actual datum shift.
+ static const INT32 MultipleRegression = 4;
#endif //_MGCOORDINATESYSTEMGEODETICTRANSFORMDEFTYPE_H_
Property changes on: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefType.h
+ native
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFile.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFile.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFile.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,94 +1,94 @@
-#ifndef _MGCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILE_H_
-#define _MGCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILE_H_
-/// \defgroup MgCoordinateSystemGeodeticTransformGridFile MgCoordinateSystemGeodeticTransformGridFile
-/// \ingroup Coordinate_System_classes
-/// \brief
-/// The MgCoordinateSystemGeodeticInterpolationTransformDefParams parameter class requires
-/// instances of MgCoordinateSystemGeodeticTransformGridFile to be set via its
-/// SetGridFiles method. An MgCoordinateSystemGeodeticTransformGridFile object simply describes
-/// the grid file rather than containing the (grid file) information itself.
-class MG_GEOMETRY_API MgCoordinateSystemGeodeticTransformGridFile : public MgGuardDisposable
- DECLARE_CLASSNAME(MgCoordinateSystemGeodeticTransformGridFile)
-PUBLISHED_API:
- /// \brief
- /// Returns the format of the grid file as a constant value as defined in
- /// MgCoordinateSystemGeodeticTransformGridFileFormat.
- /// \return
- /// Returns the file format as an INT32 value.
- virtual INT32 GetFileFormat() = 0;
- /// \brief
- /// Sets this file's format. Has to be constant
- /// as defined by MgCoordinateSystemGeodeticTransformGridFileFormat.
- virtual void SetFileFormat(INT32 gridFileFormat) = 0;
- /// \brief
- /// When used within a geodetic transformation that defines a source and a target
- /// datum, this flag instructs the API whether to consider the grid file's content
- /// to be the inverse of the actual conversion direction.
- /// \return
- /// Returns true, if the grid file provides information to transform between
- /// 2 datums in the inversed direction to what's actually specified in
- /// the parent transformation definition.
- virtual bool GetIsInverseDirection() = 0;
- /// \brief
- /// Sets the flag, whether this grid file carries the information
- /// to perform a datum transformation in the inversed direction
- /// to what's specified in the parent transformation definition.
- virtual void SetIsInverseDirection(bool isInverseDirection) = 0;
- virtual STRING GetFileName() = 0;
- virtual void SetFileName(CREFSTRING fileName) = 0;
-protected:
- /// \brief
- /// Get the class Id
- /// \return
- /// The integer value
- INT32 GetClassId(){return m_cls_id;};
-CLASS_ID:
- static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticTransformGridFile;
+#ifndef _MGCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILE_H_
+#define _MGCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILE_H_
+/// \defgroup MgCoordinateSystemGeodeticTransformGridFile MgCoordinateSystemGeodeticTransformGridFile
+/// \ingroup Coordinate_System_classes
+/// \brief
+/// The MgCoordinateSystemGeodeticInterpolationTransformDefParams parameter class requires
+/// instances of MgCoordinateSystemGeodeticTransformGridFile to be set via its
+/// SetGridFiles method. An MgCoordinateSystemGeodeticTransformGridFile object simply describes
+/// the grid file rather than containing the (grid file) information itself.
+class MG_GEOMETRY_API MgCoordinateSystemGeodeticTransformGridFile : public MgGuardDisposable
+ DECLARE_CLASSNAME(MgCoordinateSystemGeodeticTransformGridFile)
+PUBLISHED_API:
+ /// \brief
+ /// Returns the format of the grid file as a constant value as defined in
+ /// MgCoordinateSystemGeodeticTransformGridFileFormat.
+ /// \return
+ /// Returns the file format as an INT32 value.
+ virtual INT32 GetFileFormat() = 0;
+ /// \brief
+ /// Sets this file's format. Has to be constant
+ /// as defined by MgCoordinateSystemGeodeticTransformGridFileFormat.
+ virtual void SetFileFormat(INT32 gridFileFormat) = 0;
+ /// \brief
+ /// When used within a geodetic transformation that defines a source and a target
+ /// datum, this flag instructs the API whether to consider the grid file's content
+ /// to be the inverse of the actual conversion direction.
+ /// \return
+ /// Returns true, if the grid file provides information to transform between
+ /// 2 datums in the inversed direction to what's actually specified in
+ /// the parent transformation definition.
+ virtual bool GetIsInverseDirection() = 0;
+ /// \brief
+ /// Sets the flag, whether this grid file carries the information
+ /// to perform a datum transformation in the inversed direction
+ /// to what's specified in the parent transformation definition.
+ virtual void SetIsInverseDirection(bool isInverseDirection) = 0;
+ virtual STRING GetFileName() = 0;
+ virtual void SetFileName(CREFSTRING fileName) = 0;
+protected:
+ /// \brief
+ /// Get the class Id
+ /// \return
+ /// The integer value
+ INT32 GetClassId(){return m_cls_id;};
+CLASS_ID:
+ static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGeodeticTransformGridFile;
#endif //_MGCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILE_H_
Property changes on: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFile.h
+ native
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFileFormat.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFileFormat.h 2010-09-21 08:36:03 UTC (rev 5169)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFileFormat.h 2010-09-21 14:52:39 UTC (rev 5170)
@@ -1,44 +1,44 @@
-#ifndef _MGCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILEFORMAT_H_
-#define _MGCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILEFORMAT_H_
-/// \defgroup MgCoordinateSystemGeodeticTransformGridFileFormat MgCoordinateSystemGeodeticTransformGridFileFormat
-/// \brief
-/// This class contains the constants for all currently supported grid file formats.
-class MG_GEOMETRY_API MgCoordinateSystemGeodeticTransformGridFileFormat
-PUBLISHED_API:
- static const INT32 None = 0;
- static const INT32 NTv1 = 1;
- static const INT32 NTv2 = 2;
- static const INT32 NADCON = 3;
- static const INT32 RGF = 4;
- static const INT32 PAR = 5;
- static const INT32 ATS77 = 6;
+// Copyright (C) 2004-2010 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#ifndef _MGCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILEFORMAT_H_
+#define _MGCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILEFORMAT_H_
+/// \defgroup MgCoordinateSystemGeodeticTransformGridFileFormat MgCoordinateSystemGeodeticTransformGridFileFormat
+/// \brief
+/// This class contains the constants for all currently supported grid file formats.
+class MG_GEOMETRY_API MgCoordinateSystemGeodeticTransformGridFileFormat
+PUBLISHED_API:
+ static const INT32 None = 0;
+ static const INT32 NTv1 = 1;
+ static const INT32 NTv2 = 2;
+ static const INT32 NADCON = 3;
+ static const INT32 RGF = 4;
+ static const INT32 PAR = 5;
+ static const INT32 ATS77 = 6;
#endif //_MGCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILEFORMAT_H_
Property changes on: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFileFormat.h
+ native
More information about the mapguide-commits
