[mapguide-commits] r5173 - trunk/MgDev/Common/Renderers
svn_mapguide at osgeo.org
Tue Sep 21 14:04:10 EDT 2010
Author: traianstanev
Date: 2010-09-21 18:04:09 +0000 (Tue, 21 Sep 2010)
New Revision: 5173
trunk/MgDev/Common/Renderers/FontManager.cpp
trunk/MgDev/Common/Renderers/FontManager.h
Cleanup in FontManager -- removed some unused code and consolidated a loop over all faces inside a font file into a helper function (it was common for Windows and Linux).
Added ability to cache specific fonts by filename instead of iterating over all fonts, since reading all fonts can take quite some time. This is turned off for MapGuide, since startup time is not critical here.
Modified: trunk/MgDev/Common/Renderers/FontManager.cpp
--- trunk/MgDev/Common/Renderers/FontManager.cpp 2010-09-21 17:55:08 UTC (rev 5172)
+++ trunk/MgDev/Common/Renderers/FontManager.cpp 2010-09-21 18:04:09 UTC (rev 5173)
@@ -1,5 +1,5 @@
-// Copyright (C) 2004-2010 by Autodesk, Inc.
+// Copyright (C) 2004-2008 by Autodesk, Inc.
// This library is free software; you can redistribute it and/or
// modify it under the terms of version 2.1 of the GNU Lesser
@@ -34,7 +34,14 @@
#include <wctype.h>
#endif
+// FreeType includes
+#include "ft2build.h"
+#include FT_FREETYPE_H
+#include FT_GLYPH_H
+#include FT_CACHE_H
+#include FT_CACHE_MANAGER_H
// local functions
wstring ToLower(const wstring& source)
@@ -47,8 +54,12 @@
// static initializations
CustomThreadMutex FontManager::sm_mutex;
FontManager FontManager::sm_manager;
+bool FontManager::sm_init = false;
+//Option whether to preload or delay load all fonts
+static bool DELAY_LOAD_FONTS = false;
// Constructor/Desctructor
@@ -56,11 +67,7 @@
FontManager::FontManager()
- AutoMutexLocker autoLocker(sm_mutex);
- FT_Init_FreeType(&m_library); // TODO: check error code
- sm_manager.init_font_list();
@@ -68,52 +75,36 @@
- FaceMapIterator it;
- FaceMapEntryType* pEntry = NULL;
- char* pData = NULL;
- it = m_facemap.begin();
- // clean up entries
- while (it != m_facemap.end())
+ if (sm_init)
- pEntry = (FaceMapEntryType*)(*it).second;
- pData = pEntry->pData;
- free(pData);
- delete pEntry;
- ++it;
+ // free up font map entries
+ for (FontMapIterator fmi = m_fontAliases.begin(); fmi != m_fontAliases.end(); fmi++)
+ delete (*fmi).first;
+ delete (*fmi).second;
- // free up font map entries
- for (FontMapIterator fmi = m_fontAliases.begin(); fmi != m_fontAliases.end(); fmi++)
- delete (*fmi).first;
- delete (*fmi).second;
+ m_fontAliases.clear();
- m_fontAliases.clear();
+ // clean up fontlist
+ FontListIterator it_font;
+ RS_Font* font = NULL;
- // clear map
- m_facemap.clear();
+ it_font = m_fontlist.begin();
- // clean up fontlist
- FontListIterator it_font;
- RS_Font* font = NULL;
+ while (it_font != m_fontlist.end())
+ font = (RS_Font*)(*it_font);
+ delete font;
+ ++it_font;
- it_font = m_fontlist.begin();
+ // clean fontlist
+ m_fontlist.clear();
- while (it_font != m_fontlist.end())
- font = (RS_Font*)(*it_font);
- delete font;
- ++it_font;
+ // clean up the library
+ FT_Done_FreeType((FT_Library)m_library);
- // clean fontlist
- m_fontlist.clear();
- // clean up the library
- FT_Done_FreeType(m_library);
@@ -124,108 +115,67 @@
FontManager* FontManager::Instance()
- return &sm_manager;
-int FontManager::get_face(const char* filename, FT_Long index, FT_Face* face)
- int ret = 0; // our return error code
- FaceMapIterator it; // an interator
- FaceMapEntryType* pEntry = NULL; // pointer to loaded font data
- // look for face in map
- it = m_facemap.find(filename);
- if (it != m_facemap.end())
+ if (!sm_init)
- // found an entry
+ FT_Init_FreeType((FT_Library*)(&sm_manager.m_library)); // TODO: check error code
- // create a new face
- ret = FT_New_Memory_Face(m_library, (FT_Byte*)pEntry->pData, (FT_Long)pEntry->length, index, face);
- else
- // ok, we have to load it
-// ret = FT_New_Face(m_library, filename, index, face);
- pEntry = load_file(filename);
- if (pEntry)
+ if (!DELAY_LOAD_FONTS)
- // insert the entry into the map
- m_facemap.insert(FaceMapPair(filename, pEntry));
+ sm_manager.init_font_list();
- else
- face = NULL;
- ret = -1;
- return ret;
+ return &sm_manager;
-FaceMapEntryType* FontManager::load_file(const char* filename)
+//Caches the fonts/faces within a single given font file
+bool FontManager::CacheFont(wchar_t const* filename)
- int errcode = 0; // an error code
- FaceMapEntryType* pEntry = NULL; // pointer to return value
- char* pData = NULL; // pointer to loaded font file
- size_t length = 0; // length of buffer
- size_t count = 0; // length of file (obviously should be equal to above)
+ // ok, load up the face information
+ int error = 0;
+ FT_Face face = NULL;
+ FT_Long index = 0;
+ FT_Long num_faces = 0;
- FILE* pFile = fopen(filename, "rb");
- if (pFile)
+ do
- errcode = fseek(pFile, 0L, SEEK_END);
- if (!errcode)
+ string en;
+ UnicodeString::WideCharToMultiByte(filename, en);
+ error = FT_New_Face((FT_Library)m_library, en.c_str(), index, &face);
+ if (!error)
- length = (unsigned long)ftell(pFile);
+ // init num_faces if necessary
+ if (!num_faces)
+ num_faces = face->num_faces;
- errcode = fseek(pFile, 0L, SEEK_SET);
- if (!errcode)
- pData = (char*)malloc(sizeof(char) * length);
- if (pData)
- count = fread(pData, sizeof(char), length, pFile);
+ create_font(face, index, filename);
- if (ferror(pFile) == 0 && count == length)
- errcode = fclose(pFile);
+ // dispose of face
+ FT_Done_Face(face);
- if (pData)
- pEntry = new FaceMapEntryType();
- pEntry->pData = pData;
- pEntry->length = length;
+ // increment our face index
+ index++;
+ while (!error && index < num_faces);
- return pEntry;
+ return !error;
#ifdef _WIN32
-// initialize the font list
-void FontManager::init_font_list()
+// initialize the font list -- if a non-null argument is passed, only fonts
+// having the given string in their name will be cached
+void FontManager::init_font_list(const wchar_t* specificName)
- int error = 0;
// look for the windows font directory
wchar_t fontpath[MAX_PATH];
HRESULT hres = SHGetFolderPath(NULL, CSIDL_FONTS, NULL, 0, fontpath);
@@ -234,6 +184,10 @@
if (S_OK == hres)
fontdir = fontpath;
+ wstring searchString;
+ if (specificName)
+ searchString = ToLower(specificName);
// enum fonts
if (!fontdir.empty())
@@ -249,73 +203,41 @@
// do we have a file?
if (!(FindFileData.dwFileAttributes & FILE_ATTRIBUTE_DIRECTORY))
- // skip special Windows files
- if (wcscmp(FindFileData.cFileName, L"desktop.ini") != 0)
+ wstring entryName(fontdir);
+ entryName += L"\\";
+ entryName += FindFileData.cFileName;
+ //are we searching for a specific font
+ if (!searchString.empty())
- wstring entryName(fontdir);
- entryName += L"\\";
- entryName += FindFileData.cFileName;
+ wstring lowerFileName = ToLower(FindFileData.cFileName);
- // ok, load up the face information
- FT_Face face = NULL;
- FT_Long index = 0;
- FT_Long num_faces = 0;
- do
- string en;
- UnicodeString::WideCharToMultiByte(entryName.c_str(), en);
- error = FT_New_Face(m_library, en.c_str(), index, &face);
- if (!error)
- // init num_faces if necessary
- if (!num_faces)
- num_faces = face->num_faces;
- create_font(face, index, entryName.c_str());
- // dispose of face
- FT_Done_Face(face);
- // increment our face index
- index++;
- while (!error && index < num_faces);
+ if (!wcsstr(lowerFileName.c_str(), searchString.c_str()))
+ goto keepgoing;
+ CacheFont(entryName.c_str());
+keepgoing:
bOK = FindNextFile(hFile, &FindFileData);
FindClose(hFile);
- // The font matching code iterates over the font list, and the first font in the
- // list always becomes the one to beat. In the case where none of the fonts match
- // (they all have the same score), this first font ends up winning. So make sure
- // a reasonably good font, like Arial, is the first one in the list.
- wstring lowerName = L"arial"; // use lower-case
- RS_Font* font = (RS_Font*)FindFont(lowerName, false, false);
- if (font && font->m_fullname == lowerName)
- // we found Arial - move it to the front
- m_fontlist.remove(font);
- m_fontlist.push_front(font);
#else
- int error = 0;
string dirname(".");
DIR* pCurrent = opendir(dirname.c_str());
+ if (specificName)
while (pCurrent)
errno = 0;
@@ -330,36 +252,19 @@
struct stat st;
if (stat(entryName.c_str(), &st) == 0)
+ wstring en;
+ UnicodeString::MultiByteToWideChar(entryName.c_str(), en);
- do
- error = FT_New_Face(m_library, entryName.c_str(), index, &face);
- // TODO: revisit using the font manager here
-// error = m_FM->get_face(entryName.c_str(), index, &face);
- if (!error)
- if (!num_faces)
- wstring en;
- UnicodeString::MultiByteToWideChar(entryName.c_str(), en);
- create_font(face, index, en.c_str());
- index++;
+ continue;
+ CacheFont(en.c_str());
else
@@ -374,8 +279,10 @@
// create a font with the given face information
-void FontManager::create_font(FT_Face face, FT_Long index, wchar_t const* filename)
+void FontManager::create_font(void* facePtr, FT_Long index, wchar_t const* filename)
+ FT_Face face = (FT_Face)facePtr;
// do we have a valid face?
if (!face)
return;
@@ -500,6 +407,12 @@
if (entry.stylearray[index])
return entry.stylearray[index];
+ //If we are delay loading, attempt to cache the specific font
+ if (DELAY_LOAD_FONTS)
+ init_font_list(sfontname.c_str());
const wchar_t* fontname = sfontname.c_str();
// if there is an alias for the font use that instead
@@ -513,7 +426,7 @@
- wstring lowername = ToLower(fontname);
+ wstring lowername = ToLower(sfontname);
const wchar_t* buf = lowername.c_str();
int score = 0;
Modified: trunk/MgDev/Common/Renderers/FontManager.h
--- trunk/MgDev/Common/Renderers/FontManager.h 2010-09-21 17:55:08 UTC (rev 5172)
+++ trunk/MgDev/Common/Renderers/FontManager.h 2010-09-21 18:04:09 UTC (rev 5173)
@@ -1,5 +1,5 @@
@@ -22,12 +22,6 @@
#include "RS_Font.h" // for FontList
#include "CriticalSection.h"
-// FreeType includes
-#include "ft2build.h"
-#include FT_FREETYPE_H
-#include FT_GLYPH_H
-#include FT_CACHE_H
-#include FT_CACHE_MANAGER_H
#include <map>
@@ -62,11 +56,11 @@
~FontManager();
public:
- int get_face(const char* filename, FT_Long index, FT_Face* face);
- void init_font_list();
- void create_font(FT_Face face, FT_Long index, wchar_t const* filename);
+ RENDERERS_API void init_font_list(const wchar_t* specificName = NULL);
+ void create_font(void* face, long index, wchar_t const* filename);
RENDERERS_API void AddFontAlias(const wchar_t* alias, const wchar_t* asciiName);
FontList* GetFontList();
@@ -78,10 +72,10 @@
private:
FaceMapEntryType* load_file(const char* filename);
+ bool CacheFont(wchar_t const* fileName);
private:
- FT_Library m_library;
- FaceMap m_facemap;
+ void* m_library;
FontList m_fontlist;
FontMap m_fontAliases;
@@ -89,6 +83,7 @@
static CustomThreadMutex sm_mutex;
static FontManager sm_manager;
+ static bool sm_init;
#endif
More information about the mapguide-commits
